[mapguide-commits] r9613 - sandbox/jng/mvt_alt/Server/src/UnitTesting
svn_mapguide at osgeo.org
Sat Sep 21 16:28:21 PDT 2019
Author: jng
Date: 2019-09-21 16:28:21 -0700 (Sat, 21 Sep 2019)
New Revision: 9613
sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp
sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.h
Add "unit test" for MgGeometry -> LineBuffer conversion. I say "unit test" as this is merely just verifying existing behavior and is more internal documentation as to the expected layout of a LineBuffer for the purposes of rendering.
Modified: sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp
--- sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp 2019-09-21 21:36:30 UTC (rev 9612)
+++ sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp 2019-09-21 23:28:21 UTC (rev 9613)
@@ -23,6 +23,7 @@
#include "../UnitTesting/CppUnitExtensions.h"
#include "FoundationDefs.h"
#include "FdoConnectionManager.h"
+#include "LineBuffer.h"
const STRING TEST_LOCALE = L"en";
static const INT32 MG_TEST_THREADS = 16;
@@ -794,7 +795,7 @@
GetConfigValueThreadData* threadData = (GetConfigValueThreadData*)param;
INT32 threadId = threadData->threadId;
#ifdef _DEBUG
- printf("> thread %d started, tile %d,%d\n", threadId, tileRow, tileCol);
+ printf("> thread %d started\n", threadId);
#endif
try
@@ -912,4 +913,489 @@
throw;
+void TestMisc::TestCase_LineBuffer_Conversion()
+ //This isn't really a test, it's more verification and internal documentation
+ //of how LineBuffers are meant to be represented for various geometry types
+ try
+ MgWktReaderWriter wktRw;
+ MgAgfReaderWriter agfRw;
+ Ptr<MgGeometry> gPoint = wktRw.Read(L"POINT (30 10)");
+ Ptr<MgGeometry> gMultiPoint = wktRw.Read(L"MULTIPOINT (10 40, 40 30, 20 20, 30 10)");
+ Ptr<MgGeometry> gLineStr = wktRw.Read(L"LINESTRING (30 10, 10 30, 40 40)");
+ Ptr<MgGeometry> gMultiLineString = wktRw.Read(L"MULTILINESTRING ((10 10, 20 20, 10 40), (40 40, 30 30, 40 20, 30 10))");
+ Ptr<MgGeometry> gPolygon1 = wktRw.Read(L"POLYGON ((30 10, 40 40, 20 40, 10 20, 30 10))");
+ Ptr<MgGeometry> gPolygon2 = wktRw.Read(L"POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))");
+ Ptr<MgGeometry> gMultiPolygon1 = wktRw.Read(L"MULTIPOLYGON (((30 20, 45 40, 10 40, 30 20)), ((15 5, 40 10, 10 20, 5 10, 15 5)))");
+ Ptr<MgGeometry> gMultiPolygon2 = wktRw.Read(L"MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))");
+ //Point
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gPoint);
+ Ptr<MgByteSink> agfSink = new MgByteSink(agf);
+ Ptr<MgByte> bytes = agfSink->ToBuffer();
+ lb.LoadFromAgf(bytes->Bytes(), bytes->GetLength(), nullptr);
+ CPPUNIT_ASSERT(1 == lb.geom_count());
+ CPPUNIT_ASSERT(1 == lb.point_count());
+ CPPUNIT_ASSERT(30 == lb.x_coord(0));
+ CPPUNIT_ASSERT(10 == lb.y_coord(0));
+ //MultiPoint
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gMultiPoint);
+ CPPUNIT_ASSERT(1 == lb.geom_count()); //LineBuffer flattens this
+ CPPUNIT_ASSERT(4 == lb.point_count());
+ CPPUNIT_ASSERT(10 == lb.x_coord(0));
+ CPPUNIT_ASSERT(40 == lb.y_coord(0));
+ CPPUNIT_ASSERT(40 == lb.x_coord(1));
+ CPPUNIT_ASSERT(30 == lb.y_coord(1));
+ CPPUNIT_ASSERT(20 == lb.x_coord(2));
+ CPPUNIT_ASSERT(20 == lb.y_coord(2));
+ CPPUNIT_ASSERT(30 == lb.x_coord(3));
+ CPPUNIT_ASSERT(10 == lb.y_coord(3));
+ //LineString
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gLineStr);
+ int lineIdx = 0;
+ CPPUNIT_ASSERT(1 == lb.cntr_count());
+ CPPUNIT_ASSERT(3 == lb.cntr_size(lineIdx));
+ auto ptOffset = lb.contour_start_point(lineIdx);
+ for (int i = 0; i < lb.cntr_size(lineIdx); i++)
+ auto x = lb.x_coord(ptOffset + i);
+ auto y = lb.y_coord(ptOffset + i);
+ switch (i)
+ case 0:
+ CPPUNIT_ASSERT(30 == x);
+ CPPUNIT_ASSERT(10 == y);
+ break;
+ case 1:
+ CPPUNIT_ASSERT(10 == x);
+ CPPUNIT_ASSERT(30 == y);
+ break;
+ case 2:
+ CPPUNIT_ASSERT(40 == x);
+ CPPUNIT_ASSERT(40 == y);
+ break;
+ //MultiLineString
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gMultiLineString);
+ CPPUNIT_ASSERT(2 == lb.cntr_count());
+ CPPUNIT_ASSERT(3 == lb.cntr_size(0));
+ CPPUNIT_ASSERT(4 == lb.cntr_size(1));
+ //LineString 1
+ auto ptOffset = lb.contour_start_point(0);
+ for (int i = 0; i < lb.cntr_size(0); i++)
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ CPPUNIT_ASSERT(20 == x);
+ CPPUNIT_ASSERT(20 == y);
+ break;
+ case 2:
+ break;
+ //LineString 2
+ auto ptOffset = lb.contour_start_point(1);
+ for (int i = 0; i < lb.cntr_size(1); i++)
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ case 3:
+ break;
+ //Polygon 1 (1 outer, 0 inner)
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gPolygon1);
+ auto cc = lb.cntr_count();
+ CPPUNIT_ASSERT(1 == cc);
+ int lineIdx = 0;
+ CPPUNIT_ASSERT(5 == lb.cntr_size(lineIdx));
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ case 3:
+ break;
+ case 4:
+ break;
+ //Polygon 2 (1 outer, 1 inner)
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gPolygon2);
+ CPPUNIT_ASSERT(2 == cc);
+ //Outer Ring
+ CPPUNIT_ASSERT(5 == lb.cntr_size(0));
+ switch (i)
+ case 0:
+ CPPUNIT_ASSERT(35 == x);
+ break;
+ case 1:
+ CPPUNIT_ASSERT(45 == x);
+ CPPUNIT_ASSERT(45 == y);
+ break;
+ case 2:
+ CPPUNIT_ASSERT(15 == x);
+ break;
+ case 3:
+ break;
+ case 4:
+ break;
+ //Inner Ring
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ CPPUNIT_ASSERT(35 == y);
+ break;
+ case 2:
+ break;
+ case 3:
+ break;
+ //MultiPolygon 1
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gMultiPolygon1);
+ auto closed1 = lb.contour_closed(0);
+ auto closed2 = lb.contour_closed(1);
+ //Polygon 1
+ CPPUNIT_ASSERT(4 == lb.cntr_size(0));
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ case 3:
+ break;
+ //Polygon 2
+ CPPUNIT_ASSERT(5 == lb.cntr_size(1));
+ switch (i)
+ case 0:
+ CPPUNIT_ASSERT(5 == y);
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ case 3:
+ CPPUNIT_ASSERT(5 == x);
+ break;
+ case 4:
+ break;
+ //MultiPolygon 2
+ LineBuffer lb(8);
+ Ptr<MgByteReader> agf = agfRw.Write(gMultiPolygon2);
+ CPPUNIT_ASSERT(3 == cc);
+ auto closed3 = lb.contour_closed(2);
+ //Polygon 1
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ case 3:
+ break;
+ //How do we know from the LineBuffer that this is the 2nd polygon?
+ //Polygon 2 (inner ring)
+ CPPUNIT_ASSERT(6 == lb.cntr_size(1));
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ case 3:
+ break;
+ case 4:
+ break;
+ case 5:
+ break;
+ //Polygon 2 (outer ring)
+ CPPUNIT_ASSERT(4 == lb.cntr_size(2));
+ auto ptOffset = lb.contour_start_point(2);
+ for (int i = 0; i < lb.cntr_size(2); i++)
+ switch (i)
+ case 0:
+ break;
+ case 1:
+ CPPUNIT_ASSERT(15 == y);
+ break;
+ case 2:
+ CPPUNIT_ASSERT(25 == y);
+ break;
+ case 3:
+ break;
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
\ No newline at end of file
Modified: sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.h
--- sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.h 2019-09-21 21:36:30 UTC (rev 9612)
+++ sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.h 2019-09-21 23:28:21 UTC (rev 9613)
@@ -35,6 +35,7 @@
CPPUNIT_TEST(TestCase_TryParseDouble);
CPPUNIT_TEST(TestCase_BadResourceIdentifier);
CPPUNIT_TEST(TestCase_ThreadSafeConfiguration);
+ CPPUNIT_TEST(TestCase_LineBuffer_Conversion);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -59,6 +60,7 @@
void TestCase_TryParseDouble();
void TestCase_BadResourceIdentifier();
void TestCase_ThreadSafeConfiguration();
+ void TestCase_LineBuffer_Conversion();
private:
Ptr<MgSiteConnection> m_siteConnection;
More information about the mapguide-commits
