[mapguide-commits] r9821 - sandbox/jng/vanilla_swig
    svn_mapguide at osgeo.org
    Fri Dec  4 23:04:11 PST 2020
Author: jng
Date: 2020-12-04 23:04:10 -0800 (Fri, 04 Dec 2020)
New Revision: 9821
Removed:
   sandbox/jng/vanilla_swig/nuget_pack.bat
   sandbox/jng/vanilla_swig/nuget_prepare.bat
Remove obsolete nuget scripts
Deleted: sandbox/jng/vanilla_swig/nuget_pack.bat
--- sandbox/jng/vanilla_swig/nuget_pack.bat	2020-12-04 15:04:46 UTC (rev 9820)
+++ sandbox/jng/vanilla_swig/nuget_pack.bat	2020-12-05 07:04:10 UTC (rev 9821)
@@ -1,10 +0,0 @@
- at echo off
-SET MG_CPU=x86
-IF NOT "%1" == "" SET MG_CPU=%1
-pushd nuget
-nuget pack mapguide-api-base-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-base
-nuget pack mg-desktop-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-desktop
-nuget pack mg-desktop-viewer-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-desktop-viewer
-nuget pack mapguide-api-web-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-web
-nuget pack cs-map-dictionaries.nuspec -BasePath cs-map-dicts
-popd
\ No newline at end of file
Deleted: sandbox/jng/vanilla_swig/nuget_prepare.bat
--- sandbox/jng/vanilla_swig/nuget_prepare.bat	2020-12-04 15:04:46 UTC (rev 9820)
+++ sandbox/jng/vanilla_swig/nuget_prepare.bat	2020-12-05 07:04:10 UTC (rev 9821)
@@ -1,148 +0,0 @@
- at echo off
-rem Top-level build script for mg-desktop
-rem
-rem Author: Jackie Ng (jumpinjackie at gmail.com)
-rem
-rem You must call setenvironment[64].bat first with any appropriate
-rem parameters before calling this script
-SET MG_VERSION=2.4.0.0
-SET MG_CPU=x86
-IF NOT "%1" == "" SET MG_VERSION=%1
-IF NOT "%2" == "" SET MG_CPU=%2
-echo Version: %MG_VERSION%
-echo CPU: %MG_CPU%
-IF "%MG_CPU%" == "x64" (
-    SET TYPEBUILD=release64
-) ELSE (
-SET NUGET_ROOT=%CD%\nuget
-SET NUGET_BASEDIR=%NUGET_ROOT%\%MG_CPU%
-SET NUGET_TARGET=net40
-SET NUGET_BASE_ROOT=%NUGET_BASEDIR%\api-base
-SET NUGET_CONTENT_BASE=%NUGET_BASE_ROOT%\mapguide-api-base
-SET NUGET_LIB_BASE=%NUGET_BASE_ROOT%\lib\%NUGET_TARGET%
-SET NUGET_DESKTOP_ROOT=%NUGET_BASEDIR%\api-desktop
-SET NUGET_CONTENT_DESKTOP=%NUGET_DESKTOP_ROOT%\mg-desktop
-SET NUGET_LIB_DESKTOP=%NUGET_DESKTOP_ROOT%\lib\%NUGET_TARGET%
-SET NUGET_VIEWER_ROOT=%NUGET_BASEDIR%\api-desktop-viewer
-SET NUGET_CONTENT_VIEWER=%NUGET_VIEWER_ROOT%\mg-desktop-viewer
-SET NUGET_LIB_VIEWER=%NUGET_VIEWER_ROOT%\lib\%NUGET_TARGET%
-SET NUGET_WEB_ROOT=%NUGET_BASEDIR%\api-web
-SET NUGET_CONTENT_WEB=%NUGET_WEB_ROOT%\mapguide-api-web
-SET NUGET_LIB_WEB=%NUGET_WEB_ROOT%\lib\%NUGET_TARGET%
-SET NUGET_CSMAP_ROOT=%NUGET_ROOT%\cs-map-dicts
-SET NUGET_CONTENT_CSMAP=%NUGET_CSMAP_ROOT%\dictionaries
-SET WEB_BASEDIR=%CD%\Web\bin\%TYPEBUILD%
-SET DESKTOP_SRC=%CD%\Desktop\MgDesktop
-SET DESKTOP_BASEDIR=%CD%\%TYPEBUILD%\Desktop
-SET SIGNER_ROOT=%CD%\Desktop\DesktopUnmanagedApi\DotNet
-IF NOT EXIST "%DESKTOP_BASEDIR%" (
-    echo mg-desktop base directory not found: %DESKTOP_BASEDIR%
-    goto error
-) ELSE (
-    echo mg-desktop base directory: %DESKTOP_BASEDIR%
-IF NOT EXIST "%WEB_BASEDIR%" (
-    echo MapGuide Web base directory not found: %WEB_BASEDIR%
-    goto error
-) ELSE (
-    echo MapGuide Web base directory: %WEB_BASEDIR%
-IF NOT EXIST "%DESKTOP_BASEDIR%\Dictionaries" (
-    echo CS-Map dictionaries directory not found: "%DESKTOP_BASEDIR%\Dictionaries"
-    goto error
-) ELSE (
-    echo CS-Map dictionaries directory: "%DESKTOP_BASEDIR%\Dictionaries"
-IF NOT EXIST "%SIGNER_ROOT%" (
-    echo Signer root directory not found: %SIGNER_ROOT%
-    goto error
-) ELSE (
-    echo Signer root directory: %SIGNER_ROOT%
-IF NOT EXIST "%NUGET_CONTENT_BASE%" MKDIR "%NUGET_CONTENT_BASE%"
-IF NOT EXIST "%NUGET_CONTENT_DESKTOP%" MKDIR "%NUGET_CONTENT_DESKTOP%"
-IF NOT EXIST "%NUGET_CONTENT_WEB%" MKDIR "%NUGET_CONTENT_WEB%"
-IF NOT EXIST "%NUGET_CONTENT_CSMAP%" MKDIR "%NUGET_CONTENT_CSMAP%"
-echo [install]: Copy api-base files to nuget staging
-xcopy /S /Y "%DESKTOP_BASEDIR%\*" "%NUGET_CONTENT_BASE%" /EXCLUDE:package_excludes.txt+base_package_excludes.txt
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Foundation.dll" "%NUGET_LIB_BASE%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Geometry.dll" "%NUGET_LIB_BASE%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.PlatformBase.dll" "%NUGET_LIB_BASE%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Foundation.xml" "%NUGET_LIB_BASE%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Geometry.xml" "%NUGET_LIB_BASE%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.PlatformBase.xml" "%NUGET_LIB_BASE%"
-echo [install]: Copy api-desktop files to nuget staging
-xcopy /S /Y "%DESKTOP_BASEDIR%\*" "%NUGET_CONTENT_DESKTOP%" /EXCLUDE:package_excludes.txt+desktop_package_excludes.txt
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Desktop.dll" "%NUGET_LIB_DESKTOP%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Desktop.xml" "%NUGET_LIB_DESKTOP%"
-echo [install]: Copy api-web files to nuget staging
-xcopy /Y /I "%WEB_BASEDIR%\MgWebApp.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\MgWebSupport.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\MgHttpHandler.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\MgMapGuideCommon.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\MapGuideCommonUnmanagedApi.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\lib_json.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\WebUnmanagedApi.dll" "%NUGET_CONTENT_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.MapGuideCommon.dll" "%NUGET_LIB_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.Web.dll" "%NUGET_LIB_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.MapGuideCommon.xml" "%NUGET_LIB_WEB%"
-xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.Web.xml" "%NUGET_LIB_WEB%"
-xcopy /Y /I "%SIGNER_ROOT%\SignMapGuideApi.exe" "%NUGET_LIB_WEB%"
-xcopy /Y /I "%SIGNER_ROOT%\maestroapi.key" "%NUGET_LIB_WEB%"
-echo [install]: Copy cs-map dictionaries to nuget staging
-xcopy /S /Y "%DESKTOP_BASEDIR%\Dictionaries\*" "%NUGET_CONTENT_CSMAP%"
-echo [build]: Signing MapGuide API assemblies
-pushd "%NUGET_LIB_WEB%"
-SignMapGuideApi.exe /framework=4.0
-rd /S /Q Backup
-del maestroapi.key
-del SignMapGuideApi.exe
-popd
-echo [install]: Copy api-desktop-viewer files to nuget staging
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.xml" "%NUGET_LIB_VIEWER%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.dll" "%NUGET_LIB_VIEWER%"
-xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.Desktop.dll" "%NUGET_LIB_VIEWER%"
-echo [prepare]: Nuspec files for %MG_VERSION% (%MG_CPU%)
-REM prep nuspec files
-pushd "%NUGET_ROOT%"
-echo [prepare]: mapguide-api-base
-call BatchSubstitute.bat MG_CPU %MG_CPU% mapguide-api-base.nuspec.tpl > temp.txt
-call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mapguide-api-base-%MG_CPU%.nuspec
-echo [prepare]: mapguide-api-web
-call BatchSubstitute.bat MG_CPU %MG_CPU% mapguide-api-web.nuspec.tpl > temp.txt
-call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mapguide-api-web-%MG_CPU%.nuspec
-echo [prepare]: mg-desktop
-call BatchSubstitute.bat MG_CPU %MG_CPU% mg-desktop.nuspec.tpl > temp.txt
-call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mg-desktop-%MG_CPU%.nuspec
-echo [prepare]: mg-desktop-viewer
-call BatchSubstitute.bat MG_CPU %MG_CPU% mg-desktop-viewer.nuspec.tpl > temp.txt
-call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mg-desktop-viewer-%MG_CPU%.nuspec
-echo [prepare]: cs-map-dictionaries
-call BatchSubstitute.bat MG_CPU %MG_CPU% cs-map-dictionaries.nuspec.tpl > temp.txt
-call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > cs-map-dictionaries.nuspec
-del temp.txt
-echo [prepare]: NuGet Package readmes
-type api-base-readme.txt > "%NUGET_BASE_ROOT%\readme.txt"
-type api-desktop-readme.txt > "%NUGET_DESKTOP_ROOT%\readme.txt"
-type "%DESKTOP_SRC%\changelog.txt" >> "%NUGET_DESKTOP_ROOT%\readme.txt"
-type api-desktop-viewer-readme.txt > "%NUGET_VIEWER_ROOT%\readme.txt"
-type "%DESKTOP_SRC%\changelog.txt" >> "%NUGET_VIEWER_ROOT%\readme.txt"
-type api-web-readme.txt > "%NUGET_WEB_ROOT%\readme.txt"
-type cs-map-dict-readme.txt > "%NUGET_CSMAP_ROOT%\readme.txt"
-popd
-echo mg-desktop is ready for nuget packaging and publishing
-goto quit
-:error
-echo [ERROR]: There was an error building the component
-exit /B 1
-:quit
More information about the mapguide-commits
