[mapguide-commits] r9933 - in sandbox/jng/vanilla_swig/Bindings/src/SwigCommon: . Java Php
svn_mapguide at osgeo.org
Fri May 20 05:46:46 PDT 2022
Author: jng
Date: 2022-05-20 05:46:45 -0700 (Fri, 20 May 2022)
New Revision: 9933
sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Java/exception.i
sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/exception.i
sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/pointer.i
sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/refcount.i
Suffix our refcounting diagnostic functions/macros with "Hook" to prevent calls to JNIEnv->NewObject in the Java API binding being interpreted as a macro
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Java/exception.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Java/exception.i 2022-05-20 12:44:40 UTC (rev 9932)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Java/exception.i 2022-05-20 12:46:45 UTC (rev 9933)
@@ -34,7 +34,7 @@
if (mgException != NULL) {
//AddRef the exception as this is a Ptr<> it will auto-unref when leaving the method
(*mgException).AddRef();
- RefCount(mgException);
+ RefCountHook(mgException);
ThrowJavaExceptionWrapper(jenv, mgException);
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/exception.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/exception.i 2022-05-20 12:44:40 UTC (rev 9932)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/exception.i 2022-05-20 12:46:45 UTC (rev 9933)
@@ -61,7 +61,7 @@
ThrowPhpExceptionWrapper(mgException);
SWIG_fail;
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/pointer.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/pointer.i 2022-05-20 12:44:40 UTC (rev 9932)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/pointer.i 2022-05-20 12:46:45 UTC (rev 9933)
@@ -22,7 +22,7 @@
SWIG_SetPointerZval($result, (void *)$1, ty, 1); /* owner = $owner */
if ($owner) // is owner?
- NewObject($1);
+ NewObjectHook($1);
else
- RefCount($1);
+ RefCountHook($1);
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/refcount.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/refcount.i 2022-05-20 12:44:40 UTC (rev 9932)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/refcount.i 2022-05-20 12:46:45 UTC (rev 9933)
@@ -19,7 +19,7 @@
#include "Foundation.h"
#if defined(REFCOUNTING_DIAGNOSTICS)
-INT32 NewObject(MgDisposable* obj)
+INT32 NewObjectHook(MgDisposable* obj)
if (NULL != obj)
@@ -34,7 +34,7 @@
return -1;
-INT32 RefCount(MgDisposable* obj)
+INT32 RefCountHook(MgDisposable* obj)
if (NULL != obj)
@@ -63,8 +63,8 @@
SAFE_RELEASE(obj);
#else
-#define NewObject(obj)
-#define RefCount(obj)
+#define NewObjectHook(obj)
+#define RefCountHook(obj)
void ReleaseObject(MgDisposable* obj)
SAFE_RELEASE(obj);
More information about the mapguide-commits
