[mapguide-commits] r9822 - sandbox/jng/vanilla_swig
    svn_mapguide at osgeo.org
    Fri Dec  4 23:04:40 PST 2020
Author: jng
Date: 2020-12-04 23:04:40 -0800 (Fri, 04 Dec 2020)
New Revision: 9822
Removed:
   sandbox/jng/vanilla_swig/build_desktop.bat
   sandbox/jng/vanilla_swig/build_sdk.bat
Remove obsolete build scripts
Deleted: sandbox/jng/vanilla_swig/build_desktop.bat
--- sandbox/jng/vanilla_swig/build_desktop.bat	2020-12-05 07:04:10 UTC (rev 9821)
+++ sandbox/jng/vanilla_swig/build_desktop.bat	2020-12-05 07:04:40 UTC (rev 9822)
@@ -1,49 +0,0 @@
- at echo off
-rem Top-level build script for mg-desktop
-rem
-rem Author: Jackie Ng (jumpinjackie at gmail.com)
-rem
-rem You must call setenvironment[64].bat first with any appropriate
-rem parameters before calling this script
-rem
-rem This script presumes common/oem components have already been built
-rem so you should ideally run this after running build.bat
-SET MG_OUTPUT_DESKTOP=%MG_OUTPUT%\Desktop
-SET MG_OUTPUT_SAMPLES=%MG_OUTPUT%\DesktopSamples
-echo ===================================================
-echo Configuration is [%TYPEBUILD%, "%CONFIGURATION%|%PLATFORM%"]
-echo Output Directory for mg-desktop: %MG_OUTPUT_DESKTOP%
-echo Output Directory for samples: %MG_OUTPUT_SAMPLES%
-echo CPU cores: %CPU_CORES%
-pushd Desktop
-echo [build]: Desktop API (%PLATFORM%, %CONFIGURATION%)
-%MSBUILD% /p:Platform=%PLATFORM% /p:Configuration=%CONFIGURATION% MgDesktopApi.sln
-if "%errorlevel%"=="1" goto error
-echo [build]: .net components (%PLATFORM%)
-%MSBUILD% /p:Platform=%PLATFORM_CLR% /p:Configuration=%CONFIGURATION% MgDesktopDotNet.sln
-popd
-echo [install]: binaries
-%XCOPY% "Desktop\bin\%TYPEBUILD%" "%MG_OUTPUT_DESKTOP%" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
-pushd "%MG_OUTPUT_DESKTOP%"
-REM Remove WebTier stuff that has no place in mg-desktop
-if exist MgMapGuideCommon.dll del MgMapGuideCommon.dll
-if exist OSGeo.MapGuide.MapGuideCommon.xml del OSGeo.MapGuide.MapGuideCommon.xml
-if exist OSGeo.MapGuide.Web.xml del OSGeo.MapGuide.Web.xml
-if exist Backup rd /S /Q Backup
-popd
-echo [install]: Samples
-pushd Desktop
-%XCOPY% Samples "%MG_OUTPUT_SAMPLES%" /EXCLUDE:samples_exclude.txt
-popd
-goto quit
-:error
-echo [ERROR]: There was an error building the component
-exit /B 1
-:quit
\ No newline at end of file
Deleted: sandbox/jng/vanilla_swig/build_sdk.bat
--- sandbox/jng/vanilla_swig/build_sdk.bat	2020-12-05 07:04:10 UTC (rev 9821)
+++ sandbox/jng/vanilla_swig/build_sdk.bat	2020-12-05 07:04:40 UTC (rev 9822)
@@ -1,424 +0,0 @@
- at echo off
-rem MapGuide SDK build script for windows
-rem
-rem
-rem This script will build a subset of the MapGuide source code, such that an SDK can be produced for developing MapGuide
-rem applications that do not involve the server/web tier.
-rem
-rem Due to a hard dependency on ACE, the entire header collection of the ACE library is also copied to the output include directory
-rem
-rem Before you start, please make sure you have done the following:
-rem
-rem 1) Build the FDO source and place the files in \Oem\FDO (or alternatively download and extract the latest FDO binary sdk)
-rem    with the following structure:
-rem     - Bin\%CONFIG% (where %CONFIG% is debug or release)
-rem		- Inc
-rem		- Lib
-rem
-rem 2) Download and install the following:
-rem     - doxygen (http://www.doxygen.org)
-rem
-rem 3) Change the values of DOXYGEN to match the paths of your Doxygen installations respectively
-rem
-rem For a "cleaner" build experience, run this script from an exported copy of the
-rem MapGuide source code (ie. without subversion folders).
-rem
-rem Usage:
-rem
-rem build.bat [-h]
-rem           [-v]
-rem	          [-c=BuildType]
-rem           [-a=Action]
-rem           [-o=OutputDirectory]
-rem
-rem BuildType: Release(default), Debug
-rem Action: build(default), install, clean
-rem OutputDirectory: The directory where files will be copied to if -a=install, if -o=default or -o=def then
-rem files will be copied to %MG_DEFAULT_INSTALLDIR%
-rem ==================================================
-rem Top-level vars
-SET OLDPATH=%PATH%
-SET TYPEACTION=build
-SET TYPEBUILD=Release
-rem There are no components in an SDK build. Everything must be built! DO NOT CHANGE!
-SET TYPECOMPONENT=all
-rem MapGuide vars
-SET MG_DEV=%CD%
-SET MG_OEM=%MG_DEV%\Oem
-SET MG_COMMON=%MG_DEV%\Common
-SET MG_DOC=%MG_DEV%\Doc
-SET MG_WEB=%MG_DEV%\Web
-SET MG_WEB_SRC=%MG_WEB%\src
-SET MG_WEB_BIN=%MG_WEB%\bin
-SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
-SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples\phpsamples
-SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
-SET MG_SDK_OUTPUT=%MG_DEV%\SDK\%TYPEBUILD%
-SET MG_SDK_BIN=%MG_SDK_OUTPUT%\Bin
-SET MG_SDK_LIB=%MG_SDK_OUTPUT%\Lib
-SET MG_SDK_INC=%MG_SDK_OUTPUT%\Inc
-SET MG_SDK_FDO=%MG_SDK_OUTPUT%\Fdo
-SET MG_BUILD_COMPONENT=
-SET MG_ERROR=0
-rem MSBuild Settings
-rem If the NUMBER_OF_PROCESSORS environment variable is wrong for any reason. Change this value.
-SET CPU_CORES=%NUMBER_OF_PROCESSORS%
-rem Uncomment the line below to enable msbuild logging
-rem SET MSBUILD_LOG=/l:FileLogger,Microsoft.Build.Engine;logfile=Build.log;verbosity=diagnostic
-SET MSBUILD_VERBOSITY=/v:q
-rem Command aliases
-rem SET XCOPY=xcopy /E /Y /I /F
-SET XCOPY=xcopy /E /Y /I /Q
-SET XCOPY_SINGLE=xcopy /Y /I /Q
-SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
-SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /t:Clean %MSBUILD_VERBOSITY%
-rem Parameter Handling
-:study_params
-if (%1)==() goto pre_build_check
-if "%1"=="-help"    goto help_show
-if "%1"=="-h"       goto help_show
-if "%1"=="-c"       goto get_conf
-if "%1"=="-config"  goto get_conf
-if "%1"=="-a"       goto get_action
-if "%1"=="-action"  goto get_action
-if "%1"=="-v"       goto get_verbose
-if "%1"=="-o"       goto get_output
-goto custom_error
-:next_param
-shift
-shift
-goto study_params
-:get_verbose
-SET MSBUILD_VERBOSITY=/v:d
-goto next_param
-:get_output
-SET MG_OUTPUT=%2
-if "%2" == "default" SET MG_OUTPUT=%MG_DEV%
-if "%2" == "def" SET MG_OUTPUT=%MG_DEV%
-SET MG_SDK_OUTPUT=%MG_OUTPUT%\SDK\%TYPEBUILD%
-goto next_param
-:get_conf
-SET TYPEBUILD=%2
-SET MG_OUTPUT=%MG_DEV%\%TYPEBUILD%
-SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
-SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
-if "%2"=="Release" goto next_param
-if "%2"=="Debug" goto next_param
-SET ERRORMSG=Unrecognised configuration: %2
-goto custom_error
-:get_action
-SET TYPEACTION=%2
-if "%2"=="build" goto next_param
-if "%2"=="clean" goto next_param
-if "%2"=="install" goto next_param
-SET ERRORMSG=Unrecognised action: %2
-goto custom_error
-rem Check Environment Vars
-:pre_build_check
-rem :check_java
-rem if exist "%JAVA_HOME%" goto check_ant
-rem SET ERRORMSG=Unable to find java sdk installation. Please install the java sdk and set the JAVA_HOME environment variable
-rem goto custom_error_no_help
-rem :check_ant
-rem if exist "%ANT_HOME%" goto check_fdo
-rem SET ERRORMSG=Unable to find Apache ant installation. Please install apache ant and set the ANT_HOME environment variable
-:check_fdo
-:check_fdo_bin
-if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto check_fdo_inc
-SET ERRORMSG=Unable to find FDO binaries. Copy the FDO binaries %MG_OEM%\FDO\Bin\%TYPEBUILD%
-goto custom_error_no_help
-:check_fdo_inc
-if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto check_fdo_lib
-SET ERRORMSG=Unable to find FDO headers. Copy the FDO headers into %MG_OEM%\Inc
-:check_fdo_lib
-if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto start_build
-SET ERRORMSG=Unable to find FDO lib files. Copy the FDO lib files into %MG_OEM%\Lib
-:start_build
-echo Configuration is [%TYPEBUILD%]
-echo Action is [%TYPEACTION%] on [%TYPECOMPONENT%]
-echo Deployment Directory for SDK: %MG_SDK_OUTPUT%
-if "%TYPEACTION%"=="build" goto build
-if "%TYPEACTION%"=="clean" goto clean
-if "%TYPEACTION%"=="install" goto install
-:clean
-if "%TYPECOMPONENT%"=="oem" goto clean_oem
-if "%TYPECOMPONENT%"=="common" goto clean_common
-if "%TYPECOMPONENT%"=="server" goto clean_server
-if "%TYPECOMPONENT%"=="web" goto clean_web
-if "%TYPECOMPONENT%"=="doc" goto clean_doc
-:clean_oem
-echo [clean]: Clean Oem
-%MSBUILD_CLEAN% %MG_OEM%\Oem.sln
-echo [clean]: Clean Oem - CS-Map
-%MSBUILD_CLEAN% %MG_OEM%\CSMap\CsMapDev\VC90\OpenSource.sln
-if not "%TYPECOMPONENT%"=="all" goto quit
-:clean_common
-echo [clean]: Clean Common
-%MSBUILD_CLEAN% %MG_COMMON%\Common.sln
-rem if not "%TYPECOMPONENT%"=="all" goto quit
-goto quit
-rem :clean_doc
-rem echo [clean]: Clean Doc
-rem if exist %MG_DOC_OUTPUT% rd /S /Q %MG_DOC_OUTPUT%
-rem goto quit
-rem =======================================================
-rem Build Targets.... the all targets just carry on
-:build
-if "%TYPECOMPONENT%"=="oem" goto build_oem
-if "%TYPECOMPONENT%"=="common" goto build_common
-if "%TYPECOMPONENT%"=="server" goto build_server
-if "%TYPECOMPONENT%"=="web" goto build_web
-if "%TYPECOMPONENT%"=="doc" goto build_doc
-if "%TYPECOMPONENT%"=="all" goto build_oem
-if "%TYPECOMPONENT%"=="allnodoc" goto build_oem
-SET ERRORMSG=Unrecognised component: %TYPECOMPONENT%
-goto custom_error
-:build_oem
-echo [build]: Building Oem
-%MSBUILD% %MG_OEM%\Oem.sln
-rem CsMap is not in Oem.sln, so we need to build that separately
-echo [build]: Building Oem - CSMap
-%MSBUILD% %MG_OEM%\CSMap\CsMapDev\VC90\OpenSource.sln
-:build_common
-echo [build]: Building Common
-%MSBUILD% %MG_COMMON%\Common.sln
-:build_web
-rem Shortcut method. Takes longer, but we get the SWIG'd binaries GUARANTEED!
-echo [build]: Building Web Tier
-%MSBUILD% "%MG_WEB_SRC%\WebTier.sln"
-rem :build_swig
-rem echo [build]: SWIG wrappers - Unmanaged
-rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\Foundation\FoundationApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\Geometry\GeometryApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\MapGuideCommon\MapGuideCommonApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\PlatformBase\PlatformBaseApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\Web\WebApi.vcproj"
-rem echo [build]: SWIG wrappers - .net assemblies
-rem %MSBUILD% "%MG_WEB%\DotNetApi\Foundation\FoundationDotNetApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetApi\Geometry\GeometryDotNetApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetApi\MapGuideCommon\MapGuideCommonDotNetApi.vcproj"
-rem %MSBUILD% "%MG_WEB%\DotNetApi\PlatformBase\PlatformBaseDotNetApi.vcproj"
-rem :build_web
-rem echo [build]: Building Web Tier
-rem %MSBUILD% %MG_WEB_SRC%\WebTier.sln
-rem if "%errorlevel%"=="1" goto error
-rem if "%TYPECOMPONENT%"=="oem" 	 goto quit
-rem if "%TYPECOMPONENT%"=="common" 	 goto quit
-rem if "%TYPECOMPONENT%"=="server" 	 goto quit
-rem if "%TYPECOMPONENT%"=="web" 	 goto quit
-rem if "%TYPECOMPONENT%"=="doc" 	 goto quit
-rem if "%TYPECOMPONENT%"=="allnodoc" goto quit
-rem this is left out with component allnodoc
-rem :build_doc
-rem echo [build]: Building Doc
-rem pushd %MG_DOC%
-rem call MgOpenSource_run_doxygen.bat
-rem popd
-rem goto quit
-rem INSTALL Targets.... the all targets just carry on
-:install
-:install_sdk
-echo [install]: SDK
-if not exist "%MG_SDK_BIN%" mkdir "%MG_SDK_BIN%"
-if not exist "%MG_SDK_LIB%" mkdir "%MG_SDK_LIB%"
-if not exist "%MG_SDK_INC%" mkdir "%MG_SDK_INC%"
-echo [install]: SDK - Oem (ACE)
-rem ACE
-copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.dll" "%MG_SDK_BIN%"
-copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.pdb" "%MG_SDK_BIN%"
-copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.lib" "%MG_SDK_LIB%"
-rem Due to ACE headers being leaked out in public MG headers, we need these too
-%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.h" "%MG_SDK_INC%\ACE_wrappers\ACE" /EXCLUDE:svn_excludes.txt
-%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.inl" "%MG_SDK_INC%\ACE_wrappers\ACE" /EXCLUDE:svn_excludes.txt
-%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.cpp" "%MG_SDK_INC%\ACE_wrappers\ACE" /EXCLUDE:svn_excludes.txt
-echo [install]: SDK - Oem (GEOS)
-rem Same with GEOS
-copy /Y "%MG_OEM%\geos\VisualStudio\%TYPEBUILD%\GEOS.dll" "%MG_SDK_BIN%"
-copy /Y "%MG_OEM%\geos\VisualStudio\%TYPEBUILD%\GEOS.pdb" "%MG_SDK_BIN%"
-echo [install]: SDK - Oem (xerces)
-rem Same with xerces
-copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3_1mg.dll" "%MG_SDK_BIN%"
-copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3_1mg.pdb" "%MG_SDK_BIN%"
-copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3mg.lib" "%MG_SDK_LIB%"
-%XCOPY% /S "%MG_OEM%\dbxml\xerces-c-src\src\*.h" "%MG_SDK_INC%\xerces" /EXCLUDE:svn_excludes.txt
-%XCOPY% /S "%MG_OEM%\dbxml\xerces-c-src\src\*.hpp" "%MG_SDK_INC%\xerces" /EXCLUDE:svn_excludes.txt
-%XCOPY% /S "%MG_OEM%\dbxml\xerces-c-src\src\*.c" "%MG_SDK_INC%\xerces" /EXCLUDE:svn_excludes.txt
-echo [install]: SDK - Oem (DWF Toolkit)
-rem DWF Toolkit isn't technically required, but it's hard to implement your own MgDrawingService without it
-%XCOPY% /S "%MG_OEM%\DWFTK7.1\develop\global\lib\static\%TYPEBUILD%\vc8.0\*.lib" "%MG_SDK_LIB%\dwftk"
-%XCOPY% /S "%MG_OEM%\DWFTK7.1\develop\global\src\dwf\*.*" "%MG_SDK_INC%\DWFTK7.1\dwf" /EXCLUDE:svn_excludes.txt
-%XCOPY% /S "%MG_OEM%\DWFTK7.1\develop\global\src\dwfcore\*.*" "%MG_SDK_INC%\DWFTK7.1\dwfcore" /EXCLUDE:svn_excludes.txt
-%XCOPY% /S "%MG_OEM%\DWFTK7.1\develop\global\src\dwfemap\*.*" "%MG_SDK_INC%\DWFTK7.1\dwfemap" /EXCLUDE:svn_excludes.txt
-echo [install]: SDK - FDO
-rem FDO SDK. Copy each subdir into each respective "Fdo" subdirectory to distinguish FDO files from MG files
-%XCOPY% "%MG_OEM%\FDO\bin\%TYPEBUILD%" "%MG_SDK_BIN%\Fdo"
-%XCOPY% "%MG_OEM%\FDO\Inc" "%MG_SDK_INC%\Fdo"
-%XCOPY% "%MG_OEM%\FDO\Lib" "%MG_SDK_LIB%\Fdo"
-echo [install]: SDK - MG Common
-rem Common binaries
-copy /Y "%MG_COMMON%\bin\%TYPEBUILD%\*.dll" "%MG_SDK_BIN%
-copy /Y "%MG_COMMON%\lib\%TYPEBUILD%\*.lib" "%MG_SDK_LIB%
-copy /Y "%MG_COMMON%\bin\%TYPEBUILD%\*.pdb" "%MG_SDK_BIN%
-rem GD binary (required by Renderers)
-copy /Y "%MG_OEM%\gd\build\win32\gd\%TYPEBUILD%\gd.dll" "%MG_SDK_BIN%
-copy /Y "%MG_OEM%\gd\build\win32\gd\%TYPEBUILD%\gd.pdb" "%MG_SDK_BIN%
-rem Foundation
-if not exist "%MG_SDK_INC%\Foundation" mkdir "%MG_SDK_INC%\Foundation"
-%XCOPY% /S "%MG_COMMON%\Foundation\*.h" "%MG_SDK_INC%\Foundation" /EXCLUDE:svn_excludes.txt
-rem Geometry
-if not exist "%MG_SDK_INC%\Geometry" mkdir "%MG_SDK_INC%\Geometry"
-%XCOPY% /S "%MG_COMMON%\Geometry\*.h" "%MG_SDK_INC%\Geometry" /EXCLUDE:svn_excludes.txt
-rem MdfModel
-if not exist "%MG_SDK_INC%\MdfModel" mkdir "%MG_SDK_INC%\MdfModel"
-%XCOPY% /S "%MG_COMMON%\MdfModel\*.h" "%MG_SDK_INC%\MdfModel" /EXCLUDE:svn_excludes.txt
-rem MdfParser
-if not exist "%MG_SDK_INC%\MdfParser" mkdir "%MG_SDK_INC%\MdfParser"
-%XCOPY% /S "%MG_COMMON%\MdfParser\*.h" "%MG_SDK_INC%\MdfParser" /EXCLUDE:svn_excludes.txt
-rem PlatformBase
-if not exist "%MG_SDK_INC%\PlatformBase" mkdir "%MG_SDK_INC%\PlatformBase"
-%XCOPY% /S "%MG_COMMON%\PlatformBase\*.h" "%MG_SDK_INC%\PlatformBase" /EXCLUDE:svn_excludes.txt
-rem Renderers
-if not exist "%MG_SDK_INC%\Renderers" mkdir "%MG_SDK_INC%\Renderers"
-%XCOPY% /S "%MG_COMMON%\Renderers\*.h" "%MG_SDK_INC%\Renderers" /EXCLUDE:svn_excludes.txt
-rem Schema
-if not exist "%MG_SDK_INC%\Schema" mkdir "%MG_SDK_INC%\Schema"
-%XCOPY% "%MG_COMMON%\Schema" "%MG_SDK_INC%\Schema" /EXCLUDE:svn_excludes.txt
-rem Stylization
-if not exist "%MG_SDK_INC%\Stylization" mkdir "%MG_SDK_INC%\Stylization"
-%XCOPY% /S "%MG_COMMON%\Stylization\*.h" "%MG_SDK_INC%\Stylization" /EXCLUDE:svn_excludes.txt
-rem Delete some stuff that should not be there
-pushd "%MG_SDK_BIN%"
-del GeometryConsoleTest.pdb
-popd
-goto quit
-:error
-exit /B 1
-:custom_error_no_help
-echo [ERROR]: %ERRORMSG%
-SET ERRORMSG=
-exit /B 1
-:custom_error
-SET ERRORMSG=
-echo Please use the format:
-:help_show
-echo ************************************************************************
-echo build.bat [-h]
-echo           [-v]
-echo           [-c=BuildType]
-echo           [-w=Component]
-echo           [-a=Action]
-echo           [-o=OutputDirectory]
-echo Help:                  -h[elp]
-echo Verbose:               -v
-echo BuildType:             -c[onfig]=Release(default), Debug
-echo Action:                -a[ction]=build(default),
-echo                                  install,
-echo                                  clean,
-echo Component:             -w[ith]=all(default),
-echo                                oem,
-echo                                common,
-echo                                server,
-echo                                web,
-echo                                doc
-:quit
-SET TYPEACTION=
-SET TYPEBUILD=
-SET MG_OUTPUT=
-SET MG_DEV=
-SET MG_INSTALLER=
-SET MG_OEM=
-SET MG_SERVER=
-SET MG_WEB=
-SET MG_WEB_SRC=
-SET MG_WEB_BIN=
-SET MG_UNIT_TEST=
-SET MG_FUSION=
-SET MG_DOC=
-SET MG_DOC_OUTPUT=
-SET MG_ERROR=
-SET MSBUILD_LOG=
-SET XCOPY=
-SET MSBUILD=
-SET PATH=%OLDPATH%
More information about the mapguide-commits
