[mapguide-commits] r9873 - sandbox/adsk/trunk/Common/CoordinateSystem
svn_mapguide at osgeo.org
Thu Sep 23 19:20:31 PDT 2021
Author: simonliu
Date: 2021-09-23 19:20:30 -0700 (Thu, 23 Sep 2021)
New Revision: 9873
sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysTransform.cpp
CS: Update method CCoordinateSystemTransform::GetExplicitGeodeticPath().
If it is an implicitly constructed path, we'll now create a [GeodeticPathDefinition] on-the-fly
Modified: sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysTransform.cpp
--- sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysTransform.cpp 2021-09-17 08:54:03 UTC (rev 9872)
+++ sandbox/adsk/trunk/Common/CoordinateSystem/CoordSysTransform.cpp 2021-09-24 02:20:30 UTC (rev 9873)
@@ -22,6 +22,8 @@
#include "CoordSysTransform.h" //for CCoordinateSystemTransform
#include "CoordSysUtil.h" //for CsDictionaryOpenMode
#include "MentorUtil.h" //for IsLegalMentorName
+#include "CoordSysGeodeticPath.h"
+#include "CoordSysGeodeticPathElement.h"
using namespace CSLibrary;
@@ -961,10 +963,9 @@
MgCoordinateSystemGeodeticPath* CCoordinateSystemTransform::GetExplicitGeodeticPath()
STRING pathDefName;
- Ptr<MgCoordinateSystemCatalog> pCatalog;
+ Ptr<MgCoordinateSystemCatalog> pCatalog;
Ptr<MgCoordinateSystemGeodeticPath> rtnValue;
Ptr<MgCoordinateSystemGeodeticPathDictionary> pGpDefDict;
MgCoordinateSystemFactory csFactory;
// index parameter is valid, get a pointer to the appropriate
@@ -979,6 +980,73 @@
MgDisposable* tmpPtr = pGpDefDict.p->Get(pathDefName);
rtnValue = dynamic_cast<MgCoordinateSystemGeodeticPath*>(tmpPtr);
+ else
+ //this is an implicitly constructed path
+ //we'll now be creating a [GeodeticPathDefinition] on-the-fly
+ pCatalog = csFactory.GetCatalog();
+ Ptr<CCoordinateSystemGeodeticPath> geodeticPath = new CCoordinateSystemGeodeticPath(pCatalog);
+ geodeticPath->Reset();
+ geodeticPath->SetDescription(L"Auto-generated geodetic path"); // NOXLATE
+ geodeticPath->SetSourceDatum(this->GetSource()->GetDatum());
+ geodeticPath->SetTargetDatum(this->GetTarget()->GetDatum());
+ Ptr<MgDisposableCollection> pathElements = new MgDisposableCollection();
+ bool isError = false;
+ for (int i = 0; i < m_pDtcprm->xfrmCount; i++)
+ //iterate through all the transformations that CSMAP has given us
+ //and put them into the [pathElements] array
+ cs_GxXform_* pTransformation = m_pDtcprm->xforms[i];
+ if (nullptr == pTransformation)
+ isError = true;
+ break;
+ //we only support transformations, that are in the dictionaries;
+ //that is, we'll be try loading the definition from the catalog
+ cs_GeodeticTransform_ const& geoTransformDef = pTransformation->gxDef;
+ wchar_t* pwszXformName = Convert_UTF8_To_Wide(geoTransformDef.xfrmName);
+ STRING xformDefName = pwszXformName;
+ delete[] pwszXformName;
+ Ptr<MgCoordinateSystemGeodeticTransformDefDictionary> pGxDefDict = pCatalog->GetGeodeticTransformDefDictionary();
+ MgDisposable* tmpPtr = pGxDefDict.p->Get(xformDefName);
+ Ptr<MgCoordinateSystemGeodeticTransformDef> xform = dynamic_cast<MgCoordinateSystemGeodeticTransformDef*>(tmpPtr);
+ if (nullptr == xform)
+ isError = true;
+ break;
+ //the transformation exists in our dictionary - now initialize the single path element with that information
+ Ptr<MgCoordinateSystemGeodeticPathElement> pathElement = geodeticPath->NewPathElement();
+ bool pathElementIsInversed;
+ if (cs_DTCDIR_INV == pTransformation->userDirection)
+ pathElementIsInversed = true;
+ else if (cs_DTCDIR_FWD == pTransformation->userDirection)
+ pathElementIsInversed = false;
+ else /*if (cs_DTCDIR_NONE == pTransformation->userDirection)*/
+ isError = true;
+ break;
+ pathElement->SetIsInversed(pathElementIsInversed);
+ pathElement->SetTransformName(xformDefName);
+ pathElements->Add(pathElement);
+ pathElement.Detach();
+ if (!isError && 0 != pathElements->GetCount())
+ geodeticPath->SetPathElements(pathElements);
+ rtnValue = geodeticPath.Detach();
return rtnValue.Detach ();
More information about the mapguide-commits
