[mapguide-commits] r9934 - in sandbox/jng/vanilla_swig: . Web/src/MapGuideApi
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri May 20 07:24:06 PDT 2022
Author: jng
Date: 2022-05-20 07:24:06 -0700 (Fri, 20 May 2022)
New Revision: 9934
   sandbox/jng/vanilla_swig/Web/src/MapGuideApi/copydlls.bat
   sandbox/jng/vanilla_swig/build.bat
   sandbox/jng/vanilla_swig/setenvironment64.bat
Update build.bat to build oem/server/web/bindings end-to-end.
Update copydlls.bat to be usable from the root build.bat.
Update setenvironment64.bat to do a "dotnet restore" on the bindings solution (as it has net6.0 projects with external nuget package references).
Modified: sandbox/jng/vanilla_swig/Web/src/MapGuideApi/copydlls.bat
--- sandbox/jng/vanilla_swig/Web/src/MapGuideApi/copydlls.bat	2022-05-20 12:46:45 UTC (rev 9933)
+++ sandbox/jng/vanilla_swig/Web/src/MapGuideApi/copydlls.bat	2022-05-20 14:24:06 UTC (rev 9934)
@@ -16,9 +16,13 @@
 if "%1"=="BUILD" goto copy_build
 if "%1"=="RELEASE" goto copy_release
+if "%1"=="Release" goto copy_release
 if "%1"=="RELEASE64" goto copy_release64
+if "%1"=="Release64" goto copy_release64
 if "%1"=="DEBUG" goto copy_debug
+if "%1"=="Debug" goto copy_debug
 if "%1"=="DEBUG64" goto copy_debug64
+if "%1"=="Debug64" goto copy_debug64
 REM ---- DEFAULT -----
Modified: sandbox/jng/vanilla_swig/build.bat
--- sandbox/jng/vanilla_swig/build.bat	2022-05-20 12:46:45 UTC (rev 9933)
+++ sandbox/jng/vanilla_swig/build.bat	2022-05-20 14:24:06 UTC (rev 9934)
@@ -286,80 +286,90 @@
 :install_server
 echo [install]: Server
 echo [install]: Server - Binaries
-%XCOPY_SINGLE% "%MG_SERVER%\bin\%TYPEBUILD%" "%MG_OUTPUT_SERVER%\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY_SINGLE% "%MG_SERVER%\bin\%TYPEBUILD%" "%MG_OUTPUT_SERVER%\bin"
 echo [install]: Server - FDO
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\FDO" "%MG_OUTPUT_SERVER%\FDO" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\FDO" "%MG_OUTPUT_SERVER%\FDO"
 echo [install]: Server - Logs
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Logs" "%MG_OUTPUT_SERVER%\Logs" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Logs" "%MG_OUTPUT_SERVER%\Logs"
 echo [install]: Server - Packages
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Packages" "%MG_OUTPUT_SERVER%\Packages" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Packages" "%MG_OUTPUT_SERVER%\Packages"
 echo [install]: Server - Repositories
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Repositories" "%MG_OUTPUT_SERVER%\Repositories" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Repositories" "%MG_OUTPUT_SERVER%\Repositories"
 echo [install]: Server - Resources
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Resources" "%MG_OUTPUT_SERVER%\Resources" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Resources" "%MG_OUTPUT_SERVER%\Resources"
 echo [install]: Server - Schema
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Schema" "%MG_OUTPUT_SERVER%\Schema" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Schema" "%MG_OUTPUT_SERVER%\Schema"
 echo [install]: Server - Temp
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Temp" "%MG_OUTPUT_SERVER%\Temp" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Temp" "%MG_OUTPUT_SERVER%\Temp"
 echo [install]: Server - WFS
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wfs" "%MG_OUTPUT_SERVER%\wfs" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wfs" "%MG_OUTPUT_SERVER%\wfs"
 echo [install]: Server - WMS
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wms" "%MG_OUTPUT_SERVER%\wms" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wms" "%MG_OUTPUT_SERVER%\wms"
 echo [install]: Server - DBXML
 copy /Y "%MG_BUILD_DBXML_EXE_PATH%\*.exe" "%MG_OUTPUT_SERVER%\bin"
 echo [install]: Server - RepositoryAdmin
-%XCOPY% "%MG_SERVER%\RepositoryAdmin" "%MG_OUTPUT_SERVER%\RepositoryAdmin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_SERVER%\RepositoryAdmin" "%MG_OUTPUT_SERVER%\RepositoryAdmin"
 echo [install]: CsMap Dictionaries
-%XCOPY% "%MG_OEM%\CSMap\CsMapDev\Dictionaries" "%MG_OUTPUT_CSMAP%\Dictionaries" /EXCLUDE:svn_excludes.txt+csmap_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_OEM%\CSMap\CsMapDev\Dictionaries" "%MG_OUTPUT_CSMAP%\Dictionaries"
 echo [install]: PDBs - Common
-%XCOPY% "%MG_COMMON%\bin\%TYPEBUILD%\*.pdb" "%MG_OUTPUT%\pdbs" /EXCLUDE:pdb_excludes.txt
+%XCOPY% "%MG_COMMON%\bin\%TYPEBUILD%\*.pdb" "%MG_OUTPUT%\pdbs"
 echo [install]: PDBs - Server
-%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\*.pdb" "%MG_OUTPUT%\pdbs" /EXCLUDE:pdb_excludes.txt
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\*.pdb" "%MG_OUTPUT%\pdbs"
 echo [install]: PDBs - Web
-%XCOPY% "%MG_WEB%\bin\%TYPEBUILD%\*.pdb" "%MG_OUTPUT%\pdbs" /EXCLUDE:pdb_excludes.txt
-%XCOPY% "%MG_WEB%\src\mapagent64\*.pdb" "%MG_OUTPUT%\pdbs" /EXCLUDE:pdb_excludes.txt
+%XCOPY_SINGLE% "%MG_WEB%\bin\%TYPEBUILD%\*.pdb" "%MG_OUTPUT%\pdbs"
+%XCOPY_SINGLE% "%MG_WEB%\src\mapagent64\*.pdb" "%MG_OUTPUT%\pdbs"
 if "%TYPECOMPONENT%"=="server" goto quit
 if "%TYPECOMPONENT%"=="web" goto quit
 :install_web
-echo [install]: web Tier
+echo [install]: Web Tier - dll setup
+pushd "%MG_WEB_SRC%\MapGuideApi"
+call copydlls.bat %TYPEBUILD% %CONFIGURATION%
+popd
 echo [install]: Web Tier - localized
-%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized"
 echo [install]: Web Tier - mapadmin
-%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin"
 echo [install]: Web Tier - mapagent
-%XCOPY% "%MG_BUILD_MAPAGENT_PATH%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%TYPEBUILD%_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_BUILD_MAPAGENT_PATH%" "%MG_OUTPUT_WEB%\www\mapagent"
 echo [install]: Web Tier - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+java_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\www\mapagent"
 echo [install]: Web Tier - mapagent test forms
-%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent"
 echo [install]: Web Tier - stdicons
-%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons"
 echo [install]: Web Tier - viewerfiles
-%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles"
 echo [install]: Web Tier - schemareport
-%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport"
+echo [install]: Web Tier - Resources
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Resources" "%MG_OUTPUT_WEB%\www\mapagent\Resources"
 echo [install]: Web Tier - webconfig.ini
 copy /Y "%MG_WEB_SRC%\webconfig.ini" "%MG_OUTPUT_WEB%\www"
 echo [install]: Web Tier - mapviewerphp
-%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp"
 echo [install]: Web Tier - Tomcat - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\Tomcat\bin"
 echo [install]: Web Tier - php - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\Php"
 echo [install]: Web Tier - php ext - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\Php\ext"
 echo [install]: Web Tier - mapviewernet
-%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet"
 echo [install]: Web Tier - mapviewernet - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin" /EXCLUDE:svn_excludes.txt+dotnet_excludes.txt+%TYPEBUILD%_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\www\mapviewernet\bin"
 echo [install]: Web Tier - mapviewerjava
-%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava"
 echo [install]: Web Tier - mapviewerjava - WEB-INF
-%XCOPY% "%MG_WEB_SRC%\WEB-INF" "%MG_OUTPUT_WEB%\www\WEB-INF" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\WEB-INF" "%MG_OUTPUT_WEB%\www\WEB-INF"
+echo [install]: Web Tier - PHP Bindings
+%XCOPY% "%CD%\packages\php\%CONFIGURATION%\x64\php_MapGuideApi.*" "%MG_OUTPUT_WEB%\Php\ext"
+echo [install]: Web Tier - Java Bindings
+%XCOPY_SINGLE% "%CD%\packages\Java\%CONFIGURATION%\x64\*.jar" "%MG_OUTPUT_WEB%\www\WEB-INF\lib"
+%XCOPY_SINGLE% "%CD%\packages\Java\%CONFIGURATION%\x64\*.dll" "%MG_OUTPUT_WEB%\Tomcat\bin"
+echo [install]: Web Tier - .net Bindings
+%XCOPY% "%CD%\packages\DotNet\%CONFIGURATION%\netstandard2.0" "%MG_OUTPUT_WEB%\www\mapviewernet\bin"
 REM Required for Web Tier unit tests
-copy /Y "%MG_BUILD_SQLITE_PHP_API%" "%MG_OUTPUT_WEB%\Php\ext"
 echo [build]: Web Tier - Clean fusion
 call %ANT% clean -f "%MG_OEM%\fusion\build.xml"
 if not "%errorlevel%"=="0" goto error
@@ -373,43 +383,45 @@
 call %ANT% selfbuild -Dselfbuild.home="%MG_OUTPUT%\fusion-selfbuild" -f "%MG_OEM%\fusion\build.xml"
 echo [install]: Web Tier - fusion templates
-%XCOPY% "%MG_OEM%\fusionMG" "%MG_OUTPUT_WEB%\www\fusion" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_OEM%\fusionMG" "%MG_OUTPUT_WEB%\www\fusion"
 echo [install]: Web Tier - MgDevHttpServer
 if not exist "%MG_OUTPUT_WEB%\DevHttpServer" mkdir "%MG_OUTPUT_WEB%\DevHttpServer"
+%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\DevHttpServer"
 copy /Y "%MG_WEB%\DevHttpServer\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\DevHttpServer"
 copy /Y "%MG_WEB%\DevHttpServer\%TYPEBUILD%\*.exe" "%MG_OUTPUT_WEB%\DevHttpServer"
 echo [install]: Web Tier - Apache module
 if not exist "%MG_OUTPUT_WEB%\Apache24\modules" mkdir "%MG_OUTPUT_WEB%\Apache24\modules"
 %XCOPY% /F "%MG_BUILD_MAPAGENT%" "%MG_OUTPUT_WEB%\Apache24\modules"
 :install_doc
 echo [install]: Documentation
-%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi"
 echo [install]: MapGuide Developer's Guide
-%XCOPY% "%MG_DOC%\devguide\build\html" "%MG_OUTPUT_WEB%\www\help\devguide" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC%\devguide\build\html" "%MG_OUTPUT_WEB%\www\help\devguide"
 echo [install]: Developer's Guide Sample Code (PHP)
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpsamples" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpsamples" "%MG_OUTPUT_WEB%\www\phpsamples"
 echo [install]: Developer's Guide Sample Code (Java)
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javasamples" "%MG_OUTPUT_WEB%\www\javasamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javasamples" "%MG_OUTPUT_WEB%\www\javasamples"
 echo [install]: Developer's Guide Sample Code (DotNet)
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetsamples" "%MG_OUTPUT_WEB%\www\dotnetsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetsamples" "%MG_OUTPUT_WEB%\www\dotnetsamples"
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpviewersample" "%MG_OUTPUT_WEB%\www\phpviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpviewersample" "%MG_OUTPUT_WEB%\www\phpviewersample"
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javaviewersample" "%MG_OUTPUT_WEB%\www\javaviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javaviewersample" "%MG_OUTPUT_WEB%\www\javaviewersample"
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetviewersample" "%MG_OUTPUT_WEB%\www\dotnetviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetviewersample" "%MG_OUTPUT_WEB%\www\dotnetviewersample"
 echo [install]: OpenLayers Samples
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\clientsamples" "%MG_OUTPUT_WEB%\www\clientsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\clientsamples" "%MG_OUTPUT_WEB%\www\clientsamples"
 echo [install]: Samples landing page
 copy /Y "%MG_DOC_DEVGUIDE_SAMPLES%\samples.php" "%MG_OUTPUT_WEB%\www"
 echo [install]: Viewer API documentation
-%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi"
 echo [install]: Copy dlls into .net samples
-%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
-%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin"
+%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin"
 if not exist "%MG_DEV%\UnitTest\TestData\Samples\Sheboygan\Sheboygan.mgp" (
     echo [build]: Sheboygan Sample data set
     pushd %MG_DEV%\UnitTest\TestData\Samples\Sheboygan
Modified: sandbox/jng/vanilla_swig/setenvironment64.bat
--- sandbox/jng/vanilla_swig/setenvironment64.bat	2022-05-20 12:46:45 UTC (rev 9933)
+++ sandbox/jng/vanilla_swig/setenvironment64.bat	2022-05-20 14:24:06 UTC (rev 9934)
@@ -15,6 +15,7 @@
 SET CONFIGURATION=unknown
 SET PLATFORM=unknown
 SET PLATFORM_CLR=unknown
+SET PLATFORM_WIN=unknown
 SET PCONF=release
 if not "%1" == "" set PCONF=%1
@@ -24,6 +25,7 @@
 SET CONFIGURATION=Debug
 SET PLATFORM=x64
 SET PLATFORM_CLR=x64
+SET PLATFORM_WIN=Win64
 IF "%PCONF%"=="release" (
@@ -31,6 +33,7 @@
 SET CONFIGURATION=Release
 SET PLATFORM=x64
 if "%TYPEBUILD%"=="unknown" (
@@ -131,6 +134,11 @@
 SET MSBUILD_CLEAN=msbuild.exe /nologo /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% /t:Clean %MSBUILD_VERBOSITY%
 SET ANT=ant
+rem The bindings solution (with net6.0 projects) will not build from a clean slate without doing a dotnet restore first
+pushd %CD%\Bindings\src\Bindings
+dotnet restore
+popd
 echo ======== Environment Variable Summary =============
 echo PHP_SRC    = %PHP_SRC%
 echo PHP_LIB    = %PHP_LIB%
More information about the mapguide-commits mailing list
