[mapguide-commits] r9563 - in trunk/MgDev/Doc/samples: . ol2samples ol2samples/wms
svn_mapguide at osgeo.org
Fri Jun 28 23:51:33 PDT 2019
Author: jng
Date: 2019-06-28 23:51:33 -0700 (Fri, 28 Jun 2019)
New Revision: 9563
Added:
trunk/MgDev/Doc/samples/ol2samples/wms/
trunk/MgDev/Doc/samples/ol2samples/wms/index.html
trunk/MgDev/Doc/samples/samples.php
Add WMS with openlayers sample
Added: trunk/MgDev/Doc/samples/ol2samples/wms/index.html
--- trunk/MgDev/Doc/samples/ol2samples/wms/index.html (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/wms/index.html 2019-06-29 06:51:33 UTC (rev 9563)
@@ -0,0 +1,80 @@
+<html>
+ <head>
+ <title>Sheboygan WMS</title>
+ <link rel="stylesheet" href="../assets/ol.css" />
+ <style type="text/css">
+ #error { color: red; }
+ #wrap { width: 900; }
+ #map { width: 400; height: 300; float: left; border: 1px solid black; }
+ #main { margin-top: 50px; padding-top: 20px; }
+ </style>
+ <script type="text/javascript" src="../assets/ol-debug.js"></script>
+ <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+ <script type="text/javascript">
+ //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/xyz/index_ol.html
+ var mapAgentUrl = "../../mapagent/mapagent.fcgi";
+ $(document).ready(function() {
+ //NOTE: Your map definition can be in any coordinate system as long as it it transformable to LL84
+ //But the ol3 tile layer must remain as EPSG:3857
+ var map = new ol.Map({
+ layers: [
+ new ol.layer.Tile({
+ source: new ol.source.OSM({
+ attributions: [
+ new ol.Attribution({
+ html: 'Tiles © <a href="http://www.openstreetmap.org/">' +
+ 'OpenStreetMap</a>'
+ ol.source.OSM.ATTRIBUTION
+ url: 'http://{a-c}.tile.openstreetmap.org/{z}/{x}/{y}.png'
+ new ol.layer.Image({
+ source: new ol.source.ImageWMS({
+ url: mapAgentUrl + "?REQUEST=GETMAP&SERVICE=WMS&VERSION=1.3.0",
+ projection: "EPSG:4326",
+ params: {
+ "FORMAT": "image/png",
+ "LAYERS": "Samples/Sheboygan/Layers/Parcels,Samples/Sheboygan/Layers/Hydrography,Samples/Sheboygan/Layers/Districts,Samples/Sheboygan/Layers/Roads",
+ "TRANSPARENT": "TRUE"
+ renderer: 'canvas',
+ target: document.getElementById('map'),
+ view: new ol.View({
+ center: ol.proj.transform([-87.7302542509315, 43.744459064634], 'EPSG:4326', 'EPSG:3857'),
+ minZoom: 10,
+ maxZoom: 19,
+ zoom: 12
+ </script>
+ </head>
+ <body>
+ <div id="main">
+ <div class="container">
+ <div class="alert alert-info">
+ <p>This example demonstrates a Map Definition being consumed as a <strong>XYZ layer</strong> via the MapGuide REST API with <a href="http://openlayers.org/">OpenLayers 3</a>.</p>
+ <p>An OpenStreetMap layer is included as a backdrop for context</p>
+ <strong>For maximum visual fidelity, your Map Definition should be in WGS84.PseudoMercator</strong>
+ <p>Sample not loading? <a href="../data/load.php">Check that the required resources have been loaded</a></p>
+ </div>
+ <div id="error">
+ </div>
+ <div id="wrap">
+ <div id="map">
+ </div>
+ </div>
+ </div>
+ </div>
+ </body>
+</html>
Modified: trunk/MgDev/Doc/samples/samples.php
--- trunk/MgDev/Doc/samples/samples.php 2019-06-25 23:04:13 UTC (rev 9562)
+++ trunk/MgDev/Doc/samples/samples.php 2019-06-29 06:51:33 UTC (rev 9563)
@@ -126,6 +126,7 @@
<li><a href="ol2samples/hybrid/index.html">Open any map or tile set</a></li>
<li><a href="ol2samples/xyz/index_ol.html">Sheboygan map as XYZ layer</a></li>
<li><a href="ol2samples/utfgrid/index.html">Sheboygan map as XYZ layer with UTFGrid interaction tiles</a></li>
+ <li><a href="ol2samples/wms/index.html">Sheboygan map as WMS layers</a></li>
</ul>
More information about the mapguide-commits
