[mapguide-commits] r9957 - in sandbox/jng/vanilla_swig: . Bindings
svn_mapguide at osgeo.org
Tue Aug 16 04:14:19 PDT 2022
Author: jng
Date: 2022-08-16 04:14:18 -0700 (Tue, 16 Aug 2022)
New Revision: 9957
sandbox/jng/vanilla_swig/Bindings/TODO.txt
sandbox/jng/vanilla_swig/cmake_bootstrap.sh
Acquire/build SWIG in cmake_bootstrap.sh if required
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2022-08-10 15:59:36 UTC (rev 9956)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2022-08-16 11:14:18 UTC (rev 9957)
@@ -22,6 +22,7 @@
- Generate and build the .net/Java SWIG glue libraries
- Copy the compiled libs out of the docker container and into the same native library staging area for Java/.net
- (x) OR: Update our common libs dockerfile in (https://github.com/jumpinjackie/mapguide-fdo-docker-build) to perform the above tasks
+ - [ ] Remove --common-subset-only flag from cmake_bootstrap.sh. Instead do the full build, but package up a common libs tarball of the needed .so files
- [x] Refactor current .net test suite to reference these nuget packages
- [x] Verify test suite still passes (Windows)
- [x] Verify test suite still passes (Windows, legacy .net Framework)
Modified: sandbox/jng/vanilla_swig/cmake_bootstrap.sh
--- sandbox/jng/vanilla_swig/cmake_bootstrap.sh 2022-08-10 15:59:36 UTC (rev 9956)
+++ sandbox/jng/vanilla_swig/cmake_bootstrap.sh 2022-08-16 11:14:18 UTC (rev 9957)
@@ -141,6 +141,22 @@
echo "INTERNAL_GEOS = $INTERNAL_GEOS"
echo "COMMON_SUBSET_ONLY = $COMMON_SUBSET_ONLY"
+# Acquire SWIG
+which swig
+# which exits with 0 if swig is found, 1 otherwise
+have_swig=$?
+if [ "$have_swig" != "0" ]; then
+ echo "SWIG not found. Acquiring and building SWIG from source"
+ cd /tmp/ || exit
+ # TODO: Until SWIG 4.1 is actually released, should fix the source archive to a particular commit (if it's possible)
+ wget https://github.com/swig/swig/archive/refs/heads/master.zip
+ unzip master.zip
+ cd /tmp/swig-master/ || exit
+ ./autogen.sh && ./configure && make && make install
+else
+ echo "SWIG already installed"
+fi
if [ "$USE_CCACHE" = "1" ]; then
export CC="ccache gcc"
export CXX="ccache g++"
More information about the mapguide-commits
