[mapguide-commits] r9562 - in trunk/MgDev: Common/MapGuideCommon/MapLayer Server/src/Services/Tile Server/src/UnitTesting
svn_mapguide at osgeo.org
Tue Jun 25 16:04:13 PDT 2019
Author: jng
Date: 2019-06-25 16:04:13 -0700 (Tue, 25 Jun 2019)
New Revision: 9562
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.cpp
trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.h
trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
trunk/MgDev/Server/src/UnitTesting/TestTileService.h
Remove strict flag in MgMap::Create() as we now unconditionally allow creating MgMap instances from XYZ tilesets or Map Definitions that link to it.
This renders the TestCase_MgMapFromXYZTileSetStrict obsolete, so it has been removed.
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2019-06-25 23:04:13 UTC (rev 9562)
@@ -111,17 +111,12 @@
void MgMap::Create(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName)
- Create(resourceService, resource, mapName, true);
-void MgMap::Create(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName, bool strict)
MG_TRY()
if (resource->GetResourceType() == MgResourceType::MapDefinition)
CreateFromMapDefinition(resourceService, resource, mapName);
else if (resource->GetResourceType() == MgResourceType::TileSetDefinition)
- CreateFromTileSet(resourceService, resource, mapName, strict);
+ CreateFromTileSet(resourceService, resource, mapName);
else
throw new MgInvalidResourceTypeException(L"MgMap.Create", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -216,7 +211,7 @@
tdef.reset(parser.DetachTileSetDefinition());
assert(tdef.get() != NULL);
- m_srs = GetCoordinateSystemFromTileSet(tdef.get(), true);
+ m_srs = GetCoordinateSystemFromTileSet(tdef.get());
auto tsp = tdef->GetTileStoreParameters();
m_tileSetProvider = tsp->GetTileProvider();
@@ -546,7 +541,7 @@
if (NULL != tdef.get())
FINITESCALES fScales;
- GetFiniteDisplayScalesFromTileSet(tdef.get(), fScales, true);
+ GetFiniteDisplayScalesFromTileSet(tdef.get(), fScales);
for (FINITESCALES::iterator it = fScales.begin(); it != fScales.end(); it++)
double scale = *it;
@@ -601,7 +596,7 @@
MG_CATCH_AND_THROW(L"MgMap.CreateFromMapDefinition")
-void MgMap::CreateFromTileSet(MgResourceService* resourceService, MgResourceIdentifier* tileSetDefId, CREFSTRING mapName, bool strict)
+void MgMap::CreateFromTileSet(MgResourceService* resourceService, MgResourceIdentifier* tileSetDefId, CREFSTRING mapName)
MG_TRY()
@@ -668,7 +663,7 @@
Ptr<MgCoordinate> coordCenter = gf.CreateCoordinateXY(extent.GetMinX() + (extent.GetMaxX() - extent.GetMinX()) / 2,
extent.GetMinY() + (extent.GetMaxY() - extent.GetMinY()) / 2);
m_center = gf.CreatePoint(coordCenter);
- m_srs = GetCoordinateSystemFromTileSet(tdef.get(), strict);
//Calculate the meter per unit for the given coordinate system
m_metersPerUnit = 1.0; // assume a default value
@@ -794,7 +789,7 @@
// build the sorted list of finite display scales
SORTEDSCALES sortedScales;
FINITESCALES displayScales;
- GetFiniteDisplayScalesFromTileSet(tdef.get(), displayScales, strict);
+ GetFiniteDisplayScalesFromTileSet(tdef.get(), displayScales);
if (displayScales.size() > 0)
for (FINITESCALES::iterator it = displayScales.begin(); it != displayScales.end(); it++)
@@ -827,7 +822,7 @@
MG_CATCH_AND_THROW(L"MgMap.CreateFromTileSet")
-STRING MgMap::GetCoordinateSystemFromTileSet(MdfModel::TileSetDefinition* tileset, bool strict)
+STRING MgMap::GetCoordinateSystemFromTileSet(MdfModel::TileSetDefinition* tileset)
//Yes, this is hard-coded against specific providers. Revisit if we do want
//to FDO-ize this tile provider concept.
@@ -851,19 +846,10 @@
Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
return csFactory->ConvertCoordinateSystemCodeToWkt(L"WGS84.PseudoMercator"); //NOXLATE
- if (strict)
- MgStringCollection args;
- args.Add(storeParams->GetTileProvider());
- throw new MgUnsupportedTileProviderException(L"MgMap.GetCoordinateSystemFromTileSet", __LINE__, __WFILE__, &args, L"", NULL);
- else
- return L"";
+ return L"";
-void MgMap::GetFiniteDisplayScalesFromTileSet(MdfModel::TileSetDefinition* tileset, FINITESCALES& scales, bool strict)
+void MgMap::GetFiniteDisplayScalesFromTileSet(MdfModel::TileSetDefinition* tileset, FINITESCALES& scales)
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2019-06-25 23:04:13 UTC (rev 9562)
@@ -777,8 +777,6 @@
virtual void SetWatermarkUsage(INT32 watermarkUsage);
- virtual void Create(MgResourceService* resourceService, MgResourceIdentifier* mapDefinition, CREFSTRING mapName, bool strict);
/// \brief
/// compute the coordinates of a tile, increase size by meta tiling Factor sm_useMetaTiles
@@ -833,10 +831,10 @@
private:
void CreateFromMapDefinition(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName);
- void CreateFromTileSet(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName, bool strict);
+ void CreateFromTileSet(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName);
- STRING GetCoordinateSystemFromTileSet(MdfModel::TileSetDefinition* tileset, bool strict);
- void GetFiniteDisplayScalesFromTileSet(MdfModel::TileSetDefinition* tileset, FINITESCALES& scales, bool strict);
+ STRING GetCoordinateSystemFromTileSet(MdfModel::TileSetDefinition* tileset);
+ void GetFiniteDisplayScalesFromTileSet(MdfModel::TileSetDefinition* tileset, FINITESCALES& scales);
// Version for serialization
static const int m_serializeVersion = (4<<16) + 0;
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.cpp 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.cpp 2019-06-25 23:04:13 UTC (rev 9562)
@@ -262,7 +262,7 @@
ACE_OS::fclose(lockFile);
- GetMapFromDefinition(resource, scaleIndex, map, false /* Allow MgMap to be created from any tile provider if resource is tile set */);
+ GetMapFromDefinition(resource, scaleIndex, map);
} // end of mutex scope
// Render the tile and cache it.
@@ -899,7 +899,7 @@
/// helper to retrieve map
-void MgTileCacheDefault::GetMapFromDefinition(MgResourceIdentifier* mapDefinition, INT32 scaleIndex, Ptr<MgMap> &map, bool bStrictCreate)
+void MgTileCacheDefault::GetMapFromDefinition(MgResourceIdentifier* mapDefinition, INT32 scaleIndex, Ptr<MgMap> &map)
// Attempt use a cached & serialized MgMap object
Ptr<MgMemoryStreamHelper> cachedMap;
@@ -921,7 +921,7 @@
Ptr<MgSiteConnection> siteConn = new MgSiteConnection();
siteConn->Open(MgUserInformation::GetCurrentUserInfo());
map = new MgMap(siteConn);
- map->Create(resourceService, mapDefinition, mapString, bStrictCreate);
+ map->Create(resourceService, mapDefinition, mapString);
cachedMap = new MgMemoryStreamHelper();
Ptr<MgStream> stream = new MgStream(cachedMap);
map->Serialize(stream);
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.h
--- trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.h 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheDefault.h 2019-06-25 23:04:13 UTC (rev 9562)
@@ -79,7 +79,7 @@
void Set(MgByteReader* img, CREFSTRING path);
MgByteReader* Get(CREFSTRING path);
- void GetMapFromDefinition(MgResourceIdentifier* mapDefinition, INT32 scaleIndex, Ptr<MgMap> &map, bool bStrictCreate = true);
+ void GetMapFromDefinition(MgResourceIdentifier* mapDefinition, INT32 scaleIndex, Ptr<MgMap> &map);
bool DetectTileLockFile(CREFSTRING lockPathname);
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-06-25 23:04:13 UTC (rev 9562)
@@ -301,7 +301,7 @@
- GetMapFromDefinition(resource, scaleIndex, map, false);
// Render the larger meta tile but do not cache it yet! (m_metaTileFactor [prohibits caching in GetTile)
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-06-25 23:04:13 UTC (rev 9562)
@@ -395,7 +395,7 @@
- GetMapFromDefinition(resource, -1 /* Don't set view scale from index for XYZ*/, map, false);
+ GetMapFromDefinition(resource, -1 /* Don't set view scale from index for XYZ*/, map);
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2019-06-25 23:04:13 UTC (rev 9562)
@@ -6360,19 +6360,19 @@
CPPUNIT_ASSERT(factory);
ogcWkt = factory->ConvertCoordinateSystemCodeToWkt(L"EPSG:4326");
- CPPUNIT_ASSERT(ogcWkt == EPSG_4326_Wkt);
+ CPPUNIT_ASSERT_MESSAGE(MgUtil::WideCharToMultiByte(ogcWkt), ogcWkt == EPSG_4326_Wkt);
ogcWkt = factory->ConvertCoordinateSystemCodeToWkt(L"ePsG:4326");
CPPUNIT_ASSERT_THROW_MG(ogcWkt = factory->ConvertCoordinateSystemCodeToWkt(L"test:4000"), MgCoordinateSystemLoadFailedException*);
ogcWkt = factory->ConvertEpsgCodeToWkt(4326);
ogcWkt = factory->ConvertEpsgCodeToWkt(0);
// TODO: This should be throwing an exception because the conversion failed.
- CPPUNIT_ASSERT(ogcWkt == L"");
+ CPPUNIT_ASSERT_MESSAGE(MgUtil::WideCharToMultiByte(ogcWkt), ogcWkt == L"");
INT32 epsg = factory->ConvertWktToEpsgCode(EPSG_4326_Wkt);
CPPUNIT_ASSERT(epsg == 4326);
Modified: trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2019-06-25 23:04:13 UTC (rev 9562)
@@ -1591,30 +1591,6 @@
-void TestTileService::TestCase_MgMapFromXYZTileSetStrict()
- try
- // make a runtime map
- Ptr<MgResourceIdentifier> tsdres = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
- MgMap* map = new MgMap(m_siteConnection);
- map->Create(tsdres, L"XYZTileSet");
- CPPUNIT_FAIL("MgUnsupportedTileProviderException should've been thrown");
- catch (MgException* e)
- bool isCorrectException = e->IsOfClass(MapGuide_Exception_MgUnsupportedTileProviderException);
- STRING message = e->GetDetails(TEST_LOCALE);
- SAFE_RELEASE(e);
- CPPUNIT_ASSERT_MESSAGE(MG_WCHAR_TO_CHAR(message), isCorrectException);
- catch (...)
- throw;
void TestTileService::TestCase_MgMapFromXYZTileSetLoose()
try
@@ -1622,7 +1598,7 @@
- map->Create(m_svcResource, tsdres, L"XYZTileSet", false);
+ map->Create(m_svcResource, tsdres, L"XYZTileSet");
CPPUNIT_ASSERT(0 == map->GetFiniteDisplayScaleCount());
Modified: trunk/MgDev/Server/src/UnitTesting/TestTileService.h
--- trunk/MgDev/Server/src/UnitTesting/TestTileService.h 2019-06-25 16:48:43 UTC (rev 9561)
+++ trunk/MgDev/Server/src/UnitTesting/TestTileService.h 2019-06-25 23:04:13 UTC (rev 9562)
@@ -32,7 +32,6 @@
CPPUNIT_TEST(TestCase_MgMap_Inline);
CPPUNIT_TEST(TestCase_MgMap_Linked);
CPPUNIT_TEST(TestCase_MgMap_LinkedSameCS);
- CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetStrict);
CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetLoose);
CPPUNIT_TEST(TestCase_MgMapFromTileSet);
CPPUNIT_TEST(TestCase_GetTile);
@@ -61,7 +60,6 @@
void TestCase_MgMap_Inline();
void TestCase_MgMap_Linked();
void TestCase_MgMap_LinkedSameCS();
- void TestCase_MgMapFromXYZTileSetStrict();
void TestCase_MgMapFromXYZTileSetLoose();
void TestCase_MgMapFromTileSet();
void TestCase_GetTile();
More information about the mapguide-commits
