[mapguide-commits] r9956 - in trunk/Tools/MgInstantSetup: InstantSetup InstantSetup.Core
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Aug 10 08:59:37 PDT 2022
Author: jng
Date: 2022-08-10 08:59:36 -0700 (Wed, 10 Aug 2022)
New Revision: 9956
   trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs
   trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs
   trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs
   trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs
Add flag to register netstandard assembly reference for mapviewernet if required (will be required for MGOS 4.0 Preview 4 and newer releases)
Fixes #2850
Modified: trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs	2022-08-10 15:57:43 UTC (rev 9955)
+++ trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs	2022-08-10 15:59:36 UTC (rev 9956)
@@ -47,6 +47,7 @@
             this.groupBox4 = new System.Windows.Forms.GroupBox();
             this.rdDotNet = new System.Windows.Forms.RadioButton();
             this.rdPhp = new System.Windows.Forms.RadioButton();
+            this.chkRefNetstandard = new System.Windows.Forms.CheckBox();
             this.groupBox1.SuspendLayout();
             this.groupBox2.SuspendLayout();
             ((System.ComponentModel.ISupportInitialize)(this.numSitePort)).BeginInit();
@@ -270,15 +271,27 @@
             this.rdPhp.UseVisualStyleBackColor = true;
             this.rdPhp.CheckedChanged += new System.EventHandler(this.rdPhp_CheckedChanged);
+            // chkRefNetstandard
+            this.chkRefNetstandard.AutoSize = true;
+            this.chkRefNetstandard.Location = new System.Drawing.Point(12, 352);
+            this.chkRefNetstandard.Name = "chkRefNetstandard";
+            this.chkRefNetstandard.Size = new System.Drawing.Size(368, 17);
+            this.chkRefNetstandard.TabIndex = 2;
+            this.chkRefNetstandard.Text = "Add netstandard reference (needed for MGOS 4.0 Preview 4 and newer)";
+            this.chkRefNetstandard.UseVisualStyleBackColor = true;
+            this.chkRefNetstandard.CheckedChanged += new System.EventHandler(this.chkRefNetstandard_CheckedChanged);
             // IISConfigCtrl
             this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.Controls.Add(this.chkRefNetstandard);
             this.Controls.Add(this.groupBox4);
             this.Controls.Add(this.groupBox2);
             this.Controls.Add(this.groupBox1);
             this.Name = "IISConfigCtrl";
-            this.Size = new System.Drawing.Size(422, 358);
+            this.Size = new System.Drawing.Size(422, 383);
             this.groupBox1.ResumeLayout(false);
             this.groupBox1.PerformLayout();
             this.groupBox2.ResumeLayout(false);
@@ -289,6 +302,7 @@
             this.groupBox4.ResumeLayout(false);
             this.groupBox4.PerformLayout();
             this.ResumeLayout(false);
+            this.PerformLayout();
@@ -313,5 +327,6 @@
         private System.Windows.Forms.RadioButton rdPhp;
         private System.Windows.Forms.TextBox txtAppPool;
         private System.Windows.Forms.Label label7;
+        private System.Windows.Forms.CheckBox chkRefNetstandard;
Modified: trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs	2022-08-10 15:57:43 UTC (rev 9955)
+++ trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs	2022-08-10 15:59:36 UTC (rev 9956)
@@ -47,6 +47,9 @@
             rdDotNet.Checked = _confImpl.EnableDotNet;
             rdPhp.Checked = _confImpl.EnablePhp;
+            chkRefNetstandard.Enabled = rdDotNet.Checked;
+            _confImpl.AddNetstandardReference = chkRefNetstandard.Checked;
         public AbstractSetupConfigurationProcess Config
@@ -64,6 +67,8 @@
             _confImpl.EnableDotNet = rdDotNet.Checked;
             _confImpl.EnablePhp = rdPhp.Checked;
         private void rdPhp_CheckedChanged(object sender, EventArgs e)
@@ -106,5 +111,10 @@
             _confImpl.ApplicationPool = txtAppPool.Text;
+        private void chkRefNetstandard_CheckedChanged(object sender, EventArgs e)
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs	2022-08-10 15:57:43 UTC (rev 9955)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs	2022-08-10 15:59:36 UTC (rev 9956)
@@ -3,6 +3,7 @@
 using System.Text;
 using System.IO;
 using System.Diagnostics;
+using System.Xml;
 namespace InstantSetup.Core
@@ -199,9 +200,9 @@
             return Process.Start(psi);
-        internal void SetupCore(FormatLineWriter writer, bool b64BitMapGuide)
+        internal void SetupCore(FormatLineWriter writer, bool b64BitMapGuide, bool referenceNetstandard)
-            writer($"Running a series of appcmd calls to set up IIS (64-bit: {b64BitMapGuide})");
+            writer($"Running a series of appcmd calls to set up IIS (64-bit: {b64BitMapGuide}, ref netstandard: {referenceNetstandard})");
             Process p = null;
             p = StartAppCmdProcess(writer, string.Format(CREATE_FASTCGI, _phpDir));
@@ -277,6 +278,64 @@
             p = StartAppCmdProcess(writer, string.Format(SET_MAPVIEWERNET_REQ_VALIDATION_MODE, _webSite, _virtualDir));
             Trace.TraceInformation(p.StandardOutput.ReadToEnd()); p.WaitForExit();
             //if (p.ExitCode != 0) Debugger.Break();
+            //HACK: I'm pretty sure there's a way to do this through appcmd, but I can't figure it out
+            //so we'll add the necessary reference through XML document manipulation
+            if (referenceNetstandard)
+                var webConfigPath = Path.Combine(this._webExtensionsRootDir, "www", "mapviewernet", "web.config");
+                if (File.Exists(webConfigPath))
+                    var webConfig = new XmlDocument();
+                    webConfig.Load(webConfigPath);
+                    bool bChanged = false;
+                    // We should have at least a configuration/system.web/compilation element already there
+                    var conf = webConfig.SelectSingleNode("//configuration/system.web/compilation");
+                    if (conf != null)
+                        const string NETSTANDARD_REF = "netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51";
+                        XmlNode asmNode = null;
+                        if (conf["assemblies"] == null)
+                            asmNode = webConfig.CreateElement("assemblies");
+                            conf.AppendChild(asmNode);
+                            bChanged = true;
+                        var nsRefNode = asmNode.SelectSingleNode($"add[assembly='{NETSTANDARD_REF}']");
+                        if (nsRefNode == null)
+                            nsRefNode = webConfig.CreateElement("add");
+                            var asmAttr = webConfig.CreateAttribute("assembly");
+                            asmAttr.Value = NETSTANDARD_REF;
+                            nsRefNode.Attributes.Append(asmAttr);
+                            asmNode.AppendChild(nsRefNode);
+                            bChanged = true;
+                            writer($"Added netstandard reference to web.config");
+                        if (bChanged)
+                            webConfig.Save(webConfigPath);
+                            writer($"web.config updated");
+                    else
+                        writer($"ERROR: Could not find the expected configuration/system.web/compilation element in this web.config file!");
+                else
+                    writer($"WARNING: Expected to find ({webConfigPath}), but it could not be found!");
         internal void SetDefaultDotNetViewer(FormatLineWriter writer)
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs	2022-08-10 15:57:43 UTC (rev 9955)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs	2022-08-10 15:59:36 UTC (rev 9956)
@@ -65,6 +65,8 @@
         public bool Enable32BitAppsOnWin64 { get; set; }
+        public bool AddNetstandardReference { get; set; }
         protected override void DoBackupConfigFiles(FormatLineWriter writer)
@@ -83,7 +85,7 @@
         protected override void ConfigureWebServer(FormatLineWriter writer)
             var cmd = new AppCmd(this.AppCmdPath, this.WebSiteName, this.VirtualDirectoryName, this.ApplicationPool, this.WebTierRootDir, this.WebTierPhpDir);
-            cmd.SetupCore(writer, this.Is64BitMapGuide);
+            cmd.SetupCore(writer, this.Is64BitMapGuide, this.AddNetstandardReference);
             if (this.EnableDotNet)
                 cmd.SetDefaultDotNetViewer(writer);
             else if (this.EnablePhp)
More information about the mapguide-commits mailing list
