[mapguide-commits] r9614 - in sandbox/jng/mvt_alt: Common/Stylization Server/src/UnitTesting
svn_mapguide at osgeo.org
Sat Sep 21 17:20:02 PDT 2019
Author: jng
Date: 2019-09-21 17:20:02 -0700 (Sat, 21 Sep 2019)
New Revision: 9614
sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp
sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h
sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp
When rendering a MVT tile, we need to know when a new polygon of a multi-polygon begins. LineBuffers delineate everything in terms of points and contours (a series of points)
Cursory analysis of the LineBuffer class suggests that it does not have a means to determine which contour is the start of a geometry in a multi-geometry type (eg. MultiLineString/MultiPolygon).
I've added new APIs to LineBuffer to indicate:
- Geometry count:
- int num_geometries() const
- The contour indices that mark the beginning of a new geometry for a multi-geometry LineBuffer:
- int geom_start_cntr(int iGeom) const
These value are set when LoadFromAgf() is called.
I've extended the LineBuffer conversion test to verify these values are being set for multi-geometry LineBuffer instances.
Modified: sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp
--- sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp 2019-09-21 23:28:21 UTC (rev 9613)
+++ sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp 2019-09-22 00:20:02 UTC (rev 9614)
@@ -59,7 +59,9 @@
m_closeseg(NULL),
m_cur_closeseg(-1),
m_geom_type(0),
- m_drawingScale(0.0)
+ m_drawingScale(0.0),
+ m_geom_count(0),
+ m_cntr_geom_start(NULL)
ResizePoints(rs_max(size, 2));
ResizeContours(4);
@@ -113,6 +115,7 @@
delete[] m_num_geomcntrs;
delete[] m_arcs_sp;
delete[] m_closeseg;
+ delete[] m_cntr_geom_start;
@@ -144,6 +147,16 @@
m_bounds.minz = 0.0;
m_bounds.maxz = 0.0;
+ if (m_geom_count > 0)
+ _ASSERT(m_cntr_geom_start != NULL);
+ for (int i = 0; i < m_geom_count; i++)
+ m_cntr_geom_start[0] = -1;
+ m_geom_count = 0;
@@ -899,8 +912,23 @@
if (is_multi)
num_geoms = *ireader++;
+ m_geom_count = num_geoms;
+ // Release old one
+ if (m_cntr_geom_start)
+ m_cntr_geom_start = new int[m_geom_count];
+ // Fill default values
+ for (int q = 0; q < num_geoms; ++q)
+ m_cntr_geom_start[q] = -1;
+ int current_contour = 0;
for (int q=0; q<num_geoms; ++q)
+ m_cntr_geom_start[q] = current_contour;
// skip past geometry type of subgeometry
// we know it is LineString or Polygon or Point respectively
if (is_multi)
@@ -1013,6 +1041,8 @@
ireader = (int*)dreader;
//*** ireader valid again
+ current_contour++;
break;
Modified: sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h
--- sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h 2019-09-21 23:28:21 UTC (rev 9613)
+++ sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h 2019-09-22 00:20:02 UTC (rev 9614)
@@ -209,6 +209,8 @@
inline double& y_coord(int n) const;
inline double& z_coord(int n) const;
inline bool contour_closed(int cntr) const;
+ inline int num_geometries() const;
+ inline int geom_start_cntr(int iGeom) const;
// Adds point without checking for available space, updating the bounds, or applying
// the 3D transform. Thus, Ensure{Points, Contours}, and possibly ComputeBounds must
@@ -253,6 +255,9 @@
int m_closeseg_len; // length of m_closeseg array
int m_cur_closeseg; // current index into m_closeseg;
int* m_closeseg; // closed segment indices array
+ int m_geom_count; // Geometry count (for multi-geometry types)
+ int* m_cntr_geom_start; // Array of starting contours (denoting the start of a new geometry of a multi-geometry type)
void Resize();
void ResizeContours();
@@ -590,4 +595,14 @@
_ASSERT(m_cur_closeseg <= m_closeseg_len);
+int LineBuffer::num_geometries() const
+ return m_geom_count;
+int LineBuffer::geom_start_cntr(int iGeom) const
+ return m_cntr_geom_start[iGeom];
#endif
Modified: sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp
--- sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp 2019-09-21 23:28:21 UTC (rev 9613)
+++ sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp 2019-09-22 00:20:02 UTC (rev 9614)
@@ -932,15 +932,15 @@
Ptr<MgGeometry> gMultiPolygon1 = wktRw.Read(L"MULTIPOLYGON (((30 20, 45 40, 10 40, 30 20)), ((15 5, 40 10, 10 20, 5 10, 15 5)))");
Ptr<MgGeometry> gMultiPolygon2 = wktRw.Read(L"MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))");
+ LineBuffer lb(8);
//Point
- LineBuffer lb(8);
Ptr<MgByteReader> agf = agfRw.Write(gPoint);
Ptr<MgByteSink> agfSink = new MgByteSink(agf);
Ptr<MgByte> bytes = agfSink->ToBuffer();
lb.LoadFromAgf(bytes->Bytes(), bytes->GetLength(), nullptr);
- CPPUNIT_ASSERT(1 == lb.geom_count());
+ CPPUNIT_ASSERT(1 == lb.num_geometries());
CPPUNIT_ASSERT(1 == lb.point_count());
CPPUNIT_ASSERT(30 == lb.x_coord(0));
CPPUNIT_ASSERT(10 == lb.y_coord(0));
@@ -948,13 +948,14 @@
//MultiPoint
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gMultiPoint);
- CPPUNIT_ASSERT(1 == lb.geom_count()); //LineBuffer flattens this
+ CPPUNIT_ASSERT(4 == lb.num_geometries());
CPPUNIT_ASSERT(4 == lb.point_count());
CPPUNIT_ASSERT(10 == lb.x_coord(0));
CPPUNIT_ASSERT(40 == lb.y_coord(0));
@@ -968,7 +969,8 @@
//LineString
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gLineStr);
@@ -975,7 +977,7 @@
int lineIdx = 0;
CPPUNIT_ASSERT(1 == lb.cntr_count());
CPPUNIT_ASSERT(3 == lb.cntr_size(lineIdx));
@@ -1004,13 +1006,17 @@
//MultiLineString
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gMultiLineString);
+ CPPUNIT_ASSERT(2 == lb.num_geometries());
+ CPPUNIT_ASSERT(0 == lb.geom_start_cntr(0));
+ CPPUNIT_ASSERT(1 == lb.geom_start_cntr(1));
CPPUNIT_ASSERT(2 == lb.cntr_count());
CPPUNIT_ASSERT(3 == lb.cntr_size(0));
CPPUNIT_ASSERT(4 == lb.cntr_size(1));
@@ -1072,13 +1078,15 @@
//Polygon 1 (1 outer, 0 inner)
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gPolygon1);
auto cc = lb.cntr_count();
CPPUNIT_ASSERT(1 == cc);
@@ -1118,13 +1126,15 @@
//Polygon 2 (1 outer, 1 inner)
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gPolygon2);
CPPUNIT_ASSERT(2 == cc);
@@ -1195,13 +1205,16 @@
//MultiPolygon 1
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gMultiPolygon1);
auto closed1 = lb.contour_closed(0);
@@ -1274,13 +1287,16 @@
//MultiPolygon 2
- LineBuffer lb(8);
+ lb.Reset();
Ptr<MgByteReader> agf = agfRw.Write(gMultiPolygon2);
CPPUNIT_ASSERT(3 == cc);
More information about the mapguide-commits
