[mapguide-commits] r9561 - trunk/MgDev/Server/src/UnitTesting
svn_mapguide at osgeo.org
Tue Jun 25 09:48:43 PDT 2019
Author: jng
Date: 2019-06-25 09:48:43 -0700 (Tue, 25 Jun 2019)
New Revision: 9561
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
Fix up EPSG_4326_Wkt comparison
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2019-06-25 11:20:14 UTC (rev 9560)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2019-06-25 16:48:43 UTC (rev 9561)
@@ -51,7 +51,7 @@
const STRING Projected_UTM18_NAD83 = L"PROJCS[\"UTM83-18F\",GEOGCS[\"LL83\",DATUM[\"NAD83\",SPHEROID[\"GRS1980\",6378137.000,298.25722210]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"false_easting\",1640416.667],PARAMETER[\"false_northing\",0.000],PARAMETER[\"central_meridian\",-75.00000000000000],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"latitude_of_origin\",0.000],UNIT[\"Meter\",1.000000000000]]";
-const STRING EPSG_4326_Wkt = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]";
+const STRING EPSG_4326_Wkt = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722356]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]";
const STRING EPSG_4326_Wkt_Alt = L"GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS 84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
const STRING TEST_LOCALE = L"en";
More information about the mapguide-commits
