[mapguide-commits] r9872 - in sandbox/adsk/trunk: Common/CoordinateSystem Common/Foundation/Data Common/Foundation/System Common/PlatformBase Common/PlatformBase/MapLayer Web/src/DotNetApi/Foundation Web/src/DotNetApi/Geometry Web/src/DotNetApi/MapGuideCommon Web/src/DotNetApi/PlatformBase Web/src/DotNetApi/Web
svn_mapguide at osgeo.org
Fri Sep 17 01:54:04 PDT 2021
Author: christinebao
Date: 2021-09-17 01:54:03 -0700 (Fri, 17 Sep 2021)
New Revision: 9872
sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysUtil.h
sandbox/adsk/trunk/Common/Foundation/Data/NamedCollection.cpp
sandbox/adsk/trunk/Common/Foundation/System/Util.cpp
sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h
sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h
sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h
sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h
sandbox/adsk/trunk/Web/src/DotNetApi/Foundation/AssemblyInfo.cs
sandbox/adsk/trunk/Web/src/DotNetApi/Geometry/AssemblyInfo.cs
sandbox/adsk/trunk/Web/src/DotNetApi/MapGuideCommon/AssemblyInfo.cs
sandbox/adsk/trunk/Web/src/DotNetApi/PlatformBase/AssemblyInfo.cs
sandbox/adsk/trunk/Web/src/DotNetApi/Web/AssemblyInfo.cs
Revert copyright to LGPL 2.1
Modified: sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysUtil.h
--- sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysUtil.h 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysUtil.h 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
-// (C) Copyright 2021 by Autodesk, Inc.
+// Copyright (C) 2004-2021 by Autodesk, Inc.
-// The information contained herein is confidential, proprietary
-// to Autodesk, Inc., and considered a trade secret as defined
-// in section 499C of the penal code of the State of California.
-// Use of this information by anyone other than authorized
-// employees of Autodesk, Inc. is granted only under a written
-// non-disclosure agreement, expressly prescribing the scope
-// and manner of such use.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+// This implementation file provides some useful utility functions and classes.
#ifndef _CCOORDINATESYSTEMUTIL_H_
#define _CCOORDINATESYSTEMUTIL_H_
Modified: sandbox/adsk/trunk/Common/Foundation/Data/NamedCollection.cpp
--- sandbox/adsk/trunk/Common/Foundation/Data/NamedCollection.cpp 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/Foundation/Data/NamedCollection.cpp 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
#include "Foundation.h"
#include <map>
Modified: sandbox/adsk/trunk/Common/Foundation/System/Util.cpp
--- sandbox/adsk/trunk/Common/Foundation/System/Util.cpp 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/Foundation/System/Util.cpp 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
#include "UnicodeString.h"
Modified: sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h
--- sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
#ifndef _MG_LAYER_BASE_H_
#define _MG_LAYER_BASE_H_
Modified: sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h
--- sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
#ifndef _MG_LAYER_GROUP_H_
#define _MG_LAYER_GROUP_H_
Modified: sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h
--- sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
#pragma once
Modified: sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h
--- sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
#ifndef MGPLATFORMBASE_H_
#define MGPLATFORMBASE_H_
Modified: sandbox/adsk/trunk/Web/src/DotNetApi/Foundation/AssemblyInfo.cs
--- sandbox/adsk/trunk/Web/src/DotNetApi/Foundation/AssemblyInfo.cs 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Web/src/DotNetApi/Foundation/AssemblyInfo.cs 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
-// (C) Copyright 2019 by Autodesk, Inc.
using System;
using System.Reflection;
Modified: sandbox/adsk/trunk/Web/src/DotNetApi/Geometry/AssemblyInfo.cs
--- sandbox/adsk/trunk/Web/src/DotNetApi/Geometry/AssemblyInfo.cs 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Web/src/DotNetApi/Geometry/AssemblyInfo.cs 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
using System;
Modified: sandbox/adsk/trunk/Web/src/DotNetApi/MapGuideCommon/AssemblyInfo.cs
--- sandbox/adsk/trunk/Web/src/DotNetApi/MapGuideCommon/AssemblyInfo.cs 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Web/src/DotNetApi/MapGuideCommon/AssemblyInfo.cs 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
using System;
Modified: sandbox/adsk/trunk/Web/src/DotNetApi/PlatformBase/AssemblyInfo.cs
--- sandbox/adsk/trunk/Web/src/DotNetApi/PlatformBase/AssemblyInfo.cs 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Web/src/DotNetApi/PlatformBase/AssemblyInfo.cs 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
using System;
Modified: sandbox/adsk/trunk/Web/src/DotNetApi/Web/AssemblyInfo.cs
--- sandbox/adsk/trunk/Web/src/DotNetApi/Web/AssemblyInfo.cs 2021-09-17 07:23:22 UTC (rev 9871)
+++ sandbox/adsk/trunk/Web/src/DotNetApi/Web/AssemblyInfo.cs 2021-09-17 08:54:03 UTC (rev 9872)
@@ -1,14 +1,20 @@
using System;
More information about the mapguide-commits
