[mapguide-commits] r9615 - in sandbox/jng/mvt_alt: Common/Stylization Server/src/UnitTesting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Sep 21 17:40:57 PDT 2019
Author: jng
Date: 2019-09-21 17:40:57 -0700 (Sat, 21 Sep 2019)
New Revision: 9615
   sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp
   sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h
   sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp
Undo previous commit. These new APIs are meaningless as the data is lost if the LineBuffer is optimized or clipped. Let's just try to work with what we have.
Modified: sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp
--- sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp	2019-09-22 00:20:02 UTC (rev 9614)
+++ sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.cpp	2019-09-22 00:40:57 UTC (rev 9615)
@@ -59,9 +59,7 @@
     m_closeseg(NULL),
     m_cur_closeseg(-1),
     m_geom_type(0),
-    m_drawingScale(0.0),
-    m_geom_count(0),
-    m_cntr_geom_start(NULL)
+    m_drawingScale(0.0)
     ResizePoints(rs_max(size, 2));
     ResizeContours(4);
@@ -115,7 +113,6 @@
     delete[] m_num_geomcntrs;
     delete[] m_arcs_sp;
     delete[] m_closeseg;
-    delete[] m_cntr_geom_start;
@@ -147,16 +144,6 @@
         m_bounds.minz = 0.0;
         m_bounds.maxz = 0.0;
-    if (m_geom_count > 0)
-        _ASSERT(m_cntr_geom_start != NULL);
-        for (int i = 0; i < m_geom_count; i++)
-            m_cntr_geom_start[0] = -1;
-    m_geom_count = 0;
@@ -912,23 +899,8 @@
             if (is_multi)
                 num_geoms = *ireader++;
-            m_geom_count = num_geoms;
-            // Release old one
-            if (m_cntr_geom_start)
-            m_cntr_geom_start = new int[m_geom_count];
-            // Fill default values
-            for (int q = 0; q < num_geoms; ++q)
-                m_cntr_geom_start[q] = -1;
-            int current_contour = 0;
             for (int q=0; q<num_geoms; ++q)
-                m_cntr_geom_start[q] = current_contour;
                 // skip past geometry type of subgeometry
                 // we know it is LineString or Polygon or Point respectively
                 if (is_multi)
@@ -1041,8 +1013,6 @@
                     ireader = (int*)dreader;
                     //*** ireader valid again
-                    current_contour++;
             break;
Modified: sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h
--- sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h	2019-09-22 00:20:02 UTC (rev 9614)
+++ sandbox/jng/mvt_alt/Common/Stylization/LineBuffer.h	2019-09-22 00:40:57 UTC (rev 9615)
@@ -209,8 +209,6 @@
     inline double& y_coord(int n) const;
     inline double& z_coord(int n) const;
     inline bool contour_closed(int cntr) const;
-    inline int num_geometries() const;
-    inline int geom_start_cntr(int iGeom) const;
     // Adds point without checking for available space, updating the bounds, or applying
     // the 3D transform. Thus, Ensure{Points, Contours}, and possibly ComputeBounds must
@@ -255,9 +253,6 @@
     int m_closeseg_len;         // length of m_closeseg array
     int m_cur_closeseg;         // current index into m_closeseg;
     int* m_closeseg;            // closed segment indices array
-    int m_geom_count;           // Geometry count (for multi-geometry types)
-    int* m_cntr_geom_start;     // Array of starting contours (denoting the start of a new geometry of a multi-geometry type)
     void Resize();
     void ResizeContours();
@@ -595,14 +590,4 @@
     _ASSERT(m_cur_closeseg <= m_closeseg_len);
-int LineBuffer::num_geometries() const
-    return m_geom_count;
-int LineBuffer::geom_start_cntr(int iGeom) const
-    return m_cntr_geom_start[iGeom];
 #endif
Modified: sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp
--- sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp	2019-09-22 00:20:02 UTC (rev 9614)
+++ sandbox/jng/mvt_alt/Server/src/UnitTesting/TestMisc.cpp	2019-09-22 00:40:57 UTC (rev 9615)
@@ -932,15 +932,15 @@
         Ptr<MgGeometry> gMultiPolygon1 = wktRw.Read(L"MULTIPOLYGON (((30 20, 45 40, 10 40, 30 20)), ((15 5, 40 10, 10 20, 5 10, 15 5)))");
         Ptr<MgGeometry> gMultiPolygon2 = wktRw.Read(L"MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))");
-        LineBuffer lb(8);
         //Point
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gPoint);
             Ptr<MgByteSink> agfSink = new MgByteSink(agf);
             Ptr<MgByte> bytes = agfSink->ToBuffer();
             lb.LoadFromAgf(bytes->Bytes(), bytes->GetLength(), nullptr);
-            CPPUNIT_ASSERT(1 == lb.num_geometries());
+            CPPUNIT_ASSERT(1 == lb.geom_count());
             CPPUNIT_ASSERT(1 == lb.point_count());
             CPPUNIT_ASSERT(30 == lb.x_coord(0));
             CPPUNIT_ASSERT(10 == lb.y_coord(0));
@@ -948,14 +948,13 @@
         //MultiPoint
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gMultiPoint);
-            CPPUNIT_ASSERT(4 == lb.num_geometries());
+            CPPUNIT_ASSERT(1 == lb.geom_count()); //LineBuffer flattens this
             CPPUNIT_ASSERT(4 == lb.point_count());
             CPPUNIT_ASSERT(10 == lb.x_coord(0));
             CPPUNIT_ASSERT(40 == lb.y_coord(0));
@@ -969,8 +968,7 @@
         //LineString
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gLineStr);
@@ -977,7 +975,7 @@
             int lineIdx = 0;
             CPPUNIT_ASSERT(1 == lb.cntr_count());
             CPPUNIT_ASSERT(3 == lb.cntr_size(lineIdx));
@@ -1006,17 +1004,13 @@
         //MultiLineString
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gMultiLineString);
-            CPPUNIT_ASSERT(2 == lb.num_geometries());
-            CPPUNIT_ASSERT(0 == lb.geom_start_cntr(0));
-            CPPUNIT_ASSERT(1 == lb.geom_start_cntr(1));
             CPPUNIT_ASSERT(2 == lb.cntr_count());
             CPPUNIT_ASSERT(3 == lb.cntr_size(0));
             CPPUNIT_ASSERT(4 == lb.cntr_size(1));
@@ -1078,15 +1072,13 @@
         //Polygon 1 (1 outer, 0 inner)
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gPolygon1);
             auto cc = lb.cntr_count();
             CPPUNIT_ASSERT(1 == cc);
@@ -1126,15 +1118,13 @@
         //Polygon 2 (1 outer, 1 inner)
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gPolygon2);
             CPPUNIT_ASSERT(2 == cc);
@@ -1205,16 +1195,13 @@
         //MultiPolygon 1
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gMultiPolygon1);
             auto closed1 = lb.contour_closed(0);
@@ -1287,16 +1274,13 @@
         //MultiPolygon 2
-            lb.Reset();
+            LineBuffer lb(8);
             Ptr<MgByteReader> agf = agfRw.Write(gMultiPolygon2);
             CPPUNIT_ASSERT(3 == cc);
More information about the mapguide-commits mailing list
