[mapguide-commits] r9964 - in sandbox/jng/vanilla_swig: . Bindings/src/Bindings Bindings/src/Bindings/DotNet Bindings/src/Bindings/DotNet/Foundation Bindings/src/Bindings/DotNet/Geometry Bindings/src/Bindings/DotNet/MapGuideCommon Bindings/src/Bindings/DotNet/PlatformBase Bindings/src/Bindings/DotNet/Web Bindings/src/Bindings/Java Bindings/src/Bindings/Php Web/src
svn_mapguide at osgeo.org
Wed Aug 31 09:19:45 PDT 2022
Author: jng
Date: 2022-08-31 09:19:44 -0700 (Wed, 31 Aug 2022)
New Revision: 9964
sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Web/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/CMakeLists.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/CMakeLists.txt
sandbox/jng/vanilla_swig/CMakeLists.txt
sandbox/jng/vanilla_swig/Web/src/CMakeLists.txt
sandbox/jng/vanilla_swig/cmake_linuxapt.sh
Fix up the Linux build some more:
- Don't search for internal SWIG. This tool is now assumed to be externally available
- Remove more invalid params in PHP ./configure call in cmake_linuxapt.sh
- Don't add_subdirectory the "legacy" Java and PHP binding directires in WebTier. These directories will be removed eventually
- CMake changes/fixes for binding targets:
- Fix up IMake/SWIG invocation to now assume external SWIG (that we assume will be SWIG 4.1+). Primarily, the invocations should be done in the context of the original *source* directory and not the active cmake binary dir because the relative header paths in the *Constants and *ApiGen xml files are relative the the *source* directory, not the active cmake binary dir
- Remove hack PHP swig workarounds
- Streamline expected include directories
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -1,7 +1,19 @@
+# These include dirs will be common for all language binding C++ glue being built, so define it here
+include_directories(
+ ${MG_COMMON_DIR}/MdfModel
+ ${MG_COMMON_DIR}/Foundation
+ ${MG_COMMON_DIR}/Geometry
+ ${MG_COMMON_DIR}/PlatformBase
+ ${MG_COMMON_DIR}/MapGuideCommon
+ ${ACE_INCLUDE_DIR}
+ ${MG_WEB_DIR}/src/HttpHandler
+ ${MG_WEB_DIR}/src/WebSupport
+ ${MG_WEB_DIR}/src/WebApp
+ ${XERCESC_INCLUDE_DIR}
add_subdirectory(DotNet)
-#if (WITH_JAVA)
-# add_subdirectory(Java)
-#endif (WITH_JAVA)
-#if (WITH_PHP)
-# add_subdirectory(Php)
-#endif (WITH_PHP)
\ No newline at end of file
+if (WITH_JAVA)
+ add_subdirectory(Java)
+endif (WITH_JAVA)
+add_subdirectory(Php)
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -1,16 +1,3 @@
-include_directories(
- ${MG_COMMON_DIR}/MdfModel
- ${MG_COMMON_DIR}/Foundation
- ${MG_COMMON_DIR}/Geometry
- ${MG_COMMON_DIR}/PlatformBase
- ${MG_COMMON_DIR}/MapGuideCommon
- ${ACE_INCLUDE_DIR}
- ${MG_WEB_DIR}/src/HttpHandler
- ${MG_WEB_DIR}/src/WebSupport
- ${MG_WEB_DIR}/src/WebApp
- ${XERCESC_INCLUDE_DIR}
add_subdirectory(Foundation)
add_subdirectory(Geometry)
add_subdirectory(PlatformBase)
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Foundation/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -51,6 +51,13 @@
-x "FoundationApi"
${IMAKE_RELATIVE_RESOLUTION}
-o ${CMAKE_CURRENT_BINARY_DIR}
+ COMMAND ${CMAKE_COMMAND} -E remove -f
+ ${CMAKE_CURRENT_BINARY_DIR}/FoundationApi_Properties.i
+ COMMAND ${CMAKE_COMMAND} -E copy
+ ${CMAKE_CURRENT_SOURCE_DIR}/FoundationApi_Properties.i
COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [DotNet]. Output Dir: ${MG_DOTNET_PROJECT_DIR}
COMMAND ${SWIG_EXECUTABLE} -c++ -csharp
${SWIG_DOTNET_DEFS} -DDOTNETCORE -DSWIG_CSHARP_NO_EXCEPTION_HELPER
@@ -61,18 +68,15 @@
-o "${CMAKE_CURRENT_BINARY_DIR}/FoundationUnmanagedApi_wrap.cpp"
-outdir "${MG_DOTNET_PROJECT_DIR}"
"${CMAKE_CURRENT_BINARY_DIR}/FoundationApi.i"
+ # These commands need to be run in the context of the source directory so that the relative header references
+ # in the Constants and ApiGen xml files will resolve propertly (because these headers won't exist in the cmake
+ # binary dir)
+ WORKING_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}
target_link_libraries(FoundationUnmanagedApi
${ACE_LIBRARY}
MgFoundation${MG_VERSION_SUFFIX}
- #MgGeometry${MG_VERSION_SUFFIX}
- #MgPlatformBase${MG_VERSION_SUFFIX}
- #MgMapGuideCommon${MG_VERSION_SUFFIX}
- #MgHttpHandler${MG_VERSION_SUFFIX}
- #MgMdfModel${MG_VERSION_SUFFIX}
- #MgMdfParser${MG_VERSION_SUFFIX}
- #MgWebApp${MG_VERSION_SUFFIX}
${XERCESC_LIBRARIES}
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Geometry/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -49,6 +49,13 @@
-x "GeometryApi"
+ ${CMAKE_CURRENT_BINARY_DIR}/GeometryApi_Properties.i
+ ${CMAKE_CURRENT_SOURCE_DIR}/GeometryApi_Properties.i
@@ -59,6 +66,10 @@
-o "${CMAKE_CURRENT_BINARY_DIR}/GeometryUnmanagedApi_wrap.cpp"
"${CMAKE_CURRENT_BINARY_DIR}/GeometryApi.i"
+ # binary dir)
target_link_libraries(GeometryUnmanagedApi
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/MapGuideCommon/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -49,6 +49,17 @@
-x "MapGuideCommonApi"
+ # Nothing in the MapGuideCommon API surface currently declares .net property wrapper annotations so
+ # no _Properties.i file is generated at the moment. If/when that changes, uncomment the lines below to
+ # ensure this generated file is "moved" to the proper location
+ # COMMAND ${CMAKE_COMMAND} -E remove -f
+ # ${CMAKE_CURRENT_BINARY_DIR}/MapGuideCommonApi_Properties.i
+ # COMMAND ${CMAKE_COMMAND} -E copy
+ # ${CMAKE_CURRENT_SOURCE_DIR}/MapGuideCommonApi_Properties.i
@@ -59,6 +70,10 @@
-o "${CMAKE_CURRENT_BINARY_DIR}/MapGuideCommonUnmanagedApi_wrap.cpp"
"${CMAKE_CURRENT_BINARY_DIR}/MapGuideCommonApi.i"
+ # binary dir)
target_link_libraries(MapGuideCommonUnmanagedApi
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -49,6 +49,13 @@
-x "PlatformBaseApi"
+ ${CMAKE_CURRENT_BINARY_DIR}/PlatformBaseApi_Properties.i
+ ${CMAKE_CURRENT_SOURCE_DIR}/PlatformBaseApi_Properties.i
@@ -59,6 +66,10 @@
-o "${CMAKE_CURRENT_BINARY_DIR}/PlatformBaseUnmanagedApi_wrap.cpp"
"${CMAKE_CURRENT_BINARY_DIR}/PlatformBaseApi.i"
+ # binary dir)
target_link_libraries(PlatformBaseUnmanagedApi
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Web/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Web/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/Web/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -52,6 +52,13 @@
-x "WebApi"
+ # ${CMAKE_CURRENT_BINARY_DIR}/WebApi_Properties.i
+ # ${CMAKE_CURRENT_SOURCE_DIR}/WebApi_Properties.i
@@ -62,6 +69,10 @@
-o "${CMAKE_CURRENT_BINARY_DIR}/WebUnmanagedApi_wrap.cpp"
"${CMAKE_CURRENT_BINARY_DIR}/WebApi.i"
+ # binary dir)
target_link_libraries(WebUnmanagedApi
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -1,17 +1,6 @@
project(MapGuideJavaApi)
-include_directories(${JNI_INCLUDE_DIRS}
- ${MG_WEB_DIR}/HttpHandler
- ${MG_WEB_DIR}/WebSupport
- ${MG_WEB_DIR}/WebApp
+include_directories(${JNI_INCLUDE_DIRS})
set(SWIG_JAVA_DEFS "")
if (WIN32)
@@ -31,17 +20,17 @@
message(STATUS "Using IMake at: ${IMAKE_TOOL}")
add_custom_command(OUTPUT ${MapGuideJavaApi_SRCS}
- COMMAND ${CMAKE_COMMAND} -E make_directory ${MG_JAVA_OUTPUT_DIR}
+ COMMAND ${CMAKE_COMMAND} -E make_directory ${CMAKE_CURRENT_BINARY_DIR}/org/osgeo/mapguide
COMMAND ${CMAKE_COMMAND} -E echo Regenerating constant classes
- COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_BINARY_DIR}/../MapGuideApi/Constants.xml
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/../MapGuideApi/Constants.xml
-l Java
- -o ${MG_JAVA_PROJECT_DIR}/org/osgeo/mapguide
+ -o ${CMAKE_CURRENT_BINARY_DIR}/org/osgeo/mapguide
-t
${CMAKE_CURRENT_BINARY_DIR}/java.i
${CMAKE_CURRENT_BINARY_DIR}/language.i
- COMMAND ${IMAKE_TOOL} -p ../MapGuideApi/MapGuideApiGen.xml
+ COMMAND ${IMAKE_TOOL} -p ${CMAKE_CURRENT_SOURCE_DIR}/../MapGuideApi/MapGuideApiGen.xml
-l Java
@@ -54,10 +43,14 @@
-o "${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp"
${CMAKE_CURRENT_BINARY_DIR}/MapGuideApi.i
- ${MG_JAVA_PROJECT_DIR}/org/osgeo/mapguide/*.class
+ ${CMAKE_CURRENT_BINARY_DIR}/org/osgeo/mapguide/*.class
COMMAND ${MOVE_COMMAND} ${MOVE_ARGS}
- *.java
+ ${CMAKE_CURRENT_BINARY_DIR}/*.java
+ # binary dir)
add_library(MapGuideJavaApi${MG_VERSION_SUFFIX} SHARED ${MapGuideJavaApi_SRCS})
@@ -85,24 +78,16 @@
target_link_libraries(MapGuideJavaApi${MG_VERSION_SUFFIX}
${ACE_LIBRARY}
#${JNI_LIBRARIES}
- ${MG_FOUNDATION_LIBRARY}
- ${MG_GEOMETRY_LIBRARY}
- ${MG_PLATFORMBASE_LIBRARY}
- ${MG_COMMON_LIBRARY}
- ${MG_HTTPHANDLER_LIBRARY}
- ${MG_WEBAPP_LIBRARY}
- ${MG_MDFMODEL_LIBRARY}
- ${MG_MDFPARSER_LIBRARY}
- ${MG_WEBSUPPORT_LIBRARY}
- #MgFoundation${MG_VERSION_SUFFIX}
+ MgFoundation${MG_VERSION_SUFFIX}
+ MgGeometry${MG_VERSION_SUFFIX}
+ MgPlatformBase${MG_VERSION_SUFFIX}
+ MgMapGuideCommon${MG_VERSION_SUFFIX}
+ MgHttpHandler${MG_VERSION_SUFFIX}
+ MgMdfModel${MG_VERSION_SUFFIX}
+ MgMdfParser${MG_VERSION_SUFFIX}
+ MgWebApp${MG_VERSION_SUFFIX}
+ MgWebSupport${MG_VERSION_SUFFIX}
# Only needed for Linux
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -5,25 +5,21 @@
set ( CMAKE_SHARED_LINKER_FLAGS "${WEB_CMAKE_SHARED_LINKER_FLAGS}")
endif (CMAKE_COMPILER_IS_GNUCXX)
-include_directories(${CMAKE_CURRENT_SOURCE_DIR}
- ${PHP_INCLUDE_DIR}/TSRM
+include_directories(${PHP_INCLUDE_DIR}/TSRM
${PHP_INCLUDE_DIR}/Zend
${PHP_INCLUDE_DIR}/main
+ ${PHP_INCLUDE_DIR})
-set(MG_PHP_OUTPUT_DIR "${MG_PACKAGE_OUTPUT_DIR}/Php/${CMAKE_BUILD_TYPE}/${MG_ARCH}")
+set(SWIG_PHP_DEFS "")
+if (WIN32)
+ set(SWIG_PHP_DEFS "-DWIN32")
+endif (WIN32)
+# These 2 files will be #included in the MgApi_wrap translation unit so they need
+# to be present on the current binary dir where MgApi_wrap.cpp will be generated in
+file(COPY "PhpClassMap.cpp" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+file(COPY "PhpLocalizer.cpp" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
set(php_MapGuideApi_SRCS
@@ -52,32 +48,28 @@
add_custom_command(OUTPUT ${php_MapGuideApi_SRCS}
- COMMAND ${CMAKE_COMMAND} -E make_directory ${MG_PHP_OUTPUT_DIR}
- COMMAND ${CMAKE_COMMAND} -E echo Regenerating: ${CMAKE_CURRENT_BINARY_DIR}/constants.php
-l PHP
- -o ${MG_PHP_OUTPUT_DIR}/constants.php
+ -o ${CMAKE_CURRENT_BINARY_DIR}/constants.i
-t
${CMAKE_CURRENT_BINARY_DIR}/php.i
-l PHP
- COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [PHP7]
- COMMAND ${SWIG_TOOL} -c++ -php7
- -DWIN32 -DPHPSWIG
+ COMMAND ${CMAKE_COMMAND} -E echo Running SWIG [PHP]
+ COMMAND ${SWIG_TOOL} -c++ -php
+ -DPHPSWIG ${SWIG_PHP_DEFS}
-nodefaultctor -nodefaultdtor
- COMMAND ${CMAKE_COMMAND} -E echo Applying PHP7 swig workaround patch
- COMMAND ${SED_COMMAND} ${SED_ARGS} "s#(MapGuideApi_globals.error_msg)#ZEND_MODULE_GLOBALS_ACCESSOR(MapGuideApi, error_msg)#g; s#(MapGuideApi_globals.error_code)#ZEND_MODULE_GLOBALS_ACCESSOR(MapGuideApi, error_code)#g"
- "${CMAKE_CURRENT_BINARY_DIR}/MgApi_wrap.cpp"
- COMMAND ${MOVE_COMMAND} ${MOVE_ARGS}
- MapGuideApi.php
- ${MG_PHP_OUTPUT_DIR}
+ # binary dir)
# if (UNIX)
Modified: sandbox/jng/vanilla_swig/CMakeLists.txt
--- sandbox/jng/vanilla_swig/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -194,10 +194,8 @@
find_package(Sanitizers)
find_package(MapGuideThirdparty REQUIRED)
-# Set internal tool paths
-set(IMAKE_TOOL ${CMAKE_CURRENT_BINARY_DIR}/BuildTools/WebTools/IMake/IMake)
-set(SWIG_TOOL ${MG_OEM_ROOT_BUILD_DIR}/SWIGEx/swig)
-set(SWIG_LIB_PATH ${MG_OEM_ROOT_BUILD_DIR}/SWIGEx/Lib)
+# We no longer use internal SWIG, we expect this to be found externally
+find_program(SWIG_TOOL swig)
# Set common commands.
set(MOVE_COMMAND "mv")
Modified: sandbox/jng/vanilla_swig/Web/src/CMakeLists.txt
--- sandbox/jng/vanilla_swig/Web/src/CMakeLists.txt 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/Web/src/CMakeLists.txt 2022-08-31 16:19:44 UTC (rev 9964)
@@ -9,15 +9,7 @@
if (NOT MG_COMMON_SUBSET_ONLY)
add_subdirectory(DevHttpServer)
#add_subdirectory(CgiAgent)
- add_subdirectory(PhpApi)
- if (WITH_JAVA)
- # For preview 3 until new vanilla SWIG wrapper in place, only build/ship MapGuideJavaApiEx.jar
- #add_subdirectory(JavaApi)
- add_subdirectory(JavaApiEx)
- endif (WITH_JAVA)
- # Needed for api binding generation
- file(COPY "MapGuideApi" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
file(COPY "WEB-INF" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/localized DESTINATION ${MG_WWWROOT} COMPONENT ${MG_COMPONENT})
Modified: sandbox/jng/vanilla_swig/cmake_linuxapt.sh
--- sandbox/jng/vanilla_swig/cmake_linuxapt.sh 2022-08-26 20:50:46 UTC (rev 9963)
+++ sandbox/jng/vanilla_swig/cmake_linuxapt.sh 2022-08-31 16:19:44 UTC (rev 9964)
@@ -204,7 +204,7 @@
cd "${PHP_WORKDIR}" || exit
# TODO: Patch out the use of meta_ccld so ccache can work: https://bugs.php.net/bug.php?id=75940
# if/when we finally move to PHP 7, this patch is already applied
- ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --enable-mbstring --enable-gd --with-jpeg --with-png --with-libxml 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
+ ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --enable-mbstring --enable-gd --with-jpeg --with-libxml 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
check_build
echo "Building PHP. Please wait"
make 2>&1 | tee "$LINUXAPT_WORK_DIR/make_php.log"
More information about the mapguide-commits
