[mapguide-commits] r9842 - trunk/MgDev/Doc/samples/clientsamples/assets
svn_mapguide at osgeo.org
Thu May 27 05:41:07 PDT 2021
Author: jng
Date: 2021-05-27 05:41:07 -0700 (Thu, 27 May 2021)
New Revision: 9842
Removed:
trunk/MgDev/Doc/samples/clientsamples/assets/ol-debug.js
trunk/MgDev/Doc/samples/clientsamples/assets/ol.css
trunk/MgDev/Doc/samples/clientsamples/assets/ol.js
#2810: Remove ol.js in assets as we should be using the ol.js under viewerfiles that is a newer version
Deleted: trunk/MgDev/Doc/samples/clientsamples/assets/ol-debug.js
--- trunk/MgDev/Doc/samples/clientsamples/assets/ol-debug.js 2021-05-27 12:31:59 UTC (rev 9841)
+++ trunk/MgDev/Doc/samples/clientsamples/assets/ol-debug.js 2021-05-27 12:41:07 UTC (rev 9842)
@@ -1,92034 +0,0 @@
-// OpenLayers. See https://openlayers.org/
-// License: https://raw.githubusercontent.com/openlayers/openlayers/master/LICENSE.md
-// Version: v4.1.0
-;(function (root, factory) {
- if (typeof exports === "object") {
- module.exports = factory();
- } else if (typeof define === "function" && define.amd) {
- define([], factory);
- } else {
- root.ol = factory();
-}(this, function () {
- var OPENLAYERS = {};
- var goog = this.goog = {};
-this.CLOSURE_NO_DEPS = true;
-// Copyright 2006 The Closure Library Authors. All Rights Reserved.
-// Licensed under the Apache License, Version 2.0 (the "License");
-// you may not use this file except in compliance with the License.
-// You may obtain a copy of the License at
-// http://www.apache.org/licenses/LICENSE-2.0
-// Unless required by applicable law or agreed to in writing, software
-// distributed under the License is distributed on an "AS-IS" BASIS,
-// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
-// See the License for the specific language governing permissions and
-// limitations under the License.
- * @fileoverview Bootstrap for the Google JS Library (Closure).
- * In uncompiled mode base.js will write out Closure's deps file, unless the
- * global <code>CLOSURE_NO_DEPS</code> is set to true. This allows projects to
- * include their own deps file(s) from different locations.
- * Avoid including base.js more than once. This is strictly discouraged and not
- * supported. goog.require(...) won't work properly in that case.
- * @author arv at google.com (Erik Arvidsson)
- * @provideGoog
- * @define {boolean} Overridden to true by the compiler when
- * --process_closure_primitives is specified.
-var COMPILED = false;
- * Base namespace for the Closure library. Checks to see goog is already
- * defined in the current scope before assigning to prevent clobbering if
- * base.js is loaded more than once.
- * @const
-var goog = goog || {};
- * Reference to the global context. In most cases this will be 'window'.
-goog.global = this;
- * A hook for overriding the define values in uncompiled mode.
- * In uncompiled mode, {@code CLOSURE_UNCOMPILED_DEFINES} may be defined before
- * loading base.js. If a key is defined in {@code CLOSURE_UNCOMPILED_DEFINES},
- * {@code goog.define} will use the value instead of the default value. This
- * allows flags to be overwritten without compilation (this is normally
- * accomplished with the compiler's "define" flag).
- * Example:
- * <pre>
- * var CLOSURE_UNCOMPILED_DEFINES = {'goog.DEBUG': false};
- * </pre>
- * @type {Object<string, (string|number|boolean)>|undefined}
-goog.global.CLOSURE_UNCOMPILED_DEFINES;
- * A hook for overriding the define values in uncompiled or compiled mode,
- * like CLOSURE_UNCOMPILED_DEFINES but effective in compiled code. In
- * uncompiled code CLOSURE_UNCOMPILED_DEFINES takes precedence.
- * Also unlike CLOSURE_UNCOMPILED_DEFINES the values must be number, boolean or
- * string literals or the compiler will emit an error.
- * While any @define value may be set, only those set with goog.define will be
- * effective for uncompiled code.
- * Example:
- * <pre>
- * var CLOSURE_DEFINES = {'goog.DEBUG': false} ;
- * </pre>
-goog.global.CLOSURE_DEFINES;
- * Returns true if the specified value is not undefined.
- * WARNING: Do not use this to test if an object has a property. Use the in
- * operator instead.
- * @param {?} val Variable to test.
- * @return {boolean} Whether variable is defined.
-goog.isDef = function(val) {
- // void 0 always evaluates to undefined and hence we do not need to depend on
- // the definition of the global variable named 'undefined'.
- return val !== void 0;
- * Builds an object structure for the provided namespace path, ensuring that
- * names that already exist are not overwritten. For example:
- * "a.b.c" -> a = {};a.b={};a.b.c={};
- * Used by goog.provide and goog.exportSymbol.
- * @param {string} name name of the object that this file defines.
- * @param {*=} opt_object the object to expose at the end of the path.
- * @param {Object=} opt_objectToExportTo The object to add the path to; default
- * is |goog.global|.
- * @private
-goog.exportPath_ = function(name, opt_object, opt_objectToExportTo) {
- var parts = name.split('.');
- var cur = opt_objectToExportTo || goog.global;
- // Internet Explorer exhibits strange behavior when throwing errors from
- // methods externed in this manner. See the testExportSymbolExceptions in
- // base_test.html for an example.
- if (!(parts[0] in cur) && cur.execScript) {
- cur.execScript('var ' + parts[0]);
- // Certain browsers cannot parse code in the form for((a in b); c;);
- // This pattern is produced by the JSCompiler when it collapses the
- // statement above into the conditional loop below. To prevent this from
- // happening, use a for-loop and reserve the init logic as below.
- // Parentheses added to eliminate strict JS warning in Firefox.
- for (var part; parts.length && (part = parts.shift());) {
- if (!parts.length && goog.isDef(opt_object)) {
- // last part and we have an object; use it
- cur[part] = opt_object;
- } else if (cur[part] && Object.prototype.hasOwnProperty.call(cur, part)) {
- cur = cur[part];
- } else {
- cur = cur[part] = {};
- * Defines a named value. In uncompiled mode, the value is retrieved from
- * CLOSURE_DEFINES or CLOSURE_UNCOMPILED_DEFINES if the object is defined and
- * has the property specified, and otherwise used the defined defaultValue.
- * When compiled the default can be overridden using the compiler
- * options or the value set in the CLOSURE_DEFINES object.
- * @param {string} name The distinguished name to provide.
- * @param {string|number|boolean} defaultValue
-goog.define = function(name, defaultValue) {
- var value = defaultValue;
- if (!COMPILED) {
- if (goog.global.CLOSURE_UNCOMPILED_DEFINES &&
- Object.prototype.hasOwnProperty.call(
- goog.global.CLOSURE_UNCOMPILED_DEFINES, name)) {
- value = goog.global.CLOSURE_UNCOMPILED_DEFINES[name];
- } else if (
- goog.global.CLOSURE_DEFINES &&
- goog.global.CLOSURE_DEFINES, name)) {
- value = goog.global.CLOSURE_DEFINES[name];
- goog.exportPath_(name, value);
- * @define {boolean} DEBUG is provided as a convenience so that debugging code
- * that should not be included in a production js_binary can be easily stripped
- * by specifying --define goog.DEBUG=false to the JSCompiler. For example, most
- * toString() methods should be declared inside an "if (goog.DEBUG)" conditional
- * because they are generally used for debugging purposes and it is difficult
- * for the JSCompiler to statically determine whether they are used.
-goog.define('goog.DEBUG', true);
- * @define {string} LOCALE defines the locale being used for compilation. It is
- * used to select locale specific data to be compiled in js binary. BUILD rule
- * can specify this value by "--define goog.LOCALE=<locale_name>" as JSCompiler
- * option.
- * Take into account that the locale code format is important. You should use
- * the canonical Unicode format with hyphen as a delimiter. Language must be
- * lowercase, Language Script - Capitalized, Region - UPPERCASE.
- * There are few examples: pt-BR, en, en-US, sr-Latin-BO, zh-Hans-CN.
- * See more info about locale codes here:
- * http://www.unicode.org/reports/tr35/#Unicode_Language_and_Locale_Identifiers
- * For language codes you should use values defined by ISO 693-1. See it here
- * http://www.w3.org/WAI/ER/IG/ert/iso639.htm. There is only one exception from
- * this rule: the Hebrew language. For legacy reasons the old code (iw) should
- * be used instead of the new code (he), see http://wiki/Main/IIISynonyms.
-goog.define('goog.LOCALE', 'en'); // default to en
- * @define {boolean} Whether this code is running on trusted sites.
- * On untrusted sites, several native functions can be defined or overridden by
- * external libraries like Prototype, Datejs, and JQuery and setting this flag
- * to false forces closure to use its own implementations when possible.
- * If your JavaScript can be loaded by a third party site and you are wary about
- * relying on non-standard implementations, specify
- * "--define goog.TRUSTED_SITE=false" to the JSCompiler.
-goog.define('goog.TRUSTED_SITE', true);
- * @define {boolean} Whether a project is expected to be running in strict mode.
- * This define can be used to trigger alternate implementations compatible with
- * running in EcmaScript Strict mode or warn about unavailable functionality.
- * @see https://goo.gl/PudQ4y
-goog.define('goog.STRICT_MODE_COMPATIBLE', false);
- * @define {boolean} Whether code that calls {@link goog.setTestOnly} should
- * be disallowed in the compilation unit.
-goog.define('goog.DISALLOW_TEST_ONLY_CODE', COMPILED && !goog.DEBUG);
- * @define {boolean} Whether to use a Chrome app CSP-compliant method for
- * loading scripts via goog.require. @see appendScriptSrcNode_.
-goog.define('goog.ENABLE_CHROME_APP_SAFE_SCRIPT_LOADING', false);
- * Defines a namespace in Closure.
- * A namespace may only be defined once in a codebase. It may be defined using
- * goog.provide() or goog.module().
- * The presence of one or more goog.provide() calls in a file indicates
- * that the file defines the given objects/namespaces.
- * Provided symbols must not be null or undefined.
- * In addition, goog.provide() creates the object stubs for a namespace
- * (for example, goog.provide("goog.foo.bar") will create the object
- * goog.foo.bar if it does not already exist).
- * Build tools also scan for provide/require/module statements
- * to discern dependencies, build dependency files (see deps.js), etc.
- * @see goog.require
- * @see goog.module
- * @param {string} name Namespace provided by this file in the form
- * "goog.package.part".
-goog.provide = function(name) {
- if (goog.isInModuleLoader_()) {
- throw Error('goog.provide can not be used within a goog.module.');
- if (!COMPILED) {
- // Ensure that the same namespace isn't provided twice.
- // A goog.module/goog.provide maps a goog.require to a specific file
- if (goog.isProvided_(name)) {
- throw Error('Namespace "' + name + '" already declared.');
- goog.constructNamespace_(name);
- * @param {Object=} opt_obj The object to embed in the namespace.
- * @private
-goog.constructNamespace_ = function(name, opt_obj) {
- if (!COMPILED) {
- delete goog.implicitNamespaces_[name];
- var namespace = name;
- while ((namespace = namespace.substring(0, namespace.lastIndexOf('.')))) {
- if (goog.getObjectByName(namespace)) {
- break;
- goog.implicitNamespaces_[namespace] = true;
- goog.exportPath_(name, opt_obj);
- * Module identifier validation regexp.
- * Note: This is a conservative check, it is very possible to be more lenient,
- * the primary exclusion here is "/" and "\" and a leading ".", these
- * restrictions are intended to leave the door open for using goog.require
- * with relative file paths rather than module identifiers.
- * @private
-goog.VALID_MODULE_RE_ = /^[a-zA-Z_$][a-zA-Z0-9._$]*$/;
- * Defines a module in Closure.
- * Marks that this file must be loaded as a module and claims the namespace.
- * goog.module() has three requirements:
- * - goog.module may not be used in the same file as goog.provide.
- * - goog.module must be the first statement in the file.
- * - only one goog.module is allowed per file.
- * When a goog.module annotated file is loaded, it is enclosed in
- * a strict function closure. This means that:
- * - any variables declared in a goog.module file are private to the file
- * (not global), though the compiler is expected to inline the module.
- * - The code must obey all the rules of "strict" JavaScript.
- * - the file will be marked as "use strict"
- * NOTE: unlike goog.provide, goog.module does not declare any symbols by
- * itself. If declared symbols are desired, use
- * goog.module.declareLegacyNamespace().
- * See the public goog.module proposal: http://goo.gl/Va1hin
- * "goog.package.part", is expected but not required.
- * @return {void}
-goog.module = function(name) {
- if (!goog.isString(name) || !name ||
- name.search(goog.VALID_MODULE_RE_) == -1) {
- throw Error('Invalid module identifier');
- if (!goog.isInModuleLoader_()) {
- throw Error(
- 'Module ' + name + ' has been loaded incorrectly. Note, ' +
- 'modules cannot be loaded as normal scripts. They require some kind of ' +
- 'pre-processing step. You\'re likely trying to load a module via a ' +
- 'script tag or as a part of a concatenated bundle without rewriting the ' +
- 'module. For more info see: ' +
- 'https://github.com/google/closure-library/wiki/goog.module:-an-ES6-module-like-alternative-to-goog.provide.');
- if (goog.moduleLoaderState_.moduleName) {
- throw Error('goog.module may only be called once per module.');
- // Store the module name for the loader.
- goog.moduleLoaderState_.moduleName = name;
- if (!COMPILED) {
- * @param {string} name The module identifier.
- * @return {?} The module exports for an already loaded module or null.
- * Note: This is not an alternative to goog.require, it does not
- * indicate a hard dependency, instead it is used to indicate
- * an optional dependency or to access the exports of a module
- * that has already been loaded.
- * @suppress {missingProvide}
-goog.module.get = function(name) {
- return goog.module.getInternal_(name);
- * @private
-goog.module.getInternal_ = function(name) {
- if (!COMPILED) {
- if (name in goog.loadedModules_) {
- return goog.loadedModules_[name];
- } else if (!goog.implicitNamespaces_[name]) {
- var ns = goog.getObjectByName(name);
- return ns != null ? ns : null;
- return null;
- * @private {?{moduleName: (string|undefined), declareLegacyNamespace:boolean}}
-goog.moduleLoaderState_ = null;
- * @private
- * @return {boolean} Whether a goog.module is currently being initialized.
-goog.isInModuleLoader_ = function() {
- return goog.moduleLoaderState_ != null;
- * Provide the module's exports as a globally accessible object under the
- * module's declared name. This is intended to ease migration to goog.module
- * for files that have existing usages.
-goog.module.declareLegacyNamespace = function() {
- if (!COMPILED && !goog.isInModuleLoader_()) {
- throw new Error(
- 'goog.module.declareLegacyNamespace must be called from ' +
- 'within a goog.module');
- if (!COMPILED && !goog.moduleLoaderState_.moduleName) {
- throw Error(
- 'goog.module must be called prior to ' +
- 'goog.module.declareLegacyNamespace.');
- goog.moduleLoaderState_.declareLegacyNamespace = true;
- * Marks that the current file should only be used for testing, and never for
- * live code in production.
- * In the case of unit tests, the message may optionally be an exact namespace
- * for the test (e.g. 'goog.stringTest'). The linter will then ignore the extra
- * provide (if not explicitly defined in the code).
- * @param {string=} opt_message Optional message to add to the error that's
- * raised when used in production code.
-goog.setTestOnly = function(opt_message) {
- if (goog.DISALLOW_TEST_ONLY_CODE) {
- opt_message = opt_message || '';
- throw Error(
- 'Importing test-only code into non-debug environment' +
- (opt_message ? ': ' + opt_message : '.'));
- * Forward declares a symbol. This is an indication to the compiler that the
- * symbol may be used in the source yet is not required and may not be provided
- * in compilation.
- * The most common usage of forward declaration is code that takes a type as a
- * function parameter but does not need to require it. By forward declaring
- * instead of requiring, no hard dependency is made, and (if not required
- * elsewhere) the namespace may never be required and thus, not be pulled
- * into the JavaScript binary. If it is required elsewhere, it will be type
- * checked as normal.
- * Before using goog.forwardDeclare, please read the documentation at
- * https://github.com/google/closure-compiler/wiki/Bad-Type-Annotation to
- * understand the options and tradeoffs when working with forward declarations.
- * @param {string} name The namespace to forward declare in the form of
-goog.forwardDeclare = function(name) {};
- * Forward declare type information. Used to assign types to goog.global
- * referenced object that would otherwise result in unknown type references
- * and thus block property disambiguation.
-goog.forwardDeclare('Document');
-goog.forwardDeclare('HTMLScriptElement');
-goog.forwardDeclare('XMLHttpRequest');
-if (!COMPILED) {
- * Check if the given name has been goog.provided. This will return false for
- * names that are available only as implicit namespaces.
- * @param {string} name name of the object to look for.
- * @return {boolean} Whether the name has been provided.
- * @private
- goog.isProvided_ = function(name) {
- return (name in goog.loadedModules_) ||
- (!goog.implicitNamespaces_[name] &&
- goog.isDefAndNotNull(goog.getObjectByName(name)));
- * Namespaces implicitly defined by goog.provide. For example,
- * goog.provide('goog.events.Event') implicitly declares that 'goog' and
- * 'goog.events' must be namespaces.
- * @type {!Object<string, (boolean|undefined)>}
- * @private
- goog.implicitNamespaces_ = {'goog.module': true};
- // NOTE: We add goog.module as an implicit namespace as goog.module is defined
- // here and because the existing module package has not been moved yet out of
- // the goog.module namespace. This satisifies both the debug loader and
- // ahead-of-time dependency management.
- * Returns an object based on its fully qualified external name. The object
- * is not found if null or undefined. If you are using a compilation pass that
- * renames property names beware that using this function will not find renamed
- * properties.
- * @param {string} name The fully qualified name.
- * @param {Object=} opt_obj The object within which to look; default is
- * |goog.global|.
- * @return {?} The value (object or primitive) or, if not found, null.
-goog.getObjectByName = function(name, opt_obj) {
- var cur = opt_obj || goog.global;
- for (var part; part = parts.shift();) {
- if (goog.isDefAndNotNull(cur[part])) {
- cur = cur[part];
- } else {
- return null;
- return cur;
- * Globalizes a whole namespace, such as goog or goog.lang.
- * @param {!Object} obj The namespace to globalize.
- * @param {Object=} opt_global The object to add the properties to.
- * @deprecated Properties may be explicitly exported to the global scope, but
- * this should no longer be done in bulk.
-goog.globalize = function(obj, opt_global) {
- var global = opt_global || goog.global;
- for (var x in obj) {
- global[x] = obj[x];
- * Adds a dependency from a file to the files it requires.
- * @param {string} relPath The path to the js file.
- * @param {!Array<string>} provides An array of strings with
- * the names of the objects this file provides.
- * @param {!Array<string>} requires An array of strings with
- * the names of the objects this file requires.
- * @param {boolean|!Object<string>=} opt_loadFlags Parameters indicating
- * how the file must be loaded. The boolean 'true' is equivalent
- * to {'module': 'goog'} for backwards-compatibility. Valid properties
- * and values include {'module': 'goog'} and {'lang': 'es6'}.
-goog.addDependency = function(relPath, provides, requires, opt_loadFlags) {
- if (goog.DEPENDENCIES_ENABLED) {
- var provide, require;
- var path = relPath.replace(/\\/g, '/');
- var deps = goog.dependencies_;
- if (!opt_loadFlags || typeof opt_loadFlags === 'boolean') {
- opt_loadFlags = opt_loadFlags ? {'module': 'goog'} : {};
- for (var i = 0; provide = provides[i]; i++) {
- deps.nameToPath[provide] = path;
- deps.loadFlags[path] = opt_loadFlags;
- for (var j = 0; require = requires[j]; j++) {
- if (!(path in deps.requires)) {
- deps.requires[path] = {};
- deps.requires[path][require] = true;
-// NOTE(nnaze): The debug DOM loader was included in base.js as an original way
-// to do "debug-mode" development. The dependency system can sometimes be
-// confusing, as can the debug DOM loader's asynchronous nature.
-// With the DOM loader, a call to goog.require() is not blocking -- the script
-// will not load until some point after the current script. If a namespace is
-// needed at runtime, it needs to be defined in a previous script, or loaded via
-// require() with its registered dependencies.
-// User-defined namespaces may need their own deps file. For a reference on
-// creating a deps file, see:
-// Externally: https://developers.google.com/closure/library/docs/depswriter
-// Because of legacy clients, the DOM loader can't be easily removed from
-// base.js. Work is being done to make it disableable or replaceable for
-// different environments (DOM-less JavaScript interpreters like Rhino or V8,
-// for example). See bootstrap/ for more information.
- * @define {boolean} Whether to enable the debug loader.
- * If enabled, a call to goog.require() will attempt to load the namespace by
- * appending a script tag to the DOM (if the namespace has been registered).
- * If disabled, goog.require() will simply assert that the namespace has been
- * provided (and depend on the fact that some outside tool correctly ordered
- * the script).
-goog.define('goog.ENABLE_DEBUG_LOADER', true);
- * @param {string} msg
- * @private
-goog.logToConsole_ = function(msg) {
- if (goog.global.console) {
- goog.global.console['error'](msg);
- * Implements a system for the dynamic resolution of dependencies that works in
- * parallel with the BUILD system. Note that all calls to goog.require will be
- * stripped by the JSCompiler when the --process_closure_primitives option is
- * used.
- * @see goog.provide
- * @param {string} name Namespace to include (as was given in goog.provide()) in
- * the form "goog.package.part".
- * @return {?} If called within a goog.module file, the associated namespace or
- * module otherwise null.
-goog.require = function(name) {
- // If the object already exists we do not need do do anything.
- if (!COMPILED) {
- if (goog.ENABLE_DEBUG_LOADER && goog.IS_OLD_IE_) {
- goog.maybeProcessDeferredDep_(name);
- } else if (goog.ENABLE_DEBUG_LOADER) {
- var path = goog.getPathFromDeps_(name);
- if (path) {
- goog.writeScripts_(path);
- } else {
- var errorMessage = 'goog.require could not find: ' + name;
- goog.logToConsole_(errorMessage);
- throw Error(errorMessage);
- return null;
- * Path for included scripts.
- * @type {string}
-goog.basePath = '';
- * A hook for overriding the base path.
- * @type {string|undefined}
-goog.global.CLOSURE_BASE_PATH;
- * Whether to write out Closure's deps file. By default, the deps are written.
- * @type {boolean|undefined}
-goog.global.CLOSURE_NO_DEPS;
- * A function to import a single script. This is meant to be overridden when
- * Closure is being run in non-HTML contexts, such as web workers. It's defined
- * in the global scope so that it can be set before base.js is loaded, which
- * allows deps.js to be imported properly.
- * The function is passed the script source, which is a relative URI. It should
- * return true if the script was imported, false otherwise.
- * @type {(function(string): boolean)|undefined}
-goog.global.CLOSURE_IMPORT_SCRIPT;
- * Null function used for default values of callbacks, etc.
- * @return {void} Nothing.
-goog.nullFunction = function() {};
- * When defining a class Foo with an abstract method bar(), you can do:
- * Foo.prototype.bar = goog.abstractMethod
- * Now if a subclass of Foo fails to override bar(), an error will be thrown
- * when bar() is invoked.
- * Note: This does not take the name of the function to override as an argument
- * because that would make it more difficult to obfuscate our JavaScript code.
- * @type {!Function}
- * @throws {Error} when invoked to indicate the method should be overridden.
-goog.abstractMethod = function() {
- throw Error('unimplemented abstract method');
- * Adds a {@code getInstance} static method that always returns the same
- * instance object.
- * @param {!Function} ctor The constructor for the class to add the static
- * method to.
-goog.addSingletonGetter = function(ctor) {
- // instance_ is immediately set to prevent issues with sealed constructors
- // such as are encountered when a constructor is returned as the export object
- // of a goog.module in unoptimized code.
- ctor.instance_ = undefined;
- ctor.getInstance = function() {
- if (ctor.instance_) {
- return ctor.instance_;
- if (goog.DEBUG) {
- // NOTE: JSCompiler can't optimize away Array#push.
- goog.instantiatedSingletons_[goog.instantiatedSingletons_.length] = ctor;
- return ctor.instance_ = new ctor;
- * All singleton classes that have been instantiated, for testing. Don't read
- * it directly, use the {@code goog.testing.singleton} module. The compiler
- * removes this variable if unused.
- * @type {!Array<!Function>}
- * @private
-goog.instantiatedSingletons_ = [];
- * @define {boolean} Whether to load goog.modules using {@code eval} when using
- * the debug loader. This provides a better debugging experience as the
- * source is unmodified and can be edited using Chrome Workspaces or similar.
- * However in some environments the use of {@code eval} is banned
- * so we provide an alternative.
-goog.define('goog.LOAD_MODULE_USING_EVAL', true);
- * @define {boolean} Whether the exports of goog.modules should be sealed when
- * possible.
-goog.define('goog.SEAL_MODULE_EXPORTS', goog.DEBUG);
- * The registry of initialized modules:
- * the module identifier to module exports map.
- * @private @const {!Object<string, ?>}
-goog.loadedModules_ = {};
- * True if goog.dependencies_ is available.
- * @const {boolean}
-goog.DEPENDENCIES_ENABLED = !COMPILED && goog.ENABLE_DEBUG_LOADER;
- * @define {string} How to decide whether to transpile. Valid values
- * are 'always', 'never', and 'detect'. The default ('detect') is to
- * use feature detection to determine which language levels need
- * transpilation.
-// NOTE(user): we could expand this to accept a language level to bypass
-// detection: e.g. goog.TRANSPILE == 'es5' would transpile ES6 files but
-// would leave ES3 and ES5 files alone.
-goog.define('goog.TRANSPILE', 'detect');
- * @define {string} Path to the transpiler. Executing the script at this
- * path (relative to base.js) should define a function $jscomp.transpile.
-goog.define('goog.TRANSPILER', 'transpile.js');
-if (goog.DEPENDENCIES_ENABLED) {
- * This object is used to keep track of dependencies and other data that is
- * used for loading scripts.
- * @private
- * @type {{
- * loadFlags: !Object<string, !Object<string, string>>,
- * nameToPath: !Object<string, string>,
- * requires: !Object<string, !Object<string, boolean>>,
- * visited: !Object<string, boolean>,
- * written: !Object<string, boolean>,
- * deferred: !Object<string, string>
- goog.dependencies_ = {
- loadFlags: {}, // 1 to 1
- nameToPath: {}, // 1 to 1
- requires: {}, // 1 to many
- // Used when resolving dependencies to prevent us from visiting file twice.
- visited: {},
- written: {}, // Used to keep track of script files we have written.
- deferred: {} // Used to track deferred module evaluations in old IEs
- * Tries to detect whether is in the context of an HTML document.
- * @return {boolean} True if it looks like HTML document.
- * @private
- goog.inHtmlDocument_ = function() {
- /** @type {Document} */
- var doc = goog.global.document;
- return doc != null && 'write' in doc; // XULDocument misses write.
- * Tries to detect the base path of base.js script that bootstraps Closure.
- * @private
- goog.findBasePath_ = function() {
- if (goog.isDef(goog.global.CLOSURE_BASE_PATH)) {
- goog.basePath = goog.global.CLOSURE_BASE_PATH;
- return;
- } else if (!goog.inHtmlDocument_()) {
- return;
- var scripts = doc.getElementsByTagName('SCRIPT');
- // Search backwards since the current script is in almost all cases the one
- // that has base.js.
- for (var i = scripts.length - 1; i >= 0; --i) {
- var script = /** @type {!HTMLScriptElement} */ (scripts[i]);
- var src = script.src;
- var qmark = src.lastIndexOf('?');
- var l = qmark == -1 ? src.length : qmark;
- if (src.substr(l - 7, 7) == 'base.js') {
- goog.basePath = src.substr(0, l - 7);
- return;
- * Imports a script if, and only if, that script hasn't already been imported.
- * (Must be called at execution time)
- * @param {string} src Script source.
- * @param {string=} opt_sourceText The optionally source text to evaluate
- * @private
- goog.importScript_ = function(src, opt_sourceText) {
- var importScript =
- goog.global.CLOSURE_IMPORT_SCRIPT || goog.writeScriptTag_;
- if (importScript(src, opt_sourceText)) {
- goog.dependencies_.written[src] = true;
- * Whether the browser is IE9 or earlier, which needs special handling
- * for deferred modules.
- * @const @private {boolean}
- goog.IS_OLD_IE_ =
- !!(!goog.global.atob && goog.global.document && goog.global.document.all);
- * Given a URL initiate retrieval and execution of a script that needs
- * pre-processing.
- * @param {string} src Script source URL.
- * @param {boolean} isModule Whether this is a goog.module.
- * @param {boolean} needsTranspile Whether this source needs transpilation.
- * @private
- goog.importProcessedScript_ = function(src, isModule, needsTranspile) {
- // In an attempt to keep browsers from timing out loading scripts using
- // synchronous XHRs, put each load in its own script block.
- var bootstrap = 'goog.retrieveAndExec_("' + src + '", ' + isModule + ', ' +
- needsTranspile + ');';
- goog.importScript_('', bootstrap);
- /** @private {!Array<string>} */
- goog.queuedModules_ = [];
- * Return an appropriate module text. Suitable to insert into
- * a script tag (that is unescaped).
- * @param {string} srcUrl
- * @param {string} scriptText
- * @return {string}
- * @private
- goog.wrapModule_ = function(srcUrl, scriptText) {
- if (!goog.LOAD_MODULE_USING_EVAL || !goog.isDef(goog.global.JSON)) {
- return '' +
- 'goog.loadModule(function(exports) {' +
- '"use strict";' + scriptText +
- '\n' + // terminate any trailing single line comment.
- ';return exports' +
- '\n//# sourceURL=' + srcUrl + '\n';
- } else {
- return '' +
- 'goog.loadModule(' +
- goog.global.JSON.stringify(
- scriptText + '\n//# sourceURL=' + srcUrl + '\n') +
- // On IE9 and earlier, it is necessary to handle
- // deferred module loads. In later browsers, the
- // code to be evaluated is simply inserted as a script
- // block in the correct order. To eval deferred
- // code at the right time, we piggy back on goog.require to call
- // goog.maybeProcessDeferredDep_.
- // The goog.requires are used both to bootstrap
- // the loading process (when no deps are available) and
- // declare that they should be available.
- // Here we eval the sources, if all the deps are available
- // either already eval'd or goog.require'd. This will
- // be the case when all the dependencies have already
- // been loaded, and the dependent module is loaded.
- // But this alone isn't sufficient because it is also
- // necessary to handle the case where there is no root
- // that is not deferred. For that there we register for an event
- // and trigger goog.loadQueuedModules_ handle any remaining deferred
- // evaluations.
- * Handle any remaining deferred goog.module evals.
- * @private
- goog.loadQueuedModules_ = function() {
- var count = goog.queuedModules_.length;
- if (count > 0) {
- var queue = goog.queuedModules_;
- for (var i = 0; i < count; i++) {
- var path = queue[i];
- goog.maybeProcessDeferredPath_(path);
- * Eval the named module if its dependencies are
- * available.
- * @param {string} name The module to load.
- * @private
- goog.maybeProcessDeferredDep_ = function(name) {
- if (goog.isDeferredModule_(name) && goog.allDepsAreAvailable_(name)) {
- goog.maybeProcessDeferredPath_(goog.basePath + path);
- * @param {string} name The module to check.
- * @return {boolean} Whether the name represents a
- * module whose evaluation has been deferred.
- * @private
- goog.isDeferredModule_ = function(name) {
- var loadFlags = path && goog.dependencies_.loadFlags[path] || {};
- var languageLevel = loadFlags['lang'] || 'es3';
- if (path && (loadFlags['module'] == 'goog' ||
- goog.needsTranspile_(languageLevel))) {
- var abspath = goog.basePath + path;
- return (abspath) in goog.dependencies_.deferred;
- return false;
- * module whose declared dependencies have all been loaded
- * (eval'd or a deferred module load)
- * @private
- goog.allDepsAreAvailable_ = function(name) {
- if (path && (path in goog.dependencies_.requires)) {
- for (var requireName in goog.dependencies_.requires[path]) {
- if (!goog.isProvided_(requireName) &&
- !goog.isDeferredModule_(requireName)) {
- return false;
- return true;
- * @param {string} abspath
- * @private
- goog.maybeProcessDeferredPath_ = function(abspath) {
- if (abspath in goog.dependencies_.deferred) {
- var src = goog.dependencies_.deferred[abspath];
- delete goog.dependencies_.deferred[abspath];
- goog.globalEval(src);
- * Load a goog.module from the provided URL. This is not a general purpose
- * code loader and does not support late loading code, that is it should only
- * be used during page load. This method exists to support unit tests and
- * "debug" loaders that would otherwise have inserted script tags. Under the
- * hood this needs to use a synchronous XHR and is not recommeneded for
- * production code.
- * The module's goog.requires must have already been satisified; an exception
- * will be thrown if this is not the case. This assumption is that no
- * "deps.js" file exists, so there is no way to discover and locate the
- * module-to-be-loaded's dependencies and no attempt is made to do so.
- * There should only be one attempt to load a module. If
- * "goog.loadModuleFromUrl" is called for an already loaded module, an
- * exception will be throw.
- * @param {string} url The URL from which to attempt to load the goog.module.
- goog.loadModuleFromUrl = function(url) {
- // Because this executes synchronously, we don't need to do any additional
- // bookkeeping. When "goog.loadModule" the namespace will be marked as
- // having been provided which is sufficient.
- goog.retrieveAndExec_(url, true, false);
- * Writes a new script pointing to {@code src} directly into the DOM.
- * NOTE: This method is not CSP-compliant. @see goog.appendScriptSrcNode_ for
- * the fallback mechanism.
- * @param {string} src The script URL.
- * @private
- goog.writeScriptSrcNode_ = function(src) {
- goog.global.document.write(
- '<script type="text/javascript" src="' + src + '"></' +
- 'script>');
- * Appends a new script node to the DOM using a CSP-compliant mechanism. This
- * method exists as a fallback for document.write (which is not allowed in a
- * strict CSP context, e.g., Chrome apps).
- * NOTE: This method is not analogous to using document.write to insert a
- * <script> tag; specifically, the user agent will execute a script added by
- * document.write immediately after the current script block finishes
- * executing, whereas the DOM-appended script node will not be executed until
- * the entire document is parsed and executed. That is to say, this script is
- * added to the end of the script execution queue.
- * The page must not attempt to call goog.required entities until after the
- * document has loaded, e.g., in or after the window.onload callback.
- * @private
- goog.appendScriptSrcNode_ = function(src) {
- var scriptEl =
- /** @type {HTMLScriptElement} */ (doc.createElement('script'));
- scriptEl.type = 'text/javascript';
- scriptEl.src = src;
- scriptEl.defer = false;
- scriptEl.async = false;
- doc.head.appendChild(scriptEl);
- * The default implementation of the import function. Writes a script tag to
- * import the script.
- * @param {string} src The script url.
- * @return {boolean} True if the script was imported, false otherwise.
- * @private
- goog.writeScriptTag_ = function(src, opt_sourceText) {
- if (goog.inHtmlDocument_()) {
- /** @type {!HTMLDocument} */
- // If the user tries to require a new symbol after document load,
- // something has gone terribly wrong. Doing a document.write would
- // wipe out the page. This does not apply to the CSP-compliant method
- // of writing script tags.
- if (!goog.ENABLE_CHROME_APP_SAFE_SCRIPT_LOADING &&
- doc.readyState == 'complete') {
- // Certain test frameworks load base.js multiple times, which tries
- // to write deps.js each time. If that happens, just fail silently.
- // These frameworks wipe the page between each load of base.js, so this
- // is OK.
- var isDeps = /\bdeps.js$/.test(src);
- if (isDeps) {
- return false;
- } else {
- throw Error('Cannot write "' + src + '" after document load');
- if (opt_sourceText === undefined) {
- if (!goog.IS_OLD_IE_) {
- if (goog.ENABLE_CHROME_APP_SAFE_SCRIPT_LOADING) {
- goog.appendScriptSrcNode_(src);
- } else {
- goog.writeScriptSrcNode_(src);
- } else {
- var state = ' onreadystatechange=\'goog.onScriptLoad_(this, ' +
- ++goog.lastNonModuleScriptIndex_ + ')\' ';
- doc.write(
- '<script type="text/javascript" src="' + src + '"' + state +
- 'script>');
- } else {
- doc.write(
- '<script type="text/javascript">' +
- goog.protectScriptTag_(opt_sourceText) + '</' +
- 'script>');
- return true;
- } else {
- return false;
- * Rewrites closing script tags in input to avoid ending an enclosing script
- * tag.
- * @param {string} str
- * @private
- goog.protectScriptTag_ = function(str) {
- return str.replace(/<\/(SCRIPT)/ig, '\\x3c\\$1');
- * Determines whether the given language needs to be transpiled.
- * @param {string} lang
- * @private
- goog.needsTranspile_ = function(lang) {
- if (goog.TRANSPILE == 'always') {
- return true;
- } else if (goog.TRANSPILE == 'never') {
- return false;
- } else if (!goog.requiresTranspilation_) {
- goog.requiresTranspilation_ = goog.createRequiresTranspilation_();
- if (lang in goog.requiresTranspilation_) {
- return goog.requiresTranspilation_[lang];
- } else {
- throw new Error('Unknown language mode: ' + lang);
- /** @private {?Object<string, boolean>} */
- goog.requiresTranspilation_ = null;
- /** @private {number} */
- goog.lastNonModuleScriptIndex_ = 0;
- * A readystatechange handler for legacy IE
- * @param {!HTMLScriptElement} script
- * @param {number} scriptIndex
- * @private
- goog.onScriptLoad_ = function(script, scriptIndex) {
- // for now load the modules when we reach the last script,
- // later allow more inter-mingling.
- if (script.readyState == 'complete' &&
- goog.lastNonModuleScriptIndex_ == scriptIndex) {
- goog.loadQueuedModules_();
- return true;
- * Resolves dependencies based on the dependencies added using addDependency
- * and calls importScript_ in the correct order.
- * @param {string} pathToLoad The path from which to start discovering
- * dependencies.
- * @private
- goog.writeScripts_ = function(pathToLoad) {
- /** @type {!Array<string>} The scripts we need to write this time. */
- var scripts = [];
- var seenScript = {};
- /** @param {string} path */
- function visitNode(path) {
- if (path in deps.written) {
- return;
- // We have already visited this one. We can get here if we have cyclic
- // dependencies.
- if (path in deps.visited) {
- return;
- deps.visited[path] = true;
- if (path in deps.requires) {
- for (var requireName in deps.requires[path]) {
- // If the required name is defined, we assume that it was already
- // bootstrapped by other means.
- if (!goog.isProvided_(requireName)) {
- if (requireName in deps.nameToPath) {
- visitNode(deps.nameToPath[requireName]);
- } else {
- throw Error('Undefined nameToPath for ' + requireName);
- if (!(path in seenScript)) {
- seenScript[path] = true;
- scripts.push(path);
- visitNode(pathToLoad);
- // record that we are going to load all these scripts.
- for (var i = 0; i < scripts.length; i++) {
- var path = scripts[i];
- goog.dependencies_.written[path] = true;
- // If a module is loaded synchronously then we need to
- // clear the current inModuleLoader value, and restore it when we are
- // done loading the current "requires".
- var moduleState = goog.moduleLoaderState_;
- goog.moduleLoaderState_ = null;
- if (path) {
- var loadFlags = deps.loadFlags[path] || {};
- var needsTranspile = goog.needsTranspile_(languageLevel);
- if (loadFlags['module'] == 'goog' || needsTranspile) {
- goog.importProcessedScript_(
- goog.basePath + path, loadFlags['module'] == 'goog',
- needsTranspile);
- } else {
- goog.importScript_(goog.basePath + path);
- } else {
- goog.moduleLoaderState_ = moduleState;
- throw Error('Undefined script input');
- // restore the current "module loading state"
- * Looks at the dependency rules and tries to determine the script file that
- * fulfills a particular rule.
- * @param {string} rule In the form goog.namespace.Class or project.script.
- * @return {?string} Url corresponding to the rule, or null.
- * @private
- goog.getPathFromDeps_ = function(rule) {
- if (rule in goog.dependencies_.nameToPath) {
- return goog.dependencies_.nameToPath[rule];
- } else {
- return null;
- goog.findBasePath_();
- // Allow projects to manage the deps files themselves.
- if (!goog.global.CLOSURE_NO_DEPS) {
- goog.importScript_(goog.basePath + 'deps.js');
- * @package {?boolean}
- * Visible for testing.
-goog.hasBadLetScoping = null;
- * @package Visible for testing.
-goog.useSafari10Workaround = function() {
- if (goog.hasBadLetScoping == null) {
- var hasBadLetScoping;
- try {
- hasBadLetScoping = !eval(
- '"use strict";' +
- 'let x = 1; function f() { return typeof x; };' +
- 'f() == "number";');
- } catch (e) {
- // Assume that ES6 syntax isn't supported.
- hasBadLetScoping = false;
- goog.hasBadLetScoping = hasBadLetScoping;
- return goog.hasBadLetScoping;
- * @param {string} moduleDef
-goog.workaroundSafari10EvalBug = function(moduleDef) {
- return '(function(){' + moduleDef +
- '\n' + // Terminate any trailing single line comment.
- ';' + // Terminate any trailing expression.
- '})();\n';
- * @param {function(?):?|string} moduleDef The module definition.
-goog.loadModule = function(moduleDef) {
- // NOTE: we allow function definitions to be either in the from
- // of a string to eval (which keeps the original source intact) or
- // in a eval forbidden environment (CSP) we allow a function definition
- // which in its body must call {@code goog.module}, and return the exports
- // of the module.
- var previousState = goog.moduleLoaderState_;
- try {
- goog.moduleLoaderState_ = {
- moduleName: undefined,
- declareLegacyNamespace: false
- var exports;
- if (goog.isFunction(moduleDef)) {
- exports = moduleDef.call(undefined, {});
- } else if (goog.isString(moduleDef)) {
- if (goog.useSafari10Workaround()) {
- moduleDef = goog.workaroundSafari10EvalBug(moduleDef);
- exports = goog.loadModuleFromSource_.call(undefined, moduleDef);
- } else {
- throw Error('Invalid module definition');
- var moduleName = goog.moduleLoaderState_.moduleName;
- if (!goog.isString(moduleName) || !moduleName) {
- throw Error('Invalid module name \"' + moduleName + '\"');
- // Don't seal legacy namespaces as they may be uses as a parent of
- // another namespace
- if (goog.moduleLoaderState_.declareLegacyNamespace) {
- goog.constructNamespace_(moduleName, exports);
- } else if (
- goog.SEAL_MODULE_EXPORTS && Object.seal && typeof exports == 'object' &&
- exports != null) {
- Object.seal(exports);
- goog.loadedModules_[moduleName] = exports;
- } finally {
- goog.moduleLoaderState_ = previousState;
- * @private @const {function(string):?}
- * The new type inference warns because this function has no formal
- * parameters, but its jsdoc says that it takes one argument.
- * (The argument is used via arguments[0], but NTI does not detect this.)
- * @suppress {newCheckTypes}
-goog.loadModuleFromSource_ = function() {
- // NOTE: we avoid declaring parameters or local variables here to avoid
- // masking globals or leaking values into the module definition.
- 'use strict';
- var exports = {};
- eval(arguments[0]);
- return exports;
- * Normalize a file path by removing redundant ".." and extraneous "." file
- * path components.
- * @private
-goog.normalizePath_ = function(path) {
- var components = path.split('/');
- var i = 0;
- while (i < components.length) {
- if (components[i] == '.') {
- components.splice(i, 1);
- } else if (
- i && components[i] == '..' && components[i - 1] &&
- components[i - 1] != '..') {
- components.splice(--i, 2);
- } else {
- i++;
- return components.join('/');
- * Loads file by synchronous XHR. Should not be used in production environments.
- * @param {string} src Source URL.
- * @return {?string} File contents, or null if load failed.
- * @private
-goog.loadFileSync_ = function(src) {
- if (goog.global.CLOSURE_LOAD_FILE_SYNC) {
- return goog.global.CLOSURE_LOAD_FILE_SYNC(src);
- } else {
- try {
- /** @type {XMLHttpRequest} */
- var xhr = new goog.global['XMLHttpRequest']();
- xhr.open('get', src, false);
- xhr.send();
- // NOTE: Successful http: requests have a status of 200, but successful
- // file: requests may have a status of zero. Any other status, or a
- // thrown exception (particularly in case of file: requests) indicates
- // some sort of error, which we treat as a missing or unavailable file.
- return xhr.status == 0 || xhr.status == 200 ? xhr.responseText : null;
- } catch (err) {
- // No need to rethrow or log, since errors should show up on their own.
- return null;
- * Retrieve and execute a script that needs some sort of wrapping.
- * @param {boolean} isModule Whether to load as a module.
- * @param {boolean} needsTranspile Whether to transpile down to ES3.
- * @private
-goog.retrieveAndExec_ = function(src, isModule, needsTranspile) {
- if (!COMPILED) {
- // The full but non-canonicalized URL for later use.
- var originalPath = src;
- // Canonicalize the path, removing any /./ or /../ since Chrome's debugging
- // console doesn't auto-canonicalize XHR loads as it does <script> srcs.
- src = goog.normalizePath_(src);
- var scriptText = goog.loadFileSync_(src);
- if (scriptText == null) {
- throw new Error('Load of "' + src + '" failed');
- if (needsTranspile) {
- scriptText = goog.transpile_.call(goog.global, scriptText, src);
- if (isModule) {
- scriptText = goog.wrapModule_(src, scriptText);
- } else {
- scriptText += '\n//# sourceURL=' + src;
- var isOldIE = goog.IS_OLD_IE_;
- if (isOldIE) {
- goog.dependencies_.deferred[originalPath] = scriptText;
- goog.queuedModules_.push(originalPath);
- } else {
- importScript(src, scriptText);
- * Lazily retrieves the transpiler and applies it to the source.
- * @param {string} code JS code.
- * @param {string} path Path to the code.
- * @return {string} The transpiled code.
- * @private
-goog.transpile_ = function(code, path) {
- var jscomp = goog.global['$jscomp'];
- if (!jscomp) {
- goog.global['$jscomp'] = jscomp = {};
- var transpile = jscomp.transpile;
- if (!transpile) {
- var transpilerPath = goog.basePath + goog.TRANSPILER;
- var transpilerCode = goog.loadFileSync_(transpilerPath);
- if (transpilerCode) {
- // This must be executed synchronously, since by the time we know we
- // need it, we're about to load and write the ES6 code synchronously,
- // so a normal script-tag load will be too slow.
- eval(transpilerCode + '\n//# sourceURL=' + transpilerPath);
- // Even though the transpiler is optional, if $gwtExport is found, it's
- // a sign the transpiler was loaded and the $jscomp.transpile *should*
- // be there.
- if (goog.global['$gwtExport'] && goog.global['$gwtExport']['$jscomp'] &&
- !goog.global['$gwtExport']['$jscomp']['transpile']) {
- throw new Error(
- 'The transpiler did not properly export the "transpile" ' +
- 'method. $gwtExport: ' + JSON.stringify(goog.global['$gwtExport']));
- // transpile.js only exports a single $jscomp function, transpile. We
- // grab just that and add it to the existing definition of $jscomp which
- // contains the polyfills.
- goog.global['$jscomp'].transpile =
- goog.global['$gwtExport']['$jscomp']['transpile'];
- jscomp = goog.global['$jscomp'];
- transpile = jscomp.transpile;
- if (!transpile) {
- // The transpiler is an optional component. If it's not available then
- // replace it with a pass-through function that simply logs.
- var suffix = ' requires transpilation but no transpiler was found.';
- transpile = jscomp.transpile = function(code, path) {
- // TODO(user): figure out some way to get this error to show up
- // in test results, noting that the failure may occur in many
- // different ways, including in loadModule() before the test
- // runner even comes up.
- goog.logToConsole_(path + suffix);
- return code;
- // Note: any transpilation errors/warnings will be logged to the console.
- return transpile(code, path);
-// Language Enhancements
- * This is a "fixed" version of the typeof operator. It differs from the typeof
- * operator in such a way that null returns 'null' and arrays return 'array'.
- * @param {?} value The value to get the type of.
- * @return {string} The name of the type.
-goog.typeOf = function(value) {
- var s = typeof value;
- if (s == 'object') {
- if (value) {
- // Check these first, so we can avoid calling Object.prototype.toString if
- // possible.
- // IE improperly marshals typeof across execution contexts, but a
- // cross-context object will still return false for "instanceof Object".
- if (value instanceof Array) {
- return 'array';
- } else if (value instanceof Object) {
- return s;
- // HACK: In order to use an Object prototype method on the arbitrary
- // value, the compiler requires the value be cast to type Object,
- // even though the ECMA spec explicitly allows it.
- var className = Object.prototype.toString.call(
- /** @type {!Object} */ (value));
- // In Firefox 3.6, attempting to access iframe window objects' length
- // property throws an NS_ERROR_FAILURE, so we need to special-case it
- // here.
- if (className == '[object Window]') {
- return 'object';
- // We cannot always use constructor == Array or instanceof Array because
- // different frames have different Array objects. In IE6, if the iframe
- // where the array was created is destroyed, the array loses its
- // prototype. Then dereferencing val.splice here throws an exception, so
- // we can't use goog.isFunction. Calling typeof directly returns 'unknown'
- // so that will work. In this case, this function will return false and
- // most array functions will still work because the array is still
- // array-like (supports length and []) even though it has lost its
- // prototype.
- // Mark Miller noticed that Object.prototype.toString
- // allows access to the unforgeable [[Class]] property.
- // 15.2.4.2 Object.prototype.toString ( )
- // When the toString method is called, the following steps are taken:
- // 1. Get the [[Class]] property of this object.
- // 2. Compute a string value by concatenating the three strings
- // "[object ", Result(1), and "]".
- // 3. Return Result(2).
- // and this behavior survives the destruction of the execution context.
- if ((className == '[object Array]' ||
- // In IE all non value types are wrapped as objects across window
- // boundaries (not iframe though) so we have to do object detection
- // for this edge case.
- typeof value.length == 'number' &&
- typeof value.splice != 'undefined' &&
- typeof value.propertyIsEnumerable != 'undefined' &&
- !value.propertyIsEnumerable('splice')
- return 'array';
- // HACK: There is still an array case that fails.
- // function ArrayImpostor() {}
- // ArrayImpostor.prototype = [];
- // var impostor = new ArrayImpostor;
- // this can be fixed by getting rid of the fast path
- // (value instanceof Array) and solely relying on
- // (value && Object.prototype.toString.vall(value) === '[object Array]')
- // but that would require many more function calls and is not warranted
- // unless closure code is receiving objects from untrusted sources.
- // IE in cross-window calls does not correctly marshal the function type
- // (it appears just as an object) so we cannot use just typeof val ==
- // 'function'. However, if the object has a call property, it is a
- // function.
- if ((className == '[object Function]' ||
- typeof value.call != 'undefined' &&
- !value.propertyIsEnumerable('call'))) {
- return 'function';
- } else {
- return 'null';
- } else if (s == 'function' && typeof value.call == 'undefined') {
- // In Safari typeof nodeList returns 'function', and on Firefox typeof
- // behaves similarly for HTML{Applet,Embed,Object}, Elements and RegExps. We
- // would like to return object for those and we can detect an invalid
- // function by making sure that the function object has a call method.
- return 'object';
- return s;
- * Returns true if the specified value is null.
- * @return {boolean} Whether variable is null.
-goog.isNull = function(val) {
- return val === null;
- * Returns true if the specified value is defined and not null.
- * @return {boolean} Whether variable is defined and not null.
-goog.isDefAndNotNull = function(val) {
- // Note that undefined == null.
- return val != null;
- * Returns true if the specified value is an array.
- * @return {boolean} Whether variable is an array.
-goog.isArray = function(val) {
- return goog.typeOf(val) == 'array';
- * Returns true if the object looks like an array. To qualify as array like
- * the value needs to be either a NodeList or an object with a Number length
- * property. As a special case, a function value is not array like, because its
- * length property is fixed to correspond to the number of expected arguments.
-goog.isArrayLike = function(val) {
- var type = goog.typeOf(val);
- // We do not use goog.isObject here in order to exclude function values.
- return type == 'array' || type == 'object' && typeof val.length == 'number';
- * Returns true if the object looks like a Date. To qualify as Date-like the
- * value needs to be an object and have a getFullYear() function.
- * @return {boolean} Whether variable is a like a Date.
-goog.isDateLike = function(val) {
- return goog.isObject(val) && typeof val.getFullYear == 'function';
- * Returns true if the specified value is a string.
- * @return {boolean} Whether variable is a string.
-goog.isString = function(val) {
- return typeof val == 'string';
- * Returns true if the specified value is a boolean.
- * @return {boolean} Whether variable is boolean.
-goog.isBoolean = function(val) {
- return typeof val == 'boolean';
- * Returns true if the specified value is a number.
- * @return {boolean} Whether variable is a number.
-goog.isNumber = function(val) {
- return typeof val == 'number';
- * Returns true if the specified value is a function.
- * @return {boolean} Whether variable is a function.
-goog.isFunction = function(val) {
- return goog.typeOf(val) == 'function';
- * Returns true if the specified value is an object. This includes arrays and
- * functions.
- * @return {boolean} Whether variable is an object.
-goog.isObject = function(val) {
- var type = typeof val;
- return type == 'object' && val != null || type == 'function';
- // return Object(val) === val also works, but is slower, especially if val is
- // not an object.
- * Gets a unique ID for an object. This mutates the object so that further calls
- * with the same object as a parameter returns the same value. The unique ID is
- * guaranteed to be unique across the current session amongst objects that are
- * passed into {@code getUid}. There is no guarantee that the ID is unique or
- * consistent across sessions. It is unsafe to generate unique ID for function
- * prototypes.
- * @param {Object} obj The object to get the unique ID for.
- * @return {number} The unique ID for the object.
-goog.getUid = function(obj) {
- // TODO(arv): Make the type stricter, do not accept null.
- // In Opera window.hasOwnProperty exists but always returns false so we avoid
- // using it. As a consequence the unique ID generated for BaseClass.prototype
- // and SubClass.prototype will be the same.
- return obj[goog.UID_PROPERTY_] ||
- (obj[goog.UID_PROPERTY_] = ++goog.uidCounter_);
- * Whether the given object is already assigned a unique ID.
- * This does not modify the object.
- * @param {!Object} obj The object to check.
- * @return {boolean} Whether there is an assigned unique id for the object.
-goog.hasUid = function(obj) {
- return !!obj[goog.UID_PROPERTY_];
- * Removes the unique ID from an object. This is useful if the object was
- * previously mutated using {@code goog.getUid} in which case the mutation is
- * undone.
- * @param {Object} obj The object to remove the unique ID field from.
-goog.removeUid = function(obj) {
- // In IE, DOM nodes are not instances of Object and throw an exception if we
- // try to delete. Instead we try to use removeAttribute.
- if (obj !== null && 'removeAttribute' in obj) {
- obj.removeAttribute(goog.UID_PROPERTY_);
- /** @preserveTry */
- try {
- delete obj[goog.UID_PROPERTY_];
- } catch (ex) {
- * Name for unique ID property. Initialized in a way to help avoid collisions
- * with other closure JavaScript on the same page.
- * @type {string}
- * @private
-goog.UID_PROPERTY_ = 'closure_uid_' + ((Math.random() * 1e9) >>> 0);
- * Counter for UID.
- * @type {number}
- * @private
-goog.uidCounter_ = 0;
- * Adds a hash code field to an object. The hash code is unique for the
- * given object.
- * @param {Object} obj The object to get the hash code for.
- * @return {number} The hash code for the object.
- * @deprecated Use goog.getUid instead.
-goog.getHashCode = goog.getUid;
- * Removes the hash code field from an object.
- * @param {Object} obj The object to remove the field from.
- * @deprecated Use goog.removeUid instead.
-goog.removeHashCode = goog.removeUid;
- * Clones a value. The input may be an Object, Array, or basic type. Objects and
- * arrays will be cloned recursively.
- * WARNINGS:
- * <code>goog.cloneObject</code> does not detect reference loops. Objects that
- * refer to themselves will cause infinite recursion.
- * <code>goog.cloneObject</code> is unaware of unique identifiers, and copies
- * UIDs created by <code>getUid</code> into cloned results.
- * @param {*} obj The value to clone.
- * @return {*} A clone of the input value.
- * @deprecated goog.cloneObject is unsafe. Prefer the goog.object methods.
-goog.cloneObject = function(obj) {
- var type = goog.typeOf(obj);
- if (type == 'object' || type == 'array') {
- if (obj.clone) {
- return obj.clone();
- var clone = type == 'array' ? [] : {};
- for (var key in obj) {
- clone[key] = goog.cloneObject(obj[key]);
- return clone;
- return obj;
- * A native implementation of goog.bind.
- * @param {Function} fn A function to partially apply.
- * @param {Object|undefined} selfObj Specifies the object which this should
- * point to when the function is run.
- * @param {...*} var_args Additional arguments that are partially applied to the
- * function.
- * @return {!Function} A partially-applied form of the function bind() was
- * invoked as a method of.
- * @private
- * @suppress {deprecated} The compiler thinks that Function.prototype.bind is
- * deprecated because some people have declared a pure-JS version.
- * Only the pure-JS version is truly deprecated.
-goog.bindNative_ = function(fn, selfObj, var_args) {
- return /** @type {!Function} */ (fn.call.apply(fn.bind, arguments));
- * A pure-JS implementation of goog.bind.
- * function.
- * @private
-goog.bindJs_ = function(fn, selfObj, var_args) {
- if (!fn) {
- throw new Error();
- if (arguments.length > 2) {
- var boundArgs = Array.prototype.slice.call(arguments, 2);
- return function() {
- // Prepend the bound arguments to the current arguments.
- var newArgs = Array.prototype.slice.call(arguments);
- Array.prototype.unshift.apply(newArgs, boundArgs);
- return fn.apply(selfObj, newArgs);
- } else {
- return fn.apply(selfObj, arguments);
- * Partially applies this function to a particular 'this object' and zero or
- * more arguments. The result is a new function with some arguments of the first
- * function pre-filled and the value of this 'pre-specified'.
- * Remaining arguments specified at call-time are appended to the pre-specified
- * ones.
- * Also see: {@link #partial}.
- * Usage:
- * <pre>var barMethBound = goog.bind(myFunction, myObj, 'arg1', 'arg2');
- * barMethBound('arg3', 'arg4');</pre>
- * @param {?function(this:T, ...)} fn A function to partially apply.
- * @param {T} selfObj Specifies the object which this should point to when the
- * function is run.
- * function.
- * @return {!Function} A partially-applied form of the function goog.bind() was
- * @template T
- * @suppress {deprecated} See above.
-goog.bind = function(fn, selfObj, var_args) {
- // TODO(nicksantos): narrow the type signature.
- if (Function.prototype.bind &&
- // NOTE(nicksantos): Somebody pulled base.js into the default Chrome
- // extension environment. This means that for Chrome extensions, they get
- // the implementation of Function.prototype.bind that calls goog.bind
- // instead of the native one. Even worse, we don't want to introduce a
- // circular dependency between goog.bind and Function.prototype.bind, so
- // we have to hack this to make sure it works correctly.
- Function.prototype.bind.toString().indexOf('native code') != -1) {
- goog.bind = goog.bindNative_;
- } else {
- goog.bind = goog.bindJs_;
- return goog.bind.apply(null, arguments);
- * Like goog.bind(), except that a 'this object' is not required. Useful when
- * the target function is already bound.
- * Usage:
- * var g = goog.partial(f, arg1, arg2);
- * g(arg3, arg4);
- * @param {...*} var_args Additional arguments that are partially applied to fn.
- * @return {!Function} A partially-applied form of the function goog.partial()
- * was invoked as a method of.
-goog.partial = function(fn, var_args) {
- var args = Array.prototype.slice.call(arguments, 1);
- // Clone the array (with slice()) and append additional arguments
- // to the existing arguments.
- var newArgs = args.slice();
- newArgs.push.apply(newArgs, arguments);
- return fn.apply(this, newArgs);
- * Copies all the members of a source object to a target object. This method
- * does not work on all browsers for all objects that contain keys such as
- * toString or hasOwnProperty. Use goog.object.extend for this purpose.
- * @param {Object} target Target.
- * @param {Object} source Source.
-goog.mixin = function(target, source) {
- for (var x in source) {
- target[x] = source[x];
- // For IE7 or lower, the for-in-loop does not contain any properties that are
- // not enumerable on the prototype object (for example, isPrototypeOf from
- // Object.prototype) but also it will not include 'replace' on objects that
- // extend String and change 'replace' (not that it is common for anyone to
- // extend anything except Object).
- * @return {number} An integer value representing the number of milliseconds
- * between midnight, January 1, 1970 and the current time.
-goog.now = (goog.TRUSTED_SITE && Date.now) || (function() {
- // Unary plus operator converts its operand to a number which in
- // the case of
- // a date is done by calling getTime().
- return +new Date();
- * Evals JavaScript in the global scope. In IE this uses execScript, other
- * browsers use goog.global.eval. If goog.global.eval does not evaluate in the
- * global scope (for example, in Safari), appends a script tag instead.
- * Throws an exception if neither execScript or eval is defined.
- * @param {string} script JavaScript string.
-goog.globalEval = function(script) {
- if (goog.global.execScript) {
- goog.global.execScript(script, 'JavaScript');
- } else if (goog.global.eval) {
- // Test to see if eval works
- if (goog.evalWorksForGlobals_ == null) {
- goog.global.eval('var _evalTest_ = 1;');
- if (typeof goog.global['_evalTest_'] != 'undefined') {
- try {
- delete goog.global['_evalTest_'];
- } catch (ignore) {
- // Microsoft edge fails the deletion above in strict mode.
- goog.evalWorksForGlobals_ = true;
- } else {
- goog.evalWorksForGlobals_ = false;
- if (goog.evalWorksForGlobals_) {
- goog.global.eval(script);
- } else {
- var scriptElt =
- /** @type {!HTMLScriptElement} */ (doc.createElement('SCRIPT'));
- scriptElt.type = 'text/javascript';
- scriptElt.defer = false;
- // Note(user): can't use .innerHTML since "t('<test>')" will fail and
- // .text doesn't work in Safari 2. Therefore we append a text node.
- scriptElt.appendChild(doc.createTextNode(script));
- doc.body.appendChild(scriptElt);
- doc.body.removeChild(scriptElt);
- } else {
- throw Error('goog.globalEval not available');
- * Indicates whether or not we can call 'eval' directly to eval code in the
- * global scope. Set to a Boolean by the first call to goog.globalEval (which
- * empirically tests whether eval works for globals). @see goog.globalEval
- * @type {?boolean}
- * @private
-goog.evalWorksForGlobals_ = null;
- * Optional map of CSS class names to obfuscated names used with
- * goog.getCssName().
- * @private {!Object<string, string>|undefined}
- * @see goog.setCssNameMapping
-goog.cssNameMapping_;
- * Optional obfuscation style for CSS class names. Should be set to either
- * 'BY_WHOLE' or 'BY_PART' if defined.
- * @private
-goog.cssNameMappingStyle_;
- * Handles strings that are intended to be used as CSS class names.
- * This function works in tandem with @see goog.setCssNameMapping.
- * Without any mapping set, the arguments are simple joined with a hyphen and
- * passed through unaltered.
- * When there is a mapping, there are two possible styles in which these
- * mappings are used. In the BY_PART style, each part (i.e. in between hyphens)
- * of the passed in css name is rewritten according to the map. In the BY_WHOLE
- * style, the full css name is looked up in the map directly. If a rewrite is
- * not specified by the map, the compiler will output a warning.
- * When the mapping is passed to the compiler, it will replace calls to
- * goog.getCssName with the strings from the mapping, e.g.
- * var x = goog.getCssName('foo');
- * var y = goog.getCssName(this.baseClass, 'active');
- * becomes:
- * var x = 'foo';
- * var y = this.baseClass + '-active';
- * If one argument is passed it will be processed, if two are passed only the
- * modifier will be processed, as it is assumed the first argument was generated
- * as a result of calling goog.getCssName.
- * @param {string} className The class name.
- * @param {string=} opt_modifier A modifier to be appended to the class name.
- * @return {string} The class name or the concatenation of the class name and
- * the modifier.
-goog.getCssName = function(className, opt_modifier) {
- // String() is used for compatibility with compiled soy where the passed
- // className can be non-string objects.
- if (String(className).charAt(0) == '.') {
- throw new Error(
- 'className passed in goog.getCssName must not start with ".".' +
- ' You passed: ' + className);
- var getMapping = function(cssName) {
- return goog.cssNameMapping_[cssName] || cssName;
- var renameByParts = function(cssName) {
- // Remap all the parts individually.
- var parts = cssName.split('-');
- var mapped = [];
- for (var i = 0; i < parts.length; i++) {
- mapped.push(getMapping(parts[i]));
- return mapped.join('-');
- var rename;
- if (goog.cssNameMapping_) {
- rename =
- goog.cssNameMappingStyle_ == 'BY_WHOLE' ? getMapping : renameByParts;
- } else {
- rename = function(a) {
- return a;
- var result =
- opt_modifier ? className + '-' + rename(opt_modifier) : rename(className);
- // The special CLOSURE_CSS_NAME_MAP_FN allows users to specify further
- // processing of the class name.
- if (goog.global.CLOSURE_CSS_NAME_MAP_FN) {
- return goog.global.CLOSURE_CSS_NAME_MAP_FN(result);
- return result;
- * Sets the map to check when returning a value from goog.getCssName(). Example:
- * <pre>
- * goog.setCssNameMapping({
- * "goog": "a",
- * "disabled": "b",
- * var x = goog.getCssName('goog');
- * // The following evaluates to: "a a-b".
- * goog.getCssName('goog') + ' ' + goog.getCssName(x, 'disabled')
- * </pre>
- * When declared as a map of string literals to string literals, the JSCompiler
- * will replace all calls to goog.getCssName() using the supplied map if the
- * --process_closure_primitives flag is set.
- * @param {!Object} mapping A map of strings to strings where keys are possible
- * arguments to goog.getCssName() and values are the corresponding values
- * that should be returned.
- * @param {string=} opt_style The style of css name mapping. There are two valid
- * options: 'BY_PART', and 'BY_WHOLE'.
- * @see goog.getCssName for a description.
-goog.setCssNameMapping = function(mapping, opt_style) {
- goog.cssNameMapping_ = mapping;
- goog.cssNameMappingStyle_ = opt_style;
- * To use CSS renaming in compiled mode, one of the input files should have a
- * call to goog.setCssNameMapping() with an object literal that the JSCompiler
- * can extract and use to replace all calls to goog.getCssName(). In uncompiled
- * mode, JavaScript code should be loaded before this base.js file that declares
- * a global variable, CLOSURE_CSS_NAME_MAPPING, which is used below. This is
- * to ensure that the mapping is loaded before any calls to goog.getCssName()
- * are made in uncompiled mode.
- * A hook for overriding the CSS name mapping.
- * @type {!Object<string, string>|undefined}
-goog.global.CLOSURE_CSS_NAME_MAPPING;
-if (!COMPILED && goog.global.CLOSURE_CSS_NAME_MAPPING) {
- // This does not call goog.setCssNameMapping() because the JSCompiler
- // requires that goog.setCssNameMapping() be called with an object literal.
- goog.cssNameMapping_ = goog.global.CLOSURE_CSS_NAME_MAPPING;
- * Gets a localized message.
- * This function is a compiler primitive. If you give the compiler a localized
- * message bundle, it will replace the string at compile-time with a localized
- * version, and expand goog.getMsg call to a concatenated string.
- * Messages must be initialized in the form:
- * <code>
- * var MSG_NAME = goog.getMsg('Hello {$placeholder}', {'placeholder': 'world'});
- * </code>
- * This function produces a string which should be treated as plain text. Use
- * {@link goog.html.SafeHtmlFormatter} in conjunction with goog.getMsg to
- * produce SafeHtml.
- * @param {string} str Translatable string, places holders in the form {$foo}.
- * @param {Object<string, string>=} opt_values Maps place holder name to value.
- * @return {string} message with placeholders filled.
-goog.getMsg = function(str, opt_values) {
- if (opt_values) {
- str = str.replace(/\{\$([^}]+)}/g, function(match, key) {
- return (opt_values != null && key in opt_values) ? opt_values[key] :
- match;
- return str;
- * Gets a localized message. If the message does not have a translation, gives a
- * fallback message.
- * This is useful when introducing a new message that has not yet been
- * translated into all languages.
- * This function is a compiler primitive. Must be used in the form:
- * <code>var x = goog.getMsgWithFallback(MSG_A, MSG_B);</code>
- * where MSG_A and MSG_B were initialized with goog.getMsg.
- * @param {string} a The preferred message.
- * @param {string} b The fallback message.
- * @return {string} The best translated message.
-goog.getMsgWithFallback = function(a, b) {
- return a;
- * Exposes an unobfuscated global namespace path for the given object.
- * Note that fields of the exported object *will* be obfuscated, unless they are
- * exported in turn via this function or goog.exportProperty.
- * Also handy for making public items that are defined in anonymous closures.
- * ex. goog.exportSymbol('public.path.Foo', Foo);
- * ex. goog.exportSymbol('public.path.Foo.staticFunction', Foo.staticFunction);
- * public.path.Foo.staticFunction();
- * ex. goog.exportSymbol('public.path.Foo.prototype.myMethod',
- * Foo.prototype.myMethod);
- * new public.path.Foo().myMethod();
- * @param {string} publicPath Unobfuscated name to export.
- * @param {*} object Object the name should point to.
- * @param {Object=} opt_objectToExportTo The object to add the path to; default
- * is goog.global.
-goog.exportSymbol = function(publicPath, object, opt_objectToExportTo) {
- goog.exportPath_(publicPath, object, opt_objectToExportTo);
- * Exports a property unobfuscated into the object's namespace.
- * ex. goog.exportProperty(Foo, 'staticFunction', Foo.staticFunction);
- * ex. goog.exportProperty(Foo.prototype, 'myMethod', Foo.prototype.myMethod);
- * @param {Object} object Object whose static property is being exported.
- * @param {string} publicName Unobfuscated name to export.
- * @param {*} symbol Object the name should point to.
-goog.exportProperty = function(object, publicName, symbol) {
- object[publicName] = symbol;
- * Inherit the prototype methods from one constructor into another.
- * Usage:
- * <pre>
- * function ParentClass(a, b) { }
- * ParentClass.prototype.foo = function(a) { };
- * function ChildClass(a, b, c) {
- * ChildClass.base(this, 'constructor', a, b);
- * goog.inherits(ChildClass, ParentClass);
- * var child = new ChildClass('a', 'b', 'see');
- * child.foo(); // This works.
- * </pre>
- * @param {!Function} childCtor Child class.
- * @param {!Function} parentCtor Parent class.
-goog.inherits = function(childCtor, parentCtor) {
- /** @constructor */
- function tempCtor() {}
- tempCtor.prototype = parentCtor.prototype;
- childCtor.superClass_ = parentCtor.prototype;
- childCtor.prototype = new tempCtor();
- /** @override */
- childCtor.prototype.constructor = childCtor;
- * Calls superclass constructor/method.
- * This function is only available if you use goog.inherits to
- * express inheritance relationships between classes.
- * NOTE: This is a replacement for goog.base and for superClass_
- * property defined in childCtor.
- * @param {!Object} me Should always be "this".
- * @param {string} methodName The method name to call. Calling
- * superclass constructor can be done with the special string
- * 'constructor'.
- * @param {...*} var_args The arguments to pass to superclass
- * method/constructor.
- * @return {*} The return value of the superclass method/constructor.
- childCtor.base = function(me, methodName, var_args) {
- // Copying using loop to avoid deop due to passing arguments object to
- // function. This is faster in many JS engines as of late 2014.
- var args = new Array(arguments.length - 2);
- for (var i = 2; i < arguments.length; i++) {
- args[i - 2] = arguments[i];
- return parentCtor.prototype[methodName].apply(me, args);
- * Call up to the superclass.
- * If this is called from a constructor, then this calls the superclass
- * constructor with arguments 1-N.
- * If this is called from a prototype method, then you must pass the name of the
- * method as the second argument to this function. If you do not, you will get a
- * runtime error. This calls the superclass' method with arguments 2-N.
- * This function only works if you use goog.inherits to express inheritance
- * relationships between your classes.
- * This function is a compiler primitive. At compile-time, the compiler will do
- * macro expansion to remove a lot of the extra overhead that this function
- * introduces. The compiler will also enforce a lot of the assumptions that this
- * function makes, and treat it as a compiler error if you break them.
- * @param {*=} opt_methodName The method name if calling a super method.
- * @param {...*} var_args The rest of the arguments.
- * @return {*} The return value of the superclass method.
- * @suppress {es5Strict} This method can not be used in strict mode, but
- * all Closure Library consumers must depend on this file.
-goog.base = function(me, opt_methodName, var_args) {
- var caller = arguments.callee.caller;
- if (goog.STRICT_MODE_COMPATIBLE || (goog.DEBUG && !caller)) {
- throw Error(
- 'arguments.caller not defined. goog.base() cannot be used ' +
- 'with strict mode code. See ' +
- 'http://www.ecma-international.org/ecma-262/5.1/#sec-C');
- if (caller.superClass_) {
- var ctorArgs = new Array(arguments.length - 1);
- for (var i = 1; i < arguments.length; i++) {
- ctorArgs[i - 1] = arguments[i];
- // This is a constructor. Call the superclass constructor.
- return caller.superClass_.constructor.apply(me, ctorArgs);
- var foundCaller = false;
- for (var ctor = me.constructor; ctor;
- ctor = ctor.superClass_ && ctor.superClass_.constructor) {
- if (ctor.prototype[opt_methodName] === caller) {
- foundCaller = true;
- } else if (foundCaller) {
- return ctor.prototype[opt_methodName].apply(me, args);
- // If we did not find the caller in the prototype chain, then one of two
- // things happened:
- // 1) The caller is an instance method.
- // 2) This method was not called by the right caller.
- if (me[opt_methodName] === caller) {
- return me.constructor.prototype[opt_methodName].apply(me, args);
- } else {
- throw Error(
- 'goog.base called from a method of one name ' +
- 'to a method of a different name');
- * Allow for aliasing within scope functions. This function exists for
- * uncompiled code - in compiled code the calls will be inlined and the aliases
- * applied. In uncompiled code the function is simply run since the aliases as
- * written are valid JavaScript.
- * @param {function()} fn Function to call. This function can contain aliases
- * to namespaces (e.g. "var dom = goog.dom") or classes
- * (e.g. "var Timer = goog.Timer").
-goog.scope = function(fn) {
- if (goog.isInModuleLoader_()) {
- throw Error('goog.scope is not supported within a goog.module.');
- fn.call(goog.global);
- * To support uncompiled, strict mode bundles that use eval to divide source
- * like so:
- * eval('someSource;//# sourceUrl sourcefile.js');
- * We need to export the globally defined symbols "goog" and "COMPILED".
- * Exporting "goog" breaks the compiler optimizations, so we required that
- * be defined externally.
- * NOTE: We don't use goog.exportSymbol here because we don't want to trigger
- * extern generation when that compiler option is enabled.
-if (!COMPILED) {
- goog.global['COMPILED'] = COMPILED;
-// goog.defineClass implementation
- * Creates a restricted form of a Closure "class":
- * - from the compiler's perspective, the instance returned from the
- * constructor is sealed (no new properties may be added). This enables
- * better checks.
- * - the compiler will rewrite this definition to a form that is optimal
- * for type checking and optimization (initially this will be a more
- * traditional form).
- * @param {Function} superClass The superclass, Object or null.
- * @param {goog.defineClass.ClassDescriptor} def
- * An object literal describing
- * the class. It may have the following properties:
- * "constructor": the constructor function
- * "statics": an object literal containing methods to add to the constructor
- * as "static" methods or a function that will receive the constructor
- * function as its only parameter to which static properties can
- * be added.
- * all other properties are added to the prototype.
- * @return {!Function} The class constructor.
-goog.defineClass = function(superClass, def) {
- // TODO(johnlenz): consider making the superClass an optional parameter.
- var constructor = def.constructor;
- var statics = def.statics;
- // Wrap the constructor prior to setting up the prototype and static methods.
- if (!constructor || constructor == Object.prototype.constructor) {
- constructor = function() {
- throw Error('cannot instantiate an interface (no constructor defined).');
- var cls = goog.defineClass.createSealingConstructor_(constructor, superClass);
- if (superClass) {
- goog.inherits(cls, superClass);
- // Remove all the properties that should not be copied to the prototype.
- delete def.constructor;
- delete def.statics;
- goog.defineClass.applyProperties_(cls.prototype, def);
- if (statics != null) {
- if (statics instanceof Function) {
- statics(cls);
- } else {
- goog.defineClass.applyProperties_(cls, statics);
- return cls;
- * @typedef {{
- * constructor: (!Function|undefined),
- * statics: (Object|undefined|function(Function):void)
-goog.defineClass.ClassDescriptor;
- * @define {boolean} Whether the instances returned by goog.defineClass should
- * be sealed when possible.
- * When sealing is disabled the constructor function will not be wrapped by
- * goog.defineClass, making it incompatible with ES6 class methods.
-goog.define('goog.defineClass.SEAL_CLASS_INSTANCES', goog.DEBUG);
- * If goog.defineClass.SEAL_CLASS_INSTANCES is enabled and Object.seal is
- * defined, this function will wrap the constructor in a function that seals the
- * results of the provided constructor function.
- * @param {!Function} ctr The constructor whose results maybe be sealed.
- * @param {Function} superClass The superclass constructor.
- * @return {!Function} The replacement constructor.
- * @private
-goog.defineClass.createSealingConstructor_ = function(ctr, superClass) {
- if (!goog.defineClass.SEAL_CLASS_INSTANCES) {
- // Do now wrap the constructor when sealing is disabled. Angular code
- // depends on this for injection to work properly.
- return ctr;
- // Compute whether the constructor is sealable at definition time, rather
- // than when the instance is being constructed.
- var superclassSealable = !goog.defineClass.isUnsealable_(superClass);
- * @this {Object}
- * @return {?}
- var wrappedCtr = function() {
- // Don't seal an instance of a subclass when it calls the constructor of
- // its super class as there is most likely still setup to do.
- var instance = ctr.apply(this, arguments) || this;
- instance[goog.UID_PROPERTY_] = instance[goog.UID_PROPERTY_];
- if (this.constructor === wrappedCtr && superclassSealable &&
- Object.seal instanceof Function) {
- Object.seal(instance);
- return instance;
- return wrappedCtr;
- * @param {Function} ctr The constructor to test.
- * @return {boolean} Whether the constructor has been tagged as unsealable
- * using goog.tagUnsealableClass.
- * @private
-goog.defineClass.isUnsealable_ = function(ctr) {
- return ctr && ctr.prototype &&
- ctr.prototype[goog.UNSEALABLE_CONSTRUCTOR_PROPERTY_];
-// TODO(johnlenz): share these values with the goog.object
- * The names of the fields that are defined on Object.prototype.
- * @type {!Array<string>}
- * @private
- * @const
-goog.defineClass.OBJECT_PROTOTYPE_FIELDS_ = [
- 'constructor', 'hasOwnProperty', 'isPrototypeOf', 'propertyIsEnumerable',
- 'toLocaleString', 'toString', 'valueOf'
-// TODO(johnlenz): share this function with the goog.object
- * @param {!Object} target The object to add properties to.
- * @param {!Object} source The object to copy properties from.
- * @private
-goog.defineClass.applyProperties_ = function(target, source) {
- // TODO(johnlenz): update this to support ES5 getters/setters
- var key;
- for (key in source) {
- if (Object.prototype.hasOwnProperty.call(source, key)) {
- target[key] = source[key];
- // For IE the for-in-loop does not contain any properties that are not
- // enumerable on the prototype object (for example isPrototypeOf from
- // Object.prototype) and it will also not include 'replace' on objects that
- for (var i = 0; i < goog.defineClass.OBJECT_PROTOTYPE_FIELDS_.length; i++) {
- key = goog.defineClass.OBJECT_PROTOTYPE_FIELDS_[i];
- * Sealing classes breaks the older idiom of assigning properties on the
- * prototype rather than in the constructor. As such, goog.defineClass
- * must not seal subclasses of these old-style classes until they are fixed.
- * Until then, this marks a class as "broken", instructing defineClass
- * not to seal subclasses.
- * @param {!Function} ctr The legacy constructor to tag as unsealable.
-goog.tagUnsealableClass = function(ctr) {
- if (!COMPILED && goog.defineClass.SEAL_CLASS_INSTANCES) {
- ctr.prototype[goog.UNSEALABLE_CONSTRUCTOR_PROPERTY_] = true;
- * Name for unsealable tag property.
- * @const @private {string}
-goog.UNSEALABLE_CONSTRUCTOR_PROPERTY_ = 'goog_defineClass_legacy_unsealable';
- * Returns a newly created map from language mode string to a boolean
- * indicating whether transpilation should be done for that mode.
- * Guaranteed invariant:
- * For any two modes, l1 and l2 where l2 is a newer mode than l1,
- * `map[l1] == true` implies that `map[l2] == true`.
- * @private
- * @return {!Object<string, boolean>}
-goog.createRequiresTranspilation_ = function() {
- var /** !Object<string, boolean> */ requiresTranspilation = {'es3': false};
- var transpilationRequiredForAllLaterModes = false;
- * Adds an entry to requiresTranspliation for the given language mode.
- * IMPORTANT: Calls must be made in order from oldest to newest language
- * mode.
- * @param {string} modeName
- * @param {function(): boolean} isSupported Returns true if the JS engine
- * supports the given mode.
- function addNewerLanguageTranspilationCheck(modeName, isSupported) {
- if (transpilationRequiredForAllLaterModes) {
- requiresTranspilation[modeName] = true;
- } else if (isSupported()) {
- requiresTranspilation[modeName] = false;
- } else {
- transpilationRequiredForAllLaterModes = true;
- * Does the given code evaluate without syntax errors and return a truthy
- * result?
- function /** boolean */ evalCheck(/** string */ code) {
- try {
- return !!eval(code);
- } catch (ignored) {
- return false;
- // Identify ES3-only browsers by their incorrect treatment of commas.
- addNewerLanguageTranspilationCheck('es5', function() {
- return evalCheck('[1,].length==1');
- addNewerLanguageTranspilationCheck('es6', function() {
- // Test es6: [FF50 (?), Edge 14 (?), Chrome 50]
- // (a) default params (specifically shadowing locals),
- // (b) destructuring, (c) block-scoped functions,
- // (d) for-of (const), (e) new.target/Reflect.construct
- var es6fullTest =
- 'class X{constructor(){if(new.target!=String)throw 1;this.x=42}}' +
- 'let q=Reflect.construct(X,[],String);if(q.x!=42||!(q instanceof ' +
- 'String))throw 1;for(const a of[2,3]){if(a==2)continue;function ' +
- 'f(z={a}){let a=0;return z.a}{function f(){return 0;}}return f()' +
- '==3}';
- return evalCheck('(()=>{"use strict";' + es6fullTest + '})()');
- // TODO(joeltine): Remove es6-impl references for b/31340605.
- // Consider es6-impl (widely-implemented es6 features) to be supported
- // whenever es6 is supported. Technically es6-impl is a lower level of
- // support than es6, but we don't have tests specifically for it.
- addNewerLanguageTranspilationCheck('es6-impl', function() {
- return true;
- // ** and **= are the only new features in 'es7'
- addNewerLanguageTranspilationCheck('es7', function() {
- return evalCheck('2 ** 2 == 4');
- // async functions are the only new features in 'es8'
- addNewerLanguageTranspilationCheck('es8', function() {
- return evalCheck('async () => 1, true');
- return requiresTranspilation;
-goog.provide('ol.array');
- * Performs a binary search on the provided sorted list and returns the index of the item if found. If it can't be found it'll return -1.
- * https://github.com/darkskyapp/binary-search
- * @param {Array.<*>} haystack Items to search through.
- * @param {*} needle The item to look for.
- * @param {Function=} opt_comparator Comparator function.
- * @return {number} The index of the item if found, -1 if not.
-ol.array.binarySearch = function(haystack, needle, opt_comparator) {
- var mid, cmp;
- var comparator = opt_comparator || ol.array.numberSafeCompareFunction;
- var low = 0;
- var high = haystack.length;
- var found = false;
- while (low < high) {
- /* Note that "(low + high) >>> 1" may overflow, and results in a typecast
- * to double (which gives the wrong results). */
- mid = low + (high - low >> 1);
- cmp = +comparator(haystack[mid], needle);
- if (cmp < 0.0) { /* Too low. */
- low = mid + 1;
- } else { /* Key found or too high */
- high = mid;
- found = !cmp;
- /* Key not found. */
- return found ? low : ~low;
- * Compare function for array sort that is safe for numbers.
- * @param {*} a The first object to be compared.
- * @param {*} b The second object to be compared.
- * @return {number} A negative number, zero, or a positive number as the first
- * argument is less than, equal to, or greater than the second.
-ol.array.numberSafeCompareFunction = function(a, b) {
- return a > b ? 1 : a < b ? -1 : 0;
- * Whether the array contains the given object.
- * @param {Array.<*>} arr The array to test for the presence of the element.
- * @param {*} obj The object for which to test.
- * @return {boolean} The object is in the array.
-ol.array.includes = function(arr, obj) {
- return arr.indexOf(obj) >= 0;
- * @param {Array.<number>} arr Array.
- * @param {number} target Target.
- * @param {number} direction 0 means return the nearest, > 0
- * means return the largest nearest, < 0 means return the
- * smallest nearest.
- * @return {number} Index.
-ol.array.linearFindNearest = function(arr, target, direction) {
- var n = arr.length;
- if (arr[0] <= target) {
- return 0;
- } else if (target <= arr[n - 1]) {
- return n - 1;
- } else {
- var i;
- if (direction > 0) {
- for (i = 1; i < n; ++i) {
- if (arr[i] < target) {
- return i - 1;
- } else if (direction < 0) {
- if (arr[i] <= target) {
- return i;
- } else {
- if (arr[i] == target) {
- return i;
- } else if (arr[i] < target) {
- if (arr[i - 1] - target < target - arr[i]) {
- return i - 1;
- } else {
- return i;
- return n - 1;
- * @param {Array.<*>} arr Array.
- * @param {number} begin Begin index.
- * @param {number} end End index.
-ol.array.reverseSubArray = function(arr, begin, end) {
- while (begin < end) {
- var tmp = arr[begin];
- arr[begin] = arr[end];
- arr[end] = tmp;
- ++begin;
- --end;
- * @param {Array.<VALUE>} arr The array to modify.
- * @param {Array.<VALUE>|VALUE} data The elements or arrays of elements
- * to add to arr.
- * @template VALUE
-ol.array.extend = function(arr, data) {
- var i;
- var extension = Array.isArray(data) ? data : [data];
- var length = extension.length;
- for (i = 0; i < length; i++) {
- arr[arr.length] = extension[i];
- * @param {VALUE} obj The element to remove.
- * @template VALUE
- * @return {boolean} If the element was removed.
-ol.array.remove = function(arr, obj) {
- var i = arr.indexOf(obj);
- var found = i > -1;
- if (found) {
- arr.splice(i, 1);
- return found;
- * @param {Array.<VALUE>} arr The array to search in.
- * @param {function(VALUE, number, ?) : boolean} func The function to compare.
- * @template VALUE
- * @return {VALUE} The element found.
-ol.array.find = function(arr, func) {
- var length = arr.length >>> 0;
- var value;
- for (var i = 0; i < length; i++) {
- value = arr[i];
- if (func(value, i, arr)) {
- return value;
- return null;
- * @param {Array|Uint8ClampedArray} arr1 The first array to compare.
- * @param {Array|Uint8ClampedArray} arr2 The second array to compare.
- * @return {boolean} Whether the two arrays are equal.
-ol.array.equals = function(arr1, arr2) {
- var len1 = arr1.length;
- if (len1 !== arr2.length) {
- return false;
- for (var i = 0; i < len1; i++) {
- if (arr1[i] !== arr2[i]) {
- return false;
- return true;
- * @param {Array.<*>} arr The array to sort (modifies original).
- * @param {Function} compareFnc Comparison function.
-ol.array.stableSort = function(arr, compareFnc) {
- var length = arr.length;
- var tmp = Array(arr.length);
- var i;
- tmp[i] = {index: i, value: arr[i]};
- tmp.sort(function(a, b) {
- return compareFnc(a.value, b.value) || a.index - b.index;
- for (i = 0; i < arr.length; i++) {
- arr[i] = tmp[i].value;
- * @param {Array.<*>} arr The array to search in.
- * @param {Function} func Comparison function.
- * @return {number} Return index.
-ol.array.findIndex = function(arr, func) {
- var index;
- var found = !arr.every(function(el, idx) {
- index = idx;
- return !func(el, idx, arr);
- return found ? index : -1;
- * @param {Array.<*>} arr The array to test.
- * @param {Function=} opt_func Comparison function.
- * @param {boolean=} opt_strict Strictly sorted (default false).
- * @return {boolean} Return index.
-ol.array.isSorted = function(arr, opt_func, opt_strict) {
- var compare = opt_func || ol.array.numberSafeCompareFunction;
- return arr.every(function(currentVal, index) {
- if (index === 0) {
- return true;
- var res = compare(arr[index - 1], currentVal);
- return !(res > 0 || opt_strict && res === 0);
-goog.provide('ol');
- * Constants defined with the define tag cannot be changed in application
- * code, but can be set at compile time.
- * Some reduce the size of the build in advanced compile mode.
- * @define {boolean} Assume touch. Default is `false`.
-ol.ASSUME_TOUCH = false;
- * TODO: rename this to something having to do with tile grids
- * see https://github.com/openlayers/openlayers/issues/2076
- * @define {number} Default maximum zoom for default tile grids.
-ol.DEFAULT_MAX_ZOOM = 42;
- * @define {number} Default min zoom level for the map view. Default is `0`.
-ol.DEFAULT_MIN_ZOOM = 0;
- * @define {number} Default maximum allowed threshold (in pixels) for
- * reprojection triangulation. Default is `0.5`.
-ol.DEFAULT_RASTER_REPROJECTION_ERROR_THRESHOLD = 0.5;
- * @define {number} Default tile size.
-ol.DEFAULT_TILE_SIZE = 256;
- * @define {string} Default WMS version.
-ol.DEFAULT_WMS_VERSION = '1.3.0';
- * @define {boolean} Enable the Canvas renderer. Default is `true`. Setting
- * this to false at compile time in advanced mode removes all code
- * supporting the Canvas renderer from the build.
-ol.ENABLE_CANVAS = true;
- * @define {boolean} Enable integration with the Proj4js library. Default is
- * `true`.
-ol.ENABLE_PROJ4JS = true;
- * @define {boolean} Enable automatic reprojection of raster sources. Default is
- * `true`.
-ol.ENABLE_RASTER_REPROJECTION = true;
- * @define {boolean} Enable the WebGL renderer. Default is `true`. Setting
- * supporting the WebGL renderer from the build.
-ol.ENABLE_WEBGL = true;
- * @define {boolean} Include debuggable shader sources. Default is `true`.
- * This should be set to `false` for production builds (if `ol.ENABLE_WEBGL`
- * is `true`).
-ol.DEBUG_WEBGL = true;
- * @define {number} The size in pixels of the first atlas image. Default is
- * `256`.
-ol.INITIAL_ATLAS_SIZE = 256;
- * @define {number} The maximum size in pixels of atlas images. Default is
- * `-1`, meaning it is not used (and `ol.WEBGL_MAX_TEXTURE_SIZE` is
- * used instead).
-ol.MAX_ATLAS_SIZE = -1;
- * @define {number} Maximum mouse wheel delta.
-ol.MOUSEWHEELZOOM_MAXDELTA = 1;
- * @define {number} Maximum width and/or height extent ratio that determines
- * when the overview map should be zoomed out.
-ol.OVERVIEWMAP_MAX_RATIO = 0.75;
- * @define {number} Minimum width and/or height extent ratio that determines
- * when the overview map should be zoomed in.
-ol.OVERVIEWMAP_MIN_RATIO = 0.1;
- * @define {number} Maximum number of source tiles for raster reprojection of
- * a single tile.
- * If too many source tiles are determined to be loaded to create a single
- * reprojected tile the browser can become unresponsive or even crash.
- * This can happen if the developer defines projections improperly and/or
- * with unlimited extents.
- * If too many tiles are required, no tiles are loaded and
- * `ol.TileState.ERROR` state is set. Default is `100`.
-ol.RASTER_REPROJECTION_MAX_SOURCE_TILES = 100;
- * @define {number} Maximum number of subdivision steps during raster
- * reprojection triangulation. Prevents high memory usage and large
- * number of proj4 calls (for certain transformations and areas).
- * At most `2*(2^this)` triangles are created for each triangulated
- * extent (tile/image). Default is `10`.
-ol.RASTER_REPROJECTION_MAX_SUBDIVISION = 10;
- * @define {number} Maximum allowed size of triangle relative to world width.
- * When transforming corners of world extent between certain projections,
- * the resulting triangulation seems to have zero error and no subdivision
- * is performed.
- * If the triangle width is more than this (relative to world width; 0-1),
- * subdivison is forced (up to `ol.RASTER_REPROJECTION_MAX_SUBDIVISION`).
- * Default is `0.25`.
-ol.RASTER_REPROJECTION_MAX_TRIANGLE_WIDTH = 0.25;
- * @define {number} Tolerance for geometry simplification in device pixels.
-ol.SIMPLIFY_TOLERANCE = 0.5;
- * @define {number} Texture cache high water mark.
-ol.WEBGL_TEXTURE_CACHE_HIGH_WATER_MARK = 1024;
- * @define {string} OpenLayers version.
-ol.VERSION = '';
- * The maximum supported WebGL texture size in pixels. If WebGL is not
- * supported, the value is set to `undefined`.
- * @const
- * @type {number|undefined}
-ol.WEBGL_MAX_TEXTURE_SIZE; // value is set in `ol.has`
- * List of supported WebGL extensions.
- * @const
- * @type {Array.<string>}
-ol.WEBGL_EXTENSIONS; // value is set in `ol.has`
- * Usage:
- * // Call parent constructor
- * ParentClass.call(this, a, b);
- * ol.inherits(ChildClass, ParentClass);
- * @param {!Function} childCtor Child constructor.
- * @param {!Function} parentCtor Parent constructor.
- * @function
- * @api
-ol.inherits = function(childCtor, parentCtor) {
- childCtor.prototype = Object.create(parentCtor.prototype);
- * A reusable function, used e.g. as a default for callbacks.
- * @return {undefined} Nothing.
-ol.nullFunction = function() {};
- * with the same object as a parameter returns the same value. Unique IDs are generated
- * as a strictly increasing sequence. Adapted from goog.getUid.
-ol.getUid = function(obj) {
- return obj.ol_uid ||
- (obj.ol_uid = ++ol.uidCounter_);
- * Counter for getUid.
- * @type {number}
- * @private
-ol.uidCounter_ = 0;
-goog.provide('ol.AssertionError');
-goog.require('ol');
- * Error object thrown when an assertion failed. This is an ECMA-262 Error,
- * extended with a `code` property.
- * @see {@link https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Error}
- * @constructor
- * @extends {Error}
- * @implements {oli.AssertionError}
- * @param {number} code Error code.
-ol.AssertionError = function(code) {
- var path = ol.VERSION ? ol.VERSION.split('-')[0] : 'latest';
- * @type {string}
- this.message = 'Assertion failed. See https://openlayers.org/en/' + path +
- '/doc/errors/#' + code + ' for details.';
- * Error code. The meaning of the code can be found on
- * {@link https://openlayers.org/en/latest/doc/errors/} (replace `latest` with
- * the version found in the OpenLayers script's header comment if a version
- * other than the latest is used).
- * @type {number}
- * @api
- this.code = code;
- this.name = 'AssertionError';
-ol.inherits(ol.AssertionError, Error);
-goog.provide('ol.asserts');
-goog.require('ol.AssertionError');
- * @param {*} assertion Assertion we expected to be truthy.
- * @param {number} errorCode Error code.
-ol.asserts.assert = function(assertion, errorCode) {
- if (!assertion) {
- throw new ol.AssertionError(errorCode);
-goog.provide('ol.TileRange');
- * A representation of a contiguous block of tiles. A tile range is specified
- * by its min/max tile coordinates and is inclusive of coordinates.
- * @constructor
- * @param {number} minX Minimum X.
- * @param {number} maxX Maximum X.
- * @param {number} minY Minimum Y.
- * @param {number} maxY Maximum Y.
- * @struct
-ol.TileRange = function(minX, maxX, minY, maxY) {
- * @type {number}
- this.minX = minX;
- * @type {number}
- this.maxX = maxX;
- * @type {number}
- this.minY = minY;
- * @type {number}
- this.maxY = maxY;
- * @param {ol.TileRange|undefined} tileRange TileRange.
- * @return {ol.TileRange} Tile range.
-ol.TileRange.createOrUpdate = function(minX, maxX, minY, maxY, tileRange) {
- if (tileRange !== undefined) {
- tileRange.minX = minX;
- tileRange.maxX = maxX;
- tileRange.minY = minY;
- tileRange.maxY = maxY;
- return tileRange;
- } else {
- return new ol.TileRange(minX, maxX, minY, maxY);
- * @param {ol.TileCoord} tileCoord Tile coordinate.
- * @return {boolean} Contains tile coordinate.
-ol.TileRange.prototype.contains = function(tileCoord) {
- return this.containsXY(tileCoord[1], tileCoord[2]);
- * @param {ol.TileRange} tileRange Tile range.
- * @return {boolean} Contains.
-ol.TileRange.prototype.containsTileRange = function(tileRange) {
- return this.minX <= tileRange.minX && tileRange.maxX <= this.maxX &&
- this.minY <= tileRange.minY && tileRange.maxY <= this.maxY;
- * @param {number} x Tile coordinate x.
- * @param {number} y Tile coordinate y.
- * @return {boolean} Contains coordinate.
-ol.TileRange.prototype.containsXY = function(x, y) {
- return this.minX <= x && x <= this.maxX && this.minY <= y && y <= this.maxY;
- * @return {boolean} Equals.
-ol.TileRange.prototype.equals = function(tileRange) {
- return this.minX == tileRange.minX && this.minY == tileRange.minY &&
- this.maxX == tileRange.maxX && this.maxY == tileRange.maxY;
-ol.TileRange.prototype.extend = function(tileRange) {
- if (tileRange.minX < this.minX) {
- this.minX = tileRange.minX;
- if (tileRange.maxX > this.maxX) {
- this.maxX = tileRange.maxX;
- if (tileRange.minY < this.minY) {
- this.minY = tileRange.minY;
- if (tileRange.maxY > this.maxY) {
- this.maxY = tileRange.maxY;
- * @return {number} Height.
-ol.TileRange.prototype.getHeight = function() {
- return this.maxY - this.minY + 1;
- * @return {ol.Size} Size.
-ol.TileRange.prototype.getSize = function() {
- return [this.getWidth(), this.getHeight()];
- * @return {number} Width.
-ol.TileRange.prototype.getWidth = function() {
- return this.maxX - this.minX + 1;
- * @return {boolean} Intersects.
-ol.TileRange.prototype.intersects = function(tileRange) {
- return this.minX <= tileRange.maxX &&
- this.maxX >= tileRange.minX &&
- this.minY <= tileRange.maxY &&
- this.maxY >= tileRange.minY;
-goog.provide('ol.math');
-goog.require('ol.asserts');
- * Takes a number and clamps it to within the provided bounds.
- * @param {number} value The input number.
- * @param {number} min The minimum value to return.
- * @param {number} max The maximum value to return.
- * @return {number} The input number if it is within bounds, or the nearest
- * number within the bounds.
-ol.math.clamp = function(value, min, max) {
- return Math.min(Math.max(value, min), max);
- * Return the hyperbolic cosine of a given number. The method will use the
- * native `Math.cosh` function if it is available, otherwise the hyperbolic
- * cosine will be calculated via the reference implementation of the Mozilla
- * developer network.
- * @param {number} x X.
- * @return {number} Hyperbolic cosine of x.
-ol.math.cosh = (function() {
- // Wrapped in a iife, to save the overhead of checking for the native
- // implementation on every invocation.
- var cosh;
- if ('cosh' in Math) {
- // The environment supports the native Math.cosh function, use it…
- cosh = Math.cosh;
- } else {
- // … else, use the reference implementation of MDN:
- cosh = function(x) {
- var y = Math.exp(x);
- return (y + 1 / y) / 2;
- return cosh;
- * @return {number} The smallest power of two greater than or equal to x.
-ol.math.roundUpToPowerOfTwo = function(x) {
- ol.asserts.assert(0 < x, 29); // `x` must be greater than `0`
- return Math.pow(2, Math.ceil(Math.log(x) / Math.LN2));
- * Returns the square of the closest distance between the point (x, y) and the
- * line segment (x1, y1) to (x2, y2).
- * @param {number} y Y.
- * @param {number} x1 X1.
- * @param {number} y1 Y1.
- * @param {number} x2 X2.
- * @param {number} y2 Y2.
- * @return {number} Squared distance.
-ol.math.squaredSegmentDistance = function(x, y, x1, y1, x2, y2) {
- var dx = x2 - x1;
- var dy = y2 - y1;
- if (dx !== 0 || dy !== 0) {
- var t = ((x - x1) * dx + (y - y1) * dy) / (dx * dx + dy * dy);
- if (t > 1) {
- x1 = x2;
- y1 = y2;
- } else if (t > 0) {
- x1 += dx * t;
- y1 += dy * t;
- return ol.math.squaredDistance(x, y, x1, y1);
- * Returns the square of the distance between the points (x1, y1) and (x2, y2).
-ol.math.squaredDistance = function(x1, y1, x2, y2) {
- var dx = x2 - x1;
- var dy = y2 - y1;
- return dx * dx + dy * dy;
- * Solves system of linear equations using Gaussian elimination method.
- * @param {Array.<Array.<number>>} mat Augmented matrix (n x n + 1 column)
- * in row-major order.
- * @return {Array.<number>} The resulting vector.
-ol.math.solveLinearSystem = function(mat) {
- var n = mat.length;
- for (var i = 0; i < n; i++) {
- // Find max in the i-th column (ignoring i - 1 first rows)
- var maxRow = i;
- var maxEl = Math.abs(mat[i][i]);
- for (var r = i + 1; r < n; r++) {
- var absValue = Math.abs(mat[r][i]);
- if (absValue > maxEl) {
- maxEl = absValue;
- maxRow = r;
- if (maxEl === 0) {
- return null; // matrix is singular
- // Swap max row with i-th (current) row
- var tmp = mat[maxRow];
- mat[maxRow] = mat[i];
- mat[i] = tmp;
- // Subtract the i-th row to make all the remaining rows 0 in the i-th column
- for (var j = i + 1; j < n; j++) {
- var coef = -mat[j][i] / mat[i][i];
- for (var k = i; k < n + 1; k++) {
- if (i == k) {
- mat[j][k] = 0;
- } else {
- mat[j][k] += coef * mat[i][k];
- // Solve Ax=b for upper triangular matrix A (mat)
- var x = new Array(n);
- for (var l = n - 1; l >= 0; l--) {
- x[l] = mat[l][n] / mat[l][l];
- for (var m = l - 1; m >= 0; m--) {
- mat[m][n] -= mat[m][l] * x[l];
- return x;
- * Converts radians to to degrees.
- * @param {number} angleInRadians Angle in radians.
- * @return {number} Angle in degrees.
-ol.math.toDegrees = function(angleInRadians) {
- return angleInRadians * 180 / Math.PI;
- * Converts degrees to radians.
- * @param {number} angleInDegrees Angle in degrees.
- * @return {number} Angle in radians.
-ol.math.toRadians = function(angleInDegrees) {
- return angleInDegrees * Math.PI / 180;
- * Returns the modulo of a / b, depending on the sign of b.
- * @param {number} a Dividend.
- * @param {number} b Divisor.
- * @return {number} Modulo.
-ol.math.modulo = function(a, b) {
- var r = a % b;
- return r * b < 0 ? r + b : r;
- * Calculates the linearly interpolated value of x between a and b.
- * @param {number} a Number
- * @param {number} b Number
- * @param {number} x Value to be interpolated.
- * @return {number} Interpolated value.
-ol.math.lerp = function(a, b, x) {
- return a + x * (b - a);
-goog.provide('ol.size');
- * Returns a buffered size.
- * @param {ol.Size} size Size.
- * @param {number} buffer Buffer.
- * @param {ol.Size=} opt_size Optional reusable size array.
- * @return {ol.Size} The buffered size.
-ol.size.buffer = function(size, buffer, opt_size) {
- if (opt_size === undefined) {
- opt_size = [0, 0];
- opt_size[0] = size[0] + 2 * buffer;
- opt_size[1] = size[1] + 2 * buffer;
- return opt_size;
- * Determines if a size has a positive area.
- * @param {ol.Size} size The size to test.
- * @return {boolean} The size has a positive area.
-ol.size.hasArea = function(size) {
- return size[0] > 0 && size[1] > 0;
- * Returns a size scaled by a ratio. The result will be an array of integers.
- * @param {number} ratio Ratio.
- * @return {ol.Size} The scaled size.
-ol.size.scale = function(size, ratio, opt_size) {
- opt_size[0] = (size[0] * ratio + 0.5) | 0;
- opt_size[1] = (size[1] * ratio + 0.5) | 0;
- return opt_size;
- * Returns an `ol.Size` array for the passed in number (meaning: square) or
- * `ol.Size` array.
- * (meaning: non-square),
- * @param {number|ol.Size} size Width and height.
- * @api
-ol.size.toSize = function(size, opt_size) {
- if (Array.isArray(size)) {
- return size;
- } else {
- opt_size = [size, size];
- } else {
- opt_size[0] = opt_size[1] = /** @type {number} */ (size);
- return opt_size;
-goog.provide('ol.extent.Corner');
- * Extent corner.
- * @enum {string}
-ol.extent.Corner = {
- BOTTOM_LEFT: 'bottom-left',
- BOTTOM_RIGHT: 'bottom-right',
- TOP_LEFT: 'top-left',
- TOP_RIGHT: 'top-right'
-goog.provide('ol.extent.Relationship');
- * Relationship to an extent.
- * @enum {number}
-ol.extent.Relationship = {
- UNKNOWN: 0,
- INTERSECTING: 1,
- ABOVE: 2,
- RIGHT: 4,
- BELOW: 8,
- LEFT: 16
-goog.provide('ol.extent');
-goog.require('ol.extent.Corner');
-goog.require('ol.extent.Relationship');
- * Build an extent that includes all given coordinates.
- * @param {Array.<ol.Coordinate>} coordinates Coordinates.
- * @return {ol.Extent} Bounding extent.
- * @api
-ol.extent.boundingExtent = function(coordinates) {
- var extent = ol.extent.createEmpty();
- for (var i = 0, ii = coordinates.length; i < ii; ++i) {
- ol.extent.extendCoordinate(extent, coordinates[i]);
- return extent;
- * @param {Array.<number>} xs Xs.
- * @param {Array.<number>} ys Ys.
- * @param {ol.Extent=} opt_extent Destination extent.
- * @private
- * @return {ol.Extent} Extent.
-ol.extent.boundingExtentXYs_ = function(xs, ys, opt_extent) {
- var minX = Math.min.apply(null, xs);
- var minY = Math.min.apply(null, ys);
- var maxX = Math.max.apply(null, xs);
- var maxY = Math.max.apply(null, ys);
- return ol.extent.createOrUpdate(minX, minY, maxX, maxY, opt_extent);
- * Return extent increased by the provided value.
- * @param {ol.Extent} extent Extent.
- * @param {number} value The amount by which the extent should be buffered.
- * @param {ol.Extent=} opt_extent Extent.
- * @api
-ol.extent.buffer = function(extent, value, opt_extent) {
- if (opt_extent) {
- opt_extent[0] = extent[0] - value;
- opt_extent[1] = extent[1] - value;
- opt_extent[2] = extent[2] + value;
- opt_extent[3] = extent[3] + value;
- return opt_extent;
- } else {
- return [
- extent[0] - value,
- extent[1] - value,
- extent[2] + value,
- extent[3] + value
- * Creates a clone of an extent.
- * @param {ol.Extent} extent Extent to clone.
- * @return {ol.Extent} The clone.
-ol.extent.clone = function(extent, opt_extent) {
- if (opt_extent) {
- opt_extent[0] = extent[0];
- opt_extent[1] = extent[1];
- opt_extent[2] = extent[2];
- opt_extent[3] = extent[3];
- } else {
- return extent.slice();
- * @return {number} Closest squared distance.
-ol.extent.closestSquaredDistanceXY = function(extent, x, y) {
- var dx, dy;
- if (x < extent[0]) {
- dx = extent[0] - x;
- } else if (extent[2] < x) {
- dx = x - extent[2];
- } else {
- dx = 0;
- if (y < extent[1]) {
- dy = extent[1] - y;
- } else if (extent[3] < y) {
- dy = y - extent[3];
- } else {
- dy = 0;
- * Check if the passed coordinate is contained or on the edge of the extent.
- * @param {ol.Coordinate} coordinate Coordinate.
- * @return {boolean} The coordinate is contained in the extent.
- * @api
-ol.extent.containsCoordinate = function(extent, coordinate) {
- return ol.extent.containsXY(extent, coordinate[0], coordinate[1]);
- * Check if one extent contains another.
- * An extent is deemed contained if it lies completely within the other extent,
- * including if they share one or more edges.
- * @param {ol.Extent} extent1 Extent 1.
- * @param {ol.Extent} extent2 Extent 2.
- * @return {boolean} The second extent is contained by or on the edge of the
- * first.
- * @api
-ol.extent.containsExtent = function(extent1, extent2) {
- return extent1[0] <= extent2[0] && extent2[2] <= extent1[2] &&
- extent1[1] <= extent2[1] && extent2[3] <= extent1[3];
- * @param {number} x X coordinate.
- * @param {number} y Y coordinate.
- * @return {boolean} The x, y values are contained in the extent.
- * @api
-ol.extent.containsXY = function(extent, x, y) {
- return extent[0] <= x && x <= extent[2] && extent[1] <= y && y <= extent[3];
- * Get the relationship between a coordinate and extent.
- * @param {ol.Extent} extent The extent.
- * @param {ol.Coordinate} coordinate The coordinate.
- * @return {number} The relationship (bitwise compare with
- * ol.extent.Relationship).
-ol.extent.coordinateRelationship = function(extent, coordinate) {
- var minX = extent[0];
- var minY = extent[1];
- var maxX = extent[2];
- var maxY = extent[3];
- var x = coordinate[0];
- var y = coordinate[1];
- var relationship = ol.extent.Relationship.UNKNOWN;
- if (x < minX) {
- relationship = relationship | ol.extent.Relationship.LEFT;
- } else if (x > maxX) {
- relationship = relationship | ol.extent.Relationship.RIGHT;
- if (y < minY) {
- relationship = relationship | ol.extent.Relationship.BELOW;
- } else if (y > maxY) {
- relationship = relationship | ol.extent.Relationship.ABOVE;
- if (relationship === ol.extent.Relationship.UNKNOWN) {
- relationship = ol.extent.Relationship.INTERSECTING;
- return relationship;
- * Create an empty extent.
- * @return {ol.Extent} Empty extent.
- * @api
-ol.extent.createEmpty = function() {
- return [Infinity, Infinity, -Infinity, -Infinity];
- * Create a new extent or update the provided extent.
-ol.extent.createOrUpdate = function(minX, minY, maxX, maxY, opt_extent) {
- if (opt_extent) {
- opt_extent[0] = minX;
- opt_extent[1] = minY;
- opt_extent[2] = maxX;
- opt_extent[3] = maxY;
- } else {
- return [minX, minY, maxX, maxY];
- * Create a new empty extent or make the provided one empty.
-ol.extent.createOrUpdateEmpty = function(opt_extent) {
- Infinity, Infinity, -Infinity, -Infinity, opt_extent);
-ol.extent.createOrUpdateFromCoordinate = function(coordinate, opt_extent) {
- return ol.extent.createOrUpdate(x, y, x, y, opt_extent);
-ol.extent.createOrUpdateFromCoordinates = function(coordinates, opt_extent) {
- var extent = ol.extent.createOrUpdateEmpty(opt_extent);
- return ol.extent.extendCoordinates(extent, coordinates);
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
-ol.extent.createOrUpdateFromFlatCoordinates = function(flatCoordinates, offset, end, stride, opt_extent) {
- return ol.extent.extendFlatCoordinates(
- extent, flatCoordinates, offset, end, stride);
- * @param {Array.<Array.<ol.Coordinate>>} rings Rings.
-ol.extent.createOrUpdateFromRings = function(rings, opt_extent) {
- return ol.extent.extendRings(extent, rings);
- * Determine if two extents are equivalent.
- * @return {boolean} The two extents are equivalent.
- * @api
-ol.extent.equals = function(extent1, extent2) {
- return extent1[0] == extent2[0] && extent1[2] == extent2[2] &&
- extent1[1] == extent2[1] && extent1[3] == extent2[3];
- * Modify an extent to include another extent.
- * @param {ol.Extent} extent1 The extent to be modified.
- * @param {ol.Extent} extent2 The extent that will be included in the first.
- * @return {ol.Extent} A reference to the first (extended) extent.
- * @api
-ol.extent.extend = function(extent1, extent2) {
- if (extent2[0] < extent1[0]) {
- extent1[0] = extent2[0];
- if (extent2[2] > extent1[2]) {
- extent1[2] = extent2[2];
- if (extent2[1] < extent1[1]) {
- extent1[1] = extent2[1];
- if (extent2[3] > extent1[3]) {
- extent1[3] = extent2[3];
- return extent1;
-ol.extent.extendCoordinate = function(extent, coordinate) {
- if (coordinate[0] < extent[0]) {
- extent[0] = coordinate[0];
- if (coordinate[0] > extent[2]) {
- extent[2] = coordinate[0];
- if (coordinate[1] < extent[1]) {
- extent[1] = coordinate[1];
- if (coordinate[1] > extent[3]) {
- extent[3] = coordinate[1];
-ol.extent.extendCoordinates = function(extent, coordinates) {
- var i, ii;
- for (i = 0, ii = coordinates.length; i < ii; ++i) {
- return extent;
-ol.extent.extendFlatCoordinates = function(extent, flatCoordinates, offset, end, stride) {
- for (; offset < end; offset += stride) {
- ol.extent.extendXY(
- extent, flatCoordinates[offset], flatCoordinates[offset + 1]);
- return extent;
-ol.extent.extendRings = function(extent, rings) {
- var i, ii;
- for (i = 0, ii = rings.length; i < ii; ++i) {
- ol.extent.extendCoordinates(extent, rings[i]);
- return extent;
-ol.extent.extendXY = function(extent, x, y) {
- extent[0] = Math.min(extent[0], x);
- extent[1] = Math.min(extent[1], y);
- extent[2] = Math.max(extent[2], x);
- extent[3] = Math.max(extent[3], y);
- * This function calls `callback` for each corner of the extent. If the
- * callback returns a truthy value the function returns that value
- * immediately. Otherwise the function returns `false`.
- * @param {function(this:T, ol.Coordinate): S} callback Callback.
- * @param {T=} opt_this Value to use as `this` when executing `callback`.
- * @return {S|boolean} Value.
- * @template S, T
-ol.extent.forEachCorner = function(extent, callback, opt_this) {
- var val;
- val = callback.call(opt_this, ol.extent.getBottomLeft(extent));
- if (val) {
- return val;
- val = callback.call(opt_this, ol.extent.getBottomRight(extent));
- if (val) {
- return val;
- val = callback.call(opt_this, ol.extent.getTopRight(extent));
- if (val) {
- return val;
- val = callback.call(opt_this, ol.extent.getTopLeft(extent));
- if (val) {
- return val;
- return false;
- * @return {number} Area.
-ol.extent.getArea = function(extent) {
- var area = 0;
- if (!ol.extent.isEmpty(extent)) {
- area = ol.extent.getWidth(extent) * ol.extent.getHeight(extent);
- return area;
- * Get the bottom left coordinate of an extent.
- * @return {ol.Coordinate} Bottom left coordinate.
- * @api
-ol.extent.getBottomLeft = function(extent) {
- return [extent[0], extent[1]];
- * Get the bottom right coordinate of an extent.
- * @return {ol.Coordinate} Bottom right coordinate.
- * @api
-ol.extent.getBottomRight = function(extent) {
- return [extent[2], extent[1]];
- * Get the center coordinate of an extent.
- * @return {ol.Coordinate} Center.
- * @api
-ol.extent.getCenter = function(extent) {
- return [(extent[0] + extent[2]) / 2, (extent[1] + extent[3]) / 2];
- * Get a corner coordinate of an extent.
- * @param {ol.extent.Corner} corner Corner.
- * @return {ol.Coordinate} Corner coordinate.
-ol.extent.getCorner = function(extent, corner) {
- var coordinate;
- if (corner === ol.extent.Corner.BOTTOM_LEFT) {
- coordinate = ol.extent.getBottomLeft(extent);
- } else if (corner === ol.extent.Corner.BOTTOM_RIGHT) {
- coordinate = ol.extent.getBottomRight(extent);
- } else if (corner === ol.extent.Corner.TOP_LEFT) {
- coordinate = ol.extent.getTopLeft(extent);
- } else if (corner === ol.extent.Corner.TOP_RIGHT) {
- coordinate = ol.extent.getTopRight(extent);
- } else {
- ol.asserts.assert(false, 13); // Invalid corner
- return /** @type {!ol.Coordinate} */ (coordinate);
- * @return {number} Enlarged area.
-ol.extent.getEnlargedArea = function(extent1, extent2) {
- var minX = Math.min(extent1[0], extent2[0]);
- var minY = Math.min(extent1[1], extent2[1]);
- var maxX = Math.max(extent1[2], extent2[2]);
- var maxY = Math.max(extent1[3], extent2[3]);
- return (maxX - minX) * (maxY - minY);
- * @param {ol.Coordinate} center Center.
- * @param {number} resolution Resolution.
- * @param {number} rotation Rotation.
-ol.extent.getForViewAndSize = function(center, resolution, rotation, size, opt_extent) {
- var dx = resolution * size[0] / 2;
- var dy = resolution * size[1] / 2;
- var cosRotation = Math.cos(rotation);
- var sinRotation = Math.sin(rotation);
- var xCos = dx * cosRotation;
- var xSin = dx * sinRotation;
- var yCos = dy * cosRotation;
- var ySin = dy * sinRotation;
- var x = center[0];
- var y = center[1];
- var x0 = x - xCos + ySin;
- var x1 = x - xCos - ySin;
- var x2 = x + xCos - ySin;
- var x3 = x + xCos + ySin;
- var y0 = y - xSin - yCos;
- var y1 = y - xSin + yCos;
- var y2 = y + xSin + yCos;
- var y3 = y + xSin - yCos;
- Math.min(x0, x1, x2, x3), Math.min(y0, y1, y2, y3),
- Math.max(x0, x1, x2, x3), Math.max(y0, y1, y2, y3),
- opt_extent);
- * Get the height of an extent.
- * @api
-ol.extent.getHeight = function(extent) {
- return extent[3] - extent[1];
- * @return {number} Intersection area.
-ol.extent.getIntersectionArea = function(extent1, extent2) {
- var intersection = ol.extent.getIntersection(extent1, extent2);
- return ol.extent.getArea(intersection);
- * Get the intersection of two extents.
- * @param {ol.Extent=} opt_extent Optional extent to populate with intersection.
- * @return {ol.Extent} Intersecting extent.
- * @api
-ol.extent.getIntersection = function(extent1, extent2, opt_extent) {
- var intersection = opt_extent ? opt_extent : ol.extent.createEmpty();
- if (ol.extent.intersects(extent1, extent2)) {
- if (extent1[0] > extent2[0]) {
- intersection[0] = extent1[0];
- } else {
- intersection[0] = extent2[0];
- if (extent1[1] > extent2[1]) {
- intersection[1] = extent1[1];
- } else {
- intersection[1] = extent2[1];
- if (extent1[2] < extent2[2]) {
- intersection[2] = extent1[2];
- } else {
- intersection[2] = extent2[2];
- if (extent1[3] < extent2[3]) {
- intersection[3] = extent1[3];
- } else {
- intersection[3] = extent2[3];
- return intersection;
- * @return {number} Margin.
-ol.extent.getMargin = function(extent) {
- return ol.extent.getWidth(extent) + ol.extent.getHeight(extent);
- * Get the size (width, height) of an extent.
- * @return {ol.Size} The extent size.
- * @api
-ol.extent.getSize = function(extent) {
- return [extent[2] - extent[0], extent[3] - extent[1]];
- * Get the top left coordinate of an extent.
- * @return {ol.Coordinate} Top left coordinate.
- * @api
-ol.extent.getTopLeft = function(extent) {
- return [extent[0], extent[3]];
- * Get the top right coordinate of an extent.
- * @return {ol.Coordinate} Top right coordinate.
- * @api
-ol.extent.getTopRight = function(extent) {
- return [extent[2], extent[3]];
- * Get the width of an extent.
- * @api
-ol.extent.getWidth = function(extent) {
- return extent[2] - extent[0];
- * Determine if one extent intersects another.
- * @param {ol.Extent} extent2 Extent.
- * @return {boolean} The two extents intersect.
- * @api
-ol.extent.intersects = function(extent1, extent2) {
- return extent1[0] <= extent2[2] &&
- extent1[2] >= extent2[0] &&
- extent1[1] <= extent2[3] &&
- extent1[3] >= extent2[1];
- * Determine if an extent is empty.
- * @return {boolean} Is empty.
- * @api
-ol.extent.isEmpty = function(extent) {
- return extent[2] < extent[0] || extent[3] < extent[1];
-ol.extent.returnOrUpdate = function(extent, opt_extent) {
- if (opt_extent) {
- } else {
- return extent;
- * @param {number} value Value.
-ol.extent.scaleFromCenter = function(extent, value) {
- var deltaX = ((extent[2] - extent[0]) / 2) * (value - 1);
- var deltaY = ((extent[3] - extent[1]) / 2) * (value - 1);
- extent[0] -= deltaX;
- extent[2] += deltaX;
- extent[1] -= deltaY;
- extent[3] += deltaY;
- * Determine if the segment between two coordinates intersects (crosses,
- * touches, or is contained by) the provided extent.
- * @param {ol.Coordinate} start Segment start coordinate.
- * @param {ol.Coordinate} end Segment end coordinate.
- * @return {boolean} The segment intersects the extent.
-ol.extent.intersectsSegment = function(extent, start, end) {
- var intersects = false;
- var startRel = ol.extent.coordinateRelationship(extent, start);
- var endRel = ol.extent.coordinateRelationship(extent, end);
- if (startRel === ol.extent.Relationship.INTERSECTING ||
- endRel === ol.extent.Relationship.INTERSECTING) {
- intersects = true;
- } else {
- var startX = start[0];
- var startY = start[1];
- var endX = end[0];
- var endY = end[1];
- var slope = (endY - startY) / (endX - startX);
- var x, y;
- if (!!(endRel & ol.extent.Relationship.ABOVE) &&
- !(startRel & ol.extent.Relationship.ABOVE)) {
- // potentially intersects top
- x = endX - ((endY - maxY) / slope);
- intersects = x >= minX && x <= maxX;
- if (!intersects && !!(endRel & ol.extent.Relationship.RIGHT) &&
- !(startRel & ol.extent.Relationship.RIGHT)) {
- // potentially intersects right
- y = endY - ((endX - maxX) * slope);
- intersects = y >= minY && y <= maxY;
- if (!intersects && !!(endRel & ol.extent.Relationship.BELOW) &&
- !(startRel & ol.extent.Relationship.BELOW)) {
- // potentially intersects bottom
- x = endX - ((endY - minY) / slope);
- if (!intersects && !!(endRel & ol.extent.Relationship.LEFT) &&
- !(startRel & ol.extent.Relationship.LEFT)) {
- // potentially intersects left
- y = endY - ((endX - minX) * slope);
- return intersects;
- * Apply a transform function to the extent.
- * @param {ol.TransformFunction} transformFn Transform function. Called with
- * [minX, minY, maxX, maxY] extent coordinates.
- * @api
-ol.extent.applyTransform = function(extent, transformFn, opt_extent) {
- var coordinates = [
- extent[0], extent[1],
- extent[0], extent[3],
- extent[2], extent[1],
- extent[2], extent[3]
- transformFn(coordinates, coordinates, 2);
- var xs = [coordinates[0], coordinates[2], coordinates[4], coordinates[6]];
- var ys = [coordinates[1], coordinates[3], coordinates[5], coordinates[7]];
- return ol.extent.boundingExtentXYs_(xs, ys, opt_extent);
-goog.provide('ol.obj');
- * Polyfill for Object.assign(). Assigns enumerable and own properties from
- * one or more source objects to a target object.
- * @see https://developer.mozilla.org/en/docs/Web/JavaScript/Reference/Global_Objects/Object/assign
- * @param {!Object} target The target object.
- * @param {...Object} var_sources The source object(s).
- * @return {!Object} The modified target object.
-ol.obj.assign = (typeof Object.assign === 'function') ? Object.assign : function(target, var_sources) {
- if (target === undefined || target === null) {
- throw new TypeError('Cannot convert undefined or null to object');
- var output = Object(target);
- for (var i = 1, ii = arguments.length; i < ii; ++i) {
- var source = arguments[i];
- if (source !== undefined && source !== null) {
- for (var key in source) {
- if (source.hasOwnProperty(key)) {
- output[key] = source[key];
- return output;
- * Removes all properties from an object.
- * @param {Object} object The object to clear.
-ol.obj.clear = function(object) {
- for (var property in object) {
- delete object[property];
- * Get an array of property values from an object.
- * @param {Object<K,V>} object The object from which to get the values.
- * @return {!Array<V>} The property values.
- * @template K,V
-ol.obj.getValues = function(object) {
- var values = [];
- values.push(object[property]);
- return values;
- * Determine if an object has any properties.
- * @param {Object} object The object to check.
- * @return {boolean} The object is empty.
-ol.obj.isEmpty = function(object) {
- var property;
- for (property in object) {
- return false;
- return !property;
- * @license
- * Latitude/longitude spherical geodesy formulae taken from
- * http://www.movable-type.co.uk/scripts/latlong.html
- * Licensed under CC-BY-3.0.
-goog.provide('ol.Sphere');
-goog.require('ol.math');
- * @classdesc
- * Class to create objects that can be used with {@link
- * ol.geom.Polygon.circular}.
- * For example to create a sphere whose radius is equal to the semi-major
- * axis of the WGS84 ellipsoid:
- * ```js
- * var wgs84Sphere= new ol.Sphere(6378137);
- * @constructor
- * @param {number} radius Radius.
- * @api
-ol.Sphere = function(radius) {
- * @type {number}
- this.radius = radius;
- * Returns the geodesic area for a list of coordinates.
- * [Reference](https://trs-new.jpl.nasa.gov/handle/2014/40409)
- * Robert. G. Chamberlain and William H. Duquette, "Some Algorithms for
- * Polygons on a Sphere", JPL Publication 07-03, Jet Propulsion
- * Laboratory, Pasadena, CA, June 2007
- * @param {Array.<ol.Coordinate>} coordinates List of coordinates of a linear
- * ring. If the ring is oriented clockwise, the area will be positive,
- * otherwise it will be negative.
- * @api
-ol.Sphere.prototype.geodesicArea = function(coordinates) {
- var area = 0, len = coordinates.length;
- var x1 = coordinates[len - 1][0];
- var y1 = coordinates[len - 1][1];
- for (var i = 0; i < len; i++) {
- var x2 = coordinates[i][0], y2 = coordinates[i][1];
- area += ol.math.toRadians(x2 - x1) *
- (2 + Math.sin(ol.math.toRadians(y1)) +
- Math.sin(ol.math.toRadians(y2)));
- x1 = x2;
- y1 = y2;
- return area * this.radius * this.radius / 2.0;
- * Returns the distance from c1 to c2 using the haversine formula.
- * @param {ol.Coordinate} c1 Coordinate 1.
- * @param {ol.Coordinate} c2 Coordinate 2.
- * @return {number} Haversine distance.
- * @api
-ol.Sphere.prototype.haversineDistance = function(c1, c2) {
- var lat1 = ol.math.toRadians(c1[1]);
- var lat2 = ol.math.toRadians(c2[1]);
- var deltaLatBy2 = (lat2 - lat1) / 2;
- var deltaLonBy2 = ol.math.toRadians(c2[0] - c1[0]) / 2;
- var a = Math.sin(deltaLatBy2) * Math.sin(deltaLatBy2) +
- Math.sin(deltaLonBy2) * Math.sin(deltaLonBy2) *
- Math.cos(lat1) * Math.cos(lat2);
- return 2 * this.radius * Math.atan2(Math.sqrt(a), Math.sqrt(1 - a));
- * Returns the coordinate at the given distance and bearing from `c1`.
- * @param {ol.Coordinate} c1 The origin point (`[lon, lat]` in degrees).
- * @param {number} distance The great-circle distance between the origin
- * point and the target point.
- * @param {number} bearing The bearing (in radians).
- * @return {ol.Coordinate} The target point.
-ol.Sphere.prototype.offset = function(c1, distance, bearing) {
- var lon1 = ol.math.toRadians(c1[0]);
- var dByR = distance / this.radius;
- var lat = Math.asin(
- Math.sin(lat1) * Math.cos(dByR) +
- Math.cos(lat1) * Math.sin(dByR) * Math.cos(bearing));
- var lon = lon1 + Math.atan2(
- Math.sin(bearing) * Math.sin(dByR) * Math.cos(lat1),
- Math.cos(dByR) - Math.sin(lat1) * Math.sin(lat));
- return [ol.math.toDegrees(lon), ol.math.toDegrees(lat)];
-goog.provide('ol.sphere.NORMAL');
-goog.require('ol.Sphere');
- * The normal sphere.
- * @const
- * @type {ol.Sphere}
-ol.sphere.NORMAL = new ol.Sphere(6370997);
-goog.provide('ol.proj.Units');
-goog.require('ol.sphere.NORMAL');
- * Projection units: `'degrees'`, `'ft'`, `'m'`, `'pixels'`, `'tile-pixels'` or
- * `'us-ft'`.
- * @enum {string}
-ol.proj.Units = {
- DEGREES: 'degrees',
- FEET: 'ft',
- METERS: 'm',
- PIXELS: 'pixels',
- TILE_PIXELS: 'tile-pixels',
- USFEET: 'us-ft'
- * Meters per unit lookup table.
- * @const
- * @type {Object.<ol.proj.Units, number>}
- * @api
-ol.proj.Units.METERS_PER_UNIT = {};
-ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.DEGREES] =
- 2 * Math.PI * ol.sphere.NORMAL.radius / 360;
-ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.FEET] = 0.3048;
-ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.METERS] = 1;
-ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.USFEET] = 1200 / 3937;
-goog.provide('ol.proj.proj4');
- * @private
- * @type {Proj4}
-ol.proj.proj4.cache_ = null;
- * Store the proj4 function.
- * @param {Proj4} proj4 The proj4 function.
-ol.proj.proj4.set = function(proj4) {
- ol.proj.proj4.cache_ = proj4;
- * Get proj4.
- * @return {Proj4} The proj4 function set above or available globally.
-ol.proj.proj4.get = function() {
- return ol.proj.proj4.cache_ || window['proj4'];
-goog.provide('ol.proj.Projection');
-goog.require('ol.proj.Units');
-goog.require('ol.proj.proj4');
- * @classdesc
- * Projection definition class. One of these is created for each projection
- * supported in the application and stored in the {@link ol.proj} namespace.
- * You can use these in applications, but this is not required, as API params
- * and options use {@link ol.ProjectionLike} which means the simple string
- * code will suffice.
- * You can use {@link ol.proj.get} to retrieve the object for a particular
- * projection.
- * The library includes definitions for `EPSG:4326` and `EPSG:3857`, together
- * with the following aliases:
- * * `EPSG:4326`: CRS:84, urn:ogc:def:crs:EPSG:6.6:4326,
- * urn:ogc:def:crs:OGC:1.3:CRS84, urn:ogc:def:crs:OGC:2:84,
- * http://www.opengis.net/gml/srs/epsg.xml#4326,
- * urn:x-ogc:def:crs:EPSG:4326
- * * `EPSG:3857`: EPSG:102100, EPSG:102113, EPSG:900913,
- * urn:ogc:def:crs:EPSG:6.18:3:3857,
- * http://www.opengis.net/gml/srs/epsg.xml#3857
- * If you use proj4js, aliases can be added using `proj4.defs()`; see
- * [documentation](https://github.com/proj4js/proj4js). To set an alternative
- * namespace for proj4, use {@link ol.proj.setProj4}.
- * @constructor
- * @param {olx.ProjectionOptions} options Projection options.
- * @struct
- * @api
-ol.proj.Projection = function(options) {
- * @private
- * @type {string}
- this.code_ = options.code;
- * @private
- * @type {ol.proj.Units}
- this.units_ = /** @type {ol.proj.Units} */ (options.units);
- * @private
- * @type {ol.Extent}
- this.extent_ = options.extent !== undefined ? options.extent : null;
- * @private
- this.worldExtent_ = options.worldExtent !== undefined ?
- options.worldExtent : null;
- * @private
- * @type {string}
- this.axisOrientation_ = options.axisOrientation !== undefined ?
- options.axisOrientation : 'enu';
- * @private
- * @type {boolean}
- this.global_ = options.global !== undefined ? options.global : false;
- * @private
- * @type {boolean}
- this.canWrapX_ = !!(this.global_ && this.extent_);
- * @private
- * @type {function(number, ol.Coordinate):number|undefined}
- this.getPointResolutionFunc_ = options.getPointResolution;
- * @private
- * @type {ol.tilegrid.TileGrid}
- this.defaultTileGrid_ = null;
- * @private
- this.metersPerUnit_ = options.metersPerUnit;
- var code = options.code;
- if (ol.ENABLE_PROJ4JS) {
- var proj4js = ol.proj.proj4.get();
- if (typeof proj4js == 'function') {
- var def = proj4js.defs(code);
- if (def !== undefined) {
- if (def.axis !== undefined && options.axisOrientation === undefined) {
- this.axisOrientation_ = def.axis;
- if (options.metersPerUnit === undefined) {
- this.metersPerUnit_ = def.to_meter;
- if (options.units === undefined) {
- this.units_ = def.units;
- * @return {boolean} The projection is suitable for wrapping the x-axis
-ol.proj.Projection.prototype.canWrapX = function() {
- return this.canWrapX_;
- * Get the code for this projection, e.g. 'EPSG:4326'.
- * @return {string} Code.
- * @api
-ol.proj.Projection.prototype.getCode = function() {
- return this.code_;
- * Get the validity extent for this projection.
- * @api
-ol.proj.Projection.prototype.getExtent = function() {
- return this.extent_;
- * Get the units of this projection.
- * @return {ol.proj.Units} Units.
- * @api
-ol.proj.Projection.prototype.getUnits = function() {
- return this.units_;
- * Get the amount of meters per unit of this projection. If the projection is
- * not configured with `metersPerUnit` or a units identifier, the return is
- * `undefined`.
- * @return {number|undefined} Meters.
- * @api
-ol.proj.Projection.prototype.getMetersPerUnit = function() {
- return this.metersPerUnit_ || ol.proj.Units.METERS_PER_UNIT[this.units_];
- * Get the world extent for this projection.
- * @api
-ol.proj.Projection.prototype.getWorldExtent = function() {
- return this.worldExtent_;
- * Get the axis orientation of this projection.
- * Example values are:
- * enu - the default easting, northing, elevation.
- * neu - northing, easting, up - useful for "lat/long" geographic coordinates,
- * or south orientated transverse mercator.
- * wnu - westing, northing, up - some planetary coordinate systems have
- * "west positive" coordinate systems
- * @return {string} Axis orientation.
-ol.proj.Projection.prototype.getAxisOrientation = function() {
- return this.axisOrientation_;
- * Is this projection a global projection which spans the whole world?
- * @return {boolean} Whether the projection is global.
- * @api
-ol.proj.Projection.prototype.isGlobal = function() {
- return this.global_;
-* Set if the projection is a global projection which spans the whole world
-* @param {boolean} global Whether the projection is global.
-* @api
-ol.proj.Projection.prototype.setGlobal = function(global) {
- this.global_ = global;
- this.canWrapX_ = !!(global && this.extent_);
- * @return {ol.tilegrid.TileGrid} The default tile grid.
-ol.proj.Projection.prototype.getDefaultTileGrid = function() {
- return this.defaultTileGrid_;
- * @param {ol.tilegrid.TileGrid} tileGrid The default tile grid.
-ol.proj.Projection.prototype.setDefaultTileGrid = function(tileGrid) {
- this.defaultTileGrid_ = tileGrid;
- * Set the validity extent for this projection.
- * @api
-ol.proj.Projection.prototype.setExtent = function(extent) {
- this.extent_ = extent;
- this.canWrapX_ = !!(this.global_ && extent);
- * Set the world extent for this projection.
- * @param {ol.Extent} worldExtent World extent
- * [minlon, minlat, maxlon, maxlat].
- * @api
-ol.proj.Projection.prototype.setWorldExtent = function(worldExtent) {
- this.worldExtent_ = worldExtent;
- * Set the getPointResolution function for this projection.
- * @param {function(number, ol.Coordinate):number} func Function
- * @api
-ol.proj.Projection.prototype.setGetPointResolution = function(func) {
- this.getPointResolutionFunc_ = func;
- * Get the custom point resolution function for this projection (if set).
- * @return {function(number, ol.Coordinate):number|undefined} The custom point
- * resolution function (if set).
-ol.proj.Projection.prototype.getPointResolutionFunc = function() {
- return this.getPointResolutionFunc_;
-goog.provide('ol.proj.EPSG3857');
-goog.require('ol.proj.Projection');
- * @classdesc
- * Projection object for web/spherical Mercator (EPSG:3857).
- * @constructor
- * @extends {ol.proj.Projection}
- * @param {string} code Code.
- * @private
-ol.proj.EPSG3857.Projection_ = function(code) {
- ol.proj.Projection.call(this, {
- code: code,
- units: ol.proj.Units.METERS,
- extent: ol.proj.EPSG3857.EXTENT,
- global: true,
- worldExtent: ol.proj.EPSG3857.WORLD_EXTENT,
- getPointResolution: function(resolution, point) {
- return resolution / ol.math.cosh(point[1] / ol.proj.EPSG3857.RADIUS);
-ol.inherits(ol.proj.EPSG3857.Projection_, ol.proj.Projection);
- * @const
- * @type {number}
-ol.proj.EPSG3857.RADIUS = 6378137;
- * @const
- * @type {number}
-ol.proj.EPSG3857.HALF_SIZE = Math.PI * ol.proj.EPSG3857.RADIUS;
- * @const
-ol.proj.EPSG3857.EXTENT = [
- -ol.proj.EPSG3857.HALF_SIZE, -ol.proj.EPSG3857.HALF_SIZE,
- ol.proj.EPSG3857.HALF_SIZE, ol.proj.EPSG3857.HALF_SIZE
- * @const
-ol.proj.EPSG3857.WORLD_EXTENT = [-180, -85, 180, 85];
- * Lists several projection codes with the same meaning as EPSG:3857.
-ol.proj.EPSG3857.CODES = [
- 'EPSG:3857',
- 'EPSG:102100',
- 'EPSG:102113',
- 'EPSG:900913',
- 'urn:ogc:def:crs:EPSG:6.18:3:3857',
- 'urn:ogc:def:crs:EPSG::3857',
- 'http://www.opengis.net/gml/srs/epsg.xml#3857'
- * Projections equal to EPSG:3857.
- * @const
- * @type {Array.<ol.proj.Projection>}
-ol.proj.EPSG3857.PROJECTIONS = ol.proj.EPSG3857.CODES.map(function(code) {
- return new ol.proj.EPSG3857.Projection_(code);
- * Transformation from EPSG:4326 to EPSG:3857.
- * @param {Array.<number>} input Input array of coordinate values.
- * @param {Array.<number>=} opt_output Output array of coordinate values.
- * @param {number=} opt_dimension Dimension (default is `2`).
- * @return {Array.<number>} Output array of coordinate values.
-ol.proj.EPSG3857.fromEPSG4326 = function(input, opt_output, opt_dimension) {
- var length = input.length,
- dimension = opt_dimension > 1 ? opt_dimension : 2,
- output = opt_output;
- if (output === undefined) {
- if (dimension > 2) {
- // preserve values beyond second dimension
- output = input.slice();
- } else {
- output = new Array(length);
- var halfSize = ol.proj.EPSG3857.HALF_SIZE;
- for (var i = 0; i < length; i += dimension) {
- output[i] = halfSize * input[i] / 180;
- var y = ol.proj.EPSG3857.RADIUS *
- Math.log(Math.tan(Math.PI * (input[i + 1] + 90) / 360));
- if (y > halfSize) {
- y = halfSize;
- } else if (y < -halfSize) {
- y = -halfSize;
- output[i + 1] = y;
- return output;
- * Transformation from EPSG:3857 to EPSG:4326.
-ol.proj.EPSG3857.toEPSG4326 = function(input, opt_output, opt_dimension) {
- } else {
- output[i] = 180 * input[i] / ol.proj.EPSG3857.HALF_SIZE;
- output[i + 1] = 360 * Math.atan(
- Math.exp(input[i + 1] / ol.proj.EPSG3857.RADIUS)) / Math.PI - 90;
- return output;
-goog.provide('ol.sphere.WGS84');
- * A sphere with radius equal to the semi-major axis of the WGS84 ellipsoid.
- * @const
-ol.sphere.WGS84 = new ol.Sphere(6378137);
-goog.provide('ol.proj.EPSG4326');
-goog.require('ol.sphere.WGS84');
- * @classdesc
- * Projection object for WGS84 geographic coordinates (EPSG:4326).
- * Note that OpenLayers does not strictly comply with the EPSG definition.
- * The EPSG registry defines 4326 as a CRS for Latitude,Longitude (y,x).
- * OpenLayers treats EPSG:4326 as a pseudo-projection, with x,y coordinates.
- * @constructor
- * @param {string=} opt_axisOrientation Axis orientation.
- * @private
-ol.proj.EPSG4326.Projection_ = function(code, opt_axisOrientation) {
- code: code,
- units: ol.proj.Units.DEGREES,
- extent: ol.proj.EPSG4326.EXTENT,
- axisOrientation: opt_axisOrientation,
- global: true,
- metersPerUnit: ol.proj.EPSG4326.METERS_PER_UNIT,
- worldExtent: ol.proj.EPSG4326.EXTENT
-ol.inherits(ol.proj.EPSG4326.Projection_, ol.proj.Projection);
- * Extent of the EPSG:4326 projection which is the whole world.
- * @const
-ol.proj.EPSG4326.EXTENT = [-180, -90, 180, 90];
- * @const
- * @type {number}
-ol.proj.EPSG4326.METERS_PER_UNIT = Math.PI * ol.sphere.WGS84.radius / 180;
- * Projections equal to EPSG:4326.
- * @const
-ol.proj.EPSG4326.PROJECTIONS = [
- new ol.proj.EPSG4326.Projection_('CRS:84'),
- new ol.proj.EPSG4326.Projection_('EPSG:4326', 'neu'),
- new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:EPSG::4326', 'neu'),
- new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:EPSG:6.6:4326', 'neu'),
- new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:OGC:1.3:CRS84'),
- new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:OGC:2:84'),
- new ol.proj.EPSG4326.Projection_('http://www.opengis.net/gml/srs/epsg.xml#4326', 'neu'),
- new ol.proj.EPSG4326.Projection_('urn:x-ogc:def:crs:EPSG:4326', 'neu')
-goog.provide('ol.proj.projections');
- * @private
- * @type {Object.<string, ol.proj.Projection>}
-ol.proj.projections.cache_ = {};
- * Clear the projections cache.
-ol.proj.projections.clear = function() {
- ol.proj.projections.cache_ = {};
- * Get a cached projection by code.
- * @param {string} code The code for the projection.
- * @return {ol.proj.Projection} The projection (if cached).
-ol.proj.projections.get = function(code) {
- var projections = ol.proj.projections.cache_;
- return projections[code] || null;
- * Add a projection to the cache.
- * @param {string} code The projection code.
- * @param {ol.proj.Projection} projection The projection to cache.
-ol.proj.projections.add = function(code, projection) {
- projections[code] = projection;
-goog.provide('ol.proj.transforms');
-goog.require('ol.obj');
- * @private
- * @type {Object.<string, Object.<string, ol.TransformFunction>>}
-ol.proj.transforms.cache_ = {};
- * Clear the transform cache.
-ol.proj.transforms.clear = function() {
- ol.proj.transforms.cache_ = {};
- * Registers a conversion function to convert coordinates from the source
- * projection to the destination projection.
- * @param {ol.proj.Projection} source Source.
- * @param {ol.proj.Projection} destination Destination.
- * @param {ol.TransformFunction} transformFn Transform.
-ol.proj.transforms.add = function(source, destination, transformFn) {
- var sourceCode = source.getCode();
- var destinationCode = destination.getCode();
- var transforms = ol.proj.transforms.cache_;
- if (!(sourceCode in transforms)) {
- transforms[sourceCode] = {};
- transforms[sourceCode][destinationCode] = transformFn;
- * Unregisters the conversion function to convert coordinates from the source
- * projection to the destination projection. This method is used to clean up
- * cached transforms during testing.
- * @param {ol.proj.Projection} source Source projection.
- * @param {ol.proj.Projection} destination Destination projection.
- * @return {ol.TransformFunction} transformFn The unregistered transform.
-ol.proj.transforms.remove = function(source, destination) {
- var transform = transforms[sourceCode][destinationCode];
- delete transforms[sourceCode][destinationCode];
- if (ol.obj.isEmpty(transforms[sourceCode])) {
- delete transforms[sourceCode];
- return transform;
- * Get a transform given a source code and a destination code.
- * @param {string} sourceCode The code for the source projection.
- * @param {string} destinationCode The code for the destination projection.
- * @return {ol.TransformFunction|undefined} The transform function (if found).
-ol.proj.transforms.get = function(sourceCode, destinationCode) {
- var transform;
- if (sourceCode in transforms && destinationCode in transforms[sourceCode]) {
- transform = transforms[sourceCode][destinationCode];
- return transform;
-goog.provide('ol.proj');
-goog.require('ol.extent');
-goog.require('ol.proj.EPSG3857');
-goog.require('ol.proj.EPSG4326');
-goog.require('ol.proj.projections');
-goog.require('ol.proj.transforms');
- * @const
- * @api
-ol.proj.METERS_PER_UNIT = ol.proj.Units.METERS_PER_UNIT;
-if (ol.ENABLE_PROJ4JS) {
- * Register proj4. If not explicitly registered, it will be assumed that
- * proj4js will be loaded in the global namespace. For example in a
- * browserify ES6 environment you could use:
- * import ol from 'openlayers';
- * import proj4 from 'proj4';
- * ol.proj.setProj4(proj4);
- * @param {Proj4} proj4 Proj4.
- * @api
- ol.proj.setProj4 = function(proj4) {
- ol.proj.proj4.set(proj4);
- * Get the resolution of the point in degrees or distance units.
- * For projections with degrees as the unit this will simply return the
- * provided resolution. For other projections the point resolution is
- * estimated by transforming the 'point' pixel to EPSG:4326,
- * measuring its width and height on the normal sphere,
- * and taking the average of the width and height.
- * @param {ol.proj.Projection} projection The projection.
- * @param {number} resolution Nominal resolution in projection units.
- * @param {ol.Coordinate} point Point to find adjusted resolution at.
- * @return {number} Point resolution at point in projection units.
- * @api
-ol.proj.getPointResolution = function(projection, resolution, point) {
- var pointResolution;
- var getter = projection.getPointResolutionFunc();
- if (getter) {
- pointResolution = getter(resolution, point);
- } else {
- var units = projection.getUnits();
- if (units == ol.proj.Units.DEGREES) {
- pointResolution = resolution;
- } else {
- // Estimate point resolution by transforming the center pixel to EPSG:4326,
- // measuring its width and height on the normal sphere, and taking the
- // average of the width and height.
- var toEPSG4326 = ol.proj.getTransformFromProjections(projection, ol.proj.get('EPSG:4326'));
- var vertices = [
- point[0] - resolution / 2, point[1],
- point[0] + resolution / 2, point[1],
- point[0], point[1] - resolution / 2,
- point[0], point[1] + resolution / 2
- vertices = toEPSG4326(vertices, vertices, 2);
- var width = ol.sphere.NORMAL.haversineDistance(
- vertices.slice(0, 2), vertices.slice(2, 4));
- var height = ol.sphere.NORMAL.haversineDistance(
- vertices.slice(4, 6), vertices.slice(6, 8));
- pointResolution = (width + height) / 2;
- var metersPerUnit = projection.getMetersPerUnit();
- if (metersPerUnit !== undefined) {
- pointResolution /= metersPerUnit;
- return pointResolution;
- * Registers transformation functions that don't alter coordinates. Those allow
- * to transform between projections with equal meaning.
- * @param {Array.<ol.proj.Projection>} projections Projections.
- * @api
-ol.proj.addEquivalentProjections = function(projections) {
- ol.proj.addProjections(projections);
- projections.forEach(function(source) {
- projections.forEach(function(destination) {
- if (source !== destination) {
- ol.proj.transforms.add(source, destination, ol.proj.cloneTransform);
- * Registers transformation functions to convert coordinates in any projection
- * in projection1 to any projection in projection2.
- * @param {Array.<ol.proj.Projection>} projections1 Projections with equal
- * meaning.
- * @param {Array.<ol.proj.Projection>} projections2 Projections with equal
- * meaning.
- * @param {ol.TransformFunction} forwardTransform Transformation from any
- * projection in projection1 to any projection in projection2.
- * @param {ol.TransformFunction} inverseTransform Transform from any projection
- * in projection2 to any projection in projection1..
-ol.proj.addEquivalentTransforms = function(projections1, projections2, forwardTransform, inverseTransform) {
- projections1.forEach(function(projection1) {
- projections2.forEach(function(projection2) {
- ol.proj.transforms.add(projection1, projection2, forwardTransform);
- ol.proj.transforms.add(projection2, projection1, inverseTransform);
- * Add a Projection object to the list of supported projections that can be
- * looked up by their code.
- * @param {ol.proj.Projection} projection Projection instance.
- * @api
-ol.proj.addProjection = function(projection) {
- ol.proj.projections.add(projection.getCode(), projection);
- ol.proj.transforms.add(projection, projection, ol.proj.cloneTransform);
-ol.proj.addProjections = function(projections) {
- var addedProjections = [];
- projections.forEach(function(projection) {
- addedProjections.push(ol.proj.addProjection(projection));
- * Clear all cached projections and transforms.
-ol.proj.clearAllProjections = function() {
- ol.proj.projections.clear();
- ol.proj.transforms.clear();
- * @param {ol.proj.Projection|string|undefined} projection Projection.
- * @param {string} defaultCode Default code.
- * @return {ol.proj.Projection} Projection.
-ol.proj.createProjection = function(projection, defaultCode) {
- if (!projection) {
- return ol.proj.get(defaultCode);
- } else if (typeof projection === 'string') {
- return ol.proj.get(projection);
- } else {
- return /** @type {ol.proj.Projection} */ (projection);
- * Registers coordinate transform functions to convert coordinates between the
- * source projection and the destination projection.
- * The forward and inverse functions convert coordinate pairs; this function
- * converts these into the functions used internally which also handle
- * extents and coordinate arrays.
- * @param {ol.ProjectionLike} source Source projection.
- * @param {ol.ProjectionLike} destination Destination projection.
- * @param {function(ol.Coordinate): ol.Coordinate} forward The forward transform
- * function (that is, from the source projection to the destination
- * projection) that takes a {@link ol.Coordinate} as argument and returns
- * the transformed {@link ol.Coordinate}.
- * @param {function(ol.Coordinate): ol.Coordinate} inverse The inverse transform
- * function (that is, from the destination projection to the source
- * @api
-ol.proj.addCoordinateTransforms = function(source, destination, forward, inverse) {
- var sourceProj = ol.proj.get(source);
- var destProj = ol.proj.get(destination);
- ol.proj.transforms.add(sourceProj, destProj,
- ol.proj.createTransformFromCoordinateTransform(forward));
- ol.proj.transforms.add(destProj, sourceProj,
- ol.proj.createTransformFromCoordinateTransform(inverse));
- * Creates a {@link ol.TransformFunction} from a simple 2D coordinate transform
- * function.
- * @param {function(ol.Coordinate): ol.Coordinate} transform Coordinate
- * transform.
- * @return {ol.TransformFunction} Transform function.
-ol.proj.createTransformFromCoordinateTransform = function(transform) {
- return (
- * @param {Array.<number>} input Input.
- * @param {Array.<number>=} opt_output Output.
- * @param {number=} opt_dimension Dimension.
- * @return {Array.<number>} Output.
- function(input, opt_output, opt_dimension) {
- var length = input.length;
- var dimension = opt_dimension !== undefined ? opt_dimension : 2;
- var output = opt_output !== undefined ? opt_output : new Array(length);
- var point, i, j;
- for (i = 0; i < length; i += dimension) {
- point = transform([input[i], input[i + 1]]);
- output[i] = point[0];
- output[i + 1] = point[1];
- for (j = dimension - 1; j >= 2; --j) {
- output[i + j] = input[i + j];
- return output;
- * Transforms a coordinate from longitude/latitude to a different projection.
- * @param {ol.Coordinate} coordinate Coordinate as longitude and latitude, i.e.
- * an array with longitude as 1st and latitude as 2nd element.
- * @param {ol.ProjectionLike=} opt_projection Target projection. The
- * default is Web Mercator, i.e. 'EPSG:3857'.
- * @return {ol.Coordinate} Coordinate projected to the target projection.
- * @api
-ol.proj.fromLonLat = function(coordinate, opt_projection) {
- return ol.proj.transform(coordinate, 'EPSG:4326',
- opt_projection !== undefined ? opt_projection : 'EPSG:3857');
- * Transforms a coordinate to longitude/latitude.
- * @param {ol.Coordinate} coordinate Projected coordinate.
- * @param {ol.ProjectionLike=} opt_projection Projection of the coordinate.
- * The default is Web Mercator, i.e. 'EPSG:3857'.
- * @return {ol.Coordinate} Coordinate as longitude and latitude, i.e. an array
- * with longitude as 1st and latitude as 2nd element.
- * @api
-ol.proj.toLonLat = function(coordinate, opt_projection) {
- opt_projection !== undefined ? opt_projection : 'EPSG:3857', 'EPSG:4326');
- * Fetches a Projection object for the code specified.
- * @param {ol.ProjectionLike} projectionLike Either a code string which is
- * a combination of authority and identifier such as "EPSG:4326", or an
- * existing projection object, or undefined.
- * @return {ol.proj.Projection} Projection object, or null if not in list.
- * @api
-ol.proj.get = function(projectionLike) {
- var projection = null;
- if (projectionLike instanceof ol.proj.Projection) {
- projection = projectionLike;
- } else if (typeof projectionLike === 'string') {
- var code = projectionLike;
- projection = ol.proj.projections.get(code);
- if (!projection && typeof proj4js == 'function' &&
- proj4js.defs(code) !== undefined) {
- projection = new ol.proj.Projection({code: code});
- ol.proj.addProjection(projection);
- return projection;
- * Checks if two projections are the same, that is every coordinate in one
- * projection does represent the same geographic point as the same coordinate in
- * the other projection.
- * @param {ol.proj.Projection} projection1 Projection 1.
- * @param {ol.proj.Projection} projection2 Projection 2.
- * @return {boolean} Equivalent.
- * @api
-ol.proj.equivalent = function(projection1, projection2) {
- if (projection1 === projection2) {
- return true;
- var equalUnits = projection1.getUnits() === projection2.getUnits();
- if (projection1.getCode() === projection2.getCode()) {
- return equalUnits;
- } else {
- var transformFn = ol.proj.getTransformFromProjections(
- projection1, projection2);
- return transformFn === ol.proj.cloneTransform && equalUnits;
- * Given the projection-like objects, searches for a transformation
- * function to convert a coordinates array from the source projection to the
- * destination projection.
- * @param {ol.ProjectionLike} source Source.
- * @param {ol.ProjectionLike} destination Destination.
- * @api
-ol.proj.getTransform = function(source, destination) {
- var sourceProjection = ol.proj.get(source);
- var destinationProjection = ol.proj.get(destination);
- return ol.proj.getTransformFromProjections(
- sourceProjection, destinationProjection);
- * Searches in the list of transform functions for the function for converting
- * coordinates from the source projection to the destination projection.
- * @param {ol.proj.Projection} sourceProjection Source Projection object.
- * @param {ol.proj.Projection} destinationProjection Destination Projection
- * object.
-ol.proj.getTransformFromProjections = function(sourceProjection, destinationProjection) {
- var sourceCode = sourceProjection.getCode();
- var destinationCode = destinationProjection.getCode();
- var transform = ol.proj.transforms.get(sourceCode, destinationCode);
- if (ol.ENABLE_PROJ4JS && !transform) {
- var sourceDef = proj4js.defs(sourceCode);
- var destinationDef = proj4js.defs(destinationCode);
- if (sourceDef !== undefined && destinationDef !== undefined) {
- if (sourceDef === destinationDef) {
- ol.proj.addEquivalentProjections([destinationProjection, sourceProjection]);
- } else {
- var proj4Transform = proj4js(destinationCode, sourceCode);
- ol.proj.addCoordinateTransforms(destinationProjection, sourceProjection,
- proj4Transform.forward, proj4Transform.inverse);
- transform = ol.proj.transforms.get(sourceCode, destinationCode);
- if (!transform) {
- transform = ol.proj.identityTransform;
- return transform;
- * @param {Array.<number>} input Input coordinate array.
- * @return {Array.<number>} Input coordinate array (same array as input).
-ol.proj.identityTransform = function(input, opt_output, opt_dimension) {
- if (opt_output !== undefined && input !== opt_output) {
- for (var i = 0, ii = input.length; i < ii; ++i) {
- opt_output[i] = input[i];
- input = opt_output;
- return input;
- * @return {Array.<number>} Output coordinate array (new array, same coordinate
- * values).
-ol.proj.cloneTransform = function(input, opt_output, opt_dimension) {
- var output;
- if (opt_output !== undefined) {
- } else {
- return output;
- * Transforms a coordinate from source projection to destination projection.
- * This returns a new coordinate (and does not modify the original).
- * See {@link ol.proj.transformExtent} for extent transformation.
- * See the transform method of {@link ol.geom.Geometry} and its subclasses for
- * geometry transforms.
- * @param {ol.ProjectionLike} source Source projection-like.
- * @param {ol.ProjectionLike} destination Destination projection-like.
- * @return {ol.Coordinate} Coordinate.
- * @api
-ol.proj.transform = function(coordinate, source, destination) {
- var transformFn = ol.proj.getTransform(source, destination);
- return transformFn(coordinate, undefined, coordinate.length);
- * Transforms an extent from source projection to destination projection. This
- * returns a new extent (and does not modify the original).
- * @param {ol.Extent} extent The extent to transform.
- * @return {ol.Extent} The transformed extent.
- * @api
-ol.proj.transformExtent = function(extent, source, destination) {
- return ol.extent.applyTransform(extent, transformFn);
- * Transforms the given point to the destination projection.
- * @param {ol.Coordinate} point Point.
- * @param {ol.proj.Projection} sourceProjection Source projection.
- * @param {ol.proj.Projection} destinationProjection Destination projection.
- * @return {ol.Coordinate} Point.
-ol.proj.transformWithProjections = function(point, sourceProjection, destinationProjection) {
- return transformFn(point);
- * Add transforms to and from EPSG:4326 and EPSG:3857. This function is called
- * by when this module is executed and should only need to be called again after
- * `ol.proj.clearAllProjections()` is called (e.g. in tests).
-ol.proj.addCommon = function() {
- // Add transformations that don't alter coordinates to convert within set of
- // projections with equal meaning.
- ol.proj.addEquivalentProjections(ol.proj.EPSG3857.PROJECTIONS);
- ol.proj.addEquivalentProjections(ol.proj.EPSG4326.PROJECTIONS);
- // Add transformations to convert EPSG:4326 like coordinates to EPSG:3857 like
- // coordinates and back.
- ol.proj.addEquivalentTransforms(
- ol.proj.EPSG4326.PROJECTIONS,
- ol.proj.EPSG3857.PROJECTIONS,
- ol.proj.EPSG3857.fromEPSG4326,
- ol.proj.EPSG3857.toEPSG4326);
-ol.proj.addCommon();
-goog.provide('ol.tilecoord');
- * @param {number} z Z.
- * @param {ol.TileCoord=} opt_tileCoord Tile coordinate.
- * @return {ol.TileCoord} Tile coordinate.
-ol.tilecoord.createOrUpdate = function(z, x, y, opt_tileCoord) {
- if (opt_tileCoord !== undefined) {
- opt_tileCoord[0] = z;
- opt_tileCoord[1] = x;
- opt_tileCoord[2] = y;
- return opt_tileCoord;
- } else {
- return [z, x, y];
- * @return {string} Key.
-ol.tilecoord.getKeyZXY = function(z, x, y) {
- return z + '/' + x + '/' + y;
- * @param {ol.TileCoord} tileCoord Tile coord.
- * @return {number} Hash.
-ol.tilecoord.hash = function(tileCoord) {
- return (tileCoord[1] << tileCoord[0]) + tileCoord[2];
- * @return {string} Quad key.
-ol.tilecoord.quadKey = function(tileCoord) {
- var z = tileCoord[0];
- var digits = new Array(z);
- var mask = 1 << (z - 1);
- var i, charCode;
- for (i = 0; i < z; ++i) {
- // 48 is charCode for 0 - '0'.charCodeAt(0)
- charCode = 48;
- if (tileCoord[1] & mask) {
- charCode += 1;
- if (tileCoord[2] & mask) {
- charCode += 2;
- digits[i] = String.fromCharCode(charCode);
- mask >>= 1;
- return digits.join('');
- * @param {ol.TileCoord} tileCoord Tile coordinate.
- * @param {!ol.tilegrid.TileGrid} tileGrid Tile grid.
- * @return {boolean} Tile coordinate is within extent and zoom level range.
-ol.tilecoord.withinExtentAndZ = function(tileCoord, tileGrid) {
- var x = tileCoord[1];
- var y = tileCoord[2];
- if (tileGrid.getMinZoom() > z || z > tileGrid.getMaxZoom()) {
- return false;
- var extent = tileGrid.getExtent();
- var tileRange;
- if (!extent) {
- tileRange = tileGrid.getFullTileRange(z);
- } else {
- tileRange = tileGrid.getTileRangeForExtentAndZ(extent, z);
- if (!tileRange) {
- return true;
- } else {
- return tileRange.containsXY(x, y);
-goog.provide('ol.tilegrid.TileGrid');
-goog.require('ol');
-goog.require('ol.TileRange');
-goog.require('ol.array');
-goog.require('ol.size');
-goog.require('ol.tilecoord');
- * @classdesc
- * Base class for setting the grid pattern for sources accessing tiled-image
- * servers.
- * @constructor
- * @param {olx.tilegrid.TileGridOptions} options Tile grid options.
- * @struct
- * @api
-ol.tilegrid.TileGrid = function(options) {
- * @protected
- * @type {number}
- this.minZoom = options.minZoom !== undefined ? options.minZoom : 0;
- * @private
- * @type {!Array.<number>}
- this.resolutions_ = options.resolutions;
- ol.asserts.assert(ol.array.isSorted(this.resolutions_, function(a, b) {
- return b - a;
- }, true), 17); // `resolutions` must be sorted in descending order
- * @protected
- * @type {number}
- this.maxZoom = this.resolutions_.length - 1;
- * @private
- * @type {ol.Coordinate}
- this.origin_ = options.origin !== undefined ? options.origin : null;
- * @private
- * @type {Array.<ol.Coordinate>}
- this.origins_ = null;
- if (options.origins !== undefined) {
- this.origins_ = options.origins;
- ol.asserts.assert(this.origins_.length == this.resolutions_.length,
- 20); // Number of `origins` and `resolutions` must be equal
- var extent = options.extent;
- if (extent !== undefined &&
- !this.origin_ && !this.origins_) {
- this.origin_ = ol.extent.getTopLeft(extent);
- (!this.origin_ && this.origins_) || (this.origin_ && !this.origins_),
- 18); // Either `origin` or `origins` must be configured, never both
- * @private
- * @type {Array.<number|ol.Size>}
- this.tileSizes_ = null;
- if (options.tileSizes !== undefined) {
- this.tileSizes_ = options.tileSizes;
- ol.asserts.assert(this.tileSizes_.length == this.resolutions_.length,
- 19); // Number of `tileSizes` and `resolutions` must be equal
- * @private
- * @type {number|ol.Size}
- this.tileSize_ = options.tileSize !== undefined ?
- options.tileSize :
- !this.tileSizes_ ? ol.DEFAULT_TILE_SIZE : null;
- (!this.tileSize_ && this.tileSizes_) ||
- (this.tileSize_ && !this.tileSizes_),
- 22); // Either `tileSize` or `tileSizes` must be configured, never both
- * @private
- this.extent_ = extent !== undefined ? extent : null;
- * @private
- * @type {Array.<ol.TileRange>}
- this.fullTileRanges_ = null;
- * @private
- * @type {ol.Size}
- this.tmpSize_ = [0, 0];
- if (options.sizes !== undefined) {
- this.fullTileRanges_ = options.sizes.map(function(size, z) {
- var tileRange = new ol.TileRange(
- Math.min(0, size[0]), Math.max(size[0] - 1, -1),
- Math.min(0, size[1]), Math.max(size[1] - 1, -1));
- return tileRange;
- }, this);
- } else if (extent) {
- this.calculateTileRanges_(extent);
- * @private
- * @type {ol.TileCoord}
-ol.tilegrid.TileGrid.tmpTileCoord_ = [0, 0, 0];
- * Call a function with each tile coordinate for a given extent and zoom level.
- * @param {number} zoom Zoom level.
- * @param {function(ol.TileCoord)} callback Function called with each tile coordinate.
- * @api
-ol.tilegrid.TileGrid.prototype.forEachTileCoord = function(extent, zoom, callback) {
- var tileRange = this.getTileRangeForExtentAndZ(extent, zoom);
- for (var i = tileRange.minX, ii = tileRange.maxX; i <= ii; ++i) {
- for (var j = tileRange.minY, jj = tileRange.maxY; j <= jj; ++j) {
- callback([zoom, i, j]);
- * @param {function(this: T, number, ol.TileRange): boolean} callback Callback.
- * @param {T=} opt_this The object to use as `this` in `callback`.
- * @param {ol.TileRange=} opt_tileRange Temporary ol.TileRange object.
- * @param {ol.Extent=} opt_extent Temporary ol.Extent object.
- * @return {boolean} Callback succeeded.
- * @template T
-ol.tilegrid.TileGrid.prototype.forEachTileCoordParentTileRange = function(tileCoord, callback, opt_this, opt_tileRange, opt_extent) {
- var tileCoordExtent = this.getTileCoordExtent(tileCoord, opt_extent);
- var z = tileCoord[0] - 1;
- while (z >= this.minZoom) {
- if (callback.call(opt_this, z,
- this.getTileRangeForExtentAndZ(tileCoordExtent, z, opt_tileRange))) {
- return true;
- --z;
- return false;
- * Get the extent for this tile grid, if it was configured.
-ol.tilegrid.TileGrid.prototype.getExtent = function() {
- * Get the maximum zoom level for the grid.
- * @return {number} Max zoom.
- * @api
-ol.tilegrid.TileGrid.prototype.getMaxZoom = function() {
- return this.maxZoom;
- * Get the minimum zoom level for the grid.
- * @return {number} Min zoom.
- * @api
-ol.tilegrid.TileGrid.prototype.getMinZoom = function() {
- return this.minZoom;
- * Get the origin for the grid at the given zoom level.
- * @return {ol.Coordinate} Origin.
- * @api
-ol.tilegrid.TileGrid.prototype.getOrigin = function(z) {
- if (this.origin_) {
- return this.origin_;
- } else {
- return this.origins_[z];
- * Get the resolution for the given zoom level.
- * @return {number} Resolution.
- * @api
-ol.tilegrid.TileGrid.prototype.getResolution = function(z) {
- return this.resolutions_[z];
- * Get the list of resolutions for the tile grid.
- * @return {Array.<number>} Resolutions.
- * @api
-ol.tilegrid.TileGrid.prototype.getResolutions = function() {
- return this.resolutions_;
- * @return {ol.TileRange} Tile range.
-ol.tilegrid.TileGrid.prototype.getTileCoordChildTileRange = function(tileCoord, opt_tileRange, opt_extent) {
- if (tileCoord[0] < this.maxZoom) {
- return this.getTileRangeForExtentAndZ(
- tileCoordExtent, tileCoord[0] + 1, opt_tileRange);
- } else {
- return null;
- * @param {ol.TileRange} tileRange Tile range.
-ol.tilegrid.TileGrid.prototype.getTileRangeExtent = function(z, tileRange, opt_extent) {
- var origin = this.getOrigin(z);
- var resolution = this.getResolution(z);
- var tileSize = ol.size.toSize(this.getTileSize(z), this.tmpSize_);
- var minX = origin[0] + tileRange.minX * tileSize[0] * resolution;
- var maxX = origin[0] + (tileRange.maxX + 1) * tileSize[0] * resolution;
- var minY = origin[1] + tileRange.minY * tileSize[1] * resolution;
- var maxY = origin[1] + (tileRange.maxY + 1) * tileSize[1] * resolution;
- * @param {ol.TileRange=} opt_tileRange Temporary tile range object.
-ol.tilegrid.TileGrid.prototype.getTileRangeForExtentAndResolution = function(extent, resolution, opt_tileRange) {
- var tileCoord = ol.tilegrid.TileGrid.tmpTileCoord_;
- this.getTileCoordForXYAndResolution_(
- extent[0], extent[1], resolution, false, tileCoord);
- var minX = tileCoord[1];
- var minY = tileCoord[2];
- extent[2], extent[3], resolution, true, tileCoord);
- return ol.TileRange.createOrUpdate(
- minX, tileCoord[1], minY, tileCoord[2], opt_tileRange);
-ol.tilegrid.TileGrid.prototype.getTileRangeForExtentAndZ = function(extent, z, opt_tileRange) {
- return this.getTileRangeForExtentAndResolution(
- extent, resolution, opt_tileRange);
- * @return {ol.Coordinate} Tile center.
-ol.tilegrid.TileGrid.prototype.getTileCoordCenter = function(tileCoord) {
- var origin = this.getOrigin(tileCoord[0]);
- var resolution = this.getResolution(tileCoord[0]);
- var tileSize = ol.size.toSize(this.getTileSize(tileCoord[0]), this.tmpSize_);
- return [
- origin[0] + (tileCoord[1] + 0.5) * tileSize[0] * resolution,
- origin[1] + (tileCoord[2] + 0.5) * tileSize[1] * resolution
- * Get the extent of a tile coordinate.
- * @param {ol.Extent=} opt_extent Temporary extent object.
- * @api
-ol.tilegrid.TileGrid.prototype.getTileCoordExtent = function(tileCoord, opt_extent) {
- var minX = origin[0] + tileCoord[1] * tileSize[0] * resolution;
- var minY = origin[1] + tileCoord[2] * tileSize[1] * resolution;
- var maxX = minX + tileSize[0] * resolution;
- var maxY = minY + tileSize[1] * resolution;
- * Get the tile coordinate for the given map coordinate and resolution. This
- * method considers that coordinates that intersect tile boundaries should be
- * assigned the higher tile coordinate.
- * @param {ol.TileCoord=} opt_tileCoord Destination ol.TileCoord object.
- * @api
-ol.tilegrid.TileGrid.prototype.getTileCoordForCoordAndResolution = function(coordinate, resolution, opt_tileCoord) {
- return this.getTileCoordForXYAndResolution_(
- coordinate[0], coordinate[1], resolution, false, opt_tileCoord);
- * @param {number} x X.
- * @param {number} y Y.
- * @param {boolean} reverseIntersectionPolicy Instead of letting edge
- * intersections go to the higher tile coordinate, let edge intersections
- * go to the lower tile coordinate.
- * @param {ol.TileCoord=} opt_tileCoord Temporary ol.TileCoord object.
- * @private
-ol.tilegrid.TileGrid.prototype.getTileCoordForXYAndResolution_ = function(
- x, y, resolution, reverseIntersectionPolicy, opt_tileCoord) {
- var z = this.getZForResolution(resolution);
- var scale = resolution / this.getResolution(z);
- var adjustX = reverseIntersectionPolicy ? 0.5 : 0;
- var adjustY = reverseIntersectionPolicy ? 0 : 0.5;
- var xFromOrigin = Math.floor((x - origin[0]) / resolution + adjustX);
- var yFromOrigin = Math.floor((y - origin[1]) / resolution + adjustY);
- var tileCoordX = scale * xFromOrigin / tileSize[0];
- var tileCoordY = scale * yFromOrigin / tileSize[1];
- if (reverseIntersectionPolicy) {
- tileCoordX = Math.ceil(tileCoordX) - 1;
- tileCoordY = Math.ceil(tileCoordY) - 1;
- } else {
- tileCoordX = Math.floor(tileCoordX);
- tileCoordY = Math.floor(tileCoordY);
- return ol.tilecoord.createOrUpdate(z, tileCoordX, tileCoordY, opt_tileCoord);
- * Get a tile coordinate given a map coordinate and zoom level.
- * @param {number} z Zoom level.
- * @api
-ol.tilegrid.TileGrid.prototype.getTileCoordForCoordAndZ = function(coordinate, z, opt_tileCoord) {
- * @return {number} Tile resolution.
-ol.tilegrid.TileGrid.prototype.getTileCoordResolution = function(tileCoord) {
- return this.resolutions_[tileCoord[0]];
- * Get the tile size for a zoom level. The type of the return value matches the
- * `tileSize` or `tileSizes` that the tile grid was configured with. To always
- * get an `ol.Size`, run the result through `ol.size.toSize()`.
- * @return {number|ol.Size} Tile size.
- * @api
-ol.tilegrid.TileGrid.prototype.getTileSize = function(z) {
- if (this.tileSize_) {
- return this.tileSize_;
- } else {
- return this.tileSizes_[z];
- * @return {ol.TileRange} Extent tile range for the specified zoom level.
-ol.tilegrid.TileGrid.prototype.getFullTileRange = function(z) {
- if (!this.fullTileRanges_) {
- return null;
- } else {
- return this.fullTileRanges_[z];
- * @param {number=} opt_direction If 0, the nearest resolution will be used.
- * If 1, the nearest lower resolution will be used. If -1, the nearest
- * higher resolution will be used. Default is 0.
- * @return {number} Z.
- * @api
-ol.tilegrid.TileGrid.prototype.getZForResolution = function(
- resolution, opt_direction) {
- var z = ol.array.linearFindNearest(this.resolutions_, resolution,
- opt_direction || 0);
- return ol.math.clamp(z, this.minZoom, this.maxZoom);
- * @param {!ol.Extent} extent Extent for this tile grid.
- * @private
-ol.tilegrid.TileGrid.prototype.calculateTileRanges_ = function(extent) {
- var length = this.resolutions_.length;
- var fullTileRanges = new Array(length);
- for (var z = this.minZoom; z < length; ++z) {
- fullTileRanges[z] = this.getTileRangeForExtentAndZ(extent, z);
- this.fullTileRanges_ = fullTileRanges;
-goog.provide('ol.tilegrid');
-goog.require('ol.extent.Corner');
-goog.require('ol.proj');
-goog.require('ol.tilegrid.TileGrid');
- * @param {ol.proj.Projection} projection Projection.
- * @return {!ol.tilegrid.TileGrid} Default tile grid for the passed projection.
-ol.tilegrid.getForProjection = function(projection) {
- var tileGrid = projection.getDefaultTileGrid();
- if (!tileGrid) {
- tileGrid = ol.tilegrid.createForProjection(projection);
- projection.setDefaultTileGrid(tileGrid);
- return tileGrid;
- * @param {ol.tilegrid.TileGrid} tileGrid Tile grid.
-ol.tilegrid.wrapX = function(tileGrid, tileCoord, projection) {
- var center = tileGrid.getTileCoordCenter(tileCoord);
- var projectionExtent = ol.tilegrid.extentFromProjection(projection);
- if (!ol.extent.containsCoordinate(projectionExtent, center)) {
- var worldWidth = ol.extent.getWidth(projectionExtent);
- var worldsAway = Math.ceil((projectionExtent[0] - center[0]) / worldWidth);
- center[0] += worldWidth * worldsAway;
- return tileGrid.getTileCoordForCoordAndZ(center, z);
- } else {
- return tileCoord;
- * @param {ol.Extent} extent Extent.
- * @param {number=} opt_maxZoom Maximum zoom level (default is
- * ol.DEFAULT_MAX_ZOOM).
- * @param {number|ol.Size=} opt_tileSize Tile size (default uses
- * ol.DEFAULT_TILE_SIZE).
- * @param {ol.extent.Corner=} opt_corner Extent corner (default is
- * ol.extent.Corner.TOP_LEFT).
- * @return {!ol.tilegrid.TileGrid} TileGrid instance.
-ol.tilegrid.createForExtent = function(extent, opt_maxZoom, opt_tileSize, opt_corner) {
- var corner = opt_corner !== undefined ?
- opt_corner : ol.extent.Corner.TOP_LEFT;
- var resolutions = ol.tilegrid.resolutionsFromExtent(
- extent, opt_maxZoom, opt_tileSize);
- return new ol.tilegrid.TileGrid({
- extent: extent,
- origin: ol.extent.getCorner(extent, corner),
- resolutions: resolutions,
- tileSize: opt_tileSize
- * Creates a tile grid with a standard XYZ tiling scheme.
- * @param {olx.tilegrid.XYZOptions=} opt_options Tile grid options.
- * @return {ol.tilegrid.TileGrid} Tile grid instance.
- * @api
-ol.tilegrid.createXYZ = function(opt_options) {
- var options = /** @type {olx.tilegrid.TileGridOptions} */ ({});
- ol.obj.assign(options, opt_options !== undefined ?
- opt_options : /** @type {olx.tilegrid.XYZOptions} */ ({}));
- if (options.extent === undefined) {
- options.extent = ol.proj.get('EPSG:3857').getExtent();
- options.resolutions = ol.tilegrid.resolutionsFromExtent(
- options.extent, options.maxZoom, options.tileSize);
- delete options.maxZoom;
- return new ol.tilegrid.TileGrid(options);
- * Create a resolutions array from an extent. A zoom factor of 2 is assumed.
- * @return {!Array.<number>} Resolutions array.
-ol.tilegrid.resolutionsFromExtent = function(extent, opt_maxZoom, opt_tileSize) {
- var maxZoom = opt_maxZoom !== undefined ?
- opt_maxZoom : ol.DEFAULT_MAX_ZOOM;
- var height = ol.extent.getHeight(extent);
- var width = ol.extent.getWidth(extent);
- var tileSize = ol.size.toSize(opt_tileSize !== undefined ?
- opt_tileSize : ol.DEFAULT_TILE_SIZE);
- var maxResolution = Math.max(
- width / tileSize[0], height / tileSize[1]);
- var length = maxZoom + 1;
- var resolutions = new Array(length);
- for (var z = 0; z < length; ++z) {
- resolutions[z] = maxResolution / Math.pow(2, z);
- return resolutions;
- * @param {ol.ProjectionLike} projection Projection.
- * @param {ol.Size=} opt_tileSize Tile size (default uses ol.DEFAULT_TILE_SIZE).
- * ol.extent.Corner.BOTTOM_LEFT).
-ol.tilegrid.createForProjection = function(projection, opt_maxZoom, opt_tileSize, opt_corner) {
- var extent = ol.tilegrid.extentFromProjection(projection);
- return ol.tilegrid.createForExtent(
- extent, opt_maxZoom, opt_tileSize, opt_corner);
- * Generate a tile grid extent from a projection. If the projection has an
- * extent, it is used. If not, a global extent is assumed.
- * @return {ol.Extent} Extent.
-ol.tilegrid.extentFromProjection = function(projection) {
- projection = ol.proj.get(projection);
- var extent = projection.getExtent();
- if (!extent) {
- var half = 180 * ol.proj.METERS_PER_UNIT[ol.proj.Units.DEGREES] /
- projection.getMetersPerUnit();
- extent = ol.extent.createOrUpdate(-half, -half, half, half);
- return extent;
-goog.provide('ol.Attribution');
-goog.require('ol.tilegrid');
- * @classdesc
- * An attribution for a layer source.
- * Example:
- * source: new ol.source.OSM({
- * attributions: [
- * new ol.Attribution({
- * html: 'All maps © ' +
- * '<a href="https://www.opencyclemap.org/">OpenCycleMap</a>'
- * ol.source.OSM.ATTRIBUTION
- * @constructor
- * @param {olx.AttributionOptions} options Attribution options.
- * @struct
- * @api
-ol.Attribution = function(options) {
- * @private
- * @type {string}
- this.html_ = options.html;
- * @private
- * @type {Object.<string, Array.<ol.TileRange>>}
- this.tileRanges_ = options.tileRanges ? options.tileRanges : null;
- * Get the attribution markup.
- * @return {string} The attribution HTML.
- * @api
-ol.Attribution.prototype.getHTML = function() {
- return this.html_;
- * @param {Object.<string, ol.TileRange>} tileRanges Tile ranges.
- * @param {!ol.proj.Projection} projection Projection.
- * @return {boolean} Intersects any tile range.
-ol.Attribution.prototype.intersectsAnyTileRange = function(tileRanges, tileGrid, projection) {
- if (!this.tileRanges_) {
- return true;
- var i, ii, tileRange, zKey;
- for (zKey in tileRanges) {
- if (!(zKey in this.tileRanges_)) {
- continue;
- tileRange = tileRanges[zKey];
- var testTileRange;
- for (i = 0, ii = this.tileRanges_[zKey].length; i < ii; ++i) {
- testTileRange = this.tileRanges_[zKey][i];
- if (testTileRange.intersects(tileRange)) {
- return true;
- var extentTileRange = tileGrid.getTileRangeForExtentAndZ(
- ol.tilegrid.extentFromProjection(projection), parseInt(zKey, 10));
- var width = extentTileRange.getWidth();
- if (tileRange.minX < extentTileRange.minX ||
- tileRange.maxX > extentTileRange.maxX) {
- if (testTileRange.intersects(new ol.TileRange(
- ol.math.modulo(tileRange.minX, width),
- ol.math.modulo(tileRange.maxX, width),
- tileRange.minY, tileRange.maxY))) {
- return true;
- if (tileRange.getWidth() > width &&
- testTileRange.intersects(extentTileRange)) {
- return true;
- return false;
-goog.provide('ol.CenterConstraint');
- * @return {ol.CenterConstraintType} The constraint.
-ol.CenterConstraint.createExtent = function(extent) {
- return (
- * @param {ol.Coordinate|undefined} center Center.
- * @return {ol.Coordinate|undefined} Center.
- function(center) {
- if (center) {
- return [
- ol.math.clamp(center[0], extent[0], extent[2]),
- ol.math.clamp(center[1], extent[1], extent[3])
- } else {
- return undefined;
-ol.CenterConstraint.none = function(center) {
- return center;
-goog.provide('ol.CollectionEventType');
- * @enum {string}
-ol.CollectionEventType = {
- * Triggered when an item is added to the collection.
- * @event ol.Collection.Event#add
- * @api
- ADD: 'add',
- * Triggered when an item is removed from the collection.
- * @event ol.Collection.Event#remove
- * @api
- REMOVE: 'remove'
-goog.provide('ol.ObjectEventType');
- * @enum {string}
-ol.ObjectEventType = {
- * Triggered when a property is changed.
- * @event ol.Object.Event#propertychange
- * @api
- PROPERTYCHANGE: 'propertychange'
-goog.provide('ol.events');
- * @param {ol.EventsKey} listenerObj Listener object.
- * @return {ol.EventsListenerFunctionType} Bound listener.
-ol.events.bindListener_ = function(listenerObj) {
- var boundListener = function(evt) {
- var listener = listenerObj.listener;
- var bindTo = listenerObj.bindTo || listenerObj.target;
- if (listenerObj.callOnce) {
- ol.events.unlistenByKey(listenerObj);
- return listener.call(bindTo, evt);
- listenerObj.boundListener = boundListener;
- return boundListener;
- * Finds the matching {@link ol.EventsKey} in the given listener
- * array.
- * @param {!Array<!ol.EventsKey>} listeners Array of listeners.
- * @param {!Function} listener The listener function.
- * @param {Object=} opt_this The `this` value inside the listener.
- * @param {boolean=} opt_setDeleteIndex Set the deleteIndex on the matching
- * listener, for {@link ol.events.unlistenByKey}.
- * @return {ol.EventsKey|undefined} The matching listener object.
- * @private
-ol.events.findListener_ = function(listeners, listener, opt_this,
- opt_setDeleteIndex) {
- var listenerObj;
- for (var i = 0, ii = listeners.length; i < ii; ++i) {
- listenerObj = listeners[i];
- if (listenerObj.listener === listener &&
- listenerObj.bindTo === opt_this) {
- if (opt_setDeleteIndex) {
- listenerObj.deleteIndex = i;
- return listenerObj;
- return undefined;
- * @param {ol.EventTargetLike} target Target.
- * @param {string} type Type.
- * @return {Array.<ol.EventsKey>|undefined} Listeners.
-ol.events.getListeners = function(target, type) {
- var listenerMap = target.ol_lm;
- return listenerMap ? listenerMap[type] : undefined;
- * Get the lookup of listeners. If one does not exist on the target, it is
- * created.
- * @return {!Object.<string, Array.<ol.EventsKey>>} Map of
- * listeners by event type.
- * @private
-ol.events.getListenerMap_ = function(target) {
- if (!listenerMap) {
- listenerMap = target.ol_lm = {};
- return listenerMap;
- * Clean up all listener objects of the given type. All properties on the
- * listener objects will be removed, and if no listeners remain in the listener
- * map, it will be removed from the target.
- * @private
-ol.events.removeListeners_ = function(target, type) {
- var listeners = ol.events.getListeners(target, type);
- if (listeners) {
- target.removeEventListener(type, listeners[i].boundListener);
- ol.obj.clear(listeners[i]);
- listeners.length = 0;
- if (listenerMap) {
- delete listenerMap[type];
- if (Object.keys(listenerMap).length === 0) {
- delete target.ol_lm;
- * Registers an event listener on an event target. Inspired by
- * {@link https://google.github.io/closure-library/api/source/closure/goog/events/events.js.src.html}
- * This function efficiently binds a `listener` to a `this` object, and returns
- * a key for use with {@link ol.events.unlistenByKey}.
- * @param {ol.EventTargetLike} target Event target.
- * @param {string} type Event type.
- * @param {ol.EventsListenerFunctionType} listener Listener.
- * @param {Object=} opt_this Object referenced by the `this` keyword in the
- * listener. Default is the `target`.
- * @param {boolean=} opt_once If true, add the listener as one-off listener.
- * @return {ol.EventsKey} Unique key for the listener.
-ol.events.listen = function(target, type, listener, opt_this, opt_once) {
- var listenerMap = ol.events.getListenerMap_(target);
- var listeners = listenerMap[type];
- if (!listeners) {
- listeners = listenerMap[type] = [];
- var listenerObj = ol.events.findListener_(listeners, listener, opt_this,
- false);
- if (listenerObj) {
- if (!opt_once) {
- // Turn one-off listener into a permanent one.
- listenerObj.callOnce = false;
- } else {
- listenerObj = /** @type {ol.EventsKey} */ ({
- bindTo: opt_this,
- callOnce: !!opt_once,
- listener: listener,
- target: target,
- type: type
- target.addEventListener(type, ol.events.bindListener_(listenerObj));
- listeners.push(listenerObj);
- * Registers a one-off event listener on an event target. Inspired by
- * This function efficiently binds a `listener` as self-unregistering listener
- * to a `this` object, and returns a key for use with
- * {@link ol.events.unlistenByKey} in case the listener needs to be unregistered
- * before it is called.
- * When {@link ol.events.listen} is called with the same arguments after this
- * function, the self-unregistering listener will be turned into a permanent
- * listener.
- * @return {ol.EventsKey} Key for unlistenByKey.
-ol.events.listenOnce = function(target, type, listener, opt_this) {
- return ol.events.listen(target, type, listener, opt_this, true);
- * Unregisters an event listener on an event target. Inspired by
- * To return a listener, this function needs to be called with the exact same
- * arguments that were used for a previous {@link ol.events.listen} call.
-ol.events.unlisten = function(target, type, listener, opt_this) {
- if (listeners) {
- true);
- * Unregisters event listeners on an event target. Inspired by
- * The argument passed to this function is the key returned from
- * {@link ol.events.listen} or {@link ol.events.listenOnce}.
- * @param {ol.EventsKey} key The key.
-ol.events.unlistenByKey = function(key) {
- if (key && key.target) {
- key.target.removeEventListener(key.type, key.boundListener);
- var listeners = ol.events.getListeners(key.target, key.type);
- if (listeners) {
- var i = 'deleteIndex' in key ? key.deleteIndex : listeners.indexOf(key);
- if (i !== -1) {
- listeners.splice(i, 1);
- if (listeners.length === 0) {
- ol.events.removeListeners_(key.target, key.type);
- ol.obj.clear(key);
- * Unregisters all event listeners on an event target. Inspired by
-ol.events.unlistenAll = function(target) {
- for (var type in listenerMap) {
- ol.events.removeListeners_(target, type);
-goog.provide('ol.Disposable');
- * Objects that need to clean up after themselves.
- * @constructor
-ol.Disposable = function() {};
- * The object has already been disposed.
- * @type {boolean}
- * @private
-ol.Disposable.prototype.disposed_ = false;
- * Clean up.
-ol.Disposable.prototype.dispose = function() {
- if (!this.disposed_) {
- this.disposed_ = true;
- this.disposeInternal();
- * Extension point for disposable objects.
- * @protected
-ol.Disposable.prototype.disposeInternal = ol.nullFunction;
-goog.provide('ol.events.Event');
- * @classdesc
- * Stripped down implementation of the W3C DOM Level 2 Event interface.
- * @see {@link https://www.w3.org/TR/DOM-Level-2-Events/events.html#Events-interface}
- * This implementation only provides `type` and `target` properties, and
- * `stopPropagation` and `preventDefault` methods. It is meant as base class
- * for higher level events defined in the library, and works with
- * {@link ol.events.EventTarget}.
- * @constructor
- * @implements {oli.events.Event}
-ol.events.Event = function(type) {
- * @type {boolean}
- this.propagationStopped;
- * The event type.
- * @type {string}
- * @api
- this.type = type;
- * The event target.
- * @type {Object}
- * @api
- this.target = null;
- * Stop event propagation.
- * @function
- * @override
- * @api
-ol.events.Event.prototype.preventDefault =
- * @function
- * @override
- * @api
-ol.events.Event.prototype.stopPropagation = function() {
- this.propagationStopped = true;
- * @param {Event|ol.events.Event} evt Event
-ol.events.Event.stopPropagation = function(evt) {
- evt.stopPropagation();
-ol.events.Event.preventDefault = function(evt) {
- evt.preventDefault();
-goog.provide('ol.events.EventTarget');
-goog.require('ol.Disposable');
-goog.require('ol.events');
-goog.require('ol.events.Event');
- * @classdesc
- * A simplified implementation of the W3C DOM Level 2 EventTarget interface.
- * @see {@link https://www.w3.org/TR/2000/REC-DOM-Level-2-Events-20001113/events.html#Events-EventTarget}
- * There are two important simplifications compared to the specification:
- * 1. The handling of `useCapture` in `addEventListener` and
- * `removeEventListener`. There is no real capture model.
- * 2. The handling of `stopPropagation` and `preventDefault` on `dispatchEvent`.
- * There is no event target hierarchy. When a listener calls
- * `stopPropagation` or `preventDefault` on an event object, it means that no
- * more listeners after this one will be called. Same as when the listener
- * returns false.
- * @constructor
- * @extends {ol.Disposable}
-ol.events.EventTarget = function() {
- ol.Disposable.call(this);
- * @private
- * @type {!Object.<string, number>}
- this.pendingRemovals_ = {};
- * @private
- this.dispatching_ = {};
- * @private
- * @type {!Object.<string, Array.<ol.EventsListenerFunctionType>>}
- this.listeners_ = {};
-ol.inherits(ol.events.EventTarget, ol.Disposable);
-ol.events.EventTarget.prototype.addEventListener = function(type, listener) {
- var listeners = this.listeners_[type];
- if (!listeners) {
- listeners = this.listeners_[type] = [];
- if (listeners.indexOf(listener) === -1) {
- listeners.push(listener);
- * @param {{type: string,
- * target: (EventTarget|ol.events.EventTarget|undefined)}|ol.events.Event|
- * string} event Event or event type.
- * @return {boolean|undefined} `false` if anyone called preventDefault on the
- * event object or if any of the listeners returned false.
-ol.events.EventTarget.prototype.dispatchEvent = function(event) {
- var evt = typeof event === 'string' ? new ol.events.Event(event) : event;
- var type = evt.type;
- evt.target = this;
- var propagate;
- if (listeners) {
- if (!(type in this.dispatching_)) {
- this.dispatching_[type] = 0;
- this.pendingRemovals_[type] = 0;
- ++this.dispatching_[type];
- if (listeners[i].call(this, evt) === false || evt.propagationStopped) {
- propagate = false;
- break;
- --this.dispatching_[type];
- if (this.dispatching_[type] === 0) {
- var pendingRemovals = this.pendingRemovals_[type];
- delete this.pendingRemovals_[type];
- while (pendingRemovals--) {
- this.removeEventListener(type, ol.nullFunction);
- delete this.dispatching_[type];
- return propagate;
- * @inheritDoc
-ol.events.EventTarget.prototype.disposeInternal = function() {
- ol.events.unlistenAll(this);
- * Get the listeners for a specified event type. Listeners are returned in the
- * order that they will be called in.
- * @return {Array.<ol.EventsListenerFunctionType>} Listeners.
-ol.events.EventTarget.prototype.getListeners = function(type) {
- return this.listeners_[type];
- * @param {string=} opt_type Type. If not provided,
- * `true` will be returned if this EventTarget has any listeners.
- * @return {boolean} Has listeners.
-ol.events.EventTarget.prototype.hasListener = function(opt_type) {
- return opt_type ?
- opt_type in this.listeners_ :
- Object.keys(this.listeners_).length > 0;
-ol.events.EventTarget.prototype.removeEventListener = function(type, listener) {
- if (listeners) {
- var index = listeners.indexOf(listener);
- if (type in this.pendingRemovals_) {
- // make listener a no-op, and remove later in #dispatchEvent()
- listeners[index] = ol.nullFunction;
- ++this.pendingRemovals_[type];
- } else {
- listeners.splice(index, 1);
- delete this.listeners_[type];
-goog.provide('ol.events.EventType');
- * @enum {string}
- * @const
-ol.events.EventType = {
- * Generic change event. Triggered when the revision counter is increased.
- * @event ol.events.Event#change
- * @api
- CHANGE: 'change',
- CLICK: 'click',
- DBLCLICK: 'dblclick',
- DRAGENTER: 'dragenter',
- DRAGOVER: 'dragover',
- DROP: 'drop',
- ERROR: 'error',
- KEYDOWN: 'keydown',
- KEYPRESS: 'keypress',
- LOAD: 'load',
- MOUSEDOWN: 'mousedown',
- MOUSEMOVE: 'mousemove',
- MOUSEOUT: 'mouseout',
- MOUSEUP: 'mouseup',
- MOUSEWHEEL: 'mousewheel',
- MSPOINTERDOWN: 'MSPointerDown',
- RESIZE: 'resize',
- TOUCHSTART: 'touchstart',
- TOUCHMOVE: 'touchmove',
- TOUCHEND: 'touchend',
- WHEEL: 'wheel'
-goog.provide('ol.Observable');
-goog.require('ol.events.EventTarget');
-goog.require('ol.events.EventType');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * An event target providing convenient methods for listener registration
- * and unregistration. A generic `change` event is always available through
- * {@link ol.Observable#changed}.
- * @constructor
- * @extends {ol.events.EventTarget}
- * @fires ol.events.Event
- * @struct
- * @api
-ol.Observable = function() {
- ol.events.EventTarget.call(this);
- * @private
- * @type {number}
- this.revision_ = 0;
-ol.inherits(ol.Observable, ol.events.EventTarget);
- * Removes an event listener using the key returned by `on()` or `once()`.
- * @param {ol.EventsKey|Array.<ol.EventsKey>} key The key returned by `on()`
- * or `once()` (or an array of keys).
- * @api
-ol.Observable.unByKey = function(key) {
- if (Array.isArray(key)) {
- for (var i = 0, ii = key.length; i < ii; ++i) {
- ol.events.unlistenByKey(key[i]);
- } else {
- ol.events.unlistenByKey(/** @type {ol.EventsKey} */ (key));
- * Increases the revision counter and dispatches a 'change' event.
- * @api
-ol.Observable.prototype.changed = function() {
- ++this.revision_;
- this.dispatchEvent(ol.events.EventType.CHANGE);
- * Dispatches an event and calls all listeners listening for events
- * of this type. The event parameter can either be a string or an
- * Object with a `type` property.
- * string} event Event object.
- * @function
- * @api
-ol.Observable.prototype.dispatchEvent;
- * Get the version number for this object. Each time the object is modified,
- * its version number will be incremented.
- * @return {number} Revision.
- * @api
-ol.Observable.prototype.getRevision = function() {
- return this.revision_;
- * Listen for a certain type of event.
- * @param {string|Array.<string>} type The event type or array of event types.
- * @param {function(?): ?} listener The listener function.
- * @param {Object=} opt_this The object to use as `this` in `listener`.
- * @return {ol.EventsKey|Array.<ol.EventsKey>} Unique key for the listener. If
- * called with an array of event types as the first argument, the return
- * will be an array of keys.
- * @api
-ol.Observable.prototype.on = function(type, listener, opt_this) {
- if (Array.isArray(type)) {
- var len = type.length;
- var keys = new Array(len);
- for (var i = 0; i < len; ++i) {
- keys[i] = ol.events.listen(this, type[i], listener, opt_this);
- return keys;
- } else {
- this, /** @type {string} */ (type), listener, opt_this);
- * Listen once for a certain type of event.
- * @api
-ol.Observable.prototype.once = function(type, listener, opt_this) {
- keys[i] = ol.events.listenOnce(this, type[i], listener, opt_this);
- return keys;
- } else {
- return ol.events.listenOnce(
- * Unlisten for a certain type of event.
- * @param {Object=} opt_this The object which was used as `this` by the
- * `listener`.
- * @api
-ol.Observable.prototype.un = function(type, listener, opt_this) {
- for (var i = 0, ii = type.length; i < ii; ++i) {
- ol.events.unlisten(this, type[i], listener, opt_this);
- return;
- } else {
- ol.events.unlisten(this, /** @type {string} */ (type), listener, opt_this);
-goog.provide('ol.Object');
-goog.require('ol.ObjectEventType');
-goog.require('ol.Observable');
- * @classdesc
- * Most non-trivial classes inherit from this.
- * This extends {@link ol.Observable} with observable properties, where each
- * property is observable as well as the object as a whole.
- * Classes that inherit from this have pre-defined properties, to which you can
- * add your owns. The pre-defined properties are listed in this documentation as
- * 'Observable Properties', and have their own accessors; for example,
- * {@link ol.Map} has a `target` property, accessed with `getTarget()` and
- * changed with `setTarget()`. Not all properties are however settable. There
- * are also general-purpose accessors `get()` and `set()`. For example,
- * `get('target')` is equivalent to `getTarget()`.
- * The `set` accessors trigger a change event, and you can monitor this by
- * registering a listener. For example, {@link ol.View} has a `center`
- * property, so `view.on('change:center', function(evt) {...});` would call the
- * function whenever the value of the center property changes. Within the
- * function, `evt.target` would be the view, so `evt.target.getCenter()` would
- * return the new center.
- * You can add your own observable properties with
- * `object.set('prop', 'value')`, and retrieve that with `object.get('prop')`.
- * You can listen for changes on that property value with
- * `object.on('change:prop', listener)`. You can get a list of all
- * properties with {@link ol.Object#getProperties object.getProperties()}.
- * Note that the observable properties are separate from standard JS properties.
- * You can, for example, give your map object a title with
- * `map.title='New title'` and with `map.set('title', 'Another title')`. The
- * first will be a `hasOwnProperty`; the second will appear in
- * `getProperties()`. Only the second is observable.
- * Properties can be deleted by using the unset method. E.g.
- * object.unset('foo').
- * @constructor
- * @extends {ol.Observable}
- * @param {Object.<string, *>=} opt_values An object with key-value pairs.
- * @fires ol.Object.Event
- * @api
-ol.Object = function(opt_values) {
- ol.Observable.call(this);
- // Call ol.getUid to ensure that the order of objects' ids is the same as
- // the order in which they were created. This also helps to ensure that
- // object properties are always added in the same order, which helps many
- // JavaScript engines generate faster code.
- ol.getUid(this);
- * @private
- * @type {!Object.<string, *>}
- this.values_ = {};
- if (opt_values !== undefined) {
- this.setProperties(opt_values);
-ol.inherits(ol.Object, ol.Observable);
- * @private
- * @type {Object.<string, string>}
-ol.Object.changeEventTypeCache_ = {};
- * @param {string} key Key name.
- * @return {string} Change name.
-ol.Object.getChangeEventType = function(key) {
- return ol.Object.changeEventTypeCache_.hasOwnProperty(key) ?
- ol.Object.changeEventTypeCache_[key] :
- (ol.Object.changeEventTypeCache_[key] = 'change:' + key);
- * Gets a value.
- * @return {*} Value.
- * @api
-ol.Object.prototype.get = function(key) {
- var value;
- if (this.values_.hasOwnProperty(key)) {
- value = this.values_[key];
- return value;
- * Get a list of object property names.
- * @return {Array.<string>} List of property names.
- * @api
-ol.Object.prototype.getKeys = function() {
- return Object.keys(this.values_);
- * Get an object of all property names and values.
- * @return {Object.<string, *>} Object.
- * @api
-ol.Object.prototype.getProperties = function() {
- return ol.obj.assign({}, this.values_);
- * @param {*} oldValue Old value.
-ol.Object.prototype.notify = function(key, oldValue) {
- var eventType;
- eventType = ol.Object.getChangeEventType(key);
- this.dispatchEvent(new ol.Object.Event(eventType, key, oldValue));
- eventType = ol.ObjectEventType.PROPERTYCHANGE;
- * Sets a value.
- * @param {*} value Value.
- * @param {boolean=} opt_silent Update without triggering an event.
- * @api
-ol.Object.prototype.set = function(key, value, opt_silent) {
- if (opt_silent) {
- this.values_[key] = value;
- } else {
- var oldValue = this.values_[key];
- if (oldValue !== value) {
- this.notify(key, oldValue);
- * Sets a collection of key-value pairs. Note that this changes any existing
- * properties and adds new ones (it does not remove any existing properties).
- * @param {Object.<string, *>} values Values.
- * @api
-ol.Object.prototype.setProperties = function(values, opt_silent) {
- var key;
- for (key in values) {
- this.set(key, values[key], opt_silent);
- * Unsets a property.
- * @param {boolean=} opt_silent Unset without triggering an event.
- * @api
-ol.Object.prototype.unset = function(key, opt_silent) {
- if (key in this.values_) {
- delete this.values_[key];
- if (!opt_silent) {
- * @classdesc
- * Events emitted by {@link ol.Object} instances are instances of this type.
- * @param {string} type The event type.
- * @param {string} key The property name.
- * @param {*} oldValue The old value for `key`.
- * @extends {ol.events.Event}
- * @implements {oli.Object.Event}
- * @constructor
-ol.Object.Event = function(type, key, oldValue) {
- ol.events.Event.call(this, type);
- * The name of the property whose value is changing.
- * @type {string}
- * @api
- this.key = key;
- * The old value. To get the new value use `e.target.get(e.key)` where
- * `e` is the event object.
- * @type {*}
- * @api
- this.oldValue = oldValue;
-ol.inherits(ol.Object.Event, ol.events.Event);
- * An implementation of Google Maps' MVCArray.
- * @see https://developers.google.com/maps/documentation/javascript/reference
-goog.provide('ol.Collection');
-goog.require('ol.AssertionError');
-goog.require('ol.CollectionEventType');
-goog.require('ol.Object');
- * @classdesc
- * An expanded version of standard JS Array, adding convenience methods for
- * manipulation. Add and remove changes to the Collection trigger a Collection
- * event. Note that this does not cover changes to the objects _within_ the
- * Collection; they trigger events on the appropriate object, not on the
- * Collection as a whole.
- * @constructor
- * @extends {ol.Object}
- * @fires ol.Collection.Event
- * @param {!Array.<T>=} opt_array Array.
- * @param {olx.CollectionOptions=} opt_options Collection options.
- * @template T
- * @api
-ol.Collection = function(opt_array, opt_options) {
- ol.Object.call(this);
- var options = opt_options || {};
- * @private
- * @type {boolean}
- this.unique_ = !!options.unique;
- * @private
- * @type {!Array.<T>}
- this.array_ = opt_array ? opt_array : [];
- if (this.unique_) {
- for (var i = 0, ii = this.array_.length; i < ii; ++i) {
- this.assertUnique_(this.array_[i], i);
- this.updateLength_();
-ol.inherits(ol.Collection, ol.Object);
- * Remove all elements from the collection.
- * @api
-ol.Collection.prototype.clear = function() {
- while (this.getLength() > 0) {
- this.pop();
- * Add elements to the collection. This pushes each item in the provided array
- * to the end of the collection.
- * @param {!Array.<T>} arr Array.
- * @return {ol.Collection.<T>} This collection.
- * @api
-ol.Collection.prototype.extend = function(arr) {
- var i, ii;
- for (i = 0, ii = arr.length; i < ii; ++i) {
- this.push(arr[i]);
- return this;
- * Iterate over each element, calling the provided callback.
- * @param {function(this: S, T, number, Array.<T>): *} f The function to call
- * for every element. This function takes 3 arguments (the element, the
- * index and the array). The return value is ignored.
- * @param {S=} opt_this The object to use as `this` in `f`.
- * @template S
- * @api
-ol.Collection.prototype.forEach = function(f, opt_this) {
- this.array_.forEach(f, opt_this);
- * Get a reference to the underlying Array object. Warning: if the array
- * is mutated, no events will be dispatched by the collection, and the
- * collection's "length" property won't be in sync with the actual length
- * of the array.
- * @return {!Array.<T>} Array.
- * @api
-ol.Collection.prototype.getArray = function() {
- return this.array_;
- * Get the element at the provided index.
- * @param {number} index Index.
- * @return {T} Element.
- * @api
-ol.Collection.prototype.item = function(index) {
- return this.array_[index];
- * Get the length of this collection.
- * @return {number} The length of the array.
- * @observable
- * @api
-ol.Collection.prototype.getLength = function() {
- return /** @type {number} */ (this.get(ol.Collection.Property_.LENGTH));
- * Insert an element at the provided index.
- * @param {T} elem Element.
- * @api
-ol.Collection.prototype.insertAt = function(index, elem) {
- this.assertUnique_(elem);
- this.array_.splice(index, 0, elem);
- new ol.Collection.Event(ol.CollectionEventType.ADD, elem));
- * Remove the last element of the collection and return it.
- * Return `undefined` if the collection is empty.
- * @return {T|undefined} Element.
- * @api
-ol.Collection.prototype.pop = function() {
- return this.removeAt(this.getLength() - 1);
- * Insert the provided element at the end of the collection.
- * @return {number} New length of the collection.
- * @api
-ol.Collection.prototype.push = function(elem) {
- var n = this.getLength();
- this.insertAt(n, elem);
- return this.getLength();
- * Remove the first occurrence of an element from the collection.
- * @return {T|undefined} The removed element or undefined if none found.
- * @api
-ol.Collection.prototype.remove = function(elem) {
- var arr = this.array_;
- var i, ii;
- if (arr[i] === elem) {
- return this.removeAt(i);
- return undefined;
- * Remove the element at the provided index and return it.
- * Return `undefined` if the collection does not contain this index.
- * @return {T|undefined} Value.
- * @api
-ol.Collection.prototype.removeAt = function(index) {
- var prev = this.array_[index];
- this.array_.splice(index, 1);
- new ol.Collection.Event(ol.CollectionEventType.REMOVE, prev));
- return prev;
- * Set the element at the provided index.
- * @api
-ol.Collection.prototype.setAt = function(index, elem) {
- if (index < n) {
- this.assertUnique_(elem, index);
- this.array_[index] = elem;
- } else {
- var j;
- for (j = n; j < index; ++j) {
- this.insertAt(j, undefined);
- this.insertAt(index, elem);
- * @private
-ol.Collection.prototype.updateLength_ = function() {
- this.set(ol.Collection.Property_.LENGTH, this.array_.length);
- * @private
- * @param {number=} opt_except Optional index to ignore.
-ol.Collection.prototype.assertUnique_ = function(elem, opt_except) {
- if (this.array_[i] === elem && i !== opt_except) {
- throw new ol.AssertionError(58);
- * @enum {string}
- * @private
-ol.Collection.Property_ = {
- LENGTH: 'length'
- * @classdesc
- * Events emitted by {@link ol.Collection} instances are instances of this
- * type.
- * @constructor
- * @implements {oli.Collection.Event}
- * @param {ol.CollectionEventType} type Type.
- * @param {*=} opt_element Element.
-ol.Collection.Event = function(type, opt_element) {
- * The element that is added to or removed from the collection.
- * @type {*}
- * @api
- this.element = opt_element;
-ol.inherits(ol.Collection.Event, ol.events.Event);
-goog.provide('ol.color');
-goog.require('ol.asserts');
-goog.require('ol.math');
- * This RegExp matches # followed by 3 or 6 hex digits.
- * @const
- * @type {RegExp}
- * @private
-ol.color.HEX_COLOR_RE_ = /^#(?:[0-9a-f]{3}){1,2}$/i;
- * Regular expression for matching potential named color style strings.
- * @const
- * @type {RegExp}
- * @private
-ol.color.NAMED_COLOR_RE_ = /^([a-z]*)$/i;
- * Return the color as an array. This function maintains a cache of calculated
- * arrays which means the result should not be modified.
- * @param {ol.Color|string} color Color.
- * @return {ol.Color} Color.
- * @api
-ol.color.asArray = function(color) {
- if (Array.isArray(color)) {
- return color;
- } else {
- return ol.color.fromString(/** @type {string} */ (color));
- * Return the color as an rgba string.
- * @return {string} Rgba string.
- * @api
-ol.color.asString = function(color) {
- if (typeof color === 'string') {
- return color;
- } else {
- return ol.color.toString(color);
- * Return named color as an rgba string.
- * @param {string} color Named color.
- * @return {string} Rgb string.
-ol.color.fromNamed = function(color) {
- var el = document.createElement('div');
- el.style.color = color;
- document.body.appendChild(el);
- var rgb = getComputedStyle(el).color;
- document.body.removeChild(el);
- return rgb;
- * @param {string} s String.
-ol.color.fromString = (
- function() {
- // We maintain a small cache of parsed strings. To provide cheap LRU-like
- // semantics, whenever the cache grows too large we simply delete an
- // arbitrary 25% of the entries.
- * @const
- * @type {number}
- var MAX_CACHE_SIZE = 1024;
- * @type {Object.<string, ol.Color>}
- var cache = {};
- * @type {number}
- var cacheSize = 0;
- return (
- function(s) {
- var color;
- if (cache.hasOwnProperty(s)) {
- color = cache[s];
- } else {
- if (cacheSize >= MAX_CACHE_SIZE) {
- var i = 0;
- var key;
- for (key in cache) {
- if ((i++ & 3) === 0) {
- delete cache[key];
- --cacheSize;
- color = ol.color.fromStringInternal_(s);
- cache[s] = color;
- ++cacheSize;
- return color;
- * @private
-ol.color.fromStringInternal_ = function(s) {
- var r, g, b, a, color, parts;
- if (ol.color.NAMED_COLOR_RE_.exec(s)) {
- s = ol.color.fromNamed(s);
- if (ol.color.HEX_COLOR_RE_.exec(s)) { // hex
- var n = s.length - 1; // number of hex digits
- ol.asserts.assert(n == 3 || n == 6, 54); // Hex color should have 3 or 6 digits
- var d = n == 3 ? 1 : 2; // number of digits per channel
- r = parseInt(s.substr(1 + 0 * d, d), 16);
- g = parseInt(s.substr(1 + 1 * d, d), 16);
- b = parseInt(s.substr(1 + 2 * d, d), 16);
- if (d == 1) {
- r = (r << 4) + r;
- g = (g << 4) + g;
- b = (b << 4) + b;
- a = 1;
- color = [r, g, b, a];
- } else if (s.indexOf('rgba(') == 0) { // rgba()
- parts = s.slice(5, -1).split(',').map(Number);
- color = ol.color.normalize(parts);
- } else if (s.indexOf('rgb(') == 0) { // rgb()
- parts = s.slice(4, -1).split(',').map(Number);
- parts.push(1);
- } else {
- ol.asserts.assert(false, 14); // Invalid color
- return /** @type {ol.Color} */ (color);
- * @param {ol.Color} color Color.
- * @param {ol.Color=} opt_color Color.
- * @return {ol.Color} Clamped color.
-ol.color.normalize = function(color, opt_color) {
- var result = opt_color || [];
- result[0] = ol.math.clamp((color[0] + 0.5) | 0, 0, 255);
- result[1] = ol.math.clamp((color[1] + 0.5) | 0, 0, 255);
- result[2] = ol.math.clamp((color[2] + 0.5) | 0, 0, 255);
- result[3] = ol.math.clamp(color[3], 0, 1);
- return result;
- * @return {string} String.
-ol.color.toString = function(color) {
- var r = color[0];
- if (r != (r | 0)) {
- r = (r + 0.5) | 0;
- var g = color[1];
- if (g != (g | 0)) {
- g = (g + 0.5) | 0;
- var b = color[2];
- if (b != (b | 0)) {
- b = (b + 0.5) | 0;
- var a = color[3] === undefined ? 1 : color[3];
- return 'rgba(' + r + ',' + g + ',' + b + ',' + a + ')';
-goog.provide('ol.colorlike');
-goog.require('ol.color');
- * @param {ol.Color|ol.ColorLike} color Color.
- * @return {ol.ColorLike} The color as an ol.ColorLike
- * @api
-ol.colorlike.asColorLike = function(color) {
- if (ol.colorlike.isColorLike(color)) {
- return /** @type {string|CanvasPattern|CanvasGradient} */ (color);
- } else {
- return ol.color.asString(/** @type {ol.Color} */ (color));
- * @param {?} color The value that is potentially an ol.ColorLike
- * @return {boolean} Whether the color is an ol.ColorLike
-ol.colorlike.isColorLike = function(color) {
- return (
- typeof color === 'string' ||
- color instanceof CanvasPattern ||
- color instanceof CanvasGradient
-goog.provide('ol.Constraints');
- * @constructor
- * @param {ol.CenterConstraintType} centerConstraint Center constraint.
- * @param {ol.ResolutionConstraintType} resolutionConstraint
- * Resolution constraint.
- * @param {ol.RotationConstraintType} rotationConstraint
- * Rotation constraint.
-ol.Constraints = function(centerConstraint, resolutionConstraint, rotationConstraint) {
- * @type {ol.CenterConstraintType}
- this.center = centerConstraint;
- * @type {ol.ResolutionConstraintType}
- this.resolution = resolutionConstraint;
- * @type {ol.RotationConstraintType}
- this.rotation = rotationConstraint;
-goog.provide('ol.dom');
- * Create an html canvas element and returns its 2d context.
- * @param {number=} opt_width Canvas width.
- * @param {number=} opt_height Canvas height.
- * @return {CanvasRenderingContext2D} The context.
-ol.dom.createCanvasContext2D = function(opt_width, opt_height) {
- var canvas = document.createElement('CANVAS');
- if (opt_width) {
- canvas.width = opt_width;
- if (opt_height) {
- canvas.height = opt_height;
- return canvas.getContext('2d');
- * Get the current computed width for the given element including margin,
- * padding and border.
- * Equivalent to jQuery's `$(el).outerWidth(true)`.
- * @param {!Element} element Element.
- * @return {number} The width.
-ol.dom.outerWidth = function(element) {
- var width = element.offsetWidth;
- var style = getComputedStyle(element);
- width += parseInt(style.marginLeft, 10) + parseInt(style.marginRight, 10);
- return width;
- * Get the current computed height for the given element including margin,
- * Equivalent to jQuery's `$(el).outerHeight(true)`.
- * @return {number} The height.
-ol.dom.outerHeight = function(element) {
- var height = element.offsetHeight;
- height += parseInt(style.marginTop, 10) + parseInt(style.marginBottom, 10);
- return height;
- * @param {Node} newNode Node to replace old node
- * @param {Node} oldNode The node to be replaced
-ol.dom.replaceNode = function(newNode, oldNode) {
- var parent = oldNode.parentNode;
- if (parent) {
- parent.replaceChild(newNode, oldNode);
- * @param {Node} node The node to remove.
- * @returns {Node} The node that was removed or null.
-ol.dom.removeNode = function(node) {
- return node && node.parentNode ? node.parentNode.removeChild(node) : null;
- * @param {Node} node The node to remove the children from.
-ol.dom.removeChildren = function(node) {
- while (node.lastChild) {
- node.removeChild(node.lastChild);
-goog.provide('ol.MapEventType');
- * @enum {string}
-ol.MapEventType = {
- * Triggered after a map frame is rendered.
- * @event ol.MapEvent#postrender
- * @api
- POSTRENDER: 'postrender',
- * Triggered after the map is moved.
- * @event ol.MapEvent#moveend
- * @api
- MOVEEND: 'moveend'
-goog.provide('ol.control.Control');
-goog.require('ol.MapEventType');
-goog.require('ol.dom');
- * @classdesc
- * A control is a visible widget with a DOM element in a fixed position on the
- * screen. They can involve user input (buttons), or be informational only;
- * the position is determined using CSS. By default these are placed in the
- * container with CSS class name `ol-overlaycontainer-stopevent`, but can use
- * any outside DOM element.
- * This is the base class for controls. You can use it for simple custom
- * controls by creating the element with listeners, creating an instance:
- * ```js
- * var myControl = new ol.control.Control({element: myElement});
- * and then adding this to the map.
- * The main advantage of having this as a control rather than a simple separate
- * DOM element is that preventing propagation is handled for you. Controls
- * will also be `ol.Object`s in a `ol.Collection`, so you can use their
- * methods.
- * You can also extend this base for your own control class. See
- * examples/custom-controls for an example of how to do this.
- * @constructor
- * @implements {oli.control.Control}
- * @param {olx.control.ControlOptions} options Control options.
- * @api
-ol.control.Control = function(options) {
- * @protected
- * @type {Element}
- this.element = options.element ? options.element : null;
- * @private
- * @type {Element}
- this.target_ = null;
- * @private
- * @type {ol.Map}
- this.map_ = null;
- * @protected
- * @type {!Array.<ol.EventsKey>}
- this.listenerKeys = [];
- * @type {function(ol.MapEvent)}
- this.render = options.render ? options.render : ol.nullFunction;
- if (options.target) {
- this.setTarget(options.target);
-ol.inherits(ol.control.Control, ol.Object);
- * @inheritDoc
-ol.control.Control.prototype.disposeInternal = function() {
- ol.dom.removeNode(this.element);
- ol.Object.prototype.disposeInternal.call(this);
- * Get the map associated with this control.
- * @return {ol.Map} Map.
- * @api
-ol.control.Control.prototype.getMap = function() {
- return this.map_;
- * Remove the control from its current map and attach it to the new map.
- * Subclasses may set up event handlers to get notified about changes to
- * the map here.
- * @param {ol.Map} map Map.
- * @override
- * @api
-ol.control.Control.prototype.setMap = function(map) {
- if (this.map_) {
- for (var i = 0, ii = this.listenerKeys.length; i < ii; ++i) {
- ol.events.unlistenByKey(this.listenerKeys[i]);
- this.listenerKeys.length = 0;
- this.map_ = map;
- if (this.map_) {
- var target = this.target_ ?
- this.target_ : map.getOverlayContainerStopEvent();
- target.appendChild(this.element);
- if (this.render !== ol.nullFunction) {
- this.listenerKeys.push(ol.events.listen(map,
- ol.MapEventType.POSTRENDER, this.render, this));
- map.render();
- * This function is used to set a target element for the control. It has no
- * effect if it is called after the control has been added to the map (i.e.
- * after `setMap` is called on the control). If no `target` is set in the
- * options passed to the control constructor and if `setTarget` is not called
- * then the control is added to the map's overlay container.
- * @param {Element|string} target Target.
- * @api
-ol.control.Control.prototype.setTarget = function(target) {
- this.target_ = typeof target === 'string' ?
- document.getElementById(target) :
- target;
-goog.provide('ol.css');
- * The CSS class for hidden feature.
- * @const
- * @type {string}
-ol.css.CLASS_HIDDEN = 'ol-hidden';
- * The CSS class that we'll give the DOM elements to have them unselectable.
- * @const
- * @type {string}
-ol.css.CLASS_UNSELECTABLE = 'ol-unselectable';
- * The CSS class for unsupported feature.
- * @const
- * @type {string}
-ol.css.CLASS_UNSUPPORTED = 'ol-unsupported';
- * The CSS class for controls.
- * @const
- * @type {string}
-ol.css.CLASS_CONTROL = 'ol-control';
-// FIXME handle date line wrap
-goog.provide('ol.control.Attribution');
-goog.require('ol.control.Control');
-goog.require('ol.css');
-goog.require('ol.obj');
- * @classdesc
- * Control to show all the attributions associated with the layer sources
- * in the map. This control is one of the default controls included in maps.
- * By default it will show in the bottom right portion of the map, but this can
- * be changed by using a css selector for `.ol-attribution`.
- * @constructor
- * @extends {ol.control.Control}
- * @param {olx.control.AttributionOptions=} opt_options Attribution options.
- * @api
-ol.control.Attribution = function(opt_options) {
- var options = opt_options ? opt_options : {};
- * @private
- * @type {Element}
- this.ulElement_ = document.createElement('UL');
- * @private
- * @type {Element}
- this.logoLi_ = document.createElement('LI');
- this.ulElement_.appendChild(this.logoLi_);
- this.logoLi_.style.display = 'none';
- * @private
- * @type {boolean}
- this.collapsed_ = options.collapsed !== undefined ? options.collapsed : true;
- * @private
- * @type {boolean}
- this.collapsible_ = options.collapsible !== undefined ?
- options.collapsible : true;
- if (!this.collapsible_) {
- this.collapsed_ = false;
- var className = options.className !== undefined ? options.className : 'ol-attribution';
- var tipLabel = options.tipLabel !== undefined ? options.tipLabel : 'Attributions';
- var collapseLabel = options.collapseLabel !== undefined ? options.collapseLabel : '\u00BB';
- if (typeof collapseLabel === 'string') {
- * @private
- * @type {Node}
- this.collapseLabel_ = document.createElement('span');
- this.collapseLabel_.textContent = collapseLabel;
- } else {
- this.collapseLabel_ = collapseLabel;
- var label = options.label !== undefined ? options.label : 'i';
- if (typeof label === 'string') {
- * @private
- * @type {Node}
- this.label_ = document.createElement('span');
- this.label_.textContent = label;
- } else {
- this.label_ = label;
- var activeLabel = (this.collapsible_ && !this.collapsed_) ?
- this.collapseLabel_ : this.label_;
- var button = document.createElement('button');
- button.setAttribute('type', 'button');
- button.title = tipLabel;
- button.appendChild(activeLabel);
- ol.events.listen(button, ol.events.EventType.CLICK, this.handleClick_, this);
- var cssClasses = className + ' ' + ol.css.CLASS_UNSELECTABLE + ' ' +
- ol.css.CLASS_CONTROL +
- (this.collapsed_ && this.collapsible_ ? ' ol-collapsed' : '') +
- (this.collapsible_ ? '' : ' ol-uncollapsible');
- var element = document.createElement('div');
- element.className = cssClasses;
- element.appendChild(this.ulElement_);
- element.appendChild(button);
- var render = options.render ? options.render : ol.control.Attribution.render;
- ol.control.Control.call(this, {
- element: element,
- render: render,
- target: options.target
- * @private
- * @type {boolean}
- this.renderedVisible_ = true;
- * @private
- * @type {Object.<string, Element>}
- this.attributionElements_ = {};
- * @private
- * @type {Object.<string, boolean>}
- this.attributionElementRenderedVisible_ = {};
- * @private
- this.logoElements_ = {};
-ol.inherits(ol.control.Attribution, ol.control.Control);
- * @param {?olx.FrameState} frameState Frame state.
- * @return {Array.<Object.<string, ol.Attribution>>} Attributions.
-ol.control.Attribution.prototype.getSourceAttributions = function(frameState) {
- var i, ii, j, jj, tileRanges, source, sourceAttribution,
- sourceAttributionKey, sourceAttributions, sourceKey;
- var intersectsTileRange;
- var layerStatesArray = frameState.layerStatesArray;
- /** @type {Object.<string, ol.Attribution>} */
- var attributions = ol.obj.assign({}, frameState.attributions);
- var hiddenAttributions = {};
- var uniqueAttributions = {};
- var projection = /** @type {!ol.proj.Projection} */ (frameState.viewState.projection);
- for (i = 0, ii = layerStatesArray.length; i < ii; i++) {
- source = layerStatesArray[i].layer.getSource();
- if (!source) {
- continue;
- sourceKey = ol.getUid(source).toString();
- sourceAttributions = source.getAttributions();
- if (!sourceAttributions) {
- continue;
- for (j = 0, jj = sourceAttributions.length; j < jj; j++) {
- sourceAttribution = sourceAttributions[j];
- sourceAttributionKey = ol.getUid(sourceAttribution).toString();
- if (sourceAttributionKey in attributions) {
- continue;
- tileRanges = frameState.usedTiles[sourceKey];
- if (tileRanges) {
- var tileGrid = /** @type {ol.source.Tile} */ (source).getTileGridForProjection(projection);
- intersectsTileRange = sourceAttribution.intersectsAnyTileRange(
- tileRanges, tileGrid, projection);
- } else {
- intersectsTileRange = false;
- if (intersectsTileRange) {
- if (sourceAttributionKey in hiddenAttributions) {
- delete hiddenAttributions[sourceAttributionKey];
- var html = sourceAttribution.getHTML();
- if (!(html in uniqueAttributions)) {
- uniqueAttributions[html] = true;
- attributions[sourceAttributionKey] = sourceAttribution;
- } else {
- hiddenAttributions[sourceAttributionKey] = sourceAttribution;
- return [attributions, hiddenAttributions];
- * Update the attribution element.
- * @param {ol.MapEvent} mapEvent Map event.
- * @this {ol.control.Attribution}
- * @api
-ol.control.Attribution.render = function(mapEvent) {
- this.updateElement_(mapEvent.frameState);
- * @private
-ol.control.Attribution.prototype.updateElement_ = function(frameState) {
- if (!frameState) {
- if (this.renderedVisible_) {
- this.element.style.display = 'none';
- this.renderedVisible_ = false;
- return;
- var attributions = this.getSourceAttributions(frameState);
- var visibleAttributions = attributions[0];
- var hiddenAttributions = attributions[1];
- var attributionElement, attributionKey;
- for (attributionKey in this.attributionElements_) {
- if (attributionKey in visibleAttributions) {
- if (!this.attributionElementRenderedVisible_[attributionKey]) {
- this.attributionElements_[attributionKey].style.display = '';
- this.attributionElementRenderedVisible_[attributionKey] = true;
- delete visibleAttributions[attributionKey];
- } else if (attributionKey in hiddenAttributions) {
- if (this.attributionElementRenderedVisible_[attributionKey]) {
- this.attributionElements_[attributionKey].style.display = 'none';
- delete this.attributionElementRenderedVisible_[attributionKey];
- delete hiddenAttributions[attributionKey];
- } else {
- ol.dom.removeNode(this.attributionElements_[attributionKey]);
- delete this.attributionElements_[attributionKey];
- for (attributionKey in visibleAttributions) {
- attributionElement = document.createElement('LI');
- attributionElement.innerHTML =
- visibleAttributions[attributionKey].getHTML();
- this.ulElement_.appendChild(attributionElement);
- this.attributionElements_[attributionKey] = attributionElement;
- for (attributionKey in hiddenAttributions) {
- hiddenAttributions[attributionKey].getHTML();
- attributionElement.style.display = 'none';
- var renderVisible =
- !ol.obj.isEmpty(this.attributionElementRenderedVisible_) ||
- !ol.obj.isEmpty(frameState.logos);
- if (this.renderedVisible_ != renderVisible) {
- this.element.style.display = renderVisible ? '' : 'none';
- this.renderedVisible_ = renderVisible;
- if (renderVisible &&
- ol.obj.isEmpty(this.attributionElementRenderedVisible_)) {
- this.element.classList.add('ol-logo-only');
- } else {
- this.element.classList.remove('ol-logo-only');
- this.insertLogos_(frameState);
- * @private
-ol.control.Attribution.prototype.insertLogos_ = function(frameState) {
- var logo;
- var logos = frameState.logos;
- var logoElements = this.logoElements_;
- for (logo in logoElements) {
- if (!(logo in logos)) {
- ol.dom.removeNode(logoElements[logo]);
- delete logoElements[logo];
- var image, logoElement, logoKey;
- for (logoKey in logos) {
- var logoValue = logos[logoKey];
- if (logoValue instanceof HTMLElement) {
- this.logoLi_.appendChild(logoValue);
- logoElements[logoKey] = logoValue;
- if (!(logoKey in logoElements)) {
- image = new Image();
- image.src = logoKey;
- if (logoValue === '') {
- logoElement = image;
- } else {
- logoElement = document.createElement('a');
- logoElement.href = logoValue;
- logoElement.appendChild(image);
- this.logoLi_.appendChild(logoElement);
- logoElements[logoKey] = logoElement;
- this.logoLi_.style.display = !ol.obj.isEmpty(logos) ? '' : 'none';
- * @param {Event} event The event to handle
- * @private
-ol.control.Attribution.prototype.handleClick_ = function(event) {
- event.preventDefault();
- this.handleToggle_();
- * @private
-ol.control.Attribution.prototype.handleToggle_ = function() {
- this.element.classList.toggle('ol-collapsed');
- if (this.collapsed_) {
- ol.dom.replaceNode(this.collapseLabel_, this.label_);
- } else {
- ol.dom.replaceNode(this.label_, this.collapseLabel_);
- this.collapsed_ = !this.collapsed_;
- * Return `true` if the attribution is collapsible, `false` otherwise.
- * @return {boolean} True if the widget is collapsible.
- * @api
-ol.control.Attribution.prototype.getCollapsible = function() {
- return this.collapsible_;
- * Set whether the attribution should be collapsible.
- * @param {boolean} collapsible True if the widget is collapsible.
- * @api
-ol.control.Attribution.prototype.setCollapsible = function(collapsible) {
- if (this.collapsible_ === collapsible) {
- return;
- this.collapsible_ = collapsible;
- this.element.classList.toggle('ol-uncollapsible');
- if (!collapsible && this.collapsed_) {
- * Collapse or expand the attribution according to the passed parameter. Will
- * not do anything if the attribution isn't collapsible or if the current
- * collapsed state is already the one requested.
- * @param {boolean} collapsed True if the widget is collapsed.
- * @api
-ol.control.Attribution.prototype.setCollapsed = function(collapsed) {
- if (!this.collapsible_ || this.collapsed_ === collapsed) {
- return;
- * Return `true` when the attribution is currently collapsed or `false`
- * otherwise.
- * @return {boolean} True if the widget is collapsed.
- * @api
-ol.control.Attribution.prototype.getCollapsed = function() {
- return this.collapsed_;
-goog.provide('ol.easing');
- * Start slow and speed up.
- * @param {number} t Input between 0 and 1.
- * @return {number} Output between 0 and 1.
- * @api
-ol.easing.easeIn = function(t) {
- return Math.pow(t, 3);
- * Start fast and slow down.
- * @api
-ol.easing.easeOut = function(t) {
- return 1 - ol.easing.easeIn(1 - t);
- * Start slow, speed up, and then slow down again.
- * @api
-ol.easing.inAndOut = function(t) {
- return 3 * t * t - 2 * t * t * t;
- * Maintain a constant speed over time.
- * @api
-ol.easing.linear = function(t) {
- return t;
- * Start slow, speed up, and at the very end slow down again. This has the
- * same general behavior as {@link ol.easing.inAndOut}, but the final slowdown
- * is delayed.
- * @api
-ol.easing.upAndDown = function(t) {
- if (t < 0.5) {
- return ol.easing.inAndOut(2 * t);
- } else {
- return 1 - ol.easing.inAndOut(2 * (t - 0.5));
-goog.provide('ol.control.Rotate');
-goog.require('ol');
-goog.require('ol.easing');
- * @classdesc
- * A button control to reset rotation to 0.
- * To style this control use css selector `.ol-rotate`. A `.ol-hidden` css
- * selector is added to the button when the rotation is 0.
- * @constructor
- * @param {olx.control.RotateOptions=} opt_options Rotate options.
- * @api
-ol.control.Rotate = function(opt_options) {
- var className = options.className !== undefined ? options.className : 'ol-rotate';
- var label = options.label !== undefined ? options.label : '\u21E7';
- * @type {Element}
- * @private
- this.label_ = null;
- this.label_.className = 'ol-compass';
- } else {
- this.label_.classList.add('ol-compass');
- var tipLabel = options.tipLabel ? options.tipLabel : 'Reset rotation';
- button.className = className + '-reset';
- button.appendChild(this.label_);
- ol.control.Rotate.prototype.handleClick_, this);
- ol.css.CLASS_CONTROL;
- var render = options.render ? options.render : ol.control.Rotate.render;
- this.callResetNorth_ = options.resetNorth ? options.resetNorth : undefined;
- element: element,
- render: render,
- * @type {number}
- * @private
- this.duration_ = options.duration !== undefined ? options.duration : 250;
- * @type {boolean}
- * @private
- this.autoHide_ = options.autoHide !== undefined ? options.autoHide : true;
- * @private
- * @type {number|undefined}
- this.rotation_ = undefined;
- if (this.autoHide_) {
- this.element.classList.add(ol.css.CLASS_HIDDEN);
-ol.inherits(ol.control.Rotate, ol.control.Control);
- * @private
-ol.control.Rotate.prototype.handleClick_ = function(event) {
- if (this.callResetNorth_ !== undefined) {
- this.callResetNorth_();
- } else {
- this.resetNorth_();
- * @private
-ol.control.Rotate.prototype.resetNorth_ = function() {
- var map = this.getMap();
- var view = map.getView();
- if (!view) {
- // the map does not have a view, so we can't act
- // upon it
- return;
- if (view.getRotation() !== undefined) {
- if (this.duration_ > 0) {
- view.animate({
- rotation: 0,
- duration: this.duration_,
- easing: ol.easing.easeOut
- } else {
- view.setRotation(0);
- * Update the rotate control element.
- * @this {ol.control.Rotate}
- * @api
-ol.control.Rotate.render = function(mapEvent) {
- var frameState = mapEvent.frameState;
- return;
- var rotation = frameState.viewState.rotation;
- if (rotation != this.rotation_) {
- var transform = 'rotate(' + rotation + 'rad)';
- var contains = this.element.classList.contains(ol.css.CLASS_HIDDEN);
- if (!contains && rotation === 0) {
- } else if (contains && rotation !== 0) {
- this.element.classList.remove(ol.css.CLASS_HIDDEN);
- this.label_.style.msTransform = transform;
- this.label_.style.webkitTransform = transform;
- this.label_.style.transform = transform;
- this.rotation_ = rotation;
-goog.provide('ol.control.Zoom');
- * @classdesc
- * A control with 2 buttons, one for zoom in and one for zoom out.
- * This control is one of the default controls of a map. To style this control
- * use css selectors `.ol-zoom-in` and `.ol-zoom-out`.
- * @constructor
- * @param {olx.control.ZoomOptions=} opt_options Zoom options.
- * @api
-ol.control.Zoom = function(opt_options) {
- var className = options.className !== undefined ? options.className : 'ol-zoom';
- var delta = options.delta !== undefined ? options.delta : 1;
- var zoomInLabel = options.zoomInLabel !== undefined ? options.zoomInLabel : '+';
- var zoomOutLabel = options.zoomOutLabel !== undefined ? options.zoomOutLabel : '\u2212';
- var zoomInTipLabel = options.zoomInTipLabel !== undefined ?
- options.zoomInTipLabel : 'Zoom in';
- var zoomOutTipLabel = options.zoomOutTipLabel !== undefined ?
- options.zoomOutTipLabel : 'Zoom out';
- var inElement = document.createElement('button');
- inElement.className = className + '-in';
- inElement.setAttribute('type', 'button');
- inElement.title = zoomInTipLabel;
- inElement.appendChild(
- typeof zoomInLabel === 'string' ? document.createTextNode(zoomInLabel) : zoomInLabel
- ol.events.listen(inElement, ol.events.EventType.CLICK,
- ol.control.Zoom.prototype.handleClick_.bind(this, delta));
- var outElement = document.createElement('button');
- outElement.className = className + '-out';
- outElement.setAttribute('type', 'button');
- outElement.title = zoomOutTipLabel;
- outElement.appendChild(
- typeof zoomOutLabel === 'string' ? document.createTextNode(zoomOutLabel) : zoomOutLabel
- ol.events.listen(outElement, ol.events.EventType.CLICK,
- ol.control.Zoom.prototype.handleClick_.bind(this, -delta));
- element.appendChild(inElement);
- element.appendChild(outElement);
- element: element,
- * @type {number}
- * @private
-ol.inherits(ol.control.Zoom, ol.control.Control);
- * @param {number} delta Zoom delta.
- * @private
-ol.control.Zoom.prototype.handleClick_ = function(delta, event) {
- this.zoomByDelta_(delta);
- * @private
-ol.control.Zoom.prototype.zoomByDelta_ = function(delta) {
- if (!view) {
- // upon it
- return;
- var currentResolution = view.getResolution();
- if (currentResolution) {
- var newResolution = view.constrainResolution(currentResolution, delta);
- if (view.getAnimating()) {
- view.cancelAnimations();
- view.animate({
- resolution: newResolution,
- } else {
- view.setResolution(newResolution);
-goog.provide('ol.control');
-goog.require('ol.Collection');
-goog.require('ol.control.Attribution');
-goog.require('ol.control.Rotate');
-goog.require('ol.control.Zoom');
- * Set of controls included in maps by default. Unless configured otherwise,
- * this returns a collection containing an instance of each of the following
- * controls:
- * * {@link ol.control.Zoom}
- * * {@link ol.control.Rotate}
- * * {@link ol.control.Attribution}
- * @param {olx.control.DefaultsOptions=} opt_options Defaults options.
- * @return {ol.Collection.<ol.control.Control>} Controls.
- * @api
-ol.control.defaults = function(opt_options) {
- var controls = new ol.Collection();
- var zoomControl = options.zoom !== undefined ? options.zoom : true;
- if (zoomControl) {
- controls.push(new ol.control.Zoom(options.zoomOptions));
- var rotateControl = options.rotate !== undefined ? options.rotate : true;
- if (rotateControl) {
- controls.push(new ol.control.Rotate(options.rotateOptions));
- var attributionControl = options.attribution !== undefined ?
- options.attribution : true;
- if (attributionControl) {
- controls.push(new ol.control.Attribution(options.attributionOptions));
- return controls;
-goog.provide('ol.control.FullScreen');
- * @classdesc
- * Provides a button that when clicked fills up the full screen with the map.
- * The full screen source element is by default the element containing the map viewport unless
- * overriden by providing the `source` option. In which case, the dom
- * element introduced using this parameter will be displayed in full screen.
- * When in full screen mode, a close button is shown to exit full screen mode.
- * The [Fullscreen API](http://www.w3.org/TR/fullscreen/) is used to
- * toggle the map in full screen mode.
- * @constructor
- * @param {olx.control.FullScreenOptions=} opt_options Options.
- * @api
-ol.control.FullScreen = function(opt_options) {
- * @private
- * @type {string}
- this.cssClassName_ = options.className !== undefined ? options.className :
- 'ol-full-screen';
- var label = options.label !== undefined ? options.label : '\u2922';
- * @private
- * @type {Node}
- this.labelNode_ = typeof label === 'string' ?
- document.createTextNode(label) : label;
- var labelActive = options.labelActive !== undefined ? options.labelActive : '\u00d7';
- * @private
- * @type {Node}
- this.labelActiveNode_ = typeof labelActive === 'string' ?
- document.createTextNode(labelActive) : labelActive;
- var tipLabel = options.tipLabel ? options.tipLabel : 'Toggle full-screen';
- button.className = this.cssClassName_ + '-' + ol.control.FullScreen.isFullScreen();
- button.appendChild(this.labelNode_);
- this.handleClick_, this);
- var cssClasses = this.cssClassName_ + ' ' + ol.css.CLASS_UNSELECTABLE +
- ' ' + ol.css.CLASS_CONTROL + ' ' +
- (!ol.control.FullScreen.isFullScreenSupported() ? ol.css.CLASS_UNSUPPORTED : '');
- element: element,
- * @private
- * @type {boolean}
- this.keys_ = options.keys !== undefined ? options.keys : false;
- * @private
- * @type {Element|string|undefined}
- this.source_ = options.source;
-ol.inherits(ol.control.FullScreen, ol.control.Control);
- * @private
-ol.control.FullScreen.prototype.handleClick_ = function(event) {
- this.handleFullScreen_();
- * @private
-ol.control.FullScreen.prototype.handleFullScreen_ = function() {
- if (!ol.control.FullScreen.isFullScreenSupported()) {
- return;
- if (!map) {
- return;
- if (ol.control.FullScreen.isFullScreen()) {
- ol.control.FullScreen.exitFullScreen();
- } else {
- var element;
- if (this.source_) {
- element = typeof this.source_ === 'string' ?
- document.getElementById(this.source_) :
- this.source_;
- } else {
- element = map.getTargetElement();
- if (this.keys_) {
- ol.control.FullScreen.requestFullScreenWithKeys(element);
- } else {
- ol.control.FullScreen.requestFullScreen(element);
- * @private
-ol.control.FullScreen.prototype.handleFullScreenChange_ = function() {
- var button = this.element.firstElementChild;
- button.className = this.cssClassName_ + '-true';
- ol.dom.replaceNode(this.labelActiveNode_, this.labelNode_);
- } else {
- button.className = this.cssClassName_ + '-false';
- ol.dom.replaceNode(this.labelNode_, this.labelActiveNode_);
- if (map) {
- map.updateSize();
- * @inheritDoc
- * @api
-ol.control.FullScreen.prototype.setMap = function(map) {
- ol.control.Control.prototype.setMap.call(this, map);
- if (map) {
- this.listenerKeys.push(ol.events.listen(document,
- ol.control.FullScreen.getChangeType_(),
- this.handleFullScreenChange_, this)
- * @return {boolean} Fullscreen is supported by the current platform.
-ol.control.FullScreen.isFullScreenSupported = function() {
- var body = document.body;
- return !!(
- body.webkitRequestFullscreen ||
- (body.mozRequestFullScreen && document.mozFullScreenEnabled) ||
- (body.msRequestFullscreen && document.msFullscreenEnabled) ||
- (body.requestFullscreen && document.fullscreenEnabled)
- * @return {boolean} Element is currently in fullscreen.
-ol.control.FullScreen.isFullScreen = function() {
- return !!(
- document.webkitIsFullScreen || document.mozFullScreen ||
- document.msFullscreenElement || document.fullscreenElement
- * Request to fullscreen an element.
- * @param {Node} element Element to request fullscreen
-ol.control.FullScreen.requestFullScreen = function(element) {
- if (element.requestFullscreen) {
- element.requestFullscreen();
- } else if (element.msRequestFullscreen) {
- element.msRequestFullscreen();
- } else if (element.mozRequestFullScreen) {
- element.mozRequestFullScreen();
- } else if (element.webkitRequestFullscreen) {
- element.webkitRequestFullscreen();
- * Request to fullscreen an element with keyboard input.
-ol.control.FullScreen.requestFullScreenWithKeys = function(element) {
- if (element.mozRequestFullScreenWithKeys) {
- element.mozRequestFullScreenWithKeys();
- element.webkitRequestFullscreen(Element.ALLOW_KEYBOARD_INPUT);
- } else {
- * Exit fullscreen.
-ol.control.FullScreen.exitFullScreen = function() {
- if (document.exitFullscreen) {
- document.exitFullscreen();
- } else if (document.msExitFullscreen) {
- document.msExitFullscreen();
- } else if (document.mozCancelFullScreen) {
- document.mozCancelFullScreen();
- } else if (document.webkitExitFullscreen) {
- document.webkitExitFullscreen();
- * @return {string} Change type.
- * @private
-ol.control.FullScreen.getChangeType_ = (function() {
- var changeType;
- return function() {
- if (!changeType) {
- if (body.webkitRequestFullscreen) {
- changeType = 'webkitfullscreenchange';
- } else if (body.mozRequestFullScreen) {
- changeType = 'mozfullscreenchange';
- } else if (body.msRequestFullscreen) {
- changeType = 'MSFullscreenChange';
- } else if (body.requestFullscreen) {
- changeType = 'fullscreenchange';
- return changeType;
-// FIXME should listen on appropriate pane, once it is defined
-goog.provide('ol.control.MousePosition');
-goog.require('ol.proj');
- * @classdesc
- * A control to show the 2D coordinates of the mouse cursor. By default, these
- * are in the view projection, but can be in any supported projection.
- * By default the control is shown in the top right corner of the map, but this
- * can be changed by using the css selector `.ol-mouse-position`.
- * @constructor
- * @param {olx.control.MousePositionOptions=} opt_options Mouse position
- * options.
- * @api
-ol.control.MousePosition = function(opt_options) {
- var element = document.createElement('DIV');
- element.className = options.className !== undefined ? options.className : 'ol-mouse-position';
- options.render : ol.control.MousePosition.render;
- element: element,
- render: render,
- ol.events.listen(this,
- ol.Object.getChangeEventType(ol.control.MousePosition.Property_.PROJECTION),
- this.handleProjectionChanged_, this);
- if (options.coordinateFormat) {
- this.setCoordinateFormat(options.coordinateFormat);
- if (options.projection) {
- this.setProjection(ol.proj.get(options.projection));
- * @private
- * @type {string}
- this.undefinedHTML_ = options.undefinedHTML !== undefined ? options.undefinedHTML : '';
- * @private
- * @type {string}
- this.renderedHTML_ = element.innerHTML;
- * @private
- * @type {ol.proj.Projection}
- this.mapProjection_ = null;
- * @private
- * @type {?ol.TransformFunction}
- this.transform_ = null;
- * @private
- * @type {ol.Pixel}
- this.lastMouseMovePixel_ = null;
-ol.inherits(ol.control.MousePosition, ol.control.Control);
- * Update the mouseposition element.
- * @this {ol.control.MousePosition}
- * @api
-ol.control.MousePosition.render = function(mapEvent) {
- } else {
- if (this.mapProjection_ != frameState.viewState.projection) {
- this.mapProjection_ = frameState.viewState.projection;
- this.updateHTML_(this.lastMouseMovePixel_);
- * @private
-ol.control.MousePosition.prototype.handleProjectionChanged_ = function() {
- * Return the coordinate format type used to render the current position or
- * undefined.
- * @return {ol.CoordinateFormatType|undefined} The format to render the current
- * position in.
- * @observable
- * @api
-ol.control.MousePosition.prototype.getCoordinateFormat = function() {
- return /** @type {ol.CoordinateFormatType|undefined} */ (
- this.get(ol.control.MousePosition.Property_.COORDINATE_FORMAT));
- * Return the projection that is used to report the mouse position.
- * @return {ol.proj.Projection|undefined} The projection to report mouse
- * position in.
- * @observable
- * @api
-ol.control.MousePosition.prototype.getProjection = function() {
- return /** @type {ol.proj.Projection|undefined} */ (
- this.get(ol.control.MousePosition.Property_.PROJECTION));
- * @param {Event} event Browser event.
- * @protected
-ol.control.MousePosition.prototype.handleMouseMove = function(event) {
- this.lastMouseMovePixel_ = map.getEventPixel(event);
- * @protected
-ol.control.MousePosition.prototype.handleMouseOut = function(event) {
- this.updateHTML_(null);
- * @inheritDoc
- * @api
-ol.control.MousePosition.prototype.setMap = function(map) {
- if (map) {
- var viewport = map.getViewport();
- ol.events.listen(viewport, ol.events.EventType.MOUSEMOVE,
- this.handleMouseMove, this),
- ol.events.listen(viewport, ol.events.EventType.MOUSEOUT,
- this.handleMouseOut, this)
- * Set the coordinate format type used to render the current position.
- * @param {ol.CoordinateFormatType} format The format to render the current
- * position in.
- * @observable
- * @api
-ol.control.MousePosition.prototype.setCoordinateFormat = function(format) {
- this.set(ol.control.MousePosition.Property_.COORDINATE_FORMAT, format);
- * Set the projection that is used to report the mouse position.
- * @param {ol.proj.Projection} projection The projection to report mouse
- * position in.
- * @observable
- * @api
-ol.control.MousePosition.prototype.setProjection = function(projection) {
- this.set(ol.control.MousePosition.Property_.PROJECTION, projection);
- * @param {?ol.Pixel} pixel Pixel.
- * @private
-ol.control.MousePosition.prototype.updateHTML_ = function(pixel) {
- var html = this.undefinedHTML_;
- if (pixel && this.mapProjection_) {
- if (!this.transform_) {
- var projection = this.getProjection();
- if (projection) {
- this.transform_ = ol.proj.getTransformFromProjections(
- this.mapProjection_, projection);
- } else {
- this.transform_ = ol.proj.identityTransform;
- var coordinate = map.getCoordinateFromPixel(pixel);
- if (coordinate) {
- this.transform_(coordinate, coordinate);
- var coordinateFormat = this.getCoordinateFormat();
- if (coordinateFormat) {
- html = coordinateFormat(coordinate);
- } else {
- html = coordinate.toString();
- if (!this.renderedHTML_ || html != this.renderedHTML_) {
- this.element.innerHTML = html;
- this.renderedHTML_ = html;
- * @enum {string}
- * @private
-ol.control.MousePosition.Property_ = {
- PROJECTION: 'projection',
- COORDINATE_FORMAT: 'coordinateFormat'
-goog.provide('ol.MapEvent');
- * @classdesc
- * Events emitted as map events are instances of this type.
- * See {@link ol.Map} for which events trigger a map event.
- * @constructor
- * @implements {oli.MapEvent}
- * @param {string} type Event type.
- * @param {?olx.FrameState=} opt_frameState Frame state.
-ol.MapEvent = function(type, map, opt_frameState) {
- * The map where the event occurred.
- * @type {ol.Map}
- * @api
- this.map = map;
- * The frame state at the time of the event.
- * @type {?olx.FrameState}
- * @api
- this.frameState = opt_frameState !== undefined ? opt_frameState : null;
-ol.inherits(ol.MapEvent, ol.events.Event);
-goog.provide('ol.MapBrowserEvent');
-goog.require('ol.MapEvent');
- * @classdesc
- * Events emitted as map browser events are instances of this type.
- * See {@link ol.Map} for which events trigger a map browser event.
- * @constructor
- * @extends {ol.MapEvent}
- * @implements {oli.MapBrowserEvent}
- * @param {Event} browserEvent Browser event.
- * @param {boolean=} opt_dragging Is the map currently being dragged?
-ol.MapBrowserEvent = function(type, map, browserEvent, opt_dragging,
- opt_frameState) {
- ol.MapEvent.call(this, type, map, opt_frameState);
- * The original browser event.
- * @const
- * @type {Event}
- * @api
- this.originalEvent = browserEvent;
- * The map pixel relative to the viewport corresponding to the original browser event.
- * @api
- this.pixel = map.getEventPixel(browserEvent);
- * The coordinate in view projection corresponding to the original browser event.
- * @type {ol.Coordinate}
- * @api
- this.coordinate = map.getCoordinateFromPixel(this.pixel);
- * Indicates if the map is currently being dragged. Only set for
- * `POINTERDRAG` and `POINTERMOVE` events. Default is `false`.
- * @type {boolean}
- * @api
- this.dragging = opt_dragging !== undefined ? opt_dragging : false;
-ol.inherits(ol.MapBrowserEvent, ol.MapEvent);
- * Prevents the default browser action.
- * @see https://developer.mozilla.org/en-US/docs/Web/API/event.preventDefault
- * @override
- * @api
-ol.MapBrowserEvent.prototype.preventDefault = function() {
- ol.MapEvent.prototype.preventDefault.call(this);
- this.originalEvent.preventDefault();
- * Prevents further propagation of the current event.
- * @see https://developer.mozilla.org/en-US/docs/Web/API/event.stopPropagation
- * @override
- * @api
-ol.MapBrowserEvent.prototype.stopPropagation = function() {
- ol.MapEvent.prototype.stopPropagation.call(this);
- this.originalEvent.stopPropagation();
-goog.provide('ol.MapBrowserEventType');
- * Constants for event names.
- * @enum {string}
-ol.MapBrowserEventType = {
- * A true single click with no dragging and no double click. Note that this
- * event is delayed by 250 ms to ensure that it is not a double click.
- * @event ol.MapBrowserEvent#singleclick
- * @api
- SINGLECLICK: 'singleclick',
- * A click with no dragging. A double click will fire two of this.
- * @event ol.MapBrowserEvent#click
- * @api
- CLICK: ol.events.EventType.CLICK,
- * A true double click, with no dragging.
- * @event ol.MapBrowserEvent#dblclick
- * @api
- DBLCLICK: ol.events.EventType.DBLCLICK,
- * Triggered when a pointer is dragged.
- * @event ol.MapBrowserEvent#pointerdrag
- * @api
- POINTERDRAG: 'pointerdrag',
- * Triggered when a pointer is moved. Note that on touch devices this is
- * triggered when the map is panned, so is not the same as mousemove.
- * @event ol.MapBrowserEvent#pointermove
- * @api
- POINTERMOVE: 'pointermove',
- POINTERDOWN: 'pointerdown',
- POINTERUP: 'pointerup',
- POINTEROVER: 'pointerover',
- POINTEROUT: 'pointerout',
- POINTERENTER: 'pointerenter',
- POINTERLEAVE: 'pointerleave',
- POINTERCANCEL: 'pointercancel'
-goog.provide('ol.MapBrowserPointerEvent');
-goog.require('ol.MapBrowserEvent');
- * @constructor
- * @extends {ol.MapBrowserEvent}
- * @param {ol.pointer.PointerEvent} pointerEvent Pointer event.
-ol.MapBrowserPointerEvent = function(type, map, pointerEvent, opt_dragging,
- opt_frameState) {
- ol.MapBrowserEvent.call(this, type, map, pointerEvent.originalEvent, opt_dragging,
- opt_frameState);
- * @const
- * @type {ol.pointer.PointerEvent}
- this.pointerEvent = pointerEvent;
-ol.inherits(ol.MapBrowserPointerEvent, ol.MapBrowserEvent);
-goog.provide('ol.pointer.EventType');
- * @enum {string}
-ol.pointer.EventType = {
-goog.provide('ol.webgl');
-if (ol.ENABLE_WEBGL) {
- /** Constants taken from goog.webgl
- * @const
- * @type {number}
- ol.webgl.ONE = 1;
- * @const
- * @type {number}
- ol.webgl.SRC_ALPHA = 0x0302;
- * @const
- * @type {number}
- ol.webgl.COLOR_ATTACHMENT0 = 0x8CE0;
- * @const
- * @type {number}
- ol.webgl.COLOR_BUFFER_BIT = 0x00004000;
- * @const
- * @type {number}
- ol.webgl.TRIANGLES = 0x0004;
- * @const
- * @type {number}
- ol.webgl.TRIANGLE_STRIP = 0x0005;
- * @const
- * @type {number}
- ol.webgl.ONE_MINUS_SRC_ALPHA = 0x0303;
- * @const
- * @type {number}
- ol.webgl.ARRAY_BUFFER = 0x8892;
- * @const
- * @type {number}
- ol.webgl.ELEMENT_ARRAY_BUFFER = 0x8893;
- * @const
- * @type {number}
- ol.webgl.STREAM_DRAW = 0x88E0;
- * @const
- * @type {number}
- ol.webgl.STATIC_DRAW = 0x88E4;
- * @const
- * @type {number}
- ol.webgl.DYNAMIC_DRAW = 0x88E8;
- * @const
- * @type {number}
- ol.webgl.CULL_FACE = 0x0B44;
- * @const
- * @type {number}
- ol.webgl.BLEND = 0x0BE2;
- * @const
- * @type {number}
- ol.webgl.STENCIL_TEST = 0x0B90;
- * @const
- * @type {number}
- ol.webgl.DEPTH_TEST = 0x0B71;
- * @const
- * @type {number}
- ol.webgl.SCISSOR_TEST = 0x0C11;
- * @const
- * @type {number}
- ol.webgl.UNSIGNED_BYTE = 0x1401;
- * @const
- * @type {number}
- ol.webgl.UNSIGNED_SHORT = 0x1403;
- * @const
- * @type {number}
- ol.webgl.UNSIGNED_INT = 0x1405;
- * @const
- * @type {number}
- ol.webgl.FLOAT = 0x1406;
- * @const
- * @type {number}
- ol.webgl.RGBA = 0x1908;
- * @const
- * @type {number}
- ol.webgl.FRAGMENT_SHADER = 0x8B30;
- * @const
- * @type {number}
- ol.webgl.VERTEX_SHADER = 0x8B31;
- * @const
- * @type {number}
- ol.webgl.LINK_STATUS = 0x8B82;
- * @const
- * @type {number}
- ol.webgl.LINEAR = 0x2601;
- * @const
- * @type {number}
- ol.webgl.TEXTURE_MAG_FILTER = 0x2800;
- * @const
- * @type {number}
- ol.webgl.TEXTURE_MIN_FILTER = 0x2801;
- * @const
- * @type {number}
- ol.webgl.TEXTURE_WRAP_S = 0x2802;
- * @const
- * @type {number}
- ol.webgl.TEXTURE_WRAP_T = 0x2803;
- * @const
- * @type {number}
- ol.webgl.TEXTURE_2D = 0x0DE1;
- * @const
- * @type {number}
- ol.webgl.TEXTURE0 = 0x84C0;
- * @const
- * @type {number}
- ol.webgl.CLAMP_TO_EDGE = 0x812F;
- * @const
- * @type {number}
- ol.webgl.COMPILE_STATUS = 0x8B81;
- * @const
- * @type {number}
- ol.webgl.FRAMEBUFFER = 0x8D40;
- /** end of goog.webgl constants
- * @const
- * @private
- * @type {Array.<string>}
- ol.webgl.CONTEXT_IDS_ = [
- 'experimental-webgl',
- 'webgl',
- 'webkit-3d',
- 'moz-webgl'
- * @param {HTMLCanvasElement} canvas Canvas.
- * @param {Object=} opt_attributes Attributes.
- * @return {WebGLRenderingContext} WebGL rendering context.
- ol.webgl.getContext = function(canvas, opt_attributes) {
- var context, i, ii = ol.webgl.CONTEXT_IDS_.length;
- for (i = 0; i < ii; ++i) {
- try {
- context = canvas.getContext(ol.webgl.CONTEXT_IDS_[i], opt_attributes);
- if (context) {
- return /** @type {!WebGLRenderingContext} */ (context);
- } catch (e) {
- // pass
- return null;
-goog.provide('ol.has');
-goog.require('ol.webgl');
-var ua = typeof navigator !== 'undefined' ?
- navigator.userAgent.toLowerCase() : '';
- * User agent string says we are dealing with Firefox as browser.
- * @type {boolean}
-ol.has.FIREFOX = ua.indexOf('firefox') !== -1;
- * User agent string says we are dealing with Safari as browser.
- * @type {boolean}
-ol.has.SAFARI = ua.indexOf('safari') !== -1 && ua.indexOf('chrom') == -1;
- * User agent string says we are dealing with a WebKit engine.
- * @type {boolean}
-ol.has.WEBKIT = ua.indexOf('webkit') !== -1 && ua.indexOf('edge') == -1;
- * User agent string says we are dealing with a Mac as platform.
- * @type {boolean}
-ol.has.MAC = ua.indexOf('macintosh') !== -1;
- * The ratio between physical pixels and device-independent pixels
- * (dips) on the device (`window.devicePixelRatio`).
- * @const
- * @type {number}
- * @api
-ol.has.DEVICE_PIXEL_RATIO = window.devicePixelRatio || 1;
- * True if the browser's Canvas implementation implements {get,set}LineDash.
- * @type {boolean}
-ol.has.CANVAS_LINE_DASH = false;
- * True if both the library and browser support Canvas. Always `false`
- * if `ol.ENABLE_CANVAS` is set to `false` at compile time.
- * @const
- * @type {boolean}
- * @api
-ol.has.CANVAS = ol.ENABLE_CANVAS && (
- * @return {boolean} Canvas supported.
- function() {
- if (!('HTMLCanvasElement' in window)) {
- return false;
- try {
- var context = document.createElement('CANVAS').getContext('2d');
- if (!context) {
- return false;
- } else {
- if (context.setLineDash !== undefined) {
- ol.has.CANVAS_LINE_DASH = true;
- return true;
- } catch (e) {
- return false;
- * Indicates if DeviceOrientation is supported in the user's browser.
- * @const
- * @type {boolean}
- * @api
-ol.has.DEVICE_ORIENTATION = 'DeviceOrientationEvent' in window;
- * Is HTML5 geolocation supported in the current browser?
- * @const
- * @type {boolean}
- * @api
-ol.has.GEOLOCATION = 'geolocation' in navigator;
- * True if browser supports touch events.
- * @const
- * @type {boolean}
- * @api
-ol.has.TOUCH = ol.ASSUME_TOUCH || 'ontouchstart' in window;
- * True if browser supports pointer events.
- * @const
- * @type {boolean}
-ol.has.POINTER = 'PointerEvent' in window;
- * True if browser supports ms pointer events (IE 10).
- * @const
- * @type {boolean}
-ol.has.MSPOINTER = !!(navigator.msPointerEnabled);
- * True if both OpenLayers and browser support WebGL. Always `false`
- * if `ol.ENABLE_WEBGL` is set to `false` at compile time.
- * @const
- * @type {boolean}
- * @api
-ol.has.WEBGL;
-(function() {
- if (ol.ENABLE_WEBGL) {
- var hasWebGL = false;
- var textureSize;
- var /** @type {Array.<string>} */ extensions = [];
- if ('WebGLRenderingContext' in window) {
- try {
- var canvas = /** @type {HTMLCanvasElement} */
- (document.createElement('CANVAS'));
- var gl = ol.webgl.getContext(canvas, {
- failIfMajorPerformanceCaveat: true
- if (gl) {
- hasWebGL = true;
- textureSize = /** @type {number} */
- (gl.getParameter(gl.MAX_TEXTURE_SIZE));
- extensions = gl.getSupportedExtensions();
- } catch (e) {
- // pass
- ol.has.WEBGL = hasWebGL;
- ol.WEBGL_EXTENSIONS = extensions;
- ol.WEBGL_MAX_TEXTURE_SIZE = textureSize;
-goog.provide('ol.pointer.EventSource');
- * @param {ol.pointer.PointerEventHandler} dispatcher Event handler.
- * @param {!Object.<string, function(Event)>} mapping Event
- * mapping.
- * @constructor
-ol.pointer.EventSource = function(dispatcher, mapping) {
- * @type {ol.pointer.PointerEventHandler}
- this.dispatcher = dispatcher;
- * @private
- * @const
- * @type {!Object.<string, function(Event)>}
- this.mapping_ = mapping;
- * List of events supported by this source.
- * @return {Array.<string>} Event names
-ol.pointer.EventSource.prototype.getEvents = function() {
- return Object.keys(this.mapping_);
- * Returns a mapping between the supported event types and
- * the handlers that should handle an event.
- * @return {Object.<string, function(Event)>}
- * Event/Handler mapping
-ol.pointer.EventSource.prototype.getMapping = function() {
- return this.mapping_;
- * Returns the handler that should handle a given event type.
- * @param {string} eventType The event type.
- * @return {function(Event)} Handler
-ol.pointer.EventSource.prototype.getHandlerForEvent = function(eventType) {
- return this.mapping_[eventType];
-// Based on https://github.com/Polymer/PointerEvents
-// Copyright (c) 2013 The Polymer Authors. All rights reserved.
-// Redistribution and use in source and binary forms, with or without
-// modification, are permitted provided that the following conditions are
-// met:
-// * Redistributions of source code must retain the above copyright
-// notice, this list of conditions and the following disclaimer.
-// * Redistributions in binary form must reproduce the above
-// copyright notice, this list of conditions and the following disclaimer
-// in the documentation and/or other materials provided with the
-// distribution.
-// * Neither the name of Google Inc. nor the names of its
-// contributors may be used to endorse or promote products derived from
-// this software without specific prior written permission.
-// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
-// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
-// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
-// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
-// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
-// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
-// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
-// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
-// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-goog.provide('ol.pointer.MouseSource');
-goog.require('ol.pointer.EventSource');
- * @constructor
- * @extends {ol.pointer.EventSource}
-ol.pointer.MouseSource = function(dispatcher) {
- var mapping = {
- 'mousedown': this.mousedown,
- 'mousemove': this.mousemove,
- 'mouseup': this.mouseup,
- 'mouseover': this.mouseover,
- 'mouseout': this.mouseout
- ol.pointer.EventSource.call(this, dispatcher, mapping);
- * @const
- * @type {!Object.<string, Event|Object>}
- this.pointerMap = dispatcher.pointerMap;
- * @const
- * @type {Array.<ol.Pixel>}
- this.lastTouches = [];
-ol.inherits(ol.pointer.MouseSource, ol.pointer.EventSource);
- * @const
- * @type {number}
-ol.pointer.MouseSource.POINTER_ID = 1;
- * @const
- * @type {string}
-ol.pointer.MouseSource.POINTER_TYPE = 'mouse';
- * Radius around touchend that swallows mouse events.
- * @const
- * @type {number}
-ol.pointer.MouseSource.DEDUP_DIST = 25;
- * Detect if a mouse event was simulated from a touch by
- * checking if previously there was a touch event at the
- * same position.
- * FIXME - Known problem with the native Android browser on
- * Samsung GT-I9100 (Android 4.1.2):
- * In case the page is scrolled, this function does not work
- * correctly when a canvas is used (WebGL or canvas renderer).
- * Mouse listeners on canvas elements (for this browser), create
- * two mouse events: One 'good' and one 'bad' one (on other browsers or
- * when a div is used, there is only one event). For the 'bad' one,
- * clientX/clientY and also pageX/pageY are wrong when the page
- * is scrolled. Because of that, this function can not detect if
- * the events were simulated from a touch event. As result, a
- * pointer event at a wrong position is dispatched, which confuses
- * the map interactions.
- * It is unclear, how one can get the correct position for the event
- * or detect that the positions are invalid.
- * @private
- * @param {Event} inEvent The in event.
- * @return {boolean} True, if the event was generated by a touch.
-ol.pointer.MouseSource.prototype.isEventSimulatedFromTouch_ = function(inEvent) {
- var lts = this.lastTouches;
- var x = inEvent.clientX, y = inEvent.clientY;
- for (var i = 0, l = lts.length, t; i < l && (t = lts[i]); i++) {
- // simulated mouse events will be swallowed near a primary touchend
- var dx = Math.abs(x - t[0]), dy = Math.abs(y - t[1]);
- if (dx <= ol.pointer.MouseSource.DEDUP_DIST &&
- dy <= ol.pointer.MouseSource.DEDUP_DIST) {
- return true;
- return false;
- * Creates a copy of the original event that will be used
- * for the fake pointer event.
- * @return {Object} The copied event.
-ol.pointer.MouseSource.prepareEvent = function(inEvent, dispatcher) {
- var e = dispatcher.cloneEvent(inEvent, inEvent);
- // forward mouse preventDefault
- var pd = e.preventDefault;
- e.preventDefault = function() {
- inEvent.preventDefault();
- pd();
- e.pointerId = ol.pointer.MouseSource.POINTER_ID;
- e.isPrimary = true;
- e.pointerType = ol.pointer.MouseSource.POINTER_TYPE;
- return e;
- * Handler for `mousedown`.
-ol.pointer.MouseSource.prototype.mousedown = function(inEvent) {
- if (!this.isEventSimulatedFromTouch_(inEvent)) {
- // TODO(dfreedman) workaround for some elements not sending mouseup
- // http://crbug/149091
- if (ol.pointer.MouseSource.POINTER_ID.toString() in this.pointerMap) {
- this.cancel(inEvent);
- var e = ol.pointer.MouseSource.prepareEvent(inEvent, this.dispatcher);
- this.pointerMap[ol.pointer.MouseSource.POINTER_ID.toString()] = inEvent;
- this.dispatcher.down(e, inEvent);
- * Handler for `mousemove`.
-ol.pointer.MouseSource.prototype.mousemove = function(inEvent) {
- this.dispatcher.move(e, inEvent);
- * Handler for `mouseup`.
-ol.pointer.MouseSource.prototype.mouseup = function(inEvent) {
- var p = this.pointerMap[ol.pointer.MouseSource.POINTER_ID.toString()];
- if (p && p.button === inEvent.button) {
- this.dispatcher.up(e, inEvent);
- this.cleanupMouse();
- * Handler for `mouseover`.
-ol.pointer.MouseSource.prototype.mouseover = function(inEvent) {
- this.dispatcher.enterOver(e, inEvent);
- * Handler for `mouseout`.
-ol.pointer.MouseSource.prototype.mouseout = function(inEvent) {
- this.dispatcher.leaveOut(e, inEvent);
- * Dispatches a `pointercancel` event.
-ol.pointer.MouseSource.prototype.cancel = function(inEvent) {
- this.dispatcher.cancel(e, inEvent);
- * Remove the mouse from the list of active pointers.
-ol.pointer.MouseSource.prototype.cleanupMouse = function() {
- delete this.pointerMap[ol.pointer.MouseSource.POINTER_ID.toString()];
-// met:
-// distribution.
-goog.provide('ol.pointer.MsSource');
- * @constructor
-ol.pointer.MsSource = function(dispatcher) {
- var mapping = {
- 'MSPointerDown': this.msPointerDown,
- 'MSPointerMove': this.msPointerMove,
- 'MSPointerUp': this.msPointerUp,
- 'MSPointerOut': this.msPointerOut,
- 'MSPointerOver': this.msPointerOver,
- 'MSPointerCancel': this.msPointerCancel,
- 'MSGotPointerCapture': this.msGotPointerCapture,
- 'MSLostPointerCapture': this.msLostPointerCapture
- * @const
- * @const
- this.POINTER_TYPES = [
- 'unavailable',
- 'touch',
- 'pen',
- 'mouse'
-ol.inherits(ol.pointer.MsSource, ol.pointer.EventSource);
- * @private
-ol.pointer.MsSource.prototype.prepareEvent_ = function(inEvent) {
- var e = inEvent;
- if (typeof inEvent.pointerType === 'number') {
- e = this.dispatcher.cloneEvent(inEvent, inEvent);
- e.pointerType = this.POINTER_TYPES[inEvent.pointerType];
- return e;
- * Remove this pointer from the list of active pointers.
- * @param {number} pointerId Pointer identifier.
-ol.pointer.MsSource.prototype.cleanup = function(pointerId) {
- delete this.pointerMap[pointerId.toString()];
- * Handler for `msPointerDown`.
-ol.pointer.MsSource.prototype.msPointerDown = function(inEvent) {
- this.pointerMap[inEvent.pointerId.toString()] = inEvent;
- var e = this.prepareEvent_(inEvent);
- * Handler for `msPointerMove`.
-ol.pointer.MsSource.prototype.msPointerMove = function(inEvent) {
- * Handler for `msPointerUp`.
-ol.pointer.MsSource.prototype.msPointerUp = function(inEvent) {
- this.cleanup(inEvent.pointerId);
- * Handler for `msPointerOut`.
-ol.pointer.MsSource.prototype.msPointerOut = function(inEvent) {
- * Handler for `msPointerOver`.
-ol.pointer.MsSource.prototype.msPointerOver = function(inEvent) {
- * Handler for `msPointerCancel`.
-ol.pointer.MsSource.prototype.msPointerCancel = function(inEvent) {
- * Handler for `msLostPointerCapture`.
-ol.pointer.MsSource.prototype.msLostPointerCapture = function(inEvent) {
- var e = this.dispatcher.makeEvent('lostpointercapture',
- inEvent, inEvent);
- this.dispatcher.dispatchEvent(e);
- * Handler for `msGotPointerCapture`.
-ol.pointer.MsSource.prototype.msGotPointerCapture = function(inEvent) {
- var e = this.dispatcher.makeEvent('gotpointercapture',
-// met:
-// distribution.
-goog.provide('ol.pointer.NativeSource');
- * @constructor
-ol.pointer.NativeSource = function(dispatcher) {
- var mapping = {
- 'pointerdown': this.pointerDown,
- 'pointermove': this.pointerMove,
- 'pointerup': this.pointerUp,
- 'pointerout': this.pointerOut,
- 'pointerover': this.pointerOver,
- 'pointercancel': this.pointerCancel,
- 'gotpointercapture': this.gotPointerCapture,
- 'lostpointercapture': this.lostPointerCapture
-ol.inherits(ol.pointer.NativeSource, ol.pointer.EventSource);
- * Handler for `pointerdown`.
-ol.pointer.NativeSource.prototype.pointerDown = function(inEvent) {
- this.dispatcher.fireNativeEvent(inEvent);
- * Handler for `pointermove`.
-ol.pointer.NativeSource.prototype.pointerMove = function(inEvent) {
- * Handler for `pointerup`.
-ol.pointer.NativeSource.prototype.pointerUp = function(inEvent) {
- * Handler for `pointerout`.
-ol.pointer.NativeSource.prototype.pointerOut = function(inEvent) {
- * Handler for `pointerover`.
-ol.pointer.NativeSource.prototype.pointerOver = function(inEvent) {
- * Handler for `pointercancel`.
-ol.pointer.NativeSource.prototype.pointerCancel = function(inEvent) {
- * Handler for `lostpointercapture`.
-ol.pointer.NativeSource.prototype.lostPointerCapture = function(inEvent) {
- * Handler for `gotpointercapture`.
-ol.pointer.NativeSource.prototype.gotPointerCapture = function(inEvent) {
-// met:
-// distribution.
-goog.provide('ol.pointer.PointerEvent');
-goog.require('ol.events.Event');
- * A class for pointer events.
- * This class is used as an abstraction for mouse events,
- * touch events and even native pointer events.
- * @constructor
- * @extends {ol.events.Event}
- * @param {string} type The type of the event to create.
- * @param {Event} originalEvent The event.
- * @param {Object.<string, ?>=} opt_eventDict An optional dictionary of
- * initial event properties.
-ol.pointer.PointerEvent = function(type, originalEvent, opt_eventDict) {
- ol.events.Event.call(this, type);
- * @const
- * @type {Event}
- this.originalEvent = originalEvent;
- var eventDict = opt_eventDict ? opt_eventDict : {};
- * @type {number}
- this.buttons = this.getButtons_(eventDict);
- * @type {number}
- this.pressure = this.getPressure_(eventDict, this.buttons);
- // MouseEvent related properties
- * @type {boolean}
- this.bubbles = 'bubbles' in eventDict ? eventDict['bubbles'] : false;
- * @type {boolean}
- this.cancelable = 'cancelable' in eventDict ? eventDict['cancelable'] : false;
- * @type {Object}
- this.view = 'view' in eventDict ? eventDict['view'] : null;
- * @type {number}
- this.detail = 'detail' in eventDict ? eventDict['detail'] : null;
- * @type {number}
- this.screenX = 'screenX' in eventDict ? eventDict['screenX'] : 0;
- * @type {number}
- this.screenY = 'screenY' in eventDict ? eventDict['screenY'] : 0;
- * @type {number}
- this.clientX = 'clientX' in eventDict ? eventDict['clientX'] : 0;
- * @type {number}
- this.clientY = 'clientY' in eventDict ? eventDict['clientY'] : 0;
- * @type {boolean}
- this.ctrlKey = 'ctrlKey' in eventDict ? eventDict['ctrlKey'] : false;
- * @type {boolean}
- this.altKey = 'altKey' in eventDict ? eventDict['altKey'] : false;
- * @type {boolean}
- this.shiftKey = 'shiftKey' in eventDict ? eventDict['shiftKey'] : false;
- * @type {boolean}
- this.metaKey = 'metaKey' in eventDict ? eventDict['metaKey'] : false;
- * @type {number}
- this.button = 'button' in eventDict ? eventDict['button'] : 0;
- * @type {Node}
- this.relatedTarget = 'relatedTarget' in eventDict ?
- eventDict['relatedTarget'] : null;
- // PointerEvent related properties
- * @const
- * @type {number}
- this.pointerId = 'pointerId' in eventDict ? eventDict['pointerId'] : 0;
- * @type {number}
- this.width = 'width' in eventDict ? eventDict['width'] : 0;
- * @type {number}
- this.height = 'height' in eventDict ? eventDict['height'] : 0;
- * @type {number}
- this.tiltX = 'tiltX' in eventDict ? eventDict['tiltX'] : 0;
- * @type {number}
- this.tiltY = 'tiltY' in eventDict ? eventDict['tiltY'] : 0;
- * @type {string}
- this.pointerType = 'pointerType' in eventDict ? eventDict['pointerType'] : '';
- * @type {number}
- this.hwTimestamp = 'hwTimestamp' in eventDict ? eventDict['hwTimestamp'] : 0;
- * @type {boolean}
- this.isPrimary = 'isPrimary' in eventDict ? eventDict['isPrimary'] : false;
- // keep the semantics of preventDefault
- if (originalEvent.preventDefault) {
- this.preventDefault = function() {
- originalEvent.preventDefault();
-ol.inherits(ol.pointer.PointerEvent, ol.events.Event);
- * @private
- * @param {Object.<string, ?>} eventDict The event dictionary.
- * @return {number} Button indicator.
-ol.pointer.PointerEvent.prototype.getButtons_ = function(eventDict) {
- // According to the w3c spec,
- // http://www.w3.org/TR/DOM-Level-3-Events/#events-MouseEvent-button
- // MouseEvent.button == 0 can mean either no mouse button depressed, or the
- // left mouse button depressed.
- // As of now, the only way to distinguish between the two states of
- // MouseEvent.button is by using the deprecated MouseEvent.which property, as
- // this maps mouse buttons to positive integers > 0, and uses 0 to mean that
- // no mouse button is held.
- // MouseEvent.which is derived from MouseEvent.button at MouseEvent creation,
- // but initMouseEvent does not expose an argument with which to set
- // MouseEvent.which. Calling initMouseEvent with a buttonArg of 0 will set
- // MouseEvent.button == 0 and MouseEvent.which == 1, breaking the expectations
- // of app developers.
- // The only way to propagate the correct state of MouseEvent.which and
- // MouseEvent.button to a new MouseEvent.button == 0 and MouseEvent.which == 0
- // is to call initMouseEvent with a buttonArg value of -1.
- // This is fixed with DOM Level 4's use of buttons
- var buttons;
- if (eventDict.buttons || ol.pointer.PointerEvent.HAS_BUTTONS) {
- buttons = eventDict.buttons;
- } else {
- switch (eventDict.which) {
- case 1: buttons = 1; break;
- case 2: buttons = 4; break;
- case 3: buttons = 2; break;
- default: buttons = 0;
- return buttons;
- * @private
- * @param {number} buttons Button indicator.
- * @return {number} The pressure.
-ol.pointer.PointerEvent.prototype.getPressure_ = function(eventDict, buttons) {
- // Spec requires that pointers without pressure specified use 0.5 for down
- // state and 0 for up state.
- var pressure = 0;
- if (eventDict.pressure) {
- pressure = eventDict.pressure;
- } else {
- pressure = buttons ? 0.5 : 0;
- return pressure;
- * Is the `buttons` property supported?
- * @type {boolean}
-ol.pointer.PointerEvent.HAS_BUTTONS = false;
- * Checks if the `buttons` property is supported.
-(function() {
- try {
- var ev = new MouseEvent('click', {buttons: 1});
- ol.pointer.PointerEvent.HAS_BUTTONS = ev.buttons === 1;
- } catch (e) {
- // pass
-// met:
-// distribution.
-goog.provide('ol.pointer.TouchSource');
-goog.require('ol.array');
-goog.require('ol.pointer.MouseSource');
- * @constructor
- * @param {ol.pointer.PointerEventHandler} dispatcher The event handler.
- * @param {ol.pointer.MouseSource} mouseSource Mouse source.
-ol.pointer.TouchSource = function(dispatcher, mouseSource) {
- var mapping = {
- 'touchstart': this.touchstart,
- 'touchmove': this.touchmove,
- 'touchend': this.touchend,
- 'touchcancel': this.touchcancel
- * @const
- * @const
- * @type {ol.pointer.MouseSource}
- this.mouseSource = mouseSource;
- * @private
- this.firstTouchId_ = undefined;
- * @private
- * @type {number}
- this.clickCount_ = 0;
- * @private
- this.resetId_ = undefined;
-ol.inherits(ol.pointer.TouchSource, ol.pointer.EventSource);
- * Mouse event timeout: This should be long enough to
- * ignore compat mouse events made by touch.
- * @const
- * @type {number}
-ol.pointer.TouchSource.DEDUP_TIMEOUT = 2500;
- * @const
- * @type {number}
-ol.pointer.TouchSource.CLICK_COUNT_TIMEOUT = 200;
- * @const
- * @type {string}
-ol.pointer.TouchSource.POINTER_TYPE = 'touch';
- * @private
- * @param {Touch} inTouch The in touch.
- * @return {boolean} True, if this is the primary touch.
-ol.pointer.TouchSource.prototype.isPrimaryTouch_ = function(inTouch) {
- return this.firstTouchId_ === inTouch.identifier;
- * Set primary touch if there are no pointers, or the only pointer is the mouse.
- * @private
-ol.pointer.TouchSource.prototype.setPrimaryTouch_ = function(inTouch) {
- var count = Object.keys(this.pointerMap).length;
- if (count === 0 || (count === 1 &&
- ol.pointer.MouseSource.POINTER_ID.toString() in this.pointerMap)) {
- this.firstTouchId_ = inTouch.identifier;
- this.cancelResetClickCount_();
- * @private
- * @param {Object} inPointer The in pointer object.
-ol.pointer.TouchSource.prototype.removePrimaryPointer_ = function(inPointer) {
- if (inPointer.isPrimary) {
- this.resetClickCount_();
- * @private
-ol.pointer.TouchSource.prototype.resetClickCount_ = function() {
- this.resetId_ = setTimeout(
- this.resetClickCountHandler_.bind(this),
- ol.pointer.TouchSource.CLICK_COUNT_TIMEOUT);
- * @private
-ol.pointer.TouchSource.prototype.resetClickCountHandler_ = function() {
- * @private
-ol.pointer.TouchSource.prototype.cancelResetClickCount_ = function() {
- if (this.resetId_ !== undefined) {
- clearTimeout(this.resetId_);
- * @private
- * @param {Touch} inTouch Touch event
- * @return {Object} A pointer object.
-ol.pointer.TouchSource.prototype.touchToPointer_ = function(browserEvent, inTouch) {
- var e = this.dispatcher.cloneEvent(browserEvent, inTouch);
- // Spec specifies that pointerId 1 is reserved for Mouse.
- // Touch identifiers can start at 0.
- // Add 2 to the touch identifier for compatibility.
- e.pointerId = inTouch.identifier + 2;
- // TODO: check if this is necessary?
- //e.target = findTarget(e);
- e.bubbles = true;
- e.cancelable = true;
- e.detail = this.clickCount_;
- e.button = 0;
- e.buttons = 1;
- e.width = inTouch.webkitRadiusX || inTouch.radiusX || 0;
- e.height = inTouch.webkitRadiusY || inTouch.radiusY || 0;
- e.pressure = inTouch.webkitForce || inTouch.force || 0.5;
- e.isPrimary = this.isPrimaryTouch_(inTouch);
- e.pointerType = ol.pointer.TouchSource.POINTER_TYPE;
- // make sure that the properties that are different for
- // each `Touch` object are not copied from the BrowserEvent object
- e.clientX = inTouch.clientX;
- e.clientY = inTouch.clientY;
- e.screenX = inTouch.screenX;
- e.screenY = inTouch.screenY;
- return e;
- * @private
- * @param {Event} inEvent Touch event
- * @param {function(Event, Object)} inFunction In function.
-ol.pointer.TouchSource.prototype.processTouches_ = function(inEvent, inFunction) {
- var touches = Array.prototype.slice.call(
- inEvent.changedTouches);
- var count = touches.length;
- function preventDefault() {
- var i, pointer;
- for (i = 0; i < count; ++i) {
- pointer = this.touchToPointer_(inEvent, touches[i]);
- // forward touch preventDefaults
- pointer.preventDefault = preventDefault;
- inFunction.call(this, inEvent, pointer);
- * @private
- * @param {TouchList} touchList The touch list.
- * @param {number} searchId Search identifier.
- * @return {boolean} True, if the `Touch` with the given id is in the list.
-ol.pointer.TouchSource.prototype.findTouch_ = function(touchList, searchId) {
- var l = touchList.length;
- var touch;
- for (var i = 0; i < l; i++) {
- touch = touchList[i];
- if (touch.identifier === searchId) {
- return true;
- return false;
- * In some instances, a touchstart can happen without a touchend. This
- * leaves the pointermap in a broken state.
- * Therefore, on every touchstart, we remove the touches that did not fire a
- * touchend event.
- * To keep state globally consistent, we fire a pointercancel for
- * this "abandoned" touch
- * @private
-ol.pointer.TouchSource.prototype.vacuumTouches_ = function(inEvent) {
- var touchList = inEvent.touches;
- // pointerMap.getCount() should be < touchList.length here,
- // as the touchstart has not been processed yet.
- var keys = Object.keys(this.pointerMap);
- var count = keys.length;
- if (count >= touchList.length) {
- var d = [];
- var i, key, value;
- key = keys[i];
- value = this.pointerMap[key];
- // Never remove pointerId == 1, which is mouse.
- // Touch identifiers are 2 smaller than their pointerId, which is the
- // index in pointermap.
- if (key != ol.pointer.MouseSource.POINTER_ID &&
- !this.findTouch_(touchList, key - 2)) {
- d.push(value.out);
- for (i = 0; i < d.length; ++i) {
- this.cancelOut_(inEvent, d[i]);
- * Handler for `touchstart`, triggers `pointerover`,
- * `pointerenter` and `pointerdown` events.
-ol.pointer.TouchSource.prototype.touchstart = function(inEvent) {
- this.vacuumTouches_(inEvent);
- this.setPrimaryTouch_(inEvent.changedTouches[0]);
- this.dedupSynthMouse_(inEvent);
- this.clickCount_++;
- this.processTouches_(inEvent, this.overDown_);
- * @private
- * @param {Event} browserEvent The event.
-ol.pointer.TouchSource.prototype.overDown_ = function(browserEvent, inPointer) {
- this.pointerMap[inPointer.pointerId] = {
- target: inPointer.target,
- out: inPointer,
- outTarget: inPointer.target
- this.dispatcher.over(inPointer, browserEvent);
- this.dispatcher.enter(inPointer, browserEvent);
- this.dispatcher.down(inPointer, browserEvent);
- * Handler for `touchmove`.
-ol.pointer.TouchSource.prototype.touchmove = function(inEvent) {
- this.processTouches_(inEvent, this.moveOverOut_);
- * @private
- * @param {Object} inPointer The in pointer.
-ol.pointer.TouchSource.prototype.moveOverOut_ = function(browserEvent, inPointer) {
- var event = inPointer;
- var pointer = this.pointerMap[event.pointerId];
- // a finger drifted off the screen, ignore it
- if (!pointer) {
- return;
- var outEvent = pointer.out;
- var outTarget = pointer.outTarget;
- this.dispatcher.move(event, browserEvent);
- if (outEvent && outTarget !== event.target) {
- outEvent.relatedTarget = event.target;
- event.relatedTarget = outTarget;
- // recover from retargeting by shadow
- outEvent.target = outTarget;
- if (event.target) {
- this.dispatcher.leaveOut(outEvent, browserEvent);
- this.dispatcher.enterOver(event, browserEvent);
- } else {
- // clean up case when finger leaves the screen
- event.target = outTarget;
- event.relatedTarget = null;
- this.cancelOut_(browserEvent, event);
- pointer.out = event;
- pointer.outTarget = event.target;
- * Handler for `touchend`, triggers `pointerup`,
- * `pointerout` and `pointerleave` events.
- * @param {Event} inEvent The event.
-ol.pointer.TouchSource.prototype.touchend = function(inEvent) {
- this.processTouches_(inEvent, this.upOut_);
- * @private
- * @param {Event} browserEvent An event.
- * @param {Object} inPointer The inPointer object.
-ol.pointer.TouchSource.prototype.upOut_ = function(browserEvent, inPointer) {
- this.dispatcher.up(inPointer, browserEvent);
- this.dispatcher.out(inPointer, browserEvent);
- this.dispatcher.leave(inPointer, browserEvent);
- this.cleanUpPointer_(inPointer);
- * Handler for `touchcancel`, triggers `pointercancel`,
-ol.pointer.TouchSource.prototype.touchcancel = function(inEvent) {
- this.processTouches_(inEvent, this.cancelOut_);
- * @private
-ol.pointer.TouchSource.prototype.cancelOut_ = function(browserEvent, inPointer) {
- this.dispatcher.cancel(inPointer, browserEvent);
- * @private
-ol.pointer.TouchSource.prototype.cleanUpPointer_ = function(inPointer) {
- delete this.pointerMap[inPointer.pointerId];
- this.removePrimaryPointer_(inPointer);
- * Prevent synth mouse events from creating pointer events.
- * @private
-ol.pointer.TouchSource.prototype.dedupSynthMouse_ = function(inEvent) {
- var lts = this.mouseSource.lastTouches;
- var t = inEvent.changedTouches[0];
- // only the primary finger will synth mouse events
- if (this.isPrimaryTouch_(t)) {
- // remember x/y of last touch
- var lt = [t.clientX, t.clientY];
- lts.push(lt);
- setTimeout(function() {
- // remove touch after timeout
- ol.array.remove(lts, lt);
- }, ol.pointer.TouchSource.DEDUP_TIMEOUT);
-// met:
-// distribution.
-goog.provide('ol.pointer.PointerEventHandler');
-goog.require('ol.events');
-goog.require('ol.events.EventTarget');
-goog.require('ol.has');
-goog.require('ol.pointer.EventType');
-goog.require('ol.pointer.MsSource');
-goog.require('ol.pointer.NativeSource');
-goog.require('ol.pointer.PointerEvent');
-goog.require('ol.pointer.TouchSource');
- * @constructor
- * @extends {ol.events.EventTarget}
- * @param {Element|HTMLDocument} element Viewport element.
-ol.pointer.PointerEventHandler = function(element) {
- ol.events.EventTarget.call(this);
- * @const
- * @private
- * @type {Element|HTMLDocument}
- this.element_ = element;
- * @const
- this.pointerMap = {};
- * @type {Object.<string, function(Event)>}
- * @private
- this.eventMap_ = {};
- * @type {Array.<ol.pointer.EventSource>}
- * @private
- this.eventSourceList_ = [];
- this.registerSources();
-ol.inherits(ol.pointer.PointerEventHandler, ol.events.EventTarget);
- * Set up the event sources (mouse, touch and native pointers)
- * that generate pointer events.
-ol.pointer.PointerEventHandler.prototype.registerSources = function() {
- if (ol.has.POINTER) {
- this.registerSource('native', new ol.pointer.NativeSource(this));
- } else if (ol.has.MSPOINTER) {
- this.registerSource('ms', new ol.pointer.MsSource(this));
- } else {
- var mouseSource = new ol.pointer.MouseSource(this);
- this.registerSource('mouse', mouseSource);
- if (ol.has.TOUCH) {
- this.registerSource('touch',
- new ol.pointer.TouchSource(this, mouseSource));
- // register events on the viewport element
- this.register_();
- * Add a new event source that will generate pointer events.
- * @param {string} name A name for the event source
- * @param {ol.pointer.EventSource} source The source event.
-ol.pointer.PointerEventHandler.prototype.registerSource = function(name, source) {
- var s = source;
- var newEvents = s.getEvents();
- if (newEvents) {
- newEvents.forEach(function(e) {
- var handler = s.getHandlerForEvent(e);
- if (handler) {
- this.eventMap_[e] = handler.bind(s);
- }, this);
- this.eventSourceList_.push(s);
- * Set up the events for all registered event sources.
- * @private
-ol.pointer.PointerEventHandler.prototype.register_ = function() {
- var l = this.eventSourceList_.length;
- var eventSource;
- eventSource = this.eventSourceList_[i];
- this.addEvents_(eventSource.getEvents());
- * Remove all registered events.
- * @private
-ol.pointer.PointerEventHandler.prototype.unregister_ = function() {
- var eventSource;
- this.removeEvents_(eventSource.getEvents());
- * Calls the right handler for a new event.
- * @private
- * @param {Event} inEvent Browser event.
-ol.pointer.PointerEventHandler.prototype.eventHandler_ = function(inEvent) {
- var type = inEvent.type;
- var handler = this.eventMap_[type];
- if (handler) {
- handler(inEvent);
- * Setup listeners for the given events.
- * @private
- * @param {Array.<string>} events List of events.
-ol.pointer.PointerEventHandler.prototype.addEvents_ = function(events) {
- events.forEach(function(eventName) {
- ol.events.listen(this.element_, eventName, this.eventHandler_, this);
- }, this);
- * Unregister listeners for the given events.
- * @private
-ol.pointer.PointerEventHandler.prototype.removeEvents_ = function(events) {
- events.forEach(function(e) {
- ol.events.unlisten(this.element_, e, this.eventHandler_, this);
- }, this);
- * Returns a snapshot of inEvent, with writable properties.
- * @param {Event|Touch} inEvent An event that contains
- * properties to copy.
- * @return {Object} An object containing shallow copies of
- * `inEvent`'s properties.
-ol.pointer.PointerEventHandler.prototype.cloneEvent = function(event, inEvent) {
- var eventCopy = {}, p;
- for (var i = 0, ii = ol.pointer.PointerEventHandler.CLONE_PROPS.length; i < ii; i++) {
- p = ol.pointer.PointerEventHandler.CLONE_PROPS[i][0];
- eventCopy[p] = event[p] || inEvent[p] || ol.pointer.PointerEventHandler.CLONE_PROPS[i][1];
- return eventCopy;
-// EVENTS
- * Triggers a 'pointerdown' event.
- * @param {Object} data Pointer event data.
- * @param {Event} event The event.
-ol.pointer.PointerEventHandler.prototype.down = function(data, event) {
- this.fireEvent(ol.pointer.EventType.POINTERDOWN, data, event);
- * Triggers a 'pointermove' event.
-ol.pointer.PointerEventHandler.prototype.move = function(data, event) {
- this.fireEvent(ol.pointer.EventType.POINTERMOVE, data, event);
- * Triggers a 'pointerup' event.
-ol.pointer.PointerEventHandler.prototype.up = function(data, event) {
- this.fireEvent(ol.pointer.EventType.POINTERUP, data, event);
- * Triggers a 'pointerenter' event.
-ol.pointer.PointerEventHandler.prototype.enter = function(data, event) {
- data.bubbles = false;
- this.fireEvent(ol.pointer.EventType.POINTERENTER, data, event);
- * Triggers a 'pointerleave' event.
-ol.pointer.PointerEventHandler.prototype.leave = function(data, event) {
- this.fireEvent(ol.pointer.EventType.POINTERLEAVE, data, event);
- * Triggers a 'pointerover' event.
-ol.pointer.PointerEventHandler.prototype.over = function(data, event) {
- data.bubbles = true;
- this.fireEvent(ol.pointer.EventType.POINTEROVER, data, event);
- * Triggers a 'pointerout' event.
-ol.pointer.PointerEventHandler.prototype.out = function(data, event) {
- this.fireEvent(ol.pointer.EventType.POINTEROUT, data, event);
- * Triggers a 'pointercancel' event.
-ol.pointer.PointerEventHandler.prototype.cancel = function(data, event) {
- this.fireEvent(ol.pointer.EventType.POINTERCANCEL, data, event);
- * Triggers a combination of 'pointerout' and 'pointerleave' events.
-ol.pointer.PointerEventHandler.prototype.leaveOut = function(data, event) {
- this.out(data, event);
- if (!this.contains_(data.target, data.relatedTarget)) {
- this.leave(data, event);
- * Triggers a combination of 'pointerover' and 'pointerevents' events.
-ol.pointer.PointerEventHandler.prototype.enterOver = function(data, event) {
- this.over(data, event);
- this.enter(data, event);
- * @private
- * @param {Element} container The container element.
- * @param {Element} contained The contained element.
- * @return {boolean} Returns true if the container element
- * contains the other element.
-ol.pointer.PointerEventHandler.prototype.contains_ = function(container, contained) {
- if (!container || !contained) {
- return false;
- return container.contains(contained);
-// EVENT CREATION AND TRACKING
- * Creates a new Event of type `inType`, based on the information in
- * `data`.
- * @param {string} inType A string representing the type of event to create.
- * @return {ol.pointer.PointerEvent} A PointerEvent of type `inType`.
-ol.pointer.PointerEventHandler.prototype.makeEvent = function(inType, data, event) {
- return new ol.pointer.PointerEvent(inType, event, data);
- * Make and dispatch an event in one call.
- * @param {string} inType A string representing the type of event.
-ol.pointer.PointerEventHandler.prototype.fireEvent = function(inType, data, event) {
- var e = this.makeEvent(inType, data, event);
- this.dispatchEvent(e);
- * Creates a pointer event from a native pointer event
- * and dispatches this event.
- * @param {Event} event A platform event with a target.
-ol.pointer.PointerEventHandler.prototype.fireNativeEvent = function(event) {
- var e = this.makeEvent(event.type, event, event);
- * Wrap a native mouse event into a pointer event.
- * This proxy method is required for the legacy IE support.
- * @param {string} eventType The pointer event type.
- * @return {ol.pointer.PointerEvent} The wrapped event.
-ol.pointer.PointerEventHandler.prototype.wrapMouseEvent = function(eventType, event) {
- var pointerEvent = this.makeEvent(
- eventType, ol.pointer.MouseSource.prepareEvent(event, this), event);
- return pointerEvent;
- * @inheritDoc
-ol.pointer.PointerEventHandler.prototype.disposeInternal = function() {
- this.unregister_();
- ol.events.EventTarget.prototype.disposeInternal.call(this);
- * Properties to copy when cloning an event, with default values.
- * @type {Array.<Array>}
-ol.pointer.PointerEventHandler.CLONE_PROPS = [
- // MouseEvent
- ['bubbles', false],
- ['cancelable', false],
- ['view', null],
- ['detail', null],
- ['screenX', 0],
- ['screenY', 0],
- ['clientX', 0],
- ['clientY', 0],
- ['ctrlKey', false],
- ['altKey', false],
- ['shiftKey', false],
- ['metaKey', false],
- ['button', 0],
- ['relatedTarget', null],
- // DOM Level 3
- ['buttons', 0],
- // PointerEvent
- ['pointerId', 0],
- ['width', 0],
- ['height', 0],
- ['pressure', 0],
- ['tiltX', 0],
- ['tiltY', 0],
- ['pointerType', ''],
- ['hwTimestamp', 0],
- ['isPrimary', false],
- // event instance
- ['type', ''],
- ['target', null],
- ['currentTarget', null],
- ['which', 0]
-goog.provide('ol.MapBrowserEventHandler');
-goog.require('ol');
-goog.require('ol.MapBrowserEventType');
-goog.require('ol.MapBrowserPointerEvent');
-goog.require('ol.pointer.PointerEventHandler');
- * @param {ol.Map} map The map with the viewport to listen to events on.
- * @constructor
-ol.MapBrowserEventHandler = function(map) {
- * This is the element that we will listen to the real events on.
- * @type {ol.Map}
- * @private
- this.map_ = map;
- * @type {number}
- * @private
- this.clickTimeoutId_ = 0;
- * @type {boolean}
- * @private
- this.dragging_ = false;
- * @type {!Array.<ol.EventsKey>}
- * @private
- this.dragListenerKeys_ = [];
- * The most recent "down" type event (or null if none have occurred).
- * Set on pointerdown.
- * @private
- this.down_ = null;
- var element = this.map_.getViewport();
- * @type {number}
- * @private
- this.activePointers_ = 0;
- * @type {!Object.<number, boolean>}
- * @private
- this.trackedTouches_ = {};
- * Event handler which generates pointer events for
- * the viewport element.
- * @private
- this.pointerEventHandler_ = new ol.pointer.PointerEventHandler(element);
- * the document (used when dragging).
- * @private
- this.documentPointerEventHandler_ = null;
- * @type {?ol.EventsKey}
- * @private
- this.pointerdownListenerKey_ = ol.events.listen(this.pointerEventHandler_,
- ol.pointer.EventType.POINTERDOWN,
- this.handlePointerDown_, this);
- * @private
- this.relayedListenerKey_ = ol.events.listen(this.pointerEventHandler_,
- ol.pointer.EventType.POINTERMOVE,
- this.relayEvent_, this);
-ol.inherits(ol.MapBrowserEventHandler, ol.events.EventTarget);
- * @private
-ol.MapBrowserEventHandler.prototype.emulateClick_ = function(pointerEvent) {
- var newEvent = new ol.MapBrowserPointerEvent(
- ol.MapBrowserEventType.CLICK, this.map_, pointerEvent);
- this.dispatchEvent(newEvent);
- if (this.clickTimeoutId_ !== 0) {
- // double-click
- clearTimeout(this.clickTimeoutId_);
- newEvent = new ol.MapBrowserPointerEvent(
- ol.MapBrowserEventType.DBLCLICK, this.map_, pointerEvent);
- } else {
- // click
- this.clickTimeoutId_ = setTimeout(function() {
- ol.MapBrowserEventType.SINGLECLICK, this.map_, pointerEvent);
- }.bind(this), 250);
- * Keeps track on how many pointers are currently active.
- * @private
-ol.MapBrowserEventHandler.prototype.updateActivePointers_ = function(pointerEvent) {
- var event = pointerEvent;
- if (event.type == ol.MapBrowserEventType.POINTERUP ||
- event.type == ol.MapBrowserEventType.POINTERCANCEL) {
- delete this.trackedTouches_[event.pointerId];
- } else if (event.type == ol.MapBrowserEventType.POINTERDOWN) {
- this.trackedTouches_[event.pointerId] = true;
- this.activePointers_ = Object.keys(this.trackedTouches_).length;
- * @private
-ol.MapBrowserEventHandler.prototype.handlePointerUp_ = function(pointerEvent) {
- this.updateActivePointers_(pointerEvent);
- ol.MapBrowserEventType.POINTERUP, this.map_, pointerEvent);
- // We emulate click events on left mouse button click, touch contact, and pen
- // contact. isMouseActionButton returns true in these cases (evt.button is set
- // to 0).
- // See http://www.w3.org/TR/pointerevents/#button-states
- if (!this.dragging_ && this.isMouseActionButton_(pointerEvent)) {
- this.emulateClick_(this.down_);
- if (this.activePointers_ === 0) {
- this.dragListenerKeys_.forEach(ol.events.unlistenByKey);
- this.dragListenerKeys_.length = 0;
- this.documentPointerEventHandler_.dispose();
- * @return {boolean} If the left mouse button was pressed.
- * @private
-ol.MapBrowserEventHandler.prototype.isMouseActionButton_ = function(pointerEvent) {
- return pointerEvent.button === 0;
- * @private
-ol.MapBrowserEventHandler.prototype.handlePointerDown_ = function(pointerEvent) {
- ol.MapBrowserEventType.POINTERDOWN, this.map_, pointerEvent);
- this.down_ = pointerEvent;
- if (this.dragListenerKeys_.length === 0) {
- /* Set up a pointer event handler on the `document`,
- * which is required when the pointer is moved outside
- * the viewport when dragging.
- new ol.pointer.PointerEventHandler(document);
- this.dragListenerKeys_.push(
- ol.events.listen(this.documentPointerEventHandler_,
- ol.MapBrowserEventType.POINTERMOVE,
- this.handlePointerMove_, this),
- this.handlePointerUp_, this),
- /* Note that the listener for `pointercancel is set up on
- * `pointerEventHandler_` and not `documentPointerEventHandler_` like
- * the `pointerup` and `pointermove` listeners.
- * The reason for this is the following: `TouchSource.vacuumTouches_()`
- * issues `pointercancel` events, when there was no `touchend` for a
- * `touchstart`. Now, let's say a first `touchstart` is registered on
- * `pointerEventHandler_`. The `documentPointerEventHandler_` is set up.
- * But `documentPointerEventHandler_` doesn't know about the first
- * `touchstart`. If there is no `touchend` for the `touchstart`, we can
- * only receive a `touchcancel` from `pointerEventHandler_`, because it is
- * only registered there.
- ol.events.listen(this.pointerEventHandler_,
- ol.MapBrowserEventType.POINTERCANCEL,
- * @private
-ol.MapBrowserEventHandler.prototype.handlePointerMove_ = function(pointerEvent) {
- // Fix IE10 on windows Surface : When you tap the tablet, it triggers
- // multiple pointermove events between pointerdown and pointerup with
- // the exact same coordinates of the pointerdown event. To avoid a
- // 'false' touchmove event to be dispatched , we test if the pointer
- // effectively moved.
- if (this.isMoving_(pointerEvent)) {
- this.dragging_ = true;
- ol.MapBrowserEventType.POINTERDRAG, this.map_, pointerEvent,
- this.dragging_);
- // Some native android browser triggers mousemove events during small period
- // of time. See: https://code.google.com/p/android/issues/detail?id=5491 or
- // https://code.google.com/p/android/issues/detail?id=19827
- // ex: Galaxy Tab P3110 + Android 4.1.1
- pointerEvent.preventDefault();
- * Wrap and relay a pointer event. Note that this requires that the type
- * string for the MapBrowserPointerEvent matches the PointerEvent type.
- * @private
-ol.MapBrowserEventHandler.prototype.relayEvent_ = function(pointerEvent) {
- var dragging = !!(this.down_ && this.isMoving_(pointerEvent));
- this.dispatchEvent(new ol.MapBrowserPointerEvent(
- pointerEvent.type, this.map_, pointerEvent, dragging));
- * @return {boolean} Is moving.
- * @private
-ol.MapBrowserEventHandler.prototype.isMoving_ = function(pointerEvent) {
- return pointerEvent.clientX != this.down_.clientX ||
- pointerEvent.clientY != this.down_.clientY;
- * @inheritDoc
-ol.MapBrowserEventHandler.prototype.disposeInternal = function() {
- if (this.relayedListenerKey_) {
- ol.events.unlistenByKey(this.relayedListenerKey_);
- this.relayedListenerKey_ = null;
- if (this.pointerdownListenerKey_) {
- ol.events.unlistenByKey(this.pointerdownListenerKey_);
- this.pointerdownListenerKey_ = null;
- if (this.documentPointerEventHandler_) {
- if (this.pointerEventHandler_) {
- this.pointerEventHandler_.dispose();
- this.pointerEventHandler_ = null;
-goog.provide('ol.MapProperty');
- * @enum {string}
-ol.MapProperty = {
- LAYERGROUP: 'layergroup',
- SIZE: 'size',
- TARGET: 'target',
- VIEW: 'view'
-goog.provide('ol.TileState');
- * @enum {number}
-ol.TileState = {
- IDLE: 0,
- LOADING: 1,
- LOADED: 2,
- ERROR: 3,
- EMPTY: 4,
- ABORT: 5
-goog.provide('ol.structs.PriorityQueue');
-goog.require('ol.asserts');
-goog.require('ol.obj');
- * Priority queue.
- * The implementation is inspired from the Closure Library's Heap class and
- * Python's heapq module.
- * @see http://closure-library.googlecode.com/svn/docs/closure_goog_structs_heap.js.source.html
- * @see http://hg.python.org/cpython/file/2.7/Lib/heapq.py
- * @constructor
- * @param {function(T): number} priorityFunction Priority function.
- * @param {function(T): string} keyFunction Key function.
- * @struct
- * @template T
-ol.structs.PriorityQueue = function(priorityFunction, keyFunction) {
- * @type {function(T): number}
- * @private
- this.priorityFunction_ = priorityFunction;
- * @type {function(T): string}
- * @private
- this.keyFunction_ = keyFunction;
- * @type {Array.<T>}
- * @private
- this.elements_ = [];
- * @type {Array.<number>}
- * @private
- this.priorities_ = [];
- * @type {Object.<string, boolean>}
- * @private
- this.queuedElements_ = {};
- * @const
- * @type {number}
-ol.structs.PriorityQueue.DROP = Infinity;
- * FIXME empty description for jsdoc
-ol.structs.PriorityQueue.prototype.clear = function() {
- this.elements_.length = 0;
- this.priorities_.length = 0;
- ol.obj.clear(this.queuedElements_);
- * Remove and return the highest-priority element. O(log N).
- * @return {T} Element.
-ol.structs.PriorityQueue.prototype.dequeue = function() {
- var elements = this.elements_;
- var priorities = this.priorities_;
- var element = elements[0];
- if (elements.length == 1) {
- elements.length = 0;
- priorities.length = 0;
- } else {
- elements[0] = elements.pop();
- priorities[0] = priorities.pop();
- this.siftUp_(0);
- var elementKey = this.keyFunction_(element);
- delete this.queuedElements_[elementKey];
- return element;
- * Enqueue an element. O(log N).
- * @param {T} element Element.
- * @return {boolean} The element was added to the queue.
-ol.structs.PriorityQueue.prototype.enqueue = function(element) {
- ol.asserts.assert(!(this.keyFunction_(element) in this.queuedElements_),
- 31); // Tried to enqueue an `element` that was already added to the queue
- var priority = this.priorityFunction_(element);
- if (priority != ol.structs.PriorityQueue.DROP) {
- this.elements_.push(element);
- this.priorities_.push(priority);
- this.queuedElements_[this.keyFunction_(element)] = true;
- this.siftDown_(0, this.elements_.length - 1);
- return true;
- return false;
- * @return {number} Count.
-ol.structs.PriorityQueue.prototype.getCount = function() {
- return this.elements_.length;
- * Gets the index of the left child of the node at the given index.
- * @param {number} index The index of the node to get the left child for.
- * @return {number} The index of the left child.
- * @private
-ol.structs.PriorityQueue.prototype.getLeftChildIndex_ = function(index) {
- return index * 2 + 1;
- * Gets the index of the right child of the node at the given index.
- * @param {number} index The index of the node to get the right child for.
- * @return {number} The index of the right child.
- * @private
-ol.structs.PriorityQueue.prototype.getRightChildIndex_ = function(index) {
- return index * 2 + 2;
- * Gets the index of the parent of the node at the given index.
- * @param {number} index The index of the node to get the parent for.
- * @return {number} The index of the parent.
- * @private
-ol.structs.PriorityQueue.prototype.getParentIndex_ = function(index) {
- return (index - 1) >> 1;
- * Make this a heap. O(N).
- * @private
-ol.structs.PriorityQueue.prototype.heapify_ = function() {
- var i;
- for (i = (this.elements_.length >> 1) - 1; i >= 0; i--) {
- this.siftUp_(i);
- * @return {boolean} Is empty.
-ol.structs.PriorityQueue.prototype.isEmpty = function() {
- return this.elements_.length === 0;
- * @param {string} key Key.
- * @return {boolean} Is key queued.
-ol.structs.PriorityQueue.prototype.isKeyQueued = function(key) {
- return key in this.queuedElements_;
- * @return {boolean} Is queued.
-ol.structs.PriorityQueue.prototype.isQueued = function(element) {
- return this.isKeyQueued(this.keyFunction_(element));
- * @param {number} index The index of the node to move down.
- * @private
-ol.structs.PriorityQueue.prototype.siftUp_ = function(index) {
- var count = elements.length;
- var element = elements[index];
- var priority = priorities[index];
- var startIndex = index;
- while (index < (count >> 1)) {
- var lIndex = this.getLeftChildIndex_(index);
- var rIndex = this.getRightChildIndex_(index);
- var smallerChildIndex = rIndex < count &&
- priorities[rIndex] < priorities[lIndex] ?
- rIndex : lIndex;
- elements[index] = elements[smallerChildIndex];
- priorities[index] = priorities[smallerChildIndex];
- index = smallerChildIndex;
- elements[index] = element;
- priorities[index] = priority;
- this.siftDown_(startIndex, index);
- * @param {number} startIndex The index of the root.
- * @param {number} index The index of the node to move up.
- * @private
-ol.structs.PriorityQueue.prototype.siftDown_ = function(startIndex, index) {
- while (index > startIndex) {
- var parentIndex = this.getParentIndex_(index);
- if (priorities[parentIndex] > priority) {
- elements[index] = elements[parentIndex];
- priorities[index] = priorities[parentIndex];
- index = parentIndex;
- } else {
- break;
-ol.structs.PriorityQueue.prototype.reprioritize = function() {
- var priorityFunction = this.priorityFunction_;
- var index = 0;
- var n = elements.length;
- var element, i, priority;
- for (i = 0; i < n; ++i) {
- element = elements[i];
- priority = priorityFunction(element);
- if (priority == ol.structs.PriorityQueue.DROP) {
- delete this.queuedElements_[this.keyFunction_(element)];
- } else {
- elements[index++] = element;
- elements.length = index;
- priorities.length = index;
- this.heapify_();
-goog.provide('ol.TileQueue');
-goog.require('ol.TileState');
-goog.require('ol.events.EventType');
-goog.require('ol.structs.PriorityQueue');
- * @constructor
- * @extends {ol.structs.PriorityQueue.<Array>}
- * @param {ol.TilePriorityFunction} tilePriorityFunction
- * Tile priority function.
- * @param {function(): ?} tileChangeCallback
- * Function called on each tile change event.
- * @struct
-ol.TileQueue = function(tilePriorityFunction, tileChangeCallback) {
- ol.structs.PriorityQueue.call(
- this,
- * @param {Array} element Element.
- * @return {number} Priority.
- function(element) {
- return tilePriorityFunction.apply(null, element);
- * @return {string} Key.
- return /** @type {ol.Tile} */ (element[0]).getKey();
- * @private
- * @type {function(): ?}
- this.tileChangeCallback_ = tileChangeCallback;
- * @private
- * @type {number}
- this.tilesLoading_ = 0;
- * @private
- * @type {!Object.<string,boolean>}
- this.tilesLoadingKeys_ = {};
-ol.inherits(ol.TileQueue, ol.structs.PriorityQueue);
- * @inheritDoc
-ol.TileQueue.prototype.enqueue = function(element) {
- var added = ol.structs.PriorityQueue.prototype.enqueue.call(this, element);
- if (added) {
- var tile = element[0];
- ol.events.listen(tile, ol.events.EventType.CHANGE,
- this.handleTileChange, this);
- return added;
- * @return {number} Number of tiles loading.
-ol.TileQueue.prototype.getTilesLoading = function() {
- return this.tilesLoading_;
- * @param {ol.events.Event} event Event.
- * @protected
-ol.TileQueue.prototype.handleTileChange = function(event) {
- var tile = /** @type {ol.Tile} */ (event.target);
- var state = tile.getState();
- if (state === ol.TileState.LOADED || state === ol.TileState.ERROR ||
- state === ol.TileState.EMPTY || state === ol.TileState.ABORT) {
- ol.events.unlisten(tile, ol.events.EventType.CHANGE,
- var tileKey = tile.getKey();
- if (tileKey in this.tilesLoadingKeys_) {
- delete this.tilesLoadingKeys_[tileKey];
- --this.tilesLoading_;
- this.tileChangeCallback_();
- * @param {number} maxTotalLoading Maximum number tiles to load simultaneously.
- * @param {number} maxNewLoads Maximum number of new tiles to load.
-ol.TileQueue.prototype.loadMoreTiles = function(maxTotalLoading, maxNewLoads) {
- var newLoads = 0;
- var tile, tileKey;
- while (this.tilesLoading_ < maxTotalLoading && newLoads < maxNewLoads &&
- this.getCount() > 0) {
- tile = /** @type {ol.Tile} */ (this.dequeue()[0]);
- tileKey = tile.getKey();
- if (tile.getState() === ol.TileState.IDLE && !(tileKey in this.tilesLoadingKeys_)) {
- this.tilesLoadingKeys_[tileKey] = true;
- ++this.tilesLoading_;
- ++newLoads;
- tile.load();
-goog.provide('ol.ResolutionConstraint');
-goog.require('ol.math');
- * @param {Array.<number>} resolutions Resolutions.
- * @return {ol.ResolutionConstraintType} Zoom function.
-ol.ResolutionConstraint.createSnapToResolutions = function(resolutions) {
- return (
- * @param {number|undefined} resolution Resolution.
- * @param {number} delta Delta.
- * @param {number} direction Direction.
- * @return {number|undefined} Resolution.
- function(resolution, delta, direction) {
- if (resolution !== undefined) {
- var z =
- ol.array.linearFindNearest(resolutions, resolution, direction);
- z = ol.math.clamp(z + delta, 0, resolutions.length - 1);
- var index = Math.floor(z);
- if (z != index && index < resolutions.length - 1) {
- var power = resolutions[index] / resolutions[index + 1];
- return resolutions[index] / Math.pow(power, z - index);
- } else {
- return resolutions[index];
- } else {
- return undefined;
- * @param {number} power Power.
- * @param {number} maxResolution Maximum resolution.
- * @param {number=} opt_maxLevel Maximum level.
-ol.ResolutionConstraint.createSnapToPower = function(power, maxResolution, opt_maxLevel) {
- return (
- var offset = -direction / 2 + 0.5;
- var oldLevel = Math.floor(
- Math.log(maxResolution / resolution) / Math.log(power) + offset);
- var newLevel = Math.max(oldLevel + delta, 0);
- if (opt_maxLevel !== undefined) {
- newLevel = Math.min(newLevel, opt_maxLevel);
- return maxResolution / Math.pow(power, newLevel);
- } else {
- return undefined;
-goog.provide('ol.RotationConstraint');
- * @param {number|undefined} rotation Rotation.
- * @return {number|undefined} Rotation.
-ol.RotationConstraint.disable = function(rotation, delta) {
- if (rotation !== undefined) {
- return 0;
- } else {
- return undefined;
-ol.RotationConstraint.none = function(rotation, delta) {
- return rotation + delta;
- } else {
- return undefined;
- * @param {number} n N.
- * @return {ol.RotationConstraintType} Rotation constraint.
-ol.RotationConstraint.createSnapToN = function(n) {
- var theta = 2 * Math.PI / n;
- return (
- function(rotation, delta) {
- rotation = Math.floor((rotation + delta) / theta + 0.5) * theta;
- return rotation;
- } else {
- return undefined;
- * @param {number=} opt_tolerance Tolerance.
-ol.RotationConstraint.createSnapToZero = function(opt_tolerance) {
- var tolerance = opt_tolerance || ol.math.toRadians(5);
- return (
- if (Math.abs(rotation + delta) <= tolerance) {
- return 0;
- } else {
- } else {
- return undefined;
-goog.provide('ol.ViewHint');
- * @enum {number}
-ol.ViewHint = {
- ANIMATING: 0,
- INTERACTING: 1
-goog.provide('ol.ViewProperty');
- * @enum {string}
-ol.ViewProperty = {
- CENTER: 'center',
- RESOLUTION: 'resolution',
- ROTATION: 'rotation'
-goog.provide('ol.string');
- * @param {number} number Number to be formatted
- * @param {number} width The desired width
- * @param {number=} opt_precision Precision of the output string (i.e. number of decimal places)
- * @returns {string} Formatted string
-ol.string.padNumber = function(number, width, opt_precision) {
- var numberString = opt_precision !== undefined ? number.toFixed(opt_precision) : '' + number;
- var decimal = numberString.indexOf('.');
- decimal = decimal === -1 ? numberString.length : decimal;
- return decimal > width ? numberString : new Array(1 + width - decimal).join('0') + numberString;
- * Adapted from https://github.com/omichelsen/compare-versions/blob/master/index.js
- * @param {string|number} v1 First version
- * @param {string|number} v2 Second version
- * @returns {number} Value
-ol.string.compareVersions = function(v1, v2) {
- var s1 = ('' + v1).split('.');
- var s2 = ('' + v2).split('.');
- for (var i = 0; i < Math.max(s1.length, s2.length); i++) {
- var n1 = parseInt(s1[i] || '0', 10);
- var n2 = parseInt(s2[i] || '0', 10);
- if (n1 > n2) {
- return 1;
- if (n2 > n1) {
- return -1;
- return 0;
-goog.provide('ol.coordinate');
-goog.require('ol.string');
- * Add `delta` to `coordinate`. `coordinate` is modified in place and returned
- * by the function.
- * Example:
- * var coord = [7.85, 47.983333];
- * ol.coordinate.add(coord, [-2, 4]);
- * // coord is now [5.85, 51.983333]
- * @param {ol.Coordinate} coordinate Coordinate.
- * @param {ol.Coordinate} delta Delta.
- * @return {ol.Coordinate} The input coordinate adjusted by the given delta.
- * @api
-ol.coordinate.add = function(coordinate, delta) {
- coordinate[0] += delta[0];
- coordinate[1] += delta[1];
- return coordinate;
- * Calculates the point closest to the passed coordinate on the passed segment.
- * This is the foot of the perpendicular of the coordinate to the segment when
- * the foot is on the segment, or the closest segment coordinate when the foot
- * is outside the segment.
- * @param {ol.Coordinate} coordinate The coordinate.
- * @param {Array.<ol.Coordinate>} segment The two coordinates of the segment.
- * @return {ol.Coordinate} The foot of the perpendicular of the coordinate to
- * the segment.
-ol.coordinate.closestOnSegment = function(coordinate, segment) {
- var x0 = coordinate[0];
- var y0 = coordinate[1];
- var start = segment[0];
- var end = segment[1];
- var x1 = start[0];
- var y1 = start[1];
- var x2 = end[0];
- var y2 = end[1];
- var dx = x2 - x1;
- var dy = y2 - y1;
- var along = (dx === 0 && dy === 0) ? 0 :
- ((dx * (x0 - x1)) + (dy * (y0 - y1))) / ((dx * dx + dy * dy) || 0);
- var x, y;
- if (along <= 0) {
- x = x1;
- y = y1;
- } else if (along >= 1) {
- x = x2;
- y = y2;
- } else {
- x = x1 + along * dx;
- y = y1 + along * dy;
- return [x, y];
- * Returns a {@link ol.CoordinateFormatType} function that can be used to format
- * a {ol.Coordinate} to a string.
- * Example without specifying the fractional digits:
- * var stringifyFunc = ol.coordinate.createStringXY();
- * var out = stringifyFunc(coord);
- * // out is now '8, 48'
- * Example with explicitly specifying 2 fractional digits:
- * var stringifyFunc = ol.coordinate.createStringXY(2);
- * // out is now '7.85, 47.98'
- * @param {number=} opt_fractionDigits The number of digits to include
- * after the decimal point. Default is `0`.
- * @return {ol.CoordinateFormatType} Coordinate format.
- * @api
-ol.coordinate.createStringXY = function(opt_fractionDigits) {
- return (
- * @param {ol.Coordinate|undefined} coordinate Coordinate.
- * @return {string} String XY.
- function(coordinate) {
- return ol.coordinate.toStringXY(coordinate, opt_fractionDigits);
- * @private
- * @param {number} degrees Degrees.
- * @param {string} hemispheres Hemispheres.
- * @return {string} String.
-ol.coordinate.degreesToStringHDMS_ = function(degrees, hemispheres, opt_fractionDigits) {
- var normalizedDegrees = ol.math.modulo(degrees + 180, 360) - 180;
- var x = Math.abs(3600 * normalizedDegrees);
- var dflPrecision = opt_fractionDigits || 0;
- var precision = Math.pow(10, dflPrecision);
- var deg = Math.floor(x / 3600);
- var min = Math.floor((x - deg * 3600) / 60);
- var sec = x - (deg * 3600) - (min * 60);
- sec = Math.ceil(sec * precision) / precision;
- if (sec >= 60) {
- sec = 0;
- min += 1;
- if (min >= 60) {
- min = 0;
- deg += 1;
- return deg + '\u00b0 ' + ol.string.padNumber(min, 2) + '\u2032 ' +
- ol.string.padNumber(sec, 2, dflPrecision) + '\u2033 ' +
- hemispheres.charAt(normalizedDegrees < 0 ? 1 : 0);
- * Transforms the given {@link ol.Coordinate} to a string using the given string
- * template. The strings `{x}` and `{y}` in the template will be replaced with
- * the first and second coordinate values respectively.
- * var template = 'Coordinate is ({x}|{y}).';
- * var out = ol.coordinate.format(coord, template);
- * // out is now 'Coordinate is (8|48).'
- * Example explicitly specifying the fractional digits:
- * var out = ol.coordinate.format(coord, template, 2);
- * // out is now 'Coordinate is (7.85|47.98).'
- * @param {string} template A template string with `{x}` and `{y}` placeholders
- * that will be replaced by first and second coordinate values.
- * @return {string} Formatted coordinate.
- * @api
-ol.coordinate.format = function(coordinate, template, opt_fractionDigits) {
- if (coordinate) {
- return template
- .replace('{x}', coordinate[0].toFixed(opt_fractionDigits))
- .replace('{y}', coordinate[1].toFixed(opt_fractionDigits));
- } else {
- return '';
- * @param {ol.Coordinate} coordinate1 First coordinate.
- * @param {ol.Coordinate} coordinate2 Second coordinate.
- * @return {boolean} Whether the passed coordinates are equal.
-ol.coordinate.equals = function(coordinate1, coordinate2) {
- var equals = true;
- for (var i = coordinate1.length - 1; i >= 0; --i) {
- if (coordinate1[i] != coordinate2[i]) {
- equals = false;
- break;
- return equals;
- * Rotate `coordinate` by `angle`. `coordinate` is modified in place and
- * returned by the function.
- * Example:
- * var rotateRadians = Math.PI / 2; // 90 degrees
- * ol.coordinate.rotate(coord, rotateRadians);
- * // coord is now [-47.983333, 7.85]
- * @param {number} angle Angle in radian.
- * @return {ol.Coordinate} Coordinate.
- * @api
-ol.coordinate.rotate = function(coordinate, angle) {
- var cosAngle = Math.cos(angle);
- var sinAngle = Math.sin(angle);
- var x = coordinate[0] * cosAngle - coordinate[1] * sinAngle;
- var y = coordinate[1] * cosAngle + coordinate[0] * sinAngle;
- coordinate[0] = x;
- coordinate[1] = y;
- * Scale `coordinate` by `scale`. `coordinate` is modified in place and returned
- * Example:
- * var scale = 1.2;
- * ol.coordinate.scale(coord, scale);
- * // coord is now [9.42, 57.5799996]
- * @param {number} scale Scale factor.
-ol.coordinate.scale = function(coordinate, scale) {
- coordinate[0] *= scale;
- coordinate[1] *= scale;
- * Subtract `delta` to `coordinate`. `coordinate` is modified in place and
-ol.coordinate.sub = function(coordinate, delta) {
- coordinate[0] -= delta[0];
- coordinate[1] -= delta[1];
- * @param {ol.Coordinate} coord1 First coordinate.
- * @param {ol.Coordinate} coord2 Second coordinate.
- * @return {number} Squared distance between coord1 and coord2.
-ol.coordinate.squaredDistance = function(coord1, coord2) {
- var dx = coord1[0] - coord2[0];
- var dy = coord1[1] - coord2[1];
- return dx * dx + dy * dy;
- * @return {number} Distance between coord1 and coord2.
-ol.coordinate.distance = function(coord1, coord2) {
- return Math.sqrt(ol.coordinate.squaredDistance(coord1, coord2));
- * Calculate the squared distance from a coordinate to a line segment.
- * @param {ol.Coordinate} coordinate Coordinate of the point.
- * @param {Array.<ol.Coordinate>} segment Line segment (2 coordinates).
- * @return {number} Squared distance from the point to the line segment.
-ol.coordinate.squaredDistanceToSegment = function(coordinate, segment) {
- return ol.coordinate.squaredDistance(coordinate,
- ol.coordinate.closestOnSegment(coordinate, segment));
- * Format a geographic coordinate with the hemisphere, degrees, minutes, and
- * seconds.
- * Example without specifying fractional digits:
- * var out = ol.coordinate.toStringHDMS(coord);
- * // out is now '47° 58′ 60″ N 7° 50′ 60″ E'
- * Example explicitly specifying 1 fractional digit:
- * var out = ol.coordinate.toStringHDMS(coord, 1);
- * // out is now '47° 58′ 60.0″ N 7° 50′ 60.0″ E'
- * @return {string} Hemisphere, degrees, minutes and seconds.
- * @api
-ol.coordinate.toStringHDMS = function(coordinate, opt_fractionDigits) {
- if (coordinate) {
- return ol.coordinate.degreesToStringHDMS_(coordinate[1], 'NS', opt_fractionDigits) + ' ' +
- ol.coordinate.degreesToStringHDMS_(coordinate[0], 'EW', opt_fractionDigits);
- } else {
- return '';
- * Format a coordinate as a comma delimited string.
- * var out = ol.coordinate.toStringXY(coord);
- * var out = ol.coordinate.toStringXY(coord, 1);
- * // out is now '7.8, 48.0'
- * @return {string} XY.
- * @api
-ol.coordinate.toStringXY = function(coordinate, opt_fractionDigits) {
- return ol.coordinate.format(coordinate, '{x}, {y}', opt_fractionDigits);
-goog.provide('ol.geom.GeometryType');
- * The geometry type. One of `'Point'`, `'LineString'`, `'LinearRing'`,
- * `'Polygon'`, `'MultiPoint'`, `'MultiLineString'`, `'MultiPolygon'`,
- * `'GeometryCollection'`, `'Circle'`.
- * @enum {string}
-ol.geom.GeometryType = {
- POINT: 'Point',
- LINE_STRING: 'LineString',
- LINEAR_RING: 'LinearRing',
- POLYGON: 'Polygon',
- MULTI_POINT: 'MultiPoint',
- MULTI_LINE_STRING: 'MultiLineString',
- MULTI_POLYGON: 'MultiPolygon',
- GEOMETRY_COLLECTION: 'GeometryCollection',
- CIRCLE: 'Circle'
-goog.provide('ol.geom.GeometryLayout');
- * The coordinate layout for geometries, indicating whether a 3rd or 4th z ('Z')
- * or measure ('M') coordinate is available. Supported values are `'XY'`,
- * `'XYZ'`, `'XYM'`, `'XYZM'`.
- * @enum {string}
-ol.geom.GeometryLayout = {
- XY: 'XY',
- XYZ: 'XYZ',
- XYM: 'XYM',
- XYZM: 'XYZM'
-goog.provide('ol.functions');
- * Always returns true.
- * @returns {boolean} true.
-ol.functions.TRUE = function() {
- return true;
- * Always returns false.
- * @returns {boolean} false.
-ol.functions.FALSE = function() {
- return false;
-goog.provide('ol.geom.Geometry');
-goog.require('ol.Object');
-goog.require('ol.extent');
-goog.require('ol.functions');
-goog.require('ol.proj');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * Base class for vector geometries.
- * To get notified of changes to the geometry, register a listener for the
- * generic `change` event on your geometry instance.
- * @constructor
- * @abstract
- * @extends {ol.Object}
- * @api
-ol.geom.Geometry = function() {
- ol.Object.call(this);
- * @private
- * @type {ol.Extent}
- this.extent_ = ol.extent.createEmpty();
- * @private
- * @type {number}
- this.extentRevision_ = -1;
- * @protected
- * @type {Object.<string, ol.geom.Geometry>}
- this.simplifiedGeometryCache = {};
- * @protected
- * @type {number}
- this.simplifiedGeometryMaxMinSquaredTolerance = 0;
- * @protected
- * @type {number}
- this.simplifiedGeometryRevision = 0;
-ol.inherits(ol.geom.Geometry, ol.Object);
- * Make a complete copy of the geometry.
- * @abstract
- * @return {!ol.geom.Geometry} Clone.
-ol.geom.Geometry.prototype.clone = function() {};
- * @abstract
- * @param {number} x X.
- * @param {number} y Y.
- * @param {ol.Coordinate} closestPoint Closest point.
- * @param {number} minSquaredDistance Minimum squared distance.
- * @return {number} Minimum squared distance.
-ol.geom.Geometry.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {};
- * Return the closest point of the geometry to the passed point as
- * {@link ol.Coordinate coordinate}.
- * @param {ol.Coordinate} point Point.
- * @param {ol.Coordinate=} opt_closestPoint Closest point.
- * @return {ol.Coordinate} Closest point.
- * @api
-ol.geom.Geometry.prototype.getClosestPoint = function(point, opt_closestPoint) {
- var closestPoint = opt_closestPoint ? opt_closestPoint : [NaN, NaN];
- this.closestPointXY(point[0], point[1], closestPoint, Infinity);
- return closestPoint;
- * Returns true if this geometry includes the specified coordinate. If the
- * coordinate is on the boundary of the geometry, returns false.
- * @return {boolean} Contains coordinate.
- * @api
-ol.geom.Geometry.prototype.intersectsCoordinate = function(coordinate) {
- return this.containsXY(coordinate[0], coordinate[1]);
- * @abstract
- * @param {ol.Extent} extent Extent.
- * @protected
- * @return {ol.Extent} extent Extent.
-ol.geom.Geometry.prototype.computeExtent = function(extent) {};
- * @return {boolean} Contains (x, y).
-ol.geom.Geometry.prototype.containsXY = ol.functions.FALSE;
- * Get the extent of the geometry.
- * @param {ol.Extent=} opt_extent Extent.
- * @api
-ol.geom.Geometry.prototype.getExtent = function(opt_extent) {
- if (this.extentRevision_ != this.getRevision()) {
- this.extent_ = this.computeExtent(this.extent_);
- this.extentRevision_ = this.getRevision();
- return ol.extent.returnOrUpdate(this.extent_, opt_extent);
- * Rotate the geometry around a given coordinate. This modifies the geometry
- * coordinates in place.
- * @abstract
- * @param {number} angle Rotation angle in radians.
- * @param {ol.Coordinate} anchor The rotation center.
- * @api
-ol.geom.Geometry.prototype.rotate = function(angle, anchor) {};
- * Scale the geometry (with an optional origin). This modifies the geometry
- * @abstract
- * @param {number} sx The scaling factor in the x-direction.
- * @param {number=} opt_sy The scaling factor in the y-direction (defaults to
- * sx).
- * @param {ol.Coordinate=} opt_anchor The scale origin (defaults to the center
- * of the geometry extent).
- * @api
-ol.geom.Geometry.prototype.scale = function(sx, opt_sy, opt_anchor) {};
- * Create a simplified version of this geometry. For linestrings, this uses
- * the the {@link
- * https://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
- * Douglas Peucker} algorithm. For polygons, a quantization-based
- * simplification is used to preserve topology.
- * @function
- * @param {number} tolerance The tolerance distance for simplification.
- * @return {ol.geom.Geometry} A new, simplified version of the original
- * geometry.
- * @api
-ol.geom.Geometry.prototype.simplify = function(tolerance) {
- return this.getSimplifiedGeometry(tolerance * tolerance);
- * Create a simplified version of this geometry using the Douglas Peucker
- * algorithm.
- * @see https://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
- * @abstract
- * @param {number} squaredTolerance Squared tolerance.
- * @return {ol.geom.Geometry} Simplified geometry.
-ol.geom.Geometry.prototype.getSimplifiedGeometry = function(squaredTolerance) {};
- * Get the type of this geometry.
- * @abstract
- * @return {ol.geom.GeometryType} Geometry type.
-ol.geom.Geometry.prototype.getType = function() {};
- * Apply a transform function to each coordinate of the geometry.
- * The geometry is modified in place.
- * If you do not want the geometry modified in place, first `clone()` it and
- * then use this function on the clone.
- * @abstract
- * @param {ol.TransformFunction} transformFn Transform.
-ol.geom.Geometry.prototype.applyTransform = function(transformFn) {};
- * Test if the geometry and the passed extent intersect.
- * @abstract
- * @return {boolean} `true` if the geometry and the extent intersect.
-ol.geom.Geometry.prototype.intersectsExtent = function(extent) {};
- * Translate the geometry. This modifies the geometry coordinates in place. If
- * instead you want a new geometry, first `clone()` this geometry.
- * @abstract
- * @param {number} deltaX Delta X.
- * @param {number} deltaY Delta Y.
-ol.geom.Geometry.prototype.translate = function(deltaX, deltaY) {};
- * Transform each coordinate of the geometry from one coordinate reference
- * system to another. The geometry is modified in place.
- * For example, a line will be transformed to a line and a circle to a circle.
- * @param {ol.ProjectionLike} source The current projection. Can be a
- * string identifier or a {@link ol.proj.Projection} object.
- * @param {ol.ProjectionLike} destination The desired projection. Can be a
- * @return {ol.geom.Geometry} This geometry. Note that original geometry is
- * modified in place.
- * @api
-ol.geom.Geometry.prototype.transform = function(source, destination) {
- this.applyTransform(ol.proj.getTransform(source, destination));
- return this;
-goog.provide('ol.geom.flat.transform');
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
- * @param {ol.Transform} transform Transform.
- * @param {Array.<number>=} opt_dest Destination.
- * @return {Array.<number>} Transformed coordinates.
-ol.geom.flat.transform.transform2D = function(flatCoordinates, offset, end, stride, transform, opt_dest) {
- var dest = opt_dest ? opt_dest : [];
- var i = 0;
- var j;
- for (j = offset; j < end; j += stride) {
- var x = flatCoordinates[j];
- var y = flatCoordinates[j + 1];
- dest[i++] = transform[0] * x + transform[2] * y + transform[4];
- dest[i++] = transform[1] * x + transform[3] * y + transform[5];
- if (opt_dest && dest.length != i) {
- dest.length = i;
- return dest;
- * @param {number} angle Angle.
- * @param {Array.<number>} anchor Rotation anchor point.
-ol.geom.flat.transform.rotate = function(flatCoordinates, offset, end, stride, angle, anchor, opt_dest) {
- var cos = Math.cos(angle);
- var sin = Math.sin(angle);
- var anchorX = anchor[0];
- var anchorY = anchor[1];
- var i = 0;
- for (var j = offset; j < end; j += stride) {
- var deltaX = flatCoordinates[j] - anchorX;
- var deltaY = flatCoordinates[j + 1] - anchorY;
- dest[i++] = anchorX + deltaX * cos - deltaY * sin;
- dest[i++] = anchorY + deltaX * sin + deltaY * cos;
- for (var k = j + 2; k < j + stride; ++k) {
- dest[i++] = flatCoordinates[k];
- dest.length = i;
- return dest;
- * Scale the coordinates.
- * @param {number} sx Scale factor in the x-direction.
- * @param {number} sy Scale factor in the y-direction.
- * @param {Array.<number>} anchor Scale anchor point.
-ol.geom.flat.transform.scale = function(flatCoordinates, offset, end, stride, sx, sy, anchor, opt_dest) {
- var i = 0;
- dest[i++] = anchorX + sx * deltaX;
- dest[i++] = anchorY + sy * deltaY;
- dest.length = i;
- return dest;
-ol.geom.flat.transform.translate = function(flatCoordinates, offset, end, stride, deltaX, deltaY, opt_dest) {
- var i = 0;
- var j, k;
- dest[i++] = flatCoordinates[j] + deltaX;
- dest[i++] = flatCoordinates[j + 1] + deltaY;
- for (k = j + 2; k < j + stride; ++k) {
- dest.length = i;
- return dest;
-goog.provide('ol.geom.SimpleGeometry');
-goog.require('ol.geom.Geometry');
-goog.require('ol.geom.GeometryLayout');
-goog.require('ol.geom.flat.transform');
- * @classdesc
- * Abstract base class; only used for creating subclasses; do not instantiate
- * in apps, as cannot be rendered.
- * @constructor
- * @abstract
- * @extends {ol.geom.Geometry}
- * @api
-ol.geom.SimpleGeometry = function() {
- ol.geom.Geometry.call(this);
- * @protected
- * @type {ol.geom.GeometryLayout}
- this.layout = ol.geom.GeometryLayout.XY;
- * @protected
- * @type {number}
- this.stride = 2;
- * @protected
- this.flatCoordinates = null;
-ol.inherits(ol.geom.SimpleGeometry, ol.geom.Geometry);
- * @private
- * @return {ol.geom.GeometryLayout} layout Layout.
-ol.geom.SimpleGeometry.getLayoutForStride_ = function(stride) {
- var layout;
- if (stride == 2) {
- layout = ol.geom.GeometryLayout.XY;
- } else if (stride == 3) {
- layout = ol.geom.GeometryLayout.XYZ;
- } else if (stride == 4) {
- layout = ol.geom.GeometryLayout.XYZM;
- return /** @type {ol.geom.GeometryLayout} */ (layout);
- * @param {ol.geom.GeometryLayout} layout Layout.
- * @return {number} Stride.
-ol.geom.SimpleGeometry.getStrideForLayout = function(layout) {
- var stride;
- if (layout == ol.geom.GeometryLayout.XY) {
- stride = 2;
- } else if (layout == ol.geom.GeometryLayout.XYZ || layout == ol.geom.GeometryLayout.XYM) {
- stride = 3;
- } else if (layout == ol.geom.GeometryLayout.XYZM) {
- stride = 4;
- return /** @type {number} */ (stride);
- * @inheritDoc
-ol.geom.SimpleGeometry.prototype.containsXY = ol.functions.FALSE;
- * @inheritDoc
-ol.geom.SimpleGeometry.prototype.computeExtent = function(extent) {
- return ol.extent.createOrUpdateFromFlatCoordinates(
- this.flatCoordinates, 0, this.flatCoordinates.length, this.stride,
- extent);
- * @abstract
- * @return {Array} Coordinates.
-ol.geom.SimpleGeometry.prototype.getCoordinates = function() {};
- * Return the first coordinate of the geometry.
- * @return {ol.Coordinate} First coordinate.
- * @api
-ol.geom.SimpleGeometry.prototype.getFirstCoordinate = function() {
- return this.flatCoordinates.slice(0, this.stride);
- * @return {Array.<number>} Flat coordinates.
-ol.geom.SimpleGeometry.prototype.getFlatCoordinates = function() {
- return this.flatCoordinates;
- * Return the last coordinate of the geometry.
- * @return {ol.Coordinate} Last point.
- * @api
-ol.geom.SimpleGeometry.prototype.getLastCoordinate = function() {
- return this.flatCoordinates.slice(this.flatCoordinates.length - this.stride);
- * Return the {@link ol.geom.GeometryLayout layout} of the geometry.
- * @return {ol.geom.GeometryLayout} Layout.
- * @api
-ol.geom.SimpleGeometry.prototype.getLayout = function() {
- return this.layout;
- * @inheritDoc
-ol.geom.SimpleGeometry.prototype.getSimplifiedGeometry = function(squaredTolerance) {
- if (this.simplifiedGeometryRevision != this.getRevision()) {
- ol.obj.clear(this.simplifiedGeometryCache);
- this.simplifiedGeometryRevision = this.getRevision();
- // If squaredTolerance is negative or if we know that simplification will not
- // have any effect then just return this.
- if (squaredTolerance < 0 ||
- (this.simplifiedGeometryMaxMinSquaredTolerance !== 0 &&
- squaredTolerance <= this.simplifiedGeometryMaxMinSquaredTolerance)) {
- return this;
- var key = squaredTolerance.toString();
- if (this.simplifiedGeometryCache.hasOwnProperty(key)) {
- return this.simplifiedGeometryCache[key];
- } else {
- var simplifiedGeometry =
- this.getSimplifiedGeometryInternal(squaredTolerance);
- var simplifiedFlatCoordinates = simplifiedGeometry.getFlatCoordinates();
- if (simplifiedFlatCoordinates.length < this.flatCoordinates.length) {
- this.simplifiedGeometryCache[key] = simplifiedGeometry;
- return simplifiedGeometry;
- } else {
- // Simplification did not actually remove any coordinates. We now know
- // that any calls to getSimplifiedGeometry with a squaredTolerance less
- // than or equal to the current squaredTolerance will also not have any
- // effect. This allows us to short circuit simplification (saving CPU
- // cycles) and prevents the cache of simplified geometries from filling
- // up with useless identical copies of this geometry (saving memory).
- this.simplifiedGeometryMaxMinSquaredTolerance = squaredTolerance;
- return this;
- * @return {ol.geom.SimpleGeometry} Simplified geometry.
- * @protected
-ol.geom.SimpleGeometry.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
- return this;
-ol.geom.SimpleGeometry.prototype.getStride = function() {
- return this.stride;
- * @protected
-ol.geom.SimpleGeometry.prototype.setFlatCoordinatesInternal = function(layout, flatCoordinates) {
- this.stride = ol.geom.SimpleGeometry.getStrideForLayout(layout);
- this.layout = layout;
- this.flatCoordinates = flatCoordinates;
- * @abstract
- * @param {Array} coordinates Coordinates.
- * @param {ol.geom.GeometryLayout=} opt_layout Layout.
-ol.geom.SimpleGeometry.prototype.setCoordinates = function(coordinates, opt_layout) {};
- * @param {ol.geom.GeometryLayout|undefined} layout Layout.
- * @param {number} nesting Nesting.
- * @protected
-ol.geom.SimpleGeometry.prototype.setLayout = function(layout, coordinates, nesting) {
- /** @type {number} */
- var stride;
- if (layout) {
- stride = ol.geom.SimpleGeometry.getStrideForLayout(layout);
- } else {
- var i;
- for (i = 0; i < nesting; ++i) {
- if (coordinates.length === 0) {
- this.stride = 2;
- return;
- } else {
- coordinates = /** @type {Array} */ (coordinates[0]);
- stride = coordinates.length;
- layout = ol.geom.SimpleGeometry.getLayoutForStride_(stride);
- this.stride = stride;
- * @inheritDoc
- * @api
-ol.geom.SimpleGeometry.prototype.applyTransform = function(transformFn) {
- if (this.flatCoordinates) {
- transformFn(this.flatCoordinates, this.flatCoordinates, this.stride);
- this.changed();
- * @inheritDoc
- * @api
-ol.geom.SimpleGeometry.prototype.rotate = function(angle, anchor) {
- var flatCoordinates = this.getFlatCoordinates();
- if (flatCoordinates) {
- var stride = this.getStride();
- ol.geom.flat.transform.rotate(
- flatCoordinates, 0, flatCoordinates.length,
- stride, angle, anchor, flatCoordinates);
- this.changed();
- * @inheritDoc
- * @api
-ol.geom.SimpleGeometry.prototype.scale = function(sx, opt_sy, opt_anchor) {
- var sy = opt_sy;
- if (sy === undefined) {
- sy = sx;
- var anchor = opt_anchor;
- if (!anchor) {
- anchor = ol.extent.getCenter(this.getExtent());
- ol.geom.flat.transform.scale(
- stride, sx, sy, anchor, flatCoordinates);
- this.changed();
- * @inheritDoc
- * @api
-ol.geom.SimpleGeometry.prototype.translate = function(deltaX, deltaY) {
- ol.geom.flat.transform.translate(
- flatCoordinates, 0, flatCoordinates.length, stride,
- deltaX, deltaY, flatCoordinates);
- this.changed();
- * @param {ol.geom.SimpleGeometry} simpleGeometry Simple geometry.
- * @return {Array.<number>} Transformed flat coordinates.
-ol.geom.SimpleGeometry.transform2D = function(simpleGeometry, transform, opt_dest) {
- var flatCoordinates = simpleGeometry.getFlatCoordinates();
- if (!flatCoordinates) {
- return null;
- } else {
- var stride = simpleGeometry.getStride();
- return ol.geom.flat.transform.transform2D(
- transform, opt_dest);
-goog.provide('ol.geom.flat.area');
- * @return {number} Area.
-ol.geom.flat.area.linearRing = function(flatCoordinates, offset, end, stride) {
- var twiceArea = 0;
- var x1 = flatCoordinates[end - stride];
- var y1 = flatCoordinates[end - stride + 1];
- for (; offset < end; offset += stride) {
- var x2 = flatCoordinates[offset];
- var y2 = flatCoordinates[offset + 1];
- twiceArea += y1 * x2 - x1 * y2;
- x1 = x2;
- y1 = y2;
- return twiceArea / 2;
- * @param {Array.<number>} ends Ends.
-ol.geom.flat.area.linearRings = function(flatCoordinates, offset, ends, stride) {
- var area = 0;
- var i, ii;
- for (i = 0, ii = ends.length; i < ii; ++i) {
- var end = ends[i];
- area += ol.geom.flat.area.linearRing(flatCoordinates, offset, end, stride);
- offset = end;
- return area;
- * @param {Array.<Array.<number>>} endss Endss.
-ol.geom.flat.area.linearRingss = function(flatCoordinates, offset, endss, stride) {
- var area = 0;
- var i, ii;
- for (i = 0, ii = endss.length; i < ii; ++i) {
- var ends = endss[i];
- area +=
- ol.geom.flat.area.linearRings(flatCoordinates, offset, ends, stride);
- offset = ends[ends.length - 1];
- return area;
-goog.provide('ol.geom.flat.closest');
- * Returns the point on the 2D line segment flatCoordinates[offset1] to
- * flatCoordinates[offset2] that is closest to the point (x, y). Extra
- * dimensions are linearly interpolated.
- * @param {number} offset1 Offset 1.
- * @param {number} offset2 Offset 2.
- * @param {Array.<number>} closestPoint Closest point.
-ol.geom.flat.closest.point = function(flatCoordinates, offset1, offset2, stride, x, y, closestPoint) {
- var x1 = flatCoordinates[offset1];
- var y1 = flatCoordinates[offset1 + 1];
- var dx = flatCoordinates[offset2] - x1;
- var dy = flatCoordinates[offset2 + 1] - y1;
- var i, offset;
- if (dx === 0 && dy === 0) {
- offset = offset1;
- } else {
- var t = ((x - x1) * dx + (y - y1) * dy) / (dx * dx + dy * dy);
- if (t > 1) {
- offset = offset2;
- } else if (t > 0) {
- for (i = 0; i < stride; ++i) {
- closestPoint[i] = ol.math.lerp(flatCoordinates[offset1 + i],
- flatCoordinates[offset2 + i], t);
- closestPoint.length = stride;
- return;
- } else {
- offset = offset1;
- closestPoint[i] = flatCoordinates[offset + i];
- * Return the squared of the largest distance between any pair of consecutive
- * coordinates.
- * @param {number} maxSquaredDelta Max squared delta.
- * @return {number} Max squared delta.
-ol.geom.flat.closest.getMaxSquaredDelta = function(flatCoordinates, offset, end, stride, maxSquaredDelta) {
- var x1 = flatCoordinates[offset];
- var y1 = flatCoordinates[offset + 1];
- for (offset += stride; offset < end; offset += stride) {
- var squaredDelta = ol.math.squaredDistance(x1, y1, x2, y2);
- if (squaredDelta > maxSquaredDelta) {
- maxSquaredDelta = squaredDelta;
- x1 = x2;
- y1 = y2;
- return maxSquaredDelta;
-ol.geom.flat.closest.getsMaxSquaredDelta = function(flatCoordinates, offset, ends, stride, maxSquaredDelta) {
- var i, ii;
- maxSquaredDelta = ol.geom.flat.closest.getMaxSquaredDelta(
- flatCoordinates, offset, end, stride, maxSquaredDelta);
- offset = end;
-ol.geom.flat.closest.getssMaxSquaredDelta = function(flatCoordinates, offset, endss, stride, maxSquaredDelta) {
- var i, ii;
- maxSquaredDelta = ol.geom.flat.closest.getsMaxSquaredDelta(
- flatCoordinates, offset, ends, stride, maxSquaredDelta);
- * @param {number} maxDelta Max delta.
- * @param {boolean} isRing Is ring.
- * @param {Array.<number>=} opt_tmpPoint Temporary point object.
-ol.geom.flat.closest.getClosestPoint = function(flatCoordinates, offset, end,
- stride, maxDelta, isRing, x, y, closestPoint, minSquaredDistance,
- opt_tmpPoint) {
- if (offset == end) {
- return minSquaredDistance;
- var i, squaredDistance;
- if (maxDelta === 0) {
- // All points are identical, so just test the first point.
- squaredDistance = ol.math.squaredDistance(
- x, y, flatCoordinates[offset], flatCoordinates[offset + 1]);
- if (squaredDistance < minSquaredDistance) {
- return squaredDistance;
- } else {
- var tmpPoint = opt_tmpPoint ? opt_tmpPoint : [NaN, NaN];
- var index = offset + stride;
- while (index < end) {
- ol.geom.flat.closest.point(
- flatCoordinates, index - stride, index, stride, x, y, tmpPoint);
- squaredDistance = ol.math.squaredDistance(x, y, tmpPoint[0], tmpPoint[1]);
- minSquaredDistance = squaredDistance;
- closestPoint[i] = tmpPoint[i];
- index += stride;
- } else {
- // Skip ahead multiple points, because we know that all the skipped
- // points cannot be any closer than the closest point we have found so
- // far. We know this because we know how close the current point is, how
- // close the closest point we have found so far is, and the maximum
- // distance between consecutive points. For example, if we're currently
- // at distance 10, the best we've found so far is 3, and that the maximum
- // distance between consecutive points is 2, then we'll need to skip at
- // least (10 - 3) / 2 == 3 (rounded down) points to have any chance of
- // finding a closer point. We use Math.max(..., 1) to ensure that we
- // always advance at least one point, to avoid an infinite loop.
- index += stride * Math.max(
- ((Math.sqrt(squaredDistance) -
- Math.sqrt(minSquaredDistance)) / maxDelta) | 0, 1);
- if (isRing) {
- // Check the closing segment.
- flatCoordinates, end - stride, offset, stride, x, y, tmpPoint);
-ol.geom.flat.closest.getsClosestPoint = function(flatCoordinates, offset, ends,
- opt_tmpPoint) {
- var i, ii;
- minSquaredDistance = ol.geom.flat.closest.getClosestPoint(
- maxDelta, isRing, x, y, closestPoint, minSquaredDistance, tmpPoint);
- offset = end;
-ol.geom.flat.closest.getssClosestPoint = function(flatCoordinates, offset,
- endss, stride, maxDelta, isRing, x, y, closestPoint, minSquaredDistance,
- opt_tmpPoint) {
- var i, ii;
- minSquaredDistance = ol.geom.flat.closest.getsClosestPoint(
-goog.provide('ol.geom.flat.deflate');
- * @return {number} offset Offset.
-ol.geom.flat.deflate.coordinate = function(flatCoordinates, offset, coordinate, stride) {
- var i, ii;
- for (i = 0, ii = coordinate.length; i < ii; ++i) {
- flatCoordinates[offset++] = coordinate[i];
- return offset;
- * @param {Array.<ol.Coordinate>} coordinates Coordinates.
-ol.geom.flat.deflate.coordinates = function(flatCoordinates, offset, coordinates, stride) {
- var i, ii;
- for (i = 0, ii = coordinates.length; i < ii; ++i) {
- var coordinate = coordinates[i];
- var j;
- for (j = 0; j < stride; ++j) {
- flatCoordinates[offset++] = coordinate[j];
- return offset;
- * @param {Array.<Array.<ol.Coordinate>>} coordinatess Coordinatess.
- * @param {Array.<number>=} opt_ends Ends.
- * @return {Array.<number>} Ends.
-ol.geom.flat.deflate.coordinatess = function(flatCoordinates, offset, coordinatess, stride, opt_ends) {
- var ends = opt_ends ? opt_ends : [];
- var i = 0;
- var j, jj;
- for (j = 0, jj = coordinatess.length; j < jj; ++j) {
- var end = ol.geom.flat.deflate.coordinates(
- flatCoordinates, offset, coordinatess[j], stride);
- ends[i++] = end;
- offset = end;
- ends.length = i;
- return ends;
- * @param {Array.<Array.<Array.<ol.Coordinate>>>} coordinatesss Coordinatesss.
- * @param {Array.<Array.<number>>=} opt_endss Endss.
- * @return {Array.<Array.<number>>} Endss.
-ol.geom.flat.deflate.coordinatesss = function(flatCoordinates, offset, coordinatesss, stride, opt_endss) {
- var endss = opt_endss ? opt_endss : [];
- var i = 0;
- var j, jj;
- for (j = 0, jj = coordinatesss.length; j < jj; ++j) {
- var ends = ol.geom.flat.deflate.coordinatess(
- flatCoordinates, offset, coordinatesss[j], stride, endss[i]);
- endss[i++] = ends;
- endss.length = i;
- return endss;
-goog.provide('ol.geom.flat.inflate');
- * @param {Array.<ol.Coordinate>=} opt_coordinates Coordinates.
- * @return {Array.<ol.Coordinate>} Coordinates.
-ol.geom.flat.inflate.coordinates = function(flatCoordinates, offset, end, stride, opt_coordinates) {
- var coordinates = opt_coordinates !== undefined ? opt_coordinates : [];
- var i = 0;
- var j;
- coordinates[i++] = flatCoordinates.slice(j, j + stride);
- coordinates.length = i;
- return coordinates;
- * @param {Array.<Array.<ol.Coordinate>>=} opt_coordinatess Coordinatess.
- * @return {Array.<Array.<ol.Coordinate>>} Coordinatess.
-ol.geom.flat.inflate.coordinatess = function(flatCoordinates, offset, ends, stride, opt_coordinatess) {
- var coordinatess = opt_coordinatess !== undefined ? opt_coordinatess : [];
- var i = 0;
- var j, jj;
- for (j = 0, jj = ends.length; j < jj; ++j) {
- var end = ends[j];
- coordinatess[i++] = ol.geom.flat.inflate.coordinates(
- flatCoordinates, offset, end, stride, coordinatess[i]);
- offset = end;
- coordinatess.length = i;
- return coordinatess;
- * @param {Array.<Array.<Array.<ol.Coordinate>>>=} opt_coordinatesss
- * Coordinatesss.
- * @return {Array.<Array.<Array.<ol.Coordinate>>>} Coordinatesss.
-ol.geom.flat.inflate.coordinatesss = function(flatCoordinates, offset, endss, stride, opt_coordinatesss) {
- var coordinatesss = opt_coordinatesss !== undefined ? opt_coordinatesss : [];
- var i = 0;
- var j, jj;
- for (j = 0, jj = endss.length; j < jj; ++j) {
- var ends = endss[j];
- coordinatesss[i++] = ol.geom.flat.inflate.coordinatess(
- flatCoordinates, offset, ends, stride, coordinatesss[i]);
- coordinatesss.length = i;
- return coordinatesss;
-// Based on simplify-js https://github.com/mourner/simplify-js
-// Copyright (c) 2012, Vladimir Agafonkin
-// All rights reserved.
-// Redistribution and use in source and binary forms, with or without
-// modification, are permitted provided that the following conditions are met:
-// 1. Redistributions of source code must retain the above copyright notice,
-// this list of conditions and the following disclaimer.
-// 2. Redistributions in binary form must reproduce the above copyright
-// notice, this list of conditions and the following disclaimer in the
-// documentation and/or other materials provided with the distribution.
-// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-// POSSIBILITY OF SUCH DAMAGE.
-goog.provide('ol.geom.flat.simplify');
- * @param {boolean} highQuality Highest quality.
- * @param {Array.<number>=} opt_simplifiedFlatCoordinates Simplified flat
- * coordinates.
- * @return {Array.<number>} Simplified line string.
-ol.geom.flat.simplify.lineString = function(flatCoordinates, offset, end,
- stride, squaredTolerance, highQuality, opt_simplifiedFlatCoordinates) {
- var simplifiedFlatCoordinates = opt_simplifiedFlatCoordinates !== undefined ?
- opt_simplifiedFlatCoordinates : [];
- if (!highQuality) {
- end = ol.geom.flat.simplify.radialDistance(flatCoordinates, offset, end,
- simplifiedFlatCoordinates, 0);
- flatCoordinates = simplifiedFlatCoordinates;
- offset = 0;
- stride = 2;
- simplifiedFlatCoordinates.length = ol.geom.flat.simplify.douglasPeucker(
- flatCoordinates, offset, end, stride, squaredTolerance,
- return simplifiedFlatCoordinates;
- * @param {Array.<number>} simplifiedFlatCoordinates Simplified flat
- * coordinates.
- * @param {number} simplifiedOffset Simplified offset.
- * @return {number} Simplified offset.
-ol.geom.flat.simplify.douglasPeucker = function(flatCoordinates, offset, end,
- stride, squaredTolerance, simplifiedFlatCoordinates, simplifiedOffset) {
- var n = (end - offset) / stride;
- if (n < 3) {
- simplifiedFlatCoordinates[simplifiedOffset++] =
- flatCoordinates[offset];
- flatCoordinates[offset + 1];
- return simplifiedOffset;
- /** @type {Array.<number>} */
- var markers = new Array(n);
- markers[0] = 1;
- markers[n - 1] = 1;
- var stack = [offset, end - stride];
- var index = 0;
- var i;
- while (stack.length > 0) {
- var last = stack.pop();
- var first = stack.pop();
- var maxSquaredDistance = 0;
- var x1 = flatCoordinates[first];
- var y1 = flatCoordinates[first + 1];
- var x2 = flatCoordinates[last];
- var y2 = flatCoordinates[last + 1];
- for (i = first + stride; i < last; i += stride) {
- var x = flatCoordinates[i];
- var y = flatCoordinates[i + 1];
- var squaredDistance = ol.math.squaredSegmentDistance(
- x, y, x1, y1, x2, y2);
- if (squaredDistance > maxSquaredDistance) {
- index = i;
- maxSquaredDistance = squaredDistance;
- if (maxSquaredDistance > squaredTolerance) {
- markers[(index - offset) / stride] = 1;
- if (first + stride < index) {
- stack.push(first, index);
- if (index + stride < last) {
- stack.push(index, last);
- if (markers[i]) {
- flatCoordinates[offset + i * stride];
- flatCoordinates[offset + i * stride + 1];
- * coordinates.
- * @param {Array.<number>} simplifiedEnds Simplified ends.
-ol.geom.flat.simplify.douglasPeuckers = function(flatCoordinates, offset,
- ends, stride, squaredTolerance, simplifiedFlatCoordinates,
- simplifiedOffset, simplifiedEnds) {
- var i, ii;
- simplifiedOffset = ol.geom.flat.simplify.douglasPeucker(
- simplifiedFlatCoordinates, simplifiedOffset);
- simplifiedEnds.push(simplifiedOffset);
- offset = end;
- * coordinates.
- * @param {Array.<Array.<number>>} simplifiedEndss Simplified endss.
-ol.geom.flat.simplify.douglasPeuckerss = function(
- flatCoordinates, offset, endss, stride, squaredTolerance,
- simplifiedFlatCoordinates, simplifiedOffset, simplifiedEndss) {
- var i, ii;
- var simplifiedEnds = [];
- simplifiedOffset = ol.geom.flat.simplify.douglasPeuckers(
- flatCoordinates, offset, ends, stride, squaredTolerance,
- simplifiedFlatCoordinates, simplifiedOffset, simplifiedEnds);
- simplifiedEndss.push(simplifiedEnds);
- * coordinates.
-ol.geom.flat.simplify.radialDistance = function(flatCoordinates, offset, end,
- if (end <= offset + stride) {
- // zero or one point, no simplification possible, so copy and return
- simplifiedFlatCoordinates[simplifiedOffset++] = flatCoordinates[offset];
- // copy first point
- simplifiedFlatCoordinates[simplifiedOffset++] = x1;
- simplifiedFlatCoordinates[simplifiedOffset++] = y1;
- var x2 = x1;
- var y2 = y1;
- x2 = flatCoordinates[offset];
- y2 = flatCoordinates[offset + 1];
- if (ol.math.squaredDistance(x1, y1, x2, y2) > squaredTolerance) {
- // copy point at offset
- simplifiedFlatCoordinates[simplifiedOffset++] = x2;
- simplifiedFlatCoordinates[simplifiedOffset++] = y2;
- x1 = x2;
- y1 = y2;
- if (x2 != x1 || y2 != y1) {
- // copy last point
- * @param {number} value Value.
- * @param {number} tolerance Tolerance.
- * @return {number} Rounded value.
-ol.geom.flat.simplify.snap = function(value, tolerance) {
- return tolerance * Math.round(value / tolerance);
- * Simplifies a line string using an algorithm designed by Tim Schaub.
- * Coordinates are snapped to the nearest value in a virtual grid and
- * consecutive duplicate coordinates are discarded. This effectively preserves
- * topology as the simplification of any subsection of a line string is
- * independent of the rest of the line string. This means that, for examples,
- * the common edge between two polygons will be simplified to the same line
- * string independently in both polygons. This implementation uses a single
- * pass over the coordinates and eliminates intermediate collinear points.
- * coordinates.
-ol.geom.flat.simplify.quantize = function(flatCoordinates, offset, end, stride,
- tolerance, simplifiedFlatCoordinates, simplifiedOffset) {
- // do nothing if the line is empty
- // snap the first coordinate (P1)
- var x1 = ol.geom.flat.simplify.snap(flatCoordinates[offset], tolerance);
- var y1 = ol.geom.flat.simplify.snap(flatCoordinates[offset + 1], tolerance);
- offset += stride;
- // add the first coordinate to the output
- // find the next coordinate that does not snap to the same value as the first
- // coordinate (P2)
- var x2, y2;
- do {
- x2 = ol.geom.flat.simplify.snap(flatCoordinates[offset], tolerance);
- y2 = ol.geom.flat.simplify.snap(flatCoordinates[offset + 1], tolerance);
- offset += stride;
- // all coordinates snap to the same value, the line collapses to a point
- // push the last snapped value anyway to ensure that the output contains
- // at least two points
- // FIXME should we really return at least two points anyway?
- } while (x2 == x1 && y2 == y1);
- while (offset < end) {
- var x3, y3;
- // snap the next coordinate (P3)
- x3 = ol.geom.flat.simplify.snap(flatCoordinates[offset], tolerance);
- y3 = ol.geom.flat.simplify.snap(flatCoordinates[offset + 1], tolerance);
- offset += stride;
- // skip P3 if it is equal to P2
- if (x3 == x2 && y3 == y2) {
- continue;
- // calculate the delta between P1 and P2
- var dx1 = x2 - x1;
- var dy1 = y2 - y1;
- // calculate the delta between P3 and P1
- var dx2 = x3 - x1;
- var dy2 = y3 - y1;
- // if P1, P2, and P3 are colinear and P3 is further from P1 than P2 is from
- // P1 in the same direction then P2 is on the straight line between P1 and
- // P3
- if ((dx1 * dy2 == dy1 * dx2) &&
- ((dx1 < 0 && dx2 < dx1) || dx1 == dx2 || (dx1 > 0 && dx2 > dx1)) &&
- ((dy1 < 0 && dy2 < dy1) || dy1 == dy2 || (dy1 > 0 && dy2 > dy1))) {
- // discard P2 and set P2 = P3
- x2 = x3;
- y2 = y3;
- continue;
- // either P1, P2, and P3 are not colinear, or they are colinear but P3 is
- // between P3 and P1 or on the opposite half of the line to P2. add P2,
- // and continue with P1 = P2 and P2 = P3
- x1 = x2;
- y1 = y2;
- x2 = x3;
- y2 = y3;
- // add the last point (P2)
- * coordinates.
-ol.geom.flat.simplify.quantizes = function(
- tolerance,
- simplifiedFlatCoordinates, simplifiedOffset, simplifiedEnds) {
- var i, ii;
- simplifiedOffset = ol.geom.flat.simplify.quantize(
- tolerance,
- offset = end;
- * coordinates.
-ol.geom.flat.simplify.quantizess = function(
- tolerance,
- var i, ii;
- simplifiedOffset = ol.geom.flat.simplify.quantizes(
- tolerance,
-goog.provide('ol.geom.LinearRing');
-goog.require('ol');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.geom.SimpleGeometry');
-goog.require('ol.geom.flat.area');
-goog.require('ol.geom.flat.closest');
-goog.require('ol.geom.flat.deflate');
-goog.require('ol.geom.flat.inflate');
-goog.require('ol.geom.flat.simplify');
- * @classdesc
- * Linear ring geometry. Only used as part of polygon; cannot be rendered
- * on its own.
- * @constructor
- * @extends {ol.geom.SimpleGeometry}
- * @api
-ol.geom.LinearRing = function(coordinates, opt_layout) {
- ol.geom.SimpleGeometry.call(this);
- * @private
- * @type {number}
- this.maxDelta_ = -1;
- * @private
- * @type {number}
- this.maxDeltaRevision_ = -1;
- this.setCoordinates(coordinates, opt_layout);
-ol.inherits(ol.geom.LinearRing, ol.geom.SimpleGeometry);
- * @return {!ol.geom.LinearRing} Clone.
- * @override
- * @api
-ol.geom.LinearRing.prototype.clone = function() {
- var linearRing = new ol.geom.LinearRing(null);
- linearRing.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
- return linearRing;
- * @inheritDoc
-ol.geom.LinearRing.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- if (minSquaredDistance <
- ol.extent.closestSquaredDistanceXY(this.getExtent(), x, y)) {
- if (this.maxDeltaRevision_ != this.getRevision()) {
- this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getMaxSquaredDelta(
- this.flatCoordinates, 0, this.flatCoordinates.length, this.stride, 0));
- this.maxDeltaRevision_ = this.getRevision();
- return ol.geom.flat.closest.getClosestPoint(
- this.maxDelta_, true, x, y, closestPoint, minSquaredDistance);
- * Return the area of the linear ring on projected plane.
- * @return {number} Area (on projected plane).
- * @api
-ol.geom.LinearRing.prototype.getArea = function() {
- return ol.geom.flat.area.linearRing(
- this.flatCoordinates, 0, this.flatCoordinates.length, this.stride);
- * Return the coordinates of the linear ring.
- * @override
- * @api
-ol.geom.LinearRing.prototype.getCoordinates = function() {
- return ol.geom.flat.inflate.coordinates(
- * @inheritDoc
-ol.geom.LinearRing.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
- var simplifiedFlatCoordinates = [];
- squaredTolerance, simplifiedFlatCoordinates, 0);
- var simplifiedLinearRing = new ol.geom.LinearRing(null);
- simplifiedLinearRing.setFlatCoordinates(
- ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates);
- return simplifiedLinearRing;
- * @inheritDoc
- * @api
-ol.geom.LinearRing.prototype.getType = function() {
- return ol.geom.GeometryType.LINEAR_RING;
- * @inheritDoc
-ol.geom.LinearRing.prototype.intersectsExtent = function(extent) {};
- * Set the coordinates of the linear ring.
- * @override
- * @api
-ol.geom.LinearRing.prototype.setCoordinates = function(coordinates, opt_layout) {
- if (!coordinates) {
- this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null);
- } else {
- this.setLayout(opt_layout, coordinates, 1);
- if (!this.flatCoordinates) {
- this.flatCoordinates = [];
- this.flatCoordinates.length = ol.geom.flat.deflate.coordinates(
- this.flatCoordinates, 0, coordinates, this.stride);
- this.changed();
-ol.geom.LinearRing.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
- this.setFlatCoordinatesInternal(layout, flatCoordinates);
- this.changed();
-goog.provide('ol.geom.Point');
- * @classdesc
- * Point geometry.
- * @constructor
- * @param {ol.Coordinate} coordinates Coordinates.
- * @api
-ol.geom.Point = function(coordinates, opt_layout) {
-ol.inherits(ol.geom.Point, ol.geom.SimpleGeometry);
- * @return {!ol.geom.Point} Clone.
- * @override
- * @api
-ol.geom.Point.prototype.clone = function() {
- var point = new ol.geom.Point(null);
- point.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
- return point;
- * @inheritDoc
-ol.geom.Point.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- var flatCoordinates = this.flatCoordinates;
- var squaredDistance = ol.math.squaredDistance(
- x, y, flatCoordinates[0], flatCoordinates[1]);
- var stride = this.stride;
- var i;
- closestPoint[i] = flatCoordinates[i];
- } else {
- * Return the coordinate of the point.
- * @return {ol.Coordinate} Coordinates.
- * @override
- * @api
-ol.geom.Point.prototype.getCoordinates = function() {
- return !this.flatCoordinates ? [] : this.flatCoordinates.slice();
- * @inheritDoc
-ol.geom.Point.prototype.computeExtent = function(extent) {
- return ol.extent.createOrUpdateFromCoordinate(this.flatCoordinates, extent);
- * @inheritDoc
- * @api
-ol.geom.Point.prototype.getType = function() {
- return ol.geom.GeometryType.POINT;
- * @inheritDoc
- * @api
-ol.geom.Point.prototype.intersectsExtent = function(extent) {
- return ol.extent.containsXY(extent,
- this.flatCoordinates[0], this.flatCoordinates[1]);
- * @inheritDoc
- * @api
-ol.geom.Point.prototype.setCoordinates = function(coordinates, opt_layout) {
- } else {
- this.setLayout(opt_layout, coordinates, 0);
- this.flatCoordinates.length = ol.geom.flat.deflate.coordinate(
- this.changed();
-ol.geom.Point.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
- this.changed();
-goog.provide('ol.geom.flat.contains');
- * @return {boolean} Contains extent.
-ol.geom.flat.contains.linearRingContainsExtent = function(flatCoordinates, offset, end, stride, extent) {
- var outside = ol.extent.forEachCorner(extent,
- return !ol.geom.flat.contains.linearRingContainsXY(flatCoordinates,
- offset, end, stride, coordinate[0], coordinate[1]);
- return !outside;
-ol.geom.flat.contains.linearRingContainsXY = function(flatCoordinates, offset, end, stride, x, y) {
- // http://geomalgorithms.com/a03-_inclusion.html
- // Copyright 2000 softSurfer, 2012 Dan Sunday
- // This code may be freely used and modified for any purpose
- // providing that this copyright notice is included with it.
- // SoftSurfer makes no warranty for this code, and cannot be held
- // liable for any real or imagined damage resulting from its use.
- // Users of this code must verify correctness for their application.
- var wn = 0;
- if (y1 <= y) {
- if (y2 > y && ((x2 - x1) * (y - y1)) - ((x - x1) * (y2 - y1)) > 0) {
- wn++;
- } else if (y2 <= y && ((x2 - x1) * (y - y1)) - ((x - x1) * (y2 - y1)) < 0) {
- wn--;
- x1 = x2;
- y1 = y2;
- return wn !== 0;
-ol.geom.flat.contains.linearRingsContainsXY = function(flatCoordinates, offset, ends, stride, x, y) {
- if (ends.length === 0) {
- return false;
- if (!ol.geom.flat.contains.linearRingContainsXY(
- flatCoordinates, offset, ends[0], stride, x, y)) {
- return false;
- var i, ii;
- for (i = 1, ii = ends.length; i < ii; ++i) {
- if (ol.geom.flat.contains.linearRingContainsXY(
- flatCoordinates, ends[i - 1], ends[i], stride, x, y)) {
- return false;
- return true;
-ol.geom.flat.contains.linearRingssContainsXY = function(flatCoordinates, offset, endss, stride, x, y) {
- if (endss.length === 0) {
- return false;
- var i, ii;
- if (ol.geom.flat.contains.linearRingsContainsXY(
- flatCoordinates, offset, ends, stride, x, y)) {
- return true;
- return false;
-goog.provide('ol.geom.flat.interiorpoint');
-goog.require('ol.array');
-goog.require('ol.geom.flat.contains');
- * Calculates a point that is likely to lie in the interior of the linear rings.
- * Inspired by JTS's com.vividsolutions.jts.geom.Geometry#getInteriorPoint.
- * @param {Array.<number>} flatCenters Flat centers.
- * @param {number} flatCentersOffset Flat center offset.
- * @return {Array.<number>} Destination.
-ol.geom.flat.interiorpoint.linearRings = function(flatCoordinates, offset,
- ends, stride, flatCenters, flatCentersOffset, opt_dest) {
- var i, ii, x, x1, x2, y1, y2;
- var y = flatCenters[flatCentersOffset + 1];
- var intersections = [];
- // Calculate intersections with the horizontal line
- var end = ends[0];
- x1 = flatCoordinates[end - stride];
- y1 = flatCoordinates[end - stride + 1];
- for (i = offset; i < end; i += stride) {
- x2 = flatCoordinates[i];
- y2 = flatCoordinates[i + 1];
- if ((y <= y1 && y2 <= y) || (y1 <= y && y <= y2)) {
- x = (y - y1) / (y2 - y1) * (x2 - x1) + x1;
- intersections.push(x);
- x1 = x2;
- y1 = y2;
- // Find the longest segment of the horizontal line that has its center point
- // inside the linear ring.
- var pointX = NaN;
- var maxSegmentLength = -Infinity;
- intersections.sort(ol.array.numberSafeCompareFunction);
- x1 = intersections[0];
- for (i = 1, ii = intersections.length; i < ii; ++i) {
- x2 = intersections[i];
- var segmentLength = Math.abs(x2 - x1);
- if (segmentLength > maxSegmentLength) {
- x = (x1 + x2) / 2;
- pointX = x;
- maxSegmentLength = segmentLength;
- x1 = x2;
- if (isNaN(pointX)) {
- // There is no horizontal line that has its center point inside the linear
- // ring. Use the center of the the linear ring's extent.
- pointX = flatCenters[flatCentersOffset];
- if (opt_dest) {
- opt_dest.push(pointX, y);
- return opt_dest;
- } else {
- return [pointX, y];
- * @return {Array.<number>} Interior points.
-ol.geom.flat.interiorpoint.linearRingss = function(flatCoordinates, offset, endss, stride, flatCenters) {
- var interiorPoints = [];
- var i, ii;
- interiorPoints = ol.geom.flat.interiorpoint.linearRings(flatCoordinates,
- offset, ends, stride, flatCenters, 2 * i, interiorPoints);
- return interiorPoints;
-goog.provide('ol.geom.flat.segments');
- * This function calls `callback` for each segment of the flat coordinates
- * array. If the callback returns a truthy value the function returns that
- * value immediately. Otherwise the function returns `false`.
- * @param {function(this: S, ol.Coordinate, ol.Coordinate): T} callback Function
- * called for each segment.
- * @param {S=} opt_this The object to be used as the value of 'this'
- * within callback.
- * @return {T|boolean} Value.
- * @template T,S
-ol.geom.flat.segments.forEach = function(flatCoordinates, offset, end, stride, callback, opt_this) {
- var point1 = [flatCoordinates[offset], flatCoordinates[offset + 1]];
- var point2 = [];
- var ret;
- for (; (offset + stride) < end; offset += stride) {
- point2[0] = flatCoordinates[offset + stride];
- point2[1] = flatCoordinates[offset + stride + 1];
- ret = callback.call(opt_this, point1, point2);
- if (ret) {
- return ret;
- point1[0] = point2[0];
- point1[1] = point2[1];
- return false;
-goog.provide('ol.geom.flat.intersectsextent');
-goog.require('ol.geom.flat.segments');
- * @return {boolean} True if the geometry and the extent intersect.
-ol.geom.flat.intersectsextent.lineString = function(flatCoordinates, offset, end, stride, extent) {
- var coordinatesExtent = ol.extent.extendFlatCoordinates(
- ol.extent.createEmpty(), flatCoordinates, offset, end, stride);
- if (!ol.extent.intersects(extent, coordinatesExtent)) {
- return false;
- if (ol.extent.containsExtent(extent, coordinatesExtent)) {
- return true;
- if (coordinatesExtent[0] >= extent[0] &&
- coordinatesExtent[2] <= extent[2]) {
- return true;
- if (coordinatesExtent[1] >= extent[1] &&
- coordinatesExtent[3] <= extent[3]) {
- return true;
- return ol.geom.flat.segments.forEach(flatCoordinates, offset, end, stride,
- * @param {ol.Coordinate} point1 Start point.
- * @param {ol.Coordinate} point2 End point.
- * @return {boolean} `true` if the segment and the extent intersect,
- * `false` otherwise.
- function(point1, point2) {
- return ol.extent.intersectsSegment(extent, point1, point2);
-ol.geom.flat.intersectsextent.lineStrings = function(flatCoordinates, offset, ends, stride, extent) {
- var i, ii;
- if (ol.geom.flat.intersectsextent.lineString(
- flatCoordinates, offset, ends[i], stride, extent)) {
- return true;
- offset = ends[i];
- return false;
-ol.geom.flat.intersectsextent.linearRing = function(flatCoordinates, offset, end, stride, extent) {
- flatCoordinates, offset, end, stride, extent)) {
- return true;
- flatCoordinates, offset, end, stride, extent[0], extent[1])) {
- return true;
- flatCoordinates, offset, end, stride, extent[0], extent[3])) {
- return true;
- flatCoordinates, offset, end, stride, extent[2], extent[1])) {
- return true;
- flatCoordinates, offset, end, stride, extent[2], extent[3])) {
- return true;
- return false;
-ol.geom.flat.intersectsextent.linearRings = function(flatCoordinates, offset, ends, stride, extent) {
- if (!ol.geom.flat.intersectsextent.linearRing(
- flatCoordinates, offset, ends[0], stride, extent)) {
- return false;
- if (ends.length === 1) {
- return true;
- var i, ii;
- if (ol.geom.flat.contains.linearRingContainsExtent(
- flatCoordinates, ends[i - 1], ends[i], stride, extent)) {
- return false;
- return true;
-ol.geom.flat.intersectsextent.linearRingss = function(flatCoordinates, offset, endss, stride, extent) {
- var i, ii;
- if (ol.geom.flat.intersectsextent.linearRings(
- flatCoordinates, offset, ends, stride, extent)) {
- return true;
- return false;
-goog.provide('ol.geom.flat.reverse');
-ol.geom.flat.reverse.coordinates = function(flatCoordinates, offset, end, stride) {
- while (offset < end - stride) {
- var i;
- var tmp = flatCoordinates[offset + i];
- flatCoordinates[offset + i] = flatCoordinates[end - stride + i];
- flatCoordinates[end - stride + i] = tmp;
- offset += stride;
- end -= stride;
-goog.provide('ol.geom.flat.orient');
-goog.require('ol.geom.flat.reverse');
- * @return {boolean} Is clockwise.
-ol.geom.flat.orient.linearRingIsClockwise = function(flatCoordinates, offset, end, stride) {
- // http://tinyurl.com/clockwise-method
- // https://github.com/OSGeo/gdal/blob/trunk/gdal/ogr/ogrlinearring.cpp
- var edge = 0;
- edge += (x2 - x1) * (y2 + y1);
- x1 = x2;
- y1 = y2;
- return edge > 0;
- * Determines if linear rings are oriented. By default, left-hand orientation
- * is tested (first ring must be clockwise, remaining rings counter-clockwise).
- * To test for right-hand orientation, use the `opt_right` argument.
- * @param {Array.<number>} ends Array of end indexes.
- * @param {boolean=} opt_right Test for right-hand orientation
- * (counter-clockwise exterior ring and clockwise interior rings).
- * @return {boolean} Rings are correctly oriented.
-ol.geom.flat.orient.linearRingsAreOriented = function(flatCoordinates, offset, ends, stride, opt_right) {
- var right = opt_right !== undefined ? opt_right : false;
- var i, ii;
- var isClockwise = ol.geom.flat.orient.linearRingIsClockwise(
- flatCoordinates, offset, end, stride);
- if (i === 0) {
- if ((right && isClockwise) || (!right && !isClockwise)) {
- return false;
- } else {
- if ((right && !isClockwise) || (!right && isClockwise)) {
- return false;
- offset = end;
- return true;
- * @param {Array.<Array.<number>>} endss Array of array of end indexes.
-ol.geom.flat.orient.linearRingssAreOriented = function(flatCoordinates, offset, endss, stride, opt_right) {
- var i, ii;
- if (!ol.geom.flat.orient.linearRingsAreOriented(
- flatCoordinates, offset, endss[i], stride, opt_right)) {
- return false;
- return true;
- * Orient coordinates in a flat array of linear rings. By default, rings
- * are oriented following the left-hand rule (clockwise for exterior and
- * counter-clockwise for interior rings). To orient according to the
- * right-hand rule, use the `opt_right` argument.
- * @param {boolean=} opt_right Follow the right-hand rule for orientation.
- * @return {number} End.
-ol.geom.flat.orient.orientLinearRings = function(flatCoordinates, offset, ends, stride, opt_right) {
- var i, ii;
- var reverse = i === 0 ?
- (right && isClockwise) || (!right && !isClockwise) :
- (right && !isClockwise) || (!right && isClockwise);
- if (reverse) {
- ol.geom.flat.reverse.coordinates(flatCoordinates, offset, end, stride);
- offset = end;
- return offset;
-ol.geom.flat.orient.orientLinearRingss = function(flatCoordinates, offset, endss, stride, opt_right) {
- var i, ii;
- offset = ol.geom.flat.orient.orientLinearRings(
- flatCoordinates, offset, endss[i], stride, opt_right);
- return offset;
-goog.provide('ol.geom.Polygon');
-goog.require('ol.geom.LinearRing');
-goog.require('ol.geom.Point');
-goog.require('ol.geom.flat.interiorpoint');
-goog.require('ol.geom.flat.intersectsextent');
-goog.require('ol.geom.flat.orient');
-goog.require('ol.math');
- * @classdesc
- * Polygon geometry.
- * @constructor
- * @param {Array.<Array.<ol.Coordinate>>} coordinates Array of linear
- * rings that define the polygon. The first linear ring of the array
- * defines the outer-boundary or surface of the polygon. Each subsequent
- * linear ring defines a hole in the surface of the polygon. A linear ring
- * is an array of vertices' coordinates where the first coordinate and the
- * last are equivalent.
- * @api
-ol.geom.Polygon = function(coordinates, opt_layout) {
- * @type {Array.<number>}
- * @private
- this.ends_ = [];
- * @private
- * @type {number}
- this.flatInteriorPointRevision_ = -1;
- * @private
- * @type {ol.Coordinate}
- this.flatInteriorPoint_ = null;
- * @private
- * @type {number}
- * @private
- * @type {number}
- * @private
- * @type {number}
- this.orientedRevision_ = -1;
- * @private
- this.orientedFlatCoordinates_ = null;
-ol.inherits(ol.geom.Polygon, ol.geom.SimpleGeometry);
- * Append the passed linear ring to this polygon.
- * @param {ol.geom.LinearRing} linearRing Linear ring.
- * @api
-ol.geom.Polygon.prototype.appendLinearRing = function(linearRing) {
- this.flatCoordinates = linearRing.getFlatCoordinates().slice();
- } else {
- ol.array.extend(this.flatCoordinates, linearRing.getFlatCoordinates());
- this.ends_.push(this.flatCoordinates.length);
- this.changed();
- * @return {!ol.geom.Polygon} Clone.
- * @override
- * @api
-ol.geom.Polygon.prototype.clone = function() {
- var polygon = new ol.geom.Polygon(null);
- polygon.setFlatCoordinates(
- this.layout, this.flatCoordinates.slice(), this.ends_.slice());
- return polygon;
- * @inheritDoc
-ol.geom.Polygon.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getsMaxSquaredDelta(
- this.flatCoordinates, 0, this.ends_, this.stride, 0));
- return ol.geom.flat.closest.getsClosestPoint(
- * @inheritDoc
-ol.geom.Polygon.prototype.containsXY = function(x, y) {
- return ol.geom.flat.contains.linearRingsContainsXY(
- this.getOrientedFlatCoordinates(), 0, this.ends_, this.stride, x, y);
- * Return the area of the polygon on projected plane.
- * @api
-ol.geom.Polygon.prototype.getArea = function() {
- return ol.geom.flat.area.linearRings(
- this.getOrientedFlatCoordinates(), 0, this.ends_, this.stride);
- * Get the coordinate array for this geometry. This array has the structure
- * of a GeoJSON coordinate array for polygons.
- * @param {boolean=} opt_right Orient coordinates according to the right-hand
- * rule (counter-clockwise for exterior and clockwise for interior rings).
- * If `false`, coordinates will be oriented according to the left-hand rule
- * (clockwise for exterior and counter-clockwise for interior rings).
- * By default, coordinate orientation will depend on how the geometry was
- * constructed.
- * @return {Array.<Array.<ol.Coordinate>>} Coordinates.
- * @override
- * @api
-ol.geom.Polygon.prototype.getCoordinates = function(opt_right) {
- var flatCoordinates;
- if (opt_right !== undefined) {
- flatCoordinates = this.getOrientedFlatCoordinates().slice();
- ol.geom.flat.orient.orientLinearRings(
- flatCoordinates, 0, this.ends_, this.stride, opt_right);
- } else {
- flatCoordinates = this.flatCoordinates;
- return ol.geom.flat.inflate.coordinatess(
- flatCoordinates, 0, this.ends_, this.stride);
-ol.geom.Polygon.prototype.getEnds = function() {
- return this.ends_;
- * @return {Array.<number>} Interior point.
-ol.geom.Polygon.prototype.getFlatInteriorPoint = function() {
- if (this.flatInteriorPointRevision_ != this.getRevision()) {
- var flatCenter = ol.extent.getCenter(this.getExtent());
- this.flatInteriorPoint_ = ol.geom.flat.interiorpoint.linearRings(
- flatCenter, 0);
- this.flatInteriorPointRevision_ = this.getRevision();
- return this.flatInteriorPoint_;
- * Return an interior point of the polygon.
- * @return {ol.geom.Point} Interior point.
- * @api
-ol.geom.Polygon.prototype.getInteriorPoint = function() {
- return new ol.geom.Point(this.getFlatInteriorPoint());
- * Return the number of rings of the polygon, this includes the exterior
- * ring and any interior rings.
- * @return {number} Number of rings.
- * @api
-ol.geom.Polygon.prototype.getLinearRingCount = function() {
- return this.ends_.length;
- * Return the Nth linear ring of the polygon geometry. Return `null` if the
- * given index is out of range.
- * The exterior linear ring is available at index `0` and the interior rings
- * at index `1` and beyond.
- * @param {number} index Index.
- * @return {ol.geom.LinearRing} Linear ring.
- * @api
-ol.geom.Polygon.prototype.getLinearRing = function(index) {
- if (index < 0 || this.ends_.length <= index) {
- return null;
- index === 0 ? 0 : this.ends_[index - 1], this.ends_[index]));
- * Return the linear rings of the polygon.
- * @return {Array.<ol.geom.LinearRing>} Linear rings.
- * @api
-ol.geom.Polygon.prototype.getLinearRings = function() {
- var layout = this.layout;
- var ends = this.ends_;
- var linearRings = [];
- var offset = 0;
- var i, ii;
- linearRing.setFlatCoordinates(layout, flatCoordinates.slice(offset, end));
- linearRings.push(linearRing);
- offset = end;
- return linearRings;
- * @return {Array.<number>} Oriented flat coordinates.
-ol.geom.Polygon.prototype.getOrientedFlatCoordinates = function() {
- if (this.orientedRevision_ != this.getRevision()) {
- if (ol.geom.flat.orient.linearRingsAreOriented(
- flatCoordinates, 0, this.ends_, this.stride)) {
- this.orientedFlatCoordinates_ = flatCoordinates;
- } else {
- this.orientedFlatCoordinates_ = flatCoordinates.slice();
- this.orientedFlatCoordinates_.length =
- this.orientedFlatCoordinates_, 0, this.ends_, this.stride);
- this.orientedRevision_ = this.getRevision();
- return this.orientedFlatCoordinates_;
- * @inheritDoc
-ol.geom.Polygon.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
- simplifiedFlatCoordinates.length = ol.geom.flat.simplify.quantizes(
- Math.sqrt(squaredTolerance),
- simplifiedFlatCoordinates, 0, simplifiedEnds);
- var simplifiedPolygon = new ol.geom.Polygon(null);
- simplifiedPolygon.setFlatCoordinates(
- ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates, simplifiedEnds);
- return simplifiedPolygon;
- * @inheritDoc
- * @api
-ol.geom.Polygon.prototype.getType = function() {
- return ol.geom.GeometryType.POLYGON;
- * @inheritDoc
- * @api
-ol.geom.Polygon.prototype.intersectsExtent = function(extent) {
- return ol.geom.flat.intersectsextent.linearRings(
- this.getOrientedFlatCoordinates(), 0, this.ends_, this.stride, extent);
- * Set the coordinates of the polygon.
- * @param {Array.<Array.<ol.Coordinate>>} coordinates Coordinates.
- * @override
- * @api
-ol.geom.Polygon.prototype.setCoordinates = function(coordinates, opt_layout) {
- this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null, this.ends_);
- } else {
- this.setLayout(opt_layout, coordinates, 2);
- this.flatCoordinates, 0, coordinates, this.stride, this.ends_);
- this.flatCoordinates.length = ends.length === 0 ? 0 : ends[ends.length - 1];
- this.changed();
-ol.geom.Polygon.prototype.setFlatCoordinates = function(layout, flatCoordinates, ends) {
- this.ends_ = ends;
- this.changed();
- * Create an approximation of a circle on the surface of a sphere.
- * @param {ol.Sphere} sphere The sphere.
- * @param {ol.Coordinate} center Center (`[lon, lat]` in degrees).
- * @param {number} radius The great-circle distance from the center to
- * the polygon vertices.
- * @param {number=} opt_n Optional number of vertices for the resulting
- * polygon. Default is `32`.
- * @return {ol.geom.Polygon} The "circular" polygon.
- * @api
-ol.geom.Polygon.circular = function(sphere, center, radius, opt_n) {
- var n = opt_n ? opt_n : 32;
- var flatCoordinates = [];
- var i;
- for (i = 0; i < n; ++i) {
- ol.array.extend(
- flatCoordinates, sphere.offset(center, radius, 2 * Math.PI * i / n));
- flatCoordinates.push(flatCoordinates[0], flatCoordinates[1]);
- ol.geom.GeometryLayout.XY, flatCoordinates, [flatCoordinates.length]);
- return polygon;
- * Create a polygon from an extent. The layout used is `XY`.
- * @param {ol.Extent} extent The extent.
- * @return {ol.geom.Polygon} The polygon.
- * @api
-ol.geom.Polygon.fromExtent = function(extent) {
- var minX = extent[0];
- var minY = extent[1];
- var maxX = extent[2];
- var maxY = extent[3];
- [minX, minY, minX, maxY, maxX, maxY, maxX, minY, minX, minY];
- return polygon;
- * Create a regular polygon from a circle.
- * @param {ol.geom.Circle} circle Circle geometry.
- * @param {number=} opt_sides Number of sides of the polygon. Default is 32.
- * @param {number=} opt_angle Start angle for the first vertex of the polygon in
- * radians. Default is 0.
- * @return {ol.geom.Polygon} Polygon geometry.
- * @api
-ol.geom.Polygon.fromCircle = function(circle, opt_sides, opt_angle) {
- var sides = opt_sides ? opt_sides : 32;
- var stride = circle.getStride();
- var layout = circle.getLayout();
- var polygon = new ol.geom.Polygon(null, layout);
- var arrayLength = stride * (sides + 1);
- var flatCoordinates = new Array(arrayLength);
- for (var i = 0; i < arrayLength; i++) {
- flatCoordinates[i] = 0;
- var ends = [flatCoordinates.length];
- polygon.setFlatCoordinates(layout, flatCoordinates, ends);
- ol.geom.Polygon.makeRegular(
- polygon, circle.getCenter(), circle.getRadius(), opt_angle);
- return polygon;
- * Modify the coordinates of a polygon to make it a regular polygon.
- * @param {ol.geom.Polygon} polygon Polygon geometry.
- * @param {ol.Coordinate} center Center of the regular polygon.
- * @param {number} radius Radius of the regular polygon.
-ol.geom.Polygon.makeRegular = function(polygon, center, radius, opt_angle) {
- var flatCoordinates = polygon.getFlatCoordinates();
- var layout = polygon.getLayout();
- var stride = polygon.getStride();
- var ends = polygon.getEnds();
- var sides = flatCoordinates.length / stride - 1;
- var startAngle = opt_angle ? opt_angle : 0;
- var angle, offset;
- for (var i = 0; i <= sides; ++i) {
- offset = i * stride;
- angle = startAngle + (ol.math.modulo(i, sides) * 2 * Math.PI / sides);
- flatCoordinates[offset] = center[0] + (radius * Math.cos(angle));
- flatCoordinates[offset + 1] = center[1] + (radius * Math.sin(angle));
-goog.provide('ol.View');
-goog.require('ol.CenterConstraint');
-goog.require('ol.Constraints');
-goog.require('ol.Object');
-goog.require('ol.ResolutionConstraint');
-goog.require('ol.RotationConstraint');
-goog.require('ol.ViewHint');
-goog.require('ol.ViewProperty');
-goog.require('ol.asserts');
-goog.require('ol.coordinate');
-goog.require('ol.easing');
-goog.require('ol.extent');
-goog.require('ol.geom.Polygon');
-goog.require('ol.obj');
-goog.require('ol.proj');
-goog.require('ol.proj.Units');
- * @classdesc
- * An ol.View object represents a simple 2D view of the map.
- * This is the object to act upon to change the center, resolution,
- * and rotation of the map.
- * ### The view states
- * An `ol.View` is determined by three states: `center`, `resolution`,
- * and `rotation`. Each state has a corresponding getter and setter, e.g.
- * `getCenter` and `setCenter` for the `center` state.
- * An `ol.View` has a `projection`. The projection determines the
- * coordinate system of the center, and its units determine the units of the
- * resolution (projection units per pixel). The default projection is
- * Spherical Mercator (EPSG:3857).
- * ### The constraints
- * `setCenter`, `setResolution` and `setRotation` can be used to change the
- * states of the view. Any value can be passed to the setters. And the value
- * that is passed to a setter will effectively be the value set in the view,
- * and returned by the corresponding getter.
- * But an `ol.View` object also has a *resolution constraint*, a
- * *rotation constraint* and a *center constraint*.
- * As said above, no constraints are applied when the setters are used to set
- * new states for the view. Applying constraints is done explicitly through
- * the use of the `constrain*` functions (`constrainResolution` and
- * `constrainRotation` and `constrainCenter`).
- * The main users of the constraints are the interactions and the
- * controls. For example, double-clicking on the map changes the view to
- * the "next" resolution. And releasing the fingers after pinch-zooming
- * snaps to the closest resolution (with an animation).
- * The *resolution constraint* snaps to specific resolutions. It is
- * determined by the following options: `resolutions`, `maxResolution`,
- * `maxZoom`, and `zoomFactor`. If `resolutions` is set, the other three
- * options are ignored. See documentation for each option for more
- * information.
- * The *rotation constraint* snaps to specific angles. It is determined
- * by the following options: `enableRotation` and `constrainRotation`.
- * By default the rotation value is snapped to zero when approaching the
- * horizontal.
- * The *center constraint* is determined by the `extent` option. By
- * default the center is not constrained at all.
- * @constructor
- * @extends {ol.Object}
- * @param {olx.ViewOptions=} opt_options View options.
- * @api
-ol.View = function(opt_options) {
- ol.Object.call(this);
- var options = ol.obj.assign({}, opt_options);
- * @private
- this.hints_ = [0, 0];
- * @private
- * @type {Array.<Array.<ol.ViewAnimation>>}
- this.animations_ = [];
- * @private
- * @type {number|undefined}
- this.updateAnimationKey_;
- this.updateAnimations_ = this.updateAnimations_.bind(this);
- * @private
- * @const
- * @type {ol.proj.Projection}
- this.projection_ = ol.proj.createProjection(options.projection, 'EPSG:3857');
- this.applyOptions_(options);
-ol.inherits(ol.View, ol.Object);
- * Set up the view with the given options.
- * @param {olx.ViewOptions} options View options.
-ol.View.prototype.applyOptions_ = function(options) {
- * @type {Object.<string, *>}
- var properties = {};
- properties[ol.ViewProperty.CENTER] = options.center !== undefined ?
- options.center : null;
- var resolutionConstraintInfo = ol.View.createResolutionConstraint_(
- options);
- * @private
- * @type {number}
- this.maxResolution_ = resolutionConstraintInfo.maxResolution;
- * @private
- * @type {number}
- this.minResolution_ = resolutionConstraintInfo.minResolution;
- * @private
- * @type {number}
- this.zoomFactor_ = resolutionConstraintInfo.zoomFactor;
- * @private
- * @type {Array.<number>|undefined}
- this.resolutions_ = options.resolutions;
- * @private
- * @type {number}
- this.minZoom_ = resolutionConstraintInfo.minZoom;
- var centerConstraint = ol.View.createCenterConstraint_(options);
- var resolutionConstraint = resolutionConstraintInfo.constraint;
- var rotationConstraint = ol.View.createRotationConstraint_(options);
- * @private
- * @type {ol.Constraints}
- this.constraints_ = new ol.Constraints(
- centerConstraint, resolutionConstraint, rotationConstraint);
- if (options.resolution !== undefined) {
- properties[ol.ViewProperty.RESOLUTION] = options.resolution;
- } else if (options.zoom !== undefined) {
- properties[ol.ViewProperty.RESOLUTION] = this.constrainResolution(
- this.maxResolution_, options.zoom - this.minZoom_);
- properties[ol.ViewProperty.ROTATION] =
- options.rotation !== undefined ? options.rotation : 0;
- this.setProperties(properties);
- * @private
- * @type {olx.ViewOptions}
- this.options_ = options;
- * Get an updated version of the view options used to construct the view. The
- * current resolution (or zoom), center, and rotation are applied to any stored
- * options. The provided options can be uesd to apply new min/max zoom or
- * resolution limits.
- * @param {olx.ViewOptions} newOptions New options to be applied.
- * @return {olx.ViewOptions} New options updated with the current view state.
-ol.View.prototype.getUpdatedOptions_ = function(newOptions) {
- var options = ol.obj.assign({}, this.options_);
- // preserve resolution (or zoom)
- options.resolution = this.getResolution();
- } else {
- options.zoom = this.getZoom();
- // preserve center
- options.center = this.getCenter();
- // preserve rotation
- options.rotation = this.getRotation();
- return ol.obj.assign({}, options, newOptions);
- * Animate the view. The view's center, zoom (or resolution), and rotation
- * can be animated for smooth transitions between view states. For example,
- * to animate the view to a new zoom level:
- * view.animate({zoom: view.getZoom() + 1});
- * By default, the animation lasts one second and uses in-and-out easing. You
- * can customize this behavior by including `duration` (in milliseconds) and
- * `easing` options (see {@link ol.easing}).
- * To chain together multiple animations, call the method with multiple
- * animation objects. For example, to first zoom and then pan:
- * view.animate({zoom: 10}, {center: [0, 0]});
- * If you provide a function as the last argument to the animate method, it
- * will get called at the end of an animation series. The callback will be
- * called with `true` if the animation series completed on its own or `false`
- * if it was cancelled.
- * Animations are cancelled by user interactions (e.g. dragging the map) or by
- * calling `view.setCenter()`, `view.setResolution()`, or `view.setRotation()`
- * (or another method that calls one of these).
- * @param {...(olx.AnimationOptions|function(boolean))} var_args Animation
- * options. Multiple animations can be run in series by passing multiple
- * options objects. To run multiple animations in parallel, call the method
- * multiple times. An optional callback can be provided as a final
- * argument. The callback will be called with a boolean indicating whether
- * the animation completed without being cancelled.
- * @api
-ol.View.prototype.animate = function(var_args) {
- var start = Date.now();
- var center = this.getCenter().slice();
- var resolution = this.getResolution();
- var rotation = this.getRotation();
- var animationCount = arguments.length;
- var callback;
- if (animationCount > 1 && typeof arguments[animationCount - 1] === 'function') {
- callback = arguments[animationCount - 1];
- --animationCount;
- var series = [];
- for (var i = 0; i < animationCount; ++i) {
- var options = /** @type {olx.AnimationOptions} */ (arguments[i]);
- var animation = /** @type {ol.ViewAnimation} */ ({
- start: start,
- complete: false,
- anchor: options.anchor,
- duration: options.duration !== undefined ? options.duration : 1000,
- easing: options.easing || ol.easing.inAndOut
- if (options.center) {
- animation.sourceCenter = center;
- animation.targetCenter = options.center;
- center = animation.targetCenter;
- if (options.zoom !== undefined) {
- animation.sourceResolution = resolution;
- animation.targetResolution = this.constrainResolution(
- this.maxResolution_, options.zoom - this.minZoom_, 0);
- resolution = animation.targetResolution;
- } else if (options.resolution) {
- animation.targetResolution = options.resolution;
- if (options.rotation !== undefined) {
- animation.sourceRotation = rotation;
- animation.targetRotation = options.rotation;
- rotation = animation.targetRotation;
- animation.callback = callback;
- start += animation.duration;
- series.push(animation);
- this.animations_.push(series);
- this.setHint(ol.ViewHint.ANIMATING, 1);
- this.updateAnimations_();
- * Determine if the view is being animated.
- * @return {boolean} The view is being animated.
- * @api
-ol.View.prototype.getAnimating = function() {
- return this.getHints()[ol.ViewHint.ANIMATING] > 0;
- * Cancel any ongoing animations.
- * @api
-ol.View.prototype.cancelAnimations = function() {
- this.setHint(ol.ViewHint.ANIMATING, -this.getHints()[ol.ViewHint.ANIMATING]);
- for (var i = 0, ii = this.animations_.length; i < ii; ++i) {
- var series = this.animations_[i];
- if (series[0].callback) {
- series[0].callback(false);
- this.animations_.length = 0;
- * Update all animations.
-ol.View.prototype.updateAnimations_ = function() {
- if (this.updateAnimationKey_ !== undefined) {
- cancelAnimationFrame(this.updateAnimationKey_);
- this.updateAnimationKey_ = undefined;
- if (!this.getAnimating()) {
- return;
- var now = Date.now();
- var more = false;
- for (var i = this.animations_.length - 1; i >= 0; --i) {
- var seriesComplete = true;
- for (var j = 0, jj = series.length; j < jj; ++j) {
- var animation = series[j];
- if (animation.complete) {
- continue;
- var elapsed = now - animation.start;
- var fraction = animation.duration > 0 ? elapsed / animation.duration : 1;
- if (fraction >= 1) {
- animation.complete = true;
- fraction = 1;
- } else {
- seriesComplete = false;
- var progress = animation.easing(fraction);
- if (animation.sourceCenter) {
- var x0 = animation.sourceCenter[0];
- var y0 = animation.sourceCenter[1];
- var x1 = animation.targetCenter[0];
- var y1 = animation.targetCenter[1];
- var x = x0 + progress * (x1 - x0);
- var y = y0 + progress * (y1 - y0);
- this.set(ol.ViewProperty.CENTER, [x, y]);
- if (animation.sourceResolution && animation.targetResolution) {
- var resolution = progress === 1 ?
- animation.targetResolution :
- animation.sourceResolution + progress * (animation.targetResolution - animation.sourceResolution);
- if (animation.anchor) {
- this.calculateCenterZoom(resolution, animation.anchor));
- this.set(ol.ViewProperty.RESOLUTION, resolution);
- if (animation.sourceRotation !== undefined && animation.targetRotation !== undefined) {
- var rotation = progress === 1 ?
- animation.targetRotation :
- animation.sourceRotation + progress * (animation.targetRotation - animation.sourceRotation);
- this.calculateCenterRotate(rotation, animation.anchor));
- this.set(ol.ViewProperty.ROTATION, rotation);
- more = true;
- if (!animation.complete) {
- break;
- if (seriesComplete) {
- this.animations_[i] = null;
- this.setHint(ol.ViewHint.ANIMATING, -1);
- var callback = series[0].callback;
- if (callback) {
- callback(true);
- // prune completed series
- this.animations_ = this.animations_.filter(Boolean);
- if (more && this.updateAnimationKey_ === undefined) {
- this.updateAnimationKey_ = requestAnimationFrame(this.updateAnimations_);
- * @param {number} rotation Target rotation.
- * @param {ol.Coordinate} anchor Rotation anchor.
- * @return {ol.Coordinate|undefined} Center for rotation and anchor.
-ol.View.prototype.calculateCenterRotate = function(rotation, anchor) {
- var center;
- var currentCenter = this.getCenter();
- if (currentCenter !== undefined) {
- center = [currentCenter[0] - anchor[0], currentCenter[1] - anchor[1]];
- ol.coordinate.rotate(center, rotation - this.getRotation());
- ol.coordinate.add(center, anchor);
- return center;
- * @param {number} resolution Target resolution.
- * @param {ol.Coordinate} anchor Zoom anchor.
- * @return {ol.Coordinate|undefined} Center for resolution and anchor.
-ol.View.prototype.calculateCenterZoom = function(resolution, anchor) {
- var center;
- var currentResolution = this.getResolution();
- if (currentCenter !== undefined && currentResolution !== undefined) {
- var x = anchor[0] -
- resolution * (anchor[0] - currentCenter[0]) / currentResolution;
- var y = anchor[1] -
- resolution * (anchor[1] - currentCenter[1]) / currentResolution;
- center = [x, y];
- return center;
- * @private
- * @return {ol.Size} Viewport size or `[100, 100]` when no viewport is found.
-ol.View.prototype.getSizeFromViewport_ = function() {
- var size = [100, 100];
- var selector = '.ol-viewport[data-view="' + ol.getUid(this) + '"]';
- var element = document.querySelector(selector);
- if (element) {
- var metrics = getComputedStyle(element);
- size[0] = parseInt(metrics.width, 10);
- size[1] = parseInt(metrics.height, 10);
- return size;
- * Get the constrained center of this view.
- * @param {ol.Coordinate|undefined} center Center.
- * @return {ol.Coordinate|undefined} Constrained center.
- * @api
-ol.View.prototype.constrainCenter = function(center) {
- return this.constraints_.center(center);
- * Get the constrained resolution of this view.
- * @param {number|undefined} resolution Resolution.
- * @param {number=} opt_delta Delta. Default is `0`.
- * @param {number=} opt_direction Direction. Default is `0`.
- * @return {number|undefined} Constrained resolution.
- * @api
-ol.View.prototype.constrainResolution = function(
- resolution, opt_delta, opt_direction) {
- var delta = opt_delta || 0;
- var direction = opt_direction || 0;
- return this.constraints_.resolution(resolution, delta, direction);
- * Get the constrained rotation of this view.
- * @param {number|undefined} rotation Rotation.
- * @return {number|undefined} Constrained rotation.
- * @api
-ol.View.prototype.constrainRotation = function(rotation, opt_delta) {
- return this.constraints_.rotation(rotation, delta);
- * Get the view center.
- * @return {ol.Coordinate|undefined} The center of the view.
- * @observable
- * @api
-ol.View.prototype.getCenter = function() {
- return /** @type {ol.Coordinate|undefined} */ (
- this.get(ol.ViewProperty.CENTER));
- * @param {Array.<number>=} opt_hints Destination array.
- * @return {Array.<number>} Hint.
-ol.View.prototype.getHints = function(opt_hints) {
- if (opt_hints !== undefined) {
- opt_hints[0] = this.hints_[0];
- opt_hints[1] = this.hints_[1];
- return opt_hints;
- } else {
- return this.hints_.slice();
- * Calculate the extent for the current view state and the passed size.
- * The size is the pixel dimensions of the box into which the calculated extent
- * should fit. In most cases you want to get the extent of the entire map,
- * that is `map.getSize()`.
- * @param {ol.Size=} opt_size Box pixel size. If not provided, the size of the
- * first map that uses this view will be used.
- * @return {ol.Extent} Extent.
- * @api
-ol.View.prototype.calculateExtent = function(opt_size) {
- var size = opt_size || this.getSizeFromViewport_();
- var center = /** @type {!ol.Coordinate} */ (this.getCenter());
- ol.asserts.assert(center, 1); // The view center is not defined
- var resolution = /** @type {!number} */ (this.getResolution());
- ol.asserts.assert(resolution !== undefined, 2); // The view resolution is not defined
- var rotation = /** @type {!number} */ (this.getRotation());
- ol.asserts.assert(rotation !== undefined, 3); // The view rotation is not defined
- return ol.extent.getForViewAndSize(center, resolution, rotation, size);
- * Get the maximum resolution of the view.
- * @return {number} The maximum resolution of the view.
- * @api
-ol.View.prototype.getMaxResolution = function() {
- return this.maxResolution_;
- * Get the minimum resolution of the view.
- * @return {number} The minimum resolution of the view.
- * @api
-ol.View.prototype.getMinResolution = function() {
- return this.minResolution_;
- * Get the maximum zoom level for the view.
- * @return {number} The maximum zoom level.
- * @api
-ol.View.prototype.getMaxZoom = function() {
- return /** @type {number} */ (this.getZoomForResolution(this.minResolution_));
- * Set a new maximum zoom level for the view.
- * @param {number} zoom The maximum zoom level.
- * @api
-ol.View.prototype.setMaxZoom = function(zoom) {
- this.applyOptions_(this.getUpdatedOptions_({maxZoom: zoom}));
- * Get the minimum zoom level for the view.
- * @return {number} The minimum zoom level.
- * @api
-ol.View.prototype.getMinZoom = function() {
- return /** @type {number} */ (this.getZoomForResolution(this.maxResolution_));
- * Set a new minimum zoom level for the view.
- * @param {number} zoom The minimum zoom level.
- * @api
-ol.View.prototype.setMinZoom = function(zoom) {
- this.applyOptions_(this.getUpdatedOptions_({minZoom: zoom}));
- * Get the view projection.
- * @return {ol.proj.Projection} The projection of the view.
- * @api
-ol.View.prototype.getProjection = function() {
- return this.projection_;
- * Get the view resolution.
- * @return {number|undefined} The resolution of the view.
- * @observable
- * @api
-ol.View.prototype.getResolution = function() {
- return /** @type {number|undefined} */ (
- this.get(ol.ViewProperty.RESOLUTION));
- * Get the resolutions for the view. This returns the array of resolutions
- * passed to the constructor of the {ol.View}, or undefined if none were given.
- * @return {Array.<number>|undefined} The resolutions of the view.
- * @api
-ol.View.prototype.getResolutions = function() {
- return this.resolutions_;
- * Get the resolution for a provided extent (in map units) and size (in pixels).
- * @param {ol.Extent} extent Extent.
- * @param {ol.Size} size Box pixel size.
- * @return {number} The resolution at which the provided extent will render at
- * the given size.
-ol.View.prototype.getResolutionForExtent = function(extent, size) {
- var xResolution = ol.extent.getWidth(extent) / size[0];
- var yResolution = ol.extent.getHeight(extent) / size[1];
- return Math.max(xResolution, yResolution);
- * Return a function that returns a value between 0 and 1 for a
- * resolution. Exponential scaling is assumed.
- * @param {number=} opt_power Power.
- * @return {function(number): number} Resolution for value function.
-ol.View.prototype.getResolutionForValueFunction = function(opt_power) {
- var power = opt_power || 2;
- var maxResolution = this.maxResolution_;
- var minResolution = this.minResolution_;
- var max = Math.log(maxResolution / minResolution) / Math.log(power);
- return (
- * @return {number} Resolution.
- function(value) {
- var resolution = maxResolution / Math.pow(power, value * max);
- return resolution;
- * Get the view rotation.
- * @return {number} The rotation of the view in radians.
- * @observable
- * @api
-ol.View.prototype.getRotation = function() {
- return /** @type {number} */ (this.get(ol.ViewProperty.ROTATION));
- * Return a function that returns a resolution for a value between
- * 0 and 1. Exponential scaling is assumed.
- * @return {function(number): number} Value for resolution function.
-ol.View.prototype.getValueForResolutionFunction = function(opt_power) {
- return (
- * @param {number} resolution Resolution.
- * @return {number} Value.
- function(resolution) {
- var value =
- (Math.log(maxResolution / resolution) / Math.log(power)) / max;
- return value;
- * @return {olx.ViewState} View state.
-ol.View.prototype.getState = function() {
- var center = /** @type {ol.Coordinate} */ (this.getCenter());
- var projection = this.getProjection();
- var resolution = /** @type {number} */ (this.getResolution());
- return /** @type {olx.ViewState} */ ({
- center: center.slice(),
- projection: projection !== undefined ? projection : null,
- resolution: resolution,
- rotation: rotation
- * Get the current zoom level. Return undefined if the current
- * resolution is undefined or not within the "resolution constraints".
- * @return {number|undefined} Zoom.
- * @api
-ol.View.prototype.getZoom = function() {
- var zoom;
- if (resolution !== undefined) {
- zoom = this.getZoomForResolution(resolution);
- return zoom;
- * Get the zoom level for a resolution.
- * @param {number} resolution The resolution.
- * @return {number|undefined} The zoom level for the provided resolution.
- * @api
-ol.View.prototype.getZoomForResolution = function(resolution) {
- var zoom;
- if (resolution >= this.minResolution_ && resolution <= this.maxResolution_) {
- var offset = this.minZoom_ || 0;
- var max, zoomFactor;
- if (this.resolutions_) {
- var nearest = ol.array.linearFindNearest(this.resolutions_, resolution, 1);
- offset += nearest;
- if (nearest == this.resolutions_.length - 1) {
- return offset;
- max = this.resolutions_[nearest];
- zoomFactor = max / this.resolutions_[nearest + 1];
- } else {
- max = this.maxResolution_;
- zoomFactor = this.zoomFactor_;
- zoom = offset + Math.log(max / resolution) / Math.log(zoomFactor);
- return zoom;
- * Fit the given geometry or extent based on the given map size and border.
- * The size is pixel dimensions of the box to fit the extent into.
- * In most cases you will want to use the map size, that is `map.getSize()`.
- * Takes care of the map angle.
- * @param {ol.geom.SimpleGeometry|ol.Extent} geometryOrExtent The geometry or
- * extent to fit the view to.
- * @param {olx.view.FitOptions=} opt_options Options.
- * @api
-ol.View.prototype.fit = function(geometryOrExtent, opt_options) {
- var options = opt_options || {};
- var size = options.size;
- if (!size) {
- size = this.getSizeFromViewport_();
- /** @type {ol.geom.SimpleGeometry} */
- var geometry;
- if (!(geometryOrExtent instanceof ol.geom.SimpleGeometry)) {
- ol.asserts.assert(Array.isArray(geometryOrExtent),
- 24); // Invalid extent or geometry provided as `geometry`
- ol.asserts.assert(!ol.extent.isEmpty(geometryOrExtent),
- 25); // Cannot fit empty extent provided as `geometry`
- geometry = ol.geom.Polygon.fromExtent(geometryOrExtent);
- } else if (geometryOrExtent.getType() === ol.geom.GeometryType.CIRCLE) {
- geometryOrExtent = geometryOrExtent.getExtent();
- geometry.rotate(this.getRotation(), ol.extent.getCenter(geometryOrExtent));
- } else {
- geometry = geometryOrExtent;
- var padding = options.padding !== undefined ? options.padding : [0, 0, 0, 0];
- var constrainResolution = options.constrainResolution !== undefined ?
- options.constrainResolution : true;
- var nearest = options.nearest !== undefined ? options.nearest : false;
- var minResolution;
- if (options.minResolution !== undefined) {
- minResolution = options.minResolution;
- } else if (options.maxZoom !== undefined) {
- minResolution = this.constrainResolution(
- this.maxResolution_, options.maxZoom - this.minZoom_, 0);
- } else {
- minResolution = 0;
- var coords = geometry.getFlatCoordinates();
- // calculate rotated extent
- var cosAngle = Math.cos(-rotation);
- var sinAngle = Math.sin(-rotation);
- var minRotX = +Infinity;
- var minRotY = +Infinity;
- var maxRotX = -Infinity;
- var maxRotY = -Infinity;
- var stride = geometry.getStride();
- for (var i = 0, ii = coords.length; i < ii; i += stride) {
- var rotX = coords[i] * cosAngle - coords[i + 1] * sinAngle;
- var rotY = coords[i] * sinAngle + coords[i + 1] * cosAngle;
- minRotX = Math.min(minRotX, rotX);
- minRotY = Math.min(minRotY, rotY);
- maxRotX = Math.max(maxRotX, rotX);
- maxRotY = Math.max(maxRotY, rotY);
- // calculate resolution
- var resolution = this.getResolutionForExtent(
- [minRotX, minRotY, maxRotX, maxRotY],
- [size[0] - padding[1] - padding[3], size[1] - padding[0] - padding[2]]);
- resolution = isNaN(resolution) ? minResolution :
- Math.max(resolution, minResolution);
- if (constrainResolution) {
- var constrainedResolution = this.constrainResolution(resolution, 0, 0);
- if (!nearest && constrainedResolution < resolution) {
- constrainedResolution = this.constrainResolution(
- constrainedResolution, -1, 0);
- resolution = constrainedResolution;
- // calculate center
- sinAngle = -sinAngle; // go back to original rotation
- var centerRotX = (minRotX + maxRotX) / 2;
- var centerRotY = (minRotY + maxRotY) / 2;
- centerRotX += (padding[1] - padding[3]) / 2 * resolution;
- centerRotY += (padding[0] - padding[2]) / 2 * resolution;
- var centerX = centerRotX * cosAngle - centerRotY * sinAngle;
- var centerY = centerRotY * cosAngle + centerRotX * sinAngle;
- var center = [centerX, centerY];
- if (options.duration !== undefined) {
- this.animate({
- center: center,
- duration: options.duration,
- } else {
- this.setResolution(resolution);
- this.setCenter(center);
- * Center on coordinate and view position.
- * @param {ol.Coordinate} coordinate Coordinate.
- * @param {ol.Pixel} position Position on the view to center on.
- * @api
-ol.View.prototype.centerOn = function(coordinate, size, position) {
- // calculate rotated position
- var rotX = coordinate[0] * cosAngle - coordinate[1] * sinAngle;
- var rotY = coordinate[1] * cosAngle + coordinate[0] * sinAngle;
- rotX += (size[0] / 2 - position[0]) * resolution;
- rotY += (position[1] - size[1] / 2) * resolution;
- // go back to original angle
- var centerX = rotX * cosAngle - rotY * sinAngle;
- var centerY = rotY * cosAngle + rotX * sinAngle;
- this.setCenter([centerX, centerY]);
- * @return {boolean} Is defined.
-ol.View.prototype.isDef = function() {
- return !!this.getCenter() && this.getResolution() !== undefined;
- * Rotate the view around a given coordinate.
- * @param {number} rotation New rotation value for the view.
- * @param {ol.Coordinate=} opt_anchor The rotation center.
- * @api
-ol.View.prototype.rotate = function(rotation, opt_anchor) {
- if (opt_anchor !== undefined) {
- var center = this.calculateCenterRotate(rotation, opt_anchor);
- this.setRotation(rotation);
- * Set the center of the current view.
- * @param {ol.Coordinate|undefined} center The center of the view.
- * @observable
- * @api
-ol.View.prototype.setCenter = function(center) {
- this.set(ol.ViewProperty.CENTER, center);
- if (this.getAnimating()) {
- this.cancelAnimations();
- * @param {ol.ViewHint} hint Hint.
- * @param {number} delta Delta.
- * @return {number} New value.
-ol.View.prototype.setHint = function(hint, delta) {
- this.hints_[hint] += delta;
- this.changed();
- return this.hints_[hint];
- * Set the resolution for this view.
- * @param {number|undefined} resolution The resolution of the view.
- * @observable
- * @api
-ol.View.prototype.setResolution = function(resolution) {
- * Set the rotation for this view.
- * @param {number} rotation The rotation of the view in radians.
- * @observable
- * @api
-ol.View.prototype.setRotation = function(rotation) {
- * Zoom to a specific zoom level.
- * @param {number} zoom Zoom level.
- * @api
-ol.View.prototype.setZoom = function(zoom) {
- var resolution = this.constrainResolution(
- this.maxResolution_, zoom - this.minZoom_, 0);
- * @private
- * @return {ol.CenterConstraintType} The constraint.
-ol.View.createCenterConstraint_ = function(options) {
- if (options.extent !== undefined) {
- return ol.CenterConstraint.createExtent(options.extent);
- } else {
- return ol.CenterConstraint.none;
- * @private
- * @return {{constraint: ol.ResolutionConstraintType, maxResolution: number,
- * minResolution: number, zoomFactor: number}} The constraint.
-ol.View.createResolutionConstraint_ = function(options) {
- var resolutionConstraint;
- var maxResolution;
- // TODO: move these to be ol constants
- // see https://github.com/openlayers/openlayers/issues/2076
- var defaultMaxZoom = 28;
- var defaultZoomFactor = 2;
- var minZoom = options.minZoom !== undefined ?
- options.minZoom : ol.DEFAULT_MIN_ZOOM;
- var maxZoom = options.maxZoom !== undefined ?
- options.maxZoom : defaultMaxZoom;
- var zoomFactor = options.zoomFactor !== undefined ?
- options.zoomFactor : defaultZoomFactor;
- if (options.resolutions !== undefined) {
- var resolutions = options.resolutions;
- maxResolution = resolutions[0];
- minResolution = resolutions[resolutions.length - 1];
- resolutionConstraint = ol.ResolutionConstraint.createSnapToResolutions(
- resolutions);
- } else {
- // calculate the default min and max resolution
- var projection = ol.proj.createProjection(options.projection, 'EPSG:3857');
- var extent = projection.getExtent();
- var size = !extent ?
- // use an extent that can fit the whole world if need be
- 360 * ol.proj.METERS_PER_UNIT[ol.proj.Units.DEGREES] /
- projection.getMetersPerUnit() :
- Math.max(ol.extent.getWidth(extent), ol.extent.getHeight(extent));
- var defaultMaxResolution = size / ol.DEFAULT_TILE_SIZE / Math.pow(
- defaultZoomFactor, ol.DEFAULT_MIN_ZOOM);
- var defaultMinResolution = defaultMaxResolution / Math.pow(
- defaultZoomFactor, defaultMaxZoom - ol.DEFAULT_MIN_ZOOM);
- // user provided maxResolution takes precedence
- maxResolution = options.maxResolution;
- if (maxResolution !== undefined) {
- minZoom = 0;
- } else {
- maxResolution = defaultMaxResolution / Math.pow(zoomFactor, minZoom);
- // user provided minResolution takes precedence
- if (minResolution === undefined) {
- if (options.maxZoom !== undefined) {
- if (options.maxResolution !== undefined) {
- minResolution = maxResolution / Math.pow(zoomFactor, maxZoom);
- } else {
- minResolution = defaultMaxResolution / Math.pow(zoomFactor, maxZoom);
- } else {
- minResolution = defaultMinResolution;
- // given discrete zoom levels, minResolution may be different than provided
- maxZoom = minZoom + Math.floor(
- Math.log(maxResolution / minResolution) / Math.log(zoomFactor));
- minResolution = maxResolution / Math.pow(zoomFactor, maxZoom - minZoom);
- resolutionConstraint = ol.ResolutionConstraint.createSnapToPower(
- zoomFactor, maxResolution, maxZoom - minZoom);
- return {constraint: resolutionConstraint, maxResolution: maxResolution,
- minResolution: minResolution, minZoom: minZoom, zoomFactor: zoomFactor};
- * @private
- * @return {ol.RotationConstraintType} Rotation constraint.
-ol.View.createRotationConstraint_ = function(options) {
- var enableRotation = options.enableRotation !== undefined ?
- options.enableRotation : true;
- if (enableRotation) {
- var constrainRotation = options.constrainRotation;
- if (constrainRotation === undefined || constrainRotation === true) {
- return ol.RotationConstraint.createSnapToZero();
- } else if (constrainRotation === false) {
- return ol.RotationConstraint.none;
- } else if (typeof constrainRotation === 'number') {
- return ol.RotationConstraint.createSnapToN(constrainRotation);
- } else {
- } else {
- return ol.RotationConstraint.disable;
-goog.provide('ol.Kinetic');
- * @classdesc
- * Implementation of inertial deceleration for map movement.
- * @constructor
- * @param {number} decay Rate of decay (must be negative).
- * @param {number} minVelocity Minimum velocity (pixels/millisecond).
- * @param {number} delay Delay to consider to calculate the kinetic
- * initial values (milliseconds).
- * @struct
- * @api
-ol.Kinetic = function(decay, minVelocity, delay) {
- * @private
- * @type {number}
- this.decay_ = decay;
- * @private
- * @type {number}
- this.minVelocity_ = minVelocity;
- * @private
- * @type {number}
- this.delay_ = delay;
- * @private
- this.points_ = [];
- * @private
- * @type {number}
- this.angle_ = 0;
- * @private
- * @type {number}
- this.initialVelocity_ = 0;
- * FIXME empty description for jsdoc
-ol.Kinetic.prototype.begin = function() {
- this.points_.length = 0;
- this.angle_ = 0;
- * @param {number} x X.
- * @param {number} y Y.
-ol.Kinetic.prototype.update = function(x, y) {
- this.points_.push(x, y, Date.now());
- * @return {boolean} Whether we should do kinetic animation.
-ol.Kinetic.prototype.end = function() {
- if (this.points_.length < 6) {
- // at least 2 points are required (i.e. there must be at least 6 elements
- // in the array)
- return false;
- var delay = Date.now() - this.delay_;
- var lastIndex = this.points_.length - 3;
- if (this.points_[lastIndex + 2] < delay) {
- // the last tracked point is too old, which means that the user stopped
- // panning before releasing the map
- return false;
- // get the first point which still falls into the delay time
- var firstIndex = lastIndex - 3;
- while (firstIndex > 0 && this.points_[firstIndex + 2] > delay) {
- firstIndex -= 3;
- var duration = this.points_[lastIndex + 2] - this.points_[firstIndex + 2];
- var dx = this.points_[lastIndex] - this.points_[firstIndex];
- var dy = this.points_[lastIndex + 1] - this.points_[firstIndex + 1];
- this.angle_ = Math.atan2(dy, dx);
- this.initialVelocity_ = Math.sqrt(dx * dx + dy * dy) / duration;
- return this.initialVelocity_ > this.minVelocity_;
- * @return {number} Total distance travelled (pixels).
-ol.Kinetic.prototype.getDistance = function() {
- return (this.minVelocity_ - this.initialVelocity_) / this.decay_;
- * @return {number} Angle of the kinetic panning animation (radians).
-ol.Kinetic.prototype.getAngle = function() {
- return this.angle_;
-goog.provide('ol.interaction.Property');
- * @enum {string}
-ol.interaction.Property = {
- ACTIVE: 'active'
-// FIXME factor out key precondition (shift et. al)
-goog.provide('ol.interaction.Interaction');
-goog.require('ol.interaction.Property');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * User actions that change the state of the map. Some are similar to controls,
- * but are not associated with a DOM element.
- * For example, {@link ol.interaction.KeyboardZoom} is functionally the same as
- * {@link ol.control.Zoom}, but triggered by a keyboard event not a button
- * element event.
- * Although interactions do not have a DOM element, some of them do render
- * vectors and so are visible on the screen.
- * @constructor
- * @param {olx.interaction.InteractionOptions} options Options.
- * @api
-ol.interaction.Interaction = function(options) {
- * @private
- * @type {ol.Map}
- this.map_ = null;
- this.setActive(true);
- * @type {function(ol.MapBrowserEvent):boolean}
- this.handleEvent = options.handleEvent;
-ol.inherits(ol.interaction.Interaction, ol.Object);
- * Return whether the interaction is currently active.
- * @return {boolean} `true` if the interaction is active, `false` otherwise.
- * @observable
- * @api
-ol.interaction.Interaction.prototype.getActive = function() {
- return /** @type {boolean} */ (
- this.get(ol.interaction.Property.ACTIVE));
- * Get the map associated with this interaction.
- * @return {ol.Map} Map.
- * @api
-ol.interaction.Interaction.prototype.getMap = function() {
- return this.map_;
- * Activate or deactivate the interaction.
- * @param {boolean} active Active.
- * @observable
- * @api
-ol.interaction.Interaction.prototype.setActive = function(active) {
- this.set(ol.interaction.Property.ACTIVE, active);
- * Remove the interaction from its current map and attach it to the new map.
- * Subclasses may set up event handlers to get notified about changes to
- * the map here.
- * @param {ol.Map} map Map.
-ol.interaction.Interaction.prototype.setMap = function(map) {
- this.map_ = map;
- * @param {ol.View} view View.
- * @param {ol.Coordinate} delta Delta.
- * @param {number=} opt_duration Duration.
-ol.interaction.Interaction.pan = function(view, delta, opt_duration) {
- var currentCenter = view.getCenter();
- if (currentCenter) {
- var center = view.constrainCenter(
- [currentCenter[0] + delta[0], currentCenter[1] + delta[1]]);
- if (opt_duration) {
- view.animate({
- duration: opt_duration,
- easing: ol.easing.linear,
- center: center
- } else {
- view.setCenter(center);
- * @param {ol.Coordinate=} opt_anchor Anchor coordinate.
-ol.interaction.Interaction.rotate = function(view, rotation, opt_anchor, opt_duration) {
- rotation = view.constrainRotation(rotation, 0);
- ol.interaction.Interaction.rotateWithoutConstraints(
- view, rotation, opt_anchor, opt_duration);
-ol.interaction.Interaction.rotateWithoutConstraints = function(view, rotation, opt_anchor, opt_duration) {
- if (rotation !== undefined) {
- var currentRotation = view.getRotation();
- if (currentRotation !== undefined && currentCenter && opt_duration > 0) {
- view.animate({
- rotation: rotation,
- anchor: opt_anchor,
- easing: ol.easing.easeOut
- } else {
- view.rotate(rotation, opt_anchor);
- * @param {number|undefined} resolution Resolution to go to.
- * @param {number=} opt_direction Zooming direction; > 0 indicates
- * zooming out, in which case the constraints system will select
- * the largest nearest resolution; < 0 indicates zooming in, in
- * which case the constraints system will select the smallest
- * nearest resolution; == 0 indicates that the zooming direction
- * is unknown/not relevant, in which case the constraints system
- * will select the nearest resolution. If not defined 0 is
- * assumed.
-ol.interaction.Interaction.zoom = function(view, resolution, opt_anchor, opt_duration, opt_direction) {
- resolution = view.constrainResolution(resolution, 0, opt_direction);
- ol.interaction.Interaction.zoomWithoutConstraints(
- view, resolution, opt_anchor, opt_duration);
- * @param {number} delta Delta from previous zoom level.
-ol.interaction.Interaction.zoomByDelta = function(view, delta, opt_anchor, opt_duration) {
- var currentResolution = view.getResolution();
- var resolution = view.constrainResolution(currentResolution, delta, 0);
- // If we have a constraint on center, we need to change the anchor so that the
- // new center is within the extent. We first calculate the new center, apply
- // the constraint to it, and then calculate back the anchor
- if (opt_anchor && resolution !== undefined && resolution !== currentResolution) {
- var center = view.calculateCenterZoom(resolution, opt_anchor);
- center = view.constrainCenter(center);
- opt_anchor = [
- (resolution * currentCenter[0] - currentResolution * center[0]) /
- (resolution - currentResolution),
- (resolution * currentCenter[1] - currentResolution * center[1]) /
-ol.interaction.Interaction.zoomWithoutConstraints = function(view, resolution, opt_anchor, opt_duration) {
- if (resolution) {
- if (currentResolution !== undefined && currentCenter &&
- resolution !== currentResolution && opt_duration) {
- view.animate({
- } else {
- if (opt_anchor) {
- view.setResolution(resolution);
-goog.provide('ol.interaction.DoubleClickZoom');
-goog.require('ol');
-goog.require('ol.MapBrowserEventType');
-goog.require('ol.interaction.Interaction');
- * @classdesc
- * Allows the user to zoom by double-clicking on the map.
- * @constructor
- * @extends {ol.interaction.Interaction}
- * @param {olx.interaction.DoubleClickZoomOptions=} opt_options Options.
- * @api
-ol.interaction.DoubleClickZoom = function(opt_options) {
- var options = opt_options ? opt_options : {};
- * @private
- * @type {number}
- this.delta_ = options.delta ? options.delta : 1;
- ol.interaction.Interaction.call(this, {
- handleEvent: ol.interaction.DoubleClickZoom.handleEvent
- * @private
- * @type {number}
- this.duration_ = options.duration !== undefined ? options.duration : 250;
-ol.inherits(ol.interaction.DoubleClickZoom, ol.interaction.Interaction);
- * Handles the {@link ol.MapBrowserEvent map browser event} (if it was a
- * doubleclick) and eventually zooms the map.
- * @param {ol.MapBrowserEvent} mapBrowserEvent Map browser event.
- * @return {boolean} `false` to stop event propagation.
- * @this {ol.interaction.DoubleClickZoom}
- * @api
-ol.interaction.DoubleClickZoom.handleEvent = function(mapBrowserEvent) {
- var stopEvent = false;
- var browserEvent = mapBrowserEvent.originalEvent;
- if (mapBrowserEvent.type == ol.MapBrowserEventType.DBLCLICK) {
- var map = mapBrowserEvent.map;
- var anchor = mapBrowserEvent.coordinate;
- var delta = browserEvent.shiftKey ? -this.delta_ : this.delta_;
- var view = map.getView();
- ol.interaction.Interaction.zoomByDelta(
- view, delta, anchor, this.duration_);
- mapBrowserEvent.preventDefault();
- stopEvent = true;
- return !stopEvent;
-goog.provide('ol.events.condition');
-goog.require('ol.functions');
-goog.require('ol.has');
- * Return `true` if only the alt-key is pressed, `false` otherwise (e.g. when
- * additionally the shift-key is pressed).
- * @return {boolean} True if only the alt key is pressed.
- * @api
-ol.events.condition.altKeyOnly = function(mapBrowserEvent) {
- var originalEvent = mapBrowserEvent.originalEvent;
- return (
- originalEvent.altKey &&
- !(originalEvent.metaKey || originalEvent.ctrlKey) &&
- !originalEvent.shiftKey);
- * Return `true` if only the alt-key and shift-key is pressed, `false` otherwise
- * (e.g. when additionally the platform-modifier-key is pressed).
- * @return {boolean} True if only the alt and shift keys are pressed.
- * @api
-ol.events.condition.altShiftKeysOnly = function(mapBrowserEvent) {
- return (
- originalEvent.shiftKey);
- * Return always true.
- * @return {boolean} True.
- * @function
- * @api
-ol.events.condition.always = ol.functions.TRUE;
- * Return `true` if the event is a `click` event, `false` otherwise.
- * @return {boolean} True if the event is a map `click` event.
- * @api
-ol.events.condition.click = function(mapBrowserEvent) {
- return mapBrowserEvent.type == ol.MapBrowserEventType.CLICK;
- * Return `true` if the event has an "action"-producing mouse button.
- * By definition, this includes left-click on windows/linux, and left-click
- * without the ctrl key on Macs.
- * @return {boolean} The result.
-ol.events.condition.mouseActionButton = function(mapBrowserEvent) {
- return originalEvent.button == 0 &&
- !(ol.has.WEBKIT && ol.has.MAC && originalEvent.ctrlKey);
- * Return always false.
- * @return {boolean} False.
- * @function
- * @api
-ol.events.condition.never = ol.functions.FALSE;
- * Return `true` if the browser event is a `pointermove` event, `false`
- * otherwise.
- * @return {boolean} True if the browser event is a `pointermove` event.
- * @api
-ol.events.condition.pointerMove = function(mapBrowserEvent) {
- return mapBrowserEvent.type == 'pointermove';
- * Return `true` if the event is a map `singleclick` event, `false` otherwise.
- * @return {boolean} True if the event is a map `singleclick` event.
- * @api
-ol.events.condition.singleClick = function(mapBrowserEvent) {
- return mapBrowserEvent.type == ol.MapBrowserEventType.SINGLECLICK;
- * Return `true` if the event is a map `dblclick` event, `false` otherwise.
- * @return {boolean} True if the event is a map `dblclick` event.
- * @api
-ol.events.condition.doubleClick = function(mapBrowserEvent) {
- return mapBrowserEvent.type == ol.MapBrowserEventType.DBLCLICK;
- * Return `true` if no modifier key (alt-, shift- or platform-modifier-key) is
- * pressed.
- * @return {boolean} True only if there no modifier keys are pressed.
- * @api
-ol.events.condition.noModifierKeys = function(mapBrowserEvent) {
- return (
- !originalEvent.altKey &&
- * Return `true` if only the platform-modifier-key (the meta-key on Mac,
- * ctrl-key otherwise) is pressed, `false` otherwise (e.g. when additionally
- * the shift-key is pressed).
- * @return {boolean} True if only the platform modifier key is pressed.
- * @api
-ol.events.condition.platformModifierKeyOnly = function(mapBrowserEvent) {
- return (
- (ol.has.MAC ? originalEvent.metaKey : originalEvent.ctrlKey) &&
- * Return `true` if only the shift-key is pressed, `false` otherwise (e.g. when
- * additionally the alt-key is pressed).
- * @return {boolean} True if only the shift key is pressed.
- * @api
-ol.events.condition.shiftKeyOnly = function(mapBrowserEvent) {
- return (
- * Return `true` if the target element is not editable, i.e. not a `<input>`-,
- * `<select>`- or `<textarea>`-element, `false` otherwise.
- * @return {boolean} True only if the target element is not editable.
- * @api
-ol.events.condition.targetNotEditable = function(mapBrowserEvent) {
- var target = mapBrowserEvent.originalEvent.target;
- var tagName = target.tagName;
- return (
- tagName !== 'INPUT' &&
- tagName !== 'SELECT' &&
- tagName !== 'TEXTAREA');
- * Return `true` if the event originates from a mouse device.
- * @return {boolean} True if the event originates from a mouse device.
- * @api
-ol.events.condition.mouseOnly = function(mapBrowserEvent) {
- ol.asserts.assert(mapBrowserEvent.pointerEvent, 56); // mapBrowserEvent must originate from a pointer event
- // see http://www.w3.org/TR/pointerevents/#widl-PointerEvent-pointerType
- return /** @type {ol.MapBrowserEvent} */ (mapBrowserEvent).pointerEvent.pointerType == 'mouse';
- * Return `true` if the event originates from a primary pointer in
- * contact with the surface or if the left mouse button is pressed.
- * @see http://www.w3.org/TR/pointerevents/#button-states
- * @return {boolean} True if the event originates from a primary pointer.
- * @api
-ol.events.condition.primaryAction = function(mapBrowserEvent) {
- var pointerEvent = mapBrowserEvent.pointerEvent;
- return pointerEvent.isPrimary && pointerEvent.button === 0;
-goog.provide('ol.interaction.Pointer');
-goog.require('ol.MapBrowserPointerEvent');
- * @classdesc
- * Base class that calls user-defined functions on `down`, `move` and `up`
- * events. This class also manages "drag sequences".
- * When the `handleDownEvent` user function returns `true` a drag sequence is
- * started. During a drag sequence the `handleDragEvent` user function is
- * called on `move` events. The drag sequence ends when the `handleUpEvent`
- * user function is called and returns `false`.
- * @constructor
- * @param {olx.interaction.PointerOptions=} opt_options Options.
- * @api
-ol.interaction.Pointer = function(opt_options) {
- var handleEvent = options.handleEvent ?
- options.handleEvent : ol.interaction.Pointer.handleEvent;
- handleEvent: handleEvent
- * @type {function(ol.MapBrowserPointerEvent):boolean}
- * @private
- this.handleDownEvent_ = options.handleDownEvent ?
- options.handleDownEvent : ol.interaction.Pointer.handleDownEvent;
- * @type {function(ol.MapBrowserPointerEvent)}
- * @private
- this.handleDragEvent_ = options.handleDragEvent ?
- options.handleDragEvent : ol.interaction.Pointer.handleDragEvent;
- * @private
- this.handleMoveEvent_ = options.handleMoveEvent ?
- options.handleMoveEvent : ol.interaction.Pointer.handleMoveEvent;
- * @private
- this.handleUpEvent_ = options.handleUpEvent ?
- options.handleUpEvent : ol.interaction.Pointer.handleUpEvent;
- * @type {boolean}
- * @protected
- this.handlingDownUpSequence = false;
- * @type {Object.<number, ol.pointer.PointerEvent>}
- * @private
- this.trackedPointers_ = {};
- * @type {Array.<ol.pointer.PointerEvent>}
- * @protected
- this.targetPointers = [];
-ol.inherits(ol.interaction.Pointer, ol.interaction.Interaction);
- * @param {Array.<ol.pointer.PointerEvent>} pointerEvents List of events.
- * @return {ol.Pixel} Centroid pixel.
-ol.interaction.Pointer.centroid = function(pointerEvents) {
- var length = pointerEvents.length;
- var clientX = 0;
- var clientY = 0;
- for (var i = 0; i < length; i++) {
- clientX += pointerEvents[i].clientX;
- clientY += pointerEvents[i].clientY;
- return [clientX / length, clientY / length];
- * @param {ol.MapBrowserPointerEvent} mapBrowserEvent Event.
- * @return {boolean} Whether the event is a pointerdown, pointerdrag
- * or pointerup event.
- * @private
-ol.interaction.Pointer.prototype.isPointerDraggingEvent_ = function(mapBrowserEvent) {
- var type = mapBrowserEvent.type;
- return (
- type === ol.MapBrowserEventType.POINTERDOWN ||
- type === ol.MapBrowserEventType.POINTERDRAG ||
- type === ol.MapBrowserEventType.POINTERUP);
- * @private
-ol.interaction.Pointer.prototype.updateTrackedPointers_ = function(mapBrowserEvent) {
- if (this.isPointerDraggingEvent_(mapBrowserEvent)) {
- var event = mapBrowserEvent.pointerEvent;
- if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERUP) {
- delete this.trackedPointers_[event.pointerId];
- } else if (mapBrowserEvent.type ==
- ol.MapBrowserEventType.POINTERDOWN) {
- this.trackedPointers_[event.pointerId] = event;
- } else if (event.pointerId in this.trackedPointers_) {
- // update only when there was a pointerdown event for this pointer
- this.targetPointers = ol.obj.getValues(this.trackedPointers_);
- * @this {ol.interaction.Pointer}
-ol.interaction.Pointer.handleDragEvent = ol.nullFunction;
- * @return {boolean} Capture dragging.
-ol.interaction.Pointer.handleUpEvent = ol.functions.FALSE;
-ol.interaction.Pointer.handleDownEvent = ol.functions.FALSE;
-ol.interaction.Pointer.handleMoveEvent = ol.nullFunction;
- * Handles the {@link ol.MapBrowserEvent map browser event} and may call into
- * other functions, if event sequences like e.g. 'drag' or 'down-up' etc. are
- * detected.
- * @api
-ol.interaction.Pointer.handleEvent = function(mapBrowserEvent) {
- if (!(mapBrowserEvent instanceof ol.MapBrowserPointerEvent)) {
- return true;
- this.updateTrackedPointers_(mapBrowserEvent);
- if (this.handlingDownUpSequence) {
- if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERDRAG) {
- this.handleDragEvent_(mapBrowserEvent);
- } else if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERUP) {
- var handledUp = this.handleUpEvent_(mapBrowserEvent);
- this.handlingDownUpSequence = handledUp && this.targetPointers.length > 0;
- } else {
- if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERDOWN) {
- var handled = this.handleDownEvent_(mapBrowserEvent);
- this.handlingDownUpSequence = handled;
- stopEvent = this.shouldStopEvent(handled);
- } else if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERMOVE) {
- this.handleMoveEvent_(mapBrowserEvent);
- * This method is used to determine if "down" events should be propagated to
- * other interactions or should be stopped.
- * The method receives the return code of the "handleDownEvent" function.
- * By default this function is the "identity" function. It's overidden in
- * child classes.
- * @param {boolean} handled Was the event handled by the interaction?
- * @return {boolean} Should the event be stopped?
- * @protected
-ol.interaction.Pointer.prototype.shouldStopEvent = function(handled) {
- return handled;
-goog.provide('ol.interaction.DragPan');
-goog.require('ol.events.condition');
-goog.require('ol.interaction.Pointer');
- * @classdesc
- * Allows the user to pan the map by dragging the map.
- * @constructor
- * @extends {ol.interaction.Pointer}
- * @param {olx.interaction.DragPanOptions=} opt_options Options.
- * @api
-ol.interaction.DragPan = function(opt_options) {
- ol.interaction.Pointer.call(this, {
- handleDownEvent: ol.interaction.DragPan.handleDownEvent_,
- handleDragEvent: ol.interaction.DragPan.handleDragEvent_,
- handleUpEvent: ol.interaction.DragPan.handleUpEvent_
- * @private
- * @type {ol.Kinetic|undefined}
- this.kinetic_ = options.kinetic;
- * @type {ol.Pixel}
- this.lastCentroid = null;
- * @type {number}
- this.lastPointersCount_;
- * @private
- * @type {ol.EventsConditionType}
- this.condition_ = options.condition ?
- options.condition : ol.events.condition.noModifierKeys;
- * @private
- * @type {boolean}
- this.noKinetic_ = false;
-ol.inherits(ol.interaction.DragPan, ol.interaction.Pointer);
- * @this {ol.interaction.DragPan}
- * @private
-ol.interaction.DragPan.handleDragEvent_ = function(mapBrowserEvent) {
- var targetPointers = this.targetPointers;
- var centroid =
- ol.interaction.Pointer.centroid(targetPointers);
- if (targetPointers.length == this.lastPointersCount_) {
- if (this.kinetic_) {
- this.kinetic_.update(centroid[0], centroid[1]);
- if (this.lastCentroid) {
- var deltaX = this.lastCentroid[0] - centroid[0];
- var deltaY = centroid[1] - this.lastCentroid[1];
- var viewState = view.getState();
- var center = [deltaX, deltaY];
- ol.coordinate.scale(center, viewState.resolution);
- ol.coordinate.rotate(center, viewState.rotation);
- ol.coordinate.add(center, viewState.center);
- } else if (this.kinetic_) {
- // reset so we don't overestimate the kinetic energy after
- // after one finger down, tiny drag, second finger down
- this.kinetic_.begin();
- this.lastCentroid = centroid;
- this.lastPointersCount_ = targetPointers.length;
- * @return {boolean} Stop drag sequence?
- * @private
-ol.interaction.DragPan.handleUpEvent_ = function(mapBrowserEvent) {
- if (this.targetPointers.length === 0) {
- if (!this.noKinetic_ && this.kinetic_ && this.kinetic_.end()) {
- var distance = this.kinetic_.getDistance();
- var angle = this.kinetic_.getAngle();
- var center = /** @type {!ol.Coordinate} */ (view.getCenter());
- var centerpx = map.getPixelFromCoordinate(center);
- var dest = map.getCoordinateFromPixel([
- centerpx[0] - distance * Math.cos(angle),
- centerpx[1] - distance * Math.sin(angle)
- view.animate({
- center: view.constrainCenter(dest),
- duration: 500,
- view.setHint(ol.ViewHint.INTERACTING, -1);
- return false;
- } else {
- // after one finger up, tiny drag, second finger up
- return true;
- * @return {boolean} Start drag sequence?
- * @private
-ol.interaction.DragPan.handleDownEvent_ = function(mapBrowserEvent) {
- if (this.targetPointers.length > 0 && this.condition_(mapBrowserEvent)) {
- if (!this.handlingDownUpSequence) {
- view.setHint(ol.ViewHint.INTERACTING, 1);
- // stop any current animation
- if (view.getHints()[ol.ViewHint.ANIMATING]) {
- view.setCenter(mapBrowserEvent.frameState.viewState.center);
- // No kinetic as soon as more than one pointer on the screen is
- // detected. This is to prevent nasty pans after pinch.
- this.noKinetic_ = this.targetPointers.length > 1;
- return true;
- } else {
- return false;
- * @inheritDoc
-ol.interaction.DragPan.prototype.shouldStopEvent = ol.functions.FALSE;
-goog.provide('ol.interaction.DragRotate');
- * @classdesc
- * Allows the user to rotate the map by clicking and dragging on the map,
- * normally combined with an {@link ol.events.condition} that limits
- * it to when the alt and shift keys are held down.
- * This interaction is only supported for mouse devices.
- * @constructor
- * @param {olx.interaction.DragRotateOptions=} opt_options Options.
- * @api
-ol.interaction.DragRotate = function(opt_options) {
- handleDownEvent: ol.interaction.DragRotate.handleDownEvent_,
- handleDragEvent: ol.interaction.DragRotate.handleDragEvent_,
- handleUpEvent: ol.interaction.DragRotate.handleUpEvent_
- * @private
- options.condition : ol.events.condition.altShiftKeysOnly;
- * @private
- this.lastAngle_ = undefined;
- * @private
- * @type {number}
-ol.inherits(ol.interaction.DragRotate, ol.interaction.Pointer);
- * @this {ol.interaction.DragRotate}
- * @private
-ol.interaction.DragRotate.handleDragEvent_ = function(mapBrowserEvent) {
- if (!ol.events.condition.mouseOnly(mapBrowserEvent)) {
- return;
- var size = map.getSize();
- var offset = mapBrowserEvent.pixel;
- var theta =
- Math.atan2(size[1] / 2 - offset[1], offset[0] - size[0] / 2);
- if (this.lastAngle_ !== undefined) {
- var delta = theta - this.lastAngle_;
- var rotation = view.getRotation();
- view, rotation - delta);
- this.lastAngle_ = theta;
- * @private
-ol.interaction.DragRotate.handleUpEvent_ = function(mapBrowserEvent) {
- return true;
- ol.interaction.Interaction.rotate(view, rotation,
- undefined, this.duration_);
- return false;
- * @private
-ol.interaction.DragRotate.handleDownEvent_ = function(mapBrowserEvent) {
- return false;
- if (ol.events.condition.mouseActionButton(mapBrowserEvent) &&
- this.condition_(mapBrowserEvent)) {
- map.getView().setHint(ol.ViewHint.INTERACTING, 1);
- return true;
- } else {
- return false;
- * @inheritDoc
-ol.interaction.DragRotate.prototype.shouldStopEvent = ol.functions.FALSE;
-// FIXME add rotation
-goog.provide('ol.render.Box');
-goog.require('ol.Disposable');
- * @constructor
- * @extends {ol.Disposable}
- * @param {string} className CSS class name.
-ol.render.Box = function(className) {
- * @type {ol.geom.Polygon}
- * @private
- this.geometry_ = null;
- * @type {HTMLDivElement}
- * @private
- this.element_ = /** @type {HTMLDivElement} */ (document.createElement('div'));
- this.element_.style.position = 'absolute';
- this.element_.className = 'ol-box ' + className;
- * @private
- * @type {ol.Map}
- this.map_ = null;
- * @private
- this.startPixel_ = null;
- * @private
- this.endPixel_ = null;
-ol.inherits(ol.render.Box, ol.Disposable);
- * @inheritDoc
-ol.render.Box.prototype.disposeInternal = function() {
- this.setMap(null);
- * @private
-ol.render.Box.prototype.render_ = function() {
- var startPixel = this.startPixel_;
- var endPixel = this.endPixel_;
- var px = 'px';
- var style = this.element_.style;
- style.left = Math.min(startPixel[0], endPixel[0]) + px;
- style.top = Math.min(startPixel[1], endPixel[1]) + px;
- style.width = Math.abs(endPixel[0] - startPixel[0]) + px;
- style.height = Math.abs(endPixel[1] - startPixel[1]) + px;
-ol.render.Box.prototype.setMap = function(map) {
- if (this.map_) {
- this.map_.getOverlayContainer().removeChild(this.element_);
- style.left = style.top = style.width = style.height = 'inherit';
- this.map_ = map;
- if (this.map_) {
- this.map_.getOverlayContainer().appendChild(this.element_);
- * @param {ol.Pixel} startPixel Start pixel.
- * @param {ol.Pixel} endPixel End pixel.
-ol.render.Box.prototype.setPixels = function(startPixel, endPixel) {
- this.startPixel_ = startPixel;
- this.endPixel_ = endPixel;
- this.createOrUpdateGeometry();
- this.render_();
- * Creates or updates the cached geometry.
-ol.render.Box.prototype.createOrUpdateGeometry = function() {
- var pixels = [
- startPixel,
- [startPixel[0], endPixel[1]],
- endPixel,
- [endPixel[0], startPixel[1]]
- var coordinates = pixels.map(this.map_.getCoordinateFromPixel, this.map_);
- // close the polygon
- coordinates[4] = coordinates[0].slice();
- if (!this.geometry_) {
- this.geometry_ = new ol.geom.Polygon([coordinates]);
- } else {
- this.geometry_.setCoordinates([coordinates]);
- * @return {ol.geom.Polygon} Geometry.
-ol.render.Box.prototype.getGeometry = function() {
- return this.geometry_;
-// FIXME draw drag box
-goog.provide('ol.interaction.DragBox');
-goog.require('ol.events.Event');
-goog.require('ol.render.Box');
- * @classdesc
- * Allows the user to draw a vector box by clicking and dragging on the map,
- * it to when the shift or other key is held down. This is used, for example,
- * for zooming to a specific area of the map
- * (see {@link ol.interaction.DragZoom} and
- * {@link ol.interaction.DragRotateAndZoom}).
- * @constructor
- * @fires ol.interaction.DragBox.Event
- * @param {olx.interaction.DragBoxOptions=} opt_options Options.
- * @api
-ol.interaction.DragBox = function(opt_options) {
- handleDownEvent: ol.interaction.DragBox.handleDownEvent_,
- handleDragEvent: ol.interaction.DragBox.handleDragEvent_,
- handleUpEvent: ol.interaction.DragBox.handleUpEvent_
- * @type {ol.render.Box}
- * @private
- this.box_ = new ol.render.Box(options.className || 'ol-dragbox');
- * @type {number}
- * @private
- this.minArea_ = options.minArea !== undefined ? options.minArea : 64;
- * @private
- * @private
- options.condition : ol.events.condition.always;
- * @private
- * @type {ol.DragBoxEndConditionType}
- this.boxEndCondition_ = options.boxEndCondition ?
- options.boxEndCondition : ol.interaction.DragBox.defaultBoxEndCondition;
-ol.inherits(ol.interaction.DragBox, ol.interaction.Pointer);
- * The default condition for determining whether the boxend event
- * should fire.
- * @param {ol.MapBrowserEvent} mapBrowserEvent The originating MapBrowserEvent
- * leading to the box end.
- * @param {ol.Pixel} startPixel The starting pixel of the box.
- * @param {ol.Pixel} endPixel The end pixel of the box.
- * @return {boolean} Whether or not the boxend condition should be fired.
- * @this {ol.interaction.DragBox}
-ol.interaction.DragBox.defaultBoxEndCondition = function(mapBrowserEvent, startPixel, endPixel) {
- var width = endPixel[0] - startPixel[0];
- var height = endPixel[1] - startPixel[1];
- return width * width + height * height >= this.minArea_;
- * @private
-ol.interaction.DragBox.handleDragEvent_ = function(mapBrowserEvent) {
- return;
- this.box_.setPixels(this.startPixel_, mapBrowserEvent.pixel);
- this.dispatchEvent(new ol.interaction.DragBox.Event(ol.interaction.DragBox.EventType_.BOXDRAG,
- mapBrowserEvent.coordinate, mapBrowserEvent));
- * Returns geometry of last drawn box.
- * @api
-ol.interaction.DragBox.prototype.getGeometry = function() {
- return this.box_.getGeometry();
- * To be overriden by child classes.
- * FIXME: use constructor option instead of relying on overridding.
- * @protected
-ol.interaction.DragBox.prototype.onBoxEnd = ol.nullFunction;
- * @private
-ol.interaction.DragBox.handleUpEvent_ = function(mapBrowserEvent) {
- return true;
- this.box_.setMap(null);
- if (this.boxEndCondition_(mapBrowserEvent,
- this.startPixel_, mapBrowserEvent.pixel)) {
- this.onBoxEnd(mapBrowserEvent);
- this.dispatchEvent(new ol.interaction.DragBox.Event(ol.interaction.DragBox.EventType_.BOXEND,
- return false;
- * @private
-ol.interaction.DragBox.handleDownEvent_ = function(mapBrowserEvent) {
- return false;
- this.startPixel_ = mapBrowserEvent.pixel;
- this.box_.setMap(mapBrowserEvent.map);
- this.box_.setPixels(this.startPixel_, this.startPixel_);
- this.dispatchEvent(new ol.interaction.DragBox.Event(ol.interaction.DragBox.EventType_.BOXSTART,
- return true;
- } else {
- return false;
- * @enum {string}
- * @private
-ol.interaction.DragBox.EventType_ = {
- * Triggered upon drag box start.
- * @event ol.interaction.DragBox.Event#boxstart
- * @api
- BOXSTART: 'boxstart',
- * Triggered on drag when box is active.
- * @event ol.interaction.DragBox.Event#boxdrag
- * @api
- BOXDRAG: 'boxdrag',
- * Triggered upon drag box end.
- * @event ol.interaction.DragBox.Event#boxend
- * @api
- BOXEND: 'boxend'
- * @classdesc
- * Events emitted by {@link ol.interaction.DragBox} instances are instances of
- * this type.
- * @param {string} type The event type.
- * @param {ol.Coordinate} coordinate The event coordinate.
- * @param {ol.MapBrowserEvent} mapBrowserEvent Originating event.
- * @extends {ol.events.Event}
- * @constructor
- * @implements {oli.DragBoxEvent}
-ol.interaction.DragBox.Event = function(type, coordinate, mapBrowserEvent) {
- ol.events.Event.call(this, type);
- * The coordinate of the drag event.
- * @const
- * @type {ol.Coordinate}
- * @api
- this.coordinate = coordinate;
- * @const
- * @type {ol.MapBrowserEvent}
- * @api
- this.mapBrowserEvent = mapBrowserEvent;
-ol.inherits(ol.interaction.DragBox.Event, ol.events.Event);
-goog.provide('ol.interaction.DragZoom');
-goog.require('ol.easing');
-goog.require('ol.extent');
-goog.require('ol.interaction.DragBox');
- * @classdesc
- * Allows the user to zoom the map by clicking and dragging on the map,
- * it to when a key, shift by default, is held down.
- * To change the style of the box, use CSS and the `.ol-dragzoom` selector, or
- * your custom one configured with `className`.
- * @constructor
- * @extends {ol.interaction.DragBox}
- * @param {olx.interaction.DragZoomOptions=} opt_options Options.
- * @api
-ol.interaction.DragZoom = function(opt_options) {
- var condition = options.condition ?
- options.condition : ol.events.condition.shiftKeyOnly;
- * @private
- * @type {number}
- this.duration_ = options.duration !== undefined ? options.duration : 200;
- * @private
- * @type {boolean}
- this.out_ = options.out !== undefined ? options.out : false;
- ol.interaction.DragBox.call(this, {
- condition: condition,
- className: options.className || 'ol-dragzoom'
-ol.inherits(ol.interaction.DragZoom, ol.interaction.DragBox);
- * @inheritDoc
-ol.interaction.DragZoom.prototype.onBoxEnd = function() {
- var map = this.getMap();
- var view = /** @type {!ol.View} */ (map.getView());
- var size = /** @type {!ol.Size} */ (map.getSize());
- var extent = this.getGeometry().getExtent();
- if (this.out_) {
- var mapExtent = view.calculateExtent(size);
- var boxPixelExtent = ol.extent.createOrUpdateFromCoordinates([
- map.getPixelFromCoordinate(ol.extent.getBottomLeft(extent)),
- map.getPixelFromCoordinate(ol.extent.getTopRight(extent))]);
- var factor = view.getResolutionForExtent(boxPixelExtent, size);
- ol.extent.scaleFromCenter(mapExtent, 1 / factor);
- extent = mapExtent;
- view.getResolutionForExtent(extent, size));
- var center = ol.extent.getCenter(extent);
- view.animate({
- center: center,
- duration: this.duration_,
-goog.provide('ol.events.KeyCode');
- * @enum {number}
- * @const
-ol.events.KeyCode = {
- LEFT: 37,
- UP: 38,
- RIGHT: 39,
- DOWN: 40
-goog.provide('ol.interaction.KeyboardPan');
-goog.require('ol.coordinate');
-goog.require('ol.events.EventType');
-goog.require('ol.events.KeyCode');
- * @classdesc
- * Allows the user to pan the map using keyboard arrows.
- * Note that, although this interaction is by default included in maps,
- * the keys can only be used when browser focus is on the element to which
- * the keyboard events are attached. By default, this is the map div,
- * though you can change this with the `keyboardEventTarget` in
- * {@link ol.Map}. `document` never loses focus but, for any other element,
- * focus will have to be on, and returned to, this element if the keys are to
- * function.
- * See also {@link ol.interaction.KeyboardZoom}.
- * @constructor
- * @param {olx.interaction.KeyboardPanOptions=} opt_options Options.
- * @api
-ol.interaction.KeyboardPan = function(opt_options) {
- handleEvent: ol.interaction.KeyboardPan.handleEvent
- * @private
- * @param {ol.MapBrowserEvent} mapBrowserEvent Browser event.
- * @return {boolean} Combined condition result.
- this.defaultCondition_ = function(mapBrowserEvent) {
- return ol.events.condition.noModifierKeys(mapBrowserEvent) &&
- ol.events.condition.targetNotEditable(mapBrowserEvent);
- * @private
- this.condition_ = options.condition !== undefined ?
- options.condition : this.defaultCondition_;
- * @private
- * @type {number}
- this.duration_ = options.duration !== undefined ? options.duration : 100;
- * @private
- * @type {number}
- this.pixelDelta_ = options.pixelDelta !== undefined ?
- options.pixelDelta : 128;
-ol.inherits(ol.interaction.KeyboardPan, ol.interaction.Interaction);
- * Handles the {@link ol.MapBrowserEvent map browser event} if it was a
- * `KeyEvent`, and decides the direction to pan to (if an arrow key was
- * pressed).
- * @this {ol.interaction.KeyboardPan}
- * @api
-ol.interaction.KeyboardPan.handleEvent = function(mapBrowserEvent) {
- if (mapBrowserEvent.type == ol.events.EventType.KEYDOWN) {
- var keyEvent = mapBrowserEvent.originalEvent;
- var keyCode = keyEvent.keyCode;
- if (this.condition_(mapBrowserEvent) &&
- (keyCode == ol.events.KeyCode.DOWN ||
- keyCode == ol.events.KeyCode.LEFT ||
- keyCode == ol.events.KeyCode.RIGHT ||
- keyCode == ol.events.KeyCode.UP)) {
- var mapUnitsDelta = view.getResolution() * this.pixelDelta_;
- var deltaX = 0, deltaY = 0;
- if (keyCode == ol.events.KeyCode.DOWN) {
- deltaY = -mapUnitsDelta;
- } else if (keyCode == ol.events.KeyCode.LEFT) {
- deltaX = -mapUnitsDelta;
- } else if (keyCode == ol.events.KeyCode.RIGHT) {
- deltaX = mapUnitsDelta;
- } else {
- deltaY = mapUnitsDelta;
- var delta = [deltaX, deltaY];
- ol.coordinate.rotate(delta, view.getRotation());
- ol.interaction.Interaction.pan(view, delta, this.duration_);
- stopEvent = true;
-goog.provide('ol.interaction.KeyboardZoom');
- * @classdesc
- * Allows the user to zoom the map using keyboard + and -.
- * function.
- * See also {@link ol.interaction.KeyboardPan}.
- * @constructor
- * @param {olx.interaction.KeyboardZoomOptions=} opt_options Options.
- * @api
-ol.interaction.KeyboardZoom = function(opt_options) {
- handleEvent: ol.interaction.KeyboardZoom.handleEvent
- * @private
- this.condition_ = options.condition ? options.condition :
- ol.events.condition.targetNotEditable;
- * @private
- * @type {number}
- * @private
- * @type {number}
-ol.inherits(ol.interaction.KeyboardZoom, ol.interaction.Interaction);
- * `KeyEvent`, and decides whether to zoom in or out (depending on whether the
- * key pressed was '+' or '-').
- * @this {ol.interaction.KeyboardZoom}
- * @api
-ol.interaction.KeyboardZoom.handleEvent = function(mapBrowserEvent) {
- if (mapBrowserEvent.type == ol.events.EventType.KEYDOWN ||
- mapBrowserEvent.type == ol.events.EventType.KEYPRESS) {
- var charCode = keyEvent.charCode;
- (charCode == '+'.charCodeAt(0) || charCode == '-'.charCodeAt(0))) {
- var delta = (charCode == '+'.charCodeAt(0)) ? this.delta_ : -this.delta_;
- view, delta, undefined, this.duration_);
- stopEvent = true;
-goog.provide('ol.interaction.MouseWheelZoom');
-goog.require('ol.ViewHint');
-goog.require('ol.math');
- * @classdesc
- * Allows the user to zoom the map by scrolling the mouse wheel.
- * @constructor
- * @param {olx.interaction.MouseWheelZoomOptions=} opt_options Options.
- * @api
-ol.interaction.MouseWheelZoom = function(opt_options) {
- handleEvent: ol.interaction.MouseWheelZoom.handleEvent
- * @private
- * @type {number}
- this.delta_ = 0;
- * @private
- * @type {number}
- * @private
- * @type {number}
- this.timeout_ = options.timeout !== undefined ? options.timeout : 80;
- * @private
- * @type {boolean}
- this.useAnchor_ = options.useAnchor !== undefined ? options.useAnchor : true;
- * @private
- * @type {boolean}
- this.constrainResolution_ = options.constrainResolution || false;
- * @private
- * @type {?ol.Coordinate}
- this.lastAnchor_ = null;
- * @private
- * @type {number|undefined}
- this.startTime_ = undefined;
- * @private
- this.timeoutId_ = undefined;
- * @private
- * @type {ol.interaction.MouseWheelZoom.Mode_|undefined}
- this.mode_ = undefined;
- * Trackpad events separated by this delay will be considered separate
- * interactions.
- * @type {number}
- this.trackpadEventGap_ = 400;
- this.trackpadTimeoutId_ = undefined;
- * The number of delta values per zoom level
- * @private
- * @type {number}
- this.trackpadDeltaPerZoom_ = 300;
- * The zoom factor by which scroll zooming is allowed to exceed the limits.
- * @private
- * @type {number}
- this.trackpadZoomBuffer_ = 1.5;
-ol.inherits(ol.interaction.MouseWheelZoom, ol.interaction.Interaction);
- * mousewheel-event) and eventually zooms the map.
- * @return {boolean} Allow event propagation.
- * @this {ol.interaction.MouseWheelZoom}
- * @api
-ol.interaction.MouseWheelZoom.handleEvent = function(mapBrowserEvent) {
- if (type !== ol.events.EventType.WHEEL && type !== ol.events.EventType.MOUSEWHEEL) {
- return true;
- var wheelEvent = /** @type {WheelEvent} */ (mapBrowserEvent.originalEvent);
- if (this.useAnchor_) {
- this.lastAnchor_ = mapBrowserEvent.coordinate;
- // Delta normalisation inspired by
- // https://github.com/mapbox/mapbox-gl-js/blob/001c7b9/js/ui/handler/scroll_zoom.js
- var delta;
- if (mapBrowserEvent.type == ol.events.EventType.WHEEL) {
- delta = wheelEvent.deltaY;
- if (ol.has.FIREFOX &&
- wheelEvent.deltaMode === WheelEvent.DOM_DELTA_PIXEL) {
- delta /= ol.has.DEVICE_PIXEL_RATIO;
- if (wheelEvent.deltaMode === WheelEvent.DOM_DELTA_LINE) {
- delta *= 40;
- } else if (mapBrowserEvent.type == ol.events.EventType.MOUSEWHEEL) {
- delta = -wheelEvent.wheelDeltaY;
- if (ol.has.SAFARI) {
- delta /= 3;
- if (delta === 0) {
- return false;
- var now = Date.now();
- if (this.startTime_ === undefined) {
- this.startTime_ = now;
- if (!this.mode_ || now - this.startTime_ > this.trackpadEventGap_) {
- this.mode_ = Math.abs(delta) < 4 ?
- ol.interaction.MouseWheelZoom.Mode_.TRACKPAD :
- ol.interaction.MouseWheelZoom.Mode_.WHEEL;
- if (this.mode_ === ol.interaction.MouseWheelZoom.Mode_.TRACKPAD) {
- if (this.trackpadTimeoutId_) {
- clearTimeout(this.trackpadTimeoutId_);
- } else {
- this.trackpadTimeoutId_ = setTimeout(this.decrementInteractingHint_.bind(this), this.trackpadEventGap_);
- var resolution = view.getResolution() * Math.pow(2, delta / this.trackpadDeltaPerZoom_);
- var minResolution = view.getMinResolution();
- var maxResolution = view.getMaxResolution();
- var rebound = 0;
- if (resolution < minResolution) {
- resolution = Math.max(resolution, minResolution / this.trackpadZoomBuffer_);
- rebound = 1;
- } else if (resolution > maxResolution) {
- resolution = Math.min(resolution, maxResolution * this.trackpadZoomBuffer_);
- rebound = -1;
- if (this.lastAnchor_) {
- var center = view.calculateCenterZoom(resolution, this.lastAnchor_);
- view.setCenter(view.constrainCenter(center));
- if (rebound === 0 && this.constrainResolution_) {
- view.animate({
- resolution: view.constrainResolution(resolution, delta > 0 ? -1 : 1),
- easing: ol.easing.easeOut,
- anchor: this.lastAnchor_,
- if (rebound > 0) {
- view.animate({
- resolution: minResolution,
- duration: 500
- } else if (rebound < 0) {
- view.animate({
- resolution: maxResolution,
- duration: 500
- return false;
- this.delta_ += delta;
- var timeLeft = Math.max(this.timeout_ - (now - this.startTime_), 0);
- clearTimeout(this.timeoutId_);
- this.timeoutId_ = setTimeout(this.handleWheelZoom_.bind(this, map), timeLeft);
- return false;
- * @private
-ol.interaction.MouseWheelZoom.prototype.decrementInteractingHint_ = function() {
- var view = this.getMap().getView();
- * @private
-ol.interaction.MouseWheelZoom.prototype.handleWheelZoom_ = function(map) {
- if (view.getAnimating()) {
- view.cancelAnimations();
- var maxDelta = ol.MOUSEWHEELZOOM_MAXDELTA;
- var delta = ol.math.clamp(this.delta_, -maxDelta, maxDelta);
- ol.interaction.Interaction.zoomByDelta(view, -delta, this.lastAnchor_,
- this.duration_);
- this.delta_ = 0;
- * Enable or disable using the mouse's location as an anchor when zooming
- * @param {boolean} useAnchor true to zoom to the mouse's location, false
- * to zoom to the center of the map
- * @api
-ol.interaction.MouseWheelZoom.prototype.setMouseAnchor = function(useAnchor) {
- this.useAnchor_ = useAnchor;
- if (!useAnchor) {
- * @enum {string}
- * @private
-ol.interaction.MouseWheelZoom.Mode_ = {
- TRACKPAD: 'trackpad',
- WHEEL: 'wheel'
-goog.provide('ol.interaction.PinchRotate');
- * @classdesc
- * Allows the user to rotate the map by twisting with two fingers
- * on a touch screen.
- * @constructor
- * @param {olx.interaction.PinchRotateOptions=} opt_options Options.
- * @api
-ol.interaction.PinchRotate = function(opt_options) {
- handleDownEvent: ol.interaction.PinchRotate.handleDownEvent_,
- handleDragEvent: ol.interaction.PinchRotate.handleDragEvent_,
- handleUpEvent: ol.interaction.PinchRotate.handleUpEvent_
- * @private
- this.anchor_ = null;
- * @private
- * @private
- * @type {boolean}
- this.rotating_ = false;
- * @private
- * @type {number}
- this.rotationDelta_ = 0.0;
- * @private
- * @type {number}
- this.threshold_ = options.threshold !== undefined ? options.threshold : 0.3;
- * @private
- * @type {number}
-ol.inherits(ol.interaction.PinchRotate, ol.interaction.Pointer);
- * @this {ol.interaction.PinchRotate}
- * @private
-ol.interaction.PinchRotate.handleDragEvent_ = function(mapBrowserEvent) {
- var rotationDelta = 0.0;
- var touch0 = this.targetPointers[0];
- var touch1 = this.targetPointers[1];
- // angle between touches
- var angle = Math.atan2(
- touch1.clientY - touch0.clientY,
- touch1.clientX - touch0.clientX);
- var delta = angle - this.lastAngle_;
- this.rotationDelta_ += delta;
- if (!this.rotating_ &&
- Math.abs(this.rotationDelta_) > this.threshold_) {
- this.rotating_ = true;
- rotationDelta = delta;
- this.lastAngle_ = angle;
- // rotate anchor point.
- // FIXME: should be the intersection point between the lines:
- // touch0,touch1 and previousTouch0,previousTouch1
- var viewportPosition = map.getViewport().getBoundingClientRect();
- var centroid = ol.interaction.Pointer.centroid(this.targetPointers);
- centroid[0] -= viewportPosition.left;
- centroid[1] -= viewportPosition.top;
- this.anchor_ = map.getCoordinateFromPixel(centroid);
- // rotate
- if (this.rotating_) {
- map.render();
- ol.interaction.Interaction.rotateWithoutConstraints(view,
- rotation + rotationDelta, this.anchor_);
- * @private
-ol.interaction.PinchRotate.handleUpEvent_ = function(mapBrowserEvent) {
- if (this.targetPointers.length < 2) {
- view, rotation, this.anchor_, this.duration_);
- return false;
- } else {
- return true;
- * @private
-ol.interaction.PinchRotate.handleDownEvent_ = function(mapBrowserEvent) {
- if (this.targetPointers.length >= 2) {
- return true;
- } else {
- return false;
- * @inheritDoc
-ol.interaction.PinchRotate.prototype.shouldStopEvent = ol.functions.FALSE;
-goog.provide('ol.interaction.PinchZoom');
- * @classdesc
- * Allows the user to zoom the map by pinching with two fingers
- * @constructor
- * @param {olx.interaction.PinchZoomOptions=} opt_options Options.
- * @api
-ol.interaction.PinchZoom = function(opt_options) {
- handleDownEvent: ol.interaction.PinchZoom.handleDownEvent_,
- handleDragEvent: ol.interaction.PinchZoom.handleDragEvent_,
- handleUpEvent: ol.interaction.PinchZoom.handleUpEvent_
- * @private
- * @type {boolean}
- * @private
- * @private
- * @type {number}
- this.duration_ = options.duration !== undefined ? options.duration : 400;
- * @private
- this.lastDistance_ = undefined;
- * @private
- * @type {number}
- this.lastScaleDelta_ = 1;
-ol.inherits(ol.interaction.PinchZoom, ol.interaction.Pointer);
- * @this {ol.interaction.PinchZoom}
- * @private
-ol.interaction.PinchZoom.handleDragEvent_ = function(mapBrowserEvent) {
- var scaleDelta = 1.0;
- var dx = touch0.clientX - touch1.clientX;
- var dy = touch0.clientY - touch1.clientY;
- // distance between touches
- var distance = Math.sqrt(dx * dx + dy * dy);
- if (this.lastDistance_ !== undefined) {
- scaleDelta = this.lastDistance_ / distance;
- this.lastDistance_ = distance;
- var resolution = view.getResolution();
- var newResolution = resolution * scaleDelta;
- if (newResolution > maxResolution) {
- scaleDelta = maxResolution / resolution;
- newResolution = maxResolution;
- } else if (newResolution < minResolution) {
- scaleDelta = minResolution / resolution;
- newResolution = minResolution;
- if (scaleDelta != 1.0) {
- this.lastScaleDelta_ = scaleDelta;
- // scale anchor point.
- // scale, bypass the resolution constraint
- map.render();
- ol.interaction.Interaction.zoomWithoutConstraints(view, newResolution, this.anchor_);
- * @private
-ol.interaction.PinchZoom.handleUpEvent_ = function(mapBrowserEvent) {
- if (this.constrainResolution_ ||
- resolution < view.getMinResolution() ||
- resolution > view.getMaxResolution()) {
- // Zoom to final resolution, with an animation, and provide a
- // direction not to zoom out/in if user was pinching in/out.
- // Direction is > 0 if pinching out, and < 0 if pinching in.
- var direction = this.lastScaleDelta_ - 1;
- ol.interaction.Interaction.zoom(view, resolution,
- this.anchor_, this.duration_, direction);
- return false;
- } else {
- return true;
- * @private
-ol.interaction.PinchZoom.handleDownEvent_ = function(mapBrowserEvent) {
- return true;
- } else {
- return false;
- * @inheritDoc
-ol.interaction.PinchZoom.prototype.shouldStopEvent = ol.functions.FALSE;
-goog.provide('ol.interaction');
-goog.require('ol.Collection');
-goog.require('ol.Kinetic');
-goog.require('ol.interaction.DoubleClickZoom');
-goog.require('ol.interaction.DragPan');
-goog.require('ol.interaction.DragRotate');
-goog.require('ol.interaction.DragZoom');
-goog.require('ol.interaction.KeyboardPan');
-goog.require('ol.interaction.KeyboardZoom');
-goog.require('ol.interaction.MouseWheelZoom');
-goog.require('ol.interaction.PinchRotate');
-goog.require('ol.interaction.PinchZoom');
- * Set of interactions included in maps by default. Specific interactions can be
- * excluded by setting the appropriate option to false in the constructor
- * options, but the order of the interactions is fixed. If you want to specify
- * a different order for interactions, you will need to create your own
- * {@link ol.interaction.Interaction} instances and insert them into a
- * {@link ol.Collection} in the order you want before creating your
- * {@link ol.Map} instance. The default set of interactions, in sequence, is:
- * * {@link ol.interaction.DragRotate}
- * * {@link ol.interaction.DoubleClickZoom}
- * * {@link ol.interaction.DragPan}
- * * {@link ol.interaction.PinchRotate}
- * * {@link ol.interaction.PinchZoom}
- * * {@link ol.interaction.KeyboardPan}
- * * {@link ol.interaction.KeyboardZoom}
- * * {@link ol.interaction.MouseWheelZoom}
- * * {@link ol.interaction.DragZoom}
- * @param {olx.interaction.DefaultsOptions=} opt_options Defaults options.
- * @return {ol.Collection.<ol.interaction.Interaction>} A collection of
- * interactions to be used with the ol.Map constructor's interactions option.
- * @api
-ol.interaction.defaults = function(opt_options) {
- var interactions = new ol.Collection();
- var kinetic = new ol.Kinetic(-0.005, 0.05, 100);
- var altShiftDragRotate = options.altShiftDragRotate !== undefined ?
- options.altShiftDragRotate : true;
- if (altShiftDragRotate) {
- interactions.push(new ol.interaction.DragRotate());
- var doubleClickZoom = options.doubleClickZoom !== undefined ?
- options.doubleClickZoom : true;
- if (doubleClickZoom) {
- interactions.push(new ol.interaction.DoubleClickZoom({
- delta: options.zoomDelta,
- duration: options.zoomDuration
- var dragPan = options.dragPan !== undefined ? options.dragPan : true;
- if (dragPan) {
- interactions.push(new ol.interaction.DragPan({
- kinetic: kinetic
- var pinchRotate = options.pinchRotate !== undefined ? options.pinchRotate :
- true;
- if (pinchRotate) {
- interactions.push(new ol.interaction.PinchRotate());
- var pinchZoom = options.pinchZoom !== undefined ? options.pinchZoom : true;
- if (pinchZoom) {
- interactions.push(new ol.interaction.PinchZoom({
- constrainResolution: options.constrainResolution,
- var keyboard = options.keyboard !== undefined ? options.keyboard : true;
- if (keyboard) {
- interactions.push(new ol.interaction.KeyboardPan());
- interactions.push(new ol.interaction.KeyboardZoom({
- var mouseWheelZoom = options.mouseWheelZoom !== undefined ?
- options.mouseWheelZoom : true;
- if (mouseWheelZoom) {
- interactions.push(new ol.interaction.MouseWheelZoom({
- var shiftDragZoom = options.shiftDragZoom !== undefined ?
- options.shiftDragZoom : true;
- if (shiftDragZoom) {
- interactions.push(new ol.interaction.DragZoom({
- return interactions;
-goog.provide('ol.layer.Property');
- * @enum {string}
-ol.layer.Property = {
- OPACITY: 'opacity',
- VISIBLE: 'visible',
- EXTENT: 'extent',
- Z_INDEX: 'zIndex',
- MAX_RESOLUTION: 'maxResolution',
- MIN_RESOLUTION: 'minResolution',
- SOURCE: 'source'
-goog.provide('ol.layer.Base');
-goog.require('ol.Object');
-goog.require('ol.layer.Property');
-goog.require('ol.obj');
- * @classdesc
- * Note that with `ol.layer.Base` and all its subclasses, any property set in
- * the options is set as a {@link ol.Object} property on the layer object, so
- * is observable, and has get/set accessors.
- * @constructor
- * @abstract
- * @extends {ol.Object}
- * @param {olx.layer.BaseOptions} options Layer options.
- * @api
-ol.layer.Base = function(options) {
- ol.Object.call(this);
- * @type {Object.<string, *>}
- var properties = ol.obj.assign({}, options);
- properties[ol.layer.Property.OPACITY] =
- options.opacity !== undefined ? options.opacity : 1;
- properties[ol.layer.Property.VISIBLE] =
- options.visible !== undefined ? options.visible : true;
- properties[ol.layer.Property.Z_INDEX] =
- options.zIndex !== undefined ? options.zIndex : 0;
- properties[ol.layer.Property.MAX_RESOLUTION] =
- options.maxResolution !== undefined ? options.maxResolution : Infinity;
- properties[ol.layer.Property.MIN_RESOLUTION] =
- options.minResolution !== undefined ? options.minResolution : 0;
- this.setProperties(properties);
- * @type {ol.LayerState}
- * @private
- this.state_ = /** @type {ol.LayerState} */ ({
- layer: /** @type {ol.layer.Layer} */ (this),
- managed: true
-ol.inherits(ol.layer.Base, ol.Object);
- * Create a renderer for this layer.
- * @abstract
- * @param {ol.renderer.Map} mapRenderer The map renderer.
- * @return {ol.renderer.Layer} A layer renderer.
-ol.layer.Base.prototype.createRenderer = function(mapRenderer) {};
- * @return {ol.LayerState} Layer state.
-ol.layer.Base.prototype.getLayerState = function() {
- this.state_.opacity = ol.math.clamp(this.getOpacity(), 0, 1);
- this.state_.sourceState = this.getSourceState();
- this.state_.visible = this.getVisible();
- this.state_.extent = this.getExtent();
- this.state_.zIndex = this.getZIndex();
- this.state_.maxResolution = this.getMaxResolution();
- this.state_.minResolution = Math.max(this.getMinResolution(), 0);
- return this.state_;
- * @abstract
- * @param {Array.<ol.layer.Layer>=} opt_array Array of layers (to be
- * modified in place).
- * @return {Array.<ol.layer.Layer>} Array of layers.
-ol.layer.Base.prototype.getLayersArray = function(opt_array) {};
- * @abstract
- * @param {Array.<ol.LayerState>=} opt_states Optional list of layer
- * states (to be modified in place).
- * @return {Array.<ol.LayerState>} List of layer states.
-ol.layer.Base.prototype.getLayerStatesArray = function(opt_states) {};
- * Return the {@link ol.Extent extent} of the layer or `undefined` if it
- * will be visible regardless of extent.
- * @return {ol.Extent|undefined} The layer extent.
- * @observable
- * @api
-ol.layer.Base.prototype.getExtent = function() {
- return /** @type {ol.Extent|undefined} */ (
- this.get(ol.layer.Property.EXTENT));
- * Return the maximum resolution of the layer.
- * @return {number} The maximum resolution of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.getMaxResolution = function() {
- return /** @type {number} */ (
- this.get(ol.layer.Property.MAX_RESOLUTION));
- * Return the minimum resolution of the layer.
- * @return {number} The minimum resolution of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.getMinResolution = function() {
- this.get(ol.layer.Property.MIN_RESOLUTION));
- * Return the opacity of the layer (between 0 and 1).
- * @return {number} The opacity of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.getOpacity = function() {
- return /** @type {number} */ (this.get(ol.layer.Property.OPACITY));
- * @abstract
- * @return {ol.source.State} Source state.
-ol.layer.Base.prototype.getSourceState = function() {};
- * Return the visibility of the layer (`true` or `false`).
- * @return {boolean} The visibility of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.getVisible = function() {
- return /** @type {boolean} */ (this.get(ol.layer.Property.VISIBLE));
- * Return the Z-index of the layer, which is used to order layers before
- * rendering. The default Z-index is 0.
- * @return {number} The Z-index of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.getZIndex = function() {
- return /** @type {number} */ (this.get(ol.layer.Property.Z_INDEX));
- * Set the extent at which the layer is visible. If `undefined`, the layer
- * will be visible at all extents.
- * @param {ol.Extent|undefined} extent The extent of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.setExtent = function(extent) {
- this.set(ol.layer.Property.EXTENT, extent);
- * Set the maximum resolution at which the layer is visible.
- * @param {number} maxResolution The maximum resolution of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.setMaxResolution = function(maxResolution) {
- this.set(ol.layer.Property.MAX_RESOLUTION, maxResolution);
- * Set the minimum resolution at which the layer is visible.
- * @param {number} minResolution The minimum resolution of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.setMinResolution = function(minResolution) {
- this.set(ol.layer.Property.MIN_RESOLUTION, minResolution);
- * Set the opacity of the layer, allowed values range from 0 to 1.
- * @param {number} opacity The opacity of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.setOpacity = function(opacity) {
- this.set(ol.layer.Property.OPACITY, opacity);
- * Set the visibility of the layer (`true` or `false`).
- * @param {boolean} visible The visibility of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.setVisible = function(visible) {
- this.set(ol.layer.Property.VISIBLE, visible);
- * Set Z-index of the layer, which is used to order layers before rendering.
- * The default Z-index is 0.
- * @param {number} zindex The z-index of the layer.
- * @observable
- * @api
-ol.layer.Base.prototype.setZIndex = function(zindex) {
- this.set(ol.layer.Property.Z_INDEX, zindex);
-goog.provide('ol.source.State');
- * State of the source, one of 'undefined', 'loading', 'ready' or 'error'.
- * @enum {string}
-ol.source.State = {
- UNDEFINED: 'undefined',
- LOADING: 'loading',
- READY: 'ready',
- ERROR: 'error'
-goog.provide('ol.layer.Group');
-goog.require('ol.CollectionEventType');
-goog.require('ol.ObjectEventType');
-goog.require('ol.asserts');
-goog.require('ol.events');
-goog.require('ol.layer.Base');
-goog.require('ol.source.State');
- * @classdesc
- * A {@link ol.Collection} of layers that are handled together.
- * A generic `change` event is triggered when the group/Collection changes.
- * @constructor
- * @extends {ol.layer.Base}
- * @param {olx.layer.GroupOptions=} opt_options Layer options.
- * @api
-ol.layer.Group = function(opt_options) {
- var options = opt_options || {};
- var baseOptions = /** @type {olx.layer.GroupOptions} */
- (ol.obj.assign({}, options));
- delete baseOptions.layers;
- var layers = options.layers;
- ol.layer.Base.call(this, baseOptions);
- * @private
- * @type {Array.<ol.EventsKey>}
- this.layersListenerKeys_ = [];
- * @private
- * @type {Object.<string, Array.<ol.EventsKey>>}
- this.listenerKeys_ = {};
- ol.events.listen(this,
- ol.Object.getChangeEventType(ol.layer.Group.Property_.LAYERS),
- this.handleLayersChanged_, this);
- if (layers) {
- if (Array.isArray(layers)) {
- layers = new ol.Collection(layers.slice(), {unique: true});
- } else {
- ol.asserts.assert(layers instanceof ol.Collection,
- 43); // Expected `layers` to be an array or an `ol.Collection`
- layers = layers;
- } else {
- layers = new ol.Collection(undefined, {unique: true});
- this.setLayers(layers);
-ol.inherits(ol.layer.Group, ol.layer.Base);
- * @inheritDoc
-ol.layer.Group.prototype.createRenderer = function(mapRenderer) {};
- * @private
-ol.layer.Group.prototype.handleLayerChange_ = function() {
- if (this.getVisible()) {
- this.changed();
- * @param {ol.events.Event} event Event.
- * @private
-ol.layer.Group.prototype.handleLayersChanged_ = function(event) {
- this.layersListenerKeys_.forEach(ol.events.unlistenByKey);
- this.layersListenerKeys_.length = 0;
- var layers = this.getLayers();
- this.layersListenerKeys_.push(
- ol.events.listen(layers, ol.CollectionEventType.ADD,
- this.handleLayersAdd_, this),
- ol.events.listen(layers, ol.CollectionEventType.REMOVE,
- this.handleLayersRemove_, this));
- for (var id in this.listenerKeys_) {
- this.listenerKeys_[id].forEach(ol.events.unlistenByKey);
- ol.obj.clear(this.listenerKeys_);
- var layersArray = layers.getArray();
- var i, ii, layer;
- for (i = 0, ii = layersArray.length; i < ii; i++) {
- layer = layersArray[i];
- this.listenerKeys_[ol.getUid(layer).toString()] = [
- ol.events.listen(layer, ol.ObjectEventType.PROPERTYCHANGE,
- this.handleLayerChange_, this),
- ol.events.listen(layer, ol.events.EventType.CHANGE,
- this.changed();
- * @param {ol.Collection.Event} collectionEvent Collection event.
- * @private
-ol.layer.Group.prototype.handleLayersAdd_ = function(collectionEvent) {
- var layer = /** @type {ol.layer.Base} */ (collectionEvent.element);
- var key = ol.getUid(layer).toString();
- this.listenerKeys_[key] = [
- this.changed();
- * @private
-ol.layer.Group.prototype.handleLayersRemove_ = function(collectionEvent) {
- this.listenerKeys_[key].forEach(ol.events.unlistenByKey);
- delete this.listenerKeys_[key];
- this.changed();
- * Returns the {@link ol.Collection collection} of {@link ol.layer.Layer layers}
- * in this group.
- * @return {!ol.Collection.<ol.layer.Base>} Collection of
- * {@link ol.layer.Base layers} that are part of this group.
- * @observable
- * @api
-ol.layer.Group.prototype.getLayers = function() {
- return /** @type {!ol.Collection.<ol.layer.Base>} */ (this.get(
- ol.layer.Group.Property_.LAYERS));
- * Set the {@link ol.Collection collection} of {@link ol.layer.Layer layers}
- * in this group.
- * @param {!ol.Collection.<ol.layer.Base>} layers Collection of
- * @observable
- * @api
-ol.layer.Group.prototype.setLayers = function(layers) {
- this.set(ol.layer.Group.Property_.LAYERS, layers);
- * @inheritDoc
-ol.layer.Group.prototype.getLayersArray = function(opt_array) {
- var array = opt_array !== undefined ? opt_array : [];
- this.getLayers().forEach(function(layer) {
- layer.getLayersArray(array);
- return array;
- * @inheritDoc
-ol.layer.Group.prototype.getLayerStatesArray = function(opt_states) {
- var states = opt_states !== undefined ? opt_states : [];
- var pos = states.length;
- layer.getLayerStatesArray(states);
- var ownLayerState = this.getLayerState();
- var i, ii, layerState;
- for (i = pos, ii = states.length; i < ii; i++) {
- layerState = states[i];
- layerState.opacity *= ownLayerState.opacity;
- layerState.visible = layerState.visible && ownLayerState.visible;
- layerState.maxResolution = Math.min(
- layerState.maxResolution, ownLayerState.maxResolution);
- layerState.minResolution = Math.max(
- layerState.minResolution, ownLayerState.minResolution);
- if (ownLayerState.extent !== undefined) {
- if (layerState.extent !== undefined) {
- layerState.extent = ol.extent.getIntersection(
- layerState.extent, ownLayerState.extent);
- } else {
- layerState.extent = ownLayerState.extent;
- return states;
- * @inheritDoc
-ol.layer.Group.prototype.getSourceState = function() {
- return ol.source.State.READY;
- * @enum {string}
- * @private
-ol.layer.Group.Property_ = {
- LAYERS: 'layers'
-goog.provide('ol.render.EventType');
- * @enum {string}
-ol.render.EventType = {
- * @event ol.render.Event#postcompose
- * @api
- POSTCOMPOSE: 'postcompose',
- * @event ol.render.Event#precompose
- * @api
- PRECOMPOSE: 'precompose',
- * @event ol.render.Event#render
- * @api
- RENDER: 'render'
-goog.provide('ol.layer.Layer');
-goog.require('ol.render.EventType');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * A visual representation of raster or vector map data.
- * Layers group together those properties that pertain to how the data is to be
- * displayed, irrespective of the source of that data.
- * Layers are usually added to a map with {@link ol.Map#addLayer}. Components
- * like {@link ol.interaction.Select} use unmanaged layers internally. These
- * unmanaged layers are associated with the map using
- * {@link ol.layer.Layer#setMap} instead.
- * A generic `change` event is fired when the state of the source changes.
- * @constructor
- * @abstract
- * @fires ol.render.Event
- * @param {olx.layer.LayerOptions} options Layer options.
- * @api
-ol.layer.Layer = function(options) {
- var baseOptions = ol.obj.assign({}, options);
- delete baseOptions.source;
- ol.layer.Base.call(this, /** @type {olx.layer.BaseOptions} */ (baseOptions));
- * @private
- * @type {?ol.EventsKey}
- this.mapPrecomposeKey_ = null;
- * @private
- this.mapRenderKey_ = null;
- * @private
- this.sourceChangeKey_ = null;
- if (options.map) {
- this.setMap(options.map);
- ol.Object.getChangeEventType(ol.layer.Property.SOURCE),
- this.handleSourcePropertyChange_, this);
- var source = options.source ? options.source : null;
- this.setSource(source);
-ol.inherits(ol.layer.Layer, ol.layer.Base);
- * Return `true` if the layer is visible, and if the passed resolution is
- * between the layer's minResolution and maxResolution. The comparison is
- * inclusive for `minResolution` and exclusive for `maxResolution`.
- * @param {ol.LayerState} layerState Layer state.
- * @param {number} resolution Resolution.
- * @return {boolean} The layer is visible at the given resolution.
-ol.layer.Layer.visibleAtResolution = function(layerState, resolution) {
- return layerState.visible && resolution >= layerState.minResolution &&
- resolution < layerState.maxResolution;
- * @inheritDoc
-ol.layer.Layer.prototype.getLayersArray = function(opt_array) {
- var array = opt_array ? opt_array : [];
- array.push(this);
- return array;
- * @inheritDoc
-ol.layer.Layer.prototype.getLayerStatesArray = function(opt_states) {
- var states = opt_states ? opt_states : [];
- states.push(this.getLayerState());
- return states;
- * Get the layer source.
- * @return {ol.source.Source} The layer source (or `null` if not yet set).
- * @observable
- * @api
-ol.layer.Layer.prototype.getSource = function() {
- var source = this.get(ol.layer.Property.SOURCE);
- return /** @type {ol.source.Source} */ (source) || null;
- * @inheritDoc
-ol.layer.Layer.prototype.getSourceState = function() {
- var source = this.getSource();
- return !source ? ol.source.State.UNDEFINED : source.getState();
- * @private
-ol.layer.Layer.prototype.handleSourceChange_ = function() {
- this.changed();
- * @private
-ol.layer.Layer.prototype.handleSourcePropertyChange_ = function() {
- if (this.sourceChangeKey_) {
- ol.events.unlistenByKey(this.sourceChangeKey_);
- if (source) {
- this.sourceChangeKey_ = ol.events.listen(source,
- ol.events.EventType.CHANGE, this.handleSourceChange_, this);
- this.changed();
- * Sets the layer to be rendered on top of other layers on a map. The map will
- * not manage this layer in its layers collection, and the callback in
- * {@link ol.Map#forEachLayerAtPixel} will receive `null` as layer. This
- * is useful for temporary layers. To remove an unmanaged layer from the map,
- * use `#setMap(null)`.
- * To add the layer to a map and have it managed by the map, use
- * {@link ol.Map#addLayer} instead.
- * @param {ol.Map} map Map.
- * @api
-ol.layer.Layer.prototype.setMap = function(map) {
- if (this.mapPrecomposeKey_) {
- ol.events.unlistenByKey(this.mapPrecomposeKey_);
- if (!map) {
- this.changed();
- if (this.mapRenderKey_) {
- ol.events.unlistenByKey(this.mapRenderKey_);
- if (map) {
- this.mapPrecomposeKey_ = ol.events.listen(
- map, ol.render.EventType.PRECOMPOSE, function(evt) {
- var layerState = this.getLayerState();
- layerState.managed = false;
- layerState.zIndex = Infinity;
- evt.frameState.layerStatesArray.push(layerState);
- evt.frameState.layerStates[ol.getUid(this)] = layerState;
- }, this);
- this.mapRenderKey_ = ol.events.listen(
- this, ol.events.EventType.CHANGE, map.render, map);
- this.changed();
- * Set the layer source.
- * @param {ol.source.Source} source The layer source.
- * @observable
- * @api
-ol.layer.Layer.prototype.setSource = function(source) {
- this.set(ol.layer.Property.SOURCE, source);
-goog.provide('ol.style.IconImageCache');
-goog.require('ol.color');
- * @constructor
-ol.style.IconImageCache = function() {
- * @type {Object.<string, ol.style.IconImage>}
- * @private
- this.cache_ = {};
- * @type {number}
- * @private
- this.cacheSize_ = 0;
- * @const
- * @type {number}
- * @private
- this.maxCacheSize_ = 32;
- * @param {string} src Src.
- * @param {?string} crossOrigin Cross origin.
- * @param {ol.Color} color Color.
- * @return {string} Cache key.
-ol.style.IconImageCache.getKey = function(src, crossOrigin, color) {
- var colorString = color ? ol.color.asString(color) : 'null';
- return crossOrigin + ':' + src + ':' + colorString;
- * FIXME empty description for jsdoc
-ol.style.IconImageCache.prototype.clear = function() {
- this.cache_ = {};
-ol.style.IconImageCache.prototype.expire = function() {
- if (this.cacheSize_ > this.maxCacheSize_) {
- var i = 0;
- var key, iconImage;
- for (key in this.cache_) {
- iconImage = this.cache_[key];
- if ((i++ & 3) === 0 && !iconImage.hasListener()) {
- delete this.cache_[key];
- --this.cacheSize_;
- * @return {ol.style.IconImage} Icon image.
-ol.style.IconImageCache.prototype.get = function(src, crossOrigin, color) {
- var key = ol.style.IconImageCache.getKey(src, crossOrigin, color);
- return key in this.cache_ ? this.cache_[key] : null;
- * @param {ol.style.IconImage} iconImage Icon image.
-ol.style.IconImageCache.prototype.set = function(src, crossOrigin, color, iconImage) {
- this.cache_[key] = iconImage;
- ++this.cacheSize_;
-goog.provide('ol.style');
-goog.require('ol.style.IconImageCache');
-ol.style.iconImageCache = new ol.style.IconImageCache();
-goog.provide('ol.transform');
- * Collection of affine 2d transformation functions. The functions work on an
- * array of 6 elements. The element order is compatible with the [SVGMatrix
- * interface](https://developer.mozilla.org/en-US/docs/Web/API/SVGMatrix) and is
- * a subset (elements a to f) of a 3x3 martrix:
- * [ a c e ]
- * [ b d f ]
- * [ 0 0 1 ]
- * @private
- * @type {ol.Transform}
-ol.transform.tmp_ = new Array(6);
- * Create an identity transform.
- * @return {!ol.Transform} Identity transform.
-ol.transform.create = function() {
- return [1, 0, 0, 1, 0, 0];
- * Resets the given transform to an identity transform.
- * @param {!ol.Transform} transform Transform.
- * @return {!ol.Transform} Transform.
-ol.transform.reset = function(transform) {
- return ol.transform.set(transform, 1, 0, 0, 1, 0, 0);
- * Multiply the underlying matrices of two transforms and return the result in
- * the first transform.
- * @param {!ol.Transform} transform1 Transform parameters of matrix 1.
- * @param {!ol.Transform} transform2 Transform parameters of matrix 2.
- * @return {!ol.Transform} transform1 multiplied with transform2.
-ol.transform.multiply = function(transform1, transform2) {
- var a1 = transform1[0];
- var b1 = transform1[1];
- var c1 = transform1[2];
- var d1 = transform1[3];
- var e1 = transform1[4];
- var f1 = transform1[5];
- var a2 = transform2[0];
- var b2 = transform2[1];
- var c2 = transform2[2];
- var d2 = transform2[3];
- var e2 = transform2[4];
- var f2 = transform2[5];
- transform1[0] = a1 * a2 + c1 * b2;
- transform1[1] = b1 * a2 + d1 * b2;
- transform1[2] = a1 * c2 + c1 * d2;
- transform1[3] = b1 * c2 + d1 * d2;
- transform1[4] = a1 * e2 + c1 * f2 + e1;
- transform1[5] = b1 * e2 + d1 * f2 + f1;
- return transform1;
- * Set the transform components a-f on a given transform.
- * @param {number} a The a component of the transform.
- * @param {number} b The b component of the transform.
- * @param {number} c The c component of the transform.
- * @param {number} d The d component of the transform.
- * @param {number} e The e component of the transform.
- * @param {number} f The f component of the transform.
- * @return {!ol.Transform} Matrix with transform applied.
-ol.transform.set = function(transform, a, b, c, d, e, f) {
- transform[0] = a;
- transform[1] = b;
- transform[2] = c;
- transform[3] = d;
- transform[4] = e;
- transform[5] = f;
- return transform;
- * Set transform on one matrix from another matrix.
- * @param {!ol.Transform} transform1 Matrix to set transform to.
- * @param {!ol.Transform} transform2 Matrix to set transform from.
- * @return {!ol.Transform} transform1 with transform from transform2 applied.
-ol.transform.setFromArray = function(transform1, transform2) {
- transform1[0] = transform2[0];
- transform1[1] = transform2[1];
- transform1[2] = transform2[2];
- transform1[3] = transform2[3];
- transform1[4] = transform2[4];
- transform1[5] = transform2[5];
- * Transforms the given coordinate with the given transform returning the
- * resulting, transformed coordinate. The coordinate will be modified in-place.
- * @param {ol.Transform} transform The transformation.
- * @param {ol.Coordinate|ol.Pixel} coordinate The coordinate to transform.
- * @return {ol.Coordinate|ol.Pixel} return coordinate so that operations can be
- * chained together.
-ol.transform.apply = function(transform, coordinate) {
- var x = coordinate[0], y = coordinate[1];
- coordinate[0] = transform[0] * x + transform[2] * y + transform[4];
- coordinate[1] = transform[1] * x + transform[3] * y + transform[5];
- return coordinate;
- * Applies rotation to the given transform.
- * @param {number} angle Angle in radians.
- * @return {!ol.Transform} The rotated transform.
-ol.transform.rotate = function(transform, angle) {
- var cos = Math.cos(angle);
- var sin = Math.sin(angle);
- return ol.transform.multiply(transform,
- ol.transform.set(ol.transform.tmp_, cos, sin, -sin, cos, 0, 0));
- * Applies scale to a given transform.
- * @param {number} x Scale factor x.
- * @param {number} y Scale factor y.
- * @return {!ol.Transform} The scaled transform.
-ol.transform.scale = function(transform, x, y) {
- ol.transform.set(ol.transform.tmp_, x, 0, 0, y, 0, 0));
- * Applies translation to the given transform.
- * @param {number} dx Translation x.
- * @param {number} dy Translation y.
- * @return {!ol.Transform} The translated transform.
-ol.transform.translate = function(transform, dx, dy) {
- ol.transform.set(ol.transform.tmp_, 1, 0, 0, 1, dx, dy));
- * Creates a composite transform given an initial translation, scale, rotation, and
- * final translation (in that order only, not commutative).
- * @param {!ol.Transform} transform The transform (will be modified in place).
- * @param {number} dx1 Initial translation x.
- * @param {number} dy1 Initial translation y.
- * @param {number} sx Scale factor x.
- * @param {number} sy Scale factor y.
- * @param {number} angle Rotation (in counter-clockwise radians).
- * @param {number} dx2 Final translation x.
- * @param {number} dy2 Final translation y.
- * @return {!ol.Transform} The composite transform.
-ol.transform.compose = function(transform, dx1, dy1, sx, sy, angle, dx2, dy2) {
- transform[0] = sx * cos;
- transform[1] = sy * sin;
- transform[2] = -sx * sin;
- transform[3] = sy * cos;
- transform[4] = dx2 * sx * cos - dy2 * sx * sin + dx1;
- transform[5] = dx2 * sy * sin + dy2 * sy * cos + dy1;
- return transform;
- * Invert the given transform.
- * @return {!ol.Transform} Inverse of the transform.
-ol.transform.invert = function(transform) {
- var det = ol.transform.determinant(transform);
- ol.asserts.assert(det !== 0, 32); // Transformation matrix cannot be inverted
- var a = transform[0];
- var b = transform[1];
- var c = transform[2];
- var d = transform[3];
- var e = transform[4];
- var f = transform[5];
- transform[0] = d / det;
- transform[1] = -b / det;
- transform[2] = -c / det;
- transform[3] = a / det;
- transform[4] = (c * f - d * e) / det;
- transform[5] = -(a * f - b * e) / det;
- return transform;
- * Returns the determinant of the given matrix.
- * @param {!ol.Transform} mat Matrix.
- * @return {number} Determinant.
-ol.transform.determinant = function(mat) {
- return mat[0] * mat[3] - mat[1] * mat[2];
-goog.provide('ol.renderer.Map');
-goog.require('ol');
-goog.require('ol.functions');
-goog.require('ol.layer.Layer');
-goog.require('ol.style');
-goog.require('ol.transform');
- * @constructor
- * @abstract
- * @param {Element} container Container.
- * @struct
-ol.renderer.Map = function(container, map) {
- ol.Disposable.call(this);
- * @private
- * @type {ol.Map}
- this.map_ = map;
- * @private
- * @type {Object.<string, ol.renderer.Layer>}
- this.layerRenderers_ = {};
- * @private
- * @type {Object.<string, ol.EventsKey>}
- this.layerRendererListeners_ = {};
-ol.inherits(ol.renderer.Map, ol.Disposable);
- * @param {olx.FrameState} frameState FrameState.
- * @protected
-ol.renderer.Map.prototype.calculateMatrices2D = function(frameState) {
- var viewState = frameState.viewState;
- var coordinateToPixelTransform = frameState.coordinateToPixelTransform;
- var pixelToCoordinateTransform = frameState.pixelToCoordinateTransform;
- ol.transform.compose(coordinateToPixelTransform,
- frameState.size[0] / 2, frameState.size[1] / 2,
- 1 / viewState.resolution, -1 / viewState.resolution,
- -viewState.rotation,
- -viewState.center[0], -viewState.center[1]);
- ol.transform.invert(
- ol.transform.setFromArray(pixelToCoordinateTransform, coordinateToPixelTransform));
- * @inheritDoc
-ol.renderer.Map.prototype.disposeInternal = function() {
- for (var id in this.layerRenderers_) {
- this.layerRenderers_[id].dispose();
- * @param {olx.FrameState} frameState Frame state.
- * @private
-ol.renderer.Map.expireIconCache_ = function(map, frameState) {
- var cache = ol.style.iconImageCache;
- cache.expire();
- * @param {ol.Coordinate} coordinate Coordinate.
- * @param {number} hitTolerance Hit tolerance in pixels.
- * @param {function(this: S, (ol.Feature|ol.render.Feature),
- * ol.layer.Layer): T} callback Feature callback.
- * @param {S} thisArg Value to use as `this` when executing `callback`.
- * @param {function(this: U, ol.layer.Layer): boolean} layerFilter Layer filter
- * function, only layers which are visible and for which this function
- * returns `true` will be tested for features. By default, all visible
- * layers will be tested.
- * @param {U} thisArg2 Value to use as `this` when executing `layerFilter`.
- * @return {T|undefined} Callback result.
- * @template S,T,U
-ol.renderer.Map.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg,
- layerFilter, thisArg2) {
- var result;
- var viewResolution = viewState.resolution;
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- * @param {ol.layer.Layer} layer Layer.
- * @return {?} Callback result.
- function forEachFeatureAtCoordinate(feature, layer) {
- var key = ol.getUid(feature).toString();
- var managed = frameState.layerStates[ol.getUid(layer)].managed;
- if (!(key in frameState.skippedFeatureUids && !managed)) {
- return callback.call(thisArg, feature, managed ? layer : null);
- var projection = viewState.projection;
- var translatedCoordinate = coordinate;
- if (projection.canWrapX()) {
- var projectionExtent = projection.getExtent();
- var worldWidth = ol.extent.getWidth(projectionExtent);
- var x = coordinate[0];
- if (x < projectionExtent[0] || x > projectionExtent[2]) {
- var worldsAway = Math.ceil((projectionExtent[0] - x) / worldWidth);
- translatedCoordinate = [x + worldWidth * worldsAway, coordinate[1]];
- var layerStates = frameState.layerStatesArray;
- var numLayers = layerStates.length;
- var i;
- for (i = numLayers - 1; i >= 0; --i) {
- var layerState = layerStates[i];
- var layer = layerState.layer;
- if (ol.layer.Layer.visibleAtResolution(layerState, viewResolution) &&
- layerFilter.call(thisArg2, layer)) {
- var layerRenderer = this.getLayerRenderer(layer);
- if (layer.getSource()) {
- result = layerRenderer.forEachFeatureAtCoordinate(
- layer.getSource().getWrapX() ? translatedCoordinate : coordinate,
- frameState, hitTolerance, forEachFeatureAtCoordinate, thisArg);
- if (result) {
- return result;
- return undefined;
- * @abstract
- * @param {ol.Pixel} pixel Pixel.
- * @param {function(this: S, ol.layer.Layer, (Uint8ClampedArray|Uint8Array)): T} callback Layer
- * callback.
- * @template S,T,U
-ol.renderer.Map.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg,
- layerFilter, thisArg2) {};
- * @param {U} thisArg Value to use as `this` when executing `layerFilter`.
- * @return {boolean} Is there a feature at the given coordinate?
- * @template U
-ol.renderer.Map.prototype.hasFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, layerFilter, thisArg) {
- var hasFeature = this.forEachFeatureAtCoordinate(
- coordinate, frameState, hitTolerance, ol.functions.TRUE, this, layerFilter, thisArg);
- return hasFeature !== undefined;
- * @protected
- * @return {ol.renderer.Layer} Layer renderer.
-ol.renderer.Map.prototype.getLayerRenderer = function(layer) {
- var layerKey = ol.getUid(layer).toString();
- if (layerKey in this.layerRenderers_) {
- return this.layerRenderers_[layerKey];
- } else {
- var layerRenderer = layer.createRenderer(this);
- this.layerRenderers_[layerKey] = layerRenderer;
- this.layerRendererListeners_[layerKey] = ol.events.listen(layerRenderer,
- ol.events.EventType.CHANGE, this.handleLayerRendererChange_, this);
- return layerRenderer;
- * @param {string} layerKey Layer key.
- * @protected
-ol.renderer.Map.prototype.getLayerRendererByKey = function(layerKey) {
- * @protected
- * @return {Object.<string, ol.renderer.Layer>} Layer renderers.
-ol.renderer.Map.prototype.getLayerRenderers = function() {
- return this.layerRenderers_;
- * @return {ol.Map} Map.
-ol.renderer.Map.prototype.getMap = function() {
- return this.map_;
- * @abstract
- * @return {string} Type
-ol.renderer.Map.prototype.getType = function() {};
- * Handle changes in a layer renderer.
- * @private
-ol.renderer.Map.prototype.handleLayerRendererChange_ = function() {
- this.map_.render();
- * @private
-ol.renderer.Map.prototype.removeLayerRendererByKey_ = function(layerKey) {
- var layerRenderer = this.layerRenderers_[layerKey];
- delete this.layerRenderers_[layerKey];
- ol.events.unlistenByKey(this.layerRendererListeners_[layerKey]);
- delete this.layerRendererListeners_[layerKey];
- * Render.
- * @param {?olx.FrameState} frameState Frame state.
-ol.renderer.Map.prototype.renderFrame = ol.nullFunction;
- * @private
-ol.renderer.Map.prototype.removeUnusedLayerRenderers_ = function(map, frameState) {
- var layerKey;
- for (layerKey in this.layerRenderers_) {
- if (!frameState || !(layerKey in frameState.layerStates)) {
- this.removeLayerRendererByKey_(layerKey).dispose();
- * @protected
-ol.renderer.Map.prototype.scheduleExpireIconCache = function(frameState) {
- frameState.postRenderFunctions.push(
- /** @type {ol.PostRenderFunction} */ (ol.renderer.Map.expireIconCache_)
- * @param {!olx.FrameState} frameState Frame state.
- * @protected
-ol.renderer.Map.prototype.scheduleRemoveUnusedLayerRenderers = function(frameState) {
- var layerKey;
- if (!(layerKey in frameState.layerStates)) {
- /** @type {ol.PostRenderFunction} */ (this.removeUnusedLayerRenderers_.bind(this))
- return;
- * @param {ol.LayerState} state1 First layer state.
- * @param {ol.LayerState} state2 Second layer state.
- * @return {number} The zIndex difference.
-ol.renderer.Map.sortByZIndex = function(state1, state2) {
- return state1.zIndex - state2.zIndex;
-goog.provide('ol.renderer.Type');
- * Available renderers: `'canvas'` or `'webgl'`.
- * @enum {string}
-ol.renderer.Type = {
- CANVAS: 'canvas',
- WEBGL: 'webgl'
-goog.provide('ol.render.Event');
- * @constructor
- * @implements {oli.render.Event}
- * @param {ol.render.EventType} type Type.
- * @param {ol.render.VectorContext=} opt_vectorContext Vector context.
- * @param {olx.FrameState=} opt_frameState Frame state.
- * @param {?CanvasRenderingContext2D=} opt_context Context.
- * @param {?ol.webgl.Context=} opt_glContext WebGL Context.
-ol.render.Event = function(
- type, opt_vectorContext, opt_frameState, opt_context,
- opt_glContext) {
- * For canvas, this is an instance of {@link ol.render.canvas.Immediate}.
- * @type {ol.render.VectorContext|undefined}
- * @api
- this.vectorContext = opt_vectorContext;
- * An object representing the current render frame state.
- * @type {olx.FrameState|undefined}
- * @api
- this.frameState = opt_frameState;
- * Canvas context. Only available when a Canvas renderer is used, null
- * otherwise.
- * @type {CanvasRenderingContext2D|null|undefined}
- * @api
- this.context = opt_context;
- * WebGL context. Only available when a WebGL renderer is used, null
- * otherwise.
- * @type {ol.webgl.Context|null|undefined}
- * @api
- this.glContext = opt_glContext;
-ol.inherits(ol.render.Event, ol.events.Event);
-goog.provide('ol.render.canvas');
- * @const
- * @type {string}
-ol.render.canvas.defaultFont = '10px sans-serif';
- * @const
- * @type {ol.Color}
-ol.render.canvas.defaultFillStyle = [0, 0, 0, 1];
- * @const
- * @type {string}
-ol.render.canvas.defaultLineCap = 'round';
- * @const
- * @type {Array.<number>}
-ol.render.canvas.defaultLineDash = [];
- * @const
- * @type {number}
-ol.render.canvas.defaultLineDashOffset = 0;
- * @const
- * @type {string}
-ol.render.canvas.defaultLineJoin = 'round';
- * @const
- * @type {number}
-ol.render.canvas.defaultMiterLimit = 10;
- * @const
-ol.render.canvas.defaultStrokeStyle = [0, 0, 0, 1];
- * @const
- * @type {string}
-ol.render.canvas.defaultTextAlign = 'center';
- * @const
- * @type {string}
-ol.render.canvas.defaultTextBaseline = 'middle';
- * @const
- * @type {number}
-ol.render.canvas.defaultLineWidth = 1;
- * @param {CanvasRenderingContext2D} context Context.
- * @param {number} rotation Rotation.
- * @param {number} offsetX X offset.
- * @param {number} offsetY Y offset.
-ol.render.canvas.rotateAtOffset = function(context, rotation, offsetX, offsetY) {
- if (rotation !== 0) {
- context.translate(offsetX, offsetY);
- context.rotate(rotation);
- context.translate(-offsetX, -offsetY);
-goog.provide('ol.render.VectorContext');
- * Context for drawing geometries. A vector context is available on render
- * events and does not need to be constructed directly.
- * @constructor
- * @abstract
- * @struct
- * @api
-ol.render.VectorContext = function() {
- * Render a geometry.
- * @param {ol.geom.Geometry} geometry The geometry to render.
-ol.render.VectorContext.prototype.drawGeometry = function(geometry) {};
- * Set the rendering style.
- * @param {ol.style.Style} style The rendering style.
-ol.render.VectorContext.prototype.setStyle = function(style) {};
- * @param {ol.geom.Circle} circleGeometry Circle geometry.
- * @param {ol.Feature} feature Feature.
-ol.render.VectorContext.prototype.drawCircle = function(circleGeometry, feature) {};
- * @param {ol.style.Style} style Style.
-ol.render.VectorContext.prototype.drawFeature = function(feature, style) {};
- * @param {ol.geom.GeometryCollection} geometryCollectionGeometry Geometry
- * collection.
-ol.render.VectorContext.prototype.drawGeometryCollection = function(geometryCollectionGeometry, feature) {};
- * @param {ol.geom.LineString|ol.render.Feature} lineStringGeometry Line
- * string geometry.
-ol.render.VectorContext.prototype.drawLineString = function(lineStringGeometry, feature) {};
- * @param {ol.geom.MultiLineString|ol.render.Feature} multiLineStringGeometry
- * MultiLineString geometry.
-ol.render.VectorContext.prototype.drawMultiLineString = function(multiLineStringGeometry, feature) {};
- * @param {ol.geom.MultiPoint|ol.render.Feature} multiPointGeometry MultiPoint
- * geometry.
-ol.render.VectorContext.prototype.drawMultiPoint = function(multiPointGeometry, feature) {};
- * @param {ol.geom.MultiPolygon} multiPolygonGeometry MultiPolygon geometry.
-ol.render.VectorContext.prototype.drawMultiPolygon = function(multiPolygonGeometry, feature) {};
- * @param {ol.geom.Point|ol.render.Feature} pointGeometry Point geometry.
-ol.render.VectorContext.prototype.drawPoint = function(pointGeometry, feature) {};
- * @param {ol.geom.Polygon|ol.render.Feature} polygonGeometry Polygon
- * geometry.
-ol.render.VectorContext.prototype.drawPolygon = function(polygonGeometry, feature) {};
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
- * @param {ol.geom.Geometry|ol.render.Feature} geometry Geometry.
-ol.render.VectorContext.prototype.drawText = function(flatCoordinates, offset, end, stride, geometry, feature) {};
- * @param {ol.style.Fill} fillStyle Fill style.
- * @param {ol.style.Stroke} strokeStyle Stroke style.
-ol.render.VectorContext.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {};
- * @param {ol.style.Image} imageStyle Image style.
-ol.render.VectorContext.prototype.setImageStyle = function(imageStyle) {};
- * @param {ol.style.Text} textStyle Text style.
-ol.render.VectorContext.prototype.setTextStyle = function(textStyle) {};
-// FIXME test, especially polygons with holes and multipolygons
-// FIXME need to handle large thick features (where pixel size matters)
-// FIXME add offset and end to ol.geom.flat.transform.transform2D?
-goog.provide('ol.render.canvas.Immediate');
-goog.require('ol.array');
-goog.require('ol.colorlike');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.geom.SimpleGeometry');
-goog.require('ol.geom.flat.transform');
-goog.require('ol.has');
-goog.require('ol.render.VectorContext');
-goog.require('ol.render.canvas');
- * @classdesc
- * A concrete subclass of {@link ol.render.VectorContext} that implements
- * direct rendering of features and geometries to an HTML5 Canvas context.
- * Instances of this class are created internally by the library and
- * provided to application code as vectorContext member of the
- * {@link ol.render.Event} object associated with postcompose, precompose and
- * render events emitted by layers and maps.
- * @constructor
- * @extends {ol.render.VectorContext}
- * @param {number} pixelRatio Pixel ratio.
- * @param {ol.Extent} extent Extent.
- * @param {ol.Transform} transform Transform.
- * @param {number} viewRotation View rotation.
- * @struct
-ol.render.canvas.Immediate = function(context, pixelRatio, extent, transform, viewRotation) {
- ol.render.VectorContext.call(this);
- * @private
- * @type {CanvasRenderingContext2D}
- this.context_ = context;
- * @private
- * @type {number}
- this.pixelRatio_ = pixelRatio;
- * @private
- * @type {ol.Extent}
- this.extent_ = extent;
- * @private
- this.transform_ = transform;
- * @private
- * @type {number}
- this.viewRotation_ = viewRotation;
- * @private
- * @type {?ol.CanvasFillState}
- this.contextFillState_ = null;
- * @private
- * @type {?ol.CanvasStrokeState}
- this.contextStrokeState_ = null;
- * @private
- * @type {?ol.CanvasTextState}
- this.contextTextState_ = null;
- * @private
- this.fillState_ = null;
- * @private
- this.strokeState_ = null;
- * @private
- * @type {HTMLCanvasElement|HTMLVideoElement|Image}
- this.image_ = null;
- * @private
- * @type {number}
- this.imageAnchorX_ = 0;
- * @private
- * @type {number}
- this.imageAnchorY_ = 0;
- * @private
- * @type {number}
- this.imageHeight_ = 0;
- * @private
- * @type {number}
- this.imageOpacity_ = 0;
- * @private
- * @type {number}
- this.imageOriginX_ = 0;
- * @private
- * @type {number}
- this.imageOriginY_ = 0;
- * @private
- * @type {boolean}
- this.imageRotateWithView_ = false;
- * @private
- * @type {number}
- this.imageRotation_ = 0;
- * @private
- * @type {number}
- this.imageScale_ = 0;
- * @private
- * @type {boolean}
- this.imageSnapToPixel_ = false;
- * @private
- * @type {number}
- this.imageWidth_ = 0;
- * @private
- * @type {string}
- this.text_ = '';
- * @private
- * @type {number}
- this.textOffsetX_ = 0;
- * @private
- * @type {number}
- this.textOffsetY_ = 0;
- * @private
- * @type {boolean}
- this.textRotateWithView_ = false;
- * @private
- * @type {number}
- this.textRotation_ = 0;
- * @private
- * @type {number}
- this.textScale_ = 0;
- * @private
- this.textFillState_ = null;
- * @private
- this.textStrokeState_ = null;
- * @private
- this.textState_ = null;
- * @private
- this.pixelCoordinates_ = [];
- * @private
- this.tmpLocalTransform_ = ol.transform.create();
-ol.inherits(ol.render.canvas.Immediate, ol.render.VectorContext);
- * @private
-ol.render.canvas.Immediate.prototype.drawImages_ = function(flatCoordinates, offset, end, stride) {
- if (!this.image_) {
- return;
- var pixelCoordinates = ol.geom.flat.transform.transform2D(
- flatCoordinates, offset, end, 2, this.transform_,
- this.pixelCoordinates_);
- var context = this.context_;
- var localTransform = this.tmpLocalTransform_;
- var alpha = context.globalAlpha;
- if (this.imageOpacity_ != 1) {
- context.globalAlpha = alpha * this.imageOpacity_;
- var rotation = this.imageRotation_;
- if (this.imageRotateWithView_) {
- rotation += this.viewRotation_;
- var i, ii;
- for (i = 0, ii = pixelCoordinates.length; i < ii; i += 2) {
- var x = pixelCoordinates[i] - this.imageAnchorX_;
- var y = pixelCoordinates[i + 1] - this.imageAnchorY_;
- if (this.imageSnapToPixel_) {
- x = Math.round(x);
- y = Math.round(y);
- if (rotation !== 0 || this.imageScale_ != 1) {
- var centerX = x + this.imageAnchorX_;
- var centerY = y + this.imageAnchorY_;
- ol.transform.compose(localTransform,
- centerX, centerY,
- this.imageScale_, this.imageScale_,
- rotation,
- -centerX, -centerY);
- context.setTransform.apply(context, localTransform);
- context.drawImage(this.image_, this.imageOriginX_, this.imageOriginY_,
- this.imageWidth_, this.imageHeight_, x, y,
- this.imageWidth_, this.imageHeight_);
- context.setTransform(1, 0, 0, 1, 0, 0);
- context.globalAlpha = alpha;
- * @private
-ol.render.canvas.Immediate.prototype.drawText_ = function(flatCoordinates, offset, end, stride) {
- if (!this.textState_ || this.text_ === '') {
- return;
- if (this.textFillState_) {
- this.setContextFillState_(this.textFillState_);
- if (this.textStrokeState_) {
- this.setContextStrokeState_(this.textStrokeState_);
- this.setContextTextState_(this.textState_);
- flatCoordinates, offset, end, stride, this.transform_,
- var rotation = this.textRotation_;
- if (this.textRotateWithView_) {
- for (; offset < end; offset += stride) {
- var x = pixelCoordinates[offset] + this.textOffsetX_;
- var y = pixelCoordinates[offset + 1] + this.textOffsetY_;
- if (rotation !== 0 || this.textScale_ != 1) {
- var localTransform = ol.transform.compose(this.tmpLocalTransform_,
- x, y,
- this.textScale_, this.textScale_,
- rotation,
- -x, -y);
- context.strokeText(this.text_, x, y);
- context.fillText(this.text_, x, y);
- * @param {boolean} close Close.
- * @private
- * @return {number} end End.
-ol.render.canvas.Immediate.prototype.moveToLineTo_ = function(flatCoordinates, offset, end, stride, close) {
- context.moveTo(pixelCoordinates[0], pixelCoordinates[1]);
- var length = pixelCoordinates.length;
- if (close) {
- length -= 2;
- for (var i = 2; i < length; i += 2) {
- context.lineTo(pixelCoordinates[i], pixelCoordinates[i + 1]);
- if (close) {
- context.closePath();
- return end;
- * @param {Array.<number>} ends Ends.
- * @private
- * @return {number} End.
-ol.render.canvas.Immediate.prototype.drawRings_ = function(flatCoordinates, offset, ends, stride) {
- var i, ii;
- for (i = 0, ii = ends.length; i < ii; ++i) {
- offset = this.moveToLineTo_(
- flatCoordinates, offset, ends[i], stride, true);
- return offset;
- * Render a circle geometry into the canvas. Rendering is immediate and uses
- * the current fill and stroke styles.
- * @param {ol.geom.Circle} geometry Circle geometry.
- * @override
- * @api
-ol.render.canvas.Immediate.prototype.drawCircle = function(geometry) {
- if (!ol.extent.intersects(this.extent_, geometry.getExtent())) {
- return;
- if (this.fillState_ || this.strokeState_) {
- if (this.fillState_) {
- this.setContextFillState_(this.fillState_);
- if (this.strokeState_) {
- this.setContextStrokeState_(this.strokeState_);
- var pixelCoordinates = ol.geom.SimpleGeometry.transform2D(
- geometry, this.transform_, this.pixelCoordinates_);
- var dx = pixelCoordinates[2] - pixelCoordinates[0];
- var dy = pixelCoordinates[3] - pixelCoordinates[1];
- var radius = Math.sqrt(dx * dx + dy * dy);
- context.beginPath();
- context.arc(
- pixelCoordinates[0], pixelCoordinates[1], radius, 0, 2 * Math.PI);
- context.fill();
- context.stroke();
- if (this.text_ !== '') {
- this.drawText_(geometry.getCenter(), 0, 2, 2);
- * Set the rendering style. Note that since this is an immediate rendering API,
- * any `zIndex` on the provided style will be ignored.
- * @override
- * @api
-ol.render.canvas.Immediate.prototype.setStyle = function(style) {
- this.setFillStrokeStyle(style.getFill(), style.getStroke());
- this.setImageStyle(style.getImage());
- this.setTextStyle(style.getText());
- * Render a geometry into the canvas. Call
- * {@link ol.render.canvas.Immediate#setStyle} first to set the rendering style.
- * @param {ol.geom.Geometry|ol.render.Feature} geometry The geometry to render.
- * @override
- * @api
-ol.render.canvas.Immediate.prototype.drawGeometry = function(geometry) {
- var type = geometry.getType();
- switch (type) {
- case ol.geom.GeometryType.POINT:
- this.drawPoint(/** @type {ol.geom.Point} */ (geometry));
- break;
- case ol.geom.GeometryType.LINE_STRING:
- this.drawLineString(/** @type {ol.geom.LineString} */ (geometry));
- break;
- case ol.geom.GeometryType.POLYGON:
- this.drawPolygon(/** @type {ol.geom.Polygon} */ (geometry));
- break;
- case ol.geom.GeometryType.MULTI_POINT:
- this.drawMultiPoint(/** @type {ol.geom.MultiPoint} */ (geometry));
- break;
- case ol.geom.GeometryType.MULTI_LINE_STRING:
- this.drawMultiLineString(/** @type {ol.geom.MultiLineString} */ (geometry));
- break;
- case ol.geom.GeometryType.MULTI_POLYGON:
- this.drawMultiPolygon(/** @type {ol.geom.MultiPolygon} */ (geometry));
- break;
- case ol.geom.GeometryType.GEOMETRY_COLLECTION:
- this.drawGeometryCollection(/** @type {ol.geom.GeometryCollection} */ (geometry));
- break;
- case ol.geom.GeometryType.CIRCLE:
- this.drawCircle(/** @type {ol.geom.Circle} */ (geometry));
- break;
- default:
- * Render a feature into the canvas. Note that any `zIndex` on the provided
- * style will be ignored - features are rendered immediately in the order that
- * this method is called. If you need `zIndex` support, you should be using an
- * {@link ol.layer.Vector} instead.
- * @override
- * @api
-ol.render.canvas.Immediate.prototype.drawFeature = function(feature, style) {
- var geometry = style.getGeometryFunction()(feature);
- if (!geometry ||
- !ol.extent.intersects(this.extent_, geometry.getExtent())) {
- return;
- this.setStyle(style);
- this.drawGeometry(geometry);
- * Render a GeometryCollection to the canvas. Rendering is immediate and
- * uses the current styles appropriate for each geometry in the collection.
- * @param {ol.geom.GeometryCollection} geometry Geometry collection.
- * @override
-ol.render.canvas.Immediate.prototype.drawGeometryCollection = function(geometry) {
- var geometries = geometry.getGeometriesArray();
- var i, ii;
- for (i = 0, ii = geometries.length; i < ii; ++i) {
- this.drawGeometry(geometries[i]);
- * Render a Point geometry into the canvas. Rendering is immediate and uses
- * the current style.
- * @param {ol.geom.Point|ol.render.Feature} geometry Point geometry.
- * @override
-ol.render.canvas.Immediate.prototype.drawPoint = function(geometry) {
- var flatCoordinates = geometry.getFlatCoordinates();
- var stride = geometry.getStride();
- if (this.image_) {
- this.drawImages_(flatCoordinates, 0, flatCoordinates.length, stride);
- this.drawText_(flatCoordinates, 0, flatCoordinates.length, stride);
- * Render a MultiPoint geometry into the canvas. Rendering is immediate and
- * uses the current style.
- * @param {ol.geom.MultiPoint|ol.render.Feature} geometry MultiPoint geometry.
- * @override
-ol.render.canvas.Immediate.prototype.drawMultiPoint = function(geometry) {
- * Render a LineString into the canvas. Rendering is immediate and uses
- * @param {ol.geom.LineString|ol.render.Feature} geometry LineString geometry.
- * @override
-ol.render.canvas.Immediate.prototype.drawLineString = function(geometry) {
- return;
- this.moveToLineTo_(flatCoordinates, 0, flatCoordinates.length,
- geometry.getStride(), false);
- context.stroke();
- var flatMidpoint = geometry.getFlatMidpoint();
- this.drawText_(flatMidpoint, 0, 2, 2);
- * Render a MultiLineString geometry into the canvas. Rendering is immediate
- * and uses the current style.
- * @param {ol.geom.MultiLineString|ol.render.Feature} geometry MultiLineString
- * geometry.
- * @override
-ol.render.canvas.Immediate.prototype.drawMultiLineString = function(geometry) {
- var geometryExtent = geometry.getExtent();
- if (!ol.extent.intersects(this.extent_, geometryExtent)) {
- return;
- var offset = 0;
- var ends = geometry.getEnds();
- var i, ii;
- flatCoordinates, offset, ends[i], stride, false);
- context.stroke();
- var flatMidpoints = geometry.getFlatMidpoints();
- this.drawText_(flatMidpoints, 0, flatMidpoints.length, 2);
- * Render a Polygon geometry into the canvas. Rendering is immediate and uses
- * @param {ol.geom.Polygon|ol.render.Feature} geometry Polygon geometry.
- * @override
-ol.render.canvas.Immediate.prototype.drawPolygon = function(geometry) {
- return;
- if (this.strokeState_ || this.fillState_) {
- this.drawRings_(geometry.getOrientedFlatCoordinates(),
- 0, geometry.getEnds(), geometry.getStride());
- context.fill();
- context.stroke();
- var flatInteriorPoint = geometry.getFlatInteriorPoint();
- this.drawText_(flatInteriorPoint, 0, 2, 2);
- * Render MultiPolygon geometry into the canvas. Rendering is immediate and
- * @param {ol.geom.MultiPolygon} geometry MultiPolygon geometry.
- * @override
-ol.render.canvas.Immediate.prototype.drawMultiPolygon = function(geometry) {
- return;
- var flatCoordinates = geometry.getOrientedFlatCoordinates();
- var offset = 0;
- var endss = geometry.getEndss();
- var i, ii;
- for (i = 0, ii = endss.length; i < ii; ++i) {
- var ends = endss[i];
- offset = this.drawRings_(flatCoordinates, offset, ends, stride);
- context.fill();
- context.stroke();
- var flatInteriorPoints = geometry.getFlatInteriorPoints();
- this.drawText_(flatInteriorPoints, 0, flatInteriorPoints.length, 2);
- * @param {ol.CanvasFillState} fillState Fill state.
- * @private
-ol.render.canvas.Immediate.prototype.setContextFillState_ = function(fillState) {
- var contextFillState = this.contextFillState_;
- if (!contextFillState) {
- context.fillStyle = fillState.fillStyle;
- this.contextFillState_ = {
- fillStyle: fillState.fillStyle
- } else {
- if (contextFillState.fillStyle != fillState.fillStyle) {
- contextFillState.fillStyle = context.fillStyle = fillState.fillStyle;
- * @param {ol.CanvasStrokeState} strokeState Stroke state.
- * @private
-ol.render.canvas.Immediate.prototype.setContextStrokeState_ = function(strokeState) {
- var contextStrokeState = this.contextStrokeState_;
- if (!contextStrokeState) {
- context.lineCap = strokeState.lineCap;
- if (ol.has.CANVAS_LINE_DASH) {
- context.setLineDash(strokeState.lineDash);
- context.lineJoin = strokeState.lineJoin;
- context.lineWidth = strokeState.lineWidth;
- context.miterLimit = strokeState.miterLimit;
- context.strokeStyle = strokeState.strokeStyle;
- this.contextStrokeState_ = {
- lineCap: strokeState.lineCap,
- lineDash: strokeState.lineDash,
- lineJoin: strokeState.lineJoin,
- lineWidth: strokeState.lineWidth,
- miterLimit: strokeState.miterLimit,
- strokeStyle: strokeState.strokeStyle
- } else {
- if (contextStrokeState.lineCap != strokeState.lineCap) {
- contextStrokeState.lineCap = context.lineCap = strokeState.lineCap;
- if (!ol.array.equals(
- contextStrokeState.lineDash, strokeState.lineDash)) {
- context.setLineDash(contextStrokeState.lineDash = strokeState.lineDash);
- if (contextStrokeState.lineJoin != strokeState.lineJoin) {
- contextStrokeState.lineJoin = context.lineJoin = strokeState.lineJoin;
- if (contextStrokeState.lineWidth != strokeState.lineWidth) {
- contextStrokeState.lineWidth = context.lineWidth = strokeState.lineWidth;
- if (contextStrokeState.miterLimit != strokeState.miterLimit) {
- contextStrokeState.miterLimit = context.miterLimit =
- strokeState.miterLimit;
- if (contextStrokeState.strokeStyle != strokeState.strokeStyle) {
- contextStrokeState.strokeStyle = context.strokeStyle =
- strokeState.strokeStyle;
- * @param {ol.CanvasTextState} textState Text state.
- * @private
-ol.render.canvas.Immediate.prototype.setContextTextState_ = function(textState) {
- var contextTextState = this.contextTextState_;
- if (!contextTextState) {
- context.font = textState.font;
- context.textAlign = textState.textAlign;
- context.textBaseline = textState.textBaseline;
- this.contextTextState_ = {
- font: textState.font,
- textAlign: textState.textAlign,
- textBaseline: textState.textBaseline
- } else {
- if (contextTextState.font != textState.font) {
- contextTextState.font = context.font = textState.font;
- if (contextTextState.textAlign != textState.textAlign) {
- contextTextState.textAlign = context.textAlign = textState.textAlign;
- if (contextTextState.textBaseline != textState.textBaseline) {
- contextTextState.textBaseline = context.textBaseline =
- textState.textBaseline;
- * Set the fill and stroke style for subsequent draw operations. To clear
- * either fill or stroke styles, pass null for the appropriate parameter.
- * @override
-ol.render.canvas.Immediate.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- if (!fillStyle) {
- } else {
- var fillStyleColor = fillStyle.getColor();
- this.fillState_ = {
- fillStyle: ol.colorlike.asColorLike(fillStyleColor ?
- fillStyleColor : ol.render.canvas.defaultFillStyle)
- if (!strokeStyle) {
- } else {
- var strokeStyleColor = strokeStyle.getColor();
- var strokeStyleLineCap = strokeStyle.getLineCap();
- var strokeStyleLineDash = strokeStyle.getLineDash();
- var strokeStyleLineDashOffset = strokeStyle.getLineDashOffset();
- var strokeStyleLineJoin = strokeStyle.getLineJoin();
- var strokeStyleWidth = strokeStyle.getWidth();
- var strokeStyleMiterLimit = strokeStyle.getMiterLimit();
- this.strokeState_ = {
- lineCap: strokeStyleLineCap !== undefined ?
- strokeStyleLineCap : ol.render.canvas.defaultLineCap,
- lineDash: strokeStyleLineDash ?
- strokeStyleLineDash : ol.render.canvas.defaultLineDash,
- lineDashOffset: strokeStyleLineDashOffset ?
- strokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset,
- lineJoin: strokeStyleLineJoin !== undefined ?
- strokeStyleLineJoin : ol.render.canvas.defaultLineJoin,
- lineWidth: this.pixelRatio_ * (strokeStyleWidth !== undefined ?
- strokeStyleWidth : ol.render.canvas.defaultLineWidth),
- miterLimit: strokeStyleMiterLimit !== undefined ?
- strokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit,
- strokeStyle: ol.colorlike.asColorLike(strokeStyleColor ?
- strokeStyleColor : ol.render.canvas.defaultStrokeStyle)
- * Set the image style for subsequent draw operations. Pass null to remove
- * the image style.
- * @override
-ol.render.canvas.Immediate.prototype.setImageStyle = function(imageStyle) {
- if (!imageStyle) {
- } else {
- var imageAnchor = imageStyle.getAnchor();
- // FIXME pixel ratio
- var imageImage = imageStyle.getImage(1);
- var imageOrigin = imageStyle.getOrigin();
- var imageSize = imageStyle.getSize();
- this.imageAnchorX_ = imageAnchor[0];
- this.imageAnchorY_ = imageAnchor[1];
- this.imageHeight_ = imageSize[1];
- this.image_ = imageImage;
- this.imageOpacity_ = imageStyle.getOpacity();
- this.imageOriginX_ = imageOrigin[0];
- this.imageOriginY_ = imageOrigin[1];
- this.imageRotateWithView_ = imageStyle.getRotateWithView();
- this.imageRotation_ = imageStyle.getRotation();
- this.imageScale_ = imageStyle.getScale();
- this.imageSnapToPixel_ = imageStyle.getSnapToPixel();
- this.imageWidth_ = imageSize[0];
- * Set the text style for subsequent draw operations. Pass null to
- * remove the text style.
- * @override
-ol.render.canvas.Immediate.prototype.setTextStyle = function(textStyle) {
- if (!textStyle) {
- this.text_ = '';
- } else {
- var textFillStyle = textStyle.getFill();
- if (!textFillStyle) {
- } else {
- var textFillStyleColor = textFillStyle.getColor();
- this.textFillState_ = {
- fillStyle: ol.colorlike.asColorLike(textFillStyleColor ?
- textFillStyleColor : ol.render.canvas.defaultFillStyle)
- var textStrokeStyle = textStyle.getStroke();
- if (!textStrokeStyle) {
- } else {
- var textStrokeStyleColor = textStrokeStyle.getColor();
- var textStrokeStyleLineCap = textStrokeStyle.getLineCap();
- var textStrokeStyleLineDash = textStrokeStyle.getLineDash();
- var textStrokeStyleLineDashOffset = textStrokeStyle.getLineDashOffset();
- var textStrokeStyleLineJoin = textStrokeStyle.getLineJoin();
- var textStrokeStyleWidth = textStrokeStyle.getWidth();
- var textStrokeStyleMiterLimit = textStrokeStyle.getMiterLimit();
- this.textStrokeState_ = {
- lineCap: textStrokeStyleLineCap !== undefined ?
- textStrokeStyleLineCap : ol.render.canvas.defaultLineCap,
- lineDash: textStrokeStyleLineDash ?
- textStrokeStyleLineDash : ol.render.canvas.defaultLineDash,
- lineDashOffset: textStrokeStyleLineDashOffset ?
- textStrokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset,
- lineJoin: textStrokeStyleLineJoin !== undefined ?
- textStrokeStyleLineJoin : ol.render.canvas.defaultLineJoin,
- lineWidth: textStrokeStyleWidth !== undefined ?
- textStrokeStyleWidth : ol.render.canvas.defaultLineWidth,
- miterLimit: textStrokeStyleMiterLimit !== undefined ?
- textStrokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit,
- strokeStyle: ol.colorlike.asColorLike(textStrokeStyleColor ?
- textStrokeStyleColor : ol.render.canvas.defaultStrokeStyle)
- var textFont = textStyle.getFont();
- var textOffsetX = textStyle.getOffsetX();
- var textOffsetY = textStyle.getOffsetY();
- var textRotateWithView = textStyle.getRotateWithView();
- var textRotation = textStyle.getRotation();
- var textScale = textStyle.getScale();
- var textText = textStyle.getText();
- var textTextAlign = textStyle.getTextAlign();
- var textTextBaseline = textStyle.getTextBaseline();
- this.textState_ = {
- font: textFont !== undefined ?
- textFont : ol.render.canvas.defaultFont,
- textAlign: textTextAlign !== undefined ?
- textTextAlign : ol.render.canvas.defaultTextAlign,
- textBaseline: textTextBaseline !== undefined ?
- textTextBaseline : ol.render.canvas.defaultTextBaseline
- this.text_ = textText !== undefined ? textText : '';
- textOffsetX !== undefined ? (this.pixelRatio_ * textOffsetX) : 0;
- textOffsetY !== undefined ? (this.pixelRatio_ * textOffsetY) : 0;
- this.textRotateWithView_ = textRotateWithView !== undefined ? textRotateWithView : false;
- this.textRotation_ = textRotation !== undefined ? textRotation : 0;
- this.textScale_ = this.pixelRatio_ * (textScale !== undefined ?
- textScale : 1);
-// FIXME offset panning
-goog.provide('ol.renderer.canvas.Map');
-goog.require('ol.css');
-goog.require('ol.dom');
-goog.require('ol.render.Event');
-goog.require('ol.render.canvas.Immediate');
-goog.require('ol.renderer.Map');
-goog.require('ol.renderer.Type');
- * @constructor
- * @extends {ol.renderer.Map}
-ol.renderer.canvas.Map = function(container, map) {
- ol.renderer.Map.call(this, container, map);
- * @private
- this.context_ = ol.dom.createCanvasContext2D();
- * @private
- * @type {HTMLCanvasElement}
- this.canvas_ = this.context_.canvas;
- this.canvas_.style.width = '100%';
- this.canvas_.style.height = '100%';
- this.canvas_.style.display = 'block';
- this.canvas_.className = ol.css.CLASS_UNSELECTABLE;
- container.insertBefore(this.canvas_, container.childNodes[0] || null);
- * @private
- * @type {boolean}
- this.renderedVisible_ = true;
- * @private
- this.transform_ = ol.transform.create();
-ol.inherits(ol.renderer.canvas.Map, ol.renderer.Map);
- * @param {ol.render.EventType} type Event type.
- * @private
-ol.renderer.canvas.Map.prototype.dispatchComposeEvent_ = function(type, frameState) {
- var map = this.getMap();
- if (map.hasListener(type)) {
- var extent = frameState.extent;
- var pixelRatio = frameState.pixelRatio;
- var rotation = viewState.rotation;
- var transform = this.getTransform(frameState);
- var vectorContext = new ol.render.canvas.Immediate(context, pixelRatio,
- extent, transform, rotation);
- var composeEvent = new ol.render.Event(type, vectorContext,
- frameState, context, null);
- map.dispatchEvent(composeEvent);
- * @protected
-ol.renderer.canvas.Map.prototype.getTransform = function(frameState) {
- var dx1 = this.canvas_.width / 2;
- var dy1 = this.canvas_.height / 2;
- var sx = frameState.pixelRatio / viewState.resolution;
- var sy = -sx;
- var angle = -viewState.rotation;
- var dx2 = -viewState.center[0];
- var dy2 = -viewState.center[1];
- return ol.transform.compose(this.transform_, dx1, dy1, sx, sy, angle, dx2, dy2);
- * @inheritDoc
-ol.renderer.canvas.Map.prototype.getType = function() {
- return ol.renderer.Type.CANVAS;
- * @inheritDoc
-ol.renderer.canvas.Map.prototype.renderFrame = function(frameState) {
- if (!frameState) {
- if (this.renderedVisible_) {
- this.canvas_.style.display = 'none';
- this.renderedVisible_ = false;
- return;
- var width = Math.round(frameState.size[0] * pixelRatio);
- var height = Math.round(frameState.size[1] * pixelRatio);
- if (this.canvas_.width != width || this.canvas_.height != height) {
- this.canvas_.width = width;
- this.canvas_.height = height;
- } else {
- context.clearRect(0, 0, width, height);
- var rotation = frameState.viewState.rotation;
- this.calculateMatrices2D(frameState);
- this.dispatchComposeEvent_(ol.render.EventType.PRECOMPOSE, frameState);
- var layerStatesArray = frameState.layerStatesArray;
- ol.array.stableSort(layerStatesArray, ol.renderer.Map.sortByZIndex);
- if (rotation) {
- context.save();
- ol.render.canvas.rotateAtOffset(context, rotation, width / 2, height / 2);
- var viewResolution = frameState.viewState.resolution;
- var i, ii, layer, layerRenderer, layerState;
- for (i = 0, ii = layerStatesArray.length; i < ii; ++i) {
- layerState = layerStatesArray[i];
- layer = layerState.layer;
- layerRenderer = /** @type {ol.renderer.canvas.Layer} */ (this.getLayerRenderer(layer));
- if (!ol.layer.Layer.visibleAtResolution(layerState, viewResolution) ||
- layerState.sourceState != ol.source.State.READY) {
- continue;
- if (layerRenderer.prepareFrame(frameState, layerState)) {
- layerRenderer.composeFrame(frameState, layerState, context);
- if (rotation) {
- context.restore();
- ol.render.EventType.POSTCOMPOSE, frameState);
- if (!this.renderedVisible_) {
- this.canvas_.style.display = '';
- this.scheduleRemoveUnusedLayerRenderers(frameState);
- this.scheduleExpireIconCache(frameState);
- * @inheritDoc
-ol.renderer.canvas.Map.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg,
- var result;
- var coordinate = ol.transform.apply(
- frameState.pixelToCoordinateTransform, pixel.slice());
- var i;
- var layerRenderer = /** @type {ol.renderer.canvas.Layer} */ (this.getLayerRenderer(layer));
- result = layerRenderer.forEachLayerAtCoordinate(
- coordinate, frameState, callback, thisArg);
- if (result) {
- return result;
- return undefined;
-goog.provide('ol.render.ReplayType');
- * @enum {string}
-ol.render.ReplayType = {
- CIRCLE: 'Circle',
- IMAGE: 'Image',
- LINE_STRING: 'LineString',
- POLYGON: 'Polygon',
- TEXT: 'Text'
-goog.provide('ol.render.replay');
-goog.require('ol.render.ReplayType');
- * @const
- * @type {Array.<ol.render.ReplayType>}
-ol.render.replay.ORDER = [
- ol.render.ReplayType.POLYGON,
- ol.render.ReplayType.CIRCLE,
- ol.render.ReplayType.LINE_STRING,
- ol.render.ReplayType.IMAGE,
- ol.render.ReplayType.TEXT
-goog.provide('ol.render.ReplayGroup');
- * Base class for replay groups.
- * @constructor
- * @abstract
-ol.render.ReplayGroup = function() {};
- * @abstract
- * @param {number|undefined} zIndex Z index.
- * @param {ol.render.ReplayType} replayType Replay type.
- * @return {ol.render.VectorContext} Replay.
-ol.render.ReplayGroup.prototype.getReplay = function(zIndex, replayType) {};
- * @abstract
- * @return {boolean} Is empty.
-ol.render.ReplayGroup.prototype.isEmpty = function() {};
-goog.provide('ol.webgl.Shader');
-if (ol.ENABLE_WEBGL) {
- * @constructor
- * @abstract
- * @param {string} source Source.
- * @struct
- ol.webgl.Shader = function(source) {
- * @private
- * @type {string}
- this.source_ = source;
- * @abstract
- * @return {number} Type.
- ol.webgl.Shader.prototype.getType = function() {};
- * @return {string} Source.
- ol.webgl.Shader.prototype.getSource = function() {
- return this.source_;
- * @return {boolean} Is animated?
- ol.webgl.Shader.prototype.isAnimated = ol.functions.FALSE;
-goog.provide('ol.webgl.Fragment');
-goog.require('ol.webgl');
-goog.require('ol.webgl.Shader');
- * @constructor
- * @extends {ol.webgl.Shader}
- * @struct
- ol.webgl.Fragment = function(source) {
- ol.webgl.Shader.call(this, source);
- ol.inherits(ol.webgl.Fragment, ol.webgl.Shader);
- * @inheritDoc
- ol.webgl.Fragment.prototype.getType = function() {
- return ol.webgl.FRAGMENT_SHADER;
-goog.provide('ol.webgl.Vertex');
- * @constructor
- * @struct
- ol.webgl.Vertex = function(source) {
- ol.inherits(ol.webgl.Vertex, ol.webgl.Shader);
- * @inheritDoc
- ol.webgl.Vertex.prototype.getType = function() {
- return ol.webgl.VERTEX_SHADER;
-// This file is automatically generated, do not edit
-goog.provide('ol.render.webgl.circlereplay.defaultshader');
-goog.require('ol.webgl.Fragment');
-goog.require('ol.webgl.Vertex');
- * @constructor
- * @extends {ol.webgl.Fragment}
- * @struct
- ol.render.webgl.circlereplay.defaultshader.Fragment = function() {
- ol.webgl.Fragment.call(this, ol.render.webgl.circlereplay.defaultshader.Fragment.SOURCE);
- ol.inherits(ol.render.webgl.circlereplay.defaultshader.Fragment, ol.webgl.Fragment);
- * @const
- * @type {string}
- ol.render.webgl.circlereplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_center;\nvarying vec2 v_offset;\nvarying float v_halfWidth;\nvarying float v_pixelRatio;\n\n\n\nuniform float u_opacity;\nuniform vec4 u_fillColor;\nuniform vec4 u_strokeColor;\nuniform vec2 u_size;\n\nvoid main(void) {\n vec2 windowCenter = vec2((v_center.x + 1.0) / 2.0 * u_size.x * v_pixelRatio,\n (v_center.y + 1.0) / 2.0 * u_size.y * v_pixelRatio);\n vec2 windowOffset = vec2((v_offset.x + 1.0) / 2.0 * u_size.x * v_pixelRatio,\n (v_offset.y + 1.0) / 2.0 * u_size.y * v_pixelRatio);\n float radius = length(windowCenter - windowOffset);\n float dist = length(windowCenter - gl_FragCoord.xy);\n if (dist > radius + v_halfWidth) {\n if (u_strokeColor.a == 0.0) {\n gl_FragColor = u_fillColor;\n } else {\n gl_FragColor = u_strokeColor;\n }\n gl_FragColor.a = gl_FragColor.a - (dist - (radius + v_halfWidth));\n } else if (u_fillColor.a == 0.0) {
\n // Hooray, no fill, just stroke. We can use real antialiasing.\n gl_FragColor = u_strokeColor;\n if (dist < radius - v_halfWidth) {\n gl_FragColor.a = gl_FragColor.a - (radius - v_halfWidth - dist);\n }\n } else {\n gl_FragColor = u_fillColor;\n float strokeDist = radius - v_halfWidth;\n float antialias = 2.0 * v_pixelRatio;\n if (dist > strokeDist) {\n gl_FragColor = u_strokeColor;\n } else if (dist >= strokeDist - antialias) {\n float step = smoothstep(strokeDist - antialias, strokeDist, dist);\n gl_FragColor = mix(u_fillColor, u_strokeColor, step);\n }\n }\n gl_FragColor.a = gl_FragColor.a * u_opacity;\n if (gl_FragColor.a <= 0.0) {\n discard;\n }\n}\n';
- * @const
- * @type {string}
- ol.render.webgl.circlereplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;varying vec2 b;varying float c;varying float d;uniform float m;uniform vec4 n;uniform vec4 o;uniform vec2 p;void main(void){vec2 windowCenter=vec2((a.x+1.0)/2.0*p.x*d,(a.y+1.0)/2.0*p.y*d);vec2 windowOffset=vec2((b.x+1.0)/2.0*p.x*d,(b.y+1.0)/2.0*p.y*d);float radius=length(windowCenter-windowOffset);float dist=length(windowCenter-gl_FragCoord.xy);if(dist>radius+c){if(o.a==0.0){gl_FragColor=n;}else{gl_FragColor=o;}gl_FragColor.a=gl_FragColor.a-(dist-(radius+c));}else if(n.a==0.0){gl_FragColor=o;if(dist<radius-c){gl_FragColor.a=gl_FragColor.a-(radius-c-dist);}} else{gl_FragColor=n;float strokeDist=radius-c;float antialias=2.0*d;if(dist>strokeDist){gl_FragColor=o;}else if(dist>=strokeDist-antialias){float step=smoothstep(strokeDist-antialias,strokeDist,dist);gl_FragColor=mix(n,o,step);}} gl_FragColor.a=gl_FragColor.a*m;if(gl_FragColor.a<=0.0){discard;}}';
- * @const
- * @type {string}
- ol.render.webgl.circlereplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.circlereplay.defaultshader.Fragment.DEBUG_SOURCE :
- ol.render.webgl.circlereplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
- ol.render.webgl.circlereplay.defaultshader.fragment = new ol.render.webgl.circlereplay.defaultshader.Fragment();
- * @constructor
- * @extends {ol.webgl.Vertex}
- * @struct
- ol.render.webgl.circlereplay.defaultshader.Vertex = function() {
- ol.webgl.Vertex.call(this, ol.render.webgl.circlereplay.defaultshader.Vertex.SOURCE);
- ol.inherits(ol.render.webgl.circlereplay.defaultshader.Vertex, ol.webgl.Vertex);
- * @const
- * @type {string}
- ol.render.webgl.circlereplay.defaultshader.Vertex.DEBUG_SOURCE = 'varying vec2 v_center;\nvarying vec2 v_offset;\nvarying float v_halfWidth;\nvarying float v_pixelRatio;\n\n\nattribute vec2 a_position;\nattribute float a_instruction;\nattribute float a_radius;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\nuniform float u_lineWidth;\nuniform float u_pixelRatio;\n\nvoid main(void) {\n mat4 offsetMatrix = u_offsetScaleMatrix * u_offsetRotateMatrix;\n v_center = vec4(u_projectionMatrix * vec4(a_position, 0.0, 1.0)).xy;\n v_pixelRatio = u_pixelRatio;\n float lineWidth = u_lineWidth * u_pixelRatio;\n v_halfWidth = lineWidth / 2.0;\n if (lineWidth == 0.0) {\n lineWidth = 2.0 * u_pixelRatio;\n }\n vec2 offset;\n // Radius with anitaliasing (roughly).\n float radius = a_radius + 3.0 * u_pixelRatio;\n // Until we get gl_VertexID in WebGL, we store an instruction.\n if (a_instruction == 0.0) {\n // Offsetting the
edges of the triangle by lineWidth / 2 is necessary, however\n // we should also leave some space for the antialiasing, thus we offset by lineWidth.\n offset = vec2(-1.0, 1.0);\n } else if (a_instruction == 1.0) {\n offset = vec2(-1.0, -1.0);\n } else if (a_instruction == 2.0) {\n offset = vec2(1.0, -1.0);\n } else {\n offset = vec2(1.0, 1.0);\n }\n\n gl_Position = u_projectionMatrix * vec4(a_position + offset * radius, 0.0, 1.0) +\n offsetMatrix * vec4(offset * lineWidth, 0.0, 0.0);\n v_offset = vec4(u_projectionMatrix * vec4(a_position.x + a_radius, a_position.y,\n 0.0, 1.0)).xy;\n\n if (distance(v_center, v_offset) > 20000.0) {\n gl_Position = vec4(v_center, 0.0, 1.0);\n }\n}\n\n\n';
- * @const
- * @type {string}
- ol.render.webgl.circlereplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;varying vec2 b;varying float c;varying float d;attribute vec2 e;attribute float f;attribute float g;uniform mat4 h;uniform mat4 i;uniform mat4 j;uniform float k;uniform float l;void main(void){mat4 offsetMatrix=i*j;a=vec4(h*vec4(e,0.0,1.0)).xy;d=l;float lineWidth=k*l;c=lineWidth/2.0;if(lineWidth==0.0){lineWidth=2.0*l;}vec2 offset;float radius=g+3.0*l;if(f==0.0){offset=vec2(-1.0,1.0);}else if(f==1.0){offset=vec2(-1.0,-1.0);}else if(f==2.0){offset=vec2(1.0,-1.0);}else{offset=vec2(1.0,1.0);}gl_Position=h*vec4(e+offset*radius,0.0,1.0)+offsetMatrix*vec4(offset*lineWidth,0.0,0.0);b=vec4(h*vec4(e.x+g,e.y,0.0,1.0)).xy;if(distance(a,b)>20000.0){gl_Position=vec4(a,0.0,1.0);}}';
- * @const
- * @type {string}
- ol.render.webgl.circlereplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.circlereplay.defaultshader.Vertex.DEBUG_SOURCE :
- ol.render.webgl.circlereplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
- ol.render.webgl.circlereplay.defaultshader.vertex = new ol.render.webgl.circlereplay.defaultshader.Vertex();
- * @constructor
- * @param {WebGLRenderingContext} gl GL.
- * @param {WebGLProgram} program Program.
- * @struct
- ol.render.webgl.circlereplay.defaultshader.Locations = function(gl, program) {
- * @type {WebGLUniformLocation}
- this.u_fillColor = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_fillColor' : 'n');
- this.u_lineWidth = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_lineWidth' : 'k');
- this.u_offsetRotateMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_offsetRotateMatrix' : 'j');
- this.u_offsetScaleMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_offsetScaleMatrix' : 'i');
- this.u_opacity = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_opacity' : 'm');
- this.u_pixelRatio = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_pixelRatio' : 'l');
- this.u_projectionMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_projectionMatrix' : 'h');
- this.u_size = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_size' : 'p');
- this.u_strokeColor = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_strokeColor' : 'o');
- * @type {number}
- this.a_instruction = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_instruction' : 'f');
- * @type {number}
- this.a_position = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_position' : 'e');
- * @type {number}
- this.a_radius = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_radius' : 'g');
-goog.provide('ol.vec.Mat4');
- * @return {Array.<number>} 4x4 matrix representing a 3D identity transform.
-ol.vec.Mat4.create = function() {
- return [1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1];
- * @param {Array.<number>} mat4 Flattened 4x4 matrix receiving the result.
- * @param {ol.Transform} transform Transformation matrix.
- * @return {Array.<number>} 2D transformation matrix as flattened 4x4 matrix.
-ol.vec.Mat4.fromTransform = function(mat4, transform) {
- mat4[0] = transform[0];
- mat4[1] = transform[1];
- mat4[4] = transform[2];
- mat4[5] = transform[3];
- mat4[12] = transform[4];
- mat4[13] = transform[5];
- return mat4;
-goog.provide('ol.render.webgl.Replay');
-goog.require('ol.extent');
-goog.require('ol.vec.Mat4');
- * @constructor
- * @abstract
- * @param {number} tolerance Tolerance.
- * @param {ol.Extent} maxExtent Max extent.
- * @struct
- ol.render.webgl.Replay = function(tolerance, maxExtent) {
- * @protected
- * @type {number}
- this.tolerance = tolerance;
- * @protected
- * @const
- this.maxExtent = maxExtent;
- * The origin of the coordinate system for the point coordinates sent to
- * the GPU. To eliminate jitter caused by precision problems in the GPU
- * we use the "Rendering Relative to Eye" technique described in the "3D
- * Engine Design for Virtual Globes" book.
- * @protected
- * @type {ol.Coordinate}
- this.origin = ol.extent.getCenter(maxExtent);
- * @private
- this.projectionMatrix_ = ol.transform.create();
- * @private
- this.offsetRotateMatrix_ = ol.transform.create();
- * @private
- this.offsetScaleMatrix_ = ol.transform.create();
- * @private
- this.tmpMat4_ = ol.vec.Mat4.create();
- * @protected
- this.indices = [];
- * @protected
- * @type {?ol.webgl.Buffer}
- this.indicesBuffer = null;
- * Start index per feature (the index).
- * @protected
- this.startIndices = [];
- * Start index per feature (the feature).
- * @protected
- * @type {Array.<ol.Feature|ol.render.Feature>}
- this.startIndicesFeature = [];
- * @protected
- this.vertices = [];
- * @protected
- this.verticesBuffer = null;
- * Optional parameter for PolygonReplay instances.
- * @protected
- * @type {ol.render.webgl.LineStringReplay|undefined}
- this.lineStringReplay = undefined;
- ol.inherits(ol.render.webgl.Replay, ol.render.VectorContext);
- * @abstract
- * @param {ol.webgl.Context} context WebGL context.
- * @return {function()} Delete resources function.
- ol.render.webgl.Replay.prototype.getDeleteResourcesFunction = function(context) {};
- * @abstract
- * @param {ol.webgl.Context} context Context.
- ol.render.webgl.Replay.prototype.finish = function(context) {};
- * @abstract
- * @protected
- * @param {WebGLRenderingContext} gl gl.
- * @param {ol.Size} size Size.
- * @return {ol.render.webgl.circlereplay.defaultshader.Locations|
- ol.render.webgl.imagereplay.defaultshader.Locations|
- ol.render.webgl.linestringreplay.defaultshader.Locations|
- ol.render.webgl.polygonreplay.defaultshader.Locations} Locations.
- ol.render.webgl.Replay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {};
- * @abstract
- * @protected
- * @param {ol.render.webgl.circlereplay.defaultshader.Locations|
- ol.render.webgl.polygonreplay.defaultshader.Locations} locations Locations.
- ol.render.webgl.Replay.prototype.shutDownProgram = function(gl, locations) {};
- * @abstract
- * @protected
- * @param {Object.<string, boolean>} skippedFeaturesHash Ids of features
- * to skip.
- * @param {boolean} hitDetection Hit detection mode.
- ol.render.webgl.Replay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {};
- * @abstract
- * @protected
- * to skip.
- * @param {function((ol.Feature|ol.render.Feature)): T|undefined} featureCallback Feature callback.
- * @param {ol.Extent=} opt_hitExtent Hit extent: Only features intersecting
- * this extent are checked.
- * @template T
- ol.render.webgl.Replay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash, featureCallback, opt_hitExtent) {};
- * @protected
- * to skip.
- * @param {boolean} oneByOne Draw features one-by-one for the hit-detecion.
- * @template T
- ol.render.webgl.Replay.prototype.drawHitDetectionReplay = function(gl, context, skippedFeaturesHash,
- featureCallback, oneByOne, opt_hitExtent) {
- if (!oneByOne) {
- // draw all hit-detection features in "once" (by texture group)
- return this.drawHitDetectionReplayAll(gl, context,
- skippedFeaturesHash, featureCallback);
- } else {
- // draw hit-detection features one by one
- return this.drawHitDetectionReplayOneByOne(gl, context,
- skippedFeaturesHash, featureCallback, opt_hitExtent);
- * @protected
- * to skip.
- * @template T
- ol.render.webgl.Replay.prototype.drawHitDetectionReplayAll = function(gl, context, skippedFeaturesHash,
- featureCallback) {
- gl.clear(gl.COLOR_BUFFER_BIT | gl.DEPTH_BUFFER_BIT);
- this.drawReplay(gl, context, skippedFeaturesHash, true);
- var result = featureCallback(null);
- if (result) {
- return result;
- } else {
- return undefined;
- * @param {ol.Coordinate} center Center.
- * @param {number} resolution Resolution.
- * @param {number} opacity Global opacity.
- * to skip.
- * @template T
- ol.render.webgl.Replay.prototype.replay = function(context,
- center, resolution, rotation, size, pixelRatio,
- opacity, skippedFeaturesHash,
- var gl = context.getGL();
- var tmpStencil, tmpStencilFunc, tmpStencilMaskVal, tmpStencilRef, tmpStencilMask,
- tmpStencilOpFail, tmpStencilOpPass, tmpStencilOpZFail;
- if (this.lineStringReplay) {
- tmpStencil = gl.isEnabled(gl.STENCIL_TEST);
- tmpStencilFunc = gl.getParameter(gl.STENCIL_FUNC);
- tmpStencilMaskVal = gl.getParameter(gl.STENCIL_VALUE_MASK);
- tmpStencilRef = gl.getParameter(gl.STENCIL_REF);
- tmpStencilMask = gl.getParameter(gl.STENCIL_WRITEMASK);
- tmpStencilOpFail = gl.getParameter(gl.STENCIL_FAIL);
- tmpStencilOpPass = gl.getParameter(gl.STENCIL_PASS_DEPTH_PASS);
- tmpStencilOpZFail = gl.getParameter(gl.STENCIL_PASS_DEPTH_FAIL);
- gl.enable(gl.STENCIL_TEST);
- gl.clear(gl.STENCIL_BUFFER_BIT);
- gl.stencilMask(255);
- gl.stencilFunc(gl.ALWAYS, 1, 255);
- gl.stencilOp(gl.KEEP, gl.KEEP, gl.REPLACE);
- this.lineStringReplay.replay(context,
- featureCallback, oneByOne, opt_hitExtent);
- gl.stencilMask(0);
- gl.stencilFunc(gl.NOTEQUAL, 1, 255);
- context.bindBuffer(ol.webgl.ARRAY_BUFFER, this.verticesBuffer);
- context.bindBuffer(ol.webgl.ELEMENT_ARRAY_BUFFER, this.indicesBuffer);
- var locations = this.setUpProgram(gl, context, size, pixelRatio);
- // set the "uniform" values
- var projectionMatrix = ol.transform.reset(this.projectionMatrix_);
- ol.transform.scale(projectionMatrix, 2 / (resolution * size[0]), 2 / (resolution * size[1]));
- ol.transform.rotate(projectionMatrix, -rotation);
- ol.transform.translate(projectionMatrix, -(center[0] - this.origin[0]), -(center[1] - this.origin[1]));
- var offsetScaleMatrix = ol.transform.reset(this.offsetScaleMatrix_);
- ol.transform.scale(offsetScaleMatrix, 2 / size[0], 2 / size[1]);
- var offsetRotateMatrix = ol.transform.reset(this.offsetRotateMatrix_);
- ol.transform.rotate(offsetRotateMatrix, -rotation);
- gl.uniformMatrix4fv(locations.u_projectionMatrix, false,
- ol.vec.Mat4.fromTransform(this.tmpMat4_, projectionMatrix));
- gl.uniformMatrix4fv(locations.u_offsetScaleMatrix, false,
- ol.vec.Mat4.fromTransform(this.tmpMat4_, offsetScaleMatrix));
- gl.uniformMatrix4fv(locations.u_offsetRotateMatrix, false,
- ol.vec.Mat4.fromTransform(this.tmpMat4_, offsetRotateMatrix));
- gl.uniform1f(locations.u_opacity, opacity);
- // draw!
- var result;
- if (featureCallback === undefined) {
- this.drawReplay(gl, context, skippedFeaturesHash, false);
- } else {
- // draw feature by feature for the hit-detection
- result = this.drawHitDetectionReplay(gl, context, skippedFeaturesHash,
- // disable the vertex attrib arrays
- this.shutDownProgram(gl, locations);
- if (!tmpStencil) {
- gl.disable(gl.STENCIL_TEST);
- gl.stencilFunc(/** @type {number} */ (tmpStencilFunc),
- /** @type {number} */ (tmpStencilRef), /** @type {number} */ (tmpStencilMaskVal));
- gl.stencilMask(/** @type {number} */ (tmpStencilMask));
- gl.stencilOp(/** @type {number} */ (tmpStencilOpFail),
- /** @type {number} */ (tmpStencilOpZFail), /** @type {number} */ (tmpStencilOpPass));
- return result;
- * @protected
- * @param {number} start Start index.
- * @param {number} end End index.
- ol.render.webgl.Replay.prototype.drawElements = function(
- gl, context, start, end) {
- var elementType = context.hasOESElementIndexUint ?
- ol.webgl.UNSIGNED_INT : ol.webgl.UNSIGNED_SHORT;
- var elementSize = context.hasOESElementIndexUint ? 4 : 2;
- var numItems = end - start;
- var offsetInBytes = start * elementSize;
- gl.drawElements(ol.webgl.TRIANGLES, numItems, elementType, offsetInBytes);
-goog.provide('ol.render.webgl');
- * @const
- ol.render.webgl.defaultFillStyle = [0.0, 0.0, 0.0, 1.0];
- * @const
- * @type {string}
- ol.render.webgl.defaultLineCap = 'round';
- * @const
- ol.render.webgl.defaultLineDash = [];
- * @const
- * @type {number}
- ol.render.webgl.defaultLineDashOffset = 0;
- * @const
- * @type {string}
- ol.render.webgl.defaultLineJoin = 'round';
- * @const
- * @type {number}
- ol.render.webgl.defaultMiterLimit = 10;
- * @const
- ol.render.webgl.defaultStrokeStyle = [0.0, 0.0, 0.0, 1.0];
- * @const
- * @type {number}
- ol.render.webgl.defaultLineWidth = 1;
- * Calculates the orientation of a triangle based on the determinant method.
- * @param {number} x1 First X coordinate.
- * @param {number} y1 First Y coordinate.
- * @param {number} x2 Second X coordinate.
- * @param {number} y2 Second Y coordinate.
- * @param {number} x3 Third X coordinate.
- * @param {number} y3 Third Y coordinate.
- * @return {boolean|undefined} Triangle is clockwise.
- ol.render.webgl.triangleIsCounterClockwise = function(x1, y1, x2, y2, x3, y3) {
- var area = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1);
- return (area <= ol.render.webgl.EPSILON && area >= -ol.render.webgl.EPSILON) ?
- undefined : area > 0;
- * @const
- * @type {number}
- ol.render.webgl.EPSILON = Number.EPSILON || 2.220446049250313e-16;
-goog.provide('ol.webgl.Buffer');
- * @constructor
- * @param {Array.<number>=} opt_arr Array.
- * @param {number=} opt_usage Usage.
- * @struct
- ol.webgl.Buffer = function(opt_arr, opt_usage) {
- * @private
- this.arr_ = opt_arr !== undefined ? opt_arr : [];
- * @private
- * @type {number}
- this.usage_ = opt_usage !== undefined ?
- opt_usage : ol.webgl.Buffer.Usage_.STATIC_DRAW;
- * @return {Array.<number>} Array.
- ol.webgl.Buffer.prototype.getArray = function() {
- return this.arr_;
- * @return {number} Usage.
- ol.webgl.Buffer.prototype.getUsage = function() {
- return this.usage_;
- * @enum {number}
- * @private
- ol.webgl.Buffer.Usage_ = {
- STATIC_DRAW: ol.webgl.STATIC_DRAW,
- STREAM_DRAW: ol.webgl.STREAM_DRAW,
- DYNAMIC_DRAW: ol.webgl.DYNAMIC_DRAW
-goog.provide('ol.render.webgl.CircleReplay');
-goog.require('ol');
-goog.require('ol.color');
-goog.require('ol.obj');
-goog.require('ol.render.webgl.circlereplay.defaultshader');
-goog.require('ol.render.webgl.Replay');
-goog.require('ol.render.webgl');
-goog.require('ol.webgl.Buffer');
- * @constructor
- * @extends {ol.render.webgl.Replay}
- * @struct
- ol.render.webgl.CircleReplay = function(tolerance, maxExtent) {
- ol.render.webgl.Replay.call(this, tolerance, maxExtent);
- * @private
- * @type {ol.render.webgl.circlereplay.defaultshader.Locations}
- this.defaultLocations_ = null;
- * @private
- * @type {Array.<Array.<Array.<number>|number>>}
- this.styles_ = [];
- * @private
- this.styleIndices_ = [];
- * @private
- * @type {number}
- this.radius_ = 0;
- * @private
- * @type {{fillColor: (Array.<number>|null),
- * strokeColor: (Array.<number>|null),
- * lineDash: Array.<number>,
- * lineDashOffset: (number|undefined),
- * lineWidth: (number|undefined),
- * changed: boolean}|null}
- this.state_ = {
- fillColor: null,
- strokeColor: null,
- lineDash: null,
- lineDashOffset: undefined,
- lineWidth: undefined,
- changed: false
- ol.inherits(ol.render.webgl.CircleReplay, ol.render.webgl.Replay);
- * @private
- ol.render.webgl.CircleReplay.prototype.drawCoordinates_ = function(
- flatCoordinates, offset, end, stride) {
- var numVertices = this.vertices.length;
- var numIndices = this.indices.length;
- var n = numVertices / 4;
- var i, ii;
- for (i = offset, ii = end; i < ii; i += stride) {
- this.vertices[numVertices++] = flatCoordinates[i];
- this.vertices[numVertices++] = flatCoordinates[i + 1];
- this.vertices[numVertices++] = 0;
- this.vertices[numVertices++] = this.radius_;
- this.vertices[numVertices++] = 1;
- this.vertices[numVertices++] = 2;
- this.vertices[numVertices++] = 3;
- this.indices[numIndices++] = n;
- this.indices[numIndices++] = n + 1;
- this.indices[numIndices++] = n + 2;
- this.indices[numIndices++] = n + 3;
- n += 4;
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.drawCircle = function(circleGeometry, feature) {
- var radius = circleGeometry.getRadius();
- var stride = circleGeometry.getStride();
- if (radius) {
- this.startIndices.push(this.indices.length);
- this.startIndicesFeature.push(feature);
- if (this.state_.changed) {
- this.styleIndices_.push(this.indices.length);
- this.state_.changed = false;
- this.radius_ = radius;
- var flatCoordinates = circleGeometry.getFlatCoordinates();
- flatCoordinates = ol.geom.flat.transform.translate(flatCoordinates, 0, 2,
- stride, -this.origin[0], -this.origin[1]);
- this.drawCoordinates_(flatCoordinates, 0, 2, stride);
- } else {
- this.styles_.pop();
- if (this.styles_.length) {
- var lastState = this.styles_[this.styles_.length - 1];
- this.state_.fillColor = /** @type {Array.<number>} */ (lastState[0]);
- this.state_.strokeColor = /** @type {Array.<number>} */ (lastState[1]);
- this.state_.lineWidth = /** @type {number} */ (lastState[2]);
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.finish = function(context) {
- // create, bind, and populate the vertices buffer
- this.verticesBuffer = new ol.webgl.Buffer(this.vertices);
- // create, bind, and populate the indices buffer
- this.indicesBuffer = new ol.webgl.Buffer(this.indices);
- //Clean up, if there is nothing to draw
- if (this.styleIndices_.length === 0 && this.styles_.length > 0) {
- this.vertices = null;
- this.indices = null;
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.getDeleteResourcesFunction = function(context) {
- // We only delete our stuff here. The shaders and the program may
- // be used by other CircleReplay instances (for other layers). And
- // they will be deleted when disposing of the ol.webgl.Context
- // object.
- var verticesBuffer = this.verticesBuffer;
- var indicesBuffer = this.indicesBuffer;
- return function() {
- context.deleteBuffer(verticesBuffer);
- context.deleteBuffer(indicesBuffer);
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
- // get the program
- var fragmentShader, vertexShader;
- fragmentShader = ol.render.webgl.circlereplay.defaultshader.fragment;
- vertexShader = ol.render.webgl.circlereplay.defaultshader.vertex;
- var program = context.getProgram(fragmentShader, vertexShader);
- // get the locations
- var locations;
- if (!this.defaultLocations_) {
- locations =
- new ol.render.webgl.circlereplay.defaultshader.Locations(gl, program);
- this.defaultLocations_ = locations;
- } else {
- locations = this.defaultLocations_;
- context.useProgram(program);
- // enable the vertex attrib arrays
- gl.enableVertexAttribArray(locations.a_position);
- gl.vertexAttribPointer(locations.a_position, 2, ol.webgl.FLOAT,
- false, 16, 0);
- gl.enableVertexAttribArray(locations.a_instruction);
- gl.vertexAttribPointer(locations.a_instruction, 1, ol.webgl.FLOAT,
- false, 16, 8);
- gl.enableVertexAttribArray(locations.a_radius);
- gl.vertexAttribPointer(locations.a_radius, 1, ol.webgl.FLOAT,
- false, 16, 12);
- // Enable renderer specific uniforms.
- gl.uniform2fv(locations.u_size, size);
- gl.uniform1f(locations.u_pixelRatio, pixelRatio);
- return locations;
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.shutDownProgram = function(gl, locations) {
- gl.disableVertexAttribArray(locations.a_position);
- gl.disableVertexAttribArray(locations.a_instruction);
- gl.disableVertexAttribArray(locations.a_radius);
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
- if (!ol.obj.isEmpty(skippedFeaturesHash)) {
- this.drawReplaySkipping_(gl, context, skippedFeaturesHash);
- } else {
- //Draw by style groups to minimize drawElements() calls.
- var i, start, end, nextStyle;
- end = this.startIndices[this.startIndices.length - 1];
- for (i = this.styleIndices_.length - 1; i >= 0; --i) {
- start = this.styleIndices_[i];
- nextStyle = this.styles_[i];
- this.setFillStyle_(gl, /** @type {Array.<number>} */ (nextStyle[0]));
- this.setStrokeStyle_(gl, /** @type {Array.<number>} */ (nextStyle[1]),
- /** @type {number} */ (nextStyle[2]));
- this.drawElements(gl, context, start, end);
- end = start;
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
- featureCallback, opt_hitExtent) {
- var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex;
- featureIndex = this.startIndices.length - 2;
- end = this.startIndices[featureIndex + 1];
- groupStart = this.styleIndices_[i];
- while (featureIndex >= 0 &&
- this.startIndices[featureIndex] >= groupStart) {
- start = this.startIndices[featureIndex];
- feature = this.startIndicesFeature[featureIndex];
- featureUid = ol.getUid(feature).toString();
- if (skippedFeaturesHash[featureUid] === undefined &&
- feature.getGeometry() &&
- (opt_hitExtent === undefined || ol.extent.intersects(
- /** @type {Array<number>} */ (opt_hitExtent),
- feature.getGeometry().getExtent()))) {
- var result = featureCallback(feature);
- if (result) {
- return result;
- featureIndex--;
- end = start;
- return undefined;
- * @private
- * @param {Object} skippedFeaturesHash Ids of features to skip.
- ol.render.webgl.CircleReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash) {
- var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex, featureStart;
- end = start = this.startIndices[featureIndex + 1];
- featureStart = this.startIndices[featureIndex];
- if (skippedFeaturesHash[featureUid]) {
- if (start !== end) {
- end = featureStart;
- featureIndex--;
- start = featureStart;
- start = end = groupStart;
- * @private
- * @param {Array.<number>} color Color.
- ol.render.webgl.CircleReplay.prototype.setFillStyle_ = function(gl, color) {
- gl.uniform4fv(this.defaultLocations_.u_fillColor, color);
- * @private
- * @param {number} lineWidth Line width.
- ol.render.webgl.CircleReplay.prototype.setStrokeStyle_ = function(gl, color, lineWidth) {
- gl.uniform4fv(this.defaultLocations_.u_strokeColor, color);
- gl.uniform1f(this.defaultLocations_.u_lineWidth, lineWidth);
- * @inheritDoc
- ol.render.webgl.CircleReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- var strokeStyleColor, strokeStyleWidth;
- if (strokeStyle) {
- this.state_.lineDash = strokeStyleLineDash ?
- strokeStyleLineDash : ol.render.webgl.defaultLineDash;
- this.state_.lineDashOffset = strokeStyleLineDashOffset ?
- strokeStyleLineDashOffset : ol.render.webgl.defaultLineDashOffset;
- strokeStyleColor = strokeStyle.getColor();
- if (!(strokeStyleColor instanceof CanvasGradient) &&
- !(strokeStyleColor instanceof CanvasPattern)) {
- strokeStyleColor = ol.color.asArray(strokeStyleColor).map(function(c, i) {
- return i != 3 ? c / 255 : c;
- }) || ol.render.webgl.defaultStrokeStyle;
- } else {
- strokeStyleColor = ol.render.webgl.defaultStrokeStyle;
- strokeStyleWidth = strokeStyle.getWidth();
- strokeStyleWidth = strokeStyleWidth !== undefined ?
- strokeStyleWidth : ol.render.webgl.defaultLineWidth;
- } else {
- strokeStyleColor = [0, 0, 0, 0];
- strokeStyleWidth = 0;
- var fillStyleColor = fillStyle ? fillStyle.getColor() : [0, 0, 0, 0];
- if (!(fillStyleColor instanceof CanvasGradient) &&
- !(fillStyleColor instanceof CanvasPattern)) {
- fillStyleColor = ol.color.asArray(fillStyleColor).map(function(c, i) {
- }) || ol.render.webgl.defaultFillStyle;
- } else {
- fillStyleColor = ol.render.webgl.defaultFillStyle;
- if (!this.state_.strokeColor || !ol.array.equals(this.state_.strokeColor, strokeStyleColor) ||
- !this.state_.fillColor || !ol.array.equals(this.state_.fillColor, fillStyleColor) ||
- this.state_.lineWidth !== strokeStyleWidth) {
- this.state_.changed = true;
- this.state_.fillColor = fillStyleColor;
- this.state_.strokeColor = strokeStyleColor;
- this.state_.lineWidth = strokeStyleWidth;
- this.styles_.push([fillStyleColor, strokeStyleColor, strokeStyleWidth]);
-goog.provide('ol.render.webgl.imagereplay.defaultshader');
- * @constructor
- * @struct
- ol.render.webgl.imagereplay.defaultshader.Fragment = function() {
- ol.webgl.Fragment.call(this, ol.render.webgl.imagereplay.defaultshader.Fragment.SOURCE);
- ol.inherits(ol.render.webgl.imagereplay.defaultshader.Fragment, ol.webgl.Fragment);
- * @const
- * @type {string}
- ol.render.webgl.imagereplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_texCoord;\nvarying float v_opacity;\n\nuniform float u_opacity;\nuniform sampler2D u_image;\n\nvoid main(void) {\n vec4 texColor = texture2D(u_image, v_texCoord);\n gl_FragColor.rgb = texColor.rgb;\n float alpha = texColor.a * v_opacity * u_opacity;\n if (alpha == 0.0) {\n discard;\n }\n gl_FragColor.a = alpha;\n}\n';
- * @const
- * @type {string}
- ol.render.webgl.imagereplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;varying float b;uniform float k;uniform sampler2D l;void main(void){vec4 texColor=texture2D(l,a);gl_FragColor.rgb=texColor.rgb;float alpha=texColor.a*b*k;if(alpha==0.0){discard;}gl_FragColor.a=alpha;}';
- * @const
- * @type {string}
- ol.render.webgl.imagereplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.imagereplay.defaultshader.Fragment.DEBUG_SOURCE :
- ol.render.webgl.imagereplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
- ol.render.webgl.imagereplay.defaultshader.fragment = new ol.render.webgl.imagereplay.defaultshader.Fragment();
- * @constructor
- * @struct
- ol.render.webgl.imagereplay.defaultshader.Vertex = function() {
- ol.webgl.Vertex.call(this, ol.render.webgl.imagereplay.defaultshader.Vertex.SOURCE);
- ol.inherits(ol.render.webgl.imagereplay.defaultshader.Vertex, ol.webgl.Vertex);
- * @const
- * @type {string}
- ol.render.webgl.imagereplay.defaultshader.Vertex.DEBUG_SOURCE = 'varying vec2 v_texCoord;\nvarying float v_opacity;\n\nattribute vec2 a_position;\nattribute vec2 a_texCoord;\nattribute vec2 a_offsets;\nattribute float a_opacity;\nattribute float a_rotateWithView;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\n\nvoid main(void) {\n mat4 offsetMatrix = u_offsetScaleMatrix;\n if (a_rotateWithView == 1.0) {\n offsetMatrix = u_offsetScaleMatrix * u_offsetRotateMatrix;\n }\n vec4 offsets = offsetMatrix * vec4(a_offsets, 0.0, 0.0);\n gl_Position = u_projectionMatrix * vec4(a_position, 0.0, 1.0) + offsets;\n v_texCoord = a_texCoord;\n v_opacity = a_opacity;\n}\n\n\n';
- * @const
- * @type {string}
- ol.render.webgl.imagereplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;varying float b;attribute vec2 c;attribute vec2 d;attribute vec2 e;attribute float f;attribute float g;uniform mat4 h;uniform mat4 i;uniform mat4 j;void main(void){mat4 offsetMatrix=i;if(g==1.0){offsetMatrix=i*j;}vec4 offsets=offsetMatrix*vec4(e,0.0,0.0);gl_Position=h*vec4(c,0.0,1.0)+offsets;a=d;b=f;}';
- * @const
- * @type {string}
- ol.render.webgl.imagereplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.imagereplay.defaultshader.Vertex.DEBUG_SOURCE :
- ol.render.webgl.imagereplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
- ol.render.webgl.imagereplay.defaultshader.vertex = new ol.render.webgl.imagereplay.defaultshader.Vertex();
- * @constructor
- * @struct
- ol.render.webgl.imagereplay.defaultshader.Locations = function(gl, program) {
- this.u_image = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_image' : 'l');
- program, ol.DEBUG_WEBGL ? 'u_opacity' : 'k');
- * @type {number}
- this.a_offsets = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_offsets' : 'e');
- * @type {number}
- this.a_opacity = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_opacity' : 'f');
- * @type {number}
- program, ol.DEBUG_WEBGL ? 'a_position' : 'c');
- * @type {number}
- this.a_rotateWithView = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_rotateWithView' : 'g');
- * @type {number}
- this.a_texCoord = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_texCoord' : 'd');
-goog.provide('ol.webgl.ContextEventType');
- * @enum {string}
-ol.webgl.ContextEventType = {
- LOST: 'webglcontextlost',
- RESTORED: 'webglcontextrestored'
-goog.provide('ol.webgl.Context');
-goog.require('ol.Disposable');
-goog.require('ol.array');
-goog.require('ol.events');
-goog.require('ol.webgl.ContextEventType');
- * @classdesc
- * A WebGL context for accessing low-level WebGL capabilities.
- * @constructor
- * @extends {ol.Disposable}
- * @param {HTMLCanvasElement} canvas Canvas.
- ol.webgl.Context = function(canvas, gl) {
- * @private
- this.canvas_ = canvas;
- * @private
- * @type {WebGLRenderingContext}
- this.gl_ = gl;
- * @private
- * @type {Object.<string, ol.WebglBufferCacheEntry>}
- this.bufferCache_ = {};
- * @private
- * @type {Object.<string, WebGLShader>}
- this.shaderCache_ = {};
- * @private
- * @type {Object.<string, WebGLProgram>}
- this.programCache_ = {};
- * @private
- * @type {WebGLProgram}
- this.currentProgram_ = null;
- * @private
- * @type {WebGLFramebuffer}
- this.hitDetectionFramebuffer_ = null;
- * @private
- * @type {WebGLTexture}
- this.hitDetectionTexture_ = null;
- * @private
- * @type {WebGLRenderbuffer}
- this.hitDetectionRenderbuffer_ = null;
- * @type {boolean}
- this.hasOESElementIndexUint = ol.array.includes(
- ol.WEBGL_EXTENSIONS, 'OES_element_index_uint');
- // use the OES_element_index_uint extension if available
- if (this.hasOESElementIndexUint) {
- gl.getExtension('OES_element_index_uint');
- ol.events.listen(this.canvas_, ol.webgl.ContextEventType.LOST,
- this.handleWebGLContextLost, this);
- ol.events.listen(this.canvas_, ol.webgl.ContextEventType.RESTORED,
- this.handleWebGLContextRestored, this);
- ol.inherits(ol.webgl.Context, ol.Disposable);
- * Just bind the buffer if it's in the cache. Otherwise create
- * the WebGL buffer, bind it, populate it, and add an entry to
- * the cache.
- * @param {number} target Target.
- * @param {ol.webgl.Buffer} buf Buffer.
- ol.webgl.Context.prototype.bindBuffer = function(target, buf) {
- var gl = this.getGL();
- var arr = buf.getArray();
- var bufferKey = String(ol.getUid(buf));
- if (bufferKey in this.bufferCache_) {
- var bufferCacheEntry = this.bufferCache_[bufferKey];
- gl.bindBuffer(target, bufferCacheEntry.buffer);
- } else {
- var buffer = gl.createBuffer();
- gl.bindBuffer(target, buffer);
- var /** @type {ArrayBufferView} */ arrayBuffer;
- if (target == ol.webgl.ARRAY_BUFFER) {
- arrayBuffer = new Float32Array(arr);
- } else if (target == ol.webgl.ELEMENT_ARRAY_BUFFER) {
- arrayBuffer = this.hasOESElementIndexUint ?
- new Uint32Array(arr) : new Uint16Array(arr);
- gl.bufferData(target, arrayBuffer, buf.getUsage());
- this.bufferCache_[bufferKey] = {
- buf: buf,
- buffer: buffer
- ol.webgl.Context.prototype.deleteBuffer = function(buf) {
- if (!gl.isContextLost()) {
- gl.deleteBuffer(bufferCacheEntry.buffer);
- delete this.bufferCache_[bufferKey];
- * @inheritDoc
- ol.webgl.Context.prototype.disposeInternal = function() {
- ol.events.unlistenAll(this.canvas_);
- var key;
- for (key in this.bufferCache_) {
- gl.deleteBuffer(this.bufferCache_[key].buffer);
- for (key in this.programCache_) {
- gl.deleteProgram(this.programCache_[key]);
- for (key in this.shaderCache_) {
- gl.deleteShader(this.shaderCache_[key]);
- // delete objects for hit-detection
- gl.deleteFramebuffer(this.hitDetectionFramebuffer_);
- gl.deleteRenderbuffer(this.hitDetectionRenderbuffer_);
- gl.deleteTexture(this.hitDetectionTexture_);
- * @return {HTMLCanvasElement} Canvas.
- ol.webgl.Context.prototype.getCanvas = function() {
- return this.canvas_;
- * Get the WebGL rendering context
- * @return {WebGLRenderingContext} The rendering context.
- * @api
- ol.webgl.Context.prototype.getGL = function() {
- return this.gl_;
- * Get the frame buffer for hit detection.
- * @return {WebGLFramebuffer} The hit detection frame buffer.
- ol.webgl.Context.prototype.getHitDetectionFramebuffer = function() {
- if (!this.hitDetectionFramebuffer_) {
- this.initHitDetectionFramebuffer_();
- return this.hitDetectionFramebuffer_;
- * Get shader from the cache if it's in the cache. Otherwise, create
- * the WebGL shader, compile it, and add entry to cache.
- * @param {ol.webgl.Shader} shaderObject Shader object.
- * @return {WebGLShader} Shader.
- ol.webgl.Context.prototype.getShader = function(shaderObject) {
- var shaderKey = String(ol.getUid(shaderObject));
- if (shaderKey in this.shaderCache_) {
- return this.shaderCache_[shaderKey];
- } else {
- var shader = gl.createShader(shaderObject.getType());
- gl.shaderSource(shader, shaderObject.getSource());
- gl.compileShader(shader);
- this.shaderCache_[shaderKey] = shader;
- return shader;
- * Get the program from the cache if it's in the cache. Otherwise create
- * the WebGL program, attach the shaders to it, and add an entry to the
- * cache.
- * @param {ol.webgl.Fragment} fragmentShaderObject Fragment shader.
- * @param {ol.webgl.Vertex} vertexShaderObject Vertex shader.
- * @return {WebGLProgram} Program.
- ol.webgl.Context.prototype.getProgram = function(
- fragmentShaderObject, vertexShaderObject) {
- var programKey =
- ol.getUid(fragmentShaderObject) + '/' + ol.getUid(vertexShaderObject);
- if (programKey in this.programCache_) {
- return this.programCache_[programKey];
- } else {
- var program = gl.createProgram();
- gl.attachShader(program, this.getShader(fragmentShaderObject));
- gl.attachShader(program, this.getShader(vertexShaderObject));
- gl.linkProgram(program);
- this.programCache_[programKey] = program;
- return program;
- * FIXME empy description for jsdoc
- ol.webgl.Context.prototype.handleWebGLContextLost = function() {
- ol.obj.clear(this.bufferCache_);
- ol.obj.clear(this.shaderCache_);
- ol.obj.clear(this.programCache_);
- ol.webgl.Context.prototype.handleWebGLContextRestored = function() {
- * Creates a 1x1 pixel framebuffer for the hit-detection.
- * @private
- ol.webgl.Context.prototype.initHitDetectionFramebuffer_ = function() {
- var gl = this.gl_;
- var framebuffer = gl.createFramebuffer();
- gl.bindFramebuffer(gl.FRAMEBUFFER, framebuffer);
- var texture = ol.webgl.Context.createEmptyTexture(gl, 1, 1);
- var renderbuffer = gl.createRenderbuffer();
- gl.bindRenderbuffer(gl.RENDERBUFFER, renderbuffer);
- gl.renderbufferStorage(gl.RENDERBUFFER, gl.DEPTH_COMPONENT16, 1, 1);
- gl.framebufferTexture2D(
- gl.FRAMEBUFFER, gl.COLOR_ATTACHMENT0, gl.TEXTURE_2D, texture, 0);
- gl.framebufferRenderbuffer(gl.FRAMEBUFFER, gl.DEPTH_ATTACHMENT,
- gl.RENDERBUFFER, renderbuffer);
- gl.bindTexture(gl.TEXTURE_2D, null);
- gl.bindRenderbuffer(gl.RENDERBUFFER, null);
- gl.bindFramebuffer(gl.FRAMEBUFFER, null);
- this.hitDetectionFramebuffer_ = framebuffer;
- this.hitDetectionTexture_ = texture;
- this.hitDetectionRenderbuffer_ = renderbuffer;
- * Use a program. If the program is already in use, this will return `false`.
- * @return {boolean} Changed.
- * @api
- ol.webgl.Context.prototype.useProgram = function(program) {
- if (program == this.currentProgram_) {
- return false;
- } else {
- gl.useProgram(program);
- this.currentProgram_ = program;
- return true;
- * @param {WebGLRenderingContext} gl WebGL rendering context.
- * @param {number=} opt_wrapS wrapS.
- * @param {number=} opt_wrapT wrapT.
- * @return {WebGLTexture} The texture.
- * @private
- ol.webgl.Context.createTexture_ = function(gl, opt_wrapS, opt_wrapT) {
- var texture = gl.createTexture();
- gl.bindTexture(gl.TEXTURE_2D, texture);
- gl.texParameteri(gl.TEXTURE_2D, gl.TEXTURE_MAG_FILTER, gl.LINEAR);
- gl.texParameteri(gl.TEXTURE_2D, gl.TEXTURE_MIN_FILTER, gl.LINEAR);
- if (opt_wrapS !== undefined) {
- gl.texParameteri(
- ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_S, opt_wrapS);
- if (opt_wrapT !== undefined) {
- gl.texParameteri(
- ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_T, opt_wrapT);
- return texture;
- * @param {number} width Width.
- * @param {number} height Height.
- ol.webgl.Context.createEmptyTexture = function(
- gl, width, height, opt_wrapS, opt_wrapT) {
- var texture = ol.webgl.Context.createTexture_(gl, opt_wrapS, opt_wrapT);
- gl.texImage2D(
- gl.TEXTURE_2D, 0, gl.RGBA, width, height, 0, gl.RGBA, gl.UNSIGNED_BYTE,
- null);
- return texture;
- * @param {HTMLCanvasElement|HTMLImageElement|HTMLVideoElement} image Image.
- ol.webgl.Context.createTexture = function(gl, image, opt_wrapS, opt_wrapT) {
- gl.texImage2D(
- gl.TEXTURE_2D, 0, gl.RGBA, gl.RGBA, gl.UNSIGNED_BYTE, image);
- return texture;
-goog.provide('ol.render.webgl.ImageReplay');
-goog.require('ol.render.webgl.imagereplay.defaultshader');
-goog.require('ol.webgl.Context');
- * @constructor
- * @struct
- ol.render.webgl.ImageReplay = function(tolerance, maxExtent) {
- * @type {number|undefined}
- * @private
- this.anchorX_ = undefined;
- * @private
- this.anchorY_ = undefined;
- * @type {Array.<number>}
- * @private
- this.groupIndices_ = [];
- * @private
- this.hitDetectionGroupIndices_ = [];
- * @private
- this.height_ = undefined;
- * @type {Array.<HTMLCanvasElement|HTMLImageElement|HTMLVideoElement>}
- * @private
- this.images_ = [];
- * @private
- this.hitDetectionImages_ = [];
- * @private
- this.imageHeight_ = undefined;
- * @private
- this.imageWidth_ = undefined;
- * @private
- * @type {ol.render.webgl.imagereplay.defaultshader.Locations}
- * @private
- this.opacity_ = undefined;
- * @private
- this.originX_ = undefined;
- * @private
- this.originY_ = undefined;
- * @private
- * @type {boolean|undefined}
- this.rotateWithView_ = undefined;
- * @private
- this.rotation_ = undefined;
- * @private
- this.scale_ = undefined;
- * @type {Array.<WebGLTexture>}
- * @private
- this.textures_ = [];
- * @private
- this.hitDetectionTextures_ = [];
- * @private
- this.width_ = undefined;
- ol.inherits(ol.render.webgl.ImageReplay, ol.render.webgl.Replay);
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.getDeleteResourcesFunction = function(context) {
- var textures = this.textures_;
- var hitDetectionTextures = this.hitDetectionTextures_;
- var i, ii;
- for (i = 0, ii = textures.length; i < ii; ++i) {
- gl.deleteTexture(textures[i]);
- for (i = 0, ii = hitDetectionTextures.length; i < ii; ++i) {
- gl.deleteTexture(hitDetectionTextures[i]);
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
- * @return {number} My end.
- * @private
- ol.render.webgl.ImageReplay.prototype.drawCoordinates_ = function(flatCoordinates, offset, end, stride) {
- var anchorX = /** @type {number} */ (this.anchorX_);
- var anchorY = /** @type {number} */ (this.anchorY_);
- var height = /** @type {number} */ (this.height_);
- var imageHeight = /** @type {number} */ (this.imageHeight_);
- var imageWidth = /** @type {number} */ (this.imageWidth_);
- var opacity = /** @type {number} */ (this.opacity_);
- var originX = /** @type {number} */ (this.originX_);
- var originY = /** @type {number} */ (this.originY_);
- var rotateWithView = this.rotateWithView_ ? 1.0 : 0.0;
- // this.rotation_ is anti-clockwise, but rotation is clockwise
- var rotation = /** @type {number} */ (-this.rotation_);
- var scale = /** @type {number} */ (this.scale_);
- var width = /** @type {number} */ (this.width_);
- var cos = Math.cos(rotation);
- var sin = Math.sin(rotation);
- var i, n, offsetX, offsetY, x, y;
- for (i = offset; i < end; i += stride) {
- x = flatCoordinates[i] - this.origin[0];
- y = flatCoordinates[i + 1] - this.origin[1];
- // There are 4 vertices per [x, y] point, one for each corner of the
- // rectangle we're going to draw. We'd use 1 vertex per [x, y] point if
- // WebGL supported Geometry Shaders (which can emit new vertices), but that
- // is not currently the case.
- // And each vertex includes 8 values: the x and y coordinates, the x and
- // y offsets used to calculate the position of the corner, the u and
- // v texture coordinates for the corner, the opacity, and whether the
- // the image should be rotated with the view (rotateWithView).
- n = numVertices / 8;
- // bottom-left corner
- offsetX = -scale * anchorX;
- offsetY = -scale * (height - anchorY);
- this.vertices[numVertices++] = x;
- this.vertices[numVertices++] = y;
- this.vertices[numVertices++] = offsetX * cos - offsetY * sin;
- this.vertices[numVertices++] = offsetX * sin + offsetY * cos;
- this.vertices[numVertices++] = originX / imageWidth;
- this.vertices[numVertices++] = (originY + height) / imageHeight;
- this.vertices[numVertices++] = opacity;
- this.vertices[numVertices++] = rotateWithView;
- // bottom-right corner
- offsetX = scale * (width - anchorX);
- this.vertices[numVertices++] = (originX + width) / imageWidth;
- // top-right corner
- offsetY = scale * anchorY;
- this.vertices[numVertices++] = originY / imageHeight;
- // top-left corner
- return numVertices;
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.drawMultiPoint = function(multiPointGeometry, feature) {
- var flatCoordinates = multiPointGeometry.getFlatCoordinates();
- var stride = multiPointGeometry.getStride();
- flatCoordinates, 0, flatCoordinates.length, stride);
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.drawPoint = function(pointGeometry, feature) {
- var flatCoordinates = pointGeometry.getFlatCoordinates();
- var stride = pointGeometry.getStride();
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.finish = function(context) {
- this.groupIndices_.push(this.indices.length);
- this.hitDetectionGroupIndices_.push(this.indices.length);
- var indices = this.indices;
- this.indicesBuffer = new ol.webgl.Buffer(indices);
- // create textures
- /** @type {Object.<string, WebGLTexture>} */
- var texturePerImage = {};
- this.createTextures_(this.textures_, this.images_, texturePerImage, gl);
- this.createTextures_(this.hitDetectionTextures_, this.hitDetectionImages_,
- texturePerImage, gl);
- this.images_ = null;
- this.hitDetectionImages_ = null;
- * @private
- * @param {Array.<WebGLTexture>} textures Textures.
- * @param {Array.<HTMLCanvasElement|HTMLImageElement|HTMLVideoElement>} images
- * Images.
- * @param {Object.<string, WebGLTexture>} texturePerImage Texture cache.
- * @param {WebGLRenderingContext} gl Gl.
- ol.render.webgl.ImageReplay.prototype.createTextures_ = function(textures, images, texturePerImage, gl) {
- var texture, image, uid, i;
- var ii = images.length;
- for (i = 0; i < ii; ++i) {
- image = images[i];
- uid = ol.getUid(image).toString();
- if (uid in texturePerImage) {
- texture = texturePerImage[uid];
- } else {
- texture = ol.webgl.Context.createTexture(
- gl, image, ol.webgl.CLAMP_TO_EDGE, ol.webgl.CLAMP_TO_EDGE);
- texturePerImage[uid] = texture;
- textures[i] = texture;
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
- var fragmentShader = ol.render.webgl.imagereplay.defaultshader.fragment;
- var vertexShader = ol.render.webgl.imagereplay.defaultshader.vertex;
- var locations;
- locations =
- new ol.render.webgl.imagereplay.defaultshader.Locations(gl, program);
- } else {
- // use the program (FIXME: use the return value)
- false, 32, 0);
- gl.enableVertexAttribArray(locations.a_offsets);
- gl.vertexAttribPointer(locations.a_offsets, 2, ol.webgl.FLOAT,
- false, 32, 8);
- gl.enableVertexAttribArray(locations.a_texCoord);
- gl.vertexAttribPointer(locations.a_texCoord, 2, ol.webgl.FLOAT,
- false, 32, 16);
- gl.enableVertexAttribArray(locations.a_opacity);
- gl.vertexAttribPointer(locations.a_opacity, 1, ol.webgl.FLOAT,
- false, 32, 24);
- gl.enableVertexAttribArray(locations.a_rotateWithView);
- gl.vertexAttribPointer(locations.a_rotateWithView, 1, ol.webgl.FLOAT,
- false, 32, 28);
- return locations;
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.shutDownProgram = function(gl, locations) {
- gl.disableVertexAttribArray(locations.a_offsets);
- gl.disableVertexAttribArray(locations.a_texCoord);
- gl.disableVertexAttribArray(locations.a_opacity);
- gl.disableVertexAttribArray(locations.a_rotateWithView);
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
- var textures = hitDetection ? this.hitDetectionTextures_ : this.textures_;
- var groupIndices = hitDetection ? this.hitDetectionGroupIndices_ : this.groupIndices_;
- gl, context, skippedFeaturesHash, textures, groupIndices);
- } else {
- var i, ii, start;
- for (i = 0, ii = textures.length, start = 0; i < ii; ++i) {
- gl.bindTexture(ol.webgl.TEXTURE_2D, textures[i]);
- var end = groupIndices[i];
- start = end;
- * Draw the replay while paying attention to skipped features.
- * This functions creates groups of features that can be drawn to together,
- * so that the number of `drawElements` calls is minimized.
- * For example given the following texture groups:
- * Group 1: A B C
- * Group 2: D [E] F G
- * If feature E should be skipped, the following `drawElements` calls will be
- * made:
- * drawElements with feature A, B and C
- * drawElements with feature D
- * drawElements with feature F and G
- * @private
- * to skip.
- * @param {Array.<number>} groupIndices Texture group indices.
- ol.render.webgl.ImageReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash, textures,
- groupIndices) {
- var featureIndex = 0;
- var i, ii;
- var groupStart = (i > 0) ? groupIndices[i - 1] : 0;
- var groupEnd = groupIndices[i];
- var start = groupStart;
- var end = groupStart;
- while (featureIndex < this.startIndices.length &&
- this.startIndices[featureIndex] <= groupEnd) {
- var feature = this.startIndicesFeature[featureIndex];
- var featureUid = ol.getUid(feature).toString();
- if (skippedFeaturesHash[featureUid] !== undefined) {
- // feature should be skipped
- // draw the features so far
- // continue with the next feature
- start = (featureIndex === this.startIndices.length - 1) ?
- groupEnd : this.startIndices[featureIndex + 1];
- end = start;
- } else {
- // the feature is not skipped, augment the end index
- end = (featureIndex === this.startIndices.length - 1) ?
- featureIndex++;
- // draw the remaining features (in case there was no skipped feature
- // in this texture group, all features of a group are drawn together)
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
- var i, groupStart, start, end, feature, featureUid;
- var featureIndex = this.startIndices.length - 1;
- for (i = this.hitDetectionTextures_.length - 1; i >= 0; --i) {
- gl.bindTexture(ol.webgl.TEXTURE_2D, this.hitDetectionTextures_[i]);
- groupStart = (i > 0) ? this.hitDetectionGroupIndices_[i - 1] : 0;
- end = this.hitDetectionGroupIndices_[i];
- // draw all features for this texture group
- if (result) {
- return result;
- end = start;
- featureIndex--;
- return undefined;
- * @inheritDoc
- ol.render.webgl.ImageReplay.prototype.setImageStyle = function(imageStyle) {
- var anchor = imageStyle.getAnchor();
- var image = imageStyle.getImage(1);
- var imageSize = imageStyle.getImageSize();
- var hitDetectionImage = imageStyle.getHitDetectionImage(1);
- var opacity = imageStyle.getOpacity();
- var origin = imageStyle.getOrigin();
- var rotateWithView = imageStyle.getRotateWithView();
- var rotation = imageStyle.getRotation();
- var size = imageStyle.getSize();
- var scale = imageStyle.getScale();
- var currentImage;
- if (this.images_.length === 0) {
- this.images_.push(image);
- } else {
- currentImage = this.images_[this.images_.length - 1];
- if (ol.getUid(currentImage) != ol.getUid(image)) {
- if (this.hitDetectionImages_.length === 0) {
- this.hitDetectionImages_.push(hitDetectionImage);
- } else {
- currentImage =
- this.hitDetectionImages_[this.hitDetectionImages_.length - 1];
- if (ol.getUid(currentImage) != ol.getUid(hitDetectionImage)) {
- this.anchorX_ = anchor[0];
- this.anchorY_ = anchor[1];
- this.height_ = size[1];
- this.imageHeight_ = imageSize[1];
- this.imageWidth_ = imageSize[0];
- this.opacity_ = opacity;
- this.originX_ = origin[0];
- this.originY_ = origin[1];
- this.rotation_ = rotation;
- this.rotateWithView_ = rotateWithView;
- this.scale_ = scale;
- this.width_ = size[0];
-goog.provide('ol.geom.flat.topology');
-goog.require('ol.geom.flat.area');
- * Check if the linestring is a boundary.
- * @return {boolean} The linestring is a boundary.
-ol.geom.flat.topology.lineStringIsClosed = function(flatCoordinates, offset, end, stride) {
- var lastCoord = end - stride;
- if (flatCoordinates[offset] === flatCoordinates[lastCoord] &&
- flatCoordinates[offset + 1] === flatCoordinates[lastCoord + 1] && (end - offset) / stride > 3) {
- return !!ol.geom.flat.area.linearRing(flatCoordinates, offset, end, stride);
- return false;
-goog.provide('ol.render.webgl.linestringreplay.defaultshader');
- * @constructor
- * @struct
- ol.render.webgl.linestringreplay.defaultshader.Fragment = function() {
- ol.webgl.Fragment.call(this, ol.render.webgl.linestringreplay.defaultshader.Fragment.SOURCE);
- ol.inherits(ol.render.webgl.linestringreplay.defaultshader.Fragment, ol.webgl.Fragment);
- * @const
- * @type {string}
- ol.render.webgl.linestringreplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying float v_round;\nvarying vec2 v_roundVertex;\nvarying float v_halfWidth;\n\n\n\nuniform float u_opacity;\nuniform vec4 u_color;\nuniform vec2 u_size;\nuniform float u_pixelRatio;\n\nvoid main(void) {\n if (v_round > 0.0) {\n vec2 windowCoords = vec2((v_roundVertex.x + 1.0) / 2.0 * u_size.x * u_pixelRatio,\n (v_roundVertex.y + 1.0) / 2.0 * u_size.y * u_pixelRatio);\n if (length(windowCoords - gl_FragCoord.xy) > v_halfWidth * u_pixelRatio) {\n discard;\n }\n }\n gl_FragColor = u_color;\n float alpha = u_color.a * u_opacity;\n if (alpha == 0.0) {\n discard;\n }\n gl_FragColor.a = alpha;\n}\n';
- * @const
- * @type {string}
- ol.render.webgl.linestringreplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying float a;varying vec2 b;varying float c;uniform float m;uniform vec4 n;uniform vec2 o;uniform float p;void main(void){if(a>0.0){vec2 windowCoords=vec2((b.x+1.0)/2.0*o.x*p,(b.y+1.0)/2.0*o.y*p);if(length(windowCoords-gl_FragCoord.xy)>c*p){discard;}} gl_FragColor=n;float alpha=n.a*m;if(alpha==0.0){discard;}gl_FragColor.a=alpha;}';
- * @const
- * @type {string}
- ol.render.webgl.linestringreplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.linestringreplay.defaultshader.Fragment.DEBUG_SOURCE :
- ol.render.webgl.linestringreplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
- ol.render.webgl.linestringreplay.defaultshader.fragment = new ol.render.webgl.linestringreplay.defaultshader.Fragment();
- * @constructor
- * @struct
- ol.render.webgl.linestringreplay.defaultshader.Vertex = function() {
- ol.webgl.Vertex.call(this, ol.render.webgl.linestringreplay.defaultshader.Vertex.SOURCE);
- ol.inherits(ol.render.webgl.linestringreplay.defaultshader.Vertex, ol.webgl.Vertex);
- * @const
- * @type {string}
- ol.render.webgl.linestringreplay.defaultshader.Vertex.DEBUG_SOURCE = 'varying float v_round;\nvarying vec2 v_roundVertex;\nvarying float v_halfWidth;\n\n\nattribute vec2 a_lastPos;\nattribute vec2 a_position;\nattribute vec2 a_nextPos;\nattribute float a_direction;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\nuniform float u_lineWidth;\nuniform float u_miterLimit;\n\nbool nearlyEquals(in float value, in float ref) {\n float epsilon = 0.000000000001;\n return value >= ref - epsilon && value <= ref + epsilon;\n}\n\nvoid alongNormal(out vec2 offset, in vec2 nextP, in float turnDir, in float direction) {\n vec2 dirVect = nextP - a_position;\n vec2 normal = normalize(vec2(-turnDir * dirVect.y, turnDir * dirVect.x));\n offset = u_lineWidth / 2.0 * normal * direction;\n}\n\nvoid miterUp(out vec2 offset, out float round, in bool isRound, in float direction) {\n float halfWidth = u_lineWidth / 2.0;\n vec2 tangent = norma
lize(normalize(a_nextPos - a_position) + normalize(a_position - a_lastPos));\n vec2 normal = vec2(-tangent.y, tangent.x);\n vec2 dirVect = a_nextPos - a_position;\n vec2 tmpNormal = normalize(vec2(-dirVect.y, dirVect.x));\n float miterLength = abs(halfWidth / dot(normal, tmpNormal));\n offset = normal * direction * miterLength;\n round = 0.0;\n if (isRound) {\n round = 1.0;\n } else if (miterLength > u_miterLimit + u_lineWidth) {\n offset = halfWidth * tmpNormal * direction;\n }\n}\n\nbool miterDown(out vec2 offset, in vec4 projPos, in mat4 offsetMatrix, in float direction) {\n bool degenerate = false;\n vec2 tangent = normalize(normalize(a_nextPos - a_position) + normalize(a_position - a_lastPos));\n vec2 normal = vec2(-tangent.y, tangent.x);\n vec2 dirVect = a_lastPos - a_position;\n vec2 tmpNormal = normalize(vec2(-dirVect.y, dirVect.x));\n vec2 longOffset, shortOffset, longVertex;\n vec4 shortProjVertex;\n float halfWidth = u_lineWidth / 2.0;\n if (length
(a_nextPos - a_position) > length(a_lastPos - a_position)) {\n longOffset = tmpNormal * direction * halfWidth;\n shortOffset = normalize(vec2(dirVect.y, -dirVect.x)) * direction * halfWidth;\n longVertex = a_nextPos;\n shortProjVertex = u_projectionMatrix * vec4(a_lastPos, 0.0, 1.0);\n } else {\n shortOffset = tmpNormal * direction * halfWidth;\n longOffset = normalize(vec2(dirVect.y, -dirVect.x)) * direction * halfWidth;\n longVertex = a_lastPos;\n shortProjVertex = u_projectionMatrix * vec4(a_nextPos, 0.0, 1.0);\n }\n //Intersection algorithm based on theory by Paul Bourke (http://paulbourke.net/geometry/pointlineplane/).\n vec4 p1 = u_projectionMatrix * vec4(longVertex, 0.0, 1.0) + offsetMatrix * vec4(longOffset, 0.0, 0.0);\n vec4 p2 = projPos + offsetMatrix * vec4(longOffset, 0.0, 0.0);\n vec4 p3 = shortProjVertex + offsetMatrix * vec4(-shortOffset, 0.0, 0.0);\n vec4 p4 = shortProjVertex + offsetMatrix * vec4(shortOffset, 0.0, 0.0);\n float denom
= (p4.y - p3.y) * (p2.x - p1.x) - (p4.x - p3.x) * (p2.y - p1.y);\n float firstU = ((p4.x - p3.x) * (p1.y - p3.y) - (p4.y - p3.y) * (p1.x - p3.x)) / denom;\n float secondU = ((p2.x - p1.x) * (p1.y - p3.y) - (p2.y - p1.y) * (p1.x - p3.x)) / denom;\n float epsilon = 0.000000000001;\n if (firstU > epsilon && firstU < 1.0 - epsilon && secondU > epsilon && secondU < 1.0 - epsilon) {\n shortProjVertex.x = p1.x + firstU * (p2.x - p1.x);\n shortProjVertex.y = p1.y + firstU * (p2.y - p1.y);\n offset = shortProjVertex.xy;\n degenerate = true;\n } else {\n float miterLength = abs(halfWidth / dot(normal, tmpNormal));\n offset = normal * direction * miterLength;\n }\n return degenerate;\n}\n\nvoid squareCap(out vec2 offset, out float round, in bool isRound, in vec2 nextP,\n in float turnDir, in float direction) {\n round = 0.0;\n vec2 dirVect = a_position - nextP;\n vec2 firstNormal = normalize(dirVect);\n vec2 secondNormal = vec2(turnDir * firstNormal.y * directio
n, -turnDir * firstNormal.x * direction);\n vec2 hypotenuse = normalize(firstNormal - secondNormal);\n vec2 normal = vec2(turnDir * hypotenuse.y * direction, -turnDir * hypotenuse.x * direction);\n float length = sqrt(v_halfWidth * v_halfWidth * 2.0);\n offset = normal * length;\n if (isRound) {\n round = 1.0;\n }\n}\n\nvoid main(void) {\n bool degenerate = false;\n float direction = float(sign(a_direction));\n mat4 offsetMatrix = u_offsetScaleMatrix * u_offsetRotateMatrix;\n vec2 offset;\n vec4 projPos = u_projectionMatrix * vec4(a_position, 0.0, 1.0);\n bool round = nearlyEquals(mod(a_direction, 2.0), 0.0);\n\n v_round = 0.0;\n v_halfWidth = u_lineWidth / 2.0;\n v_roundVertex = projPos.xy;\n\n if (nearlyEquals(mod(a_direction, 3.0), 0.0) || nearlyEquals(mod(a_direction, 17.0), 0.0)) {\n alongNormal(offset, a_nextPos, 1.0, direction);\n } else if (nearlyEquals(mod(a_direction, 5.0), 0.0) || nearlyEquals(mod(a_direction, 13.0), 0.0)) {\n alongNormal(offset,
a_lastPos, -1.0, direction);\n } else if (nearlyEquals(mod(a_direction, 23.0), 0.0)) {\n miterUp(offset, v_round, round, direction);\n } else if (nearlyEquals(mod(a_direction, 19.0), 0.0)) {\n degenerate = miterDown(offset, projPos, offsetMatrix, direction);\n } else if (nearlyEquals(mod(a_direction, 7.0), 0.0)) {\n squareCap(offset, v_round, round, a_nextPos, 1.0, direction);\n } else if (nearlyEquals(mod(a_direction, 11.0), 0.0)) {\n squareCap(offset, v_round, round, a_lastPos, -1.0, direction);\n }\n if (!degenerate) {\n vec4 offsets = offsetMatrix * vec4(offset, 0.0, 0.0);\n gl_Position = projPos + offsets;\n } else {\n gl_Position = vec4(offset, 0.0, 1.0);\n }\n}\n\n\n';
- * @const
- * @type {string}
- ol.render.webgl.linestringreplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'varying float a;varying vec2 b;varying float c;attribute vec2 d;attribute vec2 e;attribute vec2 f;attribute float g;uniform mat4 h;uniform mat4 i;uniform mat4 j;uniform float k;uniform float l;bool nearlyEquals(in float value,in float ref){float epsilon=0.000000000001;return value>=ref-epsilon&&value<=ref+epsilon;}void alongNormal(out vec2 offset,in vec2 nextP,in float turnDir,in float direction){vec2 dirVect=nextP-e;vec2 normal=normalize(vec2(-turnDir*dirVect.y,turnDir*dirVect.x));offset=k/2.0*normal*direction;}void miterUp(out vec2 offset,out float round,in bool isRound,in float direction){float halfWidth=k/2.0;vec2 tangent=normalize(normalize(f-e)+normalize(e-d));vec2 normal=vec2(-tangent.y,tangent.x);vec2 dirVect=f-e;vec2 tmpNormal=normalize(vec2(-dirVect.y,dirVect.x));float miterLength=abs(halfWidth/dot(normal,tmpNormal));offset=normal*direction*miterLength;round=0.0;if(isRound){round=1.0;}else if(miter
Length>l+k){offset=halfWidth*tmpNormal*direction;}} bool miterDown(out vec2 offset,in vec4 projPos,in mat4 offsetMatrix,in float direction){bool degenerate=false;vec2 tangent=normalize(normalize(f-e)+normalize(e-d));vec2 normal=vec2(-tangent.y,tangent.x);vec2 dirVect=d-e;vec2 tmpNormal=normalize(vec2(-dirVect.y,dirVect.x));vec2 longOffset,shortOffset,longVertex;vec4 shortProjVertex;float halfWidth=k/2.0;if(length(f-e)>length(d-e)){longOffset=tmpNormal*direction*halfWidth;shortOffset=normalize(vec2(dirVect.y,-dirVect.x))*direction*halfWidth;longVertex=f;shortProjVertex=h*vec4(d,0.0,1.0);}else{shortOffset=tmpNormal*direction*halfWidth;longOffset=normalize(vec2(dirVect.y,-dirVect.x))*direction*halfWidth;longVertex=d;shortProjVertex=h*vec4(f,0.0,1.0);}vec4 p1=h*vec4(longVertex,0.0,1.0)+offsetMatrix*vec4(longOffset,0.0,0.0);vec4 p2=projPos+offsetMatrix*vec4(longOffset,0.0,0.0);vec4 p3=shortProjVertex+offsetMatrix*vec4(-shortOffset,0.0,0.0);vec4 p4=shortProjVertex+offsetMatrix*vec4(shortO
ffset,0.0,0.0);float denom=(p4.y-p3.y)*(p2.x-p1.x)-(p4.x-p3.x)*(p2.y-p1.y);float firstU=((p4.x-p3.x)*(p1.y-p3.y)-(p4.y-p3.y)*(p1.x-p3.x))/denom;float secondU=((p2.x-p1.x)*(p1.y-p3.y)-(p2.y-p1.y)*(p1.x-p3.x))/denom;float epsilon=0.000000000001;if(firstU>epsilon&&firstU<1.0-epsilon&&secondU>epsilon&&secondU<1.0-epsilon){shortProjVertex.x=p1.x+firstU*(p2.x-p1.x);shortProjVertex.y=p1.y+firstU*(p2.y-p1.y);offset=shortProjVertex.xy;degenerate=true;}else{float miterLength=abs(halfWidth/dot(normal,tmpNormal));offset=normal*direction*miterLength;}return degenerate;}void squareCap(out vec2 offset,out float round,in bool isRound,in vec2 nextP,in float turnDir,in float direction){round=0.0;vec2 dirVect=e-nextP;vec2 firstNormal=normalize(dirVect);vec2 secondNormal=vec2(turnDir*firstNormal.y*direction,-turnDir*firstNormal.x*direction);vec2 hypotenuse=normalize(firstNormal-secondNormal);vec2 normal=vec2(turnDir*hypotenuse.y*direction,-turnDir*hypotenuse.x*direction);float length=sqrt(c*c*2.0);offs
et=normal*length;if(isRound){round=1.0;}} void main(void){bool degenerate=false;float direction=float(sign(g));mat4 offsetMatrix=i*j;vec2 offset;vec4 projPos=h*vec4(e,0.0,1.0);bool round=nearlyEquals(mod(g,2.0),0.0);a=0.0;c=k/2.0;b=projPos.xy;if(nearlyEquals(mod(g,3.0),0.0)||nearlyEquals(mod(g,17.0),0.0)){alongNormal(offset,f,1.0,direction);}else if(nearlyEquals(mod(g,5.0),0.0)||nearlyEquals(mod(g,13.0),0.0)){alongNormal(offset,d,-1.0,direction);}else if(nearlyEquals(mod(g,23.0),0.0)){miterUp(offset,a,round,direction);}else if(nearlyEquals(mod(g,19.0),0.0)){degenerate=miterDown(offset,projPos,offsetMatrix,direction);}else if(nearlyEquals(mod(g,7.0),0.0)){squareCap(offset,a,round,f,1.0,direction);}else if(nearlyEquals(mod(g,11.0),0.0)){squareCap(offset,a,round,d,-1.0,direction);}if(!degenerate){vec4 offsets=offsetMatrix*vec4(offset,0.0,0.0);gl_Position=projPos+offsets;}else{gl_Position=vec4(offset,0.0,1.0);}}';
- * @const
- * @type {string}
- ol.render.webgl.linestringreplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.linestringreplay.defaultshader.Vertex.DEBUG_SOURCE :
- ol.render.webgl.linestringreplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
- ol.render.webgl.linestringreplay.defaultshader.vertex = new ol.render.webgl.linestringreplay.defaultshader.Vertex();
- * @constructor
- * @struct
- ol.render.webgl.linestringreplay.defaultshader.Locations = function(gl, program) {
- this.u_color = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_color' : 'n');
- this.u_miterLimit = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_miterLimit' : 'l');
- program, ol.DEBUG_WEBGL ? 'u_pixelRatio' : 'p');
- program, ol.DEBUG_WEBGL ? 'u_size' : 'o');
- * @type {number}
- this.a_direction = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_direction' : 'g');
- * @type {number}
- this.a_lastPos = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_lastPos' : 'd');
- * @type {number}
- this.a_nextPos = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_nextPos' : 'f');
- * @type {number}
-goog.provide('ol.render.webgl.LineStringReplay');
-goog.require('ol.geom.flat.orient');
-goog.require('ol.geom.flat.transform');
-goog.require('ol.geom.flat.topology');
-goog.require('ol.render.webgl.linestringreplay.defaultshader');
-goog.require('ol.webgl');
-if (ol.ENABLE_WEBGL) {
- * @constructor
- * @struct
- ol.render.webgl.LineStringReplay = function(tolerance, maxExtent) {
- * @private
- * @type {ol.render.webgl.linestringreplay.defaultshader.Locations}
- * @private
- * @type {Array.<Array.<?>>}
- * @private
- * @private
- * @type {{strokeColor: (Array.<number>|null),
- * lineCap: (string|undefined),
- * lineJoin: (string|undefined),
- * miterLimit: (number|undefined),
- this.state_ = {
- lineCap: undefined,
- lineDash: null,
- lineJoin: undefined,
- miterLimit: undefined,
- changed: false
- ol.inherits(ol.render.webgl.LineStringReplay, ol.render.webgl.Replay);
- * Draw one segment.
- * @private
- ol.render.webgl.LineStringReplay.prototype.drawCoordinates_ = function(flatCoordinates, offset, end, stride) {
- var i, ii;
- //To save a vertex, the direction of a point is a product of the sign (1 or -1), a prime from
- //ol.render.webgl.LineStringReplay.Instruction_, and a rounding factor (1 or 2). If the product is even,
- //we round it. If it is odd, we don't.
- var lineJoin = this.state_.lineJoin === 'bevel' ? 0 :
- this.state_.lineJoin === 'miter' ? 1 : 2;
- var lineCap = this.state_.lineCap === 'butt' ? 0 :
- this.state_.lineCap === 'square' ? 1 : 2;
- var closed = ol.geom.flat.topology.lineStringIsClosed(flatCoordinates, offset, end, stride);
- var startCoords, sign, n;
- var lastIndex = numIndices;
- var lastSign = 1;
- //We need the adjacent vertices to define normals in joins. p0 = last, p1 = current, p2 = next.
- var p0, p1, p2;
- n = numVertices / 7;
- p0 = p1;
- p1 = p2 || [flatCoordinates[i], flatCoordinates[i + 1]];
- //First vertex.
- if (i === offset) {
- p2 = [flatCoordinates[i + stride], flatCoordinates[i + stride + 1]];
- if (end - offset === stride * 2 && ol.array.equals(p1, p2)) {
- break;
- if (closed) {
- //A closed line! Complete the circle.
- p0 = [flatCoordinates[end - stride * 2],
- flatCoordinates[end - stride * 2 + 1]];
- startCoords = p2;
- } else {
- //Add the first two/four vertices.
- if (lineCap) {
- numVertices = this.addVertices_([0, 0], p1, p2,
- lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE_CAP * lineCap, numVertices);
- -lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE_CAP * lineCap, numVertices);
- lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE * (lineCap || 1), numVertices);
- -lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE * (lineCap || 1), numVertices);
- lastIndex = numVertices / 7 - 1;
- continue;
- } else if (i === end - stride) {
- //Last vertex.
- if (closed) {
- //Same as the first vertex.
- p2 = startCoords;
- break;
- } else {
- p0 = p0 || [0, 0];
- numVertices = this.addVertices_(p0, p1, [0, 0],
- lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE * (lineCap || 1), numVertices);
- -lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE * (lineCap || 1), numVertices);
- this.indices[numIndices++] = lastIndex - 1;
- this.indices[numIndices++] = lastIndex;
- if (lineCap) {
- lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE_CAP * lineCap, numVertices);
- -lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE_CAP * lineCap, numVertices);
- break;
- } else {
- // We group CW and straight lines, thus the not so inituitive CCW checking function.
- sign = ol.render.webgl.triangleIsCounterClockwise(p0[0], p0[1], p1[0], p1[1], p2[0], p2[1])
- ? -1 : 1;
- numVertices = this.addVertices_(p0, p1, p2,
- sign * ol.render.webgl.LineStringReplay.Instruction_.BEVEL_FIRST * (lineJoin || 1), numVertices);
- sign * ol.render.webgl.LineStringReplay.Instruction_.BEVEL_SECOND * (lineJoin || 1), numVertices);
- -sign * ol.render.webgl.LineStringReplay.Instruction_.MITER_BOTTOM * (lineJoin || 1), numVertices);
- if (i > offset) {
- this.indices[numIndices++] = lastSign * sign > 0 ? lastIndex : lastIndex - 1;
- lastIndex = n + 2;
- lastSign = sign;
- //Add miter
- if (lineJoin) {
- sign * ol.render.webgl.LineStringReplay.Instruction_.MITER_TOP * lineJoin, numVertices);
- if (closed) {
- n = n || numVertices / 7;
- sign = ol.geom.flat.orient.linearRingIsClockwise([p0[0], p0[1], p1[0], p1[1], p2[0], p2[1]], 0, 6, 2)
- ? 1 : -1;
- * @param {Array.<number>} p0 Last coordinates.
- * @param {Array.<number>} p1 Current coordinates.
- * @param {Array.<number>} p2 Next coordinates.
- * @param {number} product Sign, instruction, and rounding product.
- * @param {number} numVertices Vertex counter.
- * @return {number} Vertex counter.
- * @private
- ol.render.webgl.LineStringReplay.prototype.addVertices_ = function(p0, p1, p2, product, numVertices) {
- this.vertices[numVertices++] = p0[0];
- this.vertices[numVertices++] = p0[1];
- this.vertices[numVertices++] = p1[0];
- this.vertices[numVertices++] = p1[1];
- this.vertices[numVertices++] = p2[0];
- this.vertices[numVertices++] = p2[1];
- this.vertices[numVertices++] = product;
- * Check if the linestring can be drawn (i. e. valid).
- * @return {boolean} The linestring can be drawn.
- * @private
- ol.render.webgl.LineStringReplay.prototype.isValid_ = function(flatCoordinates, offset, end, stride) {
- var range = end - offset;
- if (range < stride * 2) {
- return false;
- } else if (range === stride * 2) {
- var firstP = [flatCoordinates[offset], flatCoordinates[offset + 1]];
- var lastP = [flatCoordinates[offset + stride], flatCoordinates[offset + stride + 1]];
- return !ol.array.equals(firstP, lastP);
- return true;
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.drawLineString = function(lineStringGeometry, feature) {
- var flatCoordinates = lineStringGeometry.getFlatCoordinates();
- var stride = lineStringGeometry.getStride();
- if (this.isValid_(flatCoordinates, 0, flatCoordinates.length, stride)) {
- flatCoordinates = ol.geom.flat.transform.translate(flatCoordinates, 0, flatCoordinates.length,
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.drawMultiLineString = function(multiLineStringGeometry, feature) {
- var indexCount = this.indices.length;
- var lineStringGeometries = multiLineStringGeometry.getLineStrings();
- var i, ii;
- for (i = 0, ii = lineStringGeometries.length; i < ii; ++i) {
- var flatCoordinates = lineStringGeometries[i].getFlatCoordinates();
- var stride = lineStringGeometries[i].getStride();
- if (this.indices.length > indexCount) {
- this.startIndices.push(indexCount);
- this.styleIndices_.push(indexCount);
- * @param {Array.<Array.<number>>} holeFlatCoordinates Hole flat coordinates.
- ol.render.webgl.LineStringReplay.prototype.drawPolygonCoordinates = function(
- flatCoordinates, holeFlatCoordinates, stride) {
- if (!ol.geom.flat.topology.lineStringIsClosed(flatCoordinates, 0,
- flatCoordinates.length, stride)) {
- flatCoordinates.push(flatCoordinates[0]);
- flatCoordinates.push(flatCoordinates[1]);
- this.drawCoordinates_(flatCoordinates, 0, flatCoordinates.length, stride);
- if (holeFlatCoordinates.length) {
- var i, ii;
- for (i = 0, ii = holeFlatCoordinates.length; i < ii; ++i) {
- if (!ol.geom.flat.topology.lineStringIsClosed(holeFlatCoordinates[i], 0,
- holeFlatCoordinates[i].length, stride)) {
- holeFlatCoordinates[i].push(holeFlatCoordinates[i][0]);
- holeFlatCoordinates[i].push(holeFlatCoordinates[i][1]);
- this.drawCoordinates_(holeFlatCoordinates[i], 0,
- holeFlatCoordinates[i].length, stride);
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- * @param {number=} opt_index Index count.
- ol.render.webgl.LineStringReplay.prototype.setPolygonStyle = function(feature, opt_index) {
- var index = opt_index === undefined ? this.indices.length : opt_index;
- this.startIndices.push(index);
- this.styleIndices_.push(index);
- * @return {number} Current index.
- ol.render.webgl.LineStringReplay.prototype.getCurrentIndex = function() {
- return this.indices.length;
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.finish = function(context) {
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.getDeleteResourcesFunction = function(context) {
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
- fragmentShader = ol.render.webgl.linestringreplay.defaultshader.fragment;
- vertexShader = ol.render.webgl.linestringreplay.defaultshader.vertex;
- var locations;
- locations =
- new ol.render.webgl.linestringreplay.defaultshader.Locations(gl, program);
- } else {
- gl.enableVertexAttribArray(locations.a_lastPos);
- gl.vertexAttribPointer(locations.a_lastPos, 2, ol.webgl.FLOAT,
- false, 28, 0);
- false, 28, 8);
- gl.enableVertexAttribArray(locations.a_nextPos);
- gl.vertexAttribPointer(locations.a_nextPos, 2, ol.webgl.FLOAT,
- false, 28, 16);
- gl.enableVertexAttribArray(locations.a_direction);
- gl.vertexAttribPointer(locations.a_direction, 1, ol.webgl.FLOAT,
- false, 28, 24);
- return locations;
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.shutDownProgram = function(gl, locations) {
- gl.disableVertexAttribArray(locations.a_lastPos);
- gl.disableVertexAttribArray(locations.a_nextPos);
- gl.disableVertexAttribArray(locations.a_direction);
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
- //Save GL parameters.
- var tmpDepthFunc = /** @type {number} */ (gl.getParameter(gl.DEPTH_FUNC));
- var tmpDepthMask = /** @type {boolean} */ (gl.getParameter(gl.DEPTH_WRITEMASK));
- if (!hitDetection) {
- gl.enable(gl.DEPTH_TEST);
- gl.depthMask(true);
- gl.depthFunc(gl.NOTEQUAL);
- } else {
- this.setStrokeStyle_(gl, nextStyle[0], nextStyle[1], nextStyle[2]);
- gl.clear(gl.DEPTH_BUFFER_BIT);
- end = start;
- gl.disable(gl.DEPTH_TEST);
- //Restore GL parameters.
- gl.depthMask(tmpDepthMask);
- gl.depthFunc(tmpDepthFunc);
- * @private
- * @param {WebGLRenderingContext} gl gl.
- * @param {ol.webgl.Context} context Context.
- ol.render.webgl.LineStringReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash) {
- featureIndex--;
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
- gl.clear(gl.COLOR_BUFFER_BIT | gl.DEPTH_BUFFER_BIT);
- if (result) {
- return result;
- featureIndex--;
- end = start;
- return undefined;
- * @private
- * @param {number} miterLimit Miter limit.
- ol.render.webgl.LineStringReplay.prototype.setStrokeStyle_ = function(gl, color, lineWidth, miterLimit) {
- gl.uniform4fv(this.defaultLocations_.u_color, color);
- gl.uniform1f(this.defaultLocations_.u_miterLimit, miterLimit);
- * @inheritDoc
- ol.render.webgl.LineStringReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- var strokeStyleLineCap = strokeStyle.getLineCap();
- this.state_.lineCap = strokeStyleLineCap !== undefined ?
- strokeStyleLineCap : ol.render.webgl.defaultLineCap;
- var strokeStyleLineDash = strokeStyle.getLineDash();
- var strokeStyleLineDashOffset = strokeStyle.getLineDashOffset();
- var strokeStyleLineJoin = strokeStyle.getLineJoin();
- this.state_.lineJoin = strokeStyleLineJoin !== undefined ?
- strokeStyleLineJoin : ol.render.webgl.defaultLineJoin;
- var strokeStyleColor = strokeStyle.getColor();
- } else {
- var strokeStyleWidth = strokeStyle.getWidth();
- var strokeStyleMiterLimit = strokeStyle.getMiterLimit();
- strokeStyleMiterLimit = strokeStyleMiterLimit !== undefined ?
- strokeStyleMiterLimit : ol.render.webgl.defaultMiterLimit;
- this.state_.lineWidth !== strokeStyleWidth || this.state_.miterLimit !== strokeStyleMiterLimit) {
- this.state_.miterLimit = strokeStyleMiterLimit;
- this.styles_.push([strokeStyleColor, strokeStyleWidth, strokeStyleMiterLimit]);
- * @enum {number}
- * @private
- ol.render.webgl.LineStringReplay.Instruction_ = {
- ROUND: 2,
- BEGIN_LINE: 3,
- END_LINE: 5,
- BEGIN_LINE_CAP: 7,
- END_LINE_CAP: 11,
- BEVEL_FIRST: 13,
- BEVEL_SECOND: 17,
- MITER_BOTTOM: 19,
- MITER_TOP: 23
-// This file is automatically generated, do not edit
-goog.provide('ol.render.webgl.polygonreplay.defaultshader');
-goog.require('ol.webgl.Fragment');
-goog.require('ol.webgl.Vertex');
- * @constructor
- * @extends {ol.webgl.Fragment}
- * @struct
- ol.render.webgl.polygonreplay.defaultshader.Fragment = function() {
- ol.webgl.Fragment.call(this, ol.render.webgl.polygonreplay.defaultshader.Fragment.SOURCE);
- ol.inherits(ol.render.webgl.polygonreplay.defaultshader.Fragment, ol.webgl.Fragment);
- * @const
- * @type {string}
- ol.render.webgl.polygonreplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\n\n\n\nuniform vec4 u_color;\nuniform float u_opacity;\n\nvoid main(void) {\n gl_FragColor = u_color;\n float alpha = u_color.a * u_opacity;\n if (alpha == 0.0) {\n discard;\n }\n gl_FragColor.a = alpha;\n}\n';
- * @const
- * @type {string}
- ol.render.webgl.polygonreplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;uniform vec4 e;uniform float f;void main(void){gl_FragColor=e;float alpha=e.a*f;if(alpha==0.0){discard;}gl_FragColor.a=alpha;}';
- * @const
- * @type {string}
- ol.render.webgl.polygonreplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.polygonreplay.defaultshader.Fragment.DEBUG_SOURCE :
- ol.render.webgl.polygonreplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
- ol.render.webgl.polygonreplay.defaultshader.fragment = new ol.render.webgl.polygonreplay.defaultshader.Fragment();
- * @constructor
- * @extends {ol.webgl.Vertex}
- * @struct
- ol.render.webgl.polygonreplay.defaultshader.Vertex = function() {
- ol.webgl.Vertex.call(this, ol.render.webgl.polygonreplay.defaultshader.Vertex.SOURCE);
- ol.inherits(ol.render.webgl.polygonreplay.defaultshader.Vertex, ol.webgl.Vertex);
- * @const
- * @type {string}
- ol.render.webgl.polygonreplay.defaultshader.Vertex.DEBUG_SOURCE = '\n\nattribute vec2 a_position;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\n\nvoid main(void) {\n gl_Position = u_projectionMatrix * vec4(a_position, 0.0, 1.0);\n}\n\n\n';
- * @const
- * @type {string}
- ol.render.webgl.polygonreplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'attribute vec2 a;uniform mat4 b;uniform mat4 c;uniform mat4 d;void main(void){gl_Position=b*vec4(a,0.0,1.0);}';
- * @const
- * @type {string}
- ol.render.webgl.polygonreplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
- ol.render.webgl.polygonreplay.defaultshader.Vertex.DEBUG_SOURCE :
- ol.render.webgl.polygonreplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
- ol.render.webgl.polygonreplay.defaultshader.vertex = new ol.render.webgl.polygonreplay.defaultshader.Vertex();
- * @constructor
- * @param {WebGLRenderingContext} gl GL.
- * @param {WebGLProgram} program Program.
- * @struct
- ol.render.webgl.polygonreplay.defaultshader.Locations = function(gl, program) {
- * @type {WebGLUniformLocation}
- program, ol.DEBUG_WEBGL ? 'u_color' : 'e');
- this.u_offsetRotateMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_offsetRotateMatrix' : 'd');
- this.u_offsetScaleMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_offsetScaleMatrix' : 'c');
- this.u_opacity = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_opacity' : 'f');
- this.u_projectionMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_projectionMatrix' : 'b');
- * @type {number}
- this.a_position = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_position' : 'a');
-goog.provide('ol.style.Stroke');
-goog.require('ol');
- * @classdesc
- * Set stroke style for vector features.
- * Note that the defaults given are the Canvas defaults, which will be used if
- * option is not defined. The `get` functions return whatever was entered in
- * the options; they will not return the default.
- * @constructor
- * @param {olx.style.StrokeOptions=} opt_options Options.
- * @api
-ol.style.Stroke = function(opt_options) {
- var options = opt_options || {};
- * @private
- * @type {ol.Color|ol.ColorLike}
- this.color_ = options.color !== undefined ? options.color : null;
- * @private
- * @type {string|undefined}
- this.lineCap_ = options.lineCap;
- * @private
- this.lineDash_ = options.lineDash !== undefined ? options.lineDash : null;
- * @private
- this.lineDashOffset_ = options.lineDashOffset;
- * @private
- this.lineJoin_ = options.lineJoin;
- * @private
- this.miterLimit_ = options.miterLimit;
- * @private
- this.width_ = options.width;
- * @private
- this.checksum_ = undefined;
- * Clones the style.
- * @return {ol.style.Stroke} The cloned style.
- * @api
-ol.style.Stroke.prototype.clone = function() {
- var color = this.getColor();
- return new ol.style.Stroke({
- color: (color && color.slice) ? color.slice() : color || undefined,
- lineCap: this.getLineCap(),
- lineDash: this.getLineDash() ? this.getLineDash().slice() : undefined,
- lineDashOffset: this.getLineDashOffset(),
- lineJoin: this.getLineJoin(),
- miterLimit: this.getMiterLimit(),
- width: this.getWidth()
- * Get the stroke color.
- * @return {ol.Color|ol.ColorLike} Color.
- * @api
-ol.style.Stroke.prototype.getColor = function() {
- return this.color_;
- * Get the line cap type for the stroke.
- * @return {string|undefined} Line cap.
- * @api
-ol.style.Stroke.prototype.getLineCap = function() {
- return this.lineCap_;
- * Get the line dash style for the stroke.
- * @return {Array.<number>} Line dash.
- * @api
-ol.style.Stroke.prototype.getLineDash = function() {
- return this.lineDash_;
- * Get the line dash offset for the stroke.
- * @return {number|undefined} Line dash offset.
- * @api
-ol.style.Stroke.prototype.getLineDashOffset = function() {
- return this.lineDashOffset_;
- * Get the line join type for the stroke.
- * @return {string|undefined} Line join.
- * @api
-ol.style.Stroke.prototype.getLineJoin = function() {
- return this.lineJoin_;
- * Get the miter limit for the stroke.
- * @return {number|undefined} Miter limit.
- * @api
-ol.style.Stroke.prototype.getMiterLimit = function() {
- return this.miterLimit_;
- * Get the stroke width.
- * @return {number|undefined} Width.
- * @api
-ol.style.Stroke.prototype.getWidth = function() {
- return this.width_;
- * Set the color.
- * @param {ol.Color|ol.ColorLike} color Color.
- * @api
-ol.style.Stroke.prototype.setColor = function(color) {
- this.color_ = color;
- * Set the line cap.
- * @param {string|undefined} lineCap Line cap.
- * @api
-ol.style.Stroke.prototype.setLineCap = function(lineCap) {
- this.lineCap_ = lineCap;
- * Set the line dash.
- * Please note that Internet Explorer 10 and lower [do not support][mdn] the
- * `setLineDash` method on the `CanvasRenderingContext2D` and therefore this
- * property will have no visual effect in these browsers.
- * [mdn]: https://developer.mozilla.org/en-US/docs/Web/API/CanvasRenderingContext2D/setLineDash#Browser_compatibility
- * @param {Array.<number>} lineDash Line dash.
- * @api
-ol.style.Stroke.prototype.setLineDash = function(lineDash) {
- this.lineDash_ = lineDash;
- * Set the line dash offset.
- * @param {number|undefined} lineDashOffset Line dash offset.
- * @api
-ol.style.Stroke.prototype.setLineDashOffset = function(lineDashOffset) {
- this.lineDashOffset_ = lineDashOffset;
- * Set the line join.
- * @param {string|undefined} lineJoin Line join.
- * @api
-ol.style.Stroke.prototype.setLineJoin = function(lineJoin) {
- this.lineJoin_ = lineJoin;
- * Set the miter limit.
- * @param {number|undefined} miterLimit Miter limit.
- * @api
-ol.style.Stroke.prototype.setMiterLimit = function(miterLimit) {
- this.miterLimit_ = miterLimit;
- * Set the width.
- * @param {number|undefined} width Width.
- * @api
-ol.style.Stroke.prototype.setWidth = function(width) {
- this.width_ = width;
- * @return {string} The checksum.
-ol.style.Stroke.prototype.getChecksum = function() {
- if (this.checksum_ === undefined) {
- this.checksum_ = 's';
- if (this.color_) {
- if (typeof this.color_ === 'string') {
- this.checksum_ += this.color_;
- } else {
- this.checksum_ += ol.getUid(this.color_).toString();
- } else {
- this.checksum_ += '-';
- this.checksum_ += ',' +
- (this.lineCap_ !== undefined ?
- this.lineCap_.toString() : '-') + ',' +
- (this.lineDash_ ?
- this.lineDash_.toString() : '-') + ',' +
- (this.lineDashOffset_ !== undefined ?
- this.lineDashOffset_ : '-') + ',' +
- (this.lineJoin_ !== undefined ?
- this.lineJoin_ : '-') + ',' +
- (this.miterLimit_ !== undefined ?
- this.miterLimit_.toString() : '-') + ',' +
- (this.width_ !== undefined ?
- this.width_.toString() : '-');
- return this.checksum_;
-goog.provide('ol.structs.LinkedList');
- * Creates an empty linked list structure.
- * @constructor
- * @struct
- * @param {boolean=} opt_circular The last item is connected to the first one,
- * and the first item to the last one. Default is true.
-ol.structs.LinkedList = function(opt_circular) {
- * @private
- * @type {ol.LinkedListItem|undefined}
- this.first_ = undefined;
- * @private
- this.last_ = undefined;
- * @private
- this.head_ = undefined;
- * @private
- * @type {boolean}
- this.circular_ = opt_circular === undefined ? true : opt_circular;
- * @private
- * @type {number}
- this.length_ = 0;
- * Inserts an item into the linked list right after the current one.
- * @param {?} data Item data.
-ol.structs.LinkedList.prototype.insertItem = function(data) {
- /** @type {ol.LinkedListItem} */
- var item = {
- prev: undefined,
- next: undefined,
- data: data
- var head = this.head_;
- //Initialize the list.
- if (!head) {
- this.first_ = item;
- this.last_ = item;
- if (this.circular_) {
- item.next = item;
- item.prev = item;
- } else {
- //Link the new item to the adjacent ones.
- var next = head.next;
- item.prev = head;
- item.next = next;
- head.next = item;
- if (next) {
- next.prev = item;
- if (head === this.last_) {
- this.head_ = item;
- this.length_++;
- * Removes the current item from the list. Sets the cursor to the next item,
- * if possible.
-ol.structs.LinkedList.prototype.removeItem = function() {
- if (head) {
- var prev = head.prev;
- if (next) {
- next.prev = prev;
- if (prev) {
- prev.next = next;
- this.head_ = next || prev;
- if (this.first_ === this.last_) {
- } else if (this.first_ === head) {
- this.first_ = this.head_;
- } else if (this.last_ === head) {
- this.last_ = prev ? this.head_.prev : this.head_;
- this.length_--;
- * Sets the cursor to the first item, and returns the associated data.
- * @return {?} Item data.
-ol.structs.LinkedList.prototype.firstItem = function() {
- this.head_ = this.first_;
- if (this.head_) {
- return this.head_.data;
- return undefined;
-* Sets the cursor to the last item, and returns the associated data.
-* @return {?} Item data.
-ol.structs.LinkedList.prototype.lastItem = function() {
- this.head_ = this.last_;
- if (this.head_) {
- return undefined;
- * Sets the cursor to the next item, and returns the associated data.
-ol.structs.LinkedList.prototype.nextItem = function() {
- if (this.head_ && this.head_.next) {
- this.head_ = this.head_.next;
- return undefined;
- * Returns the next item's data without moving the cursor.
-ol.structs.LinkedList.prototype.getNextItem = function() {
- return this.head_.next.data;
- return undefined;
- * Sets the cursor to the previous item, and returns the associated data.
-ol.structs.LinkedList.prototype.prevItem = function() {
- if (this.head_ && this.head_.prev) {
- this.head_ = this.head_.prev;
- return undefined;
- * Returns the previous item's data without moving the cursor.
-ol.structs.LinkedList.prototype.getPrevItem = function() {
- return this.head_.prev.data;
- return undefined;
- * Returns the current item's data.
-ol.structs.LinkedList.prototype.getCurrItem = function() {
- if (this.head_) {
- return undefined;
- * Sets the first item of the list. This only works for circular lists, and sets
- * the last item accordingly.
-ol.structs.LinkedList.prototype.setFirstItem = function() {
- if (this.circular_ && this.head_) {
- this.last_ = this.head_.prev;
- * Concatenates two lists.
- * @param {ol.structs.LinkedList} list List to merge into the current list.
-ol.structs.LinkedList.prototype.concat = function(list) {
- if (list.head_) {
- if (this.head_) {
- var end = this.head_.next;
- this.head_.next = list.first_;
- list.first_.prev = this.head_;
- end.prev = list.last_;
- list.last_.next = end;
- this.length_ += list.length_;
- } else {
- this.head_ = list.head_;
- this.first_ = list.first_;
- this.last_ = list.last_;
- this.length_ = list.length_;
- list.head_ = undefined;
- list.first_ = undefined;
- list.last_ = undefined;
- list.length_ = 0;
- * Returns the current length of the list.
- * @return {number} Length.
-ol.structs.LinkedList.prototype.getLength = function() {
- return this.length_;
-goog.provide('ol.ext.rbush');
-/** @typedef {function(*)} */
-ol.ext.rbush;
-(function() {
-var exports = {};
-var module = {exports: exports};
-var define;
- * @fileoverview
- * @suppress {accessControls, ambiguousFunctionDecl, checkDebuggerStatement, checkRegExp, checkTypes, checkVars, const, constantProperty, deprecated, duplicate, es5Strict, fileoverviewTags, missingProperties, nonStandardJsDocs, strictModuleDepCheck, suspiciousCode, undefinedNames, undefinedVars, unknownDefines, unusedLocalVariables, uselessCode, visibility}
-(function(f){if(typeof exports==="object"&&typeof module!=="undefined"){module.exports=f()}else if(typeof define==="function"&&define.amd){define([],f)}else{var g;if(typeof window!=="undefined"){g=window}else if(typeof global!=="undefined"){g=global}else if(typeof self!=="undefined"){g=self}else{g=this}g.rbush = f()}})(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);var f=new Error("Cannot find module '"+o+"'");throw f.code="MODULE_NOT_FOUND",f}var l=n[o]={exports:{}};t[o][0].call(l.exports,function(e){var n=t[o][1][e];return s(n?n:e)},l,l.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(_dereq_,module,exports){
-'use strict';
-module.exports = partialSort;
-// Floyd-Rivest selection algorithm:
-// Rearrange items so that all items in the [left, k] range are smaller than all items in (k, right];
-// The k-th element will have the (k - left + 1)th smallest value in [left, right]
-function partialSort(arr, k, left, right, compare) {
- left = left || 0;
- right = right || (arr.length - 1);
- compare = compare || defaultCompare;
- while (right > left) {
- if (right - left > 600) {
- var n = right - left + 1;
- var m = k - left + 1;
- var z = Math.log(n);
- var s = 0.5 * Math.exp(2 * z / 3);
- var sd = 0.5 * Math.sqrt(z * s * (n - s) / n) * (m - n / 2 < 0 ? -1 : 1);
- var newLeft = Math.max(left, Math.floor(k - m * s / n + sd));
- var newRight = Math.min(right, Math.floor(k + (n - m) * s / n + sd));
- partialSort(arr, k, newLeft, newRight, compare);
- var t = arr[k];
- var i = left;
- var j = right;
- swap(arr, left, k);
- if (compare(arr[right], t) > 0) swap(arr, left, right);
- while (i < j) {
- swap(arr, i, j);
- i++;
- j--;
- while (compare(arr[i], t) < 0) i++;
- while (compare(arr[j], t) > 0) j--;
- if (compare(arr[left], t) === 0) swap(arr, left, j);
- else {
- j++;
- swap(arr, j, right);
- if (j <= k) left = j + 1;
- if (k <= j) right = j - 1;
-function swap(arr, i, j) {
- var tmp = arr[i];
- arr[i] = arr[j];
- arr[j] = tmp;
-function defaultCompare(a, b) {
- return a < b ? -1 : a > b ? 1 : 0;
-},{}],2:[function(_dereq_,module,exports){
-'use strict';
-module.exports = rbush;
-var quickselect = _dereq_('quickselect');
-function rbush(maxEntries, format) {
- if (!(this instanceof rbush)) return new rbush(maxEntries, format);
- // max entries in a node is 9 by default; min node fill is 40% for best performance
- this._maxEntries = Math.max(4, maxEntries || 9);
- this._minEntries = Math.max(2, Math.ceil(this._maxEntries * 0.4));
- if (format) {
- this._initFormat(format);
- this.clear();
-rbush.prototype = {
- all: function () {
- return this._all(this.data, []);
- search: function (bbox) {
- var node = this.data,
- result = [],
- toBBox = this.toBBox;
- if (!intersects(bbox, node)) return result;
- var nodesToSearch = [],
- i, len, child, childBBox;
- while (node) {
- for (i = 0, len = node.children.length; i < len; i++) {
- child = node.children[i];
- childBBox = node.leaf ? toBBox(child) : child;
- if (intersects(bbox, childBBox)) {
- if (node.leaf) result.push(child);
- else if (contains(bbox, childBBox)) this._all(child, result);
- else nodesToSearch.push(child);
- node = nodesToSearch.pop();
- return result;
- collides: function (bbox) {
- if (!intersects(bbox, node)) return false;
- while (node) {
- if (node.leaf || contains(bbox, childBBox)) return true;
- nodesToSearch.push(child);
- return false;
- load: function (data) {
- if (!(data && data.length)) return this;
- if (data.length < this._minEntries) {
- for (var i = 0, len = data.length; i < len; i++) {
- this.insert(data[i]);
- return this;
- // recursively build the tree with the given data from stratch using OMT algorithm
- var node = this._build(data.slice(), 0, data.length - 1, 0);
- if (!this.data.children.length) {
- // save as is if tree is empty
- this.data = node;
- } else if (this.data.height === node.height) {
- // split root if trees have the same height
- this._splitRoot(this.data, node);
- } else {
- if (this.data.height < node.height) {
- // swap trees if inserted one is bigger
- var tmpNode = this.data;
- this.data = node;
- node = tmpNode;
- // insert the small tree into the large tree at appropriate level
- this._insert(node, this.data.height - node.height - 1, true);
- return this;
- insert: function (item) {
- if (item) this._insert(item, this.data.height - 1);
- return this;
- clear: function () {
- this.data = createNode([]);
- return this;
- remove: function (item, equalsFn) {
- if (!item) return this;
- bbox = this.toBBox(item),
- path = [],
- indexes = [],
- i, parent, index, goingUp;
- // depth-first iterative tree traversal
- while (node || path.length) {
- if (!node) { // go up
- node = path.pop();
- parent = path[path.length - 1];
- i = indexes.pop();
- goingUp = true;
- if (node.leaf) { // check current node
- index = findItem(item, node.children, equalsFn);
- if (index !== -1) {
- // item found, remove the item and condense tree upwards
- node.children.splice(index, 1);
- path.push(node);
- this._condense(path);
- return this;
- if (!goingUp && !node.leaf && contains(node, bbox)) { // go down
- path.push(node);
- indexes.push(i);
- i = 0;
- parent = node;
- node = node.children[0];
- } else if (parent) { // go right
- i++;
- node = parent.children[i];
- goingUp = false;
- } else node = null; // nothing found
- return this;
- toBBox: function (item) { return item; },
- compareMinX: compareNodeMinX,
- compareMinY: compareNodeMinY,
- toJSON: function () { return this.data; },
- fromJSON: function (data) {
- this.data = data;
- return this;
- _all: function (node, result) {
- var nodesToSearch = [];
- while (node) {
- if (node.leaf) result.push.apply(result, node.children);
- else nodesToSearch.push.apply(nodesToSearch, node.children);
- return result;
- _build: function (items, left, right, height) {
- var N = right - left + 1,
- M = this._maxEntries,
- node;
- if (N <= M) {
- // reached leaf level; return leaf
- node = createNode(items.slice(left, right + 1));
- calcBBox(node, this.toBBox);
- return node;
- if (!height) {
- // target height of the bulk-loaded tree
- height = Math.ceil(Math.log(N) / Math.log(M));
- // target number of root entries to maximize storage utilization
- M = Math.ceil(N / Math.pow(M, height - 1));
- node = createNode([]);
- node.leaf = false;
- node.height = height;
- // split the items into M mostly square tiles
- var N2 = Math.ceil(N / M),
- N1 = N2 * Math.ceil(Math.sqrt(M)),
- i, j, right2, right3;
- multiSelect(items, left, right, N1, this.compareMinX);
- for (i = left; i <= right; i += N1) {
- right2 = Math.min(i + N1 - 1, right);
- multiSelect(items, i, right2, N2, this.compareMinY);
- for (j = i; j <= right2; j += N2) {
- right3 = Math.min(j + N2 - 1, right2);
- // pack each entry recursively
- node.children.push(this._build(items, j, right3, height - 1));
- return node;
- _chooseSubtree: function (bbox, node, level, path) {
- var i, len, child, targetNode, area, enlargement, minArea, minEnlargement;
- while (true) {
- path.push(node);
- if (node.leaf || path.length - 1 === level) break;
- minArea = minEnlargement = Infinity;
- area = bboxArea(child);
- enlargement = enlargedArea(bbox, child) - area;
- // choose entry with the least area enlargement
- if (enlargement < minEnlargement) {
- minEnlargement = enlargement;
- minArea = area < minArea ? area : minArea;
- targetNode = child;
- } else if (enlargement === minEnlargement) {
- // otherwise choose one with the smallest area
- if (area < minArea) {
- minArea = area;
- node = targetNode || node.children[0];
- return node;
- _insert: function (item, level, isNode) {
- var toBBox = this.toBBox,
- bbox = isNode ? item : toBBox(item),
- insertPath = [];
- // find the best node for accommodating the item, saving all nodes along the path too
- var node = this._chooseSubtree(bbox, this.data, level, insertPath);
- // put the item into the node
- node.children.push(item);
- extend(node, bbox);
- // split on node overflow; propagate upwards if necessary
- while (level >= 0) {
- if (insertPath[level].children.length > this._maxEntries) {
- this._split(insertPath, level);
- level--;
- } else break;
- // adjust bboxes along the insertion path
- this._adjustParentBBoxes(bbox, insertPath, level);
- // split overflowed node into two
- _split: function (insertPath, level) {
- var node = insertPath[level],
- M = node.children.length,
- m = this._minEntries;
- this._chooseSplitAxis(node, m, M);
- var splitIndex = this._chooseSplitIndex(node, m, M);
- var newNode = createNode(node.children.splice(splitIndex, node.children.length - splitIndex));
- newNode.height = node.height;
- newNode.leaf = node.leaf;
- calcBBox(newNode, this.toBBox);
- if (level) insertPath[level - 1].children.push(newNode);
- else this._splitRoot(node, newNode);
- _splitRoot: function (node, newNode) {
- // split root node
- this.data = createNode([node, newNode]);
- this.data.height = node.height + 1;
- this.data.leaf = false;
- calcBBox(this.data, this.toBBox);
- _chooseSplitIndex: function (node, m, M) {
- var i, bbox1, bbox2, overlap, area, minOverlap, minArea, index;
- minOverlap = minArea = Infinity;
- for (i = m; i <= M - m; i++) {
- bbox1 = distBBox(node, 0, i, this.toBBox);
- bbox2 = distBBox(node, i, M, this.toBBox);
- overlap = intersectionArea(bbox1, bbox2);
- area = bboxArea(bbox1) + bboxArea(bbox2);
- // choose distribution with minimum overlap
- if (overlap < minOverlap) {
- minOverlap = overlap;
- index = i;
- } else if (overlap === minOverlap) {
- // otherwise choose distribution with minimum area
- minArea = area;
- index = i;
- return index;
- // sorts node children by the best axis for split
- _chooseSplitAxis: function (node, m, M) {
- var compareMinX = node.leaf ? this.compareMinX : compareNodeMinX,
- compareMinY = node.leaf ? this.compareMinY : compareNodeMinY,
- xMargin = this._allDistMargin(node, m, M, compareMinX),
- yMargin = this._allDistMargin(node, m, M, compareMinY);
- // if total distributions margin value is minimal for x, sort by minX,
- // otherwise it's already sorted by minY
- if (xMargin < yMargin) node.children.sort(compareMinX);
- // total margin of all possible split distributions where each node is at least m full
- _allDistMargin: function (node, m, M, compare) {
- node.children.sort(compare);
- leftBBox = distBBox(node, 0, m, toBBox),
- rightBBox = distBBox(node, M - m, M, toBBox),
- margin = bboxMargin(leftBBox) + bboxMargin(rightBBox),
- i, child;
- for (i = m; i < M - m; i++) {
- extend(leftBBox, node.leaf ? toBBox(child) : child);
- margin += bboxMargin(leftBBox);
- for (i = M - m - 1; i >= m; i--) {
- extend(rightBBox, node.leaf ? toBBox(child) : child);
- margin += bboxMargin(rightBBox);
- return margin;
- _adjustParentBBoxes: function (bbox, path, level) {
- // adjust bboxes along the given tree path
- for (var i = level; i >= 0; i--) {
- extend(path[i], bbox);
- _condense: function (path) {
- // go through the path, removing empty nodes and updating bboxes
- for (var i = path.length - 1, siblings; i >= 0; i--) {
- if (path[i].children.length === 0) {
- if (i > 0) {
- siblings = path[i - 1].children;
- siblings.splice(siblings.indexOf(path[i]), 1);
- } else this.clear();
- } else calcBBox(path[i], this.toBBox);
- _initFormat: function (format) {
- // data format (minX, minY, maxX, maxY accessors)
- // uses eval-type function compilation instead of just accepting a toBBox function
- // because the algorithms are very sensitive to sorting functions performance,
- // so they should be dead simple and without inner calls
- var compareArr = ['return a', ' - b', ';'];
- this.compareMinX = new Function('a', 'b', compareArr.join(format[0]));
- this.compareMinY = new Function('a', 'b', compareArr.join(format[1]));
- this.toBBox = new Function('a',
- 'return {minX: a' + format[0] +
- ', minY: a' + format[1] +
- ', maxX: a' + format[2] +
- ', maxY: a' + format[3] + '};');
-function findItem(item, items, equalsFn) {
- if (!equalsFn) return items.indexOf(item);
- for (var i = 0; i < items.length; i++) {
- if (equalsFn(item, items[i])) return i;
- return -1;
-// calculate node's bbox from bboxes of its children
-function calcBBox(node, toBBox) {
- distBBox(node, 0, node.children.length, toBBox, node);
-// min bounding rectangle of node children from k to p-1
-function distBBox(node, k, p, toBBox, destNode) {
- if (!destNode) destNode = createNode(null);
- destNode.minX = Infinity;
- destNode.minY = Infinity;
- destNode.maxX = -Infinity;
- destNode.maxY = -Infinity;
- for (var i = k, child; i < p; i++) {
- extend(destNode, node.leaf ? toBBox(child) : child);
- return destNode;
-function extend(a, b) {
- a.minX = Math.min(a.minX, b.minX);
- a.minY = Math.min(a.minY, b.minY);
- a.maxX = Math.max(a.maxX, b.maxX);
- a.maxY = Math.max(a.maxY, b.maxY);
- return a;
-function compareNodeMinX(a, b) { return a.minX - b.minX; }
-function compareNodeMinY(a, b) { return a.minY - b.minY; }
-function bboxArea(a) { return (a.maxX - a.minX) * (a.maxY - a.minY); }
-function bboxMargin(a) { return (a.maxX - a.minX) + (a.maxY - a.minY); }
-function enlargedArea(a, b) {
- return (Math.max(b.maxX, a.maxX) - Math.min(b.minX, a.minX)) *
- (Math.max(b.maxY, a.maxY) - Math.min(b.minY, a.minY));
-function intersectionArea(a, b) {
- var minX = Math.max(a.minX, b.minX),
- minY = Math.max(a.minY, b.minY),
- maxX = Math.min(a.maxX, b.maxX),
- maxY = Math.min(a.maxY, b.maxY);
- return Math.max(0, maxX - minX) *
- Math.max(0, maxY - minY);
-function contains(a, b) {
- return a.minX <= b.minX &&
- a.minY <= b.minY &&
- b.maxX <= a.maxX &&
- b.maxY <= a.maxY;
-function intersects(a, b) {
- return b.minX <= a.maxX &&
- b.minY <= a.maxY &&
- b.maxX >= a.minX &&
- b.maxY >= a.minY;
-function createNode(children) {
- return {
- children: children,
- height: 1,
- leaf: true,
- minX: Infinity,
- minY: Infinity,
- maxX: -Infinity,
- maxY: -Infinity
-// sort an array so that items come in groups of n unsorted items, with groups sorted between each other;
-// combines selection algorithm with binary divide & conquer approach
-function multiSelect(arr, left, right, n, compare) {
- var stack = [left, right],
- mid;
- while (stack.length) {
- right = stack.pop();
- left = stack.pop();
- if (right - left <= n) continue;
- mid = left + Math.ceil((right - left) / n / 2) * n;
- quickselect(arr, mid, left, right, compare);
- stack.push(left, mid, mid, right);
-},{"quickselect":1}]},{},[2])(2)
-ol.ext.rbush = module.exports;
-goog.provide('ol.structs.RBush');
-goog.require('ol.ext.rbush');
-goog.require('ol.extent');
-goog.require('ol.obj');
- * Wrapper around the RBush by Vladimir Agafonkin.
- * @constructor
- * @param {number=} opt_maxEntries Max entries.
- * @see https://github.com/mourner/rbush
- * @struct
- * @template T
-ol.structs.RBush = function(opt_maxEntries) {
- * @private
- this.rbush_ = ol.ext.rbush(opt_maxEntries);
- * A mapping between the objects added to this rbush wrapper
- * and the objects that are actually added to the internal rbush.
- * @private
- * @type {Object.<number, ol.RBushEntry>}
- this.items_ = {};
- * Insert a value into the RBush.
- * @param {ol.Extent} extent Extent.
- * @param {T} value Value.
-ol.structs.RBush.prototype.insert = function(extent, value) {
- /** @type {ol.RBushEntry} */
- var item = {
- minX: extent[0],
- minY: extent[1],
- maxX: extent[2],
- maxY: extent[3],
- value: value
- this.rbush_.insert(item);
- this.items_[ol.getUid(value)] = item;
- * Bulk-insert values into the RBush.
- * @param {Array.<ol.Extent>} extents Extents.
- * @param {Array.<T>} values Values.
-ol.structs.RBush.prototype.load = function(extents, values) {
- var items = new Array(values.length);
- for (var i = 0, l = values.length; i < l; i++) {
- var extent = extents[i];
- var value = values[i];
- var item = {
- minX: extent[0],
- minY: extent[1],
- maxX: extent[2],
- maxY: extent[3],
- value: value
- items[i] = item;
- this.rbush_.load(items);
- * Remove a value from the RBush.
- * @return {boolean} Removed.
-ol.structs.RBush.prototype.remove = function(value) {
- var uid = ol.getUid(value);
- // get the object in which the value was wrapped when adding to the
- // internal rbush. then use that object to do the removal.
- var item = this.items_[uid];
- delete this.items_[uid];
- return this.rbush_.remove(item) !== null;
- * Update the extent of a value in the RBush.
-ol.structs.RBush.prototype.update = function(extent, value) {
- var item = this.items_[ol.getUid(value)];
- var bbox = [item.minX, item.minY, item.maxX, item.maxY];
- if (!ol.extent.equals(bbox, extent)) {
- this.remove(value);
- this.insert(extent, value);
- * Return all values in the RBush.
- * @return {Array.<T>} All.
-ol.structs.RBush.prototype.getAll = function() {
- var items = this.rbush_.all();
- return items.map(function(item) {
- return item.value;
- * Return all values in the given extent.
- * @return {Array.<T>} All in extent.
-ol.structs.RBush.prototype.getInExtent = function(extent) {
- var bbox = {
- minX: extent[0],
- minY: extent[1],
- maxX: extent[2],
- maxY: extent[3]
- var items = this.rbush_.search(bbox);
- * Calls a callback function with each value in the tree.
- * If the callback returns a truthy value, this value is returned without
- * checking the rest of the tree.
- * @param {function(this: S, T): *} callback Callback.
- * @param {S=} opt_this The object to use as `this` in `callback`.
- * @return {*} Callback return value.
- * @template S
-ol.structs.RBush.prototype.forEach = function(callback, opt_this) {
- return this.forEach_(this.getAll(), callback, opt_this);
- * Calls a callback function with each value in the provided extent.
- * @template S
-ol.structs.RBush.prototype.forEachInExtent = function(extent, callback, opt_this) {
- return this.forEach_(this.getInExtent(extent), callback, opt_this);
- * @private
- * @template S
-ol.structs.RBush.prototype.forEach_ = function(values, callback, opt_this) {
- var result;
- result = callback.call(opt_this, values[i]);
- if (result) {
- return result;
- return result;
- * @return {boolean} Is empty.
-ol.structs.RBush.prototype.isEmpty = function() {
- return ol.obj.isEmpty(this.items_);
- * Remove all values from the RBush.
-ol.structs.RBush.prototype.clear = function() {
- this.rbush_.clear();
- this.items_ = {};
- * @param {ol.Extent=} opt_extent Extent.
- * @return {!ol.Extent} Extent.
-ol.structs.RBush.prototype.getExtent = function(opt_extent) {
- // FIXME add getExtent() to rbush
- var data = this.rbush_.data;
- return ol.extent.createOrUpdate(data.minX, data.minY, data.maxX, data.maxY, opt_extent);
-goog.provide('ol.render.webgl.PolygonReplay');
-goog.require('ol.array');
-goog.require('ol.color');
-goog.require('ol.geom.flat.contains');
-goog.require('ol.render.webgl.polygonreplay.defaultshader');
-goog.require('ol.render.webgl.LineStringReplay');
-goog.require('ol.render.webgl.Replay');
-goog.require('ol.render.webgl');
-goog.require('ol.style.Stroke');
-goog.require('ol.structs.LinkedList');
-goog.require('ol.structs.RBush');
-goog.require('ol.webgl.Buffer');
- * @constructor
- * @extends {ol.render.webgl.Replay}
- * @param {number} tolerance Tolerance.
- * @param {ol.Extent} maxExtent Max extent.
- * @struct
- ol.render.webgl.PolygonReplay = function(tolerance, maxExtent) {
- ol.render.webgl.Replay.call(this, tolerance, maxExtent);
- this.lineStringReplay = new ol.render.webgl.LineStringReplay(
- tolerance, maxExtent);
- * @private
- * @type {ol.render.webgl.polygonreplay.defaultshader.Locations}
- this.defaultLocations_ = null;
- * @private
- * @type {Array.<Array.<number>>}
- this.styles_ = [];
- * @private
- * @type {Array.<number>}
- this.styleIndices_ = [];
- * @private
- * @type {{fillColor: (Array.<number>|null),
- * changed: boolean}|null}
- this.state_ = {
- fillColor: null,
- changed: false
- ol.inherits(ol.render.webgl.PolygonReplay, ol.render.webgl.Replay);
- * Draw one polygon.
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {number} stride Stride.
- * @private
- ol.render.webgl.PolygonReplay.prototype.drawCoordinates_ = function(
- // Triangulate the polygon
- var outerRing = new ol.structs.LinkedList();
- var rtree = new ol.structs.RBush();
- // Initialize the outer ring
- var maxX = this.processFlatCoordinates_(flatCoordinates, stride, outerRing, rtree, true);
- // Eliminate holes, if there are any
- var i, ii;
- var holeLists = [];
- var holeList = {
- list: new ol.structs.LinkedList(),
- maxX: undefined
- holeLists.push(holeList);
- holeList.maxX = this.processFlatCoordinates_(holeFlatCoordinates[i],
- stride, holeList.list, rtree, false);
- holeLists.sort(function(a, b) {
- return b.maxX - a.maxX;
- for (i = 0; i < holeLists.length; ++i) {
- this.bridgeHole_(holeLists[i].list, holeLists[i].maxX, outerRing, maxX, rtree);
- this.classifyPoints_(outerRing, rtree, false);
- this.triangulate_(outerRing, rtree);
- * Inserts flat coordinates in a linked list and adds them to the vertex buffer.
- * @private
- * @param {ol.structs.LinkedList} list Linked list.
- * @param {ol.structs.RBush} rtree R-Tree of the polygon.
- * @param {boolean} clockwise Coordinate order should be clockwise.
- * @return {number} Maximum X value.
- ol.render.webgl.PolygonReplay.prototype.processFlatCoordinates_ = function(
- flatCoordinates, stride, list, rtree, clockwise) {
- var isClockwise = ol.geom.flat.orient.linearRingIsClockwise(flatCoordinates,
- 0, flatCoordinates.length, stride);
- var i, ii, maxX;
- var n = this.vertices.length / 2;
- /** @type {ol.WebglPolygonVertex} */
- var start;
- var p0;
- var p1;
- var extents = [];
- var segments = [];
- if (clockwise === isClockwise) {
- start = this.createPoint_(flatCoordinates[0], flatCoordinates[1], n++);
- p0 = start;
- maxX = flatCoordinates[0];
- for (i = stride, ii = flatCoordinates.length; i < ii; i += stride) {
- p1 = this.createPoint_(flatCoordinates[i], flatCoordinates[i + 1], n++);
- segments.push(this.insertItem_(p0, p1, list));
- extents.push([Math.min(p0.x, p1.x), Math.min(p0.y, p1.y), Math.max(p0.x, p1.x),
- Math.max(p0.y, p1.y)]);
- maxX = flatCoordinates[i] > maxX ? flatCoordinates[i] : maxX;
- p0 = p1;
- segments.push(this.insertItem_(p1, start, list));
- } else {
- var end = flatCoordinates.length - stride;
- start = this.createPoint_(flatCoordinates[end], flatCoordinates[end + 1], n++);
- p0 = start;
- maxX = flatCoordinates[end];
- for (i = end - stride, ii = 0; i >= ii; i -= stride) {
- p0 = p1;
- rtree.load(extents, segments);
- return maxX;
- * Classifies the points of a polygon list as convex, reflex. Removes collinear vertices.
- * @private
- * @param {ol.structs.LinkedList} list Polygon ring.
- * @param {boolean} ccw The orientation of the polygon is counter-clockwise.
- * @return {boolean} There were reclassified points.
- ol.render.webgl.PolygonReplay.prototype.classifyPoints_ = function(list, rtree, ccw) {
- var start = list.firstItem();
- var s0 = start;
- var s1 = list.nextItem();
- var pointsReclassified = false;
- do {
- var reflex = ccw ? ol.render.webgl.triangleIsCounterClockwise(s1.p1.x,
- s1.p1.y, s0.p1.x, s0.p1.y, s0.p0.x, s0.p0.y) :
- ol.render.webgl.triangleIsCounterClockwise(s0.p0.x, s0.p0.y, s0.p1.x,
- s0.p1.y, s1.p1.x, s1.p1.y);
- if (reflex === undefined) {
- this.removeItem_(s0, s1, list, rtree);
- pointsReclassified = true;
- if (s1 === start) {
- start = list.getNextItem();
- s1 = s0;
- list.prevItem();
- } else if (s0.p1.reflex !== reflex) {
- s0.p1.reflex = reflex;
- s0 = s1;
- s1 = list.nextItem();
- } while (s0 !== start);
- return pointsReclassified;
- * @private
- * @param {ol.structs.LinkedList} hole Linked list of the hole.
- * @param {number} holeMaxX Maximum X value of the hole.
- * @param {ol.structs.LinkedList} list Linked list of the polygon.
- * @param {number} listMaxX Maximum X value of the polygon.
- ol.render.webgl.PolygonReplay.prototype.bridgeHole_ = function(hole, holeMaxX,
- list, listMaxX, rtree) {
- this.classifyPoints_(hole, rtree, true);
- var seg = hole.firstItem();
- while (seg.p1.x !== holeMaxX) {
- seg = hole.nextItem();
- var p1 = seg.p1;
- var p2 = {x: listMaxX, y: p1.y, i: -1};
- var minDist = Infinity;
- var i, ii, bestPoint;
- var p5;
- var intersectingSegments = this.getIntersections_({p0: p1, p1: p2}, rtree, true);
- for (i = 0, ii = intersectingSegments.length; i < ii; ++i) {
- var currSeg = intersectingSegments[i];
- if (currSeg.p0.reflex === undefined) {
- var intersection = this.calculateIntersection_(p1, p2, currSeg.p0,
- currSeg.p1, true);
- var dist = Math.abs(p1.x - intersection[0]);
- if (dist < minDist) {
- minDist = dist;
- p5 = {x: intersection[0], y: intersection[1], i: -1};
- seg = currSeg;
- if (minDist === Infinity) {
- return;
- bestPoint = seg.p1;
- if (minDist > 0) {
- var pointsInTriangle = this.getPointsInTriangle_(p1, p5, seg.p1, rtree);
- if (pointsInTriangle.length) {
- var theta = Infinity;
- for (i = 0, ii = pointsInTriangle.length; i < ii; ++i) {
- var currPoint = pointsInTriangle[i];
- var currTheta = Math.atan2(p1.y - currPoint.y, p2.x - currPoint.x);
- if (currTheta < theta || (currTheta === theta && currPoint.x < bestPoint.x)) {
- theta = currTheta;
- bestPoint = currPoint;
- seg = list.firstItem();
- while (seg.p1 !== bestPoint) {
- seg = list.nextItem();
- //We clone the bridge points as they can have different convexity.
- var p0Bridge = {x: p1.x, y: p1.y, i: p1.i, reflex: undefined};
- var p1Bridge = {x: seg.p1.x, y: seg.p1.y, i: seg.p1.i, reflex: undefined};
- hole.getNextItem().p0 = p0Bridge;
- this.insertItem_(p1, seg.p1, hole, rtree);
- this.insertItem_(p1Bridge, p0Bridge, hole, rtree);
- seg.p1 = p1Bridge;
- hole.setFirstItem();
- list.concat(hole);
- * @private
- ol.render.webgl.PolygonReplay.prototype.triangulate_ = function(list, rtree) {
- var ccw = false;
- var simple = this.isSimple_(list, rtree);
- // Start clipping ears
- while (list.getLength() > 3) {
- if (simple) {
- if (!this.clipEars_(list, rtree, simple, ccw)) {
- if (!this.classifyPoints_(list, rtree, ccw)) {
- // Due to the behavior of OL's PIP algorithm, the ear clipping cannot
- // introduce touching segments. However, the original data may have some.
- if (!this.resolveLocalSelfIntersections_(list, rtree, true)) {
- break;
- } else {
- // We ran out of ears, try to reclassify.
- // We have a bad polygon, try to resolve local self-intersections.
- if (!this.resolveLocalSelfIntersections_(list, rtree)) {
- simple = this.isSimple_(list, rtree);
- if (!simple) {
- // We have a really bad polygon, try more time consuming methods.
- this.splitPolygon_(list, rtree);
- break;
- } else {
- ccw = !this.isClockwise_(list);
- this.classifyPoints_(list, rtree, ccw);
- if (list.getLength() === 3) {
- var numIndices = this.indices.length;
- this.indices[numIndices++] = list.getPrevItem().p0.i;
- this.indices[numIndices++] = list.getCurrItem().p0.i;
- this.indices[numIndices++] = list.getNextItem().p0.i;
- * @private
- * @param {boolean} simple The polygon is simple.
- * @param {boolean} ccw Orientation of the polygon is counter-clockwise.
- * @return {boolean} There were processed ears.
- ol.render.webgl.PolygonReplay.prototype.clipEars_ = function(list, rtree, simple, ccw) {
- var s0 = list.getPrevItem();
- var s1 = start;
- var s2 = list.nextItem();
- var s3 = list.getNextItem();
- var p0, p1, p2;
- var processedEars = false;
- do {
- p0 = s1.p0;
- p1 = s1.p1;
- p2 = s2.p1;
- if (p1.reflex === false) {
- // We might have a valid ear
- var diagonalIsInside = ccw ? this.diagonalIsInside_(s3.p1, p2, p1, p0,
- s0.p0) : this.diagonalIsInside_(s0.p0, p0, p1, p2, s3.p1);
- if ((simple || this.getIntersections_({p0: p0, p1: p2}, rtree).length === 0) &&
- diagonalIsInside && this.getPointsInTriangle_(p0, p1, p2, rtree, true).length === 0) {
- //The diagonal is completely inside the polygon
- if (simple || p0.reflex === false || p2.reflex === false ||
- ol.geom.flat.orient.linearRingIsClockwise([s0.p0.x, s0.p0.y, p0.x,
- p0.y, p1.x, p1.y, p2.x, p2.y, s3.p1.x, s3.p1.y], 0, 10, 2) === !ccw) {
- //The diagonal is persumably valid, we have an ear
- this.indices[numIndices++] = p0.i;
- this.indices[numIndices++] = p1.i;
- this.indices[numIndices++] = p2.i;
- this.removeItem_(s1, s2, list, rtree);
- if (s2 === start) {
- start = s3;
- processedEars = true;
- // Else we have a reflex point.
- s0 = list.getPrevItem();
- s1 = list.getCurrItem();
- s2 = list.nextItem();
- s3 = list.getNextItem();
- } while (s1 !== start && list.getLength() > 3);
- return processedEars;
- * @private
- * @param {boolean=} opt_touch Resolve touching segments.
- * @return {boolean} There were resolved intersections.
- ol.render.webgl.PolygonReplay.prototype.resolveLocalSelfIntersections_ = function(
- list, rtree, opt_touch) {
- list.nextItem();
- var s0 = start;
- var resolvedIntersections = false;
- do {
- var intersection = this.calculateIntersection_(s0.p0, s0.p1, s1.p0, s1.p1,
- opt_touch);
- if (intersection) {
- var breakCond = false;
- var numVertices = this.vertices.length;
- var n = numVertices / 2;
- var seg = list.prevItem();
- list.removeItem();
- rtree.remove(seg);
- breakCond = (seg === start);
- var p;
- if (opt_touch) {
- if (intersection[0] === s0.p0.x && intersection[1] === s0.p0.y) {
- list.prevItem();
- p = s0.p0;
- s1.p0 = p;
- rtree.remove(s0);
- breakCond = breakCond || (s0 === start);
- } else {
- p = s1.p1;
- s0.p1 = p;
- rtree.remove(s1);
- breakCond = breakCond || (s1 === start);
- } else {
- p = this.createPoint_(intersection[0], intersection[1], n);
- s0.p1 = p;
- s1.p0 = p;
- rtree.update([Math.min(s0.p0.x, s0.p1.x), Math.min(s0.p0.y, s0.p1.y),
- Math.max(s0.p0.x, s0.p1.x), Math.max(s0.p0.y, s0.p1.y)], s0);
- rtree.update([Math.min(s1.p0.x, s1.p1.x), Math.min(s1.p0.y, s1.p1.y),
- Math.max(s1.p0.x, s1.p1.x), Math.max(s1.p0.y, s1.p1.y)], s1);
- this.indices[numIndices++] = seg.p0.i;
- this.indices[numIndices++] = seg.p1.i;
- this.indices[numIndices++] = p.i;
- resolvedIntersections = true;
- if (breakCond) {
- break;
- return resolvedIntersections;
- * @private
- * @return {boolean} The polygon is simple.
- ol.render.webgl.PolygonReplay.prototype.isSimple_ = function(list, rtree) {
- var seg = start;
- do {
- if (this.getIntersections_(seg, rtree).length) {
- return false;
- } while (seg !== start);
- return true;
- * @private
- * @return {boolean} Orientation is clockwise.
- ol.render.webgl.PolygonReplay.prototype.isClockwise_ = function(list) {
- var length = list.getLength() * 2;
- var flatCoordinates = new Array(length);
- var seg = start;
- var i = 0;
- do {
- flatCoordinates[i++] = seg.p0.x;
- flatCoordinates[i++] = seg.p0.y;
- return ol.geom.flat.orient.linearRingIsClockwise(flatCoordinates, 0, length, 2);
- * @private
- ol.render.webgl.PolygonReplay.prototype.splitPolygon_ = function(list, rtree) {
- var s0 = start;
- do {
- var intersections = this.getIntersections_(s0, rtree);
- if (intersections.length) {
- var s1 = intersections[0];
- s0.p1, s1.p0, s1.p1);
- var p = this.createPoint_(intersection[0], intersection[1], n);
- var newPolygon = new ol.structs.LinkedList();
- var newRtree = new ol.structs.RBush();
- this.insertItem_(p, s0.p1, newPolygon, newRtree);
- s0.p1 = p;
- rtree.update([Math.min(s0.p0.x, p.x), Math.min(s0.p0.y, p.y),
- Math.max(s0.p0.x, p.x), Math.max(s0.p0.y, p.y)], s0);
- var currItem = list.nextItem();
- while (currItem !== s1) {
- this.insertItem_(currItem.p0, currItem.p1, newPolygon, newRtree);
- rtree.remove(currItem);
- currItem = list.getCurrItem();
- this.insertItem_(s1.p0, p, newPolygon, newRtree);
- s1.p0 = p;
- rtree.update([Math.min(s1.p1.x, p.x), Math.min(s1.p1.y, p.y),
- Math.max(s1.p1.x, p.x), Math.max(s1.p1.y, p.y)], s1);
- this.classifyPoints_(list, rtree, false);
- this.triangulate_(list, rtree);
- this.classifyPoints_(newPolygon, newRtree, false);
- this.triangulate_(newPolygon, newRtree);
- break;
- s0 = list.nextItem();
- * @private
- * @param {number} x X coordinate.
- * @param {number} y Y coordinate.
- * @param {number} i Index.
- * @return {ol.WebglPolygonVertex} List item.
- ol.render.webgl.PolygonReplay.prototype.createPoint_ = function(x, y, i) {
- this.vertices[numVertices++] = x;
- this.vertices[numVertices++] = y;
- var p = {
- x: x,
- y: y,
- i: i,
- reflex: undefined
- return p;
- * @private
- * @param {ol.WebglPolygonVertex} p0 First point of segment.
- * @param {ol.WebglPolygonVertex} p1 Second point of segment.
- * @param {ol.structs.RBush=} opt_rtree Insert the segment into the R-Tree.
- * @return {ol.WebglPolygonSegment} segment.
- ol.render.webgl.PolygonReplay.prototype.insertItem_ = function(p0, p1, list, opt_rtree) {
- var seg = {
- p0: p0,
- p1: p1
- list.insertItem(seg);
- if (opt_rtree) {
- opt_rtree.insert([Math.min(p0.x, p1.x), Math.min(p0.y, p1.y),
- Math.max(p0.x, p1.x), Math.max(p0.y, p1.y)], seg);
- return seg;
- * @private
- * @param {ol.WebglPolygonSegment} s0 Segment before the remove candidate.
- * @param {ol.WebglPolygonSegment} s1 Remove candidate segment.
- ol.render.webgl.PolygonReplay.prototype.removeItem_ = function(s0, s1, list, rtree) {
- if (list.getCurrItem() === s1) {
- s0.p1 = s1.p1;
- rtree.remove(s1);
- * @private
- * @param {ol.WebglPolygonVertex} p0 First point.
- * @param {ol.WebglPolygonVertex} p1 Second point.
- * @param {ol.WebglPolygonVertex} p2 Third point.
- * @param {boolean=} opt_reflex Only include reflex points.
- * @return {Array.<ol.WebglPolygonVertex>} Points in the triangle.
- ol.render.webgl.PolygonReplay.prototype.getPointsInTriangle_ = function(p0, p1,
- p2, rtree, opt_reflex) {
- var i, ii, j, p;
- var result = [];
- var segmentsInExtent = rtree.getInExtent([Math.min(p0.x, p1.x, p2.x),
- Math.min(p0.y, p1.y, p2.y), Math.max(p0.x, p1.x, p2.x), Math.max(p0.y,
- p1.y, p2.y)]);
- for (i = 0, ii = segmentsInExtent.length; i < ii; ++i) {
- for (j in segmentsInExtent[i]) {
- p = segmentsInExtent[i][j];
- if (typeof p === 'object' && (!opt_reflex || p.reflex)) {
- if ((p.x !== p0.x || p.y !== p0.y) && (p.x !== p1.x || p.y !== p1.y) &&
- (p.x !== p2.x || p.y !== p2.y) && result.indexOf(p) === -1 &&
- ol.geom.flat.contains.linearRingContainsXY([p0.x, p0.y, p1.x, p1.y,
- p2.x, p2.y], 0, 6, 2, p.x, p.y)) {
- result.push(p);
- return result;
- * @private
- * @param {ol.WebglPolygonSegment} segment Segment.
- * @param {boolean=} opt_touch Touching segments should be considered an intersection.
- * @return {Array.<ol.WebglPolygonSegment>} Intersecting segments.
- ol.render.webgl.PolygonReplay.prototype.getIntersections_ = function(segment, rtree, opt_touch) {
- var p0 = segment.p0;
- var p1 = segment.p1;
- var segmentsInExtent = rtree.getInExtent([Math.min(p0.x, p1.x),
- Math.min(p0.y, p1.y), Math.max(p0.x, p1.x), Math.max(p0.y, p1.y)]);
- var result = [];
- var i, ii;
- var currSeg = segmentsInExtent[i];
- if (segment !== currSeg && (opt_touch || currSeg.p0 !== p1 || currSeg.p1 !== p0) &&
- this.calculateIntersection_(p0, p1, currSeg.p0, currSeg.p1, opt_touch)) {
- result.push(currSeg);
- return result;
- * Line intersection algorithm by Paul Bourke.
- * @see http://paulbourke.net/geometry/pointlineplane/
- * @private
- * @param {ol.WebglPolygonVertex} p3 Fourth point.
- * @return {Array.<number>|undefined} Intersection coordinates.
- ol.render.webgl.PolygonReplay.prototype.calculateIntersection_ = function(p0,
- p1, p2, p3, opt_touch) {
- var denom = (p3.y - p2.y) * (p1.x - p0.x) - (p3.x - p2.x) * (p1.y - p0.y);
- if (denom !== 0) {
- var ua = ((p3.x - p2.x) * (p0.y - p2.y) - (p3.y - p2.y) * (p0.x - p2.x)) / denom;
- var ub = ((p1.x - p0.x) * (p0.y - p2.y) - (p1.y - p0.y) * (p0.x - p2.x)) / denom;
- if ((!opt_touch && ua > ol.render.webgl.EPSILON && ua < 1 - ol.render.webgl.EPSILON &&
- ub > ol.render.webgl.EPSILON && ub < 1 - ol.render.webgl.EPSILON) || (opt_touch &&
- ua >= 0 && ua <= 1 && ub >= 0 && ub <= 1)) {
- return [p0.x + ua * (p1.x - p0.x), p0.y + ua * (p1.y - p0.y)];
- return undefined;
- * @private
- * @param {ol.WebglPolygonVertex} p0 Point before the start of the diagonal.
- * @param {ol.WebglPolygonVertex} p1 Start point of the diagonal.
- * @param {ol.WebglPolygonVertex} p2 Ear candidate.
- * @param {ol.WebglPolygonVertex} p3 End point of the diagonal.
- * @param {ol.WebglPolygonVertex} p4 Point after the end of the diagonal.
- * @return {boolean} Diagonal is inside the polygon.
- ol.render.webgl.PolygonReplay.prototype.diagonalIsInside_ = function(p0, p1, p2, p3, p4) {
- if (p1.reflex === undefined || p3.reflex === undefined) {
- return false;
- var p1IsLeftOf = (p2.x - p3.x) * (p1.y - p3.y) > (p2.y - p3.y) * (p1.x - p3.x);
- var p1IsRightOf = (p4.x - p3.x) * (p1.y - p3.y) < (p4.y - p3.y) * (p1.x - p3.x);
- var p3IsLeftOf = (p0.x - p1.x) * (p3.y - p1.y) > (p0.y - p1.y) * (p3.x - p1.x);
- var p3IsRightOf = (p2.x - p1.x) * (p3.y - p1.y) < (p2.y - p1.y) * (p3.x - p1.x);
- var p1InCone = p3.reflex ? p1IsRightOf || p1IsLeftOf : p1IsRightOf && p1IsLeftOf;
- var p3InCone = p1.reflex ? p3IsRightOf || p3IsLeftOf : p3IsRightOf && p3IsLeftOf;
- return p1InCone && p3InCone;
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.drawMultiPolygon = function(multiPolygonGeometry, feature) {
- var polygons = multiPolygonGeometry.getPolygons();
- var stride = multiPolygonGeometry.getStride();
- var currIndex = this.indices.length;
- var currLineIndex = this.lineStringReplay.getCurrentIndex();
- var i, ii, j, jj;
- for (i = 0, ii = polygons.length; i < ii; ++i) {
- var linearRings = polygons[i].getLinearRings();
- if (linearRings.length > 0) {
- var flatCoordinates = linearRings[0].getFlatCoordinates();
- stride, -this.origin[0], -this.origin[1]);
- var holes = [];
- var holeFlatCoords;
- for (j = 1, jj = linearRings.length; j < jj; ++j) {
- holeFlatCoords = linearRings[j].getFlatCoordinates();
- holeFlatCoords = ol.geom.flat.transform.translate(holeFlatCoords, 0, holeFlatCoords.length,
- holes.push(holeFlatCoords);
- this.lineStringReplay.drawPolygonCoordinates(flatCoordinates, holes, stride);
- this.drawCoordinates_(flatCoordinates, holes, stride);
- if (this.indices.length > currIndex) {
- this.startIndices.push(currIndex);
- this.startIndicesFeature.push(feature);
- if (this.state_.changed) {
- this.styleIndices_.push(currIndex);
- this.state_.changed = false;
- if (this.lineStringReplay.getCurrentIndex() > currLineIndex) {
- this.lineStringReplay.setPolygonStyle(feature, currLineIndex);
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.drawPolygon = function(polygonGeometry, feature) {
- var linearRings = polygonGeometry.getLinearRings();
- var stride = polygonGeometry.getStride();
- this.startIndices.push(this.indices.length);
- this.styleIndices_.push(this.indices.length);
- this.lineStringReplay.setPolygonStyle(feature);
- var holes = [];
- var i, ii, holeFlatCoords;
- for (i = 1, ii = linearRings.length; i < ii; ++i) {
- holeFlatCoords = linearRings[i].getFlatCoordinates();
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.finish = function(context) {
- // create, bind, and populate the vertices buffer
- this.verticesBuffer = new ol.webgl.Buffer(this.vertices);
- // create, bind, and populate the indices buffer
- this.indicesBuffer = new ol.webgl.Buffer(this.indices);
- this.lineStringReplay.finish(context);
- //Clean up, if there is nothing to draw
- if (this.styleIndices_.length === 0 && this.styles_.length > 0) {
- this.vertices = null;
- this.indices = null;
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.getDeleteResourcesFunction = function(context) {
- var verticesBuffer = this.verticesBuffer;
- var indicesBuffer = this.indicesBuffer;
- var lineDeleter = this.lineStringReplay.getDeleteResourcesFunction(context);
- return function() {
- context.deleteBuffer(verticesBuffer);
- context.deleteBuffer(indicesBuffer);
- lineDeleter();
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
- // get the program
- var fragmentShader, vertexShader;
- fragmentShader = ol.render.webgl.polygonreplay.defaultshader.fragment;
- vertexShader = ol.render.webgl.polygonreplay.defaultshader.vertex;
- var program = context.getProgram(fragmentShader, vertexShader);
- // get the locations
- var locations;
- if (!this.defaultLocations_) {
- locations =
- new ol.render.webgl.polygonreplay.defaultshader.Locations(gl, program);
- this.defaultLocations_ = locations;
- } else {
- locations = this.defaultLocations_;
- context.useProgram(program);
- // enable the vertex attrib arrays
- gl.enableVertexAttribArray(locations.a_position);
- gl.vertexAttribPointer(locations.a_position, 2, ol.webgl.FLOAT,
- false, 8, 0);
- return locations;
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.shutDownProgram = function(gl, locations) {
- gl.disableVertexAttribArray(locations.a_position);
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
- if (!ol.obj.isEmpty(skippedFeaturesHash)) {
- this.drawReplaySkipping_(gl, context, skippedFeaturesHash);
- } else {
- //Draw by style groups to minimize drawElements() calls.
- var i, start, end, nextStyle;
- end = this.startIndices[this.startIndices.length - 1];
- for (i = this.styleIndices_.length - 1; i >= 0; --i) {
- start = this.styleIndices_[i];
- nextStyle = this.styles_[i];
- this.setFillStyle_(gl, nextStyle);
- this.drawElements(gl, context, start, end);
- end = start;
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
- featureCallback, opt_hitExtent) {
- var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex;
- featureIndex = this.startIndices.length - 2;
- end = this.startIndices[featureIndex + 1];
- groupStart = this.styleIndices_[i];
- while (featureIndex >= 0 &&
- this.startIndices[featureIndex] >= groupStart) {
- start = this.startIndices[featureIndex];
- feature = this.startIndicesFeature[featureIndex];
- featureUid = ol.getUid(feature).toString();
- if (skippedFeaturesHash[featureUid] === undefined &&
- feature.getGeometry() &&
- (opt_hitExtent === undefined || ol.extent.intersects(
- /** @type {Array<number>} */ (opt_hitExtent),
- feature.getGeometry().getExtent()))) {
- var result = featureCallback(feature);
- if (result) {
- return result;
- featureIndex--;
- end = start;
- return undefined;
- * @private
- * @param {Object} skippedFeaturesHash Ids of features to skip.
- ol.render.webgl.PolygonReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash) {
- var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex, featureStart;
- end = start = this.startIndices[featureIndex + 1];
- featureStart = this.startIndices[featureIndex];
- if (skippedFeaturesHash[featureUid]) {
- if (start !== end) {
- end = featureStart;
- featureIndex--;
- start = featureStart;
- start = end = groupStart;
- * @private
- * @param {Array.<number>} color Color.
- ol.render.webgl.PolygonReplay.prototype.setFillStyle_ = function(gl, color) {
- * @inheritDoc
- ol.render.webgl.PolygonReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- var fillStyleColor = fillStyle ? fillStyle.getColor() : [0, 0, 0, 0];
- if (!(fillStyleColor instanceof CanvasGradient) &&
- !(fillStyleColor instanceof CanvasPattern)) {
- fillStyleColor = ol.color.asArray(fillStyleColor).map(function(c, i) {
- return i != 3 ? c / 255 : c;
- }) || ol.render.webgl.defaultFillStyle;
- } else {
- fillStyleColor = ol.render.webgl.defaultFillStyle;
- if (!this.state_.fillColor || !ol.array.equals(fillStyleColor, this.state_.fillColor)) {
- this.state_.fillColor = fillStyleColor;
- this.state_.changed = true;
- this.styles_.push(fillStyleColor);
- //Provide a null stroke style, if no strokeStyle is provided. Required for the draw interaction to work.
- if (strokeStyle) {
- this.lineStringReplay.setFillStrokeStyle(null, strokeStyle);
- } else {
- var nullStrokeStyle = new ol.style.Stroke({
- color: [0, 0, 0, 0],
- lineWidth: 0
- this.lineStringReplay.setFillStrokeStyle(null, nullStrokeStyle);
-goog.provide('ol.render.webgl.TextReplay');
-if (ol.ENABLE_WEBGL) {
- * @constructor
- * @abstract
- * @struct
- ol.render.webgl.TextReplay = function(tolerance, maxExtent) {};
- * @param {ol.style.Text} textStyle Text style.
- ol.render.webgl.TextReplay.prototype.setTextStyle = function(textStyle) {};
- * @param {ol.Coordinate} center Center.
- * @param {number} resolution Resolution.
- * @param {number} rotation Rotation.
- * @param {ol.Size} size Size.
- * @param {number} pixelRatio Pixel ratio.
- * @param {number} opacity Global opacity.
- * @param {Object.<string, boolean>} skippedFeaturesHash Ids of features
- * to skip.
- * @param {function((ol.Feature|ol.render.Feature)): T|undefined} featureCallback Feature callback.
- * @param {boolean} oneByOne Draw features one-by-one for the hit-detecion.
- * @param {ol.Extent=} opt_hitExtent Hit extent: Only features intersecting
- * this extent are checked.
- * @return {T|undefined} Callback result.
- * @template T
- ol.render.webgl.TextReplay.prototype.replay = function(context,
- center, resolution, rotation, size, pixelRatio,
- opacity, skippedFeaturesHash,
- featureCallback, oneByOne, opt_hitExtent) {
- return undefined;
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {ol.geom.Geometry|ol.render.Feature} geometry Geometry.
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- ol.render.webgl.TextReplay.prototype.drawText = function(flatCoordinates, offset,
- end, stride, geometry, feature) {};
- * @abstract
- * @param {ol.webgl.Context} context Context.
- ol.render.webgl.TextReplay.prototype.finish = function(context) {};
- * @param {ol.webgl.Context} context WebGL context.
- * @return {function()} Delete resources function.
- ol.render.webgl.TextReplay.prototype.getDeleteResourcesFunction = function(context) {
- return ol.nullFunction;
-goog.provide('ol.render.webgl.ReplayGroup');
-goog.require('ol.render.replay');
-goog.require('ol.render.ReplayGroup');
-goog.require('ol.render.webgl.CircleReplay');
-goog.require('ol.render.webgl.ImageReplay');
-goog.require('ol.render.webgl.PolygonReplay');
-goog.require('ol.render.webgl.TextReplay');
- * @constructor
- * @extends {ol.render.ReplayGroup}
- * @param {number=} opt_renderBuffer Render buffer.
- * @struct
- ol.render.webgl.ReplayGroup = function(tolerance, maxExtent, opt_renderBuffer) {
- ol.render.ReplayGroup.call(this);
- * @type {ol.Extent}
- * @private
- this.maxExtent_ = maxExtent;
- * @type {number}
- * @private
- this.tolerance_ = tolerance;
- * @type {number|undefined}
- * @private
- this.renderBuffer_ = opt_renderBuffer;
- * @private
- * @type {!Object.<string,
- * Object.<ol.render.ReplayType, ol.render.webgl.Replay>>}
- this.replaysByZIndex_ = {};
- ol.inherits(ol.render.webgl.ReplayGroup, ol.render.ReplayGroup);
- ol.render.webgl.ReplayGroup.prototype.getDeleteResourcesFunction = function(context) {
- var functions = [];
- var zKey;
- for (zKey in this.replaysByZIndex_) {
- var replays = this.replaysByZIndex_[zKey];
- var replayKey;
- for (replayKey in replays) {
- functions.push(
- replays[replayKey].getDeleteResourcesFunction(context));
- var length = functions.length;
- var result;
- for (var i = 0; i < length; i++) {
- result = functions[i].apply(this, arguments);
- return result;
- ol.render.webgl.ReplayGroup.prototype.finish = function(context) {
- var zKey;
- var replayKey;
- replays[replayKey].finish(context);
- * @inheritDoc
- ol.render.webgl.ReplayGroup.prototype.getReplay = function(zIndex, replayType) {
- var zIndexKey = zIndex !== undefined ? zIndex.toString() : '0';
- var replays = this.replaysByZIndex_[zIndexKey];
- if (replays === undefined) {
- replays = {};
- this.replaysByZIndex_[zIndexKey] = replays;
- var replay = replays[replayType];
- if (replay === undefined) {
- * @type {Function}
- var Constructor = ol.render.webgl.ReplayGroup.BATCH_CONSTRUCTORS_[replayType];
- replay = new Constructor(this.tolerance_, this.maxExtent_);
- replays[replayType] = replay;
- return replay;
- * @inheritDoc
- ol.render.webgl.ReplayGroup.prototype.isEmpty = function() {
- return ol.obj.isEmpty(this.replaysByZIndex_);
- * to skip.
- ol.render.webgl.ReplayGroup.prototype.replay = function(context,
- opacity, skippedFeaturesHash) {
- /** @type {Array.<number>} */
- var zs = Object.keys(this.replaysByZIndex_).map(Number);
- zs.sort(ol.array.numberSafeCompareFunction);
- var i, ii, j, jj, replays, replay;
- for (i = 0, ii = zs.length; i < ii; ++i) {
- replays = this.replaysByZIndex_[zs[i].toString()];
- for (j = 0, jj = ol.render.replay.ORDER.length; j < jj; ++j) {
- replay = replays[ol.render.replay.ORDER[j]];
- if (replay !== undefined) {
- replay.replay(context,
- undefined, false);
- * @private
- * to skip.
- * @template T
- ol.render.webgl.ReplayGroup.prototype.replayHitDetection_ = function(context,
- center, resolution, rotation, size, pixelRatio, opacity,
- skippedFeaturesHash, featureCallback, oneByOne, opt_hitExtent) {
- zs.sort(function(a, b) {
- return b - a;
- var i, ii, j, replays, replay, result;
- for (j = ol.render.replay.ORDER.length - 1; j >= 0; --j) {
- result = replay.replay(context,
- skippedFeaturesHash, featureCallback, oneByOne, opt_hitExtent);
- if (result) {
- return result;
- return undefined;
- * @param {ol.Coordinate} coordinate Coordinate.
- * to skip.
- * @param {function((ol.Feature|ol.render.Feature)): T|undefined} callback Feature callback.
- * @template T
- ol.render.webgl.ReplayGroup.prototype.forEachFeatureAtCoordinate = function(
- coordinate, context, center, resolution, rotation, size, pixelRatio,
- callback) {
- var gl = context.getGL();
- gl.bindFramebuffer(
- gl.FRAMEBUFFER, context.getHitDetectionFramebuffer());
- var hitExtent;
- if (this.renderBuffer_ !== undefined) {
- // build an extent around the coordinate, so that only features that
- // intersect this extent are checked
- hitExtent = ol.extent.buffer(
- ol.extent.createOrUpdateFromCoordinate(coordinate),
- resolution * this.renderBuffer_);
- return this.replayHitDetection_(context,
- coordinate, resolution, rotation, ol.render.webgl.ReplayGroup.HIT_DETECTION_SIZE_,
- pixelRatio, opacity, skippedFeaturesHash,
- * @return {?} Callback result.
- function(feature) {
- var imageData = new Uint8Array(4);
- gl.readPixels(0, 0, 1, 1, gl.RGBA, gl.UNSIGNED_BYTE, imageData);
- if (imageData[3] > 0) {
- var result = callback(feature);
- if (result) {
- return result;
- }, true, hitExtent);
- * to skip.
- * @return {boolean} Is there a feature at the given coordinate?
- ol.render.webgl.ReplayGroup.prototype.hasFeatureAtCoordinate = function(
- var hasFeature = this.replayHitDetection_(context,
- * @return {boolean} Is there a feature?
- return imageData[3] > 0;
- }, false);
- return hasFeature !== undefined;
- * @const
- * @private
- ol.render.webgl.ReplayGroup.HIT_DETECTION_SIZE_ = [1, 1];
- * @const
- * @private
- * @type {Object.<ol.render.ReplayType,
- * function(new: ol.render.webgl.Replay, number,
- * ol.Extent)>}
- ol.render.webgl.ReplayGroup.BATCH_CONSTRUCTORS_ = {
- 'Circle': ol.render.webgl.CircleReplay,
- 'Image': ol.render.webgl.ImageReplay,
- 'LineString': ol.render.webgl.LineStringReplay,
- 'Polygon': ol.render.webgl.PolygonReplay,
- 'Text': ol.render.webgl.TextReplay
-goog.provide('ol.render.webgl.Immediate');
-goog.require('ol');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.render.ReplayType');
-goog.require('ol.render.VectorContext');
-goog.require('ol.render.webgl.ReplayGroup');
- * @constructor
- * @extends {ol.render.VectorContext}
- * @struct
- ol.render.webgl.Immediate = function(context, center, resolution, rotation, size, extent, pixelRatio) {
- ol.render.VectorContext.call(this);
- * @private
- this.context_ = context;
- * @private
- this.center_ = center;
- * @private
- this.extent_ = extent;
- * @private
- this.pixelRatio_ = pixelRatio;
- * @private
- this.size_ = size;
- * @private
- this.rotation_ = rotation;
- * @private
- this.resolution_ = resolution;
- * @private
- * @type {ol.style.Image}
- this.imageStyle_ = null;
- * @private
- * @type {ol.style.Fill}
- this.fillStyle_ = null;
- * @private
- * @type {ol.style.Stroke}
- this.strokeStyle_ = null;
- ol.inherits(ol.render.webgl.Immediate, ol.render.VectorContext);
- * Set the rendering style. Note that since this is an immediate rendering API,
- * any `zIndex` on the provided style will be ignored.
- * @param {ol.style.Style} style The rendering style.
- * @override
- * @api
- ol.render.webgl.Immediate.prototype.setStyle = function(style) {
- this.setFillStrokeStyle(style.getFill(), style.getStroke());
- this.setImageStyle(style.getImage());
- * Render a geometry into the canvas. Call
- * {@link ol.render.webgl.Immediate#setStyle} first to set the rendering style.
- * @param {ol.geom.Geometry|ol.render.Feature} geometry The geometry to render.
- * @override
- * @api
- ol.render.webgl.Immediate.prototype.drawGeometry = function(geometry) {
- var type = geometry.getType();
- switch (type) {
- case ol.geom.GeometryType.POINT:
- this.drawPoint(/** @type {ol.geom.Point} */ (geometry), null);
- break;
- case ol.geom.GeometryType.LINE_STRING:
- this.drawLineString(/** @type {ol.geom.LineString} */ (geometry), null);
- break;
- case ol.geom.GeometryType.POLYGON:
- this.drawPolygon(/** @type {ol.geom.Polygon} */ (geometry), null);
- break;
- case ol.geom.GeometryType.MULTI_POINT:
- this.drawMultiPoint(/** @type {ol.geom.MultiPoint} */ (geometry), null);
- break;
- case ol.geom.GeometryType.MULTI_LINE_STRING:
- this.drawMultiLineString(/** @type {ol.geom.MultiLineString} */ (geometry), null);
- break;
- case ol.geom.GeometryType.MULTI_POLYGON:
- this.drawMultiPolygon(/** @type {ol.geom.MultiPolygon} */ (geometry), null);
- break;
- case ol.geom.GeometryType.GEOMETRY_COLLECTION:
- this.drawGeometryCollection(/** @type {ol.geom.GeometryCollection} */ (geometry), null);
- break;
- case ol.geom.GeometryType.CIRCLE:
- this.drawCircle(/** @type {ol.geom.Circle} */ (geometry), null);
- break;
- default:
- // pass
- * @inheritDoc
- * @api
- ol.render.webgl.Immediate.prototype.drawFeature = function(feature, style) {
- var geometry = style.getGeometryFunction()(feature);
- if (!geometry ||
- !ol.extent.intersects(this.extent_, geometry.getExtent())) {
- return;
- this.setStyle(style);
- this.drawGeometry(geometry);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawGeometryCollection = function(geometry, data) {
- var geometries = geometry.getGeometriesArray();
- var i, ii;
- for (i = 0, ii = geometries.length; i < ii; ++i) {
- this.drawGeometry(geometries[i]);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawPoint = function(geometry, data) {
- var context = this.context_;
- var replayGroup = new ol.render.webgl.ReplayGroup(1, this.extent_);
- var replay = /** @type {ol.render.webgl.ImageReplay} */ (
- replayGroup.getReplay(0, ol.render.ReplayType.IMAGE));
- replay.setImageStyle(this.imageStyle_);
- replay.drawPoint(geometry, data);
- replay.finish(context);
- // default colors
- var opacity = 1;
- var skippedFeatures = {};
- var featureCallback;
- var oneByOne = false;
- replay.replay(this.context_, this.center_, this.resolution_, this.rotation_,
- this.size_, this.pixelRatio_, opacity, skippedFeatures, featureCallback,
- oneByOne);
- replay.getDeleteResourcesFunction(context)();
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawMultiPoint = function(geometry, data) {
- replay.drawMultiPoint(geometry, data);
- var opacity = 1;
- oneByOne);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawLineString = function(geometry, data) {
- var replay = /** @type {ol.render.webgl.LineStringReplay} */ (
- replayGroup.getReplay(0, ol.render.ReplayType.LINE_STRING));
- replay.setFillStrokeStyle(null, this.strokeStyle_);
- replay.drawLineString(geometry, data);
- var opacity = 1;
- oneByOne);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawMultiLineString = function(geometry, data) {
- replay.drawMultiLineString(geometry, data);
- var opacity = 1;
- oneByOne);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawPolygon = function(geometry, data) {
- var replay = /** @type {ol.render.webgl.PolygonReplay} */ (
- replayGroup.getReplay(0, ol.render.ReplayType.POLYGON));
- replay.setFillStrokeStyle(this.fillStyle_, this.strokeStyle_);
- replay.drawPolygon(geometry, data);
- var opacity = 1;
- oneByOne);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawMultiPolygon = function(geometry, data) {
- replay.drawMultiPolygon(geometry, data);
- var opacity = 1;
- oneByOne);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.drawCircle = function(geometry, data) {
- var replay = /** @type {ol.render.webgl.CircleReplay} */ (
- replayGroup.getReplay(0, ol.render.ReplayType.CIRCLE));
- replay.drawCircle(geometry, data);
- var opacity = 1;
- oneByOne);
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.setImageStyle = function(imageStyle) {
- this.imageStyle_ = imageStyle;
- * @inheritDoc
- ol.render.webgl.Immediate.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- this.fillStyle_ = fillStyle;
- this.strokeStyle_ = strokeStyle;
-goog.provide('ol.structs.LRUCache');
-goog.require('ol.asserts');
- * Implements a Least-Recently-Used cache where the keys do not conflict with
- * Object's properties (e.g. 'hasOwnProperty' is not allowed as a key). Expiring
- * items from the cache is the responsibility of the user.
- * @constructor
- * @struct
- * @template T
-ol.structs.LRUCache = function() {
- * @private
- * @type {number}
- this.count_ = 0;
- * @private
- * @type {!Object.<string, ol.LRUCacheEntry>}
- this.entries_ = {};
- * @private
- * @type {?ol.LRUCacheEntry}
- this.oldest_ = null;
- * @private
- this.newest_ = null;
- * FIXME empty description for jsdoc
-ol.structs.LRUCache.prototype.clear = function() {
- this.count_ = 0;
- * @param {string} key Key.
- * @return {boolean} Contains key.
-ol.structs.LRUCache.prototype.containsKey = function(key) {
- return this.entries_.hasOwnProperty(key);
- * @param {function(this: S, T, string, ol.structs.LRUCache): ?} f The function
- * to call for every entry from the oldest to the newer. This function takes
- * 3 arguments (the entry value, the entry key and the LRUCache object).
- * The return value is ignored.
- * @param {S=} opt_this The object to use as `this` in `f`.
- * @template S
-ol.structs.LRUCache.prototype.forEach = function(f, opt_this) {
- var entry = this.oldest_;
- while (entry) {
- f.call(opt_this, entry.value_, entry.key_, this);
- entry = entry.newer;
- * @return {T} Value.
-ol.structs.LRUCache.prototype.get = function(key) {
- var entry = this.entries_[key];
- ol.asserts.assert(entry !== undefined,
- 15); // Tried to get a value for a key that does not exist in the cache
- if (entry === this.newest_) {
- return entry.value_;
- } else if (entry === this.oldest_) {
- this.oldest_ = /** @type {ol.LRUCacheEntry} */ (this.oldest_.newer);
- this.oldest_.older = null;
- } else {
- entry.newer.older = entry.older;
- entry.older.newer = entry.newer;
- entry.newer = null;
- entry.older = this.newest_;
- this.newest_.newer = entry;
- this.newest_ = entry;
- * @return {number} Count.
-ol.structs.LRUCache.prototype.getCount = function() {
- return this.count_;
- * @return {Array.<string>} Keys.
-ol.structs.LRUCache.prototype.getKeys = function() {
- var keys = new Array(this.count_);
- var i = 0;
- var entry;
- for (entry = this.newest_; entry; entry = entry.older) {
- keys[i++] = entry.key_;
- return keys;
- * @return {Array.<T>} Values.
-ol.structs.LRUCache.prototype.getValues = function() {
- var values = new Array(this.count_);
- var i = 0;
- var entry;
- values[i++] = entry.value_;
- return values;
- * @return {T} Last value.
-ol.structs.LRUCache.prototype.peekLast = function() {
- return this.oldest_.value_;
- * @return {string} Last key.
-ol.structs.LRUCache.prototype.peekLastKey = function() {
- return this.oldest_.key_;
- * @return {T} value Value.
-ol.structs.LRUCache.prototype.pop = function() {
- delete this.entries_[entry.key_];
- if (entry.newer) {
- entry.newer.older = null;
- this.oldest_ = /** @type {ol.LRUCacheEntry} */ (entry.newer);
- if (!this.oldest_) {
- --this.count_;
-ol.structs.LRUCache.prototype.replace = function(key, value) {
- this.get(key); // update `newest_`
- this.entries_[key].value_ = value;
-ol.structs.LRUCache.prototype.set = function(key, value) {
- ol.asserts.assert(!(key in this.entries_),
- 16); // Tried to set a value for a key that is used already
- var entry = /** @type {ol.LRUCacheEntry} */ ({
- key_: key,
- newer: null,
- older: this.newest_,
- value_: value
- if (!this.newest_) {
- this.oldest_ = entry;
- } else {
- this.entries_[key] = entry;
- ++this.count_;
-// FIXME check against gl.getParameter(webgl.MAX_TEXTURE_SIZE)
-goog.provide('ol.renderer.webgl.Map');
-goog.require('ol.css');
-goog.require('ol.dom');
-goog.require('ol.events');
-goog.require('ol.layer.Layer');
-goog.require('ol.render.Event');
-goog.require('ol.render.EventType');
-goog.require('ol.render.webgl.Immediate');
-goog.require('ol.renderer.Map');
-goog.require('ol.renderer.Type');
-goog.require('ol.source.State');
-goog.require('ol.structs.LRUCache');
-goog.require('ol.structs.PriorityQueue');
-goog.require('ol.webgl');
-goog.require('ol.webgl.Context');
-goog.require('ol.webgl.ContextEventType');
- * @constructor
- * @extends {ol.renderer.Map}
- * @param {Element} container Container.
- * @param {ol.Map} map Map.
- ol.renderer.webgl.Map = function(container, map) {
- ol.renderer.Map.call(this, container, map);
- * @private
- * @type {HTMLCanvasElement}
- this.canvas_ = /** @type {HTMLCanvasElement} */
- (document.createElement('CANVAS'));
- this.canvas_.style.width = '100%';
- this.canvas_.style.height = '100%';
- this.canvas_.style.display = 'block';
- this.canvas_.className = ol.css.CLASS_UNSELECTABLE;
- container.insertBefore(this.canvas_, container.childNodes[0] || null);
- * @private
- * @type {number}
- this.clipTileCanvasWidth_ = 0;
- * @private
- * @type {number}
- this.clipTileCanvasHeight_ = 0;
- * @private
- * @type {CanvasRenderingContext2D}
- this.clipTileContext_ = ol.dom.createCanvasContext2D();
- * @private
- * @type {boolean}
- this.renderedVisible_ = true;
- * @private
- * @type {WebGLRenderingContext}
- this.gl_ = ol.webgl.getContext(this.canvas_, {
- antialias: true,
- depth: true,
- failIfMajorPerformanceCaveat: true,
- preserveDrawingBuffer: false,
- stencil: true
- * @private
- * @type {ol.webgl.Context}
- this.context_ = new ol.webgl.Context(this.canvas_, this.gl_);
- ol.events.listen(this.canvas_, ol.webgl.ContextEventType.LOST,
- this.handleWebGLContextLost, this);
- ol.events.listen(this.canvas_, ol.webgl.ContextEventType.RESTORED,
- this.handleWebGLContextRestored, this);
- * @private
- * @type {ol.structs.LRUCache.<ol.WebglTextureCacheEntry|null>}
- this.textureCache_ = new ol.structs.LRUCache();
- * @private
- * @type {ol.Coordinate}
- this.focus_ = null;
- * @private
- * @type {ol.structs.PriorityQueue.<Array>}
- this.tileTextureQueue_ = new ol.structs.PriorityQueue(
- * @param {Array.<*>} element Element.
- * @return {number} Priority.
- * @this {ol.renderer.webgl.Map}
- (function(element) {
- var tileCenter = /** @type {ol.Coordinate} */ (element[1]);
- var tileResolution = /** @type {number} */ (element[2]);
- var deltaX = tileCenter[0] - this.focus_[0];
- var deltaY = tileCenter[1] - this.focus_[1];
- return 65536 * Math.log(tileResolution) +
- Math.sqrt(deltaX * deltaX + deltaY * deltaY) / tileResolution;
- }).bind(this),
- * @return {string} Key.
- function(element) {
- return /** @type {ol.Tile} */ (element[0]).getKey();
- * @param {?olx.FrameState} frameState Frame state.
- * @return {boolean} false.
- this.loadNextTileTexture_ =
- function(map, frameState) {
- if (!this.tileTextureQueue_.isEmpty()) {
- this.tileTextureQueue_.reprioritize();
- var element = this.tileTextureQueue_.dequeue();
- var tile = /** @type {ol.Tile} */ (element[0]);
- var tileSize = /** @type {ol.Size} */ (element[3]);
- var tileGutter = /** @type {number} */ (element[4]);
- this.bindTileTexture(
- tile, tileSize, tileGutter, ol.webgl.LINEAR, ol.webgl.LINEAR);
- return false;
- }.bind(this);
- * @private
- * @type {number}
- this.textureCacheFrameMarkerCount_ = 0;
- this.initializeGL_();
- ol.inherits(ol.renderer.webgl.Map, ol.renderer.Map);
- * @param {ol.Tile} tile Tile.
- * @param {ol.Size} tileSize Tile size.
- * @param {number} tileGutter Tile gutter.
- * @param {number} magFilter Mag filter.
- * @param {number} minFilter Min filter.
- ol.renderer.webgl.Map.prototype.bindTileTexture = function(tile, tileSize, tileGutter, magFilter, minFilter) {
- var gl = this.getGL();
- var tileKey = tile.getKey();
- if (this.textureCache_.containsKey(tileKey)) {
- var textureCacheEntry = this.textureCache_.get(tileKey);
- gl.bindTexture(ol.webgl.TEXTURE_2D, textureCacheEntry.texture);
- if (textureCacheEntry.magFilter != magFilter) {
- gl.texParameteri(
- ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_MAG_FILTER, magFilter);
- textureCacheEntry.magFilter = magFilter;
- if (textureCacheEntry.minFilter != minFilter) {
- gl.texParameteri(
- ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_MIN_FILTER, minFilter);
- textureCacheEntry.minFilter = minFilter;
- } else {
- var texture = gl.createTexture();
- gl.bindTexture(ol.webgl.TEXTURE_2D, texture);
- if (tileGutter > 0) {
- var clipTileCanvas = this.clipTileContext_.canvas;
- var clipTileContext = this.clipTileContext_;
- if (this.clipTileCanvasWidth_ !== tileSize[0] ||
- this.clipTileCanvasHeight_ !== tileSize[1]) {
- clipTileCanvas.width = tileSize[0];
- clipTileCanvas.height = tileSize[1];
- this.clipTileCanvasWidth_ = tileSize[0];
- this.clipTileCanvasHeight_ = tileSize[1];
- } else {
- clipTileContext.clearRect(0, 0, tileSize[0], tileSize[1]);
- clipTileContext.drawImage(tile.getImage(), tileGutter, tileGutter,
- tileSize[0], tileSize[1], 0, 0, tileSize[0], tileSize[1]);
- gl.texImage2D(ol.webgl.TEXTURE_2D, 0,
- ol.webgl.RGBA, ol.webgl.RGBA,
- ol.webgl.UNSIGNED_BYTE, clipTileCanvas);
- } else {
- ol.webgl.UNSIGNED_BYTE, tile.getImage());
- gl.texParameteri(
- gl.texParameteri(
- gl.texParameteri(ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_S,
- ol.webgl.CLAMP_TO_EDGE);
- gl.texParameteri(ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_T,
- this.textureCache_.set(tileKey, {
- texture: texture,
- magFilter: magFilter,
- minFilter: minFilter
- * @param {ol.render.EventType} type Event type.
- * @param {olx.FrameState} frameState Frame state.
- * @private
- ol.renderer.webgl.Map.prototype.dispatchComposeEvent_ = function(type, frameState) {
- var map = this.getMap();
- if (map.hasListener(type)) {
- var extent = frameState.extent;
- var size = frameState.size;
- var viewState = frameState.viewState;
- var pixelRatio = frameState.pixelRatio;
- var resolution = viewState.resolution;
- var center = viewState.center;
- var rotation = viewState.rotation;
- var vectorContext = new ol.render.webgl.Immediate(context,
- center, resolution, rotation, size, extent, pixelRatio);
- var composeEvent = new ol.render.Event(type, vectorContext,
- frameState, null, context);
- map.dispatchEvent(composeEvent);
- * @inheritDoc
- ol.renderer.webgl.Map.prototype.disposeInternal = function() {
- if (!gl.isContextLost()) {
- this.textureCache_.forEach(
- * @param {?ol.WebglTextureCacheEntry} textureCacheEntry
- * Texture cache entry.
- function(textureCacheEntry) {
- if (textureCacheEntry) {
- gl.deleteTexture(textureCacheEntry.texture);
- this.context_.dispose();
- ol.renderer.Map.prototype.disposeInternal.call(this);
- * @private
- ol.renderer.webgl.Map.prototype.expireCache_ = function(map, frameState) {
- var textureCacheEntry;
- while (this.textureCache_.getCount() - this.textureCacheFrameMarkerCount_ >
- ol.WEBGL_TEXTURE_CACHE_HIGH_WATER_MARK) {
- textureCacheEntry = this.textureCache_.peekLast();
- if (!textureCacheEntry) {
- if (+this.textureCache_.peekLastKey() == frameState.index) {
- break;
- } else {
- --this.textureCacheFrameMarkerCount_;
- } else {
- this.textureCache_.pop();
- * @return {ol.webgl.Context} The context.
- ol.renderer.webgl.Map.prototype.getContext = function() {
- return this.context_;
- * @return {WebGLRenderingContext} GL.
- ol.renderer.webgl.Map.prototype.getGL = function() {
- return this.gl_;
- * @return {ol.structs.PriorityQueue.<Array>} Tile texture queue.
- ol.renderer.webgl.Map.prototype.getTileTextureQueue = function() {
- return this.tileTextureQueue_;
- * @inheritDoc
- ol.renderer.webgl.Map.prototype.getType = function() {
- return ol.renderer.Type.WEBGL;
- * @param {ol.events.Event} event Event.
- * @protected
- ol.renderer.webgl.Map.prototype.handleWebGLContextLost = function(event) {
- event.preventDefault();
- this.textureCache_.clear();
- var renderers = this.getLayerRenderers();
- for (var id in renderers) {
- var renderer = /** @type {ol.renderer.webgl.Layer} */ (renderers[id]);
- renderer.handleWebGLContextLost();
- * @protected
- ol.renderer.webgl.Map.prototype.handleWebGLContextRestored = function() {
- this.getMap().render();
- * @private
- ol.renderer.webgl.Map.prototype.initializeGL_ = function() {
- var gl = this.gl_;
- gl.activeTexture(ol.webgl.TEXTURE0);
- gl.blendFuncSeparate(
- ol.webgl.SRC_ALPHA, ol.webgl.ONE_MINUS_SRC_ALPHA,
- ol.webgl.ONE, ol.webgl.ONE_MINUS_SRC_ALPHA);
- gl.disable(ol.webgl.CULL_FACE);
- gl.disable(ol.webgl.DEPTH_TEST);
- gl.disable(ol.webgl.SCISSOR_TEST);
- gl.disable(ol.webgl.STENCIL_TEST);
- * @return {boolean} Is tile texture loaded.
- ol.renderer.webgl.Map.prototype.isTileTextureLoaded = function(tile) {
- return this.textureCache_.containsKey(tile.getKey());
- * @inheritDoc
- ol.renderer.webgl.Map.prototype.renderFrame = function(frameState) {
- var context = this.getContext();
- if (gl.isContextLost()) {
- return false;
- if (!frameState) {
- if (this.renderedVisible_) {
- this.canvas_.style.display = 'none';
- this.renderedVisible_ = false;
- return false;
- this.focus_ = frameState.focus;
- this.textureCache_.set((-frameState.index).toString(), null);
- ++this.textureCacheFrameMarkerCount_;
- this.dispatchComposeEvent_(ol.render.EventType.PRECOMPOSE, frameState);
- /** @type {Array.<ol.LayerState>} */
- var layerStatesToDraw = [];
- var layerStatesArray = frameState.layerStatesArray;
- ol.array.stableSort(layerStatesArray, ol.renderer.Map.sortByZIndex);
- var viewResolution = frameState.viewState.resolution;
- var i, ii, layerRenderer, layerState;
- for (i = 0, ii = layerStatesArray.length; i < ii; ++i) {
- layerState = layerStatesArray[i];
- if (ol.layer.Layer.visibleAtResolution(layerState, viewResolution) &&
- layerState.sourceState == ol.source.State.READY) {
- layerRenderer = /** @type {ol.renderer.webgl.Layer} */ (this.getLayerRenderer(layerState.layer));
- if (layerRenderer.prepareFrame(frameState, layerState, context)) {
- layerStatesToDraw.push(layerState);
- var width = frameState.size[0] * frameState.pixelRatio;
- var height = frameState.size[1] * frameState.pixelRatio;
- if (this.canvas_.width != width || this.canvas_.height != height) {
- this.canvas_.width = width;
- this.canvas_.height = height;
- gl.bindFramebuffer(ol.webgl.FRAMEBUFFER, null);
- gl.clearColor(0, 0, 0, 0);
- gl.clear(ol.webgl.COLOR_BUFFER_BIT);
- gl.enable(ol.webgl.BLEND);
- gl.viewport(0, 0, this.canvas_.width, this.canvas_.height);
- for (i = 0, ii = layerStatesToDraw.length; i < ii; ++i) {
- layerState = layerStatesToDraw[i];
- layerRenderer.composeFrame(frameState, layerState, context);
- if (!this.renderedVisible_) {
- this.canvas_.style.display = '';
- this.calculateMatrices2D(frameState);
- if (this.textureCache_.getCount() - this.textureCacheFrameMarkerCount_ >
- frameState.postRenderFunctions.push(
- /** @type {ol.PostRenderFunction} */ (this.expireCache_.bind(this))
- frameState.postRenderFunctions.push(this.loadNextTileTexture_);
- frameState.animate = true;
- this.dispatchComposeEvent_(ol.render.EventType.POSTCOMPOSE, frameState);
- this.scheduleRemoveUnusedLayerRenderers(frameState);
- this.scheduleExpireIconCache(frameState);
- * @inheritDoc
- ol.renderer.webgl.Map.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg,
- layerFilter, thisArg2) {
- var result;
- if (this.getGL().isContextLost()) {
- return false;
- var layerStates = frameState.layerStatesArray;
- var numLayers = layerStates.length;
- var i;
- for (i = numLayers - 1; i >= 0; --i) {
- var layerState = layerStates[i];
- var layer = layerState.layer;
- if (ol.layer.Layer.visibleAtResolution(layerState, viewState.resolution) &&
- layerFilter.call(thisArg2, layer)) {
- var layerRenderer = this.getLayerRenderer(layer);
- result = layerRenderer.forEachFeatureAtCoordinate(
- coordinate, frameState, hitTolerance, callback, thisArg);
- if (result) {
- return result;
- return undefined;
- * @inheritDoc
- ol.renderer.webgl.Map.prototype.hasFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, layerFilter, thisArg) {
- var hasFeature = false;
- return false;
- var i;
- layerFilter.call(thisArg, layer)) {
- hasFeature =
- layerRenderer.hasFeatureAtCoordinate(coordinate, frameState);
- if (hasFeature) {
- return true;
- return hasFeature;
- * @inheritDoc
- ol.renderer.webgl.Map.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg,
- return false;
- var result;
- var i;
- var layerRenderer = /** @type {ol.renderer.webgl.Layer} */ (this.getLayerRenderer(layer));
- result = layerRenderer.forEachLayerAtPixel(
- pixel, frameState, callback, thisArg);
- if (result) {
- return result;
- return undefined;
-// FIXME recheck layer/map projection compatibility when projection changes
-// FIXME layer renderers should skip when they can't reproject
-// FIXME add tilt and height?
-goog.provide('ol.Map');
-goog.require('ol.Collection');
-goog.require('ol.CollectionEventType');
-goog.require('ol.MapBrowserEvent');
-goog.require('ol.MapBrowserEventHandler');
-goog.require('ol.MapBrowserEventType');
-goog.require('ol.MapEvent');
-goog.require('ol.MapEventType');
-goog.require('ol.MapProperty');
-goog.require('ol.Object');
-goog.require('ol.ObjectEventType');
-goog.require('ol.TileQueue');
-goog.require('ol.View');
-goog.require('ol.ViewHint');
-goog.require('ol.control');
-goog.require('ol.events.Event');
-goog.require('ol.events.EventType');
-goog.require('ol.functions');
-goog.require('ol.has');
-goog.require('ol.interaction');
-goog.require('ol.layer.Group');
-goog.require('ol.renderer.canvas.Map');
-goog.require('ol.renderer.webgl.Map');
-goog.require('ol.size');
-goog.require('ol.transform');
- * @const
- * @type {string}
-ol.OL_URL = 'https://openlayers.org/';
- * @const
- * @type {string}
-ol.OL_LOGO_URL = 'data:image/png;base64,' +
- 'iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAMAAABEpIrGAAAAA3NCSVQICAjb4U/gAAAACXBI' +
- 'WXMAAAHGAAABxgEXwfpGAAAAGXRFWHRTb2Z0d2FyZQB3d3cuaW5rc2NhcGUub3Jnm+48GgAA' +
- 'AhNQTFRF////AP//AICAgP//AFVVQECA////K1VVSbbbYL/fJ05idsTYJFtbbcjbJllmZszW' +
- 'WMTOIFhoHlNiZszTa9DdUcHNHlNlV8XRIVdiasrUHlZjIVZjaMnVH1RlIFRkH1RkH1ZlasvY' +
- 'asvXVsPQH1VkacnVa8vWIVZjIFRjVMPQa8rXIVVkXsXRsNveIFVkIFZlIVVj3eDeh6GmbMvX' +
- 'H1ZkIFRka8rWbMvXIFVkIFVjIFVkbMvWH1VjbMvWIFVlbcvWIFVla8vVIFVkbMvWbMvVH1Vk' +
- 'bMvWIFVlbcvWIFVkbcvVbMvWjNPbIFVkU8LPwMzNIFVkbczWIFVkbsvWbMvXIFVkRnB8bcvW' +
- '2+TkW8XRIFVkIlZlJVloJlpoKlxrLl9tMmJwOWd0Omh1RXF8TneCT3iDUHiDU8LPVMLPVcLP' +
- 'VcPQVsPPVsPQV8PQWMTQWsTQW8TQXMXSXsXRX4SNX8bSYMfTYcfTYsfTY8jUZcfSZsnUaIqT' +
- 'acrVasrVa8jTa8rWbI2VbMvWbcvWdJObdcvUdszUd8vVeJaee87Yfc3WgJyjhqGnitDYjaar' +
- 'ldPZnrK2oNbborW5o9bbo9fbpLa6q9ndrL3ArtndscDDutzfu8fJwN7gwt7gxc/QyuHhy+Hi' +
- 'zeHi0NfX0+Pj19zb1+Tj2uXk29/e3uLg3+Lh3+bl4uXj4ufl4+fl5Ofl5ufl5ujm5+jmySDn' +
- 'BAAAAFp0Uk5TAAECAgMEBAYHCA0NDg4UGRogIiMmKSssLzU7PkJJT1JTVFliY2hrdHZ3foSF' +
- 'hYeJjY2QkpugqbG1tre5w8zQ09XY3uXn6+zx8vT09vf4+Pj5+fr6/P39/f3+gz7SsAAAAVVJ' +
- 'REFUOMtjYKA7EBDnwCPLrObS1BRiLoJLnte6CQy8FLHLCzs2QUG4FjZ5GbcmBDDjxJBXDWxC' +
- 'Brb8aM4zbkIDzpLYnAcE9VXlJSWlZRU13koIeW57mGx5XjoMZEUqwxWYQaQbSzLSkYGfKFSe' +
- '0QMsX5WbjgY0YS4MBplemI4BdGBW+DQ11eZiymfqQuXZIjqwyadPNoSZ4L+0FVM6e+oGI6g8' +
- 'a9iKNT3o8kVzNkzRg5lgl7p4wyRUL9Yt2jAxVh6mQCogae6GmflI8p0r13VFWTHBQ0rWPW7a' +
- 'hgWVcPm+9cuLoyy4kCJDzCm6d8PSFoh0zvQNC5OjDJhQopPPJqph1doJBUD5tnkbZiUEqaCn' +
- 'B3bTqLTFG1bPn71kw4b+GFdpLElKIzRxxgYgWNYc5SCENVHKeUaltHdXx0dZ8uBI1hJ2UUDg' +
- 'q82CM2MwKeibqAvSO7MCABq0wXEPiqWEAAAAAElFTkSuQmCC';
- * @type {Array.<ol.renderer.Type>}
- * @const
-ol.DEFAULT_RENDERER_TYPES = [
- ol.renderer.Type.CANVAS,
- ol.renderer.Type.WEBGL
- * @classdesc
- * The map is the core component of OpenLayers. For a map to render, a view,
- * one or more layers, and a target container are needed:
- * var map = new ol.Map({
- * view: new ol.View({
- * center: [0, 0],
- * zoom: 1
- * layers: [
- * new ol.layer.Tile({
- * source: new ol.source.OSM()
- * target: 'map'
- * The above snippet creates a map using a {@link ol.layer.Tile} to display
- * {@link ol.source.OSM} OSM data and render it to a DOM element with the
- * id `map`.
- * The constructor places a viewport container (with CSS class name
- * `ol-viewport`) in the target element (see `getViewport()`), and then two
- * further elements within the viewport: one with CSS class name
- * `ol-overlaycontainer-stopevent` for controls and some overlays, and one with
- * CSS class name `ol-overlaycontainer` for other overlays (see the `stopEvent`
- * option of {@link ol.Overlay} for the difference). The map itself is placed in
- * a further element within the viewport.
- * Layers are stored as a `ol.Collection` in layerGroups. A top-level group is
- * provided by the library. This is what is accessed by `getLayerGroup` and
- * `setLayerGroup`. Layers entered in the options are added to this group, and
- * `addLayer` and `removeLayer` change the layer collection in the group.
- * `getLayers` is a convenience function for `getLayerGroup().getLayers()`.
- * Note that `ol.layer.Group` is a subclass of `ol.layer.Base`, so layers
- * entered in the options or added with `addLayer` can be groups, which can
- * contain further groups, and so on.
- * @constructor
- * @extends {ol.Object}
- * @param {olx.MapOptions} options Map options.
- * @fires ol.MapBrowserEvent
- * @fires ol.MapEvent
- * @fires ol.render.Event#postcompose
- * @fires ol.render.Event#precompose
- * @api
-ol.Map = function(options) {
- ol.Object.call(this);
- var optionsInternal = ol.Map.createOptionsInternal(options);
- * @type {boolean}
- * @private
- this.loadTilesWhileAnimating_ =
- options.loadTilesWhileAnimating !== undefined ?
- options.loadTilesWhileAnimating : false;
- * @type {boolean}
- * @private
- this.loadTilesWhileInteracting_ =
- options.loadTilesWhileInteracting !== undefined ?
- options.loadTilesWhileInteracting : false;
- * @private
- * @type {number}
- this.pixelRatio_ = options.pixelRatio !== undefined ?
- options.pixelRatio : ol.has.DEVICE_PIXEL_RATIO;
- * @private
- * @type {Object.<string, string>}
- this.logos_ = optionsInternal.logos;
- * @private
- this.animationDelayKey_;
- * @private
- this.animationDelay_ = function() {
- this.animationDelayKey_ = undefined;
- this.renderFrame_.call(this, Date.now());
- }.bind(this);
- * @private
- * @type {ol.Transform}
- this.coordinateToPixelTransform_ = ol.transform.create();
- * @private
- this.pixelToCoordinateTransform_ = ol.transform.create();
- * @private
- * @type {number}
- this.frameIndex_ = 0;
- * @private
- * @type {?olx.FrameState}
- this.frameState_ = null;
- * The extent at the previous 'moveend' event.
- * @private
- this.previousExtent_ = ol.extent.createEmpty();
- * @private
- * @type {?ol.EventsKey}
- this.viewPropertyListenerKey_ = null;
- * @private
- this.viewChangeListenerKey_ = null;
- * @private
- * @type {Array.<ol.EventsKey>}
- this.layerGroupPropertyListenerKeys_ = null;
- * @private
- * @type {Element}
- this.viewport_ = document.createElement('DIV');
- this.viewport_.className = 'ol-viewport' + (ol.has.TOUCH ? ' ol-touch' : '');
- this.viewport_.style.position = 'relative';
- this.viewport_.style.overflow = 'hidden';
- this.viewport_.style.width = '100%';
- this.viewport_.style.height = '100%';
- // prevent page zoom on IE >= 10 browsers
- this.viewport_.style.msTouchAction = 'none';
- this.viewport_.style.touchAction = 'none';
- * @private
- * @type {!Element}
- this.overlayContainer_ = document.createElement('DIV');
- this.overlayContainer_.className = 'ol-overlaycontainer';
- this.viewport_.appendChild(this.overlayContainer_);
- * @private
- this.overlayContainerStopEvent_ = document.createElement('DIV');
- this.overlayContainerStopEvent_.className = 'ol-overlaycontainer-stopevent';
- var overlayEvents = [
- ol.events.EventType.CLICK,
- ol.events.EventType.DBLCLICK,
- ol.events.EventType.MOUSEDOWN,
- ol.events.EventType.TOUCHSTART,
- ol.events.EventType.MSPOINTERDOWN,
- ol.MapBrowserEventType.POINTERDOWN,
- ol.events.EventType.MOUSEWHEEL,
- ol.events.EventType.WHEEL
- for (var i = 0, ii = overlayEvents.length; i < ii; ++i) {
- ol.events.listen(this.overlayContainerStopEvent_, overlayEvents[i],
- ol.events.Event.stopPropagation);
- this.viewport_.appendChild(this.overlayContainerStopEvent_);
- * @private
- * @type {ol.MapBrowserEventHandler}
- this.mapBrowserEventHandler_ = new ol.MapBrowserEventHandler(this);
- for (var key in ol.MapBrowserEventType) {
- ol.events.listen(this.mapBrowserEventHandler_, ol.MapBrowserEventType[key],
- this.handleMapBrowserEvent, this);
- * @private
- * @type {Element|Document}
- this.keyboardEventTarget_ = optionsInternal.keyboardEventTarget;
- * @private
- this.keyHandlerKeys_ = null;
- ol.events.listen(this.viewport_, ol.events.EventType.WHEEL,
- this.handleBrowserEvent, this);
- ol.events.listen(this.viewport_, ol.events.EventType.MOUSEWHEEL,
- * @type {ol.Collection.<ol.control.Control>}
- * @private
- this.controls_ = optionsInternal.controls;
- * @type {ol.Collection.<ol.interaction.Interaction>}
- * @private
- this.interactions_ = optionsInternal.interactions;
- * @type {ol.Collection.<ol.Overlay>}
- * @private
- this.overlays_ = optionsInternal.overlays;
- * A lookup of overlays by id.
- * @private
- * @type {Object.<string, ol.Overlay>}
- this.overlayIdIndex_ = {};
- * @type {ol.renderer.Map}
- * @private
- this.renderer_ = new /** @type {Function} */ (optionsInternal.rendererConstructor)(this.viewport_, this);
- * @type {function(Event)|undefined}
- * @private
- this.handleResize_;
- * @private
- * @private
- * @type {Array.<ol.PostRenderFunction>}
- this.postRenderFunctions_ = [];
- * @private
- * @type {ol.TileQueue}
- this.tileQueue_ = new ol.TileQueue(
- this.getTilePriority.bind(this),
- this.handleTileChange_.bind(this));
- * Uids of features to skip at rendering time.
- * @type {Object.<string, boolean>}
- * @private
- this.skippedFeatureUids_ = {};
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.MapProperty.LAYERGROUP),
- this.handleLayerGroupChanged_, this);
- ol.events.listen(this, ol.Object.getChangeEventType(ol.MapProperty.VIEW),
- this.handleViewChanged_, this);
- ol.events.listen(this, ol.Object.getChangeEventType(ol.MapProperty.SIZE),
- this.handleSizeChanged_, this);
- ol.events.listen(this, ol.Object.getChangeEventType(ol.MapProperty.TARGET),
- this.handleTargetChanged_, this);
- // setProperties will trigger the rendering of the map if the map
- // is "defined" already.
- this.setProperties(optionsInternal.values);
- this.controls_.forEach(
- * @param {ol.control.Control} control Control.
- * @this {ol.Map}
- function(control) {
- control.setMap(this);
- }, this);
- ol.events.listen(this.controls_, ol.CollectionEventType.ADD,
- * @param {ol.Collection.Event} event Collection event.
- function(event) {
- event.element.setMap(this);
- }, this);
- ol.events.listen(this.controls_, ol.CollectionEventType.REMOVE,
- function(event) {
- event.element.setMap(null);
- }, this);
- this.interactions_.forEach(
- * @param {ol.interaction.Interaction} interaction Interaction.
- * @this {ol.Map}
- function(interaction) {
- interaction.setMap(this);
- }, this);
- ol.events.listen(this.interactions_, ol.CollectionEventType.ADD,
- function(event) {
- }, this);
- ol.events.listen(this.interactions_, ol.CollectionEventType.REMOVE,
- function(event) {
- }, this);
- this.overlays_.forEach(this.addOverlayInternal_, this);
- ol.events.listen(this.overlays_, ol.CollectionEventType.ADD,
- function(event) {
- this.addOverlayInternal_(/** @type {ol.Overlay} */ (event.element));
- }, this);
- ol.events.listen(this.overlays_, ol.CollectionEventType.REMOVE,
- function(event) {
- var overlay = /** @type {ol.Overlay} */ (event.element);
- var id = overlay.getId();
- if (id !== undefined) {
- delete this.overlayIdIndex_[id.toString()];
- }, this);
-ol.inherits(ol.Map, ol.Object);
- * Add the given control to the map.
- * @api
-ol.Map.prototype.addControl = function(control) {
- this.getControls().push(control);
- * Add the given interaction to the map.
- * @param {ol.interaction.Interaction} interaction Interaction to add.
- * @api
-ol.Map.prototype.addInteraction = function(interaction) {
- this.getInteractions().push(interaction);
- * Adds the given layer to the top of this map. If you want to add a layer
- * elsewhere in the stack, use `getLayers()` and the methods available on
- * {@link ol.Collection}.
- * @param {ol.layer.Base} layer Layer.
- * @api
-ol.Map.prototype.addLayer = function(layer) {
- var layers = this.getLayerGroup().getLayers();
- layers.push(layer);
- * Add the given overlay to the map.
- * @param {ol.Overlay} overlay Overlay.
- * @api
-ol.Map.prototype.addOverlay = function(overlay) {
- this.getOverlays().push(overlay);
- * This deals with map's overlay collection changes.
- * @private
-ol.Map.prototype.addOverlayInternal_ = function(overlay) {
- this.overlayIdIndex_[id.toString()] = overlay;
- overlay.setMap(this);
- * @inheritDoc
-ol.Map.prototype.disposeInternal = function() {
- this.mapBrowserEventHandler_.dispose();
- this.renderer_.dispose();
- ol.events.unlisten(this.viewport_, ol.events.EventType.WHEEL,
- ol.events.unlisten(this.viewport_, ol.events.EventType.MOUSEWHEEL,
- if (this.handleResize_ !== undefined) {
- window.removeEventListener(ol.events.EventType.RESIZE,
- this.handleResize_, false);
- this.handleResize_ = undefined;
- if (this.animationDelayKey_) {
- cancelAnimationFrame(this.animationDelayKey_);
- this.setTarget(null);
- ol.Object.prototype.disposeInternal.call(this);
- * Detect features that intersect a pixel on the viewport, and execute a
- * callback with each intersecting feature. Layers included in the detection can
- * be configured through `opt_layerFilter`.
- * @param {ol.Pixel} pixel Pixel.
- * @param {function(this: S, (ol.Feature|ol.render.Feature),
- * ol.layer.Layer): T} callback Feature callback. The callback will be
- * called with two arguments. The first argument is one
- * {@link ol.Feature feature} or
- * {@link ol.render.Feature render feature} at the pixel, the second is
- * the {@link ol.layer.Layer layer} of the feature and will be null for
- * unmanaged layers. To stop detection, callback functions can return a
- * truthy value.
- * @param {olx.AtPixelOptions=} opt_options Optional options.
- * @return {T|undefined} Callback result, i.e. the return value of last
- * callback execution, or the first truthy callback return value.
- * @template S,T
- * @api
-ol.Map.prototype.forEachFeatureAtPixel = function(pixel, callback, opt_options) {
- if (!this.frameState_) {
- return;
- var coordinate = this.getCoordinateFromPixel(pixel);
- opt_options = opt_options !== undefined ? opt_options : {};
- var hitTolerance = opt_options.hitTolerance !== undefined ?
- opt_options.hitTolerance * this.frameState_.pixelRatio : 0;
- var layerFilter = opt_options.layerFilter !== undefined ?
- opt_options.layerFilter : ol.functions.TRUE;
- return this.renderer_.forEachFeatureAtCoordinate(
- coordinate, this.frameState_, hitTolerance, callback, null,
- layerFilter, null);
- * Detect layers that have a color value at a pixel on the viewport, and
- * execute a callback with each matching layer. Layers included in the
- * detection can be configured through `opt_layerFilter`.
- * @param {function(this: S, ol.layer.Layer, (Uint8ClampedArray|Uint8Array)): T} callback
- * Layer callback. This callback will recieve two arguments: first is the
- * {@link ol.layer.Layer layer}, second argument is an array representing
- * [R, G, B, A] pixel values (0 - 255) and will be `null` for layer types
- * that do not currently support this argument. To stop detection, callback
- * functions can return a truthy value.
- * @param {S=} opt_this Value to use as `this` when executing `callback`.
- * @param {(function(this: U, ol.layer.Layer): boolean)=} opt_layerFilter Layer
- * filter function. The filter function will receive one argument, the
- * {@link ol.layer.Layer layer-candidate} and it should return a boolean
- * value. Only layers which are visible and for which this function returns
- * `true` will be tested for features. By default, all visible layers will
- * be tested.
- * @param {U=} opt_this2 Value to use as `this` when executing `layerFilter`.
- * @template S,T,U
- * @api
-ol.Map.prototype.forEachLayerAtPixel = function(pixel, callback, opt_this, opt_layerFilter, opt_this2) {
- return;
- var thisArg = opt_this !== undefined ? opt_this : null;
- var layerFilter = opt_layerFilter !== undefined ?
- opt_layerFilter : ol.functions.TRUE;
- var thisArg2 = opt_this2 !== undefined ? opt_this2 : null;
- return this.renderer_.forEachLayerAtPixel(
- pixel, this.frameState_, callback, thisArg,
- layerFilter, thisArg2);
- * Detect if features intersect a pixel on the viewport. Layers included in the
- * @return {boolean} Is there a feature at the given pixel?
- * @template U
- * @api
-ol.Map.prototype.hasFeatureAtPixel = function(pixel, opt_options) {
- return false;
- return this.renderer_.hasFeatureAtCoordinate(
- coordinate, this.frameState_, hitTolerance, layerFilter, null);
- * Returns the coordinate in view projection for a browser event.
- * @param {Event} event Event.
- * @return {ol.Coordinate} Coordinate.
- * @api
-ol.Map.prototype.getEventCoordinate = function(event) {
- return this.getCoordinateFromPixel(this.getEventPixel(event));
- * Returns the map pixel position for a browser event relative to the viewport.
- * @return {ol.Pixel} Pixel.
- * @api
-ol.Map.prototype.getEventPixel = function(event) {
- var viewportPosition = this.viewport_.getBoundingClientRect();
- var eventPosition = event.changedTouches ? event.changedTouches[0] : event;
- return [
- eventPosition.clientX - viewportPosition.left,
- eventPosition.clientY - viewportPosition.top
- * Get the target in which this map is rendered.
- * Note that this returns what is entered as an option or in setTarget:
- * if that was an element, it returns an element; if a string, it returns that.
- * @return {Element|string|undefined} The Element or id of the Element that the
- * map is rendered in.
- * @observable
- * @api
-ol.Map.prototype.getTarget = function() {
- return /** @type {Element|string|undefined} */ (
- this.get(ol.MapProperty.TARGET));
- * Get the DOM element into which this map is rendered. In contrast to
- * `getTarget` this method always return an `Element`, or `null` if the
- * map has no target.
- * @return {Element} The element that the map is rendered in.
- * @api
-ol.Map.prototype.getTargetElement = function() {
- var target = this.getTarget();
- if (target !== undefined) {
- return typeof target === 'string' ?
- document.getElementById(target) :
- target;
- } else {
- return null;
- * Get the coordinate for a given pixel. This returns a coordinate in the
- * map view projection.
- * @param {ol.Pixel} pixel Pixel position in the map viewport.
- * @return {ol.Coordinate} The coordinate for the pixel position.
- * @api
-ol.Map.prototype.getCoordinateFromPixel = function(pixel) {
- var frameState = this.frameState_;
- return null;
- } else {
- return ol.transform.apply(frameState.pixelToCoordinateTransform, pixel.slice());
- * Get the map controls. Modifying this collection changes the controls
- * associated with the map.
- * @return {ol.Collection.<ol.control.Control>} Controls.
- * @api
-ol.Map.prototype.getControls = function() {
- return this.controls_;
- * Get the map overlays. Modifying this collection changes the overlays
- * @return {ol.Collection.<ol.Overlay>} Overlays.
- * @api
-ol.Map.prototype.getOverlays = function() {
- return this.overlays_;
- * Get an overlay by its identifier (the value returned by overlay.getId()).
- * Note that the index treats string and numeric identifiers as the same. So
- * `map.getOverlayById(2)` will return an overlay with id `'2'` or `2`.
- * @param {string|number} id Overlay identifier.
- * @return {ol.Overlay} Overlay.
- * @api
-ol.Map.prototype.getOverlayById = function(id) {
- var overlay = this.overlayIdIndex_[id.toString()];
- return overlay !== undefined ? overlay : null;
- * Get the map interactions. Modifying this collection changes the interactions
- * Interactions are used for e.g. pan, zoom and rotate.
- * @return {ol.Collection.<ol.interaction.Interaction>} Interactions.
- * @api
-ol.Map.prototype.getInteractions = function() {
- return this.interactions_;
- * Get the layergroup associated with this map.
- * @return {ol.layer.Group} A layer group containing the layers in this map.
- * @observable
- * @api
-ol.Map.prototype.getLayerGroup = function() {
- return /** @type {ol.layer.Group} */ (this.get(ol.MapProperty.LAYERGROUP));
- * Get the collection of layers associated with this map.
- * @return {!ol.Collection.<ol.layer.Base>} Layers.
- * @api
-ol.Map.prototype.getLayers = function() {
- return layers;
- * Get the pixel for a coordinate. This takes a coordinate in the map view
- * projection and returns the corresponding pixel.
- * @param {ol.Coordinate} coordinate A map coordinate.
- * @return {ol.Pixel} A pixel position in the map viewport.
- * @api
-ol.Map.prototype.getPixelFromCoordinate = function(coordinate) {
- return null;
- } else {
- return ol.transform.apply(frameState.coordinateToPixelTransform,
- coordinate.slice(0, 2));
- * Get the map renderer.
- * @return {ol.renderer.Map} Renderer
-ol.Map.prototype.getRenderer = function() {
- return this.renderer_;
- * Get the size of this map.
- * @return {ol.Size|undefined} The size in pixels of the map in the DOM.
- * @observable
- * @api
-ol.Map.prototype.getSize = function() {
- return /** @type {ol.Size|undefined} */ (this.get(ol.MapProperty.SIZE));
- * Get the view associated with this map. A view manages properties such as
- * center and resolution.
- * @return {ol.View} The view that controls this map.
- * @observable
- * @api
-ol.Map.prototype.getView = function() {
- return /** @type {ol.View} */ (this.get(ol.MapProperty.VIEW));
- * Get the element that serves as the map viewport.
- * @return {Element} Viewport.
- * @api
-ol.Map.prototype.getViewport = function() {
- return this.viewport_;
- * Get the element that serves as the container for overlays. Elements added to
- * this container will let mousedown and touchstart events through to the map,
- * so clicks and gestures on an overlay will trigger {@link ol.MapBrowserEvent}
- * events.
- * @return {!Element} The map's overlay container.
-ol.Map.prototype.getOverlayContainer = function() {
- return this.overlayContainer_;
- * Get the element that serves as a container for overlays that don't allow
- * event propagation. Elements added to this container won't let mousedown and
- * touchstart events through to the map, so clicks and gestures on an overlay
- * don't trigger any {@link ol.MapBrowserEvent}.
- * @return {!Element} The map's overlay container that stops events.
-ol.Map.prototype.getOverlayContainerStopEvent = function() {
- return this.overlayContainerStopEvent_;
- * @param {string} tileSourceKey Tile source key.
- * @param {ol.Coordinate} tileCenter Tile center.
- * @param {number} tileResolution Tile resolution.
- * @return {number} Tile priority.
-ol.Map.prototype.getTilePriority = function(tile, tileSourceKey, tileCenter, tileResolution) {
- // Filter out tiles at higher zoom levels than the current zoom level, or that
- // are outside the visible extent.
- if (!frameState || !(tileSourceKey in frameState.wantedTiles)) {
- return ol.structs.PriorityQueue.DROP;
- if (!frameState.wantedTiles[tileSourceKey][tile.getKey()]) {
- // Prioritize the highest zoom level tiles closest to the focus.
- // Tiles at higher zoom levels are prioritized using Math.log(tileResolution).
- // Within a zoom level, tiles are prioritized by the distance in pixels
- // between the center of the tile and the focus. The factor of 65536 means
- // that the prioritization should behave as desired for tiles up to
- // 65536 * Math.log(2) = 45426 pixels from the focus.
- var deltaX = tileCenter[0] - frameState.focus[0];
- var deltaY = tileCenter[1] - frameState.focus[1];
- * @param {Event} browserEvent Browser event.
- * @param {string=} opt_type Type.
-ol.Map.prototype.handleBrowserEvent = function(browserEvent, opt_type) {
- var type = opt_type || browserEvent.type;
- var mapBrowserEvent = new ol.MapBrowserEvent(type, this, browserEvent);
- this.handleMapBrowserEvent(mapBrowserEvent);
- * @param {ol.MapBrowserEvent} mapBrowserEvent The event to handle.
-ol.Map.prototype.handleMapBrowserEvent = function(mapBrowserEvent) {
- // With no view defined, we cannot translate pixels into geographical
- // coordinates so interactions cannot be used.
- return;
- this.focus_ = mapBrowserEvent.coordinate;
- mapBrowserEvent.frameState = this.frameState_;
- var interactionsArray = this.getInteractions().getArray();
- var i;
- if (this.dispatchEvent(mapBrowserEvent) !== false) {
- for (i = interactionsArray.length - 1; i >= 0; i--) {
- var interaction = interactionsArray[i];
- if (!interaction.getActive()) {
- continue;
- var cont = interaction.handleEvent(mapBrowserEvent);
- if (!cont) {
- break;
- * @protected
-ol.Map.prototype.handlePostRender = function() {
- // Manage the tile queue
- // Image loads are expensive and a limited resource, so try to use them
- // efficiently:
- // * When the view is static we allow a large number of parallel tile loads
- // to complete the frame as quickly as possible.
- // * When animating or interacting, image loads can cause janks, so we reduce
- // the maximum number of loads per frame and limit the number of parallel
- // tile loads to remain reactive to view changes and to reduce the chance of
- // loading tiles that will quickly disappear from view.
- var tileQueue = this.tileQueue_;
- if (!tileQueue.isEmpty()) {
- var maxTotalLoading = 16;
- var maxNewLoads = maxTotalLoading;
- if (frameState) {
- var hints = frameState.viewHints;
- if (hints[ol.ViewHint.ANIMATING]) {
- maxTotalLoading = this.loadTilesWhileAnimating_ ? 8 : 0;
- maxNewLoads = 2;
- if (hints[ol.ViewHint.INTERACTING]) {
- maxTotalLoading = this.loadTilesWhileInteracting_ ? 8 : 0;
- maxNewLoads = 2;
- if (tileQueue.getTilesLoading() < maxTotalLoading) {
- tileQueue.reprioritize(); // FIXME only call if view has changed
- tileQueue.loadMoreTiles(maxTotalLoading, maxNewLoads);
- var postRenderFunctions = this.postRenderFunctions_;
- var i, ii;
- for (i = 0, ii = postRenderFunctions.length; i < ii; ++i) {
- postRenderFunctions[i](this, frameState);
- postRenderFunctions.length = 0;
- * @private
-ol.Map.prototype.handleSizeChanged_ = function() {
- this.render();
- * @private
-ol.Map.prototype.handleTargetChanged_ = function() {
- // target may be undefined, null, a string or an Element.
- // If it's a string we convert it to an Element before proceeding.
- // If it's not now an Element we remove the viewport from the DOM.
- // If it's an Element we append the viewport element to it.
- var targetElement;
- if (this.getTarget()) {
- targetElement = this.getTargetElement();
- if (this.keyHandlerKeys_) {
- for (var i = 0, ii = this.keyHandlerKeys_.length; i < ii; ++i) {
- ol.events.unlistenByKey(this.keyHandlerKeys_[i]);
- if (!targetElement) {
- ol.dom.removeNode(this.viewport_);
- } else {
- targetElement.appendChild(this.viewport_);
- var keyboardEventTarget = !this.keyboardEventTarget_ ?
- targetElement : this.keyboardEventTarget_;
- this.keyHandlerKeys_ = [
- ol.events.listen(keyboardEventTarget, ol.events.EventType.KEYDOWN,
- this.handleBrowserEvent, this),
- ol.events.listen(keyboardEventTarget, ol.events.EventType.KEYPRESS,
- if (!this.handleResize_) {
- this.handleResize_ = this.updateSize.bind(this);
- window.addEventListener(ol.events.EventType.RESIZE,
- this.updateSize();
- // updateSize calls setSize, so no need to call this.render
- // ourselves here.
- * @private
-ol.Map.prototype.handleTileChange_ = function() {
- this.render();
- * @private
-ol.Map.prototype.handleViewPropertyChanged_ = function() {
- this.render();
- * @private
-ol.Map.prototype.handleViewChanged_ = function() {
- if (this.viewPropertyListenerKey_) {
- ol.events.unlistenByKey(this.viewPropertyListenerKey_);
- if (this.viewChangeListenerKey_) {
- ol.events.unlistenByKey(this.viewChangeListenerKey_);
- var view = this.getView();
- if (view) {
- this.viewport_.setAttribute('data-view', ol.getUid(view));
- this.viewPropertyListenerKey_ = ol.events.listen(
- view, ol.ObjectEventType.PROPERTYCHANGE,
- this.handleViewPropertyChanged_, this);
- this.viewChangeListenerKey_ = ol.events.listen(
- view, ol.events.EventType.CHANGE,
- this.render();
- * @private
-ol.Map.prototype.handleLayerGroupChanged_ = function() {
- if (this.layerGroupPropertyListenerKeys_) {
- this.layerGroupPropertyListenerKeys_.forEach(ol.events.unlistenByKey);
- var layerGroup = this.getLayerGroup();
- if (layerGroup) {
- this.layerGroupPropertyListenerKeys_ = [
- ol.events.listen(
- layerGroup, ol.ObjectEventType.PROPERTYCHANGE,
- this.render, this),
- ol.events.listen(
- layerGroup, ol.events.EventType.CHANGE,
- this.render();
- * @return {boolean} Is rendered.
-ol.Map.prototype.isRendered = function() {
- return !!this.frameState_;
- * Requests an immediate render in a synchronous manner.
- * @api
-ol.Map.prototype.renderSync = function() {
- this.animationDelay_();
- * Request a map rendering (at the next animation frame).
- * @api
-ol.Map.prototype.render = function() {
- if (this.animationDelayKey_ === undefined) {
- this.animationDelayKey_ = requestAnimationFrame(
- this.animationDelay_);
- * Remove the given control from the map.
- * @return {ol.control.Control|undefined} The removed control (or undefined
- * if the control was not found).
- * @api
-ol.Map.prototype.removeControl = function(control) {
- return this.getControls().remove(control);
- * Remove the given interaction from the map.
- * @param {ol.interaction.Interaction} interaction Interaction to remove.
- * @return {ol.interaction.Interaction|undefined} The removed interaction (or
- * undefined if the interaction was not found).
- * @api
-ol.Map.prototype.removeInteraction = function(interaction) {
- return this.getInteractions().remove(interaction);
- * Removes the given layer from the map.
- * @return {ol.layer.Base|undefined} The removed layer (or undefined if the
- * layer was not found).
- * @api
-ol.Map.prototype.removeLayer = function(layer) {
- return layers.remove(layer);
- * Remove the given overlay from the map.
- * @return {ol.Overlay|undefined} The removed overlay (or undefined
- * if the overlay was not found).
- * @api
-ol.Map.prototype.removeOverlay = function(overlay) {
- return this.getOverlays().remove(overlay);
- * @param {number} time Time.
- * @private
-ol.Map.prototype.renderFrame_ = function(time) {
- var i, ii, viewState;
- var size = this.getSize();
- var extent = ol.extent.createEmpty();
- /** @type {?olx.FrameState} */
- var frameState = null;
- if (size !== undefined && ol.size.hasArea(size) && view && view.isDef()) {
- var viewHints = view.getHints(this.frameState_ ? this.frameState_.viewHints : undefined);
- var layerStatesArray = this.getLayerGroup().getLayerStatesArray();
- var layerStates = {};
- layerStates[ol.getUid(layerStatesArray[i].layer)] = layerStatesArray[i];
- viewState = view.getState();
- frameState = /** @type {olx.FrameState} */ ({
- animate: false,
- attributions: {},
- coordinateToPixelTransform: this.coordinateToPixelTransform_,
- extent: extent,
- focus: !this.focus_ ? viewState.center : this.focus_,
- index: this.frameIndex_++,
- layerStates: layerStates,
- layerStatesArray: layerStatesArray,
- logos: ol.obj.assign({}, this.logos_),
- pixelRatio: this.pixelRatio_,
- pixelToCoordinateTransform: this.pixelToCoordinateTransform_,
- postRenderFunctions: [],
- size: size,
- skippedFeatureUids: this.skippedFeatureUids_,
- tileQueue: this.tileQueue_,
- time: time,
- usedTiles: {},
- viewState: viewState,
- viewHints: viewHints,
- wantedTiles: {}
- if (frameState) {
- frameState.extent = ol.extent.getForViewAndSize(viewState.center,
- viewState.resolution, viewState.rotation, frameState.size, extent);
- this.frameState_ = frameState;
- this.renderer_.renderFrame(frameState);
- if (frameState) {
- if (frameState.animate) {
- this.render();
- Array.prototype.push.apply(
- this.postRenderFunctions_, frameState.postRenderFunctions);
- var idle = !frameState.viewHints[ol.ViewHint.ANIMATING] &&
- !frameState.viewHints[ol.ViewHint.INTERACTING] &&
- !ol.extent.equals(frameState.extent, this.previousExtent_);
- if (idle) {
- this.dispatchEvent(
- new ol.MapEvent(ol.MapEventType.MOVEEND, this, frameState));
- ol.extent.clone(frameState.extent, this.previousExtent_);
- new ol.MapEvent(ol.MapEventType.POSTRENDER, this, frameState));
- setTimeout(this.handlePostRender.bind(this), 0);
- * Sets the layergroup of this map.
- * @param {ol.layer.Group} layerGroup A layer group containing the layers in
- * this map.
- * @observable
- * @api
-ol.Map.prototype.setLayerGroup = function(layerGroup) {
- this.set(ol.MapProperty.LAYERGROUP, layerGroup);
- * Set the size of this map.
- * @param {ol.Size|undefined} size The size in pixels of the map in the DOM.
- * @observable
- * @api
-ol.Map.prototype.setSize = function(size) {
- this.set(ol.MapProperty.SIZE, size);
- * Set the target element to render this map into.
- * @param {Element|string|undefined} target The Element or id of the Element
- * that the map is rendered in.
- * @observable
- * @api
-ol.Map.prototype.setTarget = function(target) {
- this.set(ol.MapProperty.TARGET, target);
- * Set the view for this map.
- * @param {ol.View} view The view that controls this map.
- * @observable
- * @api
-ol.Map.prototype.setView = function(view) {
- this.set(ol.MapProperty.VIEW, view);
- * @param {ol.Feature} feature Feature.
-ol.Map.prototype.skipFeature = function(feature) {
- var featureUid = ol.getUid(feature).toString();
- this.skippedFeatureUids_[featureUid] = true;
- this.render();
- * Force a recalculation of the map viewport size. This should be called when
- * third-party code changes the size of the map viewport.
- * @api
-ol.Map.prototype.updateSize = function() {
- var targetElement = this.getTargetElement();
- this.setSize(undefined);
- } else {
- var computedStyle = getComputedStyle(targetElement);
- this.setSize([
- targetElement.offsetWidth -
- parseFloat(computedStyle['borderLeftWidth']) -
- parseFloat(computedStyle['paddingLeft']) -
- parseFloat(computedStyle['paddingRight']) -
- parseFloat(computedStyle['borderRightWidth']),
- targetElement.offsetHeight -
- parseFloat(computedStyle['borderTopWidth']) -
- parseFloat(computedStyle['paddingTop']) -
- parseFloat(computedStyle['paddingBottom']) -
- parseFloat(computedStyle['borderBottomWidth'])
-ol.Map.prototype.unskipFeature = function(feature) {
- delete this.skippedFeatureUids_[featureUid];
- this.render();
- * @return {ol.MapOptionsInternal} Internal map options.
-ol.Map.createOptionsInternal = function(options) {
- var keyboardEventTarget = null;
- if (options.keyboardEventTarget !== undefined) {
- keyboardEventTarget = typeof options.keyboardEventTarget === 'string' ?
- document.getElementById(options.keyboardEventTarget) :
- options.keyboardEventTarget;
- * @type {Object.<string, *>}
- var values = {};
- var logos = {};
- if (options.logo === undefined ||
- (typeof options.logo === 'boolean' && options.logo)) {
- logos[ol.OL_LOGO_URL] = ol.OL_URL;
- } else {
- var logo = options.logo;
- if (typeof logo === 'string') {
- logos[logo] = '';
- } else if (logo instanceof HTMLElement) {
- logos[ol.getUid(logo).toString()] = logo;
- } else if (logo) {
- ol.asserts.assert(typeof logo.href == 'string', 44); // `logo.href` should be a string.
- ol.asserts.assert(typeof logo.src == 'string', 45); // `logo.src` should be a string.
- logos[logo.src] = logo.href;
- var layerGroup = (options.layers instanceof ol.layer.Group) ?
- options.layers : new ol.layer.Group({layers: options.layers});
- values[ol.MapProperty.LAYERGROUP] = layerGroup;
- values[ol.MapProperty.TARGET] = options.target;
- values[ol.MapProperty.VIEW] = options.view !== undefined ?
- options.view : new ol.View();
- * @type {function(new: ol.renderer.Map, Element, ol.Map)}
- var rendererConstructor = ol.renderer.Map;
- var rendererTypes;
- if (options.renderer !== undefined) {
- if (Array.isArray(options.renderer)) {
- rendererTypes = options.renderer;
- } else if (typeof options.renderer === 'string') {
- rendererTypes = [options.renderer];
- } else {
- ol.asserts.assert(false, 46); // Incorrect format for `renderer` option
- if (rendererTypes.indexOf(/** @type {ol.renderer.Type} */ ('dom')) >= 0) {
- rendererTypes = rendererTypes.concat(ol.DEFAULT_RENDERER_TYPES);
- } else {
- rendererTypes = ol.DEFAULT_RENDERER_TYPES;
- var i, ii;
- for (i = 0, ii = rendererTypes.length; i < ii; ++i) {
- /** @type {ol.renderer.Type} */
- var rendererType = rendererTypes[i];
- if (ol.ENABLE_CANVAS && rendererType == ol.renderer.Type.CANVAS) {
- if (ol.has.CANVAS) {
- rendererConstructor = ol.renderer.canvas.Map;
- break;
- } else if (ol.ENABLE_WEBGL && rendererType == ol.renderer.Type.WEBGL) {
- if (ol.has.WEBGL) {
- rendererConstructor = ol.renderer.webgl.Map;
- break;
- var controls;
- if (options.controls !== undefined) {
- if (Array.isArray(options.controls)) {
- controls = new ol.Collection(options.controls.slice());
- } else {
- ol.asserts.assert(options.controls instanceof ol.Collection,
- 47); // Expected `controls` to be an array or an `ol.Collection`
- controls = options.controls;
- } else {
- controls = ol.control.defaults();
- var interactions;
- if (options.interactions !== undefined) {
- if (Array.isArray(options.interactions)) {
- interactions = new ol.Collection(options.interactions.slice());
- } else {
- ol.asserts.assert(options.interactions instanceof ol.Collection,
- 48); // Expected `interactions` to be an array or an `ol.Collection`
- interactions = options.interactions;
- } else {
- interactions = ol.interaction.defaults();
- var overlays;
- if (options.overlays !== undefined) {
- if (Array.isArray(options.overlays)) {
- overlays = new ol.Collection(options.overlays.slice());
- } else {
- ol.asserts.assert(options.overlays instanceof ol.Collection,
- 49); // Expected `overlays` to be an array or an `ol.Collection`
- overlays = options.overlays;
- } else {
- overlays = new ol.Collection();
- return {
- controls: controls,
- interactions: interactions,
- keyboardEventTarget: keyboardEventTarget,
- logos: logos,
- overlays: overlays,
- rendererConstructor: rendererConstructor,
- values: values
-goog.provide('ol.OverlayPositioning');
- * Overlay position: `'bottom-left'`, `'bottom-center'`, `'bottom-right'`,
- * `'center-left'`, `'center-center'`, `'center-right'`, `'top-left'`,
- * `'top-center'`, `'top-right'`
- * @enum {string}
-ol.OverlayPositioning = {
- BOTTOM_LEFT: 'bottom-left',
- BOTTOM_CENTER: 'bottom-center',
- BOTTOM_RIGHT: 'bottom-right',
- CENTER_LEFT: 'center-left',
- CENTER_CENTER: 'center-center',
- CENTER_RIGHT: 'center-right',
- TOP_LEFT: 'top-left',
- TOP_CENTER: 'top-center',
- TOP_RIGHT: 'top-right'
-goog.provide('ol.Overlay');
-goog.require('ol');
-goog.require('ol.OverlayPositioning');
-goog.require('ol.extent');
- * @classdesc
- * An element to be displayed over the map and attached to a single map
- * location. Like {@link ol.control.Control}, Overlays are visible widgets.
- * Unlike Controls, they are not in a fixed position on the screen, but are tied
- * to a geographical coordinate, so panning the map will move an Overlay but not
- * a Control.
- * Example:
- * var popup = new ol.Overlay({
- * element: document.getElementById('popup')
- * popup.setPosition(coordinate);
- * map.addOverlay(popup);
- * @constructor
- * @param {olx.OverlayOptions} options Overlay options.
- * @api
-ol.Overlay = function(options) {
- * @private
- * @type {number|string|undefined}
- this.id_ = options.id;
- * @private
- * @type {boolean}
- this.insertFirst_ = options.insertFirst !== undefined ?
- options.insertFirst : true;
- * @private
- * @type {boolean}
- this.stopEvent_ = options.stopEvent !== undefined ? options.stopEvent : true;
- * @private
- * @type {Element}
- this.element_ = document.createElement('DIV');
- this.element_.className = 'ol-overlay-container';
- this.element_.style.position = 'absolute';
- * @protected
- * @type {boolean}
- this.autoPan = options.autoPan !== undefined ? options.autoPan : false;
- * @private
- * @type {olx.OverlayPanOptions}
- this.autoPanAnimation_ = options.autoPanAnimation ||
- /** @type {olx.OverlayPanOptions} */ ({});
- * @private
- * @type {number}
- this.autoPanMargin_ = options.autoPanMargin !== undefined ?
- options.autoPanMargin : 20;
- * @private
- * @type {{bottom_: string,
- * left_: string,
- * right_: string,
- * top_: string,
- * visible: boolean}}
- this.rendered_ = {
- bottom_: '',
- left_: '',
- right_: '',
- top_: '',
- visible: true
- * @private
- this.mapPostrenderListenerKey_ = null;
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.Overlay.Property_.ELEMENT),
- this.handleElementChanged, this);
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.Overlay.Property_.MAP),
- this.handleMapChanged, this);
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.Overlay.Property_.OFFSET),
- this.handleOffsetChanged, this);
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.Overlay.Property_.POSITION),
- this.handlePositionChanged, this);
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.Overlay.Property_.POSITIONING),
- this.handlePositioningChanged, this);
- if (options.element !== undefined) {
- this.setElement(options.element);
- this.setOffset(options.offset !== undefined ? options.offset : [0, 0]);
- this.setPositioning(options.positioning !== undefined ?
- /** @type {ol.OverlayPositioning} */ (options.positioning) :
- ol.OverlayPositioning.TOP_LEFT);
- if (options.position !== undefined) {
- this.setPosition(options.position);
-ol.inherits(ol.Overlay, ol.Object);
- * Get the DOM element of this overlay.
- * @return {Element|undefined} The Element containing the overlay.
- * @observable
- * @api
-ol.Overlay.prototype.getElement = function() {
- return /** @type {Element|undefined} */ (
- this.get(ol.Overlay.Property_.ELEMENT));
- * Get the overlay identifier which is set on constructor.
- * @return {number|string|undefined} Id.
- * @api
-ol.Overlay.prototype.getId = function() {
- return this.id_;
- * Get the map associated with this overlay.
- * @return {ol.Map|undefined} The map that the overlay is part of.
- * @observable
- * @api
-ol.Overlay.prototype.getMap = function() {
- return /** @type {ol.Map|undefined} */ (
- this.get(ol.Overlay.Property_.MAP));
- * Get the offset of this overlay.
- * @return {Array.<number>} The offset.
- * @observable
- * @api
-ol.Overlay.prototype.getOffset = function() {
- return /** @type {Array.<number>} */ (
- this.get(ol.Overlay.Property_.OFFSET));
- * Get the current position of this overlay.
- * @return {ol.Coordinate|undefined} The spatial point that the overlay is
- * anchored at.
- * @observable
- * @api
-ol.Overlay.prototype.getPosition = function() {
- return /** @type {ol.Coordinate|undefined} */ (
- this.get(ol.Overlay.Property_.POSITION));
- * Get the current positioning of this overlay.
- * @return {ol.OverlayPositioning} How the overlay is positioned
- * relative to its point on the map.
- * @observable
- * @api
-ol.Overlay.prototype.getPositioning = function() {
- return /** @type {ol.OverlayPositioning} */ (
- this.get(ol.Overlay.Property_.POSITIONING));
- * @protected
-ol.Overlay.prototype.handleElementChanged = function() {
- ol.dom.removeChildren(this.element_);
- var element = this.getElement();
- if (element) {
- this.element_.appendChild(element);
- * @protected
-ol.Overlay.prototype.handleMapChanged = function() {
- if (this.mapPostrenderListenerKey_) {
- ol.dom.removeNode(this.element_);
- ol.events.unlistenByKey(this.mapPostrenderListenerKey_);
- if (map) {
- this.mapPostrenderListenerKey_ = ol.events.listen(map,
- ol.MapEventType.POSTRENDER, this.render, this);
- this.updatePixelPosition();
- var container = this.stopEvent_ ?
- map.getOverlayContainerStopEvent() : map.getOverlayContainer();
- if (this.insertFirst_) {
- container.insertBefore(this.element_, container.childNodes[0] || null);
- } else {
- container.appendChild(this.element_);
- * @protected
-ol.Overlay.prototype.render = function() {
- * @protected
-ol.Overlay.prototype.handleOffsetChanged = function() {
- * @protected
-ol.Overlay.prototype.handlePositionChanged = function() {
- if (this.get(ol.Overlay.Property_.POSITION) && this.autoPan) {
- this.panIntoView_();
- * @protected
-ol.Overlay.prototype.handlePositioningChanged = function() {
- * Set the DOM element to be associated with this overlay.
- * @param {Element|undefined} element The Element containing the overlay.
- * @observable
- * @api
-ol.Overlay.prototype.setElement = function(element) {
- this.set(ol.Overlay.Property_.ELEMENT, element);
- * Set the map to be associated with this overlay.
- * @param {ol.Map|undefined} map The map that the overlay is part of.
- * @observable
- * @api
-ol.Overlay.prototype.setMap = function(map) {
- this.set(ol.Overlay.Property_.MAP, map);
- * Set the offset for this overlay.
- * @param {Array.<number>} offset Offset.
- * @observable
- * @api
-ol.Overlay.prototype.setOffset = function(offset) {
- this.set(ol.Overlay.Property_.OFFSET, offset);
- * Set the position for this overlay. If the position is `undefined` the
- * overlay is hidden.
- * @param {ol.Coordinate|undefined} position The spatial point that the overlay
- * is anchored at.
- * @observable
- * @api
-ol.Overlay.prototype.setPosition = function(position) {
- this.set(ol.Overlay.Property_.POSITION, position);
- * Pan the map so that the overlay is entirely visible in the current viewport
- * (if necessary).
- * @private
-ol.Overlay.prototype.panIntoView_ = function() {
- if (!map || !map.getTargetElement()) {
- return;
- var mapRect = this.getRect_(map.getTargetElement(), map.getSize());
- var element = /** @type {!Element} */ (this.getElement());
- var overlayRect = this.getRect_(element,
- [ol.dom.outerWidth(element), ol.dom.outerHeight(element)]);
- var margin = this.autoPanMargin_;
- if (!ol.extent.containsExtent(mapRect, overlayRect)) {
- // the overlay is not completely inside the viewport, so pan the map
- var offsetLeft = overlayRect[0] - mapRect[0];
- var offsetRight = mapRect[2] - overlayRect[2];
- var offsetTop = overlayRect[1] - mapRect[1];
- var offsetBottom = mapRect[3] - overlayRect[3];
- var delta = [0, 0];
- if (offsetLeft < 0) {
- // move map to the left
- delta[0] = offsetLeft - margin;
- } else if (offsetRight < 0) {
- // move map to the right
- delta[0] = Math.abs(offsetRight) + margin;
- if (offsetTop < 0) {
- // move map up
- delta[1] = offsetTop - margin;
- } else if (offsetBottom < 0) {
- // move map down
- delta[1] = Math.abs(offsetBottom) + margin;
- if (delta[0] !== 0 || delta[1] !== 0) {
- var center = /** @type {ol.Coordinate} */ (map.getView().getCenter());
- var centerPx = map.getPixelFromCoordinate(center);
- var newCenterPx = [
- centerPx[0] + delta[0],
- centerPx[1] + delta[1]
- map.getView().animate({
- center: map.getCoordinateFromPixel(newCenterPx),
- duration: this.autoPanAnimation_.duration,
- easing: this.autoPanAnimation_.easing
- * Get the extent of an element relative to the document
- * @param {Element|undefined} element The element.
- * @param {ol.Size|undefined} size The size of the element.
- * @return {ol.Extent} The extent.
- * @private
-ol.Overlay.prototype.getRect_ = function(element, size) {
- var box = element.getBoundingClientRect();
- var offsetX = box.left + window.pageXOffset;
- var offsetY = box.top + window.pageYOffset;
- return [
- offsetX,
- offsetY,
- offsetX + size[0],
- offsetY + size[1]
- * Set the positioning for this overlay.
- * @param {ol.OverlayPositioning} positioning how the overlay is
- * positioned relative to its point on the map.
- * @observable
- * @api
-ol.Overlay.prototype.setPositioning = function(positioning) {
- this.set(ol.Overlay.Property_.POSITIONING, positioning);
- * Modify the visibility of the element.
- * @param {boolean} visible Element visibility.
- * @protected
-ol.Overlay.prototype.setVisible = function(visible) {
- if (this.rendered_.visible !== visible) {
- this.element_.style.display = visible ? '' : 'none';
- this.rendered_.visible = visible;
- * Update pixel position.
- * @protected
-ol.Overlay.prototype.updatePixelPosition = function() {
- var position = this.getPosition();
- if (!map || !map.isRendered() || !position) {
- this.setVisible(false);
- return;
- var pixel = map.getPixelFromCoordinate(position);
- var mapSize = map.getSize();
- this.updateRenderedPosition(pixel, mapSize);
- * @param {ol.Pixel} pixel The pixel location.
- * @param {ol.Size|undefined} mapSize The map size.
- * @protected
-ol.Overlay.prototype.updateRenderedPosition = function(pixel, mapSize) {
- var style = this.element_.style;
- var offset = this.getOffset();
- var positioning = this.getPositioning();
- this.setVisible(true);
- var offsetX = offset[0];
- var offsetY = offset[1];
- if (positioning == ol.OverlayPositioning.BOTTOM_RIGHT ||
- positioning == ol.OverlayPositioning.CENTER_RIGHT ||
- positioning == ol.OverlayPositioning.TOP_RIGHT) {
- if (this.rendered_.left_ !== '') {
- this.rendered_.left_ = style.left = '';
- var right = Math.round(mapSize[0] - pixel[0] - offsetX) + 'px';
- if (this.rendered_.right_ != right) {
- this.rendered_.right_ = style.right = right;
- } else {
- if (this.rendered_.right_ !== '') {
- this.rendered_.right_ = style.right = '';
- if (positioning == ol.OverlayPositioning.BOTTOM_CENTER ||
- positioning == ol.OverlayPositioning.CENTER_CENTER ||
- positioning == ol.OverlayPositioning.TOP_CENTER) {
- offsetX -= this.element_.offsetWidth / 2;
- var left = Math.round(pixel[0] + offsetX) + 'px';
- if (this.rendered_.left_ != left) {
- this.rendered_.left_ = style.left = left;
- if (positioning == ol.OverlayPositioning.BOTTOM_LEFT ||
- positioning == ol.OverlayPositioning.BOTTOM_CENTER ||
- positioning == ol.OverlayPositioning.BOTTOM_RIGHT) {
- if (this.rendered_.top_ !== '') {
- this.rendered_.top_ = style.top = '';
- var bottom = Math.round(mapSize[1] - pixel[1] - offsetY) + 'px';
- if (this.rendered_.bottom_ != bottom) {
- this.rendered_.bottom_ = style.bottom = bottom;
- } else {
- if (this.rendered_.bottom_ !== '') {
- this.rendered_.bottom_ = style.bottom = '';
- if (positioning == ol.OverlayPositioning.CENTER_LEFT ||
- positioning == ol.OverlayPositioning.CENTER_RIGHT) {
- offsetY -= this.element_.offsetHeight / 2;
- var top = Math.round(pixel[1] + offsetY) + 'px';
- if (this.rendered_.top_ != top) {
- this.rendered_.top_ = style.top = top;
- * @enum {string}
- * @private
-ol.Overlay.Property_ = {
- ELEMENT: 'element',
- MAP: 'map',
- OFFSET: 'offset',
- POSITION: 'position',
- POSITIONING: 'positioning'
-goog.provide('ol.control.OverviewMap');
-goog.require('ol.Map');
-goog.require('ol.Overlay');
-goog.require('ol.ViewProperty');
-goog.require('ol.control.Control');
-goog.require('ol.coordinate');
-goog.require('ol.css');
-goog.require('ol.dom');
-goog.require('ol.events');
- * Create a new control with a map acting as an overview map for an other
- * defined map.
- * @constructor
- * @extends {ol.control.Control}
- * @param {olx.control.OverviewMapOptions=} opt_options OverviewMap options.
- * @api
-ol.control.OverviewMap = function(opt_options) {
- var options = opt_options ? opt_options : {};
- * @type {boolean}
- * @private
- this.collapsed_ = options.collapsed !== undefined ? options.collapsed : true;
- * @private
- * @type {boolean}
- this.collapsible_ = options.collapsible !== undefined ?
- options.collapsible : true;
- if (!this.collapsible_) {
- this.collapsed_ = false;
- var className = options.className !== undefined ? options.className : 'ol-overviewmap';
- var tipLabel = options.tipLabel !== undefined ? options.tipLabel : 'Overview map';
- var collapseLabel = options.collapseLabel !== undefined ? options.collapseLabel : '\u00AB';
- if (typeof collapseLabel === 'string') {
- * @private
- * @type {Node}
- this.collapseLabel_ = document.createElement('span');
- this.collapseLabel_.textContent = collapseLabel;
- } else {
- this.collapseLabel_ = collapseLabel;
- var label = options.label !== undefined ? options.label : '\u00BB';
- if (typeof label === 'string') {
- * @private
- * @type {Node}
- this.label_ = document.createElement('span');
- this.label_.textContent = label;
- } else {
- this.label_ = label;
- var activeLabel = (this.collapsible_ && !this.collapsed_) ?
- this.collapseLabel_ : this.label_;
- var button = document.createElement('button');
- button.setAttribute('type', 'button');
- button.title = tipLabel;
- button.appendChild(activeLabel);
- ol.events.listen(button, ol.events.EventType.CLICK,
- this.handleClick_, this);
- * @type {Element}
- * @private
- this.ovmapDiv_ = document.createElement('DIV');
- this.ovmapDiv_.className = 'ol-overviewmap-map';
- * @type {ol.Map}
- * @private
- this.ovmap_ = new ol.Map({
- controls: new ol.Collection(),
- interactions: new ol.Collection(),
- view: options.view
- var ovmap = this.ovmap_;
- if (options.layers) {
- options.layers.forEach(
- * @param {ol.layer.Layer} layer Layer.
- function(layer) {
- ovmap.addLayer(layer);
- }, this);
- var box = document.createElement('DIV');
- box.className = 'ol-overviewmap-box';
- box.style.boxSizing = 'border-box';
- * @type {ol.Overlay}
- * @private
- this.boxOverlay_ = new ol.Overlay({
- position: [0, 0],
- positioning: ol.OverlayPositioning.BOTTOM_LEFT,
- element: box
- this.ovmap_.addOverlay(this.boxOverlay_);
- var cssClasses = className + ' ' + ol.css.CLASS_UNSELECTABLE + ' ' +
- ol.css.CLASS_CONTROL +
- (this.collapsed_ && this.collapsible_ ? ' ol-collapsed' : '') +
- (this.collapsible_ ? '' : ' ol-uncollapsible');
- var element = document.createElement('div');
- element.className = cssClasses;
- element.appendChild(this.ovmapDiv_);
- element.appendChild(button);
- var render = options.render ? options.render : ol.control.OverviewMap.render;
- ol.control.Control.call(this, {
- element: element,
- render: render,
- target: options.target
- /* Interactive map */
- var scope = this;
- var overlay = this.boxOverlay_;
- var overlayBox = this.boxOverlay_.getElement();
- /* Functions definition */
- var computeDesiredMousePosition = function(mousePosition) {
- return {
- clientX: mousePosition.clientX - (overlayBox.offsetWidth / 2),
- clientY: mousePosition.clientY + (overlayBox.offsetHeight / 2)
- var move = function(event) {
- var coordinates = ovmap.getEventCoordinate(computeDesiredMousePosition(event));
- overlay.setPosition(coordinates);
- var endMoving = function(event) {
- var coordinates = ovmap.getEventCoordinate(event);
- scope.getMap().getView().setCenter(coordinates);
- window.removeEventListener('mousemove', move);
- window.removeEventListener('mouseup', endMoving);
- /* Binding */
- overlayBox.addEventListener('mousedown', function() {
- window.addEventListener('mousemove', move);
- window.addEventListener('mouseup', endMoving);
-ol.inherits(ol.control.OverviewMap, ol.control.Control);
- * @inheritDoc
- * @api
-ol.control.OverviewMap.prototype.setMap = function(map) {
- var oldMap = this.getMap();
- if (map === oldMap) {
- return;
- if (oldMap) {
- var oldView = oldMap.getView();
- if (oldView) {
- this.unbindView_(oldView);
- this.ovmap_.setTarget(null);
- ol.control.Control.prototype.setMap.call(this, map);
- if (map) {
- this.ovmap_.setTarget(this.ovmapDiv_);
- this.listenerKeys.push(ol.events.listen(
- map, ol.ObjectEventType.PROPERTYCHANGE,
- this.handleMapPropertyChange_, this));
- // TODO: to really support map switching, this would need to be reworked
- if (this.ovmap_.getLayers().getLength() === 0) {
- this.ovmap_.setLayerGroup(map.getLayerGroup());
- var view = map.getView();
- if (view) {
- this.bindView_(view);
- if (view.isDef()) {
- this.ovmap_.updateSize();
- this.resetExtent_();
- * Handle map property changes. This only deals with changes to the map's view.
- * @param {ol.Object.Event} event The propertychange event.
- * @private
-ol.control.OverviewMap.prototype.handleMapPropertyChange_ = function(event) {
- if (event.key === ol.MapProperty.VIEW) {
- var oldView = /** @type {ol.View} */ (event.oldValue);
- if (oldView) {
- var newView = this.getMap().getView();
- this.bindView_(newView);
- * Register listeners for view property changes.
- * @param {ol.View} view The view.
- * @private
-ol.control.OverviewMap.prototype.bindView_ = function(view) {
- ol.events.listen(view,
- ol.Object.getChangeEventType(ol.ViewProperty.ROTATION),
- this.handleRotationChanged_, this);
- * Unregister listeners for view property changes.
- * @private
-ol.control.OverviewMap.prototype.unbindView_ = function(view) {
- ol.events.unlisten(view,
- * Handle rotation changes to the main map.
- * TODO: This should rotate the extent rectrangle instead of the
- * overview map's view.
- * @private
-ol.control.OverviewMap.prototype.handleRotationChanged_ = function() {
- this.ovmap_.getView().setRotation(this.getMap().getView().getRotation());
- * Update the overview map element.
- * @param {ol.MapEvent} mapEvent Map event.
- * @this {ol.control.OverviewMap}
- * @api
-ol.control.OverviewMap.render = function(mapEvent) {
- this.validateExtent_();
- this.updateBox_();
- * Reset the overview map extent if the box size (width or
- * height) is less than the size of the overview map size times minRatio
- * or is greater than the size of the overview size times maxRatio.
- * If the map extent was not reset, the box size can fits in the defined
- * ratio sizes. This method then checks if is contained inside the overview
- * map current extent. If not, recenter the overview map to the current
- * main map center location.
- * @private
-ol.control.OverviewMap.prototype.validateExtent_ = function() {
- var map = this.getMap();
- if (!map.isRendered() || !ovmap.isRendered()) {
- return;
- var mapSize = /** @type {ol.Size} */ (map.getSize());
- var extent = view.calculateExtent(mapSize);
- var ovmapSize = /** @type {ol.Size} */ (ovmap.getSize());
- var ovview = ovmap.getView();
- var ovextent = ovview.calculateExtent(ovmapSize);
- var topLeftPixel =
- ovmap.getPixelFromCoordinate(ol.extent.getTopLeft(extent));
- var bottomRightPixel =
- ovmap.getPixelFromCoordinate(ol.extent.getBottomRight(extent));
- var boxWidth = Math.abs(topLeftPixel[0] - bottomRightPixel[0]);
- var boxHeight = Math.abs(topLeftPixel[1] - bottomRightPixel[1]);
- var ovmapWidth = ovmapSize[0];
- var ovmapHeight = ovmapSize[1];
- if (boxWidth < ovmapWidth * ol.OVERVIEWMAP_MIN_RATIO ||
- boxHeight < ovmapHeight * ol.OVERVIEWMAP_MIN_RATIO ||
- boxWidth > ovmapWidth * ol.OVERVIEWMAP_MAX_RATIO ||
- boxHeight > ovmapHeight * ol.OVERVIEWMAP_MAX_RATIO) {
- } else if (!ol.extent.containsExtent(ovextent, extent)) {
- this.recenter_();
- * Reset the overview map extent to half calculated min and max ratio times
- * the extent of the main map.
- * @private
-ol.control.OverviewMap.prototype.resetExtent_ = function() {
- if (ol.OVERVIEWMAP_MAX_RATIO === 0 || ol.OVERVIEWMAP_MIN_RATIO === 0) {
- return;
- // get how many times the current map overview could hold different
- // box sizes using the min and max ratio, pick the step in the middle used
- // to calculate the extent from the main map to set it to the overview map,
- var steps = Math.log(
- ol.OVERVIEWMAP_MAX_RATIO / ol.OVERVIEWMAP_MIN_RATIO) / Math.LN2;
- var ratio = 1 / (Math.pow(2, steps / 2) * ol.OVERVIEWMAP_MIN_RATIO);
- ol.extent.scaleFromCenter(extent, ratio);
- ovview.fit(extent);
- * Set the center of the overview map to the map center without changing its
- * resolution.
- * @private
-ol.control.OverviewMap.prototype.recenter_ = function() {
- ovview.setCenter(view.getCenter());
- * Update the box using the main map extent
- * @private
-ol.control.OverviewMap.prototype.updateBox_ = function() {
- return;
- var rotation = view.getRotation();
- var box = this.boxOverlay_.getElement();
- var ovresolution = ovview.getResolution();
- var bottomLeft = ol.extent.getBottomLeft(extent);
- var topRight = ol.extent.getTopRight(extent);
- // set position using bottom left coordinates
- var rotateBottomLeft = this.calculateCoordinateRotate_(rotation, bottomLeft);
- overlay.setPosition(rotateBottomLeft);
- // set box size calculated from map extent size and overview map resolution
- if (box) {
- box.style.width = Math.abs((bottomLeft[0] - topRight[0]) / ovresolution) + 'px';
- box.style.height = Math.abs((topRight[1] - bottomLeft[1]) / ovresolution) + 'px';
- * @param {number} rotation Target rotation.
- * @param {ol.Coordinate} coordinate Coordinate.
- * @return {ol.Coordinate|undefined} Coordinate for rotation and center anchor.
- * @private
-ol.control.OverviewMap.prototype.calculateCoordinateRotate_ = function(
- rotation, coordinate) {
- var coordinateRotate;
- var currentCenter = view.getCenter();
- if (currentCenter) {
- coordinateRotate = [
- coordinate[0] - currentCenter[0],
- coordinate[1] - currentCenter[1]
- ol.coordinate.rotate(coordinateRotate, rotation);
- ol.coordinate.add(coordinateRotate, currentCenter);
- return coordinateRotate;
- * @param {Event} event The event to handle
- * @private
-ol.control.OverviewMap.prototype.handleClick_ = function(event) {
- event.preventDefault();
- this.handleToggle_();
- * @private
-ol.control.OverviewMap.prototype.handleToggle_ = function() {
- this.element.classList.toggle('ol-collapsed');
- if (this.collapsed_) {
- ol.dom.replaceNode(this.collapseLabel_, this.label_);
- } else {
- ol.dom.replaceNode(this.label_, this.collapseLabel_);
- this.collapsed_ = !this.collapsed_;
- // manage overview map if it had not been rendered before and control
- // is expanded
- if (!this.collapsed_ && !ovmap.isRendered()) {
- ovmap.updateSize();
- ol.events.listenOnce(ovmap, ol.MapEventType.POSTRENDER,
- function(event) {
- this);
- * Return `true` if the overview map is collapsible, `false` otherwise.
- * @return {boolean} True if the widget is collapsible.
- * @api
-ol.control.OverviewMap.prototype.getCollapsible = function() {
- return this.collapsible_;
- * Set whether the overview map should be collapsible.
- * @param {boolean} collapsible True if the widget is collapsible.
- * @api
-ol.control.OverviewMap.prototype.setCollapsible = function(collapsible) {
- if (this.collapsible_ === collapsible) {
- return;
- this.collapsible_ = collapsible;
- this.element.classList.toggle('ol-uncollapsible');
- if (!collapsible && this.collapsed_) {
- * Collapse or expand the overview map according to the passed parameter. Will
- * not do anything if the overview map isn't collapsible or if the current
- * collapsed state is already the one requested.
- * @param {boolean} collapsed True if the widget is collapsed.
- * @api
-ol.control.OverviewMap.prototype.setCollapsed = function(collapsed) {
- if (!this.collapsible_ || this.collapsed_ === collapsed) {
- return;
- * Determine if the overview map is collapsed.
- * @return {boolean} The overview map is collapsed.
- * @api
-ol.control.OverviewMap.prototype.getCollapsed = function() {
- return this.collapsed_;
- * Return the overview map.
- * @return {ol.Map} Overview map.
- * @api
-ol.control.OverviewMap.prototype.getOverviewMap = function() {
- return this.ovmap_;
-goog.provide('ol.control.ScaleLineUnits');
- * Units for the scale line. Supported values are `'degrees'`, `'imperial'`,
- * `'nautical'`, `'metric'`, `'us'`.
- * @enum {string}
-ol.control.ScaleLineUnits = {
- DEGREES: 'degrees',
- IMPERIAL: 'imperial',
- NAUTICAL: 'nautical',
- METRIC: 'metric',
- US: 'us'
-goog.provide('ol.control.ScaleLine');
-goog.require('ol.Object');
-goog.require('ol.asserts');
-goog.require('ol.control.ScaleLineUnits');
-goog.require('ol.proj');
-goog.require('ol.proj.Units');
- * @classdesc
- * A control displaying rough y-axis distances, calculated for the center of the
- * viewport. For conformal projections (e.g. EPSG:3857, the default view
- * projection in OpenLayers), the scale is valid for all directions.
- * No scale line will be shown when the y-axis distance of a pixel at the
- * viewport center cannot be calculated in the view projection.
- * By default the scale line will show in the bottom left portion of the map,
- * but this can be changed by using the css selector `.ol-scale-line`.
- * @constructor
- * @param {olx.control.ScaleLineOptions=} opt_options Scale line options.
- * @api
-ol.control.ScaleLine = function(opt_options) {
- var className = options.className !== undefined ? options.className : 'ol-scale-line';
- * @private
- * @type {Element}
- this.innerElement_ = document.createElement('DIV');
- this.innerElement_.className = className + '-inner';
- * @private
- * @type {Element}
- this.element_.className = className + ' ' + ol.css.CLASS_UNSELECTABLE;
- this.element_.appendChild(this.innerElement_);
- * @private
- * @type {?olx.ViewState}
- this.viewState_ = null;
- * @private
- * @type {number}
- this.minWidth_ = options.minWidth !== undefined ? options.minWidth : 64;
- * @private
- * @type {boolean}
- this.renderedVisible_ = false;
- * @private
- * @type {number|undefined}
- this.renderedWidth_ = undefined;
- * @private
- * @type {string}
- this.renderedHTML_ = '';
- var render = options.render ? options.render : ol.control.ScaleLine.render;
- element: this.element_,
- render: render,
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.control.ScaleLine.Property_.UNITS),
- this.handleUnitsChanged_, this);
- this.setUnits(/** @type {ol.control.ScaleLineUnits} */ (options.units) ||
- ol.control.ScaleLineUnits.METRIC);
-ol.inherits(ol.control.ScaleLine, ol.control.Control);
- * @const
- * @type {Array.<number>}
-ol.control.ScaleLine.LEADING_DIGITS = [1, 2, 5];
- * Return the units to use in the scale line.
- * @return {ol.control.ScaleLineUnits|undefined} The units to use in the scale
- * line.
- * @observable
- * @api
-ol.control.ScaleLine.prototype.getUnits = function() {
- return /** @type {ol.control.ScaleLineUnits|undefined} */ (
- this.get(ol.control.ScaleLine.Property_.UNITS));
- * Update the scale line element.
- * @this {ol.control.ScaleLine}
- * @api
-ol.control.ScaleLine.render = function(mapEvent) {
- var frameState = mapEvent.frameState;
- if (!frameState) {
- } else {
- this.viewState_ = frameState.viewState;
- this.updateElement_();
- * @private
-ol.control.ScaleLine.prototype.handleUnitsChanged_ = function() {
- * Set the units to use in the scale line.
- * @param {ol.control.ScaleLineUnits} units The units to use in the scale line.
- * @observable
- * @api
-ol.control.ScaleLine.prototype.setUnits = function(units) {
- this.set(ol.control.ScaleLine.Property_.UNITS, units);
- * @private
-ol.control.ScaleLine.prototype.updateElement_ = function() {
- var viewState = this.viewState_;
- if (!viewState) {
- if (this.renderedVisible_) {
- this.element_.style.display = 'none';
- return;
- var center = viewState.center;
- var projection = viewState.projection;
- var metersPerUnit = projection.getMetersPerUnit();
- var pointResolution =
- ol.proj.getPointResolution(projection, viewState.resolution, center) *
- metersPerUnit;
- var nominalCount = this.minWidth_ * pointResolution;
- var suffix = '';
- var units = this.getUnits();
- if (units == ol.control.ScaleLineUnits.DEGREES) {
- var metersPerDegree = ol.proj.METERS_PER_UNIT[ol.proj.Units.DEGREES];
- pointResolution /= metersPerDegree;
- if (nominalCount < metersPerDegree / 60) {
- suffix = '\u2033'; // seconds
- pointResolution *= 3600;
- } else if (nominalCount < metersPerDegree) {
- suffix = '\u2032'; // minutes
- pointResolution *= 60;
- } else {
- suffix = '\u00b0'; // degrees
- } else if (units == ol.control.ScaleLineUnits.IMPERIAL) {
- if (nominalCount < 0.9144) {
- suffix = 'in';
- pointResolution /= 0.0254;
- } else if (nominalCount < 1609.344) {
- suffix = 'ft';
- pointResolution /= 0.3048;
- } else {
- suffix = 'mi';
- pointResolution /= 1609.344;
- } else if (units == ol.control.ScaleLineUnits.NAUTICAL) {
- pointResolution /= 1852;
- suffix = 'nm';
- } else if (units == ol.control.ScaleLineUnits.METRIC) {
- if (nominalCount < 0.001) {
- suffix = 'μm';
- pointResolution *= 1000000;
- } else if (nominalCount < 1) {
- suffix = 'mm';
- pointResolution *= 1000;
- } else if (nominalCount < 1000) {
- suffix = 'm';
- } else {
- suffix = 'km';
- pointResolution /= 1000;
- } else if (units == ol.control.ScaleLineUnits.US) {
- suffix = 'in';
- pointResolution *= 39.37;
- suffix = 'ft';
- pointResolution /= 0.30480061;
- } else {
- suffix = 'mi';
- pointResolution /= 1609.3472;
- } else {
- ol.asserts.assert(false, 33); // Invalid units
- var i = 3 * Math.floor(
- Math.log(this.minWidth_ * pointResolution) / Math.log(10));
- var count, width;
- while (true) {
- count = ol.control.ScaleLine.LEADING_DIGITS[((i % 3) + 3) % 3] *
- Math.pow(10, Math.floor(i / 3));
- width = Math.round(count / pointResolution);
- if (isNaN(width)) {
- return;
- } else if (width >= this.minWidth_) {
- break;
- ++i;
- var html = count + ' ' + suffix;
- if (this.renderedHTML_ != html) {
- this.innerElement_.innerHTML = html;
- this.renderedHTML_ = html;
- if (this.renderedWidth_ != width) {
- this.innerElement_.style.width = width + 'px';
- this.renderedWidth_ = width;
- if (!this.renderedVisible_) {
- this.element_.style.display = '';
- this.renderedVisible_ = true;
- * @enum {string}
- * @private
-ol.control.ScaleLine.Property_ = {
- UNITS: 'units'
-// FIXME should possibly show tooltip when dragging?
-goog.provide('ol.control.ZoomSlider');
-goog.require('ol.ViewHint');
-goog.require('ol.easing');
-goog.require('ol.events.Event');
-goog.require('ol.events.EventType');
-goog.require('ol.math');
-goog.require('ol.pointer.EventType');
-goog.require('ol.pointer.PointerEventHandler');
- * @classdesc
- * A slider type of control for zooming.
- * Example:
- * map.addControl(new ol.control.ZoomSlider());
- * @constructor
- * @param {olx.control.ZoomSliderOptions=} opt_options Zoom slider options.
- * @api
-ol.control.ZoomSlider = function(opt_options) {
- * Will hold the current resolution of the view.
- * @private
- this.currentResolution_ = undefined;
- * The direction of the slider. Will be determined from actual display of the
- * container and defaults to ol.control.ZoomSlider.Direction_.VERTICAL.
- * @type {ol.control.ZoomSlider.Direction_}
- * @private
- this.direction_ = ol.control.ZoomSlider.Direction_.VERTICAL;
- * @type {boolean}
- * @private
- this.dragging_;
- * @type {number}
- * @private
- this.heightLimit_ = 0;
- * @type {number}
- * @private
- this.widthLimit_ = 0;
- * @private
- this.previousX_;
- * @private
- this.previousY_;
- * The calculated thumb size (border box plus margins). Set when initSlider_
- * is called.
- * @type {ol.Size}
- * @private
- this.thumbSize_ = null;
- * Whether the slider is initialized.
- * @type {boolean}
- * @private
- this.sliderInitialized_ = false;
- * @type {number}
- * @private
- this.duration_ = options.duration !== undefined ? options.duration : 200;
- var className = options.className !== undefined ? options.className : 'ol-zoomslider';
- var thumbElement = document.createElement('button');
- thumbElement.setAttribute('type', 'button');
- thumbElement.className = className + '-thumb ' + ol.css.CLASS_UNSELECTABLE;
- var containerElement = document.createElement('div');
- containerElement.className = className + ' ' + ol.css.CLASS_UNSELECTABLE + ' ' + ol.css.CLASS_CONTROL;
- containerElement.appendChild(thumbElement);
- * @type {ol.pointer.PointerEventHandler}
- * @private
- this.dragger_ = new ol.pointer.PointerEventHandler(containerElement);
- ol.events.listen(this.dragger_, ol.pointer.EventType.POINTERDOWN,
- this.handleDraggerStart_, this);
- ol.events.listen(this.dragger_, ol.pointer.EventType.POINTERMOVE,
- this.handleDraggerDrag_, this);
- ol.events.listen(this.dragger_, ol.pointer.EventType.POINTERUP,
- this.handleDraggerEnd_, this);
- ol.events.listen(containerElement, ol.events.EventType.CLICK,
- this.handleContainerClick_, this);
- ol.events.listen(thumbElement, ol.events.EventType.CLICK,
- ol.events.Event.stopPropagation);
- var render = options.render ? options.render : ol.control.ZoomSlider.render;
- element: containerElement,
- render: render
-ol.inherits(ol.control.ZoomSlider, ol.control.Control);
- * @inheritDoc
-ol.control.ZoomSlider.prototype.disposeInternal = function() {
- this.dragger_.dispose();
- ol.control.Control.prototype.disposeInternal.call(this);
- * The enum for available directions.
- * @enum {number}
- * @private
-ol.control.ZoomSlider.Direction_ = {
- VERTICAL: 0,
- HORIZONTAL: 1
- * @inheritDoc
-ol.control.ZoomSlider.prototype.setMap = function(map) {
- if (map) {
- map.render();
- * Initializes the slider element. This will determine and set this controls
- * direction_ and also constrain the dragging of the thumb to always be within
- * the bounds of the container.
- * @private
-ol.control.ZoomSlider.prototype.initSlider_ = function() {
- var container = this.element;
- var containerSize = {
- width: container.offsetWidth, height: container.offsetHeight
- var thumb = container.firstElementChild;
- var computedStyle = getComputedStyle(thumb);
- var thumbWidth = thumb.offsetWidth +
- parseFloat(computedStyle['marginRight']) +
- parseFloat(computedStyle['marginLeft']);
- var thumbHeight = thumb.offsetHeight +
- parseFloat(computedStyle['marginTop']) +
- parseFloat(computedStyle['marginBottom']);
- this.thumbSize_ = [thumbWidth, thumbHeight];
- if (containerSize.width > containerSize.height) {
- this.direction_ = ol.control.ZoomSlider.Direction_.HORIZONTAL;
- this.widthLimit_ = containerSize.width - thumbWidth;
- } else {
- this.heightLimit_ = containerSize.height - thumbHeight;
- this.sliderInitialized_ = true;
- * Update the zoomslider element.
- * @this {ol.control.ZoomSlider}
- * @api
-ol.control.ZoomSlider.render = function(mapEvent) {
- if (!mapEvent.frameState) {
- return;
- if (!this.sliderInitialized_) {
- this.initSlider_();
- var res = mapEvent.frameState.viewState.resolution;
- if (res !== this.currentResolution_) {
- this.currentResolution_ = res;
- this.setThumbPosition_(res);
- * @param {Event} event The browser event to handle.
- * @private
-ol.control.ZoomSlider.prototype.handleContainerClick_ = function(event) {
- var view = this.getMap().getView();
- var relativePosition = this.getRelativePosition_(
- event.offsetX - this.thumbSize_[0] / 2,
- event.offsetY - this.thumbSize_[1] / 2);
- var resolution = this.getResolutionForPosition_(relativePosition);
- view.animate({
- resolution: view.constrainResolution(resolution),
- duration: this.duration_,
- easing: ol.easing.easeOut
- * Handle dragger start events.
- * @param {ol.pointer.PointerEvent} event The drag event.
- * @private
-ol.control.ZoomSlider.prototype.handleDraggerStart_ = function(event) {
- if (!this.dragging_ && event.originalEvent.target === this.element.firstElementChild) {
- this.getMap().getView().setHint(ol.ViewHint.INTERACTING, 1);
- this.previousX_ = event.clientX;
- this.previousY_ = event.clientY;
- this.dragging_ = true;
- * Handle dragger drag events.
- * @param {ol.pointer.PointerEvent|Event} event The drag event.
- * @private
-ol.control.ZoomSlider.prototype.handleDraggerDrag_ = function(event) {
- if (this.dragging_) {
- var element = this.element.firstElementChild;
- var deltaX = event.clientX - this.previousX_ + parseInt(element.style.left, 10);
- var deltaY = event.clientY - this.previousY_ + parseInt(element.style.top, 10);
- var relativePosition = this.getRelativePosition_(deltaX, deltaY);
- this.currentResolution_ = this.getResolutionForPosition_(relativePosition);
- this.getMap().getView().setResolution(this.currentResolution_);
- this.setThumbPosition_(this.currentResolution_);
- * Handle dragger end events.
- * @private
-ol.control.ZoomSlider.prototype.handleDraggerEnd_ = function(event) {
- view.setHint(ol.ViewHint.INTERACTING, -1);
- view.animate({
- resolution: view.constrainResolution(this.currentResolution_),
- this.dragging_ = false;
- this.previousX_ = undefined;
- this.previousY_ = undefined;
- * Positions the thumb inside its container according to the given resolution.
- * @param {number} res The res.
- * @private
-ol.control.ZoomSlider.prototype.setThumbPosition_ = function(res) {
- var position = this.getPositionForResolution_(res);
- var thumb = this.element.firstElementChild;
- if (this.direction_ == ol.control.ZoomSlider.Direction_.HORIZONTAL) {
- thumb.style.left = this.widthLimit_ * position + 'px';
- } else {
- thumb.style.top = this.heightLimit_ * position + 'px';
- * Calculates the relative position of the thumb given x and y offsets. The
- * relative position scales from 0 to 1. The x and y offsets are assumed to be
- * in pixel units within the dragger limits.
- * @param {number} x Pixel position relative to the left of the slider.
- * @param {number} y Pixel position relative to the top of the slider.
- * @return {number} The relative position of the thumb.
- * @private
-ol.control.ZoomSlider.prototype.getRelativePosition_ = function(x, y) {
- var amount;
- if (this.direction_ === ol.control.ZoomSlider.Direction_.HORIZONTAL) {
- amount = x / this.widthLimit_;
- } else {
- amount = y / this.heightLimit_;
- return ol.math.clamp(amount, 0, 1);
- * Calculates the corresponding resolution of the thumb given its relative
- * position (where 0 is the minimum and 1 is the maximum).
- * @param {number} position The relative position of the thumb.
- * @return {number} The corresponding resolution.
- * @private
-ol.control.ZoomSlider.prototype.getResolutionForPosition_ = function(position) {
- var fn = this.getMap().getView().getResolutionForValueFunction();
- return fn(1 - position);
- * Determines the relative position of the slider for the given resolution. A
- * relative position of 0 corresponds to the minimum view resolution. A
- * relative position of 1 corresponds to the maximum view resolution.
- * @param {number} res The resolution.
- * @return {number} The relative position value (between 0 and 1).
- * @private
-ol.control.ZoomSlider.prototype.getPositionForResolution_ = function(res) {
- var fn = this.getMap().getView().getValueForResolutionFunction();
- return 1 - fn(res);
-goog.provide('ol.control.ZoomToExtent');
- * @classdesc
- * A button control which, when pressed, changes the map view to a specific
- * extent. To style this control use the css selector `.ol-zoom-extent`.
- * @constructor
- * @param {olx.control.ZoomToExtentOptions=} opt_options Options.
- * @api
-ol.control.ZoomToExtent = function(opt_options) {
- * @type {ol.Extent}
- * @private
- this.extent_ = options.extent ? options.extent : null;
- 'ol-zoom-extent';
- var label = options.label !== undefined ? options.label : 'E';
- options.tipLabel : 'Fit to extent';
- typeof label === 'string' ? document.createTextNode(label) : label
- ol.css.CLASS_CONTROL;
- element: element,
-ol.inherits(ol.control.ZoomToExtent, ol.control.Control);
- * @private
-ol.control.ZoomToExtent.prototype.handleClick_ = function(event) {
- this.handleZoomToExtent_();
- * @private
-ol.control.ZoomToExtent.prototype.handleZoomToExtent_ = function() {
- var extent = !this.extent_ ? view.getProjection().getExtent() : this.extent_;
- view.fit(extent);
-goog.provide('ol.DeviceOrientation');
-goog.require('ol.has');
- * @classdesc
- * The ol.DeviceOrientation class provides access to information from
- * DeviceOrientation events. See the [HTML 5 DeviceOrientation Specification](
- * http://www.w3.org/TR/orientation-event/) for more details.
- * Many new computers, and especially mobile phones
- * and tablets, provide hardware support for device orientation. Web
- * developers targeting mobile devices will be especially interested in this
- * class.
- * Device orientation data are relative to a common starting point. For mobile
- * devices, the starting point is to lay your phone face up on a table with the
- * top of the phone pointing north. This represents the zero state. All
- * angles are then relative to this state. For computers, it is the same except
- * the screen is open at 90 degrees.
- * Device orientation is reported as three angles - `alpha`, `beta`, and
- * `gamma` - relative to the starting position along the three planar axes X, Y
- * and Z. The X axis runs from the left edge to the right edge through the
- * middle of the device. Similarly, the Y axis runs from the bottom to the top
- * of the device through the middle. The Z axis runs from the back to the front
- * through the middle. In the starting position, the X axis points to the
- * right, the Y axis points away from you and the Z axis points straight up
- * from the device lying flat.
- * The three angles representing the device orientation are relative to the
- * three axes. `alpha` indicates how much the device has been rotated around the
- * Z axis, which is commonly interpreted as the compass heading (see note
- * below). `beta` indicates how much the device has been rotated around the X
- * axis, or how much it is tilted from front to back. `gamma` indicates how
- * much the device has been rotated around the Y axis, or how much it is tilted
- * from left to right.
- * For most browsers, the `alpha` value returns the compass heading so if the
- * device points north, it will be 0. With Safari on iOS, the 0 value of
- * `alpha` is calculated from when device orientation was first requested.
- * ol.DeviceOrientation provides the `heading` property which normalizes this
- * behavior across all browsers for you.
- * It is important to note that the HTML 5 DeviceOrientation specification
- * indicates that `alpha`, `beta` and `gamma` are in degrees while the
- * equivalent properties in ol.DeviceOrientation are in radians for consistency
- * with all other uses of angles throughout OpenLayers.
- * To get notified of device orientation changes, register a listener for the
- * generic `change` event on your `ol.DeviceOrientation` instance.
- * @see {@link http://www.w3.org/TR/orientation-event/}
- * @constructor
- * @extends {ol.Object}
- * @param {olx.DeviceOrientationOptions=} opt_options Options.
- * @api
-ol.DeviceOrientation = function(opt_options) {
- ol.Object.call(this);
- * @private
- * @type {?ol.EventsKey}
- this.listenerKey_ = null;
- ol.events.listen(this,
- ol.Object.getChangeEventType(ol.DeviceOrientation.Property_.TRACKING),
- this.handleTrackingChanged_, this);
- this.setTracking(options.tracking !== undefined ? options.tracking : false);
-ol.inherits(ol.DeviceOrientation, ol.Object);
- * @inheritDoc
-ol.DeviceOrientation.prototype.disposeInternal = function() {
- this.setTracking(false);
- ol.Object.prototype.disposeInternal.call(this);
- * @private
- * @param {Event} originalEvent Event.
-ol.DeviceOrientation.prototype.orientationChange_ = function(originalEvent) {
- var event = /** @type {DeviceOrientationEvent} */ (originalEvent);
- if (event.alpha !== null) {
- var alpha = ol.math.toRadians(event.alpha);
- this.set(ol.DeviceOrientation.Property_.ALPHA, alpha);
- // event.absolute is undefined in iOS.
- if (typeof event.absolute === 'boolean' && event.absolute) {
- this.set(ol.DeviceOrientation.Property_.HEADING, alpha);
- } else if (typeof event.webkitCompassHeading === 'number' &&
- event.webkitCompassAccuracy != -1) {
- var heading = ol.math.toRadians(event.webkitCompassHeading);
- this.set(ol.DeviceOrientation.Property_.HEADING, heading);
- if (event.beta !== null) {
- this.set(ol.DeviceOrientation.Property_.BETA,
- ol.math.toRadians(event.beta));
- if (event.gamma !== null) {
- this.set(ol.DeviceOrientation.Property_.GAMMA,
- ol.math.toRadians(event.gamma));
- this.changed();
- * Rotation around the device z-axis (in radians).
- * @return {number|undefined} The euler angle in radians of the device from the
- * standard Z axis.
- * @observable
- * @api
-ol.DeviceOrientation.prototype.getAlpha = function() {
- return /** @type {number|undefined} */ (
- this.get(ol.DeviceOrientation.Property_.ALPHA));
- * Rotation around the device x-axis (in radians).
- * planar X axis.
- * @observable
- * @api
-ol.DeviceOrientation.prototype.getBeta = function() {
- this.get(ol.DeviceOrientation.Property_.BETA));
- * Rotation around the device y-axis (in radians).
- * planar Y axis.
- * @observable
- * @api
-ol.DeviceOrientation.prototype.getGamma = function() {
- this.get(ol.DeviceOrientation.Property_.GAMMA));
- * The heading of the device relative to north (in radians).
- * @return {number|undefined} The heading of the device relative to north, in
- * radians, normalizing for different browser behavior.
- * @observable
- * @api
-ol.DeviceOrientation.prototype.getHeading = function() {
- this.get(ol.DeviceOrientation.Property_.HEADING));
- * Determine if orientation is being tracked.
- * @return {boolean} Changes in device orientation are being tracked.
- * @observable
- * @api
-ol.DeviceOrientation.prototype.getTracking = function() {
- return /** @type {boolean} */ (
- this.get(ol.DeviceOrientation.Property_.TRACKING));
- * @private
-ol.DeviceOrientation.prototype.handleTrackingChanged_ = function() {
- if (ol.has.DEVICE_ORIENTATION) {
- var tracking = this.getTracking();
- if (tracking && !this.listenerKey_) {
- this.listenerKey_ = ol.events.listen(window, 'deviceorientation',
- this.orientationChange_, this);
- } else if (!tracking && this.listenerKey_ !== null) {
- ol.events.unlistenByKey(this.listenerKey_);
- * Enable or disable tracking of device orientation events.
- * @param {boolean} tracking The status of tracking changes to alpha, beta and
- * gamma. If true, changes are tracked and reported immediately.
- * @observable
- * @api
-ol.DeviceOrientation.prototype.setTracking = function(tracking) {
- this.set(ol.DeviceOrientation.Property_.TRACKING, tracking);
- * @enum {string}
- * @private
-ol.DeviceOrientation.Property_ = {
- ALPHA: 'alpha',
- BETA: 'beta',
- GAMMA: 'gamma',
- HEADING: 'heading',
- TRACKING: 'tracking'
-goog.provide('ol.ImageState');
- * @enum {number}
-ol.ImageState = {
- IDLE: 0,
- LOADING: 1,
- LOADED: 2,
- ERROR: 3
-goog.provide('ol.style.Image');
- * @classdesc
- * A base class used for creating subclasses and not instantiated in
- * apps. Base class for {@link ol.style.Icon}, {@link ol.style.Circle} and
- * {@link ol.style.RegularShape}.
- * @constructor
- * @abstract
- * @param {ol.StyleImageOptions} options Options.
- * @api
-ol.style.Image = function(options) {
- * @private
- * @type {number}
- this.opacity_ = options.opacity;
- * @private
- * @type {boolean}
- this.rotateWithView_ = options.rotateWithView;
- * @private
- * @type {number}
- this.rotation_ = options.rotation;
- * @private
- * @type {number}
- this.scale_ = options.scale;
- * @private
- * @type {boolean}
- this.snapToPixel_ = options.snapToPixel;
- * Get the symbolizer opacity.
- * @return {number} Opacity.
- * @api
-ol.style.Image.prototype.getOpacity = function() {
- return this.opacity_;
- * Determine whether the symbolizer rotates with the map.
- * @return {boolean} Rotate with map.
- * @api
-ol.style.Image.prototype.getRotateWithView = function() {
- return this.rotateWithView_;
- * Get the symoblizer rotation.
- * @return {number} Rotation.
- * @api
-ol.style.Image.prototype.getRotation = function() {
- return this.rotation_;
- * Get the symbolizer scale.
- * @return {number} Scale.
- * @api
-ol.style.Image.prototype.getScale = function() {
- return this.scale_;
- * Determine whether the symbolizer should be snapped to a pixel.
- * @return {boolean} The symbolizer should snap to a pixel.
- * @api
-ol.style.Image.prototype.getSnapToPixel = function() {
- return this.snapToPixel_;
- * Get the anchor point in pixels. The anchor determines the center point for the
- * symbolizer.
- * @abstract
- * @return {Array.<number>} Anchor.
-ol.style.Image.prototype.getAnchor = function() {};
- * Get the image element for the symbolizer.
- * @abstract
- * @param {number} pixelRatio Pixel ratio.
- * @return {HTMLCanvasElement|HTMLVideoElement|Image} Image element.
-ol.style.Image.prototype.getImage = function(pixelRatio) {};
- * @abstract
-ol.style.Image.prototype.getHitDetectionImage = function(pixelRatio) {};
- * @abstract
- * @return {ol.ImageState} Image state.
-ol.style.Image.prototype.getImageState = function() {};
- * @abstract
- * @return {ol.Size} Image size.
-ol.style.Image.prototype.getImageSize = function() {};
- * @abstract
- * @return {ol.Size} Size of the hit-detection image.
-ol.style.Image.prototype.getHitDetectionImageSize = function() {};
- * Get the origin of the symbolizer.
- * @abstract
- * @return {Array.<number>} Origin.
-ol.style.Image.prototype.getOrigin = function() {};
- * Get the size of the symbolizer (in pixels).
- * @abstract
- * @return {ol.Size} Size.
-ol.style.Image.prototype.getSize = function() {};
- * Set the opacity.
- * @param {number} opacity Opacity.
- * @api
-ol.style.Image.prototype.setOpacity = function(opacity) {
- this.opacity_ = opacity;
- * Set whether to rotate the style with the view.
- * @param {boolean} rotateWithView Rotate with map.
-ol.style.Image.prototype.setRotateWithView = function(rotateWithView) {
- this.rotateWithView_ = rotateWithView;
- * Set the rotation.
- * @param {number} rotation Rotation.
- * @api
-ol.style.Image.prototype.setRotation = function(rotation) {
- this.rotation_ = rotation;
- * Set the scale.
- * @param {number} scale Scale.
- * @api
-ol.style.Image.prototype.setScale = function(scale) {
- this.scale_ = scale;
- * Set whether to snap the image to the closest pixel.
- * @param {boolean} snapToPixel Snap to pixel?
-ol.style.Image.prototype.setSnapToPixel = function(snapToPixel) {
- this.snapToPixel_ = snapToPixel;
- * @abstract
- * @param {function(this: T, ol.events.Event)} listener Listener function.
- * @param {T} thisArg Value to use as `this` when executing `listener`.
- * @return {ol.EventsKey|undefined} Listener key.
- * @template T
-ol.style.Image.prototype.listenImageChange = function(listener, thisArg) {};
- * Load not yet loaded URI.
- * @abstract
-ol.style.Image.prototype.load = function() {};
- * @abstract
- * @template T
-ol.style.Image.prototype.unlistenImageChange = function(listener, thisArg) {};
-goog.provide('ol.style.RegularShape');
-goog.require('ol.colorlike');
-goog.require('ol.ImageState');
-goog.require('ol.render.canvas');
-goog.require('ol.style.Image');
- * @classdesc
- * Set regular shape style for vector features. The resulting shape will be
- * a regular polygon when `radius` is provided, or a star when `radius1` and
- * `radius2` are provided.
- * @constructor
- * @param {olx.style.RegularShapeOptions} options Options.
- * @extends {ol.style.Image}
- * @api
-ol.style.RegularShape = function(options) {
- * @private
- * @type {Array.<string>}
- this.checksums_ = null;
- * @private
- * @type {HTMLCanvasElement}
- this.canvas_ = null;
- * @private
- this.hitDetectionCanvas_ = null;
- * @private
- * @type {ol.style.Fill}
- this.fill_ = options.fill !== undefined ? options.fill : null;
- * @private
- this.origin_ = [0, 0];
- * @private
- * @type {number}
- this.points_ = options.points;
- * @protected
- * @type {number}
- this.radius_ = /** @type {number} */ (options.radius !== undefined ?
- options.radius : options.radius1);
- * @private
- * @type {number}
- this.radius2_ =
- options.radius2 !== undefined ? options.radius2 : this.radius_;
- * @private
- * @type {number}
- this.angle_ = options.angle !== undefined ? options.angle : 0;
- * @private
- * @type {ol.style.Stroke}
- this.stroke_ = options.stroke !== undefined ? options.stroke : null;
- * @private
- this.anchor_ = null;
- * @private
- * @type {ol.Size}
- this.size_ = null;
- * @private
- * @type {ol.Size}
- this.imageSize_ = null;
- * @private
- * @type {ol.Size}
- this.hitDetectionImageSize_ = null;
- * @protected
- * @type {ol.style.AtlasManager|undefined}
- this.atlasManager_ = options.atlasManager;
- this.render_(this.atlasManager_);
- * @type {boolean}
- var snapToPixel = options.snapToPixel !== undefined ?
- options.snapToPixel : true;
- * @type {boolean}
- var rotateWithView = options.rotateWithView !== undefined ?
- options.rotateWithView : false;
- ol.style.Image.call(this, {
- opacity: 1,
- rotateWithView: rotateWithView,
- rotation: options.rotation !== undefined ? options.rotation : 0,
- scale: 1,
- snapToPixel: snapToPixel
-ol.inherits(ol.style.RegularShape, ol.style.Image);
- * Clones the style. If an atlasmanager was provided to the original style it will be used in the cloned style, too.
- * @return {ol.style.RegularShape} The cloned style.
- * @api
-ol.style.RegularShape.prototype.clone = function() {
- var style = new ol.style.RegularShape({
- fill: this.getFill() ? this.getFill().clone() : undefined,
- points: this.getRadius2() !== this.getRadius() ? this.getPoints() / 2 : this.getPoints(),
- radius: this.getRadius(),
- radius2: this.getRadius2(),
- angle: this.getAngle(),
- snapToPixel: this.getSnapToPixel(),
- stroke: this.getStroke() ? this.getStroke().clone() : undefined,
- rotation: this.getRotation(),
- rotateWithView: this.getRotateWithView(),
- atlasManager: this.atlasManager_
- style.setOpacity(this.getOpacity());
- style.setScale(this.getScale());
- return style;
- * @inheritDoc
- * @api
-ol.style.RegularShape.prototype.getAnchor = function() {
- return this.anchor_;
- * Get the angle used in generating the shape.
- * @return {number} Shape's rotation in radians.
- * @api
-ol.style.RegularShape.prototype.getAngle = function() {
- return this.angle_;
- * Get the fill style for the shape.
- * @return {ol.style.Fill} Fill style.
- * @api
-ol.style.RegularShape.prototype.getFill = function() {
- return this.fill_;
- * @inheritDoc
-ol.style.RegularShape.prototype.getHitDetectionImage = function(pixelRatio) {
- return this.hitDetectionCanvas_;
- * @inheritDoc
- * @api
-ol.style.RegularShape.prototype.getImage = function(pixelRatio) {
- return this.canvas_;
- * @inheritDoc
-ol.style.RegularShape.prototype.getImageSize = function() {
- return this.imageSize_;
- * @inheritDoc
-ol.style.RegularShape.prototype.getHitDetectionImageSize = function() {
- return this.hitDetectionImageSize_;
- * @inheritDoc
-ol.style.RegularShape.prototype.getImageState = function() {
- return ol.ImageState.LOADED;
- * @inheritDoc
- * @api
-ol.style.RegularShape.prototype.getOrigin = function() {
- return this.origin_;
- * Get the number of points for generating the shape.
- * @return {number} Number of points for stars and regular polygons.
- * @api
-ol.style.RegularShape.prototype.getPoints = function() {
- return this.points_;
- * Get the (primary) radius for the shape.
- * @return {number} Radius.
- * @api
-ol.style.RegularShape.prototype.getRadius = function() {
- return this.radius_;
- * Get the secondary radius for the shape.
- * @return {number} Radius2.
- * @api
-ol.style.RegularShape.prototype.getRadius2 = function() {
- return this.radius2_;
- * @inheritDoc
- * @api
-ol.style.RegularShape.prototype.getSize = function() {
- return this.size_;
- * Get the stroke style for the shape.
- * @return {ol.style.Stroke} Stroke style.
- * @api
-ol.style.RegularShape.prototype.getStroke = function() {
- return this.stroke_;
- * @inheritDoc
-ol.style.RegularShape.prototype.listenImageChange = function(listener, thisArg) {};
- * @inheritDoc
-ol.style.RegularShape.prototype.load = function() {};
- * @inheritDoc
-ol.style.RegularShape.prototype.unlistenImageChange = function(listener, thisArg) {};
- * @protected
- * @param {ol.style.AtlasManager|undefined} atlasManager An atlas manager.
-ol.style.RegularShape.prototype.render_ = function(atlasManager) {
- var imageSize;
- var lineCap = '';
- var lineJoin = '';
- var miterLimit = 0;
- var lineDash = null;
- var strokeStyle;
- var strokeWidth = 0;
- if (this.stroke_) {
- strokeStyle = this.stroke_.getColor();
- if (strokeStyle === null) {
- strokeStyle = ol.render.canvas.defaultStrokeStyle;
- strokeStyle = ol.colorlike.asColorLike(strokeStyle);
- strokeWidth = this.stroke_.getWidth();
- if (strokeWidth === undefined) {
- strokeWidth = ol.render.canvas.defaultLineWidth;
- lineDash = this.stroke_.getLineDash();
- if (!ol.has.CANVAS_LINE_DASH) {
- lineDash = null;
- lineJoin = this.stroke_.getLineJoin();
- if (lineJoin === undefined) {
- lineJoin = ol.render.canvas.defaultLineJoin;
- lineCap = this.stroke_.getLineCap();
- if (lineCap === undefined) {
- lineCap = ol.render.canvas.defaultLineCap;
- miterLimit = this.stroke_.getMiterLimit();
- if (miterLimit === undefined) {
- miterLimit = ol.render.canvas.defaultMiterLimit;
- var size = 2 * (this.radius_ + strokeWidth) + 1;
- /** @type {ol.RegularShapeRenderOptions} */
- var renderOptions = {
- strokeStyle: strokeStyle,
- strokeWidth: strokeWidth,
- size: size,
- lineCap: lineCap,
- lineDash: lineDash,
- lineJoin: lineJoin,
- miterLimit: miterLimit
- if (atlasManager === undefined) {
- // no atlas manager is used, create a new canvas
- var context = ol.dom.createCanvasContext2D(size, size);
- this.canvas_ = context.canvas;
- // canvas.width and height are rounded to the closest integer
- size = this.canvas_.width;
- imageSize = size;
- this.draw_(renderOptions, context, 0, 0);
- this.createHitDetectionCanvas_(renderOptions);
- } else {
- // an atlas manager is used, add the symbol to an atlas
- size = Math.round(size);
- var hasCustomHitDetectionImage = !this.fill_;
- var renderHitDetectionCallback;
- if (hasCustomHitDetectionImage) {
- // render the hit-detection image into a separate atlas image
- renderHitDetectionCallback =
- this.drawHitDetectionCanvas_.bind(this, renderOptions);
- var id = this.getChecksum();
- var info = atlasManager.add(
- id, size, size, this.draw_.bind(this, renderOptions),
- renderHitDetectionCallback);
- this.canvas_ = info.image;
- this.origin_ = [info.offsetX, info.offsetY];
- imageSize = info.image.width;
- this.hitDetectionCanvas_ = info.hitImage;
- [info.hitImage.width, info.hitImage.height];
- } else {
- this.hitDetectionCanvas_ = this.canvas_;
- this.hitDetectionImageSize_ = [imageSize, imageSize];
- this.anchor_ = [size / 2, size / 2];
- this.size_ = [size, size];
- this.imageSize_ = [imageSize, imageSize];
- * @private
- * @param {ol.RegularShapeRenderOptions} renderOptions Render options.
- * @param {CanvasRenderingContext2D} context The rendering context.
- * @param {number} x The origin for the symbol (x).
- * @param {number} y The origin for the symbol (y).
-ol.style.RegularShape.prototype.draw_ = function(renderOptions, context, x, y) {
- var i, angle0, radiusC;
- // reset transform
- context.setTransform(1, 0, 0, 1, 0, 0);
- // then move to (x, y)
- context.translate(x, y);
- context.beginPath();
- if (this.points_ === Infinity) {
- context.arc(
- renderOptions.size / 2, renderOptions.size / 2,
- this.radius_, 0, 2 * Math.PI, true);
- } else {
- if (this.radius2_ !== this.radius_) {
- this.points_ = 2 * this.points_;
- for (i = 0; i <= this.points_; i++) {
- angle0 = i * 2 * Math.PI / this.points_ - Math.PI / 2 + this.angle_;
- radiusC = i % 2 === 0 ? this.radius_ : this.radius2_;
- context.lineTo(renderOptions.size / 2 + radiusC * Math.cos(angle0),
- renderOptions.size / 2 + radiusC * Math.sin(angle0));
- if (this.fill_) {
- var color = this.fill_.getColor();
- if (color === null) {
- color = ol.render.canvas.defaultFillStyle;
- context.fillStyle = ol.colorlike.asColorLike(color);
- context.fill();
- context.strokeStyle = renderOptions.strokeStyle;
- context.lineWidth = renderOptions.strokeWidth;
- if (renderOptions.lineDash) {
- context.setLineDash(renderOptions.lineDash);
- context.lineCap = renderOptions.lineCap;
- context.lineJoin = renderOptions.lineJoin;
- context.miterLimit = renderOptions.miterLimit;
- context.stroke();
- context.closePath();
- * @private
-ol.style.RegularShape.prototype.createHitDetectionCanvas_ = function(renderOptions) {
- this.hitDetectionImageSize_ = [renderOptions.size, renderOptions.size];
- if (this.fill_) {
- return;
- // if no fill style is set, create an extra hit-detection image with a
- // default fill style
- var context = ol.dom.createCanvasContext2D(renderOptions.size, renderOptions.size);
- this.hitDetectionCanvas_ = context.canvas;
- this.drawHitDetectionCanvas_(renderOptions, context, 0, 0);
- * @private
- * @param {CanvasRenderingContext2D} context The context.
-ol.style.RegularShape.prototype.drawHitDetectionCanvas_ = function(renderOptions, context, x, y) {
- context.arc(
- } else {
- var i, radiusC, angle0;
- context.fillStyle = ol.render.canvas.defaultFillStyle;
- context.fill();
- context.stroke();
- * @return {string} The checksum.
-ol.style.RegularShape.prototype.getChecksum = function() {
- var strokeChecksum = this.stroke_ ?
- this.stroke_.getChecksum() : '-';
- var fillChecksum = this.fill_ ?
- this.fill_.getChecksum() : '-';
- var recalculate = !this.checksums_ ||
- (strokeChecksum != this.checksums_[1] ||
- fillChecksum != this.checksums_[2] ||
- this.radius_ != this.checksums_[3] ||
- this.radius2_ != this.checksums_[4] ||
- this.angle_ != this.checksums_[5] ||
- this.points_ != this.checksums_[6]);
- if (recalculate) {
- var checksum = 'r' + strokeChecksum + fillChecksum +
- (this.radius_ !== undefined ? this.radius_.toString() : '-') +
- (this.radius2_ !== undefined ? this.radius2_.toString() : '-') +
- (this.angle_ !== undefined ? this.angle_.toString() : '-') +
- (this.points_ !== undefined ? this.points_.toString() : '-');
- this.checksums_ = [checksum, strokeChecksum, fillChecksum,
- this.radius_, this.radius2_, this.angle_, this.points_];
- return this.checksums_[0];
-goog.provide('ol.style.Circle');
-goog.require('ol');
-goog.require('ol.style.RegularShape');
- * @classdesc
- * Set circle style for vector features.
- * @constructor
- * @param {olx.style.CircleOptions=} opt_options Options.
- * @extends {ol.style.RegularShape}
- * @api
-ol.style.Circle = function(opt_options) {
- var options = opt_options || {};
- ol.style.RegularShape.call(this, {
- points: Infinity,
- fill: options.fill,
- radius: options.radius,
- snapToPixel: options.snapToPixel,
- stroke: options.stroke,
- atlasManager: options.atlasManager
-ol.inherits(ol.style.Circle, ol.style.RegularShape);
- * @return {ol.style.Circle} The cloned style.
- * @override
- * @api
-ol.style.Circle.prototype.clone = function() {
- var style = new ol.style.Circle({
- return style;
- * Set the circle radius.
- * @param {number} radius Circle radius.
- * @api
-ol.style.Circle.prototype.setRadius = function(radius) {
- this.radius_ = radius;
-goog.provide('ol.style.Fill');
-goog.require('ol.color');
- * @classdesc
- * Set fill style for vector features.
- * @constructor
- * @param {olx.style.FillOptions=} opt_options Options.
- * @api
-ol.style.Fill = function(opt_options) {
- * @private
- * @type {ol.Color|ol.ColorLike}
- this.color_ = options.color !== undefined ? options.color : null;
- * @private
- * @type {string|undefined}
- this.checksum_ = undefined;
- * Clones the style. The color is not cloned if it is an {@link ol.ColorLike}.
- * @return {ol.style.Fill} The cloned style.
- * @api
-ol.style.Fill.prototype.clone = function() {
- var color = this.getColor();
- return new ol.style.Fill({
- color: (color && color.slice) ? color.slice() : color || undefined
- * Get the fill color.
- * @return {ol.Color|ol.ColorLike} Color.
- * @api
-ol.style.Fill.prototype.getColor = function() {
- return this.color_;
- * Set the color.
- * @param {ol.Color|ol.ColorLike} color Color.
- * @api
-ol.style.Fill.prototype.setColor = function(color) {
- this.color_ = color;
-ol.style.Fill.prototype.getChecksum = function() {
- if (this.checksum_ === undefined) {
- if (
- this.color_ instanceof CanvasPattern ||
- this.color_ instanceof CanvasGradient
- this.checksum_ = ol.getUid(this.color_).toString();
- } else {
- this.checksum_ = 'f' + (this.color_ ?
- ol.color.asString(this.color_) : '-');
- return this.checksum_;
-goog.provide('ol.style.Style');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.style.Circle');
-goog.require('ol.style.Fill');
-goog.require('ol.style.Stroke');
- * @classdesc
- * Container for vector feature rendering styles. Any changes made to the style
- * or its children through `set*()` methods will not take effect until the
- * feature or layer that uses the style is re-rendered.
- * @constructor
- * @struct
- * @param {olx.style.StyleOptions=} opt_options Style options.
- * @api
-ol.style.Style = function(opt_options) {
- * @private
- * @type {string|ol.geom.Geometry|ol.StyleGeometryFunction}
- this.geometry_ = null;
- * @private
- * @type {!ol.StyleGeometryFunction}
- this.geometryFunction_ = ol.style.Style.defaultGeometryFunction;
- if (options.geometry !== undefined) {
- this.setGeometry(options.geometry);
- * @private
- * @private
- * @type {ol.style.Image}
- this.image_ = options.image !== undefined ? options.image : null;
- * @private
- * @private
- * @type {ol.style.Text}
- this.text_ = options.text !== undefined ? options.text : null;
- * @private
- this.zIndex_ = options.zIndex;
- * @return {ol.style.Style} The cloned style.
- * @api
-ol.style.Style.prototype.clone = function() {
- var geometry = this.getGeometry();
- if (geometry && geometry.clone) {
- geometry = geometry.clone();
- return new ol.style.Style({
- geometry: geometry,
- image: this.getImage() ? this.getImage().clone() : undefined,
- text: this.getText() ? this.getText().clone() : undefined,
- zIndex: this.getZIndex()
- * Get the geometry to be rendered.
- * @return {string|ol.geom.Geometry|ol.StyleGeometryFunction}
- * Feature property or geometry or function that returns the geometry that will
- * be rendered with this style.
- * @api
-ol.style.Style.prototype.getGeometry = function() {
- return this.geometry_;
- * Get the function used to generate a geometry for rendering.
- * @return {!ol.StyleGeometryFunction} Function that is called with a feature
- * and returns the geometry to render instead of the feature's geometry.
- * @api
-ol.style.Style.prototype.getGeometryFunction = function() {
- return this.geometryFunction_;
- * Get the fill style.
- * @api
-ol.style.Style.prototype.getFill = function() {
- * Set the fill style.
- * @param {ol.style.Fill} fill Fill style.
- * @api
-ol.style.Style.prototype.setFill = function(fill) {
- this.fill_ = fill;
- * Get the image style.
- * @return {ol.style.Image} Image style.
- * @api
-ol.style.Style.prototype.getImage = function() {
- return this.image_;
- * Set the image style.
- * @param {ol.style.Image} image Image style.
- * @api
-ol.style.Style.prototype.setImage = function(image) {
- this.image_ = image;
- * Get the stroke style.
- * @api
-ol.style.Style.prototype.getStroke = function() {
- * Set the stroke style.
- * @param {ol.style.Stroke} stroke Stroke style.
- * @api
-ol.style.Style.prototype.setStroke = function(stroke) {
- this.stroke_ = stroke;
- * Get the text style.
- * @return {ol.style.Text} Text style.
- * @api
-ol.style.Style.prototype.getText = function() {
- return this.text_;
- * Set the text style.
- * @param {ol.style.Text} text Text style.
- * @api
-ol.style.Style.prototype.setText = function(text) {
- this.text_ = text;
- * Get the z-index for the style.
- * @return {number|undefined} ZIndex.
- * @api
-ol.style.Style.prototype.getZIndex = function() {
- return this.zIndex_;
- * Set a geometry that is rendered instead of the feature's geometry.
- * @param {string|ol.geom.Geometry|ol.StyleGeometryFunction} geometry
- * Feature property or geometry or function returning a geometry to render
- * for this style.
- * @api
-ol.style.Style.prototype.setGeometry = function(geometry) {
- if (typeof geometry === 'function') {
- this.geometryFunction_ = geometry;
- } else if (typeof geometry === 'string') {
- this.geometryFunction_ = function(feature) {
- return /** @type {ol.geom.Geometry} */ (feature.get(geometry));
- } else if (!geometry) {
- } else if (geometry !== undefined) {
- this.geometryFunction_ = function() {
- return /** @type {ol.geom.Geometry} */ (geometry);
- this.geometry_ = geometry;
- * Set the z-index.
- * @param {number|undefined} zIndex ZIndex.
- * @api
-ol.style.Style.prototype.setZIndex = function(zIndex) {
- this.zIndex_ = zIndex;
- * Convert the provided object into a style function. Functions passed through
- * unchanged. Arrays of ol.style.Style or single style objects wrapped in a
- * new style function.
- * @param {ol.StyleFunction|Array.<ol.style.Style>|ol.style.Style} obj
- * A style function, a single style, or an array of styles.
- * @return {ol.StyleFunction} A style function.
-ol.style.Style.createFunction = function(obj) {
- var styleFunction;
- if (typeof obj === 'function') {
- styleFunction = obj;
- } else {
- * @type {Array.<ol.style.Style>}
- var styles;
- if (Array.isArray(obj)) {
- styles = obj;
- } else {
- ol.asserts.assert(obj instanceof ol.style.Style,
- 41); // Expected an `ol.style.Style` or an array of `ol.style.Style`
- styles = [obj];
- styleFunction = function() {
- return styles;
- return styleFunction;
- * @private
-ol.style.Style.default_ = null;
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- * @param {number} resolution Resolution.
- * @return {Array.<ol.style.Style>} Style.
-ol.style.Style.defaultFunction = function(feature, resolution) {
- // We don't use an immediately-invoked function
- // and a closure so we don't get an error at script evaluation time in
- // browsers that do not support Canvas. (ol.style.Circle does
- // canvas.getContext('2d') at construction time, which will cause an.error
- // in such browsers.)
- if (!ol.style.Style.default_) {
- var fill = new ol.style.Fill({
- color: 'rgba(255,255,255,0.4)'
- var stroke = new ol.style.Stroke({
- color: '#3399CC',
- width: 1.25
- ol.style.Style.default_ = [
- new ol.style.Style({
- image: new ol.style.Circle({
- fill: fill,
- stroke: stroke,
- radius: 5
- fill: fill,
- stroke: stroke
- return ol.style.Style.default_;
- * Default styles for editing features.
- * @return {Object.<ol.geom.GeometryType, Array.<ol.style.Style>>} Styles
-ol.style.Style.createDefaultEditing = function() {
- /** @type {Object.<ol.geom.GeometryType, Array.<ol.style.Style>>} */
- var styles = {};
- var white = [255, 255, 255, 1];
- var blue = [0, 153, 255, 1];
- var width = 3;
- styles[ol.geom.GeometryType.POLYGON] = [
- fill: new ol.style.Fill({
- color: [255, 255, 255, 0.5]
- styles[ol.geom.GeometryType.MULTI_POLYGON] =
- styles[ol.geom.GeometryType.POLYGON];
- styles[ol.geom.GeometryType.LINE_STRING] = [
- stroke: new ol.style.Stroke({
- color: white,
- width: width + 2
- color: blue,
- width: width
- styles[ol.geom.GeometryType.MULTI_LINE_STRING] =
- styles[ol.geom.GeometryType.LINE_STRING];
- styles[ol.geom.GeometryType.CIRCLE] =
- styles[ol.geom.GeometryType.POLYGON].concat(
- styles[ol.geom.GeometryType.POINT] = [
- radius: width * 2,
- color: blue
- color: white,
- width: width / 2
- zIndex: Infinity
- styles[ol.geom.GeometryType.MULTI_POINT] =
- styles[ol.geom.GeometryType.POINT];
- styles[ol.geom.GeometryType.GEOMETRY_COLLECTION] =
- styles[ol.geom.GeometryType.LINE_STRING],
- return styles;
- * Function that is called with a feature and returns its default geometry.
- * @param {ol.Feature|ol.render.Feature} feature Feature to get the geometry
- * for.
- * @return {ol.geom.Geometry|ol.render.Feature|undefined} Geometry to render.
-ol.style.Style.defaultGeometryFunction = function(feature) {
- return feature.getGeometry();
-goog.provide('ol.Feature');
-goog.require('ol.events');
-goog.require('ol.geom.Geometry');
-goog.require('ol.style.Style');
- * @classdesc
- * A vector object for geographic features with a geometry and other
- * attribute properties, similar to the features in vector file formats like
- * GeoJSON.
- * Features can be styled individually with `setStyle`; otherwise they use the
- * style of their vector layer.
- * Note that attribute properties are set as {@link ol.Object} properties on
- * the feature object, so they are observable, and have get/set accessors.
- * Typically, a feature has a single geometry property. You can set the
- * geometry using the `setGeometry` method and get it with `getGeometry`.
- * It is possible to store more than one geometry on a feature using attribute
- * properties. By default, the geometry used for rendering is identified by
- * the property name `geometry`. If you want to use another geometry property
- * for rendering, use the `setGeometryName` method to change the attribute
- * property associated with the geometry for the feature. For example:
- * ```js
- * var feature = new ol.Feature({
- * geometry: new ol.geom.Polygon(polyCoords),
- * labelPoint: new ol.geom.Point(labelCoords),
- * name: 'My Polygon'
- * // get the polygon geometry
- * var poly = feature.getGeometry();
- * // Render the feature as a point using the coordinates from labelPoint
- * feature.setGeometryName('labelPoint');
- * // get the point geometry
- * var point = feature.getGeometry();
- * @constructor
- * @param {ol.geom.Geometry|Object.<string, *>=} opt_geometryOrProperties
- * You may pass a Geometry object directly, or an object literal
- * containing properties. If you pass an object literal, you may
- * include a Geometry associated with a `geometry` key.
- * @api
-ol.Feature = function(opt_geometryOrProperties) {
- * @private
- * @type {number|string|undefined}
- this.id_ = undefined;
- * @type {string}
- * @private
- this.geometryName_ = 'geometry';
- * User provided style.
- * @private
- * @type {ol.style.Style|Array.<ol.style.Style>|
- * ol.FeatureStyleFunction}
- this.style_ = null;
- * @private
- * @type {ol.FeatureStyleFunction|undefined}
- this.styleFunction_ = undefined;
- * @private
- this.geometryChangeKey_ = null;
- ol.events.listen(
- this, ol.Object.getChangeEventType(this.geometryName_),
- this.handleGeometryChanged_, this);
- if (opt_geometryOrProperties !== undefined) {
- if (opt_geometryOrProperties instanceof ol.geom.Geometry ||
- !opt_geometryOrProperties) {
- var geometry = opt_geometryOrProperties;
- this.setGeometry(geometry);
- } else {
- /** @type {Object.<string, *>} */
- var properties = opt_geometryOrProperties;
- this.setProperties(properties);
-ol.inherits(ol.Feature, ol.Object);
- * Clone this feature. If the original feature has a geometry it
- * is also cloned. The feature id is not set in the clone.
- * @return {ol.Feature} The clone.
- * @api
-ol.Feature.prototype.clone = function() {
- var clone = new ol.Feature(this.getProperties());
- clone.setGeometryName(this.getGeometryName());
- if (geometry) {
- clone.setGeometry(geometry.clone());
- var style = this.getStyle();
- if (style) {
- clone.setStyle(style);
- return clone;
- * Get the feature's default geometry. A feature may have any number of named
- * geometries. The "default" geometry (the one that is rendered by default) is
- * set when calling {@link ol.Feature#setGeometry}.
- * @return {ol.geom.Geometry|undefined} The default geometry for the feature.
- * @api
- * @observable
-ol.Feature.prototype.getGeometry = function() {
- return /** @type {ol.geom.Geometry|undefined} */ (
- this.get(this.geometryName_));
- * Get the feature identifier. This is a stable identifier for the feature and
- * is either set when reading data from a remote source or set explicitly by
- * calling {@link ol.Feature#setId}.
- * @return {number|string|undefined} Id.
- * @api
-ol.Feature.prototype.getId = function() {
- return this.id_;
- * Get the name of the feature's default geometry. By default, the default
- * geometry is named `geometry`.
- * @return {string} Get the property name associated with the default geometry
- * for this feature.
- * @api
-ol.Feature.prototype.getGeometryName = function() {
- return this.geometryName_;
- * Get the feature's style. Will return what was provided to the
- * {@link ol.Feature#setStyle} method.
- * @return {ol.style.Style|Array.<ol.style.Style>|
- * ol.FeatureStyleFunction|ol.StyleFunction} The feature style.
- * @api
-ol.Feature.prototype.getStyle = function() {
- return this.style_;
- * Get the feature's style function.
- * @return {ol.FeatureStyleFunction|undefined} Return a function
- * representing the current style of this feature.
- * @api
-ol.Feature.prototype.getStyleFunction = function() {
- return this.styleFunction_;
- * @private
-ol.Feature.prototype.handleGeometryChange_ = function() {
- this.changed();
- * @private
-ol.Feature.prototype.handleGeometryChanged_ = function() {
- if (this.geometryChangeKey_) {
- ol.events.unlistenByKey(this.geometryChangeKey_);
- if (geometry) {
- this.geometryChangeKey_ = ol.events.listen(geometry,
- ol.events.EventType.CHANGE, this.handleGeometryChange_, this);
- this.changed();
- * Set the default geometry for the feature. This will update the property
- * with the name returned by {@link ol.Feature#getGeometryName}.
- * @param {ol.geom.Geometry|undefined} geometry The new geometry.
- * @api
- * @observable
-ol.Feature.prototype.setGeometry = function(geometry) {
- this.set(this.geometryName_, geometry);
- * Set the style for the feature. This can be a single style object, an array
- * of styles, or a function that takes a resolution and returns an array of
- * styles. If it is `null` the feature has no style (a `null` style).
- * @param {ol.style.Style|Array.<ol.style.Style>|
- * ol.FeatureStyleFunction|ol.StyleFunction} style Style for this feature.
- * @api
- * @fires ol.events.Event#event:change
-ol.Feature.prototype.setStyle = function(style) {
- this.style_ = style;
- this.styleFunction_ = !style ?
- undefined : ol.Feature.createStyleFunction(style);
- this.changed();
- * Set the feature id. The feature id is considered stable and may be used when
- * requesting features or comparing identifiers returned from a remote source.
- * The feature id can be used with the {@link ol.source.Vector#getFeatureById}
- * method.
- * @param {number|string|undefined} id The feature id.
- * @api
-ol.Feature.prototype.setId = function(id) {
- this.id_ = id;
- this.changed();
- * Set the property name to be used when getting the feature's default geometry.
- * When calling {@link ol.Feature#getGeometry}, the value of the property with
- * this name will be returned.
- * @param {string} name The property name of the default geometry.
- * @api
-ol.Feature.prototype.setGeometryName = function(name) {
- ol.events.unlisten(
- this.geometryName_ = name;
- ol.events.listen(
- this.handleGeometryChanged_();
- * Convert the provided object into a feature style function. Functions passed
- * through unchanged. Arrays of ol.style.Style or single style objects wrapped
- * in a new feature style function.
- * @param {ol.FeatureStyleFunction|!Array.<ol.style.Style>|!ol.style.Style} obj
- * A feature style function, a single style, or an array of styles.
- * @return {ol.FeatureStyleFunction} A style function.
-ol.Feature.createStyleFunction = function(obj) {
- if (obj.length == 2) {
- styleFunction = function(resolution) {
- return /** @type {ol.StyleFunction} */ (obj)(this, resolution);
- } else {
- } else {
- var styles;
- styles = obj;
- } else {
- styles = [obj];
- return styles;
-goog.provide('ol.format.FormatType');
- * @enum {string}
-ol.format.FormatType = {
- ARRAY_BUFFER: 'arraybuffer',
- JSON: 'json',
- TEXT: 'text',
- XML: 'xml'
-goog.provide('ol.xml');
-goog.require('ol.array');
- * This document should be used when creating nodes for XML serializations. This
- * document is also used by {@link ol.xml.createElementNS} and
- * {@link ol.xml.setAttributeNS}
- * @const
- * @type {Document}
-ol.xml.DOCUMENT = document.implementation.createDocument('', '', null);
- * @param {string} namespaceURI Namespace URI.
- * @param {string} qualifiedName Qualified name.
- * @return {Node} Node.
-ol.xml.createElementNS = function(namespaceURI, qualifiedName) {
- return ol.xml.DOCUMENT.createElementNS(namespaceURI, qualifiedName);
- * Recursively grab all text content of child nodes into a single string.
- * @param {Node} node Node.
- * @param {boolean} normalizeWhitespace Normalize whitespace: remove all line
- * breaks.
- * @return {string} All text content.
- * @api
-ol.xml.getAllTextContent = function(node, normalizeWhitespace) {
- return ol.xml.getAllTextContent_(node, normalizeWhitespace, []).join('');
- * breaks.
- * @param {Array.<string>} accumulator Accumulator.
- * @private
- * @return {Array.<string>} Accumulator.
-ol.xml.getAllTextContent_ = function(node, normalizeWhitespace, accumulator) {
- if (node.nodeType == Node.CDATA_SECTION_NODE ||
- node.nodeType == Node.TEXT_NODE) {
- if (normalizeWhitespace) {
- accumulator.push(String(node.nodeValue).replace(/(\r\n|\r|\n)/g, ''));
- } else {
- accumulator.push(node.nodeValue);
- } else {
- var n;
- for (n = node.firstChild; n; n = n.nextSibling) {
- ol.xml.getAllTextContent_(n, normalizeWhitespace, accumulator);
- return accumulator;
- * @param {?} value Value.
- * @return {boolean} Is document.
-ol.xml.isDocument = function(value) {
- return value instanceof Document;
- * @return {boolean} Is node.
-ol.xml.isNode = function(value) {
- return value instanceof Node;
- * @param {?string} namespaceURI Namespace URI.
- * @param {string} name Attribute name.
- * @return {string} Value
-ol.xml.getAttributeNS = function(node, namespaceURI, name) {
- return node.getAttributeNS(namespaceURI, name) || '';
- * @param {string|number} value Value.
-ol.xml.setAttributeNS = function(node, namespaceURI, name, value) {
- node.setAttributeNS(namespaceURI, name, value);
- * Parse an XML string to an XML Document.
- * @param {string} xml XML.
- * @return {Document} Document.
- * @api
-ol.xml.parse = function(xml) {
- return new DOMParser().parseFromString(xml, 'application/xml');
- * Make an array extender function for extending the array at the top of the
- * object stack.
- * @param {function(this: T, Node, Array.<*>): (Array.<*>|undefined)}
- * valueReader Value reader.
- * @param {T=} opt_this The object to use as `this` in `valueReader`.
- * @return {ol.XmlParser} Parser.
- * @template T
-ol.xml.makeArrayExtender = function(valueReader, opt_this) {
- return (
- * @param {Array.<*>} objectStack Object stack.
- function(node, objectStack) {
- var value = valueReader.call(opt_this, node, objectStack);
- if (value !== undefined) {
- var array = /** @type {Array.<*>} */
- (objectStack[objectStack.length - 1]);
- ol.array.extend(array, value);
- * Make an array pusher function for pushing to the array at the top of the
- * object stack.
- * @param {function(this: T, Node, Array.<*>): *} valueReader Value reader.
- * @template T
-ol.xml.makeArrayPusher = function(valueReader, opt_this) {
- return (
- var value = valueReader.call(opt_this !== undefined ? opt_this : this,
- node, objectStack);
- var array = objectStack[objectStack.length - 1];
- array.push(value);
- * Make an object stack replacer function for replacing the object at the
- * top of the stack.
- * @template T
-ol.xml.makeReplacer = function(valueReader, opt_this) {
- return (
- objectStack[objectStack.length - 1] = value;
- * Make an object property pusher function for adding a property to the
- * object at the top of the stack.
- * @param {string=} opt_property Property.
- * @template T
-ol.xml.makeObjectPropertyPusher = function(valueReader, opt_property, opt_this) {
- return (
- var object = /** @type {Object} */
- var property = opt_property !== undefined ?
- opt_property : node.localName;
- var array;
- if (property in object) {
- array = object[property];
- } else {
- array = object[property] = [];
- * Make an object property setter function.
- * @template T
-ol.xml.makeObjectPropertySetter = function(valueReader, opt_property, opt_this) {
- return (
- object[property] = value;
- * Create a serializer that appends nodes written by its `nodeWriter` to its
- * designated parent. The parent is the `node` of the
- * {@link ol.XmlNodeStackItem} at the top of the `objectStack`.
- * @param {function(this: T, Node, V, Array.<*>)}
- * nodeWriter Node writer.
- * @param {T=} opt_this The object to use as `this` in `nodeWriter`.
- * @return {ol.XmlSerializer} Serializer.
- * @template T, V
-ol.xml.makeChildAppender = function(nodeWriter, opt_this) {
- return function(node, value, objectStack) {
- nodeWriter.call(opt_this !== undefined ? opt_this : this,
- node, value, objectStack);
- var parent = objectStack[objectStack.length - 1];
- var parentNode = parent.node;
- parentNode.appendChild(node);
- * Create a serializer that calls the provided `nodeWriter` from
- * {@link ol.xml.serialize}. This can be used by the parent writer to have the
- * 'nodeWriter' called with an array of values when the `nodeWriter` was
- * designed to serialize a single item. An example would be a LineString
- * geometry writer, which could be reused for writing MultiLineString
- * geometries.
- * @template T, V
-ol.xml.makeArraySerializer = function(nodeWriter, opt_this) {
- var serializersNS, nodeFactory;
- if (serializersNS === undefined) {
- serializersNS = {};
- var serializers = {};
- serializers[node.localName] = nodeWriter;
- serializersNS[node.namespaceURI] = serializers;
- nodeFactory = ol.xml.makeSimpleNodeFactory(node.localName);
- ol.xml.serialize(serializersNS, nodeFactory, value, objectStack);
- * Create a node factory which can use the `opt_keys` passed to
- * {@link ol.xml.serialize} or {@link ol.xml.pushSerializeAndPop} as node names,
- * or a fixed node name. The namespace of the created nodes can either be fixed,
- * or the parent namespace will be used.
- * @param {string=} opt_nodeName Fixed node name which will be used for all
- * created nodes. If not provided, the 3rd argument to the resulting node
- * factory needs to be provided and will be the nodeName.
- * @param {string=} opt_namespaceURI Fixed namespace URI which will be used for
- * all created nodes. If not provided, the namespace of the parent node will
- * be used.
- * @return {function(*, Array.<*>, string=): (Node|undefined)} Node factory.
-ol.xml.makeSimpleNodeFactory = function(opt_nodeName, opt_namespaceURI) {
- var fixedNodeName = opt_nodeName;
- return (
- * @param {*} value Value.
- * @param {string=} opt_nodeName Node name.
- function(value, objectStack, opt_nodeName) {
- var context = objectStack[objectStack.length - 1];
- var node = context.node;
- var nodeName = fixedNodeName;
- if (nodeName === undefined) {
- nodeName = opt_nodeName;
- var namespaceURI = opt_namespaceURI;
- if (opt_namespaceURI === undefined) {
- namespaceURI = node.namespaceURI;
- return ol.xml.createElementNS(namespaceURI, /** @type {string} */ (nodeName));
- * A node factory that creates a node using the parent's `namespaceURI` and the
- * `nodeName` passed by {@link ol.xml.serialize} or
- * {@link ol.xml.pushSerializeAndPop} to the node factory.
- * @const
- * @type {function(*, Array.<*>, string=): (Node|undefined)}
-ol.xml.OBJECT_PROPERTY_NODE_FACTORY = ol.xml.makeSimpleNodeFactory();
- * Create an array of `values` to be used with {@link ol.xml.serialize} or
- * {@link ol.xml.pushSerializeAndPop}, where `orderedKeys` has to be provided as
- * `opt_key` argument.
- * @param {Object.<string, V>} object Key-value pairs for the sequence. Keys can
- * be a subset of the `orderedKeys`.
- * @param {Array.<string>} orderedKeys Keys in the order of the sequence.
- * @return {Array.<V>} Values in the order of the sequence. The resulting array
- * has the same length as the `orderedKeys` array. Values that are not
- * present in `object` will be `undefined` in the resulting array.
- * @template V
-ol.xml.makeSequence = function(object, orderedKeys) {
- var length = orderedKeys.length;
- var sequence = new Array(length);
- for (var i = 0; i < length; ++i) {
- sequence[i] = object[orderedKeys[i]];
- return sequence;
- * Create a namespaced structure, using the same values for each namespace.
- * This can be used as a starting point for versioned parsers, when only a few
- * values are version specific.
- * @param {Array.<string>} namespaceURIs Namespace URIs.
- * @param {T} structure Structure.
- * @param {Object.<string, T>=} opt_structureNS Namespaced structure to add to.
- * @return {Object.<string, T>} Namespaced structure.
- * @template T
-ol.xml.makeStructureNS = function(namespaceURIs, structure, opt_structureNS) {
- * @type {Object.<string, *>}
- var structureNS = opt_structureNS !== undefined ? opt_structureNS : {};
- var i, ii;
- for (i = 0, ii = namespaceURIs.length; i < ii; ++i) {
- structureNS[namespaceURIs[i]] = structure;
- return structureNS;
- * Parse a node using the parsers and object stack.
- * @param {Object.<string, Object.<string, ol.XmlParser>>} parsersNS
- * Parsers by namespace.
- * @param {*=} opt_this The object to use as `this`.
-ol.xml.parseNode = function(parsersNS, node, objectStack, opt_this) {
- var n;
- for (n = node.firstElementChild; n; n = n.nextElementSibling) {
- var parsers = parsersNS[n.namespaceURI];
- if (parsers !== undefined) {
- var parser = parsers[n.localName];
- if (parser !== undefined) {
- parser.call(opt_this, n, objectStack);
- * Push an object on top of the stack, parse and return the popped object.
- * @param {T} object Object.
- * @return {T} Object.
- * @template T
-ol.xml.pushParseAndPop = function(
- object, parsersNS, node, objectStack, opt_this) {
- objectStack.push(object);
- ol.xml.parseNode(parsersNS, node, objectStack, opt_this);
- return objectStack.pop();
- * Walk through an array of `values` and call a serializer for each value.
- * @param {Object.<string, Object.<string, ol.XmlSerializer>>} serializersNS
- * Namespaced serializers.
- * @param {function(this: T, *, Array.<*>, (string|undefined)): (Node|undefined)} nodeFactory
- * Node factory. The `nodeFactory` creates the node whose namespace and name
- * will be used to choose a node writer from `serializersNS`. This
- * separation allows us to decide what kind of node to create, depending on
- * the value we want to serialize. An example for this would be different
- * geometry writers based on the geometry type.
- * @param {Array.<*>} values Values to serialize. An example would be an array
- * of {@link ol.Feature} instances.
- * @param {Array.<*>} objectStack Node stack.
- * @param {Array.<string>=} opt_keys Keys of the `values`. Will be passed to the
- * `nodeFactory`. This is used for serializing object literals where the
- * node name relates to the property key. The array length of `opt_keys` has
- * to match the length of `values`. For serializing a sequence, `opt_keys`
- * determines the order of the sequence.
- * @param {T=} opt_this The object to use as `this` for the node factory and
- * serializers.
- * @template T
-ol.xml.serialize = function(
- serializersNS, nodeFactory, values, objectStack, opt_keys, opt_this) {
- var length = (opt_keys !== undefined ? opt_keys : values).length;
- var value, node;
- value = values[i];
- node = nodeFactory.call(opt_this, value, objectStack,
- opt_keys !== undefined ? opt_keys[i] : undefined);
- if (node !== undefined) {
- serializersNS[node.namespaceURI][node.localName]
- .call(opt_this, node, value, objectStack);
- * @param {O} object Object.
- * serializers.
- * @return {O|undefined} Object.
- * @template O, T
-ol.xml.pushSerializeAndPop = function(object,
- ol.xml.serialize(
- serializersNS, nodeFactory, values, objectStack, opt_keys, opt_this);
-goog.provide('ol.featureloader');
-goog.require('ol.format.FormatType');
-goog.require('ol.xml');
- * @param {string|ol.FeatureUrlFunction} url Feature URL service.
- * @param {ol.format.Feature} format Feature format.
- * @param {function(this:ol.VectorTile, Array.<ol.Feature>, ol.proj.Projection)|function(this:ol.source.Vector, Array.<ol.Feature>)} success
- * Function called with the loaded features and optionally with the data
- * projection. Called with the vector tile or source as `this`.
- * @param {function(this:ol.VectorTile)|function(this:ol.source.Vector)} failure
- * Function called when loading failed. Called with the vector tile or
- * source as `this`.
- * @return {ol.FeatureLoader} The feature loader.
-ol.featureloader.loadFeaturesXhr = function(url, format, success, failure) {
- return (
- * @param {ol.Extent} extent Extent.
- * @param {ol.proj.Projection} projection Projection.
- * @this {ol.source.Vector|ol.VectorTile}
- function(extent, resolution, projection) {
- var xhr = new XMLHttpRequest();
- xhr.open('GET',
- typeof url === 'function' ? url(extent, resolution, projection) : url,
- true);
- if (format.getType() == ol.format.FormatType.ARRAY_BUFFER) {
- xhr.responseType = 'arraybuffer';
- * @param {Event} event Event.
- * @private
- xhr.onload = function(event) {
- // status will be 0 for file:// urls
- if (!xhr.status || xhr.status >= 200 && xhr.status < 300) {
- var type = format.getType();
- /** @type {Document|Node|Object|string|undefined} */
- var source;
- if (type == ol.format.FormatType.JSON ||
- type == ol.format.FormatType.TEXT) {
- source = xhr.responseText;
- } else if (type == ol.format.FormatType.XML) {
- source = xhr.responseXML;
- if (!source) {
- source = ol.xml.parse(xhr.responseText);
- } else if (type == ol.format.FormatType.ARRAY_BUFFER) {
- source = /** @type {ArrayBuffer} */ (xhr.response);
- if (source) {
- success.call(this, format.readFeatures(source,
- {featureProjection: projection}),
- format.readProjection(source));
- } else {
- failure.call(this);
- } else {
- }.bind(this);
- * @private
- xhr.onerror = function() {
- }.bind(this);
- xhr.send();
- * Create an XHR feature loader for a `url` and `format`. The feature loader
- * loads features (with XHR), parses the features, and adds them to the
- * vector source.
- * @api
-ol.featureloader.xhr = function(url, format) {
- return ol.featureloader.loadFeaturesXhr(url, format,
- * @param {Array.<ol.Feature>} features The loaded features.
- * @param {ol.proj.Projection} dataProjection Data projection.
- * @this {ol.source.Vector}
- function(features, dataProjection) {
- this.addFeatures(features);
- }, /* FIXME handle error */ ol.nullFunction);
-goog.provide('ol.format.Feature');
-goog.require('ol.obj');
-goog.require('ol.proj');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * Base class for feature formats.
- * {ol.format.Feature} subclasses provide the ability to decode and encode
- * {@link ol.Feature} objects from a variety of commonly used geospatial
- * file formats. See the documentation for each format for more details.
- * @constructor
- * @abstract
- * @api
-ol.format.Feature = function() {
- * @protected
- * @type {ol.proj.Projection}
- this.defaultDataProjection = null;
- * @protected
- this.defaultFeatureProjection = null;
- * Adds the data projection to the read options.
- * @param {Document|Node|Object|string} source Source.
- * @param {olx.format.ReadOptions=} opt_options Options.
- * @return {olx.format.ReadOptions|undefined} Options.
- * @protected
-ol.format.Feature.prototype.getReadOptions = function(source, opt_options) {
- var options;
- if (opt_options) {
- options = {
- dataProjection: opt_options.dataProjection ?
- opt_options.dataProjection : this.readProjection(source),
- featureProjection: opt_options.featureProjection
- return this.adaptOptions(options);
- * Sets the `defaultDataProjection` on the options, if no `dataProjection`
- * is set.
- * @param {olx.format.WriteOptions|olx.format.ReadOptions|undefined} options
- * Options.
- * @protected
- * @return {olx.format.WriteOptions|olx.format.ReadOptions|undefined}
- * Updated options.
-ol.format.Feature.prototype.adaptOptions = function(options) {
- return ol.obj.assign({
- dataProjection: this.defaultDataProjection,
- featureProjection: this.defaultFeatureProjection
- }, options);
- * @abstract
- * @return {ol.format.FormatType} Format.
-ol.format.Feature.prototype.getType = function() {};
- * Read a single feature from a source.
- * @abstract
- * @param {olx.format.ReadOptions=} opt_options Read options.
- * @return {ol.Feature} Feature.
-ol.format.Feature.prototype.readFeature = function(source, opt_options) {};
- * Read all features from a source.
- * @abstract
- * @param {Document|Node|ArrayBuffer|Object|string} source Source.
- * @return {Array.<ol.Feature>} Features.
-ol.format.Feature.prototype.readFeatures = function(source, opt_options) {};
- * Read a single geometry from a source.
- * @abstract
- * @return {ol.geom.Geometry} Geometry.
-ol.format.Feature.prototype.readGeometry = function(source, opt_options) {};
- * Read the projection from a source.
- * @abstract
- * @return {ol.proj.Projection} Projection.
-ol.format.Feature.prototype.readProjection = function(source) {};
- * Encode a feature in this format.
- * @abstract
- * @param {ol.Feature} feature Feature.
- * @param {olx.format.WriteOptions=} opt_options Write options.
- * @return {string} Result.
-ol.format.Feature.prototype.writeFeature = function(feature, opt_options) {};
- * Encode an array of features in this format.
- * @abstract
- * @param {Array.<ol.Feature>} features Features.
-ol.format.Feature.prototype.writeFeatures = function(features, opt_options) {};
- * Write a single geometry in this format.
- * @abstract
- * @param {ol.geom.Geometry} geometry Geometry.
-ol.format.Feature.prototype.writeGeometry = function(geometry, opt_options) {};
- * @param {ol.geom.Geometry|ol.Extent} geometry Geometry.
- * @param {boolean} write Set to true for writing, false for reading.
- * @param {(olx.format.WriteOptions|olx.format.ReadOptions)=} opt_options
- * Options.
- * @return {ol.geom.Geometry|ol.Extent} Transformed geometry.
- * @protected
-ol.format.Feature.transformWithOptions = function(
- geometry, write, opt_options) {
- var featureProjection = opt_options ?
- ol.proj.get(opt_options.featureProjection) : null;
- var dataProjection = opt_options ?
- ol.proj.get(opt_options.dataProjection) : null;
- * @type {ol.geom.Geometry|ol.Extent}
- var transformed;
- if (featureProjection && dataProjection &&
- !ol.proj.equivalent(featureProjection, dataProjection)) {
- if (geometry instanceof ol.geom.Geometry) {
- transformed = (write ? geometry.clone() : geometry).transform(
- write ? featureProjection : dataProjection,
- write ? dataProjection : featureProjection);
- } else {
- // FIXME this is necessary because ol.format.GML treats extents
- // as geometries
- transformed = ol.proj.transformExtent(
- write ? geometry.slice() : geometry,
- } else {
- transformed = geometry;
- if (write && opt_options && opt_options.decimals) {
- var power = Math.pow(10, opt_options.decimals);
- // if decimals option on write, round each coordinate appropriately
- * @param {Array.<number>} coordinates Coordinates.
- * @return {Array.<number>} Transformed coordinates.
- var transform = function(coordinates) {
- for (var i = 0, ii = coordinates.length; i < ii; ++i) {
- coordinates[i] = Math.round(coordinates[i] * power) / power;
- return coordinates;
- if (Array.isArray(transformed)) {
- transform(transformed);
- } else {
- transformed.applyTransform(transform);
- return transformed;
-goog.provide('ol.format.JSONFeature');
-goog.require('ol.format.Feature');
- * @classdesc
- * Base class for JSON feature formats.
- * @constructor
- * @abstract
- * @extends {ol.format.Feature}
-ol.format.JSONFeature = function() {
- ol.format.Feature.call(this);
-ol.inherits(ol.format.JSONFeature, ol.format.Feature);
- * @private
- * @return {Object} Object.
-ol.format.JSONFeature.prototype.getObject_ = function(source) {
- if (typeof source === 'string') {
- var object = JSON.parse(source);
- return object ? /** @type {Object} */ (object) : null;
- } else if (source !== null) {
- return source;
- } else {
- return null;
- * @inheritDoc
-ol.format.JSONFeature.prototype.getType = function() {
- return ol.format.FormatType.JSON;
- * @inheritDoc
-ol.format.JSONFeature.prototype.readFeature = function(source, opt_options) {
- return this.readFeatureFromObject(
- this.getObject_(source), this.getReadOptions(source, opt_options));
- * @inheritDoc
-ol.format.JSONFeature.prototype.readFeatures = function(source, opt_options) {
- return this.readFeaturesFromObject(
- * @abstract
- * @param {Object} object Object.
- * @protected
-ol.format.JSONFeature.prototype.readFeatureFromObject = function(object, opt_options) {};
- * @abstract
- * @protected
-ol.format.JSONFeature.prototype.readFeaturesFromObject = function(object, opt_options) {};
- * @inheritDoc
-ol.format.JSONFeature.prototype.readGeometry = function(source, opt_options) {
- return this.readGeometryFromObject(
- * @abstract
- * @protected
-ol.format.JSONFeature.prototype.readGeometryFromObject = function(object, opt_options) {};
- * @inheritDoc
-ol.format.JSONFeature.prototype.readProjection = function(source) {
- return this.readProjectionFromObject(this.getObject_(source));
- * @abstract
- * @protected
-ol.format.JSONFeature.prototype.readProjectionFromObject = function(object) {};
- * @inheritDoc
-ol.format.JSONFeature.prototype.writeFeature = function(feature, opt_options) {
- return JSON.stringify(this.writeFeatureObject(feature, opt_options));
- * @abstract
-ol.format.JSONFeature.prototype.writeFeatureObject = function(feature, opt_options) {};
- * @inheritDoc
-ol.format.JSONFeature.prototype.writeFeatures = function(features, opt_options) {
- return JSON.stringify(this.writeFeaturesObject(features, opt_options));
- * @abstract
-ol.format.JSONFeature.prototype.writeFeaturesObject = function(features, opt_options) {};
- * @inheritDoc
-ol.format.JSONFeature.prototype.writeGeometry = function(geometry, opt_options) {
- return JSON.stringify(this.writeGeometryObject(geometry, opt_options));
- * @abstract
-ol.format.JSONFeature.prototype.writeGeometryObject = function(geometry, opt_options) {};
-goog.provide('ol.geom.flat.interpolate');
-goog.require('ol.math');
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
- * @param {number} fraction Fraction.
- * @param {Array.<number>=} opt_dest Destination.
- * @return {Array.<number>} Destination.
-ol.geom.flat.interpolate.lineString = function(flatCoordinates, offset, end, stride, fraction, opt_dest) {
- var pointX = NaN;
- var pointY = NaN;
- var n = (end - offset) / stride;
- if (n === 1) {
- pointX = flatCoordinates[offset];
- pointY = flatCoordinates[offset + 1];
- } else if (n == 2) {
- pointX = (1 - fraction) * flatCoordinates[offset] +
- fraction * flatCoordinates[offset + stride];
- pointY = (1 - fraction) * flatCoordinates[offset + 1] +
- fraction * flatCoordinates[offset + stride + 1];
- } else if (n !== 0) {
- var x1 = flatCoordinates[offset];
- var y1 = flatCoordinates[offset + 1];
- var length = 0;
- var cumulativeLengths = [0];
- var i;
- for (i = offset + stride; i < end; i += stride) {
- var x2 = flatCoordinates[i];
- var y2 = flatCoordinates[i + 1];
- length += Math.sqrt((x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1));
- cumulativeLengths.push(length);
- x1 = x2;
- y1 = y2;
- var target = fraction * length;
- var index = ol.array.binarySearch(cumulativeLengths, target);
- if (index < 0) {
- var t = (target - cumulativeLengths[-index - 2]) /
- (cumulativeLengths[-index - 1] - cumulativeLengths[-index - 2]);
- var o = offset + (-index - 2) * stride;
- pointX = ol.math.lerp(
- flatCoordinates[o], flatCoordinates[o + stride], t);
- pointY = ol.math.lerp(
- flatCoordinates[o + 1], flatCoordinates[o + stride + 1], t);
- } else {
- pointX = flatCoordinates[offset + index * stride];
- pointY = flatCoordinates[offset + index * stride + 1];
- if (opt_dest) {
- opt_dest[0] = pointX;
- opt_dest[1] = pointY;
- return opt_dest;
- } else {
- return [pointX, pointY];
- * @param {number} m M.
- * @param {boolean} extrapolate Extrapolate.
- * @return {ol.Coordinate} Coordinate.
-ol.geom.flat.interpolate.lineStringCoordinateAtM = function(flatCoordinates, offset, end, stride, m, extrapolate) {
- if (end == offset) {
- return null;
- var coordinate;
- if (m < flatCoordinates[offset + stride - 1]) {
- if (extrapolate) {
- coordinate = flatCoordinates.slice(offset, offset + stride);
- coordinate[stride - 1] = m;
- return coordinate;
- } else {
- return null;
- } else if (flatCoordinates[end - 1] < m) {
- coordinate = flatCoordinates.slice(end - stride, end);
- } else {
- return null;
- // FIXME use O(1) search
- if (m == flatCoordinates[offset + stride - 1]) {
- return flatCoordinates.slice(offset, offset + stride);
- var lo = offset / stride;
- var hi = end / stride;
- while (lo < hi) {
- var mid = (lo + hi) >> 1;
- if (m < flatCoordinates[(mid + 1) * stride - 1]) {
- hi = mid;
- } else {
- lo = mid + 1;
- var m0 = flatCoordinates[lo * stride - 1];
- if (m == m0) {
- return flatCoordinates.slice((lo - 1) * stride, (lo - 1) * stride + stride);
- var m1 = flatCoordinates[(lo + 1) * stride - 1];
- var t = (m - m0) / (m1 - m0);
- coordinate = [];
- var i;
- for (i = 0; i < stride - 1; ++i) {
- coordinate.push(ol.math.lerp(flatCoordinates[(lo - 1) * stride + i],
- flatCoordinates[lo * stride + i], t));
- coordinate.push(m);
- * @param {Array.<number>} ends Ends.
- * @param {boolean} interpolate Interpolate.
-ol.geom.flat.interpolate.lineStringsCoordinateAtM = function(
- flatCoordinates, offset, ends, stride, m, extrapolate, interpolate) {
- if (interpolate) {
- return ol.geom.flat.interpolate.lineStringCoordinateAtM(
- flatCoordinates, offset, ends[ends.length - 1], stride, m, extrapolate);
- var coordinate;
- if (m < flatCoordinates[stride - 1]) {
- coordinate = flatCoordinates.slice(0, stride);
- } else {
- return null;
- if (flatCoordinates[flatCoordinates.length - 1] < m) {
- coordinate = flatCoordinates.slice(flatCoordinates.length - stride);
- } else {
- return null;
- var i, ii;
- for (i = 0, ii = ends.length; i < ii; ++i) {
- var end = ends[i];
- if (offset == end) {
- continue;
- return null;
- } else if (m <= flatCoordinates[end - 1]) {
- flatCoordinates, offset, end, stride, m, false);
- offset = end;
- return null;
-goog.provide('ol.geom.flat.length');
- * @return {number} Length.
-ol.geom.flat.length.lineString = function(flatCoordinates, offset, end, stride) {
- var length = 0;
- var i;
- x1 = x2;
- y1 = y2;
- return length;
- * @return {number} Perimeter.
-ol.geom.flat.length.linearRing = function(flatCoordinates, offset, end, stride) {
- var perimeter =
- ol.geom.flat.length.lineString(flatCoordinates, offset, end, stride);
- var dx = flatCoordinates[end - stride] - flatCoordinates[offset];
- var dy = flatCoordinates[end - stride + 1] - flatCoordinates[offset + 1];
- perimeter += Math.sqrt(dx * dx + dy * dy);
- return perimeter;
-goog.provide('ol.geom.LineString');
-goog.require('ol.extent');
-goog.require('ol.geom.GeometryLayout');
-goog.require('ol.geom.SimpleGeometry');
-goog.require('ol.geom.flat.closest');
-goog.require('ol.geom.flat.deflate');
-goog.require('ol.geom.flat.inflate');
-goog.require('ol.geom.flat.interpolate');
-goog.require('ol.geom.flat.intersectsextent');
-goog.require('ol.geom.flat.length');
-goog.require('ol.geom.flat.segments');
-goog.require('ol.geom.flat.simplify');
- * @classdesc
- * Linestring geometry.
- * @constructor
- * @extends {ol.geom.SimpleGeometry}
- * @param {Array.<ol.Coordinate>} coordinates Coordinates.
- * @param {ol.geom.GeometryLayout=} opt_layout Layout.
- * @api
-ol.geom.LineString = function(coordinates, opt_layout) {
- ol.geom.SimpleGeometry.call(this);
- * @private
- * @type {ol.Coordinate}
- this.flatMidpoint_ = null;
- * @private
- * @type {number}
- this.flatMidpointRevision_ = -1;
- * @private
- * @type {number}
- this.maxDelta_ = -1;
- * @private
- * @type {number}
- this.maxDeltaRevision_ = -1;
- this.setCoordinates(coordinates, opt_layout);
-ol.inherits(ol.geom.LineString, ol.geom.SimpleGeometry);
- * Append the passed coordinate to the coordinates of the linestring.
- * @param {ol.Coordinate} coordinate Coordinate.
- * @api
-ol.geom.LineString.prototype.appendCoordinate = function(coordinate) {
- if (!this.flatCoordinates) {
- this.flatCoordinates = coordinate.slice();
- } else {
- ol.array.extend(this.flatCoordinates, coordinate);
- this.changed();
- * Make a complete copy of the geometry.
- * @return {!ol.geom.LineString} Clone.
- * @override
- * @api
-ol.geom.LineString.prototype.clone = function() {
- var lineString = new ol.geom.LineString(null);
- lineString.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
- return lineString;
- * @inheritDoc
-ol.geom.LineString.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- if (minSquaredDistance <
- ol.extent.closestSquaredDistanceXY(this.getExtent(), x, y)) {
- return minSquaredDistance;
- if (this.maxDeltaRevision_ != this.getRevision()) {
- this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getMaxSquaredDelta(
- this.flatCoordinates, 0, this.flatCoordinates.length, this.stride, 0));
- this.maxDeltaRevision_ = this.getRevision();
- return ol.geom.flat.closest.getClosestPoint(
- this.maxDelta_, false, x, y, closestPoint, minSquaredDistance);
- * Iterate over each segment, calling the provided callback.
- * If the callback returns a truthy value the function returns that
- * value immediately. Otherwise the function returns `false`.
- * @param {function(this: S, ol.Coordinate, ol.Coordinate): T} callback Function
- * called for each segment.
- * @param {S=} opt_this The object to be used as the value of 'this'
- * within callback.
- * @return {T|boolean} Value.
- * @template T,S
- * @api
-ol.geom.LineString.prototype.forEachSegment = function(callback, opt_this) {
- return ol.geom.flat.segments.forEach(this.flatCoordinates, 0,
- this.flatCoordinates.length, this.stride, callback, opt_this);
- * Returns the coordinate at `m` using linear interpolation, or `null` if no
- * such coordinate exists.
- * `opt_extrapolate` controls extrapolation beyond the range of Ms in the
- * MultiLineString. If `opt_extrapolate` is `true` then Ms less than the first
- * M will return the first coordinate and Ms greater than the last M will
- * return the last coordinate.
- * @param {boolean=} opt_extrapolate Extrapolate. Default is `false`.
- * @api
-ol.geom.LineString.prototype.getCoordinateAtM = function(m, opt_extrapolate) {
- if (this.layout != ol.geom.GeometryLayout.XYM &&
- this.layout != ol.geom.GeometryLayout.XYZM) {
- return null;
- var extrapolate = opt_extrapolate !== undefined ? opt_extrapolate : false;
- return ol.geom.flat.interpolate.lineStringCoordinateAtM(this.flatCoordinates, 0,
- this.flatCoordinates.length, this.stride, m, extrapolate);
- * Return the coordinates of the linestring.
- * @return {Array.<ol.Coordinate>} Coordinates.
- * @override
- * @api
-ol.geom.LineString.prototype.getCoordinates = function() {
- return ol.geom.flat.inflate.coordinates(
- this.flatCoordinates, 0, this.flatCoordinates.length, this.stride);
- * Return the coordinate at the provided fraction along the linestring.
- * The `fraction` is a number between 0 and 1, where 0 is the start of the
- * linestring and 1 is the end.
- * @param {ol.Coordinate=} opt_dest Optional coordinate whose values will
- * be modified. If not provided, a new coordinate will be returned.
- * @return {ol.Coordinate} Coordinate of the interpolated point.
- * @api
-ol.geom.LineString.prototype.getCoordinateAt = function(fraction, opt_dest) {
- return ol.geom.flat.interpolate.lineString(
- fraction, opt_dest);
- * Return the length of the linestring on projected plane.
- * @return {number} Length (on projected plane).
- * @api
-ol.geom.LineString.prototype.getLength = function() {
- return ol.geom.flat.length.lineString(
- * @return {Array.<number>} Flat midpoint.
-ol.geom.LineString.prototype.getFlatMidpoint = function() {
- if (this.flatMidpointRevision_ != this.getRevision()) {
- this.flatMidpoint_ = this.getCoordinateAt(0.5, this.flatMidpoint_);
- this.flatMidpointRevision_ = this.getRevision();
- return this.flatMidpoint_;
- * @inheritDoc
-ol.geom.LineString.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
- var simplifiedFlatCoordinates = [];
- simplifiedFlatCoordinates.length = ol.geom.flat.simplify.douglasPeucker(
- squaredTolerance, simplifiedFlatCoordinates, 0);
- var simplifiedLineString = new ol.geom.LineString(null);
- simplifiedLineString.setFlatCoordinates(
- ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates);
- return simplifiedLineString;
- * @inheritDoc
- * @api
-ol.geom.LineString.prototype.getType = function() {
- return ol.geom.GeometryType.LINE_STRING;
- * @inheritDoc
- * @api
-ol.geom.LineString.prototype.intersectsExtent = function(extent) {
- return ol.geom.flat.intersectsextent.lineString(
- extent);
- * Set the coordinates of the linestring.
- * @override
- * @api
-ol.geom.LineString.prototype.setCoordinates = function(coordinates, opt_layout) {
- if (!coordinates) {
- this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null);
- } else {
- this.setLayout(opt_layout, coordinates, 1);
- this.flatCoordinates = [];
- this.flatCoordinates.length = ol.geom.flat.deflate.coordinates(
- this.flatCoordinates, 0, coordinates, this.stride);
- this.changed();
- * @param {ol.geom.GeometryLayout} layout Layout.
-ol.geom.LineString.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
- this.setFlatCoordinatesInternal(layout, flatCoordinates);
- this.changed();
-goog.provide('ol.geom.MultiLineString');
-goog.require('ol.geom.LineString');
- * @classdesc
- * Multi-linestring geometry.
- * @constructor
- * @param {Array.<Array.<ol.Coordinate>>} coordinates Coordinates.
- * @api
-ol.geom.MultiLineString = function(coordinates, opt_layout) {
- * @type {Array.<number>}
- * @private
- this.ends_ = [];
- * @private
- * @type {number}
- * @private
- * @type {number}
-ol.inherits(ol.geom.MultiLineString, ol.geom.SimpleGeometry);
- * Append the passed linestring to the multilinestring.
- * @param {ol.geom.LineString} lineString LineString.
- * @api
-ol.geom.MultiLineString.prototype.appendLineString = function(lineString) {
- this.flatCoordinates = lineString.getFlatCoordinates().slice();
- } else {
- ol.array.extend(
- this.flatCoordinates, lineString.getFlatCoordinates().slice());
- this.ends_.push(this.flatCoordinates.length);
- this.changed();
- * @return {!ol.geom.MultiLineString} Clone.
- * @override
- * @api
-ol.geom.MultiLineString.prototype.clone = function() {
- var multiLineString = new ol.geom.MultiLineString(null);
- multiLineString.setFlatCoordinates(
- this.layout, this.flatCoordinates.slice(), this.ends_.slice());
- return multiLineString;
- * @inheritDoc
-ol.geom.MultiLineString.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getsMaxSquaredDelta(
- this.flatCoordinates, 0, this.ends_, this.stride, 0));
- return ol.geom.flat.closest.getsClosestPoint(
- * `opt_interpolate` controls interpolation between consecutive LineStrings
- * within the MultiLineString. If `opt_interpolate` is `true` the coordinates
- * will be linearly interpolated between the last coordinate of one LineString
- * and the first coordinate of the next LineString. If `opt_interpolate` is
- * `false` then the function will return `null` for Ms falling between
- * LineStrings.
- * @param {boolean=} opt_interpolate Interpolate. Default is `false`.
- * @api
-ol.geom.MultiLineString.prototype.getCoordinateAtM = function(m, opt_extrapolate, opt_interpolate) {
- if ((this.layout != ol.geom.GeometryLayout.XYM &&
- this.layout != ol.geom.GeometryLayout.XYZM) ||
- this.flatCoordinates.length === 0) {
- return null;
- var interpolate = opt_interpolate !== undefined ? opt_interpolate : false;
- return ol.geom.flat.interpolate.lineStringsCoordinateAtM(this.flatCoordinates, 0,
- this.ends_, this.stride, m, extrapolate, interpolate);
- * Return the coordinates of the multilinestring.
- * @return {Array.<Array.<ol.Coordinate>>} Coordinates.
- * @override
- * @api
-ol.geom.MultiLineString.prototype.getCoordinates = function() {
- return ol.geom.flat.inflate.coordinatess(
- this.flatCoordinates, 0, this.ends_, this.stride);
- * @return {Array.<number>} Ends.
-ol.geom.MultiLineString.prototype.getEnds = function() {
- return this.ends_;
- * Return the linestring at the specified index.
- * @param {number} index Index.
- * @return {ol.geom.LineString} LineString.
- * @api
-ol.geom.MultiLineString.prototype.getLineString = function(index) {
- if (index < 0 || this.ends_.length <= index) {
- return null;
- index === 0 ? 0 : this.ends_[index - 1], this.ends_[index]));
- * Return the linestrings of this multilinestring.
- * @return {Array.<ol.geom.LineString>} LineStrings.
- * @api
-ol.geom.MultiLineString.prototype.getLineStrings = function() {
- var flatCoordinates = this.flatCoordinates;
- var ends = this.ends_;
- var layout = this.layout;
- /** @type {Array.<ol.geom.LineString>} */
- var lineStrings = [];
- var offset = 0;
- var i, ii;
- lineString.setFlatCoordinates(layout, flatCoordinates.slice(offset, end));
- lineStrings.push(lineString);
- offset = end;
- return lineStrings;
- * @return {Array.<number>} Flat midpoints.
-ol.geom.MultiLineString.prototype.getFlatMidpoints = function() {
- var midpoints = [];
- var offset = 0;
- var stride = this.stride;
- var i, ii;
- var midpoint = ol.geom.flat.interpolate.lineString(
- flatCoordinates, offset, end, stride, 0.5);
- ol.array.extend(midpoints, midpoint);
- offset = end;
- return midpoints;
- * @inheritDoc
-ol.geom.MultiLineString.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
- var simplifiedEnds = [];
- simplifiedFlatCoordinates.length = ol.geom.flat.simplify.douglasPeuckers(
- this.flatCoordinates, 0, this.ends_, this.stride, squaredTolerance,
- simplifiedFlatCoordinates, 0, simplifiedEnds);
- var simplifiedMultiLineString = new ol.geom.MultiLineString(null);
- simplifiedMultiLineString.setFlatCoordinates(
- ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates, simplifiedEnds);
- return simplifiedMultiLineString;
- * @inheritDoc
- * @api
-ol.geom.MultiLineString.prototype.getType = function() {
- return ol.geom.GeometryType.MULTI_LINE_STRING;
- * @inheritDoc
- * @api
-ol.geom.MultiLineString.prototype.intersectsExtent = function(extent) {
- return ol.geom.flat.intersectsextent.lineStrings(
- this.flatCoordinates, 0, this.ends_, this.stride, extent);
- * Set the coordinates of the multilinestring.
- * @override
- * @api
-ol.geom.MultiLineString.prototype.setCoordinates = function(coordinates, opt_layout) {
- this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null, this.ends_);
- } else {
- this.setLayout(opt_layout, coordinates, 2);
- var ends = ol.geom.flat.deflate.coordinatess(
- this.flatCoordinates, 0, coordinates, this.stride, this.ends_);
- this.flatCoordinates.length = ends.length === 0 ? 0 : ends[ends.length - 1];
- this.changed();
-ol.geom.MultiLineString.prototype.setFlatCoordinates = function(layout, flatCoordinates, ends) {
- this.ends_ = ends;
- this.changed();
- * @param {Array.<ol.geom.LineString>} lineStrings LineStrings.
-ol.geom.MultiLineString.prototype.setLineStrings = function(lineStrings) {
- var layout = this.getLayout();
- var flatCoordinates = [];
- var ends = [];
- var i, ii;
- for (i = 0, ii = lineStrings.length; i < ii; ++i) {
- var lineString = lineStrings[i];
- if (i === 0) {
- layout = lineString.getLayout();
- ol.array.extend(flatCoordinates, lineString.getFlatCoordinates());
- ends.push(flatCoordinates.length);
- this.setFlatCoordinates(layout, flatCoordinates, ends);
-goog.provide('ol.geom.MultiPoint');
-goog.require('ol.geom.Point');
- * @classdesc
- * Multi-point geometry.
- * @constructor
- * @api
-ol.geom.MultiPoint = function(coordinates, opt_layout) {
-ol.inherits(ol.geom.MultiPoint, ol.geom.SimpleGeometry);
- * Append the passed point to this multipoint.
- * @param {ol.geom.Point} point Point.
- * @api
-ol.geom.MultiPoint.prototype.appendPoint = function(point) {
- this.flatCoordinates = point.getFlatCoordinates().slice();
- } else {
- ol.array.extend(this.flatCoordinates, point.getFlatCoordinates());
- this.changed();
- * @return {!ol.geom.MultiPoint} Clone.
- * @override
- * @api
-ol.geom.MultiPoint.prototype.clone = function() {
- var multiPoint = new ol.geom.MultiPoint(null);
- multiPoint.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
- return multiPoint;
- * @inheritDoc
-ol.geom.MultiPoint.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- var i, ii, j;
- for (i = 0, ii = flatCoordinates.length; i < ii; i += stride) {
- var squaredDistance = ol.math.squaredDistance(
- x, y, flatCoordinates[i], flatCoordinates[i + 1]);
- if (squaredDistance < minSquaredDistance) {
- minSquaredDistance = squaredDistance;
- for (j = 0; j < stride; ++j) {
- closestPoint[j] = flatCoordinates[i + j];
- closestPoint.length = stride;
- * Return the coordinates of the multipoint.
- * @override
- * @api
-ol.geom.MultiPoint.prototype.getCoordinates = function() {
- * Return the point at the specified index.
- * @return {ol.geom.Point} Point.
- * @api
-ol.geom.MultiPoint.prototype.getPoint = function(index) {
- var n = !this.flatCoordinates ?
- 0 : this.flatCoordinates.length / this.stride;
- if (index < 0 || n <= index) {
- return null;
- var point = new ol.geom.Point(null);
- point.setFlatCoordinates(this.layout, this.flatCoordinates.slice(
- index * this.stride, (index + 1) * this.stride));
- return point;
- * Return the points of this multipoint.
- * @return {Array.<ol.geom.Point>} Points.
- * @api
-ol.geom.MultiPoint.prototype.getPoints = function() {
- /** @type {Array.<ol.geom.Point>} */
- var points = [];
- var i, ii;
- point.setFlatCoordinates(layout, flatCoordinates.slice(i, i + stride));
- points.push(point);
- return points;
- * @inheritDoc
- * @api
-ol.geom.MultiPoint.prototype.getType = function() {
- return ol.geom.GeometryType.MULTI_POINT;
- * @inheritDoc
- * @api
-ol.geom.MultiPoint.prototype.intersectsExtent = function(extent) {
- var i, ii, x, y;
- x = flatCoordinates[i];
- y = flatCoordinates[i + 1];
- if (ol.extent.containsXY(extent, x, y)) {
- return true;
- return false;
- * Set the coordinates of the multipoint.
- * @override
- * @api
-ol.geom.MultiPoint.prototype.setCoordinates = function(coordinates, opt_layout) {
- } else {
- this.changed();
-ol.geom.MultiPoint.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
- this.changed();
-goog.provide('ol.geom.flat.center');
- * @param {Array.<Array.<number>>} endss Endss.
- * @return {Array.<number>} Flat centers.
-ol.geom.flat.center.linearRingss = function(flatCoordinates, offset, endss, stride) {
- var flatCenters = [];
- var i, ii;
- var extent = ol.extent.createEmpty();
- for (i = 0, ii = endss.length; i < ii; ++i) {
- var ends = endss[i];
- extent = ol.extent.createOrUpdateFromFlatCoordinates(
- flatCoordinates, offset, ends[0], stride);
- flatCenters.push((extent[0] + extent[2]) / 2, (extent[1] + extent[3]) / 2);
- offset = ends[ends.length - 1];
- return flatCenters;
-goog.provide('ol.geom.MultiPolygon');
-goog.require('ol');
-goog.require('ol.geom.MultiPoint');
-goog.require('ol.geom.Polygon');
-goog.require('ol.geom.flat.area');
-goog.require('ol.geom.flat.center');
-goog.require('ol.geom.flat.contains');
-goog.require('ol.geom.flat.interiorpoint');
-goog.require('ol.geom.flat.orient');
- * @classdesc
- * Multi-polygon geometry.
- * @constructor
- * @param {Array.<Array.<Array.<ol.Coordinate>>>} coordinates Coordinates.
- * @api
-ol.geom.MultiPolygon = function(coordinates, opt_layout) {
- * @type {Array.<Array.<number>>}
- * @private
- this.endss_ = [];
- * @private
- * @type {number}
- this.flatInteriorPointsRevision_ = -1;
- * @private
- this.flatInteriorPoints_ = null;
- * @private
- * @type {number}
- * @private
- * @type {number}
- * @private
- * @type {number}
- this.orientedRevision_ = -1;
- * @private
- this.orientedFlatCoordinates_ = null;
-ol.inherits(ol.geom.MultiPolygon, ol.geom.SimpleGeometry);
- * Append the passed polygon to this multipolygon.
- * @param {ol.geom.Polygon} polygon Polygon.
- * @api
-ol.geom.MultiPolygon.prototype.appendPolygon = function(polygon) {
- /** @type {Array.<number>} */
- var ends;
- this.flatCoordinates = polygon.getFlatCoordinates().slice();
- ends = polygon.getEnds().slice();
- this.endss_.push();
- } else {
- var offset = this.flatCoordinates.length;
- ol.array.extend(this.flatCoordinates, polygon.getFlatCoordinates());
- var i, ii;
- ends[i] += offset;
- this.endss_.push(ends);
- this.changed();
- * @return {!ol.geom.MultiPolygon} Clone.
- * @override
- * @api
-ol.geom.MultiPolygon.prototype.clone = function() {
- var multiPolygon = new ol.geom.MultiPolygon(null);
- var len = this.endss_.length;
- var newEndss = new Array(len);
- for (var i = 0; i < len; ++i) {
- newEndss[i] = this.endss_[i].slice();
- multiPolygon.setFlatCoordinates(
- this.layout, this.flatCoordinates.slice(), newEndss);
- return multiPolygon;
- * @inheritDoc
-ol.geom.MultiPolygon.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getssMaxSquaredDelta(
- this.flatCoordinates, 0, this.endss_, this.stride, 0));
- return ol.geom.flat.closest.getssClosestPoint(
- this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride,
- this.maxDelta_, true, x, y, closestPoint, minSquaredDistance);
- * @inheritDoc
-ol.geom.MultiPolygon.prototype.containsXY = function(x, y) {
- return ol.geom.flat.contains.linearRingssContainsXY(
- this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride, x, y);
- * Return the area of the multipolygon on projected plane.
- * @return {number} Area (on projected plane).
- * @api
-ol.geom.MultiPolygon.prototype.getArea = function() {
- return ol.geom.flat.area.linearRingss(
- this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride);
- * Get the coordinate array for this geometry. This array has the structure
- * of a GeoJSON coordinate array for multi-polygons.
- * @param {boolean=} opt_right Orient coordinates according to the right-hand
- * rule (counter-clockwise for exterior and clockwise for interior rings).
- * If `false`, coordinates will be oriented according to the left-hand rule
- * (clockwise for exterior and counter-clockwise for interior rings).
- * By default, coordinate orientation will depend on how the geometry was
- * constructed.
- * @return {Array.<Array.<Array.<ol.Coordinate>>>} Coordinates.
- * @override
- * @api
-ol.geom.MultiPolygon.prototype.getCoordinates = function(opt_right) {
- var flatCoordinates;
- if (opt_right !== undefined) {
- flatCoordinates = this.getOrientedFlatCoordinates().slice();
- ol.geom.flat.orient.orientLinearRingss(
- flatCoordinates, 0, this.endss_, this.stride, opt_right);
- } else {
- flatCoordinates = this.flatCoordinates;
- return ol.geom.flat.inflate.coordinatesss(
- flatCoordinates, 0, this.endss_, this.stride);
- * @return {Array.<Array.<number>>} Endss.
-ol.geom.MultiPolygon.prototype.getEndss = function() {
- return this.endss_;
- * @return {Array.<number>} Flat interior points.
-ol.geom.MultiPolygon.prototype.getFlatInteriorPoints = function() {
- if (this.flatInteriorPointsRevision_ != this.getRevision()) {
- var flatCenters = ol.geom.flat.center.linearRingss(
- this.flatCoordinates, 0, this.endss_, this.stride);
- this.flatInteriorPoints_ = ol.geom.flat.interiorpoint.linearRingss(
- flatCenters);
- this.flatInteriorPointsRevision_ = this.getRevision();
- return this.flatInteriorPoints_;
- * Return the interior points as {@link ol.geom.MultiPoint multipoint}.
- * @return {ol.geom.MultiPoint} Interior points.
- * @api
-ol.geom.MultiPolygon.prototype.getInteriorPoints = function() {
- var interiorPoints = new ol.geom.MultiPoint(null);
- interiorPoints.setFlatCoordinates(ol.geom.GeometryLayout.XY,
- this.getFlatInteriorPoints().slice());
- return interiorPoints;
- * @return {Array.<number>} Oriented flat coordinates.
-ol.geom.MultiPolygon.prototype.getOrientedFlatCoordinates = function() {
- if (this.orientedRevision_ != this.getRevision()) {
- if (ol.geom.flat.orient.linearRingssAreOriented(
- flatCoordinates, 0, this.endss_, this.stride)) {
- this.orientedFlatCoordinates_ = flatCoordinates;
- } else {
- this.orientedFlatCoordinates_ = flatCoordinates.slice();
- this.orientedFlatCoordinates_.length =
- this.orientedFlatCoordinates_, 0, this.endss_, this.stride);
- this.orientedRevision_ = this.getRevision();
- return this.orientedFlatCoordinates_;
- * @inheritDoc
-ol.geom.MultiPolygon.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
- var simplifiedEndss = [];
- simplifiedFlatCoordinates.length = ol.geom.flat.simplify.quantizess(
- Math.sqrt(squaredTolerance),
- simplifiedFlatCoordinates, 0, simplifiedEndss);
- var simplifiedMultiPolygon = new ol.geom.MultiPolygon(null);
- simplifiedMultiPolygon.setFlatCoordinates(
- ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates, simplifiedEndss);
- return simplifiedMultiPolygon;
- * Return the polygon at the specified index.
- * @return {ol.geom.Polygon} Polygon.
- * @api
-ol.geom.MultiPolygon.prototype.getPolygon = function(index) {
- if (index < 0 || this.endss_.length <= index) {
- return null;
- var offset;
- if (index === 0) {
- offset = 0;
- } else {
- var prevEnds = this.endss_[index - 1];
- offset = prevEnds[prevEnds.length - 1];
- var ends = this.endss_[index].slice();
- var end = ends[ends.length - 1];
- if (offset !== 0) {
- var i, ii;
- ends[i] -= offset;
- var polygon = new ol.geom.Polygon(null);
- polygon.setFlatCoordinates(
- this.layout, this.flatCoordinates.slice(offset, end), ends);
- return polygon;
- * Return the polygons of this multipolygon.
- * @return {Array.<ol.geom.Polygon>} Polygons.
- * @api
-ol.geom.MultiPolygon.prototype.getPolygons = function() {
- var endss = this.endss_;
- var polygons = [];
- var offset = 0;
- var i, ii, j, jj;
- var ends = endss[i].slice();
- for (j = 0, jj = ends.length; j < jj; ++j) {
- ends[j] -= offset;
- layout, flatCoordinates.slice(offset, end), ends);
- polygons.push(polygon);
- offset = end;
- return polygons;
- * @inheritDoc
- * @api
-ol.geom.MultiPolygon.prototype.getType = function() {
- return ol.geom.GeometryType.MULTI_POLYGON;
- * @inheritDoc
- * @api
-ol.geom.MultiPolygon.prototype.intersectsExtent = function(extent) {
- return ol.geom.flat.intersectsextent.linearRingss(
- this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride, extent);
- * Set the coordinates of the multipolygon.
- * @override
- * @api
-ol.geom.MultiPolygon.prototype.setCoordinates = function(coordinates, opt_layout) {
- this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null, this.endss_);
- } else {
- this.setLayout(opt_layout, coordinates, 3);
- var endss = ol.geom.flat.deflate.coordinatesss(
- this.flatCoordinates, 0, coordinates, this.stride, this.endss_);
- if (endss.length === 0) {
- this.flatCoordinates.length = 0;
- } else {
- var lastEnds = endss[endss.length - 1];
- this.flatCoordinates.length = lastEnds.length === 0 ?
- 0 : lastEnds[lastEnds.length - 1];
- this.changed();
-ol.geom.MultiPolygon.prototype.setFlatCoordinates = function(layout, flatCoordinates, endss) {
- this.endss_ = endss;
- this.changed();
- * @param {Array.<ol.geom.Polygon>} polygons Polygons.
-ol.geom.MultiPolygon.prototype.setPolygons = function(polygons) {
- var endss = [];
- var i, ii, ends;
- for (i = 0, ii = polygons.length; i < ii; ++i) {
- var polygon = polygons[i];
- if (i === 0) {
- layout = polygon.getLayout();
- var offset = flatCoordinates.length;
- ends = polygon.getEnds();
- var j, jj;
- ends[j] += offset;
- ol.array.extend(flatCoordinates, polygon.getFlatCoordinates());
- endss.push(ends);
- this.setFlatCoordinates(layout, flatCoordinates, endss);
-goog.provide('ol.format.EsriJSON');
-goog.require('ol.Feature');
-goog.require('ol.asserts');
-goog.require('ol.format.JSONFeature');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.geom.LinearRing');
-goog.require('ol.geom.MultiLineString');
-goog.require('ol.geom.MultiPolygon');
- * @classdesc
- * Feature format for reading and writing data in the EsriJSON format.
- * @constructor
- * @extends {ol.format.JSONFeature}
- * @param {olx.format.EsriJSONOptions=} opt_options Options.
- * @api
-ol.format.EsriJSON = function(opt_options) {
- var options = opt_options ? opt_options : {};
- ol.format.JSONFeature.call(this);
- * Name of the geometry attribute for features.
- * @type {string|undefined}
- * @private
- this.geometryName_ = options.geometryName;
-ol.inherits(ol.format.EsriJSON, ol.format.JSONFeature);
- * @param {EsriJSONGeometry} object Object.
- * @private
-ol.format.EsriJSON.readGeometry_ = function(object, opt_options) {
- if (!object) {
- return null;
- /** @type {ol.geom.GeometryType} */
- var type;
- if (typeof object.x === 'number' && typeof object.y === 'number') {
- type = ol.geom.GeometryType.POINT;
- } else if (object.points) {
- type = ol.geom.GeometryType.MULTI_POINT;
- } else if (object.paths) {
- if (object.paths.length === 1) {
- type = ol.geom.GeometryType.LINE_STRING;
- } else {
- type = ol.geom.GeometryType.MULTI_LINE_STRING;
- } else if (object.rings) {
- var layout = ol.format.EsriJSON.getGeometryLayout_(object);
- var rings = ol.format.EsriJSON.convertRings_(object.rings, layout);
- object = /** @type {EsriJSONGeometry} */(ol.obj.assign({}, object));
- if (rings.length === 1) {
- type = ol.geom.GeometryType.POLYGON;
- object.rings = rings[0];
- } else {
- type = ol.geom.GeometryType.MULTI_POLYGON;
- object.rings = rings;
- var geometryReader = ol.format.EsriJSON.GEOMETRY_READERS_[type];
- return /** @type {ol.geom.Geometry} */ (
- ol.format.Feature.transformWithOptions(
- geometryReader(object), false, opt_options));
- * Determines inner and outer rings.
- * Checks if any polygons in this array contain any other polygons in this
- * array. It is used for checking for holes.
- * Logic inspired by: https://github.com/Esri/terraformer-arcgis-parser
- * @param {Array.<!Array.<!Array.<number>>>} rings Rings.
- * @param {ol.geom.GeometryLayout} layout Geometry layout.
- * @private
- * @return {Array.<!Array.<!Array.<number>>>} Transformed rings.
-ol.format.EsriJSON.convertRings_ = function(rings, layout) {
- var flatRing = [];
- var outerRings = [];
- var holes = [];
- var i, ii;
- for (i = 0, ii = rings.length; i < ii; ++i) {
- flatRing.length = 0;
- ol.geom.flat.deflate.coordinates(flatRing, 0, rings[i], layout.length);
- // is this ring an outer ring? is it clockwise?
- var clockwise = ol.geom.flat.orient.linearRingIsClockwise(flatRing, 0,
- flatRing.length, layout.length);
- if (clockwise) {
- outerRings.push([rings[i]]);
- } else {
- holes.push(rings[i]);
- while (holes.length) {
- var hole = holes.shift();
- var matched = false;
- // loop over all outer rings and see if they contain our hole.
- for (i = outerRings.length - 1; i >= 0; i--) {
- var outerRing = outerRings[i][0];
- if (ol.extent.containsExtent(new ol.geom.LinearRing(
- outerRing).getExtent(),
- new ol.geom.LinearRing(hole).getExtent())) {
- // the hole is contained push it into our polygon
- outerRings[i].push(hole);
- matched = true;
- break;
- if (!matched) {
- // no outer rings contain this hole turn it into and outer
- // ring (reverse it)
- outerRings.push([hole.reverse()]);
- return outerRings;
- * @private
- * @return {ol.geom.Geometry} Point.
-ol.format.EsriJSON.readPointGeometry_ = function(object) {
- var point;
- if (object.m !== undefined && object.z !== undefined) {
- point = new ol.geom.Point([object.x, object.y, object.z, object.m],
- ol.geom.GeometryLayout.XYZM);
- } else if (object.z !== undefined) {
- point = new ol.geom.Point([object.x, object.y, object.z],
- ol.geom.GeometryLayout.XYZ);
- } else if (object.m !== undefined) {
- point = new ol.geom.Point([object.x, object.y, object.m],
- ol.geom.GeometryLayout.XYM);
- } else {
- point = new ol.geom.Point([object.x, object.y]);
- return point;
- * @private
- * @return {ol.geom.Geometry} LineString.
-ol.format.EsriJSON.readLineStringGeometry_ = function(object) {
- return new ol.geom.LineString(object.paths[0], layout);
- * @private
- * @return {ol.geom.Geometry} MultiLineString.
-ol.format.EsriJSON.readMultiLineStringGeometry_ = function(object) {
- return new ol.geom.MultiLineString(object.paths, layout);
- * @private
- * @return {ol.geom.GeometryLayout} The geometry layout to use.
-ol.format.EsriJSON.getGeometryLayout_ = function(object) {
- var layout = ol.geom.GeometryLayout.XY;
- if (object.hasZ === true && object.hasM === true) {
- layout = ol.geom.GeometryLayout.XYZM;
- } else if (object.hasZ === true) {
- layout = ol.geom.GeometryLayout.XYZ;
- } else if (object.hasM === true) {
- layout = ol.geom.GeometryLayout.XYM;
- return layout;
- * @private
- * @return {ol.geom.Geometry} MultiPoint.
-ol.format.EsriJSON.readMultiPointGeometry_ = function(object) {
- return new ol.geom.MultiPoint(object.points, layout);
- * @private
- * @return {ol.geom.Geometry} MultiPolygon.
-ol.format.EsriJSON.readMultiPolygonGeometry_ = function(object) {
- return new ol.geom.MultiPolygon(
- /** @type {Array.<Array.<Array.<Array.<number>>>>} */(object.rings),
- layout);
- * @private
- * @return {ol.geom.Geometry} Polygon.
-ol.format.EsriJSON.readPolygonGeometry_ = function(object) {
- return new ol.geom.Polygon(object.rings, layout);
- * @private
- * @return {EsriJSONGeometry} EsriJSON geometry.
-ol.format.EsriJSON.writePointGeometry_ = function(geometry, opt_options) {
- var coordinates = /** @type {ol.geom.Point} */ (geometry).getCoordinates();
- var esriJSON;
- var layout = /** @type {ol.geom.Point} */ (geometry).getLayout();
- if (layout === ol.geom.GeometryLayout.XYZ) {
- esriJSON = /** @type {EsriJSONPoint} */ ({
- x: coordinates[0],
- y: coordinates[1],
- z: coordinates[2]
- } else if (layout === ol.geom.GeometryLayout.XYM) {
- m: coordinates[2]
- } else if (layout === ol.geom.GeometryLayout.XYZM) {
- z: coordinates[2],
- m: coordinates[3]
- } else if (layout === ol.geom.GeometryLayout.XY) {
- y: coordinates[1]
- } else {
- ol.asserts.assert(false, 34); // Invalid geometry layout
- return /** @type {EsriJSONGeometry} */ (esriJSON);
- * @param {ol.geom.SimpleGeometry} geometry Geometry.
- * @private
- * @return {Object} Object with boolean hasZ and hasM keys.
-ol.format.EsriJSON.getHasZM_ = function(geometry) {
- var layout = geometry.getLayout();
- return {
- hasZ: (layout === ol.geom.GeometryLayout.XYZ ||
- layout === ol.geom.GeometryLayout.XYZM),
- hasM: (layout === ol.geom.GeometryLayout.XYM ||
- * @private
- * @return {EsriJSONPolyline} EsriJSON geometry.
-ol.format.EsriJSON.writeLineStringGeometry_ = function(geometry, opt_options) {
- var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.LineString} */ (geometry));
- return /** @type {EsriJSONPolyline} */ ({
- hasZ: hasZM.hasZ,
- hasM: hasZM.hasM,
- paths: [
- /** @type {ol.geom.LineString} */ (geometry).getCoordinates()
- * @private
- * @return {EsriJSONPolygon} EsriJSON geometry.
-ol.format.EsriJSON.writePolygonGeometry_ = function(geometry, opt_options) {
- // Esri geometries use the left-hand rule
- var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.Polygon} */ (geometry));
- return /** @type {EsriJSONPolygon} */ ({
- hasZ: hasZM.hasZ,
- hasM: hasZM.hasM,
- rings: /** @type {ol.geom.Polygon} */ (geometry).getCoordinates(false)
- * @private
-ol.format.EsriJSON.writeMultiLineStringGeometry_ = function(geometry, opt_options) {
- var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.MultiLineString} */ (geometry));
- hasZ: hasZM.hasZ,
- hasM: hasZM.hasM,
- paths: /** @type {ol.geom.MultiLineString} */ (geometry).getCoordinates()
- * @private
- * @return {EsriJSONMultipoint} EsriJSON geometry.
-ol.format.EsriJSON.writeMultiPointGeometry_ = function(geometry, opt_options) {
- var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.MultiPoint} */ (geometry));
- return /** @type {EsriJSONMultipoint} */ ({
- hasZ: hasZM.hasZ,
- hasM: hasZM.hasM,
- points: /** @type {ol.geom.MultiPoint} */ (geometry).getCoordinates()
- * @private
-ol.format.EsriJSON.writeMultiPolygonGeometry_ = function(geometry,
- opt_options) {
- var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.MultiPolygon} */ (geometry));
- var coordinates = /** @type {ol.geom.MultiPolygon} */ (geometry).getCoordinates(false);
- var output = [];
- for (var i = 0; i < coordinates.length; i++) {
- for (var x = coordinates[i].length - 1; x >= 0; x--) {
- output.push(coordinates[i][x]);
- hasZ: hasZM.hasZ,
- hasM: hasZM.hasM,
- rings: output
- * @const
- * @private
- * @type {Object.<ol.geom.GeometryType, function(EsriJSONGeometry): ol.geom.Geometry>}
-ol.format.EsriJSON.GEOMETRY_READERS_ = {};
-ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.POINT] =
- ol.format.EsriJSON.readPointGeometry_;
-ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.LINE_STRING] =
- ol.format.EsriJSON.readLineStringGeometry_;
-ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.POLYGON] =
- ol.format.EsriJSON.readPolygonGeometry_;
-ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.MULTI_POINT] =
- ol.format.EsriJSON.readMultiPointGeometry_;
-ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.MULTI_LINE_STRING] =
- ol.format.EsriJSON.readMultiLineStringGeometry_;
-ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.MULTI_POLYGON] =
- ol.format.EsriJSON.readMultiPolygonGeometry_;
- * @const
- * @private
- * @type {Object.<string, function(ol.geom.Geometry, olx.format.WriteOptions=): (EsriJSONGeometry)>}
-ol.format.EsriJSON.GEOMETRY_WRITERS_ = {};
-ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.POINT] =
- ol.format.EsriJSON.writePointGeometry_;
-ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.LINE_STRING] =
- ol.format.EsriJSON.writeLineStringGeometry_;
-ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.POLYGON] =
- ol.format.EsriJSON.writePolygonGeometry_;
-ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.MULTI_POINT] =
- ol.format.EsriJSON.writeMultiPointGeometry_;
-ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.MULTI_LINE_STRING] =
- ol.format.EsriJSON.writeMultiLineStringGeometry_;
-ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.MULTI_POLYGON] =
- ol.format.EsriJSON.writeMultiPolygonGeometry_;
- * Read a feature from a EsriJSON Feature source. Only works for Feature,
- * use `readFeatures` to read FeatureCollection source.
- * @function
- * @param {ArrayBuffer|Document|Node|Object|string} source Source.
- * @api
-ol.format.EsriJSON.prototype.readFeature;
- * Read all features from a EsriJSON source. Works with both Feature and
- * FeatureCollection sources.
- * @function
- * @api
-ol.format.EsriJSON.prototype.readFeatures;
- * @inheritDoc
-ol.format.EsriJSON.prototype.readFeatureFromObject = function(
- object, opt_options) {
- var esriJSONFeature = /** @type {EsriJSONFeature} */ (object);
- var geometry = ol.format.EsriJSON.readGeometry_(esriJSONFeature.geometry,
- opt_options);
- var feature = new ol.Feature();
- if (this.geometryName_) {
- feature.setGeometryName(this.geometryName_);
- feature.setGeometry(geometry);
- if (opt_options && opt_options.idField &&
- esriJSONFeature.attributes[opt_options.idField]) {
- feature.setId(/** @type {number} */(
- esriJSONFeature.attributes[opt_options.idField]));
- if (esriJSONFeature.attributes) {
- feature.setProperties(esriJSONFeature.attributes);
- return feature;
- * @inheritDoc
-ol.format.EsriJSON.prototype.readFeaturesFromObject = function(
- var esriJSONObject = /** @type {EsriJSONObject} */ (object);
- if (esriJSONObject.features) {
- var esriJSONFeatureCollection = /** @type {EsriJSONFeatureCollection} */
- (object);
- /** @type {Array.<ol.Feature>} */
- var features = [];
- var esriJSONFeatures = esriJSONFeatureCollection.features;
- var i, ii;
- options.idField = object.objectIdFieldName;
- for (i = 0, ii = esriJSONFeatures.length; i < ii; ++i) {
- features.push(this.readFeatureFromObject(esriJSONFeatures[i],
- options));
- return features;
- } else {
- return [this.readFeatureFromObject(object, options)];
- * Read a geometry from a EsriJSON source.
- * @function
- * @api
-ol.format.EsriJSON.prototype.readGeometry;
- * @inheritDoc
-ol.format.EsriJSON.prototype.readGeometryFromObject = function(
- return ol.format.EsriJSON.readGeometry_(
- /** @type {EsriJSONGeometry} */ (object), opt_options);
- * Read the projection from a EsriJSON source.
- * @function
- * @api
-ol.format.EsriJSON.prototype.readProjection;
- * @inheritDoc
-ol.format.EsriJSON.prototype.readProjectionFromObject = function(object) {
- if (esriJSONObject.spatialReference && esriJSONObject.spatialReference.wkid) {
- var crs = esriJSONObject.spatialReference.wkid;
- return ol.proj.get('EPSG:' + crs);
- } else {
- return null;
- * @private
-ol.format.EsriJSON.writeGeometry_ = function(geometry, opt_options) {
- var geometryWriter = ol.format.EsriJSON.GEOMETRY_WRITERS_[geometry.getType()];
- return geometryWriter(/** @type {ol.geom.Geometry} */ (
- ol.format.Feature.transformWithOptions(geometry, true, opt_options)),
- opt_options);
- * Encode a geometry as a EsriJSON string.
- * @function
- * @return {string} EsriJSON.
- * @api
-ol.format.EsriJSON.prototype.writeGeometry;
- * Encode a geometry as a EsriJSON object.
- * @return {EsriJSONGeometry} Object.
- * @override
- * @api
-ol.format.EsriJSON.prototype.writeGeometryObject = function(geometry,
- opt_options) {
- return ol.format.EsriJSON.writeGeometry_(geometry,
- this.adaptOptions(opt_options));
- * Encode a feature as a EsriJSON Feature string.
- * @function
- * @api
-ol.format.EsriJSON.prototype.writeFeature;
- * Encode a feature as a esriJSON Feature object.
- * @override
- * @api
-ol.format.EsriJSON.prototype.writeFeatureObject = function(
- feature, opt_options) {
- opt_options = this.adaptOptions(opt_options);
- var object = {};
- var geometry = feature.getGeometry();
- if (geometry) {
- object['geometry'] =
- ol.format.EsriJSON.writeGeometry_(geometry, opt_options);
- var properties = feature.getProperties();
- delete properties[feature.getGeometryName()];
- if (!ol.obj.isEmpty(properties)) {
- object['attributes'] = properties;
- } else {
- object['attributes'] = {};
- if (opt_options && opt_options.featureProjection) {
- object['spatialReference'] = /** @type {EsriJSONCRS} */({
- wkid: ol.proj.get(
- opt_options.featureProjection).getCode().split(':').pop()
- return object;
- * Encode an array of features as EsriJSON.
- * @function
- * @api
-ol.format.EsriJSON.prototype.writeFeatures;
- * Encode an array of features as a EsriJSON object.
- * @return {Object} EsriJSON Object.
- * @override
- * @api
-ol.format.EsriJSON.prototype.writeFeaturesObject = function(features, opt_options) {
- var objects = [];
- var i, ii;
- for (i = 0, ii = features.length; i < ii; ++i) {
- objects.push(this.writeFeatureObject(features[i], opt_options));
- return /** @type {EsriJSONFeatureCollection} */ ({
- 'features': objects
-goog.provide('ol.format.filter.Filter');
- * @classdesc
- * Abstract class; normally only used for creating subclasses and not instantiated in apps.
- * Base class for WFS GetFeature filters.
- * @constructor
- * @param {!string} tagName The XML tag name for this filter.
- * @struct
- * @api
-ol.format.filter.Filter = function(tagName) {
- * @private
- * @type {!string}
- this.tagName_ = tagName;
- * The XML tag name for a filter.
- * @returns {!string} Name.
-ol.format.filter.Filter.prototype.getTagName = function() {
- return this.tagName_;
-goog.provide('ol.format.filter.LogicalNary');
-goog.require('ol.format.filter.Filter');
- * @classdesc
- * Base class for WFS GetFeature n-ary logical filters.
- * @constructor
- * @param {...ol.format.filter.Filter} conditions Conditions.
- * @extends {ol.format.filter.Filter}
-ol.format.filter.LogicalNary = function(tagName, conditions) {
- ol.format.filter.Filter.call(this, tagName);
- * @public
- * @type {Array.<ol.format.filter.Filter>}
- this.conditions = Array.prototype.slice.call(arguments, 1);
- ol.asserts.assert(this.conditions.length >= 2, 57); // At least 2 conditions are required.
-ol.inherits(ol.format.filter.LogicalNary, ol.format.filter.Filter);
-goog.provide('ol.format.filter.And');
-goog.require('ol.format.filter.LogicalNary');
- * @classdesc
- * Represents a logical `<And>` operator between two or more filter conditions.
- * @constructor
- * @extends {ol.format.filter.LogicalNary}
- * @api
-ol.format.filter.And = function(conditions) {
- var params = ['And'].concat(Array.prototype.slice.call(arguments));
- ol.format.filter.LogicalNary.apply(this, params);
-ol.inherits(ol.format.filter.And, ol.format.filter.LogicalNary);
-goog.provide('ol.format.filter.Bbox');
- * @classdesc
- * Represents a `<BBOX>` operator to test whether a geometry-valued property
- * intersects a fixed bounding box
- * @constructor
- * @param {!string} geometryName Geometry name to use.
- * @param {!ol.Extent} extent Extent.
- * @param {string=} opt_srsName SRS name. No srsName attribute will be
- * set on geometries when this is not provided.
- * @api
-ol.format.filter.Bbox = function(geometryName, extent, opt_srsName) {
- ol.format.filter.Filter.call(this, 'BBOX');
- * @public
- * @type {!string}
- this.geometryName = geometryName;
- * @public
- * @type {ol.Extent}
- this.extent = extent;
- * @public
- this.srsName = opt_srsName;
-ol.inherits(ol.format.filter.Bbox, ol.format.filter.Filter);
-goog.provide('ol.format.filter.Comparison');
- * @classdesc
- * Base class for WFS GetFeature property comparison filters.
- * @constructor
- * @param {!string} propertyName Name of the context property to compare.
- * @api
-ol.format.filter.Comparison = function(tagName, propertyName) {
- * @public
- * @type {!string}
- this.propertyName = propertyName;
-ol.inherits(ol.format.filter.Comparison, ol.format.filter.Filter);
-goog.provide('ol.format.filter.ComparisonBinary');
-goog.require('ol.format.filter.Comparison');
- * @classdesc
- * Base class for WFS GetFeature property binary comparison filters.
- * @constructor
- * @param {!(string|number)} expression The value to compare.
- * @param {boolean=} opt_matchCase Case-sensitive?
- * @extends {ol.format.filter.Comparison}
- * @api
-ol.format.filter.ComparisonBinary = function(
- tagName, propertyName, expression, opt_matchCase) {
- ol.format.filter.Comparison.call(this, tagName, propertyName);
- * @public
- * @type {!(string|number)}
- this.expression = expression;
- * @public
- * @type {boolean|undefined}
- this.matchCase = opt_matchCase;
-ol.inherits(ol.format.filter.ComparisonBinary, ol.format.filter.Comparison);
-goog.provide('ol.format.filter.EqualTo');
-goog.require('ol.format.filter.ComparisonBinary');
- * @classdesc
- * Represents a `<PropertyIsEqualTo>` comparison operator.
- * @constructor
- * @extends {ol.format.filter.ComparisonBinary}
- * @api
-ol.format.filter.EqualTo = function(propertyName, expression, opt_matchCase) {
- ol.format.filter.ComparisonBinary.call(this, 'PropertyIsEqualTo', propertyName, expression, opt_matchCase);
-ol.inherits(ol.format.filter.EqualTo, ol.format.filter.ComparisonBinary);
-goog.provide('ol.format.filter.GreaterThan');
- * @classdesc
- * Represents a `<PropertyIsGreaterThan>` comparison operator.
- * @constructor
- * @param {!number} expression The value to compare.
- * @api
-ol.format.filter.GreaterThan = function(propertyName, expression) {
- ol.format.filter.ComparisonBinary.call(this, 'PropertyIsGreaterThan', propertyName, expression);
-ol.inherits(ol.format.filter.GreaterThan, ol.format.filter.ComparisonBinary);
-goog.provide('ol.format.filter.GreaterThanOrEqualTo');
- * @classdesc
- * Represents a `<PropertyIsGreaterThanOrEqualTo>` comparison operator.
- * @constructor
- * @api
-ol.format.filter.GreaterThanOrEqualTo = function(propertyName, expression) {
- ol.format.filter.ComparisonBinary.call(this, 'PropertyIsGreaterThanOrEqualTo', propertyName, expression);
-ol.inherits(ol.format.filter.GreaterThanOrEqualTo, ol.format.filter.ComparisonBinary);
-goog.provide('ol.format.filter.Spatial');
- * @classdesc
- * Represents a spatial operator to test whether a geometry-valued property
- * relates to a given geometry.
- * @constructor
- * @param {!ol.geom.Geometry} geometry Geometry.
- * @api
-ol.format.filter.Spatial = function(tagName, geometryName, geometry, opt_srsName) {
- * @public
- * @type {!string}
- this.geometryName = geometryName || 'the_geom';
- * @public
- * @type {ol.geom.Geometry}
- this.geometry = geometry;
- * @public
-ol.inherits(ol.format.filter.Spatial, ol.format.filter.Filter);
-goog.provide('ol.format.filter.Intersects');
-goog.require('ol.format.filter.Spatial');
- * @classdesc
- * Represents a `<Intersects>` operator to test whether a geometry-valued property
- * intersects a given geometry.
- * @constructor
- * @extends {ol.format.filter.Spatial}
- * @api
-ol.format.filter.Intersects = function(geometryName, geometry, opt_srsName) {
- ol.format.filter.Spatial.call(this, 'Intersects', geometryName, geometry, opt_srsName);
-ol.inherits(ol.format.filter.Intersects, ol.format.filter.Spatial);
-goog.provide('ol.format.filter.IsBetween');
- * @classdesc
- * Represents a `<PropertyIsBetween>` comparison operator.
- * @constructor
- * @param {!number} lowerBoundary The lower bound of the range.
- * @param {!number} upperBoundary The upper bound of the range.
- * @api
-ol.format.filter.IsBetween = function(propertyName, lowerBoundary, upperBoundary) {
- ol.format.filter.Comparison.call(this, 'PropertyIsBetween', propertyName);
- * @public
- * @type {!number}
- this.lowerBoundary = lowerBoundary;
- * @public
- * @type {!number}
- this.upperBoundary = upperBoundary;
-ol.inherits(ol.format.filter.IsBetween, ol.format.filter.Comparison);
-goog.provide('ol.format.filter.IsLike');
- * @classdesc
- * Represents a `<PropertyIsLike>` comparison operator.
- * @constructor
- * @param {!string} pattern Text pattern.
- * @param {string=} opt_wildCard Pattern character which matches any sequence of
- * zero or more string characters. Default is '*'.
- * @param {string=} opt_singleChar pattern character which matches any single
- * string character. Default is '.'.
- * @param {string=} opt_escapeChar Escape character which can be used to escape
- * the pattern characters. Default is '!'.
- * @api
-ol.format.filter.IsLike = function(propertyName, pattern,
- opt_wildCard, opt_singleChar, opt_escapeChar, opt_matchCase) {
- ol.format.filter.Comparison.call(this, 'PropertyIsLike', propertyName);
- * @public
- * @type {!string}
- this.pattern = pattern;
- * @public
- * @type {!string}
- this.wildCard = (opt_wildCard !== undefined) ? opt_wildCard : '*';
- * @public
- * @type {!string}
- this.singleChar = (opt_singleChar !== undefined) ? opt_singleChar : '.';
- * @public
- * @type {!string}
- this.escapeChar = (opt_escapeChar !== undefined) ? opt_escapeChar : '!';
- * @public
-ol.inherits(ol.format.filter.IsLike, ol.format.filter.Comparison);
-goog.provide('ol.format.filter.IsNull');
- * @classdesc
- * Represents a `<PropertyIsNull>` comparison operator.
- * @constructor
- * @api
-ol.format.filter.IsNull = function(propertyName) {
- ol.format.filter.Comparison.call(this, 'PropertyIsNull', propertyName);
-ol.inherits(ol.format.filter.IsNull, ol.format.filter.Comparison);
-goog.provide('ol.format.filter.LessThan');
- * @classdesc
- * Represents a `<PropertyIsLessThan>` comparison operator.
- * @constructor
- * @api
-ol.format.filter.LessThan = function(propertyName, expression) {
- ol.format.filter.ComparisonBinary.call(this, 'PropertyIsLessThan', propertyName, expression);
-ol.inherits(ol.format.filter.LessThan, ol.format.filter.ComparisonBinary);
-goog.provide('ol.format.filter.LessThanOrEqualTo');
- * @classdesc
- * Represents a `<PropertyIsLessThanOrEqualTo>` comparison operator.
- * @constructor
- * @api
-ol.format.filter.LessThanOrEqualTo = function(propertyName, expression) {
- ol.format.filter.ComparisonBinary.call(this, 'PropertyIsLessThanOrEqualTo', propertyName, expression);
-ol.inherits(ol.format.filter.LessThanOrEqualTo, ol.format.filter.ComparisonBinary);
-goog.provide('ol.format.filter.Not');
- * @classdesc
- * Represents a logical `<Not>` operator for a filter condition.
- * @constructor
- * @param {!ol.format.filter.Filter} condition Filter condition.
- * @api
-ol.format.filter.Not = function(condition) {
- ol.format.filter.Filter.call(this, 'Not');
- * @public
- * @type {!ol.format.filter.Filter}
- this.condition = condition;
-ol.inherits(ol.format.filter.Not, ol.format.filter.Filter);
-goog.provide('ol.format.filter.NotEqualTo');
- * @classdesc
- * Represents a `<PropertyIsNotEqualTo>` comparison operator.
- * @constructor
- * @api
-ol.format.filter.NotEqualTo = function(propertyName, expression, opt_matchCase) {
- ol.format.filter.ComparisonBinary.call(this, 'PropertyIsNotEqualTo', propertyName, expression, opt_matchCase);
-ol.inherits(ol.format.filter.NotEqualTo, ol.format.filter.ComparisonBinary);
-goog.provide('ol.format.filter.Or');
- * @classdesc
- * Represents a logical `<Or>` operator between two ore more filter conditions.
- * @constructor
- * @api
-ol.format.filter.Or = function(conditions) {
- var params = ['Or'].concat(Array.prototype.slice.call(arguments));
-ol.inherits(ol.format.filter.Or, ol.format.filter.LogicalNary);
-goog.provide('ol.format.filter.Within');
- * @classdesc
- * Represents a `<Within>` operator to test whether a geometry-valued property
- * is within a given geometry.
- * @constructor
- * @api
-ol.format.filter.Within = function(geometryName, geometry, opt_srsName) {
- ol.format.filter.Spatial.call(this, 'Within', geometryName, geometry, opt_srsName);
-ol.inherits(ol.format.filter.Within, ol.format.filter.Spatial);
-goog.provide('ol.format.filter');
-goog.require('ol.format.filter.And');
-goog.require('ol.format.filter.Bbox');
-goog.require('ol.format.filter.EqualTo');
-goog.require('ol.format.filter.GreaterThan');
-goog.require('ol.format.filter.GreaterThanOrEqualTo');
-goog.require('ol.format.filter.Intersects');
-goog.require('ol.format.filter.IsBetween');
-goog.require('ol.format.filter.IsLike');
-goog.require('ol.format.filter.IsNull');
-goog.require('ol.format.filter.LessThan');
-goog.require('ol.format.filter.LessThanOrEqualTo');
-goog.require('ol.format.filter.Not');
-goog.require('ol.format.filter.NotEqualTo');
-goog.require('ol.format.filter.Or');
-goog.require('ol.format.filter.Within');
- * Create a logical `<And>` operator between two or more filter conditions.
- * @param {...ol.format.filter.Filter} conditions Filter conditions.
- * @returns {!ol.format.filter.And} `<And>` operator.
- * @api
-ol.format.filter.and = function(conditions) {
- var params = [null].concat(Array.prototype.slice.call(arguments));
- return new (Function.prototype.bind.apply(ol.format.filter.And, params));
- * Create a logical `<Or>` operator between two or more filter conditions.
- * @returns {!ol.format.filter.Or} `<Or>` operator.
- * @api
-ol.format.filter.or = function(conditions) {
- return new (Function.prototype.bind.apply(ol.format.filter.Or, params));
- * @returns {!ol.format.filter.Not} `<Not>` operator.
- * @api
-ol.format.filter.not = function(condition) {
- return new ol.format.filter.Not(condition);
- * Create a `<BBOX>` operator to test whether a geometry-valued property
- * @returns {!ol.format.filter.Bbox} `<BBOX>` operator.
- * @api
-ol.format.filter.bbox = function(geometryName, extent, opt_srsName) {
- return new ol.format.filter.Bbox(geometryName, extent, opt_srsName);
- * Create a `<Intersects>` operator to test whether a geometry-valued property
- * @returns {!ol.format.filter.Intersects} `<Intersects>` operator.
- * @api
-ol.format.filter.intersects = function(geometryName, geometry, opt_srsName) {
- return new ol.format.filter.Intersects(geometryName, geometry, opt_srsName);
- * Create a `<Within>` operator to test whether a geometry-valued property
- * @returns {!ol.format.filter.Within} `<Within>` operator.
- * @api
-ol.format.filter.within = function(geometryName, geometry, opt_srsName) {
- return new ol.format.filter.Within(geometryName, geometry, opt_srsName);
- * Creates a `<PropertyIsEqualTo>` comparison operator.
- * @returns {!ol.format.filter.EqualTo} `<PropertyIsEqualTo>` operator.
- * @api
-ol.format.filter.equalTo = function(propertyName, expression, opt_matchCase) {
- return new ol.format.filter.EqualTo(propertyName, expression, opt_matchCase);
- * Creates a `<PropertyIsNotEqualTo>` comparison operator.
- * @returns {!ol.format.filter.NotEqualTo} `<PropertyIsNotEqualTo>` operator.
- * @api
-ol.format.filter.notEqualTo = function(propertyName, expression, opt_matchCase) {
- return new ol.format.filter.NotEqualTo(propertyName, expression, opt_matchCase);
- * Creates a `<PropertyIsLessThan>` comparison operator.
- * @returns {!ol.format.filter.LessThan} `<PropertyIsLessThan>` operator.
- * @api
-ol.format.filter.lessThan = function(propertyName, expression) {
- return new ol.format.filter.LessThan(propertyName, expression);
- * Creates a `<PropertyIsLessThanOrEqualTo>` comparison operator.
- * @returns {!ol.format.filter.LessThanOrEqualTo} `<PropertyIsLessThanOrEqualTo>` operator.
- * @api
-ol.format.filter.lessThanOrEqualTo = function(propertyName, expression) {
- return new ol.format.filter.LessThanOrEqualTo(propertyName, expression);
- * Creates a `<PropertyIsGreaterThan>` comparison operator.
- * @returns {!ol.format.filter.GreaterThan} `<PropertyIsGreaterThan>` operator.
- * @api
-ol.format.filter.greaterThan = function(propertyName, expression) {
- return new ol.format.filter.GreaterThan(propertyName, expression);
- * Creates a `<PropertyIsGreaterThanOrEqualTo>` comparison operator.
- * @returns {!ol.format.filter.GreaterThanOrEqualTo} `<PropertyIsGreaterThanOrEqualTo>` operator.
- * @api
-ol.format.filter.greaterThanOrEqualTo = function(propertyName, expression) {
- return new ol.format.filter.GreaterThanOrEqualTo(propertyName, expression);
- * Creates a `<PropertyIsNull>` comparison operator to test whether a property value
- * is null.
- * @returns {!ol.format.filter.IsNull} `<PropertyIsNull>` operator.
- * @api
-ol.format.filter.isNull = function(propertyName) {
- return new ol.format.filter.IsNull(propertyName);
- * Creates a `<PropertyIsBetween>` comparison operator to test whether an expression
- * value lies within a range given by a lower and upper bound (inclusive).
- * @returns {!ol.format.filter.IsBetween} `<PropertyIsBetween>` operator.
- * @api
-ol.format.filter.between = function(propertyName, lowerBoundary, upperBoundary) {
- return new ol.format.filter.IsBetween(propertyName, lowerBoundary, upperBoundary);
- * Represents a `<PropertyIsLike>` comparison operator that matches a string property
- * value against a text pattern.
- * @returns {!ol.format.filter.IsLike} `<PropertyIsLike>` operator.
- * @api
-ol.format.filter.like = function(propertyName, pattern,
- return new ol.format.filter.IsLike(propertyName, pattern,
- opt_wildCard, opt_singleChar, opt_escapeChar, opt_matchCase);
-goog.provide('ol.geom.GeometryCollection');
-goog.require('ol.events');
-goog.require('ol.events.EventType');
-goog.require('ol.geom.Geometry');
-goog.require('ol.obj');
- * @classdesc
- * An array of {@link ol.geom.Geometry} objects.
- * @constructor
- * @extends {ol.geom.Geometry}
- * @param {Array.<ol.geom.Geometry>=} opt_geometries Geometries.
- * @api
-ol.geom.GeometryCollection = function(opt_geometries) {
- ol.geom.Geometry.call(this);
- * @private
- * @type {Array.<ol.geom.Geometry>}
- this.geometries_ = opt_geometries ? opt_geometries : null;
- this.listenGeometriesChange_();
-ol.inherits(ol.geom.GeometryCollection, ol.geom.Geometry);
- * @param {Array.<ol.geom.Geometry>} geometries Geometries.
- * @private
- * @return {Array.<ol.geom.Geometry>} Cloned geometries.
-ol.geom.GeometryCollection.cloneGeometries_ = function(geometries) {
- var clonedGeometries = [];
- var i, ii;
- for (i = 0, ii = geometries.length; i < ii; ++i) {
- clonedGeometries.push(geometries[i].clone());
- return clonedGeometries;
- * @private
-ol.geom.GeometryCollection.prototype.unlistenGeometriesChange_ = function() {
- var i, ii;
- if (!this.geometries_) {
- return;
- for (i = 0, ii = this.geometries_.length; i < ii; ++i) {
- ol.events.unlisten(
- this.geometries_[i], ol.events.EventType.CHANGE,
- this.changed, this);
- * @private
-ol.geom.GeometryCollection.prototype.listenGeometriesChange_ = function() {
- var i, ii;
- return;
- ol.events.listen(
- * @return {!ol.geom.GeometryCollection} Clone.
- * @override
- * @api
-ol.geom.GeometryCollection.prototype.clone = function() {
- var geometryCollection = new ol.geom.GeometryCollection(null);
- geometryCollection.setGeometries(this.geometries_);
- return geometryCollection;
- * @inheritDoc
-ol.geom.GeometryCollection.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- var geometries = this.geometries_;
- var i, ii;
- minSquaredDistance = geometries[i].closestPointXY(
- x, y, closestPoint, minSquaredDistance);
- * @inheritDoc
-ol.geom.GeometryCollection.prototype.containsXY = function(x, y) {
- var i, ii;
- if (geometries[i].containsXY(x, y)) {
- return true;
- return false;
- * @inheritDoc
-ol.geom.GeometryCollection.prototype.computeExtent = function(extent) {
- ol.extent.createOrUpdateEmpty(extent);
- for (var i = 0, ii = geometries.length; i < ii; ++i) {
- ol.extent.extend(extent, geometries[i].getExtent());
- return extent;
- * Return the geometries that make up this geometry collection.
- * @return {Array.<ol.geom.Geometry>} Geometries.
- * @api
-ol.geom.GeometryCollection.prototype.getGeometries = function() {
- return ol.geom.GeometryCollection.cloneGeometries_(this.geometries_);
-ol.geom.GeometryCollection.prototype.getGeometriesArray = function() {
- return this.geometries_;
- * @inheritDoc
-ol.geom.GeometryCollection.prototype.getSimplifiedGeometry = function(squaredTolerance) {
- if (this.simplifiedGeometryRevision != this.getRevision()) {
- ol.obj.clear(this.simplifiedGeometryCache);
- this.simplifiedGeometryMaxMinSquaredTolerance = 0;
- this.simplifiedGeometryRevision = this.getRevision();
- if (squaredTolerance < 0 ||
- (this.simplifiedGeometryMaxMinSquaredTolerance !== 0 &&
- squaredTolerance < this.simplifiedGeometryMaxMinSquaredTolerance)) {
- return this;
- var key = squaredTolerance.toString();
- if (this.simplifiedGeometryCache.hasOwnProperty(key)) {
- return this.simplifiedGeometryCache[key];
- } else {
- var simplifiedGeometries = [];
- var simplified = false;
- var i, ii;
- var geometry = geometries[i];
- var simplifiedGeometry = geometry.getSimplifiedGeometry(squaredTolerance);
- simplifiedGeometries.push(simplifiedGeometry);
- if (simplifiedGeometry !== geometry) {
- simplified = true;
- if (simplified) {
- var simplifiedGeometryCollection = new ol.geom.GeometryCollection(null);
- simplifiedGeometryCollection.setGeometriesArray(simplifiedGeometries);
- this.simplifiedGeometryCache[key] = simplifiedGeometryCollection;
- return simplifiedGeometryCollection;
- } else {
- this.simplifiedGeometryMaxMinSquaredTolerance = squaredTolerance;
- return this;
- * @inheritDoc
- * @api
-ol.geom.GeometryCollection.prototype.getType = function() {
- return ol.geom.GeometryType.GEOMETRY_COLLECTION;
- * @inheritDoc
- * @api
-ol.geom.GeometryCollection.prototype.intersectsExtent = function(extent) {
- var i, ii;
- if (geometries[i].intersectsExtent(extent)) {
- return true;
- return false;
- * @return {boolean} Is empty.
-ol.geom.GeometryCollection.prototype.isEmpty = function() {
- return this.geometries_.length === 0;
- * @inheritDoc
- * @api
-ol.geom.GeometryCollection.prototype.rotate = function(angle, anchor) {
- geometries[i].rotate(angle, anchor);
- this.changed();
- * @inheritDoc
- * @api
-ol.geom.GeometryCollection.prototype.scale = function(sx, opt_sy, opt_anchor) {
- var anchor = opt_anchor;
- if (!anchor) {
- anchor = ol.extent.getCenter(this.getExtent());
- geometries[i].scale(sx, opt_sy, anchor);
- this.changed();
- * Set the geometries that make up this geometry collection.
- * @api
-ol.geom.GeometryCollection.prototype.setGeometries = function(geometries) {
- this.setGeometriesArray(
- ol.geom.GeometryCollection.cloneGeometries_(geometries));
-ol.geom.GeometryCollection.prototype.setGeometriesArray = function(geometries) {
- this.unlistenGeometriesChange_();
- this.geometries_ = geometries;
- this.changed();
- * @inheritDoc
- * @api
-ol.geom.GeometryCollection.prototype.applyTransform = function(transformFn) {
- var i, ii;
- geometries[i].applyTransform(transformFn);
- this.changed();
- * Translate the geometry.
- * @param {number} deltaX Delta X.
- * @param {number} deltaY Delta Y.
- * @override
- * @api
-ol.geom.GeometryCollection.prototype.translate = function(deltaX, deltaY) {
- var i, ii;
- geometries[i].translate(deltaX, deltaY);
- this.changed();
- * @inheritDoc
-ol.geom.GeometryCollection.prototype.disposeInternal = function() {
- ol.geom.Geometry.prototype.disposeInternal.call(this);
-// TODO: serialize dataProjection as crs member when writing
-// see https://github.com/openlayers/openlayers/issues/2078
-goog.provide('ol.format.GeoJSON');
-goog.require('ol.format.Feature');
-goog.require('ol.geom.GeometryCollection');
-goog.require('ol.proj');
- * @classdesc
- * Feature format for reading and writing data in the GeoJSON format.
- * @constructor
- * @param {olx.format.GeoJSONOptions=} opt_options Options.
- * @api
-ol.format.GeoJSON = function(opt_options) {
- * @inheritDoc
- this.defaultDataProjection = ol.proj.get(
- options.defaultDataProjection ?
- options.defaultDataProjection : 'EPSG:4326');
- if (options.featureProjection) {
- this.defaultFeatureProjection = ol.proj.get(options.featureProjection);
- * @private
-ol.inherits(ol.format.GeoJSON, ol.format.JSONFeature);
- * @param {GeoJSONGeometry|GeoJSONGeometryCollection} object Object.
- * @param {olx.format.ReadOptions=} opt_options Read options.
- * @private
- * @return {ol.geom.Geometry} Geometry.
-ol.format.GeoJSON.readGeometry_ = function(object, opt_options) {
- if (!object) {
- return null;
- var geometryReader = ol.format.GeoJSON.GEOMETRY_READERS_[object.type];
- * @param {GeoJSONGeometryCollection} object Object.
- * @private
- * @return {ol.geom.GeometryCollection} Geometry collection.
-ol.format.GeoJSON.readGeometryCollectionGeometry_ = function(
- var geometries = object.geometries.map(
- * @param {GeoJSONGeometry} geometry Geometry.
- * @return {ol.geom.Geometry} geometry Geometry.
- function(geometry) {
- return ol.format.GeoJSON.readGeometry_(geometry, opt_options);
- return new ol.geom.GeometryCollection(geometries);
- * @param {GeoJSONGeometry} object Object.
- * @private
-ol.format.GeoJSON.readPointGeometry_ = function(object) {
- return new ol.geom.Point(object.coordinates);
- * @private
-ol.format.GeoJSON.readLineStringGeometry_ = function(object) {
- return new ol.geom.LineString(object.coordinates);
- * @private
- * @return {ol.geom.MultiLineString} MultiLineString.
-ol.format.GeoJSON.readMultiLineStringGeometry_ = function(object) {
- return new ol.geom.MultiLineString(object.coordinates);
- * @private
- * @return {ol.geom.MultiPoint} MultiPoint.
-ol.format.GeoJSON.readMultiPointGeometry_ = function(object) {
- return new ol.geom.MultiPoint(object.coordinates);
- * @private
- * @return {ol.geom.MultiPolygon} MultiPolygon.
-ol.format.GeoJSON.readMultiPolygonGeometry_ = function(object) {
- return new ol.geom.MultiPolygon(object.coordinates);
- * @private
-ol.format.GeoJSON.readPolygonGeometry_ = function(object) {
- return new ol.geom.Polygon(object.coordinates);
- * @param {ol.geom.Geometry} geometry Geometry.
- * @param {olx.format.WriteOptions=} opt_options Write options.
- * @private
- * @return {GeoJSONGeometry|GeoJSONGeometryCollection} GeoJSON geometry.
-ol.format.GeoJSON.writeGeometry_ = function(geometry, opt_options) {
- var geometryWriter = ol.format.GeoJSON.GEOMETRY_WRITERS_[geometry.getType()];
- opt_options);
- * @private
- * @return {GeoJSONGeometryCollection} Empty GeoJSON geometry collection.
-ol.format.GeoJSON.writeEmptyGeometryCollectionGeometry_ = function(geometry) {
- return /** @type {GeoJSONGeometryCollection} */ ({
- type: 'GeometryCollection',
- geometries: []
- * @param {ol.geom.GeometryCollection} geometry Geometry.
- * @private
- * @return {GeoJSONGeometryCollection} GeoJSON geometry collection.
-ol.format.GeoJSON.writeGeometryCollectionGeometry_ = function(
- geometry, opt_options) {
- var geometries = geometry.getGeometriesArray().map(function(geometry) {
- var options = ol.obj.assign({}, opt_options);
- delete options.featureProjection;
- return ol.format.GeoJSON.writeGeometry_(geometry, options);
- geometries: geometries
- * @param {ol.geom.LineString} geometry Geometry.
- * @private
- * @return {GeoJSONGeometry} GeoJSON geometry.
-ol.format.GeoJSON.writeLineStringGeometry_ = function(geometry, opt_options) {
- return /** @type {GeoJSONGeometry} */ ({
- type: 'LineString',
- coordinates: geometry.getCoordinates()
- * @param {ol.geom.MultiLineString} geometry Geometry.
- * @private
-ol.format.GeoJSON.writeMultiLineStringGeometry_ = function(geometry, opt_options) {
- type: 'MultiLineString',
- * @param {ol.geom.MultiPoint} geometry Geometry.
- * @private
-ol.format.GeoJSON.writeMultiPointGeometry_ = function(geometry, opt_options) {
- type: 'MultiPoint',
- * @param {ol.geom.MultiPolygon} geometry Geometry.
- * @private
-ol.format.GeoJSON.writeMultiPolygonGeometry_ = function(geometry, opt_options) {
- var right;
- if (opt_options) {
- right = opt_options.rightHanded;
- type: 'MultiPolygon',
- coordinates: geometry.getCoordinates(right)
- * @param {ol.geom.Point} geometry Geometry.
- * @private
-ol.format.GeoJSON.writePointGeometry_ = function(geometry, opt_options) {
- type: 'Point',
- * @param {ol.geom.Polygon} geometry Geometry.
- * @private
-ol.format.GeoJSON.writePolygonGeometry_ = function(geometry, opt_options) {
- var right;
- type: 'Polygon',
- * @const
- * @private
- * @type {Object.<string, function(GeoJSONObject): ol.geom.Geometry>}
-ol.format.GeoJSON.GEOMETRY_READERS_ = {
- 'Point': ol.format.GeoJSON.readPointGeometry_,
- 'LineString': ol.format.GeoJSON.readLineStringGeometry_,
- 'Polygon': ol.format.GeoJSON.readPolygonGeometry_,
- 'MultiPoint': ol.format.GeoJSON.readMultiPointGeometry_,
- 'MultiLineString': ol.format.GeoJSON.readMultiLineStringGeometry_,
- 'MultiPolygon': ol.format.GeoJSON.readMultiPolygonGeometry_,
- 'GeometryCollection': ol.format.GeoJSON.readGeometryCollectionGeometry_
- * @const
- * @private
- * @type {Object.<string, function(ol.geom.Geometry, olx.format.WriteOptions=): (GeoJSONGeometry|GeoJSONGeometryCollection)>}
-ol.format.GeoJSON.GEOMETRY_WRITERS_ = {
- 'Point': ol.format.GeoJSON.writePointGeometry_,
- 'LineString': ol.format.GeoJSON.writeLineStringGeometry_,
- 'Polygon': ol.format.GeoJSON.writePolygonGeometry_,
- 'MultiPoint': ol.format.GeoJSON.writeMultiPointGeometry_,
- 'MultiLineString': ol.format.GeoJSON.writeMultiLineStringGeometry_,
- 'MultiPolygon': ol.format.GeoJSON.writeMultiPolygonGeometry_,
- 'GeometryCollection': ol.format.GeoJSON.writeGeometryCollectionGeometry_,
- 'Circle': ol.format.GeoJSON.writeEmptyGeometryCollectionGeometry_
- * Read a feature from a GeoJSON Feature source. Only works for Feature or
- * geometry types. Use {@link ol.format.GeoJSON#readFeatures} to read
- * FeatureCollection source.
- * @function
- * @param {Document|Node|Object|string} source Source.
- * @return {ol.Feature} Feature.
- * @api
-ol.format.GeoJSON.prototype.readFeature;
- * Read all features from a GeoJSON source. Works for all GeoJSON types.
- * If the source includes only geometries, features will be created with those
- * geometries.
- * @function
- * @return {Array.<ol.Feature>} Features.
- * @api
-ol.format.GeoJSON.prototype.readFeatures;
- * @inheritDoc
-ol.format.GeoJSON.prototype.readFeatureFromObject = function(
- * @type {GeoJSONFeature}
- var geoJSONFeature = null;
- if (object.type === 'Feature') {
- geoJSONFeature = /** @type {GeoJSONFeature} */ (object);
- } else {
- geoJSONFeature = /** @type {GeoJSONFeature} */ ({
- type: 'Feature',
- geometry: /** @type {GeoJSONGeometry|GeoJSONGeometryCollection} */ (object)
- var geometry = ol.format.GeoJSON.readGeometry_(geoJSONFeature.geometry, opt_options);
- if (geoJSONFeature.id !== undefined) {
- feature.setId(geoJSONFeature.id);
- if (geoJSONFeature.properties) {
- feature.setProperties(geoJSONFeature.properties);
- return feature;
- * @inheritDoc
-ol.format.GeoJSON.prototype.readFeaturesFromObject = function(
- var geoJSONObject = /** @type {GeoJSONObject} */ (object);
- var features = null;
- if (geoJSONObject.type === 'FeatureCollection') {
- var geoJSONFeatureCollection = /** @type {GeoJSONFeatureCollection} */
- (object);
- features = [];
- var geoJSONFeatures = geoJSONFeatureCollection.features;
- var i, ii;
- for (i = 0, ii = geoJSONFeatures.length; i < ii; ++i) {
- features.push(this.readFeatureFromObject(geoJSONFeatures[i],
- opt_options));
- } else {
- features = [this.readFeatureFromObject(object, opt_options)];
- return features;
- * Read a geometry from a GeoJSON source.
- * @function
- * @api
-ol.format.GeoJSON.prototype.readGeometry;
- * @inheritDoc
-ol.format.GeoJSON.prototype.readGeometryFromObject = function(
- /** @type {GeoJSONGeometry} */ (object), opt_options);
- * Read the projection from a GeoJSON source.
- * @function
- * @return {ol.proj.Projection} Projection.
- * @api
-ol.format.GeoJSON.prototype.readProjection;
- * @inheritDoc
-ol.format.GeoJSON.prototype.readProjectionFromObject = function(object) {
- var crs = geoJSONObject.crs;
- var projection;
- if (crs) {
- if (crs.type == 'name') {
- projection = ol.proj.get(crs.properties.name);
- } else if (crs.type == 'EPSG') {
- // 'EPSG' is not part of the GeoJSON specification, but is generated by
- // GeoServer.
- // TODO: remove this when http://jira.codehaus.org/browse/GEOS-5996
- // is fixed and widely deployed.
- projection = ol.proj.get('EPSG:' + crs.properties.code);
- } else {
- ol.asserts.assert(false, 36); // Unknown SRS type
- } else {
- projection = this.defaultDataProjection;
- return /** @type {ol.proj.Projection} */ (projection);
- * Encode a feature as a GeoJSON Feature string.
- * @function
- * @param {ol.Feature} feature Feature.
- * @return {string} GeoJSON.
- * @override
- * @api
-ol.format.GeoJSON.prototype.writeFeature;
- * Encode a feature as a GeoJSON Feature object.
- * @return {GeoJSONFeature} Object.
- * @override
- * @api
-ol.format.GeoJSON.prototype.writeFeatureObject = function(feature, opt_options) {
- var object = /** @type {GeoJSONFeature} */ ({
- 'type': 'Feature'
- var id = feature.getId();
- if (id !== undefined) {
- object.id = id;
- if (geometry) {
- object.geometry =
- ol.format.GeoJSON.writeGeometry_(geometry, opt_options);
- } else {
- object.geometry = null;
- object.properties = properties;
- } else {
- object.properties = null;
- return object;
- * Encode an array of features as GeoJSON.
- * @function
- * @param {Array.<ol.Feature>} features Features.
- * @api
-ol.format.GeoJSON.prototype.writeFeatures;
- * Encode an array of features as a GeoJSON object.
- * @return {GeoJSONFeatureCollection} GeoJSON Object.
- * @override
- * @api
-ol.format.GeoJSON.prototype.writeFeaturesObject = function(features, opt_options) {
- var objects = [];
- var i, ii;
- return /** @type {GeoJSONFeatureCollection} */ ({
- type: 'FeatureCollection',
- features: objects
- * Encode a geometry as a GeoJSON string.
- * @function
- * @api
-ol.format.GeoJSON.prototype.writeGeometry;
- * Encode a geometry as a GeoJSON object.
- * @return {GeoJSONGeometry|GeoJSONGeometryCollection} Object.
- * @override
- * @api
-ol.format.GeoJSON.prototype.writeGeometryObject = function(geometry,
- opt_options) {
-goog.provide('ol.format.XMLFeature');
-goog.require('ol.array');
-goog.require('ol.format.FormatType');
-goog.require('ol.xml');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * Base class for XML feature formats.
- * @constructor
- * @abstract
- * @extends {ol.format.Feature}
-ol.format.XMLFeature = function() {
- * @type {XMLSerializer}
- * @private
- this.xmlSerializer_ = new XMLSerializer();
- ol.format.Feature.call(this);
-ol.inherits(ol.format.XMLFeature, ol.format.Feature);
- * @inheritDoc
-ol.format.XMLFeature.prototype.getType = function() {
- return ol.format.FormatType.XML;
- * @inheritDoc
-ol.format.XMLFeature.prototype.readFeature = function(source, opt_options) {
- if (ol.xml.isDocument(source)) {
- return this.readFeatureFromDocument(
- /** @type {Document} */ (source), opt_options);
- } else if (ol.xml.isNode(source)) {
- return this.readFeatureFromNode(/** @type {Node} */ (source), opt_options);
- } else if (typeof source === 'string') {
- var doc = ol.xml.parse(source);
- return this.readFeatureFromDocument(doc, opt_options);
- } else {
- return null;
- * @param {Document} doc Document.
- * @param {olx.format.ReadOptions=} opt_options Options.
-ol.format.XMLFeature.prototype.readFeatureFromDocument = function(
- doc, opt_options) {
- var features = this.readFeaturesFromDocument(doc, opt_options);
- if (features.length > 0) {
- return features[0];
- } else {
- return null;
- * @param {Node} node Node.
-ol.format.XMLFeature.prototype.readFeatureFromNode = function(node, opt_options) {
- return null; // not implemented
- * @inheritDoc
-ol.format.XMLFeature.prototype.readFeatures = function(source, opt_options) {
- return this.readFeaturesFromDocument(
- return this.readFeaturesFromNode(/** @type {Node} */ (source), opt_options);
- return this.readFeaturesFromDocument(doc, opt_options);
- } else {
- return [];
- * @protected
-ol.format.XMLFeature.prototype.readFeaturesFromDocument = function(
- var n;
- for (n = doc.firstChild; n; n = n.nextSibling) {
- if (n.nodeType == Node.ELEMENT_NODE) {
- ol.array.extend(features, this.readFeaturesFromNode(n, opt_options));
- return features;
- * @abstract
- * @protected
-ol.format.XMLFeature.prototype.readFeaturesFromNode = function(node, opt_options) {};
- * @inheritDoc
-ol.format.XMLFeature.prototype.readGeometry = function(source, opt_options) {
- return this.readGeometryFromDocument(
- return this.readGeometryFromNode(/** @type {Node} */ (source), opt_options);
- return this.readGeometryFromDocument(doc, opt_options);
- } else {
- return null;
- * @protected
-ol.format.XMLFeature.prototype.readGeometryFromDocument = function(doc, opt_options) {
- * @protected
-ol.format.XMLFeature.prototype.readGeometryFromNode = function(node, opt_options) {
- * @inheritDoc
-ol.format.XMLFeature.prototype.readProjection = function(source) {
- return this.readProjectionFromDocument(/** @type {Document} */ (source));
- return this.readProjectionFromNode(/** @type {Node} */ (source));
- return this.readProjectionFromDocument(doc);
- } else {
- return null;
- * @protected
-ol.format.XMLFeature.prototype.readProjectionFromDocument = function(doc) {
- return this.defaultDataProjection;
- * @protected
-ol.format.XMLFeature.prototype.readProjectionFromNode = function(node) {
- * @inheritDoc
-ol.format.XMLFeature.prototype.writeFeature = function(feature, opt_options) {
- var node = this.writeFeatureNode(feature, opt_options);
- return this.xmlSerializer_.serializeToString(node);
- * @param {olx.format.WriteOptions=} opt_options Options.
- * @protected
- * @return {Node} Node.
-ol.format.XMLFeature.prototype.writeFeatureNode = function(feature, opt_options) {
- * @inheritDoc
-ol.format.XMLFeature.prototype.writeFeatures = function(features, opt_options) {
- var node = this.writeFeaturesNode(features, opt_options);
-ol.format.XMLFeature.prototype.writeFeaturesNode = function(features, opt_options) {
- * @inheritDoc
-ol.format.XMLFeature.prototype.writeGeometry = function(geometry, opt_options) {
- var node = this.writeGeometryNode(geometry, opt_options);
-ol.format.XMLFeature.prototype.writeGeometryNode = function(geometry, opt_options) {
-// FIXME Envelopes should not be treated as geometries! readEnvelope_ is part
-// of GEOMETRY_PARSERS_ and methods using GEOMETRY_PARSERS_ do not expect
-// envelopes/extents, only geometries!
-goog.provide('ol.format.GMLBase');
-goog.require('ol');
-goog.require('ol.format.XMLFeature');
-goog.require('ol.geom.GeometryLayout');
-goog.require('ol.geom.LineString');
-goog.require('ol.geom.MultiPoint');
-goog.require('ol.geom.Point');
-goog.require('ol.geom.Polygon');
- * @classdesc
- * Feature base format for reading and writing data in the GML format.
- * This class cannot be instantiated, it contains only base content that
- * is shared with versioned format classes ol.format.GML2 and
- * ol.format.GML3.
- * @constructor
- * @abstract
- * @param {olx.format.GMLOptions=} opt_options
- * Optional configuration object.
- * @extends {ol.format.XMLFeature}
-ol.format.GMLBase = function(opt_options) {
- var options = /** @type {olx.format.GMLOptions} */
- (opt_options ? opt_options : {});
- * @protected
- * @type {Array.<string>|string|undefined}
- this.featureType = options.featureType;
- * @protected
- * @type {Object.<string, string>|string|undefined}
- this.featureNS = options.featureNS;
- * @protected
- * @type {string}
- this.srsName = options.srsName;
- * @protected
- * @type {string}
- this.schemaLocation = '';
- * @type {Object.<string, Object.<string, Object>>}
- this.FEATURE_COLLECTION_PARSERS = {};
- this.FEATURE_COLLECTION_PARSERS[ol.format.GMLBase.GMLNS] = {
- 'featureMember': ol.xml.makeReplacer(
- ol.format.GMLBase.prototype.readFeaturesInternal),
- 'featureMembers': ol.xml.makeReplacer(
- ol.format.XMLFeature.call(this);
-ol.inherits(ol.format.GMLBase, ol.format.XMLFeature);
- * @const
- * @type {string}
-ol.format.GMLBase.GMLNS = 'http://www.opengis.net/gml';
- * A regular expression that matches if a string only contains whitespace
- * characters. It will e.g. match `''`, `' '`, `'\n'` etc. The non-breaking
- * space (0xa0) is explicitly included as IE doesn't include it in its
- * definition of `\s`.
- * Information from `goog.string.isEmptyOrWhitespace`: https://github.com/google/closure-library/blob/e877b1e/closure/goog/string/string.js#L156-L160
- * @const
- * @type {RegExp}
- * @private
-ol.format.GMLBase.ONLY_WHITESPACE_RE_ = /^[\s\xa0]*$/;
- * @param {Array.<*>} objectStack Object stack.
- * @return {Array.<ol.Feature> | undefined} Features.
-ol.format.GMLBase.prototype.readFeaturesInternal = function(node, objectStack) {
- var localName = node.localName;
- if (localName == 'FeatureCollection') {
- if (node.namespaceURI === 'http://www.opengis.net/wfs') {
- features = ol.xml.pushParseAndPop([],
- this.FEATURE_COLLECTION_PARSERS, node,
- objectStack, this);
- } else {
- features = ol.xml.pushParseAndPop(null,
- } else if (localName == 'featureMembers' || localName == 'featureMember') {
- var context = objectStack[0];
- var featureType = context['featureType'];
- var featureNS = context['featureNS'];
- var i, ii, prefix = 'p', defaultPrefix = 'p0';
- if (!featureType && node.childNodes) {
- featureType = [], featureNS = {};
- for (i = 0, ii = node.childNodes.length; i < ii; ++i) {
- var child = node.childNodes[i];
- if (child.nodeType === 1) {
- var ft = child.nodeName.split(':').pop();
- if (featureType.indexOf(ft) === -1) {
- var key = '';
- var count = 0;
- var uri = child.namespaceURI;
- for (var candidate in featureNS) {
- if (featureNS[candidate] === uri) {
- key = candidate;
- break;
- ++count;
- if (!key) {
- key = prefix + count;
- featureNS[key] = uri;
- featureType.push(key + ':' + ft);
- if (localName != 'featureMember') {
- // recheck featureType for each featureMember
- context['featureType'] = featureType;
- context['featureNS'] = featureNS;
- if (typeof featureNS === 'string') {
- var ns = featureNS;
- featureNS = {};
- featureNS[defaultPrefix] = ns;
- var parsersNS = {};
- var featureTypes = Array.isArray(featureType) ? featureType : [featureType];
- for (var p in featureNS) {
- var parsers = {};
- for (i = 0, ii = featureTypes.length; i < ii; ++i) {
- var featurePrefix = featureTypes[i].indexOf(':') === -1 ?
- defaultPrefix : featureTypes[i].split(':')[0];
- if (featurePrefix === p) {
- parsers[featureTypes[i].split(':').pop()] =
- (localName == 'featureMembers') ?
- ol.xml.makeArrayPusher(this.readFeatureElement, this) :
- ol.xml.makeReplacer(this.readFeatureElement, this);
- parsersNS[featureNS[p]] = parsers;
- if (localName == 'featureMember') {
- features = ol.xml.pushParseAndPop(undefined, parsersNS, node, objectStack);
- } else {
- features = ol.xml.pushParseAndPop([], parsersNS, node, objectStack);
- if (features === null) {
- features = [];
- return features;
- * @return {ol.geom.Geometry|undefined} Geometry.
-ol.format.GMLBase.prototype.readGeometryElement = function(node, objectStack) {
- var context = /** @type {Object} */ (objectStack[0]);
- context['srsName'] = node.firstElementChild.getAttribute('srsName');
- /** @type {ol.geom.Geometry} */
- var geometry = ol.xml.pushParseAndPop(null,
- this.GEOMETRY_PARSERS_, node, objectStack, this);
- if (geometry) {
- ol.format.Feature.transformWithOptions(geometry, false, context));
- } else {
- return undefined;
-ol.format.GMLBase.prototype.readFeatureElement = function(node, objectStack) {
- var n;
- var fid = node.getAttribute('fid') ||
- ol.xml.getAttributeNS(node, ol.format.GMLBase.GMLNS, 'id');
- var values = {}, geometryName;
- for (n = node.firstElementChild; n; n = n.nextElementSibling) {
- var localName = n.localName;
- // Assume attribute elements have one child node and that the child
- // is a text or CDATA node (to be treated as text).
- // Otherwise assume it is a geometry node.
- if (n.childNodes.length === 0 ||
- (n.childNodes.length === 1 &&
- (n.firstChild.nodeType === 3 || n.firstChild.nodeType === 4))) {
- var value = ol.xml.getAllTextContent(n, false);
- if (ol.format.GMLBase.ONLY_WHITESPACE_RE_.test(value)) {
- value = undefined;
- values[localName] = value;
- } else {
- // boundedBy is an extent and must not be considered as a geometry
- if (localName !== 'boundedBy') {
- geometryName = localName;
- values[localName] = this.readGeometryElement(n, objectStack);
- var feature = new ol.Feature(values);
- if (geometryName) {
- feature.setGeometryName(geometryName);
- if (fid) {
- feature.setId(fid);
- return feature;
- * @return {ol.geom.Point|undefined} Point.
-ol.format.GMLBase.prototype.readPoint = function(node, objectStack) {
- var flatCoordinates =
- this.readFlatCoordinatesFromNode_(node, objectStack);
- if (flatCoordinates) {
- var point = new ol.geom.Point(null);
- point.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
- return point;
- * @return {ol.geom.MultiPoint|undefined} MultiPoint.
-ol.format.GMLBase.prototype.readMultiPoint = function(node, objectStack) {
- /** @type {Array.<Array.<number>>} */
- var coordinates = ol.xml.pushParseAndPop([],
- this.MULTIPOINT_PARSERS_, node, objectStack, this);
- if (coordinates) {
- return new ol.geom.MultiPoint(coordinates);
- } else {
- return undefined;
- * @return {ol.geom.MultiLineString|undefined} MultiLineString.
-ol.format.GMLBase.prototype.readMultiLineString = function(node, objectStack) {
- /** @type {Array.<ol.geom.LineString>} */
- var lineStrings = ol.xml.pushParseAndPop([],
- this.MULTILINESTRING_PARSERS_, node, objectStack, this);
- if (lineStrings) {
- var multiLineString = new ol.geom.MultiLineString(null);
- multiLineString.setLineStrings(lineStrings);
- return multiLineString;
- } else {
- return undefined;
- * @return {ol.geom.MultiPolygon|undefined} MultiPolygon.
-ol.format.GMLBase.prototype.readMultiPolygon = function(node, objectStack) {
- /** @type {Array.<ol.geom.Polygon>} */
- var polygons = ol.xml.pushParseAndPop([],
- this.MULTIPOLYGON_PARSERS_, node, objectStack, this);
- if (polygons) {
- var multiPolygon = new ol.geom.MultiPolygon(null);
- multiPolygon.setPolygons(polygons);
- return multiPolygon;
- } else {
- return undefined;
- * @private
-ol.format.GMLBase.prototype.pointMemberParser_ = function(node, objectStack) {
- ol.xml.parseNode(this.POINTMEMBER_PARSERS_,
- node, objectStack, this);
- * @private
-ol.format.GMLBase.prototype.lineStringMemberParser_ = function(node, objectStack) {
- ol.xml.parseNode(this.LINESTRINGMEMBER_PARSERS_,
- * @private
-ol.format.GMLBase.prototype.polygonMemberParser_ = function(node, objectStack) {
- ol.xml.parseNode(this.POLYGONMEMBER_PARSERS_, node,
- * @return {ol.geom.LineString|undefined} LineString.
-ol.format.GMLBase.prototype.readLineString = function(node, objectStack) {
- var lineString = new ol.geom.LineString(null);
- lineString.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
- return lineString;
- } else {
- return undefined;
- * @private
- * @return {Array.<number>|undefined} LinearRing flat coordinates.
-ol.format.GMLBase.prototype.readFlatLinearRing_ = function(node, objectStack) {
- var ring = ol.xml.pushParseAndPop(null,
- this.GEOMETRY_FLAT_COORDINATES_PARSERS_, node,
- if (ring) {
- return ring;
- } else {
- return undefined;
- * @return {ol.geom.LinearRing|undefined} LinearRing.
-ol.format.GMLBase.prototype.readLinearRing = function(node, objectStack) {
- var ring = new ol.geom.LinearRing(null);
- ring.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
- return ring;
- } else {
- return undefined;
- * @return {ol.geom.Polygon|undefined} Polygon.
-ol.format.GMLBase.prototype.readPolygon = function(node, objectStack) {
- var flatLinearRings = ol.xml.pushParseAndPop([null],
- this.FLAT_LINEAR_RINGS_PARSERS_, node, objectStack, this);
- if (flatLinearRings && flatLinearRings[0]) {
- var polygon = new ol.geom.Polygon(null);
- var flatCoordinates = flatLinearRings[0];
- var ends = [flatCoordinates.length];
- var i, ii;
- for (i = 1, ii = flatLinearRings.length; i < ii; ++i) {
- ol.array.extend(flatCoordinates, flatLinearRings[i]);
- ends.push(flatCoordinates.length);
- polygon.setFlatCoordinates(
- ol.geom.GeometryLayout.XYZ, flatCoordinates, ends);
- return polygon;
- } else {
- return undefined;
- * @private
- * @return {Array.<number>} Flat coordinates.
-ol.format.GMLBase.prototype.readFlatCoordinatesFromNode_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop(null,
- * @const
- * @type {Object.<string, Object.<string, ol.XmlParser>>}
- * @private
-ol.format.GMLBase.prototype.MULTIPOINT_PARSERS_ = {
- 'http://www.opengis.net/gml': {
- 'pointMember': ol.xml.makeArrayPusher(
- ol.format.GMLBase.prototype.pointMemberParser_),
- 'pointMembers': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GMLBase.prototype.MULTILINESTRING_PARSERS_ = {
- 'lineStringMember': ol.xml.makeArrayPusher(
- ol.format.GMLBase.prototype.lineStringMemberParser_),
- 'lineStringMembers': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GMLBase.prototype.MULTIPOLYGON_PARSERS_ = {
- 'polygonMember': ol.xml.makeArrayPusher(
- ol.format.GMLBase.prototype.polygonMemberParser_),
- 'polygonMembers': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GMLBase.prototype.POINTMEMBER_PARSERS_ = {
- 'Point': ol.xml.makeArrayPusher(
- ol.format.GMLBase.prototype.readFlatCoordinatesFromNode_)
- * @const
- * @private
-ol.format.GMLBase.prototype.LINESTRINGMEMBER_PARSERS_ = {
- 'LineString': ol.xml.makeArrayPusher(
- ol.format.GMLBase.prototype.readLineString)
- * @const
- * @private
-ol.format.GMLBase.prototype.POLYGONMEMBER_PARSERS_ = {
- 'Polygon': ol.xml.makeArrayPusher(
- ol.format.GMLBase.prototype.readPolygon)
- * @const
- * @protected
-ol.format.GMLBase.prototype.RING_PARSERS = {
- 'LinearRing': ol.xml.makeReplacer(
- ol.format.GMLBase.prototype.readFlatLinearRing_)
- * @inheritDoc
-ol.format.GMLBase.prototype.readGeometryFromNode = function(node, opt_options) {
- var geometry = this.readGeometryElement(node,
- [this.getReadOptions(node, opt_options ? opt_options : {})]);
- return geometry ? geometry : null;
- * Read all features from a GML FeatureCollection.
- * @function
- * @api
-ol.format.GMLBase.prototype.readFeatures;
- * @inheritDoc
-ol.format.GMLBase.prototype.readFeaturesFromNode = function(node, opt_options) {
- var options = {
- featureType: this.featureType,
- featureNS: this.featureNS
- ol.obj.assign(options, this.getReadOptions(node, opt_options));
- var features = this.readFeaturesInternal(node, [options]);
- return features || [];
- * @inheritDoc
-ol.format.GMLBase.prototype.readProjectionFromNode = function(node) {
- return ol.proj.get(this.srsName ? this.srsName :
- node.firstElementChild.getAttribute('srsName'));
-goog.provide('ol.format.XSD');
-goog.require('ol.string');
- * @const
- * @type {string}
-ol.format.XSD.NAMESPACE_URI = 'http://www.w3.org/2001/XMLSchema';
- * @return {boolean|undefined} Boolean.
-ol.format.XSD.readBoolean = function(node) {
- var s = ol.xml.getAllTextContent(node, false);
- return ol.format.XSD.readBooleanString(s);
- * @param {string} string String.
-ol.format.XSD.readBooleanString = function(string) {
- var m = /^\s*(true|1)|(false|0)\s*$/.exec(string);
- if (m) {
- return m[1] !== undefined || false;
- } else {
- return undefined;
- * @return {number|undefined} DateTime in seconds.
-ol.format.XSD.readDateTime = function(node) {
- var dateTime = Date.parse(s);
- return isNaN(dateTime) ? undefined : dateTime / 1000;
- * @return {number|undefined} Decimal.
-ol.format.XSD.readDecimal = function(node) {
- return ol.format.XSD.readDecimalString(s);
-ol.format.XSD.readDecimalString = function(string) {
- // FIXME check spec
- var m = /^\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?)\s*$/i.exec(string);
- if (m) {
- return parseFloat(m[1]);
- } else {
- return undefined;
- * @return {number|undefined} Non negative integer.
-ol.format.XSD.readNonNegativeInteger = function(node) {
- return ol.format.XSD.readNonNegativeIntegerString(s);
-ol.format.XSD.readNonNegativeIntegerString = function(string) {
- var m = /^\s*(\d+)\s*$/.exec(string);
- if (m) {
- return parseInt(m[1], 10);
- } else {
- return undefined;
- * @return {string|undefined} String.
-ol.format.XSD.readString = function(node) {
- return ol.xml.getAllTextContent(node, false).trim();
- * @param {Node} node Node to append a TextNode with the boolean to.
- * @param {boolean} bool Boolean.
-ol.format.XSD.writeBooleanTextNode = function(node, bool) {
- ol.format.XSD.writeStringTextNode(node, (bool) ? '1' : '0');
- * @param {Node} node Node to append a CDATA Section with the string to.
-ol.format.XSD.writeCDATASection = function(node, string) {
- node.appendChild(ol.xml.DOCUMENT.createCDATASection(string));
- * @param {Node} node Node to append a TextNode with the dateTime to.
- * @param {number} dateTime DateTime in seconds.
-ol.format.XSD.writeDateTimeTextNode = function(node, dateTime) {
- var date = new Date(dateTime * 1000);
- var string = date.getUTCFullYear() + '-' +
- ol.string.padNumber(date.getUTCMonth() + 1, 2) + '-' +
- ol.string.padNumber(date.getUTCDate(), 2) + 'T' +
- ol.string.padNumber(date.getUTCHours(), 2) + ':' +
- ol.string.padNumber(date.getUTCMinutes(), 2) + ':' +
- ol.string.padNumber(date.getUTCSeconds(), 2) + 'Z';
- node.appendChild(ol.xml.DOCUMENT.createTextNode(string));
- * @param {Node} node Node to append a TextNode with the decimal to.
- * @param {number} decimal Decimal.
-ol.format.XSD.writeDecimalTextNode = function(node, decimal) {
- var string = decimal.toPrecision();
- * @param {number} nonNegativeInteger Non negative integer.
-ol.format.XSD.writeNonNegativeIntegerTextNode = function(node, nonNegativeInteger) {
- var string = nonNegativeInteger.toString();
- * @param {Node} node Node to append a TextNode with the string to.
-ol.format.XSD.writeStringTextNode = function(node, string) {
-goog.provide('ol.format.GML3');
-goog.require('ol.extent');
-goog.require('ol.format.GMLBase');
-goog.require('ol.format.XSD');
-goog.require('ol.geom.MultiLineString');
-goog.require('ol.geom.MultiPolygon');
- * @classdesc
- * Feature format for reading and writing data in the GML format
- * version 3.1.1.
- * Currently only supports GML 3.1.1 Simple Features profile.
- * @constructor
- * @extends {ol.format.GMLBase}
- * @api
-ol.format.GML3 = function(opt_options) {
- ol.format.GMLBase.call(this, options);
- * @private
- * @type {boolean}
- this.surface_ = options.surface !== undefined ? options.surface : false;
- * @private
- * @type {boolean}
- this.curve_ = options.curve !== undefined ? options.curve : false;
- * @private
- * @type {boolean}
- this.multiCurve_ = options.multiCurve !== undefined ?
- options.multiCurve : true;
- * @private
- * @type {boolean}
- this.multiSurface_ = options.multiSurface !== undefined ?
- options.multiSurface : true;
- * @inheritDoc
- this.schemaLocation = options.schemaLocation ?
- options.schemaLocation : ol.format.GML3.schemaLocation_;
-ol.inherits(ol.format.GML3, ol.format.GMLBase);
- * @const
- * @type {string}
- * @private
-ol.format.GML3.schemaLocation_ = ol.format.GMLBase.GMLNS +
- ' http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/' +
- '1.0.0/gmlsf.xsd';
- * @private
-ol.format.GML3.prototype.readMultiCurve_ = function(node, objectStack) {
- this.MULTICURVE_PARSERS_, node, objectStack, this);
- } else {
- return undefined;
- * @private
-ol.format.GML3.prototype.readMultiSurface_ = function(node, objectStack) {
- this.MULTISURFACE_PARSERS_, node, objectStack, this);
- if (polygons) {
- } else {
- return undefined;
- * @private
-ol.format.GML3.prototype.curveMemberParser_ = function(node, objectStack) {
- ol.xml.parseNode(this.CURVEMEMBER_PARSERS_, node, objectStack, this);
- * @private
-ol.format.GML3.prototype.surfaceMemberParser_ = function(node, objectStack) {
- ol.xml.parseNode(this.SURFACEMEMBER_PARSERS_,
- * @private
- * @return {Array.<(Array.<number>)>|undefined} flat coordinates.
-ol.format.GML3.prototype.readPatch_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop([null],
- this.PATCHES_PARSERS_, node, objectStack, this);
- * @private
- * @return {Array.<number>|undefined} flat coordinates.
-ol.format.GML3.prototype.readSegment_ = function(node, objectStack) {
- this.SEGMENTS_PARSERS_, node, objectStack, this);
- * @private
-ol.format.GML3.prototype.readPolygonPatch_ = function(node, objectStack) {
- * @private
-ol.format.GML3.prototype.readLineStringSegment_ = function(node, objectStack) {
- * @private
-ol.format.GML3.prototype.interiorParser_ = function(node, objectStack) {
- /** @type {Array.<number>|undefined} */
- var flatLinearRing = ol.xml.pushParseAndPop(undefined,
- this.RING_PARSERS, node, objectStack, this);
- if (flatLinearRing) {
- var flatLinearRings = /** @type {Array.<Array.<number>>} */
- (objectStack[objectStack.length - 1]);
- flatLinearRings.push(flatLinearRing);
- * @private
-ol.format.GML3.prototype.exteriorParser_ = function(node, objectStack) {
- flatLinearRings[0] = flatLinearRing;
- * @private
-ol.format.GML3.prototype.readSurface_ = function(node, objectStack) {
- this.SURFACE_PARSERS_, node, objectStack, this);
- var i, ii;
- return polygon;
- } else {
- return undefined;
- * @private
-ol.format.GML3.prototype.readCurve_ = function(node, objectStack) {
- /** @type {Array.<number>} */
- var flatCoordinates = ol.xml.pushParseAndPop([null],
- this.CURVE_PARSERS_, node, objectStack, this);
- } else {
- return undefined;
- * @private
- * @return {ol.Extent|undefined} Envelope.
-ol.format.GML3.prototype.readEnvelope_ = function(node, objectStack) {
- this.ENVELOPE_PARSERS_, node, objectStack, this);
- return ol.extent.createOrUpdate(flatCoordinates[1][0],
- flatCoordinates[1][1], flatCoordinates[2][0],
- flatCoordinates[2][1]);
- * @private
- * @return {Array.<number>|undefined} Flat coordinates.
-ol.format.GML3.prototype.readFlatPos_ = function(node, objectStack) {
- var re = /^\s*([+\-]?\d*\.?\d+(?:[eE][+\-]?\d+)?)\s*/;
- var flatCoordinates = [];
- var m;
- while ((m = re.exec(s))) {
- flatCoordinates.push(parseFloat(m[1]));
- s = s.substr(m[0].length);
- if (s !== '') {
- return undefined;
- var containerSrs = context['srsName'];
- var axisOrientation = 'enu';
- if (containerSrs) {
- var proj = ol.proj.get(containerSrs);
- axisOrientation = proj.getAxisOrientation();
- if (axisOrientation === 'neu') {
- var i, ii;
- for (i = 0, ii = flatCoordinates.length; i < ii; i += 3) {
- var y = flatCoordinates[i];
- var x = flatCoordinates[i + 1];
- flatCoordinates[i] = x;
- flatCoordinates[i + 1] = y;
- var len = flatCoordinates.length;
- if (len == 2) {
- flatCoordinates.push(0);
- if (len === 0) {
- return undefined;
- return flatCoordinates;
- * @private
-ol.format.GML3.prototype.readFlatPosList_ = function(node, objectStack) {
- var s = ol.xml.getAllTextContent(node, false).replace(/^\s*|\s*$/g, '');
- var containerDimension = node.parentNode.getAttribute('srsDimension');
- var coords = s.split(/\s+/);
- // The "dimension" attribute is from the GML 3.0.1 spec.
- var dim = 2;
- if (node.getAttribute('srsDimension')) {
- dim = ol.format.XSD.readNonNegativeIntegerString(
- node.getAttribute('srsDimension'));
- } else if (node.getAttribute('dimension')) {
- node.getAttribute('dimension'));
- } else if (containerDimension) {
- dim = ol.format.XSD.readNonNegativeIntegerString(containerDimension);
- var x, y, z;
- for (var i = 0, ii = coords.length; i < ii; i += dim) {
- x = parseFloat(coords[i]);
- y = parseFloat(coords[i + 1]);
- z = (dim === 3) ? parseFloat(coords[i + 2]) : 0;
- if (axisOrientation.substr(0, 2) === 'en') {
- flatCoordinates.push(x, y, z);
- } else {
- flatCoordinates.push(y, x, z);
- * @const
- * @private
-ol.format.GML3.prototype.GEOMETRY_FLAT_COORDINATES_PARSERS_ = {
- 'pos': ol.xml.makeReplacer(ol.format.GML3.prototype.readFlatPos_),
- 'posList': ol.xml.makeReplacer(ol.format.GML3.prototype.readFlatPosList_)
- * @const
- * @private
-ol.format.GML3.prototype.FLAT_LINEAR_RINGS_PARSERS_ = {
- 'interior': ol.format.GML3.prototype.interiorParser_,
- 'exterior': ol.format.GML3.prototype.exteriorParser_
- * @const
- * @private
-ol.format.GML3.prototype.GEOMETRY_PARSERS_ = {
- 'Point': ol.xml.makeReplacer(ol.format.GMLBase.prototype.readPoint),
- 'MultiPoint': ol.xml.makeReplacer(
- ol.format.GMLBase.prototype.readMultiPoint),
- 'LineString': ol.xml.makeReplacer(
- ol.format.GMLBase.prototype.readLineString),
- 'MultiLineString': ol.xml.makeReplacer(
- ol.format.GMLBase.prototype.readMultiLineString),
- ol.format.GMLBase.prototype.readLinearRing),
- 'Polygon': ol.xml.makeReplacer(ol.format.GMLBase.prototype.readPolygon),
- 'MultiPolygon': ol.xml.makeReplacer(
- ol.format.GMLBase.prototype.readMultiPolygon),
- 'Surface': ol.xml.makeReplacer(ol.format.GML3.prototype.readSurface_),
- 'MultiSurface': ol.xml.makeReplacer(
- ol.format.GML3.prototype.readMultiSurface_),
- 'Curve': ol.xml.makeReplacer(ol.format.GML3.prototype.readCurve_),
- 'MultiCurve': ol.xml.makeReplacer(
- ol.format.GML3.prototype.readMultiCurve_),
- 'Envelope': ol.xml.makeReplacer(ol.format.GML3.prototype.readEnvelope_)
- * @const
- * @private
-ol.format.GML3.prototype.MULTICURVE_PARSERS_ = {
- 'curveMember': ol.xml.makeArrayPusher(
- ol.format.GML3.prototype.curveMemberParser_),
- 'curveMembers': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GML3.prototype.MULTISURFACE_PARSERS_ = {
- 'surfaceMember': ol.xml.makeArrayPusher(
- ol.format.GML3.prototype.surfaceMemberParser_),
- 'surfaceMembers': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GML3.prototype.CURVEMEMBER_PARSERS_ = {
- 'Curve': ol.xml.makeArrayPusher(ol.format.GML3.prototype.readCurve_)
- * @const
- * @private
-ol.format.GML3.prototype.SURFACEMEMBER_PARSERS_ = {
- 'Polygon': ol.xml.makeArrayPusher(ol.format.GMLBase.prototype.readPolygon),
- 'Surface': ol.xml.makeArrayPusher(ol.format.GML3.prototype.readSurface_)
- * @const
- * @private
-ol.format.GML3.prototype.SURFACE_PARSERS_ = {
- 'patches': ol.xml.makeReplacer(ol.format.GML3.prototype.readPatch_)
- * @const
- * @private
-ol.format.GML3.prototype.CURVE_PARSERS_ = {
- 'segments': ol.xml.makeReplacer(ol.format.GML3.prototype.readSegment_)
- * @const
- * @private
-ol.format.GML3.prototype.ENVELOPE_PARSERS_ = {
- 'lowerCorner': ol.xml.makeArrayPusher(
- ol.format.GML3.prototype.readFlatPosList_),
- 'upperCorner': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GML3.prototype.PATCHES_PARSERS_ = {
- 'PolygonPatch': ol.xml.makeReplacer(
- ol.format.GML3.prototype.readPolygonPatch_)
- * @const
- * @private
-ol.format.GML3.prototype.SEGMENTS_PARSERS_ = {
- 'LineStringSegment': ol.xml.makeReplacer(
- ol.format.GML3.prototype.readLineStringSegment_)
- * @param {ol.geom.Point} value Point geometry.
- * @param {Array.<*>} objectStack Node stack.
- * @private
-ol.format.GML3.prototype.writePos_ = function(node, value, objectStack) {
- var context = objectStack[objectStack.length - 1];
- var srsName = context['srsName'];
- if (srsName) {
- axisOrientation = ol.proj.get(srsName).getAxisOrientation();
- var point = value.getCoordinates();
- var coords;
- // only 2d for simple features profile
- coords = (point[0] + ' ' + point[1]);
- } else {
- coords = (point[1] + ' ' + point[0]);
- ol.format.XSD.writeStringTextNode(node, coords);
- * @param {Array.<number>} point Point geometry.
- * @param {string=} opt_srsName Optional srsName
- * @return {string} The coords string.
- * @private
-ol.format.GML3.prototype.getCoords_ = function(point, opt_srsName) {
- if (opt_srsName) {
- axisOrientation = ol.proj.get(opt_srsName).getAxisOrientation();
- return ((axisOrientation.substr(0, 2) === 'en') ?
- point[0] + ' ' + point[1] :
- point[1] + ' ' + point[0]);
- * @param {ol.geom.LineString|ol.geom.LinearRing} value Geometry.
- * @private
-ol.format.GML3.prototype.writePosList_ = function(node, value, objectStack) {
- var points = value.getCoordinates();
- var len = points.length;
- var parts = new Array(len);
- var point;
- for (var i = 0; i < len; ++i) {
- point = points[i];
- parts[i] = this.getCoords_(point, srsName);
- ol.format.XSD.writeStringTextNode(node, parts.join(' '));
- * @param {ol.geom.Point} geometry Point geometry.
- * @private
-ol.format.GML3.prototype.writePoint_ = function(node, geometry, objectStack) {
- if (srsName) {
- node.setAttribute('srsName', srsName);
- var pos = ol.xml.createElementNS(node.namespaceURI, 'pos');
- node.appendChild(pos);
- this.writePos_(pos, geometry, objectStack);
- * @type {Object.<string, Object.<string, ol.XmlSerializer>>}
- * @private
-ol.format.GML3.ENVELOPE_SERIALIZERS_ = {
- 'lowerCorner': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'upperCorner': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
- * @param {ol.Extent} extent Extent.
-ol.format.GML3.prototype.writeEnvelope = function(node, extent, objectStack) {
- if (srsName) {
- var keys = ['lowerCorner', 'upperCorner'];
- var values = [extent[0] + ' ' + extent[1], extent[2] + ' ' + extent[3]];
- ol.xml.pushSerializeAndPop(/** @type {ol.XmlNodeStackItem} */
- ({node: node}), ol.format.GML3.ENVELOPE_SERIALIZERS_,
- ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
- values,
- objectStack, keys, this);
- * @param {ol.geom.LinearRing} geometry LinearRing geometry.
- * @private
-ol.format.GML3.prototype.writeLinearRing_ = function(node, geometry, objectStack) {
- if (srsName) {
- var posList = ol.xml.createElementNS(node.namespaceURI, 'posList');
- node.appendChild(posList);
- this.writePosList_(posList, geometry, objectStack);
- * @param {*} value Value.
- * @param {string=} opt_nodeName Node name.
- * @private
-ol.format.GML3.prototype.RING_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- var parentNode = context.node;
- var exteriorWritten = context['exteriorWritten'];
- if (exteriorWritten === undefined) {
- context['exteriorWritten'] = true;
- return ol.xml.createElementNS(parentNode.namespaceURI,
- exteriorWritten !== undefined ? 'interior' : 'exterior');
- * @param {ol.geom.Polygon} geometry Polygon geometry.
- * @private
-ol.format.GML3.prototype.writeSurfaceOrPolygon_ = function(node, geometry, objectStack) {
- if (node.nodeName !== 'PolygonPatch' && srsName) {
- if (node.nodeName === 'Polygon' || node.nodeName === 'PolygonPatch') {
- var rings = geometry.getLinearRings();
- {node: node, srsName: srsName},
- ol.format.GML3.RING_SERIALIZERS_,
- this.RING_NODE_FACTORY_,
- rings, objectStack, undefined, this);
- } else if (node.nodeName === 'Surface') {
- var patches = ol.xml.createElementNS(node.namespaceURI, 'patches');
- node.appendChild(patches);
- this.writeSurfacePatches_(
- patches, geometry, objectStack);
- * @param {ol.geom.LineString} geometry LineString geometry.
- * @private
-ol.format.GML3.prototype.writeCurveOrLineString_ = function(node, geometry, objectStack) {
- if (node.nodeName !== 'LineStringSegment' && srsName) {
- if (node.nodeName === 'LineString' ||
- node.nodeName === 'LineStringSegment') {
- } else if (node.nodeName === 'Curve') {
- var segments = ol.xml.createElementNS(node.namespaceURI, 'segments');
- node.appendChild(segments);
- this.writeCurveSegments_(segments,
- geometry, objectStack);
- * @param {ol.geom.MultiPolygon} geometry MultiPolygon geometry.
- * @private
-ol.format.GML3.prototype.writeMultiSurfaceOrPolygon_ = function(node, geometry, objectStack) {
- var surface = context['surface'];
- if (srsName) {
- var polygons = geometry.getPolygons();
- ol.xml.pushSerializeAndPop({node: node, srsName: srsName, surface: surface},
- ol.format.GML3.SURFACEORPOLYGONMEMBER_SERIALIZERS_,
- this.MULTIGEOMETRY_MEMBER_NODE_FACTORY_, polygons,
- objectStack, undefined, this);
- * @param {ol.geom.MultiPoint} geometry MultiPoint geometry.
- * @private
-ol.format.GML3.prototype.writeMultiPoint_ = function(node, geometry,
- objectStack) {
- if (srsName) {
- var points = geometry.getPoints();
- ol.xml.pushSerializeAndPop({node: node, srsName: srsName},
- ol.format.GML3.POINTMEMBER_SERIALIZERS_,
- ol.xml.makeSimpleNodeFactory('pointMember'), points,
- * @param {ol.geom.MultiLineString} geometry MultiLineString geometry.
- * @private
-ol.format.GML3.prototype.writeMultiCurveOrLineString_ = function(node, geometry, objectStack) {
- var curve = context['curve'];
- if (srsName) {
- var lines = geometry.getLineStrings();
- ol.xml.pushSerializeAndPop({node: node, srsName: srsName, curve: curve},
- ol.format.GML3.LINESTRINGORCURVEMEMBER_SERIALIZERS_,
- this.MULTIGEOMETRY_MEMBER_NODE_FACTORY_, lines,
- * @param {ol.geom.LinearRing} ring LinearRing geometry.
- * @private
-ol.format.GML3.prototype.writeRing_ = function(node, ring, objectStack) {
- var linearRing = ol.xml.createElementNS(node.namespaceURI, 'LinearRing');
- node.appendChild(linearRing);
- this.writeLinearRing_(linearRing, ring, objectStack);
- * @param {ol.geom.Polygon} polygon Polygon geometry.
- * @private
-ol.format.GML3.prototype.writeSurfaceOrPolygonMember_ = function(node, polygon, objectStack) {
- var child = this.GEOMETRY_NODE_FACTORY_(
- polygon, objectStack);
- if (child) {
- node.appendChild(child);
- this.writeSurfaceOrPolygon_(child, polygon, objectStack);
- * @param {ol.geom.Point} point Point geometry.
- * @private
-ol.format.GML3.prototype.writePointMember_ = function(node, point, objectStack) {
- var child = ol.xml.createElementNS(node.namespaceURI, 'Point');
- this.writePoint_(child, point, objectStack);
- * @param {ol.geom.LineString} line LineString geometry.
- * @private
-ol.format.GML3.prototype.writeLineStringOrCurveMember_ = function(node, line, objectStack) {
- var child = this.GEOMETRY_NODE_FACTORY_(line, objectStack);
- if (child) {
- this.writeCurveOrLineString_(child, line, objectStack);
- * @private
-ol.format.GML3.prototype.writeSurfacePatches_ = function(node, polygon, objectStack) {
- var child = ol.xml.createElementNS(node.namespaceURI, 'PolygonPatch');
- * @private
-ol.format.GML3.prototype.writeCurveSegments_ = function(node, line, objectStack) {
- 'LineStringSegment');
- * @param {ol.geom.Geometry|ol.Extent} geometry Geometry.
-ol.format.GML3.prototype.writeGeometryElement = function(node, geometry, objectStack) {
- var context = /** @type {olx.format.WriteOptions} */ (objectStack[objectStack.length - 1]);
- var item = ol.obj.assign({}, context);
- item.node = node;
- var value;
- if (Array.isArray(geometry)) {
- if (context.dataProjection) {
- value = ol.proj.transformExtent(
- geometry, context.featureProjection, context.dataProjection);
- } else {
- value = geometry;
- } else {
- value =
- ol.format.Feature.transformWithOptions(/** @type {ol.geom.Geometry} */ (geometry), true, context);
- (item), ol.format.GML3.GEOMETRY_SERIALIZERS_,
- this.GEOMETRY_NODE_FACTORY_, [value],
-ol.format.GML3.prototype.writeFeatureElement = function(node, feature, objectStack) {
- var fid = feature.getId();
- if (fid) {
- node.setAttribute('fid', fid);
- var context = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var geometryName = feature.getGeometryName();
- if (!context.serializers) {
- context.serializers = {};
- context.serializers[featureNS] = {};
- var properties = feature.getProperties();
- var keys = [], values = [];
- for (var key in properties) {
- var value = properties[key];
- if (value !== null) {
- keys.push(key);
- values.push(value);
- if (key == geometryName || value instanceof ol.geom.Geometry) {
- if (!(key in context.serializers[featureNS])) {
- context.serializers[featureNS][key] = ol.xml.makeChildAppender(
- this.writeGeometryElement, this);
- } else {
- ol.format.XSD.writeStringTextNode);
- item.node = node;
- (item), context.serializers,
- ol.xml.makeSimpleNodeFactory(undefined, featureNS),
- values,
- objectStack, keys);
- * @private
-ol.format.GML3.prototype.writeFeatureMembers_ = function(node, features, objectStack) {
- var serializers = {};
- serializers[featureNS] = {};
- serializers[featureNS][featureType] = ol.xml.makeChildAppender(
- this.writeFeatureElement, this);
- item.node = node;
- (item),
- serializers,
- ol.xml.makeSimpleNodeFactory(featureType, featureNS), features,
- objectStack);
- * @private
-ol.format.GML3.SURFACEORPOLYGONMEMBER_SERIALIZERS_ = {
- 'surfaceMember': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeSurfaceOrPolygonMember_),
- 'polygonMember': ol.xml.makeChildAppender(
- * @private
-ol.format.GML3.POINTMEMBER_SERIALIZERS_ = {
- 'pointMember': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writePointMember_)
- * @private
-ol.format.GML3.LINESTRINGORCURVEMEMBER_SERIALIZERS_ = {
- 'lineStringMember': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeLineStringOrCurveMember_),
- 'curveMember': ol.xml.makeChildAppender(
- * @private
-ol.format.GML3.RING_SERIALIZERS_ = {
- 'exterior': ol.xml.makeChildAppender(ol.format.GML3.prototype.writeRing_),
- 'interior': ol.xml.makeChildAppender(ol.format.GML3.prototype.writeRing_)
- * @private
-ol.format.GML3.GEOMETRY_SERIALIZERS_ = {
- 'Curve': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeCurveOrLineString_),
- 'MultiCurve': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeMultiCurveOrLineString_),
- 'Point': ol.xml.makeChildAppender(ol.format.GML3.prototype.writePoint_),
- 'MultiPoint': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeMultiPoint_),
- 'LineString': ol.xml.makeChildAppender(
- 'MultiLineString': ol.xml.makeChildAppender(
- 'LinearRing': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeLinearRing_),
- 'Polygon': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeSurfaceOrPolygon_),
- 'MultiPolygon': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeMultiSurfaceOrPolygon_),
- 'Surface': ol.xml.makeChildAppender(
- 'MultiSurface': ol.xml.makeChildAppender(
- 'Envelope': ol.xml.makeChildAppender(
- ol.format.GML3.prototype.writeEnvelope)
- * @const
- * @type {Object.<string, string>}
- * @private
-ol.format.GML3.MULTIGEOMETRY_TO_MEMBER_NODENAME_ = {
- 'MultiLineString': 'lineStringMember',
- 'MultiCurve': 'curveMember',
- 'MultiPolygon': 'polygonMember',
- 'MultiSurface': 'surfaceMember'
- * @const
- * @return {Node|undefined} Node.
- * @private
-ol.format.GML3.prototype.MULTIGEOMETRY_MEMBER_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- var parentNode = objectStack[objectStack.length - 1].node;
- return ol.xml.createElementNS('http://www.opengis.net/gml',
- ol.format.GML3.MULTIGEOMETRY_TO_MEMBER_NODENAME_[parentNode.nodeName]);
- * @const
- * @private
-ol.format.GML3.prototype.GEOMETRY_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- var multiSurface = context['multiSurface'];
- var multiCurve = context['multiCurve'];
- var nodeName;
- if (!Array.isArray(value)) {
- nodeName = /** @type {ol.geom.Geometry} */ (value).getType();
- if (nodeName === 'MultiPolygon' && multiSurface === true) {
- nodeName = 'MultiSurface';
- } else if (nodeName === 'Polygon' && surface === true) {
- nodeName = 'Surface';
- } else if (nodeName === 'LineString' && curve === true) {
- nodeName = 'Curve';
- } else if (nodeName === 'MultiLineString' && multiCurve === true) {
- nodeName = 'MultiCurve';
- } else {
- nodeName = 'Envelope';
- nodeName);
- * Encode a geometry in GML 3.1.1 Simple Features.
- * @override
- * @api
-ol.format.GML3.prototype.writeGeometryNode = function(geometry, opt_options) {
- opt_options = this.adaptOptions(opt_options);
- var geom = ol.xml.createElementNS('http://www.opengis.net/gml', 'geom');
- var context = {node: geom, srsName: this.srsName,
- curve: this.curve_, surface: this.surface_,
- multiSurface: this.multiSurface_, multiCurve: this.multiCurve_};
- ol.obj.assign(context, opt_options);
- this.writeGeometryElement(geom, geometry, [context]);
- return geom;
- * Encode an array of features in GML 3.1.1 Simple Features.
- * @function
- * @return {string} Result.
- * @api
-ol.format.GML3.prototype.writeFeatures;
- * Encode an array of features in the GML 3.1.1 format as an XML node.
- * @override
- * @api
-ol.format.GML3.prototype.writeFeaturesNode = function(features, opt_options) {
- var node = ol.xml.createElementNS('http://www.opengis.net/gml',
- 'featureMembers');
- ol.xml.setAttributeNS(node, 'http://www.w3.org/2001/XMLSchema-instance',
- 'xsi:schemaLocation', this.schemaLocation);
- var context = {
- srsName: this.srsName,
- surface: this.surface_,
- multiCurve: this.multiCurve_,
- featureNS: this.featureNS,
- this.writeFeatureMembers_(node, features, [context]);
- return node;
-goog.provide('ol.format.GML');
-goog.require('ol.format.GML3');
- * @classdesc
- * version 3.1.1.
- * @constructor
- * @api
-ol.format.GML = ol.format.GML3;
- * @function
- * @api
-ol.format.GML.prototype.writeFeatures;
- * @function
- * @api
-ol.format.GML.prototype.writeFeaturesNode;
-goog.provide('ol.format.GML2');
- * @classdesc
- * Feature format for reading and writing data in the GML format,
- * version 2.1.2.
- * @constructor
- * @param {olx.format.GMLOptions=} opt_options Optional configuration object.
- * @api
-ol.format.GML2 = function(opt_options) {
- this.FEATURE_COLLECTION_PARSERS[ol.format.GMLBase.GMLNS][
- 'featureMember'] =
- ol.xml.makeArrayPusher(ol.format.GMLBase.prototype.readFeaturesInternal);
- * @inheritDoc
- options.schemaLocation : ol.format.GML2.schemaLocation_;
-ol.inherits(ol.format.GML2, ol.format.GMLBase);
- * @const
- * @type {string}
- * @private
-ol.format.GML2.schemaLocation_ = ol.format.GMLBase.GMLNS +
- ' http://schemas.opengis.net/gml/2.1.2/feature.xsd';
- * @private
-ol.format.GML2.prototype.readFlatCoordinates_ = function(node, objectStack) {
- var context = /** @type {ol.XmlNodeStackItem} */ (objectStack[0]);
- if (proj) {
- var coordsGroups = s.trim().split(/\s+/);
- var x, y, z;
- for (var i = 0, ii = coordsGroups.length; i < ii; i++) {
- var coords = coordsGroups[i].split(/,+/);
- x = parseFloat(coords[0]);
- y = parseFloat(coords[1]);
- z = (coords.length === 3) ? parseFloat(coords[2]) : 0;
- } else {
- * @private
-ol.format.GML2.prototype.readBox_ = function(node, objectStack) {
- this.BOX_PARSERS_, node, objectStack, this);
- flatCoordinates[1][1], flatCoordinates[1][3],
- flatCoordinates[1][4]);
- * @private
-ol.format.GML2.prototype.innerBoundaryIsParser_ = function(node, objectStack) {
- * @private
-ol.format.GML2.prototype.outerBoundaryIsParser_ = function(node, objectStack) {
- * @const
- * @private
-ol.format.GML2.prototype.GEOMETRY_FLAT_COORDINATES_PARSERS_ = {
- 'coordinates': ol.xml.makeReplacer(
- ol.format.GML2.prototype.readFlatCoordinates_)
- * @const
- * @private
-ol.format.GML2.prototype.FLAT_LINEAR_RINGS_PARSERS_ = {
- 'innerBoundaryIs': ol.format.GML2.prototype.innerBoundaryIsParser_,
- 'outerBoundaryIs': ol.format.GML2.prototype.outerBoundaryIsParser_
- * @const
- * @private
-ol.format.GML2.prototype.BOX_PARSERS_ = {
- 'coordinates': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.GML2.prototype.GEOMETRY_PARSERS_ = {
- 'Box': ol.xml.makeReplacer(ol.format.GML2.prototype.readBox_)
- * @const
- * @private
-ol.format.GML2.prototype.GEOMETRY_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- var nodeName;
- } else {
- nodeName);
-ol.format.GML2.prototype.writeFeatureElement = function(node, feature, objectStack) {
- if (fid) {
- keys.push(key);
- } else {
- item.node = node;
- values,
-ol.format.GML2.prototype.writeGeometryElement = function(node, geometry, objectStack) {
- item.node = node;
- var value;
- } else {
- value = geometry;
- } else {
- value =
- (item), ol.format.GML2.GEOMETRY_SERIALIZERS_,
- * @private
-ol.format.GML2.prototype.writeCurveOrLineString_ = function(node, geometry, objectStack) {
- var coordinates = this.createCoordinatesNode_(node.namespaceURI);
- node.appendChild(coordinates);
- this.writeCoordinates_(coordinates, geometry, objectStack);
- * @param {string} namespaceURI XML namespace.
- * @returns {Node} coordinates node.
- * @private
-ol.format.GML2.prototype.createCoordinatesNode_ = function(namespaceURI) {
- var coordinates = ol.xml.createElementNS(namespaceURI, 'coordinates');
- coordinates.setAttribute('decimal', '.');
- coordinates.setAttribute('cs', ',');
- coordinates.setAttribute('ts', ' ');
- return coordinates;
- * @private
-ol.format.GML2.prototype.writeCoordinates_ = function(node, value, objectStack) {
- var point;
- * @private
-ol.format.GML2.prototype.writeCurveSegments_ = function(node, line, objectStack) {
- * @private
-ol.format.GML2.prototype.writeSurfaceOrPolygon_ = function(node, geometry, objectStack) {
- ol.format.GML2.RING_SERIALIZERS_,
- * @private
-ol.format.GML2.prototype.RING_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- exteriorWritten !== undefined ? 'innerBoundaryIs' : 'outerBoundaryIs');
- * @private
-ol.format.GML2.prototype.writeSurfacePatches_ = function(node, polygon, objectStack) {
- * @private
-ol.format.GML2.prototype.writeRing_ = function(node, ring, objectStack) {
- * @private
-ol.format.GML2.prototype.getCoords_ = function(point, opt_srsName) {
- point[0] + ',' + point[1] :
- point[1] + ',' + point[0]);
- * @private
-ol.format.GML2.prototype.writeMultiCurveOrLineString_ = function(node, geometry, objectStack) {
- if (srsName) {
- ol.format.GML2.LINESTRINGORCURVEMEMBER_SERIALIZERS_,
- * @private
-ol.format.GML2.prototype.writePoint_ = function(node, geometry, objectStack) {
- if (srsName) {
- var point = geometry.getCoordinates();
- var coord = this.getCoords_(point, srsName);
- ol.format.XSD.writeStringTextNode(coordinates, coord);
- * @private
-ol.format.GML2.prototype.writeMultiPoint_ = function(node, geometry,
- objectStack) {
- if (srsName) {
- ol.format.GML2.POINTMEMBER_SERIALIZERS_,
- * @private
-ol.format.GML2.prototype.writePointMember_ = function(node, point, objectStack) {
- * @private
-ol.format.GML2.prototype.writeLineStringOrCurveMember_ = function(node, line, objectStack) {
- if (child) {
- * @private
-ol.format.GML2.prototype.writeLinearRing_ = function(node, geometry, objectStack) {
- if (srsName) {
- * @private
-ol.format.GML2.prototype.writeMultiSurfaceOrPolygon_ = function(node, geometry, objectStack) {
- if (srsName) {
- ol.format.GML2.SURFACEORPOLYGONMEMBER_SERIALIZERS_,
- * @private
-ol.format.GML2.prototype.writeSurfaceOrPolygonMember_ = function(node, polygon, objectStack) {
- if (child) {
- * @private
-ol.format.GML2.prototype.writeEnvelope = function(node, extent, objectStack) {
- if (srsName) {
- ({node: node}), ol.format.GML2.ENVELOPE_SERIALIZERS_,
- values,
- * @const
- * @private
-ol.format.GML2.GEOMETRY_SERIALIZERS_ = {
- ol.format.GML2.prototype.writeCurveOrLineString_),
- ol.format.GML2.prototype.writeMultiCurveOrLineString_),
- 'Point': ol.xml.makeChildAppender(ol.format.GML2.prototype.writePoint_),
- ol.format.GML2.prototype.writeMultiPoint_),
- ol.format.GML2.prototype.writeLinearRing_),
- ol.format.GML2.prototype.writeSurfaceOrPolygon_),
- ol.format.GML2.prototype.writeMultiSurfaceOrPolygon_),
- ol.format.GML2.prototype.writeEnvelope)
- * @private
-ol.format.GML2.RING_SERIALIZERS_ = {
- 'outerBoundaryIs': ol.xml.makeChildAppender(ol.format.GML2.prototype.writeRing_),
- 'innerBoundaryIs': ol.xml.makeChildAppender(ol.format.GML2.prototype.writeRing_)
- * @private
-ol.format.GML2.POINTMEMBER_SERIALIZERS_ = {
- ol.format.GML2.prototype.writePointMember_)
- * @private
-ol.format.GML2.LINESTRINGORCURVEMEMBER_SERIALIZERS_ = {
- ol.format.GML2.prototype.writeLineStringOrCurveMember_),
- * @const
- * @private
-ol.format.GML2.prototype.MULTIGEOMETRY_MEMBER_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- ol.format.GML2.MULTIGEOMETRY_TO_MEMBER_NODENAME_[parentNode.nodeName]);
- * @const
- * @private
-ol.format.GML2.MULTIGEOMETRY_TO_MEMBER_NODENAME_ = {
- * @const
- * @private
-ol.format.GML2.SURFACEORPOLYGONMEMBER_SERIALIZERS_ = {
- ol.format.GML2.prototype.writeSurfaceOrPolygonMember_),
- * @private
-ol.format.GML2.ENVELOPE_SERIALIZERS_ = {
-goog.provide('ol.format.GPX');
-goog.require('ol.Feature');
-goog.require('ol.format.Feature');
-goog.require('ol.proj');
- * @classdesc
- * Feature format for reading and writing data in the GPX format.
- * @constructor
- * @param {olx.format.GPXOptions=} opt_options Options.
- * @api
-ol.format.GPX = function(opt_options) {
- var options = opt_options ? opt_options : {};
- * @inheritDoc
- this.defaultDataProjection = ol.proj.get('EPSG:4326');
- * @type {function(ol.Feature, Node)|undefined}
- * @private
- this.readExtensions_ = options.readExtensions;
-ol.inherits(ol.format.GPX, ol.format.XMLFeature);
- * @const
- * @private
- * @type {Array.<string>}
-ol.format.GPX.NAMESPACE_URIS_ = [
- null,
- 'http://www.topografix.com/GPX/1/0',
- 'http://www.topografix.com/GPX/1/1'
- * @const
- * @type {string}
- * @private
-ol.format.GPX.SCHEMA_LOCATION_ = 'http://www.topografix.com/GPX/1/1 ' +
- 'http://www.topografix.com/GPX/1/1/gpx.xsd';
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {ol.LayoutOptions} layoutOptions Layout options.
- * @param {Object} values Values.
- * @private
-ol.format.GPX.appendCoordinate_ = function(flatCoordinates, layoutOptions, node, values) {
- parseFloat(node.getAttribute('lon')),
- parseFloat(node.getAttribute('lat')));
- if ('ele' in values) {
- flatCoordinates.push(/** @type {number} */ (values['ele']));
- delete values['ele'];
- layoutOptions.hasZ = true;
- } else {
- if ('time' in values) {
- flatCoordinates.push(/** @type {number} */ (values['time']));
- delete values['time'];
- layoutOptions.hasM = true;
- } else {
- * Choose GeometryLayout based on flags in layoutOptions and adjust flatCoordinates
- * and ends arrays by shrinking them accordingly (removing unused zero entries).
- * @param {Array.<number>=} ends Ends.
- * @return {ol.geom.GeometryLayout} Layout.
-ol.format.GPX.applyLayoutOptions_ = function(layoutOptions, flatCoordinates, ends) {
- var layout = ol.geom.GeometryLayout.XY;
- var stride = 2;
- if (layoutOptions.hasZ && layoutOptions.hasM) {
- layout = ol.geom.GeometryLayout.XYZM;
- stride = 4;
- } else if (layoutOptions.hasZ) {
- layout = ol.geom.GeometryLayout.XYZ;
- stride = 3;
- } else if (layoutOptions.hasM) {
- layout = ol.geom.GeometryLayout.XYM;
- stride = 3;
- if (stride !== 4) {
- var i, ii;
- for (i = 0, ii = flatCoordinates.length / 4; i < ii; i++) {
- flatCoordinates[i * stride] = flatCoordinates[i * 4];
- flatCoordinates[i * stride + 1] = flatCoordinates[i * 4 + 1];
- if (layoutOptions.hasZ) {
- flatCoordinates[i * stride + 2] = flatCoordinates[i * 4 + 2];
- if (layoutOptions.hasM) {
- flatCoordinates[i * stride + 2] = flatCoordinates[i * 4 + 3];
- flatCoordinates.length = flatCoordinates.length / 4 * stride;
- if (ends) {
- for (i = 0, ii = ends.length; i < ii; i++) {
- ends[i] = ends[i] / 4 * stride;
- return layout;
- * @private
-ol.format.GPX.parseLink_ = function(node, objectStack) {
- var values = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var href = node.getAttribute('href');
- if (href !== null) {
- values['link'] = href;
- ol.xml.parseNode(ol.format.GPX.LINK_PARSERS_, node, objectStack);
- * @private
-ol.format.GPX.parseExtensions_ = function(node, objectStack) {
- values['extensionsNode_'] = node;
- * @private
-ol.format.GPX.parseRtePt_ = function(node, objectStack) {
- var values = ol.xml.pushParseAndPop(
- {}, ol.format.GPX.RTEPT_PARSERS_, node, objectStack);
- if (values) {
- var rteValues = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var flatCoordinates = /** @type {Array.<number>} */
- (rteValues['flatCoordinates']);
- var layoutOptions = /** @type {ol.LayoutOptions} */
- (rteValues['layoutOptions']);
- ol.format.GPX.appendCoordinate_(flatCoordinates, layoutOptions, node, values);
- * @private
-ol.format.GPX.parseTrkPt_ = function(node, objectStack) {
- {}, ol.format.GPX.TRKPT_PARSERS_, node, objectStack);
- if (values) {
- var trkValues = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- (trkValues['flatCoordinates']);
- (trkValues['layoutOptions']);
- * @private
-ol.format.GPX.parseTrkSeg_ = function(node, objectStack) {
- ol.xml.parseNode(ol.format.GPX.TRKSEG_PARSERS_, node, objectStack);
- (values['flatCoordinates']);
- var ends = /** @type {Array.<number>} */ (values['ends']);
- * @private
- * @return {ol.Feature|undefined} Track.
-ol.format.GPX.readRte_ = function(node, objectStack) {
- var options = /** @type {olx.format.ReadOptions} */ (objectStack[0]);
- var values = ol.xml.pushParseAndPop({
- 'flatCoordinates': [],
- 'layoutOptions': {}
- }, ol.format.GPX.RTE_PARSERS_, node, objectStack);
- if (!values) {
- return undefined;
- delete values['flatCoordinates'];
- var layoutOptions = /** @type {ol.LayoutOptions} */ (values['layoutOptions']);
- delete values['layoutOptions'];
- var layout = ol.format.GPX.applyLayoutOptions_(layoutOptions, flatCoordinates);
- var geometry = new ol.geom.LineString(null);
- geometry.setFlatCoordinates(layout, flatCoordinates);
- ol.format.Feature.transformWithOptions(geometry, false, options);
- var feature = new ol.Feature(geometry);
- feature.setProperties(values);
- return feature;
- * @private
-ol.format.GPX.readTrk_ = function(node, objectStack) {
- 'ends': [],
- }, ol.format.GPX.TRK_PARSERS_, node, objectStack);
- if (!values) {
- return undefined;
- delete values['ends'];
- var layout = ol.format.GPX.applyLayoutOptions_(layoutOptions, flatCoordinates, ends);
- var geometry = new ol.geom.MultiLineString(null);
- geometry.setFlatCoordinates(layout, flatCoordinates, ends);
- return feature;
- * @private
- * @return {ol.Feature|undefined} Waypoint.
-ol.format.GPX.readWpt_ = function(node, objectStack) {
- {}, ol.format.GPX.WPT_PARSERS_, node, objectStack);
- if (!values) {
- return undefined;
- var layoutOptions = /** @type {ol.LayoutOptions} */ ({});
- var coordinates = ol.format.GPX.appendCoordinate_([], layoutOptions, node, values);
- var layout = ol.format.GPX.applyLayoutOptions_(layoutOptions, coordinates);
- var geometry = new ol.geom.Point(coordinates, layout);
- return feature;
- * @const
- * @type {Object.<string, function(Node, Array.<*>): (ol.Feature|undefined)>}
- * @private
-ol.format.GPX.FEATURE_READER_ = {
- 'rte': ol.format.GPX.readRte_,
- 'trk': ol.format.GPX.readTrk_,
- 'wpt': ol.format.GPX.readWpt_
- * @const
- * @private
-ol.format.GPX.GPX_PARSERS_ = ol.xml.makeStructureNS(
- ol.format.GPX.NAMESPACE_URIS_, {
- 'rte': ol.xml.makeArrayPusher(ol.format.GPX.readRte_),
- 'trk': ol.xml.makeArrayPusher(ol.format.GPX.readTrk_),
- 'wpt': ol.xml.makeArrayPusher(ol.format.GPX.readWpt_)
- * @const
- * @private
-ol.format.GPX.LINK_PARSERS_ = ol.xml.makeStructureNS(
- 'text':
- ol.xml.makeObjectPropertySetter(ol.format.XSD.readString, 'linkText'),
- 'type':
- ol.xml.makeObjectPropertySetter(ol.format.XSD.readString, 'linkType')
- * @const
- * @private
-ol.format.GPX.RTE_PARSERS_ = ol.xml.makeStructureNS(
- 'name': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'cmt': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'desc': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'src': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'link': ol.format.GPX.parseLink_,
- 'number':
- ol.xml.makeObjectPropertySetter(ol.format.XSD.readNonNegativeInteger),
- 'extensions': ol.format.GPX.parseExtensions_,
- 'type': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'rtept': ol.format.GPX.parseRtePt_
- * @const
- * @private
-ol.format.GPX.RTEPT_PARSERS_ = ol.xml.makeStructureNS(
- 'ele': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'time': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDateTime)
- * @const
- * @private
-ol.format.GPX.TRK_PARSERS_ = ol.xml.makeStructureNS(
- 'number':
- 'trkseg': ol.format.GPX.parseTrkSeg_
- * @const
- * @private
-ol.format.GPX.TRKSEG_PARSERS_ = ol.xml.makeStructureNS(
- 'trkpt': ol.format.GPX.parseTrkPt_
- * @const
- * @private
-ol.format.GPX.TRKPT_PARSERS_ = ol.xml.makeStructureNS(
- * @const
- * @private
-ol.format.GPX.WPT_PARSERS_ = ol.xml.makeStructureNS(
- 'time': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDateTime),
- 'magvar': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'geoidheight': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'sym': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'fix': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'sat': ol.xml.makeObjectPropertySetter(
- ol.format.XSD.readNonNegativeInteger),
- 'hdop': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'vdop': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'pdop': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'ageofdgpsdata':
- ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'dgpsid':
- * @param {Array.<ol.Feature>} features List of features.
- * @private
-ol.format.GPX.prototype.handleReadExtensions_ = function(features) {
- if (!features) {
- features = [];
- for (var i = 0, ii = features.length; i < ii; ++i) {
- var feature = features[i];
- if (this.readExtensions_) {
- var extensionsNode = feature.get('extensionsNode_') || null;
- this.readExtensions_(feature, extensionsNode);
- feature.set('extensionsNode_', undefined);
- * Read the first feature from a GPX source.
- * Routes (`<rte>`) are converted into LineString geometries, and tracks (`<trk>`)
- * into MultiLineString. Any properties on route and track waypoints are ignored.
- * @function
- * @param {Document|Node|Object|string} source Source.
- * @param {olx.format.ReadOptions=} opt_options Read options.
- * @return {ol.Feature} Feature.
- * @api
-ol.format.GPX.prototype.readFeature;
- * @inheritDoc
-ol.format.GPX.prototype.readFeatureFromNode = function(node, opt_options) {
- if (!ol.array.includes(ol.format.GPX.NAMESPACE_URIS_, node.namespaceURI)) {
- return null;
- var featureReader = ol.format.GPX.FEATURE_READER_[node.localName];
- if (!featureReader) {
- return null;
- var feature = featureReader(node, [this.getReadOptions(node, opt_options)]);
- if (!feature) {
- return null;
- this.handleReadExtensions_([feature]);
- return feature;
- * Read all features from a GPX source.
- * @function
- * @return {Array.<ol.Feature>} Features.
- * @api
-ol.format.GPX.prototype.readFeatures;
- * @inheritDoc
-ol.format.GPX.prototype.readFeaturesFromNode = function(node, opt_options) {
- return [];
- if (node.localName == 'gpx') {
- /** @type {Array.<ol.Feature>} */
- var features = ol.xml.pushParseAndPop([], ol.format.GPX.GPX_PARSERS_,
- node, [this.getReadOptions(node, opt_options)]);
- if (features) {
- this.handleReadExtensions_(features);
- return features;
- } else {
- return [];
- return [];
- * Read the projection from a GPX source.
- * @function
- * @return {ol.proj.Projection} Projection.
- * @api
-ol.format.GPX.prototype.readProjection;
- * @param {string} value Value for the link's `href` attribute.
- * @private
-ol.format.GPX.writeLink_ = function(node, value, objectStack) {
- node.setAttribute('href', value);
- var properties = context['properties'];
- var link = [
- properties['linkText'],
- properties['linkType']
- ol.xml.pushSerializeAndPop(/** @type {ol.XmlNodeStackItem} */ ({node: node}),
- ol.format.GPX.LINK_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
- link, objectStack, ol.format.GPX.LINK_SEQUENCE_);
- * @param {ol.Coordinate} coordinate Coordinate.
- * @private
-ol.format.GPX.writeWptType_ = function(node, coordinate, objectStack) {
- var namespaceURI = parentNode.namespaceURI;
- //FIXME Projection handling
- ol.xml.setAttributeNS(node, null, 'lat', coordinate[1]);
- ol.xml.setAttributeNS(node, null, 'lon', coordinate[0]);
- var geometryLayout = context['geometryLayout'];
- switch (geometryLayout) {
- case ol.geom.GeometryLayout.XYZM:
- if (coordinate[3] !== 0) {
- properties['time'] = coordinate[3];
- // fall through
- case ol.geom.GeometryLayout.XYZ:
- if (coordinate[2] !== 0) {
- properties['ele'] = coordinate[2];
- break;
- case ol.geom.GeometryLayout.XYM:
- properties['time'] = coordinate[2];
- break;
- default:
- // pass
- var orderedKeys = (node.nodeName == 'rtept') ?
- ol.format.GPX.RTEPT_TYPE_SEQUENCE_[namespaceURI] :
- ol.format.GPX.WPT_TYPE_SEQUENCE_[namespaceURI];
- var values = ol.xml.makeSequence(properties, orderedKeys);
- ({node: node, 'properties': properties}),
- ol.format.GPX.WPT_TYPE_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
- values, objectStack, orderedKeys);
- * @param {Node} node Node.
- * @param {ol.Feature} feature Feature.
- * @private
-ol.format.GPX.writeRte_ = function(node, feature, objectStack) {
- var options = /** @type {olx.format.WriteOptions} */ (objectStack[0]);
- var context = {node: node, 'properties': properties};
- var geometry = feature.getGeometry();
- if (geometry) {
- geometry = /** @type {ol.geom.LineString} */
- (ol.format.Feature.transformWithOptions(geometry, true, options));
- context['geometryLayout'] = geometry.getLayout();
- properties['rtept'] = geometry.getCoordinates();
- var orderedKeys = ol.format.GPX.RTE_SEQUENCE_[parentNode.namespaceURI];
- ol.xml.pushSerializeAndPop(context,
- ol.format.GPX.RTE_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
- * @private
-ol.format.GPX.writeTrk_ = function(node, feature, objectStack) {
- /** @type {ol.XmlNodeStackItem} */
- if (geometry) {
- geometry = /** @type {ol.geom.MultiLineString} */
- properties['trkseg'] = geometry.getLineStrings();
- var orderedKeys = ol.format.GPX.TRK_SEQUENCE_[parentNode.namespaceURI];
- ol.format.GPX.TRK_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
- * @param {ol.geom.LineString} lineString LineString.
- * @private
-ol.format.GPX.writeTrkSeg_ = function(node, lineString, objectStack) {
- var context = {node: node, 'geometryLayout': lineString.getLayout(),
- 'properties': {}};
- ol.format.GPX.TRKSEG_SERIALIZERS_, ol.format.GPX.TRKSEG_NODE_FACTORY_,
- lineString.getCoordinates(), objectStack);
- * @private
-ol.format.GPX.writeWpt_ = function(node, feature, objectStack) {
- context['properties'] = feature.getProperties();
- if (geometry) {
- geometry = /** @type {ol.geom.Point} */
- ol.format.GPX.writeWptType_(node, geometry.getCoordinates(), objectStack);
- * @const
- * @private
-ol.format.GPX.LINK_SEQUENCE_ = ['text', 'type'];
- * @private
-ol.format.GPX.LINK_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'text': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'type': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
- * @const
- * @type {Object.<string, Array.<string>>}
- * @private
-ol.format.GPX.RTE_SEQUENCE_ = ol.xml.makeStructureNS(
- ol.format.GPX.NAMESPACE_URIS_, [
- 'name', 'cmt', 'desc', 'src', 'link', 'number', 'type', 'rtept'
- * @const
- * @private
-ol.format.GPX.RTE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'name': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'cmt': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'desc': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'src': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'link': ol.xml.makeChildAppender(ol.format.GPX.writeLink_),
- 'number': ol.xml.makeChildAppender(
- ol.format.XSD.writeNonNegativeIntegerTextNode),
- 'type': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'rtept': ol.xml.makeArraySerializer(ol.xml.makeChildAppender(
- ol.format.GPX.writeWptType_))
- * @const
- * @private
-ol.format.GPX.RTEPT_TYPE_SEQUENCE_ = ol.xml.makeStructureNS(
- 'ele', 'time'
- * @const
- * @private
-ol.format.GPX.TRK_SEQUENCE_ = ol.xml.makeStructureNS(
- 'name', 'cmt', 'desc', 'src', 'link', 'number', 'type', 'trkseg'
- * @const
- * @private
-ol.format.GPX.TRK_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'trkseg': ol.xml.makeArraySerializer(ol.xml.makeChildAppender(
- ol.format.GPX.writeTrkSeg_))
- * @const
- * @type {function(*, Array.<*>, string=): (Node|undefined)}
- * @private
-ol.format.GPX.TRKSEG_NODE_FACTORY_ = ol.xml.makeSimpleNodeFactory('trkpt');
- * @const
- * @private
-ol.format.GPX.TRKSEG_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'trkpt': ol.xml.makeChildAppender(ol.format.GPX.writeWptType_)
- * @const
- * @private
-ol.format.GPX.WPT_TYPE_SEQUENCE_ = ol.xml.makeStructureNS(
- 'ele', 'time', 'magvar', 'geoidheight', 'name', 'cmt', 'desc', 'src',
- 'link', 'sym', 'type', 'fix', 'sat', 'hdop', 'vdop', 'pdop',
- 'ageofdgpsdata', 'dgpsid'
- * @private
-ol.format.GPX.WPT_TYPE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'ele': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'time': ol.xml.makeChildAppender(ol.format.XSD.writeDateTimeTextNode),
- 'magvar': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'geoidheight': ol.xml.makeChildAppender(
- ol.format.XSD.writeDecimalTextNode),
- 'sym': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'fix': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'sat': ol.xml.makeChildAppender(
- 'hdop': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'vdop': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'pdop': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'ageofdgpsdata': ol.xml.makeChildAppender(
- 'dgpsid': ol.xml.makeChildAppender(
- * @const
- * @private
-ol.format.GPX.GEOMETRY_TYPE_TO_NODENAME_ = {
- 'Point': 'wpt',
- 'LineString': 'rte',
- 'MultiLineString': 'trk'
- * @const
- * @param {Array.<*>} objectStack Object stack.
- * @private
-ol.format.GPX.GPX_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- var geometry = /** @type {ol.Feature} */ (value).getGeometry();
- if (geometry) {
- var nodeName = ol.format.GPX.GEOMETRY_TYPE_TO_NODENAME_[geometry.getType()];
- if (nodeName) {
- return ol.xml.createElementNS(parentNode.namespaceURI, nodeName);
- * @const
- * @private
-ol.format.GPX.GPX_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'rte': ol.xml.makeChildAppender(ol.format.GPX.writeRte_),
- 'trk': ol.xml.makeChildAppender(ol.format.GPX.writeTrk_),
- 'wpt': ol.xml.makeChildAppender(ol.format.GPX.writeWpt_)
- * Encode an array of features in the GPX format.
- * LineString geometries are output as routes (`<rte>`), and MultiLineString
- * as tracks (`<trk>`).
- * @function
- * @param {Array.<ol.Feature>} features Features.
- * @param {olx.format.WriteOptions=} opt_options Write options.
- * @api
-ol.format.GPX.prototype.writeFeatures;
- * Encode an array of features in the GPX format as an XML node.
- * @param {olx.format.WriteOptions=} opt_options Options.
- * @return {Node} Node.
- * @override
- * @api
-ol.format.GPX.prototype.writeFeaturesNode = function(features, opt_options) {
- //FIXME Serialize metadata
- var gpx = ol.xml.createElementNS('http://www.topografix.com/GPX/1/1', 'gpx');
- var xmlnsUri = 'http://www.w3.org/2000/xmlns/';
- var xmlSchemaInstanceUri = 'http://www.w3.org/2001/XMLSchema-instance';
- ol.xml.setAttributeNS(gpx, xmlnsUri, 'xmlns:xsi', xmlSchemaInstanceUri);
- ol.xml.setAttributeNS(gpx, xmlSchemaInstanceUri, 'xsi:schemaLocation',
- ol.format.GPX.SCHEMA_LOCATION_);
- gpx.setAttribute('version', '1.1');
- gpx.setAttribute('creator', 'OpenLayers');
- ({node: gpx}), ol.format.GPX.GPX_SERIALIZERS_,
- ol.format.GPX.GPX_NODE_FACTORY_, features, [opt_options]);
- return gpx;
-goog.provide('ol.format.IGCZ');
- * IGC altitude/z. One of 'barometric', 'gps', 'none'.
- * @enum {string}
-ol.format.IGCZ = {
- BAROMETRIC: 'barometric',
- GPS: 'gps',
- NONE: 'none'
-goog.provide('ol.format.TextFeature');
-goog.require('ol');
-goog.require('ol.format.FormatType');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * Base class for text feature formats.
- * @constructor
- * @abstract
- * @extends {ol.format.Feature}
-ol.format.TextFeature = function() {
- ol.format.Feature.call(this);
-ol.inherits(ol.format.TextFeature, ol.format.Feature);
- * @private
- * @return {string} Text.
-ol.format.TextFeature.prototype.getText_ = function(source) {
- if (typeof source === 'string') {
- return source;
- } else {
- return '';
- * @inheritDoc
-ol.format.TextFeature.prototype.getType = function() {
- return ol.format.FormatType.TEXT;
- * @inheritDoc
-ol.format.TextFeature.prototype.readFeature = function(source, opt_options) {
- return this.readFeatureFromText(
- this.getText_(source), this.adaptOptions(opt_options));
- * @abstract
- * @param {string} text Text.
- * @protected
-ol.format.TextFeature.prototype.readFeatureFromText = function(text, opt_options) {};
- * @inheritDoc
-ol.format.TextFeature.prototype.readFeatures = function(source, opt_options) {
- return this.readFeaturesFromText(
- * @abstract
- * @protected
-ol.format.TextFeature.prototype.readFeaturesFromText = function(text, opt_options) {};
- * @inheritDoc
-ol.format.TextFeature.prototype.readGeometry = function(source, opt_options) {
- return this.readGeometryFromText(
- * @abstract
- * @protected
- * @return {ol.geom.Geometry} Geometry.
-ol.format.TextFeature.prototype.readGeometryFromText = function(text, opt_options) {};
- * @inheritDoc
-ol.format.TextFeature.prototype.readProjection = function(source) {
- return this.readProjectionFromText(this.getText_(source));
- * @protected
-ol.format.TextFeature.prototype.readProjectionFromText = function(text) {
- return this.defaultDataProjection;
- * @inheritDoc
-ol.format.TextFeature.prototype.writeFeature = function(feature, opt_options) {
- return this.writeFeatureText(feature, this.adaptOptions(opt_options));
- * @abstract
- * @param {ol.Feature} feature Features.
- * @protected
-ol.format.TextFeature.prototype.writeFeatureText = function(feature, opt_options) {};
- * @inheritDoc
-ol.format.TextFeature.prototype.writeFeatures = function(
- features, opt_options) {
- return this.writeFeaturesText(features, this.adaptOptions(opt_options));
- * @abstract
- * @protected
-ol.format.TextFeature.prototype.writeFeaturesText = function(features, opt_options) {};
- * @inheritDoc
-ol.format.TextFeature.prototype.writeGeometry = function(
- geometry, opt_options) {
- return this.writeGeometryText(geometry, this.adaptOptions(opt_options));
- * @abstract
- * @param {ol.geom.Geometry} geometry Geometry.
- * @protected
-ol.format.TextFeature.prototype.writeGeometryText = function(geometry, opt_options) {};
-goog.provide('ol.format.IGC');
-goog.require('ol.format.IGCZ');
-goog.require('ol.format.TextFeature');
-goog.require('ol.geom.GeometryLayout');
-goog.require('ol.geom.LineString');
- * @classdesc
- * Feature format for `*.igc` flight recording files.
- * @constructor
- * @extends {ol.format.TextFeature}
- * @param {olx.format.IGCOptions=} opt_options Options.
- * @api
-ol.format.IGC = function(opt_options) {
- ol.format.TextFeature.call(this);
- * @inheritDoc
- * @private
- * @type {ol.format.IGCZ}
- this.altitudeMode_ = options.altitudeMode ?
- options.altitudeMode : ol.format.IGCZ.NONE;
-ol.inherits(ol.format.IGC, ol.format.TextFeature);
- * @const
- * @type {RegExp}
- * @private
-ol.format.IGC.B_RECORD_RE_ =
- /^B(\d{2})(\d{2})(\d{2})(\d{2})(\d{5})([NS])(\d{3})(\d{5})([EW])([AV])(\d{5})(\d{5})/;
- * @const
- * @type {RegExp}
- * @private
-ol.format.IGC.H_RECORD_RE_ = /^H.([A-Z]{3}).*?:(.*)/;
- * @const
- * @type {RegExp}
- * @private
-ol.format.IGC.HFDTE_RECORD_RE_ = /^HFDTE(\d{2})(\d{2})(\d{2})/;
- * A regular expression matching the newline characters `\r\n`, `\r` and `\n`.
- * @const
- * @type {RegExp}
- * @private
-ol.format.IGC.NEWLINE_RE_ = /\r\n|\r|\n/;
- * Read the feature from the IGC source.
- * @function
- * @api
-ol.format.IGC.prototype.readFeature;
- * @inheritDoc
-ol.format.IGC.prototype.readFeatureFromText = function(text, opt_options) {
- var altitudeMode = this.altitudeMode_;
- var lines = text.split(ol.format.IGC.NEWLINE_RE_);
- /** @type {Object.<string, string>} */
- var properties = {};
- var year = 2000;
- var month = 0;
- var day = 1;
- var lastDateTime = -1;
- var i, ii;
- for (i = 0, ii = lines.length; i < ii; ++i) {
- var line = lines[i];
- var m;
- if (line.charAt(0) == 'B') {
- m = ol.format.IGC.B_RECORD_RE_.exec(line);
- if (m) {
- var hour = parseInt(m[1], 10);
- var minute = parseInt(m[2], 10);
- var second = parseInt(m[3], 10);
- var y = parseInt(m[4], 10) + parseInt(m[5], 10) / 60000;
- if (m[6] == 'S') {
- y = -y;
- var x = parseInt(m[7], 10) + parseInt(m[8], 10) / 60000;
- if (m[9] == 'W') {
- x = -x;
- flatCoordinates.push(x, y);
- if (altitudeMode != ol.format.IGCZ.NONE) {
- var z;
- if (altitudeMode == ol.format.IGCZ.GPS) {
- z = parseInt(m[11], 10);
- } else if (altitudeMode == ol.format.IGCZ.BAROMETRIC) {
- z = parseInt(m[12], 10);
- } else {
- z = 0;
- flatCoordinates.push(z);
- var dateTime = Date.UTC(year, month, day, hour, minute, second);
- // Detect UTC midnight wrap around.
- if (dateTime < lastDateTime) {
- dateTime = Date.UTC(year, month, day + 1, hour, minute, second);
- flatCoordinates.push(dateTime / 1000);
- lastDateTime = dateTime;
- } else if (line.charAt(0) == 'H') {
- m = ol.format.IGC.HFDTE_RECORD_RE_.exec(line);
- if (m) {
- day = parseInt(m[1], 10);
- month = parseInt(m[2], 10) - 1;
- year = 2000 + parseInt(m[3], 10);
- } else {
- m = ol.format.IGC.H_RECORD_RE_.exec(line);
- if (m) {
- properties[m[1]] = m[2].trim();
- if (flatCoordinates.length === 0) {
- return null;
- var lineString = new ol.geom.LineString(null);
- var layout = altitudeMode == ol.format.IGCZ.NONE ?
- ol.geom.GeometryLayout.XYM : ol.geom.GeometryLayout.XYZM;
- lineString.setFlatCoordinates(layout, flatCoordinates);
- var feature = new ol.Feature(ol.format.Feature.transformWithOptions(
- lineString, false, opt_options));
- feature.setProperties(properties);
- return feature;
- * Read the feature from the source. As IGC sources contain a single
- * feature, this will return the feature in an array.
- * @function
- * @api
-ol.format.IGC.prototype.readFeatures;
- * @inheritDoc
-ol.format.IGC.prototype.readFeaturesFromText = function(text, opt_options) {
- var feature = this.readFeatureFromText(text, opt_options);
- if (feature) {
- return [feature];
- } else {
- return [];
- * Read the projection from the IGC source.
- * @function
- * @api
-ol.format.IGC.prototype.readProjection;
- * Not implemented.
- * @inheritDoc
-ol.format.IGC.prototype.writeFeatureText = function(feature, opt_options) {};
- * @inheritDoc
-ol.format.IGC.prototype.writeFeaturesText = function(features, opt_options) {};
- * @inheritDoc
-ol.format.IGC.prototype.writeGeometryText = function(geometry, opt_options) {};
- * @inheritDoc
-ol.format.IGC.prototype.readGeometryFromText = function(text, opt_options) {};
-goog.provide('ol.style.IconAnchorUnits');
- * Icon anchor units. One of 'fraction', 'pixels'.
- * @enum {string}
-ol.style.IconAnchorUnits = {
- FRACTION: 'fraction',
- PIXELS: 'pixels'
-goog.provide('ol.style.IconImage');
-goog.require('ol.dom');
-goog.require('ol.events');
-goog.require('ol.events.EventTarget');
-goog.require('ol.events.EventType');
-goog.require('ol.ImageState');
-goog.require('ol.style');
- * @constructor
- * @param {Image|HTMLCanvasElement} image Image.
- * @param {string|undefined} src Src.
- * @param {ol.Size} size Size.
- * @param {?string} crossOrigin Cross origin.
- * @param {ol.ImageState} imageState Image state.
- * @param {ol.Color} color Color.
- * @extends {ol.events.EventTarget}
-ol.style.IconImage = function(image, src, size, crossOrigin, imageState,
- color) {
- ol.events.EventTarget.call(this);
- * @private
- * @type {Image|HTMLCanvasElement}
- this.hitDetectionImage_ = null;
- * @private
- this.image_ = !image ? new Image() : image;
- if (crossOrigin !== null) {
- this.image_.crossOrigin = crossOrigin;
- * @private
- * @type {HTMLCanvasElement}
- this.canvas_ = color ?
- /** @type {HTMLCanvasElement} */ (document.createElement('CANVAS')) :
- null;
- * @private
- * @type {ol.Color}
- this.color_ = color;
- * @private
- * @type {Array.<ol.EventsKey>}
- this.imageListenerKeys_ = null;
- * @private
- * @type {ol.ImageState}
- this.imageState_ = imageState;
- * @private
- * @type {ol.Size}
- this.size_ = size;
- * @private
- * @type {string|undefined}
- this.src_ = src;
- * @private
- * @type {boolean}
- this.tainting_ = false;
- if (this.imageState_ == ol.ImageState.LOADED) {
- this.determineTainting_();
-ol.inherits(ol.style.IconImage, ol.events.EventTarget);
- * @param {string} src Src.
- * @return {ol.style.IconImage} Icon image.
-ol.style.IconImage.get = function(image, src, size, crossOrigin, imageState,
- color) {
- var iconImageCache = ol.style.iconImageCache;
- var iconImage = iconImageCache.get(src, crossOrigin, color);
- if (!iconImage) {
- iconImage = new ol.style.IconImage(
- image, src, size, crossOrigin, imageState, color);
- iconImageCache.set(src, crossOrigin, color, iconImage);
- return iconImage;
- * @private
-ol.style.IconImage.prototype.determineTainting_ = function() {
- var context = ol.dom.createCanvasContext2D(1, 1);
- try {
- context.drawImage(this.image_, 0, 0);
- context.getImageData(0, 0, 1, 1);
- } catch (e) {
- this.tainting_ = true;
- * @private
-ol.style.IconImage.prototype.dispatchChangeEvent_ = function() {
- this.dispatchEvent(ol.events.EventType.CHANGE);
- * @private
-ol.style.IconImage.prototype.handleImageError_ = function() {
- this.imageState_ = ol.ImageState.ERROR;
- this.unlistenImage_();
- this.dispatchChangeEvent_();
- * @private
-ol.style.IconImage.prototype.handleImageLoad_ = function() {
- this.imageState_ = ol.ImageState.LOADED;
- if (this.size_) {
- this.image_.width = this.size_[0];
- this.image_.height = this.size_[1];
- this.size_ = [this.image_.width, this.image_.height];
- this.replaceColor_();
- * @param {number} pixelRatio Pixel ratio.
- * @return {Image|HTMLCanvasElement} Image or Canvas element.
-ol.style.IconImage.prototype.getImage = function(pixelRatio) {
- return this.canvas_ ? this.canvas_ : this.image_;
- * @return {ol.ImageState} Image state.
-ol.style.IconImage.prototype.getImageState = function() {
- return this.imageState_;
- * @return {Image|HTMLCanvasElement} Image element.
-ol.style.IconImage.prototype.getHitDetectionImage = function(pixelRatio) {
- if (!this.hitDetectionImage_) {
- if (this.tainting_) {
- var width = this.size_[0];
- var height = this.size_[1];
- var context = ol.dom.createCanvasContext2D(width, height);
- context.fillRect(0, 0, width, height);
- this.hitDetectionImage_ = context.canvas;
- } else {
- this.hitDetectionImage_ = this.image_;
- return this.hitDetectionImage_;
- * @return {ol.Size} Image size.
-ol.style.IconImage.prototype.getSize = function() {
- return this.size_;
- * @return {string|undefined} Image src.
-ol.style.IconImage.prototype.getSrc = function() {
- return this.src_;
- * Load not yet loaded URI.
-ol.style.IconImage.prototype.load = function() {
- if (this.imageState_ == ol.ImageState.IDLE) {
- this.imageState_ = ol.ImageState.LOADING;
- this.imageListenerKeys_ = [
- ol.events.listenOnce(this.image_, ol.events.EventType.ERROR,
- this.handleImageError_, this),
- ol.events.listenOnce(this.image_, ol.events.EventType.LOAD,
- this.handleImageLoad_, this)
- try {
- this.image_.src = this.src_;
- } catch (e) {
- this.handleImageError_();
- * @private
-ol.style.IconImage.prototype.replaceColor_ = function() {
- if (this.tainting_ || this.color_ === null) {
- return;
- this.canvas_.width = this.image_.width;
- this.canvas_.height = this.image_.height;
- var ctx = this.canvas_.getContext('2d');
- ctx.drawImage(this.image_, 0, 0);
- var imgData = ctx.getImageData(0, 0, this.image_.width, this.image_.height);
- var data = imgData.data;
- var r = this.color_[0] / 255.0;
- var g = this.color_[1] / 255.0;
- var b = this.color_[2] / 255.0;
- for (var i = 0, ii = data.length; i < ii; i += 4) {
- data[i] *= r;
- data[i + 1] *= g;
- data[i + 2] *= b;
- ctx.putImageData(imgData, 0, 0);
- * Discards event handlers which listen for load completion or errors.
- * @private
-ol.style.IconImage.prototype.unlistenImage_ = function() {
- this.imageListenerKeys_.forEach(ol.events.unlistenByKey);
-goog.provide('ol.style.IconOrigin');
- * Icon origin. One of 'bottom-left', 'bottom-right', 'top-left', 'top-right'.
- * @enum {string}
-ol.style.IconOrigin = {
- BOTTOM_LEFT: 'bottom-left',
- BOTTOM_RIGHT: 'bottom-right',
- TOP_LEFT: 'top-left',
- TOP_RIGHT: 'top-right'
-goog.provide('ol.style.Icon');
-goog.require('ol.asserts');
-goog.require('ol.color');
-goog.require('ol.style.IconAnchorUnits');
-goog.require('ol.style.IconImage');
-goog.require('ol.style.IconOrigin');
-goog.require('ol.style.Image');
- * @classdesc
- * Set icon style for vector features.
- * @constructor
- * @param {olx.style.IconOptions=} opt_options Options.
- * @extends {ol.style.Image}
- * @api
-ol.style.Icon = function(opt_options) {
- var options = opt_options || {};
- * @private
- * @type {Array.<number>}
- this.anchor_ = options.anchor !== undefined ? options.anchor : [0.5, 0.5];
- * @private
- this.normalizedAnchor_ = null;
- * @private
- * @type {ol.style.IconOrigin}
- this.anchorOrigin_ = options.anchorOrigin !== undefined ?
- options.anchorOrigin : ol.style.IconOrigin.TOP_LEFT;
- * @private
- * @type {ol.style.IconAnchorUnits}
- this.anchorXUnits_ = options.anchorXUnits !== undefined ?
- options.anchorXUnits : ol.style.IconAnchorUnits.FRACTION;
- * @private
- this.anchorYUnits_ = options.anchorYUnits !== undefined ?
- options.anchorYUnits : ol.style.IconAnchorUnits.FRACTION;
- * @private
- * @type {?string}
- this.crossOrigin_ =
- options.crossOrigin !== undefined ? options.crossOrigin : null;
- var image = options.img !== undefined ? options.img : null;
- * @type {ol.Size}
- var imgSize = options.imgSize !== undefined ? options.imgSize : null;
- var src = options.src;
- ol.asserts.assert(!(src !== undefined && image),
- 4); // `image` and `src` cannot be provided at the same time
- ol.asserts.assert(!image || (image && imgSize),
- 5); // `imgSize` must be set when `image` is provided
- if ((src === undefined || src.length === 0) && image) {
- src = image.src || ol.getUid(image).toString();
- ol.asserts.assert(src !== undefined && src.length > 0,
- 6); // A defined and non-empty `src` or `image` must be provided
- var imageState = options.src !== undefined ?
- ol.ImageState.IDLE : ol.ImageState.LOADED;
- * @private
- this.color_ = options.color !== undefined ? ol.color.asArray(options.color) :
- null;
- * @private
- * @type {ol.style.IconImage}
- this.iconImage_ = ol.style.IconImage.get(
- image, /** @type {string} */ (src), imgSize, this.crossOrigin_, imageState, this.color_);
- * @private
- this.offset_ = options.offset !== undefined ? options.offset : [0, 0];
- * @private
- this.offsetOrigin_ = options.offsetOrigin !== undefined ?
- options.offsetOrigin : ol.style.IconOrigin.TOP_LEFT;
- * @private
- this.origin_ = null;
- * @private
- * @type {ol.Size}
- this.size_ = options.size !== undefined ? options.size : null;
- * @type {number}
- var opacity = options.opacity !== undefined ? options.opacity : 1;
- * @type {boolean}
- var rotateWithView = options.rotateWithView !== undefined ?
- options.rotateWithView : false;
- * @type {number}
- var rotation = options.rotation !== undefined ? options.rotation : 0;
- * @type {number}
- var scale = options.scale !== undefined ? options.scale : 1;
- * @type {boolean}
- var snapToPixel = options.snapToPixel !== undefined ?
- options.snapToPixel : true;
- ol.style.Image.call(this, {
- opacity: opacity,
- rotation: rotation,
- scale: scale,
- snapToPixel: snapToPixel,
- rotateWithView: rotateWithView
-ol.inherits(ol.style.Icon, ol.style.Image);
- * Clones the style.
- * @return {ol.style.Icon} The cloned style.
- * @api
-ol.style.Icon.prototype.clone = function() {
- var oldImage = this.getImage(1);
- var newImage;
- if (this.iconImage_.getImageState() === ol.ImageState.LOADED) {
- if (oldImage.tagName.toUpperCase() === 'IMG') {
- newImage = /** @type {Image} */ (oldImage.cloneNode(true));
- } else {
- newImage = /** @type {HTMLCanvasElement} */ (document.createElement('canvas'));
- var context = newImage.getContext('2d');
- newImage.width = oldImage.width;
- newImage.height = oldImage.height;
- context.drawImage(oldImage, 0, 0);
- return new ol.style.Icon({
- anchor: this.anchor_.slice(),
- anchorOrigin: this.anchorOrigin_,
- anchorXUnits: this.anchorXUnits_,
- anchorYUnits: this.anchorYUnits_,
- crossOrigin: this.crossOrigin_,
- color: (this.color_ && this.color_.slice) ? this.color_.slice() : this.color_ || undefined,
- img: newImage ? newImage : undefined,
- imgSize: newImage ? this.iconImage_.getSize().slice() : undefined,
- src: newImage ? undefined : this.getSrc(),
- offset: this.offset_.slice(),
- offsetOrigin: this.offsetOrigin_,
- size: this.size_ !== null ? this.size_.slice() : undefined,
- opacity: this.getOpacity(),
- scale: this.getScale(),
- snapToPixel: this.getSnapToPixel(),
- rotation: this.getRotation(),
- rotateWithView: this.getRotateWithView()
- * @inheritDoc
- * @api
-ol.style.Icon.prototype.getAnchor = function() {
- if (this.normalizedAnchor_) {
- return this.normalizedAnchor_;
- var anchor = this.anchor_;
- var size = this.getSize();
- if (this.anchorXUnits_ == ol.style.IconAnchorUnits.FRACTION ||
- this.anchorYUnits_ == ol.style.IconAnchorUnits.FRACTION) {
- if (!size) {
- return null;
- anchor = this.anchor_.slice();
- if (this.anchorXUnits_ == ol.style.IconAnchorUnits.FRACTION) {
- anchor[0] *= size[0];
- if (this.anchorYUnits_ == ol.style.IconAnchorUnits.FRACTION) {
- anchor[1] *= size[1];
- if (this.anchorOrigin_ != ol.style.IconOrigin.TOP_LEFT) {
- if (!size) {
- return null;
- if (anchor === this.anchor_) {
- if (this.anchorOrigin_ == ol.style.IconOrigin.TOP_RIGHT ||
- this.anchorOrigin_ == ol.style.IconOrigin.BOTTOM_RIGHT) {
- anchor[0] = -anchor[0] + size[0];
- if (this.anchorOrigin_ == ol.style.IconOrigin.BOTTOM_LEFT ||
- anchor[1] = -anchor[1] + size[1];
- this.normalizedAnchor_ = anchor;
- * Get the icon color.
- * @return {ol.Color} Color.
- * @api
-ol.style.Icon.prototype.getColor = function() {
- return this.color_;
- * Get the image icon.
- * @override
- * @api
-ol.style.Icon.prototype.getImage = function(pixelRatio) {
- return this.iconImage_.getImage(pixelRatio);
- * @override
-ol.style.Icon.prototype.getImageSize = function() {
- return this.iconImage_.getSize();
- * @override
-ol.style.Icon.prototype.getHitDetectionImageSize = function() {
- return this.getImageSize();
- * @override
-ol.style.Icon.prototype.getImageState = function() {
- return this.iconImage_.getImageState();
- * @override
-ol.style.Icon.prototype.getHitDetectionImage = function(pixelRatio) {
- return this.iconImage_.getHitDetectionImage(pixelRatio);
- * @inheritDoc
- * @api
-ol.style.Icon.prototype.getOrigin = function() {
- if (this.origin_) {
- return this.origin_;
- var offset = this.offset_;
- if (this.offsetOrigin_ != ol.style.IconOrigin.TOP_LEFT) {
- var iconImageSize = this.iconImage_.getSize();
- if (!size || !iconImageSize) {
- return null;
- offset = offset.slice();
- if (this.offsetOrigin_ == ol.style.IconOrigin.TOP_RIGHT ||
- this.offsetOrigin_ == ol.style.IconOrigin.BOTTOM_RIGHT) {
- offset[0] = iconImageSize[0] - size[0] - offset[0];
- if (this.offsetOrigin_ == ol.style.IconOrigin.BOTTOM_LEFT ||
- offset[1] = iconImageSize[1] - size[1] - offset[1];
- this.origin_ = offset;
- * Get the image URL.
- * @api
-ol.style.Icon.prototype.getSrc = function() {
- return this.iconImage_.getSrc();
- * @inheritDoc
- * @api
-ol.style.Icon.prototype.getSize = function() {
- return !this.size_ ? this.iconImage_.getSize() : this.size_;
- * @override
-ol.style.Icon.prototype.listenImageChange = function(listener, thisArg) {
- return ol.events.listen(this.iconImage_, ol.events.EventType.CHANGE,
- listener, thisArg);
- * When rendering a feature with an icon style, the vector renderer will
- * automatically call this method. However, you might want to call this
- * method yourself for preloading or other purposes.
- * @override
- * @api
-ol.style.Icon.prototype.load = function() {
- this.iconImage_.load();
- * @override
-ol.style.Icon.prototype.unlistenImageChange = function(listener, thisArg) {
- ol.events.unlisten(this.iconImage_, ol.events.EventType.CHANGE,
-goog.provide('ol.style.Text');
-goog.require('ol.style.Fill');
- * @classdesc
- * Set text style for vector features.
- * @constructor
- * @param {olx.style.TextOptions=} opt_options Options.
- * @api
-ol.style.Text = function(opt_options) {
- * @private
- this.font_ = options.font;
- * @private
- * @type {number|undefined}
- this.rotation_ = options.rotation;
- * @private
- * @type {boolean|undefined}
- this.rotateWithView_ = options.rotateWithView;
- * @private
- this.scale_ = options.scale;
- * @private
- this.text_ = options.text;
- * @private
- this.textAlign_ = options.textAlign;
- * @private
- this.textBaseline_ = options.textBaseline;
- * @private
- * @type {ol.style.Fill}
- this.fill_ = options.fill !== undefined ? options.fill :
- new ol.style.Fill({color: ol.style.Text.DEFAULT_FILL_COLOR_});
- * @private
- * @type {ol.style.Stroke}
- this.stroke_ = options.stroke !== undefined ? options.stroke : null;
- * @private
- * @type {number}
- this.offsetX_ = options.offsetX !== undefined ? options.offsetX : 0;
- * @private
- * @type {number}
- this.offsetY_ = options.offsetY !== undefined ? options.offsetY : 0;
- * The default fill color to use if no fill was set at construction time; a
- * blackish `#333`.
- * @const {string}
- * @private
-ol.style.Text.DEFAULT_FILL_COLOR_ = '#333';
- * @return {ol.style.Text} The cloned style.
- * @api
-ol.style.Text.prototype.clone = function() {
- return new ol.style.Text({
- font: this.getFont(),
- rotateWithView: this.getRotateWithView(),
- text: this.getText(),
- textAlign: this.getTextAlign(),
- textBaseline: this.getTextBaseline(),
- fill: this.getFill() ? this.getFill().clone() : undefined,
- stroke: this.getStroke() ? this.getStroke().clone() : undefined,
- offsetX: this.getOffsetX(),
- offsetY: this.getOffsetY()
- * Get the font name.
- * @return {string|undefined} Font.
- * @api
-ol.style.Text.prototype.getFont = function() {
- return this.font_;
- * Get the x-offset for the text.
- * @return {number} Horizontal text offset.
- * @api
-ol.style.Text.prototype.getOffsetX = function() {
- return this.offsetX_;
- * Get the y-offset for the text.
- * @return {number} Vertical text offset.
- * @api
-ol.style.Text.prototype.getOffsetY = function() {
- return this.offsetY_;
- * Get the fill style for the text.
- * @return {ol.style.Fill} Fill style.
- * @api
-ol.style.Text.prototype.getFill = function() {
- return this.fill_;
- * Determine whether the text rotates with the map.
- * @return {boolean|undefined} Rotate with map.
- * @api
-ol.style.Text.prototype.getRotateWithView = function() {
- return this.rotateWithView_;
- * Get the text rotation.
- * @return {number|undefined} Rotation.
- * @api
-ol.style.Text.prototype.getRotation = function() {
- return this.rotation_;
- * Get the text scale.
- * @return {number|undefined} Scale.
- * @api
-ol.style.Text.prototype.getScale = function() {
- return this.scale_;
- * Get the stroke style for the text.
- * @return {ol.style.Stroke} Stroke style.
- * @api
-ol.style.Text.prototype.getStroke = function() {
- return this.stroke_;
- * Get the text to be rendered.
- * @return {string|undefined} Text.
- * @api
-ol.style.Text.prototype.getText = function() {
- return this.text_;
- * Get the text alignment.
- * @return {string|undefined} Text align.
- * @api
-ol.style.Text.prototype.getTextAlign = function() {
- return this.textAlign_;
- * Get the text baseline.
- * @return {string|undefined} Text baseline.
- * @api
-ol.style.Text.prototype.getTextBaseline = function() {
- return this.textBaseline_;
- * Set the font.
- * @param {string|undefined} font Font.
- * @api
-ol.style.Text.prototype.setFont = function(font) {
- this.font_ = font;
- * Set the x offset.
- * @param {number} offsetX Horizontal text offset.
- * @api
-ol.style.Text.prototype.setOffsetX = function(offsetX) {
- this.offsetX_ = offsetX;
- * Set the y offset.
- * @param {number} offsetY Vertical text offset.
- * @api
-ol.style.Text.prototype.setOffsetY = function(offsetY) {
- this.offsetY_ = offsetY;
- * Set the fill.
- * @param {ol.style.Fill} fill Fill style.
- * @api
-ol.style.Text.prototype.setFill = function(fill) {
- this.fill_ = fill;
- * Set the rotation.
- * @param {number|undefined} rotation Rotation.
- * @api
-ol.style.Text.prototype.setRotation = function(rotation) {
- this.rotation_ = rotation;
- * Set the scale.
- * @param {number|undefined} scale Scale.
- * @api
-ol.style.Text.prototype.setScale = function(scale) {
- this.scale_ = scale;
- * Set the stroke.
- * @param {ol.style.Stroke} stroke Stroke style.
- * @api
-ol.style.Text.prototype.setStroke = function(stroke) {
- this.stroke_ = stroke;
- * Set the text.
- * @param {string|undefined} text Text.
- * @api
-ol.style.Text.prototype.setText = function(text) {
- this.text_ = text;
- * Set the text alignment.
- * @param {string|undefined} textAlign Text align.
- * @api
-ol.style.Text.prototype.setTextAlign = function(textAlign) {
- this.textAlign_ = textAlign;
- * Set the text baseline.
- * @param {string|undefined} textBaseline Text baseline.
- * @api
-ol.style.Text.prototype.setTextBaseline = function(textBaseline) {
- this.textBaseline_ = textBaseline;
-// FIXME http://earth.google.com/kml/1.0 namespace?
-// FIXME why does node.getAttribute return an unknown type?
-// FIXME serialize arbitrary feature properties
-// FIXME don't parse style if extractStyles is false
-goog.provide('ol.format.KML');
-goog.require('ol.array');
-goog.require('ol.format.XMLFeature');
-goog.require('ol.format.XSD');
-goog.require('ol.geom.GeometryCollection');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.geom.MultiLineString');
-goog.require('ol.geom.MultiPoint');
-goog.require('ol.geom.MultiPolygon');
-goog.require('ol.geom.Point');
-goog.require('ol.geom.Polygon');
-goog.require('ol.math');
-goog.require('ol.style.Icon');
-goog.require('ol.style.Stroke');
-goog.require('ol.style.Style');
-goog.require('ol.style.Text');
-goog.require('ol.xml');
- * @classdesc
- * Feature format for reading and writing data in the KML format.
- * Note that the KML format uses the URL() constructor. Older browsers such as IE
- * which do not support this will need a URL polyfill to be loaded before use.
- * @constructor
- * @extends {ol.format.XMLFeature}
- * @param {olx.format.KMLOptions=} opt_options Options.
- * @api
-ol.format.KML = function(opt_options) {
- ol.format.XMLFeature.call(this);
- if (!ol.format.KML.DEFAULT_STYLE_ARRAY_) {
- ol.format.KML.createStyleDefaults_();
- * @inheritDoc
- * @private
- * @type {Array.<ol.style.Style>}
- this.defaultStyle_ = options.defaultStyle ?
- options.defaultStyle : ol.format.KML.DEFAULT_STYLE_ARRAY_;
- * @private
- * @type {boolean}
- this.extractStyles_ = options.extractStyles !== undefined ?
- options.extractStyles : true;
- * @private
- * @type {boolean}
- this.writeStyles_ = options.writeStyles !== undefined ?
- options.writeStyles : true;
- * @private
- * @type {Object.<string, (Array.<ol.style.Style>|string)>}
- this.sharedStyles_ = {};
- * @private
- * @type {boolean}
- this.showPointNames_ = options.showPointNames !== undefined ?
- options.showPointNames : true;
-ol.inherits(ol.format.KML, ol.format.XMLFeature);
- * @const
- * @private
-ol.format.KML.GX_NAMESPACE_URIS_ = [
- 'http://www.google.com/kml/ext/2.2'
- * @const
- * @private
-ol.format.KML.NAMESPACE_URIS_ = [
- null,
- 'http://earth.google.com/kml/2.0',
- 'http://earth.google.com/kml/2.1',
- 'http://earth.google.com/kml/2.2',
- 'http://www.opengis.net/kml/2.2'
- * @const
- * @type {string}
- * @private
-ol.format.KML.SCHEMA_LOCATION_ = 'http://www.opengis.net/kml/2.2 ' +
- 'https://developers.google.com/kml/schema/kml22gx.xsd';
- * @return {Array.<ol.style.Style>} Default style.
- * @private
-ol.format.KML.createStyleDefaults_ = function() {
- * @const
- * @private
- ol.format.KML.DEFAULT_COLOR_ = [255, 255, 255, 1];
- * @const
- * @private
- ol.format.KML.DEFAULT_FILL_STYLE_ = new ol.style.Fill({
- color: ol.format.KML.DEFAULT_COLOR_
- * @const
- * @type {ol.Size}
- * @private
- ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_ = [20, 2]; // FIXME maybe [8, 32] ?
- * @const
- * @private
- ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_X_UNITS_ =
- ol.style.IconAnchorUnits.PIXELS;
- * @const
- * @private
- ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_Y_UNITS_ =
- * @const
- * @type {ol.Size}
- * @private
- ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_ = [64, 64];
- * @const
- * @type {string}
- * @private
- ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_ =
- 'https://maps.google.com/mapfiles/kml/pushpin/ylw-pushpin.png';
- * @const
- * @type {number}
- * @private
- ol.format.KML.DEFAULT_IMAGE_SCALE_MULTIPLIER_ = 0.5;
- * @const
- * @type {ol.style.Image}
- * @private
- ol.format.KML.DEFAULT_IMAGE_STYLE_ = new ol.style.Icon({
- anchor: ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_,
- anchorOrigin: ol.style.IconOrigin.BOTTOM_LEFT,
- anchorXUnits: ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_X_UNITS_,
- anchorYUnits: ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_Y_UNITS_,
- crossOrigin: 'anonymous',
- rotation: 0,
- scale: ol.format.KML.DEFAULT_IMAGE_SCALE_MULTIPLIER_,
- size: ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_,
- src: ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_
- * @const
- * @type {string}
- * @private
- ol.format.KML.DEFAULT_NO_IMAGE_STYLE_ = 'NO_IMAGE';
- * @const
- * @private
- ol.format.KML.DEFAULT_STROKE_STYLE_ = new ol.style.Stroke({
- color: ol.format.KML.DEFAULT_COLOR_,
- width: 1
- * @const
- * @private
- ol.format.KML.DEFAULT_TEXT_STROKE_STYLE_ = new ol.style.Stroke({
- color: [51, 51, 51, 1],
- width: 2
- * @const
- * @type {ol.style.Text}
- * @private
- ol.format.KML.DEFAULT_TEXT_STYLE_ = new ol.style.Text({
- font: 'bold 16px Helvetica',
- fill: ol.format.KML.DEFAULT_FILL_STYLE_,
- stroke: ol.format.KML.DEFAULT_TEXT_STROKE_STYLE_,
- scale: 0.8
- * @const
- * @type {ol.style.Style}
- * @private
- ol.format.KML.DEFAULT_STYLE_ = new ol.style.Style({
- image: ol.format.KML.DEFAULT_IMAGE_STYLE_,
- text: ol.format.KML.DEFAULT_TEXT_STYLE_,
- stroke: ol.format.KML.DEFAULT_STROKE_STYLE_,
- zIndex: 0
- * @const
- * @private
- ol.format.KML.DEFAULT_STYLE_ARRAY_ = [ol.format.KML.DEFAULT_STYLE_];
- return ol.format.KML.DEFAULT_STYLE_ARRAY_;
- * @const
- * @type {Object.<string, ol.style.IconAnchorUnits>}
- * @private
-ol.format.KML.ICON_ANCHOR_UNITS_MAP_ = {
- 'fraction': ol.style.IconAnchorUnits.FRACTION,
- 'pixels': ol.style.IconAnchorUnits.PIXELS
- * @param {ol.style.Style|undefined} foundStyle Style.
- * @param {string} name Name.
- * @return {ol.style.Style} style Style.
- * @private
-ol.format.KML.createNameStyleFunction_ = function(foundStyle, name) {
- var textStyle = null;
- var textOffset = [0, 0];
- var textAlign = 'start';
- if (foundStyle.getImage()) {
- var imageSize = foundStyle.getImage().getImageSize();
- if (imageSize === null) {
- imageSize = ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_;
- if (imageSize.length == 2) {
- var imageScale = foundStyle.getImage().getScale();
- // Offset the label to be centered to the right of the icon, if there is
- // one.
- textOffset[0] = imageScale * imageSize[0] / 2;
- textOffset[1] = -imageScale * imageSize[1] / 2;
- textAlign = 'left';
- if (foundStyle.getText() !== null) {
- // clone the text style, customizing it with name, alignments and offset.
- // Note that kml does not support many text options that OpenLayers does (rotation, textBaseline).
- var foundText = foundStyle.getText();
- textStyle = foundText.clone();
- textStyle.setFont(foundText.getFont() || ol.format.KML.DEFAULT_TEXT_STYLE_.getFont());
- textStyle.setScale(foundText.getScale() || ol.format.KML.DEFAULT_TEXT_STYLE_.getScale());
- textStyle.setFill(foundText.getFill() || ol.format.KML.DEFAULT_TEXT_STYLE_.getFill());
- textStyle.setStroke(foundText.getStroke() || ol.format.KML.DEFAULT_TEXT_STROKE_STYLE_);
- } else {
- textStyle = ol.format.KML.DEFAULT_TEXT_STYLE_.clone();
- textStyle.setText(name);
- textStyle.setOffsetX(textOffset[0]);
- textStyle.setOffsetY(textOffset[1]);
- textStyle.setTextAlign(textAlign);
- var nameStyle = new ol.style.Style({
- text: textStyle
- return nameStyle;
- * @param {Array.<ol.style.Style>|undefined} style Style.
- * @param {string} styleUrl Style URL.
- * @param {Array.<ol.style.Style>} defaultStyle Default style.
- * @param {Object.<string, (Array.<ol.style.Style>|string)>} sharedStyles Shared
- * styles.
- * @param {boolean|undefined} showPointNames true to show names for point
- * placemarks.
- * @return {ol.FeatureStyleFunction} Feature style function.
- * @private
-ol.format.KML.createFeatureStyleFunction_ = function(style, styleUrl,
- defaultStyle, sharedStyles, showPointNames) {
- return (
- * @param {number} resolution Resolution.
- * @return {Array.<ol.style.Style>} Style.
- * @this {ol.Feature}
- function(resolution) {
- var drawName = showPointNames;
- /** @type {ol.style.Style|undefined} */
- var nameStyle;
- var name = '';
- if (drawName) {
- if (this.getGeometry()) {
- drawName = (this.getGeometry().getType() ===
- ol.geom.GeometryType.POINT);
- if (drawName) {
- name = /** @type {string} */ (this.get('name'));
- drawName = drawName && name;
- if (style) {
- if (drawName) {
- nameStyle = ol.format.KML.createNameStyleFunction_(style[0],
- name);
- return style.concat(nameStyle);
- return style;
- if (styleUrl) {
- var foundStyle = ol.format.KML.findStyle_(styleUrl, defaultStyle,
- sharedStyles);
- if (drawName) {
- nameStyle = ol.format.KML.createNameStyleFunction_(foundStyle[0],
- name);
- return foundStyle.concat(nameStyle);
- return foundStyle;
- if (drawName) {
- nameStyle = ol.format.KML.createNameStyleFunction_(defaultStyle[0],
- name);
- return defaultStyle.concat(nameStyle);
- return defaultStyle;
- * @param {Array.<ol.style.Style>|string|undefined} styleValue Style value.
- * Shared styles.
- * @private
-ol.format.KML.findStyle_ = function(styleValue, defaultStyle, sharedStyles) {
- if (Array.isArray(styleValue)) {
- return styleValue;
- } else if (typeof styleValue === 'string') {
- // KML files in the wild occasionally forget the leading `#` on styleUrls
- // defined in the same document. Add a leading `#` if it enables to find
- // a style.
- if (!(styleValue in sharedStyles) && ('#' + styleValue in sharedStyles)) {
- styleValue = '#' + styleValue;
- return ol.format.KML.findStyle_(
- sharedStyles[styleValue], defaultStyle, sharedStyles);
- } else {
- * @private
- * @return {ol.Color|undefined} Color.
-ol.format.KML.readColor_ = function(node) {
- var s = ol.xml.getAllTextContent(node, false);
- // The KML specification states that colors should not include a leading `#`
- // but we tolerate them.
- var m = /^\s*#?\s*([0-9A-Fa-f]{8})\s*$/.exec(s);
- if (m) {
- var hexColor = m[1];
- return [
- parseInt(hexColor.substr(6, 2), 16),
- parseInt(hexColor.substr(4, 2), 16),
- parseInt(hexColor.substr(2, 2), 16),
- parseInt(hexColor.substr(0, 2), 16) / 255
- } else {
- return undefined;
- * @private
- * @return {Array.<number>|undefined} Flat coordinates.
-ol.format.KML.readFlatCoordinates_ = function(node) {
- var flatCoordinates = [];
- // The KML specification states that coordinate tuples should not include
- // spaces, but we tolerate them.
- var re =
- /^\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?)\s*,\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?)(?:\s*,\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?))?\s*/i;
- var m;
- while ((m = re.exec(s))) {
- var x = parseFloat(m[1]);
- var y = parseFloat(m[2]);
- var z = m[3] ? parseFloat(m[3]) : 0;
- flatCoordinates.push(x, y, z);
- s = s.substr(m[0].length);
- if (s !== '') {
- return undefined;
- return flatCoordinates;
- * @private
- * @return {string} URI.
-ol.format.KML.readURI_ = function(node) {
- var s = ol.xml.getAllTextContent(node, false).trim();
- if (node.baseURI) {
- var url = new URL(s, node.baseURI);
- return url.href;
- } else {
- return s;
- * @private
- * @return {ol.KMLVec2_} Vec2.
-ol.format.KML.readVec2_ = function(node) {
- var xunits = node.getAttribute('xunits');
- var yunits = node.getAttribute('yunits');
- return {
- x: parseFloat(node.getAttribute('x')),
- xunits: ol.format.KML.ICON_ANCHOR_UNITS_MAP_[xunits],
- y: parseFloat(node.getAttribute('y')),
- yunits: ol.format.KML.ICON_ANCHOR_UNITS_MAP_[yunits]
- * @private
-ol.format.KML.readScale_ = function(node) {
- return ol.format.XSD.readDecimal(node);
- * @private
- * @return {Array.<ol.style.Style>|string|undefined} StyleMap.
-ol.format.KML.readStyleMapValue_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop(undefined,
- ol.format.KML.STYLE_MAP_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.IconStyleParser_ = function(node, objectStack) {
- // FIXME refreshMode
- // FIXME refreshInterval
- // FIXME viewRefreshTime
- // FIXME viewBoundScale
- // FIXME viewFormat
- // FIXME httpQuery
- var object = ol.xml.pushParseAndPop(
- {}, ol.format.KML.ICON_STYLE_PARSERS_, node, objectStack);
- if (!object) {
- return;
- var styleObject = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var IconObject = 'Icon' in object ? object['Icon'] : {};
- var drawIcon = (!('Icon' in object) || Object.keys(IconObject).length > 0);
- var src;
- var href = /** @type {string|undefined} */
- (IconObject['href']);
- if (href) {
- src = href;
- } else if (drawIcon) {
- src = ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_;
- var anchor, anchorXUnits, anchorYUnits;
- var hotSpot = /** @type {ol.KMLVec2_|undefined} */
- (object['hotSpot']);
- if (hotSpot) {
- anchor = [hotSpot.x, hotSpot.y];
- anchorXUnits = hotSpot.xunits;
- anchorYUnits = hotSpot.yunits;
- } else if (src === ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_) {
- anchor = ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_;
- anchorXUnits = ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_X_UNITS_;
- anchorYUnits = ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_Y_UNITS_;
- } else if (/^http:\/\/maps\.(?:google|gstatic)\.com\//.test(src)) {
- anchor = [0.5, 0];
- anchorXUnits = ol.style.IconAnchorUnits.FRACTION;
- anchorYUnits = ol.style.IconAnchorUnits.FRACTION;
- var offset;
- var x = /** @type {number|undefined} */
- (IconObject['x']);
- var y = /** @type {number|undefined} */
- (IconObject['y']);
- if (x !== undefined && y !== undefined) {
- offset = [x, y];
- var size;
- var w = /** @type {number|undefined} */
- (IconObject['w']);
- var h = /** @type {number|undefined} */
- (IconObject['h']);
- if (w !== undefined && h !== undefined) {
- size = [w, h];
- var rotation;
- var heading = /** @type {number} */
- (object['heading']);
- if (heading !== undefined) {
- rotation = ol.math.toRadians(heading);
- var scale = /** @type {number|undefined} */
- (object['scale']);
- if (drawIcon) {
- if (src == ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_) {
- size = ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_;
- if (scale === undefined) {
- scale = ol.format.KML.DEFAULT_IMAGE_SCALE_MULTIPLIER_;
- var imageStyle = new ol.style.Icon({
- anchor: anchor,
- anchorXUnits: anchorXUnits,
- anchorYUnits: anchorYUnits,
- crossOrigin: 'anonymous', // FIXME should this be configurable?
- offset: offset,
- offsetOrigin: ol.style.IconOrigin.BOTTOM_LEFT,
- scale: scale,
- size: size,
- src: src
- styleObject['imageStyle'] = imageStyle;
- } else {
- // handle the case when we explicitly want to draw no icon.
- styleObject['imageStyle'] = ol.format.KML.DEFAULT_NO_IMAGE_STYLE_;
- * @private
-ol.format.KML.LabelStyleParser_ = function(node, objectStack) {
- // FIXME colorMode
- {}, ol.format.KML.LABEL_STYLE_PARSERS_, node, objectStack);
- if (!object) {
- return;
- var styleObject = objectStack[objectStack.length - 1];
- var textStyle = new ol.style.Text({
- fill: new ol.style.Fill({
- color: /** @type {ol.Color} */
- ('color' in object ? object['color'] : ol.format.KML.DEFAULT_COLOR_)
- scale: /** @type {number|undefined} */
- (object['scale'])
- styleObject['textStyle'] = textStyle;
- * @private
-ol.format.KML.LineStyleParser_ = function(node, objectStack) {
- // FIXME gx:outerColor
- // FIXME gx:outerWidth
- // FIXME gx:physicalWidth
- // FIXME gx:labelVisibility
- {}, ol.format.KML.LINE_STYLE_PARSERS_, node, objectStack);
- if (!object) {
- return;
- var strokeStyle = new ol.style.Stroke({
- ('color' in object ? object['color'] : ol.format.KML.DEFAULT_COLOR_),
- width: /** @type {number} */ ('width' in object ? object['width'] : 1)
- styleObject['strokeStyle'] = strokeStyle;
- * @private
-ol.format.KML.PolyStyleParser_ = function(node, objectStack) {
- {}, ol.format.KML.POLY_STYLE_PARSERS_, node, objectStack);
- if (!object) {
- return;
- var fillStyle = new ol.style.Fill({
- styleObject['fillStyle'] = fillStyle;
- var fill = /** @type {boolean|undefined} */ (object['fill']);
- if (fill !== undefined) {
- styleObject['fill'] = fill;
- var outline =
- /** @type {boolean|undefined} */ (object['outline']);
- if (outline !== undefined) {
- styleObject['outline'] = outline;
- * @private
- * @return {Array.<number>} LinearRing flat coordinates.
-ol.format.KML.readFlatLinearRing_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop(null,
- ol.format.KML.FLAT_LINEAR_RING_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.gxCoordParser_ = function(node, objectStack) {
- var gxTrackObject = /** @type {ol.KMLGxTrackObject_} */
- (objectStack[objectStack.length - 1]);
- var flatCoordinates = gxTrackObject.flatCoordinates;
- var re =
- /^\s*([+\-]?\d+(?:\.\d*)?(?:e[+\-]?\d*)?)\s+([+\-]?\d+(?:\.\d*)?(?:e[+\-]?\d*)?)\s+([+\-]?\d+(?:\.\d*)?(?:e[+\-]?\d*)?)\s*$/i;
- var m = re.exec(s);
- if (m) {
- var z = parseFloat(m[3]);
- flatCoordinates.push(x, y, z, 0);
- } else {
- flatCoordinates.push(0, 0, 0, 0);
- * @private
- * @return {ol.geom.MultiLineString|undefined} MultiLineString.
-ol.format.KML.readGxMultiTrack_ = function(node, objectStack) {
- var lineStrings = ol.xml.pushParseAndPop([],
- ol.format.KML.GX_MULTITRACK_GEOMETRY_PARSERS_, node, objectStack);
- if (!lineStrings) {
- return undefined;
- var multiLineString = new ol.geom.MultiLineString(null);
- multiLineString.setLineStrings(lineStrings);
- return multiLineString;
- * @private
- * @return {ol.geom.LineString|undefined} LineString.
-ol.format.KML.readGxTrack_ = function(node, objectStack) {
- var gxTrackObject = ol.xml.pushParseAndPop(
- /** @type {ol.KMLGxTrackObject_} */ ({
- flatCoordinates: [],
- whens: []
- }), ol.format.KML.GX_TRACK_PARSERS_, node, objectStack);
- if (!gxTrackObject) {
- return undefined;
- var whens = gxTrackObject.whens;
- var i, ii;
- for (i = 0, ii = Math.min(flatCoordinates.length, whens.length); i < ii;
- ++i) {
- flatCoordinates[4 * i + 3] = whens[i];
- lineString.setFlatCoordinates(ol.geom.GeometryLayout.XYZM, flatCoordinates);
- return lineString;
- * @private
- * @return {Object} Icon object.
-ol.format.KML.readIcon_ = function(node, objectStack) {
- var iconObject = ol.xml.pushParseAndPop(
- {}, ol.format.KML.ICON_PARSERS_, node, objectStack);
- if (iconObject) {
- return iconObject;
- } else {
- return null;
- * @private
- * @return {Array.<number>} Flat coordinates.
-ol.format.KML.readFlatCoordinatesFromNode_ = function(node, objectStack) {
- ol.format.KML.GEOMETRY_FLAT_COORDINATES_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.readLineString_ = function(node, objectStack) {
- var properties = ol.xml.pushParseAndPop({},
- ol.format.KML.EXTRUDE_AND_ALTITUDE_MODE_PARSERS_, node,
- objectStack);
- ol.format.KML.readFlatCoordinatesFromNode_(node, objectStack);
- if (flatCoordinates) {
- lineString.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
- lineString.setProperties(properties);
- } else {
- return undefined;
- * @private
- * @return {ol.geom.Polygon|undefined} Polygon.
-ol.format.KML.readLinearRing_ = function(node, objectStack) {
- objectStack);
- var polygon = new ol.geom.Polygon(null);
- polygon.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates,
- [flatCoordinates.length]);
- polygon.setProperties(properties);
- return polygon;
- } else {
- return undefined;
- * @private
-ol.format.KML.readMultiGeometry_ = function(node, objectStack) {
- var geometries = ol.xml.pushParseAndPop([],
- ol.format.KML.MULTI_GEOMETRY_PARSERS_, node, objectStack);
- if (!geometries) {
- return null;
- if (geometries.length === 0) {
- return new ol.geom.GeometryCollection(geometries);
- /** @type {ol.geom.Geometry} */
- var multiGeometry;
- var homogeneous = true;
- var type = geometries[0].getType();
- var geometry, i, ii;
- for (i = 1, ii = geometries.length; i < ii; ++i) {
- geometry = geometries[i];
- if (geometry.getType() != type) {
- homogeneous = false;
- break;
- if (homogeneous) {
- var layout;
- var flatCoordinates;
- if (type == ol.geom.GeometryType.POINT) {
- var point = geometries[0];
- layout = point.getLayout();
- flatCoordinates = point.getFlatCoordinates();
- ol.array.extend(flatCoordinates, geometry.getFlatCoordinates());
- multiGeometry = new ol.geom.MultiPoint(null);
- multiGeometry.setFlatCoordinates(layout, flatCoordinates);
- ol.format.KML.setCommonGeometryProperties_(multiGeometry, geometries);
- } else if (type == ol.geom.GeometryType.LINE_STRING) {
- multiGeometry = new ol.geom.MultiLineString(null);
- multiGeometry.setLineStrings(geometries);
- } else if (type == ol.geom.GeometryType.POLYGON) {
- multiGeometry = new ol.geom.MultiPolygon(null);
- multiGeometry.setPolygons(geometries);
- } else if (type == ol.geom.GeometryType.GEOMETRY_COLLECTION) {
- multiGeometry = new ol.geom.GeometryCollection(geometries);
- } else {
- ol.asserts.assert(false, 37); // Unknown geometry type found
- } else {
- return /** @type {ol.geom.Geometry} */ (multiGeometry);
- * @private
- * @return {ol.geom.Point|undefined} Point.
-ol.format.KML.readPoint_ = function(node, objectStack) {
- objectStack);
- var point = new ol.geom.Point(null);
- point.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
- point.setProperties(properties);
- return point;
- } else {
- return undefined;
- * @private
-ol.format.KML.readPolygon_ = function(node, objectStack) {
- var properties = ol.xml.pushParseAndPop(/** @type {Object<string,*>} */ ({}),
- objectStack);
- var flatLinearRings = ol.xml.pushParseAndPop([null],
- ol.format.KML.FLAT_LINEAR_RINGS_PARSERS_, node, objectStack);
- if (flatLinearRings && flatLinearRings[0]) {
- var flatCoordinates = flatLinearRings[0];
- var ends = [flatCoordinates.length];
- var i, ii;
- for (i = 1, ii = flatLinearRings.length; i < ii; ++i) {
- ol.array.extend(flatCoordinates, flatLinearRings[i]);
- ends.push(flatCoordinates.length);
- ol.geom.GeometryLayout.XYZ, flatCoordinates, ends);
- return polygon;
- } else {
- return undefined;
- * @private
-ol.format.KML.readStyle_ = function(node, objectStack) {
- var styleObject = ol.xml.pushParseAndPop(
- {}, ol.format.KML.STYLE_PARSERS_, node, objectStack);
- if (!styleObject) {
- return null;
- var fillStyle = /** @type {ol.style.Fill} */
- ('fillStyle' in styleObject ?
- styleObject['fillStyle'] : ol.format.KML.DEFAULT_FILL_STYLE_);
- var fill = /** @type {boolean|undefined} */ (styleObject['fill']);
- if (fill !== undefined && !fill) {
- fillStyle = null;
- var imageStyle = /** @type {ol.style.Image} */
- ('imageStyle' in styleObject ?
- styleObject['imageStyle'] : ol.format.KML.DEFAULT_IMAGE_STYLE_);
- if (imageStyle == ol.format.KML.DEFAULT_NO_IMAGE_STYLE_) {
- imageStyle = undefined;
- var textStyle = /** @type {ol.style.Text} */
- ('textStyle' in styleObject ?
- styleObject['textStyle'] : ol.format.KML.DEFAULT_TEXT_STYLE_);
- var strokeStyle = /** @type {ol.style.Stroke} */
- ('strokeStyle' in styleObject ?
- styleObject['strokeStyle'] : ol.format.KML.DEFAULT_STROKE_STYLE_);
- var outline = /** @type {boolean|undefined} */
- (styleObject['outline']);
- if (outline !== undefined && !outline) {
- strokeStyle = null;
- return [new ol.style.Style({
- fill: fillStyle,
- image: imageStyle,
- stroke: strokeStyle,
- text: textStyle,
- zIndex: undefined // FIXME
- * Reads an array of geometries and creates arrays for common geometry
- * properties. Then sets them to the multi geometry.
- * @param {ol.geom.MultiPoint|ol.geom.MultiLineString|ol.geom.MultiPolygon}
- * multiGeometry A multi-geometry.
- * @param {Array.<ol.geom.Geometry>} geometries List of geometries.
- * @private
-ol.format.KML.setCommonGeometryProperties_ = function(multiGeometry,
- geometries) {
- var ii = geometries.length;
- var extrudes = new Array(geometries.length);
- var altitudeModes = new Array(geometries.length);
- var geometry, i, hasExtrude, hasAltitudeMode;
- hasExtrude = hasAltitudeMode = false;
- for (i = 0; i < ii; ++i) {
- extrudes[i] = geometry.get('extrude');
- altitudeModes[i] = geometry.get('altitudeMode');
- hasExtrude = hasExtrude || extrudes[i] !== undefined;
- hasAltitudeMode = hasAltitudeMode || altitudeModes[i];
- if (hasExtrude) {
- multiGeometry.set('extrude', extrudes);
- if (hasAltitudeMode) {
- multiGeometry.set('altitudeMode', altitudeModes);
- * @private
-ol.format.KML.DataParser_ = function(node, objectStack) {
- var name = node.getAttribute('name');
- ol.xml.parseNode(ol.format.KML.DATA_PARSERS_, node, objectStack);
- var featureObject =
- /** @type {Object} */ (objectStack[objectStack.length - 1]);
- if (name !== null) {
- featureObject[name] = featureObject.value;
- } else if (featureObject.displayName !== null) {
- featureObject[featureObject.displayName] = featureObject.value;
- * @private
-ol.format.KML.ExtendedDataParser_ = function(node, objectStack) {
- ol.xml.parseNode(ol.format.KML.EXTENDED_DATA_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.RegionParser_ = function(node, objectStack) {
- ol.xml.parseNode(ol.format.KML.REGION_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.PairDataParser_ = function(node, objectStack) {
- var pairObject = ol.xml.pushParseAndPop(
- {}, ol.format.KML.PAIR_PARSERS_, node, objectStack);
- if (!pairObject) {
- return;
- var key = /** @type {string|undefined} */
- (pairObject['key']);
- if (key && key == 'normal') {
- var styleUrl = /** @type {string|undefined} */
- (pairObject['styleUrl']);
- if (styleUrl) {
- objectStack[objectStack.length - 1] = styleUrl;
- var Style = /** @type {ol.style.Style} */
- (pairObject['Style']);
- if (Style) {
- objectStack[objectStack.length - 1] = Style;
- * @private
-ol.format.KML.PlacemarkStyleMapParser_ = function(node, objectStack) {
- var styleMapValue = ol.format.KML.readStyleMapValue_(node, objectStack);
- if (!styleMapValue) {
- return;
- var placemarkObject = objectStack[objectStack.length - 1];
- if (Array.isArray(styleMapValue)) {
- placemarkObject['Style'] = styleMapValue;
- } else if (typeof styleMapValue === 'string') {
- placemarkObject['styleUrl'] = styleMapValue;
- } else {
- ol.asserts.assert(false, 38); // `styleMapValue` has an unknown type
- * @private
-ol.format.KML.SchemaDataParser_ = function(node, objectStack) {
- ol.xml.parseNode(ol.format.KML.SCHEMA_DATA_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.SimpleDataParser_ = function(node, objectStack) {
- var data = ol.format.XSD.readString(node);
- featureObject[name] = data;
- * @private
-ol.format.KML.LatLonAltBoxParser_ = function(node, objectStack) {
- var object = ol.xml.pushParseAndPop({}, ol.format.KML.LAT_LON_ALT_BOX_PARSERS_, node, objectStack);
- if (!object) {
- return;
- var regionObject = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var extent = [
- parseFloat(object['west']),
- parseFloat(object['south']),
- parseFloat(object['east']),
- parseFloat(object['north'])
- regionObject['extent'] = extent;
- regionObject['altitudeMode'] = object['altitudeMode'];
- regionObject['minAltitude'] = parseFloat(object['minAltitude']);
- regionObject['maxAltitude'] = parseFloat(object['maxAltitude']);
- * @private
-ol.format.KML.LodParser_ = function(node, objectStack) {
- var object = ol.xml.pushParseAndPop({}, ol.format.KML.LOD_PARSERS_, node, objectStack);
- if (!object) {
- return;
- var lodObject = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- lodObject['minLodPixels'] = parseFloat(object['minLodPixels']);
- lodObject['maxLodPixels'] = parseFloat(object['maxLodPixels']);
- lodObject['minFadeExtent'] = parseFloat(object['minFadeExtent']);
- lodObject['maxFadeExtent'] = parseFloat(object['maxFadeExtent']);
- * @private
-ol.format.KML.innerBoundaryIsParser_ = function(node, objectStack) {
- /** @type {Array.<number>|undefined} */
- var flatLinearRing = ol.xml.pushParseAndPop(undefined,
- ol.format.KML.INNER_BOUNDARY_IS_PARSERS_, node, objectStack);
- if (flatLinearRing) {
- var flatLinearRings = /** @type {Array.<Array.<number>>} */
- flatLinearRings.push(flatLinearRing);
- * @param {Node} node Node.
- * @private
-ol.format.KML.outerBoundaryIsParser_ = function(node, objectStack) {
- ol.format.KML.OUTER_BOUNDARY_IS_PARSERS_, node, objectStack);
- flatLinearRings[0] = flatLinearRing;
- * @private
-ol.format.KML.LinkParser_ = function(node, objectStack) {
- ol.xml.parseNode(ol.format.KML.LINK_PARSERS_, node, objectStack);
- * @private
-ol.format.KML.whenParser_ = function(node, objectStack) {
- var when = Date.parse(s);
- whens.push(isNaN(when) ? 0 : when);
- * @const
- * @type {Object.<string, Object.<string, ol.XmlParser>>}
- * @private
-ol.format.KML.DATA_PARSERS_ = ol.xml.makeStructureNS(
- ol.format.KML.NAMESPACE_URIS_, {
- 'displayName': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'value': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
- * @const
- * @private
-ol.format.KML.EXTENDED_DATA_PARSERS_ = ol.xml.makeStructureNS(
- 'Data': ol.format.KML.DataParser_,
- 'SchemaData': ol.format.KML.SchemaDataParser_
- * @const
- * @private
-ol.format.KML.REGION_PARSERS_ = ol.xml.makeStructureNS(
- 'LatLonAltBox': ol.format.KML.LatLonAltBoxParser_,
- 'Lod': ol.format.KML.LodParser_
- * @const
- * @private
-ol.format.KML.LAT_LON_ALT_BOX_PARSERS_ = ol.xml.makeStructureNS(
- 'altitudeMode': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'minAltitude': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'maxAltitude': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'north': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'south': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'east': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'west': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
- * @const
- * @private
-ol.format.KML.LOD_PARSERS_ = ol.xml.makeStructureNS(
- 'minLodPixels': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'maxLodPixels': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'minFadeExtent': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'maxFadeExtent': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
- * @const
- * @private
-ol.format.KML.EXTRUDE_AND_ALTITUDE_MODE_PARSERS_ = ol.xml.makeStructureNS(
- 'extrude': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean),
- * @const
- * @private
-ol.format.KML.FLAT_LINEAR_RING_PARSERS_ = ol.xml.makeStructureNS(
- 'coordinates': ol.xml.makeReplacer(ol.format.KML.readFlatCoordinates_)
- * @const
- * @private
-ol.format.KML.FLAT_LINEAR_RINGS_PARSERS_ = ol.xml.makeStructureNS(
- 'innerBoundaryIs': ol.format.KML.innerBoundaryIsParser_,
- 'outerBoundaryIs': ol.format.KML.outerBoundaryIsParser_
- * @const
- * @private
-ol.format.KML.GX_TRACK_PARSERS_ = ol.xml.makeStructureNS(
- 'when': ol.format.KML.whenParser_
- }, ol.xml.makeStructureNS(
- ol.format.KML.GX_NAMESPACE_URIS_, {
- 'coord': ol.format.KML.gxCoordParser_
- * @const
- * @private
-ol.format.KML.GEOMETRY_FLAT_COORDINATES_PARSERS_ = ol.xml.makeStructureNS(
- * @const
- * @private
-ol.format.KML.ICON_PARSERS_ = ol.xml.makeStructureNS(
- 'href': ol.xml.makeObjectPropertySetter(ol.format.KML.readURI_)
- 'x': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'y': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'w': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'h': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
- * @const
- * @private
-ol.format.KML.ICON_STYLE_PARSERS_ = ol.xml.makeStructureNS(
- 'Icon': ol.xml.makeObjectPropertySetter(ol.format.KML.readIcon_),
- 'heading': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
- 'hotSpot': ol.xml.makeObjectPropertySetter(ol.format.KML.readVec2_),
- 'scale': ol.xml.makeObjectPropertySetter(ol.format.KML.readScale_)
- * @const
- * @private
-ol.format.KML.INNER_BOUNDARY_IS_PARSERS_ = ol.xml.makeStructureNS(
- 'LinearRing': ol.xml.makeReplacer(ol.format.KML.readFlatLinearRing_)
- * @const
- * @private
-ol.format.KML.LABEL_STYLE_PARSERS_ = ol.xml.makeStructureNS(
- 'color': ol.xml.makeObjectPropertySetter(ol.format.KML.readColor_),
- * @const
- * @private
-ol.format.KML.LINE_STYLE_PARSERS_ = ol.xml.makeStructureNS(
- 'width': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
- * @const
- * @private
-ol.format.KML.MULTI_GEOMETRY_PARSERS_ = ol.xml.makeStructureNS(
- 'LineString': ol.xml.makeArrayPusher(ol.format.KML.readLineString_),
- 'LinearRing': ol.xml.makeArrayPusher(ol.format.KML.readLinearRing_),
- 'MultiGeometry': ol.xml.makeArrayPusher(ol.format.KML.readMultiGeometry_),
- 'Point': ol.xml.makeArrayPusher(ol.format.KML.readPoint_),
- 'Polygon': ol.xml.makeArrayPusher(ol.format.KML.readPolygon_)
- * @const
- * @private
-ol.format.KML.GX_MULTITRACK_GEOMETRY_PARSERS_ = ol.xml.makeStructureNS(
- 'Track': ol.xml.makeArrayPusher(ol.format.KML.readGxTrack_)
- * @const
- * @private
-ol.format.KML.NETWORK_LINK_PARSERS_ = ol.xml.makeStructureNS(
- 'ExtendedData': ol.format.KML.ExtendedDataParser_,
- 'Region': ol.format.KML.RegionParser_,
- 'Link': ol.format.KML.LinkParser_,
- 'address': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'description': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'name': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'open': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean),
- 'phoneNumber': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'visibility': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean)
- * @const
- * @private
-ol.format.KML.LINK_PARSERS_ = ol.xml.makeStructureNS(
- * @const
- * @private
-ol.format.KML.OUTER_BOUNDARY_IS_PARSERS_ = ol.xml.makeStructureNS(
- * @const
- * @private
-ol.format.KML.PAIR_PARSERS_ = ol.xml.makeStructureNS(
- 'Style': ol.xml.makeObjectPropertySetter(ol.format.KML.readStyle_),
- 'key': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'styleUrl': ol.xml.makeObjectPropertySetter(ol.format.KML.readURI_)
- * @const
- * @private
-ol.format.KML.PLACEMARK_PARSERS_ = ol.xml.makeStructureNS(
- 'MultiGeometry': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readMultiGeometry_, 'geometry'),
- 'LineString': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readLineString_, 'geometry'),
- 'LinearRing': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readLinearRing_, 'geometry'),
- 'Point': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readPoint_, 'geometry'),
- 'Polygon': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readPolygon_, 'geometry'),
- 'StyleMap': ol.format.KML.PlacemarkStyleMapParser_,
- 'styleUrl': ol.xml.makeObjectPropertySetter(ol.format.KML.readURI_),
- 'MultiTrack': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readGxMultiTrack_, 'geometry'),
- 'Track': ol.xml.makeObjectPropertySetter(
- ol.format.KML.readGxTrack_, 'geometry')
- * @const
- * @private
-ol.format.KML.POLY_STYLE_PARSERS_ = ol.xml.makeStructureNS(
- 'fill': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean),
- 'outline': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean)
- * @const
- * @private
-ol.format.KML.SCHEMA_DATA_PARSERS_ = ol.xml.makeStructureNS(
- 'SimpleData': ol.format.KML.SimpleDataParser_
- * @const
- * @private
-ol.format.KML.STYLE_PARSERS_ = ol.xml.makeStructureNS(
- 'IconStyle': ol.format.KML.IconStyleParser_,
- 'LabelStyle': ol.format.KML.LabelStyleParser_,
- 'LineStyle': ol.format.KML.LineStyleParser_,
- 'PolyStyle': ol.format.KML.PolyStyleParser_
- * @const
- * @private
-ol.format.KML.STYLE_MAP_PARSERS_ = ol.xml.makeStructureNS(
- 'Pair': ol.format.KML.PairDataParser_
- * @param {Array.<*>} objectStack Object stack.
- * @private
- * @return {Array.<ol.Feature>|undefined} Features.
-ol.format.KML.prototype.readDocumentOrFolder_ = function(node, objectStack) {
- // FIXME use scope somehow
- var parsersNS = ol.xml.makeStructureNS(
- 'Document': ol.xml.makeArrayExtender(this.readDocumentOrFolder_, this),
- 'Folder': ol.xml.makeArrayExtender(this.readDocumentOrFolder_, this),
- 'Placemark': ol.xml.makeArrayPusher(this.readPlacemark_, this),
- 'Style': this.readSharedStyle_.bind(this),
- 'StyleMap': this.readSharedStyleMap_.bind(this)
- /** @type {Array.<ol.Feature>} */
- var features = ol.xml.pushParseAndPop([], parsersNS, node, objectStack, this);
- if (features) {
- return features;
- } else {
- return undefined;
- * @private
- * @return {ol.Feature|undefined} Feature.
-ol.format.KML.prototype.readPlacemark_ = function(node, objectStack) {
- var object = ol.xml.pushParseAndPop({'geometry': null},
- ol.format.KML.PLACEMARK_PARSERS_, node, objectStack);
- if (!object) {
- return undefined;
- var feature = new ol.Feature();
- var id = node.getAttribute('id');
- if (id !== null) {
- feature.setId(id);
- var options = /** @type {olx.format.ReadOptions} */ (objectStack[0]);
- var geometry = object['geometry'];
- if (geometry) {
- ol.format.Feature.transformWithOptions(geometry, false, options);
- feature.setGeometry(geometry);
- delete object['geometry'];
- if (this.extractStyles_) {
- var style = object['Style'];
- var styleUrl = object['styleUrl'];
- var styleFunction = ol.format.KML.createFeatureStyleFunction_(
- style, styleUrl, this.defaultStyle_, this.sharedStyles_,
- this.showPointNames_);
- feature.setStyle(styleFunction);
- delete object['Style'];
- // we do not remove the styleUrl property from the object, so it
- // gets stored on feature when setProperties is called
- feature.setProperties(object);
- return feature;
- * @private
-ol.format.KML.prototype.readSharedStyle_ = function(node, objectStack) {
- var style = ol.format.KML.readStyle_(node, objectStack);
- if (style) {
- var styleUri;
- var url = new URL('#' + id, node.baseURI);
- styleUri = url.href;
- } else {
- styleUri = '#' + id;
- this.sharedStyles_[styleUri] = style;
- * @private
-ol.format.KML.prototype.readSharedStyleMap_ = function(node, objectStack) {
- if (id === null) {
- return;
- return;
- var styleUri;
- } else {
- this.sharedStyles_[styleUri] = styleMapValue;
- * Read the first feature from a KML source. MultiGeometries are converted into
- * GeometryCollections if they are a mix of geometry types, and into MultiPoint/
- * MultiLineString/MultiPolygon if they are all of the same type.
- * @function
- * @param {Document|Node|Object|string} source Source.
- * @param {olx.format.ReadOptions=} opt_options Read options.
- * @return {ol.Feature} Feature.
- * @api
-ol.format.KML.prototype.readFeature;
- * @inheritDoc
-ol.format.KML.prototype.readFeatureFromNode = function(node, opt_options) {
- if (!ol.array.includes(ol.format.KML.NAMESPACE_URIS_, node.namespaceURI)) {
- return null;
- var feature = this.readPlacemark_(
- node, [this.getReadOptions(node, opt_options)]);
- if (feature) {
- return feature;
- } else {
- return null;
- * Read all features from a KML source. MultiGeometries are converted into
- * @function
- * @return {Array.<ol.Feature>} Features.
- * @api
-ol.format.KML.prototype.readFeatures;
- * @inheritDoc
-ol.format.KML.prototype.readFeaturesFromNode = function(node, opt_options) {
- return [];
- var features;
- var localName = node.localName;
- if (localName == 'Document' || localName == 'Folder') {
- features = this.readDocumentOrFolder_(
- if (features) {
- return features;
- } else {
- return [];
- } else if (localName == 'Placemark') {
- if (feature) {
- return [feature];
- } else {
- return [];
- } else if (localName == 'kml') {
- features = [];
- var n;
- for (n = node.firstElementChild; n; n = n.nextElementSibling) {
- var fs = this.readFeaturesFromNode(n, opt_options);
- if (fs) {
- ol.array.extend(features, fs);
- return features;
- } else {
- return [];
- * Read the name of the KML.
- * @param {Document|Node|string} source Souce.
- * @return {string|undefined} Name.
- * @api
-ol.format.KML.prototype.readName = function(source) {
- if (ol.xml.isDocument(source)) {
- return this.readNameFromDocument(/** @type {Document} */ (source));
- } else if (ol.xml.isNode(source)) {
- return this.readNameFromNode(/** @type {Node} */ (source));
- } else if (typeof source === 'string') {
- var doc = ol.xml.parse(source);
- return this.readNameFromDocument(doc);
- } else {
- return undefined;
- * @param {Document} doc Document.
-ol.format.KML.prototype.readNameFromDocument = function(doc) {
- var n;
- for (n = doc.firstChild; n; n = n.nextSibling) {
- if (n.nodeType == Node.ELEMENT_NODE) {
- var name = this.readNameFromNode(n);
- if (name) {
- return name;
- return undefined;
-ol.format.KML.prototype.readNameFromNode = function(node) {
- var n;
- if (ol.array.includes(ol.format.KML.NAMESPACE_URIS_, n.namespaceURI) &&
- n.localName == 'name') {
- return ol.format.XSD.readString(n);
- var localName = n.localName;
- (localName == 'Document' ||
- localName == 'Folder' ||
- localName == 'Placemark' ||
- localName == 'kml')) {
- if (name) {
- return name;
- return undefined;
- * Read the network links of the KML.
- * @param {Document|Node|string} source Source.
- * @return {Array.<Object>} Network links.
- * @api
-ol.format.KML.prototype.readNetworkLinks = function(source) {
- var networkLinks = [];
- ol.array.extend(networkLinks, this.readNetworkLinksFromDocument(
- /** @type {Document} */ (source)));
- ol.array.extend(networkLinks, this.readNetworkLinksFromNode(
- /** @type {Node} */ (source)));
- ol.array.extend(networkLinks, this.readNetworkLinksFromDocument(doc));
- return networkLinks;
-ol.format.KML.prototype.readNetworkLinksFromDocument = function(doc) {
- var n, networkLinks = [];
- ol.array.extend(networkLinks, this.readNetworkLinksFromNode(n));
-ol.format.KML.prototype.readNetworkLinksFromNode = function(node) {
- n.localName == 'NetworkLink') {
- var obj = ol.xml.pushParseAndPop({}, ol.format.KML.NETWORK_LINK_PARSERS_,
- n, []);
- networkLinks.push(obj);
- * Read the regions of the KML.
- * @return {Array.<Object>} Regions.
- * @api
-ol.format.KML.prototype.readRegion = function(source) {
- var regions = [];
- ol.array.extend(regions, this.readRegionFromDocument(
- ol.array.extend(regions, this.readRegionFromNode(
- ol.array.extend(regions, this.readRegionFromDocument(doc));
- return regions;
- * @return {Array.<Object>} Region.
-ol.format.KML.prototype.readRegionFromDocument = function(doc) {
- var n, regions = [];
- ol.array.extend(regions, this.readRegionFromNode(n));
- return regions;
- * @api
-ol.format.KML.prototype.readRegionFromNode = function(node) {
- n.localName == 'Region') {
- var obj = ol.xml.pushParseAndPop({}, ol.format.KML.REGION_PARSERS_,
- n, []);
- regions.push(obj);
- return regions;
- * Read the projection from a KML source.
- * @function
- * @return {ol.proj.Projection} Projection.
- * @api
-ol.format.KML.prototype.readProjection;
- * @param {Node} node Node to append a TextNode with the color to.
- * @param {ol.Color|string} color Color.
- * @private
-ol.format.KML.writeColorTextNode_ = function(node, color) {
- var rgba = ol.color.asArray(color);
- var opacity = (rgba.length == 4) ? rgba[3] : 1;
- var abgr = [opacity * 255, rgba[2], rgba[1], rgba[0]];
- var i;
- for (i = 0; i < 4; ++i) {
- var hex = parseInt(abgr[i], 10).toString(16);
- abgr[i] = (hex.length == 1) ? '0' + hex : hex;
- ol.format.XSD.writeStringTextNode(node, abgr.join(''));
- * @param {Node} node Node to append a TextNode with the coordinates to.
- * @param {Array.<number>} coordinates Coordinates.
- * @private
-ol.format.KML.writeCoordinatesTextNode_ = function(node, coordinates, objectStack) {
- var context = objectStack[objectStack.length - 1];
- var layout = context['layout'];
- var stride = context['stride'];
- var dimension;
- if (layout == ol.geom.GeometryLayout.XY ||
- layout == ol.geom.GeometryLayout.XYM) {
- dimension = 2;
- } else if (layout == ol.geom.GeometryLayout.XYZ ||
- layout == ol.geom.GeometryLayout.XYZM) {
- dimension = 3;
- } else {
- ol.asserts.assert(false, 34); // Invalid geometry layout
- var d, i;
- var ii = coordinates.length;
- var text = '';
- if (ii > 0) {
- text += coordinates[0];
- for (d = 1; d < dimension; ++d) {
- text += ',' + coordinates[d];
- for (i = stride; i < ii; i += stride) {
- text += ' ' + coordinates[i];
- text += ',' + coordinates[i + d];
- ol.format.XSD.writeStringTextNode(node, text);
- * @param {{name: *, value: *}} pair Name value pair.
- * @private
-ol.format.KML.writeDataNode_ = function(node, pair, objectStack) {
- node.setAttribute('name', pair.name);
- var /** @type {ol.XmlNodeStackItem} */ context = {node: node};
- var value = pair.value;
- if (typeof value == 'object') {
- if (value !== null && value.displayName) {
- ol.xml.pushSerializeAndPop(context, ol.format.KML.EXTENDEDDATA_NODE_SERIALIZERS_,
- ol.xml.OBJECT_PROPERTY_NODE_FACTORY, [value.displayName], objectStack, ['displayName']);
- if (value !== null && value.value) {
- ol.xml.OBJECT_PROPERTY_NODE_FACTORY, [value.value], objectStack, ['value']);
- } else {
- ol.xml.OBJECT_PROPERTY_NODE_FACTORY, [value], objectStack, ['value']);
- * @param {Node} node Node to append a TextNode with the name to.
- * @param {string} name DisplayName.
- * @private
-ol.format.KML.writeDataNodeName_ = function(node, name) {
- ol.format.XSD.writeCDATASection(node, name);
- * @param {Node} node Node to append a CDATA Section with the value to.
- * @param {string} value Value.
- * @private
-ol.format.KML.writeDataNodeValue_ = function(node, value) {
- ol.format.XSD.writeStringTextNode(node, value);
- * @param {Array.<ol.Feature>} features Features.
- * @this {ol.format.KML}
- * @private
-ol.format.KML.writeDocument_ = function(node, features, objectStack) {
- ol.xml.pushSerializeAndPop(context, ol.format.KML.DOCUMENT_SERIALIZERS_,
- ol.format.KML.DOCUMENT_NODE_FACTORY_, features, objectStack, undefined,
- this);
- * @param {{names: Array<string>, values: (Array<*>)}} namesAndValues Names and values.
- * @private
-ol.format.KML.writeExtendedData_ = function(node, namesAndValues, objectStack) {
- var names = namesAndValues.names, values = namesAndValues.values;
- var length = names.length;
- for (var i = 0; i < length; i++) {
- ol.format.KML.DATA_NODE_FACTORY_, [{name: names[i], value: values[i]}], objectStack);
- * @param {Object} icon Icon object.
- * @private
-ol.format.KML.writeIcon_ = function(node, icon, objectStack) {
- var parentNode = objectStack[objectStack.length - 1].node;
- var orderedKeys = ol.format.KML.ICON_SEQUENCE_[parentNode.namespaceURI];
- var values = ol.xml.makeSequence(icon, orderedKeys);
- ol.format.KML.ICON_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
- values, objectStack, orderedKeys);
- orderedKeys =
- ol.format.KML.ICON_SEQUENCE_[ol.format.KML.GX_NAMESPACE_URIS_[0]];
- values = ol.xml.makeSequence(icon, orderedKeys);
- ol.xml.pushSerializeAndPop(context, ol.format.KML.ICON_SERIALIZERS_,
- ol.format.KML.GX_NODE_FACTORY_, values, objectStack, orderedKeys);
- * @param {ol.style.Icon} style Icon style.
- * @private
-ol.format.KML.writeIconStyle_ = function(node, style, objectStack) {
- var properties = {};
- var src = style.getSrc();
- var size = style.getSize();
- var iconImageSize = style.getImageSize();
- var iconProperties = {
- 'href': src
- if (size) {
- iconProperties['w'] = size[0];
- iconProperties['h'] = size[1];
- var anchor = style.getAnchor(); // top-left
- var origin = style.getOrigin(); // top-left
- if (origin && iconImageSize && origin[0] !== 0 && origin[1] !== size[1]) {
- iconProperties['x'] = origin[0];
- iconProperties['y'] = iconImageSize[1] - (origin[1] + size[1]);
- if (anchor && anchor[0] !== 0 && anchor[1] !== size[1]) {
- var /** @type {ol.KMLVec2_} */ hotSpot = {
- x: anchor[0],
- xunits: ol.style.IconAnchorUnits.PIXELS,
- y: size[1] - anchor[1],
- yunits: ol.style.IconAnchorUnits.PIXELS
- properties['hotSpot'] = hotSpot;
- properties['Icon'] = iconProperties;
- var scale = style.getScale();
- if (scale !== 1) {
- properties['scale'] = scale;
- var rotation = style.getRotation();
- if (rotation !== 0) {
- properties['heading'] = rotation; // 0-360
- var orderedKeys = ol.format.KML.ICON_STYLE_SEQUENCE_[parentNode.namespaceURI];
- var values = ol.xml.makeSequence(properties, orderedKeys);
- ol.xml.pushSerializeAndPop(context, ol.format.KML.ICON_STYLE_SERIALIZERS_,
- ol.xml.OBJECT_PROPERTY_NODE_FACTORY, values, objectStack, orderedKeys);
- * @param {ol.style.Text} style style.
- * @private
-ol.format.KML.writeLabelStyle_ = function(node, style, objectStack) {
- var fill = style.getFill();
- if (fill) {
- properties['color'] = fill.getColor();
- if (scale && scale !== 1) {
- var orderedKeys =
- ol.format.KML.LABEL_STYLE_SEQUENCE_[parentNode.namespaceURI];
- ol.xml.pushSerializeAndPop(context, ol.format.KML.LABEL_STYLE_SERIALIZERS_,
- * @param {ol.style.Stroke} style style.
- * @private
-ol.format.KML.writeLineStyle_ = function(node, style, objectStack) {
- 'color': style.getColor(),
- 'width': style.getWidth()
- var orderedKeys = ol.format.KML.LINE_STYLE_SEQUENCE_[parentNode.namespaceURI];
- ol.xml.pushSerializeAndPop(context, ol.format.KML.LINE_STYLE_SERIALIZERS_,
- * @param {ol.geom.Geometry} geometry Geometry.
- * @private
-ol.format.KML.writeMultiGeometry_ = function(node, geometry, objectStack) {
- /** @type {ol.XmlNodeStackItem} */
- var context = {node: node};
- var type = geometry.getType();
- /** @type {Array.<ol.geom.Geometry>} */
- var geometries;
- /** @type {function(*, Array.<*>, string=): (Node|undefined)} */
- var factory;
- if (type == ol.geom.GeometryType.GEOMETRY_COLLECTION) {
- geometries = /** @type {ol.geom.GeometryCollection} */ (geometry).getGeometries();
- factory = ol.format.KML.GEOMETRY_NODE_FACTORY_;
- } else if (type == ol.geom.GeometryType.MULTI_POINT) {
- geometries = /** @type {ol.geom.MultiPoint} */ (geometry).getPoints();
- factory = ol.format.KML.POINT_NODE_FACTORY_;
- } else if (type == ol.geom.GeometryType.MULTI_LINE_STRING) {
- geometries =
- (/** @type {ol.geom.MultiLineString} */ (geometry)).getLineStrings();
- factory = ol.format.KML.LINE_STRING_NODE_FACTORY_;
- } else if (type == ol.geom.GeometryType.MULTI_POLYGON) {
- geometries =
- (/** @type {ol.geom.MultiPolygon} */ (geometry)).getPolygons();
- factory = ol.format.KML.POLYGON_NODE_FACTORY_;
- } else {
- ol.asserts.assert(false, 39); // Unknown geometry type
- ol.format.KML.MULTI_GEOMETRY_SERIALIZERS_, factory,
- geometries, objectStack);
- * @param {ol.geom.LinearRing} linearRing Linear ring.
- * @private
-ol.format.KML.writeBoundaryIs_ = function(node, linearRing, objectStack) {
- ol.format.KML.BOUNDARY_IS_SERIALIZERS_,
- ol.format.KML.LINEAR_RING_NODE_FACTORY_, [linearRing], objectStack);
- * FIXME currently we do serialize arbitrary/custom feature properties
- * (ExtendedData).
- * @param {ol.Feature} feature Feature.
- * @private
-ol.format.KML.writePlacemark_ = function(node, feature, objectStack) {
- // set id
- if (feature.getId()) {
- node.setAttribute('id', feature.getId());
- // serialize properties (properties unknown to KML are not serialized)
- var properties = feature.getProperties();
- // don't export these to ExtendedData
- var filter = {'address': 1, 'description': 1, 'name': 1, 'open': 1,
- 'phoneNumber': 1, 'styleUrl': 1, 'visibility': 1};
- filter[feature.getGeometryName()] = 1;
- var keys = Object.keys(properties || {}).sort().filter(function(v) {
- return !filter[v];
- if (keys.length > 0) {
- var sequence = ol.xml.makeSequence(properties, keys);
- var namesAndValues = {names: keys, values: sequence};
- ol.xml.pushSerializeAndPop(context, ol.format.KML.PLACEMARK_SERIALIZERS_,
- ol.format.KML.EXTENDEDDATA_NODE_FACTORY_, [namesAndValues], objectStack);
- var styleFunction = feature.getStyleFunction();
- if (styleFunction) {
- // FIXME the styles returned by the style function are supposed to be
- // resolution-independent here
- var styles = styleFunction.call(feature, 0);
- if (styles) {
- var style = Array.isArray(styles) ? styles[0] : styles;
- if (this.writeStyles_) {
- properties['Style'] = style;
- var textStyle = style.getText();
- if (textStyle) {
- properties['name'] = textStyle.getText();
- var orderedKeys = ol.format.KML.PLACEMARK_SEQUENCE_[parentNode.namespaceURI];
- // serialize geometry
- var options = /** @type {olx.format.WriteOptions} */ (objectStack[0]);
- var geometry = feature.getGeometry();
- if (geometry) {
- geometry =
- ol.format.Feature.transformWithOptions(geometry, true, options);
- ol.format.KML.GEOMETRY_NODE_FACTORY_, [geometry], objectStack);
- * @param {ol.geom.SimpleGeometry} geometry Geometry.
- * @private
-ol.format.KML.writePrimitiveGeometry_ = function(node, geometry, objectStack) {
- var flatCoordinates = geometry.getFlatCoordinates();
- context['layout'] = geometry.getLayout();
- context['stride'] = geometry.getStride();
- ol.format.KML.PRIMITIVE_GEOMETRY_SERIALIZERS_,
- ol.format.KML.COORDINATES_NODE_FACTORY_,
- [flatCoordinates], objectStack);
- * @param {ol.geom.Polygon} polygon Polygon.
- * @private
-ol.format.KML.writePolygon_ = function(node, polygon, objectStack) {
- var linearRings = polygon.getLinearRings();
- var outerRing = linearRings.shift();
- // inner rings
- ol.format.KML.POLYGON_SERIALIZERS_,
- ol.format.KML.INNER_BOUNDARY_NODE_FACTORY_,
- linearRings, objectStack);
- // outer ring
- ol.format.KML.OUTER_BOUNDARY_NODE_FACTORY_,
- [outerRing], objectStack);
- * @param {ol.style.Fill} style Style.
- * @private
-ol.format.KML.writePolyStyle_ = function(node, style, objectStack) {
- ol.xml.pushSerializeAndPop(context, ol.format.KML.POLY_STYLE_SERIALIZERS_,
- ol.format.KML.COLOR_NODE_FACTORY_, [style.getColor()], objectStack);
- * @param {Node} node Node to append a TextNode with the scale to.
- * @private
-ol.format.KML.writeScaleTextNode_ = function(node, scale) {
- // the Math is to remove any excess decimals created by float arithmetic
- ol.format.XSD.writeDecimalTextNode(node,
- Math.round(scale * 1e6) / 1e6);
- * @param {ol.style.Style} style Style.
- * @private
-ol.format.KML.writeStyle_ = function(node, style, objectStack) {
- var fillStyle = style.getFill();
- var strokeStyle = style.getStroke();
- var imageStyle = style.getImage();
- if (imageStyle instanceof ol.style.Icon) {
- properties['IconStyle'] = imageStyle;
- if (textStyle) {
- properties['LabelStyle'] = textStyle;
- if (strokeStyle) {
- properties['LineStyle'] = strokeStyle;
- if (fillStyle) {
- properties['PolyStyle'] = fillStyle;
- var orderedKeys = ol.format.KML.STYLE_SEQUENCE_[parentNode.namespaceURI];
- ol.xml.pushSerializeAndPop(context, ol.format.KML.STYLE_SERIALIZERS_,
- * @param {Node} node Node to append a TextNode with the Vec2 to.
- * @param {ol.KMLVec2_} vec2 Vec2.
- * @private
-ol.format.KML.writeVec2_ = function(node, vec2) {
- node.setAttribute('x', vec2.x);
- node.setAttribute('y', vec2.y);
- node.setAttribute('xunits', vec2.xunits);
- node.setAttribute('yunits', vec2.yunits);
- * @const
- * @type {Object.<string, Array.<string>>}
- * @private
-ol.format.KML.KML_SEQUENCE_ = ol.xml.makeStructureNS(
- ol.format.KML.NAMESPACE_URIS_, [
- 'Document', 'Placemark'
- * @const
- * @type {Object.<string, Object.<string, ol.XmlSerializer>>}
- * @private
-ol.format.KML.KML_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'Document': ol.xml.makeChildAppender(ol.format.KML.writeDocument_),
- 'Placemark': ol.xml.makeChildAppender(ol.format.KML.writePlacemark_)
- * @const
- * @private
-ol.format.KML.DOCUMENT_SERIALIZERS_ = ol.xml.makeStructureNS(
- * @const
- * @private
-ol.format.KML.EXTENDEDDATA_NODE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'Data': ol.xml.makeChildAppender(ol.format.KML.writeDataNode_),
- 'value': ol.xml.makeChildAppender(ol.format.KML.writeDataNodeValue_),
- 'displayName': ol.xml.makeChildAppender(ol.format.KML.writeDataNodeName_)
- * @const
- * @type {Object.<string, string>}
- * @private
-ol.format.KML.GEOMETRY_TYPE_TO_NODENAME_ = {
- 'Point': 'Point',
- 'LineString': 'LineString',
- 'LinearRing': 'LinearRing',
- 'Polygon': 'Polygon',
- 'MultiPoint': 'MultiGeometry',
- 'MultiLineString': 'MultiGeometry',
- 'MultiPolygon': 'MultiGeometry',
- 'GeometryCollection': 'MultiGeometry'
- * @const
- * @private
-ol.format.KML.ICON_SEQUENCE_ = ol.xml.makeStructureNS(
- 'href'
- ol.xml.makeStructureNS(ol.format.KML.GX_NAMESPACE_URIS_, [
- 'x', 'y', 'w', 'h'
- * @const
- * @private
-ol.format.KML.ICON_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'href': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
- 'x': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'y': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'w': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'h': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode)
- * @const
- * @private
-ol.format.KML.ICON_STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
- 'scale', 'heading', 'Icon', 'hotSpot'
- * @const
- * @private
-ol.format.KML.ICON_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'Icon': ol.xml.makeChildAppender(ol.format.KML.writeIcon_),
- 'heading': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
- 'hotSpot': ol.xml.makeChildAppender(ol.format.KML.writeVec2_),
- 'scale': ol.xml.makeChildAppender(ol.format.KML.writeScaleTextNode_)
- * @const
- * @private
-ol.format.KML.LABEL_STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
- 'color', 'scale'
- * @const
- * @private
-ol.format.KML.LABEL_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'color': ol.xml.makeChildAppender(ol.format.KML.writeColorTextNode_),
- * @const
- * @private
-ol.format.KML.LINE_STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
- 'color', 'width'
- * @const
- * @private
-ol.format.KML.LINE_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'width': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode)
- * @const
- * @private
-ol.format.KML.BOUNDARY_IS_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'LinearRing': ol.xml.makeChildAppender(
- ol.format.KML.writePrimitiveGeometry_)
- * @const
- * @private
-ol.format.KML.MULTI_GEOMETRY_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'LineString': ol.xml.makeChildAppender(
- ol.format.KML.writePrimitiveGeometry_),
- 'Point': ol.xml.makeChildAppender(
- 'Polygon': ol.xml.makeChildAppender(ol.format.KML.writePolygon_),
- 'GeometryCollection': ol.xml.makeChildAppender(
- ol.format.KML.writeMultiGeometry_)
- * @const
- * @private
-ol.format.KML.PLACEMARK_SEQUENCE_ = ol.xml.makeStructureNS(
- 'name', 'open', 'visibility', 'address', 'phoneNumber', 'description',
- 'styleUrl', 'Style'
- * @const
- * @private
-ol.format.KML.PLACEMARK_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'ExtendedData': ol.xml.makeChildAppender(
- ol.format.KML.writeExtendedData_),
- 'MultiGeometry': ol.xml.makeChildAppender(
- ol.format.KML.writeMultiGeometry_),
- 'Style': ol.xml.makeChildAppender(ol.format.KML.writeStyle_),
- 'address': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'description': ol.xml.makeChildAppender(
- ol.format.XSD.writeStringTextNode),
- 'name': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'open': ol.xml.makeChildAppender(ol.format.XSD.writeBooleanTextNode),
- 'phoneNumber': ol.xml.makeChildAppender(
- 'styleUrl': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
- 'visibility': ol.xml.makeChildAppender(
- ol.format.XSD.writeBooleanTextNode)
- * @const
- * @private
-ol.format.KML.PRIMITIVE_GEOMETRY_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'coordinates': ol.xml.makeChildAppender(
- ol.format.KML.writeCoordinatesTextNode_)
- * @const
- * @private
-ol.format.KML.POLYGON_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'outerBoundaryIs': ol.xml.makeChildAppender(
- ol.format.KML.writeBoundaryIs_),
- 'innerBoundaryIs': ol.xml.makeChildAppender(
- * @const
- * @private
-ol.format.KML.POLY_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
- * @const
- * @private
-ol.format.KML.STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
- 'IconStyle', 'LabelStyle', 'LineStyle', 'PolyStyle'
- * @const
- * @private
-ol.format.KML.STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
- 'IconStyle': ol.xml.makeChildAppender(ol.format.KML.writeIconStyle_),
- 'LabelStyle': ol.xml.makeChildAppender(ol.format.KML.writeLabelStyle_),
- 'LineStyle': ol.xml.makeChildAppender(ol.format.KML.writeLineStyle_),
- 'PolyStyle': ol.xml.makeChildAppender(ol.format.KML.writePolyStyle_)
- * @const
- * @param {*} value Value.
- * @param {string=} opt_nodeName Node name.
- * @return {Node|undefined} Node.
- * @private
-ol.format.KML.GX_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
- return ol.xml.createElementNS(ol.format.KML.GX_NAMESPACE_URIS_[0],
- 'gx:' + opt_nodeName);
- * @const
- * @private
-ol.format.KML.DOCUMENT_NODE_FACTORY_ = function(value, objectStack,
- opt_nodeName) {
- return ol.xml.createElementNS(parentNode.namespaceURI, 'Placemark');
- * @const
- * @private
-ol.format.KML.GEOMETRY_NODE_FACTORY_ = function(value, objectStack,
- opt_nodeName) {
- if (value) {
- ol.format.KML.GEOMETRY_TYPE_TO_NODENAME_[/** @type {ol.geom.Geometry} */ (value).getType()]);
- * A factory for creating coordinates nodes.
- * @const
- * @type {function(*, Array.<*>, string=): (Node|undefined)}
- * @private
-ol.format.KML.COLOR_NODE_FACTORY_ = ol.xml.makeSimpleNodeFactory('color');
- * @const
- * @private
-ol.format.KML.COORDINATES_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('coordinates');
- * A factory for creating Data nodes.
- * @const
- * @type {function(*, Array.<*>): (Node|undefined)}
- * @private
-ol.format.KML.DATA_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('Data');
- * A factory for creating ExtendedData nodes.
- * @const
- * @private
-ol.format.KML.EXTENDEDDATA_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('ExtendedData');
- * A factory for creating innerBoundaryIs nodes.
- * @const
- * @private
-ol.format.KML.INNER_BOUNDARY_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('innerBoundaryIs');
- * A factory for creating Point nodes.
- * @const
- * @private
-ol.format.KML.POINT_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('Point');
- * A factory for creating LineString nodes.
- * @const
- * @private
-ol.format.KML.LINE_STRING_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('LineString');
- * A factory for creating LinearRing nodes.
- * @const
- * @private
-ol.format.KML.LINEAR_RING_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('LinearRing');
- * A factory for creating Polygon nodes.
- * @const
- * @private
-ol.format.KML.POLYGON_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('Polygon');
- * A factory for creating outerBoundaryIs nodes.
- * @const
- * @private
-ol.format.KML.OUTER_BOUNDARY_NODE_FACTORY_ =
- ol.xml.makeSimpleNodeFactory('outerBoundaryIs');
- * Encode an array of features in the KML format. GeometryCollections, MultiPoints,
- * MultiLineStrings, and MultiPolygons are output as MultiGeometries.
- * @function
- * @param {olx.format.WriteOptions=} opt_options Options.
- * @return {string} Result.
- * @api
-ol.format.KML.prototype.writeFeatures;
- * Encode an array of features in the KML format as an XML node. GeometryCollections,
- * MultiPoints, MultiLineStrings, and MultiPolygons are output as MultiGeometries.
- * @return {Node} Node.
- * @override
- * @api
-ol.format.KML.prototype.writeFeaturesNode = function(features, opt_options) {
- opt_options = this.adaptOptions(opt_options);
- var kml = ol.xml.createElementNS(ol.format.KML.NAMESPACE_URIS_[4], 'kml');
- var xmlnsUri = 'http://www.w3.org/2000/xmlns/';
- var xmlSchemaInstanceUri = 'http://www.w3.org/2001/XMLSchema-instance';
- ol.xml.setAttributeNS(kml, xmlnsUri, 'xmlns:gx',
- ol.format.KML.GX_NAMESPACE_URIS_[0]);
- ol.xml.setAttributeNS(kml, xmlnsUri, 'xmlns:xsi', xmlSchemaInstanceUri);
- ol.xml.setAttributeNS(kml, xmlSchemaInstanceUri, 'xsi:schemaLocation',
- ol.format.KML.SCHEMA_LOCATION_);
- var /** @type {ol.XmlNodeStackItem} */ context = {node: kml};
- if (features.length > 1) {
- properties['Document'] = features;
- } else if (features.length == 1) {
- properties['Placemark'] = features[0];
- var orderedKeys = ol.format.KML.KML_SEQUENCE_[kml.namespaceURI];
- ol.xml.pushSerializeAndPop(context, ol.format.KML.KML_SERIALIZERS_,
- ol.xml.OBJECT_PROPERTY_NODE_FACTORY, values, [opt_options], orderedKeys,
- this);
- return kml;
-goog.provide('ol.ext.pbf');
-/** @typedef {function(*)} */
-ol.ext.pbf;
-(function() {
-var exports = {};
-var module = {exports: exports};
-var define;
- * @fileoverview
- * @suppress {accessControls, ambiguousFunctionDecl, checkDebuggerStatement, checkRegExp, checkTypes, checkVars, const, constantProperty, deprecated, duplicate, es5Strict, fileoverviewTags, missingProperties, nonStandardJsDocs, strictModuleDepCheck, suspiciousCode, undefinedNames, undefinedVars, unknownDefines, unusedLocalVariables, uselessCode, visibility}
-(function(f){if(typeof exports==="object"&&typeof module!=="undefined"){module.exports=f()}else if(typeof define==="function"&&define.amd){define([],f)}else{var g;if(typeof window!=="undefined"){g=window}else if(typeof global!=="undefined"){g=global}else if(typeof self!=="undefined"){g=self}else{g=this}g.pbf = f()}})(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);var f=new Error("Cannot find module '"+o+"'");throw f.code="MODULE_NOT_FOUND",f}var l=n[o]={exports:{}};t[o][0].call(l.exports,function(e){var n=t[o][1][e];return s(n?n:e)},l,l.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(_dereq_,module,exports){
-exports.read = function (buffer, offset, isLE, mLen, nBytes) {
- var e, m
- var eLen = nBytes * 8 - mLen - 1
- var eMax = (1 << eLen) - 1
- var eBias = eMax >> 1
- var nBits = -7
- var i = isLE ? (nBytes - 1) : 0
- var d = isLE ? -1 : 1
- var s = buffer[offset + i]
- i += d
- e = s & ((1 << (-nBits)) - 1)
- s >>= (-nBits)
- nBits += eLen
- for (; nBits > 0; e = e * 256 + buffer[offset + i], i += d, nBits -= 8) {}
- m = e & ((1 << (-nBits)) - 1)
- e >>= (-nBits)
- nBits += mLen
- for (; nBits > 0; m = m * 256 + buffer[offset + i], i += d, nBits -= 8) {}
- if (e === 0) {
- e = 1 - eBias
- } else if (e === eMax) {
- return m ? NaN : ((s ? -1 : 1) * Infinity)
- } else {
- m = m + Math.pow(2, mLen)
- e = e - eBias
- return (s ? -1 : 1) * m * Math.pow(2, e - mLen)
-exports.write = function (buffer, value, offset, isLE, mLen, nBytes) {
- var e, m, c
- var rt = (mLen === 23 ? Math.pow(2, -24) - Math.pow(2, -77) : 0)
- var i = isLE ? 0 : (nBytes - 1)
- var d = isLE ? 1 : -1
- var s = value < 0 || (value === 0 && 1 / value < 0) ? 1 : 0
- value = Math.abs(value)
- if (isNaN(value) || value === Infinity) {
- m = isNaN(value) ? 1 : 0
- e = eMax
- } else {
- e = Math.floor(Math.log(value) / Math.LN2)
- if (value * (c = Math.pow(2, -e)) < 1) {
- e--
- c *= 2
- if (e + eBias >= 1) {
- value += rt / c
- } else {
- value += rt * Math.pow(2, 1 - eBias)
- if (value * c >= 2) {
- e++
- c /= 2
- if (e + eBias >= eMax) {
- m = 0
- e = eMax
- } else if (e + eBias >= 1) {
- m = (value * c - 1) * Math.pow(2, mLen)
- e = e + eBias
- } else {
- m = value * Math.pow(2, eBias - 1) * Math.pow(2, mLen)
- e = 0
- for (; mLen >= 8; buffer[offset + i] = m & 0xff, i += d, m /= 256, mLen -= 8) {}
- e = (e << mLen) | m
- eLen += mLen
- for (; eLen > 0; buffer[offset + i] = e & 0xff, i += d, e /= 256, eLen -= 8) {}
- buffer[offset + i - d] |= s * 128
-},{}],2:[function(_dereq_,module,exports){
-'use strict';
-module.exports = Pbf;
-var ieee754 = _dereq_('ieee754');
-function Pbf(buf) {
- this.buf = ArrayBuffer.isView && ArrayBuffer.isView(buf) ? buf : new Uint8Array(buf || 0);
- this.pos = 0;
- this.type = 0;
- this.length = this.buf.length;
-Pbf.Varint = 0; // varint: int32, int64, uint32, uint64, sint32, sint64, bool, enum
-Pbf.Fixed64 = 1; // 64-bit: double, fixed64, sfixed64
-Pbf.Bytes = 2; // length-delimited: string, bytes, embedded messages, packed repeated fields
-Pbf.Fixed32 = 5; // 32-bit: float, fixed32, sfixed32
-var SHIFT_LEFT_32 = (1 << 16) * (1 << 16),
- SHIFT_RIGHT_32 = 1 / SHIFT_LEFT_32;
-Pbf.prototype = {
- destroy: function() {
- this.buf = null;
- // === READING =================================================================
- readFields: function(readField, result, end) {
- end = end || this.length;
- while (this.pos < end) {
- var val = this.readVarint(),
- tag = val >> 3,
- startPos = this.pos;
- this.type = val & 0x7;
- readField(tag, result, this);
- if (this.pos === startPos) this.skip(val);
- return result;
- readMessage: function(readField, result) {
- return this.readFields(readField, result, this.readVarint() + this.pos);
- readFixed32: function() {
- var val = readUInt32(this.buf, this.pos);
- this.pos += 4;
- return val;
- readSFixed32: function() {
- var val = readInt32(this.buf, this.pos);
- this.pos += 4;
- return val;
- // 64-bit int handling is based on github.com/dpw/node-buffer-more-ints (MIT-licensed)
- readFixed64: function() {
- var val = readUInt32(this.buf, this.pos) + readUInt32(this.buf, this.pos + 4) * SHIFT_LEFT_32;
- this.pos += 8;
- return val;
- readSFixed64: function() {
- var val = readUInt32(this.buf, this.pos) + readInt32(this.buf, this.pos + 4) * SHIFT_LEFT_32;
- this.pos += 8;
- return val;
- readFloat: function() {
- var val = ieee754.read(this.buf, this.pos, true, 23, 4);
- this.pos += 4;
- return val;
- readDouble: function() {
- var val = ieee754.read(this.buf, this.pos, true, 52, 8);
- this.pos += 8;
- return val;
- readVarint: function(isSigned) {
- var buf = this.buf,
- val, b;
- b = buf[this.pos++]; val = b & 0x7f; if (b < 0x80) return val;
- b = buf[this.pos++]; val |= (b & 0x7f) << 7; if (b < 0x80) return val;
- b = buf[this.pos++]; val |= (b & 0x7f) << 14; if (b < 0x80) return val;
- b = buf[this.pos++]; val |= (b & 0x7f) << 21; if (b < 0x80) return val;
- b = buf[this.pos]; val |= (b & 0x0f) << 28;
- return readVarintRemainder(val, isSigned, this);
- readVarint64: function() { // for compatibility with v2.0.1
- return this.readVarint(true);
- readSVarint: function() {
- var num = this.readVarint();
- return num % 2 === 1 ? (num + 1) / -2 : num / 2; // zigzag encoding
- readBoolean: function() {
- return Boolean(this.readVarint());
- readString: function() {
- var end = this.readVarint() + this.pos,
- str = readUtf8(this.buf, this.pos, end);
- this.pos = end;
- return str;
- readBytes: function() {
- buffer = this.buf.subarray(this.pos, end);
- this.pos = end;
- return buffer;
- // verbose for performance reasons; doesn't affect gzipped size
- readPackedVarint: function(arr, isSigned) {
- var end = readPackedEnd(this);
- arr = arr || [];
- while (this.pos < end) arr.push(this.readVarint(isSigned));
- return arr;
- readPackedSVarint: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readSVarint());
- return arr;
- readPackedBoolean: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readBoolean());
- return arr;
- readPackedFloat: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readFloat());
- return arr;
- readPackedDouble: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readDouble());
- return arr;
- readPackedFixed32: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readFixed32());
- return arr;
- readPackedSFixed32: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readSFixed32());
- return arr;
- readPackedFixed64: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readFixed64());
- return arr;
- readPackedSFixed64: function(arr) {
- arr = arr || [];
- while (this.pos < end) arr.push(this.readSFixed64());
- return arr;
- skip: function(val) {
- var type = val & 0x7;
- if (type === Pbf.Varint) while (this.buf[this.pos++] > 0x7f) {}
- else if (type === Pbf.Bytes) this.pos = this.readVarint() + this.pos;
- else if (type === Pbf.Fixed32) this.pos += 4;
- else if (type === Pbf.Fixed64) this.pos += 8;
- else throw new Error('Unimplemented type: ' + type);
- // === WRITING =================================================================
- writeTag: function(tag, type) {
- this.writeVarint((tag << 3) | type);
- realloc: function(min) {
- var length = this.length || 16;
- while (length < this.pos + min) length *= 2;
- if (length !== this.length) {
- var buf = new Uint8Array(length);
- buf.set(this.buf);
- this.buf = buf;
- this.length = length;
- finish: function() {
- this.length = this.pos;
- this.pos = 0;
- return this.buf.subarray(0, this.length);
- writeFixed32: function(val) {
- this.realloc(4);
- writeInt32(this.buf, val, this.pos);
- this.pos += 4;
- writeSFixed32: function(val) {
- this.realloc(4);
- this.pos += 4;
- writeFixed64: function(val) {
- this.realloc(8);
- writeInt32(this.buf, val & -1, this.pos);
- writeInt32(this.buf, Math.floor(val * SHIFT_RIGHT_32), this.pos + 4);
- this.pos += 8;
- writeSFixed64: function(val) {
- this.realloc(8);
- this.pos += 8;
- writeVarint: function(val) {
- val = +val || 0;
- if (val > 0xfffffff || val < 0) {
- writeBigVarint(val, this);
- return;
- this.realloc(4);
- this.buf[this.pos++] = val & 0x7f | (val > 0x7f ? 0x80 : 0); if (val <= 0x7f) return;
- this.buf[this.pos++] = ((val >>>= 7) & 0x7f) | (val > 0x7f ? 0x80 : 0); if (val <= 0x7f) return;
- this.buf[this.pos++] = (val >>> 7) & 0x7f;
- writeSVarint: function(val) {
- this.writeVarint(val < 0 ? -val * 2 - 1 : val * 2);
- writeBoolean: function(val) {
- this.writeVarint(Boolean(val));
- writeString: function(str) {
- str = String(str);
- this.realloc(str.length * 4);
- this.pos++; // reserve 1 byte for short string length
- var startPos = this.pos;
- // write the string directly to the buffer and see how much was written
- this.pos = writeUtf8(this.buf, str, this.pos);
- var len = this.pos - startPos;
- if (len >= 0x80) makeRoomForExtraLength(startPos, len, this);
- // finally, write the message length in the reserved place and restore the position
- this.pos = startPos - 1;
- this.writeVarint(len);
- this.pos += len;
- writeFloat: function(val) {
- this.realloc(4);
- ieee754.write(this.buf, val, this.pos, true, 23, 4);
- this.pos += 4;
- writeDouble: function(val) {
- this.realloc(8);
- ieee754.write(this.buf, val, this.pos, true, 52, 8);
- this.pos += 8;
- writeBytes: function(buffer) {
- var len = buffer.length;
- this.realloc(len);
- for (var i = 0; i < len; i++) this.buf[this.pos++] = buffer[i];
- writeRawMessage: function(fn, obj) {
- this.pos++; // reserve 1 byte for short message length
- // write the message directly to the buffer and see how much was written
- fn(obj, this);
- this.pos += len;
- writeMessage: function(tag, fn, obj) {
- this.writeTag(tag, Pbf.Bytes);
- this.writeRawMessage(fn, obj);
- writePackedVarint: function(tag, arr) { this.writeMessage(tag, writePackedVarint, arr); },
- writePackedSVarint: function(tag, arr) { this.writeMessage(tag, writePackedSVarint, arr); },
- writePackedBoolean: function(tag, arr) { this.writeMessage(tag, writePackedBoolean, arr); },
- writePackedFloat: function(tag, arr) { this.writeMessage(tag, writePackedFloat, arr); },
- writePackedDouble: function(tag, arr) { this.writeMessage(tag, writePackedDouble, arr); },
- writePackedFixed32: function(tag, arr) { this.writeMessage(tag, writePackedFixed32, arr); },
- writePackedSFixed32: function(tag, arr) { this.writeMessage(tag, writePackedSFixed32, arr); },
- writePackedFixed64: function(tag, arr) { this.writeMessage(tag, writePackedFixed64, arr); },
- writePackedSFixed64: function(tag, arr) { this.writeMessage(tag, writePackedSFixed64, arr); },
- writeBytesField: function(tag, buffer) {
- this.writeBytes(buffer);
- writeFixed32Field: function(tag, val) {
- this.writeTag(tag, Pbf.Fixed32);
- this.writeFixed32(val);
- writeSFixed32Field: function(tag, val) {
- this.writeSFixed32(val);
- writeFixed64Field: function(tag, val) {
- this.writeTag(tag, Pbf.Fixed64);
- this.writeFixed64(val);
- writeSFixed64Field: function(tag, val) {
- this.writeSFixed64(val);
- writeVarintField: function(tag, val) {
- this.writeTag(tag, Pbf.Varint);
- this.writeVarint(val);
- writeSVarintField: function(tag, val) {
- this.writeSVarint(val);
- writeStringField: function(tag, str) {
- this.writeString(str);
- writeFloatField: function(tag, val) {
- this.writeFloat(val);
- writeDoubleField: function(tag, val) {
- this.writeDouble(val);
- writeBooleanField: function(tag, val) {
- this.writeVarintField(tag, Boolean(val));
-function readVarintRemainder(l, s, p) {
- var buf = p.buf,
- h, b;
- b = buf[p.pos++]; h = (b & 0x70) >> 4; if (b < 0x80) return toNum(l, h, s);
- b = buf[p.pos++]; h |= (b & 0x7f) << 3; if (b < 0x80) return toNum(l, h, s);
- b = buf[p.pos++]; h |= (b & 0x7f) << 10; if (b < 0x80) return toNum(l, h, s);
- b = buf[p.pos++]; h |= (b & 0x7f) << 17; if (b < 0x80) return toNum(l, h, s);
- b = buf[p.pos++]; h |= (b & 0x7f) << 24; if (b < 0x80) return toNum(l, h, s);
- b = buf[p.pos++]; h |= (b & 0x01) << 31; if (b < 0x80) return toNum(l, h, s);
- throw new Error('Expected varint not more than 10 bytes');
-function readPackedEnd(pbf) {
- return pbf.type === Pbf.Bytes ?
- pbf.readVarint() + pbf.pos : pbf.pos + 1;
-function toNum(low, high, isSigned) {
- if (isSigned) {
- return high * 0x100000000 + (low >>> 0);
- return ((high >>> 0) * 0x100000000) + (low >>> 0);
-function writeBigVarint(val, pbf) {
- var low, high;
- if (val >= 0) {
- low = (val % 0x100000000) | 0;
- high = (val / 0x100000000) | 0;
- } else {
- low = ~(-val % 0x100000000);
- high = ~(-val / 0x100000000);
- if (low ^ 0xffffffff) {
- low = (low + 1) | 0;
- } else {
- low = 0;
- high = (high + 1) | 0;
- if (val >= 0x10000000000000000 || val < -0x10000000000000000) {
- throw new Error('Given varint doesn\'t fit into 10 bytes');
- pbf.realloc(10);
- writeBigVarintLow(low, high, pbf);
- writeBigVarintHigh(high, pbf);
-function writeBigVarintLow(low, high, pbf) {
- pbf.buf[pbf.pos++] = low & 0x7f | 0x80; low >>>= 7;
- pbf.buf[pbf.pos] = low & 0x7f;
-function writeBigVarintHigh(high, pbf) {
- var lsb = (high & 0x07) << 4;
- pbf.buf[pbf.pos++] |= lsb | ((high >>>= 3) ? 0x80 : 0); if (!high) return;
- pbf.buf[pbf.pos++] = high & 0x7f | ((high >>>= 7) ? 0x80 : 0); if (!high) return;
- pbf.buf[pbf.pos++] = high & 0x7f;
-function makeRoomForExtraLength(startPos, len, pbf) {
- var extraLen =
- len <= 0x3fff ? 1 :
- len <= 0x1fffff ? 2 :
- len <= 0xfffffff ? 3 : Math.ceil(Math.log(len) / (Math.LN2 * 7));
- // if 1 byte isn't enough for encoding message length, shift the data to the right
- pbf.realloc(extraLen);
- for (var i = pbf.pos - 1; i >= startPos; i--) pbf.buf[i + extraLen] = pbf.buf[i];
-function writePackedVarint(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeVarint(arr[i]); }
-function writePackedSVarint(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeSVarint(arr[i]); }
-function writePackedFloat(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeFloat(arr[i]); }
-function writePackedDouble(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeDouble(arr[i]); }
-function writePackedBoolean(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeBoolean(arr[i]); }
-function writePackedFixed32(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeFixed32(arr[i]); }
-function writePackedSFixed32(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeSFixed32(arr[i]); }
-function writePackedFixed64(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeFixed64(arr[i]); }
-function writePackedSFixed64(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeSFixed64(arr[i]); }
-// Buffer code below from https://github.com/feross/buffer, MIT-licensed
-function readUInt32(buf, pos) {
- return ((buf[pos]) |
- (buf[pos + 1] << 8) |
- (buf[pos + 2] << 16)) +
- (buf[pos + 3] * 0x1000000);
-function writeInt32(buf, val, pos) {
- buf[pos] = val;
- buf[pos + 1] = (val >>> 8);
- buf[pos + 2] = (val >>> 16);
- buf[pos + 3] = (val >>> 24);
-function readInt32(buf, pos) {
- (buf[pos + 3] << 24);
-function readUtf8(buf, pos, end) {
- var str = '';
- var i = pos;
- while (i < end) {
- var b0 = buf[i];
- var c = null; // codepoint
- var bytesPerSequence =
- b0 > 0xEF ? 4 :
- b0 > 0xDF ? 3 :
- b0 > 0xBF ? 2 : 1;
- if (i + bytesPerSequence > end) break;
- var b1, b2, b3;
- if (bytesPerSequence === 1) {
- if (b0 < 0x80) {
- c = b0;
- } else if (bytesPerSequence === 2) {
- b1 = buf[i + 1];
- if ((b1 & 0xC0) === 0x80) {
- c = (b0 & 0x1F) << 0x6 | (b1 & 0x3F);
- if (c <= 0x7F) {
- c = null;
- } else if (bytesPerSequence === 3) {
- b1 = buf[i + 1];
- b2 = buf[i + 2];
- if ((b1 & 0xC0) === 0x80 && (b2 & 0xC0) === 0x80) {
- c = (b0 & 0xF) << 0xC | (b1 & 0x3F) << 0x6 | (b2 & 0x3F);
- if (c <= 0x7FF || (c >= 0xD800 && c <= 0xDFFF)) {
- c = null;
- } else if (bytesPerSequence === 4) {
- b1 = buf[i + 1];
- b2 = buf[i + 2];
- b3 = buf[i + 3];
- if ((b1 & 0xC0) === 0x80 && (b2 & 0xC0) === 0x80 && (b3 & 0xC0) === 0x80) {
- c = (b0 & 0xF) << 0x12 | (b1 & 0x3F) << 0xC | (b2 & 0x3F) << 0x6 | (b3 & 0x3F);
- if (c <= 0xFFFF || c >= 0x110000) {
- c = null;
- if (c === null) {
- c = 0xFFFD;
- bytesPerSequence = 1;
- } else if (c > 0xFFFF) {
- c -= 0x10000;
- str += String.fromCharCode(c >>> 10 & 0x3FF | 0xD800);
- c = 0xDC00 | c & 0x3FF;
- str += String.fromCharCode(c);
- i += bytesPerSequence;
- return str;
-function writeUtf8(buf, str, pos) {
- for (var i = 0, c, lead; i < str.length; i++) {
- c = str.charCodeAt(i); // code point
- if (c > 0xD7FF && c < 0xE000) {
- if (lead) {
- if (c < 0xDC00) {
- buf[pos++] = 0xEF;
- buf[pos++] = 0xBF;
- buf[pos++] = 0xBD;
- lead = c;
- continue;
- } else {
- c = lead - 0xD800 << 10 | c - 0xDC00 | 0x10000;
- lead = null;
- } else {
- if (c > 0xDBFF || (i + 1 === str.length)) {
- } else {
- lead = c;
- continue;
- } else if (lead) {
- lead = null;
- if (c < 0x80) {
- buf[pos++] = c;
- } else {
- if (c < 0x800) {
- buf[pos++] = c >> 0x6 | 0xC0;
- } else {
- if (c < 0x10000) {
- buf[pos++] = c >> 0xC | 0xE0;
- } else {
- buf[pos++] = c >> 0x12 | 0xF0;
- buf[pos++] = c >> 0xC & 0x3F | 0x80;
- buf[pos++] = c >> 0x6 & 0x3F | 0x80;
- buf[pos++] = c & 0x3F | 0x80;
- return pos;
-},{"ieee754":1}]},{},[2])(2)
-ol.ext.pbf = module.exports;
-goog.provide('ol.ext.vectortile');
-ol.ext.vectortile;
-(function() {
-var exports = {};
-var define;
- * @fileoverview
-(function(f){if(typeof exports==="object"&&typeof module!=="undefined"){module.exports=f()}else if(typeof define==="function"&&define.amd){define([],f)}else{var g;if(typeof window!=="undefined"){g=window}else if(typeof global!=="undefined"){g=global}else if(typeof self!=="undefined"){g=self}else{g=this}g.vectortile = f()}})(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);var f=new Error("Cannot find module '"+o+"'");throw f.code="MODULE_NOT_FOUND",f}var l=n[o]={exports:{}};t[o][0].call(l.exports,function(e){var n=t[o][1][e];return s(n?n:e)},l,l.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(_dereq_,module,exports){
-'use strict';
-module.exports = Point;
-function Point(x, y) {
- this.x = x;
- this.y = y;
-Point.prototype = {
- clone: function() { return new Point(this.x, this.y); },
- add: function(p) { return this.clone()._add(p); },
- sub: function(p) { return this.clone()._sub(p); },
- mult: function(k) { return this.clone()._mult(k); },
- div: function(k) { return this.clone()._div(k); },
- rotate: function(a) { return this.clone()._rotate(a); },
- matMult: function(m) { return this.clone()._matMult(m); },
- unit: function() { return this.clone()._unit(); },
- perp: function() { return this.clone()._perp(); },
- round: function() { return this.clone()._round(); },
- mag: function() {
- return Math.sqrt(this.x * this.x + this.y * this.y);
- equals: function(p) {
- return this.x === p.x &&
- this.y === p.y;
- dist: function(p) {
- return Math.sqrt(this.distSqr(p));
- distSqr: function(p) {
- var dx = p.x - this.x,
- dy = p.y - this.y;
- return dx * dx + dy * dy;
- angle: function() {
- return Math.atan2(this.y, this.x);
- angleTo: function(b) {
- return Math.atan2(this.y - b.y, this.x - b.x);
- angleWith: function(b) {
- return this.angleWithSep(b.x, b.y);
- // Find the angle of the two vectors, solving the formula for the cross product a x b = |a||b|sin(θ) for θ.
- angleWithSep: function(x, y) {
- this.x * y - this.y * x,
- this.x * x + this.y * y);
- _matMult: function(m) {
- var x = m[0] * this.x + m[1] * this.y,
- y = m[2] * this.x + m[3] * this.y;
- this.x = x;
- this.y = y;
- return this;
- _add: function(p) {
- this.x += p.x;
- this.y += p.y;
- return this;
- _sub: function(p) {
- this.x -= p.x;
- this.y -= p.y;
- return this;
- _mult: function(k) {
- this.x *= k;
- this.y *= k;
- return this;
- _div: function(k) {
- this.x /= k;
- this.y /= k;
- return this;
- _unit: function() {
- this._div(this.mag());
- return this;
- _perp: function() {
- var y = this.y;
- this.y = this.x;
- this.x = -y;
- return this;
- _rotate: function(angle) {
- var cos = Math.cos(angle),
- sin = Math.sin(angle),
- x = cos * this.x - sin * this.y,
- y = sin * this.x + cos * this.y;
- this.x = x;
- this.y = y;
- return this;
- _round: function() {
- this.x = Math.round(this.x);
- this.y = Math.round(this.y);
- return this;
-// constructs Point from an array if necessary
-Point.convert = function (a) {
- if (a instanceof Point) {
- return a;
- if (Array.isArray(a)) {
- return new Point(a[0], a[1]);
- return a;
-module.exports.VectorTile = _dereq_('./lib/vectortile.js');
-module.exports.VectorTileFeature = _dereq_('./lib/vectortilefeature.js');
-module.exports.VectorTileLayer = _dereq_('./lib/vectortilelayer.js');
-},{"./lib/vectortile.js":3,"./lib/vectortilefeature.js":4,"./lib/vectortilelayer.js":5}],3:[function(_dereq_,module,exports){
-'use strict';
-var VectorTileLayer = _dereq_('./vectortilelayer');
-module.exports = VectorTile;
-function VectorTile(pbf, end) {
- this.layers = pbf.readFields(readTile, {}, end);
-function readTile(tag, layers, pbf) {
- if (tag === 3) {
- var layer = new VectorTileLayer(pbf, pbf.readVarint() + pbf.pos);
- if (layer.length) layers[layer.name] = layer;
-},{"./vectortilelayer":5}],4:[function(_dereq_,module,exports){
-'use strict';
-var Point = _dereq_('point-geometry');
-module.exports = VectorTileFeature;
-function VectorTileFeature(pbf, end, extent, keys, values) {
- // Public
- this.properties = {};
- this.extent = extent;
- this.type = 0;
- // Private
- this._pbf = pbf;
- this._geometry = -1;
- this._keys = keys;
- this._values = values;
- pbf.readFields(readFeature, this, end);
-function readFeature(tag, feature, pbf) {
- if (tag == 1) feature.id = pbf.readVarint();
- else if (tag == 2) readTag(pbf, feature);
- else if (tag == 3) feature.type = pbf.readVarint();
- else if (tag == 4) feature._geometry = pbf.pos;
-function readTag(pbf, feature) {
- var end = pbf.readVarint() + pbf.pos;
- while (pbf.pos < end) {
- var key = feature._keys[pbf.readVarint()],
- value = feature._values[pbf.readVarint()];
- feature.properties[key] = value;
-VectorTileFeature.types = ['Unknown', 'Point', 'LineString', 'Polygon'];
-VectorTileFeature.prototype.loadGeometry = function() {
- var pbf = this._pbf;
- pbf.pos = this._geometry;
- var end = pbf.readVarint() + pbf.pos,
- cmd = 1,
- length = 0,
- x = 0,
- y = 0,
- lines = [],
- line;
- if (!length) {
- var cmdLen = pbf.readVarint();
- cmd = cmdLen & 0x7;
- length = cmdLen >> 3;
- length--;
- if (cmd === 1 || cmd === 2) {
- x += pbf.readSVarint();
- y += pbf.readSVarint();
- if (cmd === 1) { // moveTo
- if (line) lines.push(line);
- line = [];
- line.push(new Point(x, y));
- } else if (cmd === 7) {
- // Workaround for https://github.com/mapbox/mapnik-vector-tile/issues/90
- if (line) {
- line.push(line[0].clone()); // closePolygon
- } else {
- throw new Error('unknown command ' + cmd);
- return lines;
-VectorTileFeature.prototype.bbox = function() {
- cmd = 1,
- length = 0,
- x = 0,
- y = 0,
- x1 = Infinity,
- x2 = -Infinity,
- y1 = Infinity,
- y2 = -Infinity;
- if (!length) {
- length--;
- if (x < x1) x1 = x;
- if (x > x2) x2 = x;
- if (y < y1) y1 = y;
- if (y > y2) y2 = y;
- } else if (cmd !== 7) {
- return [x1, y1, x2, y2];
-VectorTileFeature.prototype.toGeoJSON = function(x, y, z) {
- var size = this.extent * Math.pow(2, z),
- x0 = this.extent * x,
- y0 = this.extent * y,
- coords = this.loadGeometry(),
- type = VectorTileFeature.types[this.type],
- i, j;
- function project(line) {
- for (var j = 0; j < line.length; j++) {
- var p = line[j], y2 = 180 - (p.y + y0) * 360 / size;
- line[j] = [
- (p.x + x0) * 360 / size - 180,
- 360 / Math.PI * Math.atan(Math.exp(y2 * Math.PI / 180)) - 90
- switch (this.type) {
- case 1:
- var points = [];
- for (i = 0; i < coords.length; i++) {
- points[i] = coords[i][0];
- coords = points;
- project(coords);
- break;
- case 2:
- project(coords[i]);
- break;
- case 3:
- coords = classifyRings(coords);
- for (j = 0; j < coords[i].length; j++) {
- project(coords[i][j]);
- break;
- if (coords.length === 1) {
- coords = coords[0];
- } else {
- type = 'Multi' + type;
- var result = {
- type: "Feature",
- geometry: {
- type: type,
- coordinates: coords
- properties: this.properties
- if ('id' in this) {
- result.id = this.id;
- return result;
-// classifies an array of rings into polygons with outer rings and holes
-function classifyRings(rings) {
- var len = rings.length;
- if (len <= 1) return [rings];
- var polygons = [],
- polygon,
- ccw;
- for (var i = 0; i < len; i++) {
- var area = signedArea(rings[i]);
- if (area === 0) continue;
- if (ccw === undefined) ccw = area < 0;
- if (ccw === area < 0) {
- if (polygon) polygons.push(polygon);
- polygon = [rings[i]];
- } else {
- polygon.push(rings[i]);
- return polygons;
-function signedArea(ring) {
- var sum = 0;
- for (var i = 0, len = ring.length, j = len - 1, p1, p2; i < len; j = i++) {
- p1 = ring[i];
- p2 = ring[j];
- sum += (p2.x - p1.x) * (p1.y + p2.y);
- return sum;
-},{"point-geometry":1}],5:[function(_dereq_,module,exports){
-'use strict';
-var VectorTileFeature = _dereq_('./vectortilefeature.js');
-module.exports = VectorTileLayer;
-function VectorTileLayer(pbf, end) {
- // Public
- this.version = 1;
- this.name = null;
- this.extent = 4096;
- this.length = 0;
- // Private
- this._pbf = pbf;
- this._keys = [];
- this._values = [];
- this._features = [];
- pbf.readFields(readLayer, this, end);
- this.length = this._features.length;
-function readLayer(tag, layer, pbf) {
- if (tag === 15) layer.version = pbf.readVarint();
- else if (tag === 1) layer.name = pbf.readString();
- else if (tag === 5) layer.extent = pbf.readVarint();
- else if (tag === 2) layer._features.push(pbf.pos);
- else if (tag === 3) layer._keys.push(pbf.readString());
- else if (tag === 4) layer._values.push(readValueMessage(pbf));
-function readValueMessage(pbf) {
- var value = null,
- end = pbf.readVarint() + pbf.pos;
- var tag = pbf.readVarint() >> 3;
- value = tag === 1 ? pbf.readString() :
- tag === 2 ? pbf.readFloat() :
- tag === 3 ? pbf.readDouble() :
- tag === 4 ? pbf.readVarint64() :
- tag === 5 ? pbf.readVarint() :
- tag === 6 ? pbf.readSVarint() :
- tag === 7 ? pbf.readBoolean() : null;
- return value;
-// return feature `i` from this layer as a `VectorTileFeature`
-VectorTileLayer.prototype.feature = function(i) {
- if (i < 0 || i >= this._features.length) throw new Error('feature index out of bounds');
- this._pbf.pos = this._features[i];
- var end = this._pbf.readVarint() + this._pbf.pos;
- return new VectorTileFeature(this._pbf, end, this.extent, this._keys, this._values);
-},{"./vectortilefeature.js":4}]},{},[2])(2)
-ol.ext.vectortile = module.exports;
-goog.provide('ol.render.Feature');
-goog.require('ol');
-goog.require('ol.extent');
-goog.require('ol.geom.GeometryType');
- * Lightweight, read-only, {@link ol.Feature} and {@link ol.geom.Geometry} like
- * structure, optimized for rendering and styling. Geometry access through the
- * API is limited to getting the type and extent of the geometry.
- * @constructor
- * @param {ol.geom.GeometryType} type Geometry type.
- * @param {Array.<number>} flatCoordinates Flat coordinates. These always need
- * to be right-handed for polygons.
- * @param {Array.<number>|Array.<Array.<number>>} ends Ends or Endss.
- * @param {Object.<string, *>} properties Properties.
-ol.render.Feature = function(type, flatCoordinates, ends, properties) {
- * @private
- * @type {ol.Extent|undefined}
- this.extent_;
- * @private
- * @type {ol.geom.GeometryType}
- this.type_ = type;
- * @private
- * @type {Array.<number>}
- this.flatCoordinates_ = flatCoordinates;
- * @private
- * @type {Array.<number>|Array.<Array.<number>>}
- this.ends_ = ends;
- * @private
- * @type {Object.<string, *>}
- this.properties_ = properties;
- * Get a feature property by its key.
- * @param {string} key Key
- * @return {*} Value for the requested key.
- * @api
-ol.render.Feature.prototype.get = function(key) {
- return this.properties_[key];
- * @return {Array.<number>|Array.<Array.<number>>} Ends or endss.
-ol.render.Feature.prototype.getEnds = function() {
- return this.ends_;
- * Get the extent of this feature's geometry.
- * @return {ol.Extent} Extent.
- * @api
-ol.render.Feature.prototype.getExtent = function() {
- if (!this.extent_) {
- this.extent_ = this.type_ === ol.geom.GeometryType.POINT ?
- ol.extent.createOrUpdateFromCoordinate(this.flatCoordinates_) :
- ol.extent.createOrUpdateFromFlatCoordinates(
- this.flatCoordinates_, 0, this.flatCoordinates_.length, 2);
- return this.extent_;
- * @return {Array.<number>} Flat coordinates.
-ol.render.Feature.prototype.getOrientedFlatCoordinates = function() {
- return this.flatCoordinates_;
-ol.render.Feature.prototype.getFlatCoordinates =
- ol.render.Feature.prototype.getOrientedFlatCoordinates;
- * Get the feature for working with its geometry.
- * @return {ol.render.Feature} Feature.
- * @api
-ol.render.Feature.prototype.getGeometry = function() {
- return this;
- * Get the feature properties.
- * @return {Object.<string, *>} Feature properties.
- * @api
-ol.render.Feature.prototype.getProperties = function() {
- return this.properties_;
-ol.render.Feature.prototype.getSimplifiedGeometry =
- ol.render.Feature.prototype.getGeometry;
- * @return {number} Stride.
-ol.render.Feature.prototype.getStride = function() {
- return 2;
- * @return {undefined}
-ol.render.Feature.prototype.getStyleFunction = ol.nullFunction;
- * Get the type of this feature's geometry.
- * @return {ol.geom.GeometryType} Geometry type.
- * @api
-ol.render.Feature.prototype.getType = function() {
- return this.type_;
-//FIXME Implement projection handling
-goog.provide('ol.format.MVT');
-goog.require('ol.ext.pbf');
-goog.require('ol.ext.vectortile');
-goog.require('ol.format.Feature');
-goog.require('ol.format.FormatType');
-goog.require('ol.geom.GeometryLayout');
-goog.require('ol.geom.LineString');
-goog.require('ol.geom.MultiLineString');
-goog.require('ol.geom.MultiPoint');
-goog.require('ol.geom.Point');
-goog.require('ol.geom.Polygon');
-goog.require('ol.proj.Projection');
-goog.require('ol.proj.Units');
-goog.require('ol.render.Feature');
- * @classdesc
- * Feature format for reading data in the Mapbox MVT format.
- * @constructor
- * @extends {ol.format.Feature}
- * @param {olx.format.MVTOptions=} opt_options Options.
- * @api
-ol.format.MVT = function(opt_options) {
- ol.format.Feature.call(this);
- var options = opt_options ? opt_options : {};
- * @type {ol.proj.Projection}
- this.defaultDataProjection = new ol.proj.Projection({
- code: '',
- units: ol.proj.Units.TILE_PIXELS
- * @private
- * @type {function((ol.geom.Geometry|Object.<string, *>)=)|
- * function(ol.geom.GeometryType,Array.<number>,
- * (Array.<number>|Array.<Array.<number>>),Object.<string, *>)}
- this.featureClass_ = options.featureClass ?
- options.featureClass : ol.render.Feature;
- * @private
- * @type {string|undefined}
- this.geometryName_ = options.geometryName;
- * @private
- * @type {string}
- this.layerName_ = options.layerName ? options.layerName : 'layer';
- * @private
- * @type {Array.<string>}
- this.layers_ = options.layers ? options.layers : null;
-ol.inherits(ol.format.MVT, ol.format.Feature);
- * @inheritDoc
-ol.format.MVT.prototype.getType = function() {
- return ol.format.FormatType.ARRAY_BUFFER;
- * @private
- * @param {Object} rawFeature Raw Mapbox feature.
- * @param {string} layer Layer.
-ol.format.MVT.prototype.readFeature_ = function(
- rawFeature, layer, opt_options) {
- var feature = new this.featureClass_();
- var id = rawFeature.id;
- var values = rawFeature.properties;
- values[this.layerName_] = layer;
- if (this.geometryName_) {
- feature.setGeometryName(this.geometryName_);
- var geometry = ol.format.Feature.transformWithOptions(
- ol.format.MVT.readGeometry_(rawFeature), false,
- this.adaptOptions(opt_options));
- feature.setId(id);
- feature.setProperties(values);
- return feature;
- * @private
-ol.format.MVT.prototype.readRenderFeature_ = function(rawFeature, layer) {
- var coords = rawFeature.loadGeometry();
- var ends = [];
- var flatCoordinates = [];
- ol.format.MVT.calculateFlatCoordinates_(coords, flatCoordinates, ends);
- var type = rawFeature.type;
- /** @type {ol.geom.GeometryType} */
- var geometryType;
- if (type === 1) {
- geometryType = coords.length === 1 ?
- ol.geom.GeometryType.POINT : ol.geom.GeometryType.MULTI_POINT;
- } else if (type === 2) {
- geometryType = ol.geom.GeometryType.LINE_STRING;
- } else {
- geometryType = ol.geom.GeometryType.MULTI_LINE_STRING;
- } else if (type === 3) {
- geometryType = ol.geom.GeometryType.POLYGON;
- return new this.featureClass_(geometryType, flatCoordinates, ends, values);
- * @inheritDoc
- * @api
-ol.format.MVT.prototype.readFeatures = function(source, opt_options) {
- var layers = this.layers_;
- var pbf = new ol.ext.pbf(/** @type {ArrayBuffer} */ (source));
- var tile = new ol.ext.vectortile.VectorTile(pbf);
- var features = [];
- var featureClass = this.featureClass_;
- var layer, feature;
- for (var name in tile.layers) {
- if (layers && layers.indexOf(name) == -1) {
- continue;
- layer = tile.layers[name];
- for (var i = 0, ii = layer.length; i < ii; ++i) {
- if (featureClass === ol.render.Feature) {
- feature = this.readRenderFeature_(layer.feature(i), name);
- } else {
- feature = this.readFeature_(layer.feature(i), name, opt_options);
- features.push(feature);
- return features;
- * @inheritDoc
- * @api
-ol.format.MVT.prototype.readProjection = function(source) {
- return this.defaultDataProjection;
- * Sets the layers that features will be read from.
- * @param {Array.<string>} layers Layers.
- * @api
-ol.format.MVT.prototype.setLayers = function(layers) {
- this.layers_ = layers;
- * @private
- * @param {Object} coords Raw feature coordinates.
- * @param {Array.<number>} flatCoordinates Flat coordinates to be populated by
- * this function.
- * @param {Array.<number>} ends Ends to be populated by this function.
-ol.format.MVT.calculateFlatCoordinates_ = function(
- coords, flatCoordinates, ends) {
- var end = 0;
- for (var i = 0, ii = coords.length; i < ii; ++i) {
- var line = coords[i];
- var j, jj;
- for (j = 0, jj = line.length; j < jj; ++j) {
- var coord = line[j];
- // Non-tilespace coords can be calculated here when a TileGrid and
- // TileCoord are known.
- flatCoordinates.push(coord.x, coord.y);
- end += 2 * j;
- ends.push(end);
- * @private
- * @return {ol.geom.Geometry} Geometry.
-ol.format.MVT.readGeometry_ = function(rawFeature) {
- if (type === 0) {
- return null;
- var ends = [];
- var geom;
- if (type === 1) {
- geom = coords.length === 1 ?
- new ol.geom.Point(null) : new ol.geom.MultiPoint(null);
- geom = new ol.geom.LineString(null);
- } else {
- geom = new ol.geom.MultiLineString(null);
- geom = new ol.geom.Polygon(null);
- geom.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates,
- ends);
- return geom;
- * Not implemented.
- * @override
-ol.format.MVT.prototype.readFeature = function() {};
- * @override
-ol.format.MVT.prototype.readGeometry = function() {};
- * @override
-ol.format.MVT.prototype.writeFeature = function() {};
- * @override
-ol.format.MVT.prototype.writeGeometry = function() {};
- * @override
-ol.format.MVT.prototype.writeFeatures = function() {};
-// FIXME add typedef for stack state objects
-goog.provide('ol.format.OSMXML');
-goog.require('ol.array');
-goog.require('ol.Feature');
-goog.require('ol.format.XMLFeature');
-goog.require('ol.obj');
-goog.require('ol.proj');
-goog.require('ol.xml');
- * @classdesc
- * [OSMXML format](http://wiki.openstreetmap.org/wiki/OSM_XML).
- * @constructor
- * @extends {ol.format.XMLFeature}
- * @api
-ol.format.OSMXML = function() {
- ol.format.XMLFeature.call(this);
- * @inheritDoc
- this.defaultDataProjection = ol.proj.get('EPSG:4326');
-ol.inherits(ol.format.OSMXML, ol.format.XMLFeature);
- * @param {Node} node Node.
- * @param {Array.<*>} objectStack Object stack.
- * @private
-ol.format.OSMXML.readNode_ = function(node, objectStack) {
- var options = /** @type {olx.format.ReadOptions} */ (objectStack[0]);
- var state = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var id = node.getAttribute('id');
- /** @type {ol.Coordinate} */
- var coordinates = [
- parseFloat(node.getAttribute('lon')),
- parseFloat(node.getAttribute('lat'))
- state.nodes[id] = coordinates;
- var values = ol.xml.pushParseAndPop({
- tags: {}
- }, ol.format.OSMXML.NODE_PARSERS_, node, objectStack);
- if (!ol.obj.isEmpty(values.tags)) {
- var geometry = new ol.geom.Point(coordinates);
- ol.format.Feature.transformWithOptions(geometry, false, options);
- var feature = new ol.Feature(geometry);
- feature.setProperties(values.tags);
- state.features.push(feature);
- * @private
-ol.format.OSMXML.readWay_ = function(node, objectStack) {
- ndrefs: [],
- tags: {}
- }, ol.format.OSMXML.WAY_PARSERS_, node, objectStack);
- /** @type {Array.<number>} */
- for (var i = 0, ii = values.ndrefs.length; i < ii; i++) {
- var point = state.nodes[values.ndrefs[i]];
- ol.array.extend(flatCoordinates, point);
- var geometry;
- if (values.ndrefs[0] == values.ndrefs[values.ndrefs.length - 1]) {
- // closed way
- geometry = new ol.geom.Polygon(null);
- geometry.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates,
- [flatCoordinates.length]);
- } else {
- geometry = new ol.geom.LineString(null);
- geometry.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates);
- * @private
-ol.format.OSMXML.readNd_ = function(node, objectStack) {
- var values = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- values.ndrefs.push(node.getAttribute('ref'));
- * @private
-ol.format.OSMXML.readTag_ = function(node, objectStack) {
- values.tags[node.getAttribute('k')] = node.getAttribute('v');
- * @const
- * @private
-ol.format.OSMXML.NAMESPACE_URIS_ = [
- null
- * @const
- * @type {Object.<string, Object.<string, ol.XmlParser>>}
- * @private
-ol.format.OSMXML.WAY_PARSERS_ = ol.xml.makeStructureNS(
- ol.format.OSMXML.NAMESPACE_URIS_, {
- 'nd': ol.format.OSMXML.readNd_,
- 'tag': ol.format.OSMXML.readTag_
- * @const
- * @private
-ol.format.OSMXML.PARSERS_ = ol.xml.makeStructureNS(
- 'node': ol.format.OSMXML.readNode_,
- 'way': ol.format.OSMXML.readWay_
- * @const
- * @private
-ol.format.OSMXML.NODE_PARSERS_ = ol.xml.makeStructureNS(
- * Read all features from an OSM source.
- * @function
- * @param {Document|Node|Object|string} source Source.
- * @param {olx.format.ReadOptions=} opt_options Read options.
- * @return {Array.<ol.Feature>} Features.
- * @api
-ol.format.OSMXML.prototype.readFeatures;
- * @inheritDoc
-ol.format.OSMXML.prototype.readFeaturesFromNode = function(node, opt_options) {
- var options = this.getReadOptions(node, opt_options);
- if (node.localName == 'osm') {
- var state = ol.xml.pushParseAndPop({
- nodes: {},
- features: []
- }, ol.format.OSMXML.PARSERS_, node, [options]);
- if (state.features) {
- return state.features;
- return [];
- * Read the projection from an OSM source.
- * @function
- * @return {ol.proj.Projection} Projection.
- * @api
-ol.format.OSMXML.prototype.readProjection;
- * @inheritDoc
-ol.format.OSMXML.prototype.writeFeatureNode = function(feature, opt_options) {};
- * @inheritDoc
-ol.format.OSMXML.prototype.writeFeaturesNode = function(features, opt_options) {};
- * @inheritDoc
-ol.format.OSMXML.prototype.writeGeometryNode = function(geometry, opt_options) {};
-goog.provide('ol.format.XLink');
- * @const
- * @type {string}
-ol.format.XLink.NAMESPACE_URI = 'http://www.w3.org/1999/xlink';
- * @return {boolean|undefined} Boolean.
-ol.format.XLink.readHref = function(node) {
- return node.getAttributeNS(ol.format.XLink.NAMESPACE_URI, 'href');
-goog.provide('ol.format.XML');
- * @classdesc
- * Generic format for reading non-feature XML data
- * @constructor
- * @abstract
- * @struct
-ol.format.XML = function() {
- * @param {Document|Node|string} source Source.
- * @return {Object} The parsed result.
-ol.format.XML.prototype.read = function(source) {
- if (ol.xml.isDocument(source)) {
- return this.readFromDocument(/** @type {Document} */ (source));
- } else if (ol.xml.isNode(source)) {
- return this.readFromNode(/** @type {Node} */ (source));
- } else if (typeof source === 'string') {
- var doc = ol.xml.parse(source);
- return this.readFromDocument(doc);
- } else {
- return null;
- * @abstract
- * @param {Document} doc Document.
- * @return {Object} Object
-ol.format.XML.prototype.readFromDocument = function(doc) {};
- * @abstract
-ol.format.XML.prototype.readFromNode = function(node) {};
-goog.provide('ol.format.OWS');
-goog.require('ol.format.XLink');
-goog.require('ol.format.XML');
-goog.require('ol.format.XSD');
- * @constructor
- * @extends {ol.format.XML}
-ol.format.OWS = function() {
- ol.format.XML.call(this);
-ol.inherits(ol.format.OWS, ol.format.XML);
- * @inheritDoc
-ol.format.OWS.prototype.readFromDocument = function(doc) {
- for (var n = doc.firstChild; n; n = n.nextSibling) {
- if (n.nodeType == Node.ELEMENT_NODE) {
- return this.readFromNode(n);
- return null;
- * @inheritDoc
-ol.format.OWS.prototype.readFromNode = function(node) {
- var owsObject = ol.xml.pushParseAndPop({},
- ol.format.OWS.PARSERS_, node, []);
- return owsObject ? owsObject : null;
- * @private
- * @return {Object|undefined} The address.
-ol.format.OWS.readAddress_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop({},
- ol.format.OWS.ADDRESS_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} The values.
-ol.format.OWS.readAllowedValues_ = function(node, objectStack) {
- ol.format.OWS.ALLOWED_VALUES_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} The constraint.
-ol.format.OWS.readConstraint_ = function(node, objectStack) {
- var name = node.getAttribute('name');
- if (!name) {
- return undefined;
- return ol.xml.pushParseAndPop({'name': name},
- ol.format.OWS.CONSTRAINT_PARSERS_, node,
- objectStack);
- * @private
- * @return {Object|undefined} The contact info.
-ol.format.OWS.readContactInfo_ = function(node, objectStack) {
- ol.format.OWS.CONTACT_INFO_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} The DCP.
-ol.format.OWS.readDcp_ = function(node, objectStack) {
- ol.format.OWS.DCP_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} The GET object.
-ol.format.OWS.readGet_ = function(node, objectStack) {
- var href = ol.format.XLink.readHref(node);
- if (!href) {
- return undefined;
- return ol.xml.pushParseAndPop({'href': href},
- ol.format.OWS.REQUEST_METHOD_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} The HTTP object.
-ol.format.OWS.readHttp_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop({}, ol.format.OWS.HTTP_PARSERS_,
- node, objectStack);
- * @private
- * @return {Object|undefined} The operation.
-ol.format.OWS.readOperation_ = function(node, objectStack) {
- var value = ol.xml.pushParseAndPop({},
- ol.format.OWS.OPERATION_PARSERS_, node, objectStack);
- if (!value) {
- return undefined;
- var object = /** @type {Object} */
- (objectStack[objectStack.length - 1]);
- object[name] = value;
- * @private
- * @return {Object|undefined} The operations metadata.
-ol.format.OWS.readOperationsMetadata_ = function(node,
- objectStack) {
- ol.format.OWS.OPERATIONS_METADATA_PARSERS_, node,
- objectStack);
- * @private
- * @return {Object|undefined} The phone.
-ol.format.OWS.readPhone_ = function(node, objectStack) {
- ol.format.OWS.PHONE_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} The service identification.
-ol.format.OWS.readServiceIdentification_ = function(node,
- objectStack) {
- {}, ol.format.OWS.SERVICE_IDENTIFICATION_PARSERS_, node,
- objectStack);
- * @private
- * @return {Object|undefined} The service contact.
-ol.format.OWS.readServiceContact_ = function(node, objectStack) {
- {}, ol.format.OWS.SERVICE_CONTACT_PARSERS_, node,
- objectStack);
- * @private
- * @return {Object|undefined} The service provider.
-ol.format.OWS.readServiceProvider_ = function(node, objectStack) {
- {}, ol.format.OWS.SERVICE_PROVIDER_PARSERS_, node,
- objectStack);
- * @private
- * @return {string|undefined} The value.
-ol.format.OWS.readValue_ = function(node, objectStack) {
- return ol.format.XSD.readString(node);
- * @const
- * @private
-ol.format.OWS.NAMESPACE_URIS_ = [
- null,
- 'http://www.opengis.net/ows/1.1'
- * @const
- * @private
-ol.format.OWS.PARSERS_ = ol.xml.makeStructureNS(
- ol.format.OWS.NAMESPACE_URIS_, {
- 'ServiceIdentification': ol.xml.makeObjectPropertySetter(
- ol.format.OWS.readServiceIdentification_),
- 'ServiceProvider': ol.xml.makeObjectPropertySetter(
- ol.format.OWS.readServiceProvider_),
- 'OperationsMetadata': ol.xml.makeObjectPropertySetter(
- ol.format.OWS.readOperationsMetadata_)
- * @const
- * @private
-ol.format.OWS.ADDRESS_PARSERS_ = ol.xml.makeStructureNS(
- 'DeliveryPoint': ol.xml.makeObjectPropertySetter(
- ol.format.XSD.readString),
- 'City': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'AdministrativeArea': ol.xml.makeObjectPropertySetter(
- 'PostalCode': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'Country': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'ElectronicMailAddress': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.OWS.ALLOWED_VALUES_PARSERS_ = ol.xml.makeStructureNS(
- 'Value': ol.xml.makeObjectPropertyPusher(ol.format.OWS.readValue_)
- * @const
- * @private
-ol.format.OWS.CONSTRAINT_PARSERS_ = ol.xml.makeStructureNS(
- 'AllowedValues': ol.xml.makeObjectPropertySetter(
- ol.format.OWS.readAllowedValues_)
- * @const
- * @private
-ol.format.OWS.CONTACT_INFO_PARSERS_ = ol.xml.makeStructureNS(
- 'Phone': ol.xml.makeObjectPropertySetter(ol.format.OWS.readPhone_),
- 'Address': ol.xml.makeObjectPropertySetter(ol.format.OWS.readAddress_)
- * @const
- * @private
-ol.format.OWS.DCP_PARSERS_ = ol.xml.makeStructureNS(
- 'HTTP': ol.xml.makeObjectPropertySetter(ol.format.OWS.readHttp_)
- * @const
- * @private
-ol.format.OWS.HTTP_PARSERS_ = ol.xml.makeStructureNS(
- 'Get': ol.xml.makeObjectPropertyPusher(ol.format.OWS.readGet_),
- 'Post': undefined // TODO
- * @const
- * @private
-ol.format.OWS.OPERATION_PARSERS_ = ol.xml.makeStructureNS(
- 'DCP': ol.xml.makeObjectPropertySetter(ol.format.OWS.readDcp_)
- * @const
- * @private
-ol.format.OWS.OPERATIONS_METADATA_PARSERS_ = ol.xml.makeStructureNS(
- 'Operation': ol.format.OWS.readOperation_
- * @const
- * @private
-ol.format.OWS.PHONE_PARSERS_ = ol.xml.makeStructureNS(
- 'Voice': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'Facsimile': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
- * @const
- * @private
-ol.format.OWS.REQUEST_METHOD_PARSERS_ = ol.xml.makeStructureNS(
- 'Constraint': ol.xml.makeObjectPropertyPusher(
- ol.format.OWS.readConstraint_)
- * @const
- * @private
-ol.format.OWS.SERVICE_CONTACT_PARSERS_ =
- 'IndividualName': ol.xml.makeObjectPropertySetter(
- 'PositionName': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'ContactInfo': ol.xml.makeObjectPropertySetter(
- ol.format.OWS.readContactInfo_)
- * @const
- * @private
-ol.format.OWS.SERVICE_IDENTIFICATION_PARSERS_ =
- 'Title': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'ServiceTypeVersion': ol.xml.makeObjectPropertySetter(
- 'ServiceType': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
- * @const
- * @private
-ol.format.OWS.SERVICE_PROVIDER_PARSERS_ =
- 'ProviderName': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'ProviderSite': ol.xml.makeObjectPropertySetter(ol.format.XLink.readHref),
- 'ServiceContact': ol.xml.makeObjectPropertySetter(
- ol.format.OWS.readServiceContact_)
-goog.provide('ol.geom.flat.flip');
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
- * @param {Array.<number>=} opt_dest Destination.
- * @param {number=} opt_destOffset Destination offset.
-ol.geom.flat.flip.flipXY = function(flatCoordinates, offset, end, stride, opt_dest, opt_destOffset) {
- var dest, destOffset;
- if (opt_dest !== undefined) {
- dest = opt_dest;
- destOffset = opt_destOffset !== undefined ? opt_destOffset : 0;
- } else {
- dest = [];
- destOffset = 0;
- var j = offset;
- while (j < end) {
- var x = flatCoordinates[j++];
- dest[destOffset++] = flatCoordinates[j++];
- dest[destOffset++] = x;
- for (var k = 2; k < stride; ++k) {
- dest.length = destOffset;
- return dest;
-goog.provide('ol.format.Polyline');
-goog.require('ol.asserts');
-goog.require('ol.format.TextFeature');
-goog.require('ol.geom.SimpleGeometry');
-goog.require('ol.geom.flat.flip');
-goog.require('ol.geom.flat.inflate');
- * @classdesc
- * Feature format for reading and writing data in the Encoded
- * Polyline Algorithm Format.
- * @constructor
- * @extends {ol.format.TextFeature}
- * @param {olx.format.PolylineOptions=} opt_options
- * Optional configuration object.
- * @api
-ol.format.Polyline = function(opt_options) {
- ol.format.TextFeature.call(this);
- * @inheritDoc
- * @private
- * @type {number}
- this.factor_ = options.factor ? options.factor : 1e5;
- * @private
- * @type {ol.geom.GeometryLayout}
- this.geometryLayout_ = options.geometryLayout ?
- options.geometryLayout : ol.geom.GeometryLayout.XY;
-ol.inherits(ol.format.Polyline, ol.format.TextFeature);
- * Encode a list of n-dimensional points and return an encoded string
- * Attention: This function will modify the passed array!
- * @param {Array.<number>} numbers A list of n-dimensional points.
- * @param {number} stride The number of dimension of the points in the list.
- * @param {number=} opt_factor The factor by which the numbers will be
- * multiplied. The remaining decimal places will get rounded away.
- * Default is `1e5`.
- * @return {string} The encoded string.
- * @api
-ol.format.Polyline.encodeDeltas = function(numbers, stride, opt_factor) {
- var factor = opt_factor ? opt_factor : 1e5;
- var d;
- var lastNumbers = new Array(stride);
- for (d = 0; d < stride; ++d) {
- lastNumbers[d] = 0;
- var i, ii;
- for (i = 0, ii = numbers.length; i < ii;) {
- for (d = 0; d < stride; ++d, ++i) {
- var num = numbers[i];
- var delta = num - lastNumbers[d];
- lastNumbers[d] = num;
- numbers[i] = delta;
- return ol.format.Polyline.encodeFloats(numbers, factor);
- * Decode a list of n-dimensional points from an encoded string
- * @param {string} encoded An encoded string.
- * encoded string.
- * @param {number=} opt_factor The factor by which the resulting numbers will
- * be divided. Default is `1e5`.
- * @return {Array.<number>} A list of n-dimensional points.
- * @api
-ol.format.Polyline.decodeDeltas = function(encoded, stride, opt_factor) {
- var d;
- var numbers = ol.format.Polyline.decodeFloats(encoded, factor);
- var i, ii;
- lastNumbers[d] += numbers[i];
- numbers[i] = lastNumbers[d];
- return numbers;
- * Encode a list of floating point numbers and return an encoded string
- * @param {Array.<number>} numbers A list of floating point numbers.
- * @api
-ol.format.Polyline.encodeFloats = function(numbers, opt_factor) {
- var i, ii;
- for (i = 0, ii = numbers.length; i < ii; ++i) {
- numbers[i] = Math.round(numbers[i] * factor);
- return ol.format.Polyline.encodeSignedIntegers(numbers);
- * Decode a list of floating point numbers from an encoded string
- * @param {number=} opt_factor The factor by which the result will be divided.
- * @return {Array.<number>} A list of floating point numbers.
- * @api
-ol.format.Polyline.decodeFloats = function(encoded, opt_factor) {
- var numbers = ol.format.Polyline.decodeSignedIntegers(encoded);
- var i, ii;
- numbers[i] /= factor;
- return numbers;
- * Encode a list of signed integers and return an encoded string
- * @param {Array.<number>} numbers A list of signed integers.
-ol.format.Polyline.encodeSignedIntegers = function(numbers) {
- var i, ii;
- numbers[i] = (num < 0) ? ~(num << 1) : (num << 1);
- return ol.format.Polyline.encodeUnsignedIntegers(numbers);
- * Decode a list of signed integers from an encoded string
- * @return {Array.<number>} A list of signed integers.
-ol.format.Polyline.decodeSignedIntegers = function(encoded) {
- var numbers = ol.format.Polyline.decodeUnsignedIntegers(encoded);
- var i, ii;
- numbers[i] = (num & 1) ? ~(num >> 1) : (num >> 1);
- return numbers;
- * Encode a list of unsigned integers and return an encoded string
- * @param {Array.<number>} numbers A list of unsigned integers.
-ol.format.Polyline.encodeUnsignedIntegers = function(numbers) {
- var encoded = '';
- var i, ii;
- encoded += ol.format.Polyline.encodeUnsignedInteger(numbers[i]);
- return encoded;
- * Decode a list of unsigned integers from an encoded string
- * @return {Array.<number>} A list of unsigned integers.
-ol.format.Polyline.decodeUnsignedIntegers = function(encoded) {
- var numbers = [];
- var current = 0;
- var shift = 0;
- var i, ii;
- for (i = 0, ii = encoded.length; i < ii; ++i) {
- var b = encoded.charCodeAt(i) - 63;
- current |= (b & 0x1f) << shift;
- if (b < 0x20) {
- numbers.push(current);
- current = 0;
- shift = 0;
- } else {
- shift += 5;
- return numbers;
- * Encode one single unsigned integer and return an encoded string
- * @param {number} num Unsigned integer that should be encoded.
-ol.format.Polyline.encodeUnsignedInteger = function(num) {
- var value, encoded = '';
- while (num >= 0x20) {
- value = (0x20 | (num & 0x1f)) + 63;
- encoded += String.fromCharCode(value);
- num >>= 5;
- value = num + 63;
- return encoded;
- * Read the feature from the Polyline source. The coordinates are assumed to be
- * in two dimensions and in latitude, longitude order.
- * @function
- * @return {ol.Feature} Feature.
- * @api
-ol.format.Polyline.prototype.readFeature;
- * @inheritDoc
-ol.format.Polyline.prototype.readFeatureFromText = function(text, opt_options) {
- var geometry = this.readGeometryFromText(text, opt_options);
- return new ol.Feature(geometry);
- * Read the feature from the source. As Polyline sources contain a single
- * feature, this will return the feature in an array.
- * @function
- * @api
-ol.format.Polyline.prototype.readFeatures;
- * @inheritDoc
-ol.format.Polyline.prototype.readFeaturesFromText = function(text, opt_options) {
- var feature = this.readFeatureFromText(text, opt_options);
- return [feature];
- * Read the geometry from the source.
- * @function
- * @api
-ol.format.Polyline.prototype.readGeometry;
- * @inheritDoc
-ol.format.Polyline.prototype.readGeometryFromText = function(text, opt_options) {
- var stride = ol.geom.SimpleGeometry.getStrideForLayout(this.geometryLayout_);
- var flatCoordinates = ol.format.Polyline.decodeDeltas(
- text, stride, this.factor_);
- ol.geom.flat.flip.flipXY(
- flatCoordinates, 0, flatCoordinates.length, stride, flatCoordinates);
- var coordinates = ol.geom.flat.inflate.coordinates(
- flatCoordinates, 0, flatCoordinates.length, stride);
- return /** @type {ol.geom.Geometry} */ (
- new ol.geom.LineString(coordinates, this.geometryLayout_), false,
- this.adaptOptions(opt_options)));
- * Read the projection from a Polyline source.
- * @function
- * @api
-ol.format.Polyline.prototype.readProjection;
- * @inheritDoc
-ol.format.Polyline.prototype.writeFeatureText = function(feature, opt_options) {
- var geometry = feature.getGeometry();
- if (geometry) {
- return this.writeGeometryText(geometry, opt_options);
- } else {
- ol.asserts.assert(false, 40); // Expected `feature` to have a geometry
- return '';
- * @inheritDoc
-ol.format.Polyline.prototype.writeFeaturesText = function(features, opt_options) {
- return this.writeFeatureText(features[0], opt_options);
- * Write a single geometry in Polyline format.
- * @function
- * @param {ol.geom.Geometry} geometry Geometry.
- * @param {olx.format.WriteOptions=} opt_options Write options.
- * @return {string} Geometry.
- * @api
-ol.format.Polyline.prototype.writeGeometry;
- * @inheritDoc
-ol.format.Polyline.prototype.writeGeometryText = function(geometry, opt_options) {
- geometry = /** @type {ol.geom.LineString} */
- (ol.format.Feature.transformWithOptions(
- geometry, true, this.adaptOptions(opt_options)));
- var flatCoordinates = geometry.getFlatCoordinates();
- var stride = geometry.getStride();
- return ol.format.Polyline.encodeDeltas(flatCoordinates, stride, this.factor_);
-goog.provide('ol.format.TopoJSON');
-goog.require('ol.format.JSONFeature');
-goog.require('ol.geom.MultiPolygon');
- * @classdesc
- * Feature format for reading data in the TopoJSON format.
- * @constructor
- * @extends {ol.format.JSONFeature}
- * @param {olx.format.TopoJSONOptions=} opt_options Options.
- * @api
-ol.format.TopoJSON = function(opt_options) {
- ol.format.JSONFeature.call(this);
- * @inheritDoc
- options.defaultDataProjection ?
- options.defaultDataProjection : 'EPSG:4326');
-ol.inherits(ol.format.TopoJSON, ol.format.JSONFeature);
- * Concatenate arcs into a coordinate array.
- * @param {Array.<number>} indices Indices of arcs to concatenate. Negative
- * values indicate arcs need to be reversed.
- * @param {Array.<Array.<ol.Coordinate>>} arcs Array of arcs (already
- * transformed).
- * @return {Array.<ol.Coordinate>} Coordinates array.
- * @private
-ol.format.TopoJSON.concatenateArcs_ = function(indices, arcs) {
- /** @type {Array.<ol.Coordinate>} */
- var coordinates = [];
- var index, arc;
- var i, ii;
- var j, jj;
- for (i = 0, ii = indices.length; i < ii; ++i) {
- index = indices[i];
- if (i > 0) {
- // splicing together arcs, discard last point
- coordinates.pop();
- if (index >= 0) {
- // forward arc
- arc = arcs[index];
- } else {
- // reverse arc
- arc = arcs[~index].slice().reverse();
- coordinates.push.apply(coordinates, arc);
- // provide fresh copies of coordinate arrays
- for (j = 0, jj = coordinates.length; j < jj; ++j) {
- coordinates[j] = coordinates[j].slice();
- return coordinates;
- * Create a point from a TopoJSON geometry object.
- * @param {TopoJSONGeometry} object TopoJSON object.
- * @param {Array.<number>} scale Scale for each dimension.
- * @param {Array.<number>} translate Translation for each dimension.
- * @return {ol.geom.Point} Geometry.
- * @private
-ol.format.TopoJSON.readPointGeometry_ = function(object, scale, translate) {
- var coordinates = object.coordinates;
- if (scale && translate) {
- ol.format.TopoJSON.transformVertex_(coordinates, scale, translate);
- return new ol.geom.Point(coordinates);
- * Create a multi-point from a TopoJSON geometry object.
- * @return {ol.geom.MultiPoint} Geometry.
- * @private
-ol.format.TopoJSON.readMultiPointGeometry_ = function(object, scale,
- translate) {
- var i, ii;
- for (i = 0, ii = coordinates.length; i < ii; ++i) {
- ol.format.TopoJSON.transformVertex_(coordinates[i], scale, translate);
- return new ol.geom.MultiPoint(coordinates);
- * Create a linestring from a TopoJSON geometry object.
- * @param {Array.<Array.<ol.Coordinate>>} arcs Array of arcs.
- * @return {ol.geom.LineString} Geometry.
- * @private
-ol.format.TopoJSON.readLineStringGeometry_ = function(object, arcs) {
- var coordinates = ol.format.TopoJSON.concatenateArcs_(object.arcs, arcs);
- return new ol.geom.LineString(coordinates);
- * Create a multi-linestring from a TopoJSON geometry object.
- * @return {ol.geom.MultiLineString} Geometry.
- * @private
-ol.format.TopoJSON.readMultiLineStringGeometry_ = function(object, arcs) {
- var i, ii;
- for (i = 0, ii = object.arcs.length; i < ii; ++i) {
- coordinates[i] = ol.format.TopoJSON.concatenateArcs_(object.arcs[i], arcs);
- return new ol.geom.MultiLineString(coordinates);
- * Create a polygon from a TopoJSON geometry object.
- * @return {ol.geom.Polygon} Geometry.
- * @private
-ol.format.TopoJSON.readPolygonGeometry_ = function(object, arcs) {
- var i, ii;
- return new ol.geom.Polygon(coordinates);
- * Create a multi-polygon from a TopoJSON geometry object.
- * @return {ol.geom.MultiPolygon} Geometry.
- * @private
-ol.format.TopoJSON.readMultiPolygonGeometry_ = function(object, arcs) {
- var polyArray, ringCoords, j, jj;
- var i, ii;
- // for each polygon
- polyArray = object.arcs[i];
- ringCoords = [];
- for (j = 0, jj = polyArray.length; j < jj; ++j) {
- // for each ring
- ringCoords[j] = ol.format.TopoJSON.concatenateArcs_(polyArray[j], arcs);
- coordinates[i] = ringCoords;
- return new ol.geom.MultiPolygon(coordinates);
- * Create features from a TopoJSON GeometryCollection object.
- * @param {TopoJSONGeometryCollection} collection TopoJSON Geometry
- * object.
- * @return {Array.<ol.Feature>} Array of features.
- * @private
-ol.format.TopoJSON.readFeaturesFromGeometryCollection_ = function(
- collection, arcs, scale, translate, opt_options) {
- var geometries = collection.geometries;
- var i, ii;
- for (i = 0, ii = geometries.length; i < ii; ++i) {
- features[i] = ol.format.TopoJSON.readFeatureFromGeometry_(
- geometries[i], arcs, scale, translate, opt_options);
- return features;
- * Create a feature from a TopoJSON geometry object.
- * @param {TopoJSONGeometry} object TopoJSON geometry object.
- * @private
-ol.format.TopoJSON.readFeatureFromGeometry_ = function(object, arcs,
- scale, translate, opt_options) {
- var geometry;
- var type = object.type;
- var geometryReader = ol.format.TopoJSON.GEOMETRY_READERS_[type];
- if ((type === 'Point') || (type === 'MultiPoint')) {
- geometry = geometryReader(object, scale, translate);
- } else {
- geometry = geometryReader(object, arcs);
- var feature = new ol.Feature();
- feature.setGeometry(/** @type {ol.geom.Geometry} */ (
- ol.format.Feature.transformWithOptions(geometry, false, opt_options)));
- if (object.id !== undefined) {
- feature.setId(object.id);
- if (object.properties) {
- feature.setProperties(object.properties);
- return feature;
- * Read all features from a TopoJSON source.
- * @function
- * @api
-ol.format.TopoJSON.prototype.readFeatures;
- * @inheritDoc
-ol.format.TopoJSON.prototype.readFeaturesFromObject = function(
- object, opt_options) {
- if (object.type == 'Topology') {
- var topoJSONTopology = /** @type {TopoJSONTopology} */ (object);
- var transform, scale = null, translate = null;
- if (topoJSONTopology.transform) {
- transform = topoJSONTopology.transform;
- scale = transform.scale;
- translate = transform.translate;
- var arcs = topoJSONTopology.arcs;
- if (transform) {
- ol.format.TopoJSON.transformArcs_(arcs, scale, translate);
- /** @type {Array.<ol.Feature>} */
- var topoJSONFeatures = ol.obj.getValues(topoJSONTopology.objects);
- var i, ii;
- var feature;
- for (i = 0, ii = topoJSONFeatures.length; i < ii; ++i) {
- if (topoJSONFeatures[i].type === 'GeometryCollection') {
- feature = /** @type {TopoJSONGeometryCollection} */
- (topoJSONFeatures[i]);
- features.push.apply(features,
- ol.format.TopoJSON.readFeaturesFromGeometryCollection_(
- feature, arcs, scale, translate, opt_options));
- } else {
- feature = /** @type {TopoJSONGeometry} */
- features.push(ol.format.TopoJSON.readFeatureFromGeometry_(
- return features;
- } else {
- return [];
- * Apply a linear transform to array of arcs. The provided array of arcs is
- * modified in place.
- * @private
-ol.format.TopoJSON.transformArcs_ = function(arcs, scale, translate) {
- var i, ii;
- for (i = 0, ii = arcs.length; i < ii; ++i) {
- ol.format.TopoJSON.transformArc_(arcs[i], scale, translate);
- * Apply a linear transform to an arc. The provided arc is modified in place.
- * @param {Array.<ol.Coordinate>} arc Arc.
- * @private
-ol.format.TopoJSON.transformArc_ = function(arc, scale, translate) {
- var x = 0;
- var y = 0;
- var vertex;
- var i, ii;
- for (i = 0, ii = arc.length; i < ii; ++i) {
- vertex = arc[i];
- x += vertex[0];
- y += vertex[1];
- vertex[0] = x;
- vertex[1] = y;
- ol.format.TopoJSON.transformVertex_(vertex, scale, translate);
- * Apply a linear transform to a vertex. The provided vertex is modified in
- * place.
- * @param {ol.Coordinate} vertex Vertex.
- * @private
-ol.format.TopoJSON.transformVertex_ = function(vertex, scale, translate) {
- vertex[0] = vertex[0] * scale[0] + translate[0];
- vertex[1] = vertex[1] * scale[1] + translate[1];
- * Read the projection from a TopoJSON source.
- * @param {Document|Node|Object|string} object Source.
- * @override
- * @api
-ol.format.TopoJSON.prototype.readProjection;
- * @inheritDoc
-ol.format.TopoJSON.prototype.readProjectionFromObject = function(object) {
- * @const
- * @private
- * @type {Object.<string, function(TopoJSONGeometry, Array, ...Array): ol.geom.Geometry>}
-ol.format.TopoJSON.GEOMETRY_READERS_ = {
- 'Point': ol.format.TopoJSON.readPointGeometry_,
- 'LineString': ol.format.TopoJSON.readLineStringGeometry_,
- 'Polygon': ol.format.TopoJSON.readPolygonGeometry_,
- 'MultiPoint': ol.format.TopoJSON.readMultiPointGeometry_,
- 'MultiLineString': ol.format.TopoJSON.readMultiLineStringGeometry_,
- 'MultiPolygon': ol.format.TopoJSON.readMultiPolygonGeometry_
- * @inheritDoc
-ol.format.TopoJSON.prototype.writeFeatureObject = function(feature, opt_options) {};
- * @inheritDoc
-ol.format.TopoJSON.prototype.writeFeaturesObject = function(features, opt_options) {};
- * @inheritDoc
-ol.format.TopoJSON.prototype.writeGeometryObject = function(geometry, opt_options) {};
- * @override
-ol.format.TopoJSON.prototype.readGeometryFromObject = function() {};
- * @override
-ol.format.TopoJSON.prototype.readFeatureFromObject = function() {};
-goog.provide('ol.format.WFS');
-goog.require('ol.format.GML2');
-goog.require('ol.format.GML3');
-goog.require('ol.format.GMLBase');
-goog.require('ol.format.filter');
-goog.require('ol.geom.Geometry');
- * @classdesc
- * Feature format for reading and writing data in the WFS format.
- * By default, supports WFS version 1.1.0. You can pass a GML format
- * as option if you want to read a WFS that contains GML2 (WFS 1.0.0).
- * Also see {@link ol.format.GMLBase} which is used by this format.
- * @constructor
- * @param {olx.format.WFSOptions=} opt_options
- * @api
-ol.format.WFS = function(opt_options) {
- * @private
- * @type {Array.<string>|string|undefined}
- this.featureType_ = options.featureType;
- * @private
- * @type {Object.<string, string>|string|undefined}
- this.featureNS_ = options.featureNS;
- * @private
- * @type {ol.format.GMLBase}
- this.gmlFormat_ = options.gmlFormat ?
- options.gmlFormat : new ol.format.GML3();
- * @private
- * @type {string}
- this.schemaLocation_ = options.schemaLocation ?
- options.schemaLocation :
- ol.format.WFS.SCHEMA_LOCATIONS[ol.format.WFS.DEFAULT_VERSION];
-ol.inherits(ol.format.WFS, ol.format.XMLFeature);
- * @const
- * @type {string}
-ol.format.WFS.FEATURE_PREFIX = 'feature';
- * @const
- * @type {string}
-ol.format.WFS.XMLNS = 'http://www.w3.org/2000/xmlns/';
- * @const
- * @type {string}
-ol.format.WFS.OGCNS = 'http://www.opengis.net/ogc';
- * @const
- * @type {string}
-ol.format.WFS.WFSNS = 'http://www.opengis.net/wfs';
- * @const
- * @type {Object.<string, string>}
-ol.format.WFS.SCHEMA_LOCATIONS = {
- '1.1.0': 'http://www.opengis.net/wfs ' +
- 'http://schemas.opengis.net/wfs/1.1.0/wfs.xsd',
- '1.0.0': 'http://www.opengis.net/wfs ' +
- 'http://schemas.opengis.net/wfs/1.0.0/wfs.xsd'
- * @const
- * @type {string}
-ol.format.WFS.DEFAULT_VERSION = '1.1.0';
- * Read all features from a WFS FeatureCollection.
- * @function
- * @api
-ol.format.WFS.prototype.readFeatures;
- * @inheritDoc
-ol.format.WFS.prototype.readFeaturesFromNode = function(node, opt_options) {
- var context = /** @type {ol.XmlNodeStackItem} */ ({
- 'featureType': this.featureType_,
- 'featureNS': this.featureNS_
- ol.obj.assign(context, this.getReadOptions(node,
- opt_options ? opt_options : {}));
- var objectStack = [context];
- this.gmlFormat_.FEATURE_COLLECTION_PARSERS[ol.format.GMLBase.GMLNS][
- 'featureMember'] =
- ol.xml.makeArrayPusher(ol.format.GMLBase.prototype.readFeaturesInternal);
- var features = ol.xml.pushParseAndPop([],
- this.gmlFormat_.FEATURE_COLLECTION_PARSERS, node,
- objectStack, this.gmlFormat_);
- if (!features) {
- features = [];
- return features;
- * Read transaction response of the source.
- * @return {ol.WFSTransactionResponse|undefined} Transaction response.
- * @api
-ol.format.WFS.prototype.readTransactionResponse = function(source) {
- return this.readTransactionResponseFromDocument(
- /** @type {Document} */ (source));
- return this.readTransactionResponseFromNode(/** @type {Node} */ (source));
- return this.readTransactionResponseFromDocument(doc);
- } else {
- return undefined;
- * Read feature collection metadata of the source.
- * @return {ol.WFSFeatureCollectionMetadata|undefined}
- * FeatureCollection metadata.
- * @api
-ol.format.WFS.prototype.readFeatureCollectionMetadata = function(source) {
- return this.readFeatureCollectionMetadataFromDocument(
- return this.readFeatureCollectionMetadataFromNode(
- /** @type {Node} */ (source));
- return this.readFeatureCollectionMetadataFromDocument(doc);
- } else {
- return undefined;
-ol.format.WFS.prototype.readFeatureCollectionMetadataFromDocument = function(doc) {
- return this.readFeatureCollectionMetadataFromNode(n);
- return undefined;
- * @const
- * @private
-ol.format.WFS.FEATURE_COLLECTION_PARSERS_ = {
- 'http://www.opengis.net/gml': {
- 'boundedBy': ol.xml.makeObjectPropertySetter(
- ol.format.GMLBase.prototype.readGeometryElement, 'bounds')
-ol.format.WFS.prototype.readFeatureCollectionMetadataFromNode = function(node) {
- var result = {};
- var value = ol.format.XSD.readNonNegativeIntegerString(
- node.getAttribute('numberOfFeatures'));
- result['numberOfFeatures'] = value;
- /** @type {ol.WFSFeatureCollectionMetadata} */ (result),
- ol.format.WFS.FEATURE_COLLECTION_PARSERS_, node, [], this.gmlFormat_);
- * @const
- * @private
-ol.format.WFS.TRANSACTION_SUMMARY_PARSERS_ = {
- 'http://www.opengis.net/wfs': {
- 'totalInserted': ol.xml.makeObjectPropertySetter(
- ol.format.XSD.readNonNegativeInteger),
- 'totalUpdated': ol.xml.makeObjectPropertySetter(
- 'totalDeleted': ol.xml.makeObjectPropertySetter(
- * @return {Object|undefined} Transaction Summary.
- * @private
-ol.format.WFS.readTransactionSummary_ = function(node, objectStack) {
- {}, ol.format.WFS.TRANSACTION_SUMMARY_PARSERS_, node, objectStack);
- * @const
- * @private
-ol.format.WFS.OGC_FID_PARSERS_ = {
- 'http://www.opengis.net/ogc': {
- 'FeatureId': ol.xml.makeArrayPusher(function(node, objectStack) {
- return node.getAttribute('fid');
- * @private
-ol.format.WFS.fidParser_ = function(node, objectStack) {
- ol.xml.parseNode(ol.format.WFS.OGC_FID_PARSERS_, node, objectStack);
- * @const
- * @private
-ol.format.WFS.INSERT_RESULTS_PARSERS_ = {
- 'Feature': ol.format.WFS.fidParser_
- * @return {Array.<string>|undefined} Insert results.
- * @private
-ol.format.WFS.readInsertResults_ = function(node, objectStack) {
- [], ol.format.WFS.INSERT_RESULTS_PARSERS_, node, objectStack);
- * @const
- * @private
-ol.format.WFS.TRANSACTION_RESPONSE_PARSERS_ = {
- 'TransactionSummary': ol.xml.makeObjectPropertySetter(
- ol.format.WFS.readTransactionSummary_, 'transactionSummary'),
- 'InsertResults': ol.xml.makeObjectPropertySetter(
- ol.format.WFS.readInsertResults_, 'insertIds')
-ol.format.WFS.prototype.readTransactionResponseFromDocument = function(doc) {
- return this.readTransactionResponseFromNode(n);
- return undefined;
-ol.format.WFS.prototype.readTransactionResponseFromNode = function(node) {
- /** @type {ol.WFSTransactionResponse} */({}),
- ol.format.WFS.TRANSACTION_RESPONSE_PARSERS_, node, []);
- * @type {Object.<string, Object.<string, ol.XmlSerializer>>}
- * @private
-ol.format.WFS.QUERY_SERIALIZERS_ = {
- 'PropertyName': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
- * @param {ol.Feature} feature Feature.
- * @param {Array.<*>} objectStack Node stack.
- * @private
-ol.format.WFS.writeFeature_ = function(node, feature, objectStack) {
- var context = objectStack[objectStack.length - 1];
- var featureType = context['featureType'];
- var featureNS = context['featureNS'];
- var gmlVersion = context['gmlVersion'];
- var child = ol.xml.createElementNS(featureNS, featureType);
- node.appendChild(child);
- if (gmlVersion === 2) {
- ol.format.GML2.prototype.writeFeatureElement(child, feature, objectStack);
- } else {
- ol.format.GML3.prototype.writeFeatureElement(child, feature, objectStack);
- * @param {number|string} fid Feature identifier.
- * @private
-ol.format.WFS.writeOgcFidFilter_ = function(node, fid, objectStack) {
- var filter = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'Filter');
- var child = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'FeatureId');
- filter.appendChild(child);
- child.setAttribute('fid', fid);
- node.appendChild(filter);
- * @private
-ol.format.WFS.writeDelete_ = function(node, feature, objectStack) {
- ol.asserts.assert(feature.getId() !== undefined, 26); // Features must have an id set
- var featurePrefix = context['featurePrefix'];
- featurePrefix = featurePrefix ? featurePrefix :
- ol.format.WFS.FEATURE_PREFIX;
- node.setAttribute('typeName', featurePrefix + ':' + featureType);
- ol.xml.setAttributeNS(node, ol.format.WFS.XMLNS, 'xmlns:' + featurePrefix,
- featureNS);
- var fid = feature.getId();
- if (fid !== undefined) {
- ol.format.WFS.writeOgcFidFilter_(node, fid, objectStack);
- * @private
-ol.format.WFS.writeUpdate_ = function(node, feature, objectStack) {
- ol.asserts.assert(feature.getId() !== undefined, 27); // Features must have an id set
- featureNS);
- var keys = feature.getKeys();
- var values = [];
- for (var i = 0, ii = keys.length; i < ii; i++) {
- var value = feature.get(keys[i]);
- if (value !== undefined) {
- values.push({name: keys[i], value: value});
- ol.xml.pushSerializeAndPop(/** @type {ol.XmlNodeStackItem} */ (
- {'gmlVersion': context['gmlVersion'], node: node,
- 'srsName': context['srsName']}),
- ol.format.WFS.TRANSACTION_SERIALIZERS_,
- ol.xml.makeSimpleNodeFactory('Property'), values,
- objectStack);
- * @param {Object} pair Property name and value.
- * @private
-ol.format.WFS.writeProperty_ = function(node, pair, objectStack) {
- var name = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'Name');
- node.appendChild(name);
- ol.format.XSD.writeStringTextNode(name, pair.name);
- if (pair.value !== undefined && pair.value !== null) {
- var value = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'Value');
- node.appendChild(value);
- if (pair.value instanceof ol.geom.Geometry) {
- ol.format.GML2.prototype.writeGeometryElement(value,
- pair.value, objectStack);
- } else {
- ol.format.GML3.prototype.writeGeometryElement(value,
- } else {
- ol.format.XSD.writeStringTextNode(value, pair.value);
- * @param {{vendorId: string, safeToIgnore: boolean, value: string}}
- * nativeElement The native element.
- * @private
-ol.format.WFS.writeNative_ = function(node, nativeElement, objectStack) {
- if (nativeElement.vendorId) {
- node.setAttribute('vendorId', nativeElement.vendorId);
- if (nativeElement.safeToIgnore !== undefined) {
- node.setAttribute('safeToIgnore', nativeElement.safeToIgnore);
- if (nativeElement.value !== undefined) {
- ol.format.XSD.writeStringTextNode(node, nativeElement.value);
- * @private
-ol.format.WFS.TRANSACTION_SERIALIZERS_ = {
- 'Insert': ol.xml.makeChildAppender(ol.format.WFS.writeFeature_),
- 'Update': ol.xml.makeChildAppender(ol.format.WFS.writeUpdate_),
- 'Delete': ol.xml.makeChildAppender(ol.format.WFS.writeDelete_),
- 'Property': ol.xml.makeChildAppender(ol.format.WFS.writeProperty_),
- 'Native': ol.xml.makeChildAppender(ol.format.WFS.writeNative_)
- * @param {string} featureType Feature type.
- * @private
-ol.format.WFS.writeQuery_ = function(node, featureType, objectStack) {
- var context = /** @type {Object} */ (objectStack[objectStack.length - 1]);
- var propertyNames = context['propertyNames'];
- var srsName = context['srsName'];
- var prefix = featurePrefix ? featurePrefix + ':' : '';
- node.setAttribute('typeName', prefix + featureType);
- if (srsName) {
- node.setAttribute('srsName', srsName);
- if (featureNS) {
- featureNS);
- var item = /** @type {ol.XmlNodeStackItem} */ (ol.obj.assign({}, context));
- item.node = node;
- ol.xml.pushSerializeAndPop(item,
- ol.format.WFS.QUERY_SERIALIZERS_,
- ol.xml.makeSimpleNodeFactory('PropertyName'), propertyNames,
- objectStack);
- var filter = context['filter'];
- if (filter) {
- var child = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'Filter');
- ol.format.WFS.writeFilterCondition_(child, filter, objectStack);
- * @param {ol.format.filter.Filter} filter Filter.
- * @private
-ol.format.WFS.writeFilterCondition_ = function(node, filter, objectStack) {
- /** @type {ol.XmlNodeStackItem} */
- var item = {node: node};
- ol.format.WFS.GETFEATURE_SERIALIZERS_,
- ol.xml.makeSimpleNodeFactory(filter.getTagName()),
- [filter], objectStack);
- * @param {ol.format.filter.Bbox} filter Filter.
- * @private
-ol.format.WFS.writeBboxFilter_ = function(node, filter, objectStack) {
- context['srsName'] = filter.srsName;
- ol.format.WFS.writeOgcPropertyName_(node, filter.geometryName);
- ol.format.GML3.prototype.writeGeometryElement(node, filter.extent, objectStack);
- * @param {ol.format.filter.Intersects} filter Filter.
- * @private
-ol.format.WFS.writeIntersectsFilter_ = function(node, filter, objectStack) {
- ol.format.GML3.prototype.writeGeometryElement(node, filter.geometry, objectStack);
- * @param {ol.format.filter.Within} filter Filter.
- * @private
-ol.format.WFS.writeWithinFilter_ = function(node, filter, objectStack) {
- * @param {ol.format.filter.LogicalNary} filter Filter.
- * @private
-ol.format.WFS.writeLogicalFilter_ = function(node, filter, objectStack) {
- filter.conditions.forEach(function(condition) {
- ol.xml.makeSimpleNodeFactory(condition.getTagName()),
- [condition], objectStack);
- * @param {ol.format.filter.Not} filter Filter.
- * @private
-ol.format.WFS.writeNotFilter_ = function(node, filter, objectStack) {
- var condition = filter.condition;
- * @param {ol.format.filter.ComparisonBinary} filter Filter.
- * @private
-ol.format.WFS.writeComparisonFilter_ = function(node, filter, objectStack) {
- if (filter.matchCase !== undefined) {
- node.setAttribute('matchCase', filter.matchCase.toString());
- ol.format.WFS.writeOgcPropertyName_(node, filter.propertyName);
- ol.format.WFS.writeOgcLiteral_(node, '' + filter.expression);
- * @param {ol.format.filter.IsNull} filter Filter.
- * @private
-ol.format.WFS.writeIsNullFilter_ = function(node, filter, objectStack) {
- * @param {ol.format.filter.IsBetween} filter Filter.
- * @private
-ol.format.WFS.writeIsBetweenFilter_ = function(node, filter, objectStack) {
- var lowerBoundary = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'LowerBoundary');
- node.appendChild(lowerBoundary);
- ol.format.WFS.writeOgcLiteral_(lowerBoundary, '' + filter.lowerBoundary);
- var upperBoundary = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'UpperBoundary');
- node.appendChild(upperBoundary);
- ol.format.WFS.writeOgcLiteral_(upperBoundary, '' + filter.upperBoundary);
- * @param {ol.format.filter.IsLike} filter Filter.
- * @private
-ol.format.WFS.writeIsLikeFilter_ = function(node, filter, objectStack) {
- node.setAttribute('wildCard', filter.wildCard);
- node.setAttribute('singleChar', filter.singleChar);
- node.setAttribute('escapeChar', filter.escapeChar);
- ol.format.WFS.writeOgcLiteral_(node, '' + filter.pattern);
- * @param {string} tagName Tag name.
- * @param {string} value Value.
- * @private
-ol.format.WFS.writeOgcExpression_ = function(tagName, node, value) {
- var property = ol.xml.createElementNS(ol.format.WFS.OGCNS, tagName);
- ol.format.XSD.writeStringTextNode(property, value);
- node.appendChild(property);
- * @param {string} value PropertyName value.
- * @private
-ol.format.WFS.writeOgcPropertyName_ = function(node, value) {
- ol.format.WFS.writeOgcExpression_('PropertyName', node, value);
- * @private
-ol.format.WFS.writeOgcLiteral_ = function(node, value) {
- ol.format.WFS.writeOgcExpression_('Literal', node, value);
- * @private
-ol.format.WFS.GETFEATURE_SERIALIZERS_ = {
- 'Query': ol.xml.makeChildAppender(ol.format.WFS.writeQuery_)
- 'And': ol.xml.makeChildAppender(ol.format.WFS.writeLogicalFilter_),
- 'Or': ol.xml.makeChildAppender(ol.format.WFS.writeLogicalFilter_),
- 'Not': ol.xml.makeChildAppender(ol.format.WFS.writeNotFilter_),
- 'BBOX': ol.xml.makeChildAppender(ol.format.WFS.writeBboxFilter_),
- 'Intersects': ol.xml.makeChildAppender(ol.format.WFS.writeIntersectsFilter_),
- 'Within': ol.xml.makeChildAppender(ol.format.WFS.writeWithinFilter_),
- 'PropertyIsEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
- 'PropertyIsNotEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
- 'PropertyIsLessThan': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
- 'PropertyIsLessThanOrEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
- 'PropertyIsGreaterThan': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
- 'PropertyIsGreaterThanOrEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
- 'PropertyIsNull': ol.xml.makeChildAppender(ol.format.WFS.writeIsNullFilter_),
- 'PropertyIsBetween': ol.xml.makeChildAppender(ol.format.WFS.writeIsBetweenFilter_),
- 'PropertyIsLike': ol.xml.makeChildAppender(ol.format.WFS.writeIsLikeFilter_)
- * Encode filter as WFS `Filter` and return the Node.
- * @return {Node} Result.
- * @api
-ol.format.WFS.writeFilter = function(filter) {
- ol.format.WFS.writeFilterCondition_(child, filter, []);
- return child;
- * @param {Array.<string>} featureTypes Feature types.
- * @private
-ol.format.WFS.writeGetFeature_ = function(node, featureTypes, objectStack) {
- item.node = node;
- ol.xml.makeSimpleNodeFactory('Query'), featureTypes,
- objectStack);
- * Encode format as WFS `GetFeature` and return the Node.
- * @param {olx.format.WFSWriteGetFeatureOptions} options Options.
- * @api
-ol.format.WFS.prototype.writeGetFeature = function(options) {
- var node = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'GetFeature');
- node.setAttribute('service', 'WFS');
- node.setAttribute('version', '1.1.0');
- var filter;
- if (options) {
- if (options.handle) {
- node.setAttribute('handle', options.handle);
- if (options.outputFormat) {
- node.setAttribute('outputFormat', options.outputFormat);
- if (options.maxFeatures !== undefined) {
- node.setAttribute('maxFeatures', options.maxFeatures);
- if (options.resultType) {
- node.setAttribute('resultType', options.resultType);
- if (options.startIndex !== undefined) {
- node.setAttribute('startIndex', options.startIndex);
- if (options.count !== undefined) {
- node.setAttribute('count', options.count);
- filter = options.filter;
- if (options.bbox) {
- ol.asserts.assert(options.geometryName,
- 12); // `options.geometryName` must also be provided when `options.bbox` is set
- var bbox = ol.format.filter.bbox(
- /** @type {string} */ (options.geometryName), options.bbox, options.srsName);
- if (filter) {
- // if bbox and filter are both set, combine the two into a single filter
- filter = ol.format.filter.and(filter, bbox);
- } else {
- filter = bbox;
- ol.xml.setAttributeNS(node, 'http://www.w3.org/2001/XMLSchema-instance',
- 'xsi:schemaLocation', this.schemaLocation_);
- var context = {
- node: node,
- 'srsName': options.srsName,
- 'featureNS': options.featureNS ? options.featureNS : this.featureNS_,
- 'featurePrefix': options.featurePrefix,
- 'geometryName': options.geometryName,
- 'filter': filter,
- 'propertyNames': options.propertyNames ? options.propertyNames : []
- ol.asserts.assert(Array.isArray(options.featureTypes),
- 11); // `options.featureTypes` should be an Array
- ol.format.WFS.writeGetFeature_(node, /** @type {!Array.<string>} */ (options.featureTypes), [context]);
- return node;
- * Encode format as WFS `Transaction` and return the Node.
- * @param {Array.<ol.Feature>} inserts The features to insert.
- * @param {Array.<ol.Feature>} updates The features to update.
- * @param {Array.<ol.Feature>} deletes The features to delete.
- * @param {olx.format.WFSWriteTransactionOptions} options Write options.
- * @api
-ol.format.WFS.prototype.writeTransaction = function(inserts, updates, deletes,
- options) {
- var objectStack = [];
- var node = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'Transaction');
- var version = options.version ?
- options.version : ol.format.WFS.DEFAULT_VERSION;
- var gmlVersion = version === '1.0.0' ? 2 : 3;
- node.setAttribute('version', version);
- var baseObj;
- var obj;
- if (options) {
- baseObj = options.gmlOptions ? options.gmlOptions : {};
- var schemaLocation = ol.format.WFS.SCHEMA_LOCATIONS[version];
- 'xsi:schemaLocation', schemaLocation);
- if (inserts) {
- obj = {node: node, 'featureNS': options.featureNS,
- 'featureType': options.featureType, 'featurePrefix': options.featurePrefix,
- 'gmlVersion': gmlVersion, 'srsName': options.srsName};
- ol.obj.assign(obj, baseObj);
- ol.xml.pushSerializeAndPop(obj,
- ol.xml.makeSimpleNodeFactory('Insert'), inserts,
- objectStack);
- if (updates) {
- ol.xml.makeSimpleNodeFactory('Update'), updates,
- objectStack);
- if (deletes) {
- ol.xml.pushSerializeAndPop({node: node, 'featureNS': options.featureNS,
- 'gmlVersion': gmlVersion, 'srsName': options.srsName},
- ol.xml.makeSimpleNodeFactory('Delete'), deletes,
- objectStack);
- if (options.nativeElements) {
- ol.xml.makeSimpleNodeFactory('Native'), options.nativeElements,
- objectStack);
- return node;
- * Read the projection from a WFS source.
- * @function
- * @return {?ol.proj.Projection} Projection.
- * @api
-ol.format.WFS.prototype.readProjection;
- * @inheritDoc
-ol.format.WFS.prototype.readProjectionFromDocument = function(doc) {
- return this.readProjectionFromNode(n);
- return null;
- * @inheritDoc
-ol.format.WFS.prototype.readProjectionFromNode = function(node) {
- if (node.firstElementChild &&
- node.firstElementChild.firstElementChild) {
- node = node.firstElementChild.firstElementChild;
- for (var n = node.firstElementChild; n; n = n.nextElementSibling) {
- if (!(n.childNodes.length === 0 ||
- (n.childNodes.length === 1 &&
- n.firstChild.nodeType === 3))) {
- var objectStack = [{}];
- this.gmlFormat_.readGeometryElement(n, objectStack);
- return ol.proj.get(objectStack.pop().srsName);
- return null;
-goog.provide('ol.format.WKT');
-goog.require('ol.geom.GeometryCollection');
- * @classdesc
- * Geometry format for reading and writing data in the `WellKnownText` (WKT)
- * format.
- * @constructor
- * @param {olx.format.WKTOptions=} opt_options Options.
- * @api
-ol.format.WKT = function(opt_options) {
- * Split GeometryCollection into multiple features.
- * @type {boolean}
- * @private
- this.splitCollection_ = options.splitCollection !== undefined ?
- options.splitCollection : false;
-ol.inherits(ol.format.WKT, ol.format.TextFeature);
- * @const
- * @type {string}
-ol.format.WKT.EMPTY = 'EMPTY';
- * @const
- * @type {string}
-ol.format.WKT.Z = 'Z';
- * @const
- * @type {string}
-ol.format.WKT.M = 'M';
- * @const
- * @type {string}
-ol.format.WKT.ZM = 'ZM';
- * @param {ol.geom.Point} geom Point geometry.
- * @return {string} Coordinates part of Point as WKT.
- * @private
-ol.format.WKT.encodePointGeometry_ = function(geom) {
- var coordinates = geom.getCoordinates();
- if (coordinates.length === 0) {
- return '';
- return coordinates.join(' ');
- * @param {ol.geom.MultiPoint} geom MultiPoint geometry.
- * @return {string} Coordinates part of MultiPoint as WKT.
- * @private
-ol.format.WKT.encodeMultiPointGeometry_ = function(geom) {
- var array = [];
- var components = geom.getPoints();
- for (var i = 0, ii = components.length; i < ii; ++i) {
- array.push('(' + ol.format.WKT.encodePointGeometry_(components[i]) + ')');
- return array.join(',');
- * @param {ol.geom.GeometryCollection} geom GeometryCollection geometry.
- * @return {string} Coordinates part of GeometryCollection as WKT.
- * @private
-ol.format.WKT.encodeGeometryCollectionGeometry_ = function(geom) {
- var array = [];
- var geoms = geom.getGeometries();
- for (var i = 0, ii = geoms.length; i < ii; ++i) {
- array.push(ol.format.WKT.encode_(geoms[i]));
- * @param {ol.geom.LineString|ol.geom.LinearRing} geom LineString geometry.
- * @return {string} Coordinates part of LineString as WKT.
- * @private
-ol.format.WKT.encodeLineStringGeometry_ = function(geom) {
- var array = [];
- for (var i = 0, ii = coordinates.length; i < ii; ++i) {
- array.push(coordinates[i].join(' '));
- * @param {ol.geom.MultiLineString} geom MultiLineString geometry.
- * @return {string} Coordinates part of MultiLineString as WKT.
- * @private
-ol.format.WKT.encodeMultiLineStringGeometry_ = function(geom) {
- var array = [];
- var components = geom.getLineStrings();
- array.push('(' + ol.format.WKT.encodeLineStringGeometry_(
- components[i]) + ')');
- * @param {ol.geom.Polygon} geom Polygon geometry.
- * @return {string} Coordinates part of Polygon as WKT.
- * @private
-ol.format.WKT.encodePolygonGeometry_ = function(geom) {
- var array = [];
- var rings = geom.getLinearRings();
- for (var i = 0, ii = rings.length; i < ii; ++i) {
- rings[i]) + ')');
- * @param {ol.geom.MultiPolygon} geom MultiPolygon geometry.
- * @return {string} Coordinates part of MultiPolygon as WKT.
- * @private
-ol.format.WKT.encodeMultiPolygonGeometry_ = function(geom) {
- var array = [];
- var components = geom.getPolygons();
- array.push('(' + ol.format.WKT.encodePolygonGeometry_(
- * @param {ol.geom.SimpleGeometry} geom SimpleGeometry geometry.
- * @return {string} Potential dimensional information for WKT type.
- * @private
-ol.format.WKT.encodeGeometryLayout_ = function(geom) {
- var layout = geom.getLayout();
- var dimInfo = '';
- if (layout === ol.geom.GeometryLayout.XYZ || layout === ol.geom.GeometryLayout.XYZM) {
- dimInfo += ol.format.WKT.Z;
- if (layout === ol.geom.GeometryLayout.XYM || layout === ol.geom.GeometryLayout.XYZM) {
- dimInfo += ol.format.WKT.M;
- return dimInfo;
- * Encode a geometry as WKT.
- * @param {ol.geom.Geometry} geom The geometry to encode.
- * @return {string} WKT string for the geometry.
- * @private
-ol.format.WKT.encode_ = function(geom) {
- var type = geom.getType();
- var geometryEncoder = ol.format.WKT.GeometryEncoder_[type];
- var enc = geometryEncoder(geom);
- type = type.toUpperCase();
- if (geom instanceof ol.geom.SimpleGeometry) {
- var dimInfo = ol.format.WKT.encodeGeometryLayout_(geom);
- if (dimInfo.length > 0) {
- type += ' ' + dimInfo;
- if (enc.length === 0) {
- return type + ' ' + ol.format.WKT.EMPTY;
- return type + '(' + enc + ')';
- * @const
- * @type {Object.<string, function(ol.geom.Geometry): string>}
- * @private
-ol.format.WKT.GeometryEncoder_ = {
- 'Point': ol.format.WKT.encodePointGeometry_,
- 'LineString': ol.format.WKT.encodeLineStringGeometry_,
- 'Polygon': ol.format.WKT.encodePolygonGeometry_,
- 'MultiPoint': ol.format.WKT.encodeMultiPointGeometry_,
- 'MultiLineString': ol.format.WKT.encodeMultiLineStringGeometry_,
- 'MultiPolygon': ol.format.WKT.encodeMultiPolygonGeometry_,
- 'GeometryCollection': ol.format.WKT.encodeGeometryCollectionGeometry_
- * Parse a WKT string.
- * @param {string} wkt WKT string.
- * @return {ol.geom.Geometry|undefined}
- * The geometry created.
- * @private
-ol.format.WKT.prototype.parse_ = function(wkt) {
- var lexer = new ol.format.WKT.Lexer(wkt);
- var parser = new ol.format.WKT.Parser(lexer);
- return parser.parse();
- * Read a feature from a WKT source.
- * @function
- * @api
-ol.format.WKT.prototype.readFeature;
- * @inheritDoc
-ol.format.WKT.prototype.readFeatureFromText = function(text, opt_options) {
- var geom = this.readGeometryFromText(text, opt_options);
- if (geom) {
- feature.setGeometry(geom);
- return feature;
- return null;
- * Read all features from a WKT source.
- * @function
- * @api
-ol.format.WKT.prototype.readFeatures;
- * @inheritDoc
-ol.format.WKT.prototype.readFeaturesFromText = function(text, opt_options) {
- var geometries = [];
- if (this.splitCollection_ &&
- geometry.getType() == ol.geom.GeometryType.GEOMETRY_COLLECTION) {
- geometries = (/** @type {ol.geom.GeometryCollection} */ (geometry))
- .getGeometriesArray();
- } else {
- geometries = [geometry];
- var feature, features = [];
- for (var i = 0, ii = geometries.length; i < ii; ++i) {
- feature = new ol.Feature();
- feature.setGeometry(geometries[i]);
- return features;
- * Read a single geometry from a WKT source.
- * @function
- * @api
-ol.format.WKT.prototype.readGeometry;
- * @inheritDoc
-ol.format.WKT.prototype.readGeometryFromText = function(text, opt_options) {
- var geometry = this.parse_(text);
- if (geometry) {
- ol.format.Feature.transformWithOptions(geometry, false, opt_options));
- } else {
- return null;
- * Encode a feature as a WKT string.
- * @function
- * @return {string} WKT string.
- * @api
-ol.format.WKT.prototype.writeFeature;
- * @inheritDoc
-ol.format.WKT.prototype.writeFeatureText = function(feature, opt_options) {
- if (geometry) {
- return '';
- * Encode an array of features as a WKT string.
- * @function
- * @param {Array.<ol.Feature>} features Features.
- * @api
-ol.format.WKT.prototype.writeFeatures;
- * @inheritDoc
-ol.format.WKT.prototype.writeFeaturesText = function(features, opt_options) {
- if (features.length == 1) {
- for (var i = 0, ii = features.length; i < ii; ++i) {
- geometries.push(features[i].getGeometry());
- var collection = new ol.geom.GeometryCollection(geometries);
- return this.writeGeometryText(collection, opt_options);
- * Write a single geometry as a WKT string.
- * @function
- * @api
-ol.format.WKT.prototype.writeGeometry;
- * @inheritDoc
-ol.format.WKT.prototype.writeGeometryText = function(geometry, opt_options) {
- return ol.format.WKT.encode_(/** @type {ol.geom.Geometry} */ (
- ol.format.Feature.transformWithOptions(geometry, true, opt_options)));
- * @const
- * @enum {number}
- * @private
-ol.format.WKT.TokenType_ = {
- TEXT: 1,
- LEFT_PAREN: 2,
- RIGHT_PAREN: 3,
- NUMBER: 4,
- COMMA: 5,
- EOF: 6
- * Class to tokenize a WKT string.
- * @constructor
- * @protected
-ol.format.WKT.Lexer = function(wkt) {
- * @type {string}
- this.wkt = wkt;
- * @type {number}
- * @private
- this.index_ = -1;
- * @param {string} c Character.
- * @return {boolean} Whether the character is alphabetic.
- * @private
-ol.format.WKT.Lexer.prototype.isAlpha_ = function(c) {
- return c >= 'a' && c <= 'z' || c >= 'A' && c <= 'Z';
- * @param {boolean=} opt_decimal Whether the string number
- * contains a dot, i.e. is a decimal number.
- * @return {boolean} Whether the character is numeric.
- * @private
-ol.format.WKT.Lexer.prototype.isNumeric_ = function(c, opt_decimal) {
- var decimal = opt_decimal !== undefined ? opt_decimal : false;
- return c >= '0' && c <= '9' || c == '.' && !decimal;
- * @return {boolean} Whether the character is whitespace.
- * @private
-ol.format.WKT.Lexer.prototype.isWhiteSpace_ = function(c) {
- return c == ' ' || c == '\t' || c == '\r' || c == '\n';
- * @return {string} Next string character.
- * @private
-ol.format.WKT.Lexer.prototype.nextChar_ = function() {
- return this.wkt.charAt(++this.index_);
- * Fetch and return the next token.
- * @return {!ol.WKTToken} Next string token.
-ol.format.WKT.Lexer.prototype.nextToken = function() {
- var c = this.nextChar_();
- var token = {position: this.index_, value: c};
- if (c == '(') {
- token.type = ol.format.WKT.TokenType_.LEFT_PAREN;
- } else if (c == ',') {
- token.type = ol.format.WKT.TokenType_.COMMA;
- } else if (c == ')') {
- token.type = ol.format.WKT.TokenType_.RIGHT_PAREN;
- } else if (this.isNumeric_(c) || c == '-') {
- token.type = ol.format.WKT.TokenType_.NUMBER;
- token.value = this.readNumber_();
- } else if (this.isAlpha_(c)) {
- token.type = ol.format.WKT.TokenType_.TEXT;
- token.value = this.readText_();
- } else if (this.isWhiteSpace_(c)) {
- return this.nextToken();
- } else if (c === '') {
- token.type = ol.format.WKT.TokenType_.EOF;
- } else {
- throw new Error('Unexpected character: ' + c);
- return token;
- * @return {number} Numeric token value.
- * @private
-ol.format.WKT.Lexer.prototype.readNumber_ = function() {
- var c, index = this.index_;
- var decimal = false;
- var scientificNotation = false;
- do {
- if (c == '.') {
- decimal = true;
- } else if (c == 'e' || c == 'E') {
- scientificNotation = true;
- c = this.nextChar_();
- } while (
- this.isNumeric_(c, decimal) ||
- // if we haven't detected a scientific number before, 'e' or 'E'
- // hint that we should continue to read
- !scientificNotation && (c == 'e' || c == 'E') ||
- // once we know that we have a scientific number, both '-' and '+'
- // are allowed
- scientificNotation && (c == '-' || c == '+')
- return parseFloat(this.wkt.substring(index, this.index_--));
- * @return {string} String token value.
- * @private
-ol.format.WKT.Lexer.prototype.readText_ = function() {
- do {
- } while (this.isAlpha_(c));
- return this.wkt.substring(index, this.index_--).toUpperCase();
- * Class to parse the tokens from the WKT string.
- * @param {ol.format.WKT.Lexer} lexer The lexer.
- * @constructor
- * @protected
-ol.format.WKT.Parser = function(lexer) {
- * @type {ol.format.WKT.Lexer}
- * @private
- this.lexer_ = lexer;
- * @type {ol.WKTToken}
- * @private
- this.token_;
- * @private
- this.layout_ = ol.geom.GeometryLayout.XY;
- * Fetch the next token form the lexer and replace the active token.
- * @private
-ol.format.WKT.Parser.prototype.consume_ = function() {
- this.token_ = this.lexer_.nextToken();
- * Tests if the given type matches the type of the current token.
- * @param {ol.format.WKT.TokenType_} type Token type.
- * @return {boolean} Whether the token matches the given type.
-ol.format.WKT.Parser.prototype.isTokenType = function(type) {
- var isMatch = this.token_.type == type;
- return isMatch;
- * If the given type matches the current token, consume it.
-ol.format.WKT.Parser.prototype.match = function(type) {
- var isMatch = this.isTokenType(type);
- if (isMatch) {
- this.consume_();
- return isMatch;
- * Try to parse the tokens provided by the lexer.
- * @return {ol.geom.Geometry} The geometry.
-ol.format.WKT.Parser.prototype.parse = function() {
- this.consume_();
- var geometry = this.parseGeometry_();
- return geometry;
- * Try to parse the dimensional info.
- * @return {ol.geom.GeometryLayout} The layout.
- * @private
-ol.format.WKT.Parser.prototype.parseGeometryLayout_ = function() {
- var layout = ol.geom.GeometryLayout.XY;
- var dimToken = this.token_;
- if (this.isTokenType(ol.format.WKT.TokenType_.TEXT)) {
- var dimInfo = dimToken.value;
- if (dimInfo === ol.format.WKT.Z) {
- layout = ol.geom.GeometryLayout.XYZ;
- } else if (dimInfo === ol.format.WKT.M) {
- layout = ol.geom.GeometryLayout.XYM;
- } else if (dimInfo === ol.format.WKT.ZM) {
- layout = ol.geom.GeometryLayout.XYZM;
- if (layout !== ol.geom.GeometryLayout.XY) {
- this.consume_();
- return layout;
- * @return {!ol.geom.Geometry} The geometry.
- * @private
-ol.format.WKT.Parser.prototype.parseGeometry_ = function() {
- var token = this.token_;
- if (this.match(ol.format.WKT.TokenType_.TEXT)) {
- var geomType = token.value;
- this.layout_ = this.parseGeometryLayout_();
- if (geomType == ol.geom.GeometryType.GEOMETRY_COLLECTION.toUpperCase()) {
- var geometries = this.parseGeometryCollectionText_();
- return new ol.geom.GeometryCollection(geometries);
- } else {
- var parser = ol.format.WKT.Parser.GeometryParser_[geomType];
- var ctor = ol.format.WKT.Parser.GeometryConstructor_[geomType];
- if (!parser || !ctor) {
- throw new Error('Invalid geometry type: ' + geomType);
- var coordinates = parser.call(this);
- return new ctor(coordinates, this.layout_);
- throw new Error(this.formatErrorMessage_());
- * @return {!Array.<ol.geom.Geometry>} A collection of geometries.
- * @private
-ol.format.WKT.Parser.prototype.parseGeometryCollectionText_ = function() {
- if (this.match(ol.format.WKT.TokenType_.LEFT_PAREN)) {
- do {
- geometries.push(this.parseGeometry_());
- } while (this.match(ol.format.WKT.TokenType_.COMMA));
- if (this.match(ol.format.WKT.TokenType_.RIGHT_PAREN)) {
- return geometries;
- } else if (this.isEmptyGeometry_()) {
- return [];
- * @return {Array.<number>} All values in a point.
- * @private
-ol.format.WKT.Parser.prototype.parsePointText_ = function() {
- var coordinates = this.parsePoint_();
- return null;
- * @return {!Array.<!Array.<number>>} All points in a linestring.
- * @private
-ol.format.WKT.Parser.prototype.parseLineStringText_ = function() {
- var coordinates = this.parsePointList_();
- return [];
- * @return {!Array.<!Array.<number>>} All points in a polygon.
- * @private
-ol.format.WKT.Parser.prototype.parsePolygonText_ = function() {
- var coordinates = this.parseLineStringTextList_();
- return [];
- * @return {!Array.<!Array.<number>>} All points in a multipoint.
- * @private
-ol.format.WKT.Parser.prototype.parseMultiPointText_ = function() {
- var coordinates;
- if (this.token_.type == ol.format.WKT.TokenType_.LEFT_PAREN) {
- coordinates = this.parsePointTextList_();
- } else {
- coordinates = this.parsePointList_();
- return [];
- * @return {!Array.<!Array.<number>>} All linestring points
- * in a multilinestring.
- * @private
-ol.format.WKT.Parser.prototype.parseMultiLineStringText_ = function() {
- return [];
- * @return {!Array.<!Array.<number>>} All polygon points in a multipolygon.
- * @private
-ol.format.WKT.Parser.prototype.parseMultiPolygonText_ = function() {
- var coordinates = this.parsePolygonTextList_();
- return [];
- * @return {!Array.<number>} A point.
- * @private
-ol.format.WKT.Parser.prototype.parsePoint_ = function() {
- var dimensions = this.layout_.length;
- for (var i = 0; i < dimensions; ++i) {
- if (this.match(ol.format.WKT.TokenType_.NUMBER)) {
- coordinates.push(token.value);
- } else {
- break;
- if (coordinates.length == dimensions) {
- * @return {!Array.<!Array.<number>>} An array of points.
- * @private
-ol.format.WKT.Parser.prototype.parsePointList_ = function() {
- var coordinates = [this.parsePoint_()];
- while (this.match(ol.format.WKT.TokenType_.COMMA)) {
- coordinates.push(this.parsePoint_());
- * @private
-ol.format.WKT.Parser.prototype.parsePointTextList_ = function() {
- var coordinates = [this.parsePointText_()];
- coordinates.push(this.parsePointText_());
- * @private
-ol.format.WKT.Parser.prototype.parseLineStringTextList_ = function() {
- var coordinates = [this.parseLineStringText_()];
- coordinates.push(this.parseLineStringText_());
- * @private
-ol.format.WKT.Parser.prototype.parsePolygonTextList_ = function() {
- var coordinates = [this.parsePolygonText_()];
- coordinates.push(this.parsePolygonText_());
- * @return {boolean} Whether the token implies an empty geometry.
- * @private
-ol.format.WKT.Parser.prototype.isEmptyGeometry_ = function() {
- var isEmpty = this.isTokenType(ol.format.WKT.TokenType_.TEXT) &&
- this.token_.value == ol.format.WKT.EMPTY;
- if (isEmpty) {
- this.consume_();
- return isEmpty;
- * Create an error message for an unexpected token error.
- * @return {string} Error message.
- * @private
-ol.format.WKT.Parser.prototype.formatErrorMessage_ = function() {
- return 'Unexpected `' + this.token_.value + '` at position ' +
- this.token_.position + ' in `' + this.lexer_.wkt + '`';
- * @enum {function (new:ol.geom.Geometry, Array, ol.geom.GeometryLayout)}
- * @private
-ol.format.WKT.Parser.GeometryConstructor_ = {
- 'POINT': ol.geom.Point,
- 'LINESTRING': ol.geom.LineString,
- 'POLYGON': ol.geom.Polygon,
- 'MULTIPOINT': ol.geom.MultiPoint,
- 'MULTILINESTRING': ol.geom.MultiLineString,
- 'MULTIPOLYGON': ol.geom.MultiPolygon
- * @enum {(function(): Array)}
- * @private
-ol.format.WKT.Parser.GeometryParser_ = {
- 'POINT': ol.format.WKT.Parser.prototype.parsePointText_,
- 'LINESTRING': ol.format.WKT.Parser.prototype.parseLineStringText_,
- 'POLYGON': ol.format.WKT.Parser.prototype.parsePolygonText_,
- 'MULTIPOINT': ol.format.WKT.Parser.prototype.parseMultiPointText_,
- 'MULTILINESTRING': ol.format.WKT.Parser.prototype.parseMultiLineStringText_,
- 'MULTIPOLYGON': ol.format.WKT.Parser.prototype.parseMultiPolygonText_
-goog.provide('ol.format.WMSCapabilities');
-goog.require('ol');
-goog.require('ol.format.XLink');
-goog.require('ol.format.XML');
-goog.require('ol.format.XSD');
-goog.require('ol.xml');
- * @classdesc
- * Format for reading WMS capabilities data
- * @constructor
- * @extends {ol.format.XML}
- * @api
-ol.format.WMSCapabilities = function() {
- ol.format.XML.call(this);
- * @type {string|undefined}
- this.version = undefined;
-ol.inherits(ol.format.WMSCapabilities, ol.format.XML);
- * Read a WMS capabilities document.
- * @function
- * @param {Document|Node|string} source The XML source.
- * @return {Object} An object representing the WMS capabilities.
- * @api
-ol.format.WMSCapabilities.prototype.read;
- * @inheritDoc
-ol.format.WMSCapabilities.prototype.readFromDocument = function(doc) {
- for (var n = doc.firstChild; n; n = n.nextSibling) {
- if (n.nodeType == Node.ELEMENT_NODE) {
- return this.readFromNode(n);
- return null;
- * @inheritDoc
-ol.format.WMSCapabilities.prototype.readFromNode = function(node) {
- this.version = node.getAttribute('version').trim();
- var wmsCapabilityObject = ol.xml.pushParseAndPop({
- 'version': this.version
- }, ol.format.WMSCapabilities.PARSERS_, node, []);
- return wmsCapabilityObject ? wmsCapabilityObject : null;
- * @private
- * @param {Node} node Node.
- * @param {Array.<*>} objectStack Object stack.
- * @return {Object|undefined} Attribution object.
-ol.format.WMSCapabilities.readAttribution_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop(
- {}, ol.format.WMSCapabilities.ATTRIBUTION_PARSERS_, node, objectStack);
- * @private
- * @return {Object} Bounding box object.
-ol.format.WMSCapabilities.readBoundingBox_ = function(node, objectStack) {
- var extent = [
- ol.format.XSD.readDecimalString(node.getAttribute('minx')),
- ol.format.XSD.readDecimalString(node.getAttribute('miny')),
- ol.format.XSD.readDecimalString(node.getAttribute('maxx')),
- ol.format.XSD.readDecimalString(node.getAttribute('maxy'))
- var resolutions = [
- ol.format.XSD.readDecimalString(node.getAttribute('resx')),
- ol.format.XSD.readDecimalString(node.getAttribute('resy'))
- return {
- 'crs': node.getAttribute('CRS'),
- 'extent': extent,
- 'res': resolutions
- * @private
- * @return {ol.Extent|undefined} Bounding box object.
-ol.format.WMSCapabilities.readEXGeographicBoundingBox_ = function(node, objectStack) {
- var geographicBoundingBox = ol.xml.pushParseAndPop(
- ol.format.WMSCapabilities.EX_GEOGRAPHIC_BOUNDING_BOX_PARSERS_,
- node, objectStack);
- if (!geographicBoundingBox) {
- return undefined;
- var westBoundLongitude = /** @type {number|undefined} */
- (geographicBoundingBox['westBoundLongitude']);
- var southBoundLatitude = /** @type {number|undefined} */
- (geographicBoundingBox['southBoundLatitude']);
- var eastBoundLongitude = /** @type {number|undefined} */
- (geographicBoundingBox['eastBoundLongitude']);
- var northBoundLatitude = /** @type {number|undefined} */
- (geographicBoundingBox['northBoundLatitude']);
- if (westBoundLongitude === undefined || southBoundLatitude === undefined ||
- eastBoundLongitude === undefined || northBoundLatitude === undefined) {
- return undefined;
- return [
- westBoundLongitude, southBoundLatitude,
- eastBoundLongitude, northBoundLatitude
- * @private
- * @return {Object|undefined} Capability object.
-ol.format.WMSCapabilities.readCapability_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.CAPABILITY_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Service object.
-ol.format.WMSCapabilities.readService_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.SERVICE_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Contact information object.
-ol.format.WMSCapabilities.readContactInformation_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.CONTACT_INFORMATION_PARSERS_,
- * @private
- * @return {Object|undefined} Contact person object.
-ol.format.WMSCapabilities.readContactPersonPrimary_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.CONTACT_PERSON_PARSERS_,
- * @private
- * @return {Object|undefined} Contact address object.
-ol.format.WMSCapabilities.readContactAddress_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.CONTACT_ADDRESS_PARSERS_,
- * @private
- * @return {Array.<string>|undefined} Format array.
-ol.format.WMSCapabilities.readException_ = function(node, objectStack) {
- [], ol.format.WMSCapabilities.EXCEPTION_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Layer object.
-ol.format.WMSCapabilities.readCapabilityLayer_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.LAYER_PARSERS_, node, objectStack);
- * @private
-ol.format.WMSCapabilities.readLayer_ = function(node, objectStack) {
- var parentLayerObject = /** @type {Object.<string,*>} */
- (objectStack[objectStack.length - 1]);
- var layerObject = ol.xml.pushParseAndPop(
- if (!layerObject) {
- return undefined;
- var queryable =
- ol.format.XSD.readBooleanString(node.getAttribute('queryable'));
- if (queryable === undefined) {
- queryable = parentLayerObject['queryable'];
- layerObject['queryable'] = queryable !== undefined ? queryable : false;
- var cascaded = ol.format.XSD.readNonNegativeIntegerString(
- node.getAttribute('cascaded'));
- if (cascaded === undefined) {
- cascaded = parentLayerObject['cascaded'];
- layerObject['cascaded'] = cascaded;
- var opaque = ol.format.XSD.readBooleanString(node.getAttribute('opaque'));
- if (opaque === undefined) {
- opaque = parentLayerObject['opaque'];
- layerObject['opaque'] = opaque !== undefined ? opaque : false;
- var noSubsets =
- ol.format.XSD.readBooleanString(node.getAttribute('noSubsets'));
- if (noSubsets === undefined) {
- noSubsets = parentLayerObject['noSubsets'];
- layerObject['noSubsets'] = noSubsets !== undefined ? noSubsets : false;
- var fixedWidth =
- ol.format.XSD.readDecimalString(node.getAttribute('fixedWidth'));
- if (!fixedWidth) {
- fixedWidth = parentLayerObject['fixedWidth'];
- layerObject['fixedWidth'] = fixedWidth;
- var fixedHeight =
- ol.format.XSD.readDecimalString(node.getAttribute('fixedHeight'));
- if (!fixedHeight) {
- fixedHeight = parentLayerObject['fixedHeight'];
- layerObject['fixedHeight'] = fixedHeight;
- // See 7.2.4.8
- var addKeys = ['Style', 'CRS', 'AuthorityURL'];
- addKeys.forEach(function(key) {
- if (key in parentLayerObject) {
- var childValue = layerObject[key] || [];
- layerObject[key] = childValue.concat(parentLayerObject[key]);
- var replaceKeys = ['EX_GeographicBoundingBox', 'BoundingBox', 'Dimension',
- 'Attribution', 'MinScaleDenominator', 'MaxScaleDenominator'];
- replaceKeys.forEach(function(key) {
- if (!(key in layerObject)) {
- var parentValue = parentLayerObject[key];
- layerObject[key] = parentValue;
- return layerObject;
- * @private
- * @return {Object} Dimension object.
-ol.format.WMSCapabilities.readDimension_ = function(node, objectStack) {
- var dimensionObject = {
- 'name': node.getAttribute('name'),
- 'units': node.getAttribute('units'),
- 'unitSymbol': node.getAttribute('unitSymbol'),
- 'default': node.getAttribute('default'),
- 'multipleValues': ol.format.XSD.readBooleanString(
- node.getAttribute('multipleValues')),
- 'nearestValue': ol.format.XSD.readBooleanString(
- node.getAttribute('nearestValue')),
- 'current': ol.format.XSD.readBooleanString(node.getAttribute('current')),
- 'values': ol.format.XSD.readString(node)
- return dimensionObject;
- * @private
- * @return {Object|undefined} Online resource object.
-ol.format.WMSCapabilities.readFormatOnlineresource_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.FORMAT_ONLINERESOURCE_PARSERS_,
- * @private
- * @return {Object|undefined} Request object.
-ol.format.WMSCapabilities.readRequest_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.REQUEST_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} DCP type object.
-ol.format.WMSCapabilities.readDCPType_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.DCPTYPE_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} HTTP object.
-ol.format.WMSCapabilities.readHTTP_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.HTTP_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Operation type object.
-ol.format.WMSCapabilities.readOperationType_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.OPERATIONTYPE_PARSERS_, node, objectStack);
- * @private
-ol.format.WMSCapabilities.readSizedFormatOnlineresource_ = function(node, objectStack) {
- var formatOnlineresource =
- ol.format.WMSCapabilities.readFormatOnlineresource_(node, objectStack);
- if (formatOnlineresource) {
- var size = [
- ol.format.XSD.readNonNegativeIntegerString(node.getAttribute('width')),
- ol.format.XSD.readNonNegativeIntegerString(node.getAttribute('height'))
- formatOnlineresource['size'] = size;
- return formatOnlineresource;
- return undefined;
- * @private
- * @return {Object|undefined} Authority URL object.
-ol.format.WMSCapabilities.readAuthorityURL_ = function(node, objectStack) {
- var authorityObject =
- if (authorityObject) {
- authorityObject['name'] = node.getAttribute('name');
- return authorityObject;
- return undefined;
- * @private
- * @return {Object|undefined} Metadata URL object.
-ol.format.WMSCapabilities.readMetadataURL_ = function(node, objectStack) {
- var metadataObject =
- if (metadataObject) {
- metadataObject['type'] = node.getAttribute('type');
- return metadataObject;
- return undefined;
- * @private
- * @return {Object|undefined} Style object.
-ol.format.WMSCapabilities.readStyle_ = function(node, objectStack) {
- {}, ol.format.WMSCapabilities.STYLE_PARSERS_, node, objectStack);
- * @private
- * @return {Array.<string>|undefined} Keyword list.
-ol.format.WMSCapabilities.readKeywordList_ = function(node, objectStack) {
- [], ol.format.WMSCapabilities.KEYWORDLIST_PARSERS_, node, objectStack);
- * @const
- * @private
- * @type {Array.<string>}
-ol.format.WMSCapabilities.NAMESPACE_URIS_ = [
- null,
- 'http://www.opengis.net/wms'
- * @const
- * @type {Object.<string, Object.<string, ol.XmlParser>>}
- * @private
-ol.format.WMSCapabilities.PARSERS_ = ol.xml.makeStructureNS(
- ol.format.WMSCapabilities.NAMESPACE_URIS_, {
- 'Service': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readService_),
- 'Capability': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readCapability_)
- * @const
- * @private
-ol.format.WMSCapabilities.CAPABILITY_PARSERS_ = ol.xml.makeStructureNS(
- 'Request': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readRequest_),
- 'Exception': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readException_),
- 'Layer': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readCapabilityLayer_)
- * @const
- * @private
-ol.format.WMSCapabilities.SERVICE_PARSERS_ = ol.xml.makeStructureNS(
- 'Name': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'Title': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'Abstract': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'KeywordList': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readKeywordList_),
- 'OnlineResource': ol.xml.makeObjectPropertySetter(
- ol.format.XLink.readHref),
- 'ContactInformation': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readContactInformation_),
- 'Fees': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'AccessConstraints': ol.xml.makeObjectPropertySetter(
- ol.format.XSD.readString),
- 'LayerLimit': ol.xml.makeObjectPropertySetter(
- 'MaxWidth': ol.xml.makeObjectPropertySetter(
- 'MaxHeight': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.CONTACT_INFORMATION_PARSERS_ = ol.xml.makeStructureNS(
- 'ContactPersonPrimary': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readContactPersonPrimary_),
- 'ContactPosition': ol.xml.makeObjectPropertySetter(
- 'ContactAddress': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readContactAddress_),
- 'ContactVoiceTelephone': ol.xml.makeObjectPropertySetter(
- 'ContactFacsimileTelephone': ol.xml.makeObjectPropertySetter(
- 'ContactElectronicMailAddress': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.CONTACT_PERSON_PARSERS_ = ol.xml.makeStructureNS(
- 'ContactPerson': ol.xml.makeObjectPropertySetter(
- 'ContactOrganization': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.CONTACT_ADDRESS_PARSERS_ = ol.xml.makeStructureNS(
- 'AddressType': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'Address': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'City': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'StateOrProvince': ol.xml.makeObjectPropertySetter(
- 'PostCode': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- 'Country': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
- * @const
- * @private
-ol.format.WMSCapabilities.EXCEPTION_PARSERS_ = ol.xml.makeStructureNS(
- 'Format': ol.xml.makeArrayPusher(ol.format.XSD.readString)
- * @const
- * @private
-ol.format.WMSCapabilities.LAYER_PARSERS_ = ol.xml.makeStructureNS(
- 'CRS': ol.xml.makeObjectPropertyPusher(ol.format.XSD.readString),
- 'EX_GeographicBoundingBox': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readEXGeographicBoundingBox_),
- 'BoundingBox': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readBoundingBox_),
- 'Dimension': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readDimension_),
- 'Attribution': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readAttribution_),
- 'AuthorityURL': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readAuthorityURL_),
- 'Identifier': ol.xml.makeObjectPropertyPusher(ol.format.XSD.readString),
- 'MetadataURL': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readMetadataURL_),
- 'DataURL': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readFormatOnlineresource_),
- 'FeatureListURL': ol.xml.makeObjectPropertyPusher(
- 'Style': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readStyle_),
- 'MinScaleDenominator': ol.xml.makeObjectPropertySetter(
- ol.format.XSD.readDecimal),
- 'MaxScaleDenominator': ol.xml.makeObjectPropertySetter(
- 'Layer': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readLayer_)
- * @const
- * @private
-ol.format.WMSCapabilities.ATTRIBUTION_PARSERS_ = ol.xml.makeStructureNS(
- 'LogoURL': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readSizedFormatOnlineresource_)
- * @const
- * @private
-ol.format.WMSCapabilities.EX_GEOGRAPHIC_BOUNDING_BOX_PARSERS_ =
- ol.xml.makeStructureNS(ol.format.WMSCapabilities.NAMESPACE_URIS_, {
- 'westBoundLongitude': ol.xml.makeObjectPropertySetter(
- 'eastBoundLongitude': ol.xml.makeObjectPropertySetter(
- 'southBoundLatitude': ol.xml.makeObjectPropertySetter(
- 'northBoundLatitude': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.REQUEST_PARSERS_ = ol.xml.makeStructureNS(
- 'GetCapabilities': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readOperationType_),
- 'GetMap': ol.xml.makeObjectPropertySetter(
- 'GetFeatureInfo': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.OPERATIONTYPE_PARSERS_ = ol.xml.makeStructureNS(
- 'Format': ol.xml.makeObjectPropertyPusher(ol.format.XSD.readString),
- 'DCPType': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readDCPType_)
- * @const
- * @private
-ol.format.WMSCapabilities.DCPTYPE_PARSERS_ = ol.xml.makeStructureNS(
- 'HTTP': ol.xml.makeObjectPropertySetter(
- ol.format.WMSCapabilities.readHTTP_)
- * @const
- * @private
-ol.format.WMSCapabilities.HTTP_PARSERS_ = ol.xml.makeStructureNS(
- 'Get': ol.xml.makeObjectPropertySetter(
- 'Post': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.STYLE_PARSERS_ = ol.xml.makeStructureNS(
- 'LegendURL': ol.xml.makeObjectPropertyPusher(
- ol.format.WMSCapabilities.readSizedFormatOnlineresource_),
- 'StyleSheetURL': ol.xml.makeObjectPropertySetter(
- 'StyleURL': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMSCapabilities.FORMAT_ONLINERESOURCE_PARSERS_ =
- 'Format': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
- * @const
- * @private
-ol.format.WMSCapabilities.KEYWORDLIST_PARSERS_ = ol.xml.makeStructureNS(
- 'Keyword': ol.xml.makeArrayPusher(ol.format.XSD.readString)
-goog.provide('ol.format.WMSGetFeatureInfo');
-goog.require('ol.array');
-goog.require('ol.format.XMLFeature');
-goog.require('ol.obj');
- * @classdesc
- * Format for reading WMSGetFeatureInfo format. It uses
- * {@link ol.format.GML2} to read features.
- * @constructor
- * @extends {ol.format.XMLFeature}
- * @param {olx.format.WMSGetFeatureInfoOptions=} opt_options Options.
- * @api
-ol.format.WMSGetFeatureInfo = function(opt_options) {
- var options = opt_options ? opt_options : {};
- * @private
- * @type {string}
- this.featureNS_ = 'http://mapserver.gis.umn.edu/mapserver';
- * @private
- * @type {ol.format.GML2}
- this.gmlFormat_ = new ol.format.GML2();
- * @private
- this.layers_ = options.layers ? options.layers : null;
- ol.format.XMLFeature.call(this);
-ol.inherits(ol.format.WMSGetFeatureInfo, ol.format.XMLFeature);
- * @const
- * @type {string}
- * @private
-ol.format.WMSGetFeatureInfo.featureIdentifier_ = '_feature';
- * @const
- * @type {string}
- * @private
-ol.format.WMSGetFeatureInfo.layerIdentifier_ = '_layer';
- * @return {Array.<ol.Feature>} Features.
- * @private
-ol.format.WMSGetFeatureInfo.prototype.readFeatures_ = function(node, objectStack) {
- node.setAttribute('namespaceURI', this.featureNS_);
- var localName = node.localName;
- var features = [];
- if (node.childNodes.length === 0) {
- return features;
- if (localName == 'msGMLOutput') {
- for (var i = 0, ii = node.childNodes.length; i < ii; i++) {
- var layer = node.childNodes[i];
- if (layer.nodeType !== Node.ELEMENT_NODE) {
- continue;
- var context = objectStack[0];
- var toRemove = ol.format.WMSGetFeatureInfo.layerIdentifier_;
- var layerName = layer.localName.replace(toRemove, '');
- if (this.layers_ && !ol.array.includes(this.layers_, layerName)) {
- continue;
- var featureType = layerName +
- ol.format.WMSGetFeatureInfo.featureIdentifier_;
- context['featureType'] = featureType;
- context['featureNS'] = this.featureNS_;
- var parsers = {};
- parsers[featureType] = ol.xml.makeArrayPusher(
- this.gmlFormat_.readFeatureElement, this.gmlFormat_);
- var parsersNS = ol.xml.makeStructureNS(
- [context['featureNS'], null], parsers);
- layer.setAttribute('namespaceURI', this.featureNS_);
- var layerFeatures = ol.xml.pushParseAndPop(
- [], parsersNS, layer, objectStack, this.gmlFormat_);
- if (layerFeatures) {
- ol.array.extend(features, layerFeatures);
- if (localName == 'FeatureCollection') {
- var gmlFeatures = ol.xml.pushParseAndPop([],
- [{}], this.gmlFormat_);
- if (gmlFeatures) {
- features = gmlFeatures;
- return features;
- * Read all features from a WMSGetFeatureInfo response.
- * @function
- * @param {Document|Node|Object|string} source Source.
- * @param {olx.format.ReadOptions=} opt_options Options.
- * @api
-ol.format.WMSGetFeatureInfo.prototype.readFeatures;
- * @inheritDoc
-ol.format.WMSGetFeatureInfo.prototype.readFeaturesFromNode = function(node, opt_options) {
- var options = {};
- if (opt_options) {
- ol.obj.assign(options, this.getReadOptions(node, opt_options));
- return this.readFeatures_(node, [options]);
- * Not implemented.
- * @inheritDoc
-ol.format.WMSGetFeatureInfo.prototype.writeFeatureNode = function(feature, opt_options) {};
- * @inheritDoc
-ol.format.WMSGetFeatureInfo.prototype.writeFeaturesNode = function(features, opt_options) {};
- * @inheritDoc
-ol.format.WMSGetFeatureInfo.prototype.writeGeometryNode = function(geometry, opt_options) {};
-goog.provide('ol.format.WMTSCapabilities');
-goog.require('ol.extent');
-goog.require('ol.format.OWS');
- * @classdesc
- * Format for reading WMTS capabilities data.
- * @constructor
- * @api
-ol.format.WMTSCapabilities = function() {
- * @type {ol.format.OWS}
- * @private
- this.owsParser_ = new ol.format.OWS();
-ol.inherits(ol.format.WMTSCapabilities, ol.format.XML);
- * Read a WMTS capabilities document.
- * @function
- * @return {Object} An object representing the WMTS capabilities.
- * @api
-ol.format.WMTSCapabilities.prototype.read;
- * @inheritDoc
-ol.format.WMTSCapabilities.prototype.readFromDocument = function(doc) {
- return null;
- * @inheritDoc
-ol.format.WMTSCapabilities.prototype.readFromNode = function(node) {
- var version = node.getAttribute('version').trim();
- var WMTSCapabilityObject = this.owsParser_.readFromNode(node);
- if (!WMTSCapabilityObject) {
- return null;
- WMTSCapabilityObject['version'] = version;
- WMTSCapabilityObject = ol.xml.pushParseAndPop(WMTSCapabilityObject,
- ol.format.WMTSCapabilities.PARSERS_, node, []);
- return WMTSCapabilityObject ? WMTSCapabilityObject : null;
- * @private
-ol.format.WMTSCapabilities.readContents_ = function(node, objectStack) {
- return ol.xml.pushParseAndPop({},
- ol.format.WMTSCapabilities.CONTENTS_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Layers object.
-ol.format.WMTSCapabilities.readLayer_ = function(node, objectStack) {
- ol.format.WMTSCapabilities.LAYER_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Tile Matrix Set object.
-ol.format.WMTSCapabilities.readTileMatrixSet_ = function(node, objectStack) {
- ol.format.WMTSCapabilities.TMS_PARSERS_, node, objectStack);
- * @private
-ol.format.WMTSCapabilities.readStyle_ = function(node, objectStack) {
- var style = ol.xml.pushParseAndPop({},
- ol.format.WMTSCapabilities.STYLE_PARSERS_, node, objectStack);
- if (!style) {
- return undefined;
- var isDefault = node.getAttribute('isDefault') === 'true';
- style['isDefault'] = isDefault;
- return style;
- * @private
- * @return {Object|undefined} Tile Matrix Set Link object.
-ol.format.WMTSCapabilities.readTileMatrixSetLink_ = function(node,
- objectStack) {
- ol.format.WMTSCapabilities.TMS_LINKS_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Dimension object.
-ol.format.WMTSCapabilities.readDimensions_ = function(node, objectStack) {
- ol.format.WMTSCapabilities.DIMENSION_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} Resource URL object.
-ol.format.WMTSCapabilities.readResourceUrl_ = function(node, objectStack) {
- var format = node.getAttribute('format');
- var template = node.getAttribute('template');
- var resourceType = node.getAttribute('resourceType');
- var resource = {};
- if (format) {
- resource['format'] = format;
- if (template) {
- resource['template'] = template;
- if (resourceType) {
- resource['resourceType'] = resourceType;
- return resource;
- * @private
- * @return {Object|undefined} WGS84 BBox object.
-ol.format.WMTSCapabilities.readWgs84BoundingBox_ = function(node, objectStack) {
- var coordinates = ol.xml.pushParseAndPop([],
- ol.format.WMTSCapabilities.WGS84_BBOX_READERS_, node, objectStack);
- if (coordinates.length != 2) {
- return undefined;
- return ol.extent.boundingExtent(coordinates);
- * @private
- * @return {Object|undefined} Legend object.
-ol.format.WMTSCapabilities.readLegendUrl_ = function(node, objectStack) {
- var legend = {};
- legend['format'] = node.getAttribute('format');
- legend['href'] = ol.format.XLink.readHref(node);
- return legend;
- * @private
- * @return {Object|undefined} Coordinates object.
-ol.format.WMTSCapabilities.readCoordinates_ = function(node, objectStack) {
- var coordinates = ol.format.XSD.readString(node).split(' ');
- if (!coordinates || coordinates.length != 2) {
- return undefined;
- var x = +coordinates[0];
- var y = +coordinates[1];
- if (isNaN(x) || isNaN(y)) {
- return undefined;
- return [x, y];
- * @private
- * @return {Object|undefined} TileMatrix object.
-ol.format.WMTSCapabilities.readTileMatrix_ = function(node, objectStack) {
- ol.format.WMTSCapabilities.TM_PARSERS_, node, objectStack);
- * @private
- * @return {Object|undefined} TileMatrixSetLimits Object.
-ol.format.WMTSCapabilities.readTileMatrixLimitsList_ = function(node,
- objectStack) {
- return ol.xml.pushParseAndPop([],
- ol.format.WMTSCapabilities.TMS_LIMITS_LIST_PARSERS_, node,
- objectStack);
- * @private
- * @return {Object|undefined} TileMatrixLimits Array.
-ol.format.WMTSCapabilities.readTileMatrixLimits_ = function(node, objectStack) {
- ol.format.WMTSCapabilities.TMS_LIMITS_PARSERS_, node, objectStack);
- * @const
- * @private
-ol.format.WMTSCapabilities.NAMESPACE_URIS_ = [
- null,
- 'http://www.opengis.net/wmts/1.0'
- * @const
- * @private
-ol.format.WMTSCapabilities.OWS_NAMESPACE_URIS_ = [
- null,
- 'http://www.opengis.net/ows/1.1'
- * @const
- * @private
-ol.format.WMTSCapabilities.PARSERS_ = ol.xml.makeStructureNS(
- ol.format.WMTSCapabilities.NAMESPACE_URIS_, {
- 'Contents': ol.xml.makeObjectPropertySetter(
- ol.format.WMTSCapabilities.readContents_)
- * @const
- * @private
-ol.format.WMTSCapabilities.CONTENTS_PARSERS_ = ol.xml.makeStructureNS(
- ol.format.WMTSCapabilities.readLayer_),
- 'TileMatrixSet': ol.xml.makeObjectPropertyPusher(
- ol.format.WMTSCapabilities.readTileMatrixSet_)
- * @const
- * @private
-ol.format.WMTSCapabilities.LAYER_PARSERS_ = ol.xml.makeStructureNS(
- ol.format.WMTSCapabilities.readStyle_),
- 'TileMatrixSetLink': ol.xml.makeObjectPropertyPusher(
- ol.format.WMTSCapabilities.readTileMatrixSetLink_),
- ol.format.WMTSCapabilities.readDimensions_),
- 'ResourceURL': ol.xml.makeObjectPropertyPusher(
- ol.format.WMTSCapabilities.readResourceUrl_)
- }, ol.xml.makeStructureNS(ol.format.WMTSCapabilities.OWS_NAMESPACE_URIS_, {
- 'WGS84BoundingBox': ol.xml.makeObjectPropertySetter(
- ol.format.WMTSCapabilities.readWgs84BoundingBox_),
- 'Identifier': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMTSCapabilities.STYLE_PARSERS_ = ol.xml.makeStructureNS(
- ol.format.WMTSCapabilities.readLegendUrl_)
- * @const
- * @private
-ol.format.WMTSCapabilities.TMS_LINKS_PARSERS_ = ol.xml.makeStructureNS(
- 'TileMatrixSet': ol.xml.makeObjectPropertySetter(
- 'TileMatrixSetLimits': ol.xml.makeObjectPropertySetter(
- ol.format.WMTSCapabilities.readTileMatrixLimitsList_)
- * @const
- * @private
-ol.format.WMTSCapabilities.TMS_LIMITS_LIST_PARSERS_ = ol.xml.makeStructureNS(
- 'TileMatrixLimits': ol.xml.makeArrayPusher(
- ol.format.WMTSCapabilities.readTileMatrixLimits_)
- * @const
- * @private
-ol.format.WMTSCapabilities.TMS_LIMITS_PARSERS_ = ol.xml.makeStructureNS(
- 'TileMatrix': ol.xml.makeObjectPropertySetter(
- 'MinTileRow': ol.xml.makeObjectPropertySetter(
- ol.format.XSD.readNonNegativeInteger),
- 'MaxTileRow': ol.xml.makeObjectPropertySetter(
- 'MinTileCol': ol.xml.makeObjectPropertySetter(
- 'MaxTileCol': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMTSCapabilities.DIMENSION_PARSERS_ = ol.xml.makeStructureNS(
- 'Default': ol.xml.makeObjectPropertySetter(
- 'Value': ol.xml.makeObjectPropertyPusher(
- * @const
- * @private
-ol.format.WMTSCapabilities.WGS84_BBOX_READERS_ = ol.xml.makeStructureNS(
- ol.format.WMTSCapabilities.OWS_NAMESPACE_URIS_, {
- 'LowerCorner': ol.xml.makeArrayPusher(
- ol.format.WMTSCapabilities.readCoordinates_),
- 'UpperCorner': ol.xml.makeArrayPusher(
- * @const
- * @private
-ol.format.WMTSCapabilities.TMS_PARSERS_ = ol.xml.makeStructureNS(
- 'WellKnownScaleSet': ol.xml.makeObjectPropertySetter(
- 'TileMatrix': ol.xml.makeObjectPropertyPusher(
- ol.format.WMTSCapabilities.readTileMatrix_)
- 'SupportedCRS': ol.xml.makeObjectPropertySetter(
- * @const
- * @private
-ol.format.WMTSCapabilities.TM_PARSERS_ = ol.xml.makeStructureNS(
- 'TopLeftCorner': ol.xml.makeObjectPropertySetter(
- 'ScaleDenominator': ol.xml.makeObjectPropertySetter(
- 'TileWidth': ol.xml.makeObjectPropertySetter(
- 'TileHeight': ol.xml.makeObjectPropertySetter(
- 'MatrixWidth': ol.xml.makeObjectPropertySetter(
- 'MatrixHeight': ol.xml.makeObjectPropertySetter(
-goog.provide('ol.GeolocationProperty');
- * @enum {string}
-ol.GeolocationProperty = {
- ACCURACY: 'accuracy',
- ACCURACY_GEOMETRY: 'accuracyGeometry',
- ALTITUDE: 'altitude',
- ALTITUDE_ACCURACY: 'altitudeAccuracy',
- HEADING: 'heading',
- POSITION: 'position',
- PROJECTION: 'projection',
- SPEED: 'speed',
- TRACKING: 'tracking',
- TRACKING_OPTIONS: 'trackingOptions'
-// FIXME handle geolocation not supported
-goog.provide('ol.Geolocation');
-goog.require('ol.Object');
-goog.require('ol.GeolocationProperty');
-goog.require('ol.events');
-goog.require('ol.events.EventType');
-goog.require('ol.geom.Polygon');
-goog.require('ol.has');
-goog.require('ol.math');
-goog.require('ol.proj');
-goog.require('ol.sphere.WGS84');
- * @classdesc
- * Helper class for providing HTML5 Geolocation capabilities.
- * The [Geolocation API](http://www.w3.org/TR/geolocation-API/)
- * is used to locate a user's position.
- * To get notified of position changes, register a listener for the generic
- * `change` event on your instance of `ol.Geolocation`.
- * Example:
- * var geolocation = new ol.Geolocation({
- * // take the projection to use from the map's view
- * projection: view.getProjection()
- * // listen to changes in position
- * geolocation.on('change', function(evt) {
- * window.console.log(geolocation.getPosition());
- * @fires error
- * @constructor
- * @extends {ol.Object}
- * @param {olx.GeolocationOptions=} opt_options Options.
- * @api
-ol.Geolocation = function(opt_options) {
- ol.Object.call(this);
- var options = opt_options || {};
- * The unprojected (EPSG:4326) device position.
- * @private
- * @type {ol.Coordinate}
- this.position_ = null;
- * @private
- * @type {ol.TransformFunction}
- this.transform_ = ol.proj.identityTransform;
- * @private
- * @type {number|undefined}
- this.watchId_ = undefined;
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.GeolocationProperty.PROJECTION),
- this.handleProjectionChanged_, this);
- ol.events.listen(
- this, ol.Object.getChangeEventType(ol.GeolocationProperty.TRACKING),
- this.handleTrackingChanged_, this);
- if (options.projection !== undefined) {
- this.setProjection(ol.proj.get(options.projection));
- if (options.trackingOptions !== undefined) {
- this.setTrackingOptions(options.trackingOptions);
- this.setTracking(options.tracking !== undefined ? options.tracking : false);
-ol.inherits(ol.Geolocation, ol.Object);
- * @inheritDoc
-ol.Geolocation.prototype.disposeInternal = function() {
- this.setTracking(false);
- ol.Object.prototype.disposeInternal.call(this);
- * @private
-ol.Geolocation.prototype.handleProjectionChanged_ = function() {
- var projection = this.getProjection();
- if (projection) {
- this.transform_ = ol.proj.getTransformFromProjections(
- ol.proj.get('EPSG:4326'), projection);
- if (this.position_) {
- this.set(
- ol.GeolocationProperty.POSITION, this.transform_(this.position_));
- * @private
-ol.Geolocation.prototype.handleTrackingChanged_ = function() {
- if (ol.has.GEOLOCATION) {
- var tracking = this.getTracking();
- if (tracking && this.watchId_ === undefined) {
- this.watchId_ = navigator.geolocation.watchPosition(
- this.positionChange_.bind(this),
- this.positionError_.bind(this),
- this.getTrackingOptions());
- } else if (!tracking && this.watchId_ !== undefined) {
- navigator.geolocation.clearWatch(this.watchId_);
- * @private
- * @param {GeolocationPosition} position position event.
-ol.Geolocation.prototype.positionChange_ = function(position) {
- var coords = position.coords;
- this.set(ol.GeolocationProperty.ACCURACY, coords.accuracy);
- this.set(ol.GeolocationProperty.ALTITUDE,
- coords.altitude === null ? undefined : coords.altitude);
- this.set(ol.GeolocationProperty.ALTITUDE_ACCURACY,
- coords.altitudeAccuracy === null ?
- undefined : coords.altitudeAccuracy);
- this.set(ol.GeolocationProperty.HEADING, coords.heading === null ?
- undefined : ol.math.toRadians(coords.heading));
- if (!this.position_) {
- this.position_ = [coords.longitude, coords.latitude];
- } else {
- this.position_[0] = coords.longitude;
- this.position_[1] = coords.latitude;
- var projectedPosition = this.transform_(this.position_);
- this.set(ol.GeolocationProperty.POSITION, projectedPosition);
- this.set(ol.GeolocationProperty.SPEED,
- coords.speed === null ? undefined : coords.speed);
- var geometry = ol.geom.Polygon.circular(
- ol.sphere.WGS84, this.position_, coords.accuracy);
- geometry.applyTransform(this.transform_);
- this.set(ol.GeolocationProperty.ACCURACY_GEOMETRY, geometry);
- this.changed();
- * Triggered when the Geolocation returns an error.
- * @event error
- * @api
- * @private
- * @param {GeolocationPositionError} error error object.
-ol.Geolocation.prototype.positionError_ = function(error) {
- error.type = ol.events.EventType.ERROR;
- this.dispatchEvent(/** @type {{type: string, target: undefined}} */ (error));
- * Get the accuracy of the position in meters.
- * @return {number|undefined} The accuracy of the position measurement in
- * meters.
- * @observable
- * @api
-ol.Geolocation.prototype.getAccuracy = function() {
- return /** @type {number|undefined} */ (
- this.get(ol.GeolocationProperty.ACCURACY));
- * Get a geometry of the position accuracy.
- * @return {?ol.geom.Polygon} A geometry of the position accuracy.
- * @observable
- * @api
-ol.Geolocation.prototype.getAccuracyGeometry = function() {
- return /** @type {?ol.geom.Polygon} */ (
- this.get(ol.GeolocationProperty.ACCURACY_GEOMETRY) || null);
- * Get the altitude associated with the position.
- * @return {number|undefined} The altitude of the position in meters above mean
- * sea level.
- * @observable
- * @api
-ol.Geolocation.prototype.getAltitude = function() {
- this.get(ol.GeolocationProperty.ALTITUDE));
- * Get the altitude accuracy of the position.
- * @return {number|undefined} The accuracy of the altitude measurement in
- * meters.
- * @observable
- * @api
-ol.Geolocation.prototype.getAltitudeAccuracy = function() {
- this.get(ol.GeolocationProperty.ALTITUDE_ACCURACY));
- * Get the heading as radians clockwise from North.
- * @return {number|undefined} The heading of the device in radians from north.
- * @observable
- * @api
-ol.Geolocation.prototype.getHeading = function() {
- this.get(ol.GeolocationProperty.HEADING));
- * Get the position of the device.
- * @return {ol.Coordinate|undefined} The current position of the device reported
- * in the current projection.
- * @observable
- * @api
-ol.Geolocation.prototype.getPosition = function() {
- return /** @type {ol.Coordinate|undefined} */ (
- this.get(ol.GeolocationProperty.POSITION));
- * Get the projection associated with the position.
- * @return {ol.proj.Projection|undefined} The projection the position is
- * reported in.
- * @observable
- * @api
-ol.Geolocation.prototype.getProjection = function() {
- return /** @type {ol.proj.Projection|undefined} */ (
- this.get(ol.GeolocationProperty.PROJECTION));
- * Get the speed in meters per second.
- * @return {number|undefined} The instantaneous speed of the device in meters
- * per second.
- * @observable
- * @api
-ol.Geolocation.prototype.getSpeed = function() {
- this.get(ol.GeolocationProperty.SPEED));
- * Determine if the device location is being tracked.
- * @return {boolean} The device location is being tracked.
- * @observable
- * @api
-ol.Geolocation.prototype.getTracking = function() {
- return /** @type {boolean} */ (
- this.get(ol.GeolocationProperty.TRACKING));
- * Get the tracking options.
- * @see http://www.w3.org/TR/geolocation-API/#position-options
- * @return {GeolocationPositionOptions|undefined} PositionOptions as defined by
- * the [HTML5 Geolocation spec
- * ](http://www.w3.org/TR/geolocation-API/#position_options_interface).
- * @observable
- * @api
-ol.Geolocation.prototype.getTrackingOptions = function() {
- return /** @type {GeolocationPositionOptions|undefined} */ (
- this.get(ol.GeolocationProperty.TRACKING_OPTIONS));
- * Set the projection to use for transforming the coordinates.
- * @param {ol.proj.Projection} projection The projection the position is
- * reported in.
- * @observable
- * @api
-ol.Geolocation.prototype.setProjection = function(projection) {
- this.set(ol.GeolocationProperty.PROJECTION, projection);
- * Enable or disable tracking.
- * @param {boolean} tracking Enable tracking.
- * @observable
- * @api
-ol.Geolocation.prototype.setTracking = function(tracking) {
- this.set(ol.GeolocationProperty.TRACKING, tracking);
- * Set the tracking options.
- * @param {GeolocationPositionOptions} options PositionOptions as defined by the
- * [HTML5 Geolocation spec
- * @observable
- * @api
-ol.Geolocation.prototype.setTrackingOptions = function(options) {
- this.set(ol.GeolocationProperty.TRACKING_OPTIONS, options);
-goog.provide('ol.geom.Circle');
-goog.require('ol.geom.GeometryLayout');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.geom.SimpleGeometry');
-goog.require('ol.geom.flat.deflate');
- * @classdesc
- * Circle geometry.
- * @constructor
- * @extends {ol.geom.SimpleGeometry}
- * @param {ol.Coordinate} center Center.
- * @param {number=} opt_radius Radius.
- * @param {ol.geom.GeometryLayout=} opt_layout Layout.
- * @api
-ol.geom.Circle = function(center, opt_radius, opt_layout) {
- ol.geom.SimpleGeometry.call(this);
- var radius = opt_radius ? opt_radius : 0;
- this.setCenterAndRadius(center, radius, opt_layout);
-ol.inherits(ol.geom.Circle, ol.geom.SimpleGeometry);
- * Make a complete copy of the geometry.
- * @return {!ol.geom.Circle} Clone.
- * @override
- * @api
-ol.geom.Circle.prototype.clone = function() {
- var circle = new ol.geom.Circle(null);
- circle.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
- return circle;
- * @inheritDoc
-ol.geom.Circle.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
- var flatCoordinates = this.flatCoordinates;
- var dx = x - flatCoordinates[0];
- var dy = y - flatCoordinates[1];
- var squaredDistance = dx * dx + dy * dy;
- if (squaredDistance < minSquaredDistance) {
- var i;
- if (squaredDistance === 0) {
- for (i = 0; i < this.stride; ++i) {
- closestPoint[i] = flatCoordinates[i];
- } else {
- var delta = this.getRadius() / Math.sqrt(squaredDistance);
- closestPoint[0] = flatCoordinates[0] + delta * dx;
- closestPoint[1] = flatCoordinates[1] + delta * dy;
- for (i = 2; i < this.stride; ++i) {
- closestPoint.length = this.stride;
- return squaredDistance;
- } else {
- return minSquaredDistance;
- * @inheritDoc
-ol.geom.Circle.prototype.containsXY = function(x, y) {
- return dx * dx + dy * dy <= this.getRadiusSquared_();
- * Return the center of the circle as {@link ol.Coordinate coordinate}.
- * @return {ol.Coordinate} Center.
- * @api
-ol.geom.Circle.prototype.getCenter = function() {
- return this.flatCoordinates.slice(0, this.stride);
- * @inheritDoc
-ol.geom.Circle.prototype.computeExtent = function(extent) {
- var radius = flatCoordinates[this.stride] - flatCoordinates[0];
- return ol.extent.createOrUpdate(
- flatCoordinates[0] - radius, flatCoordinates[1] - radius,
- flatCoordinates[0] + radius, flatCoordinates[1] + radius,
- extent);
- * Return the radius of the circle.
- * @return {number} Radius.
- * @api
-ol.geom.Circle.prototype.getRadius = function() {
- return Math.sqrt(this.getRadiusSquared_());
- * @private
- * @return {number} Radius squared.
-ol.geom.Circle.prototype.getRadiusSquared_ = function() {
- var dx = this.flatCoordinates[this.stride] - this.flatCoordinates[0];
- var dy = this.flatCoordinates[this.stride + 1] - this.flatCoordinates[1];
- return dx * dx + dy * dy;
- * @inheritDoc
- * @api
-ol.geom.Circle.prototype.getType = function() {
- return ol.geom.GeometryType.CIRCLE;
- * @inheritDoc
- * @api
-ol.geom.Circle.prototype.intersectsExtent = function(extent) {
- var circleExtent = this.getExtent();
- if (ol.extent.intersects(extent, circleExtent)) {
- var center = this.getCenter();
- if (extent[0] <= center[0] && extent[2] >= center[0]) {
- return true;
- if (extent[1] <= center[1] && extent[3] >= center[1]) {
- return true;
- return ol.extent.forEachCorner(extent, this.intersectsCoordinate, this);
- return false;
- * Set the center of the circle as {@link ol.Coordinate coordinate}.
- * @api
-ol.geom.Circle.prototype.setCenter = function(center) {
- var stride = this.stride;
- var radius = this.flatCoordinates[stride] - this.flatCoordinates[0];
- var flatCoordinates = center.slice();
- flatCoordinates[stride] = flatCoordinates[0] + radius;
- var i;
- for (i = 1; i < stride; ++i) {
- flatCoordinates[stride + i] = center[i];
- this.setFlatCoordinates(this.layout, flatCoordinates);
- * Set the center (as {@link ol.Coordinate coordinate}) and the radius (as
- * number) of the circle.
- * @param {number} radius Radius.
- * @api
-ol.geom.Circle.prototype.setCenterAndRadius = function(center, radius, opt_layout) {
- if (!center) {
- this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null);
- } else {
- this.setLayout(opt_layout, center, 0);
- if (!this.flatCoordinates) {
- this.flatCoordinates = [];
- /** @type {Array.<number>} */
- var offset = ol.geom.flat.deflate.coordinate(
- flatCoordinates, 0, center, this.stride);
- flatCoordinates[offset++] = flatCoordinates[0] + radius;
- var i, ii;
- for (i = 1, ii = this.stride; i < ii; ++i) {
- flatCoordinates[offset++] = flatCoordinates[i];
- flatCoordinates.length = offset;
- this.changed();
- * @inheritDoc
-ol.geom.Circle.prototype.getCoordinates = function() {};
- * @inheritDoc
-ol.geom.Circle.prototype.setCoordinates = function(coordinates, opt_layout) {};
- * @param {ol.geom.GeometryLayout} layout Layout.
- * @param {Array.<number>} flatCoordinates Flat coordinates.
-ol.geom.Circle.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
- this.setFlatCoordinatesInternal(layout, flatCoordinates);
- this.changed();
- * Set the radius of the circle. The radius is in the units of the projection.
- * @api
-ol.geom.Circle.prototype.setRadius = function(radius) {
- this.flatCoordinates[this.stride] = this.flatCoordinates[0] + radius;
- this.changed();
- * Transform each coordinate of the circle from one coordinate reference system
- * to another. The geometry is modified in place.
- * If you do not want the geometry modified in place, first clone() it and
- * then use this function on the clone.
- * Internally a circle is currently represented by two points: the center of
- * the circle `[cx, cy]`, and the point to the right of the circle
- * `[cx + r, cy]`. This `transform` function just transforms these two points.
- * So the resulting geometry is also a circle, and that circle does not
- * correspond to the shape that would be obtained by transforming every point
- * of the original circle.
- * @param {ol.ProjectionLike} source The current projection. Can be a
- * string identifier or a {@link ol.proj.Projection} object.
- * @param {ol.ProjectionLike} destination The desired projection. Can be a
- * @return {ol.geom.Circle} This geometry. Note that original geometry is
- * modified in place.
- * @function
- * @api
-ol.geom.Circle.prototype.transform;
-goog.provide('ol.geom.flat.geodesic');
- * @private
- * @param {function(number): ol.Coordinate} interpolate Interpolate function.
- * @param {ol.TransformFunction} transform Transform from longitude/latitude to
- * projected coordinates.
- * @param {number} squaredTolerance Squared tolerance.
- * @return {Array.<number>} Flat coordinates.
-ol.geom.flat.geodesic.line_ = function(interpolate, transform, squaredTolerance) {
- // FIXME reduce garbage generation
- // FIXME optimize stack operations
- var flatCoordinates = [];
- var geoA = interpolate(0);
- var geoB = interpolate(1);
- var a = transform(geoA);
- var b = transform(geoB);
- /** @type {Array.<ol.Coordinate>} */
- var geoStack = [geoB, geoA];
- var stack = [b, a];
- var fractionStack = [1, 0];
- /** @type {Object.<string, boolean>} */
- var fractions = {};
- var maxIterations = 1e5;
- var geoM, m, fracA, fracB, fracM, key;
- while (--maxIterations > 0 && fractionStack.length > 0) {
- // Pop the a coordinate off the stack
- fracA = fractionStack.pop();
- geoA = geoStack.pop();
- a = stack.pop();
- // Add the a coordinate if it has not been added yet
- key = fracA.toString();
- if (!(key in fractions)) {
- flatCoordinates.push(a[0], a[1]);
- fractions[key] = true;
- // Pop the b coordinate off the stack
- fracB = fractionStack.pop();
- geoB = geoStack.pop();
- b = stack.pop();
- // Find the m point between the a and b coordinates
- fracM = (fracA + fracB) / 2;
- geoM = interpolate(fracM);
- m = transform(geoM);
- if (ol.math.squaredSegmentDistance(m[0], m[1], a[0], a[1],
- b[0], b[1]) < squaredTolerance) {
- // If the m point is sufficiently close to the straight line, then we
- // discard it. Just use the b coordinate and move on to the next line
- // segment.
- flatCoordinates.push(b[0], b[1]);
- key = fracB.toString();
- } else {
- // Otherwise, we need to subdivide the current line segment. Split it
- // into two and push the two line segments onto the stack.
- fractionStack.push(fracB, fracM, fracM, fracA);
- stack.push(b, m, m, a);
- geoStack.push(geoB, geoM, geoM, geoA);
- return flatCoordinates;
-* Generate a great-circle arcs between two lat/lon points.
-* @param {number} lon1 Longitude 1 in degrees.
-* @param {number} lat1 Latitude 1 in degrees.
-* @param {number} lon2 Longitude 2 in degrees.
-* @param {number} lat2 Latitude 2 in degrees.
- * @param {ol.proj.Projection} projection Projection.
-* @param {number} squaredTolerance Squared tolerance.
-* @return {Array.<number>} Flat coordinates.
-ol.geom.flat.geodesic.greatCircleArc = function(
- lon1, lat1, lon2, lat2, projection, squaredTolerance) {
- var geoProjection = ol.proj.get('EPSG:4326');
- var cosLat1 = Math.cos(ol.math.toRadians(lat1));
- var sinLat1 = Math.sin(ol.math.toRadians(lat1));
- var cosLat2 = Math.cos(ol.math.toRadians(lat2));
- var sinLat2 = Math.sin(ol.math.toRadians(lat2));
- var cosDeltaLon = Math.cos(ol.math.toRadians(lon2 - lon1));
- var sinDeltaLon = Math.sin(ol.math.toRadians(lon2 - lon1));
- var d = sinLat1 * sinLat2 + cosLat1 * cosLat2 * cosDeltaLon;
- return ol.geom.flat.geodesic.line_(
- * @param {number} frac Fraction.
- * @return {ol.Coordinate} Coordinate.
- function(frac) {
- if (1 <= d) {
- return [lon2, lat2];
- var D = frac * Math.acos(d);
- var cosD = Math.cos(D);
- var sinD = Math.sin(D);
- var y = sinDeltaLon * cosLat2;
- var x = cosLat1 * sinLat2 - sinLat1 * cosLat2 * cosDeltaLon;
- var theta = Math.atan2(y, x);
- var lat = Math.asin(sinLat1 * cosD + cosLat1 * sinD * Math.cos(theta));
- var lon = ol.math.toRadians(lon1) +
- Math.atan2(Math.sin(theta) * sinD * cosLat1,
- cosD - sinLat1 * Math.sin(lat));
- return [ol.math.toDegrees(lon), ol.math.toDegrees(lat)];
- }, ol.proj.getTransform(geoProjection, projection), squaredTolerance);
- * Generate a meridian (line at constant longitude).
- * @param {number} lon Longitude.
- * @param {number} lat1 Latitude 1.
- * @param {number} lat2 Latitude 2.
-ol.geom.flat.geodesic.meridian = function(lon, lat1, lat2, projection, squaredTolerance) {
- var epsg4326Projection = ol.proj.get('EPSG:4326');
- function(frac) {
- return [lon, lat1 + ((lat2 - lat1) * frac)];
- ol.proj.getTransform(epsg4326Projection, projection), squaredTolerance);
- * Generate a parallel (line at constant latitude).
- * @param {number} lat Latitude.
- * @param {number} lon1 Longitude 1.
- * @param {number} lon2 Longitude 2.
-ol.geom.flat.geodesic.parallel = function(lat, lon1, lon2, projection, squaredTolerance) {
- function(frac) {
- return [lon1 + ((lon2 - lon1) * frac), lat];
-goog.provide('ol.Graticule');
-goog.require('ol.geom.LineString');
-goog.require('ol.geom.flat.geodesic');
-goog.require('ol.render.EventType');
-goog.require('ol.style.Stroke');
- * Render a grid for a coordinate system on a map.
- * @constructor
- * @param {olx.GraticuleOptions=} opt_options Options.
- * @api
-ol.Graticule = function(opt_options) {
- * @type {ol.Map}
- * @private
- this.map_ = null;
- * @type {ol.proj.Projection}
- * @private
- this.projection_ = null;
- * @type {number}
- * @private
- this.maxLat_ = Infinity;
- * @type {number}
- * @private
- this.maxLon_ = Infinity;
- * @type {number}
- * @private
- this.minLat_ = -Infinity;
- * @type {number}
- * @private
- this.minLon_ = -Infinity;
- * @type {number}
- * @private
- this.maxLatP_ = Infinity;
- * @type {number}
- * @private
- this.maxLonP_ = Infinity;
- * @type {number}
- * @private
- this.minLatP_ = -Infinity;
- * @type {number}
- * @private
- this.minLonP_ = -Infinity;
- * @type {number}
- * @private
- this.targetSize_ = options.targetSize !== undefined ?
- options.targetSize : 100;
- * @type {number}
- * @private
- this.maxLines_ = options.maxLines !== undefined ? options.maxLines : 100;
- * @type {Array.<ol.geom.LineString>}
- * @private
- this.meridians_ = [];
- * @private
- this.parallels_ = [];
- * @type {ol.style.Stroke}
- * @private
- this.strokeStyle_ = options.strokeStyle !== undefined ?
- options.strokeStyle : ol.Graticule.DEFAULT_STROKE_STYLE_;
- * @type {ol.TransformFunction|undefined}
- * @private
- this.fromLonLatTransform_ = undefined;
- * @private
- this.toLonLatTransform_ = undefined;
- * @private
- this.projectionCenterLonLat_ = null;
- this.setMap(options.map !== undefined ? options.map : null);
- * @private
- * @const
-ol.Graticule.DEFAULT_STROKE_STYLE_ = new ol.style.Stroke({
- color: 'rgba(0,0,0,0.2)'
- * TODO can be configurable
- * @type {Array.<number>}
- * @private
-ol.Graticule.intervals_ = [90, 45, 30, 20, 10, 5, 2, 1, 0.5, 0.2, 0.1, 0.05,
- 0.01, 0.005, 0.002, 0.001];
- * @param {number} minLat Minimal latitude.
- * @param {number} maxLat Maximal latitude.
- * @param {ol.Extent} extent Extent.
- * @param {number} index Index.
- * @return {number} Index.
- * @private
-ol.Graticule.prototype.addMeridian_ = function(lon, minLat, maxLat, squaredTolerance, extent, index) {
- var lineString = this.getMeridian_(lon, minLat, maxLat,
- squaredTolerance, index);
- if (ol.extent.intersects(lineString.getExtent(), extent)) {
- this.meridians_[index++] = lineString;
- return index;
- * @param {number} minLon Minimal longitude.
- * @param {number} maxLon Maximal longitude.
- * @private
-ol.Graticule.prototype.addParallel_ = function(lat, minLon, maxLon, squaredTolerance, extent, index) {
- var lineString = this.getParallel_(lat, minLon, maxLon, squaredTolerance,
- index);
- this.parallels_[index++] = lineString;
- return index;
- * @param {number} resolution Resolution.
- * @private
-ol.Graticule.prototype.createGraticule_ = function(extent, center, resolution, squaredTolerance) {
- var interval = this.getInterval_(resolution);
- if (interval == -1) {
- this.meridians_.length = this.parallels_.length = 0;
- return;
- var centerLonLat = this.toLonLatTransform_(center);
- var centerLon = centerLonLat[0];
- var centerLat = centerLonLat[1];
- var maxLines = this.maxLines_;
- var cnt, idx, lat, lon;
- var validExtent = [
- Math.max(extent[0], this.minLonP_),
- Math.max(extent[1], this.minLatP_),
- Math.min(extent[2], this.maxLonP_),
- Math.min(extent[3], this.maxLatP_)
- validExtent = ol.proj.transformExtent(validExtent, this.projection_,
- 'EPSG:4326');
- var maxLat = validExtent[3];
- var maxLon = validExtent[2];
- var minLat = validExtent[1];
- var minLon = validExtent[0];
- // Create meridians
- centerLon = Math.floor(centerLon / interval) * interval;
- lon = ol.math.clamp(centerLon, this.minLon_, this.maxLon_);
- idx = this.addMeridian_(lon, minLat, maxLat, squaredTolerance, extent, 0);
- cnt = 0;
- while (lon != this.minLon_ && cnt++ < maxLines) {
- lon = Math.max(lon - interval, this.minLon_);
- idx = this.addMeridian_(lon, minLat, maxLat, squaredTolerance, extent, idx);
- cnt = 0;
- while (lon != this.maxLon_ && cnt++ < maxLines) {
- lon = Math.min(lon + interval, this.maxLon_);
- this.meridians_.length = idx;
- // Create parallels
- centerLat = Math.floor(centerLat / interval) * interval;
- lat = ol.math.clamp(centerLat, this.minLat_, this.maxLat_);
- idx = this.addParallel_(lat, minLon, maxLon, squaredTolerance, extent, 0);
- cnt = 0;
- while (lat != this.minLat_ && cnt++ < maxLines) {
- lat = Math.max(lat - interval, this.minLat_);
- idx = this.addParallel_(lat, minLon, maxLon, squaredTolerance, extent, idx);
- cnt = 0;
- while (lat != this.maxLat_ && cnt++ < maxLines) {
- lat = Math.min(lat + interval, this.maxLat_);
- this.parallels_.length = idx;
- * @return {number} The interval in degrees.
- * @private
-ol.Graticule.prototype.getInterval_ = function(resolution) {
- var centerLon = this.projectionCenterLonLat_[0];
- var centerLat = this.projectionCenterLonLat_[1];
- var interval = -1;
- var i, ii, delta, dist;
- var target = Math.pow(this.targetSize_ * resolution, 2);
- /** @type {Array.<number>} **/
- var p1 = [];
- var p2 = [];
- for (i = 0, ii = ol.Graticule.intervals_.length; i < ii; ++i) {
- delta = ol.Graticule.intervals_[i] / 2;
- p1[0] = centerLon - delta;
- p1[1] = centerLat - delta;
- p2[0] = centerLon + delta;
- p2[1] = centerLat + delta;
- this.fromLonLatTransform_(p1, p1);
- this.fromLonLatTransform_(p2, p2);
- dist = Math.pow(p2[0] - p1[0], 2) + Math.pow(p2[1] - p1[1], 2);
- if (dist <= target) {
- break;
- interval = ol.Graticule.intervals_[i];
- return interval;
- * Get the map associated with this graticule.
- * @return {ol.Map} The map.
- * @api
-ol.Graticule.prototype.getMap = function() {
- return this.map_;
- * @return {ol.geom.LineString} The meridian line string.
- * @private
-ol.Graticule.prototype.getMeridian_ = function(lon, minLat, maxLat,
- squaredTolerance, index) {
- var flatCoordinates = ol.geom.flat.geodesic.meridian(lon,
- minLat, maxLat, this.projection_, squaredTolerance);
- var lineString = this.meridians_[index] !== undefined ?
- this.meridians_[index] : new ol.geom.LineString(null);
- lineString.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates);
- return lineString;
- * Get the list of meridians. Meridians are lines of equal longitude.
- * @return {Array.<ol.geom.LineString>} The meridians.
- * @api
-ol.Graticule.prototype.getMeridians = function() {
- return this.meridians_;
- * @return {ol.geom.LineString} The parallel line string.
- * @private
-ol.Graticule.prototype.getParallel_ = function(lat, minLon, maxLon,
- var flatCoordinates = ol.geom.flat.geodesic.parallel(lat,
- this.minLon_, this.maxLon_, this.projection_, squaredTolerance);
- var lineString = this.parallels_[index] !== undefined ?
- this.parallels_[index] : new ol.geom.LineString(null);
- * Get the list of parallels. Pallels are lines of equal latitude.
- * @return {Array.<ol.geom.LineString>} The parallels.
- * @api
-ol.Graticule.prototype.getParallels = function() {
- return this.parallels_;
- * @param {ol.render.Event} e Event.
- * @private
-ol.Graticule.prototype.handlePostCompose_ = function(e) {
- var vectorContext = e.vectorContext;
- var frameState = e.frameState;
- var extent = frameState.extent;
- var viewState = frameState.viewState;
- var center = viewState.center;
- var projection = viewState.projection;
- var resolution = viewState.resolution;
- var pixelRatio = frameState.pixelRatio;
- var squaredTolerance =
- resolution * resolution / (4 * pixelRatio * pixelRatio);
- var updateProjectionInfo = !this.projection_ ||
- !ol.proj.equivalent(this.projection_, projection);
- if (updateProjectionInfo) {
- this.updateProjectionInfo_(projection);
- //Fix the extent if wrapped.
- //(note: this is the same extent as vectorContext.extent_)
- var offsetX = 0;
- if (projection.canWrapX()) {
- var projectionExtent = projection.getExtent();
- var worldWidth = ol.extent.getWidth(projectionExtent);
- var x = frameState.focus[0];
- if (x < projectionExtent[0] || x > projectionExtent[2]) {
- var worldsAway = Math.ceil((projectionExtent[0] - x) / worldWidth);
- offsetX = worldWidth * worldsAway;
- extent = [
- extent[0] + offsetX, extent[1],
- extent[2] + offsetX, extent[3]
- this.createGraticule_(extent, center, resolution, squaredTolerance);
- // Draw the lines
- vectorContext.setFillStrokeStyle(null, this.strokeStyle_);
- var i, l, line;
- for (i = 0, l = this.meridians_.length; i < l; ++i) {
- line = this.meridians_[i];
- vectorContext.drawLineString(line, null);
- for (i = 0, l = this.parallels_.length; i < l; ++i) {
- line = this.parallels_[i];
- * @private
-ol.Graticule.prototype.updateProjectionInfo_ = function(projection) {
- var extent = projection.getExtent();
- var worldExtent = projection.getWorldExtent();
- var worldExtentP = ol.proj.transformExtent(worldExtent,
- epsg4326Projection, projection);
- var maxLat = worldExtent[3];
- var maxLon = worldExtent[2];
- var minLat = worldExtent[1];
- var minLon = worldExtent[0];
- var maxLatP = worldExtentP[3];
- var maxLonP = worldExtentP[2];
- var minLatP = worldExtentP[1];
- var minLonP = worldExtentP[0];
- this.maxLat_ = maxLat;
- this.maxLon_ = maxLon;
- this.minLat_ = minLat;
- this.minLon_ = minLon;
- this.maxLatP_ = maxLatP;
- this.maxLonP_ = maxLonP;
- this.minLatP_ = minLatP;
- this.minLonP_ = minLonP;
- this.fromLonLatTransform_ = ol.proj.getTransform(
- this.toLonLatTransform_ = ol.proj.getTransform(
- projection, epsg4326Projection);
- this.projectionCenterLonLat_ = this.toLonLatTransform_(
- ol.extent.getCenter(extent));
- this.projection_ = projection;
- * Set the map for this graticule. The graticule will be rendered on the
- * provided map.
- * @param {ol.Map} map Map.
- * @api
-ol.Graticule.prototype.setMap = function(map) {
- if (this.map_) {
- this.map_.un(ol.render.EventType.POSTCOMPOSE,
- this.handlePostCompose_, this);
- this.map_.render();
- if (map) {
- map.on(ol.render.EventType.POSTCOMPOSE,
- map.render();
- this.map_ = map;
-goog.provide('ol.ImageBase');
-goog.require('ol.events.EventTarget');
- * @constructor
- * @abstract
- * @extends {ol.events.EventTarget}
- * @param {number|undefined} resolution Resolution.
- * @param {number} pixelRatio Pixel ratio.
- * @param {ol.ImageState} state State.
- * @param {Array.<ol.Attribution>} attributions Attributions.
-ol.ImageBase = function(extent, resolution, pixelRatio, state, attributions) {
- ol.events.EventTarget.call(this);
- * @private
- * @type {Array.<ol.Attribution>}
- this.attributions_ = attributions;
- * @protected
- * @type {ol.Extent}
- this.extent = extent;
- * @private
- * @type {number}
- this.pixelRatio_ = pixelRatio;
- * @protected
- this.resolution = resolution;
- * @protected
- * @type {ol.ImageState}
- this.state = state;
-ol.inherits(ol.ImageBase, ol.events.EventTarget);
- * @protected
-ol.ImageBase.prototype.changed = function() {
- this.dispatchEvent(ol.events.EventType.CHANGE);
- * @return {Array.<ol.Attribution>} Attributions.
-ol.ImageBase.prototype.getAttributions = function() {
- return this.attributions_;
- * @return {ol.Extent} Extent.
-ol.ImageBase.prototype.getExtent = function() {
- return this.extent;
- * @abstract
- * @param {Object=} opt_context Object.
- * @return {HTMLCanvasElement|Image|HTMLVideoElement} Image.
-ol.ImageBase.prototype.getImage = function(opt_context) {};
- * @return {number} PixelRatio.
-ol.ImageBase.prototype.getPixelRatio = function() {
- return this.pixelRatio_;
- * @return {number} Resolution.
-ol.ImageBase.prototype.getResolution = function() {
- return /** @type {number} */ (this.resolution);
- * @return {ol.ImageState} State.
-ol.ImageBase.prototype.getState = function() {
- return this.state;
- * Load not yet loaded URI.
- * @abstract
-ol.ImageBase.prototype.load = function() {};
-goog.provide('ol.Image');
-goog.require('ol.ImageBase');
-goog.require('ol.ImageState');
- * @constructor
- * @extends {ol.ImageBase}
- * @param {string} src Image source URI.
- * @param {?string} crossOrigin Cross origin.
- * @param {ol.ImageLoadFunctionType} imageLoadFunction Image load function.
-ol.Image = function(extent, resolution, pixelRatio, attributions, src,
- crossOrigin, imageLoadFunction) {
- ol.ImageBase.call(this, extent, resolution, pixelRatio, ol.ImageState.IDLE,
- attributions);
- * @private
- * @type {string}
- this.src_ = src;
- * @private
- * @type {HTMLCanvasElement|Image|HTMLVideoElement}
- this.image_ = new Image();
- if (crossOrigin !== null) {
- this.image_.crossOrigin = crossOrigin;
- * @private
- * @type {Object.<number, (HTMLCanvasElement|Image|HTMLVideoElement)>}
- this.imageByContext_ = {};
- * @private
- * @type {Array.<ol.EventsKey>}
- this.imageListenerKeys_ = null;
- * @protected
- this.state = ol.ImageState.IDLE;
- * @private
- * @type {ol.ImageLoadFunctionType}
- this.imageLoadFunction_ = imageLoadFunction;
-ol.inherits(ol.Image, ol.ImageBase);
- * @inheritDoc
- * @api
-ol.Image.prototype.getImage = function(opt_context) {
- if (opt_context !== undefined) {
- var image;
- var key = ol.getUid(opt_context);
- if (key in this.imageByContext_) {
- return this.imageByContext_[key];
- } else if (ol.obj.isEmpty(this.imageByContext_)) {
- image = this.image_;
- } else {
- image = /** @type {Image} */ (this.image_.cloneNode(false));
- this.imageByContext_[key] = image;
- return image;
- } else {
- return this.image_;
- * Tracks loading or read errors.
- * @private
-ol.Image.prototype.handleImageError_ = function() {
- this.state = ol.ImageState.ERROR;
- this.unlistenImage_();
- this.changed();
- * Tracks successful image load.
- * @private
-ol.Image.prototype.handleImageLoad_ = function() {
- if (this.resolution === undefined) {
- this.resolution = ol.extent.getHeight(this.extent) / this.image_.height;
- this.state = ol.ImageState.LOADED;
- this.changed();
- * Load the image or retry if loading previously failed.
- * Loading is taken care of by the tile queue, and calling this method is
- * only needed for preloading or for reloading in case of an error.
- * @override
- * @api
-ol.Image.prototype.load = function() {
- if (this.state == ol.ImageState.IDLE || this.state == ol.ImageState.ERROR) {
- this.state = ol.ImageState.LOADING;
- this.changed();
- this.imageListenerKeys_ = [
- ol.events.listenOnce(this.image_, ol.events.EventType.ERROR,
- this.handleImageError_, this),
- ol.events.listenOnce(this.image_, ol.events.EventType.LOAD,
- this.handleImageLoad_, this)
- this.imageLoadFunction_(this, this.src_);
- * @param {HTMLCanvasElement|Image|HTMLVideoElement} image Image.
-ol.Image.prototype.setImage = function(image) {
- this.image_ = image;
- * Discards event handlers which listen for load completion or errors.
- * @private
-ol.Image.prototype.unlistenImage_ = function() {
- this.imageListenerKeys_.forEach(ol.events.unlistenByKey);
-goog.provide('ol.ImageCanvas');
-goog.require('ol');
- * @constructor
- * @param {HTMLCanvasElement} canvas Canvas.
- * @param {ol.ImageCanvasLoader=} opt_loader Optional loader function to
- * support asynchronous canvas drawing.
-ol.ImageCanvas = function(extent, resolution, pixelRatio, attributions,
- canvas, opt_loader) {
- * Optional canvas loader function.
- * @type {?ol.ImageCanvasLoader}
- * @private
- this.loader_ = opt_loader !== undefined ? opt_loader : null;
- var state = opt_loader !== undefined ?
- ol.ImageState.IDLE : ol.ImageState.LOADED;
- ol.ImageBase.call(this, extent, resolution, pixelRatio, state, attributions);
- * @private
- * @type {HTMLCanvasElement}
- this.canvas_ = canvas;
- * @private
- * @type {Error}
- this.error_ = null;
-ol.inherits(ol.ImageCanvas, ol.ImageBase);
- * Get any error associated with asynchronous rendering.
- * @return {Error} Any error that occurred during rendering.
-ol.ImageCanvas.prototype.getError = function() {
- return this.error_;
- * Handle async drawing complete.
- * @param {Error} err Any error during drawing.
- * @private
-ol.ImageCanvas.prototype.handleLoad_ = function(err) {
- if (err) {
- this.error_ = err;
- } else {
- this.changed();
- * @inheritDoc
-ol.ImageCanvas.prototype.load = function() {
- if (this.state == ol.ImageState.IDLE) {
- this.changed();
- this.loader_(this.handleLoad_.bind(this));
- * @inheritDoc
-ol.ImageCanvas.prototype.getImage = function(opt_context) {
- return this.canvas_;
-goog.provide('ol.Tile');
-goog.require('ol.TileState');
- * @classdesc
- * Base class for tiles.
- * @constructor
- * @abstract
- * @param {ol.TileCoord} tileCoord Tile coordinate.
- * @param {ol.TileState} state State.
-ol.Tile = function(tileCoord, state) {
- * @type {ol.TileCoord}
- this.tileCoord = tileCoord;
- * @protected
- * @type {ol.TileState}
- * An "interim" tile for this tile. The interim tile may be used while this
- * one is loading, for "smooth" transitions when changing params/dimensions
- * on the source.
- * @type {ol.Tile}
- this.interimTile = null;
- * A key assigned to the tile. This is used by the tile source to determine
- * if this tile can effectively be used, or if a new tile should be created
- * and this one be used as an interim tile for this new tile.
- * @type {string}
- this.key = '';
-ol.inherits(ol.Tile, ol.events.EventTarget);
- * @protected
-ol.Tile.prototype.changed = function() {
- * Get the HTML image element for this tile (may be a Canvas, Image, or Video).
- * @abstract
- * @return {HTMLCanvasElement|HTMLImageElement|HTMLVideoElement} Image.
-ol.Tile.prototype.getImage = function() {};
- * @return {string} Key.
-ol.Tile.prototype.getKey = function() {
- return this.key + '/' + this.tileCoord;
- * Get the interim tile most suitable for rendering using the chain of interim
- * tiles. This corresponds to the most recent tile that has been loaded, if no
- * such tile exists, the original tile is returned.
- * @return {!ol.Tile} Best tile for rendering.
-ol.Tile.prototype.getInterimTile = function() {
- if (!this.interimTile) {
- //empty chain
- return this;
- var tile = this.interimTile;
- // find the first loaded tile and return it. Since the chain is sorted in
- // decreasing order of creation time, there is no need to search the remainder
- // of the list (all those tiles correspond to older requests and will be
- // cleaned up by refreshInterimChain)
- do {
- if (tile.getState() == ol.TileState.LOADED) {
- return tile;
- tile = tile.interimTile;
- } while (tile);
- // we can not find a better tile
- return this;
- * Goes through the chain of interim tiles and discards sections of the chain
- * that are no longer relevant.
-ol.Tile.prototype.refreshInterimChain = function() {
- return;
- var prev = this;
- do {
- //we have a loaded tile, we can discard the rest of the list
- //we would could abort any LOADING tile request
- //older than this tile (i.e. any LOADING tile following this entry in the chain)
- tile.interimTile = null;
- break;
- } else if (tile.getState() == ol.TileState.LOADING) {
- //keep this LOADING tile any loaded tiles later in the chain are
- //older than this tile, so we're still interested in the request
- prev = tile;
- } else if (tile.getState() == ol.TileState.IDLE) {
- //the head of the list is the most current tile, we don't need
- //to start any other requests for this chain
- prev.interimTile = tile.interimTile;
- } else {
- prev = tile;
- tile = prev.interimTile;
- } while (tile);
- * Get the tile coordinate for this tile.
- * @return {ol.TileCoord} The tile coordinate.
- * @api
-ol.Tile.prototype.getTileCoord = function() {
- return this.tileCoord;
- * @return {ol.TileState} State.
-ol.Tile.prototype.getState = function() {
- * @abstract
- * @api
-ol.Tile.prototype.load = function() {};
-goog.provide('ol.ImageTile');
-goog.require('ol.Tile');
- * @constructor
- * @extends {ol.Tile}
- * @param {ol.TileLoadFunctionType} tileLoadFunction Tile load function.
-ol.ImageTile = function(tileCoord, state, src, crossOrigin, tileLoadFunction) {
- ol.Tile.call(this, tileCoord, state);
- * Image URI
- * @private
- * @type {string}
- this.src_ = src;
- * @private
- * @type {Image}
- * @private
- * @private
- * @type {ol.TileLoadFunctionType}
- this.tileLoadFunction_ = tileLoadFunction;
-ol.inherits(ol.ImageTile, ol.Tile);
- * @inheritDoc
-ol.ImageTile.prototype.disposeInternal = function() {
- if (this.state == ol.TileState.LOADING) {
- if (this.interimTile) {
- this.interimTile.dispose();
- this.state = ol.TileState.ABORT;
- this.changed();
- ol.Tile.prototype.disposeInternal.call(this);
- * Get the image element for this tile.
- * @inheritDoc
- * @api
-ol.ImageTile.prototype.getImage = function() {
- * @inheritDoc
-ol.ImageTile.prototype.getKey = function() {
- return this.src_;
- * @private
-ol.ImageTile.prototype.handleImageError_ = function() {
- this.state = ol.TileState.ERROR;
- this.changed();
- * @private
-ol.ImageTile.prototype.handleImageLoad_ = function() {
- if (this.image_.naturalWidth && this.image_.naturalHeight) {
- this.state = ol.TileState.LOADED;
- } else {
- this.state = ol.TileState.EMPTY;
- this.changed();
- * @inheritDoc
- * @api
-ol.ImageTile.prototype.load = function() {
- if (this.state == ol.TileState.IDLE || this.state == ol.TileState.ERROR) {
- this.state = ol.TileState.LOADING;
- this.changed();
- this.tileLoadFunction_(this, this.src_);
- * @private
-ol.ImageTile.prototype.unlistenImage_ = function() {
-// FIXME should handle all geo-referenced data, not just vector data
-goog.provide('ol.interaction.DragAndDrop');
-goog.require('ol.functions');
-goog.require('ol.events.Event');
-goog.require('ol.interaction.Interaction');
- * @classdesc
- * Handles input of vector data by drag and drop.
- * @constructor
- * @extends {ol.interaction.Interaction}
- * @fires ol.interaction.DragAndDrop.Event
- * @param {olx.interaction.DragAndDropOptions=} opt_options Options.
- * @api
-ol.interaction.DragAndDrop = function(opt_options) {
- ol.interaction.Interaction.call(this, {
- handleEvent: ol.interaction.DragAndDrop.handleEvent
- * @private
- * @type {Array.<function(new: ol.format.Feature)>}
- this.formatConstructors_ = options.formatConstructors ?
- options.formatConstructors : [];
- * @private
- this.projection_ = options.projection ?
- ol.proj.get(options.projection) : null;
- * @private
- this.dropListenKeys_ = null;
- * @private
- * @type {Element}
- this.target = options.target ? options.target : null;
-ol.inherits(ol.interaction.DragAndDrop, ol.interaction.Interaction);
- * @param {Event} event Event.
- * @this {ol.interaction.DragAndDrop}
- * @private
-ol.interaction.DragAndDrop.handleDrop_ = function(event) {
- var files = event.dataTransfer.files;
- var i, ii, file;
- for (i = 0, ii = files.length; i < ii; ++i) {
- file = files.item(i);
- var reader = new FileReader();
- reader.addEventListener(ol.events.EventType.LOAD,
- this.handleResult_.bind(this, file));
- reader.readAsText(file);
- * @private
-ol.interaction.DragAndDrop.handleStop_ = function(event) {
- event.stopPropagation();
- event.preventDefault();
- event.dataTransfer.dropEffect = 'copy';
- * @param {File} file File.
- * @param {Event} event Load event.
- * @private
-ol.interaction.DragAndDrop.prototype.handleResult_ = function(file, event) {
- var result = event.target.result;
- var map = this.getMap();
- var projection = this.projection_;
- if (!projection) {
- var view = map.getView();
- projection = view.getProjection();
- var formatConstructors = this.formatConstructors_;
- var i, ii;
- for (i = 0, ii = formatConstructors.length; i < ii; ++i) {
- * Avoid "cannot instantiate abstract class" error.
- * @type {Function}
- var formatConstructor = formatConstructors[i];
- * @type {ol.format.Feature}
- var format = new formatConstructor();
- features = this.tryReadFeatures_(format, result, {
- featureProjection: projection
- if (features && features.length > 0) {
- break;
- new ol.interaction.DragAndDrop.Event(
- ol.interaction.DragAndDrop.EventType_.ADD_FEATURES, file,
- features, projection));
- * Handles the {@link ol.MapBrowserEvent map browser event} unconditionally and
- * neither prevents the browser default nor stops event propagation.
- * @param {ol.MapBrowserEvent} mapBrowserEvent Map browser event.
- * @return {boolean} `false` to stop event propagation.
- * @api
-ol.interaction.DragAndDrop.handleEvent = ol.functions.TRUE;
- * @inheritDoc
-ol.interaction.DragAndDrop.prototype.setMap = function(map) {
- if (this.dropListenKeys_) {
- this.dropListenKeys_.forEach(ol.events.unlistenByKey);
- ol.interaction.Interaction.prototype.setMap.call(this, map);
- if (map) {
- var dropArea = this.target ? this.target : map.getViewport();
- this.dropListenKeys_ = [
- ol.events.listen(dropArea, ol.events.EventType.DROP,
- ol.interaction.DragAndDrop.handleDrop_, this),
- ol.events.listen(dropArea, ol.events.EventType.DRAGENTER,
- ol.interaction.DragAndDrop.handleStop_, this),
- ol.events.listen(dropArea, ol.events.EventType.DRAGOVER,
- * @param {ol.format.Feature} format Format.
- * @param {string} text Text.
- * @param {olx.format.ReadOptions} options Read options.
- * @private
-ol.interaction.DragAndDrop.prototype.tryReadFeatures_ = function(format, text, options) {
- try {
- return format.readFeatures(text, options);
- } catch (e) {
- return null;
- * @enum {string}
- * @private
-ol.interaction.DragAndDrop.EventType_ = {
- * Triggered when features are added
- * @event ol.interaction.DragAndDrop.Event#addfeatures
- * @api
- ADD_FEATURES: 'addfeatures'
- * @classdesc
- * Events emitted by {@link ol.interaction.DragAndDrop} instances are instances
- * of this type.
- * @constructor
- * @extends {ol.events.Event}
- * @implements {oli.interaction.DragAndDropEvent}
- * @param {ol.interaction.DragAndDrop.EventType_} type Type.
- * @param {Array.<ol.Feature>=} opt_features Features.
- * @param {ol.proj.Projection=} opt_projection Projection.
-ol.interaction.DragAndDrop.Event = function(type, file, opt_features, opt_projection) {
- ol.events.Event.call(this, type);
- * The features parsed from dropped data.
- * @type {Array.<ol.Feature>|undefined}
- * @api
- this.features = opt_features;
- * The dropped file.
- * @type {File}
- * @api
- this.file = file;
- * The feature projection.
- * @type {ol.proj.Projection|undefined}
- * @api
- this.projection = opt_projection;
-ol.inherits(ol.interaction.DragAndDrop.Event, ol.events.Event);
-goog.provide('ol.interaction.DragRotateAndZoom');
-goog.require('ol.ViewHint');
-goog.require('ol.events.condition');
-goog.require('ol.interaction.Pointer');
- * @classdesc
- * Allows the user to zoom and rotate the map by clicking and dragging
- * on the map. By default, this interaction is limited to when the shift
- * key is held down.
- * This interaction is only supported for mouse devices.
- * And this interaction is not included in the default interactions.
- * @constructor
- * @extends {ol.interaction.Pointer}
- * @param {olx.interaction.DragRotateAndZoomOptions=} opt_options Options.
- * @api
-ol.interaction.DragRotateAndZoom = function(opt_options) {
- ol.interaction.Pointer.call(this, {
- handleDownEvent: ol.interaction.DragRotateAndZoom.handleDownEvent_,
- handleDragEvent: ol.interaction.DragRotateAndZoom.handleDragEvent_,
- handleUpEvent: ol.interaction.DragRotateAndZoom.handleUpEvent_
- * @private
- * @type {ol.EventsConditionType}
- this.condition_ = options.condition ?
- options.condition : ol.events.condition.shiftKeyOnly;
- * @private
- this.lastAngle_ = undefined;
- * @private
- this.lastMagnitude_ = undefined;
- * @private
- * @type {number}
- this.lastScaleDelta_ = 0;
- * @private
- * @type {number}
- this.duration_ = options.duration !== undefined ? options.duration : 400;
-ol.inherits(ol.interaction.DragRotateAndZoom, ol.interaction.Pointer);
- * @param {ol.MapBrowserPointerEvent} mapBrowserEvent Event.
- * @this {ol.interaction.DragRotateAndZoom}
- * @private
-ol.interaction.DragRotateAndZoom.handleDragEvent_ = function(mapBrowserEvent) {
- if (!ol.events.condition.mouseOnly(mapBrowserEvent)) {
- return;
- var map = mapBrowserEvent.map;
- var size = map.getSize();
- var offset = mapBrowserEvent.pixel;
- var deltaX = offset[0] - size[0] / 2;
- var deltaY = size[1] / 2 - offset[1];
- var theta = Math.atan2(deltaY, deltaX);
- var magnitude = Math.sqrt(deltaX * deltaX + deltaY * deltaY);
- if (this.lastAngle_ !== undefined) {
- var angleDelta = theta - this.lastAngle_;
- ol.interaction.Interaction.rotateWithoutConstraints(
- view, view.getRotation() - angleDelta);
- this.lastAngle_ = theta;
- if (this.lastMagnitude_ !== undefined) {
- var resolution = this.lastMagnitude_ * (view.getResolution() / magnitude);
- ol.interaction.Interaction.zoomWithoutConstraints(view, resolution);
- this.lastScaleDelta_ = this.lastMagnitude_ / magnitude;
- this.lastMagnitude_ = magnitude;
- * @return {boolean} Stop drag sequence?
- * @private
-ol.interaction.DragRotateAndZoom.handleUpEvent_ = function(mapBrowserEvent) {
- return true;
- view.setHint(ol.ViewHint.INTERACTING, -1);
- var direction = this.lastScaleDelta_ - 1;
- ol.interaction.Interaction.rotate(view, view.getRotation());
- ol.interaction.Interaction.zoom(view, view.getResolution(),
- undefined, this.duration_, direction);
- return false;
- * @return {boolean} Start drag sequence?
- * @private
-ol.interaction.DragRotateAndZoom.handleDownEvent_ = function(mapBrowserEvent) {
- return false;
- if (this.condition_(mapBrowserEvent)) {
- mapBrowserEvent.map.getView().setHint(ol.ViewHint.INTERACTING, 1);
- return true;
- } else {
- return false;
-goog.provide('ol.interaction.DrawEventType');
- * @enum {string}
-ol.interaction.DrawEventType = {
- * Triggered upon feature draw start
- * @event ol.interaction.Draw.Event#drawstart
- * @api
- DRAWSTART: 'drawstart',
- * Triggered upon feature draw end
- * @event ol.interaction.Draw.Event#drawend
- * @api
- DRAWEND: 'drawend'
-goog.provide('ol.render.canvas.Instruction');
- * @enum {number}
-ol.render.canvas.Instruction = {
- BEGIN_GEOMETRY: 0,
- BEGIN_PATH: 1,
- CIRCLE: 2,
- CLOSE_PATH: 3,
- DRAW_IMAGE: 4,
- DRAW_TEXT: 5,
- END_GEOMETRY: 6,
- FILL: 7,
- MOVE_TO_LINE_TO: 8,
- SET_FILL_STYLE: 9,
- SET_STROKE_STYLE: 10,
- SET_TEXT_STYLE: 11,
- STROKE: 12
-goog.provide('ol.render.canvas.Replay');
-goog.require('ol.array');
-goog.require('ol.extent.Relationship');
-goog.require('ol.geom.flat.transform');
-goog.require('ol.obj');
-goog.require('ol.render.VectorContext');
-goog.require('ol.render.canvas.Instruction');
-goog.require('ol.transform');
- * @constructor
- * @extends {ol.render.VectorContext}
- * @param {number} tolerance Tolerance.
- * @param {ol.Extent} maxExtent Maximum extent.
- * @param {boolean} overlaps The replay can have overlapping geometries.
- * @struct
-ol.render.canvas.Replay = function(tolerance, maxExtent, resolution, overlaps) {
- ol.render.VectorContext.call(this);
- * @protected
- * @type {number}
- this.tolerance = tolerance;
- * @protected
- * @const
- this.maxExtent = maxExtent;
- * @protected
- * @type {boolean}
- this.overlaps = overlaps;
- * @protected
- * @type {number}
- this.maxLineWidth = 0;
- * @protected
- * @const
- * @type {number}
- * @private
- this.fillOrigin_;
- * @private
- * @type {Array.<*>}
- this.beginGeometryInstruction1_ = null;
- * @private
- this.beginGeometryInstruction2_ = null;
- * @protected
- this.instructions = [];
- * @protected
- this.coordinates = [];
- * @private
- * @type {!ol.Transform}
- this.renderedTransform_ = ol.transform.create();
- * @protected
- this.hitDetectionInstructions = [];
- * @private
- this.pixelCoordinates_ = null;
- * @private
- this.tmpLocalTransform_ = ol.transform.create();
- * @private
- this.resetTransform_ = ol.transform.create();
-ol.inherits(ol.render.canvas.Replay, ol.render.VectorContext);
- * @param {number} offset Offset.
- * @param {number} end End.
- * @param {number} stride Stride.
- * @param {boolean} closed Last input coordinate equals first.
- * @param {boolean} skipFirst Skip first coordinate.
- * @protected
- * @return {number} My end.
-ol.render.canvas.Replay.prototype.appendFlatCoordinates = function(flatCoordinates, offset, end, stride, closed, skipFirst) {
- var myEnd = this.coordinates.length;
- var extent = this.getBufferedMaxExtent();
- if (skipFirst) {
- offset += stride;
- var lastCoord = [flatCoordinates[offset], flatCoordinates[offset + 1]];
- var nextCoord = [NaN, NaN];
- var skipped = true;
- var i, lastRel, nextRel;
- for (i = offset + stride; i < end; i += stride) {
- nextCoord[0] = flatCoordinates[i];
- nextCoord[1] = flatCoordinates[i + 1];
- nextRel = ol.extent.coordinateRelationship(extent, nextCoord);
- if (nextRel !== lastRel) {
- if (skipped) {
- this.coordinates[myEnd++] = lastCoord[0];
- this.coordinates[myEnd++] = lastCoord[1];
- this.coordinates[myEnd++] = nextCoord[0];
- this.coordinates[myEnd++] = nextCoord[1];
- skipped = false;
- } else if (nextRel === ol.extent.Relationship.INTERSECTING) {
- skipped = false;
- } else {
- skipped = true;
- lastCoord[0] = nextCoord[0];
- lastCoord[1] = nextCoord[1];
- lastRel = nextRel;
- // Last coordinate equals first or only one point to append:
- if ((closed && skipped) || i === offset + stride) {
- return myEnd;
- * @protected
- * @param {ol.geom.Geometry|ol.render.Feature} geometry Geometry.
- * @param {ol.Feature|ol.render.Feature} feature Feature.
-ol.render.canvas.Replay.prototype.beginGeometry = function(geometry, feature) {
- [ol.render.canvas.Instruction.BEGIN_GEOMETRY, feature, 0];
- this.instructions.push(this.beginGeometryInstruction1_);
- this.hitDetectionInstructions.push(this.beginGeometryInstruction2_);
- * @private
- * @param {CanvasRenderingContext2D} context Context.
- * @param {number} rotation Rotation.
-ol.render.canvas.Replay.prototype.fill_ = function(context, rotation) {
- if (this.fillOrigin_) {
- var origin = ol.transform.apply(this.renderedTransform_, this.fillOrigin_.slice());
- context.translate(origin[0], origin[1]);
- context.rotate(rotation);
- context.fill();
- context.setTransform.apply(context, this.resetTransform_);
- * @private
- * @param {ol.Transform} transform Transform.
- * @param {number} viewRotation View rotation.
- * @param {Object.<string, boolean>} skippedFeaturesHash Ids of features
- * to skip.
- * @param {Array.<*>} instructions Instructions array.
- * @param {function((ol.Feature|ol.render.Feature)): T|undefined}
- * featureCallback Feature callback.
- * @param {ol.Extent=} opt_hitExtent Only check features that intersect this
- * extent.
- * @return {T|undefined} Callback result.
- * @template T
-ol.render.canvas.Replay.prototype.replay_ = function(
- context, pixelRatio, transform, viewRotation, skippedFeaturesHash,
- instructions, featureCallback, opt_hitExtent) {
- var pixelCoordinates;
- if (this.pixelCoordinates_ && ol.array.equals(transform, this.renderedTransform_)) {
- pixelCoordinates = this.pixelCoordinates_;
- } else {
- if (!this.pixelCoordinates_) {
- this.pixelCoordinates_ = [];
- pixelCoordinates = ol.geom.flat.transform.transform2D(
- this.coordinates, 0, this.coordinates.length, 2,
- transform, this.pixelCoordinates_);
- ol.transform.setFromArray(this.renderedTransform_, transform);
- var skipFeatures = !ol.obj.isEmpty(skippedFeaturesHash);
- var i = 0; // instruction index
- var ii = instructions.length; // end of instructions
- var d = 0; // data index
- var dd; // end of per-instruction data
- var localTransform = this.tmpLocalTransform_;
- var resetTransform = this.resetTransform_;
- var prevX, prevY, roundX, roundY;
- var pendingFill = 0;
- var pendingStroke = 0;
- // When the batch size gets too big, performance decreases. 200 is a good
- // balance between batch size and number of fill/stroke instructions.
- var batchSize =
- this.instructions != instructions || this.overlaps ? 0 : 200;
- while (i < ii) {
- var instruction = instructions[i];
- var type = /** @type {ol.render.canvas.Instruction} */ (instruction[0]);
- var feature, fill, stroke, text, x, y;
- switch (type) {
- case ol.render.canvas.Instruction.BEGIN_GEOMETRY:
- feature = /** @type {ol.Feature|ol.render.Feature} */ (instruction[1]);
- if ((skipFeatures &&
- skippedFeaturesHash[ol.getUid(feature).toString()]) ||
- !feature.getGeometry()) {
- i = /** @type {number} */ (instruction[2]);
- } else if (opt_hitExtent !== undefined && !ol.extent.intersects(
- opt_hitExtent, feature.getGeometry().getExtent())) {
- i = /** @type {number} */ (instruction[2]) + 1;
- } else {
- ++i;
- break;
- case ol.render.canvas.Instruction.BEGIN_PATH:
- if (pendingFill > batchSize) {
- this.fill_(context, viewRotation);
- pendingFill = 0;
- if (pendingStroke > batchSize) {
- context.stroke();
- pendingStroke = 0;
- if (!pendingFill && !pendingStroke) {
- context.beginPath();
- prevX = prevY = NaN;
- ++i;
- break;
- case ol.render.canvas.Instruction.CIRCLE:
- d = /** @type {number} */ (instruction[1]);
- var x1 = pixelCoordinates[d];
- var y1 = pixelCoordinates[d + 1];
- var x2 = pixelCoordinates[d + 2];
- var y2 = pixelCoordinates[d + 3];
- var dx = x2 - x1;
- var dy = y2 - y1;
- var r = Math.sqrt(dx * dx + dy * dy);
- context.moveTo(x1 + r, y1);
- context.arc(x1, y1, r, 0, 2 * Math.PI, true);
- ++i;
- break;
- case ol.render.canvas.Instruction.CLOSE_PATH:
- context.closePath();
- ++i;
- break;
- case ol.render.canvas.Instruction.DRAW_IMAGE:
- dd = /** @type {number} */ (instruction[2]);
- var image = /** @type {HTMLCanvasElement|HTMLVideoElement|Image} */
- (instruction[3]);
- // Remaining arguments in DRAW_IMAGE are in alphabetical order
- var anchorX = /** @type {number} */ (instruction[4]) * pixelRatio;
- var anchorY = /** @type {number} */ (instruction[5]) * pixelRatio;
- var height = /** @type {number} */ (instruction[6]);
- var opacity = /** @type {number} */ (instruction[7]);
- var originX = /** @type {number} */ (instruction[8]);
- var originY = /** @type {number} */ (instruction[9]);
- var rotateWithView = /** @type {boolean} */ (instruction[10]);
- var rotation = /** @type {number} */ (instruction[11]);
- var scale = /** @type {number} */ (instruction[12]);
- var snapToPixel = /** @type {boolean} */ (instruction[13]);
- var width = /** @type {number} */ (instruction[14]);
- if (rotateWithView) {
- rotation += viewRotation;
- for (; d < dd; d += 2) {
- x = pixelCoordinates[d] - anchorX;
- y = pixelCoordinates[d + 1] - anchorY;
- if (snapToPixel) {
- x = Math.round(x);
- y = Math.round(y);
- if (scale != 1 || rotation !== 0) {
- var centerX = x + anchorX;
- var centerY = y + anchorY;
- ol.transform.compose(localTransform,
- centerX, centerY, scale, scale, rotation, -centerX, -centerY);
- context.setTransform.apply(context, localTransform);
- var alpha = context.globalAlpha;
- if (opacity != 1) {
- context.globalAlpha = alpha * opacity;
- var w = (width + originX > image.width) ? image.width - originX : width;
- var h = (height + originY > image.height) ? image.height - originY : height;
- context.drawImage(image, originX, originY, w, h,
- x, y, w * pixelRatio, h * pixelRatio);
- context.globalAlpha = alpha;
- context.setTransform.apply(context, resetTransform);
- ++i;
- break;
- case ol.render.canvas.Instruction.DRAW_TEXT:
- text = /** @type {string} */ (instruction[3]);
- var offsetX = /** @type {number} */ (instruction[4]) * pixelRatio;
- var offsetY = /** @type {number} */ (instruction[5]) * pixelRatio;
- rotation = /** @type {number} */ (instruction[6]);
- scale = /** @type {number} */ (instruction[7]) * pixelRatio;
- fill = /** @type {boolean} */ (instruction[8]);
- stroke = /** @type {boolean} */ (instruction[9]);
- rotateWithView = /** @type {boolean} */ (instruction[10]);
- x = pixelCoordinates[d] + offsetX;
- y = pixelCoordinates[d + 1] + offsetY;
- ol.transform.compose(localTransform, x, y, scale, scale, rotation, -x, -y);
- // Support multiple lines separated by \n
- var lines = text.split('\n');
- var numLines = lines.length;
- var fontSize, lineY;
- if (numLines > 1) {
- // Estimate line height using width of capital M, and add padding
- fontSize = Math.round(context.measureText('M').width * 1.5);
- lineY = y - (((numLines - 1) / 2) * fontSize);
- } else {
- // No need to calculate line height/offset for a single line
- fontSize = 0;
- lineY = y;
- for (var lineIndex = 0; lineIndex < numLines; lineIndex++) {
- var line = lines[lineIndex];
- if (stroke) {
- context.strokeText(line, x, lineY);
- if (fill) {
- context.fillText(line, x, lineY);
- // Move next line down by fontSize px
- lineY = lineY + fontSize;
- ++i;
- break;
- case ol.render.canvas.Instruction.END_GEOMETRY:
- if (featureCallback !== undefined) {
- feature =
- /** @type {ol.Feature|ol.render.Feature} */ (instruction[1]);
- var result = featureCallback(feature);
- if (result) {
- return result;
- ++i;
- break;
- case ol.render.canvas.Instruction.FILL:
- if (batchSize) {
- pendingFill++;
- } else {
- ++i;
- break;
- case ol.render.canvas.Instruction.MOVE_TO_LINE_TO:
- x = pixelCoordinates[d];
- y = pixelCoordinates[d + 1];
- roundX = (x + 0.5) | 0;
- roundY = (y + 0.5) | 0;
- if (roundX !== prevX || roundY !== prevY) {
- context.moveTo(x, y);
- prevX = roundX;
- prevY = roundY;
- for (d += 2; d < dd; d += 2) {
- if (d == dd - 2 || roundX !== prevX || roundY !== prevY) {
- context.lineTo(x, y);
- prevX = roundX;
- prevY = roundY;
- ++i;
- break;
- case ol.render.canvas.Instruction.SET_FILL_STYLE:
- this.fillOrigin_ = instruction[2];
- if (pendingFill) {
- pendingFill = 0;
- if (pendingStroke) {
- context.stroke();
- context.fillStyle = /** @type {ol.ColorLike} */ (instruction[1]);
- ++i;
- break;
- case ol.render.canvas.Instruction.SET_STROKE_STYLE:
- var usePixelRatio = instruction[8] !== undefined ?
- instruction[8] : true;
- var renderedPixelRatio = instruction[9];
- var lineWidth = /** @type {number} */ (instruction[2]);
- context.stroke();
- context.strokeStyle = /** @type {ol.ColorLike} */ (instruction[1]);
- context.lineWidth = usePixelRatio ? lineWidth * pixelRatio : lineWidth;
- context.lineCap = /** @type {string} */ (instruction[3]);
- context.lineJoin = /** @type {string} */ (instruction[4]);
- context.miterLimit = /** @type {number} */ (instruction[5]);
- if (ol.has.CANVAS_LINE_DASH) {
- var lineDash = /** @type {Array.<number>} */ (instruction[6]);
- var lineDashOffset = /** @type {number} */ (instruction[7]);
- if (usePixelRatio && pixelRatio !== renderedPixelRatio) {
- lineDash = lineDash.map(function(dash) {
- return dash * pixelRatio / renderedPixelRatio;
- lineDashOffset *= pixelRatio / renderedPixelRatio;
- instruction[6] = lineDash;
- instruction[7] = lineDashOffset;
- instruction[9] = pixelRatio;
- context.lineDashOffset = lineDashOffset;
- context.setLineDash(lineDash);
- ++i;
- break;
- case ol.render.canvas.Instruction.SET_TEXT_STYLE:
- context.font = /** @type {string} */ (instruction[1]);
- context.textAlign = /** @type {string} */ (instruction[2]);
- context.textBaseline = /** @type {string} */ (instruction[3]);
- ++i;
- break;
- case ol.render.canvas.Instruction.STROKE:
- if (batchSize) {
- pendingStroke++;
- } else {
- context.stroke();
- ++i;
- break;
- default:
- ++i; // consume the instruction anyway, to avoid an infinite loop
- break;
- context.stroke();
- return undefined;
- * to skip.
-ol.render.canvas.Replay.prototype.replay = function(
- context, pixelRatio, transform, viewRotation, skippedFeaturesHash) {
- var instructions = this.instructions;
- this.replay_(context, pixelRatio, transform, viewRotation,
- skippedFeaturesHash, instructions, undefined, undefined);
- * to skip.
- * @param {function((ol.Feature|ol.render.Feature)): T=} opt_featureCallback
- * Feature callback.
- * extent.
- * @template T
-ol.render.canvas.Replay.prototype.replayHitDetection = function(
- context, transform, viewRotation, skippedFeaturesHash,
- opt_featureCallback, opt_hitExtent) {
- var instructions = this.hitDetectionInstructions;
- return this.replay_(context, 1, transform, viewRotation,
- skippedFeaturesHash, instructions, opt_featureCallback, opt_hitExtent);
- * Reverse the hit detection instructions.
-ol.render.canvas.Replay.prototype.reverseHitDetectionInstructions = function() {
- var hitDetectionInstructions = this.hitDetectionInstructions;
- // step 1 - reverse array
- hitDetectionInstructions.reverse();
- // step 2 - reverse instructions within geometry blocks
- var i;
- var n = hitDetectionInstructions.length;
- var instruction;
- var type;
- var begin = -1;
- for (i = 0; i < n; ++i) {
- instruction = hitDetectionInstructions[i];
- type = /** @type {ol.render.canvas.Instruction} */ (instruction[0]);
- if (type == ol.render.canvas.Instruction.END_GEOMETRY) {
- begin = i;
- } else if (type == ol.render.canvas.Instruction.BEGIN_GEOMETRY) {
- instruction[2] = i;
- ol.array.reverseSubArray(this.hitDetectionInstructions, begin, i);
- begin = -1;
-ol.render.canvas.Replay.prototype.endGeometry = function(geometry, feature) {
- this.beginGeometryInstruction1_[2] = this.instructions.length;
- this.beginGeometryInstruction2_[2] = this.hitDetectionInstructions.length;
- var endGeometryInstruction =
- [ol.render.canvas.Instruction.END_GEOMETRY, feature];
- this.instructions.push(endGeometryInstruction);
- this.hitDetectionInstructions.push(endGeometryInstruction);
- * FIXME empty description for jsdoc
-ol.render.canvas.Replay.prototype.finish = ol.nullFunction;
- * Get the buffered rendering extent. Rendering will be clipped to the extent
- * provided to the constructor. To account for symbolizers that may intersect
- * this extent, we calculate a buffered extent (e.g. based on stroke width).
- * @return {ol.Extent} The buffered rendering extent.
- * @protected
-ol.render.canvas.Replay.prototype.getBufferedMaxExtent = function() {
- return this.maxExtent;
-goog.provide('ol.render.canvas.ImageReplay');
-goog.require('ol.render.canvas.Replay');
- * @constructor
- * @extends {ol.render.canvas.Replay}
- * @struct
-ol.render.canvas.ImageReplay = function(tolerance, maxExtent, resolution, overlaps) {
- ol.render.canvas.Replay.call(this, tolerance, maxExtent, resolution, overlaps);
- * @private
- * @type {HTMLCanvasElement|HTMLVideoElement|Image}
- this.hitDetectionImage_ = null;
- * @private
- this.image_ = null;
- * @private
- * @type {number|undefined}
- this.anchorX_ = undefined;
- * @private
- this.anchorY_ = undefined;
- * @private
- this.height_ = undefined;
- * @private
- this.opacity_ = undefined;
- * @private
- this.originX_ = undefined;
- * @private
- this.originY_ = undefined;
- * @private
- * @type {boolean|undefined}
- this.rotateWithView_ = undefined;
- * @private
- this.rotation_ = undefined;
- * @private
- this.scale_ = undefined;
- * @private
- this.snapToPixel_ = undefined;
- * @private
- this.width_ = undefined;
-ol.inherits(ol.render.canvas.ImageReplay, ol.render.canvas.Replay);
- * @private
-ol.render.canvas.ImageReplay.prototype.drawCoordinates_ = function(flatCoordinates, offset, end, stride) {
- return this.appendFlatCoordinates(
- flatCoordinates, offset, end, stride, false, false);
- * @inheritDoc
-ol.render.canvas.ImageReplay.prototype.drawPoint = function(pointGeometry, feature) {
- if (!this.image_) {
- return;
- this.beginGeometry(pointGeometry, feature);
- var flatCoordinates = pointGeometry.getFlatCoordinates();
- var stride = pointGeometry.getStride();
- var myBegin = this.coordinates.length;
- var myEnd = this.drawCoordinates_(
- flatCoordinates, 0, flatCoordinates.length, stride);
- this.instructions.push([
- ol.render.canvas.Instruction.DRAW_IMAGE, myBegin, myEnd, this.image_,
- // Remaining arguments to DRAW_IMAGE are in alphabetical order
- this.anchorX_, this.anchorY_, this.height_, this.opacity_,
- this.originX_, this.originY_, this.rotateWithView_, this.rotation_,
- this.scale_, this.snapToPixel_, this.width_
- this.hitDetectionInstructions.push([
- this.hitDetectionImage_,
- this.endGeometry(pointGeometry, feature);
- * @inheritDoc
-ol.render.canvas.ImageReplay.prototype.drawMultiPoint = function(multiPointGeometry, feature) {
- return;
- this.beginGeometry(multiPointGeometry, feature);
- var flatCoordinates = multiPointGeometry.getFlatCoordinates();
- var stride = multiPointGeometry.getStride();
- this.endGeometry(multiPointGeometry, feature);
- * @inheritDoc
-ol.render.canvas.ImageReplay.prototype.finish = function() {
- this.reverseHitDetectionInstructions();
- // FIXME this doesn't really protect us against further calls to draw*Geometry
- * @inheritDoc
-ol.render.canvas.ImageReplay.prototype.setImageStyle = function(imageStyle) {
- var anchor = imageStyle.getAnchor();
- var size = imageStyle.getSize();
- var hitDetectionImage = imageStyle.getHitDetectionImage(1);
- var image = imageStyle.getImage(1);
- var origin = imageStyle.getOrigin();
- this.anchorX_ = anchor[0];
- this.anchorY_ = anchor[1];
- this.hitDetectionImage_ = hitDetectionImage;
- this.height_ = size[1];
- this.opacity_ = imageStyle.getOpacity();
- this.originX_ = origin[0];
- this.originY_ = origin[1];
- this.rotateWithView_ = imageStyle.getRotateWithView();
- this.rotation_ = imageStyle.getRotation();
- this.scale_ = imageStyle.getScale();
- this.snapToPixel_ = imageStyle.getSnapToPixel();
- this.width_ = size[0];
-goog.provide('ol.render.canvas.LineStringReplay');
-goog.require('ol.colorlike');
-goog.require('ol.extent');
-goog.require('ol.render.canvas');
- * @constructor
- * @struct
-ol.render.canvas.LineStringReplay = function(tolerance, maxExtent, resolution, overlaps) {
- * @private
- this.bufferedMaxExtent_ = null;
- * @private
- * @type {{currentStrokeStyle: (ol.ColorLike|undefined),
- * currentLineCap: (string|undefined),
- * currentLineDash: Array.<number>,
- * currentLineDashOffset: (number|undefined),
- * currentLineJoin: (string|undefined),
- * currentLineWidth: (number|undefined),
- * currentMiterLimit: (number|undefined),
- * lastStroke: number,
- * strokeStyle: (ol.ColorLike|undefined),
- * lineCap: (string|undefined),
- * lineDash: Array.<number>,
- * lineDashOffset: (number|undefined),
- * lineJoin: (string|undefined),
- * lineWidth: (number|undefined),
- * miterLimit: (number|undefined)}|null}
- this.state_ = {
- currentStrokeStyle: undefined,
- currentLineCap: undefined,
- currentLineDash: null,
- currentLineDashOffset: undefined,
- currentLineJoin: undefined,
- currentLineWidth: undefined,
- currentMiterLimit: undefined,
- lastStroke: 0,
- strokeStyle: undefined,
- lineCap: undefined,
- lineDash: null,
- lineDashOffset: undefined,
- lineJoin: undefined,
- lineWidth: undefined,
- miterLimit: undefined
-ol.inherits(ol.render.canvas.LineStringReplay, ol.render.canvas.Replay);
- * @private
- * @return {number} end.
-ol.render.canvas.LineStringReplay.prototype.drawFlatCoordinates_ = function(flatCoordinates, offset, end, stride) {
- var myEnd = this.appendFlatCoordinates(
- var moveToLineToInstruction =
- [ol.render.canvas.Instruction.MOVE_TO_LINE_TO, myBegin, myEnd];
- this.instructions.push(moveToLineToInstruction);
- this.hitDetectionInstructions.push(moveToLineToInstruction);
- return end;
- * @inheritDoc
-ol.render.canvas.LineStringReplay.prototype.getBufferedMaxExtent = function() {
- if (!this.bufferedMaxExtent_) {
- this.bufferedMaxExtent_ = ol.extent.clone(this.maxExtent);
- if (this.maxLineWidth > 0) {
- var width = this.resolution * (this.maxLineWidth + 1) / 2;
- ol.extent.buffer(this.bufferedMaxExtent_, width, this.bufferedMaxExtent_);
- return this.bufferedMaxExtent_;
- * @private
-ol.render.canvas.LineStringReplay.prototype.setStrokeStyle_ = function() {
- var state = this.state_;
- var strokeStyle = state.strokeStyle;
- var lineCap = state.lineCap;
- var lineDash = state.lineDash;
- var lineDashOffset = state.lineDashOffset;
- var lineJoin = state.lineJoin;
- var lineWidth = state.lineWidth;
- var miterLimit = state.miterLimit;
- if (state.currentStrokeStyle != strokeStyle ||
- state.currentLineCap != lineCap ||
- !ol.array.equals(state.currentLineDash, lineDash) ||
- state.currentLineDashOffset != lineDashOffset ||
- state.currentLineJoin != lineJoin ||
- state.currentLineWidth != lineWidth ||
- state.currentMiterLimit != miterLimit) {
- if (state.lastStroke != this.coordinates.length) {
- this.instructions.push([ol.render.canvas.Instruction.STROKE]);
- state.lastStroke = this.coordinates.length;
- ol.render.canvas.Instruction.SET_STROKE_STYLE,
- strokeStyle, lineWidth, lineCap, lineJoin, miterLimit, lineDash, lineDashOffset, true, 1
- ol.render.canvas.Instruction.BEGIN_PATH
- state.currentStrokeStyle = strokeStyle;
- state.currentLineCap = lineCap;
- state.currentLineDash = lineDash;
- state.currentLineDashOffset = lineDashOffset;
- state.currentLineJoin = lineJoin;
- state.currentLineWidth = lineWidth;
- state.currentMiterLimit = miterLimit;
- * @inheritDoc
-ol.render.canvas.LineStringReplay.prototype.drawLineString = function(lineStringGeometry, feature) {
- if (strokeStyle === undefined || lineWidth === undefined) {
- return;
- this.setStrokeStyle_();
- this.beginGeometry(lineStringGeometry, feature);
- state.strokeStyle, state.lineWidth, state.lineCap, state.lineJoin,
- state.miterLimit, state.lineDash, state.lineDashOffset, true, 1
- var flatCoordinates = lineStringGeometry.getFlatCoordinates();
- var stride = lineStringGeometry.getStride();
- this.drawFlatCoordinates_(flatCoordinates, 0, flatCoordinates.length, stride);
- this.hitDetectionInstructions.push([ol.render.canvas.Instruction.STROKE]);
- this.endGeometry(lineStringGeometry, feature);
- * @inheritDoc
-ol.render.canvas.LineStringReplay.prototype.drawMultiLineString = function(multiLineStringGeometry, feature) {
- return;
- this.beginGeometry(multiLineStringGeometry, feature);
- var ends = multiLineStringGeometry.getEnds();
- var flatCoordinates = multiLineStringGeometry.getFlatCoordinates();
- var stride = multiLineStringGeometry.getStride();
- var offset = 0;
- var i, ii;
- for (i = 0, ii = ends.length; i < ii; ++i) {
- offset = this.drawFlatCoordinates_(
- flatCoordinates, offset, ends[i], stride);
- this.endGeometry(multiLineStringGeometry, feature);
- * @inheritDoc
-ol.render.canvas.LineStringReplay.prototype.finish = function() {
- this.state_ = null;
- * @inheritDoc
-ol.render.canvas.LineStringReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- var strokeStyleColor = strokeStyle.getColor();
- this.state_.strokeStyle = ol.colorlike.asColorLike(strokeStyleColor ?
- strokeStyleColor : ol.render.canvas.defaultStrokeStyle);
- var strokeStyleLineCap = strokeStyle.getLineCap();
- this.state_.lineCap = strokeStyleLineCap !== undefined ?
- strokeStyleLineCap : ol.render.canvas.defaultLineCap;
- var strokeStyleLineDash = strokeStyle.getLineDash();
- this.state_.lineDash = strokeStyleLineDash ?
- strokeStyleLineDash : ol.render.canvas.defaultLineDash;
- var strokeStyleLineDashOffset = strokeStyle.getLineDashOffset();
- this.state_.lineDashOffset = strokeStyleLineDashOffset ?
- strokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset;
- var strokeStyleLineJoin = strokeStyle.getLineJoin();
- this.state_.lineJoin = strokeStyleLineJoin !== undefined ?
- strokeStyleLineJoin : ol.render.canvas.defaultLineJoin;
- var strokeStyleWidth = strokeStyle.getWidth();
- this.state_.lineWidth = strokeStyleWidth !== undefined ?
- strokeStyleWidth : ol.render.canvas.defaultLineWidth;
- var strokeStyleMiterLimit = strokeStyle.getMiterLimit();
- this.state_.miterLimit = strokeStyleMiterLimit !== undefined ?
- strokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit;
- if (this.state_.lineWidth > this.maxLineWidth) {
- this.maxLineWidth = this.state_.lineWidth;
- // invalidate the buffered max extent cache
-goog.provide('ol.render.canvas.PolygonReplay');
-goog.require('ol.color');
-goog.require('ol.geom.flat.simplify');
- * @constructor
- * @struct
-ol.render.canvas.PolygonReplay = function(tolerance, maxExtent, resolution, overlaps) {
- * @private
- * @private
- * @type {{currentFillStyle: (ol.ColorLike|undefined),
- * currentStrokeStyle: (ol.ColorLike|undefined),
- * fillStyle: (ol.ColorLike|undefined),
- this.state_ = {
- currentFillStyle: undefined,
- fillStyle: undefined,
- lineDash: null,
-ol.inherits(ol.render.canvas.PolygonReplay, ol.render.canvas.Replay);
- * @param {Array.<number>} flatCoordinates Flat coordinates.
- * @param {Array.<number>} ends Ends.
- * @private
- * @return {number} End.
-ol.render.canvas.PolygonReplay.prototype.drawFlatCoordinatess_ = function(flatCoordinates, offset, ends, stride) {
- var fill = state.fillStyle !== undefined;
- var stroke = state.strokeStyle != undefined;
- var numEnds = ends.length;
- var beginPathInstruction = [ol.render.canvas.Instruction.BEGIN_PATH];
- this.instructions.push(beginPathInstruction);
- this.hitDetectionInstructions.push(beginPathInstruction);
- for (var i = 0; i < numEnds; ++i) {
- var end = ends[i];
- flatCoordinates, offset, end, stride, true, !stroke);
- if (stroke) {
- // Performance optimization: only call closePath() when we have a stroke.
- // Otherwise the ring is closed already (see appendFlatCoordinates above).
- var closePathInstruction = [ol.render.canvas.Instruction.CLOSE_PATH];
- this.instructions.push(closePathInstruction);
- this.hitDetectionInstructions.push(closePathInstruction);
- offset = end;
- var fillInstruction = [ol.render.canvas.Instruction.FILL];
- this.hitDetectionInstructions.push(fillInstruction);
- if (fill) {
- this.instructions.push(fillInstruction);
- if (stroke) {
- var strokeInstruction = [ol.render.canvas.Instruction.STROKE];
- this.instructions.push(strokeInstruction);
- this.hitDetectionInstructions.push(strokeInstruction);
- return offset;
- * @inheritDoc
-ol.render.canvas.PolygonReplay.prototype.drawCircle = function(circleGeometry, feature) {
- var fillStyle = state.fillStyle;
- if (fillStyle === undefined && strokeStyle === undefined) {
- return;
- this.setFillStrokeStyles_(circleGeometry);
- this.beginGeometry(circleGeometry, feature);
- // always fill the circle for hit detection
- ol.render.canvas.Instruction.SET_FILL_STYLE,
- ol.color.asString(ol.render.canvas.defaultFillStyle)
- if (state.strokeStyle !== undefined) {
- var flatCoordinates = circleGeometry.getFlatCoordinates();
- var stride = circleGeometry.getStride();
- this.appendFlatCoordinates(
- flatCoordinates, 0, flatCoordinates.length, stride, false, false);
- var circleInstruction = [ol.render.canvas.Instruction.CIRCLE, myBegin];
- this.instructions.push(beginPathInstruction, circleInstruction);
- this.hitDetectionInstructions.push(beginPathInstruction, circleInstruction);
- if (state.fillStyle !== undefined) {
- this.endGeometry(circleGeometry, feature);
- * @inheritDoc
-ol.render.canvas.PolygonReplay.prototype.drawPolygon = function(polygonGeometry, feature) {
- this.setFillStrokeStyles_(polygonGeometry);
- this.beginGeometry(polygonGeometry, feature);
- // always fill the polygon for hit detection
- ol.color.asString(ol.render.canvas.defaultFillStyle)]
- var ends = polygonGeometry.getEnds();
- var flatCoordinates = polygonGeometry.getOrientedFlatCoordinates();
- var stride = polygonGeometry.getStride();
- this.drawFlatCoordinatess_(flatCoordinates, 0, ends, stride);
- this.endGeometry(polygonGeometry, feature);
- * @inheritDoc
-ol.render.canvas.PolygonReplay.prototype.drawMultiPolygon = function(multiPolygonGeometry, feature) {
- return;
- this.setFillStrokeStyles_(multiPolygonGeometry);
- this.beginGeometry(multiPolygonGeometry, feature);
- // always fill the multi-polygon for hit detection
- var endss = multiPolygonGeometry.getEndss();
- var flatCoordinates = multiPolygonGeometry.getOrientedFlatCoordinates();
- var stride = multiPolygonGeometry.getStride();
- var offset = 0;
- var i, ii;
- for (i = 0, ii = endss.length; i < ii; ++i) {
- offset = this.drawFlatCoordinatess_(
- flatCoordinates, offset, endss[i], stride);
- this.endGeometry(multiPolygonGeometry, feature);
- * @inheritDoc
-ol.render.canvas.PolygonReplay.prototype.finish = function() {
- // We want to preserve topology when drawing polygons. Polygons are
- // simplified using quantization and point elimination. However, we might
- // have received a mix of quantized and non-quantized geometries, so ensure
- // that all are quantized by quantizing all coordinates in the batch.
- var tolerance = this.tolerance;
- if (tolerance !== 0) {
- var coordinates = this.coordinates;
- var i, ii;
- for (i = 0, ii = coordinates.length; i < ii; ++i) {
- coordinates[i] = ol.geom.flat.simplify.snap(coordinates[i], tolerance);
- * @inheritDoc
-ol.render.canvas.PolygonReplay.prototype.getBufferedMaxExtent = function() {
- * @inheritDoc
-ol.render.canvas.PolygonReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
- if (fillStyle) {
- var fillStyleColor = fillStyle.getColor();
- state.fillStyle = ol.colorlike.asColorLike(fillStyleColor ?
- fillStyleColor : ol.render.canvas.defaultFillStyle);
- } else {
- state.fillStyle = undefined;
- if (strokeStyle) {
- state.strokeStyle = ol.colorlike.asColorLike(strokeStyleColor ?
- state.lineCap = strokeStyleLineCap !== undefined ?
- state.lineDash = strokeStyleLineDash ?
- strokeStyleLineDash.slice() : ol.render.canvas.defaultLineDash;
- state.lineDashOffset = strokeStyleLineDashOffset ?
- state.lineJoin = strokeStyleLineJoin !== undefined ?
- state.lineWidth = strokeStyleWidth !== undefined ?
- state.miterLimit = strokeStyleMiterLimit !== undefined ?
- if (state.lineWidth > this.maxLineWidth) {
- this.maxLineWidth = state.lineWidth;
- } else {
- state.strokeStyle = undefined;
- state.lineCap = undefined;
- state.lineDash = null;
- state.lineDashOffset = undefined;
- state.lineJoin = undefined;
- state.lineWidth = undefined;
- state.miterLimit = undefined;
- * @private
-ol.render.canvas.PolygonReplay.prototype.setFillStrokeStyles_ = function(geometry) {
- if (fillStyle !== undefined && (typeof fillStyle !== 'string' || state.currentFillStyle != fillStyle)) {
- var fillInstruction = [ol.render.canvas.Instruction.SET_FILL_STYLE, fillStyle];
- if (typeof fillStyle !== 'string') {
- var fillExtent = geometry.getExtent();
- fillInstruction.push([fillExtent[0], fillExtent[3]]);
- state.currentFillStyle = state.fillStyle;
- if (strokeStyle !== undefined) {
-goog.provide('ol.render.canvas.TextReplay');
- * @constructor
- * @struct
-ol.render.canvas.TextReplay = function(tolerance, maxExtent, resolution, overlaps) {
- * @private
- * @type {?ol.CanvasFillState}
- this.replayFillState_ = null;
- * @private
- * @type {?ol.CanvasStrokeState}
- this.replayStrokeState_ = null;
- * @private
- * @type {?ol.CanvasTextState}
- this.replayTextState_ = null;
- * @private
- * @type {string}
- this.text_ = '';
- * @private
- * @type {number}
- this.textOffsetX_ = 0;
- * @private
- * @type {number}
- this.textOffsetY_ = 0;
- * @private
- this.textRotateWithView_ = undefined;
- * @private
- * @type {number}
- this.textRotation_ = 0;
- * @private
- * @type {number}
- this.textScale_ = 0;
- * @private
- this.textFillState_ = null;
- * @private
- this.textStrokeState_ = null;
- * @private
- this.textState_ = null;
-ol.inherits(ol.render.canvas.TextReplay, ol.render.canvas.Replay);
- * @inheritDoc
-ol.render.canvas.TextReplay.prototype.drawText = function(flatCoordinates, offset, end, stride, geometry, feature) {
- if (this.text_ === '' || !this.textState_ ||
- (!this.textFillState_ && !this.textStrokeState_)) {
- return;
- if (this.textFillState_) {
- this.setReplayFillState_(this.textFillState_);
- if (this.textStrokeState_) {
- this.setReplayStrokeState_(this.textStrokeState_);
- this.setReplayTextState_(this.textState_);
- this.beginGeometry(geometry, feature);
- var myEnd =
- this.appendFlatCoordinates(flatCoordinates, offset, end, stride, false, false);
- var fill = !!this.textFillState_;
- var stroke = !!this.textStrokeState_;
- var drawTextInstruction = [
- ol.render.canvas.Instruction.DRAW_TEXT, myBegin, myEnd, this.text_,
- this.textOffsetX_, this.textOffsetY_, this.textRotation_, this.textScale_,
- fill, stroke, this.textRotateWithView_];
- this.instructions.push(drawTextInstruction);
- this.hitDetectionInstructions.push(drawTextInstruction);
- this.endGeometry(geometry, feature);
- * @param {ol.CanvasFillState} fillState Fill state.
- * @private
-ol.render.canvas.TextReplay.prototype.setReplayFillState_ = function(fillState) {
- var replayFillState = this.replayFillState_;
- if (replayFillState &&
- replayFillState.fillStyle == fillState.fillStyle) {
- return;
- var setFillStyleInstruction =
- [ol.render.canvas.Instruction.SET_FILL_STYLE, fillState.fillStyle];
- this.instructions.push(setFillStyleInstruction);
- this.hitDetectionInstructions.push(setFillStyleInstruction);
- if (!replayFillState) {
- this.replayFillState_ = {
- fillStyle: fillState.fillStyle
- } else {
- replayFillState.fillStyle = fillState.fillStyle;
- * @param {ol.CanvasStrokeState} strokeState Stroke state.
- * @private
-ol.render.canvas.TextReplay.prototype.setReplayStrokeState_ = function(strokeState) {
- var replayStrokeState = this.replayStrokeState_;
- if (replayStrokeState &&
- replayStrokeState.lineCap == strokeState.lineCap &&
- replayStrokeState.lineDash == strokeState.lineDash &&
- replayStrokeState.lineDashOffset == strokeState.lineDashOffset &&
- replayStrokeState.lineJoin == strokeState.lineJoin &&
- replayStrokeState.lineWidth == strokeState.lineWidth &&
- replayStrokeState.miterLimit == strokeState.miterLimit &&
- replayStrokeState.strokeStyle == strokeState.strokeStyle) {
- return;
- var setStrokeStyleInstruction = [
- ol.render.canvas.Instruction.SET_STROKE_STYLE, strokeState.strokeStyle,
- strokeState.lineWidth, strokeState.lineCap, strokeState.lineJoin,
- strokeState.miterLimit, strokeState.lineDash, strokeState.lineDashOffset, false, 1
- this.instructions.push(setStrokeStyleInstruction);
- this.hitDetectionInstructions.push(setStrokeStyleInstruction);
- if (!replayStrokeState) {
- this.replayStrokeState_ = {
- lineCap: strokeState.lineCap,
- lineDash: strokeState.lineDash,
- lineDashOffset: strokeState.lineDashOffset,
- lineJoin: strokeState.lineJoin,
- lineWidth: strokeState.lineWidth,
- miterLimit: strokeState.miterLimit,
- strokeStyle: strokeState.strokeStyle
- } else {
- replayStrokeState.lineCap = strokeState.lineCap;
- replayStrokeState.lineDash = strokeState.lineDash;
- replayStrokeState.lineDashOffset = strokeState.lineDashOffset;
- replayStrokeState.lineJoin = strokeState.lineJoin;
- replayStrokeState.lineWidth = strokeState.lineWidth;
- replayStrokeState.miterLimit = strokeState.miterLimit;
- replayStrokeState.strokeStyle = strokeState.strokeStyle;
- * @param {ol.CanvasTextState} textState Text state.
- * @private
-ol.render.canvas.TextReplay.prototype.setReplayTextState_ = function(textState) {
- var replayTextState = this.replayTextState_;
- if (replayTextState &&
- replayTextState.font == textState.font &&
- replayTextState.textAlign == textState.textAlign &&
- replayTextState.textBaseline == textState.textBaseline) {
- return;
- var setTextStyleInstruction = [ol.render.canvas.Instruction.SET_TEXT_STYLE,
- textState.font, textState.textAlign, textState.textBaseline];
- this.instructions.push(setTextStyleInstruction);
- this.hitDetectionInstructions.push(setTextStyleInstruction);
- if (!replayTextState) {
- this.replayTextState_ = {
- font: textState.font,
- textAlign: textState.textAlign,
- textBaseline: textState.textBaseline
- } else {
- replayTextState.font = textState.font;
- replayTextState.textAlign = textState.textAlign;
- replayTextState.textBaseline = textState.textBaseline;
- * @inheritDoc
-ol.render.canvas.TextReplay.prototype.setTextStyle = function(textStyle) {
- if (!textStyle) {
- this.text_ = '';
- } else {
- var textFillStyle = textStyle.getFill();
- if (!textFillStyle) {
- } else {
- var textFillStyleColor = textFillStyle.getColor();
- var fillStyle = ol.colorlike.asColorLike(textFillStyleColor ?
- textFillStyleColor : ol.render.canvas.defaultFillStyle);
- if (!this.textFillState_) {
- this.textFillState_ = {
- fillStyle: fillStyle
- } else {
- var textFillState = this.textFillState_;
- textFillState.fillStyle = fillStyle;
- var textStrokeStyle = textStyle.getStroke();
- if (!textStrokeStyle) {
- } else {
- var textStrokeStyleColor = textStrokeStyle.getColor();
- var textStrokeStyleLineCap = textStrokeStyle.getLineCap();
- var textStrokeStyleLineDash = textStrokeStyle.getLineDash();
- var textStrokeStyleLineDashOffset = textStrokeStyle.getLineDashOffset();
- var textStrokeStyleLineJoin = textStrokeStyle.getLineJoin();
- var textStrokeStyleWidth = textStrokeStyle.getWidth();
- var textStrokeStyleMiterLimit = textStrokeStyle.getMiterLimit();
- var lineCap = textStrokeStyleLineCap !== undefined ?
- textStrokeStyleLineCap : ol.render.canvas.defaultLineCap;
- var lineDash = textStrokeStyleLineDash ?
- textStrokeStyleLineDash.slice() : ol.render.canvas.defaultLineDash;
- var lineDashOffset = textStrokeStyleLineDashOffset !== undefined ?
- textStrokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset;
- var lineJoin = textStrokeStyleLineJoin !== undefined ?
- textStrokeStyleLineJoin : ol.render.canvas.defaultLineJoin;
- var lineWidth = textStrokeStyleWidth !== undefined ?
- textStrokeStyleWidth : ol.render.canvas.defaultLineWidth;
- var miterLimit = textStrokeStyleMiterLimit !== undefined ?
- textStrokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit;
- var strokeStyle = ol.colorlike.asColorLike(textStrokeStyleColor ?
- textStrokeStyleColor : ol.render.canvas.defaultStrokeStyle);
- if (!this.textStrokeState_) {
- this.textStrokeState_ = {
- lineCap: lineCap,
- lineDash: lineDash,
- lineDashOffset: lineDashOffset,
- lineJoin: lineJoin,
- lineWidth: lineWidth,
- miterLimit: miterLimit,
- strokeStyle: strokeStyle
- } else {
- var textStrokeState = this.textStrokeState_;
- textStrokeState.lineCap = lineCap;
- textStrokeState.lineDash = lineDash;
- textStrokeState.lineDashOffset = lineDashOffset;
- textStrokeState.lineJoin = lineJoin;
- textStrokeState.lineWidth = lineWidth;
- textStrokeState.miterLimit = miterLimit;
- textStrokeState.strokeStyle = strokeStyle;
- var textFont = textStyle.getFont();
- var textOffsetX = textStyle.getOffsetX();
- var textOffsetY = textStyle.getOffsetY();
- var textRotateWithView = textStyle.getRotateWithView();
- var textRotation = textStyle.getRotation();
- var textScale = textStyle.getScale();
- var textText = textStyle.getText();
- var textTextAlign = textStyle.getTextAlign();
- var textTextBaseline = textStyle.getTextBaseline();
- var font = textFont !== undefined ?
- textFont : ol.render.canvas.defaultFont;
- var textAlign = textTextAlign !== undefined ?
- textTextAlign : ol.render.canvas.defaultTextAlign;
- var textBaseline = textTextBaseline !== undefined ?
- textTextBaseline : ol.render.canvas.defaultTextBaseline;
- if (!this.textState_) {
- this.textState_ = {
- font: font,
- textAlign: textAlign,
- textBaseline: textBaseline
- } else {
- var textState = this.textState_;
- textState.font = font;
- textState.textAlign = textAlign;
- textState.textBaseline = textBaseline;
- this.text_ = textText !== undefined ? textText : '';
- this.textOffsetX_ = textOffsetX !== undefined ? textOffsetX : 0;
- this.textOffsetY_ = textOffsetY !== undefined ? textOffsetY : 0;
- this.textRotateWithView_ = textRotateWithView !== undefined ? textRotateWithView : false;
- this.textRotation_ = textRotation !== undefined ? textRotation : 0;
- this.textScale_ = textScale !== undefined ? textScale : 1;
-goog.provide('ol.render.canvas.ReplayGroup');
-goog.require('ol.dom');
-goog.require('ol.render.ReplayGroup');
-goog.require('ol.render.canvas.ImageReplay');
-goog.require('ol.render.canvas.LineStringReplay');
-goog.require('ol.render.canvas.PolygonReplay');
-goog.require('ol.render.canvas.TextReplay');
-goog.require('ol.render.replay');
- * @constructor
- * @extends {ol.render.ReplayGroup}
- * @param {ol.Extent} maxExtent Max extent.
- * @param {number} resolution Resolution.
- * @param {boolean} overlaps The replay group can have overlapping geometries.
- * @param {number=} opt_renderBuffer Optional rendering buffer.
- * @struct
-ol.render.canvas.ReplayGroup = function(
- tolerance, maxExtent, resolution, overlaps, opt_renderBuffer) {
- ol.render.ReplayGroup.call(this);
- * @private
- * @type {number}
- this.tolerance_ = tolerance;
- * @private
- * @type {ol.Extent}
- this.maxExtent_ = maxExtent;
- * @private
- * @type {boolean}
- this.overlaps_ = overlaps;
- * @private
- * @type {number}
- this.resolution_ = resolution;
- * @private
- this.renderBuffer_ = opt_renderBuffer;
- * @private
- * @type {!Object.<string,
- * Object.<ol.render.ReplayType, ol.render.canvas.Replay>>}
- this.replaysByZIndex_ = {};
- * @private
- * @type {CanvasRenderingContext2D}
- this.hitDetectionContext_ = ol.dom.createCanvasContext2D(1, 1);
- * @private
- * @type {ol.Transform}
- this.hitDetectionTransform_ = ol.transform.create();
-ol.inherits(ol.render.canvas.ReplayGroup, ol.render.ReplayGroup);
- * This cache is used for storing calculated pixel circles for increasing performance.
- * It is a static property to allow each Replaygroup to access it.
- * @type {Object.<number, Array.<Array.<(boolean|undefined)>>>}
- * @private
-ol.render.canvas.ReplayGroup.circleArrayCache_ = {
- 0: [[true]]
- * This method fills a row in the array from the given coordinate to the
- * middle with `true`.
- * @param {Array.<Array.<(boolean|undefined)>>} array The array that will be altered.
- * @param {number} x X coordinate.
- * @param {number} y Y coordinate.
- * @private
-ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_ = function(array, x, y) {
- var i;
- var radius = Math.floor(array.length / 2);
- if (x >= radius) {
- for (i = radius; i < x; i++) {
- array[i][y] = true;
- } else if (x < radius) {
- for (i = x + 1; i < radius; i++) {
- * This methods creates a circle inside a fitting array. Points inside the
- * circle are marked by true, points on the outside are undefined.
- * It uses the midpoint circle algorithm.
- * A cache is used to increase performance.
- * @param {number} radius Radius.
- * @returns {Array.<Array.<(boolean|undefined)>>} An array with marked circle points.
- * @private
-ol.render.canvas.ReplayGroup.getCircleArray_ = function(radius) {
- if (ol.render.canvas.ReplayGroup.circleArrayCache_[radius] !== undefined) {
- return ol.render.canvas.ReplayGroup.circleArrayCache_[radius];
- var arraySize = radius * 2 + 1;
- var arr = new Array(arraySize);
- for (var i = 0; i < arraySize; i++) {
- arr[i] = new Array(arraySize);
- var x = radius;
- var y = 0;
- var error = 0;
- while (x >= y) {
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + x, radius + y);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + y, radius + x);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - y, radius + x);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - x, radius + y);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - x, radius - y);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - y, radius - x);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + y, radius - x);
- ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + x, radius - y);
- y++;
- error += 1 + 2 * y;
- if (2 * (error - x) + 1 > 0) {
- x -= 1;
- error += 1 - 2 * x;
- ol.render.canvas.ReplayGroup.circleArrayCache_[radius] = arr;
- return arr;
-ol.render.canvas.ReplayGroup.prototype.finish = function() {
- var zKey;
- for (zKey in this.replaysByZIndex_) {
- var replays = this.replaysByZIndex_[zKey];
- var replayKey;
- for (replayKey in replays) {
- replays[replayKey].finish();
- * @param {ol.Coordinate} coordinate Coordinate.
- * @param {number} hitTolerance Hit tolerance in pixels.
- * to skip.
- * @param {function((ol.Feature|ol.render.Feature)): T} callback Feature
- * callback.
- * @template T
-ol.render.canvas.ReplayGroup.prototype.forEachFeatureAtCoordinate = function(
- coordinate, resolution, rotation, hitTolerance, skippedFeaturesHash, callback) {
- hitTolerance = Math.round(hitTolerance);
- var contextSize = hitTolerance * 2 + 1;
- var transform = ol.transform.compose(this.hitDetectionTransform_,
- hitTolerance + 0.5, hitTolerance + 0.5,
- 1 / resolution, -1 / resolution,
- -rotation,
- -coordinate[0], -coordinate[1]);
- var context = this.hitDetectionContext_;
- if (context.canvas.width !== contextSize || context.canvas.height !== contextSize) {
- context.canvas.width = contextSize;
- context.canvas.height = contextSize;
- } else {
- context.clearRect(0, 0, contextSize, contextSize);
- var hitExtent;
- if (this.renderBuffer_ !== undefined) {
- hitExtent = ol.extent.createEmpty();
- ol.extent.extendCoordinate(hitExtent, coordinate);
- ol.extent.buffer(hitExtent, resolution * (this.renderBuffer_ + hitTolerance), hitExtent);
- var mask = ol.render.canvas.ReplayGroup.getCircleArray_(hitTolerance);
- return this.replayHitDetection_(context, transform, rotation,
- * @return {?} Callback result.
- function(feature) {
- var imageData = context.getImageData(0, 0, contextSize, contextSize).data;
- for (var i = 0; i < contextSize; i++) {
- for (var j = 0; j < contextSize; j++) {
- if (mask[i][j]) {
- if (imageData[(j * contextSize + i) * 4 + 3] > 0) {
- var result = callback(feature);
- if (result) {
- return result;
- } else {
- return undefined;
- }, hitExtent);
- * @return {Array.<number>} Clip coordinates.
-ol.render.canvas.ReplayGroup.prototype.getClipCoords = function(transform) {
- var maxExtent = this.maxExtent_;
- var minX = maxExtent[0];
- var minY = maxExtent[1];
- var maxX = maxExtent[2];
- var maxY = maxExtent[3];
- var flatClipCoords = [minX, minY, minX, maxY, maxX, maxY, maxX, minY];
- ol.geom.flat.transform.transform2D(
- flatClipCoords, 0, 8, 2, transform, flatClipCoords);
- return flatClipCoords;
- * @inheritDoc
-ol.render.canvas.ReplayGroup.prototype.getReplay = function(zIndex, replayType) {
- var zIndexKey = zIndex !== undefined ? zIndex.toString() : '0';
- var replays = this.replaysByZIndex_[zIndexKey];
- if (replays === undefined) {
- replays = {};
- this.replaysByZIndex_[zIndexKey] = replays;
- var replay = replays[replayType];
- if (replay === undefined) {
- var Constructor = ol.render.canvas.ReplayGroup.BATCH_CONSTRUCTORS_[replayType];
- replay = new Constructor(this.tolerance_, this.maxExtent_,
- this.resolution_, this.overlaps_);
- replays[replayType] = replay;
- return replay;
- * @inheritDoc
-ol.render.canvas.ReplayGroup.prototype.isEmpty = function() {
- return ol.obj.isEmpty(this.replaysByZIndex_);
- * @param {number} pixelRatio Pixel ratio.
- * to skip.
- * @param {Array.<ol.render.ReplayType>=} opt_replayTypes Ordered replay types
- * to replay. Default is {@link ol.render.replay.ORDER}
-ol.render.canvas.ReplayGroup.prototype.replay = function(context, pixelRatio,
- transform, viewRotation, skippedFeaturesHash, opt_replayTypes) {
- /** @type {Array.<number>} */
- var zs = Object.keys(this.replaysByZIndex_).map(Number);
- zs.sort(ol.array.numberSafeCompareFunction);
- // setup clipping so that the parts of over-simplified geometries are not
- // visible outside the current extent when panning
- var flatClipCoords = this.getClipCoords(transform);
- context.save();
- context.moveTo(flatClipCoords[0], flatClipCoords[1]);
- context.lineTo(flatClipCoords[2], flatClipCoords[3]);
- context.lineTo(flatClipCoords[4], flatClipCoords[5]);
- context.lineTo(flatClipCoords[6], flatClipCoords[7]);
- context.clip();
- var replayTypes = opt_replayTypes ? opt_replayTypes : ol.render.replay.ORDER;
- var i, ii, j, jj, replays, replay;
- for (i = 0, ii = zs.length; i < ii; ++i) {
- replays = this.replaysByZIndex_[zs[i].toString()];
- for (j = 0, jj = replayTypes.length; j < jj; ++j) {
- replay = replays[replayTypes[j]];
- if (replay !== undefined) {
- replay.replay(context, pixelRatio, transform, viewRotation,
- skippedFeaturesHash);
- context.restore();
- * @private
- * to skip.
- * @param {function((ol.Feature|ol.render.Feature)): T} featureCallback
- * extent.
- * @template T
-ol.render.canvas.ReplayGroup.prototype.replayHitDetection_ = function(
- featureCallback, opt_hitExtent) {
- zs.sort(function(a, b) {
- return b - a;
- var i, ii, j, replays, replay, result;
- for (j = ol.render.replay.ORDER.length - 1; j >= 0; --j) {
- replay = replays[ol.render.replay.ORDER[j]];
- result = replay.replayHitDetection(context, transform, viewRotation,
- skippedFeaturesHash, featureCallback, opt_hitExtent);
- if (result) {
- return result;
- return undefined;
- * @const
- * @private
- * @type {Object.<ol.render.ReplayType,
- * function(new: ol.render.canvas.Replay, number, ol.Extent,
- * number, boolean)>}
-ol.render.canvas.ReplayGroup.BATCH_CONSTRUCTORS_ = {
- 'Circle': ol.render.canvas.PolygonReplay,
- 'Image': ol.render.canvas.ImageReplay,
- 'LineString': ol.render.canvas.LineStringReplay,
- 'Polygon': ol.render.canvas.PolygonReplay,
- 'Text': ol.render.canvas.TextReplay
-goog.provide('ol.renderer.Layer');
-goog.require('ol');
-goog.require('ol.ImageState');
-goog.require('ol.Observable');
-goog.require('ol.TileState');
-goog.require('ol.asserts');
-goog.require('ol.events');
-goog.require('ol.events.EventType');
-goog.require('ol.source.State');
- * @constructor
- * @extends {ol.Observable}
- * @param {ol.layer.Layer} layer Layer.
- * @struct
-ol.renderer.Layer = function(layer) {
- ol.Observable.call(this);
- * @private
- * @type {ol.layer.Layer}
- this.layer_ = layer;
-ol.inherits(ol.renderer.Layer, ol.Observable);
- * @param {olx.FrameState} frameState Frame state.
- * @param {function(this: S, (ol.Feature|ol.render.Feature), ol.layer.Layer): T}
- * callback Feature callback.
- * @param {S} thisArg Value to use as `this` when executing `callback`.
- * @template S,T
-ol.renderer.Layer.prototype.forEachFeatureAtCoordinate = ol.nullFunction;
- * @return {boolean} Is there a feature at the given coordinate?
-ol.renderer.Layer.prototype.hasFeatureAtCoordinate = ol.functions.FALSE;
- * Create a function that adds loaded tiles to the tile lookup.
- * @param {ol.source.Tile} source Tile source.
- * @param {ol.proj.Projection} projection Projection of the tiles.
- * @param {Object.<number, Object.<string, ol.Tile>>} tiles Lookup of loaded
- * tiles by zoom level.
- * @return {function(number, ol.TileRange):boolean} A function that can be
- * called with a zoom level and a tile range to add loaded tiles to the
- * lookup.
- * @protected
-ol.renderer.Layer.prototype.createLoadedTileFinder = function(source, projection, tiles) {
- return (
- * @param {number} zoom Zoom level.
- * @param {ol.TileRange} tileRange Tile range.
- * @return {boolean} The tile range is fully loaded.
- function(zoom, tileRange) {
- function callback(tile) {
- if (!tiles[zoom]) {
- tiles[zoom] = {};
- tiles[zoom][tile.tileCoord.toString()] = tile;
- return source.forEachLoadedTile(projection, zoom, tileRange, callback);
- * @return {ol.layer.Layer} Layer.
-ol.renderer.Layer.prototype.getLayer = function() {
- return this.layer_;
- * Handle changes in image state.
- * @param {ol.events.Event} event Image change event.
- * @private
-ol.renderer.Layer.prototype.handleImageChange_ = function(event) {
- var image = /** @type {ol.Image} */ (event.target);
- if (image.getState() === ol.ImageState.LOADED) {
- this.renderIfReadyAndVisible();
- * Load the image if not already loaded, and register the image change
- * listener if needed.
- * @param {ol.ImageBase} image Image.
- * @return {boolean} `true` if the image is already loaded, `false`
- * otherwise.
- * @protected
-ol.renderer.Layer.prototype.loadImage = function(image) {
- var imageState = image.getState();
- if (imageState != ol.ImageState.LOADED &&
- imageState != ol.ImageState.ERROR) {
- ol.events.listen(image, ol.events.EventType.CHANGE,
- this.handleImageChange_, this);
- if (imageState == ol.ImageState.IDLE) {
- image.load();
- imageState = image.getState();
- return imageState == ol.ImageState.LOADED;
- * @protected
-ol.renderer.Layer.prototype.renderIfReadyAndVisible = function() {
- var layer = this.getLayer();
- if (layer.getVisible() && layer.getSourceState() == ol.source.State.READY) {
- this.changed();
- * @param {ol.source.Tile} tileSource Tile source.
- * @protected
-ol.renderer.Layer.prototype.scheduleExpireCache = function(frameState, tileSource) {
- if (tileSource.canExpireCache()) {
- * @param {ol.Map} map Map.
- var postRenderFunction = function(tileSource, map, frameState) {
- var tileSourceKey = ol.getUid(tileSource).toString();
- tileSource.expireCache(frameState.viewState.projection,
- frameState.usedTiles[tileSourceKey]);
- }.bind(null, tileSource);
- frameState.postRenderFunctions.push(
- /** @type {ol.PostRenderFunction} */ (postRenderFunction)
- * @param {Object.<string, ol.Attribution>} attributionsSet Attributions
- * set (target).
- * @param {Array.<ol.Attribution>} attributions Attributions (source).
- * @protected
-ol.renderer.Layer.prototype.updateAttributions = function(attributionsSet, attributions) {
- if (attributions) {
- var attribution, i, ii;
- for (i = 0, ii = attributions.length; i < ii; ++i) {
- attribution = attributions[i];
- attributionsSet[ol.getUid(attribution).toString()] = attribution;
- * @param {ol.source.Source} source Source.
- * @protected
-ol.renderer.Layer.prototype.updateLogos = function(frameState, source) {
- var logo = source.getLogo();
- if (logo !== undefined) {
- if (typeof logo === 'string') {
- frameState.logos[logo] = '';
- } else if (logo) {
- ol.asserts.assert(typeof logo.href == 'string', 44); // `logo.href` should be a string.
- ol.asserts.assert(typeof logo.src == 'string', 45); // `logo.src` should be a string.
- frameState.logos[logo.src] = logo.href;
- * @param {Object.<string, Object.<string, ol.TileRange>>} usedTiles Used tiles.
- * @param {number} z Z.
- * @protected
-ol.renderer.Layer.prototype.updateUsedTiles = function(usedTiles, tileSource, z, tileRange) {
- // FIXME should we use tilesToDrawByZ instead?
- var zKey = z.toString();
- if (tileSourceKey in usedTiles) {
- if (zKey in usedTiles[tileSourceKey]) {
- usedTiles[tileSourceKey][zKey].extend(tileRange);
- } else {
- usedTiles[tileSourceKey][zKey] = tileRange;
- } else {
- usedTiles[tileSourceKey] = {};
- * Manage tile pyramid.
- * This function performs a number of functions related to the tiles at the
- * current zoom and lower zoom levels:
- * - registers idle tiles in frameState.wantedTiles so that they are not
- * discarded by the tile queue
- * - enqueues missing tiles
- * @param {ol.tilegrid.TileGrid} tileGrid Tile grid.
- * @param {ol.proj.Projection} projection Projection.
- * @param {ol.Extent} extent Extent.
- * @param {number} currentZ Current Z.
- * @param {number} preload Load low resolution tiles up to 'preload' levels.
- * @param {function(this: T, ol.Tile)=} opt_tileCallback Tile callback.
- * @param {T=} opt_this Object to use as `this` in `opt_tileCallback`.
- * @protected
- * @template T
-ol.renderer.Layer.prototype.manageTilePyramid = function(
- frameState, tileSource, tileGrid, pixelRatio, projection, extent,
- currentZ, preload, opt_tileCallback, opt_this) {
- if (!(tileSourceKey in frameState.wantedTiles)) {
- frameState.wantedTiles[tileSourceKey] = {};
- var wantedTiles = frameState.wantedTiles[tileSourceKey];
- var tileQueue = frameState.tileQueue;
- var minZoom = tileGrid.getMinZoom();
- var tile, tileRange, tileResolution, x, y, z;
- for (z = currentZ; z >= minZoom; --z) {
- tileRange = tileGrid.getTileRangeForExtentAndZ(extent, z, tileRange);
- tileResolution = tileGrid.getResolution(z);
- for (x = tileRange.minX; x <= tileRange.maxX; ++x) {
- for (y = tileRange.minY; y <= tileRange.maxY; ++y) {
- if (currentZ - z <= preload) {
- tile = tileSource.getTile(z, x, y, pixelRatio, projection);
- if (tile.getState() == ol.TileState.IDLE) {
- wantedTiles[tile.getKey()] = true;
- if (!tileQueue.isKeyQueued(tile.getKey())) {
- tileQueue.enqueue([tile, tileSourceKey,
- tileGrid.getTileCoordCenter(tile.tileCoord), tileResolution]);
- if (opt_tileCallback !== undefined) {
- opt_tileCallback.call(opt_this, tile);
- } else {
- tileSource.useTile(z, x, y, projection);
-goog.provide('ol.renderer.canvas.Layer');
-goog.require('ol.functions');
-goog.require('ol.render.Event');
-goog.require('ol.render.EventType');
-goog.require('ol.render.canvas.Immediate');
-goog.require('ol.renderer.Layer');
- * @constructor
- * @abstract
- * @extends {ol.renderer.Layer}
-ol.renderer.canvas.Layer = function(layer) {
- ol.renderer.Layer.call(this, layer);
- * @protected
- * @type {number}
- this.renderedResolution;
- * @private
- this.transform_ = ol.transform.create();
-ol.inherits(ol.renderer.canvas.Layer, ol.renderer.Layer);
- * @param {ol.Extent} extent Clip extent.
- * @protected
-ol.renderer.canvas.Layer.prototype.clip = function(context, frameState, extent) {
- var pixelRatio = frameState.pixelRatio;
- var width = frameState.size[0] * pixelRatio;
- var height = frameState.size[1] * pixelRatio;
- var rotation = frameState.viewState.rotation;
- var topLeft = ol.extent.getTopLeft(/** @type {ol.Extent} */ (extent));
- var topRight = ol.extent.getTopRight(/** @type {ol.Extent} */ (extent));
- var bottomRight = ol.extent.getBottomRight(/** @type {ol.Extent} */ (extent));
- var bottomLeft = ol.extent.getBottomLeft(/** @type {ol.Extent} */ (extent));
- ol.transform.apply(frameState.coordinateToPixelTransform, topLeft);
- ol.transform.apply(frameState.coordinateToPixelTransform, topRight);
- ol.transform.apply(frameState.coordinateToPixelTransform, bottomRight);
- ol.transform.apply(frameState.coordinateToPixelTransform, bottomLeft);
- context.save();
- ol.render.canvas.rotateAtOffset(context, -rotation, width / 2, height / 2);
- context.moveTo(topLeft[0] * pixelRatio, topLeft[1] * pixelRatio);
- context.lineTo(topRight[0] * pixelRatio, topRight[1] * pixelRatio);
- context.lineTo(bottomRight[0] * pixelRatio, bottomRight[1] * pixelRatio);
- context.lineTo(bottomLeft[0] * pixelRatio, bottomLeft[1] * pixelRatio);
- context.clip();
- ol.render.canvas.rotateAtOffset(context, rotation, width / 2, height / 2);
- * @param {ol.render.EventType} type Event type.
- * @param {ol.Transform=} opt_transform Transform.
- * @private
-ol.renderer.canvas.Layer.prototype.dispatchComposeEvent_ = function(type, context, frameState, opt_transform) {
- if (layer.hasListener(type)) {
- var width = frameState.size[0] * frameState.pixelRatio;
- var height = frameState.size[1] * frameState.pixelRatio;
- var transform = opt_transform !== undefined ?
- opt_transform : this.getTransform(frameState, 0);
- var render = new ol.render.canvas.Immediate(
- context, frameState.pixelRatio, frameState.extent, transform,
- frameState.viewState.rotation);
- var composeEvent = new ol.render.Event(type, render, frameState,
- context, null);
- layer.dispatchEvent(composeEvent);
- * @param {olx.FrameState} frameState FrameState.
- * @param {function(this: S, ol.layer.Layer, (Uint8ClampedArray|Uint8Array)): T} callback Layer
- * callback.
- * @template S,T,U
-ol.renderer.canvas.Layer.prototype.forEachLayerAtCoordinate = function(coordinate, frameState, callback, thisArg) {
- var hasFeature = this.forEachFeatureAtCoordinate(
- coordinate, frameState, 0, ol.functions.TRUE, this);
- if (hasFeature) {
- return callback.call(thisArg, this.getLayer(), null);
- } else {
- return undefined;
- * @param {ol.LayerState} layerState Layer state.
- * @protected
-ol.renderer.canvas.Layer.prototype.postCompose = function(context, frameState, layerState, opt_transform) {
- this.dispatchComposeEvent_(ol.render.EventType.POSTCOMPOSE, context,
- frameState, opt_transform);
- * @protected
-ol.renderer.canvas.Layer.prototype.preCompose = function(context, frameState, opt_transform) {
- this.dispatchComposeEvent_(ol.render.EventType.PRECOMPOSE, context,
- * @protected
-ol.renderer.canvas.Layer.prototype.dispatchRenderEvent = function(context, frameState, opt_transform) {
- this.dispatchComposeEvent_(ol.render.EventType.RENDER, context,
- * @param {number} offsetX Offset on the x-axis in view coordinates.
- * @protected
- * @return {!ol.Transform} Transform.
-ol.renderer.canvas.Layer.prototype.getTransform = function(frameState, offsetX) {
- var viewState = frameState.viewState;
- var dx1 = pixelRatio * frameState.size[0] / 2;
- var dy1 = pixelRatio * frameState.size[1] / 2;
- var sx = pixelRatio / viewState.resolution;
- var sy = -sx;
- var angle = -viewState.rotation;
- var dx2 = -viewState.center[0] + offsetX;
- var dy2 = -viewState.center[1];
- return ol.transform.compose(this.transform_, dx1, dy1, sx, sy, angle, dx2, dy2);
- * @abstract
-ol.renderer.canvas.Layer.prototype.composeFrame = function(frameState, layerState, context) {};
- * @abstract
- * @return {boolean} whether composeFrame should be called.
-ol.renderer.canvas.Layer.prototype.prepareFrame = function(frameState, layerState) {};
-goog.provide('ol.renderer.vector');
-goog.require('ol.render.ReplayType');
- * @param {ol.Feature|ol.render.Feature} feature1 Feature 1.
- * @param {ol.Feature|ol.render.Feature} feature2 Feature 2.
- * @return {number} Order.
-ol.renderer.vector.defaultOrder = function(feature1, feature2) {
- return ol.getUid(feature1) - ol.getUid(feature2);
- * @return {number} Squared pixel tolerance.
-ol.renderer.vector.getSquaredTolerance = function(resolution, pixelRatio) {
- var tolerance = ol.renderer.vector.getTolerance(resolution, pixelRatio);
- return tolerance * tolerance;
- * @return {number} Pixel tolerance.
-ol.renderer.vector.getTolerance = function(resolution, pixelRatio) {
- return ol.SIMPLIFY_TOLERANCE * resolution / pixelRatio;
- * @param {ol.render.ReplayGroup} replayGroup Replay group.
- * @param {ol.geom.Circle} geometry Geometry.
- * @param {ol.style.Style} style Style.
- * @param {ol.Feature} feature Feature.
- * @private
-ol.renderer.vector.renderCircleGeometry_ = function(replayGroup, geometry, style, feature) {
- var fillStyle = style.getFill();
- var strokeStyle = style.getStroke();
- if (fillStyle || strokeStyle) {
- var circleReplay = replayGroup.getReplay(
- style.getZIndex(), ol.render.ReplayType.CIRCLE);
- circleReplay.setFillStrokeStyle(fillStyle, strokeStyle);
- circleReplay.drawCircle(geometry, feature);
- var textStyle = style.getText();
- if (textStyle) {
- var textReplay = replayGroup.getReplay(
- style.getZIndex(), ol.render.ReplayType.TEXT);
- textReplay.setTextStyle(textStyle);
- textReplay.drawText(geometry.getCenter(), 0, 2, 2, geometry, feature);
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- * @param {number} squaredTolerance Squared tolerance.
- * @param {function(this: T, ol.events.Event)} listener Listener function.
- * @param {T} thisArg Value to use as `this` when executing `listener`.
- * @return {boolean} `true` if style is loading.
- * @template T
-ol.renderer.vector.renderFeature = function(
- replayGroup, feature, style, squaredTolerance, listener, thisArg) {
- var loading = false;
- var imageStyle, imageState;
- imageStyle = style.getImage();
- if (imageStyle) {
- imageState = imageStyle.getImageState();
- if (imageState == ol.ImageState.LOADED ||
- imageState == ol.ImageState.ERROR) {
- imageStyle.unlistenImageChange(listener, thisArg);
- } else {
- imageStyle.load();
- imageStyle.listenImageChange(listener, thisArg);
- loading = true;
- ol.renderer.vector.renderFeature_(replayGroup, feature, style,
- squaredTolerance);
- return loading;
- * @private
-ol.renderer.vector.renderFeature_ = function(
- replayGroup, feature, style, squaredTolerance) {
- var geometry = style.getGeometryFunction()(feature);
- if (!geometry) {
- return;
- var simplifiedGeometry = geometry.getSimplifiedGeometry(squaredTolerance);
- var geometryRenderer =
- ol.renderer.vector.GEOMETRY_RENDERERS_[simplifiedGeometry.getType()];
- geometryRenderer(replayGroup, simplifiedGeometry, style, feature);
- * @param {ol.geom.GeometryCollection} geometry Geometry.
- * @private
-ol.renderer.vector.renderGeometryCollectionGeometry_ = function(replayGroup, geometry, style, feature) {
- var geometries = geometry.getGeometriesArray();
- var i, ii;
- for (i = 0, ii = geometries.length; i < ii; ++i) {
- ol.renderer.vector.GEOMETRY_RENDERERS_[geometries[i].getType()];
- geometryRenderer(replayGroup, geometries[i], style, feature);
- * @param {ol.geom.LineString|ol.render.Feature} geometry Geometry.
- * @private
-ol.renderer.vector.renderLineStringGeometry_ = function(replayGroup, geometry, style, feature) {
- var lineStringReplay = replayGroup.getReplay(
- style.getZIndex(), ol.render.ReplayType.LINE_STRING);
- lineStringReplay.setFillStrokeStyle(null, strokeStyle);
- lineStringReplay.drawLineString(geometry, feature);
- if (textStyle) {
- textReplay.drawText(geometry.getFlatMidpoint(), 0, 2, 2, geometry, feature);
- * @param {ol.geom.MultiLineString|ol.render.Feature} geometry Geometry.
- * @private
-ol.renderer.vector.renderMultiLineStringGeometry_ = function(replayGroup, geometry, style, feature) {
- lineStringReplay.drawMultiLineString(geometry, feature);
- if (textStyle) {
- var flatMidpointCoordinates = geometry.getFlatMidpoints();
- textReplay.drawText(flatMidpointCoordinates, 0,
- flatMidpointCoordinates.length, 2, geometry, feature);
- * @param {ol.geom.MultiPolygon} geometry Geometry.
- * @private
-ol.renderer.vector.renderMultiPolygonGeometry_ = function(replayGroup, geometry, style, feature) {
- if (strokeStyle || fillStyle) {
- var polygonReplay = replayGroup.getReplay(
- style.getZIndex(), ol.render.ReplayType.POLYGON);
- polygonReplay.setFillStrokeStyle(fillStyle, strokeStyle);
- polygonReplay.drawMultiPolygon(geometry, feature);
- if (textStyle) {
- var flatInteriorPointCoordinates = geometry.getFlatInteriorPoints();
- textReplay.drawText(flatInteriorPointCoordinates, 0,
- flatInteriorPointCoordinates.length, 2, geometry, feature);
- * @param {ol.geom.Point|ol.render.Feature} geometry Geometry.
- * @private
-ol.renderer.vector.renderPointGeometry_ = function(replayGroup, geometry, style, feature) {
- var imageStyle = style.getImage();
- if (imageStyle) {
- if (imageStyle.getImageState() != ol.ImageState.LOADED) {
- return;
- var imageReplay = replayGroup.getReplay(
- style.getZIndex(), ol.render.ReplayType.IMAGE);
- imageReplay.setImageStyle(imageStyle);
- imageReplay.drawPoint(geometry, feature);
- if (textStyle) {
- textReplay.drawText(geometry.getFlatCoordinates(), 0, 2, 2, geometry,
- feature);
- * @param {ol.geom.MultiPoint|ol.render.Feature} geometry Geometry.
- * @private
-ol.renderer.vector.renderMultiPointGeometry_ = function(replayGroup, geometry, style, feature) {
- if (imageStyle) {
- return;
- imageReplay.drawMultiPoint(geometry, feature);
- if (textStyle) {
- var flatCoordinates = geometry.getFlatCoordinates();
- textReplay.drawText(flatCoordinates, 0, flatCoordinates.length,
- geometry.getStride(), geometry, feature);
- * @param {ol.geom.Polygon|ol.render.Feature} geometry Geometry.
- * @private
-ol.renderer.vector.renderPolygonGeometry_ = function(replayGroup, geometry, style, feature) {
- polygonReplay.drawPolygon(geometry, feature);
- if (textStyle) {
- geometry.getFlatInteriorPoint(), 0, 2, 2, geometry, feature);
- * @const
- * @private
- * @type {Object.<ol.geom.GeometryType,
- * function(ol.render.ReplayGroup, ol.geom.Geometry,
- * ol.style.Style, Object)>}
-ol.renderer.vector.GEOMETRY_RENDERERS_ = {
- 'Point': ol.renderer.vector.renderPointGeometry_,
- 'LineString': ol.renderer.vector.renderLineStringGeometry_,
- 'Polygon': ol.renderer.vector.renderPolygonGeometry_,
- 'MultiPoint': ol.renderer.vector.renderMultiPointGeometry_,
- 'MultiLineString': ol.renderer.vector.renderMultiLineStringGeometry_,
- 'MultiPolygon': ol.renderer.vector.renderMultiPolygonGeometry_,
- 'GeometryCollection': ol.renderer.vector.renderGeometryCollectionGeometry_,
- 'Circle': ol.renderer.vector.renderCircleGeometry_
-goog.provide('ol.renderer.canvas.VectorLayer');
-goog.require('ol.ViewHint');
-goog.require('ol.render.canvas.ReplayGroup');
-goog.require('ol.renderer.canvas.Layer');
-goog.require('ol.renderer.vector');
- * @constructor
- * @extends {ol.renderer.canvas.Layer}
- * @param {ol.layer.Vector} vectorLayer Vector layer.
-ol.renderer.canvas.VectorLayer = function(vectorLayer) {
- ol.renderer.canvas.Layer.call(this, vectorLayer);
- * @private
- * @type {boolean}
- this.dirty_ = false;
- * @private
- * @type {number}
- this.renderedRevision_ = -1;
- * @private
- * @type {number}
- this.renderedResolution_ = NaN;
- * @private
- this.renderedExtent_ = ol.extent.createEmpty();
- * @private
- * @type {function(ol.Feature, ol.Feature): number|null}
- this.renderedRenderOrder_ = null;
- * @private
- * @type {ol.render.canvas.ReplayGroup}
- this.replayGroup_ = null;
- * @private
- this.context_ = ol.dom.createCanvasContext2D();
-ol.inherits(ol.renderer.canvas.VectorLayer, ol.renderer.canvas.Layer);
- * @inheritDoc
-ol.renderer.canvas.VectorLayer.prototype.composeFrame = function(frameState, layerState, context) {
- var extent = frameState.extent;
- var skippedFeatureUids = layerState.managed ?
- frameState.skippedFeatureUids : {};
- var projection = viewState.projection;
- var rotation = viewState.rotation;
- var projectionExtent = projection.getExtent();
- var vectorSource = /** @type {ol.source.Vector} */ (this.getLayer().getSource());
- var transform = this.getTransform(frameState, 0);
- this.preCompose(context, frameState, transform);
- // clipped rendering if layer extent is set
- var clipExtent = layerState.extent;
- var clipped = clipExtent !== undefined;
- if (clipped) {
- this.clip(context, frameState, /** @type {ol.Extent} */ (clipExtent));
- var replayGroup = this.replayGroup_;
- if (replayGroup && !replayGroup.isEmpty()) {
- var drawOffsetX = 0;
- var drawOffsetY = 0;
- var replayContext;
- if (layer.hasListener(ol.render.EventType.RENDER)) {
- var drawWidth = context.canvas.width;
- var drawHeight = context.canvas.height;
- if (rotation) {
- var drawSize = Math.round(Math.sqrt(drawWidth * drawWidth + drawHeight * drawHeight));
- drawOffsetX = (drawSize - drawWidth) / 2;
- drawOffsetY = (drawSize - drawHeight) / 2;
- drawWidth = drawHeight = drawSize;
- // resize and clear
- this.context_.canvas.width = drawWidth;
- this.context_.canvas.height = drawHeight;
- replayContext = this.context_;
- } else {
- replayContext = context;
- // for performance reasons, context.save / context.restore is not used
- // to save and restore the transformation matrix and the opacity.
- // see http://jsperf.com/context-save-restore-versus-variable
- var alpha = replayContext.globalAlpha;
- replayContext.globalAlpha = layerState.opacity;
- if (replayContext != context) {
- replayContext.translate(drawOffsetX, drawOffsetY);
- ol.render.canvas.rotateAtOffset(replayContext, -rotation,
- width / 2, height / 2);
- replayGroup.replay(replayContext, pixelRatio, transform, rotation,
- skippedFeatureUids);
- if (vectorSource.getWrapX() && projection.canWrapX() &&
- !ol.extent.containsExtent(projectionExtent, extent)) {
- var startX = extent[0];
- var worldWidth = ol.extent.getWidth(projectionExtent);
- var world = 0;
- var offsetX;
- while (startX < projectionExtent[0]) {
- --world;
- offsetX = worldWidth * world;
- transform = this.getTransform(frameState, offsetX);
- startX += worldWidth;
- world = 0;
- startX = extent[2];
- while (startX > projectionExtent[2]) {
- ++world;
- startX -= worldWidth;
- // restore original transform for render and compose events
- transform = this.getTransform(frameState, 0);
- ol.render.canvas.rotateAtOffset(replayContext, rotation,
- this.dispatchRenderEvent(replayContext, frameState, transform);
- context.drawImage(replayContext.canvas, -drawOffsetX, -drawOffsetY);
- replayContext.translate(-drawOffsetX, -drawOffsetY);
- replayContext.globalAlpha = alpha;
- if (clipped) {
- this.postCompose(context, frameState, layerState, transform);
- * @inheritDoc
-ol.renderer.canvas.VectorLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
- if (!this.replayGroup_) {
- return undefined;
- } else {
- var resolution = frameState.viewState.resolution;
- /** @type {Object.<string, boolean>} */
- var features = {};
- return this.replayGroup_.forEachFeatureAtCoordinate(coordinate, resolution,
- rotation, hitTolerance, {},
- var key = ol.getUid(feature).toString();
- if (!(key in features)) {
- features[key] = true;
- return callback.call(thisArg, feature, layer);
- * Handle changes in image style state.
- * @param {ol.events.Event} event Image style change event.
- * @private
-ol.renderer.canvas.VectorLayer.prototype.handleStyleImageChange_ = function(event) {
- * @inheritDoc
-ol.renderer.canvas.VectorLayer.prototype.prepareFrame = function(frameState, layerState) {
- var vectorLayer = /** @type {ol.layer.Vector} */ (this.getLayer());
- var vectorSource = vectorLayer.getSource();
- this.updateAttributions(
- frameState.attributions, vectorSource.getAttributions());
- this.updateLogos(frameState, vectorSource);
- var animating = frameState.viewHints[ol.ViewHint.ANIMATING];
- var interacting = frameState.viewHints[ol.ViewHint.INTERACTING];
- var updateWhileAnimating = vectorLayer.getUpdateWhileAnimating();
- var updateWhileInteracting = vectorLayer.getUpdateWhileInteracting();
- if (!this.dirty_ && (!updateWhileAnimating && animating) ||
- (!updateWhileInteracting && interacting)) {
- return true;
- var frameStateExtent = frameState.extent;
- var resolution = viewState.resolution;
- var vectorLayerRevision = vectorLayer.getRevision();
- var vectorLayerRenderBuffer = vectorLayer.getRenderBuffer();
- var vectorLayerRenderOrder = vectorLayer.getRenderOrder();
- if (vectorLayerRenderOrder === undefined) {
- vectorLayerRenderOrder = ol.renderer.vector.defaultOrder;
- var extent = ol.extent.buffer(frameStateExtent,
- vectorLayerRenderBuffer * resolution);
- var projectionExtent = viewState.projection.getExtent();
- if (vectorSource.getWrapX() && viewState.projection.canWrapX() &&
- !ol.extent.containsExtent(projectionExtent, frameState.extent)) {
- // For the replay group, we need an extent that intersects the real world
- // (-180° to +180°). To support geometries in a coordinate range from -540°
- // to +540°, we add at least 1 world width on each side of the projection
- // extent. If the viewport is wider than the world, we need to add half of
- // the viewport width to make sure we cover the whole viewport.
- var buffer = Math.max(ol.extent.getWidth(extent) / 2, worldWidth);
- extent[0] = projectionExtent[0] - buffer;
- extent[2] = projectionExtent[2] + buffer;
- this.renderedResolution_ == resolution &&
- this.renderedRevision_ == vectorLayerRevision &&
- this.renderedRenderOrder_ == vectorLayerRenderOrder &&
- ol.extent.containsExtent(this.renderedExtent_, extent)) {
- return true;
- var replayGroup =
- new ol.render.canvas.ReplayGroup(
- ol.renderer.vector.getTolerance(resolution, pixelRatio), extent,
- resolution, vectorSource.getOverlaps(), vectorLayer.getRenderBuffer());
- vectorSource.loadFeatures(extent, resolution, projection);
- * @this {ol.renderer.canvas.VectorLayer}
- var renderFeature = function(feature) {
- var styles;
- var styleFunction = feature.getStyleFunction();
- if (styleFunction) {
- styles = styleFunction.call(feature, resolution);
- } else {
- styleFunction = vectorLayer.getStyleFunction();
- styles = styleFunction(feature, resolution);
- if (styles) {
- var dirty = this.renderFeature(
- feature, resolution, pixelRatio, styles, replayGroup);
- this.dirty_ = this.dirty_ || dirty;
- if (vectorLayerRenderOrder) {
- /** @type {Array.<ol.Feature>} */
- var features = [];
- vectorSource.forEachFeatureInExtent(extent,
- features.push(feature);
- }, this);
- features.sort(vectorLayerRenderOrder);
- features.forEach(renderFeature, this);
- } else {
- vectorSource.forEachFeatureInExtent(extent, renderFeature, this);
- replayGroup.finish();
- this.renderedResolution_ = resolution;
- this.renderedRevision_ = vectorLayerRevision;
- this.renderedRenderOrder_ = vectorLayerRenderOrder;
- this.renderedExtent_ = extent;
- this.replayGroup_ = replayGroup;
- return true;
- * @param {(ol.style.Style|Array.<ol.style.Style>)} styles The style or array of
- * styles.
- * @param {ol.render.canvas.ReplayGroup} replayGroup Replay group.
- * @return {boolean} `true` if an image is loading.
-ol.renderer.canvas.VectorLayer.prototype.renderFeature = function(feature, resolution, pixelRatio, styles, replayGroup) {
- if (!styles) {
- return false;
- if (Array.isArray(styles)) {
- for (var i = 0, ii = styles.length; i < ii; ++i) {
- loading = ol.renderer.vector.renderFeature(
- replayGroup, feature, styles[i],
- ol.renderer.vector.getSquaredTolerance(resolution, pixelRatio),
- this.handleStyleImageChange_, this) || loading;
- } else {
- replayGroup, feature, styles,
- return loading;
-// This file is automatically generated, do not edit
-goog.provide('ol.renderer.webgl.defaultmapshader');
-goog.require('ol.webgl.Fragment');
-goog.require('ol.webgl.Vertex');
-if (ol.ENABLE_WEBGL) {
- * @constructor
- * @extends {ol.webgl.Fragment}
- * @struct
- ol.renderer.webgl.defaultmapshader.Fragment = function() {
- ol.webgl.Fragment.call(this, ol.renderer.webgl.defaultmapshader.Fragment.SOURCE);
- ol.inherits(ol.renderer.webgl.defaultmapshader.Fragment, ol.webgl.Fragment);
- * @const
- * @type {string}
- ol.renderer.webgl.defaultmapshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_texCoord;\n\n\nuniform float u_opacity;\nuniform sampler2D u_texture;\n\nvoid main(void) {\n vec4 texColor = texture2D(u_texture, v_texCoord);\n gl_FragColor.rgb = texColor.rgb;\n gl_FragColor.a = texColor.a * u_opacity;\n}\n';
- * @const
- * @type {string}
- ol.renderer.webgl.defaultmapshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;uniform float f;uniform sampler2D g;void main(void){vec4 texColor=texture2D(g,a);gl_FragColor.rgb=texColor.rgb;gl_FragColor.a=texColor.a*f;}';
- * @const
- * @type {string}
- ol.renderer.webgl.defaultmapshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
- ol.renderer.webgl.defaultmapshader.Fragment.DEBUG_SOURCE :
- ol.renderer.webgl.defaultmapshader.Fragment.OPTIMIZED_SOURCE;
- ol.renderer.webgl.defaultmapshader.fragment = new ol.renderer.webgl.defaultmapshader.Fragment();
- * @constructor
- * @extends {ol.webgl.Vertex}
- * @struct
- ol.renderer.webgl.defaultmapshader.Vertex = function() {
- ol.webgl.Vertex.call(this, ol.renderer.webgl.defaultmapshader.Vertex.SOURCE);
- ol.inherits(ol.renderer.webgl.defaultmapshader.Vertex, ol.webgl.Vertex);
- * @const
- * @type {string}
- ol.renderer.webgl.defaultmapshader.Vertex.DEBUG_SOURCE = 'varying vec2 v_texCoord;\n\n\nattribute vec2 a_position;\nattribute vec2 a_texCoord;\n\nuniform mat4 u_texCoordMatrix;\nuniform mat4 u_projectionMatrix;\n\nvoid main(void) {\n gl_Position = u_projectionMatrix * vec4(a_position, 0., 1.);\n v_texCoord = (u_texCoordMatrix * vec4(a_texCoord, 0., 1.)).st;\n}\n\n\n';
- * @const
- * @type {string}
- ol.renderer.webgl.defaultmapshader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;attribute vec2 b;attribute vec2 c;uniform mat4 d;uniform mat4 e;void main(void){gl_Position=e*vec4(b,0.,1.);a=(d*vec4(c,0.,1.)).st;}';
- * @const
- * @type {string}
- ol.renderer.webgl.defaultmapshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
- ol.renderer.webgl.defaultmapshader.Vertex.DEBUG_SOURCE :
- ol.renderer.webgl.defaultmapshader.Vertex.OPTIMIZED_SOURCE;
- ol.renderer.webgl.defaultmapshader.vertex = new ol.renderer.webgl.defaultmapshader.Vertex();
- * @constructor
- * @param {WebGLRenderingContext} gl GL.
- * @param {WebGLProgram} program Program.
- * @struct
- ol.renderer.webgl.defaultmapshader.Locations = function(gl, program) {
- * @type {WebGLUniformLocation}
- this.u_opacity = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_opacity' : 'f');
- this.u_projectionMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_projectionMatrix' : 'e');
- this.u_texCoordMatrix = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_texCoordMatrix' : 'd');
- this.u_texture = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_texture' : 'g');
- * @type {number}
- this.a_position = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_position' : 'b');
- * @type {number}
- this.a_texCoord = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_texCoord' : 'c');
-goog.provide('ol.renderer.webgl.Layer');
-goog.require('ol.render.webgl.Immediate');
-goog.require('ol.renderer.webgl.defaultmapshader');
-goog.require('ol.transform');
-goog.require('ol.vec.Mat4');
-goog.require('ol.webgl');
-goog.require('ol.webgl.Buffer');
-goog.require('ol.webgl.Context');
- * @constructor
- * @abstract
- * @param {ol.renderer.webgl.Map} mapRenderer Map renderer.
- ol.renderer.webgl.Layer = function(mapRenderer, layer) {
- * @protected
- * @type {ol.renderer.webgl.Map}
- this.mapRenderer = mapRenderer;
- * @private
- * @type {ol.webgl.Buffer}
- this.arrayBuffer_ = new ol.webgl.Buffer([
- -1, -1, 0, 0,
- 1, -1, 1, 0,
- -1, 1, 0, 1,
- 1, 1, 1, 1
- * @protected
- * @type {WebGLTexture}
- this.texture = null;
- * @protected
- * @type {WebGLFramebuffer}
- this.framebuffer = null;
- * @protected
- * @type {number|undefined}
- this.framebufferDimension = undefined;
- * @protected
- this.texCoordMatrix = ol.transform.create();
- * @protected
- this.projectionMatrix = ol.transform.create();
- * @type {Array.<number>}
- * @private
- this.tmpMat4_ = ol.vec.Mat4.create();
- * @private
- * @type {ol.renderer.webgl.defaultmapshader.Locations}
- this.defaultLocations_ = null;
- ol.inherits(ol.renderer.webgl.Layer, ol.renderer.Layer);
- * @param {number} framebufferDimension Framebuffer dimension.
- * @protected
- ol.renderer.webgl.Layer.prototype.bindFramebuffer = function(frameState, framebufferDimension) {
- var gl = this.mapRenderer.getGL();
- if (this.framebufferDimension === undefined ||
- this.framebufferDimension != framebufferDimension) {
- * @param {WebGLFramebuffer} framebuffer Framebuffer.
- * @param {WebGLTexture} texture Texture.
- var postRenderFunction = function(gl, framebuffer, texture) {
- if (!gl.isContextLost()) {
- gl.deleteFramebuffer(framebuffer);
- gl.deleteTexture(texture);
- }.bind(null, gl, this.framebuffer, this.texture);
- var texture = ol.webgl.Context.createEmptyTexture(
- gl, framebufferDimension, framebufferDimension);
- var framebuffer = gl.createFramebuffer();
- gl.bindFramebuffer(ol.webgl.FRAMEBUFFER, framebuffer);
- gl.framebufferTexture2D(ol.webgl.FRAMEBUFFER,
- ol.webgl.COLOR_ATTACHMENT0, ol.webgl.TEXTURE_2D, texture, 0);
- this.texture = texture;
- this.framebuffer = framebuffer;
- this.framebufferDimension = framebufferDimension;
- } else {
- gl.bindFramebuffer(ol.webgl.FRAMEBUFFER, this.framebuffer);
- * @param {ol.webgl.Context} context Context.
- ol.renderer.webgl.Layer.prototype.composeFrame = function(frameState, layerState, context) {
- ol.render.EventType.PRECOMPOSE, context, frameState);
- context.bindBuffer(ol.webgl.ARRAY_BUFFER, this.arrayBuffer_);
- var gl = context.getGL();
- var fragmentShader = ol.renderer.webgl.defaultmapshader.fragment;
- var vertexShader = ol.renderer.webgl.defaultmapshader.vertex;
- var program = context.getProgram(fragmentShader, vertexShader);
- var locations;
- if (!this.defaultLocations_) {
- locations =
- new ol.renderer.webgl.defaultmapshader.Locations(gl, program);
- this.defaultLocations_ = locations;
- } else {
- locations = this.defaultLocations_;
- if (context.useProgram(program)) {
- gl.enableVertexAttribArray(locations.a_position);
- gl.vertexAttribPointer(
- locations.a_position, 2, ol.webgl.FLOAT, false, 16, 0);
- gl.enableVertexAttribArray(locations.a_texCoord);
- locations.a_texCoord, 2, ol.webgl.FLOAT, false, 16, 8);
- gl.uniform1i(locations.u_texture, 0);
- gl.uniformMatrix4fv(locations.u_texCoordMatrix, false,
- ol.vec.Mat4.fromTransform(this.tmpMat4_, this.getTexCoordMatrix()));
- gl.uniformMatrix4fv(locations.u_projectionMatrix, false,
- ol.vec.Mat4.fromTransform(this.tmpMat4_, this.getProjectionMatrix()));
- gl.uniform1f(locations.u_opacity, layerState.opacity);
- gl.bindTexture(ol.webgl.TEXTURE_2D, this.getTexture());
- gl.drawArrays(ol.webgl.TRIANGLE_STRIP, 0, 4);
- ol.render.EventType.POSTCOMPOSE, context, frameState);
- * @param {ol.webgl.Context} context WebGL context.
- * @private
- ol.renderer.webgl.Layer.prototype.dispatchComposeEvent_ = function(type, context, frameState) {
- var center = viewState.center;
- var size = frameState.size;
- var render = new ol.render.webgl.Immediate(
- context, center, resolution, rotation, size, extent, pixelRatio);
- type, render, frameState, null, context);
- * @return {!ol.Transform} Matrix.
- ol.renderer.webgl.Layer.prototype.getTexCoordMatrix = function() {
- return this.texCoordMatrix;
- * @return {WebGLTexture} Texture.
- ol.renderer.webgl.Layer.prototype.getTexture = function() {
- return this.texture;
- ol.renderer.webgl.Layer.prototype.getProjectionMatrix = function() {
- return this.projectionMatrix;
- * Handle webglcontextlost.
- ol.renderer.webgl.Layer.prototype.handleWebGLContextLost = function() {
- * @abstract
- ol.renderer.webgl.Layer.prototype.prepareFrame = function(frameState, layerState, context) {};
- * @abstract
- * @param {ol.Pixel} pixel Pixel.
- * callback.
- * @return {T|undefined} Callback result.
- * @template S,T,U
- ol.renderer.webgl.Layer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {};
-goog.provide('ol.renderer.webgl.VectorLayer');
-goog.require('ol.extent');
-goog.require('ol.render.webgl.ReplayGroup');
-goog.require('ol.renderer.webgl.Layer');
- * @constructor
- * @extends {ol.renderer.webgl.Layer}
- ol.renderer.webgl.VectorLayer = function(mapRenderer, vectorLayer) {
- ol.renderer.webgl.Layer.call(this, mapRenderer, vectorLayer);
- * @private
- * @type {boolean}
- * @private
- * @type {number}
- * @private
- * @type {number}
- * @private
- * @private
- * @private
- * @type {ol.render.webgl.ReplayGroup}
- * The last layer state.
- * @private
- * @type {?ol.LayerState}
- this.layerState_ = null;
- ol.inherits(ol.renderer.webgl.VectorLayer, ol.renderer.webgl.Layer);
- * @inheritDoc
- ol.renderer.webgl.VectorLayer.prototype.composeFrame = function(frameState, layerState, context) {
- this.layerState_ = layerState;
- gl.enable(gl.SCISSOR_TEST);
- gl.scissor(0, 0, size[0] * pixelRatio, size[1] * pixelRatio);
- replayGroup.replay(context,
- viewState.center, viewState.resolution, viewState.rotation,
- size, pixelRatio, layerState.opacity,
- layerState.managed ? frameState.skippedFeatureUids : {});
- gl.disable(gl.SCISSOR_TEST);
- * @inheritDoc
- ol.renderer.webgl.VectorLayer.prototype.disposeInternal = function() {
- if (replayGroup) {
- var context = this.mapRenderer.getContext();
- replayGroup.getDeleteResourcesFunction(context)();
- ol.renderer.webgl.Layer.prototype.disposeInternal.call(this);
- * @inheritDoc
- ol.renderer.webgl.VectorLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
- if (!this.replayGroup_ || !this.layerState_) {
- return undefined;
- } else {
- var layerState = this.layerState_;
- context, viewState.center, viewState.resolution, viewState.rotation,
- frameState.size, frameState.pixelRatio, layerState.opacity,
- * @inheritDoc
- ol.renderer.webgl.VectorLayer.prototype.hasFeatureAtCoordinate = function(coordinate, frameState) {
- return false;
- } else {
- return this.replayGroup_.hasFeatureAtCoordinate(coordinate,
- frameState.skippedFeatureUids);
- * @inheritDoc
- ol.renderer.webgl.VectorLayer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {
- var coordinate = ol.transform.apply(
- frameState.pixelToCoordinateTransform, pixel.slice());
- var hasFeature = this.hasFeatureAtCoordinate(coordinate, frameState);
- if (hasFeature) {
- } else {
- return undefined;
- * @private
- ol.renderer.webgl.VectorLayer.prototype.handleStyleImageChange_ = function(event) {
- * @inheritDoc
- ol.renderer.webgl.VectorLayer.prototype.prepareFrame = function(frameState, layerState, context) {
- return true;
- return true;
- if (this.replayGroup_) {
- this.replayGroup_.getDeleteResourcesFunction(context));
- var replayGroup = new ol.render.webgl.ReplayGroup(
- extent, vectorLayer.getRenderBuffer());
- * @this {ol.renderer.webgl.VectorLayer}
- var styles;
- } else {
- if (styles) {
- }, this);
- } else {
- replayGroup.finish(context);
- return true;
- * styles.
- * @param {ol.render.webgl.ReplayGroup} replayGroup Replay group.
- ol.renderer.webgl.VectorLayer.prototype.renderFeature = function(feature, resolution, pixelRatio, styles, replayGroup) {
- if (!styles) {
- return false;
- for (var i = styles.length - 1, ii = 0; i >= ii; --i) {
- } else {
- return loading;
-goog.provide('ol.layer.Vector');
-goog.require('ol.layer.Layer');
-goog.require('ol.obj');
-goog.require('ol.renderer.Type');
-goog.require('ol.renderer.canvas.VectorLayer');
-goog.require('ol.renderer.webgl.VectorLayer');
-goog.require('ol.style.Style');
- * @classdesc
- * Vector data that is rendered client-side.
- * Note that any property set in the options is set as a {@link ol.Object}
- * property on the layer object; for example, setting `title: 'My Title'` in the
- * options means that `title` is observable, and has get/set accessors.
- * @constructor
- * @extends {ol.layer.Layer}
- * @fires ol.render.Event
- * @param {olx.layer.VectorOptions=} opt_options Options.
- * @api
-ol.layer.Vector = function(opt_options) {
- var options = opt_options ?
- opt_options : /** @type {olx.layer.VectorOptions} */ ({});
- var baseOptions = ol.obj.assign({}, options);
- delete baseOptions.style;
- delete baseOptions.renderBuffer;
- delete baseOptions.updateWhileAnimating;
- delete baseOptions.updateWhileInteracting;
- ol.layer.Layer.call(this, /** @type {olx.layer.LayerOptions} */ (baseOptions));
- * @type {number}
- * @private
- this.renderBuffer_ = options.renderBuffer !== undefined ?
- options.renderBuffer : 100;
- * User provided style.
- * @type {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
- * @private
- this.style_ = null;
- * Style function for use within the library.
- * @type {ol.StyleFunction|undefined}
- * @private
- this.styleFunction_ = undefined;
- this.setStyle(options.style);
- * @type {boolean}
- * @private
- this.updateWhileAnimating_ = options.updateWhileAnimating !== undefined ?
- options.updateWhileAnimating : false;
- * @type {boolean}
- * @private
- this.updateWhileInteracting_ = options.updateWhileInteracting !== undefined ?
- options.updateWhileInteracting : false;
-ol.inherits(ol.layer.Vector, ol.layer.Layer);
- * @inheritDoc
-ol.layer.Vector.prototype.createRenderer = function(mapRenderer) {
- var renderer = null;
- var type = mapRenderer.getType();
- if (ol.ENABLE_CANVAS && type === ol.renderer.Type.CANVAS) {
- renderer = new ol.renderer.canvas.VectorLayer(this);
- } else if (ol.ENABLE_WEBGL && type === ol.renderer.Type.WEBGL) {
- renderer = new ol.renderer.webgl.VectorLayer(/** @type {ol.renderer.webgl.Map} */ (mapRenderer), this);
- return renderer;
- * @return {number|undefined} Render buffer.
-ol.layer.Vector.prototype.getRenderBuffer = function() {
- return this.renderBuffer_;
- * @return {function(ol.Feature, ol.Feature): number|null|undefined} Render
- * order.
-ol.layer.Vector.prototype.getRenderOrder = function() {
- return /** @type {ol.RenderOrderFunction|null|undefined} */ (
- this.get(ol.layer.Vector.Property_.RENDER_ORDER));
- * Return the associated {@link ol.source.Vector vectorsource} of the layer.
- * @function
- * @return {ol.source.Vector} Source.
- * @api
-ol.layer.Vector.prototype.getSource;
- * Get the style for features. This returns whatever was passed to the `style`
- * option at construction or to the `setStyle` method.
- * @return {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
- * Layer style.
- * @api
-ol.layer.Vector.prototype.getStyle = function() {
- return this.style_;
- * Get the style function.
- * @return {ol.StyleFunction|undefined} Layer style function.
- * @api
-ol.layer.Vector.prototype.getStyleFunction = function() {
- return this.styleFunction_;
- * @return {boolean} Whether the rendered layer should be updated while
- * animating.
-ol.layer.Vector.prototype.getUpdateWhileAnimating = function() {
- return this.updateWhileAnimating_;
- * interacting.
-ol.layer.Vector.prototype.getUpdateWhileInteracting = function() {
- return this.updateWhileInteracting_;
- * @param {ol.RenderOrderFunction|null|undefined} renderOrder
- * Render order.
-ol.layer.Vector.prototype.setRenderOrder = function(renderOrder) {
- this.set(ol.layer.Vector.Property_.RENDER_ORDER, renderOrder);
- * Set the style for features. This can be a single style object, an array
- * of styles, or a function that takes a feature and resolution and returns
- * an array of styles. If it is `undefined` the default style is used. If
- * it is `null` the layer has no style (a `null` style), so only features
- * that have their own styles will be rendered in the layer. See
- * {@link ol.style} for information on the default style.
- * @param {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction|null|undefined}
- * style Layer style.
- * @api
-ol.layer.Vector.prototype.setStyle = function(style) {
- this.style_ = style !== undefined ? style : ol.style.Style.defaultFunction;
- this.styleFunction_ = style === null ?
- undefined : ol.style.Style.createFunction(this.style_);
- this.changed();
- * @enum {string}
- * @private
-ol.layer.Vector.Property_ = {
- RENDER_ORDER: 'renderOrder'
-goog.provide('ol.loadingstrategy');
- * Strategy function for loading all features with a single request.
- * @return {Array.<ol.Extent>} Extents.
- * @api
-ol.loadingstrategy.all = function(extent, resolution) {
- return [[-Infinity, -Infinity, Infinity, Infinity]];
- * Strategy function for loading features based on the view's extent and
- * resolution.
- * @api
-ol.loadingstrategy.bbox = function(extent, resolution) {
- return [extent];
- * Creates a strategy function for loading features based on a tile grid.
- * @return {function(ol.Extent, number): Array.<ol.Extent>} Loading strategy.
- * @api
-ol.loadingstrategy.tile = function(tileGrid) {
- return (
- function(extent, resolution) {
- var z = tileGrid.getZForResolution(resolution);
- var tileRange = tileGrid.getTileRangeForExtentAndZ(extent, z);
- /** @type {Array.<ol.Extent>} */
- var extents = [];
- /** @type {ol.TileCoord} */
- var tileCoord = [z, 0, 0];
- for (tileCoord[1] = tileRange.minX; tileCoord[1] <= tileRange.maxX;
- ++tileCoord[1]) {
- for (tileCoord[2] = tileRange.minY; tileCoord[2] <= tileRange.maxY;
- ++tileCoord[2]) {
- extents.push(tileGrid.getTileCoordExtent(tileCoord));
- return extents;
-goog.provide('ol.source.Source');
-goog.require('ol.Attribution');
-goog.require('ol.Object');
-goog.require('ol.proj');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * Base class for {@link ol.layer.Layer} sources.
- * A generic `change` event is triggered when the state of the source changes.
- * @constructor
- * @abstract
- * @extends {ol.Object}
- * @param {ol.SourceSourceOptions} options Source options.
- * @api
-ol.source.Source = function(options) {
- ol.Object.call(this);
- * @private
- * @type {ol.proj.Projection}
- this.projection_ = ol.proj.get(options.projection);
- * @private
- * @type {Array.<ol.Attribution>}
- this.attributions_ = ol.source.Source.toAttributionsArray_(options.attributions);
- * @private
- * @type {string|olx.LogoOptions|undefined}
- this.logo_ = options.logo;
- * @private
- * @type {ol.source.State}
- this.state_ = options.state !== undefined ?
- options.state : ol.source.State.READY;
- * @private
- * @type {boolean}
- this.wrapX_ = options.wrapX !== undefined ? options.wrapX : false;
-ol.inherits(ol.source.Source, ol.Object);
- * Turns various ways of defining an attribution to an array of `ol.Attributions`.
- * @param {ol.AttributionLike|undefined}
- * attributionLike The attributions as string, array of strings,
- * `ol.Attribution`, array of `ol.Attribution` or undefined.
- * @return {Array.<ol.Attribution>} The array of `ol.Attribution` or null if
- * `undefined` was given.
-ol.source.Source.toAttributionsArray_ = function(attributionLike) {
- if (typeof attributionLike === 'string') {
- return [new ol.Attribution({html: attributionLike})];
- } else if (attributionLike instanceof ol.Attribution) {
- return [attributionLike];
- } else if (Array.isArray(attributionLike)) {
- var len = attributionLike.length;
- var attributions = new Array(len);
- for (var i = 0; i < len; i++) {
- var item = attributionLike[i];
- if (typeof item === 'string') {
- attributions[i] = new ol.Attribution({html: item});
- } else {
- attributions[i] = item;
- return attributions;
- } else {
- return null;
- * @param {number} rotation Rotation.
- * @param {Object.<string, boolean>} skippedFeatureUids Skipped feature uids.
- * callback.
- * @template T
-ol.source.Source.prototype.forEachFeatureAtCoordinate = ol.nullFunction;
- * Get the attributions of the source.
- * @return {Array.<ol.Attribution>} Attributions.
- * @api
-ol.source.Source.prototype.getAttributions = function() {
- return this.attributions_;
- * Get the logo of the source.
- * @return {string|olx.LogoOptions|undefined} Logo.
- * @api
-ol.source.Source.prototype.getLogo = function() {
- return this.logo_;
- * Get the projection of the source.
- * @return {ol.proj.Projection} Projection.
- * @api
-ol.source.Source.prototype.getProjection = function() {
- return this.projection_;
- * @abstract
- * @return {Array.<number>|undefined} Resolutions.
-ol.source.Source.prototype.getResolutions = function() {};
- * Get the state of the source, see {@link ol.source.State} for possible states.
- * @return {ol.source.State} State.
- * @api
-ol.source.Source.prototype.getState = function() {
- return this.state_;
- * @return {boolean|undefined} Wrap X.
-ol.source.Source.prototype.getWrapX = function() {
- return this.wrapX_;
- * Refreshes the source and finally dispatches a 'change' event.
- * @api
-ol.source.Source.prototype.refresh = function() {
- this.changed();
- * Set the attributions of the source.
- * @param {ol.AttributionLike|undefined} attributions Attributions.
- * Can be passed as `string`, `Array<string>`, `{@link ol.Attribution}`,
- * `Array<{@link ol.Attribution}>` or `undefined`.
- * @api
-ol.source.Source.prototype.setAttributions = function(attributions) {
- this.attributions_ = ol.source.Source.toAttributionsArray_(attributions);
- this.changed();
- * Set the logo of the source.
- * @param {string|olx.LogoOptions|undefined} logo Logo.
-ol.source.Source.prototype.setLogo = function(logo) {
- this.logo_ = logo;
- * Set the state of the source.
- * @param {ol.source.State} state State.
- * @protected
-ol.source.Source.prototype.setState = function(state) {
- this.state_ = state;
- this.changed();
-goog.provide('ol.source.VectorEventType');
- * @enum {string}
-ol.source.VectorEventType = {
- * Triggered when a feature is added to the source.
- * @event ol.source.Vector.Event#addfeature
- * @api
- ADDFEATURE: 'addfeature',
- * Triggered when a feature is updated.
- * @event ol.source.Vector.Event#changefeature
- * @api
- CHANGEFEATURE: 'changefeature',
- * Triggered when the clear method is called on the source.
- * @event ol.source.Vector.Event#clear
- * @api
- CLEAR: 'clear',
- * Triggered when a feature is removed from the source.
- * See {@link ol.source.Vector#clear source.clear()} for exceptions.
- * @event ol.source.Vector.Event#removefeature
- * @api
- REMOVEFEATURE: 'removefeature'
-// FIXME bulk feature upload - suppress events
-// FIXME make change-detection more refined (notably, geometry hint)
-goog.provide('ol.source.Vector');
-goog.require('ol.Collection');
-goog.require('ol.CollectionEventType');
-goog.require('ol.ObjectEventType');
-goog.require('ol.array');
-goog.require('ol.events.Event');
-goog.require('ol.featureloader');
-goog.require('ol.loadingstrategy');
-goog.require('ol.source.Source');
-goog.require('ol.source.VectorEventType');
-goog.require('ol.structs.RBush');
- * @classdesc
- * Provides a source of features for vector layers. Vector features provided
- * by this source are suitable for editing. See {@link ol.source.VectorTile} for
- * vector data that is optimized for rendering.
- * @constructor
- * @extends {ol.source.Source}
- * @fires ol.source.Vector.Event
- * @param {olx.source.VectorOptions=} opt_options Vector source options.
- * @api
-ol.source.Vector = function(opt_options) {
- var options = opt_options || {};
- ol.source.Source.call(this, {
- attributions: options.attributions,
- logo: options.logo,
- projection: undefined,
- state: ol.source.State.READY,
- wrapX: options.wrapX !== undefined ? options.wrapX : true
- * @private
- * @type {ol.FeatureLoader}
- this.loader_ = ol.nullFunction;
- * @private
- * @type {ol.format.Feature|undefined}
- this.format_ = options.format;
- * @private
- * @type {boolean}
- this.overlaps_ = options.overlaps == undefined ? true : options.overlaps;
- * @private
- * @type {string|ol.FeatureUrlFunction|undefined}
- this.url_ = options.url;
- if (options.loader !== undefined) {
- this.loader_ = options.loader;
- } else if (this.url_ !== undefined) {
- ol.asserts.assert(this.format_, 7); // `format` must be set when `url` is set
- // create a XHR feature loader for "url" and "format"
- this.loader_ = ol.featureloader.xhr(this.url_, /** @type {ol.format.Feature} */ (this.format_));
- * @private
- * @type {ol.LoadingStrategy}
- this.strategy_ = options.strategy !== undefined ? options.strategy :
- ol.loadingstrategy.all;
- var useSpatialIndex =
- options.useSpatialIndex !== undefined ? options.useSpatialIndex : true;
- * @private
- * @type {ol.structs.RBush.<ol.Feature>}
- this.featuresRtree_ = useSpatialIndex ? new ol.structs.RBush() : null;
- * @private
- * @type {ol.structs.RBush.<{extent: ol.Extent}>}
- this.loadedExtentsRtree_ = new ol.structs.RBush();
- * @private
- * @type {Object.<string, ol.Feature>}
- this.nullGeometryFeatures_ = {};
- * A lookup of features by id (the return from feature.getId()).
- * @private
- this.idIndex_ = {};
- * A lookup of features without id (keyed by ol.getUid(feature)).
- * @private
- this.undefIdIndex_ = {};
- * @private
- * @type {Object.<string, Array.<ol.EventsKey>>}
- this.featureChangeKeys_ = {};
- * @private
- * @type {ol.Collection.<ol.Feature>}
- this.featuresCollection_ = null;
- var collection, features;
- if (options.features instanceof ol.Collection) {
- collection = options.features;
- features = collection.getArray();
- } else if (Array.isArray(options.features)) {
- features = options.features;
- if (!useSpatialIndex && collection === undefined) {
- collection = new ol.Collection(features);
- if (features !== undefined) {
- this.addFeaturesInternal(features);
- if (collection !== undefined) {
- this.bindFeaturesCollection_(collection);
-ol.inherits(ol.source.Vector, ol.source.Source);
- * Add a single feature to the source. If you want to add a batch of features
- * at once, call {@link ol.source.Vector#addFeatures source.addFeatures()}
- * instead.
- * @param {ol.Feature} feature Feature to add.
- * @api
-ol.source.Vector.prototype.addFeature = function(feature) {
- this.addFeatureInternal(feature);
- this.changed();
- * Add a feature without firing a `change` event.
- * @protected
-ol.source.Vector.prototype.addFeatureInternal = function(feature) {
- var featureKey = ol.getUid(feature).toString();
- if (!this.addToIndex_(featureKey, feature)) {
- return;
- this.setupChangeEvents_(featureKey, feature);
- var geometry = feature.getGeometry();
- if (geometry) {
- var extent = geometry.getExtent();
- if (this.featuresRtree_) {
- this.featuresRtree_.insert(extent, feature);
- } else {
- this.nullGeometryFeatures_[featureKey] = feature;
- this.dispatchEvent(
- new ol.source.Vector.Event(ol.source.VectorEventType.ADDFEATURE, feature));
- * @param {string} featureKey Unique identifier for the feature.
- * @param {ol.Feature} feature The feature.
- * @private
-ol.source.Vector.prototype.setupChangeEvents_ = function(featureKey, feature) {
- this.featureChangeKeys_[featureKey] = [
- ol.events.listen(feature, ol.events.EventType.CHANGE,
- this.handleFeatureChange_, this),
- ol.events.listen(feature, ol.ObjectEventType.PROPERTYCHANGE,
- * @return {boolean} The feature is "valid", in the sense that it is also a
- * candidate for insertion into the Rtree.
- * @private
-ol.source.Vector.prototype.addToIndex_ = function(featureKey, feature) {
- var valid = true;
- var id = feature.getId();
- if (id !== undefined) {
- if (!(id.toString() in this.idIndex_)) {
- this.idIndex_[id.toString()] = feature;
- } else {
- valid = false;
- } else {
- ol.asserts.assert(!(featureKey in this.undefIdIndex_),
- 30); // The passed `feature` was already added to the source
- this.undefIdIndex_[featureKey] = feature;
- return valid;
- * Add a batch of features to the source.
- * @param {Array.<ol.Feature>} features Features to add.
- * @api
-ol.source.Vector.prototype.addFeatures = function(features) {
- this.changed();
- * Add features without firing a `change` event.
- * @param {Array.<ol.Feature>} features Features.
- * @protected
-ol.source.Vector.prototype.addFeaturesInternal = function(features) {
- var featureKey, i, length, feature;
- var extents = [];
- var newFeatures = [];
- var geometryFeatures = [];
- for (i = 0, length = features.length; i < length; i++) {
- feature = features[i];
- featureKey = ol.getUid(feature).toString();
- if (this.addToIndex_(featureKey, feature)) {
- newFeatures.push(feature);
- for (i = 0, length = newFeatures.length; i < length; i++) {
- feature = newFeatures[i];
- if (geometry) {
- extents.push(extent);
- geometryFeatures.push(feature);
- } else {
- this.featuresRtree_.load(extents, geometryFeatures);
- this.dispatchEvent(new ol.source.Vector.Event(
- ol.source.VectorEventType.ADDFEATURE, newFeatures[i]));
- * @param {!ol.Collection.<ol.Feature>} collection Collection.
- * @private
-ol.source.Vector.prototype.bindFeaturesCollection_ = function(collection) {
- var modifyingCollection = false;
- ol.events.listen(this, ol.source.VectorEventType.ADDFEATURE,
- function(evt) {
- if (!modifyingCollection) {
- modifyingCollection = true;
- collection.push(evt.feature);
- modifyingCollection = false;
- ol.events.listen(this, ol.source.VectorEventType.REMOVEFEATURE,
- function(evt) {
- collection.remove(evt.feature);
- ol.events.listen(collection, ol.CollectionEventType.ADD,
- function(evt) {
- this.addFeature(/** @type {ol.Feature} */ (evt.element));
- }, this);
- ol.events.listen(collection, ol.CollectionEventType.REMOVE,
- function(evt) {
- this.removeFeature(/** @type {ol.Feature} */ (evt.element));
- }, this);
- this.featuresCollection_ = collection;
- * Remove all features from the source.
- * @param {boolean=} opt_fast Skip dispatching of {@link removefeature} events.
- * @api
-ol.source.Vector.prototype.clear = function(opt_fast) {
- if (opt_fast) {
- for (var featureId in this.featureChangeKeys_) {
- var keys = this.featureChangeKeys_[featureId];
- keys.forEach(ol.events.unlistenByKey);
- if (!this.featuresCollection_) {
- } else {
- this.featuresRtree_.forEach(this.removeFeatureInternal, this);
- for (var id in this.nullGeometryFeatures_) {
- this.removeFeatureInternal(this.nullGeometryFeatures_[id]);
- if (this.featuresCollection_) {
- this.featuresCollection_.clear();
- this.featuresRtree_.clear();
- this.loadedExtentsRtree_.clear();
- var clearEvent = new ol.source.Vector.Event(ol.source.VectorEventType.CLEAR);
- this.dispatchEvent(clearEvent);
- this.changed();
- * Iterate through all features on the source, calling the provided callback
- * with each one. If the callback returns any "truthy" value, iteration will
- * stop and the function will return the same value.
- * @param {function(this: T, ol.Feature): S} callback Called with each feature
- * on the source. Return a truthy value to stop iteration.
- * @param {T=} opt_this The object to use as `this` in the callback.
- * @return {S|undefined} The return value from the last call to the callback.
- * @template T,S
- * @api
-ol.source.Vector.prototype.forEachFeature = function(callback, opt_this) {
- return this.featuresRtree_.forEach(callback, opt_this);
- } else if (this.featuresCollection_) {
- return this.featuresCollection_.forEach(callback, opt_this);
- * Iterate through all features whose geometries contain the provided
- * coordinate, calling the callback with each feature. If the callback returns
- * a "truthy" value, iteration will stop and the function will return the same
- * value.
- * @param {ol.Coordinate} coordinate Coordinate.
- * whose goemetry contains the provided coordinate.
- * @template T,S
-ol.source.Vector.prototype.forEachFeatureAtCoordinateDirect = function(coordinate, callback, opt_this) {
- var extent = [coordinate[0], coordinate[1], coordinate[0], coordinate[1]];
- return this.forEachFeatureInExtent(extent, function(feature) {
- if (geometry.intersectsCoordinate(coordinate)) {
- return callback.call(opt_this, feature);
- } else {
- return undefined;
- * Iterate through all features whose bounding box intersects the provided
- * extent (note that the feature's geometry may not intersect the extent),
- * calling the callback with each feature. If the callback returns a "truthy"
- * value, iteration will stop and the function will return the same value.
- * If you are interested in features whose geometry intersects an extent, call
- * the {@link ol.source.Vector#forEachFeatureIntersectingExtent
- * source.forEachFeatureIntersectingExtent()} method instead.
- * When `useSpatialIndex` is set to false, this method will loop through all
- * features, equivalent to {@link ol.source.Vector#forEachFeature}.
- * whose bounding box intersects the provided extent.
- * @template T,S
- * @api
-ol.source.Vector.prototype.forEachFeatureInExtent = function(extent, callback, opt_this) {
- return this.featuresRtree_.forEachInExtent(extent, callback, opt_this);
- * Iterate through all features whose geometry intersects the provided extent,
- * If you only want to test for bounding box intersection, call the
- * {@link ol.source.Vector#forEachFeatureInExtent
- * source.forEachFeatureInExtent()} method instead.
- * whose geometry intersects the provided extent.
- * @template T,S
- * @api
-ol.source.Vector.prototype.forEachFeatureIntersectingExtent = function(extent, callback, opt_this) {
- * @template S
- function(feature) {
- if (geometry.intersectsExtent(extent)) {
- var result = callback.call(opt_this, feature);
- if (result) {
- return result;
- * Get the features collection associated with this source. Will be `null`
- * unless the source was configured with `useSpatialIndex` set to `false`, or
- * with an {@link ol.Collection} as `features`.
- * @return {ol.Collection.<ol.Feature>} The collection of features.
- * @api
-ol.source.Vector.prototype.getFeaturesCollection = function() {
- return this.featuresCollection_;
- * Get all features on the source in random order.
- * @return {Array.<ol.Feature>} Features.
- * @api
-ol.source.Vector.prototype.getFeatures = function() {
- var features;
- features = this.featuresCollection_.getArray();
- } else if (this.featuresRtree_) {
- features = this.featuresRtree_.getAll();
- if (!ol.obj.isEmpty(this.nullGeometryFeatures_)) {
- ol.array.extend(
- features, ol.obj.getValues(this.nullGeometryFeatures_));
- return /** @type {Array.<ol.Feature>} */ (features);
- * Get all features whose geometry intersects the provided coordinate.
- * @api
-ol.source.Vector.prototype.getFeaturesAtCoordinate = function(coordinate) {
- this.forEachFeatureAtCoordinateDirect(coordinate, function(feature) {
- return features;
- * Get all features in the provided extent. Note that this returns an array of
- * all features intersecting the given extent in random order (so it may include
- * features whose geometries do not intersect the extent).
- * This method is not available when the source is configured with
- * `useSpatialIndex` set to `false`.
- * @api
-ol.source.Vector.prototype.getFeaturesInExtent = function(extent) {
- return this.featuresRtree_.getInExtent(extent);
- * Get the closest feature to the provided coordinate.
- * @param {function(ol.Feature):boolean=} opt_filter Feature filter function.
- * The filter function will receive one argument, the {@link ol.Feature feature}
- * and it should return a boolean value. By default, no filtering is made.
- * @return {ol.Feature} Closest feature.
- * @api
-ol.source.Vector.prototype.getClosestFeatureToCoordinate = function(coordinate, opt_filter) {
- // Find the closest feature using branch and bound. We start searching an
- // infinite extent, and find the distance from the first feature found. This
- // becomes the closest feature. We then compute a smaller extent which any
- // closer feature must intersect. We continue searching with this smaller
- // extent, trying to find a closer feature. Every time we find a closer
- // feature, we update the extent being searched so that any even closer
- // feature must intersect it. We continue until we run out of features.
- var x = coordinate[0];
- var y = coordinate[1];
- var closestFeature = null;
- var closestPoint = [NaN, NaN];
- var minSquaredDistance = Infinity;
- var extent = [-Infinity, -Infinity, Infinity, Infinity];
- var filter = opt_filter ? opt_filter : ol.functions.TRUE;
- this.featuresRtree_.forEachInExtent(extent,
- if (filter(feature)) {
- var previousMinSquaredDistance = minSquaredDistance;
- minSquaredDistance = geometry.closestPointXY(
- x, y, closestPoint, minSquaredDistance);
- if (minSquaredDistance < previousMinSquaredDistance) {
- closestFeature = feature;
- // This is sneaky. Reduce the extent that it is currently being
- // searched while the R-Tree traversal using this same extent object
- // is still in progress. This is safe because the new extent is
- // strictly contained by the old extent.
- var minDistance = Math.sqrt(minSquaredDistance);
- extent[0] = x - minDistance;
- extent[1] = y - minDistance;
- extent[2] = x + minDistance;
- extent[3] = y + minDistance;
- return closestFeature;
- * Get the extent of the features currently in the source.
- * @param {ol.Extent=} opt_extent Destination extent. If provided, no new extent
- * will be created. Instead, that extent's coordinates will be overwritten.
- * @return {!ol.Extent} Extent.
- * @api
-ol.source.Vector.prototype.getExtent = function(opt_extent) {
- return this.featuresRtree_.getExtent(opt_extent);
- * Get a feature by its identifier (the value returned by feature.getId()).
- * Note that the index treats string and numeric identifiers as the same. So
- * `source.getFeatureById(2)` will return a feature with id `'2'` or `2`.
- * @param {string|number} id Feature identifier.
- * @return {ol.Feature} The feature (or `null` if not found).
- * @api
-ol.source.Vector.prototype.getFeatureById = function(id) {
- var feature = this.idIndex_[id.toString()];
- return feature !== undefined ? feature : null;
- * Get the format associated with this source.
- * @return {ol.format.Feature|undefined} The feature format.
- * @api
-ol.source.Vector.prototype.getFormat = function() {
- return this.format_;
- * @return {boolean} The source can have overlapping geometries.
-ol.source.Vector.prototype.getOverlaps = function() {
- return this.overlaps_;
- * @override
-ol.source.Vector.prototype.getResolutions = function() {};
- * Get the url associated with this source.
- * @return {string|ol.FeatureUrlFunction|undefined} The url.
- * @api
-ol.source.Vector.prototype.getUrl = function() {
- return this.url_;
- * @param {ol.events.Event} event Event.
- * @private
-ol.source.Vector.prototype.handleFeatureChange_ = function(event) {
- var feature = /** @type {ol.Feature} */ (event.target);
- if (!geometry) {
- if (!(featureKey in this.nullGeometryFeatures_)) {
- this.featuresRtree_.remove(feature);
- } else {
- if (featureKey in this.nullGeometryFeatures_) {
- delete this.nullGeometryFeatures_[featureKey];
- } else {
- this.featuresRtree_.update(extent, feature);
- var sid = id.toString();
- if (featureKey in this.undefIdIndex_) {
- delete this.undefIdIndex_[featureKey];
- this.idIndex_[sid] = feature;
- } else {
- if (this.idIndex_[sid] !== feature) {
- this.removeFromIdIndex_(feature);
- } else {
- if (!(featureKey in this.undefIdIndex_)) {
- this.changed();
- ol.source.VectorEventType.CHANGEFEATURE, feature));
- * @return {boolean} Is empty.
-ol.source.Vector.prototype.isEmpty = function() {
- return this.featuresRtree_.isEmpty() &&
- ol.obj.isEmpty(this.nullGeometryFeatures_);
- * @param {ol.Extent} extent Extent.
- * @param {number} resolution Resolution.
- * @param {ol.proj.Projection} projection Projection.
-ol.source.Vector.prototype.loadFeatures = function(
- extent, resolution, projection) {
- var loadedExtentsRtree = this.loadedExtentsRtree_;
- var extentsToLoad = this.strategy_(extent, resolution);
- var i, ii;
- for (i = 0, ii = extentsToLoad.length; i < ii; ++i) {
- var extentToLoad = extentsToLoad[i];
- var alreadyLoaded = loadedExtentsRtree.forEachInExtent(extentToLoad,
- * @param {{extent: ol.Extent}} object Object.
- * @return {boolean} Contains.
- function(object) {
- return ol.extent.containsExtent(object.extent, extentToLoad);
- if (!alreadyLoaded) {
- this.loader_.call(this, extentToLoad, resolution, projection);
- loadedExtentsRtree.insert(extentToLoad, {extent: extentToLoad.slice()});
- * Remove a single feature from the source. If you want to remove all features
- * at once, use the {@link ol.source.Vector#clear source.clear()} method
- * instead.
- * @param {ol.Feature} feature Feature to remove.
- * @api
-ol.source.Vector.prototype.removeFeature = function(feature) {
- } else {
- this.removeFeatureInternal(feature);
- this.changed();
- * Remove feature without firing a `change` event.
- * @protected
-ol.source.Vector.prototype.removeFeatureInternal = function(feature) {
- this.featureChangeKeys_[featureKey].forEach(ol.events.unlistenByKey);
- delete this.featureChangeKeys_[featureKey];
- delete this.idIndex_[id.toString()];
- } else {
- ol.source.VectorEventType.REMOVEFEATURE, feature));
- * Remove a feature from the id index. Called internally when the feature id
- * may have changed.
- * @return {boolean} Removed the feature from the index.
- * @private
-ol.source.Vector.prototype.removeFromIdIndex_ = function(feature) {
- var removed = false;
- for (var id in this.idIndex_) {
- if (this.idIndex_[id] === feature) {
- delete this.idIndex_[id];
- removed = true;
- break;
- return removed;
- * @classdesc
- * Events emitted by {@link ol.source.Vector} instances are instances of this
- * type.
- * @constructor
- * @extends {ol.events.Event}
- * @implements {oli.source.Vector.Event}
- * @param {string} type Type.
- * @param {ol.Feature=} opt_feature Feature.
-ol.source.Vector.Event = function(type, opt_feature) {
- ol.events.Event.call(this, type);
- * The feature being added or removed.
- * @type {ol.Feature|undefined}
- * @api
- this.feature = opt_feature;
-ol.inherits(ol.source.Vector.Event, ol.events.Event);
-goog.provide('ol.interaction.Draw');
-goog.require('ol');
-goog.require('ol.Feature');
-goog.require('ol.MapBrowserEventType');
-goog.require('ol.coordinate');
-goog.require('ol.events');
-goog.require('ol.events.condition');
-goog.require('ol.functions');
-goog.require('ol.geom.Circle');
-goog.require('ol.geom.GeometryType');
-goog.require('ol.geom.LineString');
-goog.require('ol.geom.MultiLineString');
-goog.require('ol.geom.MultiPoint');
-goog.require('ol.geom.MultiPolygon');
-goog.require('ol.geom.Point');
-goog.require('ol.geom.Polygon');
-goog.require('ol.interaction.DrawEventType');
-goog.require('ol.interaction.Pointer');
-goog.require('ol.interaction.Property');
-goog.require('ol.layer.Vector');
-goog.require('ol.source.Vector');
- * @classdesc
- * Interaction for drawing feature geometries.
- * @constructor
- * @extends {ol.interaction.Pointer}
- * @fires ol.interaction.Draw.Event
- * @param {olx.interaction.DrawOptions} options Options.
- * @api
-ol.interaction.Draw = function(options) {
- ol.interaction.Pointer.call(this, {
- handleDownEvent: ol.interaction.Draw.handleDownEvent_,
- handleEvent: ol.interaction.Draw.handleEvent,
- handleUpEvent: ol.interaction.Draw.handleUpEvent_
- * @type {boolean}
- * @private
- this.shouldHandle_ = false;
- * @type {ol.Pixel}
- * @private
- this.downPx_ = null;
- * @type {boolean}
- * @private
- this.freehand_ = false;
- * Target source for drawn features.
- * @type {ol.source.Vector}
- * @private
- this.source_ = options.source ? options.source : null;
- * Target collection for drawn features.
- * @private
- this.features_ = options.features ? options.features : null;
- * Pixel distance for snapping.
- * @type {number}
- * @private
- this.snapTolerance_ = options.snapTolerance ? options.snapTolerance : 12;
- * Geometry type.
- * @type {ol.geom.GeometryType}
- * @private
- this.type_ = options.type;
- * Drawing mode (derived from geometry type.
- * @type {ol.interaction.Draw.Mode_}
- * @private
- this.mode_ = ol.interaction.Draw.getMode_(this.type_);
- * The number of points that must be drawn before a polygon ring or line
- * string can be finished. The default is 3 for polygon rings and 2 for
- * line strings.
- * @type {number}
- * @private
- this.minPoints_ = options.minPoints ?
- options.minPoints :
- (this.mode_ === ol.interaction.Draw.Mode_.POLYGON ? 3 : 2);
- * The number of points that can be drawn before a polygon ring or line string
- * is finished. The default is no restriction.
- * @type {number}
- * @private
- this.maxPoints_ = options.maxPoints ? options.maxPoints : Infinity;
- * A function to decide if a potential finish coordinate is permissable
- * @private
- * @type {ol.EventsConditionType}
- this.finishCondition_ = options.finishCondition ? options.finishCondition : ol.functions.TRUE;
- var geometryFunction = options.geometryFunction;
- if (!geometryFunction) {
- if (this.type_ === ol.geom.GeometryType.CIRCLE) {
- * @param {ol.Coordinate|Array.<ol.Coordinate>|Array.<Array.<ol.Coordinate>>} coordinates
- * The coordinates.
- * @param {ol.geom.SimpleGeometry=} opt_geometry Optional geometry.
- * @return {ol.geom.SimpleGeometry} A geometry.
- geometryFunction = function(coordinates, opt_geometry) {
- var circle = opt_geometry ? /** @type {ol.geom.Circle} */ (opt_geometry) :
- new ol.geom.Circle([NaN, NaN]);
- var squaredLength = ol.coordinate.squaredDistance(
- coordinates[0], coordinates[1]);
- circle.setCenterAndRadius(coordinates[0], Math.sqrt(squaredLength));
- return circle;
- } else {
- var Constructor;
- var mode = this.mode_;
- if (mode === ol.interaction.Draw.Mode_.POINT) {
- Constructor = ol.geom.Point;
- } else if (mode === ol.interaction.Draw.Mode_.LINE_STRING) {
- Constructor = ol.geom.LineString;
- } else if (mode === ol.interaction.Draw.Mode_.POLYGON) {
- Constructor = ol.geom.Polygon;
- var geometry = opt_geometry;
- if (geometry) {
- if (mode === ol.interaction.Draw.Mode_.POLYGON) {
- geometry.setCoordinates([coordinates[0].concat([coordinates[0][0]])]);
- } else {
- geometry.setCoordinates(coordinates);
- } else {
- geometry = new Constructor(coordinates);
- return geometry;
- * @type {ol.DrawGeometryFunctionType}
- * @private
- this.geometryFunction_ = geometryFunction;
- * Finish coordinate for the feature (first point for polygons, last point for
- * linestrings).
- * @type {ol.Coordinate}
- * @private
- this.finishCoordinate_ = null;
- * Sketch feature.
- * @type {ol.Feature}
- * @private
- this.sketchFeature_ = null;
- * Sketch point.
- * @private
- this.sketchPoint_ = null;
- * Sketch coordinates. Used when drawing a line or polygon.
- * @type {ol.Coordinate|Array.<ol.Coordinate>|Array.<Array.<ol.Coordinate>>}
- * @private
- this.sketchCoords_ = null;
- * Sketch line. Used when drawing polygon.
- * @private
- this.sketchLine_ = null;
- * Sketch line coordinates. Used when drawing a polygon or circle.
- * @type {Array.<ol.Coordinate>}
- * @private
- this.sketchLineCoords_ = null;
- * Squared tolerance for handling up events. If the squared distance
- * between a down and up event is greater than this tolerance, up events
- * will not be handled.
- * @type {number}
- * @private
- this.squaredClickTolerance_ = options.clickTolerance ?
- options.clickTolerance * options.clickTolerance : 36;
- * Draw overlay where our sketch features are drawn.
- * @type {ol.layer.Vector}
- * @private
- this.overlay_ = new ol.layer.Vector({
- source: new ol.source.Vector({
- useSpatialIndex: false,
- wrapX: options.wrapX ? options.wrapX : false
- style: options.style ? options.style :
- ol.interaction.Draw.getDefaultStyleFunction()
- * Name of the geometry attribute for newly created features.
- * @type {string|undefined}
- * @private
- this.geometryName_ = options.geometryName;
- * @private
- this.condition_ = options.condition ?
- options.condition : ol.events.condition.noModifierKeys;
- * @private
- this.freehandCondition_;
- if (options.freehand) {
- this.freehandCondition_ = ol.events.condition.always;
- } else {
- this.freehandCondition_ = options.freehandCondition ?
- options.freehandCondition : ol.events.condition.shiftKeyOnly;
- ol.Object.getChangeEventType(ol.interaction.Property.ACTIVE),
- this.updateState_, this);
-ol.inherits(ol.interaction.Draw, ol.interaction.Pointer);
- * @return {ol.StyleFunction} Styles.
-ol.interaction.Draw.getDefaultStyleFunction = function() {
- var styles = ol.style.Style.createDefaultEditing();
- return function(feature, resolution) {
- return styles[feature.getGeometry().getType()];
- * @inheritDoc
-ol.interaction.Draw.prototype.setMap = function(map) {
- ol.interaction.Pointer.prototype.setMap.call(this, map);
- this.updateState_();
- * Handles the {@link ol.MapBrowserEvent map browser event} and may actually
- * draw or finish the drawing.
- * @param {ol.MapBrowserEvent} event Map browser event.
- * @return {boolean} `false` to stop event propagation.
- * @this {ol.interaction.Draw}
- * @api
-ol.interaction.Draw.handleEvent = function(event) {
- this.freehand_ = this.mode_ !== ol.interaction.Draw.Mode_.POINT && this.freehandCondition_(event);
- var pass = !this.freehand_;
- if (this.freehand_ &&
- event.type === ol.MapBrowserEventType.POINTERDRAG && this.sketchFeature_ !== null) {
- this.addToDrawing_(event);
- pass = false;
- } else if (event.type ===
- ol.MapBrowserEventType.POINTERMOVE) {
- pass = this.handlePointerMove_(event);
- } else if (event.type === ol.MapBrowserEventType.DBLCLICK) {
- pass = false;
- return ol.interaction.Pointer.handleEvent.call(this, event) && pass;
- * @param {ol.MapBrowserPointerEvent} event Event.
- * @return {boolean} Start drag sequence?
- * @private
-ol.interaction.Draw.handleDownEvent_ = function(event) {
- this.shouldHandle_ = !this.freehand_;
- if (this.freehand_) {
- this.downPx_ = event.pixel;
- if (!this.finishCoordinate_) {
- this.startDrawing_(event);
- return true;
- } else if (this.condition_(event)) {
- return true;
- } else {
- return false;
- * @return {boolean} Stop drag sequence?
- * @private
-ol.interaction.Draw.handleUpEvent_ = function(event) {
- var pass = true;
- this.handlePointerMove_(event);
- var circleMode = this.mode_ === ol.interaction.Draw.Mode_.CIRCLE;
- if (this.shouldHandle_) {
- if (this.mode_ === ol.interaction.Draw.Mode_.POINT) {
- this.finishDrawing();
- } else if (this.freehand_ || circleMode) {
- } else if (this.atFinish_(event)) {
- if (this.finishCondition_(event)) {
- } else {
- pass = false;
- } else if (this.freehand_) {
- this.abortDrawing_();
- return pass;
- * Handle move events.
- * @param {ol.MapBrowserEvent} event A move event.
- * @return {boolean} Pass the event to other interactions.
- * @private
-ol.interaction.Draw.prototype.handlePointerMove_ = function(event) {
- if (this.downPx_ &&
- ((!this.freehand_ && this.shouldHandle_) ||
- (this.freehand_ && !this.shouldHandle_))) {
- var downPx = this.downPx_;
- var clickPx = event.pixel;
- var dx = downPx[0] - clickPx[0];
- var dy = downPx[1] - clickPx[1];
- var squaredDistance = dx * dx + dy * dy;
- this.shouldHandle_ = this.freehand_ ?
- squaredDistance > this.squaredClickTolerance_ :
- squaredDistance <= this.squaredClickTolerance_;
- if (this.finishCoordinate_) {
- this.modifyDrawing_(event);
- } else {
- this.createOrUpdateSketchPoint_(event);
- return true;
- * Determine if an event is within the snapping tolerance of the start coord.
- * @param {ol.MapBrowserEvent} event Event.
- * @return {boolean} The event is within the snapping tolerance of the start.
- * @private
-ol.interaction.Draw.prototype.atFinish_ = function(event) {
- var at = false;
- if (this.sketchFeature_) {
- var potentiallyDone = false;
- var potentiallyFinishCoordinates = [this.finishCoordinate_];
- if (this.mode_ === ol.interaction.Draw.Mode_.LINE_STRING) {
- potentiallyDone = this.sketchCoords_.length > this.minPoints_;
- } else if (this.mode_ === ol.interaction.Draw.Mode_.POLYGON) {
- potentiallyDone = this.sketchCoords_[0].length >
- this.minPoints_;
- potentiallyFinishCoordinates = [this.sketchCoords_[0][0],
- this.sketchCoords_[0][this.sketchCoords_[0].length - 2]];
- if (potentiallyDone) {
- var map = event.map;
- for (var i = 0, ii = potentiallyFinishCoordinates.length; i < ii; i++) {
- var finishCoordinate = potentiallyFinishCoordinates[i];
- var finishPixel = map.getPixelFromCoordinate(finishCoordinate);
- var pixel = event.pixel;
- var dx = pixel[0] - finishPixel[0];
- var dy = pixel[1] - finishPixel[1];
- var snapTolerance = this.freehand_ ? 1 : this.snapTolerance_;
- at = Math.sqrt(dx * dx + dy * dy) <= snapTolerance;
- if (at) {
- this.finishCoordinate_ = finishCoordinate;
- break;
- return at;
- * @private
-ol.interaction.Draw.prototype.createOrUpdateSketchPoint_ = function(event) {
- var coordinates = event.coordinate.slice();
- if (!this.sketchPoint_) {
- this.sketchPoint_ = new ol.Feature(new ol.geom.Point(coordinates));
- this.updateSketchFeatures_();
- } else {
- var sketchPointGeom = /** @type {ol.geom.Point} */ (this.sketchPoint_.getGeometry());
- sketchPointGeom.setCoordinates(coordinates);
- * Start the drawing.
- * @private
-ol.interaction.Draw.prototype.startDrawing_ = function(event) {
- var start = event.coordinate;
- this.finishCoordinate_ = start;
- this.sketchCoords_ = start.slice();
- this.sketchCoords_ = [[start.slice(), start.slice()]];
- this.sketchLineCoords_ = this.sketchCoords_[0];
- } else {
- this.sketchCoords_ = [start.slice(), start.slice()];
- if (this.mode_ === ol.interaction.Draw.Mode_.CIRCLE) {
- this.sketchLineCoords_ = this.sketchCoords_;
- if (this.sketchLineCoords_) {
- this.sketchLine_ = new ol.Feature(
- new ol.geom.LineString(this.sketchLineCoords_));
- var geometry = this.geometryFunction_(this.sketchCoords_);
- this.sketchFeature_ = new ol.Feature();
- if (this.geometryName_) {
- this.sketchFeature_.setGeometryName(this.geometryName_);
- this.sketchFeature_.setGeometry(geometry);
- this.dispatchEvent(new ol.interaction.Draw.Event(
- ol.interaction.DrawEventType.DRAWSTART, this.sketchFeature_));
- * Modify the drawing.
- * @private
-ol.interaction.Draw.prototype.modifyDrawing_ = function(event) {
- var coordinate = event.coordinate;
- var geometry = /** @type {ol.geom.SimpleGeometry} */ (this.sketchFeature_.getGeometry());
- var coordinates, last;
- last = this.sketchCoords_;
- coordinates = this.sketchCoords_[0];
- last = coordinates[coordinates.length - 1];
- if (this.atFinish_(event)) {
- // snap to finish
- coordinate = this.finishCoordinate_.slice();
- } else {
- coordinates = this.sketchCoords_;
- last[0] = coordinate[0];
- last[1] = coordinate[1];
- this.geometryFunction_(
- /** @type {!ol.Coordinate|!Array.<ol.Coordinate>|!Array.<Array.<ol.Coordinate>>} */ (this.sketchCoords_),
- geometry);
- if (this.sketchPoint_) {
- sketchPointGeom.setCoordinates(coordinate);
- var sketchLineGeom;
- if (geometry instanceof ol.geom.Polygon &&
- this.mode_ !== ol.interaction.Draw.Mode_.POLYGON) {
- if (!this.sketchLine_) {
- this.sketchLine_ = new ol.Feature(new ol.geom.LineString(null));
- var ring = geometry.getLinearRing(0);
- sketchLineGeom = /** @type {ol.geom.LineString} */ (this.sketchLine_.getGeometry());
- sketchLineGeom.setFlatCoordinates(
- ring.getLayout(), ring.getFlatCoordinates());
- } else if (this.sketchLineCoords_) {
- sketchLineGeom.setCoordinates(this.sketchLineCoords_);
- * Add a new coordinate to the drawing.
- * @private
-ol.interaction.Draw.prototype.addToDrawing_ = function(event) {
- var done;
- var coordinates;
- this.finishCoordinate_ = coordinate.slice();
- if (coordinates.length >= this.maxPoints_) {
- coordinates.pop();
- } else {
- done = true;
- coordinates.push(coordinate.slice());
- this.geometryFunction_(coordinates, geometry);
- } else {
- done = true;
- if (done) {
- this.finishCoordinate_ = coordinates[0];
- this.geometryFunction_(this.sketchCoords_, geometry);
- if (done) {
- * Remove last point of the feature currently being drawn.
- * @api
-ol.interaction.Draw.prototype.removeLastPoint = function() {
- if (!this.sketchFeature_) {
- return;
- var coordinates, sketchLineGeom;
- coordinates.splice(-2, 1);
- if (coordinates.length >= 2) {
- this.finishCoordinate_ = coordinates[coordinates.length - 2].slice();
- sketchLineGeom.setCoordinates(coordinates);
- if (coordinates.length === 0) {
- * Stop drawing and add the sketch feature to the target layer.
- * The {@link ol.interaction.DrawEventType.DRAWEND} event is dispatched before
- * inserting the feature.
- * @api
-ol.interaction.Draw.prototype.finishDrawing = function() {
- var sketchFeature = this.abortDrawing_();
- var coordinates = this.sketchCoords_;
- var geometry = /** @type {ol.geom.SimpleGeometry} */ (sketchFeature.getGeometry());
- // remove the redundant last point
- // remove the redundant last point in ring
- coordinates[0].pop();
- coordinates = geometry.getCoordinates();
- // cast multi-part geometries
- if (this.type_ === ol.geom.GeometryType.MULTI_POINT) {
- sketchFeature.setGeometry(new ol.geom.MultiPoint([coordinates]));
- } else if (this.type_ === ol.geom.GeometryType.MULTI_LINE_STRING) {
- sketchFeature.setGeometry(new ol.geom.MultiLineString([coordinates]));
- } else if (this.type_ === ol.geom.GeometryType.MULTI_POLYGON) {
- sketchFeature.setGeometry(new ol.geom.MultiPolygon([coordinates]));
- // First dispatch event to allow full set up of feature
- ol.interaction.DrawEventType.DRAWEND, sketchFeature));
- // Then insert feature
- if (this.features_) {
- this.features_.push(sketchFeature);
- if (this.source_) {
- this.source_.addFeature(sketchFeature);
- * Stop drawing without adding the sketch feature to the target layer.
- * @return {ol.Feature} The sketch feature (or null if none).
- * @private
-ol.interaction.Draw.prototype.abortDrawing_ = function() {
- var sketchFeature = this.sketchFeature_;
- if (sketchFeature) {
- this.overlay_.getSource().clear(true);
- return sketchFeature;
- * Extend an existing geometry by adding additional points. This only works
- * on features with `LineString` geometries, where the interaction will
- * extend lines by adding points to the end of the coordinates array.
- * @param {!ol.Feature} feature Feature to be extended.
- * @api
-ol.interaction.Draw.prototype.extend = function(feature) {
- var lineString = /** @type {ol.geom.LineString} */ (geometry);
- this.sketchFeature_ = feature;
- this.sketchCoords_ = lineString.getCoordinates();
- var last = this.sketchCoords_[this.sketchCoords_.length - 1];
- this.finishCoordinate_ = last.slice();
- this.sketchCoords_.push(last.slice());
- * @inheritDoc
-ol.interaction.Draw.prototype.shouldStopEvent = ol.functions.FALSE;
- * Redraw the sketch features.
- * @private
-ol.interaction.Draw.prototype.updateSketchFeatures_ = function() {
- var sketchFeatures = [];
- sketchFeatures.push(this.sketchFeature_);
- if (this.sketchLine_) {
- sketchFeatures.push(this.sketchLine_);
- sketchFeatures.push(this.sketchPoint_);
- var overlaySource = this.overlay_.getSource();
- overlaySource.clear(true);
- overlaySource.addFeatures(sketchFeatures);
- * @private
-ol.interaction.Draw.prototype.updateState_ = function() {
- var map = this.getMap();
- var active = this.getActive();
- if (!map || !active) {
- this.overlay_.setMap(active ? map : null);
- * Create a `geometryFunction` for `type: 'Circle'` that will create a regular
- * polygon with a user specified number of sides and start angle instead of an
- * `ol.geom.Circle` geometry.
- * @param {number=} opt_sides Number of sides of the regular polygon. Default is
- * 32.
- * @param {number=} opt_angle Angle of the first point in radians. 0 means East.
- * Default is the angle defined by the heading from the center of the
- * regular polygon to the current pointer position.
- * @return {ol.DrawGeometryFunctionType} Function that draws a
- * polygon.
- * @api
-ol.interaction.Draw.createRegularPolygon = function(opt_sides, opt_angle) {
- return (
- function(coordinates, opt_geometry) {
- var center = coordinates[0];
- var end = coordinates[1];
- var radius = Math.sqrt(
- ol.coordinate.squaredDistance(center, end));
- var geometry = opt_geometry ? /** @type {ol.geom.Polygon} */ (opt_geometry) :
- ol.geom.Polygon.fromCircle(new ol.geom.Circle(center), opt_sides);
- var angle = opt_angle ? opt_angle :
- Math.atan((end[1] - center[1]) / (end[0] - center[0]));
- ol.geom.Polygon.makeRegular(geometry, center, radius, angle);
- return geometry;
- * Create a `geometryFunction` that will create a box-shaped polygon (aligned
- * with the coordinate system axes). Use this with the draw interaction and
- * `type: 'Circle'` to return a box instead of a circle geometry.
- * @return {ol.DrawGeometryFunctionType} Function that draws a box-shaped polygon.
- * @api
-ol.interaction.Draw.createBox = function() {
- return (
- var extent = ol.extent.boundingExtent(coordinates);
- var geometry = opt_geometry || new ol.geom.Polygon(null);
- geometry.setCoordinates([[
- ol.extent.getBottomLeft(extent),
- ol.extent.getBottomRight(extent),
- ol.extent.getTopRight(extent),
- ol.extent.getTopLeft(extent),
- return geometry;
- * Get the drawing mode. The mode for mult-part geometries is the same as for
- * their single-part cousins.
- * @param {ol.geom.GeometryType} type Geometry type.
- * @return {ol.interaction.Draw.Mode_} Drawing mode.
- * @private
-ol.interaction.Draw.getMode_ = function(type) {
- var mode;
- if (type === ol.geom.GeometryType.POINT ||
- type === ol.geom.GeometryType.MULTI_POINT) {
- mode = ol.interaction.Draw.Mode_.POINT;
- } else if (type === ol.geom.GeometryType.LINE_STRING ||
- type === ol.geom.GeometryType.MULTI_LINE_STRING) {
- mode = ol.interaction.Draw.Mode_.LINE_STRING;
- } else if (type === ol.geom.GeometryType.POLYGON ||
- type === ol.geom.GeometryType.MULTI_POLYGON) {
- mode = ol.interaction.Draw.Mode_.POLYGON;
- } else if (type === ol.geom.GeometryType.CIRCLE) {
- mode = ol.interaction.Draw.Mode_.CIRCLE;
- return /** @type {!ol.interaction.Draw.Mode_} */ (mode);
- * Draw mode. This collapses multi-part geometry types with their single-part
- * cousins.
- * @enum {string}
- * @private
-ol.interaction.Draw.Mode_ = {
- POINT: 'Point',
- LINE_STRING: 'LineString',
- POLYGON: 'Polygon',
- CIRCLE: 'Circle'
- * @classdesc
- * Events emitted by {@link ol.interaction.Draw} instances are instances of
- * this type.
- * @constructor
- * @implements {oli.DrawEvent}
- * @param {ol.interaction.DrawEventType} type Type.
- * @param {ol.Feature} feature The feature drawn.
-ol.interaction.Draw.Event = function(type, feature) {
- * The feature being drawn.
- * @api
- this.feature = feature;
-ol.inherits(ol.interaction.Draw.Event, ol.events.Event);
-goog.provide('ol.interaction.Extent');
-goog.require('ol.MapBrowserPointerEvent');
- * @classdesc
- * Allows the user to draw a vector box by clicking and dragging on the map.
- * Once drawn, the vector box can be modified by dragging its vertices or edges.
- * This interaction is only supported for mouse devices.
- * @constructor
- * @fires ol.interaction.Extent.Event
- * @param {olx.interaction.ExtentOptions=} opt_options Options.
- * @api
-ol.interaction.Extent = function(opt_options) {
- * Extent of the drawn box
- * @type {ol.Extent}
- * @private
- this.extent_ = null;
- * Handler for pointer move events
- * @type {function (ol.Coordinate): ol.Extent|null}
- * @private
- this.pointerHandler_ = null;
- * Pixel threshold to snap to extent
- * @type {number}
- * @private
- this.pixelTolerance_ = 10;
- * Is the pointer snapped to an extent vertex
- * @type {boolean}
- * @private
- this.snappedToVertex_ = false;
- * Feature for displaying the visible extent
- * @private
- this.extentFeature_ = null;
- * Feature for displaying the visible pointer
- * @private
- this.vertexFeature_ = null;
- if (!opt_options) {
- opt_options = {};
- if (opt_options.extent) {
- this.setExtent(opt_options.extent);
- /* Inherit ol.interaction.Pointer */
- handleDownEvent: ol.interaction.Extent.handleDownEvent_,
- handleDragEvent: ol.interaction.Extent.handleDragEvent_,
- handleEvent: ol.interaction.Extent.handleEvent_,
- handleUpEvent: ol.interaction.Extent.handleUpEvent_
- * Layer for the extentFeature
- * @private
- this.extentOverlay_ = new ol.layer.Vector({
- wrapX: !!opt_options.wrapX
- style: opt_options.boxStyle ? opt_options.boxStyle : ol.interaction.Extent.getDefaultExtentStyleFunction_(),
- updateWhileAnimating: true,
- updateWhileInteracting: true
- * Layer for the vertexFeature
- * @private
- this.vertexOverlay_ = new ol.layer.Vector({
- style: opt_options.pointerStyle ? opt_options.pointerStyle : ol.interaction.Extent.getDefaultPointerStyleFunction_(),
-ol.inherits(ol.interaction.Extent, ol.interaction.Pointer);
- * @param {ol.MapBrowserEvent} mapBrowserEvent Event.
- * @return {boolean} Propagate event?
- * @this {ol.interaction.Extent}
- * @private
-ol.interaction.Extent.handleEvent_ = function(mapBrowserEvent) {
- if (!(mapBrowserEvent instanceof ol.MapBrowserPointerEvent)) {
- return true;
- //display pointer (if not dragging)
- if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERMOVE && !this.handlingDownUpSequence) {
- this.handlePointerMove_(mapBrowserEvent);
- //call pointer to determine up/down/drag
- ol.interaction.Pointer.handleEvent.call(this, mapBrowserEvent);
- //return false to stop propagation
- return false;
- * @param {ol.MapBrowserPointerEvent} mapBrowserEvent Event.
- * @return {boolean} Event handled?
- * @private
-ol.interaction.Extent.handleDownEvent_ = function(mapBrowserEvent) {
- var pixel = mapBrowserEvent.pixel;
- var map = mapBrowserEvent.map;
- var extent = this.getExtent();
- var vertex = this.snapToVertex_(pixel, map);
- //find the extent corner opposite the passed corner
- var getOpposingPoint = function(point) {
- var x_ = null;
- var y_ = null;
- if (point[0] == extent[0]) {
- x_ = extent[2];
- } else if (point[0] == extent[2]) {
- x_ = extent[0];
- if (point[1] == extent[1]) {
- y_ = extent[3];
- } else if (point[1] == extent[3]) {
- y_ = extent[1];
- if (x_ !== null && y_ !== null) {
- return [x_, y_];
- return null;
- if (vertex && extent) {
- var x = (vertex[0] == extent[0] || vertex[0] == extent[2]) ? vertex[0] : null;
- var y = (vertex[1] == extent[1] || vertex[1] == extent[3]) ? vertex[1] : null;
- //snap to point
- if (x !== null && y !== null) {
- this.pointerHandler_ = ol.interaction.Extent.getPointHandler_(getOpposingPoint(vertex));
- //snap to edge
- } else if (x !== null) {
- this.pointerHandler_ = ol.interaction.Extent.getEdgeHandler_(
- getOpposingPoint([x, extent[1]]),
- getOpposingPoint([x, extent[3]])
- } else if (y !== null) {
- getOpposingPoint([extent[0], y]),
- getOpposingPoint([extent[2], y])
- //no snap - new bbox
- } else {
- vertex = map.getCoordinateFromPixel(pixel);
- this.setExtent([vertex[0], vertex[1], vertex[0], vertex[1]]);
- this.pointerHandler_ = ol.interaction.Extent.getPointHandler_(vertex);
- return true; //event handled; start downup sequence
- * @private
-ol.interaction.Extent.handleDragEvent_ = function(mapBrowserEvent) {
- if (this.pointerHandler_) {
- var pixelCoordinate = mapBrowserEvent.coordinate;
- this.setExtent(this.pointerHandler_(pixelCoordinate));
- this.createOrUpdatePointerFeature_(pixelCoordinate);
- return true;
- * @private
-ol.interaction.Extent.handleUpEvent_ = function(mapBrowserEvent) {
- //If bbox is zero area, set to null;
- if (!extent || ol.extent.getArea(extent) === 0) {
- this.setExtent(null);
- return false; //Stop handling downup sequence
- * Returns the default style for the drawn bbox
- * @return {ol.StyleFunction} Default Extent style
- * @private
-ol.interaction.Extent.getDefaultExtentStyleFunction_ = function() {
- var style = ol.style.Style.createDefaultEditing();
- return style[ol.geom.GeometryType.POLYGON];
- * Returns the default style for the pointer
- * @return {ol.StyleFunction} Default pointer style
- * @private
-ol.interaction.Extent.getDefaultPointerStyleFunction_ = function() {
- return style[ol.geom.GeometryType.POINT];
- * @param {ol.Coordinate} fixedPoint corner that will be unchanged in the new extent
- * @returns {function (ol.Coordinate): ol.Extent} event handler
- * @private
-ol.interaction.Extent.getPointHandler_ = function(fixedPoint) {
- return function(point) {
- return ol.extent.boundingExtent([fixedPoint, point]);
- * @param {ol.Coordinate} fixedP1 first corner that will be unchanged in the new extent
- * @param {ol.Coordinate} fixedP2 second corner that will be unchanged in the new extent
- * @returns {function (ol.Coordinate): ol.Extent|null} event handler
- * @private
-ol.interaction.Extent.getEdgeHandler_ = function(fixedP1, fixedP2) {
- if (fixedP1[0] == fixedP2[0]) {
- return ol.extent.boundingExtent([fixedP1, [point[0], fixedP2[1]]]);
- } else if (fixedP1[1] == fixedP2[1]) {
- return ol.extent.boundingExtent([fixedP1, [fixedP2[0], point[1]]]);
- } else {
- return null;
- * @param {ol.Extent} extent extent
- * @returns {Array<Array<ol.Coordinate>>} extent line segments
- * @private
-ol.interaction.Extent.getSegments_ = function(extent) {
- return [
- [[extent[0], extent[1]], [extent[0], extent[3]]],
- [[extent[0], extent[3]], [extent[2], extent[3]]],
- [[extent[2], extent[3]], [extent[2], extent[1]]],
- [[extent[2], extent[1]], [extent[0], extent[1]]]
- * @param {ol.Pixel} pixel cursor location
- * @param {ol.Map} map map
- * @returns {ol.Coordinate|null} snapped vertex on extent
- * @private
-ol.interaction.Extent.prototype.snapToVertex_ = function(pixel, map) {
- var pixelCoordinate = map.getCoordinateFromPixel(pixel);
- var sortByDistance = function(a, b) {
- return ol.coordinate.squaredDistanceToSegment(pixelCoordinate, a) -
- ol.coordinate.squaredDistanceToSegment(pixelCoordinate, b);
- if (extent) {
- //convert extents to line segments and find the segment closest to pixelCoordinate
- var segments = ol.interaction.Extent.getSegments_(extent);
- segments.sort(sortByDistance);
- var closestSegment = segments[0];
- var vertex = (ol.coordinate.closestOnSegment(pixelCoordinate,
- closestSegment));
- var vertexPixel = map.getPixelFromCoordinate(vertex);
- //if the distance is within tolerance, snap to the segment
- if (ol.coordinate.distance(pixel, vertexPixel) <= this.pixelTolerance_) {
- //test if we should further snap to a vertex
- var pixel1 = map.getPixelFromCoordinate(closestSegment[0]);
- var pixel2 = map.getPixelFromCoordinate(closestSegment[1]);
- var squaredDist1 = ol.coordinate.squaredDistance(vertexPixel, pixel1);
- var squaredDist2 = ol.coordinate.squaredDistance(vertexPixel, pixel2);
- var dist = Math.sqrt(Math.min(squaredDist1, squaredDist2));
- this.snappedToVertex_ = dist <= this.pixelTolerance_;
- if (this.snappedToVertex_) {
- vertex = squaredDist1 > squaredDist2 ?
- closestSegment[1] : closestSegment[0];
- return vertex;
- return null;
- * @param {ol.MapBrowserEvent} mapBrowserEvent pointer move event
- * @private
-ol.interaction.Extent.prototype.handlePointerMove_ = function(mapBrowserEvent) {
- if (!vertex) {
- this.createOrUpdatePointerFeature_(vertex);
- * @returns {ol.Feature} extent as featrue
- * @private
-ol.interaction.Extent.prototype.createOrUpdateExtentFeature_ = function(extent) {
- var extentFeature = this.extentFeature_;
- if (!extentFeature) {
- if (!extent) {
- extentFeature = new ol.Feature({});
- } else {
- extentFeature = new ol.Feature(ol.geom.Polygon.fromExtent(extent));
- this.extentFeature_ = extentFeature;
- this.extentOverlay_.getSource().addFeature(extentFeature);
- } else {
- if (!extent) {
- extentFeature.setGeometry(undefined);
- } else {
- extentFeature.setGeometry(ol.geom.Polygon.fromExtent(extent));
- return extentFeature;
- * @param {ol.Coordinate} vertex location of feature
- * @returns {ol.Feature} vertex as feature
- * @private
-ol.interaction.Extent.prototype.createOrUpdatePointerFeature_ = function(vertex) {
- var vertexFeature = this.vertexFeature_;
- if (!vertexFeature) {
- vertexFeature = new ol.Feature(new ol.geom.Point(vertex));
- this.vertexFeature_ = vertexFeature;
- this.vertexOverlay_.getSource().addFeature(vertexFeature);
- } else {
- var geometry = /** @type {ol.geom.Point} */ (vertexFeature.getGeometry());
- geometry.setCoordinates(vertex);
- return vertexFeature;
- * @inheritDoc
-ol.interaction.Extent.prototype.setMap = function(map) {
- this.extentOverlay_.setMap(map);
- this.vertexOverlay_.setMap(map);
- * Returns the current drawn extent in the view projection
- * @return {ol.Extent} Drawn extent in the view projection.
- * @api
-ol.interaction.Extent.prototype.getExtent = function() {
- return this.extent_;
- * Manually sets the drawn extent, using the view projection.
- * @api
-ol.interaction.Extent.prototype.setExtent = function(extent) {
- //Null extent means no bbox
- this.extent_ = extent ? extent : null;
- this.createOrUpdateExtentFeature_(extent);
- this.dispatchEvent(new ol.interaction.Extent.Event(this.extent_));
- * @classdesc
- * Events emitted by {@link ol.interaction.Extent} instances are instances of
- * this type.
- * @constructor
- * @param {ol.Extent} extent the new extent
-ol.interaction.Extent.Event = function(extent) {
- ol.events.Event.call(this, ol.interaction.Extent.EventType_.EXTENTCHANGED);
- * The current extent.
- * @api
- this.extent_ = extent;
-ol.inherits(ol.interaction.Extent.Event, ol.events.Event);
- * @enum {string}
- * @private
-ol.interaction.Extent.EventType_ = {
- * Triggered after the extent is changed
- * @event ol.interaction.Extent.Event
- * @api
- EXTENTCHANGED: 'extentchanged'
-goog.provide('ol.interaction.ModifyEventType');
- * @enum {string}
-ol.interaction.ModifyEventType = {
- * Triggered upon feature modification start
- * @event ol.interaction.Modify.Event#modifystart
- * @api
- MODIFYSTART: 'modifystart',
- * Triggered upon feature modification end
- * @event ol.interaction.Modify.Event#modifyend
- * @api
- MODIFYEND: 'modifyend'
-goog.provide('ol.interaction.Modify');
-goog.require('ol.ViewHint');
-goog.require('ol.events.EventType');
-goog.require('ol.extent');
-goog.require('ol.interaction.ModifyEventType');
-goog.require('ol.style.Style');
- * @classdesc
- * Interaction for modifying feature geometries.
- * @constructor
- * @param {olx.interaction.ModifyOptions} options Options.
- * @fires ol.interaction.Modify.Event
- * @api
-ol.interaction.Modify = function(options) {
- handleDownEvent: ol.interaction.Modify.handleDownEvent_,
- handleDragEvent: ol.interaction.Modify.handleDragEvent_,
- handleEvent: ol.interaction.Modify.handleEvent,
- handleUpEvent: ol.interaction.Modify.handleUpEvent_
- * @private
- options.condition : ol.events.condition.primaryAction;
- * @private
- * @param {ol.MapBrowserEvent} mapBrowserEvent Browser event.
- * @return {boolean} Combined condition result.
- this.defaultDeleteCondition_ = function(mapBrowserEvent) {
- return ol.events.condition.noModifierKeys(mapBrowserEvent) &&
- ol.events.condition.singleClick(mapBrowserEvent);
- * @private
- this.deleteCondition_ = options.deleteCondition ?
- options.deleteCondition : this.defaultDeleteCondition_;
- * Editing vertex.
- * @private
- * Segments intersecting {@link this.vertexFeature_} by segment uid.
- * @type {Object.<string, boolean>}
- * @private
- this.vertexSegments_ = null;
- * @private
- this.lastPixel_ = [0, 0];
- * Tracks if the next `singleclick` event should be ignored to prevent
- * accidental deletion right after vertex creation.
- * @type {boolean}
- * @private
- this.ignoreNextSingleClick_ = false;
- * @type {boolean}
- * @private
- this.modified_ = false;
- * Segment RTree for each layer
- * @type {ol.structs.RBush.<ol.ModifySegmentDataType>}
- * @private
- this.rBush_ = new ol.structs.RBush();
- * @type {number}
- * @private
- this.pixelTolerance_ = options.pixelTolerance !== undefined ?
- options.pixelTolerance : 10;
- * @type {boolean}
- * @private
- * Indicate whether the interaction is currently changing a feature's
- * coordinates.
- * @type {boolean}
- * @private
- this.changingFeature_ = false;
- * @type {Array}
- * @private
- this.dragSegments_ = [];
- * Draw overlay where sketch features are drawn.
- * @private
- wrapX: !!options.wrapX
- ol.interaction.Modify.getDefaultStyleFunction(),
- * @const
- * @private
- * @type {Object.<string, function(ol.Feature, ol.geom.Geometry)>}
- this.SEGMENT_WRITERS_ = {
- 'Point': this.writePointGeometry_,
- 'LineString': this.writeLineStringGeometry_,
- 'LinearRing': this.writeLineStringGeometry_,
- 'Polygon': this.writePolygonGeometry_,
- 'MultiPoint': this.writeMultiPointGeometry_,
- 'MultiLineString': this.writeMultiLineStringGeometry_,
- 'MultiPolygon': this.writeMultiPolygonGeometry_,
- 'Circle': this.writeCircleGeometry_,
- 'GeometryCollection': this.writeGeometryCollectionGeometry_
- * @private
- this.features_ = options.features;
- this.features_.forEach(this.addFeature_, this);
- ol.events.listen(this.features_, ol.CollectionEventType.ADD,
- this.handleFeatureAdd_, this);
- ol.events.listen(this.features_, ol.CollectionEventType.REMOVE,
- this.handleFeatureRemove_, this);
- * @type {ol.MapBrowserPointerEvent}
- * @private
- this.lastPointerEvent_ = null;
-ol.inherits(ol.interaction.Modify, ol.interaction.Pointer);
- * @define {number} The segment index assigned to a circle's center when
- * breaking up a cicrle into ModifySegmentDataType segments.
-ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX = 0;
- * @define {number} The segment index assigned to a circle's circumference when
- * breaking up a circle into ModifySegmentDataType segments.
-ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX = 1;
- * @param {ol.Feature} feature Feature.
- * @private
-ol.interaction.Modify.prototype.addFeature_ = function(feature) {
- if (geometry && geometry.getType() in this.SEGMENT_WRITERS_) {
- this.SEGMENT_WRITERS_[geometry.getType()].call(this, feature, geometry);
- if (map && map.isRendered() && this.getActive()) {
- this.handlePointerAtPixel_(this.lastPixel_, map);
- this.handleFeatureChange_, this);
- * @param {ol.MapBrowserPointerEvent} evt Map browser event
- * @private
-ol.interaction.Modify.prototype.willModifyFeatures_ = function(evt) {
- if (!this.modified_) {
- this.modified_ = true;
- this.dispatchEvent(new ol.interaction.Modify.Event(
- ol.interaction.ModifyEventType.MODIFYSTART, this.features_, evt));
- * @private
-ol.interaction.Modify.prototype.removeFeature_ = function(feature) {
- this.removeFeatureSegmentData_(feature);
- // Remove the vertex feature if the collection of canditate features
- // is empty.
- if (this.vertexFeature_ && this.features_.getLength() === 0) {
- this.overlay_.getSource().removeFeature(this.vertexFeature_);
- ol.events.unlisten(feature, ol.events.EventType.CHANGE,
- * @private
-ol.interaction.Modify.prototype.removeFeatureSegmentData_ = function(feature) {
- var rBush = this.rBush_;
- var /** @type {Array.<ol.ModifySegmentDataType>} */ nodesToRemove = [];
- rBush.forEach(
- * @param {ol.ModifySegmentDataType} node RTree node.
- function(node) {
- if (feature === node.feature) {
- nodesToRemove.push(node);
- for (var i = nodesToRemove.length - 1; i >= 0; --i) {
- rBush.remove(nodesToRemove[i]);
- * @inheritDoc
-ol.interaction.Modify.prototype.setActive = function(active) {
- if (this.vertexFeature_ && !active) {
- ol.interaction.Pointer.prototype.setActive.call(this, active);
- * @inheritDoc
-ol.interaction.Modify.prototype.setMap = function(map) {
- this.overlay_.setMap(map);
- * @param {ol.Collection.Event} evt Event.
- * @private
-ol.interaction.Modify.prototype.handleFeatureAdd_ = function(evt) {
- this.addFeature_(/** @type {ol.Feature} */ (evt.element));
- * @param {ol.events.Event} evt Event.
- * @private
-ol.interaction.Modify.prototype.handleFeatureChange_ = function(evt) {
- if (!this.changingFeature_) {
- var feature = /** @type {ol.Feature} */ (evt.target);
- this.removeFeature_(feature);
- this.addFeature_(feature);
- * @private
-ol.interaction.Modify.prototype.handleFeatureRemove_ = function(evt) {
- var feature = /** @type {ol.Feature} */ (evt.element);
- * @param {ol.geom.Point} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writePointGeometry_ = function(feature, geometry) {
- var coordinates = geometry.getCoordinates();
- var segmentData = /** @type {ol.ModifySegmentDataType} */ ({
- feature: feature,
- geometry: geometry,
- segment: [coordinates, coordinates]
- this.rBush_.insert(geometry.getExtent(), segmentData);
- * @param {ol.geom.MultiPoint} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writeMultiPointGeometry_ = function(feature, geometry) {
- var points = geometry.getCoordinates();
- var coordinates, i, ii, segmentData;
- for (i = 0, ii = points.length; i < ii; ++i) {
- coordinates = points[i];
- segmentData = /** @type {ol.ModifySegmentDataType} */ ({
- feature: feature,
- depth: [i],
- index: i,
- * @param {ol.geom.LineString} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writeLineStringGeometry_ = function(feature, geometry) {
- var i, ii, segment, segmentData;
- for (i = 0, ii = coordinates.length - 1; i < ii; ++i) {
- segment = coordinates.slice(i, i + 2);
- feature: feature,
- index: i,
- segment: segment
- this.rBush_.insert(ol.extent.boundingExtent(segment), segmentData);
- * @param {ol.geom.MultiLineString} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writeMultiLineStringGeometry_ = function(feature, geometry) {
- var lines = geometry.getCoordinates();
- var coordinates, i, ii, j, jj, segment, segmentData;
- for (j = 0, jj = lines.length; j < jj; ++j) {
- coordinates = lines[j];
- feature: feature,
- depth: [j],
- index: i,
- segment: segment
- * @param {ol.geom.Polygon} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writePolygonGeometry_ = function(feature, geometry) {
- var rings = geometry.getCoordinates();
- for (j = 0, jj = rings.length; j < jj; ++j) {
- coordinates = rings[j];
- feature: feature,
- depth: [j],
- index: i,
- segment: segment
- * @param {ol.geom.MultiPolygon} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writeMultiPolygonGeometry_ = function(feature, geometry) {
- var polygons = geometry.getCoordinates();
- var coordinates, i, ii, j, jj, k, kk, rings, segment, segmentData;
- for (k = 0, kk = polygons.length; k < kk; ++k) {
- rings = polygons[k];
- feature: feature,
- depth: [j, k],
- index: i,
- segment: segment
- * We convert a circle into two segments. The segment at index
- * {@link ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX} is the
- * circle's center (a point). The segment at index
- * {@link ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX} is
- * the circumference, and is not a line segment.
- * @param {ol.geom.Circle} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writeCircleGeometry_ = function(feature, geometry) {
- var coordinates = geometry.getCenter();
- var centerSegmentData = /** @type {ol.ModifySegmentDataType} */ ({
- feature: feature,
- index: ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX,
- var circumferenceSegmentData = /** @type {ol.ModifySegmentDataType} */ ({
- feature: feature,
- index: ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX,
- var featureSegments = [centerSegmentData, circumferenceSegmentData];
- centerSegmentData.featureSegments = circumferenceSegmentData.featureSegments = featureSegments;
- this.rBush_.insert(ol.extent.createOrUpdateFromCoordinate(coordinates), centerSegmentData);
- this.rBush_.insert(geometry.getExtent(), circumferenceSegmentData);
- * @param {ol.geom.GeometryCollection} geometry Geometry.
- * @private
-ol.interaction.Modify.prototype.writeGeometryCollectionGeometry_ = function(feature, geometry) {
- var i, geometries = geometry.getGeometriesArray();
- for (i = 0; i < geometries.length; ++i) {
- this.SEGMENT_WRITERS_[geometries[i].getType()].call(
- this, feature, geometries[i]);
- * @param {ol.Coordinate} coordinates Coordinates.
- * @return {ol.Feature} Vertex feature.
- * @private
-ol.interaction.Modify.prototype.createOrUpdateVertexFeature_ = function(coordinates) {
- vertexFeature = new ol.Feature(new ol.geom.Point(coordinates));
- this.overlay_.getSource().addFeature(vertexFeature);
- } else {
- * @param {ol.ModifySegmentDataType} a The first segment data.
- * @param {ol.ModifySegmentDataType} b The second segment data.
- * @return {number} The difference in indexes.
- * @private
-ol.interaction.Modify.compareIndexes_ = function(a, b) {
- return a.index - b.index;
- * @param {ol.MapBrowserPointerEvent} evt Event.
- * @this {ol.interaction.Modify}
- * @private
-ol.interaction.Modify.handleDownEvent_ = function(evt) {
- if (!this.condition_(evt)) {
- return false;
- this.handlePointerAtPixel_(evt.pixel, evt.map);
- var pixelCoordinate = evt.map.getCoordinateFromPixel(evt.pixel);
- this.dragSegments_.length = 0;
- if (vertexFeature) {
- var insertVertices = [];
- var vertex = geometry.getCoordinates();
- var vertexExtent = ol.extent.boundingExtent([vertex]);
- var segmentDataMatches = this.rBush_.getInExtent(vertexExtent);
- var componentSegments = {};
- segmentDataMatches.sort(ol.interaction.Modify.compareIndexes_);
- for (var i = 0, ii = segmentDataMatches.length; i < ii; ++i) {
- var segmentDataMatch = segmentDataMatches[i];
- var segment = segmentDataMatch.segment;
- var uid = ol.getUid(segmentDataMatch.feature);
- var depth = segmentDataMatch.depth;
- if (depth) {
- uid += '-' + depth.join('-'); // separate feature components
- if (!componentSegments[uid]) {
- componentSegments[uid] = new Array(2);
- if (segmentDataMatch.geometry.getType() === ol.geom.GeometryType.CIRCLE &&
- segmentDataMatch.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
- var closestVertex = ol.interaction.Modify.closestOnSegmentData_(pixelCoordinate, segmentDataMatch);
- if (ol.coordinate.equals(closestVertex, vertex) && !componentSegments[uid][0]) {
- this.dragSegments_.push([segmentDataMatch, 0]);
- componentSegments[uid][0] = segmentDataMatch;
- } else if (ol.coordinate.equals(segment[0], vertex) &&
- !componentSegments[uid][0]) {
- } else if (ol.coordinate.equals(segment[1], vertex) &&
- !componentSegments[uid][1]) {
- // prevent dragging closed linestrings by the connecting node
- if ((segmentDataMatch.geometry.getType() ===
- ol.geom.GeometryType.LINE_STRING ||
- segmentDataMatch.geometry.getType() ===
- ol.geom.GeometryType.MULTI_LINE_STRING) &&
- componentSegments[uid][0] &&
- componentSegments[uid][0].index === 0) {
- continue;
- this.dragSegments_.push([segmentDataMatch, 1]);
- componentSegments[uid][1] = segmentDataMatch;
- } else if (ol.getUid(segment) in this.vertexSegments_ &&
- (!componentSegments[uid][0] && !componentSegments[uid][1])) {
- insertVertices.push([segmentDataMatch, vertex]);
- if (insertVertices.length) {
- this.willModifyFeatures_(evt);
- for (var j = insertVertices.length - 1; j >= 0; --j) {
- this.insertVertex_.apply(this, insertVertices[j]);
- return !!this.vertexFeature_;
- * @private
-ol.interaction.Modify.handleDragEvent_ = function(evt) {
- var vertex = evt.coordinate;
- for (var i = 0, ii = this.dragSegments_.length; i < ii; ++i) {
- var dragSegment = this.dragSegments_[i];
- var segmentData = dragSegment[0];
- var depth = segmentData.depth;
- var geometry = segmentData.geometry;
- var coordinates;
- var segment = segmentData.segment;
- var index = dragSegment[1];
- while (vertex.length < geometry.getStride()) {
- vertex.push(segment[index][vertex.length]);
- switch (geometry.getType()) {
- case ol.geom.GeometryType.POINT:
- coordinates = vertex;
- segment[0] = segment[1] = vertex;
- break;
- case ol.geom.GeometryType.MULTI_POINT:
- coordinates[segmentData.index] = vertex;
- break;
- case ol.geom.GeometryType.LINE_STRING:
- coordinates[segmentData.index + index] = vertex;
- segment[index] = vertex;
- break;
- case ol.geom.GeometryType.MULTI_LINE_STRING:
- coordinates[depth[0]][segmentData.index + index] = vertex;
- break;
- case ol.geom.GeometryType.POLYGON:
- break;
- case ol.geom.GeometryType.MULTI_POLYGON:
- coordinates[depth[1]][depth[0]][segmentData.index + index] = vertex;
- break;
- case ol.geom.GeometryType.CIRCLE:
- if (segmentData.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX) {
- this.changingFeature_ = true;
- geometry.setCenter(vertex);
- } else { // We're dragging the circle's circumference:
- geometry.setRadius(ol.coordinate.distance(geometry.getCenter(), vertex));
- break;
- default:
- // pass
- if (coordinates) {
- this.setGeometryCoordinates_(geometry, coordinates);
- this.createOrUpdateVertexFeature_(vertex);
- * @private
-ol.interaction.Modify.handleUpEvent_ = function(evt) {
- var segmentData;
- var geometry;
- for (var i = this.dragSegments_.length - 1; i >= 0; --i) {
- segmentData = this.dragSegments_[i][0];
- geometry = segmentData.geometry;
- if (geometry.getType() === ol.geom.GeometryType.CIRCLE) {
- // Update a circle object in the R* bush:
- var centerSegmentData = segmentData.featureSegments[0];
- var circumferenceSegmentData = segmentData.featureSegments[1];
- centerSegmentData.segment[0] = centerSegmentData.segment[1] = coordinates;
- circumferenceSegmentData.segment[0] = circumferenceSegmentData.segment[1] = coordinates;
- this.rBush_.update(ol.extent.createOrUpdateFromCoordinate(coordinates), centerSegmentData);
- this.rBush_.update(geometry.getExtent(), circumferenceSegmentData);
- } else {
- this.rBush_.update(ol.extent.boundingExtent(segmentData.segment),
- segmentData);
- if (this.modified_) {
- ol.interaction.ModifyEventType.MODIFYEND, this.features_, evt));
- return false;
- * Handles the {@link ol.MapBrowserEvent map browser event} and may modify the
- * geometry.
- * @param {ol.MapBrowserEvent} mapBrowserEvent Map browser event.
- * @api
-ol.interaction.Modify.handleEvent = function(mapBrowserEvent) {
- return true;
- this.lastPointerEvent_ = mapBrowserEvent;
- var handled;
- if (!mapBrowserEvent.map.getView().getHints()[ol.ViewHint.INTERACTING] &&
- mapBrowserEvent.type == ol.MapBrowserEventType.POINTERMOVE &&
- !this.handlingDownUpSequence) {
- if (this.vertexFeature_ && this.deleteCondition_(mapBrowserEvent)) {
- if (mapBrowserEvent.type != ol.MapBrowserEventType.SINGLECLICK ||
- !this.ignoreNextSingleClick_) {
- handled = this.removePoint();
- } else {
- handled = true;
- if (mapBrowserEvent.type == ol.MapBrowserEventType.SINGLECLICK) {
- return ol.interaction.Pointer.handleEvent.call(this, mapBrowserEvent) &&
- !handled;
- * @param {ol.MapBrowserEvent} evt Event.
- * @private
-ol.interaction.Modify.prototype.handlePointerMove_ = function(evt) {
- this.lastPixel_ = evt.pixel;
- * @param {ol.Pixel} pixel Pixel
- * @param {ol.Map} map Map.
- * @private
-ol.interaction.Modify.prototype.handlePointerAtPixel_ = function(pixel, map) {
- return ol.interaction.Modify.pointDistanceToSegmentDataSquared_(pixelCoordinate, a) -
- ol.interaction.Modify.pointDistanceToSegmentDataSquared_(pixelCoordinate, b);
- var box = ol.extent.buffer(
- ol.extent.createOrUpdateFromCoordinate(pixelCoordinate),
- map.getView().getResolution() * this.pixelTolerance_);
- var nodes = rBush.getInExtent(box);
- if (nodes.length > 0) {
- nodes.sort(sortByDistance);
- var node = nodes[0];
- var closestSegment = node.segment;
- var vertex = ol.interaction.Modify.closestOnSegmentData_(pixelCoordinate, node);
- var dist = ol.coordinate.distance(pixel, vertexPixel);
- if (dist <= this.pixelTolerance_) {
- var vertexSegments = {};
- if (node.geometry.getType() === ol.geom.GeometryType.CIRCLE &&
- node.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
- this.snappedToVertex_ = true;
- } else {
- dist = Math.sqrt(Math.min(squaredDist1, squaredDist2));
- var segment;
- for (var i = 1, ii = nodes.length; i < ii; ++i) {
- segment = nodes[i].segment;
- if ((ol.coordinate.equals(closestSegment[0], segment[0]) &&
- ol.coordinate.equals(closestSegment[1], segment[1]) ||
- (ol.coordinate.equals(closestSegment[0], segment[1]) &&
- ol.coordinate.equals(closestSegment[1], segment[0])))) {
- vertexSegments[ol.getUid(segment)] = true;
- } else {
- break;
- vertexSegments[ol.getUid(closestSegment)] = true;
- this.vertexSegments_ = vertexSegments;
- return;
- if (this.vertexFeature_) {
- * Returns the distance from a point to a line segment.
- * @param {ol.Coordinate} pointCoordinates The coordinates of the point from
- * which to calculate the distance.
- * @param {ol.ModifySegmentDataType} segmentData The object describing the line
- * segment we are calculating the distance to.
- * @return {number} The square of the distance between a point and a line segment.
-ol.interaction.Modify.pointDistanceToSegmentDataSquared_ = function(pointCoordinates, segmentData) {
- var circleGeometry = /** @type {ol.geom.Circle} */ (geometry);
- if (segmentData.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
- var distanceToCenterSquared =
- ol.coordinate.squaredDistance(circleGeometry.getCenter(), pointCoordinates);
- var distanceToCircumference =
- Math.sqrt(distanceToCenterSquared) - circleGeometry.getRadius();
- return distanceToCircumference * distanceToCircumference;
- return ol.coordinate.squaredDistanceToSegment(pointCoordinates, segmentData.segment);
- * Returns the point closest to a given line segment.
- * @param {ol.Coordinate} pointCoordinates The point to which a closest point
- * should be found.
- * segment which should contain the closest point.
- * @return {ol.Coordinate} The point closest to the specified line segment.
-ol.interaction.Modify.closestOnSegmentData_ = function(pointCoordinates, segmentData) {
- if (geometry.getType() === ol.geom.GeometryType.CIRCLE &&
- segmentData.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
- return geometry.getClosestPoint(pointCoordinates);
- return ol.coordinate.closestOnSegment(pointCoordinates, segmentData.segment);
- * @param {ol.ModifySegmentDataType} segmentData Segment data.
- * @param {ol.Coordinate} vertex Vertex.
- * @private
-ol.interaction.Modify.prototype.insertVertex_ = function(segmentData, vertex) {
- var feature = segmentData.feature;
- var index = /** @type {number} */ (segmentData.index);
- var coordinates;
- vertex.push(0);
- coordinates[depth[0]].splice(index + 1, 0, vertex);
- break;
- break;
- coordinates[depth[1]][depth[0]].splice(index + 1, 0, vertex);
- break;
- coordinates.splice(index + 1, 0, vertex);
- break;
- default:
- return;
- var rTree = this.rBush_;
- rTree.remove(segmentData);
- this.updateSegmentIndices_(geometry, index, depth, 1);
- var newSegmentData = /** @type {ol.ModifySegmentDataType} */ ({
- segment: [segment[0], vertex],
- feature: feature,
- depth: depth,
- index: index
- rTree.insert(ol.extent.boundingExtent(newSegmentData.segment),
- newSegmentData);
- this.dragSegments_.push([newSegmentData, 1]);
- var newSegmentData2 = /** @type {ol.ModifySegmentDataType} */ ({
- segment: [vertex, segment[1]],
- feature: feature,
- depth: depth,
- index: index + 1
- rTree.insert(ol.extent.boundingExtent(newSegmentData2.segment),
- newSegmentData2);
- this.dragSegments_.push([newSegmentData2, 0]);
- this.ignoreNextSingleClick_ = true;
- * Removes the vertex currently being pointed.
- * @return {boolean} True when a vertex was removed.
- * @api
-ol.interaction.Modify.prototype.removePoint = function() {
- if (this.lastPointerEvent_ && this.lastPointerEvent_.type != ol.MapBrowserEventType.POINTERDRAG) {
- var evt = this.lastPointerEvent_;
- this.removeVertex_();
- return true;
- return false;
- * Removes a vertex from all matching features.
- * @private
-ol.interaction.Modify.prototype.removeVertex_ = function() {
- var dragSegments = this.dragSegments_;
- var segmentsByFeature = {};
- var deleted = false;
- var component, coordinates, dragSegment, geometry, i, index, left;
- var newIndex, right, segmentData, uid;
- for (i = dragSegments.length - 1; i >= 0; --i) {
- dragSegment = dragSegments[i];
- segmentData = dragSegment[0];
- uid = ol.getUid(segmentData.feature);
- if (segmentData.depth) {
- // separate feature components
- uid += '-' + segmentData.depth.join('-');
- if (!(uid in segmentsByFeature)) {
- segmentsByFeature[uid] = {};
- if (dragSegment[1] === 0) {
- segmentsByFeature[uid].right = segmentData;
- segmentsByFeature[uid].index = segmentData.index;
- } else if (dragSegment[1] == 1) {
- segmentsByFeature[uid].left = segmentData;
- segmentsByFeature[uid].index = segmentData.index + 1;
- for (uid in segmentsByFeature) {
- right = segmentsByFeature[uid].right;
- left = segmentsByFeature[uid].left;
- index = segmentsByFeature[uid].index;
- newIndex = index - 1;
- if (left !== undefined) {
- segmentData = left;
- } else {
- segmentData = right;
- if (newIndex < 0) {
- newIndex = 0;
- component = coordinates;
- deleted = false;
- if (coordinates[segmentData.depth[0]].length > 2) {
- coordinates[segmentData.depth[0]].splice(index, 1);
- deleted = true;
- break;
- if (coordinates.length > 2) {
- coordinates.splice(index, 1);
- deleted = true;
- break;
- component = component[segmentData.depth[1]];
- /* falls through */
- component = component[segmentData.depth[0]];
- if (component.length > 4) {
- if (index == component.length - 1) {
- index = 0;
- component.splice(index, 1);
- deleted = true;
- if (index === 0) {
- // close the ring again
- component.pop();
- component.push(component[0]);
- newIndex = component.length - 1;
- break;
- default:
- // pass
- if (deleted) {
- var segments = [];
- this.rBush_.remove(left);
- segments.push(left.segment[0]);
- if (right !== undefined) {
- this.rBush_.remove(right);
- segments.push(right.segment[1]);
- if (left !== undefined && right !== undefined) {
- depth: segmentData.depth,
- feature: segmentData.feature,
- geometry: segmentData.geometry,
- index: newIndex,
- segment: segments
- this.rBush_.insert(ol.extent.boundingExtent(newSegmentData.segment),
- newSegmentData);
- this.updateSegmentIndices_(geometry, index, segmentData.depth, -1);
- dragSegments.length = 0;
- return deleted;
- * @param {ol.geom.SimpleGeometry} geometry Geometry.
- * @param {Array} coordinates Coordinates.
- * @private
-ol.interaction.Modify.prototype.setGeometryCoordinates_ = function(geometry, coordinates) {
- * @param {number} index Index.
- * @param {Array.<number>|undefined} depth Depth.
- * @param {number} delta Delta (1 or -1).
- * @private
-ol.interaction.Modify.prototype.updateSegmentIndices_ = function(
- geometry, index, depth, delta) {
- this.rBush_.forEachInExtent(geometry.getExtent(), function(segmentDataMatch) {
- if (segmentDataMatch.geometry === geometry &&
- (depth === undefined || segmentDataMatch.depth === undefined ||
- ol.array.equals(segmentDataMatch.depth, depth)) &&
- segmentDataMatch.index > index) {
- segmentDataMatch.index += delta;
-ol.interaction.Modify.getDefaultStyleFunction = function() {
- * @classdesc
- * Events emitted by {@link ol.interaction.Modify} instances are instances of
- * this type.
- * @constructor
- * @implements {oli.ModifyEvent}
- * @param {ol.interaction.ModifyEventType} type Type.
- * @param {ol.Collection.<ol.Feature>} features The features modified.
- * @param {ol.MapBrowserPointerEvent} mapBrowserPointerEvent Associated
- * {@link ol.MapBrowserPointerEvent}.
-ol.interaction.Modify.Event = function(type, features, mapBrowserPointerEvent) {
- * The features being modified.
- * @type {ol.Collection.<ol.Feature>}
- * @api
- this.features = features;
- * Associated {@link ol.MapBrowserEvent}.
- * @type {ol.MapBrowserEvent}
- * @api
- this.mapBrowserEvent = mapBrowserPointerEvent;
-ol.inherits(ol.interaction.Modify.Event, ol.events.Event);
-goog.provide('ol.interaction.Select');
-goog.require('ol.CollectionEventType');
-goog.require('ol.array');
-goog.require('ol.events.Event');
-goog.require('ol.interaction.Interaction');
-goog.require('ol.obj');
- * @classdesc
- * Interaction for selecting vector features. By default, selected features are
- * styled differently, so this interaction can be used for visual highlighting,
- * as well as selecting features for other actions, such as modification or
- * output. There are three ways of controlling which features are selected:
- * using the browser event as defined by the `condition` and optionally the
- * `toggle`, `add`/`remove`, and `multi` options; a `layers` filter; and a
- * further feature filter using the `filter` option.
- * Selected features are added to an internal unmanaged layer.
- * @constructor
- * @extends {ol.interaction.Interaction}
- * @param {olx.interaction.SelectOptions=} opt_options Options.
- * @fires ol.interaction.Select.Event
- * @api
-ol.interaction.Select = function(opt_options) {
- ol.interaction.Interaction.call(this, {
- handleEvent: ol.interaction.Select.handleEvent
- var options = opt_options ? opt_options : {};
- * @private
- options.condition : ol.events.condition.singleClick;
- * @private
- this.addCondition_ = options.addCondition ?
- options.addCondition : ol.events.condition.never;
- * @private
- this.removeCondition_ = options.removeCondition ?
- options.removeCondition : ol.events.condition.never;
- * @private
- this.toggleCondition_ = options.toggleCondition ?
- options.toggleCondition : ol.events.condition.shiftKeyOnly;
- * @private
- * @type {boolean}
- this.multi_ = options.multi ? options.multi : false;
- * @private
- * @type {ol.SelectFilterFunction}
- this.filter_ = options.filter ? options.filter :
- ol.functions.TRUE;
- * @private
- * @type {number}
- this.hitTolerance_ = options.hitTolerance ? options.hitTolerance : 0;
- var featureOverlay = new ol.layer.Vector({
- features: options.features,
- ol.interaction.Select.getDefaultStyleFunction(),
- * @private
- this.featureOverlay_ = featureOverlay;
- /** @type {function(ol.layer.Layer): boolean} */
- var layerFilter;
- if (options.layers) {
- if (typeof options.layers === 'function') {
- layerFilter = options.layers;
- } else {
- var layers = options.layers;
- layerFilter = function(layer) {
- return ol.array.includes(layers, layer);
- } else {
- layerFilter = ol.functions.TRUE;
- * @private
- * @type {function(ol.layer.Layer): boolean}
- this.layerFilter_ = layerFilter;
- * An association between selected feature (key)
- * and layer (value)
- * @private
- * @type {Object.<number, ol.layer.Layer>}
- this.featureLayerAssociation_ = {};
- var features = this.featureOverlay_.getSource().getFeaturesCollection();
- ol.events.listen(features, ol.CollectionEventType.ADD,
- this.addFeature_, this);
- ol.events.listen(features, ol.CollectionEventType.REMOVE,
- this.removeFeature_, this);
-ol.inherits(ol.interaction.Select, ol.interaction.Interaction);
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- * @param {ol.layer.Layer} layer Layer.
- * @private
-ol.interaction.Select.prototype.addFeatureLayerAssociation_ = function(feature, layer) {
- var key = ol.getUid(feature);
- this.featureLayerAssociation_[key] = layer;
- * Get the selected features.
- * @return {ol.Collection.<ol.Feature>} Features collection.
- * @api
-ol.interaction.Select.prototype.getFeatures = function() {
- return this.featureOverlay_.getSource().getFeaturesCollection();
- * Returns the Hit-detection tolerance.
- * @returns {number} Hit tolerance in pixels.
- * @api
-ol.interaction.Select.prototype.getHitTolerance = function() {
- return this.hitTolerance_;
- * Returns the associated {@link ol.layer.Vector vectorlayer} of
- * the (last) selected feature. Note that this will not work with any
- * programmatic method like pushing features to
- * {@link ol.interaction.Select#getFeatures collection}.
- * @return {ol.layer.Vector} Layer.
- * @api
-ol.interaction.Select.prototype.getLayer = function(feature) {
- return /** @type {ol.layer.Vector} */ (this.featureLayerAssociation_[key]);
- * Handles the {@link ol.MapBrowserEvent map browser event} and may change the
- * selected state of features.
- * @this {ol.interaction.Select}
- * @api
-ol.interaction.Select.handleEvent = function(mapBrowserEvent) {
- if (!this.condition_(mapBrowserEvent)) {
- return true;
- var add = this.addCondition_(mapBrowserEvent);
- var remove = this.removeCondition_(mapBrowserEvent);
- var toggle = this.toggleCondition_(mapBrowserEvent);
- var set = !add && !remove && !toggle;
- var deselected = [];
- var selected = [];
- if (set) {
- // Replace the currently selected feature(s) with the feature(s) at the
- // pixel, or clear the selected feature(s) if there is no feature at
- // the pixel.
- ol.obj.clear(this.featureLayerAssociation_);
- map.forEachFeatureAtPixel(mapBrowserEvent.pixel,
- * @return {boolean|undefined} Continue to iterate over the features.
- function(feature, layer) {
- if (this.filter_(feature, layer)) {
- selected.push(feature);
- this.addFeatureLayerAssociation_(feature, layer);
- return !this.multi_;
- }).bind(this), {
- layerFilter: this.layerFilter_,
- hitTolerance: this.hitTolerance_
- var i;
- for (i = features.getLength() - 1; i >= 0; --i) {
- var feature = features.item(i);
- var index = selected.indexOf(feature);
- if (index > -1) {
- // feature is already selected
- selected.splice(index, 1);
- } else {
- features.remove(feature);
- deselected.push(feature);
- if (selected.length !== 0) {
- features.extend(selected);
- } else {
- // Modify the currently selected feature(s).
- if ((add || toggle) &&
- !ol.array.includes(features.getArray(), feature)) {
- } else if ((remove || toggle) &&
- ol.array.includes(features.getArray(), feature)) {
- this.removeFeatureLayerAssociation_(feature);
- }).bind(this), {
- var j;
- for (j = deselected.length - 1; j >= 0; --j) {
- features.remove(deselected[j]);
- if (selected.length > 0 || deselected.length > 0) {
- new ol.interaction.Select.Event(ol.interaction.Select.EventType_.SELECT,
- selected, deselected, mapBrowserEvent));
- return ol.events.condition.pointerMove(mapBrowserEvent);
- * Hit-detection tolerance. Pixels inside the radius around the given position
- * will be checked for features. This only works for the canvas renderer and
- * not for WebGL.
- * @param {number} hitTolerance Hit tolerance in pixels.
- * @api
-ol.interaction.Select.prototype.setHitTolerance = function(hitTolerance) {
- this.hitTolerance_ = hitTolerance;
- * Remove the interaction from its current map, if any, and attach it to a new
- * map, if any. Pass `null` to just remove the interaction from the current map.
- * @override
- * @api
-ol.interaction.Select.prototype.setMap = function(map) {
- var currentMap = this.getMap();
- var selectedFeatures =
- this.featureOverlay_.getSource().getFeaturesCollection();
- if (currentMap) {
- selectedFeatures.forEach(currentMap.unskipFeature, currentMap);
- ol.interaction.Interaction.prototype.setMap.call(this, map);
- this.featureOverlay_.setMap(map);
- if (map) {
- selectedFeatures.forEach(map.skipFeature, map);
-ol.interaction.Select.getDefaultStyleFunction = function() {
- ol.array.extend(styles[ol.geom.GeometryType.POLYGON],
- styles[ol.geom.GeometryType.LINE_STRING]);
- ol.array.extend(styles[ol.geom.GeometryType.GEOMETRY_COLLECTION],
- if (!feature.getGeometry()) {
- return null;
- * @private
-ol.interaction.Select.prototype.addFeature_ = function(evt) {
- if (map) {
- map.skipFeature(/** @type {ol.Feature} */ (evt.element));
- * @private
-ol.interaction.Select.prototype.removeFeature_ = function(evt) {
- if (map) {
- map.unskipFeature(/** @type {ol.Feature} */ (evt.element));
- * @private
-ol.interaction.Select.prototype.removeFeatureLayerAssociation_ = function(feature) {
- delete this.featureLayerAssociation_[key];
- * @classdesc
- * Events emitted by {@link ol.interaction.Select} instances are instances of
- * this type.
- * @param {ol.interaction.Select.EventType_} type The event type.
- * @param {Array.<ol.Feature>} selected Selected features.
- * @param {Array.<ol.Feature>} deselected Deselected features.
- * @param {ol.MapBrowserEvent} mapBrowserEvent Associated
- * {@link ol.MapBrowserEvent}.
- * @implements {oli.SelectEvent}
- * @extends {ol.events.Event}
- * @constructor
-ol.interaction.Select.Event = function(type, selected, deselected, mapBrowserEvent) {
- ol.events.Event.call(this, type);
- * Selected features array.
- * @type {Array.<ol.Feature>}
- * @api
- this.selected = selected;
- * Deselected features array.
- * @api
- this.deselected = deselected;
- * @api
- this.mapBrowserEvent = mapBrowserEvent;
-ol.inherits(ol.interaction.Select.Event, ol.events.Event);
- * @enum {string}
- * @private
-ol.interaction.Select.EventType_ = {
- * Triggered when feature(s) has been (de)selected.
- * @event ol.interaction.Select.Event#select
- * @api
- SELECT: 'select'
-goog.provide('ol.interaction.Snap');
-goog.require('ol');
-goog.require('ol.Collection');
-goog.require('ol.coordinate');
-goog.require('ol.events');
-goog.require('ol.functions');
-goog.require('ol.interaction.Pointer');
-goog.require('ol.source.Vector');
-goog.require('ol.source.VectorEventType');
-goog.require('ol.structs.RBush');
- * @classdesc
- * Handles snapping of vector features while modifying or drawing them. The
- * features can come from a {@link ol.source.Vector} or {@link ol.Collection}
- * Any interaction object that allows the user to interact
- * with the features using the mouse can benefit from the snapping, as long
- * as it is added before.
- * The snap interaction modifies map browser event `coordinate` and `pixel`
- * properties to force the snap to occur to any interaction that them.
- * Example:
- * var snap = new ol.interaction.Snap({
- * source: source
- * @constructor
- * @extends {ol.interaction.Pointer}
- * @param {olx.interaction.SnapOptions=} opt_options Options.
- * @api
-ol.interaction.Snap = function(opt_options) {
- ol.interaction.Pointer.call(this, {
- handleEvent: ol.interaction.Snap.handleEvent_,
- handleDownEvent: ol.functions.TRUE,
- handleUpEvent: ol.interaction.Snap.handleUpEvent_
- * @type {ol.source.Vector}
- * @private
- this.source_ = options.source ? options.source : null;
- * @private
- * @type {boolean}
- this.vertex_ = options.vertex !== undefined ? options.vertex : true;
- * @private
- * @type {boolean}
- this.edge_ = options.edge !== undefined ? options.edge : true;
- * @private
- this.features_ = options.features ? options.features : null;
- * @type {Array.<ol.EventsKey>}
- * @private
- this.featuresListenerKeys_ = [];
- * @type {Object.<number, ol.EventsKey>}
- * @private
- this.featureChangeListenerKeys_ = {};
- * Extents are preserved so indexed segment can be quickly removed
- * when its feature geometry changes
- * @type {Object.<number, ol.Extent>}
- * @private
- this.indexedFeaturesExtents_ = {};
- * If a feature geometry changes while a pointer drag|move event occurs, the
- * feature doesn't get updated right away. It will be at the next 'pointerup'
- * event fired.
- * @type {Object.<number, ol.Feature>}
- * @private
- this.pendingFeatures_ = {};
- * Used for distance sorting in sortByDistance_
- * @type {ol.Coordinate}
- * @private
- this.pixelCoordinate_ = null;
- * @type {number}
- * @private
- * @type {function(ol.SnapSegmentDataType, ol.SnapSegmentDataType): number}
- * @private
- this.sortByDistance_ = ol.interaction.Snap.sortByDistance.bind(this);
- * @type {ol.structs.RBush.<ol.SnapSegmentDataType>}
- * @private
- * @const
- * @private
-ol.inherits(ol.interaction.Snap, ol.interaction.Pointer);
- * Add a feature to the collection of features that we may snap to.
- * @param {boolean=} opt_listen Whether to listen to the feature change or not
- * Defaults to `true`.
- * @api
-ol.interaction.Snap.prototype.addFeature = function(feature, opt_listen) {
- var listen = opt_listen !== undefined ? opt_listen : true;
- var feature_uid = ol.getUid(feature);
- var geometry = feature.getGeometry();
- if (geometry) {
- var segmentWriter = this.SEGMENT_WRITERS_[geometry.getType()];
- if (segmentWriter) {
- this.indexedFeaturesExtents_[feature_uid] = geometry.getExtent(
- ol.extent.createEmpty());
- segmentWriter.call(this, feature, geometry);
- if (listen) {
- this.featureChangeListenerKeys_[feature_uid] = ol.events.listen(
- feature,
- ol.events.EventType.CHANGE,
- * @private
-ol.interaction.Snap.prototype.forEachFeatureAdd_ = function(feature) {
- this.addFeature(feature);
- * @private
-ol.interaction.Snap.prototype.forEachFeatureRemove_ = function(feature) {
- this.removeFeature(feature);
- * @return {ol.Collection.<ol.Feature>|Array.<ol.Feature>} Features.
- * @private
-ol.interaction.Snap.prototype.getFeatures_ = function() {
- var features;
- features = this.features_;
- } else if (this.source_) {
- features = this.source_.getFeatures();
- return /** @type {!Array.<ol.Feature>|!ol.Collection.<ol.Feature>} */ (features);
- * @param {ol.source.Vector.Event|ol.Collection.Event} evt Event.
- * @private
-ol.interaction.Snap.prototype.handleFeatureAdd_ = function(evt) {
- var feature;
- if (evt instanceof ol.source.Vector.Event) {
- feature = evt.feature;
- } else if (evt instanceof ol.Collection.Event) {
- feature = evt.element;
- this.addFeature(/** @type {ol.Feature} */ (feature));
- * @private
-ol.interaction.Snap.prototype.handleFeatureRemove_ = function(evt) {
- var feature;
- this.removeFeature(/** @type {ol.Feature} */ (feature));
- * @private
-ol.interaction.Snap.prototype.handleFeatureChange_ = function(evt) {
- if (this.handlingDownUpSequence) {
- var uid = ol.getUid(feature);
- if (!(uid in this.pendingFeatures_)) {
- this.pendingFeatures_[uid] = feature;
- } else {
- this.updateFeature_(feature);
- * Remove a feature from the collection of features that we may snap to.
- * @param {boolean=} opt_unlisten Whether to unlisten to the feature change
- * or not. Defaults to `true`.
- * @api
-ol.interaction.Snap.prototype.removeFeature = function(feature, opt_unlisten) {
- var unlisten = opt_unlisten !== undefined ? opt_unlisten : true;
- var extent = this.indexedFeaturesExtents_[feature_uid];
- if (extent) {
- var i, nodesToRemove = [];
- rBush.forEachInExtent(extent, function(node) {
- for (i = nodesToRemove.length - 1; i >= 0; --i) {
- if (unlisten) {
- ol.events.unlistenByKey(this.featureChangeListenerKeys_[feature_uid]);
- delete this.featureChangeListenerKeys_[feature_uid];
- * @inheritDoc
-ol.interaction.Snap.prototype.setMap = function(map) {
- var keys = this.featuresListenerKeys_;
- var features = this.getFeatures_();
- if (currentMap) {
- keys.forEach(ol.events.unlistenByKey);
- keys.length = 0;
- features.forEach(this.forEachFeatureRemove_, this);
- ol.interaction.Pointer.prototype.setMap.call(this, map);
- if (map) {
- keys.push(
- this.handleFeatureAdd_, this),
- keys.push(
- ol.events.listen(this.source_, ol.source.VectorEventType.ADDFEATURE,
- ol.events.listen(this.source_, ol.source.VectorEventType.REMOVEFEATURE,
- features.forEach(this.forEachFeatureAdd_, this);
- * @inheritDoc
-ol.interaction.Snap.prototype.shouldStopEvent = ol.functions.FALSE;
- * @param {ol.Coordinate} pixelCoordinate Coordinate
- * @return {ol.SnapResultType} Snap result
-ol.interaction.Snap.prototype.snapTo = function(pixel, pixelCoordinate, map) {
- var lowerLeft = map.getCoordinateFromPixel(
- [pixel[0] - this.pixelTolerance_, pixel[1] + this.pixelTolerance_]);
- var upperRight = map.getCoordinateFromPixel(
- [pixel[0] + this.pixelTolerance_, pixel[1] - this.pixelTolerance_]);
- var box = ol.extent.boundingExtent([lowerLeft, upperRight]);
- var segments = this.rBush_.getInExtent(box);
- var snappedToVertex = false;
- var snapped = false;
- var vertex = null;
- var vertexPixel = null;
- var dist, pixel1, pixel2, squaredDist1, squaredDist2;
- if (segments.length > 0) {
- this.pixelCoordinate_ = pixelCoordinate;
- segments.sort(this.sortByDistance_);
- var closestSegment = segments[0].segment;
- if (this.vertex_ && !this.edge_) {
- pixel1 = map.getPixelFromCoordinate(closestSegment[0]);
- pixel2 = map.getPixelFromCoordinate(closestSegment[1]);
- squaredDist1 = ol.coordinate.squaredDistance(pixel, pixel1);
- squaredDist2 = ol.coordinate.squaredDistance(pixel, pixel2);
- snappedToVertex = dist <= this.pixelTolerance_;
- if (snappedToVertex) {
- snapped = true;
- vertexPixel = map.getPixelFromCoordinate(vertex);
- } else if (this.edge_) {
- vertex = (ol.coordinate.closestOnSegment(pixelCoordinate,
- closestSegment));
- snapped = true;
- if (this.vertex_) {
- squaredDist1 = ol.coordinate.squaredDistance(vertexPixel, pixel1);
- squaredDist2 = ol.coordinate.squaredDistance(vertexPixel, pixel2);
- if (snapped) {
- vertexPixel = [Math.round(vertexPixel[0]), Math.round(vertexPixel[1])];
- return /** @type {ol.SnapResultType} */ ({
- snapped: snapped,
- vertex: vertex,
- vertexPixel: vertexPixel
- * @private
-ol.interaction.Snap.prototype.updateFeature_ = function(feature) {
- this.removeFeature(feature, false);
- this.addFeature(feature, false);
- * @private
-ol.interaction.Snap.prototype.writeGeometryCollectionGeometry_ = function(feature, geometry) {
- * @private
-ol.interaction.Snap.prototype.writeLineStringGeometry_ = function(feature, geometry) {
- segmentData = /** @type {ol.SnapSegmentDataType} */ ({
- feature: feature,
- segment: segment
- * @private
-ol.interaction.Snap.prototype.writeMultiLineStringGeometry_ = function(feature, geometry) {
- feature: feature,
- segment: segment
- * @private
-ol.interaction.Snap.prototype.writeMultiPointGeometry_ = function(feature, geometry) {
- feature: feature,
- * @private
-ol.interaction.Snap.prototype.writeMultiPolygonGeometry_ = function(feature, geometry) {
- feature: feature,
- segment: segment
- * @private
-ol.interaction.Snap.prototype.writePointGeometry_ = function(feature, geometry) {
- var segmentData = /** @type {ol.SnapSegmentDataType} */ ({
- feature: feature,
- * @private
-ol.interaction.Snap.prototype.writePolygonGeometry_ = function(feature, geometry) {
- feature: feature,
- segment: segment
- * Handle all pointer events events.
- * @param {ol.MapBrowserEvent} evt A move event.
- * @return {boolean} Pass the event to other interactions.
- * @this {ol.interaction.Snap}
- * @private
-ol.interaction.Snap.handleEvent_ = function(evt) {
- var result = this.snapTo(evt.pixel, evt.coordinate, evt.map);
- if (result.snapped) {
- evt.coordinate = result.vertex.slice(0, 2);
- evt.pixel = result.vertexPixel;
- return ol.interaction.Pointer.handleEvent.call(this, evt);
- * @return {boolean} Stop drag sequence?
- * @private
-ol.interaction.Snap.handleUpEvent_ = function(evt) {
- var featuresToUpdate = ol.obj.getValues(this.pendingFeatures_);
- if (featuresToUpdate.length) {
- featuresToUpdate.forEach(this.updateFeature_, this);
- return false;
- * Sort segments by distance, helper function
- * @param {ol.SnapSegmentDataType} a The first segment data.
- * @param {ol.SnapSegmentDataType} b The second segment data.
- * @return {number} The difference in distance.
-ol.interaction.Snap.sortByDistance = function(a, b) {
- this.pixelCoordinate_, a.segment) -
- this.pixelCoordinate_, b.segment);
-goog.provide('ol.interaction.TranslateEventType');
- * @enum {string}
-ol.interaction.TranslateEventType = {
- * Triggered upon feature translation start.
- * @event ol.interaction.Translate.Event#translatestart
- * @api
- TRANSLATESTART: 'translatestart',
- * Triggered upon feature translation.
- * @event ol.interaction.Translate.Event#translating
- * @api
- TRANSLATING: 'translating',
- * Triggered upon feature translation end.
- * @event ol.interaction.Translate.Event#translateend
- * @api
- TRANSLATEEND: 'translateend'
-goog.provide('ol.interaction.Translate');
-goog.require('ol.interaction.TranslateEventType');
- * @classdesc
- * Interaction for translating (moving) features.
- * @constructor
- * @fires ol.interaction.Translate.Event
- * @param {olx.interaction.TranslateOptions=} opt_options Options.
- * @api
-ol.interaction.Translate = function(opt_options) {
- handleDownEvent: ol.interaction.Translate.handleDownEvent_,
- handleDragEvent: ol.interaction.Translate.handleDragEvent_,
- handleMoveEvent: ol.interaction.Translate.handleMoveEvent_,
- handleUpEvent: ol.interaction.Translate.handleUpEvent_
- * @type {string|undefined}
- * @private
- this.previousCursor_ = undefined;
- * The last position we translated to.
- * @private
- this.lastCoordinate_ = null;
- * @private
- this.features_ = options.features !== undefined ? options.features : null;
- var layerFilter;
- } else {
- } else {
- * @private
- * @private
- * @type {number}
- * @type {ol.Feature}
- * @private
- this.lastFeature_ = null;
- ol.events.listen(this,
- ol.Object.getChangeEventType(ol.interaction.Property.ACTIVE),
- this.handleActiveChanged_, this);
-ol.inherits(ol.interaction.Translate, ol.interaction.Pointer);
- * @param {ol.MapBrowserPointerEvent} event Event.
- * @return {boolean} Start drag sequence?
- * @this {ol.interaction.Translate}
- * @private
-ol.interaction.Translate.handleDownEvent_ = function(event) {
- this.lastFeature_ = this.featuresAtPixel_(event.pixel, event.map);
- if (!this.lastCoordinate_ && this.lastFeature_) {
- this.lastCoordinate_ = event.coordinate;
- ol.interaction.Translate.handleMoveEvent_.call(this, event);
- var features = this.features_ || new ol.Collection([this.lastFeature_]);
- new ol.interaction.Translate.Event(
- ol.interaction.TranslateEventType.TRANSLATESTART, features,
- event.coordinate));
- return true;
- return false;
- * @private
-ol.interaction.Translate.handleUpEvent_ = function(event) {
- if (this.lastCoordinate_) {
- ol.interaction.TranslateEventType.TRANSLATEEND, features,
- return true;
- return false;
- * @private
-ol.interaction.Translate.handleDragEvent_ = function(event) {
- var newCoordinate = event.coordinate;
- var deltaX = newCoordinate[0] - this.lastCoordinate_[0];
- var deltaY = newCoordinate[1] - this.lastCoordinate_[1];
- features.forEach(function(feature) {
- var geom = feature.getGeometry();
- geom.translate(deltaX, deltaY);
- feature.setGeometry(geom);
- this.lastCoordinate_ = newCoordinate;
- ol.interaction.TranslateEventType.TRANSLATING, features,
- newCoordinate));
- * @param {ol.MapBrowserEvent} event Event.
- * @private
-ol.interaction.Translate.handleMoveEvent_ = function(event) {
- var elem = event.map.getTargetElement();
- // Change the cursor to grab/grabbing if hovering any of the features managed
- // by the interaction
- if (this.featuresAtPixel_(event.pixel, event.map)) {
- this.previousCursor_ = this.previousCursor_ !== undefined ?
- this.previousCursor_ : elem.style.cursor;
- // WebKit browsers don't support the grab icons without a prefix
- elem.style.cursor = this.lastCoordinate_ ?
- '-webkit-grabbing' : '-webkit-grab';
- // Thankfully, attempting to set the standard ones will silently fail,
- // keeping the prefixed icons
- elem.style.cursor = this.lastCoordinate_ ? 'grabbing' : 'grab';
- } else if (this.previousCursor_ !== undefined) {
- elem.style.cursor = this.previousCursor_;
- * Tests to see if the given coordinates intersects any of our selected
- * features.
- * @param {ol.Pixel} pixel Pixel coordinate to test for intersection.
- * @param {ol.Map} map Map to test the intersection on.
- * @return {ol.Feature} Returns the feature found at the specified pixel
- * coordinates.
- * @private
-ol.interaction.Translate.prototype.featuresAtPixel_ = function(pixel, map) {
- return map.forEachFeatureAtPixel(pixel,
- function(feature) {
- if (!this.features_ ||
- ol.array.includes(this.features_.getArray(), feature)) {
- return feature;
- }.bind(this), {
- * @api
-ol.interaction.Translate.prototype.getHitTolerance = function() {
- * not for WebGL.
- * @api
-ol.interaction.Translate.prototype.setHitTolerance = function(hitTolerance) {
- * @inheritDoc
-ol.interaction.Translate.prototype.setMap = function(map) {
- var oldMap = this.getMap();
- this.updateState_(oldMap);
- * @private
-ol.interaction.Translate.prototype.handleActiveChanged_ = function() {
- this.updateState_(null);
- * @param {ol.Map} oldMap Old map.
- * @private
-ol.interaction.Translate.prototype.updateState_ = function(oldMap) {
- var map = this.getMap();
- var active = this.getActive();
- if ((!map || !active) && this.previousCursor_ !== undefined) {
- if (!map) {
- map = oldMap;
- var elem = map.getTargetElement();
- * @classdesc
- * Events emitted by {@link ol.interaction.Translate} instances are instances of
- * this type.
- * @constructor
- * @implements {oli.interaction.TranslateEvent}
- * @param {ol.interaction.TranslateEventType} type Type.
- * @param {ol.Collection.<ol.Feature>} features The features translated.
- * @param {ol.Coordinate} coordinate The event coordinate.
-ol.interaction.Translate.Event = function(type, features, coordinate) {
- * The features being translated.
- * @api
- * The coordinate of the drag event.
- * @const
- * @api
- this.coordinate = coordinate;
-ol.inherits(ol.interaction.Translate.Event, ol.events.Event);
-goog.provide('ol.layer.Heatmap');
-goog.require('ol.Object');
-goog.require('ol.dom');
-goog.require('ol.layer.Vector');
-goog.require('ol.math');
-goog.require('ol.render.EventType');
-goog.require('ol.style.Icon');
- * @classdesc
- * Layer for rendering vector data as a heatmap.
- * Note that any property set in the options is set as a {@link ol.Object}
- * property on the layer object; for example, setting `title: 'My Title'` in the
- * options means that `title` is observable, and has get/set accessors.
- * @constructor
- * @extends {ol.layer.Vector}
- * @fires ol.render.Event
- * @param {olx.layer.HeatmapOptions=} opt_options Options.
- * @api
-ol.layer.Heatmap = function(opt_options) {
- var baseOptions = ol.obj.assign({}, options);
- delete baseOptions.gradient;
- delete baseOptions.radius;
- delete baseOptions.blur;
- delete baseOptions.shadow;
- delete baseOptions.weight;
- ol.layer.Vector.call(this, /** @type {olx.layer.VectorOptions} */ (baseOptions));
- * @private
- * @type {Uint8ClampedArray}
- this.gradient_ = null;
- * @private
- * @type {number}
- this.shadow_ = options.shadow !== undefined ? options.shadow : 250;
- * @private
- this.circleImage_ = undefined;
- * @private
- * @type {Array.<Array.<ol.style.Style>>}
- this.styleCache_ = null;
- ol.Object.getChangeEventType(ol.layer.Heatmap.Property_.GRADIENT),
- this.handleGradientChanged_, this);
- this.setGradient(options.gradient ?
- options.gradient : ol.layer.Heatmap.DEFAULT_GRADIENT);
- this.setBlur(options.blur !== undefined ? options.blur : 15);
- this.setRadius(options.radius !== undefined ? options.radius : 8);
- ol.Object.getChangeEventType(ol.layer.Heatmap.Property_.BLUR),
- this.handleStyleChanged_, this);
- ol.Object.getChangeEventType(ol.layer.Heatmap.Property_.RADIUS),
- this.handleStyleChanged_();
- var weight = options.weight ? options.weight : 'weight';
- var weightFunction;
- if (typeof weight === 'string') {
- weightFunction = function(feature) {
- return feature.get(weight);
- } else {
- weightFunction = weight;
- this.setStyle(function(feature, resolution) {
- var weight = weightFunction(feature);
- var opacity = weight !== undefined ? ol.math.clamp(weight, 0, 1) : 1;
- // cast to 8 bits
- var index = (255 * opacity) | 0;
- var style = this.styleCache_[index];
- if (!style) {
- style = [
- new ol.style.Style({
- image: new ol.style.Icon({
- opacity: opacity,
- src: this.circleImage_
- this.styleCache_[index] = style;
- return style;
- }.bind(this));
- // For performance reasons, don't sort the features before rendering.
- // The render order is not relevant for a heatmap representation.
- this.setRenderOrder(null);
- ol.events.listen(this, ol.render.EventType.RENDER, this.handleRender_, this);
-ol.inherits(ol.layer.Heatmap, ol.layer.Vector);
- * @const
- * @type {Array.<string>}
-ol.layer.Heatmap.DEFAULT_GRADIENT = ['#00f', '#0ff', '#0f0', '#ff0', '#f00'];
- * @param {Array.<string>} colors A list of colored.
- * @return {Uint8ClampedArray} An array.
- * @private
-ol.layer.Heatmap.createGradient_ = function(colors) {
- var width = 1;
- var height = 256;
- var context = ol.dom.createCanvasContext2D(width, height);
- var gradient = context.createLinearGradient(0, 0, width, height);
- var step = 1 / (colors.length - 1);
- for (var i = 0, ii = colors.length; i < ii; ++i) {
- gradient.addColorStop(i * step, colors[i]);
- context.fillStyle = gradient;
- context.fillRect(0, 0, width, height);
- return context.getImageData(0, 0, width, height).data;
- * @return {string} Data URL for a circle.
- * @private
-ol.layer.Heatmap.prototype.createCircle_ = function() {
- var radius = this.getRadius();
- var blur = this.getBlur();
- var halfSize = radius + blur + 1;
- var size = 2 * halfSize;
- var context = ol.dom.createCanvasContext2D(size, size);
- context.shadowOffsetX = context.shadowOffsetY = this.shadow_;
- context.shadowBlur = blur;
- context.shadowColor = '#000';
- context.beginPath();
- var center = halfSize - this.shadow_;
- context.arc(center, center, radius, 0, Math.PI * 2, true);
- context.fill();
- return context.canvas.toDataURL();
- * Return the blur size in pixels.
- * @return {number} Blur size in pixels.
- * @api
- * @observable
-ol.layer.Heatmap.prototype.getBlur = function() {
- return /** @type {number} */ (this.get(ol.layer.Heatmap.Property_.BLUR));
- * Return the gradient colors as array of strings.
- * @return {Array.<string>} Colors.
- * @api
- * @observable
-ol.layer.Heatmap.prototype.getGradient = function() {
- return /** @type {Array.<string>} */ (
- this.get(ol.layer.Heatmap.Property_.GRADIENT));
- * Return the size of the radius in pixels.
- * @return {number} Radius size in pixel.
- * @api
- * @observable
-ol.layer.Heatmap.prototype.getRadius = function() {
- return /** @type {number} */ (this.get(ol.layer.Heatmap.Property_.RADIUS));
- * @private
-ol.layer.Heatmap.prototype.handleGradientChanged_ = function() {
- this.gradient_ = ol.layer.Heatmap.createGradient_(this.getGradient());
- * @private
-ol.layer.Heatmap.prototype.handleStyleChanged_ = function() {
- this.circleImage_ = this.createCircle_();
- this.styleCache_ = new Array(256);
- this.changed();
- * @param {ol.render.Event} event Post compose event
- * @private
-ol.layer.Heatmap.prototype.handleRender_ = function(event) {
- var context = event.context;
- var canvas = context.canvas;
- var image = context.getImageData(0, 0, canvas.width, canvas.height);
- var view8 = image.data;
- var i, ii, alpha;
- for (i = 0, ii = view8.length; i < ii; i += 4) {
- alpha = view8[i + 3] * 4;
- if (alpha) {
- view8[i] = this.gradient_[alpha];
- view8[i + 1] = this.gradient_[alpha + 1];
- view8[i + 2] = this.gradient_[alpha + 2];
- context.putImageData(image, 0, 0);
- * Set the blur size in pixels.
- * @param {number} blur Blur size in pixels.
- * @api
- * @observable
-ol.layer.Heatmap.prototype.setBlur = function(blur) {
- this.set(ol.layer.Heatmap.Property_.BLUR, blur);
- * Set the gradient colors as array of strings.
- * @param {Array.<string>} colors Gradient.
- * @api
- * @observable
-ol.layer.Heatmap.prototype.setGradient = function(colors) {
- this.set(ol.layer.Heatmap.Property_.GRADIENT, colors);
- * Set the size of the radius in pixels.
- * @param {number} radius Radius size in pixel.
- * @api
- * @observable
-ol.layer.Heatmap.prototype.setRadius = function(radius) {
- this.set(ol.layer.Heatmap.Property_.RADIUS, radius);
- * @enum {string}
- * @private
-ol.layer.Heatmap.Property_ = {
- BLUR: 'blur',
- GRADIENT: 'gradient',
- RADIUS: 'radius'
-goog.provide('ol.renderer.canvas.IntermediateCanvas');
-goog.require('ol.renderer.canvas.Layer');
-goog.require('ol.transform');
- * @constructor
- * @abstract
- * @extends {ol.renderer.canvas.Layer}
-ol.renderer.canvas.IntermediateCanvas = function(layer) {
- ol.renderer.canvas.Layer.call(this, layer);
- * @protected
- * @type {ol.Transform}
- this.coordinateToCanvasPixelTransform = ol.transform.create();
- * @private
- * @type {CanvasRenderingContext2D}
- this.hitCanvasContext_ = null;
-ol.inherits(ol.renderer.canvas.IntermediateCanvas, ol.renderer.canvas.Layer);
- * @inheritDoc
-ol.renderer.canvas.IntermediateCanvas.prototype.composeFrame = function(frameState, layerState, context) {
- this.preCompose(context, frameState);
- var image = this.getImage();
- if (image) {
- // clipped rendering if layer extent is set
- var extent = layerState.extent;
- var clipped = extent !== undefined &&
- !ol.extent.containsExtent(extent, frameState.extent) &&
- ol.extent.intersects(extent, frameState.extent);
- if (clipped) {
- this.clip(context, frameState, /** @type {ol.Extent} */ (extent));
- var imageTransform = this.getImageTransform();
- // for performance reasons, context.save / context.restore is not used
- // to save and restore the transformation matrix and the opacity.
- // see http://jsperf.com/context-save-restore-versus-variable
- var alpha = context.globalAlpha;
- context.globalAlpha = layerState.opacity;
- // for performance reasons, context.setTransform is only used
- // when the view is rotated. see http://jsperf.com/canvas-transform
- var dx = imageTransform[4];
- var dy = imageTransform[5];
- var dw = image.width * imageTransform[0];
- var dh = image.height * imageTransform[3];
- context.drawImage(image, 0, 0, +image.width, +image.height,
- Math.round(dx), Math.round(dy), Math.round(dw), Math.round(dh));
- context.globalAlpha = alpha;
- if (clipped) {
- context.restore();
- this.postCompose(context, frameState, layerState);
- * @abstract
- * @return {HTMLCanvasElement|HTMLVideoElement|Image} Canvas.
-ol.renderer.canvas.IntermediateCanvas.prototype.getImage = function() {};
- * @abstract
- * @return {!ol.Transform} Image transform.
-ol.renderer.canvas.IntermediateCanvas.prototype.getImageTransform = function() {};
- * @inheritDoc
-ol.renderer.canvas.IntermediateCanvas.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
- var layer = this.getLayer();
- var source = layer.getSource();
- var resolution = frameState.viewState.resolution;
- var rotation = frameState.viewState.rotation;
- var skippedFeatureUids = frameState.skippedFeatureUids;
- return source.forEachFeatureAtCoordinate(
- coordinate, resolution, rotation, hitTolerance, skippedFeatureUids,
- * @return {?} Callback result.
- return callback.call(thisArg, feature, layer);
- * @inheritDoc
-ol.renderer.canvas.IntermediateCanvas.prototype.forEachLayerAtCoordinate = function(coordinate, frameState, callback, thisArg) {
- if (!this.getImage()) {
- return undefined;
- if (this.getLayer().getSource().forEachFeatureAtCoordinate !== ol.nullFunction) {
- // for ImageVector sources use the original hit-detection logic,
- // so that for example also transparent polygons are detected
- return ol.renderer.canvas.Layer.prototype.forEachLayerAtCoordinate.apply(this, arguments);
- } else {
- var pixel = ol.transform.apply(this.coordinateToCanvasPixelTransform, coordinate.slice());
- ol.coordinate.scale(pixel, frameState.viewState.resolution / this.renderedResolution);
- if (!this.hitCanvasContext_) {
- this.hitCanvasContext_ = ol.dom.createCanvasContext2D(1, 1);
- this.hitCanvasContext_.clearRect(0, 0, 1, 1);
- this.hitCanvasContext_.drawImage(this.getImage(), pixel[0], pixel[1], 1, 1, 0, 0, 1, 1);
- var imageData = this.hitCanvasContext_.getImageData(0, 0, 1, 1).data;
- if (imageData[3] > 0) {
- return callback.call(thisArg, this.getLayer(), imageData);
- } else {
- return undefined;
-goog.provide('ol.renderer.canvas.ImageLayer');
-goog.require('ol.ViewHint');
-goog.require('ol.extent');
-goog.require('ol.renderer.canvas.IntermediateCanvas');
- * @constructor
- * @extends {ol.renderer.canvas.IntermediateCanvas}
- * @param {ol.layer.Image} imageLayer Single image layer.
-ol.renderer.canvas.ImageLayer = function(imageLayer) {
- ol.renderer.canvas.IntermediateCanvas.call(this, imageLayer);
- * @private
- * @type {?ol.ImageBase}
- this.image_ = null;
- * @private
- this.imageTransform_ = ol.transform.create();
-ol.inherits(ol.renderer.canvas.ImageLayer, ol.renderer.canvas.IntermediateCanvas);
- * @inheritDoc
-ol.renderer.canvas.ImageLayer.prototype.getImage = function() {
- return !this.image_ ? null : this.image_.getImage();
- * @inheritDoc
-ol.renderer.canvas.ImageLayer.prototype.getImageTransform = function() {
- return this.imageTransform_;
- * @inheritDoc
-ol.renderer.canvas.ImageLayer.prototype.prepareFrame = function(frameState, layerState) {
- var pixelRatio = frameState.pixelRatio;
- var size = frameState.size;
- var viewState = frameState.viewState;
- var viewCenter = viewState.center;
- var viewResolution = viewState.resolution;
- var image;
- var imageLayer = /** @type {ol.layer.Image} */ (this.getLayer());
- var imageSource = imageLayer.getSource();
- var hints = frameState.viewHints;
- var renderedExtent = frameState.extent;
- if (layerState.extent !== undefined) {
- renderedExtent = ol.extent.getIntersection(
- renderedExtent, layerState.extent);
- if (!hints[ol.ViewHint.ANIMATING] && !hints[ol.ViewHint.INTERACTING] &&
- !ol.extent.isEmpty(renderedExtent)) {
- var projection = viewState.projection;
- if (!ol.ENABLE_RASTER_REPROJECTION) {
- var sourceProjection = imageSource.getProjection();
- if (sourceProjection) {
- projection = sourceProjection;
- image = imageSource.getImage(
- renderedExtent, viewResolution, pixelRatio, projection);
- if (image) {
- var loaded = this.loadImage(image);
- if (loaded) {
- this.image_ = image;
- if (this.image_) {
- image = this.image_;
- var imageExtent = image.getExtent();
- var imageResolution = image.getResolution();
- var imagePixelRatio = image.getPixelRatio();
- var scale = pixelRatio * imageResolution /
- (viewResolution * imagePixelRatio);
- var transform = ol.transform.compose(this.imageTransform_,
- pixelRatio * size[0] / 2, pixelRatio * size[1] / 2,
- scale, scale,
- 0,
- imagePixelRatio * (imageExtent[0] - viewCenter[0]) / imageResolution,
- imagePixelRatio * (viewCenter[1] - imageExtent[3]) / imageResolution);
- ol.transform.compose(this.coordinateToCanvasPixelTransform,
- pixelRatio * size[0] / 2 - transform[4], pixelRatio * size[1] / 2 - transform[5],
- pixelRatio / viewResolution, -pixelRatio / viewResolution,
- 0,
- -viewCenter[0], -viewCenter[1]);
- this.updateAttributions(frameState.attributions, image.getAttributions());
- this.updateLogos(frameState, imageSource);
- this.renderedResolution = viewResolution * pixelRatio / imagePixelRatio;
- return !!this.image_;
-goog.provide('ol.reproj');
-goog.require('ol.proj');
- * Calculates ideal resolution to use from the source in order to achieve
- * pixel mapping as close as possible to 1:1 during reprojection.
- * The resolution is calculated regardless of what resolutions
- * are actually available in the dataset (TileGrid, Image, ...).
- * @param {ol.proj.Projection} sourceProj Source projection.
- * @param {ol.proj.Projection} targetProj Target projection.
- * @param {ol.Coordinate} targetCenter Target center.
- * @param {number} targetResolution Target resolution.
- * @return {number} The best resolution to use. Can be +-Infinity, NaN or 0.
-ol.reproj.calculateSourceResolution = function(sourceProj, targetProj,
- targetCenter, targetResolution) {
- var sourceCenter = ol.proj.transform(targetCenter, targetProj, sourceProj);
- // calculate the ideal resolution of the source data
- var sourceResolution =
- ol.proj.getPointResolution(targetProj, targetResolution, targetCenter);
- var targetMetersPerUnit = targetProj.getMetersPerUnit();
- if (targetMetersPerUnit !== undefined) {
- sourceResolution *= targetMetersPerUnit;
- var sourceMetersPerUnit = sourceProj.getMetersPerUnit();
- if (sourceMetersPerUnit !== undefined) {
- sourceResolution /= sourceMetersPerUnit;
- // Based on the projection properties, the point resolution at the specified
- // coordinates may be slightly different. We need to reverse-compensate this
- // in order to achieve optimal results.
- var compensationFactor =
- ol.proj.getPointResolution(sourceProj, sourceResolution, sourceCenter) /
- sourceResolution;
- if (isFinite(compensationFactor) && compensationFactor > 0) {
- sourceResolution /= compensationFactor;
- return sourceResolution;
- * Enlarge the clipping triangle point by 1 pixel to ensure the edges overlap
- * in order to mask gaps caused by antialiasing.
- * @param {number} centroidX Centroid of the triangle (x coordinate in pixels).
- * @param {number} centroidY Centroid of the triangle (y coordinate in pixels).
- * @param {number} x X coordinate of the point (in pixels).
- * @param {number} y Y coordinate of the point (in pixels).
- * @return {ol.Coordinate} New point 1 px farther from the centroid.
- * @private
-ol.reproj.enlargeClipPoint_ = function(centroidX, centroidY, x, y) {
- var dX = x - centroidX, dY = y - centroidY;
- var distance = Math.sqrt(dX * dX + dY * dY);
- return [Math.round(x + dX / distance), Math.round(y + dY / distance)];
- * Renders the source data into new canvas based on the triangulation.
- * @param {number} width Width of the canvas.
- * @param {number} height Height of the canvas.
- * @param {number} pixelRatio Pixel ratio.
- * @param {number} sourceResolution Source resolution.
- * @param {ol.Extent} sourceExtent Extent of the data source.
- * @param {ol.Extent} targetExtent Target extent.
- * @param {ol.reproj.Triangulation} triangulation Calculated triangulation.
- * @param {Array.<{extent: ol.Extent,
- * image: (HTMLCanvasElement|Image|HTMLVideoElement)}>} sources
- * Array of sources.
- * @param {number} gutter Gutter of the sources.
- * @param {boolean=} opt_renderEdges Render reprojection edges.
- * @return {HTMLCanvasElement} Canvas with reprojected data.
-ol.reproj.render = function(width, height, pixelRatio,
- sourceResolution, sourceExtent, targetResolution, targetExtent,
- triangulation, sources, gutter, opt_renderEdges) {
- var context = ol.dom.createCanvasContext2D(Math.round(pixelRatio * width),
- Math.round(pixelRatio * height));
- if (sources.length === 0) {
- return context.canvas;
- context.scale(pixelRatio, pixelRatio);
- var sourceDataExtent = ol.extent.createEmpty();
- sources.forEach(function(src, i, arr) {
- ol.extent.extend(sourceDataExtent, src.extent);
- var canvasWidthInUnits = ol.extent.getWidth(sourceDataExtent);
- var canvasHeightInUnits = ol.extent.getHeight(sourceDataExtent);
- var stitchContext = ol.dom.createCanvasContext2D(
- Math.round(pixelRatio * canvasWidthInUnits / sourceResolution),
- Math.round(pixelRatio * canvasHeightInUnits / sourceResolution));
- var stitchScale = pixelRatio / sourceResolution;
- var xPos = src.extent[0] - sourceDataExtent[0];
- var yPos = -(src.extent[3] - sourceDataExtent[3]);
- var srcWidth = ol.extent.getWidth(src.extent);
- var srcHeight = ol.extent.getHeight(src.extent);
- stitchContext.drawImage(
- src.image,
- gutter, gutter,
- src.image.width - 2 * gutter, src.image.height - 2 * gutter,
- xPos * stitchScale, yPos * stitchScale,
- srcWidth * stitchScale, srcHeight * stitchScale);
- var targetTopLeft = ol.extent.getTopLeft(targetExtent);
- triangulation.getTriangles().forEach(function(triangle, i, arr) {
- /* Calculate affine transform (src -> dst)
- * Resulting matrix can be used to transform coordinate
- * from `sourceProjection` to destination pixels.
- * To optimize number of context calls and increase numerical stability,
- * we also do the following operations:
- * trans(-topLeftExtentCorner), scale(1 / targetResolution), scale(1, -1)
- * here before solving the linear system so [ui, vi] are pixel coordinates.
- * Src points: xi, yi
- * Dst points: ui, vi
- * Affine coefficients: aij
- * | x0 y0 1 0 0 0 | |a00| |u0|
- * | x1 y1 1 0 0 0 | |a01| |u1|
- * | x2 y2 1 0 0 0 | x |a02| = |u2|
- * | 0 0 0 x0 y0 1 | |a10| |v0|
- * | 0 0 0 x1 y1 1 | |a11| |v1|
- * | 0 0 0 x2 y2 1 | |a12| |v2|
- var source = triangle.source, target = triangle.target;
- var x0 = source[0][0], y0 = source[0][1],
- x1 = source[1][0], y1 = source[1][1],
- x2 = source[2][0], y2 = source[2][1];
- var u0 = (target[0][0] - targetTopLeft[0]) / targetResolution,
- v0 = -(target[0][1] - targetTopLeft[1]) / targetResolution;
- var u1 = (target[1][0] - targetTopLeft[0]) / targetResolution,
- v1 = -(target[1][1] - targetTopLeft[1]) / targetResolution;
- var u2 = (target[2][0] - targetTopLeft[0]) / targetResolution,
- v2 = -(target[2][1] - targetTopLeft[1]) / targetResolution;
- // Shift all the source points to improve numerical stability
- // of all the subsequent calculations. The [x0, y0] is used here.
- // This is also used to simplify the linear system.
- var sourceNumericalShiftX = x0, sourceNumericalShiftY = y0;
- x0 = 0;
- y0 = 0;
- x1 -= sourceNumericalShiftX;
- y1 -= sourceNumericalShiftY;
- x2 -= sourceNumericalShiftX;
- y2 -= sourceNumericalShiftY;
- var augmentedMatrix = [
- [x1, y1, 0, 0, u1 - u0],
- [x2, y2, 0, 0, u2 - u0],
- [0, 0, x1, y1, v1 - v0],
- [0, 0, x2, y2, v2 - v0]
- var affineCoefs = ol.math.solveLinearSystem(augmentedMatrix);
- if (!affineCoefs) {
- return;
- context.save();
- var centroidX = (u0 + u1 + u2) / 3, centroidY = (v0 + v1 + v2) / 3;
- var p0 = ol.reproj.enlargeClipPoint_(centroidX, centroidY, u0, v0);
- var p1 = ol.reproj.enlargeClipPoint_(centroidX, centroidY, u1, v1);
- var p2 = ol.reproj.enlargeClipPoint_(centroidX, centroidY, u2, v2);
- context.moveTo(p1[0], p1[1]);
- context.lineTo(p0[0], p0[1]);
- context.lineTo(p2[0], p2[1]);
- context.clip();
- context.transform(
- affineCoefs[0], affineCoefs[2], affineCoefs[1], affineCoefs[3], u0, v0);
- context.translate(sourceDataExtent[0] - sourceNumericalShiftX,
- sourceDataExtent[3] - sourceNumericalShiftY);
- context.scale(sourceResolution / pixelRatio,
- -sourceResolution / pixelRatio);
- context.drawImage(stitchContext.canvas, 0, 0);
- if (opt_renderEdges) {
- context.save();
- context.strokeStyle = 'black';
- context.lineWidth = 1;
- var target = triangle.target;
- context.moveTo(u1, v1);
- context.lineTo(u0, v0);
- context.lineTo(u2, v2);
- context.closePath();
- context.stroke();
-goog.provide('ol.reproj.Triangulation');
- * @classdesc
- * Class containing triangulation of the given target extent.
- * Used for determining source data and the reprojection itself.
- * @param {ol.Extent} targetExtent Target extent to triangulate.
- * @param {ol.Extent} maxSourceExtent Maximal source extent that can be used.
- * @param {number} errorThreshold Acceptable error (in source units).
- * @constructor
-ol.reproj.Triangulation = function(sourceProj, targetProj, targetExtent,
- maxSourceExtent, errorThreshold) {
- * @type {ol.proj.Projection}
- * @private
- this.sourceProj_ = sourceProj;
- * @private
- this.targetProj_ = targetProj;
- /** @type {!Object.<string, ol.Coordinate>} */
- var transformInvCache = {};
- var transformInv = ol.proj.getTransform(this.targetProj_, this.sourceProj_);
- * @param {ol.Coordinate} c A coordinate.
- * @return {ol.Coordinate} Transformed coordinate.
- * @private
- this.transformInv_ = function(c) {
- var key = c[0] + '/' + c[1];
- if (!transformInvCache[key]) {
- transformInvCache[key] = transformInv(c);
- return transformInvCache[key];
- * @type {ol.Extent}
- * @private
- this.maxSourceExtent_ = maxSourceExtent;
- * @type {number}
- * @private
- this.errorThresholdSquared_ = errorThreshold * errorThreshold;
- * @type {Array.<ol.ReprojTriangle>}
- * @private
- this.triangles_ = [];
- * Indicates that the triangulation crosses edge of the source projection.
- * @type {boolean}
- * @private
- this.wrapsXInSource_ = false;
- * @type {boolean}
- * @private
- this.canWrapXInSource_ = this.sourceProj_.canWrapX() &&
- !!maxSourceExtent &&
- !!this.sourceProj_.getExtent() &&
- (ol.extent.getWidth(maxSourceExtent) ==
- ol.extent.getWidth(this.sourceProj_.getExtent()));
- * @type {?number}
- * @private
- this.sourceWorldWidth_ = this.sourceProj_.getExtent() ?
- ol.extent.getWidth(this.sourceProj_.getExtent()) : null;
- * @type {?number}
- * @private
- this.targetWorldWidth_ = this.targetProj_.getExtent() ?
- ol.extent.getWidth(this.targetProj_.getExtent()) : null;
- var destinationTopLeft = ol.extent.getTopLeft(targetExtent);
- var destinationTopRight = ol.extent.getTopRight(targetExtent);
- var destinationBottomRight = ol.extent.getBottomRight(targetExtent);
- var destinationBottomLeft = ol.extent.getBottomLeft(targetExtent);
- var sourceTopLeft = this.transformInv_(destinationTopLeft);
- var sourceTopRight = this.transformInv_(destinationTopRight);
- var sourceBottomRight = this.transformInv_(destinationBottomRight);
- var sourceBottomLeft = this.transformInv_(destinationBottomLeft);
- this.addQuad_(
- destinationTopLeft, destinationTopRight,
- destinationBottomRight, destinationBottomLeft,
- sourceTopLeft, sourceTopRight, sourceBottomRight, sourceBottomLeft,
- ol.RASTER_REPROJECTION_MAX_SUBDIVISION);
- if (this.wrapsXInSource_) {
- var leftBound = Infinity;
- this.triangles_.forEach(function(triangle, i, arr) {
- leftBound = Math.min(leftBound,
- triangle.source[0][0], triangle.source[1][0], triangle.source[2][0]);
- // Shift triangles to be as close to `leftBound` as possible
- // (if the distance is more than `worldWidth / 2` it can be closer.
- this.triangles_.forEach(function(triangle) {
- if (Math.max(triangle.source[0][0], triangle.source[1][0],
- triangle.source[2][0]) - leftBound > this.sourceWorldWidth_ / 2) {
- var newTriangle = [[triangle.source[0][0], triangle.source[0][1]],
- [triangle.source[1][0], triangle.source[1][1]],
- [triangle.source[2][0], triangle.source[2][1]]];
- if ((newTriangle[0][0] - leftBound) > this.sourceWorldWidth_ / 2) {
- newTriangle[0][0] -= this.sourceWorldWidth_;
- if ((newTriangle[1][0] - leftBound) > this.sourceWorldWidth_ / 2) {
- newTriangle[1][0] -= this.sourceWorldWidth_;
- if ((newTriangle[2][0] - leftBound) > this.sourceWorldWidth_ / 2) {
- newTriangle[2][0] -= this.sourceWorldWidth_;
- // Rarely (if the extent contains both the dateline and prime meridian)
- // the shift can in turn break some triangles.
- // Detect this here and don't shift in such cases.
- var minX = Math.min(
- newTriangle[0][0], newTriangle[1][0], newTriangle[2][0]);
- var maxX = Math.max(
- if ((maxX - minX) < this.sourceWorldWidth_ / 2) {
- triangle.source = newTriangle;
- }, this);
- transformInvCache = {};
- * Adds triangle to the triangulation.
- * @param {ol.Coordinate} a The target a coordinate.
- * @param {ol.Coordinate} b The target b coordinate.
- * @param {ol.Coordinate} c The target c coordinate.
- * @param {ol.Coordinate} aSrc The source a coordinate.
- * @param {ol.Coordinate} bSrc The source b coordinate.
- * @param {ol.Coordinate} cSrc The source c coordinate.
- * @private
-ol.reproj.Triangulation.prototype.addTriangle_ = function(a, b, c,
- aSrc, bSrc, cSrc) {
- this.triangles_.push({
- source: [aSrc, bSrc, cSrc],
- target: [a, b, c]
- * Adds quad (points in clock-wise order) to the triangulation
- * (and reprojects the vertices) if valid.
- * Performs quad subdivision if needed to increase precision.
- * @param {ol.Coordinate} d The target d coordinate.
- * @param {ol.Coordinate} dSrc The source d coordinate.
- * @param {number} maxSubdivision Maximal allowed subdivision of the quad.
- * @private
-ol.reproj.Triangulation.prototype.addQuad_ = function(a, b, c, d,
- aSrc, bSrc, cSrc, dSrc, maxSubdivision) {
- var sourceQuadExtent = ol.extent.boundingExtent([aSrc, bSrc, cSrc, dSrc]);
- var sourceCoverageX = this.sourceWorldWidth_ ?
- ol.extent.getWidth(sourceQuadExtent) / this.sourceWorldWidth_ : null;
- var sourceWorldWidth = /** @type {number} */ (this.sourceWorldWidth_);
- // when the quad is wrapped in the source projection
- // it covers most of the projection extent, but not fully
- var wrapsX = this.sourceProj_.canWrapX() &&
- sourceCoverageX > 0.5 && sourceCoverageX < 1;
- var needsSubdivision = false;
- if (maxSubdivision > 0) {
- if (this.targetProj_.isGlobal() && this.targetWorldWidth_) {
- var targetQuadExtent = ol.extent.boundingExtent([a, b, c, d]);
- var targetCoverageX =
- ol.extent.getWidth(targetQuadExtent) / this.targetWorldWidth_;
- needsSubdivision |=
- targetCoverageX > ol.RASTER_REPROJECTION_MAX_TRIANGLE_WIDTH;
- if (!wrapsX && this.sourceProj_.isGlobal() && sourceCoverageX) {
- sourceCoverageX > ol.RASTER_REPROJECTION_MAX_TRIANGLE_WIDTH;
- if (!needsSubdivision && this.maxSourceExtent_) {
- if (!ol.extent.intersects(sourceQuadExtent, this.maxSourceExtent_)) {
- // whole quad outside source projection extent -> ignore
- return;
- if (!needsSubdivision) {
- if (!isFinite(aSrc[0]) || !isFinite(aSrc[1]) ||
- !isFinite(bSrc[0]) || !isFinite(bSrc[1]) ||
- !isFinite(cSrc[0]) || !isFinite(cSrc[1]) ||
- !isFinite(dSrc[0]) || !isFinite(dSrc[1])) {
- needsSubdivision = true;
- } else {
- return;
- var center = [(a[0] + c[0]) / 2, (a[1] + c[1]) / 2];
- var centerSrc = this.transformInv_(center);
- var dx;
- if (wrapsX) {
- var centerSrcEstimX =
- (ol.math.modulo(aSrc[0], sourceWorldWidth) +
- ol.math.modulo(cSrc[0], sourceWorldWidth)) / 2;
- dx = centerSrcEstimX -
- ol.math.modulo(centerSrc[0], sourceWorldWidth);
- } else {
- dx = (aSrc[0] + cSrc[0]) / 2 - centerSrc[0];
- var dy = (aSrc[1] + cSrc[1]) / 2 - centerSrc[1];
- var centerSrcErrorSquared = dx * dx + dy * dy;
- needsSubdivision = centerSrcErrorSquared > this.errorThresholdSquared_;
- if (needsSubdivision) {
- if (Math.abs(a[0] - c[0]) <= Math.abs(a[1] - c[1])) {
- // split horizontally (top & bottom)
- var bc = [(b[0] + c[0]) / 2, (b[1] + c[1]) / 2];
- var bcSrc = this.transformInv_(bc);
- var da = [(d[0] + a[0]) / 2, (d[1] + a[1]) / 2];
- var daSrc = this.transformInv_(da);
- this.addQuad_(
- a, b, bc, da, aSrc, bSrc, bcSrc, daSrc, maxSubdivision - 1);
- this.addQuad_(
- da, bc, c, d, daSrc, bcSrc, cSrc, dSrc, maxSubdivision - 1);
- } else {
- // split vertically (left & right)
- var ab = [(a[0] + b[0]) / 2, (a[1] + b[1]) / 2];
- var abSrc = this.transformInv_(ab);
- var cd = [(c[0] + d[0]) / 2, (c[1] + d[1]) / 2];
- var cdSrc = this.transformInv_(cd);
- this.addQuad_(
- a, ab, cd, d, aSrc, abSrc, cdSrc, dSrc, maxSubdivision - 1);
- this.addQuad_(
- ab, b, c, cd, abSrc, bSrc, cSrc, cdSrc, maxSubdivision - 1);
- return;
- if (wrapsX) {
- if (!this.canWrapXInSource_) {
- return;
- this.wrapsXInSource_ = true;
- this.addTriangle_(a, c, d, aSrc, cSrc, dSrc);
- this.addTriangle_(a, b, c, aSrc, bSrc, cSrc);
- * Calculates extent of the 'source' coordinates from all the triangles.
- * @return {ol.Extent} Calculated extent.
-ol.reproj.Triangulation.prototype.calculateSourceExtent = function() {
- var extent = ol.extent.createEmpty();
- var src = triangle.source;
- ol.extent.extendCoordinate(extent, src[0]);
- ol.extent.extendCoordinate(extent, src[1]);
- ol.extent.extendCoordinate(extent, src[2]);
- return extent;
- * @return {Array.<ol.ReprojTriangle>} Array of the calculated triangles.
-ol.reproj.Triangulation.prototype.getTriangles = function() {
- return this.triangles_;
-goog.provide('ol.reproj.Image');
-goog.require('ol.ImageBase');
-goog.require('ol.ImageState');
-goog.require('ol.events.EventType');
-goog.require('ol.reproj');
-goog.require('ol.reproj.Triangulation');
- * @classdesc
- * Class encapsulating single reprojected image.
- * See {@link ol.source.Image}.
- * @constructor
- * @extends {ol.ImageBase}
- * @param {ol.proj.Projection} sourceProj Source projection (of the data).
- * @param {ol.ReprojImageFunctionType} getImageFunction
- * Function returning source images (extent, resolution, pixelRatio).
-ol.reproj.Image = function(sourceProj, targetProj,
- targetExtent, targetResolution, pixelRatio, getImageFunction) {
- * @private
- * @private
- this.maxSourceExtent_ = sourceProj.getExtent();
- var maxTargetExtent = targetProj.getExtent();
- var limitedTargetExtent = maxTargetExtent ?
- ol.extent.getIntersection(targetExtent, maxTargetExtent) : targetExtent;
- var targetCenter = ol.extent.getCenter(limitedTargetExtent);
- var sourceResolution = ol.reproj.calculateSourceResolution(
- sourceProj, targetProj, targetCenter, targetResolution);
- var errorThresholdInPixels = ol.DEFAULT_RASTER_REPROJECTION_ERROR_THRESHOLD;
- * @private
- * @type {!ol.reproj.Triangulation}
- this.triangulation_ = new ol.reproj.Triangulation(
- sourceProj, targetProj, limitedTargetExtent, this.maxSourceExtent_,
- sourceResolution * errorThresholdInPixels);
- * @private
- * @type {number}
- this.targetResolution_ = targetResolution;
- * @private
- this.targetExtent_ = targetExtent;
- var sourceExtent = this.triangulation_.calculateSourceExtent();
- * @private
- * @type {ol.ImageBase}
- this.sourceImage_ =
- getImageFunction(sourceExtent, sourceResolution, pixelRatio);
- * @private
- * @type {number}
- this.sourcePixelRatio_ =
- this.sourceImage_ ? this.sourceImage_.getPixelRatio() : 1;
- * @private
- * @type {HTMLCanvasElement}
- this.canvas_ = null;
- * @private
- * @type {?ol.EventsKey}
- this.sourceListenerKey_ = null;
- var state = ol.ImageState.LOADED;
- var attributions = [];
- if (this.sourceImage_) {
- state = ol.ImageState.IDLE;
- attributions = this.sourceImage_.getAttributions();
- ol.ImageBase.call(this, targetExtent, targetResolution, this.sourcePixelRatio_,
- state, attributions);
-ol.inherits(ol.reproj.Image, ol.ImageBase);
- * @inheritDoc
-ol.reproj.Image.prototype.disposeInternal = function() {
- if (this.state == ol.ImageState.LOADING) {
- this.unlistenSource_();
- ol.ImageBase.prototype.disposeInternal.call(this);
- * @inheritDoc
-ol.reproj.Image.prototype.getImage = function(opt_context) {
- return this.canvas_;
- * @return {ol.proj.Projection} Projection.
-ol.reproj.Image.prototype.getProjection = function() {
- return this.targetProj_;
- * @private
-ol.reproj.Image.prototype.reproject_ = function() {
- var sourceState = this.sourceImage_.getState();
- if (sourceState == ol.ImageState.LOADED) {
- var width = ol.extent.getWidth(this.targetExtent_) / this.targetResolution_;
- var height =
- ol.extent.getHeight(this.targetExtent_) / this.targetResolution_;
- this.canvas_ = ol.reproj.render(width, height, this.sourcePixelRatio_,
- this.sourceImage_.getResolution(), this.maxSourceExtent_,
- this.targetResolution_, this.targetExtent_, this.triangulation_, [{
- extent: this.sourceImage_.getExtent(),
- image: this.sourceImage_.getImage()
- }], 0);
- this.state = sourceState;
- this.changed();
- * @inheritDoc
-ol.reproj.Image.prototype.load = function() {
- if (this.state == ol.ImageState.IDLE) {
- this.state = ol.ImageState.LOADING;
- this.changed();
- if (sourceState == ol.ImageState.LOADED ||
- sourceState == ol.ImageState.ERROR) {
- this.reproject_();
- } else {
- this.sourceListenerKey_ = ol.events.listen(this.sourceImage_,
- ol.events.EventType.CHANGE, function(e) {
- }, this);
- this.sourceImage_.load();
- * @private
-ol.reproj.Image.prototype.unlistenSource_ = function() {
- ol.events.unlistenByKey(/** @type {!ol.EventsKey} */ (this.sourceListenerKey_));
-goog.provide('ol.source.Image');
-goog.require('ol.reproj.Image');
-goog.require('ol.source.Source');
- * @classdesc
- * Abstract base class; normally only used for creating subclasses and not
- * instantiated in apps.
- * Base class for sources providing a single image.
- * @constructor
- * @abstract
- * @extends {ol.source.Source}
- * @param {ol.SourceImageOptions} options Single image source options.
- * @api
-ol.source.Image = function(options) {
- ol.source.Source.call(this, {
- attributions: options.attributions,
- extent: options.extent,
- logo: options.logo,
- projection: options.projection,
- state: options.state
- * @private
- * @type {Array.<number>}
- this.resolutions_ = options.resolutions !== undefined ?
- options.resolutions : null;
- * @private
- * @type {ol.reproj.Image}
- this.reprojectedImage_ = null;
- * @private
- * @type {number}
- this.reprojectedRevision_ = 0;
-ol.inherits(ol.source.Image, ol.source.Source);
- * @return {Array.<number>} Resolutions.
- * @override
-ol.source.Image.prototype.getResolutions = function() {
- return this.resolutions_;
- * @protected
- * @param {number} resolution Resolution.
- * @return {number} Resolution.
-ol.source.Image.prototype.findNearestResolution = function(resolution) {
- if (this.resolutions_) {
- var idx = ol.array.linearFindNearest(this.resolutions_, resolution, 0);
- resolution = this.resolutions_[idx];
- return resolution;
- * @param {ol.Extent} extent Extent.
- * @param {ol.proj.Projection} projection Projection.
- * @return {ol.ImageBase} Single image.
-ol.source.Image.prototype.getImage = function(extent, resolution, pixelRatio, projection) {
- var sourceProjection = this.getProjection();
- if (!ol.ENABLE_RASTER_REPROJECTION ||
- !sourceProjection ||
- !projection ||
- ol.proj.equivalent(sourceProjection, projection)) {
- return this.getImageInternal(extent, resolution, pixelRatio, projection);
- } else {
- if (this.reprojectedImage_) {
- if (this.reprojectedRevision_ == this.getRevision() &&
- this.reprojectedImage_.getProjection(), projection) &&
- this.reprojectedImage_.getResolution() == resolution &&
- this.reprojectedImage_.getPixelRatio() == pixelRatio &&
- ol.extent.equals(this.reprojectedImage_.getExtent(), extent)) {
- return this.reprojectedImage_;
- this.reprojectedImage_.dispose();
- this.reprojectedImage_ = new ol.reproj.Image(
- sourceProjection, projection, extent, resolution, pixelRatio,
- function(extent, resolution, pixelRatio) {
- pixelRatio, sourceProjection);
- }.bind(this));
- this.reprojectedRevision_ = this.getRevision();
- * @abstract
- * @protected
-ol.source.Image.prototype.getImageInternal = function(extent, resolution, pixelRatio, projection) {};
- * Handle image change events.
- * @param {ol.events.Event} event Event.
- * @protected
-ol.source.Image.prototype.handleImageChange = function(event) {
- var image = /** @type {ol.Image} */ (event.target);
- switch (image.getState()) {
- case ol.ImageState.LOADING:
- this.dispatchEvent(
- new ol.source.Image.Event(ol.source.Image.EventType_.IMAGELOADSTART,
- image));
- break;
- case ol.ImageState.LOADED:
- new ol.source.Image.Event(ol.source.Image.EventType_.IMAGELOADEND,
- image));
- break;
- case ol.ImageState.ERROR:
- new ol.source.Image.Event(ol.source.Image.EventType_.IMAGELOADERROR,
- image));
- break;
- default:
- // pass
- * Default image load function for image sources that use ol.Image image
- * instances.
- * @param {ol.Image} image Image.
- * @param {string} src Source.
-ol.source.Image.defaultImageLoadFunction = function(image, src) {
- image.getImage().src = src;
- * @classdesc
- * Events emitted by {@link ol.source.Image} instances are instances of this
- * type.
- * @constructor
- * @implements {oli.source.ImageEvent}
- * @param {string} type Type.
- * @param {ol.Image} image The image.
-ol.source.Image.Event = function(type, image) {
- * The image related to the event.
- * @type {ol.Image}
- * @api
- this.image = image;
-ol.inherits(ol.source.Image.Event, ol.events.Event);
- * @enum {string}
- * @private
-ol.source.Image.EventType_ = {
- * Triggered when an image starts loading.
- * @event ol.source.Image.Event#imageloadstart
- * @api
- IMAGELOADSTART: 'imageloadstart',
- * Triggered when an image finishes loading.
- * @event ol.source.Image.Event#imageloadend
- * @api
- IMAGELOADEND: 'imageloadend',
- * Triggered if image loading results in an error.
- * @event ol.source.Image.Event#imageloaderror
- * @api
- IMAGELOADERROR: 'imageloaderror'
-goog.provide('ol.source.ImageCanvas');
-goog.require('ol.ImageCanvas');
-goog.require('ol.source.Image');
- * @classdesc
- * Base class for image sources where a canvas element is the image.
- * @constructor
- * @extends {ol.source.Image}
- * @param {olx.source.ImageCanvasOptions} options Constructor options.
- * @api
-ol.source.ImageCanvas = function(options) {
- ol.source.Image.call(this, {
- resolutions: options.resolutions,
- * @private
- * @type {ol.CanvasFunctionType}
- this.canvasFunction_ = options.canvasFunction;
- * @private
- * @type {ol.ImageCanvas}
- * @private
- * @type {number}
- this.renderedRevision_ = 0;
- * @private
- * @type {number}
- this.ratio_ = options.ratio !== undefined ?
- options.ratio : 1.5;
-ol.inherits(ol.source.ImageCanvas, ol.source.Image);
- * @inheritDoc
-ol.source.ImageCanvas.prototype.getImageInternal = function(extent, resolution, pixelRatio, projection) {
- resolution = this.findNearestResolution(resolution);
- var canvas = this.canvas_;
- if (canvas &&
- this.renderedRevision_ == this.getRevision() &&
- canvas.getResolution() == resolution &&
- canvas.getPixelRatio() == pixelRatio &&
- ol.extent.containsExtent(canvas.getExtent(), extent)) {
- return canvas;
- extent = extent.slice();
- ol.extent.scaleFromCenter(extent, this.ratio_);
- var width = ol.extent.getWidth(extent) / resolution;
- var height = ol.extent.getHeight(extent) / resolution;
- var size = [width * pixelRatio, height * pixelRatio];
- var canvasElement = this.canvasFunction_(
- extent, resolution, pixelRatio, size, projection);
- if (canvasElement) {
- canvas = new ol.ImageCanvas(extent, resolution, pixelRatio,
- this.getAttributions(), canvasElement);
- this.canvas_ = canvas;
- this.renderedRevision_ = this.getRevision();
- return canvas;
-goog.provide('ol.source.ImageVector');
-goog.require('ol.render.canvas.ReplayGroup');
-goog.require('ol.renderer.vector');
-goog.require('ol.source.ImageCanvas');
-goog.require('ol.style.Style');
- * @classdesc
- * An image source whose images are canvas elements into which vector features
- * read from a vector source (`ol.source.Vector`) are drawn. An
- * `ol.source.ImageVector` object is to be used as the `source` of an image
- * layer (`ol.layer.Image`). Image layers are rotated, scaled, and translated,
- * as opposed to being re-rendered, during animations and interactions. So, like
- * any other image layer, an image layer configured with an
- * `ol.source.ImageVector` will exhibit this behaviour. This is in contrast to a
- * vector layer, where vector features are re-drawn during animations and
- * interactions.
- * @constructor
- * @extends {ol.source.ImageCanvas}
- * @param {olx.source.ImageVectorOptions} options Options.
- * @api
-ol.source.ImageVector = function(options) {
- * @private
- this.source_ = options.source;
- * @private
- this.transform_ = ol.transform.create();
- * @private
- this.canvasContext_ = ol.dom.createCanvasContext2D();
- * @private
- * @type {ol.Size}
- this.canvasSize_ = [0, 0];
- * @private
- * @type {number}
- this.renderBuffer_ = options.renderBuffer == undefined ? 100 : options.renderBuffer;
- * @private
- * @type {ol.render.canvas.ReplayGroup}
- this.replayGroup_ = null;
- ol.source.ImageCanvas.call(this, {
- canvasFunction: this.canvasFunctionInternal_.bind(this),
- ratio: options.ratio,
- state: this.source_.getState()
- * User provided style.
- * @type {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
- * @private
- this.style_ = null;
- * Style function for use within the library.
- * @type {ol.StyleFunction|undefined}
- * @private
- this.styleFunction_ = undefined;
- this.setStyle(options.style);
- ol.events.listen(this.source_, ol.events.EventType.CHANGE,
- this.handleSourceChange_, this);
-ol.inherits(ol.source.ImageVector, ol.source.ImageCanvas);
- * @param {ol.Size} size Size.
- * @param {ol.proj.Projection} projection Projection;
- * @return {HTMLCanvasElement} Canvas element.
- * @private
-ol.source.ImageVector.prototype.canvasFunctionInternal_ = function(extent, resolution, pixelRatio, size, projection) {
- var replayGroup = new ol.render.canvas.ReplayGroup(
- ol.renderer.vector.getTolerance(resolution, pixelRatio), extent,
- resolution, this.source_.getOverlaps(), this.renderBuffer_);
- this.source_.loadFeatures(extent, resolution, projection);
- var loading = false;
- this.source_.forEachFeatureInExtent(extent,
- * @param {ol.Feature} feature Feature.
- loading = loading ||
- this.renderFeature_(feature, resolution, pixelRatio, replayGroup);
- }, this);
- replayGroup.finish();
- if (loading) {
- return null;
- if (this.canvasSize_[0] != size[0] || this.canvasSize_[1] != size[1]) {
- this.canvasContext_.canvas.width = size[0];
- this.canvasContext_.canvas.height = size[1];
- this.canvasSize_[0] = size[0];
- this.canvasSize_[1] = size[1];
- } else {
- this.canvasContext_.clearRect(0, 0, size[0], size[1]);
- var transform = this.getTransform_(ol.extent.getCenter(extent),
- resolution, pixelRatio, size);
- replayGroup.replay(this.canvasContext_, pixelRatio, transform, 0, {});
- this.replayGroup_ = replayGroup;
- return this.canvasContext_.canvas;
- * @inheritDoc
-ol.source.ImageVector.prototype.forEachFeatureAtCoordinate = function(
- coordinate, resolution, rotation, hitTolerance, skippedFeatureUids, callback) {
- if (!this.replayGroup_) {
- return undefined;
- } else {
- /** @type {Object.<string, boolean>} */
- var features = {};
- return this.replayGroup_.forEachFeatureAtCoordinate(
- coordinate, resolution, 0, hitTolerance, skippedFeatureUids,
- * @param {ol.Feature|ol.render.Feature} feature Feature.
- var key = ol.getUid(feature).toString();
- if (!(key in features)) {
- features[key] = true;
- return callback(feature);
- * Get a reference to the wrapped source.
- * @return {ol.source.Vector} Source.
- * @api
-ol.source.ImageVector.prototype.getSource = function() {
- return this.source_;
- * Get the style for features. This returns whatever was passed to the `style`
- * option at construction or to the `setStyle` method.
- * @return {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
- * Layer style.
- * @api
-ol.source.ImageVector.prototype.getStyle = function() {
- return this.style_;
- * Get the style function.
- * @return {ol.StyleFunction|undefined} Layer style function.
- * @api
-ol.source.ImageVector.prototype.getStyleFunction = function() {
- return this.styleFunction_;
- * @param {ol.Coordinate} center Center.
- * @return {!ol.Transform} Transform.
- * @private
-ol.source.ImageVector.prototype.getTransform_ = function(center, resolution, pixelRatio, size) {
- var dx1 = size[0] / 2;
- var dy1 = size[1] / 2;
- var sx = pixelRatio / resolution;
- var sy = -sx;
- var dx2 = -center[0];
- var dy2 = -center[1];
- return ol.transform.compose(this.transform_, dx1, dy1, sx, sy, 0, dx2, dy2);
- * Handle changes in image style state.
- * @param {ol.events.Event} event Image style change event.
- * @private
-ol.source.ImageVector.prototype.handleImageChange_ = function(event) {
- this.changed();
- * @private
-ol.source.ImageVector.prototype.handleSourceChange_ = function() {
- // setState will trigger a CHANGE event, so we always rely
- // change events by calling setState.
- this.setState(this.source_.getState());
- * @param {ol.render.canvas.ReplayGroup} replayGroup Replay group.
- * @return {boolean} `true` if an image is loading.
- * @private
-ol.source.ImageVector.prototype.renderFeature_ = function(feature, resolution, pixelRatio, replayGroup) {
- var styles;
- var styleFunction = feature.getStyleFunction();
- if (styleFunction) {
- styles = styleFunction.call(feature, resolution);
- } else if (this.styleFunction_) {
- styles = this.styleFunction_(feature, resolution);
- if (!styles) {
- return false;
- var i, ii, loading = false;
- if (!Array.isArray(styles)) {
- styles = [styles];
- for (i = 0, ii = styles.length; i < ii; ++i) {
- loading = ol.renderer.vector.renderFeature(
- replayGroup, feature, styles[i],
- ol.renderer.vector.getSquaredTolerance(resolution, pixelRatio),
- this.handleImageChange_, this) || loading;
- return loading;
- * Set the style for features. This can be a single style object, an array
- * of styles, or a function that takes a feature and resolution and returns
- * an array of styles. If it is `undefined` the default style is used. If
- * it is `null` the layer has no style (a `null` style), so only features
- * that have their own styles will be rendered in the layer. See
- * {@link ol.style} for information on the default style.
- * @param {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction|undefined}
- * style Layer style.
- * @api
-ol.source.ImageVector.prototype.setStyle = function(style) {
- this.style_ = style !== undefined ? style : ol.style.Style.defaultFunction;
- this.styleFunction_ = !style ?
- undefined : ol.style.Style.createFunction(this.style_);
- this.changed();
-goog.provide('ol.renderer.webgl.ImageLayer');
-goog.require('ol');
-goog.require('ol.functions');
-goog.require('ol.renderer.webgl.Layer');
-goog.require('ol.source.ImageVector');
-goog.require('ol.webgl');
-goog.require('ol.webgl.Context');
-if (ol.ENABLE_WEBGL) {
- * @constructor
- * @extends {ol.renderer.webgl.Layer}
- * @param {ol.renderer.webgl.Map} mapRenderer Map renderer.
- * @param {ol.layer.Image} imageLayer Tile layer.
- ol.renderer.webgl.ImageLayer = function(mapRenderer, imageLayer) {
- ol.renderer.webgl.Layer.call(this, mapRenderer, imageLayer);
- * The last rendered image.
- * @private
- * @private
- * @private
- * @type {?ol.Transform}
- this.hitTransformationMatrix_ = null;
- ol.inherits(ol.renderer.webgl.ImageLayer, ol.renderer.webgl.Layer);
- * @param {ol.ImageBase} image Image.
- * @private
- * @return {WebGLTexture} Texture.
- ol.renderer.webgl.ImageLayer.prototype.createTexture_ = function(image) {
- // We meet the conditions to work with non-power of two textures.
- // http://www.khronos.org/webgl/wiki/WebGL_and_OpenGL_Differences#Non-Power_of_Two_Texture_Support
- // http://learningwebgl.com/blog/?p=2101
- var imageElement = image.getImage();
- var gl = this.mapRenderer.getGL();
- return ol.webgl.Context.createTexture(
- gl, imageElement, ol.webgl.CLAMP_TO_EDGE, ol.webgl.CLAMP_TO_EDGE);
- * @inheritDoc
- ol.renderer.webgl.ImageLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
- * @inheritDoc
- ol.renderer.webgl.ImageLayer.prototype.prepareFrame = function(frameState, layerState, context) {
- var viewRotation = viewState.rotation;
- var image = this.image_;
- var texture = this.texture;
- var image_ = imageSource.getImage(renderedExtent, viewResolution,
- pixelRatio, projection);
- if (image_) {
- var loaded = this.loadImage(image_);
- if (loaded) {
- image = image_;
- texture = this.createTexture_(image_);
- if (this.texture) {
- * @param {WebGLRenderingContext} gl GL.
- * @param {WebGLTexture} texture Texture.
- var postRenderFunction = function(gl, texture) {
- if (!gl.isContextLost()) {
- gl.deleteTexture(texture);
- }.bind(null, gl, this.texture);
- frameState.postRenderFunctions.push(
- /** @type {ol.PostRenderFunction} */ (postRenderFunction)
- if (image) {
- var canvas = this.mapRenderer.getContext().getCanvas();
- this.updateProjectionMatrix_(canvas.width, canvas.height,
- pixelRatio, viewCenter, viewResolution, viewRotation,
- image.getExtent());
- // Translate and scale to flip the Y coord.
- var texCoordMatrix = this.texCoordMatrix;
- ol.transform.reset(texCoordMatrix);
- ol.transform.scale(texCoordMatrix, 1, -1);
- ol.transform.translate(texCoordMatrix, 0, -1);
- this.texture = texture;
- return !!image;
- * @param {number} canvasWidth Canvas width.
- * @param {number} canvasHeight Canvas height.
- * @param {ol.Coordinate} viewCenter View center.
- * @param {number} viewResolution View resolution.
- * @param {number} viewRotation View rotation.
- * @param {ol.Extent} imageExtent Image extent.
- * @private
- ol.renderer.webgl.ImageLayer.prototype.updateProjectionMatrix_ = function(canvasWidth, canvasHeight, pixelRatio,
- viewCenter, viewResolution, viewRotation, imageExtent) {
- var canvasExtentWidth = canvasWidth * viewResolution;
- var canvasExtentHeight = canvasHeight * viewResolution;
- var projectionMatrix = this.projectionMatrix;
- ol.transform.reset(projectionMatrix);
- ol.transform.scale(projectionMatrix,
- pixelRatio * 2 / canvasExtentWidth,
- pixelRatio * 2 / canvasExtentHeight);
- ol.transform.rotate(projectionMatrix, -viewRotation);
- ol.transform.translate(projectionMatrix,
- imageExtent[0] - viewCenter[0],
- imageExtent[1] - viewCenter[1]);
- (imageExtent[2] - imageExtent[0]) / 2,
- (imageExtent[3] - imageExtent[1]) / 2);
- ol.transform.translate(projectionMatrix, 1, 1);
- * @inheritDoc
- ol.renderer.webgl.ImageLayer.prototype.hasFeatureAtCoordinate = function(coordinate, frameState) {
- var hasFeature = this.forEachFeatureAtCoordinate(
- coordinate, frameState, 0, ol.functions.TRUE, this);
- return hasFeature !== undefined;
- * @inheritDoc
- ol.renderer.webgl.ImageLayer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {
- if (!this.image_ || !this.image_.getImage()) {
- return undefined;
- if (this.getLayer().getSource() instanceof ol.source.ImageVector) {
- var coordinate = ol.transform.apply(
- frameState.pixelToCoordinateTransform, pixel.slice());
- if (hasFeature) {
- return callback.call(thisArg, this.getLayer(), null);
- } else {
- return undefined;
- } else {
- var imageSize =
- [this.image_.getImage().width, this.image_.getImage().height];
- if (!this.hitTransformationMatrix_) {
- this.hitTransformationMatrix_ = this.getHitTransformationMatrix_(
- frameState.size, imageSize);
- var pixelOnFrameBuffer = ol.transform.apply(
- this.hitTransformationMatrix_, pixel.slice());
- if (pixelOnFrameBuffer[0] < 0 || pixelOnFrameBuffer[0] > imageSize[0] ||
- pixelOnFrameBuffer[1] < 0 || pixelOnFrameBuffer[1] > imageSize[1]) {
- // outside the image, no need to check
- return undefined;
- this.hitCanvasContext_.drawImage(this.image_.getImage(),
- pixelOnFrameBuffer[0], pixelOnFrameBuffer[1], 1, 1, 0, 0, 1, 1);
- } else {
- return undefined;
- * The transformation matrix to get the pixel on the image for a
- * pixel on the map.
- * @param {ol.Size} mapSize The map size.
- * @param {ol.Size} imageSize The image size.
- * @return {ol.Transform} The transformation matrix.
- * @private
- ol.renderer.webgl.ImageLayer.prototype.getHitTransformationMatrix_ = function(mapSize, imageSize) {
- // the first matrix takes a map pixel, flips the y-axis and scales to
- // a range between -1 ... 1
- var mapCoordTransform = ol.transform.create();
- ol.transform.translate(mapCoordTransform, -1, -1);
- ol.transform.scale(mapCoordTransform, 2 / mapSize[0], 2 / mapSize[1]);
- ol.transform.translate(mapCoordTransform, 0, mapSize[1]);
- ol.transform.scale(mapCoordTransform, 1, -1);
- // the second matrix is the inverse of the projection matrix used in the
- // shader for drawing
- var projectionMatrixInv = ol.transform.invert(this.projectionMatrix.slice());
- // the third matrix scales to the image dimensions and flips the y-axis again
- var transform = ol.transform.create();
- ol.transform.translate(transform, 0, imageSize[1]);
- ol.transform.scale(transform, 1, -1);
- ol.transform.scale(transform, imageSize[0] / 2, imageSize[1] / 2);
- ol.transform.translate(transform, 1, 1);
- ol.transform.multiply(transform, projectionMatrixInv);
- ol.transform.multiply(transform, mapCoordTransform);
- return transform;
-goog.provide('ol.layer.Image');
-goog.require('ol.layer.Layer');
-goog.require('ol.renderer.Type');
-goog.require('ol.renderer.canvas.ImageLayer');
-goog.require('ol.renderer.webgl.ImageLayer');
- * @classdesc
- * Server-rendered images that are available for arbitrary extents and
- * resolutions.
- * @constructor
- * @extends {ol.layer.Layer}
- * @param {olx.layer.ImageOptions=} opt_options Layer options.
- * @api
-ol.layer.Image = function(opt_options) {
- var options = opt_options ? opt_options : {};
- ol.layer.Layer.call(this, /** @type {olx.layer.LayerOptions} */ (options));
-ol.inherits(ol.layer.Image, ol.layer.Layer);
- * @inheritDoc
-ol.layer.Image.prototype.createRenderer = function(mapRenderer) {
- var renderer = null;
- var type = mapRenderer.getType();
- if (ol.ENABLE_CANVAS && type === ol.renderer.Type.CANVAS) {
- renderer = new ol.renderer.canvas.ImageLayer(this);
- } else if (ol.ENABLE_WEBGL && type === ol.renderer.Type.WEBGL) {
- renderer = new ol.renderer.webgl.ImageLayer(/** @type {ol.renderer.webgl.Map} */ (mapRenderer), this);
- return renderer;
- * Return the associated {@link ol.source.Image source} of the image layer.
- * @function
- * @return {ol.source.Image} Source.
- * @api
-ol.layer.Image.prototype.getSource;
-goog.provide('ol.layer.TileProperty');
- * @enum {string}
-ol.layer.TileProperty = {
- PRELOAD: 'preload',
- USE_INTERIM_TILES_ON_ERROR: 'useInterimTilesOnError'
-// FIXME find correct globalCompositeOperation
-goog.provide('ol.renderer.canvas.TileLayer');
-goog.require('ol.TileRange');
-goog.require('ol.TileState');
-goog.require('ol.array');
- * @constructor
- * @param {ol.layer.Tile|ol.layer.VectorTile} tileLayer Tile layer.
-ol.renderer.canvas.TileLayer = function(tileLayer) {
- ol.renderer.canvas.IntermediateCanvas.call(this, tileLayer);
- * @protected
- this.context = this.context === null ? null : ol.dom.createCanvasContext2D();
- * @private
- * @type {number}
- this.oversampling_;
- * @private
- this.renderedExtent_ = null;
- * @protected
- * @type {number}
- this.renderedRevision;
- * @protected
- * @type {!Array.<ol.Tile>}
- this.renderedTiles = [];
- * @protected
- this.tmpExtent = ol.extent.createEmpty();
- * @private
- * @type {ol.TileRange}
- this.tmpTileRange_ = new ol.TileRange(0, 0, 0, 0);
- * @private
- * @protected
- * @type {number}
- this.zDirection = 0;
-ol.inherits(ol.renderer.canvas.TileLayer, ol.renderer.canvas.IntermediateCanvas);
- * @private
- * @param {ol.Tile} tile Tile.
- * @return {boolean} Tile is drawable.
-ol.renderer.canvas.TileLayer.prototype.isDrawableTile_ = function(tile) {
- var tileState = tile.getState();
- var useInterimTilesOnError = this.getLayer().getUseInterimTilesOnError();
- return tileState == ol.TileState.LOADED ||
- tileState == ol.TileState.EMPTY ||
- tileState == ol.TileState.ERROR && !useInterimTilesOnError;
- * @inheritDoc
-ol.renderer.canvas.TileLayer.prototype.prepareFrame = function(frameState, layerState) {
- var tileLayer = this.getLayer();
- var tileSource = /** @type {ol.source.Tile} */ (tileLayer.getSource());
- var sourceRevision = tileSource.getRevision();
- var tileGrid = tileSource.getTileGridForProjection(projection);
- var z = tileGrid.getZForResolution(viewResolution, this.zDirection);
- var tileResolution = tileGrid.getResolution(z);
- var oversampling = Math.round(viewResolution / tileResolution) || 1;
- var extent = frameState.extent;
- extent = ol.extent.getIntersection(extent, layerState.extent);
- if (ol.extent.isEmpty(extent)) {
- // Return false to prevent the rendering of the layer.
- return false;
- var tileRange = tileGrid.getTileRangeForExtentAndResolution(
- extent, tileResolution);
- var imageExtent = tileGrid.getTileRangeExtent(z, tileRange);
- var tilePixelRatio = tileSource.getTilePixelRatio(pixelRatio);
- * @type {Object.<number, Object.<string, ol.Tile>>}
- var tilesToDrawByZ = {};
- tilesToDrawByZ[z] = {};
- var findLoadedTiles = this.createLoadedTileFinder(
- tileSource, projection, tilesToDrawByZ);
- var tmpExtent = this.tmpExtent;
- var tmpTileRange = this.tmpTileRange_;
- var newTiles = false;
- var tile, x, y;
- for (x = tileRange.minX; x <= tileRange.maxX; ++x) {
- for (y = tileRange.minY; y <= tileRange.maxY; ++y) {
- tile = tileSource.getTile(z, x, y, pixelRatio, projection);
- if (!this.isDrawableTile_(tile)) {
- tile = tile.getInterimTile();
- if (this.isDrawableTile_(tile)) {
- if (tile.getState() == ol.TileState.LOADED) {
- tilesToDrawByZ[z][tile.tileCoord.toString()] = tile;
- if (!newTiles && this.renderedTiles.indexOf(tile) == -1) {
- newTiles = true;
- continue;
- var fullyLoaded = tileGrid.forEachTileCoordParentTileRange(
- tile.tileCoord, findLoadedTiles, null, tmpTileRange, tmpExtent);
- if (!fullyLoaded) {
- var childTileRange = tileGrid.getTileCoordChildTileRange(
- tile.tileCoord, tmpTileRange, tmpExtent);
- if (childTileRange) {
- findLoadedTiles(z + 1, childTileRange);
- if (!(this.renderedResolution && Date.now() - frameState.time > 16 &&
- (hints[ol.ViewHint.ANIMATING] || hints[ol.ViewHint.INTERACTING])) &&
- (newTiles || !(this.renderedExtent_ &&
- ol.extent.containsExtent(this.renderedExtent_, extent)) ||
- this.renderedRevision != sourceRevision) ||
- oversampling != this.oversampling_) {
- var context = this.context;
- if (context) {
- var tilePixelSize = tileSource.getTilePixelSize(z, pixelRatio, projection);
- var width = Math.round(tileRange.getWidth() * tilePixelSize[0] / oversampling);
- var height = Math.round(tileRange.getHeight() * tilePixelSize[1] / oversampling);
- if (canvas.width != width || canvas.height != height) {
- this.oversampling_ = oversampling;
- canvas.width = width;
- canvas.height = height;
- } else {
- context.clearRect(0, 0, width, height);
- oversampling = this.oversampling_;
- this.renderedTiles.length = 0;
- /** @type {Array.<number>} */
- var zs = Object.keys(tilesToDrawByZ).map(Number);
- zs.sort(ol.array.numberSafeCompareFunction);
- var currentResolution, currentScale, currentTilePixelSize, currentZ, i, ii;
- var tileExtent, tileGutter, tilesToDraw, w, h;
- for (i = 0, ii = zs.length; i < ii; ++i) {
- currentZ = zs[i];
- currentTilePixelSize = tileSource.getTilePixelSize(currentZ, pixelRatio, projection);
- currentResolution = tileGrid.getResolution(currentZ);
- currentScale = currentResolution / tileResolution;
- tileGutter = tilePixelRatio * tileSource.getGutter(projection);
- tilesToDraw = tilesToDrawByZ[currentZ];
- for (var tileCoordKey in tilesToDraw) {
- tile = tilesToDraw[tileCoordKey];
- tileExtent = tileGrid.getTileCoordExtent(tile.getTileCoord(), tmpExtent);
- x = (tileExtent[0] - imageExtent[0]) / tileResolution * tilePixelRatio / oversampling;
- y = (imageExtent[3] - tileExtent[3]) / tileResolution * tilePixelRatio / oversampling;
- w = currentTilePixelSize[0] * currentScale / oversampling;
- h = currentTilePixelSize[1] * currentScale / oversampling;
- this.drawTileImage(tile, frameState, layerState, x, y, w, h, tileGutter);
- this.renderedTiles.push(tile);
- this.renderedRevision = sourceRevision;
- this.renderedResolution = tileResolution * pixelRatio / tilePixelRatio * oversampling;
- this.renderedExtent_ = imageExtent;
- var scale = this.renderedResolution / viewResolution;
- scale, scale,
- 0,
- (this.renderedExtent_[0] - viewCenter[0]) / this.renderedResolution * pixelRatio,
- (viewCenter[1] - this.renderedExtent_[3]) / this.renderedResolution * pixelRatio);
- 0,
- this.updateUsedTiles(frameState.usedTiles, tileSource, z, tileRange);
- this.manageTilePyramid(frameState, tileSource, tileGrid, pixelRatio,
- projection, extent, z, tileLayer.getPreload());
- this.scheduleExpireCache(frameState, tileSource);
- this.updateLogos(frameState, tileSource);
- return this.renderedTiles.length > 0;
- * @param {olx.FrameState} frameState Frame state.
- * @param {ol.LayerState} layerState Layer state.
- * @param {number} x Left of the tile.
- * @param {number} y Top of the tile.
- * @param {number} w Width of the tile.
- * @param {number} h Height of the tile.
- * @param {number} gutter Tile gutter.
-ol.renderer.canvas.TileLayer.prototype.drawTileImage = function(tile, frameState, layerState, x, y, w, h, gutter) {
- if (!this.getLayer().getSource().getOpaque(frameState.viewState.projection)) {
- this.context.clearRect(x, y, w, h);
- var image = tile.getImage();
- if (image) {
- this.context.drawImage(image, gutter, gutter,
- image.width - 2 * gutter, image.height - 2 * gutter, x, y, w, h);
- * @inheritDoc
-ol.renderer.canvas.TileLayer.prototype.getImage = function() {
- return context ? context.canvas : null;
- * @function
- * @return {ol.layer.Tile|ol.layer.VectorTile}
-ol.renderer.canvas.TileLayer.prototype.getLayer;
- * @inheritDoc
-ol.renderer.canvas.TileLayer.prototype.getImageTransform = function() {
-// This file is automatically generated, do not edit
-goog.provide('ol.renderer.webgl.tilelayershader');
-goog.require('ol.webgl.Fragment');
-goog.require('ol.webgl.Vertex');
- * @constructor
- * @extends {ol.webgl.Fragment}
- * @struct
- ol.renderer.webgl.tilelayershader.Fragment = function() {
- ol.webgl.Fragment.call(this, ol.renderer.webgl.tilelayershader.Fragment.SOURCE);
- ol.inherits(ol.renderer.webgl.tilelayershader.Fragment, ol.webgl.Fragment);
- * @const
- * @type {string}
- ol.renderer.webgl.tilelayershader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_texCoord;\n\n\nuniform sampler2D u_texture;\n\nvoid main(void) {\n gl_FragColor = texture2D(u_texture, v_texCoord);\n}\n';
- * @const
- * @type {string}
- ol.renderer.webgl.tilelayershader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;uniform sampler2D e;void main(void){gl_FragColor=texture2D(e,a);}';
- * @const
- * @type {string}
- ol.renderer.webgl.tilelayershader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
- ol.renderer.webgl.tilelayershader.Fragment.DEBUG_SOURCE :
- ol.renderer.webgl.tilelayershader.Fragment.OPTIMIZED_SOURCE;
- ol.renderer.webgl.tilelayershader.fragment = new ol.renderer.webgl.tilelayershader.Fragment();
- * @constructor
- * @extends {ol.webgl.Vertex}
- * @struct
- ol.renderer.webgl.tilelayershader.Vertex = function() {
- ol.webgl.Vertex.call(this, ol.renderer.webgl.tilelayershader.Vertex.SOURCE);
- ol.inherits(ol.renderer.webgl.tilelayershader.Vertex, ol.webgl.Vertex);
- * @const
- * @type {string}
- ol.renderer.webgl.tilelayershader.Vertex.DEBUG_SOURCE = 'varying vec2 v_texCoord;\n\n\nattribute vec2 a_position;\nattribute vec2 a_texCoord;\nuniform vec4 u_tileOffset;\n\nvoid main(void) {\n gl_Position = vec4(a_position * u_tileOffset.xy + u_tileOffset.zw, 0., 1.);\n v_texCoord = a_texCoord;\n}\n\n\n';
- * @const
- * @type {string}
- ol.renderer.webgl.tilelayershader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;attribute vec2 b;attribute vec2 c;uniform vec4 d;void main(void){gl_Position=vec4(b*d.xy+d.zw,0.,1.);a=c;}';
- * @const
- * @type {string}
- ol.renderer.webgl.tilelayershader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
- ol.renderer.webgl.tilelayershader.Vertex.DEBUG_SOURCE :
- ol.renderer.webgl.tilelayershader.Vertex.OPTIMIZED_SOURCE;
- ol.renderer.webgl.tilelayershader.vertex = new ol.renderer.webgl.tilelayershader.Vertex();
- * @constructor
- * @param {WebGLProgram} program Program.
- * @struct
- ol.renderer.webgl.tilelayershader.Locations = function(gl, program) {
- * @type {WebGLUniformLocation}
- this.u_texture = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_texture' : 'e');
- this.u_tileOffset = gl.getUniformLocation(
- program, ol.DEBUG_WEBGL ? 'u_tileOffset' : 'd');
- * @type {number}
- this.a_position = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_position' : 'b');
- * @type {number}
- this.a_texCoord = gl.getAttribLocation(
- program, ol.DEBUG_WEBGL ? 'a_texCoord' : 'c');
-// FIXME large resolutions lead to too large framebuffers :-(
-// FIXME animated shaders! check in redraw
-goog.provide('ol.renderer.webgl.TileLayer');
-goog.require('ol.math');
-goog.require('ol.renderer.webgl.tilelayershader');
-goog.require('ol.size');
-goog.require('ol.webgl.Buffer');
- * @constructor
- * @param {ol.layer.Tile} tileLayer Tile layer.
- ol.renderer.webgl.TileLayer = function(mapRenderer, tileLayer) {
- ol.renderer.webgl.Layer.call(this, mapRenderer, tileLayer);
- * @private
- * @type {ol.webgl.Fragment}
- this.fragmentShader_ = ol.renderer.webgl.tilelayershader.fragment;
- * @private
- * @type {ol.webgl.Vertex}
- this.vertexShader_ = ol.renderer.webgl.tilelayershader.vertex;
- * @private
- * @type {ol.renderer.webgl.tilelayershader.Locations}
- this.locations_ = null;
- * @private
- * @type {ol.webgl.Buffer}
- this.renderArrayBuffer_ = new ol.webgl.Buffer([
- 0, 0, 0, 1,
- 1, 0, 1, 1,
- 0, 1, 0, 0,
- 1, 1, 1, 0
- * @private
- this.renderedTileRange_ = null;
- * @private
- this.renderedFramebufferExtent_ = null;
- * @private
- * @type {number}
- this.renderedRevision_ = -1;
- * @private
- * @type {ol.Size}
- this.tmpSize_ = [0, 0];
- ol.inherits(ol.renderer.webgl.TileLayer, ol.renderer.webgl.Layer);
- * @inheritDoc
- ol.renderer.webgl.TileLayer.prototype.disposeInternal = function() {
- var context = this.mapRenderer.getContext();
- context.deleteBuffer(this.renderArrayBuffer_);
- ol.renderer.webgl.Layer.prototype.disposeInternal.call(this);
- * @inheritDoc
- ol.renderer.webgl.TileLayer.prototype.createLoadedTileFinder = function(source, projection, tiles) {
- var mapRenderer = this.mapRenderer;
- return (
- * @param {number} zoom Zoom level.
- * @param {ol.TileRange} tileRange Tile range.
- * @return {boolean} The tile range is fully loaded.
- function(zoom, tileRange) {
- function callback(tile) {
- var loaded = mapRenderer.isTileTextureLoaded(tile);
- if (loaded) {
- if (!tiles[zoom]) {
- tiles[zoom] = {};
- tiles[zoom][tile.tileCoord.toString()] = tile;
- return loaded;
- return source.forEachLoadedTile(projection, zoom, tileRange, callback);
- * @inheritDoc
- ol.renderer.webgl.TileLayer.prototype.handleWebGLContextLost = function() {
- ol.renderer.webgl.Layer.prototype.handleWebGLContextLost.call(this);
- * @inheritDoc
- ol.renderer.webgl.TileLayer.prototype.prepareFrame = function(frameState, layerState, context) {
- var gl = context.getGL();
- var tileLayer = /** @type {ol.layer.Tile} */ (this.getLayer());
- var tileSource = tileLayer.getSource();
- var z = tileGrid.getZForResolution(viewState.resolution);
- tileSource.getTilePixelSize(z, frameState.pixelRatio, projection);
- var pixelRatio = tilePixelSize[0] /
- ol.size.toSize(tileGrid.getTileSize(z), this.tmpSize_)[0];
- var tilePixelResolution = tileResolution / pixelRatio;
- var tileGutter = tileSource.getTilePixelRatio(pixelRatio) * tileSource.getGutter(projection);
- var center = viewState.center;
- var framebufferExtent;
- if (this.renderedTileRange_ &&
- this.renderedTileRange_.equals(tileRange) &&
- this.renderedRevision_ == tileSource.getRevision()) {
- framebufferExtent = this.renderedFramebufferExtent_;
- } else {
- var tileRangeSize = tileRange.getSize();
- var maxDimension = Math.max(
- tileRangeSize[0] * tilePixelSize[0],
- tileRangeSize[1] * tilePixelSize[1]);
- var framebufferDimension = ol.math.roundUpToPowerOfTwo(maxDimension);
- var framebufferExtentDimension = tilePixelResolution * framebufferDimension;
- var origin = tileGrid.getOrigin(z);
- var minX = origin[0] +
- tileRange.minX * tilePixelSize[0] * tilePixelResolution;
- var minY = origin[1] +
- tileRange.minY * tilePixelSize[1] * tilePixelResolution;
- framebufferExtent = [
- minX, minY,
- minX + framebufferExtentDimension, minY + framebufferExtentDimension
- this.bindFramebuffer(frameState, framebufferDimension);
- gl.viewport(0, 0, framebufferDimension, framebufferDimension);
- gl.clearColor(0, 0, 0, 0);
- gl.clear(ol.webgl.COLOR_BUFFER_BIT);
- gl.disable(ol.webgl.BLEND);
- var program = context.getProgram(this.fragmentShader_, this.vertexShader_);
- context.useProgram(program);
- if (!this.locations_) {
- this.locations_ =
- new ol.renderer.webgl.tilelayershader.Locations(gl, program);
- context.bindBuffer(ol.webgl.ARRAY_BUFFER, this.renderArrayBuffer_);
- gl.enableVertexAttribArray(this.locations_.a_position);
- gl.vertexAttribPointer(
- this.locations_.a_position, 2, ol.webgl.FLOAT, false, 16, 0);
- gl.enableVertexAttribArray(this.locations_.a_texCoord);
- this.locations_.a_texCoord, 2, ol.webgl.FLOAT, false, 16, 8);
- gl.uniform1i(this.locations_.u_texture, 0);
- var useInterimTilesOnError = tileLayer.getUseInterimTilesOnError();
- var allTilesLoaded = true;
- var tmpExtent = ol.extent.createEmpty();
- var tmpTileRange = new ol.TileRange(0, 0, 0, 0);
- var childTileRange, drawable, fullyLoaded, tile, tileState;
- var x, y, tileExtent;
- // ignore tiles outside layer extent
- tileExtent = tileGrid.getTileCoordExtent(tile.tileCoord, tmpExtent);
- if (!ol.extent.intersects(tileExtent, layerState.extent)) {
- continue;
- tileState = tile.getState();
- drawable = tileState == ol.TileState.LOADED ||
- if (!drawable) {
- if (tileState == ol.TileState.LOADED) {
- if (mapRenderer.isTileTextureLoaded(tile)) {
- continue;
- } else if (tileState == ol.TileState.EMPTY ||
- (tileState == ol.TileState.ERROR &&
- !useInterimTilesOnError)) {
- continue;
- allTilesLoaded = false;
- fullyLoaded = tileGrid.forEachTileCoordParentTileRange(
- childTileRange = tileGrid.getTileCoordChildTileRange(
- var u_tileOffset = new Float32Array(4);
- var i, ii, tileKey, tilesToDraw;
- tilesToDraw = tilesToDrawByZ[zs[i]];
- for (tileKey in tilesToDraw) {
- tile = tilesToDraw[tileKey];
- u_tileOffset[0] = 2 * (tileExtent[2] - tileExtent[0]) /
- framebufferExtentDimension;
- u_tileOffset[1] = 2 * (tileExtent[3] - tileExtent[1]) /
- u_tileOffset[2] = 2 * (tileExtent[0] - framebufferExtent[0]) /
- framebufferExtentDimension - 1;
- u_tileOffset[3] = 2 * (tileExtent[1] - framebufferExtent[1]) /
- gl.uniform4fv(this.locations_.u_tileOffset, u_tileOffset);
- mapRenderer.bindTileTexture(tile, tilePixelSize,
- tileGutter * pixelRatio, ol.webgl.LINEAR, ol.webgl.LINEAR);
- gl.drawArrays(ol.webgl.TRIANGLE_STRIP, 0, 4);
- if (allTilesLoaded) {
- this.renderedTileRange_ = tileRange;
- this.renderedFramebufferExtent_ = framebufferExtent;
- this.renderedRevision_ = tileSource.getRevision();
- } else {
- frameState.animate = true;
- var tileTextureQueue = mapRenderer.getTileTextureQueue();
- frameState, tileSource, tileGrid, pixelRatio, projection, extent, z,
- tileLayer.getPreload(),
- function(tile) {
- if (tile.getState() == ol.TileState.LOADED &&
- !mapRenderer.isTileTextureLoaded(tile) &&
- !tileTextureQueue.isKeyQueued(tile.getKey())) {
- tileTextureQueue.enqueue([
- tile,
- tileGrid.getTileCoordCenter(tile.tileCoord),
- tileGrid.getResolution(tile.tileCoord[0]),
- tilePixelSize, tileGutter * pixelRatio
- }, this);
- (Math.round(center[0] / tileResolution) * tileResolution - framebufferExtent[0]) /
- (framebufferExtent[2] - framebufferExtent[0]),
- (Math.round(center[1] / tileResolution) * tileResolution - framebufferExtent[1]) /
- (framebufferExtent[3] - framebufferExtent[1]));
- if (viewState.rotation !== 0) {
- ol.transform.rotate(texCoordMatrix, viewState.rotation);
- frameState.size[0] * viewState.resolution /
- frameState.size[1] * viewState.resolution /
- ol.transform.translate(texCoordMatrix, -0.5, -0.5);
- return true;
- * @inheritDoc
- ol.renderer.webgl.TileLayer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {
- if (!this.framebuffer) {
- return undefined;
- var pixelOnMapScaled = [
- pixel[0] / frameState.size[0],
- (frameState.size[1] - pixel[1]) / frameState.size[1]];
- var pixelOnFrameBufferScaled = ol.transform.apply(
- this.texCoordMatrix, pixelOnMapScaled.slice());
- var pixelOnFrameBuffer = [
- pixelOnFrameBufferScaled[0] * this.framebufferDimension,
- pixelOnFrameBufferScaled[1] * this.framebufferDimension];
- var gl = this.mapRenderer.getContext().getGL();
- gl.bindFramebuffer(gl.FRAMEBUFFER, this.framebuffer);
- var imageData = new Uint8Array(4);
- gl.readPixels(pixelOnFrameBuffer[0], pixelOnFrameBuffer[1], 1, 1,
- gl.RGBA, gl.UNSIGNED_BYTE, imageData);
- if (imageData[3] > 0) {
- return callback.call(thisArg, this.getLayer(), imageData);
- } else {
- return undefined;
-goog.provide('ol.layer.Tile');
-goog.require('ol.layer.TileProperty');
-goog.require('ol.obj');
-goog.require('ol.renderer.canvas.TileLayer');
-goog.require('ol.renderer.webgl.TileLayer');
- * @classdesc
- * For layer sources that provide pre-rendered, tiled images in grids that are
- * organized by zoom levels for specific resolutions.
- * Note that any property set in the options is set as a {@link ol.Object}
- * property on the layer object; for example, setting `title: 'My Title'` in the
- * options means that `title` is observable, and has get/set accessors.
- * @constructor
- * @fires ol.render.Event
- * @param {olx.layer.TileOptions=} opt_options Tile layer options.
- * @api
-ol.layer.Tile = function(opt_options) {
- var baseOptions = ol.obj.assign({}, options);
- delete baseOptions.preload;
- delete baseOptions.useInterimTilesOnError;
- ol.layer.Layer.call(this, /** @type {olx.layer.LayerOptions} */ (baseOptions));
- this.setPreload(options.preload !== undefined ? options.preload : 0);
- this.setUseInterimTilesOnError(options.useInterimTilesOnError !== undefined ?
- options.useInterimTilesOnError : true);
-ol.inherits(ol.layer.Tile, ol.layer.Layer);
- * @inheritDoc
-ol.layer.Tile.prototype.createRenderer = function(mapRenderer) {
- renderer = new ol.renderer.canvas.TileLayer(this);
- renderer = new ol.renderer.webgl.TileLayer(/** @type {ol.renderer.webgl.Map} */ (mapRenderer), this);
- return renderer;
- * Return the level as number to which we will preload tiles up to.
- * @return {number} The level to preload tiles up to.
- * @observable
- * @api
-ol.layer.Tile.prototype.getPreload = function() {
- return /** @type {number} */ (this.get(ol.layer.TileProperty.PRELOAD));
- * Return the associated {@link ol.source.Tile tilesource} of the layer.
- * @function
- * @return {ol.source.Tile} Source.
- * @api
-ol.layer.Tile.prototype.getSource;
- * Set the level as number to which we will preload tiles up to.
- * @param {number} preload The level to preload tiles up to.
- * @observable
- * @api
-ol.layer.Tile.prototype.setPreload = function(preload) {
- this.set(ol.layer.TileProperty.PRELOAD, preload);
- * Whether we use interim tiles on error.
- * @return {boolean} Use interim tiles on error.
- * @observable
- * @api
-ol.layer.Tile.prototype.getUseInterimTilesOnError = function() {
- return /** @type {boolean} */ (
- this.get(ol.layer.TileProperty.USE_INTERIM_TILES_ON_ERROR));
- * Set whether we use interim tiles on error.
- * @param {boolean} useInterimTilesOnError Use interim tiles on error.
- * @observable
- * @api
-ol.layer.Tile.prototype.setUseInterimTilesOnError = function(useInterimTilesOnError) {
- this.set(
- ol.layer.TileProperty.USE_INTERIM_TILES_ON_ERROR, useInterimTilesOnError);
-goog.provide('ol.layer.VectorTileRenderType');
- * @enum {string}
- * Render mode for vector tiles:
- * * `'image'`: Vector tiles are rendered as images. Great performance, but
- * point symbols and texts are always rotated with the view and pixels are
- * scaled during zoom animations.
- * * `'hybrid'`: Polygon and line elements are rendered as images, so pixels
- * are scaled during zoom animations. Point symbols and texts are accurately
- * rendered as vectors and can stay upright on rotated views.
- * * `'vector'`: Vector tiles are rendered as vectors. Most accurate rendering
- * even during animations, but slower performance than the other options.
- * @api
-ol.layer.VectorTileRenderType = {
- IMAGE: 'image',
- HYBRID: 'hybrid',
- VECTOR: 'vector'
-goog.provide('ol.renderer.canvas.VectorTileLayer');
-goog.require('ol.dom');
-goog.require('ol.extent');
-goog.require('ol.proj');
-goog.require('ol.proj.Units');
-goog.require('ol.layer.VectorTileRenderType');
-goog.require('ol.render.ReplayType');
-goog.require('ol.render.canvas');
-goog.require('ol.render.replay');
-goog.require('ol.transform');
- * @constructor
- * @extends {ol.renderer.canvas.TileLayer}
- * @param {ol.layer.VectorTile} layer VectorTile layer.
-ol.renderer.canvas.VectorTileLayer = function(layer) {
- this.context = null;
- ol.renderer.canvas.TileLayer.call(this, layer);
- * @private
- * @type {boolean}
- this.dirty_ = false;
- * @private
- * @type {number}
- this.renderedLayerRevision_;
- * @private
- * @type {ol.Transform}
- this.tmpTransform_ = ol.transform.create();
- // Use lower resolution for pure vector rendering. Closest resolution otherwise.
- this.zDirection =
- layer.getRenderMode() == ol.layer.VectorTileRenderType.VECTOR ? 1 : 0;
-ol.inherits(ol.renderer.canvas.VectorTileLayer, ol.renderer.canvas.TileLayer);
- * @const
- * @type {!Object.<string, Array.<ol.render.ReplayType>>}
-ol.renderer.canvas.VectorTileLayer.IMAGE_REPLAYS = {
- 'image': ol.render.replay.ORDER,
- 'hybrid': [ol.render.ReplayType.POLYGON, ol.render.ReplayType.LINE_STRING]
- * @const
-ol.renderer.canvas.VectorTileLayer.VECTOR_REPLAYS = {
- 'hybrid': [ol.render.ReplayType.IMAGE, ol.render.ReplayType.TEXT],
- 'vector': ol.render.replay.ORDER
- * @inheritDoc
-ol.renderer.canvas.VectorTileLayer.prototype.prepareFrame = function(frameState, layerState) {
- var layer = this.getLayer();
- var layerRevision = layer.getRevision();
- if (this.renderedLayerRevision_ != layerRevision) {
- var renderMode = layer.getRenderMode();
- if (!this.context && renderMode != ol.layer.VectorTileRenderType.VECTOR) {
- this.context = ol.dom.createCanvasContext2D();
- if (this.context && renderMode == ol.layer.VectorTileRenderType.VECTOR) {
- this.renderedLayerRevision_ = layerRevision;
- return ol.renderer.canvas.TileLayer.prototype.prepareFrame.apply(this, arguments);
- * @param {ol.VectorTile} tile Tile.
- * @private
-ol.renderer.canvas.VectorTileLayer.prototype.createReplayGroup_ = function(tile,
- frameState) {
- var pixelRatio = frameState.pixelRatio;
- var projection = frameState.viewState.projection;
- var revision = layer.getRevision();
- var renderOrder = layer.getRenderOrder() || null;
- var replayState = tile.getReplayState();
- if (!replayState.dirty && replayState.renderedRevision == revision &&
- replayState.renderedRenderOrder == renderOrder) {
- return;
- replayState.replayGroup = null;
- replayState.dirty = false;
- var source = /** @type {ol.source.VectorTile} */ (layer.getSource());
- var tileGrid = source.getTileGrid();
- var tileCoord = tile.tileCoord;
- var tileProjection = tile.getProjection();
- var resolution = tileGrid.getResolution(tileCoord[0]);
- var extent, reproject, tileResolution;
- if (tileProjection.getUnits() == ol.proj.Units.TILE_PIXELS) {
- var tilePixelRatio = tileResolution = source.getTilePixelRatio();
- var tileSize = ol.size.toSize(tileGrid.getTileSize(tileCoord[0]));
- extent = [0, 0, tileSize[0] * tilePixelRatio, tileSize[1] * tilePixelRatio];
- } else {
- tileResolution = resolution;
- extent = tileGrid.getTileCoordExtent(tileCoord);
- if (!ol.proj.equivalent(projection, tileProjection)) {
- reproject = true;
- tile.setProjection(projection);
- var replayGroup = new ol.render.canvas.ReplayGroup(0, extent,
- tileResolution, source.getOverlaps(), layer.getRenderBuffer());
- var squaredTolerance = ol.renderer.vector.getSquaredTolerance(
- tileResolution, pixelRatio);
- * @this {ol.renderer.canvas.VectorTileLayer}
- function renderFeature(feature) {
- var styles;
- styles = styleFunction.call(/** @type {ol.Feature} */ (feature), resolution);
- } else {
- styleFunction = layer.getStyleFunction();
- styles = styleFunction(feature, resolution);
- if (styles) {
- var dirty = this.renderFeature(feature, squaredTolerance, styles,
- replayGroup);
- this.dirty_ = this.dirty_ || dirty;
- replayState.dirty = replayState.dirty || dirty;
- var features = tile.getFeatures();
- if (renderOrder && renderOrder !== replayState.renderedRenderOrder) {
- features.sort(renderOrder);
- var feature;
- for (var i = 0, ii = features.length; i < ii; ++i) {
- feature = features[i];
- if (reproject) {
- feature.getGeometry().transform(tileProjection, projection);
- renderFeature.call(this, feature);
- replayState.renderedRevision = revision;
- replayState.renderedRenderOrder = renderOrder;
- replayState.replayGroup = replayGroup;
- replayState.resolution = NaN;
- * @inheritDoc
-ol.renderer.canvas.VectorTileLayer.prototype.drawTileImage = function(
- tile, frameState, layerState, x, y, w, h, gutter) {
- var vectorTile = /** @type {ol.VectorTile} */ (tile);
- this.createReplayGroup_(vectorTile, frameState);
- if (this.context) {
- this.renderTileImage_(vectorTile, frameState, layerState);
- ol.renderer.canvas.TileLayer.prototype.drawTileImage.apply(this, arguments);
- * @inheritDoc
-ol.renderer.canvas.VectorTileLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
- var resolution = frameState.viewState.resolution;
- var rotation = frameState.viewState.rotation;
- hitTolerance = hitTolerance == undefined ? 0 : hitTolerance;
- /** @type {Array.<ol.VectorTile>} */
- var replayables = this.renderedTiles;
- var found, tileSpaceCoordinate;
- var i, ii, origin, replayGroup;
- var tile, tileCoord, tileExtent, tilePixelRatio, tileResolution;
- for (i = 0, ii = replayables.length; i < ii; ++i) {
- tile = replayables[i];
- tileCoord = tile.tileCoord;
- tileExtent = source.getTileGrid().getTileCoordExtent(tileCoord, this.tmpExte
