[mapguide-commits] r9963 - in sandbox/jng/vanilla_swig: . Oem/DWFTK/develop/global/src Oem/DWFTK/develop/global/src/dwfcore Oem/DWFTK/develop/global/src/dwfcore/x64 Oem/agg-2.4/include Oem/dbxml/db-4.8.26/dbinc Oem/dbxml/db-4.8.26/mutex cmake/modules
svn_mapguide at osgeo.org
Fri Aug 26 13:50:48 PDT 2022
Author: jng
Date: 2022-08-26 13:50:46 -0700 (Fri, 26 Aug 2022)
New Revision: 9963
Added:
sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/atomic.h
sandbox/jng/vanilla_swig/cmake/modules/FindUUID.cmake
sandbox/jng/vanilla_swig/CMakeLists.txt
sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/CMakeLists.txt
sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt
sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp
sandbox/jng/vanilla_swig/Oem/agg-2.4/include/agg_renderer_outline_aa.h
sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/dbinc/atomic.h
sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/mutex/mut_tas.c
sandbox/jng/vanilla_swig/cmake_bootstrap.sh
sandbox/jng/vanilla_swig/cmake_linuxapt.sh
Start fixing up the Linux build:
- Don't add_subdirectory the BuildTools directory. This caused a double-definition of the IMake target. The one in BuildTools is the older one which will be removed soon.
- Add local atomic.h to DWFTK. This is a file we previously externally overlaid into /usr/include in our build VM images or docker build containers, so it was trusted to exist. When building on bare-metal Ubuntu this isn't the case.
- Use cmake packages to find pthread and uuid for DWFTK instead of find_library
- Fix berkeley db build.
- Rename "__atomic_compare_exchange" to "__atomic_compare_exchange_db" to prevent collision with a built-in of the same name
- The previous fixes to get this compiling for MSVC 2019 on Windows was incomplete for Linux as there was still several cases of "atomic_init" that didn't get renamed to "bdb_atomic_init"
- Fix up SWIG acquision code to not wget the master archive if it already exists in destination
- Remove non-const profile() method from agg_renderer_outline_aa
- Update various version numbers of LinuxApt tarballs in cmake_linuxapt.sh
- Update php ./configure arguments for PHP 8.1
Modified: sandbox/jng/vanilla_swig/CMakeLists.txt
--- sandbox/jng/vanilla_swig/CMakeLists.txt 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
@@ -253,9 +253,6 @@
set (NEED_LIBRT 1)
endif (NOT HAVE_CLOCK_GETTIME)
-if (NOT MG_COMMON_SUBSET_ONLY)
- add_subdirectory(BuildTools)
-endif (NOT MG_COMMON_SUBSET_ONLY)
add_subdirectory(Oem)
add_subdirectory(Common)
Modified: sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/CMakeLists.txt 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
@@ -2,8 +2,8 @@
add_definitions(-DDWFCORE_BUILD_ZLIB -DDWFCORE_BUILD_EXPAT)
-find_library(pthread REQUIRED)
-find_library(uuid REQUIRED)
+find_package(Threads REQUIRED)
+find_package(UUID REQUIRED)
check_cxx_source_compiles(
"#include <uuid/uuid.h>
int main() {
Modified: sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
@@ -107,19 +107,19 @@
add_library(dwfcore-${DWFCORE_VERSION} SHARED ${dwfcore_SRCS})
-if (HAS_UUID AND NOT uuid-NOTFOUND)
+if (UUID_FOUND)
target_link_libraries(dwfcore-${DWFCORE_VERSION}
-Wl,-Bsymbolic
dl
- pthread
- uuid
+ ${CMAKE_THREAD_LIBS_INIT}
+ ${UUID_LIBRARY}
-else (HAS_UUID AND NOT uuid-NOTFOUND)
+else (UUID_FOUND)
-Wl,-Bsymbolic
dl
- pthread
-endif (HAS_UUID AND NOT uuid-NOTFOUND)
+endif (UUID_FOUND)
configure_file(${CMAKE_CURRENT_SOURCE_DIR}/config.h.in ${CMAKE_CURRENT_BINARY_DIR}/config.h)
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp
--- sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp 2022-08-26 20:50:46 UTC (rev 9963)
@@ -66,7 +66,7 @@
#elif defined( HAVE_ALSA_IATOMIC_H )
#include <alsa/iatomic.h>
#else
- #error Missing atomic header file containing definition of atomic_t - cannot continue
+ #include "atomic.h"
#endif
Added: sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/atomic.h
--- sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/atomic.h (rev 0)
+++ sandbox/jng/vanilla_swig/Oem/DWFTK/develop/global/src/dwfcore/x64/atomic.h 2022-08-26 20:50:46 UTC (rev 9963)
@@ -0,0 +1,127 @@
+#ifndef _ATOMIC_H
+#define _ATOMIC_H
+ * Atomic type.
+typedef struct {
+ volatile int counter;
+} atomic_t;
+#define ATOMIC_INIT(i) { (i) }
+ * Read atomic variable
+ * @param v pointer of type atomic_t
+ * Atomically reads the value of @v.
+#define atomic_read(v) ((v)->counter)
+ * Set atomic variable
+ * @param i required value
+#define atomic_set(v,i) (((v)->counter) = (i))
+ * Add to the atomic variable
+ * @param i integer value to add
+static inline void atomic_add( int i, atomic_t *v )
+ (void)__sync_add_and_fetch(&v->counter, i);
+ * Subtract the atomic variable
+ * @param i integer value to subtract
+ * Atomically subtracts @i from @v.
+static inline void atomic_sub( int i, atomic_t *v )
+ (void)__sync_sub_and_fetch(&v->counter, i);
+ * Subtract value from variable and test result
+ * Atomically subtracts @i from @v and returns
+ * true if the result is zero, or false for all
+ * other cases.
+static inline int atomic_sub_and_test( int i, atomic_t *v )
+ return !(__sync_sub_and_fetch(&v->counter, i));
+ * Increment atomic variable
+ * Atomically increments @v by 1.
+static inline void atomic_inc( atomic_t *v )
+ (void)__sync_fetch_and_add(&v->counter, 1);
+ * @brief decrement atomic variable
+ * @param v: pointer of type atomic_t
+ * Atomically decrements @v by 1. Note that the guaranteed
+ * useful range of an atomic_t is only 24 bits.
+static inline void atomic_dec( atomic_t *v )
+ (void)__sync_fetch_and_sub(&v->counter, 1);
+ * @brief Decrement and test
+ * Atomically decrements @v by 1 and
+ * returns true if the result is 0, or false for all other
+ * cases.
+static inline int atomic_dec_and_test( atomic_t *v )
+ return !(__sync_sub_and_fetch(&v->counter, 1));
+ * @brief Increment and test
+ * and returns true if the result is zero, or false for all
+ * other cases.
+static inline int atomic_inc_and_test( atomic_t *v )
+ return !(__sync_add_and_fetch(&v->counter, 1));
+ * @brief add and test if negative
+ * Atomically adds @i to @v and returns true
+ * if the result is negative, or false when
+ * result is greater than or equal to zero.
+static inline int atomic_add_negative( int i, atomic_t *v )
+ return (__sync_add_and_fetch(&v->counter, i) < 0);
+#endif
Modified: sandbox/jng/vanilla_swig/Oem/agg-2.4/include/agg_renderer_outline_aa.h
--- sandbox/jng/vanilla_swig/Oem/agg-2.4/include/agg_renderer_outline_aa.h 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/Oem/agg-2.4/include/agg_renderer_outline_aa.h 2022-08-26 20:50:46 UTC (rev 9963)
@@ -1365,7 +1365,6 @@
void profile(const line_profile_aa& prof) { m_profile = &prof; }
const line_profile_aa& profile() const { return *m_profile; }
- line_profile_aa& profile() { return *m_profile; }
int subpixel_width() const { return m_profile->subpixel_width(); }
Modified: sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/dbinc/atomic.h
--- sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/dbinc/atomic.h 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/dbinc/atomic.h 2022-08-26 20:50:46 UTC (rev 9963)
@@ -144,7 +144,7 @@
#define atomic_inc(env, p) __atomic_inc(p)
#define atomic_dec(env, p) __atomic_dec(p)
#define atomic_compare_exchange(env, p, o, n) \
- __atomic_compare_exchange((p), (o), (n))
+ __atomic_compare_exchange_db((p), (o), (n))
static inline int __atomic_inc(db_atomic_t *p)
int temp;
@@ -176,7 +176,7 @@
* http://gcc.gnu.org/onlinedocs/gcc-4.1.0/gcc/Atomic-Builtins.html
* which configure could be changed to use.
-static inline int __atomic_compare_exchange(
+static inline int __atomic_compare_exchange_db(
db_atomic_t *p, atomic_value_t oldval, atomic_value_t newval)
atomic_value_t was;
@@ -206,7 +206,7 @@
#define atomic_dec(env, p) (--(p)->value)
#define atomic_compare_exchange(env, p, oldval, newval) \
(DB_ASSERT(env, atomic_read(p) == (oldval)), \
- atomic_init(p, (newval)), 1)
+ bdb_atomic_init(p, (newval)), 1)
#else
#define atomic_inc(env, p) __atomic_inc(env, p)
#define atomic_dec(env, p) __atomic_dec(env, p)
Modified: sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/mutex/mut_tas.c
--- sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/mutex/mut_tas.c 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/Oem/dbxml/db-4.8.26/mutex/mut_tas.c 2022-08-26 20:50:46 UTC (rev 9963)
@@ -46,7 +46,7 @@
#ifdef HAVE_SHARED_LATCHES
if (F_ISSET(mutexp, DB_MUTEX_SHARED))
- atomic_init(&mutexp->sharecount, 0);
+ bdb_atomic_init(&mutexp->sharecount, 0);
else
#endif
if (MUTEX_INIT(&mutexp->tas)) {
@@ -486,7 +486,7 @@
F_CLR(mutexp, DB_MUTEX_LOCKED);
/* Flush flag update before zeroing count */
MEMBAR_EXIT();
} else {
DB_ASSERT(env, sharecount > 0);
MEMBAR_EXIT();
Added: sandbox/jng/vanilla_swig/cmake/modules/FindUUID.cmake
--- sandbox/jng/vanilla_swig/cmake/modules/FindUUID.cmake (rev 0)
+++ sandbox/jng/vanilla_swig/cmake/modules/FindUUID.cmake 2022-08-26 20:50:46 UTC (rev 9963)
@@ -0,0 +1,71 @@
+# - Find UUID
+# Find the native UUID includes and library
+# This module defines
+# UUID_INCLUDE_DIR, where to find jpeglib.h, etc.
+# UUID_LIBRARIES, the libraries needed to use UUID.
+# UUID_FOUND, If false, do not try to use UUID.
+# also defined, but not for general use are
+# UUID_LIBRARY, where to find the UUID library.
+# Copyright (c) 2006-2011 Mathieu Malaterre <mathieu.malaterre at gmail.com>
+# Redistribution and use is allowed according to the terms of the New
+# BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+# On MacOSX we have:
+# $ nm -g /usr/lib/libSystem.dylib | grep uuid_generate
+# 000b3aeb T _uuid_generate
+# 0003e67e T _uuid_generate_random
+# 000b37a1 T _uuid_generate_time
+if(APPLE)
+ set(UUID_LIBRARY_VAR System)
+else()
+ # Linux type:
+ set(UUID_LIBRARY_VAR uuid)
+endif()
+find_library(UUID_LIBRARY
+ NAMES ${UUID_LIBRARY_VAR}
+ PATHS /lib /usr/lib /usr/local/lib
+# Must be *after* the lib itself
+set(CMAKE_FIND_FRAMEWORK_SAVE ${CMAKE_FIND_FRAMEWORK})
+set(CMAKE_FIND_FRAMEWORK NEVER)
+find_path(UUID_INCLUDE_DIR uuid/uuid.h
+/usr/local/include
+/usr/include
+if (UUID_LIBRARY AND UUID_INCLUDE_DIR)
+ set(UUID_LIBRARIES ${UUID_LIBRARY})
+ set(UUID_FOUND "YES")
+else ()
+ set(UUID_FOUND "NO")
+endif ()
+if (UUID_FOUND)
+ if (NOT UUID_FIND_QUIETLY)
+ message(STATUS "Found UUID: ${UUID_LIBRARIES}")
+ endif ()
+else ()
+ if (UUID_FIND_REQUIRED)
+ message( "library: ${UUID_LIBRARY}" )
+ message( "include: ${UUID_INCLUDE_DIR}" )
+ message(FATAL_ERROR "Could not find UUID library")
+ endif ()
+endif ()
+# Deprecated declarations.
+#set (NATIVE_UUID_INCLUDE_PATH ${UUID_INCLUDE_DIR} )
+#get_filename_component (NATIVE_UUID_LIB_PATH ${UUID_LIBRARY} PATH)
+mark_as_advanced(
+ UUID_LIBRARY
+ UUID_INCLUDE_DIR
+set(CMAKE_FIND_FRAMEWORK ${CMAKE_FIND_FRAMEWORK_SAVE})
Modified: sandbox/jng/vanilla_swig/cmake_bootstrap.sh
--- sandbox/jng/vanilla_swig/cmake_bootstrap.sh 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/cmake_bootstrap.sh 2022-08-26 20:50:46 UTC (rev 9963)
@@ -148,9 +148,11 @@
if [ "$have_swig" != "0" ]; then
echo "SWIG not found. Acquiring and building SWIG from source"
cd /tmp/ || exit
- # TODO: Until SWIG 4.1 is actually released, should fix the source archive to a particular commit (if it's possible)
- wget https://github.com/swig/swig/archive/refs/heads/master.zip
- unzip master.zip
+ if [ ! -f /tmp/master.zip ]; then
+ # TODO: Until SWIG 4.1 is actually released, should fix the source archive to a particular commit (if it's possible)
+ wget https://github.com/swig/swig/archive/refs/heads/master.zip
+ fi
+ unzip -o master.zip
cd /tmp/swig-master/ || exit
./autogen.sh && ./configure && make && make install
else
@@ -369,7 +371,7 @@
echo "Has DBXML Library: $HAS_DBXML_LIB"
echo "Has XQilla Library: $HAS_XQILLA_LIB"
-if [ "$COMMON_SUBSET_ONLY" == "1" ]; then
+if [ "$COMMON_SUBSET_ONLY" = "1" ]; then
cp -Rf "${SOURCE_DIR}/Oem/dbxml" "${OEM_WORK_DIR}/dbxml"
cd "${OEM_WORK_DIR}/dbxml" || exit
# The buildall.sh script supports a --build-one flag so we can only build xerces and skip everything else
Modified: sandbox/jng/vanilla_swig/cmake_linuxapt.sh
--- sandbox/jng/vanilla_swig/cmake_linuxapt.sh 2022-08-23 23:53:18 UTC (rev 9962)
+++ sandbox/jng/vanilla_swig/cmake_linuxapt.sh 2022-08-26 20:50:46 UTC (rev 9963)
@@ -119,10 +119,10 @@
echo "Created LinuxApt working dir at: $LINUXAPT_WORK_DIR"
fi
-PHP_VER=5.6.40
-HTTPD_VER=2.4.37
+PHP_VER=8.1.9
+HTTPD_VER=2.4.52
TC_VER=1.2.48
-APR_VER=1.6.5
+APR_VER=1.7.0
APR_UTIL_VER=1.6.1
HTTPD_PORT=8008
@@ -204,7 +204,7 @@
cd "${PHP_WORKDIR}" || exit
# TODO: Patch out the use of meta_ccld so ccache can work: https://bugs.php.net/bug.php?id=75940
# if/when we finally move to PHP 7, this patch is already applied
- ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --with-curl --enable-xml --enable-wddx --enable-shared --with-zlib-dir="$PHP_ZLIB_DIR" --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png-dir="$PHP_PNG_DIR" --with-jpeg-dir="$PHP_JPEG_DIR" --with-freetype-dir="$PHP_FREETYPE_DIR" 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
+ ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --enable-mbstring --enable-gd --with-jpeg --with-png --with-libxml 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
check_build
echo "Building PHP. Please wait"
make 2>&1 | tee "$LINUXAPT_WORK_DIR/make_php.log"
More information about the mapguide-commits
