[mapguide-commits] r9560 - in trunk/MgDev: . Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Resources Common/MapGuideCommon/Services Common/Schema Doc/samples Doc/samples/ol2samples Doc/samples/ol2samples/assets Doc/samples/ol2samples/xyz Server/src/PostBuild Server/src/Services/Mapping Server/src/Services/Rendering Server/src/Services/Tile Server/src/UnitTesting UnitTest/TestData/Samples/Sheboygan UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets UnitTest/TestData/TileService Web/src/HttpHandler Web/src/localized Web/src/mapviewerjava Web/src/mapviewernet Web/src/mapviewerphp
svn_mapguide at osgeo.org
Tue Jun 25 04:20:14 PDT 2019
Author: jng
Date: 2019-06-25 04:20:14 -0700 (Tue, 25 Jun 2019)
New Revision: 9560
Added:
trunk/MgDev/Common/Schema/RuntimeMap-4.0.0.xsd
trunk/MgDev/Doc/samples/ol2samples/assets/legend_ol.js
trunk/MgDev/Doc/samples/ol2samples/hybrid/
trunk/MgDev/Doc/samples/ol2samples/xyz/index_ol.html
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml
trunk/MgDev/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf
trunk/MgDev/
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h
trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h
trunk/MgDev/Doc/samples/samples.php
trunk/MgDev/Server/src/PostBuild/PostBuild.mak
trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
trunk/MgDev/Server/src/Services/Rendering/OpRenderMetatileXYZ.cpp
trunk/MgDev/Server/src/Services/Rendering/OpRenderTileXYZ.cpp
trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp
trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
trunk/MgDev/Server/src/Services/Tile/ServerTileService.h
trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp
trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h
trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestMappingService.h
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h
trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp
trunk/MgDev/Web/src/localized/en
trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
trunk/MgDev/Web/src/mapviewernet/mapframe.aspx
trunk/MgDev/Web/src/mapviewerphp/mapframe.php
Merged revision(s) 9539-9559 from sandbox/jng/tiling_v3: Implement MapGuide RFC 173 - Tile Service Enhancements (Round 3)
Index: trunk/MgDev
--- trunk/MgDev 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev 2019-06-25 11:20:14 UTC (rev 9560)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -26,6 +26,7 ##
/sandbox/jng/simplify:8814-9141
/sandbox/jng/tiling:8174-8208
/sandbox/jng/tiling_v2:9490-9509
+/sandbox/jng/tiling_v3:9539-9559
/sandbox/jng/utfgrid:9179-9212
/sandbox/jng/v30:8212-8227
/sandbox/jng/v4:9511-9519
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -43,7 +43,8 @@
m_unpackedLayersGroups(false),
m_colorPalette(NULL), // lazy instantiation
m_watermarkUsage(Viewer),
- m_tileSetId((MgResourceIdentifier*)NULL)
+ m_tileSetId((MgResourceIdentifier*)NULL),
+ m_tilePixelRatio(1)
@@ -57,7 +58,8 @@
CHECKARGUMENTNULL(siteConnection, L"MgMap.MgMap");
@@ -216,6 +218,22 @@
m_srs = GetCoordinateSystemFromTileSet(tdef.get(), true);
+ auto tsp = tdef->GetTileStoreParameters();
+ m_tileSetProvider = tsp->GetTileProvider();
+ auto parameters = tsp->GetParameters();
+ for (auto i = 0; i < parameters->GetCount(); i++)
+ auto nvp = parameters->GetAt(i);
+ if (nvp->GetName() == MG_TILE_PROVIDER_XYZ_PARAM_RETINASCALE)
+ m_tilePixelRatio = MgUtil::StringToInt32(nvp->GetValue());
+ else if (nvp->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_TILEFORMAT)
+ m_tileFormat = nvp->GetValue();
//If tile CS is not the same as map def CS, then the bounds of the map def need to be transformed
if (m_srs != mdef->GetCoordinateSystem())
@@ -622,6 +640,22 @@
std::unique_ptr<MdfModel::TileSetDefinition> tdef(parser.DetachTileSetDefinition());
assert(tdef.get() != NULL);
MgGeometryFactory gf;
const Box2D& extent = tdef->GetExtents();
@@ -852,12 +886,6 @@
- else if (strict)
- MgStringCollection args;
- args.Add(storeParams->GetTileProvider());
- throw new MgUnsupportedTileProviderException(L"MgMap.GetFiniteDisplayScalesFromTileSet", __LINE__, __WFILE__, &args, L"", NULL);
@@ -1304,6 +1332,15 @@
//tile set definition
stream->WriteObject(m_tileSetId);
+ //tile set provider
+ stream->WriteString(m_tileSetProvider);
+ //tile format
+ stream->WriteString(m_tileFormat);
+ //tile pixel ratio
+ stream->WriteInt32(m_tilePixelRatio);
// Serialize Layers and Groups as a blob.
if (m_inSave)
@@ -1428,6 +1465,15 @@
m_tileSetId = (MgResourceIdentifier*)stream->GetObject();
+ stream->GetString(m_tileSetProvider);
+ //tile format
+ stream->GetString(m_tileFormat);
+ stream->GetInt32(m_tilePixelRatio);
//blob for layers and groups
INT32 nBytes = 0;
streamReader->GetInt32(nBytes);
@@ -1612,4 +1658,19 @@
MgResourceIdentifier* MgMap::GetTileSetDefinition()
return SAFE_ADDREF((MgResourceIdentifier*)m_tileSetId);
+STRING MgMap::GetTileSetProvider()
+ return m_tileSetProvider;
+STRING MgMap::GetTileFormat()
+ return m_tileFormat;
+INT32 MgMap::GetTilePixelRatio()
+ return m_tilePixelRatio;
\ No newline at end of file
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -506,6 +506,70 @@
/// to a Tile Set
MgResourceIdentifier* GetTileSetDefinition();
+ /// \brief
+ /// Returns the provider name of the referenced tile set definition
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// string GetTileSetProvider();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// String GetTileSetProvider();
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \since 4.0
+ /// \return
+ /// Returns the tile set provider name. Or an empty string if this map does not reference a tile set
+ STRING GetTileSetProvider();
+ /// \brief
+ /// Returns the tile pixel ratio for retina tiles. This is only
+ /// applicable for XYZ tiles.
+ /// int GetTilePixelRatio();
+ /// \since 4.0
+ /// \return
+ INT32 GetTilePixelRatio();
+ /// \brief
+ /// Returns the tile content format for the tile set definition
+ /// string GetTileFormat();
+ /// String GetTileFormat();
+ /// \since 4.0
+ /// \return
+ STRING GetTileFormat();
INTERNAL_API:
@@ -787,6 +851,9 @@
ColorStringList* m_colorPalette;
INT32 m_watermarkUsage;
+ STRING m_tileSetProvider;
+ STRING m_tileFormat;
+ INT32 m_tilePixelRatio;
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2019-06-25 11:20:14 UTC (rev 9560)
@@ -452,6 +452,7 @@
MgTileProvider_Common_Property_TileExtentOffset_LocalizedName = Tile Extent Offset
MgTileProvider_Common_Property_MetaTileFactor_LocalizedName = Meta-tiling factor
MgTileProvider_Common_Property_MetaTileLockMethod_LocalizedName = Meta-tiling lock method
+MgTileProvider_XYZ_Property_RetinaScale_LocalizedName = Scaling factor for Retina Tiles
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -234,15 +234,16 @@
INT32 z,
INT32 dpi,
CREFSTRING tileImageFormat,
- double tileExtentOffset)
+ double tileExtentOffset,
+ INT32 retinaScale)
MgCommand cmd;
- cmd.ExecuteCommand(m_connProp, // Connection
+ cmd.ExecuteCommand(m_connProp, // Connection
MgCommand::knObject, // Return type expected
MgRenderingServiceOpId::RenderTileXYZ2, // Command Code
- 8, // No of arguments
+ 9, // No of arguments
Rendering_Service, // Service Id
- BUILD_VERSION(4,0,0), // Operation version
+ BUILD_VERSION(4,0,0), // Operation version
MgCommand::knObject, map, // Argument#1
MgCommand::knString, &baseMapLayerGroupName, // Argument#2
MgCommand::knInt32, x, // Argument#3
@@ -251,6 +252,7 @@
MgCommand::knInt32, dpi, // Argument#6
MgCommand::knString, &tileImageFormat, // Argument#7
MgCommand::knDouble, tileExtentOffset, // Argument#8
+ MgCommand::knInt32, retinaScale, // Argument#9
MgCommand::knNone); // End of arguments
SetWarning(cmd.GetWarningObject());
@@ -1379,15 +1381,16 @@
INT32 dpi,
- INT32 metaTilingFactor)
+ INT32 metaTilingFactor,
MgCommand cmd;
- MgRenderingServiceOpId::RenderTileXYZ2, // Command Code
- 9, // No of arguments
+ MgRenderingServiceOpId::RenderMetatileXYZ, // Command Code
+ 10, // No of arguments
@@ -1397,6 +1400,7 @@
MgCommand::knInt32, metaTilingFactor, // Argument#9
+ MgCommand::knInt32, retinaScale, // Argument#10
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -263,6 +263,8 @@
/// Specifies the ratio by which the tile to be rendered should be "buffered out". The tile will be rendered at the specified width
/// multiplied by the given ration, which will be cropped back to the original requested size after rendering. This is to improve
/// label placement on rendered tiles by giving extra "breathing space" to label placement algorithms.
+ /// \param retinaScale
+ /// The scaling factor to apply for "retina" tiles
/// \return
/// A byte reader containing the rendered tile image.
@@ -276,7 +278,8 @@
INT32 z,
INT32 dpi,
- double tileExtentOffset);
+ INT32 retinaScale);
/// \brief
@@ -1206,6 +1209,9 @@
/// The meta-tiling factor. If less than or equal to 1, no meta-tiling is done and the returned meta-tile can be extracted
/// as the orignally requested tile image. If greater than 1, a tile that is m times bigger than the requested tile is rendered
/// (where m is the specified tiling factor) and the raw image frame buffer of this meta-tile is returned instead.
+ /// Input
/// \return
/// A meta-tile with sufficient information for the consumer to properly sub-divide this back into sub-tiles of the
@@ -1221,7 +1227,8 @@
INT32 dpi,
- INT32 metaTilingFactor);
/// \brief
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -49,6 +49,7 @@
static const int QueryFeatureProperties3 = 0x1111E915;
static const int RenderMetatile = 0x1111E916;
static const int RenderTileFromMetaTile = 0x1111E917;
+ static const int RenderMetatileXYZ = 0x1111E918;
/// \endcond
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -278,6 +278,8 @@
/// \return
@@ -291,7 +293,8 @@
INT32 z,
INT32 dpi,
- double tileExtentOffset) = 0;
+ INT32 retinaScale) = 0;
/// \brief
@@ -1221,6 +1224,9 @@
+ /// Input
/// \return
@@ -1236,7 +1242,8 @@
INT32 dpi,
- INT32 metaTilingFactor) = 0;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -69,6 +69,7 @@
#define MG_TILE_PROVIDER_COMMON_PARAM_TILEEXTENTOFFSET L"TileExtentOffset"
#define MG_TILE_PROVIDER_COMMON_PARAM_METATILEFACTOR L"MetaTileFactor"
#define MG_TILE_PROVIDER_COMMON_PARAM_METATILELOCKMETHOD L"MetaTileLockMethod"
+#define MG_TILE_PROVIDER_XYZ_PARAM_RETINASCALE L"RetinaScale"
#define MG_METATILE_MAX_FACTOR 8
Copied: trunk/MgDev/Common/Schema/RuntimeMap-4.0.0.xsd (from rev 9559, sandbox/jng/tiling_v3/Common/Schema/RuntimeMap-4.0.0.xsd)
--- trunk/MgDev/Common/Schema/RuntimeMap-4.0.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/RuntimeMap-4.0.0.xsd 2019-06-25 11:20:14 UTC (rev 9560)
@@ -0,0 +1,324 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:element name="RuntimeMap">
+ <xs:annotation>
+ <xs:documentation>Describes information about a Runtime Map, so that client applications can interact with it</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="SiteVersion" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The MapGuide Site Version</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Name" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the runtime map. This is the value required for any mapagent operation that require a MAPNAME parameter</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MapDefinition" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The resource id of the Map Definition from which this runtime map was created from</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TileSetDefinition" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The resource id of the Tile Set Definition that this Map Definition is linked from. If this Map Definition does not link to a tile set, this element is omitted</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TileSetProvider" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The provider for the Tile Set Definition</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TileFormat" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The tile content format</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TilePixelRatio" type="xs:integer" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The tile pixel ratio for retina tiles</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TileWidth" type="xs:integer" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The tile width as defined by the settings in the Tile Set Definition. If this Map Definition does not link to a tile set, this element is omitted</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TileHeight" type="xs:integer" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The tile height as defined by the settings in the Tile Set Definition. If this Map Definition does not link to a tile set, this element is omitted</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="BackgroundColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The map's background color in ARGB hex string format</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DisplayDpi" type="xs:integer">
+ <xs:annotation>
+ <xs:documentation>The number of dots per inch of the map display</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="IconMimeType" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The mime type of all inline icons</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CoordinateSystem" type="CoordinateSystemType" />
+ <xs:element name="Extents" type="Envelope" />
+ <xs:element name="Group" type="RuntimeMapGroup" minOccurs="0" maxOccurs="unbounded" />
+ <xs:element name="Layer" type="RuntimeMapLayer" minOccurs="0" maxOccurs="unbounded" />
+ <xs:element name="FiniteDisplayScale" type="xs:double" minOccurs="0" maxOccurs="unbounded" />
+ <xs:attribute name="version" type="xs:string" use="required" fixed="3.0.0"/>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="CoordinateSystemType">
+ <xs:annotation>
+ <xs:documentation>Describes the coordinate system of the runtime map</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Wkt" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The WKT string of the coordinate system</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MentorCode" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The CS-Map code of the coordinate system</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="EpsgCode" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The EPSG code of the coordinate system</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MetersPerUnit" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The meters-per-unit value of the coordinate system</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="RuntimeMapGroup">
+ <xs:annotation>
+ <xs:documentation>Describes a group of Runtime Map Layers</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The name of the group</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Type" type="xs:integer">
+ <xs:annotation>
+ <xs:documentation>The type of this group. Can be tiled or dynamic. Uses the value of MgLayerGroupType</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LegendLabel" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The group's legend label</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ObjectId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The group's unique id. Use this value for turning on/off this group in a GETDYNAMICMAPOVERLAYIMAGE request</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ParentId" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The group's parent group id. Use this value for determining parent-child relationships when building a layer/group hierarchy</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DisplayInLegend" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether this group should be displayed in the legend</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ExpandInLegend" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether this group should be initially expanded in the legend</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Visible" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether this group is potentially visible. Note that this may be true even though the group is not visible. This will occur if one of the groups this group is organized within is not visible.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ActuallyVisible" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates the actual visibility of the group. The visibility depends on the visible property of the group, and the visible property of each group this group is organized within.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="RuntimeMapLayer">
+ <xs:annotation>
+ <xs:documentation>Describes a runtime instance of a Layer Definition</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The name of the layer</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The type of this layer. Can be tiled or dynamic. Uses the value of MgLayerType</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The layer's legend label</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The layer's unique id. Use this value for turning on/off this layer in a GETDYNAMICMAPOVERLAYIMAGE request</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The layer's parent group id. Use this value for determining parent-child relationships when building a layer/group hierarchy</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Indicates whether this layer should be displayed in the legend</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Indicates whether this layer should be initially expanded (if layer is themed) in the legend</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Indicates whether this layer is potentially visible. Note that this may be true even though the layer is not visible. This will occur if the visible flag of one of the groups this layer is organized within is not visible or when the current viewScale property of the map is outside the scale ranges defined for this layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Indicates the actual visibility of the layer. The visibility depends on the visible property of the group, and the visible property of each group this group is organized within.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerDefinition" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The Layer Definition from which this runtime layer was created from</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FeatureSource" type="FeatureSourceInfo" minOccurs="0" />
+ <xs:element name="ScaleRange" type="ScaleRangeInfo" minOccurs="0" maxOccurs="unbounded" />
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="FeatureSourceInfo">
+ <xs:annotation>
+ <xs:documentation>Describe the Feature Source information for a runtime layer</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The Feature Source resource id</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ClassName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The qualified FDO class name</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Geometry" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the default Geometry property</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ScaleRangeInfo">
+ <xs:annotation>
+ <xs:documentation>Describes a scale range of the runtime layer</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="MinScale" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The minimum scale of this scale range</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaxScale" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The maximum scale of this scale range</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FeatureStyle" type="FeatureStyleInfo" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The feature style for a given geometry type. This is empty for drawing and raster layers</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="FeatureStyleInfo">
+ <xs:annotation>
+ <xs:documentation>Defines the style rules for a given geometry type</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The geometry type that this rule is applicable to (1=point, 2=line, 3=area, 4=composite)</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Rule" type="RuleInfo" minOccurs="0" maxOccurs="unbounded" />
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="RuleInfo">
+ <xs:annotation>
+ <xs:documentation>Describes a stylization rule in a layer's scale range</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The legend label for this rule</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Filter" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The FDO filter that features must match in order for them to be stylized using this particular rule</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Icon" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Defines the icon for this rule. The icon's image content is in base64 format</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Envelope">
+ <xs:annotation>
+ <xs:documentation>Specifies an envelope (a rectangle) using two corner points.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LowerLeftCoordinate">
+ <xs:annotation>
+ <xs:documentation>Specifies the lower left corner of the envelope.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="X" type="xs:double"/>
+ <xs:element name="Y" type="xs:double"/>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="UpperRightCoordinate">
+ <xs:annotation>
+ <xs:documentation>Specifies the upper right corner of the envelope.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Copied: trunk/MgDev/Doc/samples/ol2samples/assets/legend_ol.js (from rev 9559, sandbox/jng/tiling_v3/Doc/samples/ol2samples/assets/legend_ol.js)
--- trunk/MgDev/Doc/samples/ol2samples/assets/legend_ol.js (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/legend_ol.js 2019-06-25 11:20:14 UTC (rev 9560)
@@ -0,0 +1,241 @@
+//A simple legend to toggle MapGuide Layer visbility for a OpenLayers.Layer.MapGuide instance
+//NOTE: Only tested with the Sheboygan dataset. Probably doesn't handle all corner cases that can be possible with a MapGuide Map Definition
+//NOTE: This uses the "clean" mapguide-rest JSON APIs which does not blindly array-ify every JSON property
+//Requires: OpenLayers, jQuery
+function Legend(options)
+ var legendSelector = options.legendSelector;
+ this.map = options.map;
+ this.mgLayer = options.mgLayerOL;
+ this.mgTiledLayers = options.mgTiledLayers || {};
+ this.debug = false;
+ var rtMapInfo = options.runtimeMap;
+ this.dpi = rtMapInfo.RuntimeMap.DisplayDpi;
+ this.inPerUnit = rtMapInfo.RuntimeMap.CoordinateSystem.MetersPerUnit * 39.37;
+ this.iconMimeType = rtMapInfo.RuntimeMap.IconMimeType;
+ this.stdIconRoot = options.stdIconRoot || "../../stdicons";
+ this.rootEl = $(legendSelector);
+ var _self = this;
+ this.map.getView().on("change:resolution", this.update, this);
+ this.updateLayersAndGroups(rtMapInfo);
+ //$("input.group-checkbox", this.rootEl).change(function() {
+ this.rootEl.on("change", "input.group-checkbox", function() {
+ var el = $(this);
+ var bShow = el.is(":checked");
+ if (el.attr("data-is-tiled") == "true") {
+ var name = el.attr("data-group-name");
+ if (typeof(_self.mgTiledLayers[name]) != 'undefined') {
+ _self.mgTiledLayers[name].setVisible(bShow);
+ } else {
+ var objId = el.val();
+ _self.showGroup(objId, bShow);
+ //$("input.layer-checkbox", this.rootEl).change(function() {
+ this.rootEl.on("change", "input.layer-checkbox", function() {
+ var el = $(this);
+ _self.showLayer(objId, bShow);
+ this.req = {
+ showgroups: null,
+ showlayers: null,
+ hidegroups: null,
+ hidelayers: null
+Legend.prototype.updateLayersAndGroups = function(rtMapInfo) {
+ this.mapInfo = rtMapInfo;
+ var groupElMap = {};
+ this.rootEl.empty();
+ if (rtMapInfo.RuntimeMap.Group) {
+ var remainingGroups = {};
+ //1st pass, un-parented groups
+ for (var i = 0; i < rtMapInfo.RuntimeMap.Group.length; i++) {
+ var group = rtMapInfo.RuntimeMap.Group[i];
+ if (group.ParentId) {
+ remainingGroups[group.ObjectId] = group;
+ continue;
+ var el = this.createGroupElement(group);
+ groupElMap[group.ObjectId] = el;
+ this.rootEl.append(el);
+ //2nd pass, parented groups
+ var itemCount = 0;
+ for (var objId in remainingGroups) {
+ itemCount++;
+ //Whittle down
+ while(itemCount > 0) {
+ var removeIds = [];
+ var group = remainingGroups[objId];
+ //Do we have a parent?
+ if (typeof(groupElMap[group.ParentId]) != 'undefined') {
+ groupElMap[group.ParentId].find("ul.groupChildren").append(el);
+ removeIds.push(group.ObjectId);
+ for (var i = 0; i < removeIds.length; i++) {
+ delete remainingGroups[removeIds[i]];
+ itemCount = 0;
+ itemCount++;
+ if (rtMapInfo.RuntimeMap.Layer) {
+ for (var i = 0; i < rtMapInfo.RuntimeMap.Layer.length; i++) {
+ var layer = rtMapInfo.RuntimeMap.Layer[i];
+ var els = this.createLayerElements(layer);
+ for (var j = 0; j < els.length; j++) {
+ if (layer.ParentId) {
+ groupElMap[layer.ParentId].find("ul.groupChildren").append(els[j]);
+ } else {
+ this.rootEl.append(els[j]);
+Legend.prototype.resetRequest = function() {
+ this.req.showgroups = null;
+ this.req.showlayers = null;
+ this.req.hidegroups = null;
+ this.req.hidelayers = null;
+Legend.prototype.refreshLayer = function() {
+ this.mgLayer.getSource().updateParams({ seq: (new Date()).getTime() });
+Legend.prototype.updateMgLayer_ = function() {
+ //this.mgLayer.mergeNewParams(this.req);
+ this.mgLayer.getSource().updateParams(this.req);
+Legend.prototype.showGroup = function(groupId, bShow) {
+ this.resetRequest();
+ if (bShow)
+ this.req.showgroups = groupId;
+ else
+ this.req.hidegroups = groupId;
+ this.updateMgLayer_();
+Legend.prototype.showLayer = function(layerId, bShow) {
+ if (bShow)
+ this.req.showlayers = layerId;
+ else
+ this.req.hidelayers = layerId;
+Legend.prototype.getScale = function() {
+ return this.map.getView().getResolution() * this.dpi * this.inPerUnit;
+Legend.prototype.update = function() {
+ var scale = this.getScale();
+ var nodes = $("li.layer-node");
+ nodes.each(function(i, e) {
+ var el = $(e);
+ var min = el.attr("data-layer-min-scale");
+ var max = el.attr("data-layer-max-scale");
+ if ((scale >= min && scale < max) || (scale >= min && max==="infinity")) {
+ if (el.is(":hidden"))
+ el.show();
+ } else {
+ if (el.is(":visible"))
+ el.hide();
+Legend.prototype.createGroupElement = function(group) {
+ return $("<li><input type='checkbox' class='group-checkbox' data-is-tiled='" + (group.Type == 2 || group.Type == 3) + "' data-group-name='" + group.Name + "' value='" + group.ObjectId + "' " + ((group.Visible) ? "checked='checked'" : "") + " /><img src='" + this.stdIconRoot + "/lc_group.gif' /> " + group.LegendLabel + "<ul class='groupChildren'></ul></li>");
+Legend.prototype.getIconUri = function(iconBase64) {
+ return "data:" + this.iconMimeType + ";base64," + iconBase64;
+Legend.prototype.createLayerElements = function(layer) {
+ var icon = "legend-layer.png";
+ var label = layer.LegendLabel ? layer.LegendLabel : "";
+ var text = label;
+ var childHtml = "";
+ //This is using the first scale range and the first geometry type. To do this proper you'd find the matching scale range
+ //based on the current map's view scale. Then dynamically, toggle item visibility when the map scale
+ //changes
+ var els = [];
+ if (layer.ScaleRange) {
+ for (var i = 0; i < layer.ScaleRange.length; i++) {
+ var scaleRange = layer.ScaleRange[i];
+ if (scaleRange.FeatureStyle) {
+ if (this.debug)
+ text = label + " (" + scaleRange.MinScale + " - " + scaleRange.MaxScale + ")";
+ var fts = scaleRange.FeatureStyle[0];
+ var ruleCount = fts.Rule.length;
+ if (ruleCount > 1) {
+ icon = this.stdIconRoot + "/lc_theme.gif";
+ childHtml = "<ul>";
+ //Test compression
+ var bCompressed = false;
+ if (ruleCount > 3) {
+ bCompressed = !(fts.Rule[1].Icon);
+ if (bCompressed) {
+ childHtml += "<li><img src='" + this.getIconUri(fts.Rule.Icon) + "' /> " + (fts.Rule.LegendLabel ? fts.Rule.LegendLabel : "") + "</li>";
+ childHtml += "<li>... (" + (ruleCount - 2) + " other theme rules)</li>";
+ childHtml += "<li><img src='" + this.getIconUri(fts.Rule[ruleCount-1].Icon) + "' /> " + (fts.Rule[ruleCount-1].LegendLabel ? fts.Rule[ruleCount-1].LegendLabel : "") + "</li>";
+ } else {
+ for (var i = 0; i < ruleCount; i++) {
+ var rule = fts.Rule[i];
+ childHtml += "<li><img src='" + this.getIconUri(rule.Icon) + "' /> " + (rule.LegendLabel ? rule.LegendLabel : "") + "</li>";
+ childHtml += "</ul>";
+ } else {
+ icon = this.getIconUri(fts.Rule[0].Icon);
+ var chkBoxHtml = "";
+ if (layer.Type == 1) //Dynamic
+ chkBoxHtml = "<input type='checkbox' class='layer-checkbox' value='" + layer.ObjectId + "' " + ((layer.Visible == true) ? "checked='checked'" : "") + " />";
+ els.push($("<li class='layer-node' data-layer-name='" + layer.Name + "' data-layer-selectable='" + layer.Selectable + "' data-layer-min-scale='" + scaleRange.MinScale + "' data-layer-max-scale='" + scaleRange.MaxScale + "'>" + chkBoxHtml + "<img src='" + icon + "' /> " + text + childHtml + "</li>"));
+ return els;
+Legend.prototype.getSelectedLayerNames = function() {
+ var names = [];
+ $("li.layer-node:visible").each(function(i, e) {
+ var el = $(e);
+ if (el.data("layer-selectable") == true)
+ names.push(el.data("layer-name"));
+ return names;
Copied: trunk/MgDev/Doc/samples/ol2samples/xyz/index_ol.html (from rev 9559, sandbox/jng/tiling_v3/Doc/samples/ol2samples/xyz/index_ol.html)
--- trunk/MgDev/Doc/samples/ol2samples/xyz/index_ol.html (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/xyz/index_ol.html 2019-06-25 11:20:14 UTC (rev 9560)
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ <title>Sheboygan map as XYZ</title>
+ <link rel="stylesheet" href="../assets/ol.css" />
+ <style type="text/css">
+ #error { color: red; }
+ #wrap { width: 900; }
+ #map { width: 400; height: 300; float: left; border: 1px solid black; }
+ #main { margin-top: 50px; padding-top: 20px; }
+ </style>
+ <script type="text/javascript" src="../assets/ol-debug.js"></script>
+ <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+ <script type="text/javascript">
+ //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/xyz/index_ol.html
+ var mapAgentUrl = "../../mapagent/mapagent.fcgi";
+ $(document).ready(function() {
+ //NOTE: Your map definition can be in any coordinate system as long as it it transformable to LL84
+ //But the ol3 tile layer must remain as EPSG:3857
+ var map = new ol.Map({
+ layers: [
+ new ol.layer.Tile({
+ source: new ol.source.OSM({
+ attributions: [
+ new ol.Attribution({
+ html: 'Tiles © <a href="http://www.openstreetmap.org/">' +
+ 'OpenStreetMap</a>'
+ ol.source.OSM.ATTRIBUTION
+ url: 'http://{a-c}.tile.openstreetmap.org/{z}/{x}/{y}.png'
+ source: new ol.source.XYZ({
+ url: mapAgentUrl + "?OPERATION=GETTILEIMAGE&VERSION=1.2.0&CLIENTAGENT=OpenLayers&USERNAME=Anonymous&MAPDEFINITION=Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition&BASEMAPLAYERGROUPNAME=Base+Layer+Group&TILECOL={y}&TILEROW={x}&SCALEINDEX={z}"
+ renderer: 'canvas',
+ target: document.getElementById('map'),
+ view: new ol.View({
+ center: ol.proj.transform([-87.7302542509315, 43.744459064634], 'EPSG:4326', 'EPSG:3857'),
+ minZoom: 10,
+ maxZoom: 19,
+ zoom: 12
+ </script>
+ </head>
+ <body>
+ <div id="main">
+ <div class="container">
+ <div class="alert alert-info">
+ <p>This example demonstrates a Map Definition being consumed as a <strong>XYZ layer</strong> via the MapGuide REST API with <a href="http://openlayers.org/">OpenLayers 3</a>.</p>
+ <p>An OpenStreetMap layer is included as a backdrop for context</p>
+ <strong>For maximum visual fidelity, your Map Definition should be in WGS84.PseudoMercator</strong>
+ <p>Sample not loading? <a href="../data/load.php">Check that the required resources have been loaded</a></p>
+ </div>
+ <div id="error">
+ </div>
+ <div id="wrap">
+ <div id="map">
+ </div>
+ </div>
+ </div>
+ </div>
+ </body>
+</html>
Modified: trunk/MgDev/Doc/samples/samples.php
--- trunk/MgDev/Doc/samples/samples.php 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Doc/samples/samples.php 2019-06-25 11:20:14 UTC (rev 9560)
@@ -123,6 +123,8 @@
</ul>
<p class="sample-header">MapGuide with <a href="http://www.openlayers.org">OpenLayers</a></p>
<ul>
+ <li><a href="ol2samples/hybrid/index.html">Open any map or tile set</a></li>
+ <li><a href="ol2samples/xyz/index_ol.html">Sheboygan map as XYZ layer</a></li>
<li><a href="ol2samples/utfgrid/index.html">Sheboygan map as XYZ layer with UTFGrid interaction tiles</a></li>
</ul>
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2019-06-25 11:20:14 UTC (rev 9560)
@@ -170,6 +170,7 @@
..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd \
..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd \
..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
+ ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf \
..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
..\..\bin\UnitTestFiles\UT_Parcels.fs \
..\..\bin\UnitTestFiles\UT_Parcels.ldf \
@@ -450,6 +451,7 @@
@@ -730,6 +732,7 @@
@@ -1010,6 +1013,7 @@
@@ -1163,6 +1167,7 @@
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd del /F ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd del /F ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
+ if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
@@ -1311,6 +1316,7 @@
@@ -1459,6 +1465,7 @@
@@ -1605,6 +1612,7 @@
@@ -1878,6 +1886,7 @@
@@ -2151,6 +2160,7 @@
@@ -2424,6 +2434,7 @@
@@ -2697,6 +2708,7 @@
@@ -2843,6 +2855,7 @@
@@ -2984,6 +2997,7 @@
@@ -3125,6 +3139,7 @@
@@ -3264,6 +3279,7 @@
@@ -3415,6 +3431,7 @@
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
+"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" :
@@ -3698,6 +3715,10 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf : "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf"
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" ..\..\bin\UnitTestFiles\
Modified: trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -1249,8 +1249,11 @@
std::string xml = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n"; // NOXLATE
if (schemaVersion == MG_API_VERSION(2, 6, 0))
xml.append("<RuntimeMap xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"RuntimeMap-2.6.0.xsd\">\n");
+ else if (schemaVersion == MG_API_VERSION(3, 0, 0))
+ xml.append("<RuntimeMap xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"RuntimeMap-3.0.0.xsd\" version=\"3.0.0\">\n");
else
- xml.append("<RuntimeMap xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"RuntimeMap-3.0.0.xsd\" version=\"3.0.0\">\n");
+ xml.append("<RuntimeMap xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"RuntimeMap-4.0.0.xsd\" version=\"4.0.0\">\n");
// ------------------------------ Site Version ----------------------------------//
xml.append("<SiteVersion>");
MgServerManager* serverMgr = MgServerManager::GetInstance();
@@ -1265,12 +1268,25 @@
xml.append(MgUtil::WideCharToMultiByte(targetMapName));
xml.append("</Name>\n");
// ------------------------------ Map Definition ID --------------------------------- //
- xml.append("<MapDefinition>");
- xml.append(MgUtil::WideCharToMultiByte(mapDefinition->ToString()));
- xml.append("</MapDefinition>\n");
- //Write tile set definition if requesting a v3.0.0 response
- if (NULL != (MgResourceIdentifier*)tileSetDefinition && schemaVersion == MG_API_VERSION(3, 0, 0))
+ if (schemaVersion >= MG_API_VERSION(4, 0, 0))
+ //Map Definition may be null under this version
+ if (NULL != mapDefinition.p)
+ xml.append("<MapDefinition>");
+ xml.append(MgUtil::WideCharToMultiByte(mapDefinition->ToString()));
+ xml.append("</MapDefinition>\n");
+ else
+ //Write tile set definition if requesting a v3.0.0 response or higher
+ if (NULL != (MgResourceIdentifier*)tileSetDefinition && schemaVersion >= MG_API_VERSION(3, 0, 0))
if (m_svcTile == NULL)
InitializeTileService();
@@ -1283,6 +1299,23 @@
xml.append("<TileSetDefinition>");
xml.append(MgUtil::WideCharToMultiByte(tileSetDefinition->ToString()));
xml.append("</TileSetDefinition>\n");
+ // ------------------------------ Tile Set Provider --------------------------------- //
+ if (schemaVersion == MG_API_VERSION(4, 0, 0))
+ xml.append("<TileSetProvider>");
+ xml.append(MgUtil::WideCharToMultiByte(map->GetTileSetProvider()));
+ xml.append("</TileSetProvider>\n");
+ xml.append("<TileFormat>");
+ xml.append(MgUtil::WideCharToMultiByte(map->GetTileFormat()));
+ xml.append("</TileFormat>\n");
+ xml.append("<TilePixelRatio>");
+ std::string sPR;
+ MgUtil::Int32ToString(map->GetTilePixelRatio(), sPR);
+ xml.append(sPR);
+ xml.append("</TilePixelRatio>");
// ------------------------------ Tile Width ---------------------------------- //
xml.append("<TileWidth>");
xml.append(sWidth);
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderMetatileXYZ.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderMetatileXYZ.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderMetatileXYZ.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -38,7 +38,7 @@
ACE_ASSERT(m_stream != NULL);
- if (8 == m_packet.m_NumArguments)
+ if (10 == m_packet.m_NumArguments)
Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
Ptr<MgResourceIdentifier> resource = map->GetResourceId();
@@ -68,6 +68,9 @@
INT32 metaTilingFactor = 0;
m_stream->GetInt32(metaTilingFactor);
+ INT32 retinaScale = 1;
+ m_stream->GetInt32(retinaScale);
BeginExecution();
MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
@@ -88,11 +91,13 @@
MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(tileExtentOffset);
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_INT32(metaTilingFactor);
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(retinaScale);
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
Validate();
- Ptr<MgMetatile> metaTile = m_service->RenderMetatileXYZ(map, baseMapLayerGroupName, x, y, z, tileDpi, tileImageFormat, tileExtentOffset, metaTilingFactor);
+ Ptr<MgMetatile> metaTile = m_service->RenderMetatileXYZ(map, baseMapLayerGroupName, x, y, z, tileDpi, tileImageFormat, tileExtentOffset, metaTilingFactor, retinaScale);
EndExecution(metaTile);
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderTileXYZ.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderTileXYZ.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderTileXYZ.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -146,7 +146,7 @@
EndExecution(byteReader);
- else if (8 == m_packet.m_NumArguments)
+ else if (9 == m_packet.m_NumArguments)
@@ -173,6 +173,9 @@
double tileExtentOffset = 0.0;
m_stream->GetDouble(tileExtentOffset);
BeginExecution();
@@ -191,11 +194,13 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(tileImageFormat.c_str());
Validate();
- Ptr<MgByteReader> byteReader = m_service->RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, tileDpi, tileImageFormat, tileExtentOffset);
+ Ptr<MgByteReader> byteReader = m_service->RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, tileDpi, tileImageFormat, tileExtentOffset, retinaScale);
Modified: trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp
--- trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -101,6 +101,7 @@
switch (VERSION_NO_PHASE(operationVersion))
case VERSION_SUPPORTED(3,0):
+ case VERSION_SUPPORTED(4,0):
handler.reset(new MgOpRenderTileXYZ());
break;
default:
@@ -119,6 +120,17 @@
L"MgRenderingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
break;
+ case MgRenderingServiceOpId::RenderMetatileXYZ:
+ switch (VERSION_NO_PHASE(operationVersion))
+ handler.reset(new MgOpRenderMetatileXYZ());
+ break;
+ default:
+ throw new MgInvalidOperationVersionException(
+ L"MgRenderingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
+ break;
case MgRenderingServiceOpId::RenderTileFromMetaTile:
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -268,7 +268,7 @@
MG_TRY()
- ret = RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, dpi, tileImageFormat, tileExtentOffset);
+ ret = RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, dpi, tileImageFormat, tileExtentOffset, 1 /* retinaScale */);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTileXYZ")
@@ -2233,7 +2233,8 @@
INT32 z,
INT32 dpi,
Ptr<MgByteReader> ret;
@@ -2240,10 +2241,10 @@
MG_TRY()
- Ptr<MgMetatile> metaTile = RenderMetatileXYZ(map, baseMapLayerGroupName, x, y, z, dpi, tileImageFormat, tileExtentOffset, metaTilingFactor);
+ Ptr<MgMetatile> metaTile = RenderMetatileXYZ(map, baseMapLayerGroupName, x, y, z, dpi, tileImageFormat, tileExtentOffset, metaTilingFactor, retinaScale);
- _ASSERT(metaTile->GetRequestedWidth() == XYZ_TILE_WIDTH);
- _ASSERT(metaTile->GetRequestedHeight() == XYZ_TILE_HEIGHT);
+ _ASSERT(metaTile->GetRequestedWidth() == (XYZ_TILE_WIDTH * std::max(retinaScale, 1)));
+ _ASSERT(metaTile->GetRequestedHeight() == (XYZ_TILE_HEIGHT * std::max(retinaScale, 1)));
_ASSERT(metaTile->GetMetaTilingFactor() <= 1);
ret = metaTile->GetImage();
@@ -2375,7 +2376,8 @@
INT32 dpi,
Ptr<MgMetatile> ret;
@@ -2423,8 +2425,11 @@
StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
bgColor.alpha() = 0;
- INT32 width = XYZ_TILE_WIDTH * std::max(metaTilingFactor, 1);
- INT32 height = XYZ_TILE_HEIGHT * std::max(metaTilingFactor, 1);
+ INT32 xyzWidth = (XYZ_TILE_WIDTH * std::max(1, retinaScale));
+ INT32 xyzHeight = (XYZ_TILE_HEIGHT * std::max(1, retinaScale));
+ INT32 width = xyzWidth * std::max(metaTilingFactor, 1);
+ INT32 height = xyzHeight * std::max(metaTilingFactor, 1);
INT32 drawWidth = width;
INT32 drawHeight = height;
double scale = 0.0;
@@ -2462,7 +2467,7 @@
tile = RenderMapInternal(map, NULL, roLayers, dr.get(), drawWidth, drawHeight, drawWidth, drawHeight, format, scale, extent, true, true, false, NULL);
else
tile = RenderMapInternal(map, NULL, roLayers, dr.get(), drawWidth, drawHeight, width, height, format, scale, extent, true, true, false, NULL);
- ret = new MgMetatile(tile, drawWidth, drawHeight, XYZ_TILE_WIDTH, XYZ_TILE_HEIGHT, tileImageFormat, metaTilingFactor);
+ ret = new MgMetatile(tile, drawWidth, drawHeight, xyzWidth, xyzHeight, tileImageFormat, metaTilingFactor);
// restore the base group's visibility
baseGroup->SetVisible(groupVisible);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -90,7 +90,8 @@
INT32 z,
INT32 dpi,
virtual MgByteReader* RenderTileUTFGrid(MgMap* map,
CREFSTRING baseMapLayerGroupName,
@@ -284,7 +285,8 @@
INT32 dpi,
virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, INT32 subTileX, INT32 subTileY);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -24,6 +24,7 @@
#include "OpRenderMap.cpp"
#include "OpRenderMapLegend.cpp"
#include "OpRenderMetatile.cpp"
+#include "OpRenderMetatileXYZ.cpp"
#include "OpRenderTileFromMetatile.cpp"
#include "OpRenderTile.cpp"
#include "OpRenderTileXYZ.cpp"
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -147,6 +147,93 @@
return ret;
+void MgServerTileService::WriteCommonTileProviderProperties(std::string& xml)
+ //Property: TilePath
+ xml.append("<ConnectionProperty Enumerable=\"false\" Protected=\"false\" Required=\"true\">\n");
+ xml.append("<Name>");
+ std::string mbTilePath;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_TILEPATH, mbTilePath);
+ xml.append(mbTilePath);
+ xml.append("</Name>\n");
+ xml.append("<LocalizedName>");
+ std::string mbLocName;
+ STRING wLocName = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_TilePath_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocName, mbLocName);
+ xml.append(mbLocName);
+ xml.append("</LocalizedName>\n");
+ xml.append("<DefaultValue>");
+ std::string mbDefaultTag;
+ MgUtil::WideCharToMultiByte(MgResourceTag::TileCachePath, mbDefaultTag);
+ xml.append(mbDefaultTag);
+ xml.append("</DefaultValue>\n");
+ xml.append("</ConnectionProperty>\n");
+ //Property: RenderOnly
+ xml.append("<ConnectionProperty Enumerable=\"false\" Protected=\"false\" Required=\"false\">\n");
+ std::string mbRenderOnly;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_RENDERONLY, mbRenderOnly);
+ xml.append(mbRenderOnly);
+ std::string mbLocRenderOnly;
+ STRING wLocRenderOnly = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_RenderOnly_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocRenderOnly, mbLocRenderOnly);
+ xml.append(mbLocRenderOnly);
+ xml.append("<DefaultValue>false</DefaultValue>\n");
+ //Property: TileExtentOffset
+ std::string mbTileExtentOffset;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_TILEEXTENTOFFSET, mbTileExtentOffset);
+ xml.append(mbTileExtentOffset);
+ std::string mbLocTileExtentOffset;
+ STRING wLocTileExtentOffset = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_TileExtentOffset_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocTileExtentOffset, mbLocTileExtentOffset);
+ xml.append(mbLocTileExtentOffset);
+ xml.append("<DefaultValue></DefaultValue>\n");
+ //Property: MetaTileFactor
+ std::string mbMetaTileFactor;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_METATILEFACTOR, mbMetaTileFactor);
+ xml.append(mbMetaTileFactor);
+ std::string mbLocMetaTileFactor;
+ STRING wLocMetaTileFactor = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_MetaTileFactor_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocMetaTileFactor, mbLocMetaTileFactor);
+ xml.append(mbLocMetaTileFactor);
+ //Property: MetaTileLockMethod
+ std::string mbMetaTileLockMethod;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_METATILELOCKMETHOD, mbMetaTileLockMethod);
+ xml.append(mbMetaTileLockMethod);
+ std::string mbLocMetaTileLockMethod;
+ STRING wLocMetaTileLockMethod = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_MetaTileLockMethod_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocMetaTileLockMethod, mbLocMetaTileLockMethod);
+ xml.append(mbLocMetaTileLockMethod);
MgByteReader* MgServerTileService::GetTileProviders()
@@ -180,27 +267,7 @@
xml.append(mbDescription);
xml.append("</Description>\n");
xml.append("<ConnectionProperties>\n");
- //Property: TilePath
- xml.append("<ConnectionProperty Enumerable=\"false\" Protected=\"false\" Required=\"true\">\n");
- xml.append("<Name>");
- std::string mbTilePath;
- MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_TILEPATH, mbTilePath);
- xml.append(mbTilePath);
- xml.append("</Name>\n");
- xml.append("<LocalizedName>");
- std::string mbLocName;
- STRING wLocName = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_TilePath_LocalizedName");
- MgUtil::WideCharToMultiByte(wLocName, mbLocName);
- xml.append(mbLocName);
- xml.append("</LocalizedName>\n");
- xml.append("<DefaultValue>");
- std::string mbDefaultTag;
- MgUtil::WideCharToMultiByte(MgResourceTag::TileCachePath, mbDefaultTag);
- xml.append(mbDefaultTag);
- xml.append("</DefaultValue>\n");
- xml.append("</ConnectionProperty>\n");
//Property: TileWidth
@@ -263,22 +330,6 @@
- //Property: RenderOnly
- xml.append("<ConnectionProperty Enumerable=\"false\" Protected=\"false\" Required=\"false\">\n");
- std::string mbRenderOnly;
- MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_RENDERONLY, mbRenderOnly);
- xml.append(mbRenderOnly);
- std::string mbLocRenderOnly;
- STRING wLocRenderOnly = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_RenderOnly_LocalizedName");
- MgUtil::WideCharToMultiByte(wLocRenderOnly, mbLocRenderOnly);
- xml.append(mbLocRenderOnly);
- xml.append("<DefaultValue>false</DefaultValue>\n");
//Property: CoordinateSystem
@@ -311,54 +362,8 @@
- //Property: TileExtentOffset
- std::string mbTileExtentOffset;
- MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_TILEEXTENTOFFSET, mbTileExtentOffset);
- xml.append(mbTileExtentOffset);
- std::string mbLocTileExtentOffset;
- STRING wLocTileExtentOffset = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_TileExtentOffset_LocalizedName");
- MgUtil::WideCharToMultiByte(wLocTileExtentOffset, mbLocTileExtentOffset);
- xml.append(mbLocTileExtentOffset);
- xml.append("<DefaultValue></DefaultValue>\n");
+ WriteCommonTileProviderProperties(xml);
- //Property: MetaTileFactor
- std::string mbMetaTileFactor;
- MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_METATILEFACTOR, mbMetaTileFactor);
- xml.append(mbMetaTileFactor);
- std::string mbLocMetaTileFactor;
- STRING wLocMetaTileFactor = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_MetaTileFactor_LocalizedName");
- MgUtil::WideCharToMultiByte(wLocMetaTileFactor, mbLocMetaTileFactor);
- xml.append(mbLocMetaTileFactor);
- //Property: MetaTileLockMethod
- std::string mbMetaTileLockMethod;
- MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_METATILELOCKMETHOD, mbMetaTileLockMethod);
- xml.append(mbMetaTileLockMethod);
- std::string mbLocMetaTileLockMethod;
- STRING wLocMetaTileLockMethod = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_MetaTileLockMethod_LocalizedName");
- MgUtil::WideCharToMultiByte(wLocMetaTileLockMethod, mbLocMetaTileLockMethod);
- xml.append(mbLocMetaTileLockMethod);
xml.append("</ConnectionProperties>\n");
xml.append("</TileProvider>\n");
@@ -384,26 +389,6 @@
//Property: TileFormat
xml.append("<ConnectionProperty Enumerable=\"true\" Protected=\"false\" Required=\"true\">\n");
@@ -427,71 +412,24 @@
xml.append("<Value>UTFGRID</Value>");
+ //Property: RetinaScale
+ std::string mbRetinaScale;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_XYZ_PARAM_RETINASCALE, mbRetinaScale);
+ xml.append(mbRetinaScale);
+ std::string mbLocRetinaScale;
+ STRING wLocRetinaScale = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_XYZ_Property_RetinaScale_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocRetinaScale, mbLocRetinaScale);
+ xml.append(mbLocRetinaScale);
@@ -662,6 +600,7 @@
bool bRenderOnly = false;
INT32 metaTileFactor = 0;
INT32 metaTileLockMethod = 0;
for (INT32 i = 0; i < parameters->GetCount(); i++)
MdfModel::NameStringPair* pair = parameters->GetAt(i);
@@ -693,6 +632,10 @@
metaTileLockMethod = MgUtil::StringToInt32(pair->GetValue());
+ else if (pair->GetName() == MG_TILE_PROVIDER_XYZ_PARAM_RETINASCALE)
+ retinaScale = MgUtil::StringToInt32(pair->GetValue());
//If we find the cache path substitution tag, replace it with the default path from the configuration
@@ -701,7 +644,7 @@
path = MgTileParameters::tileCachePath;
- cache = new MgTileCacheXYZProvider(tileSetId, path, format, bRenderOnly, tileExtentOffset, metaTileFactor, metaTileLockMethod);
+ cache = new MgTileCacheXYZProvider(tileSetId, path, format, bRenderOnly, tileExtentOffset, metaTileFactor, metaTileLockMethod, retinaScale);
else
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.h
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -76,6 +76,8 @@
void SetConnectionProperties(MgConnectionProperties* connProp);
private:
+ void WriteCommonTileProviderProperties(std::string& xml);
MgTileCache* GetTileCache(MgResourceIdentifier* resource);
MgTileCache* GetTileCache(MgResourceIdentifier* tileSetId, MdfModel::TileSetDefinition* tileset);
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -26,7 +26,8 @@
bool bRenderOnly,
INT32 metaTileFactor,
- INT32 metaTileLockMethod)
+ INT32 metaTileLockMethod,
m_tilesetId = SAFE_ADDREF(tileSetId);
m_path = path;
@@ -35,6 +36,7 @@
m_tileExtentOffset = tileExtentOffset;
m_metaTileFactor = metaTileFactor;
m_metaTileLockMethod = metaTileLockMethod;
+ m_retinaScale = retinaScale;
MgTileCacheXYZProvider::~MgTileCacheXYZProvider()
@@ -42,15 +44,20 @@
+bool MgTileCacheXYZProvider::IsTileImageFormat()
+ return m_format == L"UTFGRID";
MgByteReader* MgTileCacheXYZProvider::GetTile(CREFSTRING baseMapLayerGroupName,
- INT32 tileColumn,
- INT32 tileRow,
- INT32 scaleIndex)
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex)
MG_TRY()
- if (m_metaTileFactor > 1)
+ if (IsTileImageFormat() && m_metaTileFactor > 1)
ret = GetMetatileForResource(m_tilesetId, baseMapLayerGroupName, tileColumn, tileRow, scaleIndex);
else
ret = GetTileForResource(m_tilesetId, baseMapLayerGroupName, tileColumn, tileRow, scaleIndex);
@@ -84,7 +91,7 @@
else //Assume it must be image-based at this point
// generate the tile
- img = svcRendering->RenderTileXYZ(map, baseMapLayerGroupName, tileRow, tileColumn, scaleIndex, map->GetDisplayDpi(), m_format, m_tileExtentOffset);
+ img = svcRendering->RenderTileXYZ(map, baseMapLayerGroupName, tileRow, tileColumn, scaleIndex, map->GetDisplayDpi(), m_format, m_tileExtentOffset, m_retinaScale);
// cache the tile
if (!m_renderOnly)
@@ -104,12 +111,12 @@
INT32 MgTileCacheXYZProvider::GetDefaultTileSizeX()
- return 256; //Always
+ return 256 * m_retinaScale;
INT32 MgTileCacheXYZProvider::GetDefaultTileSizeY()
STRING MgTileCacheXYZProvider::GetTileFormat()
@@ -404,9 +411,8 @@
serviceMan->RequestService(MgServiceType::RenderingService));
_ASSERT(NULL != svcRendering);
- //Ptr<MgByteReader> metaTileBitMap = GetTile(metaTileName, map, scaleIndex, baseMapLayerGroupName, metaTileColumn, metaTileRow);
INT32 tileDpi = map->GetDisplayDpi();
- Ptr<MgMetatile> metaTile = svcRendering->RenderMetatileXYZ(map, baseMapLayerGroupName, metaTileRow, metaTileColumn, scaleIndex, tileDpi, m_format, m_tileExtentOffset, m_metaTileFactor);
+ Ptr<MgMetatile> metaTile = svcRendering->RenderMetatileXYZ(map, baseMapLayerGroupName, metaTileRow, metaTileColumn, scaleIndex, tileDpi, m_format, m_tileExtentOffset, m_metaTileFactor, m_retinaScale);
#ifdef _DEBUG
Ptr<MgByteReader> mtContent = metaTile->GetImage();
INT32 metaTileLen = mtContent->GetLength();
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h
--- trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -28,7 +28,9 @@
bool bRenderOnly,
- INT32 metaTileLockMethod);
virtual ~MgTileCacheXYZProvider();
virtual MgByteReader* GetTile(CREFSTRING baseMapLayerGroupName,
@@ -59,6 +61,8 @@
virtual STRING GetTileFileExtension();
private:
+ bool IsTileImageFormat();
// ---------------- Begin Metatile stuff --------------------- //
MgByteReader* GetMetatileForResource(MgResourceIdentifier* resource,
@@ -78,6 +82,7 @@
double m_tileExtentOffset;
INT32 m_metaTileFactor;
INT32 m_metaTileLockMethod;
+ INT32 m_retinaScale;
#endif
Modified: trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -202,11 +202,21 @@
Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
+ Ptr<MgResourceIdentifier> mapres3 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSetXYZ.MapDefinition");
+ Ptr<MgByteSource> mdfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_LinkedTileSetXYZ.mdf", false);
+ Ptr<MgByteReader> mdfrdr3 = mdfsrc3->GetReader();
+ m_svcResource->SetResource(mapres3, mdfrdr3, NULL);
Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
m_svcResource->SetResource(tilesetres1, tsdrdr1, NULL);
+ Ptr<MgResourceIdentifier> tilesetres2 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc2 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
+ Ptr<MgByteReader> tsdrdr2 = tsdsrc2->GetReader();
+ m_svcResource->SetResource(tilesetres2, tsdrdr2, NULL);
Ptr<MgByteSource> bsPackage = new MgByteSource(L"../UnitTestFiles/PlotHole.mgp", false);
Ptr<MgByteReader> pkgReader = bsPackage->GetReader();
m_svcResource->ApplyResourcePackage(pkgReader);
@@ -286,9 +296,15 @@
Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
m_svcResource->DeleteResource(mapres2);
+ m_svcResource->DeleteResource(mapres3);
m_svcResource->DeleteResource(tilesetres1);
+ m_svcResource->DeleteResource(tilesetres2);
Ptr<MgResourceIdentifier> plotHoleFolder = new MgResourceIdentifier(L"Library://UnitTests/PlotHole/");
m_svcResource->DeleteResource(plotHoleFolder);
@@ -314,91 +330,121 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nMapping Service tests completed.\n\n")));
-void TestMappingService::TestCase_CreateRuntimeMap()
+void TestMappingService::TestCase_CreateRuntimeMap(INT32 major, INT32 minor, INT32 rev)
try
+ STRING suffix = L"_";
+ STRING s;
+ MgUtil::Int32ToString(major, s);
+ suffix += s;
+ suffix += L"_";
+ MgUtil::Int32ToString(minor, s);
+ suffix += s;
+ suffix += L"_";
+ MgUtil::Int32ToString(rev, s);
+ suffix += s;
+ auto schemaVersion = MG_API_VERSION(major, minor, rev);
//make a runtime map
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgResourceIdentifier> mdfLinkedRes = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+ Ptr<MgResourceIdentifier> mdfLinkedXYZRes = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSetXYZ.MapDefinition");
STRING format = MgImageFormats::Png;
//call the API
- Ptr<MgByteReader> rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan1", m_session, format, 16, 16, 0, 25);
+ Ptr<MgByteReader> rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan1", m_session, format, 16, 16, 0, 25, schemaVersion);
Ptr<MgByteSink> sink = new MgByteSink(rtMap);
sink->ToFile(L"../UnitTestFiles/RuntimeMapBarebones.xml");
- rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan2", m_session, format, 16, 16, 1, 25);
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan2", m_session, format, 16, 16, 1, 25, schemaVersion);
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroups.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroups" + suffix + L".xml");
- rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan3", m_session, format, 16, 16, (1 | 2), 25);
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan3", m_session, format, 16, 16, (1 | 2), 25, schemaVersion);
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG16x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG16x16" + suffix + L".xml");
- rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan4", m_session, format, 16, 16, (1 | 2 | 4), 25);
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan4", m_session, format, 16, 16, (1 | 2 | 4), 25, schemaVersion);
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG16x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG16x16" + suffix + L".xml");
- rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan5", m_session, format, 32, 32, (1 | 2), 25);
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan5", m_session, format, 32, 32, (1 | 2), 25, schemaVersion);
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG32x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG32x32" + suffix + L".xml");
- rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan6", m_session, format, 32, 32, (1 | 2 | 4), 25);
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan6", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG32x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG32x32" + suffix + L".xml");
format = MgImageFormats::Gif;
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsGIF16x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsGIF16x16" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceGIF16x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceGIF16x16" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsGIF32x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsGIF32x32" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceGIF32x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceGIF32x32" + suffix + L".xml");
format = MgImageFormats::Jpeg;
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsJPEG16x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsJPEG16x16" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceJPEG16x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceJPEG16x16" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsJPEG32x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsJPEG32x32" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceJPEG32x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceJPEG32x32" + suffix + L".xml");
format = MgImageFormats::Png8;
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG816x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG816x16" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG816x16.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG816x16" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG832x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG832x32" + suffix + L".xml");
- sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG832x32.xml");
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
+ Ptr<MgResourceIdentifier> tsdRes = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
+ rtMap = m_svcMapping->CreateRuntimeMap(tsdRes, L"UnitTestSheboygan7", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
+ sink = new MgByteSink(rtMap);
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapFromTileSetLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfLinkedRes, L"UnitTestSheboygan8", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapFromLinkedTileSetLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
+ rtMap = m_svcMapping->CreateRuntimeMap(mdfLinkedXYZRes, L"UnitTestSheboygan9", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
+ sink->ToFile(L"../UnitTestFiles/RuntimeMapFromLinkedXYZTileSetLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
catch(MgException* e)
Modified: trunk/MgDev/Server/src/UnitTesting/TestMappingService.h
--- trunk/MgDev/Server/src/UnitTesting/TestMappingService.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/UnitTesting/TestMappingService.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -39,7 +39,9 @@
CPPUNIT_TEST(TestCase_GetLegendImageCompositeConvenience);
CPPUNIT_TEST(TestCase_GetLegendImageCompositeThemedConvenience);
CPPUNIT_TEST(TestCase_GetLegendImagePointStyleWithConstRotationsConvenience);
- CPPUNIT_TEST(TestCase_CreateRuntimeMap);
+ CPPUNIT_TEST(TestCase_CreateRuntimeMap260);
+ CPPUNIT_TEST(TestCase_CreateRuntimeMap300);
+ CPPUNIT_TEST(TestCase_CreateRuntimeMap400);
CPPUNIT_TEST(TestCase_DescribeRuntimeMap);
CPPUNIT_TEST(TestCase_CreateAndDescribeLinkedRuntimeMap);
//CPPUNIT_TEST(TestCase_QueryFeaturesImageMap);
@@ -57,7 +59,10 @@
void TestStart();
void TestEnd();
- void TestCase_CreateRuntimeMap();
+ void TestCase_CreateRuntimeMap(INT32 major, INT32 minor, INT32 rev);
+ void TestCase_CreateRuntimeMap260() { TestCase_CreateRuntimeMap(2, 6, 0); }
+ void TestCase_CreateRuntimeMap300() { TestCase_CreateRuntimeMap(3, 0, 0); }
+ void TestCase_CreateRuntimeMap400() { TestCase_CreateRuntimeMap(4, 0, 0); }
void TestCase_DescribeRuntimeMap();
void TestCase_SaveMap();
void TestCase_GetPlot();
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -1759,21 +1759,30 @@
-void TestRenderingService::TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension)
+void TestRenderingService::TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension, INT32 retinaScale)
try
+ STRING retinaSuffix = L"";
+ if (retinaScale > 1)
+ retinaSuffix = L"@";
+ STRING sRetina;
+ MgUtil::Int32ToString(retinaScale, sRetina);
+ retinaSuffix += sRetina;
Ptr<MgMap> map = CreateTestTiledMap();
map->SetViewScale(12500.0);
- Ptr<MgByteReader> tile_16798_23891_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16798, 23891, 16, MgTileParameters::tileDPI, imageFormat);
- Ptr<MgByteReader> tile_16799_23891_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16799, 23891, 16, MgTileParameters::tileDPI, imageFormat);
- Ptr<MgByteReader> tile_16798_23892_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16798, 23892, 16, MgTileParameters::tileDPI, imageFormat);
- Ptr<MgByteReader> tile_16799_23892_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16799, 23892, 16, MgTileParameters::tileDPI, imageFormat);
+ Ptr<MgByteReader> tile_16798_23891_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16798, 23891, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, retinaScale);
+ Ptr<MgByteReader> tile_16799_23891_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16799, 23891, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, retinaScale);
+ Ptr<MgByteReader> tile_16798_23892_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16798, 23892, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, retinaScale);
+ Ptr<MgByteReader> tile_16799_23892_baseline = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16799, 23892, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, retinaScale);
- tile_16798_23891_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23891_16_Baseline", imageFormat, extension));
- tile_16799_23891_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23891_16_Baseline", imageFormat, extension));
- tile_16798_23892_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23892_16_Baseline", imageFormat, extension));
- tile_16799_23892_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23892_16_Baseline", imageFormat, extension));
+ tile_16798_23891_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23891_16_Baseline" + retinaSuffix, imageFormat, extension));
+ tile_16799_23891_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23891_16_Baseline" + retinaSuffix, imageFormat, extension));
+ tile_16798_23892_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23892_16_Baseline" + retinaSuffix, imageFormat, extension));
+ tile_16799_23892_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23892_16_Baseline" + retinaSuffix, imageFormat, extension));
MgRenderingService* renderSvc = dynamic_cast<MgRenderingService*>(m_svcRendering.p);
CPPUNIT_ASSERT(NULL != renderSvc);
@@ -1780,7 +1789,7 @@
// Render a 2x2 metatile which should cover the same tiles as the baseline test.
INT32 metaTileFactor = 2;
- Ptr<MgMetatile> metaTile = renderSvc->RenderMetatileXYZ(map, L"BaseLayers", 16798, 23891, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor);
+ Ptr<MgMetatile> metaTile = renderSvc->RenderMetatileXYZ(map, L"BaseLayers", 16798, 23891, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor, retinaScale);
//metaTile->ToFile(L"../UnitTestFiles/RenderTileXYZ_Metatile at 16798_23891_16.png");
//CPPUNIT_ASSERT(metaTile->IsRewindable());
//metaTile->Rewind();
@@ -1789,10 +1798,10 @@
Ptr<MgByteReader> tile_16798_23892 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 1);
Ptr<MgByteReader> tile_16799_23892 = renderSvc->RenderTileFromMetaTile(map, metaTile, 1, 1);
- tile_16798_23891->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23891_16_Metatiled", imageFormat, extension));
- tile_16799_23891->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23891_16_Metatiled", imageFormat, extension));
- tile_16798_23892->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23892_16_Metatiled", imageFormat, extension));
- tile_16799_23892->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23892_16_Metatiled", imageFormat, extension));
+ tile_16798_23891->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23891_16_Metatiled" + retinaSuffix, imageFormat, extension));
+ tile_16799_23891->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23891_16_Metatiled" + retinaSuffix, imageFormat, extension));
+ tile_16798_23892->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23892_16_Metatiled" + retinaSuffix, imageFormat, extension));
+ tile_16799_23892->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23892_16_Metatiled" + retinaSuffix, imageFormat, extension));
catch (MgException* e)
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h 2019-06-25 11:20:14 UTC (rev 9560)
@@ -29,6 +29,16 @@
CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG8);
CPPUNIT_TEST(TestCase_RenderXYZMetatileJPG);
CPPUNIT_TEST(TestCase_RenderXYZMetatileGIF);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG_2x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG8_2x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatileJPG_2x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatileGIF_2x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG_4x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG8_4x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatileJPG_4x);
+ CPPUNIT_TEST(TestCase_RenderXYZMetatileGIF_4x);
CPPUNIT_TEST(TestCase_RenderMetatilePNG);
CPPUNIT_TEST(TestCase_RenderMetatilePNG8);
@@ -169,7 +179,7 @@
void TestCase_QueryFeatures();
void TestCase_RenderMetatile(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension, INT32 retinaScale);
void TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension);
@@ -318,11 +328,21 @@
void TestCase_RenderMetatileJPG() { TestCase_RenderMetatile(L"JPG", L"jpg"); }
void TestCase_RenderMetatileGIF() { TestCase_RenderMetatile(L"GIF", L"gif"); }
- void TestCase_RenderXYZMetatilePNG() { TestCase_RenderXYZMetatile(L"PNG", L"png"); }
- void TestCase_RenderXYZMetatilePNG8() { TestCase_RenderXYZMetatile(L"PNG8", L"png"); }
- void TestCase_RenderXYZMetatileJPG() { TestCase_RenderXYZMetatile(L"JPG", L"jpg"); }
- void TestCase_RenderXYZMetatileGIF() { TestCase_RenderXYZMetatile(L"GIF", L"gif"); }
+ void TestCase_RenderXYZMetatilePNG() { TestCase_RenderXYZMetatile(L"PNG", L"png", 1); }
+ void TestCase_RenderXYZMetatilePNG8() { TestCase_RenderXYZMetatile(L"PNG8", L"png", 1); }
+ void TestCase_RenderXYZMetatileJPG() { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 1); }
+ void TestCase_RenderXYZMetatileGIF() { TestCase_RenderXYZMetatile(L"GIF", L"gif", 1); }
+ void TestCase_RenderXYZMetatilePNG_2x() { TestCase_RenderXYZMetatile(L"PNG", L"png", 2); }
+ void TestCase_RenderXYZMetatilePNG8_2x() { TestCase_RenderXYZMetatile(L"PNG8", L"png", 2); }
+ void TestCase_RenderXYZMetatileJPG_2x() { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 2); }
+ void TestCase_RenderXYZMetatileGIF_2x() { TestCase_RenderXYZMetatile(L"GIF", L"gif", 2); }
+ void TestCase_RenderXYZMetatilePNG_4x() { TestCase_RenderXYZMetatile(L"PNG", L"png", 4); }
+ void TestCase_RenderXYZMetatilePNG8_4x() { TestCase_RenderXYZMetatile(L"PNG8", L"png", 4); }
+ void TestCase_RenderXYZMetatileJPG_4x() { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 4); }
+ void TestCase_RenderXYZMetatileGIF_4x() { TestCase_RenderXYZMetatile(L"GIF", L"gif", 4); }
private:
MgMap* CreateTestMap();
MgMap* CreateTestTiledMap();
Modified: trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -1860,7 +1860,7 @@
INT32 mtX = y;
INT32 mtY = x;
- Ptr<MgMetatile> metaTile = renderSvc->RenderMetatileXYZ(map, L"BaseLayers", mtX, mtY, z, MgTileParameters::tileDPI, MgImageFormats::Png, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor);
+ Ptr<MgMetatile> metaTile = renderSvc->RenderMetatileXYZ(map, L"BaseLayers", mtX, mtY, z, MgTileParameters::tileDPI, MgImageFormats::Png, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor, 1 /* retinaScale */);
INT64 metaTileLen = mtContent->GetLength();
INT32 mtFactor = metaTile->GetMetaTilingFactor();
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml 2019-06-25 11:20:14 UTC (rev 9560)
@@ -12,10 +12,10 @@
</Parameter>
</TileStoreParameters>
<Extents>
- <MinX>-87.79786601383196</MinX>
- <MaxX>-87.66452777186925</MaxX>
- <MinY>43.6868578621819</MinY>
- <MaxY>43.8037962206133</MaxY>
+ <MinX>-9769953.6613122653</MinX>
+ <MaxX>-9762220.7994439267</MaxX>
+ <MinY>5417808.8801717851</MinY>
+ <MaxY>5434161.2241863841</MaxY>
</Extents>
<BaseMapLayerGroup>
<Name>Base Layer Group</Name>
Copied: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml (from rev 9559, sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml)
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml (rev 0)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml 2019-06-25 11:20:14 UTC (rev 9560)
@@ -0,0 +1,87 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>XYZ</TileProvider>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileFormat</Name>
+ <Value>PNG</Value>
+ </Parameter>
+ <Parameter>
+ <Name>RetinaScale</Name>
+ <Value>2</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <Extents>
+ </Extents>
+ <BaseMapLayerGroup>
+ <Name>Base Layer Group</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Tiled Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Roads</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <LegendLabel>Roads</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Districts</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
+ <LegendLabel>Districts</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Buildings</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
+ <LegendLabel>Buildings</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Islands</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
+ <LegendLabel>Islands</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Hydrography</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
+ <LegendLabel>Hydrography</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>CityLimits</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
+ <LegendLabel>CityLimits</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
\ No newline at end of file
Copied: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml (from rev 9559, sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml)
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml (rev 0)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml 2019-06-25 11:20:14 UTC (rev 9560)
@@ -0,0 +1,6 @@
+<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
+ <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+ <Inherited>true</Inherited>
+ </Security>
+</ResourceDocumentHeader>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2019-06-25 11:20:14 UTC (rev 9560)
@@ -1,2409 +1 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
-<ResourcePackageManifest
- xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd">
- <Operations>
- <Operation>
- <Name>SETRESOURCE</Name>
- <Version>1.0.0</Version>
- <Parameters>
- <Parameter>
- <Name>HEADER</Name>
- <Value>Library/Samples/Sheboygan/_HEADER.xml</Value>
- <ContentType>text/xml</ContentType>
- </Parameter>
- <Parameter>
- <Name>RESOURCEID</Name>
- <Value>Library://Samples/Sheboygan/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/MapsTiled/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Name>DELETERESOURCE</Name>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>CONTENT</Name>
- <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Name>SETRESOURCEDATA</Name>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value>
- <ContentType>model/vnd.dwf</ContentType>
- </Parameter>
- <Parameter>
- <Name>DATALENGTH</Name>
- <Value>5594</Value>
- </Parameter>
- <Parameter>
- <Name>DATANAME</Name>
- <Value>symbols.dwf</Value>
- </Parameter>
- <Parameter>
- <Name>DATATYPE</Name>
- <Value>File</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value>
- </Parameter>
- <Parameter>
- <Value>22760</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value>
- <ContentType>application/octet-stream</ContentType>
- </Parameter>
- <Parameter>
- <Value>8038400</Value>
- </Parameter>
- <Parameter>
- <Value>BuildingOutlines.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>307200</Value>
- </Parameter>
- <Parameter>
- <Value>CityLimits.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>768000</Value>
- </Parameter>
- <Parameter>
- <Value>HydrographicLines.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>512000</Value>
- </Parameter>
- <Parameter>
- <Value>HydrographicPolygons.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- <Value>Islands.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>1996800</Value>
- </Parameter>
- <Parameter>
- <Value>LandUse.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>11929600</Value>
- </Parameter>
- <Parameter>
- <Value>Parcels.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>870400</Value>
- </Parameter>
- <Parameter>
- <Value>Rail.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>665600</Value>
- </Parameter>
- <Parameter>
- <Value>RoadCenterLines.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>4556800</Value>
- </Parameter>
- <Parameter>
- <Value>Soils.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>6656000</Value>
- </Parameter>
- <Parameter>
- <Value>Trees.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- <Value>VotingDistricts.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- </Operations>
-</ResourcePackageManifest>
+<?xml version="1.0" encoding="UTF-8" standalone="no" ?><ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd"><Operations><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value><Content
Type>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value><ContentType>
text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value><ContentType>text/xml
</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value><Content
Type>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Paramet
ers><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><N
ame>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerD
efinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERE
SOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0<
/Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>
Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.We
bLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter
></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentTyp
e></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboy
gan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Bas
icSymbols.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>5594</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Valu
e><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>22760</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Ope
ration><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>8038400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>BuildingOutlines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Val
ue>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Paramete
rs><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>CityLimits.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Para
meter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>768000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Ver
sion><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value><ContentType>application/octet-stream</ContentType><
/Parameter><Parameter><Name>DATALENGTH</Name><Value>512000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicPolygons.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOUR
CEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Islands.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Para
meter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>1996800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>LandUse.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Va
lue></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value><ContentType>application/octet-s
tream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>11929600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Parcels.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><V
alue>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>870400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Rail.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT<
/Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>665600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>RoadCenterLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Dat
a/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value><ContentT
ype>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>4556800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Soils.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Nam
e>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>6656000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Trees.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameter
s><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>VotingDistricts.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Libr
ary://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/
Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.Water
markDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition
_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value><
/Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Pa
rameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheb
oygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/She
boygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/
Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Paramete
r><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Vers
ion><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Soils.L
ayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURC
E</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><
Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentT
ype>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Para
meter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Ver
sion><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0
.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>
Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Par
ameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value
></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advance
d/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value><
ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Op
eration><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></P
arameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value><Con
tentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESO
URCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Par
ameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Versi
on>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value></Parameter></Parameters></Operation></Operations></ResourcePackageManifest>
\ No newline at end of file
Copied: trunk/MgDev/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf (from rev 9559, sandbox/jng/tiling_v3/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf)
--- trunk/MgDev/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf (rev 0)
+++ trunk/MgDev/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf 2019-06-25 11:20:14 UTC (rev 9560)
@@ -0,0 +1,25 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-3.0.0.xsd" version="3.0.0">
+ <Name>Base Map linked to Tile Set</Name>
+ <CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
+ <Extents>
+ <MinX>-9773613.7373958</MinX>
+ <MaxX>-9758770.5921973</MaxX>
+ <MinY>5417109.9090669</MinY>
+ <MaxY>5435129.2308673</MaxY>
+ </Extents>
+ <BackgroundColor>FFF7E1D2</BackgroundColor>
+ <MapLayer>
+ <Name>RoadCenterLines</Name>
+ <ResourceId>Library://UnitTests/Layers/RoadCenterLines.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <ShowInLegend>true</ShowInLegend>
+ <LegendLabel>Road CenterLines</LegendLabel>
+ <ExpandInLegend>false</ExpandInLegend>
+ <Visible>true</Visible>
+ <Group></Group>
+ </MapLayer>
+ <TileSetSource>
+ <ResourceId>Library://UnitTests/TileSets/XYZ.TileSetDefinition</ResourceId>
+ </TileSetSource>
+</MapDefinition>
Modified: trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp
--- trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -827,6 +827,8 @@
//RuntimeMap-3.0.0.xsd
s_elementPathTypeMap["/RuntimeMap/TileWidth"] = XML_DATA_TYPE_NUM_INT;
s_elementPathTypeMap["/RuntimeMap/TileHeight"] = XML_DATA_TYPE_NUM_INT;
+ //RuntimeMap-4.0.0.xsd
+ s_elementPathTypeMap["/RuntimeMap/TilePixelRatio"] = XML_DATA_TYPE_NUM_INT;
//SiteInformation-1.0.0.xsd
s_elementPathTypeMap["/SiteInformation/SiteServer/OperatingSystem/AvailablePhysicalMemory"] = XML_DATA_TYPE_NUM_INT;
s_elementPathTypeMap["/SiteInformation/SiteServer/OperatingSystem/TotalPhysicalMemory"] = XML_DATA_TYPE_NUM_INT;
Modified: trunk/MgDev/Web/src/localized/en
--- trunk/MgDev/Web/src/localized/en 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Web/src/localized/en 2019-06-25 11:20:14 UTC (rev 9560)
@@ -276,3 +276,6 @@
# Multiple Property Processing
SERVERERROR = Server Error
ERRORSTACKTRACE = Stack Trace
+# Unsupported tile set
+ERR_UNSUPPORTED_TILESET = Unsupported tile set provider: {0}
Modified: trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2019-06-25 11:20:14 UTC (rev 9560)
@@ -75,6 +75,11 @@
int tileSizeY = tileSrvc.GetDefaultTileSizeY();
if (null != tileSetId)
+ //Can't load map if it points to a non-default tile set provider
+ if (map.GetTileSetProvider() != "Default")
+ throw new RuntimeException(MessageFormat.format(MgLocalizer.GetString("ERR_UNSUPPORTED_TILESET", locale), new Object[] { map.GetTileSetProvider() }));
//Overwrite the map definition with tile set id (this is for GETTILE requests) and
//use size settings from that tile set
mapDefinition = tileSetId.ToString();
Modified: trunk/MgDev/Web/src/mapviewernet/mapframe.aspx
--- trunk/MgDev/Web/src/mapviewernet/mapframe.aspx 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Web/src/mapviewernet/mapframe.aspx 2019-06-25 11:20:14 UTC (rev 9560)
@@ -78,6 +78,11 @@
+ throw new Exception(String.Format(MgLocalizer.GetString("ERR_UNSUPPORTED_TILESET", locale), new Object[] { map.GetTileSetProvider() }));
Modified: trunk/MgDev/Web/src/mapviewerphp/mapframe.php
--- trunk/MgDev/Web/src/mapviewerphp/mapframe.php 2019-06-22 08:42:36 UTC (rev 9559)
+++ trunk/MgDev/Web/src/mapviewerphp/mapframe.php 2019-06-25 11:20:14 UTC (rev 9560)
@@ -68,6 +68,11 @@
$tileSizeY = $tileSrvc->GetDefaultTileSizeY();
if (NULL != $tileSetId)
+ if ($map->GetTileSetProvider() != "Default")
+ throw new Exception(FormatMessage("ERR_UNSUPPORTED_TILESET", $locale, array($map->GetTileSetProvider())));
$mapDefinition = $tileSetId->ToString();
@@ -152,6 +157,11 @@
$errorMsg = EscapeForHtml($e->GetDetails());
echo $errorMsg;
+catch(Exception $e)
+ $errorMsg = EscapeForHtml($e->getMessage());
+ echo $errorMsg;
//load ajax template code and format it
function GetParameters($params)
More information about the mapguide-commits
