[mapguide-commits] r9564 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Sun Jun 30 03:16:21 PDT 2019
Author: jng
Date: 2019-06-30 03:16:21 -0700 (Sun, 30 Jun 2019)
New Revision: 9564
trunk/MgDev/Common/Stylization/LabelRenderer.cpp
trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
Add extra debugging code for labelling
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2019-06-29 06:51:33 UTC (rev 9563)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2019-06-30 10:16:21 UTC (rev 9564)
@@ -20,7 +20,12 @@
#include "SE_Renderer.h"
//#define DEBUG_LABELS
+//#define DEBUG_LABEL_CALLS
+#ifdef DEBUG_LABEL_CALLS
+#include <iostream>
+#endif
extern void ProcessStylizerException(FdoException* exception, int line, wchar_t* file);
@@ -337,7 +342,15 @@
lb.Close();
SE_LineStroke lineStroke(0xffff0000, 3.0);
m_serenderer->DrawScreenPolyline(&lb, NULL, lineStroke);
+ std::wcout << L"LabelRenderer::AddExclusionRegion ["
+ << L"(" << pts[0].x << L"," << pts[0].y << L"),"
+ << L"(" << pts[1].x << L"," << pts[1].y << L"),"
+ << L"(" << pts[2].x << L"," << pts[2].y << L"),"
+ << L"(" << pts[3].x << L"," << pts[3].y << L")"
+ << L"]" << std::endl;
#endif
+#endif
RS_F_Point* tmp = (RS_F_Point*)alloca(npts * sizeof(RS_F_Point));
@@ -406,6 +419,14 @@
lb.Close();
SE_LineStroke lineStroke(info.m_tdef.textcolor().argb(), 0.0);
+ std::wcout << L"LabelRenderer::DrawSimpleLabel ["
+ << L"] - (" << info.m_text << L")" << std::endl;
+#endif
#endif
@@ -490,7 +511,15 @@
lb.Close();
SE_LineStroke lineStroke(0xff000000, 0.0);
+ std::wcout << L"LabelRenderer::DrawSELabel ["
+ << L"(" << fpts[0].x << L"," << fpts[0].y << L"),"
+ << L"(" << fpts[1].x << L"," << fpts[1].y << L"),"
+ << L"(" << fpts[2].x << L"," << fpts[2].y << L"),"
+ << L"(" << fpts[3].x << L"," << fpts[3].y << L")"
#endif
+#endif
return true;
@@ -576,7 +605,15 @@
lb.Close();
+ std::wcout << L"LabelRenderer::DrawPathLabel ["
#endif
+#endif
Modified: trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
--- trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2019-06-29 06:51:33 UTC (rev 9563)
+++ trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2019-06-30 10:16:21 UTC (rev 9564)
@@ -20,7 +20,12 @@
+#endif
@@ -904,6 +909,14 @@
SE_LineStroke lineStroke(color, 0.0);
// SE_LineStroke lineStroke(info.m_tdef.textcolor().argb(), 0.0);
+ std::wcout << L"LabelRendererLocal::ComputeSimpleLabelBounds ["
+#endif
#endif
@@ -1006,7 +1019,15 @@
+ std::wcout << L"LabelRendererLocal::ComputePathLabelBounds ["
#endif
+#endif
// add current periodic label to the return list
@@ -1073,7 +1094,15 @@
+ std::wcout << L"LabelRenderer::ComputeSELabelBounds ["
+ << L"(" << info.m_rotated_points[0].x << L"," << info.m_rotated_points[0].y << L"),"
+ << L"(" << info.m_rotated_points[1].x << L"," << info.m_rotated_points[1].y << L"),"
+ << L"(" << info.m_rotated_points[2].x << L"," << info.m_rotated_points[2].y << L"),"
+ << L"(" << info.m_rotated_points[3].x << L"," << info.m_rotated_points[3].y << L")"
#endif
+#endif
return true;
@@ -1189,7 +1218,15 @@
lb.Close();
+ std::wcout << L"LabelRendererLocal::AddExclusionRegion ["
#endif
+#endif
More information about the mapguide-commits
