[mapguide-commits] r9802 - in sandbox/jng/vanilla_swig/Bindings/src: Managed/DotNet/Common Managed/DotNet/MapGuideDotNetApi Managed/DotNet/MapGuideDotNetApi/custom SwigCommon/DotNet Test/DotNet/src/TestMapGuideApi/ExternalTests Test/DotNet/src/TestMisc Tools/ClassMapGen Tools/ClassMapGen/Data/Templates
    svn_mapguide at osgeo.org
    Sat Nov 21 07:32:08 PST 2020
Author: jng
Date: 2020-11-21 07:32:08 -0800 (Sat, 21 Nov 2020)
New Revision: 9802
Removed:
   sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/custom/MgClassMap.cs
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs
   sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs
   sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj
   sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs
   sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt
   sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs
Rework class map setup on .net so that it mirrors its java ObjectFactory counterpart, which is that we don't build a dictionary of class id -> class name, which then requires a class id -> class name -> .net type constructor lookup at runtime.
Instead build a dictionary of class id -> .net type constructor. If we missed a class, it will manifest as an exception in MgClassMap's static ctor rather than fail later on.
By doing this, we have effectively replicated the class id sanity test (the act of successfully obtaining a .net type constructor *is* testing that said class exists in .net) and as a result that test is now redundant, so it has been removed from the .net test suite.
We also have a nice benefit of avoiding having to do repeated .net assembly/constructor lookups on every MgObjectFactory.CreateObject() invocation as that is now all cached in the auto-generated MgClassMap.
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs	2020-11-21 15:32:08 UTC (rev 9802)
@@ -2,242 +2,264 @@
 using System;
 using System.Collections.Generic;
+using System.Linq;
+using System.Reflection;
 namespace OSGeo.MapGuide
     internal static class MgClassMap
-        //TODO: We should take a page out of the java binding and convert this to a
-        //Dictionary<int, ConstructorInfo>. This would save us having to do repeated lookups
-        //for this information. Also it would serve as a fail-early sanity check that we are
-        //not registering class ids of classes that are not actual classes (eg. Classes with
-        //constants should not be here)
-        static Dictionary<int, string> classNameMap;
+        static HashSet<string> assemblyNames;
+        static Dictionary<int, ConstructorInfo> classIdCtorMap;
         static Dictionary<string, int> nameClassMap;
         static MgClassMap()
-            classNameMap = new Dictionary<int, string>();
+            assemblyNames = new HashSet<string>
+                "OSGeo.MapGuide.Foundation",
+                "OSGeo.MapGuide.Geometry",
+                "OSGeo.MapGuide.PlatformBase",
+                "OSGeo.MapGuide.MapGuideCommon",
+                "OSGeo.MapGuide.Web",
+                "OSGeo.MapGuide.Portable"
+            classIdCtorMap = new Dictionary<int, ConstructorInfo>();
+            var classNameMap = new Dictionary<int, string>();
             nameClassMap = new Dictionary<string, int>();
-            classNameMap[20004] = "OSGeo.MapGuide.MgAgfReaderWriter";
-            classNameMap[20005] = "OSGeo.MapGuide.MgAggregateGeometry";
-            classNameMap[20006] = "OSGeo.MapGuide.MgArcSegment";
-            classNameMap[1005] = "OSGeo.MapGuide.MgBatchPropertyCollection";
-            classNameMap[10252] = "OSGeo.MapGuide.MgBlobProperty";
-            classNameMap[10253] = "OSGeo.MapGuide.MgBooleanProperty";
-            classNameMap[10254] = "OSGeo.MapGuide.MgByteProperty";
-            classNameMap[1250] = "OSGeo.MapGuide.MgByteReader";
-            classNameMap[1257] = "OSGeo.MapGuide.MgByteSink";
-            classNameMap[1251] = "OSGeo.MapGuide.MgByteSource";
-            classNameMap[11750] = "OSGeo.MapGuide.MgClassDefinition";
-            classNameMap[11780] = "OSGeo.MapGuide.MgClassDefinitionCollection";
-            classNameMap[10255] = "OSGeo.MapGuide.MgClobProperty";
-            classNameMap[10250] = "OSGeo.MapGuide.MgColor";
-            classNameMap[20003] = "OSGeo.MapGuide.MgCoordinate";
-            classNameMap[20008] = "OSGeo.MapGuide.MgCoordinateCollection";
-            classNameMap[20009] = "OSGeo.MapGuide.MgCoordinateIterator";
-            classNameMap[20500] = "OSGeo.MapGuide.MgCoordinateSystem";
-            classNameMap[20504] = "OSGeo.MapGuide.MgCoordinateSystemCatalog";
-            classNameMap[20506] = "OSGeo.MapGuide.MgCoordinateSystemCategory";
-            classNameMap[20510] = "OSGeo.MapGuide.MgCoordinateSystemCategoryDictionary";
-            classNameMap[20507] = "OSGeo.MapGuide.MgCoordinateSystemDatum";
-            classNameMap[20512] = "OSGeo.MapGuide.MgCoordinateSystemDatumDictionary";
-            classNameMap[20511] = "OSGeo.MapGuide.MgCoordinateSystemDictionary";
-            classNameMap[20521] = "OSGeo.MapGuide.MgCoordinateSystemDictionaryUtility";
-            classNameMap[20509] = "OSGeo.MapGuide.MgCoordinateSystemEllipsoid";
-            classNameMap[20513] = "OSGeo.MapGuide.MgCoordinateSystemEllipsoidDictionary";
-            classNameMap[20514] = "OSGeo.MapGuide.MgCoordinateSystemEnum";
-            classNameMap[20515] = "OSGeo.MapGuide.MgCoordinateSystemEnumInteger32";
-            classNameMap[20501] = "OSGeo.MapGuide.MgCoordinateSystemFactory";
-            classNameMap[20516] = "OSGeo.MapGuide.MgCoordinateSystemFilter";
-            classNameMap[20517] = "OSGeo.MapGuide.MgCoordinateSystemFilterInteger32";
-            classNameMap[20505] = "OSGeo.MapGuide.MgCoordinateSystemFormatConverter";
-            classNameMap[20542] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticAnalyticalTransformDefParams";
-            classNameMap[20543] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticInterpolationTransformDefParams";
-            classNameMap[20544] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams";
-            classNameMap[20533] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticPath";
-            classNameMap[20535] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticPathDictionary";
-            classNameMap[20534] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticPathElement";
-            classNameMap[20546] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticStandaloneTransformDefParams";
-            classNameMap[20508] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformation";
-            classNameMap[20536] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef";
-            classNameMap[20540] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefDictionary";
-            classNameMap[20541] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams";
-            classNameMap[20545] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformGridFile";
-            classNameMap[20532] = "OSGeo.MapGuide.MgCoordinateSystemGridBase";
-            classNameMap[20524] = "OSGeo.MapGuide.MgCoordinateSystemGridBoundary";
-            classNameMap[20529] = "OSGeo.MapGuide.MgCoordinateSystemGridLine";
-            classNameMap[20526] = "OSGeo.MapGuide.MgCoordinateSystemGridLineCollection";
-            classNameMap[20530] = "OSGeo.MapGuide.MgCoordinateSystemGridRegion";
-            classNameMap[20527] = "OSGeo.MapGuide.MgCoordinateSystemGridRegionCollection";
-            classNameMap[20525] = "OSGeo.MapGuide.MgCoordinateSystemGridSpecification";
-            classNameMap[20531] = "OSGeo.MapGuide.MgCoordinateSystemGridTick";
-            classNameMap[20528] = "OSGeo.MapGuide.MgCoordinateSystemGridTickCollection";
-            classNameMap[20518] = "OSGeo.MapGuide.MgCoordinateSystemMathComparator";
-            classNameMap[20502] = "OSGeo.MapGuide.MgCoordinateSystemMeasure";
-            classNameMap[20522] = "OSGeo.MapGuide.MgCoordinateSystemMgrs";
-            classNameMap[20520] = "OSGeo.MapGuide.MgCoordinateSystemProjectionInformation";
-            classNameMap[20503] = "OSGeo.MapGuide.MgCoordinateSystemTransform";
-            classNameMap[20519] = "OSGeo.MapGuide.MgCoordinateSystemUnitInformation";
-            classNameMap[20048] = "OSGeo.MapGuide.MgCoordinateXY";
-            classNameMap[20051] = "OSGeo.MapGuide.MgCoordinateXYM";
-            classNameMap[20049] = "OSGeo.MapGuide.MgCoordinateXYZ";
-            classNameMap[20050] = "OSGeo.MapGuide.MgCoordinateXYZM";
-            classNameMap[20010] = "OSGeo.MapGuide.MgCurve";
-            classNameMap[20011] = "OSGeo.MapGuide.MgCurvePolygon";
-            classNameMap[20047] = "OSGeo.MapGuide.MgCurvePolygonCollection";
-            classNameMap[20012] = "OSGeo.MapGuide.MgCurveRing";
-            classNameMap[20052] = "OSGeo.MapGuide.MgCurveRingCollection";
-            classNameMap[20013] = "OSGeo.MapGuide.MgCurveSegment";
-            classNameMap[20041] = "OSGeo.MapGuide.MgCurveSegmentCollection";
-            classNameMap[20014] = "OSGeo.MapGuide.MgCurveString";
-            classNameMap[20043] = "OSGeo.MapGuide.MgCurveStringCollection";
-            classNameMap[11751] = "OSGeo.MapGuide.MgDataPropertyDefinition";
-            classNameMap[11773] = "OSGeo.MapGuide.MgDataReader";
-            classNameMap[1256] = "OSGeo.MapGuide.MgDateTime";
-            classNameMap[10256] = "OSGeo.MapGuide.MgDateTimeProperty";
-            classNameMap[11775] = "OSGeo.MapGuide.MgDeleteFeatures";
-            classNameMap[2251] = "OSGeo.MapGuide.MgDisposable";
-            classNameMap[1000] = "OSGeo.MapGuide.MgDisposableCollection";
-            classNameMap[10257] = "OSGeo.MapGuide.MgDoubleProperty";
-            classNameMap[30700] = "OSGeo.MapGuide.MgDrawingService";
-            classNameMap[30901] = "OSGeo.MapGuide.MgDwfVersion";
-            classNameMap[20001] = "OSGeo.MapGuide.MgEnvelope";
-            classNameMap[1515] = "OSGeo.MapGuide.MgException";
-            classNameMap[11772] = "OSGeo.MapGuide.MgFeatureAggregateOptions";
-            classNameMap[11774] = "OSGeo.MapGuide.MgFeatureCommandCollection";
-            classNameMap[31001] = "OSGeo.MapGuide.MgFeatureInformation";
-            classNameMap[11764] = "OSGeo.MapGuide.MgFeatureProperty";
-            classNameMap[11771] = "OSGeo.MapGuide.MgFeatureQueryOptions";
-            classNameMap[11753] = "OSGeo.MapGuide.MgFeatureReader";
-            classNameMap[11778] = "OSGeo.MapGuide.MgFeatureSchema";
-            classNameMap[11779] = "OSGeo.MapGuide.MgFeatureSchemaCollection";
-            classNameMap[11754] = "OSGeo.MapGuide.MgFeatureService";
-            classNameMap[11786] = "OSGeo.MapGuide.MgFileFeatureSourceParams";
-            classNameMap[20016] = "OSGeo.MapGuide.MgGeometricEntity";
-            classNameMap[11756] = "OSGeo.MapGuide.MgGeometricPropertyDefinition";
-            classNameMap[11757] = "OSGeo.MapGuide.MgGeometry";
-            classNameMap[20020] = "OSGeo.MapGuide.MgGeometryCollection";
-            classNameMap[20021] = "OSGeo.MapGuide.MgGeometryComponent";
-            classNameMap[20002] = "OSGeo.MapGuide.MgGeometryFactory";
-            classNameMap[11758] = "OSGeo.MapGuide.MgGeometryProperty";
-            classNameMap[20054] = "OSGeo.MapGuide.MgGeometrySimplifier";
-            classNameMap[11785] = "OSGeo.MapGuide.MgGeometryTypeInfo";
-            classNameMap[11782] = "OSGeo.MapGuide.MgGwsFeatureReader";
-            classNameMap[40000] = "OSGeo.MapGuide.MgHttpHeader";
-            classNameMap[40006] = "OSGeo.MapGuide.MgHttpPrimitiveValue";
-            classNameMap[40004] = "OSGeo.MapGuide.MgHttpRequest";
-            classNameMap[40002] = "OSGeo.MapGuide.MgHttpRequestMetadata";
-            classNameMap[40001] = "OSGeo.MapGuide.MgHttpRequestParam";
-            classNameMap[40005] = "OSGeo.MapGuide.MgHttpResponse";
-            classNameMap[40003] = "OSGeo.MapGuide.MgHttpResult";
-            classNameMap[11776] = "OSGeo.MapGuide.MgInsertFeatures";
-            classNameMap[10258] = "OSGeo.MapGuide.MgInt16Property";
-            classNameMap[10259] = "OSGeo.MapGuide.MgInt32Property";
-            classNameMap[10260] = "OSGeo.MapGuide.MgInt64Property";
-            classNameMap[10000] = "OSGeo.MapGuide.MgIntCollection";
-            classNameMap[31300] = "OSGeo.MapGuide.MgKmlService";
-            classNameMap[30501] = "OSGeo.MapGuide.MgLayer";
-            classNameMap[12003] = "OSGeo.MapGuide.MgLayerBase";
-            classNameMap[12002] = "OSGeo.MapGuide.MgLayerCollection";
-            classNameMap[12001] = "OSGeo.MapGuide.MgLayerGroup";
-            classNameMap[12004] = "OSGeo.MapGuide.MgLayerGroupCollection";
-            classNameMap[30904] = "OSGeo.MapGuide.MgLayout";
-            classNameMap[20023] = "OSGeo.MapGuide.MgLinearRing";
-            classNameMap[20053] = "OSGeo.MapGuide.MgLinearRingCollection";
-            classNameMap[20024] = "OSGeo.MapGuide.MgLinearSegment";
-            classNameMap[20042] = "OSGeo.MapGuide.MgLineString";
-            classNameMap[20044] = "OSGeo.MapGuide.MgLineStringCollection";
-            classNameMap[11766] = "OSGeo.MapGuide.MgLongTransactionReader";
-            classNameMap[30500] = "OSGeo.MapGuide.MgMap";
-            classNameMap[12000] = "OSGeo.MapGuide.MgMapBase";
-            classNameMap[12005] = "OSGeo.MapGuide.MgMapCollection";
-            classNameMap[30900] = "OSGeo.MapGuide.MgMappingService";
-            classNameMap[30905] = "OSGeo.MapGuide.MgMapPlot";
-            classNameMap[30906] = "OSGeo.MapGuide.MgMapPlotCollection";
-            classNameMap[20027] = "OSGeo.MapGuide.MgMeasure";
-            classNameMap[31003] = "OSGeo.MapGuide.MgMetatile";
-            classNameMap[20029] = "OSGeo.MapGuide.MgMultiCurvePolygon";
-            classNameMap[20030] = "OSGeo.MapGuide.MgMultiCurveString";
-            classNameMap[20031] = "OSGeo.MapGuide.MgMultiGeometry";
-            classNameMap[20032] = "OSGeo.MapGuide.MgMultiLineString";
-            classNameMap[20033] = "OSGeo.MapGuide.MgMultiPoint";
-            classNameMap[20034] = "OSGeo.MapGuide.MgMultiPolygon";
-            classNameMap[2252] = "OSGeo.MapGuide.MgObject";
-            classNameMap[11759] = "OSGeo.MapGuide.MgObjectPropertyDefinition";
-            classNameMap[30604] = "OSGeo.MapGuide.MgPackageStatusInformation";
-            classNameMap[11788] = "OSGeo.MapGuide.MgParameter";
-            classNameMap[10004] = "OSGeo.MapGuide.MgParameterCollection";
-            classNameMap[30902] = "OSGeo.MapGuide.MgPlotSpecification";
-            classNameMap[20000] = "OSGeo.MapGuide.MgPoint";
-            classNameMap[20045] = "OSGeo.MapGuide.MgPointCollection";
-            classNameMap[20035] = "OSGeo.MapGuide.MgPolygon";
-            classNameMap[20046] = "OSGeo.MapGuide.MgPolygonCollection";
-            classNameMap[20055] = "OSGeo.MapGuide.MgPreparedGeometry";
-            classNameMap[31400] = "OSGeo.MapGuide.MgProfilingService";
-            classNameMap[2000] = "OSGeo.MapGuide.MgProperty";
-            classNameMap[1002] = "OSGeo.MapGuide.MgPropertyCollection";
-            classNameMap[10251] = "OSGeo.MapGuide.MgPropertyDefinition";
-            classNameMap[10001] = "OSGeo.MapGuide.MgPropertyDefinitionCollection";
-            classNameMap[11769] = "OSGeo.MapGuide.MgRaster";
-            classNameMap[11770] = "OSGeo.MapGuide.MgRasterProperty";
-            classNameMap[11768] = "OSGeo.MapGuide.MgRasterPropertyDefinition";
-            classNameMap[12006] = "OSGeo.MapGuide.MgReadOnlyLayerCollection";
-            classNameMap[20037] = "OSGeo.MapGuide.MgRegion";
-            classNameMap[31002] = "OSGeo.MapGuide.MgRenderingOptions";
-            classNameMap[31000] = "OSGeo.MapGuide.MgRenderingService";
-            classNameMap[11526] = "OSGeo.MapGuide.MgResource";
-            classNameMap[11500] = "OSGeo.MapGuide.MgResourceIdentifier";
-            classNameMap[11501] = "OSGeo.MapGuide.MgResourceService";
-            classNameMap[20038] = "OSGeo.MapGuide.MgRing";
-            classNameMap[30502] = "OSGeo.MapGuide.MgSelection";
-            classNameMap[12007] = "OSGeo.MapGuide.MgSelectionBase";
-            classNameMap[30607] = "OSGeo.MapGuide.MgServerAdmin";
-            classNameMap[11251] = "OSGeo.MapGuide.MgService";
-            classNameMap[10261] = "OSGeo.MapGuide.MgSingleProperty";
-            classNameMap[30605] = "OSGeo.MapGuide.MgSite";
-            classNameMap[30601] = "OSGeo.MapGuide.MgSiteConnection";
-            classNameMap[30608] = "OSGeo.MapGuide.MgSiteInfo";
-            classNameMap[11761] = "OSGeo.MapGuide.MgSpatialContextReader";
-            classNameMap[11762] = "OSGeo.MapGuide.MgSqlDataReader";
-            classNameMap[1003] = "OSGeo.MapGuide.MgStringCollection";
-            classNameMap[2001] = "OSGeo.MapGuide.MgStringProperty";
-            classNameMap[10003] = "OSGeo.MapGuide.MgStringPropertyCollection";
-            classNameMap[31200] = "OSGeo.MapGuide.MgTileService";
-            classNameMap[11787] = "OSGeo.MapGuide.MgTransaction";
-            classNameMap[20039] = "OSGeo.MapGuide.MgTransform";
-            classNameMap[11777] = "OSGeo.MapGuide.MgUpdateFeatures";
-            classNameMap[30606] = "OSGeo.MapGuide.MgUserInformation";
-            classNameMap[11257] = "OSGeo.MapGuide.MgWarnings";
-            classNameMap[50005] = "OSGeo.MapGuide.MgWebBufferCommand";
-            classNameMap[50000] = "OSGeo.MapGuide.MgWebCommand";
-            classNameMap[50012] = "OSGeo.MapGuide.MgWebCommandCollection";
-            classNameMap[50015] = "OSGeo.MapGuide.MgWebCommandWidget";
-            classNameMap[50025] = "OSGeo.MapGuide.MgWebContextMenu";
-            classNameMap[50016] = "OSGeo.MapGuide.MgWebFlyoutWidget";
-            classNameMap[50009] = "OSGeo.MapGuide.MgWebGetPrintablePageCommand";
-            classNameMap[50011] = "OSGeo.MapGuide.MgWebHelpCommand";
-            classNameMap[50022] = "OSGeo.MapGuide.MgWebInformationPane";
-            classNameMap[50003] = "OSGeo.MapGuide.MgWebInvokeScriptCommand";
-            classNameMap[50004] = "OSGeo.MapGuide.MgWebInvokeUrlCommand";
-            classNameMap[50026] = "OSGeo.MapGuide.MgWebLayout";
-            classNameMap[50008] = "OSGeo.MapGuide.MgWebMeasureCommand";
-            classNameMap[50007] = "OSGeo.MapGuide.MgWebPrintCommand";
-            classNameMap[50002] = "OSGeo.MapGuide.MgWebSearchCommand";
-            classNameMap[50006] = "OSGeo.MapGuide.MgWebSelectWithinCommand";
-            classNameMap[50014] = "OSGeo.MapGuide.MgWebSeparatorWidget";
-            classNameMap[50023] = "OSGeo.MapGuide.MgWebTaskBar";
-            classNameMap[50017] = "OSGeo.MapGuide.MgWebTaskBarWidget";
-            classNameMap[50024] = "OSGeo.MapGuide.MgWebTaskPane";
-            classNameMap[50021] = "OSGeo.MapGuide.MgWebToolBar";
-            classNameMap[50019] = "OSGeo.MapGuide.MgWebUiPane";
-            classNameMap[50020] = "OSGeo.MapGuide.MgWebUiSizablePane";
-            classNameMap[50001] = "OSGeo.MapGuide.MgWebUiTargetCommand";
-            classNameMap[50010] = "OSGeo.MapGuide.MgWebViewOptionsCommand";
-            classNameMap[50013] = "OSGeo.MapGuide.MgWebWidget";
-            classNameMap[50018] = "OSGeo.MapGuide.MgWebWidgetCollection";
-            classNameMap[20040] = "OSGeo.MapGuide.MgWktReaderWriter";
+            if (HasAssemblyInAppDomain("OSGeo.MapGuide.Foundation")) {
+                classIdCtorMap[1000] = ResolveConstructor("OSGeo.MapGuide.MgDisposableCollection");
+                classIdCtorMap[1002] = ResolveConstructor("OSGeo.MapGuide.MgPropertyCollection");
+                classIdCtorMap[1003] = ResolveConstructor("OSGeo.MapGuide.MgStringCollection");
+                classIdCtorMap[1004] = ResolveConstructor("OSGeo.MapGuide.MgStringPropertyCollection");
+                classIdCtorMap[1005] = ResolveConstructor("OSGeo.MapGuide.MgBatchPropertyCollection");
+                classIdCtorMap[1250] = ResolveConstructor("OSGeo.MapGuide.MgByteReader");
+                classIdCtorMap[1251] = ResolveConstructor("OSGeo.MapGuide.MgByteSource");
+                classIdCtorMap[1256] = ResolveConstructor("OSGeo.MapGuide.MgDateTime");
+                classIdCtorMap[1257] = ResolveConstructor("OSGeo.MapGuide.MgByteSink");
+                classIdCtorMap[1515] = ResolveConstructor("OSGeo.MapGuide.MgException");
+                classIdCtorMap[2000] = ResolveConstructor("OSGeo.MapGuide.MgProperty");
+                classIdCtorMap[2001] = ResolveConstructor("OSGeo.MapGuide.MgStringProperty");
+                classIdCtorMap[2002] = ResolveConstructor("OSGeo.MapGuide.MgPropertyDefinition");
+                classIdCtorMap[2251] = ResolveConstructor("OSGeo.MapGuide.MgDisposable");
+                classIdCtorMap[2252] = ResolveConstructor("OSGeo.MapGuide.MgObject");
+            if (HasAssemblyInAppDomain("OSGeo.MapGuide.Geometry")) {
+                classIdCtorMap[20000] = ResolveConstructor("OSGeo.MapGuide.MgPoint");
+                classIdCtorMap[20001] = ResolveConstructor("OSGeo.MapGuide.MgEnvelope");
+                classIdCtorMap[20002] = ResolveConstructor("OSGeo.MapGuide.MgGeometryFactory");
+                classIdCtorMap[20003] = ResolveConstructor("OSGeo.MapGuide.MgCoordinate");
+                classIdCtorMap[20004] = ResolveConstructor("OSGeo.MapGuide.MgAgfReaderWriter");
+                classIdCtorMap[20005] = ResolveConstructor("OSGeo.MapGuide.MgAggregateGeometry");
+                classIdCtorMap[20006] = ResolveConstructor("OSGeo.MapGuide.MgArcSegment");
+                classIdCtorMap[20008] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateCollection");
+                classIdCtorMap[20009] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateIterator");
+                classIdCtorMap[20010] = ResolveConstructor("OSGeo.MapGuide.MgCurve");
+                classIdCtorMap[20011] = ResolveConstructor("OSGeo.MapGuide.MgCurvePolygon");
+                classIdCtorMap[20012] = ResolveConstructor("OSGeo.MapGuide.MgCurveRing");
+                classIdCtorMap[20013] = ResolveConstructor("OSGeo.MapGuide.MgCurveSegment");
+                classIdCtorMap[20014] = ResolveConstructor("OSGeo.MapGuide.MgCurveString");
+                classIdCtorMap[20016] = ResolveConstructor("OSGeo.MapGuide.MgGeometricEntity");
+                classIdCtorMap[20019] = ResolveConstructor("OSGeo.MapGuide.MgGeometry");
+                classIdCtorMap[20020] = ResolveConstructor("OSGeo.MapGuide.MgGeometryCollection");
+                classIdCtorMap[20021] = ResolveConstructor("OSGeo.MapGuide.MgGeometryComponent");
+                classIdCtorMap[20023] = ResolveConstructor("OSGeo.MapGuide.MgLinearRing");
+                classIdCtorMap[20024] = ResolveConstructor("OSGeo.MapGuide.MgLinearSegment");
+                classIdCtorMap[20027] = ResolveConstructor("OSGeo.MapGuide.MgMeasure");
+                classIdCtorMap[20029] = ResolveConstructor("OSGeo.MapGuide.MgMultiCurvePolygon");
+                classIdCtorMap[20030] = ResolveConstructor("OSGeo.MapGuide.MgMultiCurveString");
+                classIdCtorMap[20031] = ResolveConstructor("OSGeo.MapGuide.MgMultiGeometry");
+                classIdCtorMap[20032] = ResolveConstructor("OSGeo.MapGuide.MgMultiLineString");
+                classIdCtorMap[20033] = ResolveConstructor("OSGeo.MapGuide.MgMultiPoint");
+                classIdCtorMap[20034] = ResolveConstructor("OSGeo.MapGuide.MgMultiPolygon");
+                classIdCtorMap[20035] = ResolveConstructor("OSGeo.MapGuide.MgPolygon");
+                classIdCtorMap[20037] = ResolveConstructor("OSGeo.MapGuide.MgRegion");
+                classIdCtorMap[20038] = ResolveConstructor("OSGeo.MapGuide.MgRing");
+                classIdCtorMap[20039] = ResolveConstructor("OSGeo.MapGuide.MgTransform");
+                classIdCtorMap[20040] = ResolveConstructor("OSGeo.MapGuide.MgWktReaderWriter");
+                classIdCtorMap[20041] = ResolveConstructor("OSGeo.MapGuide.MgCurveSegmentCollection");
+                classIdCtorMap[20042] = ResolveConstructor("OSGeo.MapGuide.MgLineString");
+                classIdCtorMap[20043] = ResolveConstructor("OSGeo.MapGuide.MgCurveStringCollection");
+                classIdCtorMap[20044] = ResolveConstructor("OSGeo.MapGuide.MgLineStringCollection");
+                classIdCtorMap[20045] = ResolveConstructor("OSGeo.MapGuide.MgPointCollection");
+                classIdCtorMap[20046] = ResolveConstructor("OSGeo.MapGuide.MgPolygonCollection");
+                classIdCtorMap[20047] = ResolveConstructor("OSGeo.MapGuide.MgCurvePolygonCollection");
+                classIdCtorMap[20048] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateXY");
+                classIdCtorMap[20049] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateXYZ");
+                classIdCtorMap[20050] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateXYZM");
+                classIdCtorMap[20051] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateXYM");
+                classIdCtorMap[20052] = ResolveConstructor("OSGeo.MapGuide.MgCurveRingCollection");
+                classIdCtorMap[20053] = ResolveConstructor("OSGeo.MapGuide.MgLinearRingCollection");
+                classIdCtorMap[20054] = ResolveConstructor("OSGeo.MapGuide.MgGeometrySimplifier");
+                classIdCtorMap[20055] = ResolveConstructor("OSGeo.MapGuide.MgPreparedGeometry");
+                classIdCtorMap[20500] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystem");
+                classIdCtorMap[20501] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemFactory");
+                classIdCtorMap[20502] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemMeasure");
+                classIdCtorMap[20503] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemTransform");
+                classIdCtorMap[20504] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemCatalog");
+                classIdCtorMap[20505] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemFormatConverter");
+                classIdCtorMap[20506] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemCategory");
+                classIdCtorMap[20507] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemDatum");
+                classIdCtorMap[20508] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformation");
+                classIdCtorMap[20509] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemEllipsoid");
+                classIdCtorMap[20510] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemCategoryDictionary");
+                classIdCtorMap[20511] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemDictionary");
+                classIdCtorMap[20512] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemDatumDictionary");
+                classIdCtorMap[20513] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemEllipsoidDictionary");
+                classIdCtorMap[20514] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemEnum");
+                classIdCtorMap[20515] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemEnumInteger32");
+                classIdCtorMap[20516] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemFilter");
+                classIdCtorMap[20517] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemFilterInteger32");
+                classIdCtorMap[20518] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemMathComparator");
+                classIdCtorMap[20519] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemUnitInformation");
+                classIdCtorMap[20520] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemProjectionInformation");
+                classIdCtorMap[20521] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemDictionaryUtility");
+                classIdCtorMap[20522] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemMgrs");
+                classIdCtorMap[20524] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridBoundary");
+                classIdCtorMap[20525] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridSpecification");
+                classIdCtorMap[20526] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridLineCollection");
+                classIdCtorMap[20527] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridRegionCollection");
+                classIdCtorMap[20528] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridTickCollection");
+                classIdCtorMap[20529] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridLine");
+                classIdCtorMap[20530] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridRegion");
+                classIdCtorMap[20531] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridTick");
+                classIdCtorMap[20532] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGridBase");
+                classIdCtorMap[20533] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticPath");
+                classIdCtorMap[20534] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticPathElement");
+                classIdCtorMap[20535] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticPathDictionary");
+                classIdCtorMap[20536] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef");
+                classIdCtorMap[20540] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefDictionary");
+                classIdCtorMap[20541] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams");
+                classIdCtorMap[20542] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticAnalyticalTransformDefParams");
+                classIdCtorMap[20543] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticInterpolationTransformDefParams");
+                classIdCtorMap[20544] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams");
+                classIdCtorMap[20545] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformGridFile");
+                classIdCtorMap[20546] = ResolveConstructor("OSGeo.MapGuide.MgCoordinateSystemGeodeticStandaloneTransformDefParams");
+            if (HasAssemblyInAppDomain("OSGeo.MapGuide.PlatformBase")) {
+                classIdCtorMap[10000] = ResolveConstructor("OSGeo.MapGuide.MgIntCollection");
+                classIdCtorMap[10001] = ResolveConstructor("OSGeo.MapGuide.MgPropertyDefinitionCollection");
+                classIdCtorMap[10003] = ResolveConstructor("OSGeo.MapGuide.MgStringPropertyCollection");
+                classIdCtorMap[10004] = ResolveConstructor("OSGeo.MapGuide.MgParameterCollection");
+                classIdCtorMap[10250] = ResolveConstructor("OSGeo.MapGuide.MgColor");
+                classIdCtorMap[10251] = ResolveConstructor("OSGeo.MapGuide.MgPropertyDefinition");
+                classIdCtorMap[10252] = ResolveConstructor("OSGeo.MapGuide.MgBlobProperty");
+                classIdCtorMap[10253] = ResolveConstructor("OSGeo.MapGuide.MgBooleanProperty");
+                classIdCtorMap[10254] = ResolveConstructor("OSGeo.MapGuide.MgByteProperty");
+                classIdCtorMap[10255] = ResolveConstructor("OSGeo.MapGuide.MgClobProperty");
+                classIdCtorMap[10256] = ResolveConstructor("OSGeo.MapGuide.MgDateTimeProperty");
+                classIdCtorMap[10257] = ResolveConstructor("OSGeo.MapGuide.MgDoubleProperty");
+                classIdCtorMap[10258] = ResolveConstructor("OSGeo.MapGuide.MgInt16Property");
+                classIdCtorMap[10259] = ResolveConstructor("OSGeo.MapGuide.MgInt32Property");
+                classIdCtorMap[10260] = ResolveConstructor("OSGeo.MapGuide.MgInt64Property");
+                classIdCtorMap[10261] = ResolveConstructor("OSGeo.MapGuide.MgSingleProperty");
+                classIdCtorMap[12000] = ResolveConstructor("OSGeo.MapGuide.MgMapBase");
+                classIdCtorMap[12001] = ResolveConstructor("OSGeo.MapGuide.MgLayerGroup");
+                classIdCtorMap[12002] = ResolveConstructor("OSGeo.MapGuide.MgLayerCollection");
+                classIdCtorMap[12003] = ResolveConstructor("OSGeo.MapGuide.MgLayerBase");
+                classIdCtorMap[12004] = ResolveConstructor("OSGeo.MapGuide.MgLayerGroupCollection");
+                classIdCtorMap[12005] = ResolveConstructor("OSGeo.MapGuide.MgMapCollection");
+                classIdCtorMap[12006] = ResolveConstructor("OSGeo.MapGuide.MgReadOnlyLayerCollection");
+                classIdCtorMap[12007] = ResolveConstructor("OSGeo.MapGuide.MgSelectionBase");
+                classIdCtorMap[11251] = ResolveConstructor("OSGeo.MapGuide.MgService");
+                classIdCtorMap[11257] = ResolveConstructor("OSGeo.MapGuide.MgWarnings");
+                classIdCtorMap[11750] = ResolveConstructor("OSGeo.MapGuide.MgClassDefinition");
+                classIdCtorMap[11751] = ResolveConstructor("OSGeo.MapGuide.MgDataPropertyDefinition");
+                classIdCtorMap[11753] = ResolveConstructor("OSGeo.MapGuide.MgFeatureReader");
+                classIdCtorMap[11754] = ResolveConstructor("OSGeo.MapGuide.MgFeatureService");
+                classIdCtorMap[11756] = ResolveConstructor("OSGeo.MapGuide.MgGeometricPropertyDefinition");
+                classIdCtorMap[11757] = ResolveConstructor("OSGeo.MapGuide.MgGeometry");
+                classIdCtorMap[11758] = ResolveConstructor("OSGeo.MapGuide.MgGeometryProperty");
+                classIdCtorMap[11759] = ResolveConstructor("OSGeo.MapGuide.MgObjectPropertyDefinition");
+                classIdCtorMap[11761] = ResolveConstructor("OSGeo.MapGuide.MgSpatialContextReader");
+                classIdCtorMap[11762] = ResolveConstructor("OSGeo.MapGuide.MgSqlDataReader");
+                classIdCtorMap[11764] = ResolveConstructor("OSGeo.MapGuide.MgFeatureProperty");
+                classIdCtorMap[11766] = ResolveConstructor("OSGeo.MapGuide.MgLongTransactionReader");
+                classIdCtorMap[11768] = ResolveConstructor("OSGeo.MapGuide.MgRasterPropertyDefinition");
+                classIdCtorMap[11769] = ResolveConstructor("OSGeo.MapGuide.MgRaster");
+                classIdCtorMap[11770] = ResolveConstructor("OSGeo.MapGuide.MgRasterProperty");
+                classIdCtorMap[11771] = ResolveConstructor("OSGeo.MapGuide.MgFeatureQueryOptions");
+                classIdCtorMap[11772] = ResolveConstructor("OSGeo.MapGuide.MgFeatureAggregateOptions");
+                classIdCtorMap[11773] = ResolveConstructor("OSGeo.MapGuide.MgDataReader");
+                classIdCtorMap[11774] = ResolveConstructor("OSGeo.MapGuide.MgFeatureCommandCollection");
+                classIdCtorMap[11775] = ResolveConstructor("OSGeo.MapGuide.MgDeleteFeatures");
+                classIdCtorMap[11776] = ResolveConstructor("OSGeo.MapGuide.MgInsertFeatures");
+                classIdCtorMap[11777] = ResolveConstructor("OSGeo.MapGuide.MgUpdateFeatures");
+                classIdCtorMap[11778] = ResolveConstructor("OSGeo.MapGuide.MgFeatureSchema");
+                classIdCtorMap[11779] = ResolveConstructor("OSGeo.MapGuide.MgFeatureSchemaCollection");
+                classIdCtorMap[11780] = ResolveConstructor("OSGeo.MapGuide.MgClassDefinitionCollection");
+                classIdCtorMap[11782] = ResolveConstructor("OSGeo.MapGuide.MgGwsFeatureReader");
+                classIdCtorMap[11785] = ResolveConstructor("OSGeo.MapGuide.MgGeometryTypeInfo");
+                classIdCtorMap[11786] = ResolveConstructor("OSGeo.MapGuide.MgFileFeatureSourceParams");
+                classIdCtorMap[11787] = ResolveConstructor("OSGeo.MapGuide.MgTransaction");
+                classIdCtorMap[11788] = ResolveConstructor("OSGeo.MapGuide.MgParameter");
+                classIdCtorMap[11500] = ResolveConstructor("OSGeo.MapGuide.MgResourceIdentifier");
+                classIdCtorMap[11501] = ResolveConstructor("OSGeo.MapGuide.MgResourceService");
+                classIdCtorMap[11526] = ResolveConstructor("OSGeo.MapGuide.MgResource");
+            if (HasAssemblyInAppDomain("OSGeo.MapGuide.MapGuideCommon")) {
+                classIdCtorMap[30500] = ResolveConstructor("OSGeo.MapGuide.MgMap");
+                classIdCtorMap[30501] = ResolveConstructor("OSGeo.MapGuide.MgLayer");
+                classIdCtorMap[30502] = ResolveConstructor("OSGeo.MapGuide.MgSelection");
+                classIdCtorMap[30601] = ResolveConstructor("OSGeo.MapGuide.MgSiteConnection");
+                classIdCtorMap[30604] = ResolveConstructor("OSGeo.MapGuide.MgPackageStatusInformation");
+                classIdCtorMap[30605] = ResolveConstructor("OSGeo.MapGuide.MgSite");
+                classIdCtorMap[30606] = ResolveConstructor("OSGeo.MapGuide.MgUserInformation");
+                classIdCtorMap[30607] = ResolveConstructor("OSGeo.MapGuide.MgServerAdmin");
+                classIdCtorMap[30608] = ResolveConstructor("OSGeo.MapGuide.MgSiteInfo");
+                classIdCtorMap[30700] = ResolveConstructor("OSGeo.MapGuide.MgDrawingService");
+                classIdCtorMap[30900] = ResolveConstructor("OSGeo.MapGuide.MgMappingService");
+                classIdCtorMap[30901] = ResolveConstructor("OSGeo.MapGuide.MgDwfVersion");
+                classIdCtorMap[30902] = ResolveConstructor("OSGeo.MapGuide.MgPlotSpecification");
+                classIdCtorMap[30904] = ResolveConstructor("OSGeo.MapGuide.MgLayout");
+                classIdCtorMap[30905] = ResolveConstructor("OSGeo.MapGuide.MgMapPlot");
+                classIdCtorMap[30906] = ResolveConstructor("OSGeo.MapGuide.MgMapPlotCollection");
+                classIdCtorMap[31000] = ResolveConstructor("OSGeo.MapGuide.MgRenderingService");
+                classIdCtorMap[31001] = ResolveConstructor("OSGeo.MapGuide.MgFeatureInformation");
+                classIdCtorMap[31002] = ResolveConstructor("OSGeo.MapGuide.MgRenderingOptions");
+                classIdCtorMap[31003] = ResolveConstructor("OSGeo.MapGuide.MgMetatile");
+                classIdCtorMap[31200] = ResolveConstructor("OSGeo.MapGuide.MgTileService");
+                classIdCtorMap[31300] = ResolveConstructor("OSGeo.MapGuide.MgKmlService");
+                classIdCtorMap[31400] = ResolveConstructor("OSGeo.MapGuide.MgProfilingService");
+            if (HasAssemblyInAppDomain("OSGeo.MapGuide.Web")) {
+                classIdCtorMap[50000] = ResolveConstructor("OSGeo.MapGuide.MgWebCommand");
+                classIdCtorMap[50001] = ResolveConstructor("OSGeo.MapGuide.MgWebUiTargetCommand");
+                classIdCtorMap[50002] = ResolveConstructor("OSGeo.MapGuide.MgWebSearchCommand");
+                classIdCtorMap[50003] = ResolveConstructor("OSGeo.MapGuide.MgWebInvokeScriptCommand");
+                classIdCtorMap[50004] = ResolveConstructor("OSGeo.MapGuide.MgWebInvokeUrlCommand");
+                classIdCtorMap[50005] = ResolveConstructor("OSGeo.MapGuide.MgWebBufferCommand");
+                classIdCtorMap[50006] = ResolveConstructor("OSGeo.MapGuide.MgWebSelectWithinCommand");
+                classIdCtorMap[50007] = ResolveConstructor("OSGeo.MapGuide.MgWebPrintCommand");
+                classIdCtorMap[50008] = ResolveConstructor("OSGeo.MapGuide.MgWebMeasureCommand");
+                classIdCtorMap[50009] = ResolveConstructor("OSGeo.MapGuide.MgWebGetPrintablePageCommand");
+                classIdCtorMap[50010] = ResolveConstructor("OSGeo.MapGuide.MgWebViewOptionsCommand");
+                classIdCtorMap[50011] = ResolveConstructor("OSGeo.MapGuide.MgWebHelpCommand");
+                classIdCtorMap[50012] = ResolveConstructor("OSGeo.MapGuide.MgWebCommandCollection");
+                classIdCtorMap[50013] = ResolveConstructor("OSGeo.MapGuide.MgWebWidget");
+                classIdCtorMap[50014] = ResolveConstructor("OSGeo.MapGuide.MgWebSeparatorWidget");
+                classIdCtorMap[50015] = ResolveConstructor("OSGeo.MapGuide.MgWebCommandWidget");
+                classIdCtorMap[50016] = ResolveConstructor("OSGeo.MapGuide.MgWebFlyoutWidget");
+                classIdCtorMap[50017] = ResolveConstructor("OSGeo.MapGuide.MgWebTaskBarWidget");
+                classIdCtorMap[50018] = ResolveConstructor("OSGeo.MapGuide.MgWebWidgetCollection");
+                classIdCtorMap[50019] = ResolveConstructor("OSGeo.MapGuide.MgWebUiPane");
+                classIdCtorMap[50020] = ResolveConstructor("OSGeo.MapGuide.MgWebUiSizablePane");
+                classIdCtorMap[50021] = ResolveConstructor("OSGeo.MapGuide.MgWebToolBar");
+                classIdCtorMap[50022] = ResolveConstructor("OSGeo.MapGuide.MgWebInformationPane");
+                classIdCtorMap[50023] = ResolveConstructor("OSGeo.MapGuide.MgWebTaskBar");
+                classIdCtorMap[50024] = ResolveConstructor("OSGeo.MapGuide.MgWebTaskPane");
+                classIdCtorMap[50025] = ResolveConstructor("OSGeo.MapGuide.MgWebContextMenu");
+                classIdCtorMap[50026] = ResolveConstructor("OSGeo.MapGuide.MgWebLayout");
+                classIdCtorMap[40000] = ResolveConstructor("OSGeo.MapGuide.MgHttpHeader");
+                classIdCtorMap[40001] = ResolveConstructor("OSGeo.MapGuide.MgHttpRequestParam");
+                classIdCtorMap[40002] = ResolveConstructor("OSGeo.MapGuide.MgHttpRequestMetadata");
+                classIdCtorMap[40003] = ResolveConstructor("OSGeo.MapGuide.MgHttpResult");
+                classIdCtorMap[40004] = ResolveConstructor("OSGeo.MapGuide.MgHttpRequest");
+                classIdCtorMap[40005] = ResolveConstructor("OSGeo.MapGuide.MgHttpResponse");
+                classIdCtorMap[40006] = ResolveConstructor("OSGeo.MapGuide.MgHttpPrimitiveValue");
             //Sanity check that we haven't double registered the same type name under different
@@ -254,16 +276,89 @@
-        internal static IEnumerable<int> ClassIds => classNameMap.Keys;
+        internal static IEnumerable<int> ClassIds => classIdCtorMap.Keys;
-        internal static string GetTypeName(int id)
+        internal static int? GetClassId(string typeName)
-            return classNameMap.ContainsKey(id) ? classNameMap[id] : null;
+            return nameClassMap.ContainsKey(typeName) ? nameClassMap[typeName] : (int?)null;
-        internal static int? GetClassId(string typeName)
+        internal static ConstructorInfo GetProxyConstructor(int classId)
-            return nameClassMap.ContainsKey(typeName) ? nameClassMap[typeName] : (int?)null;
+            return classIdCtorMap.ContainsKey(classId) ? classIdCtorMap[classId] : null;
+        static bool HasAssemblyInAppDomain(string assemblyName)
+#if MONOLITHIC_ASSEMBLY
+            return true;
+#else
+            var assemblies = global::System.AppDomain.CurrentDomain.GetAssemblies();
+            foreach (var assem in assemblies)
+                var asmName = new global::System.Reflection.AssemblyName(assem.FullName);
+                if (asmName.Name == assemblyName)
+                    return true;
+            return false;
+#endif
+        static ConstructorInfo ResolveConstructor(string typeName)
+            var type = global::System.Type.GetType(typeName);
+            if (type == null)
+                // Find the specified class in the pre-defined assemblies
+                    var assemblyName = new global::System.Reflection.AssemblyName(assem.FullName);
+                    if (assemblyNames.Contains(assemblyName.Name))
+                        type = assem.GetType(typeName, false);
+                        if (type != null)
+                            break;
+                // Fall back to finding the type in every assembly in the current appdomain
+                foreach (var assem in global::System.AppDomain.CurrentDomain.GetAssemblies())
+                    if (type != null)
+                        break;
+            if (type == null) //Shouldn't happen. But if it did, this would mean we didn't expose this class to SWIG
+                throw new global::System.Exception("The type " + typeName + " does not exist in the list of loaded assemblies");
+            else
+                //The constructor we require has been assigned internal visibility by SWIG. We could change it to public, but the internal
+                //visibility is the ideal one for purposes of encapulsation (this is internal use only). So instead of Activator.CreateInstance()
+                //which does not work with internal constructors, we'll find the ctor ourselves and invoke it.
+                var flags = global::System.Reflection.BindingFlags.NonPublic | global::System.Reflection.BindingFlags.Public | global::System.Reflection.BindingFlags.Instance;
+                var ctors = type.GetTypeInfo().GetConstructors(flags);
+                var ctor = ctors.FirstOrDefault(ci =>
+                    var parms = ci.GetParameters();
+                    if (parms.Length == 2)
+                        return parms[0].ParameterType == typeof(global::System.IntPtr)
+                            && parms[1].ParameterType == typeof(bool);
+                    return false;
+                if (ctor == null)
+                    throw new global::System.Exception("Could not find required constructor among " + ctors.Length + " constructors with signature (IntPtr, bool) on type: " + type.Name);
+                return ctor;
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj	2020-11-21 15:32:08 UTC (rev 9802)
@@ -20,10 +20,12 @@
   <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|AnyCPU'">
     <OutputPath>..\..\..\..\packages\DotNet\Release</OutputPath>
     <DocumentationFile>..\..\..\..\packages\DotNet\Release\MapGuideDotNetApi.xml</DocumentationFile>
+    <DefineConstants>TRACE;MONOLITHIC_ASSEMBLY</DefineConstants>
   </PropertyGroup>
   <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|AnyCPU'">
     <OutputPath>..\..\..\..\packages\DotNet\Debug</OutputPath>
+    <DefineConstants>MONOLITHIC_ASSEMBLY</DefineConstants>
   </PropertyGroup>
   <ItemGroup>
@@ -32,6 +34,10 @@
   </ItemGroup>
   <ItemGroup>
+    <Compile Include="..\Common\MgClassMap.cs" Link="MgClassMap.cs" />
+  </ItemGroup>
+  <ItemGroup>
     <None Include="..\..\..\..\..\License.txt">
       <Pack>True</Pack>
       <PackagePath></PackagePath>
Deleted: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/custom/MgClassMap.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/custom/MgClassMap.cs	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/custom/MgClassMap.cs	2020-11-21 15:32:08 UTC (rev 9802)
@@ -1,361 +0,0 @@
-// This file is autogenerated by ClassMapGen. DO NOT EDIT
-using System;
-using System.Collections.Generic;
-namespace OSGeo.MapGuide
-    internal static class MgClassMap
-        static MgClassMap()
-            classNameMap[1500] = "OSGeo.MapGuide.MgApplicationException";
-            classNameMap[1501] = "OSGeo.MapGuide.MgArgumentOutOfRangeException";
-            classNameMap[10500] = "OSGeo.MapGuide.MgArrayTypeMismatchException";
-            classNameMap[30000] = "OSGeo.MapGuide.MgAuthenticationFailedException";
-            classNameMap[1502] = "OSGeo.MapGuide.MgClassNotFoundException";
-            classNameMap[1503] = "OSGeo.MapGuide.MgConfigurationException";
-            classNameMap[1504] = "OSGeo.MapGuide.MgConfigurationLoadFailedException";
-            classNameMap[1505] = "OSGeo.MapGuide.MgConfigurationSaveFailedException";
-            classNameMap[30001] = "OSGeo.MapGuide.MgConnectionFailedException";
-            classNameMap[30002] = "OSGeo.MapGuide.MgConnectionNotOpenException";
-            classNameMap[21000] = "OSGeo.MapGuide.MgCoordinateSystemComputationFailedException";
-            classNameMap[21001] = "OSGeo.MapGuide.MgCoordinateSystemConversionFailedException";
-            classNameMap[21002] = "OSGeo.MapGuide.MgCoordinateSystemInitializationFailedException";
-            classNameMap[21003] = "OSGeo.MapGuide.MgCoordinateSystemLoadFailedException";
-            classNameMap[21004] = "OSGeo.MapGuide.MgCoordinateSystemMeasureFailedException";
-            classNameMap[21005] = "OSGeo.MapGuide.MgCoordinateSystemTransformFailedException";
-            classNameMap[1506] = "OSGeo.MapGuide.MgDateTimeException";
-            classNameMap[30003] = "OSGeo.MapGuide.MgDbException";
-            classNameMap[30004] = "OSGeo.MapGuide.MgDbXmlException";
-            classNameMap[1507] = "OSGeo.MapGuide.MgDecryptionException";
-            classNameMap[1508] = "OSGeo.MapGuide.MgDirectoryNotFoundException";
-            classNameMap[1509] = "OSGeo.MapGuide.MgDivideByZeroException";
-            classNameMap[1510] = "OSGeo.MapGuide.MgDomainException";
-            classNameMap[1511] = "OSGeo.MapGuide.MgDuplicateDirectoryException";
-            classNameMap[1512] = "OSGeo.MapGuide.MgDuplicateFileException";
-            classNameMap[30005] = "OSGeo.MapGuide.MgDuplicateGroupException";
-            classNameMap[30006] = "OSGeo.MapGuide.MgDuplicateNameException";
-            classNameMap[1513] = "OSGeo.MapGuide.MgDuplicateObjectException";
-            classNameMap[30007] = "OSGeo.MapGuide.MgDuplicateParameterException";
-            classNameMap[30008] = "OSGeo.MapGuide.MgDuplicateRepositoryException";
-            classNameMap[10501] = "OSGeo.MapGuide.MgDuplicateResourceDataException";
-            classNameMap[10502] = "OSGeo.MapGuide.MgDuplicateResourceException";
-            classNameMap[30009] = "OSGeo.MapGuide.MgDuplicateRoleException";
-            classNameMap[30010] = "OSGeo.MapGuide.MgDuplicateServerException";
-            classNameMap[30011] = "OSGeo.MapGuide.MgDuplicateSessionException";
-            classNameMap[30012] = "OSGeo.MapGuide.MgDuplicateUserException";
-            classNameMap[30013] = "OSGeo.MapGuide.MgDwfException";
-            classNameMap[30014] = "OSGeo.MapGuide.MgDwfSectionNotFoundException";
-            classNameMap[30015] = "OSGeo.MapGuide.MgDwfSectionResourceNotFoundException";
-            classNameMap[10503] = "OSGeo.MapGuide.MgEmptyFeatureSetException";
-            classNameMap[1514] = "OSGeo.MapGuide.MgEncryptionException";
-            classNameMap[30016] = "OSGeo.MapGuide.MgEndOfStreamException";
-            classNameMap[10504] = "OSGeo.MapGuide.MgFdoException";
-            classNameMap[10505] = "OSGeo.MapGuide.MgFeatureServiceException";
-            classNameMap[1516] = "OSGeo.MapGuide.MgFileIoException";
-            classNameMap[1517] = "OSGeo.MapGuide.MgFileNotFoundException";
-            classNameMap[20019] = "OSGeo.MapGuide.MgGeometry";
-            classNameMap[21006] = "OSGeo.MapGuide.MgGeometryException";
-            classNameMap[30018] = "OSGeo.MapGuide.MgGroupNotFoundException";
-            classNameMap[1518] = "OSGeo.MapGuide.MgIndexOutOfRangeException";
-            classNameMap[1519] = "OSGeo.MapGuide.MgInvalidArgumentException";
-            classNameMap[1520] = "OSGeo.MapGuide.MgInvalidCastException";
-            classNameMap[21007] = "OSGeo.MapGuide.MgInvalidCoordinateSystemException";
-            classNameMap[21008] = "OSGeo.MapGuide.MgInvalidCoordinateSystemTypeException";
-            classNameMap[21009] = "OSGeo.MapGuide.MgInvalidCoordinateSystemUnitsException";
-            classNameMap[30019] = "OSGeo.MapGuide.MgInvalidDwfPackageException";
-            classNameMap[30020] = "OSGeo.MapGuide.MgInvalidDwfSectionException";
-            classNameMap[30021] = "OSGeo.MapGuide.MgInvalidFeatureSourceException";
-            classNameMap[30022] = "OSGeo.MapGuide.MgInvalidIpAddressException";
-            classNameMap[30023] = "OSGeo.MapGuide.MgInvalidLicenseException";
-            classNameMap[30024] = "OSGeo.MapGuide.MgInvalidLogEntryException";
-            classNameMap[10507] = "OSGeo.MapGuide.MgInvalidMapDefinitionException";
-            classNameMap[1522] = "OSGeo.MapGuide.MgInvalidOperationException";
-            classNameMap[30026] = "OSGeo.MapGuide.MgInvalidPasswordException";
-            classNameMap[30027] = "OSGeo.MapGuide.MgInvalidPrintLayoutFontSizeUnitsException";
-            classNameMap[30028] = "OSGeo.MapGuide.MgInvalidPrintLayoutPositionUnitsException";
-            classNameMap[30029] = "OSGeo.MapGuide.MgInvalidPrintLayoutSizeUnitsException";
-            classNameMap[1523] = "OSGeo.MapGuide.MgInvalidPropertyTypeException";
-            classNameMap[10508] = "OSGeo.MapGuide.MgInvalidRepositoryNameException";
-            classNameMap[10509] = "OSGeo.MapGuide.MgInvalidRepositoryTypeException";
-            classNameMap[10510] = "OSGeo.MapGuide.MgInvalidResourceDataNameException";
-            classNameMap[10511] = "OSGeo.MapGuide.MgInvalidResourceDataTypeException";
-            classNameMap[10512] = "OSGeo.MapGuide.MgInvalidResourceNameException";
-            classNameMap[10513] = "OSGeo.MapGuide.MgInvalidResourcePathException";
-            classNameMap[10514] = "OSGeo.MapGuide.MgInvalidResourcePreProcessingTypeException";
-            classNameMap[10515] = "OSGeo.MapGuide.MgInvalidResourceTypeException";
-            classNameMap[30031] = "OSGeo.MapGuide.MgInvalidServerNameException";
-            classNameMap[1524] = "OSGeo.MapGuide.MgInvalidStreamHeaderException";
-            classNameMap[1525] = "OSGeo.MapGuide.MgIoException";
-            classNameMap[10517] = "OSGeo.MapGuide.MgLayerNotFoundException";
-            classNameMap[1526] = "OSGeo.MapGuide.MgLengthException";
-            classNameMap[30032] = "OSGeo.MapGuide.MgLicenseException";
-            classNameMap[30033] = "OSGeo.MapGuide.MgLicenseExpiredException";
-            classNameMap[1527] = "OSGeo.MapGuide.MgLogicException";
-            classNameMap[1528] = "OSGeo.MapGuide.MgNotFiniteNumberException";
-            classNameMap[1529] = "OSGeo.MapGuide.MgNotImplementedException";
-            classNameMap[1530] = "OSGeo.MapGuide.MgNullArgumentException";
-            classNameMap[1531] = "OSGeo.MapGuide.MgNullPropertyValueException";
-            classNameMap[1532] = "OSGeo.MapGuide.MgNullReferenceException";
-            classNameMap[1533] = "OSGeo.MapGuide.MgObjectNotFoundException";
-            classNameMap[30035] = "OSGeo.MapGuide.MgOperationProcessingException";
-            classNameMap[1534] = "OSGeo.MapGuide.MgOutOfMemoryException";
-            classNameMap[1535] = "OSGeo.MapGuide.MgOutOfRangeException";
-            classNameMap[1536] = "OSGeo.MapGuide.MgOverflowException";
-            classNameMap[30036] = "OSGeo.MapGuide.MgParameterNotFoundException";
-            classNameMap[30037] = "OSGeo.MapGuide.MgPathTooLongException";
-            classNameMap[1537] = "OSGeo.MapGuide.MgPlatformNotSupportedException";
-            classNameMap[30039] = "OSGeo.MapGuide.MgPortNotAvailableException";
-            classNameMap[30040] = "OSGeo.MapGuide.MgPrintToScaleModeNotSelectedException";
-            classNameMap[2002] = "OSGeo.MapGuide.MgPropertyDefinition";
-            classNameMap[30041] = "OSGeo.MapGuide.MgRepositoryCreationFailedException";
-            classNameMap[30042] = "OSGeo.MapGuide.MgRepositoryNotFoundException";
-            classNameMap[30043] = "OSGeo.MapGuide.MgRepositoryNotOpenException";
-            classNameMap[30044] = "OSGeo.MapGuide.MgRepositoryOpenFailedException";
-            classNameMap[10518] = "OSGeo.MapGuide.MgResourceBusyException";
-            classNameMap[10519] = "OSGeo.MapGuide.MgResourceDataNotFoundException";
-            classNameMap[10520] = "OSGeo.MapGuide.MgResourceNotFoundException";
-            classNameMap[1538] = "OSGeo.MapGuide.MgResourcesException";
-            classNameMap[1539] = "OSGeo.MapGuide.MgResourcesLoadFailedException";
-            classNameMap[1540] = "OSGeo.MapGuide.MgResourceTagNotFoundException";
-            classNameMap[30045] = "OSGeo.MapGuide.MgRoleNotFoundException";
-            classNameMap[1541] = "OSGeo.MapGuide.MgRuntimeException";
-            classNameMap[30046] = "OSGeo.MapGuide.MgServerNotFoundException";
-            classNameMap[30047] = "OSGeo.MapGuide.MgServerNotOnlineException";
-            classNameMap[10521] = "OSGeo.MapGuide.MgServiceNotAvailableException";
-            classNameMap[10522] = "OSGeo.MapGuide.MgServiceNotSupportedException";
-            classNameMap[30048] = "OSGeo.MapGuide.MgSessionExpiredException";
-            classNameMap[30052] = "OSGeo.MapGuide.MgSessionNotFoundException";
-            classNameMap[1542] = "OSGeo.MapGuide.MgStreamIoException";
-            classNameMap[1543] = "OSGeo.MapGuide.MgSystemException";
-            classNameMap[1544] = "OSGeo.MapGuide.MgTemporaryFileNotAvailableException";
-            classNameMap[1545] = "OSGeo.MapGuide.MgThirdPartyException";
-            classNameMap[30049] = "OSGeo.MapGuide.MgUnauthorizedAccessException";
-            classNameMap[1547] = "OSGeo.MapGuide.MgUnclassifiedException";
-            classNameMap[1548] = "OSGeo.MapGuide.MgUnderflowException";
-            classNameMap[30056] = "OSGeo.MapGuide.MgUnknownTileProviderException";
-            classNameMap[30057] = "OSGeo.MapGuide.MgUnsupportedTileProviderException";
-            classNameMap[30050] = "OSGeo.MapGuide.MgUriFormatException";
-            classNameMap[10523] = "OSGeo.MapGuide.MgUserNotFoundException";
-            classNameMap[1549] = "OSGeo.MapGuide.MgXmlException";
-            classNameMap[1550] = "OSGeo.MapGuide.MgXmlParserException";
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i	2020-11-21 15:32:08 UTC (rev 9802)
@@ -213,71 +213,22 @@
                 clsId = $imclassname.GetClassId(objPtr);
-            var typeName = MgClassMap.GetTypeName(clsId.Value);
-            if (typeName == null) //Shouldn't happen. But if it did, this would mean we missed a spot when compiling class ids
+            var ctor = MgClassMap.GetProxyConstructor(clsId.Value);
+            if (ctor == null)
                 throw new global::System.Exception("Could not resolve .net type for this unmanaged pointer. The unmanaged pointer reported a class ID of: " + clsId);
-            var type = global::System.Type.GetType(typeName);
-            if (type == null)
+            var args = new object[]
-                // Find the specified class in the pre-defined assemblies
-                var assemblies = global::System.AppDomain.CurrentDomain.GetAssemblies();
-                foreach (var assem in assemblies)
-                    var assemblyName = new global::System.Reflection.AssemblyName(assem.FullName);
-                    if (assemblyNameMap.ContainsKey(assemblyName.Name))
-                        type = assem.GetType(typeName, false);
-                        if (type != null)
-                            break;
-                // Fall back to finding the type in every assembly in the current appdomain
-                foreach (var assem in global::System.AppDomain.CurrentDomain.GetAssemblies())
-                    if (type != null)
-                        break;
+                objPtr,
+                true /* ownMemory */
-            if (type == null) //Shouldn't happen. But if it did, this would mean we didn't expose this class to SWIG
-                throw new global::System.Exception("The type " + typeName + " does not exist. The unmanaged pointer reported a class ID of: " + clsId);
-            else
-                var args = new object[]
-                    objPtr,
-                    true /* ownMemory */
-                //The constructor we require has been assigned internal visibility by SWIG. We could change it to public, but the internal
-                //visibility is the ideal one for purposes of encapulsation (this is internal use only). So instead of Activator.CreateInstance()
-                //which does not work with internal constructors, we'll find the ctor ourselves and invoke it.
-                var flags = global::System.Reflection.BindingFlags.NonPublic | global::System.Reflection.BindingFlags.Public | global::System.Reflection.BindingFlags.Instance;
-                var ctors = type.GetTypeInfo().GetConstructors(flags);
-                var ctor = ctors.FirstOrDefault(ci =>
-                    var parms = ci.GetParameters();
-                    if (parms.Length == 2)
-                        return parms[0].ParameterType == typeof(global::System.IntPtr)
-                            && parms[1].ParameterType == typeof(bool);
-                    return false;
-                if (ctor == null)
-                    throw new global::System.Exception("Could not find required constructor among " + ctors.Length + " constructors with signature (IntPtr, bool) on type: " + type.Name);
-                obj = ctor.Invoke(args) as T;
-                if (obj == null)
-                    throw new global::System.Exception("Could not create an instance of type " + typeof(T).Name + " (concrete type: " + type.Name + "). The unmanaged pointer reported a class ID of: " + clsId);
+            obj = ctor.Invoke(args) as T;
+            if (obj == null)
+                throw new global::System.Exception("Could not create an instance of type " + typeof(T).Name + " (concrete type: " + ctor.DeclaringType.Name + "). The unmanaged pointer reported a class ID of: " + clsId);
             return obj;
Deleted: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs	2020-11-21 15:32:08 UTC (rev 9802)
@@ -1,26 +0,0 @@
-using OSGeo.MapGuide.Test.Common;
-using System;
-using System.Linq;
-namespace TestMapGuideApi.ExternalTests
-    public class ClassIdSanityTest : IExternalTest
-        public void Execute(IPlatformFactory factory, ITestLogger logger)
-            var missing = 0;
-            var mgAssemblies = AppDomain.CurrentDomain.GetAssemblies().Where(asm => asm.FullName.Contains("OSGeo.MapGuide"));
-            foreach (var clsId in OSGeo.MapGuide.MgClassMap.ClassIds)
-                var typeName = OSGeo.MapGuide.MgClassMap.GetTypeName(clsId);
-                var types = mgAssemblies.Select(asm => asm.GetType(typeName, false));
-                if (!types.Any())
-                    logger.WriteLine($"ERROR: .net proxy class ({typeName}, id: {clsId} does not exist");
-                    missing++;
-            Assert.AreEqual(0, missing);
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs	2020-11-21 15:32:08 UTC (rev 9802)
@@ -14,8 +14,6 @@
                 mentorDictionaryPath = Path.GetFullPath(Path.Combine(Environment.CurrentDirectory, mentorDictionaryPath));
             Environment.SetEnvironmentVariable("MENTOR_DICTIONARY_PATH", mentorDictionaryPath, EnvironmentVariableTarget.Process);
-            ClassIdSanityTest();
             var csFactory = new MgCoordinateSystemFactory();
             var csCat = csFactory.GetCatalog();
             csCat.SetDictionaryDir(mentorDictionaryPath);
@@ -140,47 +138,6 @@
             Console.WriteLine("*********** ALL OK ****************");
-        private static void ClassIdSanityTest()
-            var missing = 0;
-                    .Where(t => t != null)
-                    .ToList();
-                if (types.Count == 0)
-                    Console.WriteLine($"ERROR: .net proxy class ({typeName}, id: {clsId}) does not exist");
-                    missing++;
-            if (missing > 0)
-                throw new Exception($"{missing} .net proxy class(es) could not be found");
-            missing = 0;
-            //Now check in reverse
-            foreach (var type in mgAssemblies.SelectMany(asm => asm.ExportedTypes.Where(t => t.Name.StartsWith("Mg"))))
-                if (type.IsClass && !IsConstantClass(type))
-                    var id = MgClassMap.GetClassId(type.FullName);
-                    if (!id.HasValue)
-                        Console.WriteLine($".net proxy class ({type.FullName}) does not have a known corresponding class id");
-                        missing++;
-            if (missing > 0)
-                throw new Exception($"{missing} .net proxy class(es) are missing class ids");
         private static bool IsConstantClass(Type type)
             if (type.IsClass)
Modified: sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt	2020-11-21 15:32:08 UTC (rev 9802)
@@ -2,22 +2,31 @@
 using System;
+using System.Linq;
         static MgClassMap()
 $CLASS_NAME_MAP_BODY$
@@ -36,16 +45,89 @@
+            return true;
+#else
+                    return true;
+            return false;
+#endif
+            if (type == null)
+                        if (type != null)
+                            break;
+                    if (type != null)
+                        break;
+            else
+                    return false;
+                if (ctor == null)
+                return ctor;
Modified: sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs	2020-11-20 15:56:48 UTC (rev 9801)
+++ sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs	2020-11-21 15:32:08 UTC (rev 9802)
@@ -7,6 +7,7 @@
 using CommandLine;
 using System.Xml;
 using NCalc;
+using System.Collections.Concurrent;
 namespace ClassMapGen
@@ -57,46 +58,18 @@
             MasterClassMap clsMap = ReadFromSwigXml(opts.SwigXmlFile);
-            var foundation = clsMap.Modules.FirstOrDefault(m => m.Name == "Foundation");
-            var geometry = clsMap.Modules.FirstOrDefault(m => m.Name == "Geometry");
-            var platform = clsMap.Modules.FirstOrDefault(m => m.Name == "PlatformBase");
-            var mapguide = clsMap.Modules.FirstOrDefault(m => m.Name == "MapGuideCommon");
-            var web = clsMap.Modules.FirstOrDefault(m => m.Name == "Web");
-            int foundationAdded = 0;
-            int geometryAdded = 0;
-            int platformAdded = 0;
-            int mapguideAdded = 0;
-            int webAdded = 0;
             var classMapMaster = new Dictionary<int, string>();
             var classMapMasterReverse = new SortedDictionary<string, int>();
+            var addedStats = new ConcurrentDictionary<string, int>();
-            foreach (var kvp in foundation.Classes)
+            foreach (var mod in clsMap.Modules)
-                if (classMapMaster.TryAdd(kvp.Key, kvp.Value))
-                    foundationAdded++;
+                foreach (var kvp in mod.Classes)
+                    if (classMapMaster.TryAdd(kvp.Key, kvp.Value))
+                        addedStats.AddOrUpdate(mod.Name, k => 1, (k, cv) => cv + 1);
-            foreach (var kvp in geometry.Classes)
-                    geometryAdded++;
-            foreach (var kvp in platform.Classes)
-                    platformAdded++;
-            foreach (var kvp in mapguide.Classes)
-                    mapguideAdded++;
-            foreach (var kvp in web.Classes)
-                    webAdded++;
             //Now populate reverse map
             foreach (var kvp in classMapMaster)
@@ -104,11 +77,10 @@
                 classMapMasterReverse[kvp.Value] = kvp.Key;
-            Console.WriteLine($"Foundation: {foundationAdded} classes added");
-            Console.WriteLine($"Geometry: {geometryAdded} classes added");
-            Console.WriteLine($"PlatformBase: {platformAdded} classes added");
-            Console.WriteLine($"MapGuideCommon: {mapguideAdded} classes added");
-            Console.WriteLine($"Web: {webAdded} classes added");
+            foreach (var kvp in addedStats)
+                Console.WriteLine($"{kvp.Key}: {kvp.Value} classes added");
             Console.WriteLine($"Class map has {classMapMaster.Count} classes");
@@ -125,25 +97,32 @@
             phpTpl.Replace("$CLASS_NAME_MAP_BODY$", phpClassMaps.ToString());
-            var dotNetClassMaps = new StringBuilder();
+            var javaClassMaps = new StringBuilder();
-            //.net
+            //Java
             foreach (var kvp in classMapMasterReverse)
-                dotNetClassMaps.AppendLine($"{DOTNET_INDENT}classNameMap[{kvp.Value}] = \"OSGeo.MapGuide.{kvp.Key}\";");
+                javaClassMaps.AppendLine($"{JAVA_INDENT}classMap.put(new Integer({kvp.Value}), getSWIGCtor(\"{kvp.Key}\"));");
-            dotNetTpl.Replace("$CLASS_NAME_MAP_BODY$", dotNetClassMaps.ToString());
+            javaTpl.Replace("$CLASS_NAME_MAP_BODY$", javaClassMaps.ToString());
-            var javaClassMaps = new StringBuilder();
+            var dotNetClassMaps = new StringBuilder();
-            //Java
-            foreach (var kvp in classMapMasterReverse)
+            //.net
-                javaClassMaps.AppendLine($"{JAVA_INDENT}classMap.put(new Integer({kvp.Value}), getSWIGCtor(\"{kvp.Key}\"));");
+                dotNetClassMaps.AppendLine($"{DOTNET_INDENT}if (HasAssemblyInAppDomain(\"OSGeo.MapGuide.{mod.Name}\")) {{");
+                    dotNetClassMaps.AppendLine($"{DOTNET_INDENT}    classIdCtorMap[{kvp.Key}] = ResolveConstructor(\"OSGeo.MapGuide.{kvp.Value}\");");
+                dotNetClassMaps.AppendLine($"{DOTNET_INDENT}}}");
-            javaTpl.Replace("$CLASS_NAME_MAP_BODY$", javaClassMaps.ToString());
+            dotNetTpl.Replace("$CLASS_NAME_MAP_BODY$", dotNetClassMaps.ToString());
             File.WriteAllText(phpOut, phpTpl.ToString());
             Console.WriteLine($"Written: {phpOut}");
More information about the mapguide-commits
