[mapguide-commits] r9803 - in sandbox/jng/vanilla_swig: . Bindings Bindings/src Bindings/src/Bindings Bindings/src/Bindings/DotNet Bindings/src/Bindings/DotNet/Foundation Bindings/src/Bindings/DotNet/Geometry Bindings/src/Bindings/DotNet/MapGuideCommon Bindings/src/Bindings/DotNet/PlatformBase Bindings/src/Bindings/DotNet/Web Bindings/src/IMake Bindings/src/SwigCommon/DotNet Common cmake/modules
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 26 07:14:39 PST 2020
Author: jng
Date: 2020-11-26 07:14:38 -0800 (Thu, 26 Nov 2020)
New Revision: 9803
Added:
   sandbox/jng/vanilla_swig/Bindings/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Web/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/TODO.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore.i
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore_split.i
   sandbox/jng/vanilla_swig/Bindings/src/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/IMake/CMakeLists.txt
   sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i
   sandbox/jng/vanilla_swig/CMakeLists.txt
   sandbox/jng/vanilla_swig/Common/CMakeLists.txt
   sandbox/jng/vanilla_swig/cmake/modules/FindMapGuideThirdparty.cmake
Get Foundation .net glue library building on the Linux side
Added: sandbox/jng/vanilla_swig/Bindings/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/CMakeLists.txt	                        (rev 0)
+++ sandbox/jng/vanilla_swig/Bindings/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -0,0 +1 @@
+add_subdirectory(src)
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -7,6 +7,7 @@
  - [x] Check in test case admin tool
  - [x] Consolidate Tools.sln into Bindings.sln
  - [ ] Relocate/remove existing test code
+ - [ ] Move packages dir up to to top-level MgDev subdirectory and make sure nuget.config sources from this dir
  - Split .net binding into the Foundation/Geometry/PlatformBase/MapGuideCommon/Web layout (https://github.com/jumpinjackie/mapguide-api-bindings/issues/18)
    - [x] Add .targets files to each C# project so that native dlls are copied properly when consumed by legacy .net framework applications/libraries
    - [x] Consolidate TestCommon and TestMapGuideApi .net projects to unified netstandard2.0 libraries
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -1,12 +1,7 @@
-if (WITH_DOTNET)
-    add_subdirectory(DotNet)
-endif (WITH_DOTNET)
-if (WITH_JAVA)
-    add_subdirectory(Java)
-endif (WITH_JAVA)
-if (WITH_PHP)
-    add_subdirectory(Php)
-endif (WITH_PHP)
-# Needed for api binding generation
-file(COPY "Common" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
-file(COPY "MapGuideApi" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+add_subdirectory(DotNet)
+#if (WITH_JAVA)
+#    add_subdirectory(Java)
+#endif (WITH_JAVA)
+#if (WITH_PHP)
+#    add_subdirectory(Php)
+#endif (WITH_PHP)
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -1,4 +1,4 @@
-project(MapGuideDotNetUnmanagedApi)
+#project(MapGuideDotNetUnmanagedApi)
 include_directories(
     ${MG_COMMON_DIR}/MdfModel
@@ -13,91 +13,99 @@
     ${XERCESC_INCLUDE_DIR}
-set(DotNetUnmanagedApi_SRCS
-    ${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp
+add_subdirectory(Foundation)
+add_subdirectory(Geometry)
+add_subdirectory(PlatformBase)
+add_subdirectory(MapGuideCommon)
+add_subdirectory(Web)
-add_library(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} SHARED ${DotNetUnmanagedApi_SRCS})
-add_dependencies(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} IMake)
-if (UNIX)
-    add_definitions(-DDOTNETCORE)
-endif (UNIX)
-if (MSVC)
-    add_definitions(-DSWIG_PUBLIC_API)
-    add_definitions(/bigobj)
-    set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
-    set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
-    set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
-endif (MSVC)
+#set(DotNetUnmanagedApi_SRCS
+#    ${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp
+#add_library(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} SHARED ${DotNetUnmanagedApi_SRCS})
+#add_dependencies(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} IMake)
+#if (UNIX)
+#    add_definitions(-DDOTNETCORE)
+#endif (UNIX)
+#if (MSVC)
+#    add_definitions(-DSWIG_PUBLIC_API)
+#    add_definitions(/bigobj)
+#    set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
+#    set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
+#    set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
+#endif (MSVC)
+#set(IMAKE_RELATIVE_RESOLUTION "-r ${CMAKE_CURRENT_SOURCE_DIR}")
+#if (UNIX)
+#    set(IMAKE_RELATIVE_RESOLUTION "-a")
+#endif (UNIX)
+#set(SWIG_DOTNET_DEFS "")
+#if (WIN32)
+#    set(SWIG_DOTNET_DEFS "-DWIN32")
+#endif (WIN32)
+#message(STATUS "Using IMake at: ${IMAKE_TOOL}")
+#add_custom_command(OUTPUT ${DotNetUnmanagedApi_SRCS}
+#    COMMAND ${CMAKE_COMMAND} -E echo Removing: ${MG_DOTNET_PROJECT_DIR}/*.cs
+#    COMMAND ${CMAKE_COMMAND} -E remove -f
+#            ${MG_DOTNET_PROJECT_DIR}/*.cs
+#    COMMAND ${CMAKE_COMMAND} -E echo Regenerating: ${MG_DOTNET_PROJECT_DIR}/Constants.cs
+#    COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/Constants.xml
+#            -l "C#"
+#            ${IMAKE_RELATIVE_RESOLUTION}
+#            -o ${MG_DOTNET_PROJECT_DIR}/Constants.cs
+#            -t
+#    COMMAND ${CMAKE_COMMAND} -E copy
+#            ${CMAKE_CURRENT_BINARY_DIR}/dotnetcore.i
+#            ${CMAKE_CURRENT_BINARY_DIR}/language.i
+#    COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/MapGuideApiGen.xml
+#            -l "C#"
+#            -o ${CMAKE_CURRENT_BINARY_DIR}
+#    COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [DotNet]. Output Dir: ${MG_DOTNET_PROJECT_DIR}
+#    COMMAND ${SWIG_TOOL} -c++ -csharp
+#            ${SWIG_DOTNET_DEFS} -DDOTNETCORE -DSWIG_CSHARP_NO_EXCEPTION_HELPER
+#            -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER
+#            -namespace OSGeo.MapGuide
+#            -nodefaultctor -nodefaultdtor
+#            -module MapGuideDotNetUnmanagedApi
+#            -o "${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp"
+#            -outdir "${MG_DOTNET_PROJECT_DIR}"
+#            "${CMAKE_CURRENT_BINARY_DIR}/MapGuideApi.i"
+#            ${MG_DOTNET_PROJECT_DIR}/MapGuideDotNetUnmanagedApi.cs
+#target_link_libraries(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX}
+#    ${ACE_LIBRARY}
+#    ${MG_FOUNDATION_LIBRARY}
+#    ${MG_GEOMETRY_LIBRARY}
+#    ${MG_PLATFORMBASE_LIBRARY}
+#    ${MG_COMMON_LIBRARY}
+#    ${MG_HTTPHANDLER_LIBRARY}
+#    ${MG_WEBAPP_LIBRARY}
+#    ${MG_MDFMODEL_LIBRARY}
+#    ${MG_MDFPARSER_LIBRARY}
+#    ${MG_WEBSUPPORT_LIBRARY}
+#    #MgFoundation${MG_VERSION_SUFFIX}
+#    #MgGeometry${MG_VERSION_SUFFIX}
+#    #MgPlatformBase${MG_VERSION_SUFFIX}
+#    #MgMapGuideCommon${MG_VERSION_SUFFIX}
+#    #MgHttpHandler${MG_VERSION_SUFFIX}
+#    #MgMdfModel${MG_VERSION_SUFFIX}
+#    #MgMdfParser${MG_VERSION_SUFFIX}
+#    ${XERCESC_LIBRARIES}
+#    #MgWebApp${MG_VERSION_SUFFIX}
+## Only needed for Linux
+#if (UNIX)
+#    file(COPY "InitializeWebTier.cpp" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+#    install( TARGETS MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} DESTINATION ${MG_DOTNET_OUTPUT_DIR})
+#endif (UNIX)
+#file(COPY "dotnetcore.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
-set(IMAKE_RELATIVE_RESOLUTION "-r ${CMAKE_CURRENT_SOURCE_DIR}")
-if (UNIX)
-    set(IMAKE_RELATIVE_RESOLUTION "-a")
-endif (UNIX)
-set(SWIG_DOTNET_DEFS "")
-if (WIN32)
-    set(SWIG_DOTNET_DEFS "-DWIN32")
-endif (WIN32)
-message(STATUS "Using IMake at: ${IMAKE_TOOL}")
-add_custom_command(OUTPUT ${DotNetUnmanagedApi_SRCS}
-    COMMAND ${CMAKE_COMMAND} -E echo Removing: ${MG_DOTNET_PROJECT_DIR}/*.cs
-    COMMAND ${CMAKE_COMMAND} -E remove -f
-            ${MG_DOTNET_PROJECT_DIR}/*.cs
-    COMMAND ${CMAKE_COMMAND} -E echo Regenerating: ${MG_DOTNET_PROJECT_DIR}/Constants.cs
-    COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/Constants.xml
-            -l "C#"
-            ${IMAKE_RELATIVE_RESOLUTION}
-            -o ${MG_DOTNET_PROJECT_DIR}/Constants.cs
-            -t
-    COMMAND ${CMAKE_COMMAND} -E copy
-            ${CMAKE_CURRENT_BINARY_DIR}/dotnetcore.i
-            ${CMAKE_CURRENT_BINARY_DIR}/language.i
-    COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/MapGuideApiGen.xml
-            -l "C#"
-            -o ${CMAKE_CURRENT_BINARY_DIR}
-    COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [DotNet]. Output Dir: ${MG_DOTNET_PROJECT_DIR}
-    COMMAND ${SWIG_TOOL} -c++ -csharp
-            ${SWIG_DOTNET_DEFS} -DDOTNETCORE -DSWIG_CSHARP_NO_EXCEPTION_HELPER
-            -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER
-            -namespace OSGeo.MapGuide
-            -nodefaultctor -nodefaultdtor
-            -module MapGuideDotNetUnmanagedApi
-            -o "${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp"
-            -outdir "${MG_DOTNET_PROJECT_DIR}"
-            "${CMAKE_CURRENT_BINARY_DIR}/MapGuideApi.i"
-            ${MG_DOTNET_PROJECT_DIR}/MapGuideDotNetUnmanagedApi.cs
-target_link_libraries(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX}
-    ${ACE_LIBRARY}
-    ${MG_FOUNDATION_LIBRARY}
-    ${MG_GEOMETRY_LIBRARY}
-    ${MG_PLATFORMBASE_LIBRARY}
-    ${MG_COMMON_LIBRARY}
-    ${MG_HTTPHANDLER_LIBRARY}
-    ${MG_WEBAPP_LIBRARY}
-    ${MG_MDFMODEL_LIBRARY}
-    ${MG_MDFPARSER_LIBRARY}
-    ${MG_WEBSUPPORT_LIBRARY}
-    #MgFoundation${MG_VERSION_SUFFIX}
-    #MgGeometry${MG_VERSION_SUFFIX}
-    #MgPlatformBase${MG_VERSION_SUFFIX}
-    #MgMapGuideCommon${MG_VERSION_SUFFIX}
-    #MgHttpHandler${MG_VERSION_SUFFIX}
-    #MgMdfModel${MG_VERSION_SUFFIX}
-    #MgMdfParser${MG_VERSION_SUFFIX}
-    ${XERCESC_LIBRARIES}
-    #MgWebApp${MG_VERSION_SUFFIX}
-# Only needed for Linux
-if (UNIX)
-    file(COPY "InitializeWebTier.cpp" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
-    install( TARGETS MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} DESTINATION ${MG_DOTNET_OUTPUT_DIR})
-endif (UNIX)
-file(COPY "dotnetcore.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+file(COPY "dotnetcore_split.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
Added: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt	                        (rev 0)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -0,0 +1,79 @@
+project(FoundationUnmanagedApi)
+set(FoundationUnmanagedApi_SRCS
+    ${CMAKE_CURRENT_BINARY_DIR}/FoundationUnmanagedApi_wrap.cpp
+file(COPY "InitializeLibrary.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+add_library(FoundationUnmanagedApi SHARED ${FoundationUnmanagedApi_SRCS})
+add_dependencies(FoundationUnmanagedApi IMake)
+if (UNIX)
+    add_definitions(-DDOTNETCORE)
+    # NOTE: We don't care where this source is generated because the C# source is only built on windows
+    set(MG_DOTNET_PROJECT_DIR ${CMAKE_CURRENT_BINARY_DIR})
+    set_target_properties(FoundationUnmanagedApi PROPERTIES INSTALL_RPATH "$ORIGIN")
+endif (UNIX)
+if (MSVC)
+    add_definitions(-DSWIG_PUBLIC_API)
+    add_definitions(/bigobj)
+    set_target_properties(FoundationUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
+    set_target_properties(FoundationUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
+    set_target_properties(FoundationUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
+endif (MSVC)
+set(IMAKE_RELATIVE_RESOLUTION "-r ${CMAKE_CURRENT_SOURCE_DIR}")
+if (UNIX)
+    set(IMAKE_RELATIVE_RESOLUTION "-a")
+endif (UNIX)
+set(SWIG_DOTNET_DEFS "")
+if (WIN32)
+    set(SWIG_DOTNET_DEFS "-DWIN32")
+endif (WIN32)
+message(STATUS "Using IMake at: ${IMAKE_TOOL}")
+add_custom_command(OUTPUT ${FoundationUnmanagedApi_SRCS}
+    COMMAND ${CMAKE_COMMAND} -E echo Removing: ${MG_DOTNET_PROJECT_DIR}/*.cs
+    COMMAND ${CMAKE_COMMAND} -E remove -f
+            ${MG_DOTNET_PROJECT_DIR}/*.cs
+    COMMAND ${CMAKE_COMMAND} -E echo Regenerating: ${MG_DOTNET_PROJECT_DIR}/Constants.cs
+    COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/FoundationConstants.xml
+            -l "C#"
+            ${IMAKE_RELATIVE_RESOLUTION}
+            -o ${MG_DOTNET_PROJECT_DIR}/Constants.cs
+            -t
+    COMMAND ${CMAKE_COMMAND} -E copy
+            ${CMAKE_CURRENT_BINARY_DIR}/../dotnetcore_split.i
+            ${CMAKE_CURRENT_BINARY_DIR}/language.i
+    COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/FoundationApiGen.xml
+            -l "C#"
+            -x "FoundationApi"
+            -o ${CMAKE_CURRENT_BINARY_DIR}
+    COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [DotNet]. Output Dir: ${MG_DOTNET_PROJECT_DIR}
+    COMMAND ${SWIG_EXECUTABLE} -c++ -csharp
+            ${SWIG_DOTNET_DEFS} -DDOTNETCORE -DSWIG_CSHARP_NO_EXCEPTION_HELPER
+            -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER
+            -namespace OSGeo.MapGuide
+            -nodefaultctor -nodefaultdtor
+            -module FoundationUnmanagedApi
+            -o "${CMAKE_CURRENT_BINARY_DIR}/FoundationUnmanagedApi_wrap.cpp"
+            -outdir "${MG_DOTNET_PROJECT_DIR}"
+            "${CMAKE_CURRENT_BINARY_DIR}/FoundationApi.i"
+target_link_libraries(FoundationUnmanagedApi
+    ${ACE_LIBRARY}
+    MgFoundation${MG_VERSION_SUFFIX}
+    #MgGeometry${MG_VERSION_SUFFIX}
+    #MgPlatformBase${MG_VERSION_SUFFIX}
+    #MgMapGuideCommon${MG_VERSION_SUFFIX}
+    #MgHttpHandler${MG_VERSION_SUFFIX}
+    #MgMdfModel${MG_VERSION_SUFFIX}
+    #MgMdfParser${MG_VERSION_SUFFIX}
+    #MgWebApp${MG_VERSION_SUFFIX}
+    ${XERCESC_LIBRARIES}
+install( TARGETS FoundationUnmanagedApi DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT} )
Added: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt
Added: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt
Added: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt
Added: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Web/CMakeLists.txt
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore.i
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore.i	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore.i	2020-11-26 15:14:38 UTC (rev 9803)
@@ -130,7 +130,7 @@
     xstring u16String;
     UnicodeString::UTF32toUTF16((const LCh*) $1.c_str(), u16String);
     $result = mg_string_callback((int)(u16String.length()+1)*sizeof(LCh));
-    XMLString::copyString((XMLCh*)$result, u16String.c_str());
+    MgUtil::copyString((XMLCh*)$result, u16String.c_str());
 #endif
 #else
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore_split.i
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore_split.i	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/dotnetcore_split.i	2020-11-26 15:14:38 UTC (rev 9803)
@@ -129,7 +129,7 @@
     xstring u16String;
 #endif
 #else
Modified: sandbox/jng/vanilla_swig/Bindings/src/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/CMakeLists.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -1,2 +1,10 @@
+set(MG_COMPONENT ${MG_COMPONENT_COMMON})
+set_install_subdir("")
+find_package(SWIG 4.0)
+set(IMAKE_TOOL ${CMAKE_CURRENT_BINARY_DIR}/IMake/IMake)
+file(COPY "SwigCommon" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
 add_subdirectory(IMake)
 add_subdirectory(Bindings)
Modified: sandbox/jng/vanilla_swig/Bindings/src/IMake/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/IMake/CMakeLists.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/IMake/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -1,6 +1,6 @@
 project(IMake)
-    ${TCLAP_INCLUDE}
+    ${TCLAP_INCLUDE_DIR}
 set(IMake_SRCS
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/DotNet/coreclr_compat.i	2020-11-26 15:14:38 UTC (rev 9803)
@@ -280,7 +280,7 @@
     xstring u16String;
     UnicodeString::UTF32toUTF16((const LCh*) clsName.c_str(), u16String);
-    XMLString::copyString((XMLCh*)result, u16String.c_str());
+    MgUtil::copyString((XMLCh*)result, u16String.c_str());
 #endif
     return result;
Modified: sandbox/jng/vanilla_swig/CMakeLists.txt
--- sandbox/jng/vanilla_swig/CMakeLists.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -265,6 +265,7 @@
 if (NOT MG_COMMON_SUBSET_ONLY)
     add_subdirectory(UnitTest)
 endif (NOT MG_COMMON_SUBSET_ONLY)
+add_subdirectory(Bindings)
 if (WITH_DESKTOP)
     add_subdirectory(Desktop)
Modified: sandbox/jng/vanilla_swig/Common/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Common/CMakeLists.txt	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/Common/CMakeLists.txt	2020-11-26 15:14:38 UTC (rev 9803)
@@ -46,6 +46,11 @@
         DESTINATION ${MG_INSTALL_PREFIX}/include/Common
         FILES_MATCHING PATTERN *.h
+    file(COPY "CoordinateSystem" DESTINATION ${CMAKE_CURRENT_BINARY_DIR} FILES_MATCHING PATTERN *.h)
+    file(COPY "Foundation" DESTINATION ${CMAKE_CURRENT_BINARY_DIR} FILES_MATCHING PATTERN *.h)
+    file(COPY "Geometry" DESTINATION ${CMAKE_CURRENT_BINARY_DIR} FILES_MATCHING PATTERN *.h)
+    file(COPY "MapGuideCommon" DESTINATION ${CMAKE_CURRENT_BINARY_DIR} FILES_MATCHING PATTERN *.h)
+    file(COPY "PlatformBase" DESTINATION ${CMAKE_CURRENT_BINARY_DIR} FILES_MATCHING PATTERN *.h)
 configure_file(${CMAKE_MODULE_PATH}/../configs/ProductVersion.h.in ${MG_AUTO_GENERATED_HEADER_DIR}/ProductVersion.h)
Modified: sandbox/jng/vanilla_swig/cmake/modules/FindMapGuideThirdparty.cmake
--- sandbox/jng/vanilla_swig/cmake/modules/FindMapGuideThirdparty.cmake	2020-11-21 15:32:08 UTC (rev 9802)
+++ sandbox/jng/vanilla_swig/cmake/modules/FindMapGuideThirdparty.cmake	2020-11-26 15:14:38 UTC (rev 9803)
@@ -192,10 +192,11 @@
     endif (INTERNAL_ZLIB)
     find_package(FDO REQUIRED)
-    find_package(TCLAP REQUIRED)
     find_package(CppHttpLib REQUIRED)
     find_package(LinuxApt REQUIRED)
     find_package(DbXmlInternal REQUIRED)
     find_package(Ant REQUIRED)
-endif (NOT MG_COMMON_SUBSET_ONLY)
+endif (NOT MG_COMMON_SUBSET_ONLY)
+find_package(TCLAP REQUIRED)
More information about the mapguide-commits mailing list
