[mapguide-commits] r9804 - in sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet: . Geometry MapGuideCommon PlatformBase
svn_mapguide at osgeo.org
Thu Nov 26 07:26:22 PST 2020
Author: jng
Date: 2020-11-26 07:26:21 -0800 (Thu, 26 Nov 2020)
New Revision: 9804
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt
Get Geometry/PlatformBase/MapGuideCommon .net glue libraries building on the Linux side
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt 2020-11-26 15:14:38 UTC (rev 9803)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt 2020-11-26 15:26:21 UTC (rev 9804)
@@ -19,93 +19,4 @@
add_subdirectory(MapGuideCommon)
add_subdirectory(Web)
-#set(DotNetUnmanagedApi_SRCS
-# ${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp
-#add_library(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} SHARED ${DotNetUnmanagedApi_SRCS})
-#add_dependencies(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} IMake)
-#if (UNIX)
-# add_definitions(-DDOTNETCORE)
-#endif (UNIX)
-#if (MSVC)
-# add_definitions(-DSWIG_PUBLIC_API)
-# add_definitions(/bigobj)
-# set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
-# set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
-# set_target_properties(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
-#endif (MSVC)
-#set(IMAKE_RELATIVE_RESOLUTION "-r ${CMAKE_CURRENT_SOURCE_DIR}")
-#if (UNIX)
-# set(IMAKE_RELATIVE_RESOLUTION "-a")
-#endif (UNIX)
-#set(SWIG_DOTNET_DEFS "")
-#if (WIN32)
-# set(SWIG_DOTNET_DEFS "-DWIN32")
-#endif (WIN32)
-#message(STATUS "Using IMake at: ${IMAKE_TOOL}")
-#add_custom_command(OUTPUT ${DotNetUnmanagedApi_SRCS}
-# COMMAND ${CMAKE_COMMAND} -E echo Removing: ${MG_DOTNET_PROJECT_DIR}/*.cs
-# COMMAND ${CMAKE_COMMAND} -E remove -f
-# ${MG_DOTNET_PROJECT_DIR}/*.cs
-# COMMAND ${CMAKE_COMMAND} -E echo Regenerating: ${MG_DOTNET_PROJECT_DIR}/Constants.cs
-# COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/Constants.xml
-# -l "C#"
-# ${IMAKE_RELATIVE_RESOLUTION}
-# -o ${MG_DOTNET_PROJECT_DIR}/Constants.cs
-# -t
-# COMMAND ${CMAKE_COMMAND} -E copy
-# ${CMAKE_CURRENT_BINARY_DIR}/dotnetcore.i
-# ${CMAKE_CURRENT_BINARY_DIR}/language.i
-# COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/MapGuideApiGen.xml
-# -l "C#"
-# -o ${CMAKE_CURRENT_BINARY_DIR}
-# COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [DotNet]. Output Dir: ${MG_DOTNET_PROJECT_DIR}
-# COMMAND ${SWIG_TOOL} -c++ -csharp
-# ${SWIG_DOTNET_DEFS} -DDOTNETCORE -DSWIG_CSHARP_NO_EXCEPTION_HELPER
-# -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER
-# -namespace OSGeo.MapGuide
-# -nodefaultctor -nodefaultdtor
-# -module MapGuideDotNetUnmanagedApi
-# -o "${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp"
-# -outdir "${MG_DOTNET_PROJECT_DIR}"
-# "${CMAKE_CURRENT_BINARY_DIR}/MapGuideApi.i"
-# ${MG_DOTNET_PROJECT_DIR}/MapGuideDotNetUnmanagedApi.cs
-#target_link_libraries(MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX}
-# ${ACE_LIBRARY}
-# ${MG_FOUNDATION_LIBRARY}
-# ${MG_GEOMETRY_LIBRARY}
-# ${MG_PLATFORMBASE_LIBRARY}
-# ${MG_COMMON_LIBRARY}
-# ${MG_HTTPHANDLER_LIBRARY}
-# ${MG_WEBAPP_LIBRARY}
-# ${MG_MDFMODEL_LIBRARY}
-# ${MG_MDFPARSER_LIBRARY}
-# ${MG_WEBSUPPORT_LIBRARY}
-# #MgFoundation${MG_VERSION_SUFFIX}
-# #MgGeometry${MG_VERSION_SUFFIX}
-# #MgPlatformBase${MG_VERSION_SUFFIX}
-# #MgMapGuideCommon${MG_VERSION_SUFFIX}
-# #MgHttpHandler${MG_VERSION_SUFFIX}
-# #MgMdfModel${MG_VERSION_SUFFIX}
-# #MgMdfParser${MG_VERSION_SUFFIX}
-# ${XERCESC_LIBRARIES}
-# #MgWebApp${MG_VERSION_SUFFIX}
-## Only needed for Linux
-#if (UNIX)
-# file(COPY "InitializeWebTier.cpp" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
-# install( TARGETS MapGuideDotNetUnmanagedApi${MG_VERSION_SUFFIX} DESTINATION ${MG_DOTNET_OUTPUT_DIR})
-#endif (UNIX)
-#file(COPY "dotnetcore.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
file(COPY "dotnetcore_split.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt 2020-11-26 15:14:38 UTC (rev 9803)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt 2020-11-26 15:26:21 UTC (rev 9804)
@@ -0,0 +1,70 @@
+project(GeometryUnmanagedApi)
+set(GeometryUnmanagedApi_SRCS
+ ${CMAKE_CURRENT_BINARY_DIR}/GeometryUnmanagedApi_wrap.cpp
+add_library(GeometryUnmanagedApi SHARED ${GeometryUnmanagedApi_SRCS})
+add_dependencies(GeometryUnmanagedApi IMake)
+if (UNIX)
+ add_definitions(-DDOTNETCORE)
+ # NOTE: We don't care where this source is generated because the C# source is only built on windows
+ set(MG_DOTNET_PROJECT_DIR ${CMAKE_CURRENT_BINARY_DIR})
+ set_target_properties(GeometryUnmanagedApi PROPERTIES INSTALL_RPATH "$ORIGIN")
+endif (UNIX)
+if (MSVC)
+ add_definitions(-DSWIG_PUBLIC_API)
+ add_definitions(/bigobj)
+ set_target_properties(GeometryUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
+ set_target_properties(GeometryUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
+ set_target_properties(GeometryUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
+endif (MSVC)
+set(IMAKE_RELATIVE_RESOLUTION "-r ${CMAKE_CURRENT_SOURCE_DIR}")
+if (UNIX)
+ set(IMAKE_RELATIVE_RESOLUTION "-a")
+endif (UNIX)
+set(SWIG_DOTNET_DEFS "")
+if (WIN32)
+ set(SWIG_DOTNET_DEFS "-DWIN32")
+endif (WIN32)
+message(STATUS "Using IMake at: ${IMAKE_TOOL}")
+add_custom_command(OUTPUT ${GeometryUnmanagedApi_SRCS}
+ COMMAND ${CMAKE_COMMAND} -E echo Removing: ${MG_DOTNET_PROJECT_DIR}/*.cs
+ COMMAND ${CMAKE_COMMAND} -E remove -f
+ ${MG_DOTNET_PROJECT_DIR}/*.cs
+ COMMAND ${CMAKE_COMMAND} -E echo Regenerating: ${MG_DOTNET_PROJECT_DIR}/Constants.cs
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/GeometryConstants.xml
+ -l "C#"
+ ${IMAKE_RELATIVE_RESOLUTION}
+ -o ${MG_DOTNET_PROJECT_DIR}/Constants.cs
+ -t
+ COMMAND ${CMAKE_COMMAND} -E copy
+ ${CMAKE_CURRENT_BINARY_DIR}/../dotnetcore_split.i
+ ${CMAKE_CURRENT_BINARY_DIR}/language.i
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/GeometryApiGen.xml
+ -l "C#"
+ -x "GeometryApi"
+ -o ${CMAKE_CURRENT_BINARY_DIR}
+ COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [DotNet]. Output Dir: ${MG_DOTNET_PROJECT_DIR}
+ COMMAND ${SWIG_EXECUTABLE} -c++ -csharp
+ ${SWIG_DOTNET_DEFS} -DDOTNETCORE -DSWIG_CSHARP_NO_EXCEPTION_HELPER
+ -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER
+ -namespace OSGeo.MapGuide
+ -nodefaultctor -nodefaultdtor
+ -module GeometryUnmanagedApi
+ -o "${CMAKE_CURRENT_BINARY_DIR}/GeometryUnmanagedApi_wrap.cpp"
+ -outdir "${MG_DOTNET_PROJECT_DIR}"
+ "${CMAKE_CURRENT_BINARY_DIR}/GeometryApi.i"
+target_link_libraries(GeometryUnmanagedApi
+ ${ACE_LIBRARY}
+ MgGeometry${MG_VERSION_SUFFIX}
+ ${XERCESC_LIBRARIES}
+install( TARGETS GeometryUnmanagedApi DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT} )
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt 2020-11-26 15:14:38 UTC (rev 9803)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt 2020-11-26 15:26:21 UTC (rev 9804)
@@ -0,0 +1,70 @@
+project(MapGuideCommonUnmanagedApi)
+set(MapGuideCommonUnmanagedApi_SRCS
+ ${CMAKE_CURRENT_BINARY_DIR}/MapGuideCommonUnmanagedApi_wrap.cpp
+add_library(MapGuideCommonUnmanagedApi SHARED ${MapGuideCommonUnmanagedApi_SRCS})
+add_dependencies(MapGuideCommonUnmanagedApi IMake)
+if (UNIX)
+ set_target_properties(MapGuideCommonUnmanagedApi PROPERTIES INSTALL_RPATH "$ORIGIN")
+endif (UNIX)
+if (MSVC)
+ set_target_properties(MapGuideCommonUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
+ set_target_properties(MapGuideCommonUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
+ set_target_properties(MapGuideCommonUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
+endif (MSVC)
+if (UNIX)
+endif (UNIX)
+if (WIN32)
+endif (WIN32)
+add_custom_command(OUTPUT ${MapGuideCommonUnmanagedApi_SRCS}
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/MapGuideCommonConstants.xml
+ -l "C#"
+ -t
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/MapGuideCommonApiGen.xml
+ -l "C#"
+ -x "MapGuideCommonApi"
+ -module MapGuideCommonUnmanagedApi
+ -o "${CMAKE_CURRENT_BINARY_DIR}/MapGuideCommonUnmanagedApi_wrap.cpp"
+ "${CMAKE_CURRENT_BINARY_DIR}/MapGuideCommonApi.i"
+target_link_libraries(MapGuideCommonUnmanagedApi
+ ${ACE_LIBRARY}
+ MgMapGuideCommon${MG_VERSION_SUFFIX}
+install( TARGETS MapGuideCommonUnmanagedApi DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT} )
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt 2020-11-26 15:14:38 UTC (rev 9803)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt 2020-11-26 15:26:21 UTC (rev 9804)
@@ -0,0 +1,70 @@
+project(PlatformBaseUnmanagedApi)
+set(PlatformBaseUnmanagedApi_SRCS
+ ${CMAKE_CURRENT_BINARY_DIR}/PlatformBaseUnmanagedApi_wrap.cpp
+add_library(PlatformBaseUnmanagedApi SHARED ${PlatformBaseUnmanagedApi_SRCS})
+add_dependencies(PlatformBaseUnmanagedApi IMake)
+if (UNIX)
+ set_target_properties(PlatformBaseUnmanagedApi PROPERTIES INSTALL_RPATH "$ORIGIN")
+endif (UNIX)
+if (MSVC)
+ set_target_properties(PlatformBaseUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY ${MG_DOTNET_OUTPUT_DIR} )
+ set_target_properties(PlatformBaseUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_DEBUG ${MG_DOTNET_OUTPUT_DIR} )
+ set_target_properties(PlatformBaseUnmanagedApi PROPERTIES RUNTIME_OUTPUT_DIRECTORY_RELEASE ${MG_DOTNET_OUTPUT_DIR} )
+endif (MSVC)
+if (UNIX)
+endif (UNIX)
+if (WIN32)
+endif (WIN32)
+add_custom_command(OUTPUT ${PlatformBaseUnmanagedApi_SRCS}
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/PlatformBaseConstants.xml
+ -l "C#"
+ -t
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/PlatformBaseApiGen.xml
+ -l "C#"
+ -x "PlatformBaseApi"
+ -module PlatformBaseUnmanagedApi
+ -o "${CMAKE_CURRENT_BINARY_DIR}/PlatformBaseUnmanagedApi_wrap.cpp"
+ "${CMAKE_CURRENT_BINARY_DIR}/PlatformBaseApi.i"
+target_link_libraries(PlatformBaseUnmanagedApi
+ ${ACE_LIBRARY}
+ MgPlatformBase${MG_VERSION_SUFFIX}
+install( TARGETS PlatformBaseUnmanagedApi DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT} )
More information about the mapguide-commits
