[mapguide-commits] r9979 - in trunk/MgDev: . Oem/LinuxApt Oem/php Oem/php/include/Zend Oem/php/include/ext/date/lib Oem/php/include/ext/mbstring/libmbfl/mbfl Oem/php/include/ext/mysqli Oem/php/include/main Oem/php/lib Oem/php/script
svn_mapguide at osgeo.org
Mon Oct 10 06:14:04 PDT 2022
Author: jng
Date: 2022-10-10 06:14:04 -0700 (Mon, 10 Oct 2022)
New Revision: 9979
Added:
trunk/MgDev/Oem/LinuxApt/php-8.1.11.tar.bz2
trunk/MgDev/Oem/php/lib/php_dl_test.lib
Removed:
trunk/MgDev/Oem/LinuxApt/php-5.6.40.tar.bz2
trunk/MgDev/Oem/php/PROVENANCE.TXT
trunk/MgDev/Oem/php/include/Zend/zend.h
trunk/MgDev/Oem/php/include/Zend/zend_API.h
trunk/MgDev/Oem/php/include/Zend/zend_alloc_sizes.h
trunk/MgDev/Oem/php/include/Zend/zend_compile.h
trunk/MgDev/Oem/php/include/Zend/zend_constants.h
trunk/MgDev/Oem/php/include/Zend/zend_execute.h
trunk/MgDev/Oem/php/include/Zend/zend_ini.h
trunk/MgDev/Oem/php/include/Zend/zend_operators.h
trunk/MgDev/Oem/php/include/Zend/zend_portability.h
trunk/MgDev/Oem/php/include/Zend/zend_types.h
trunk/MgDev/Oem/php/include/Zend/zend_vm_def.h
trunk/MgDev/Oem/php/include/Zend/zend_vm_execute.h
trunk/MgDev/Oem/php/include/ext/date/lib/timelib.h
trunk/MgDev/Oem/php/include/ext/mbstring/libmbfl/mbfl/mbfl_encoding.h
trunk/MgDev/Oem/php/include/ext/mysqli/php_mysqli_structs.h
trunk/MgDev/Oem/php/include/main/SAPI.h
trunk/MgDev/Oem/php/include/main/php_syslog.h
trunk/MgDev/Oem/php/include/main/php_version.h
trunk/MgDev/Oem/php/lib/php8.lib
trunk/MgDev/Oem/php/lib/php_bz2.lib
trunk/MgDev/Oem/php/lib/php_com_dotnet.lib
trunk/MgDev/Oem/php/lib/php_curl.lib
trunk/MgDev/Oem/php/lib/php_dba.lib
trunk/MgDev/Oem/php/lib/php_enchant.lib
trunk/MgDev/Oem/php/lib/php_exif.lib
trunk/MgDev/Oem/php/lib/php_ffi.lib
trunk/MgDev/Oem/php/lib/php_fileinfo.lib
trunk/MgDev/Oem/php/lib/php_ftp.lib
trunk/MgDev/Oem/php/lib/php_gd.lib
trunk/MgDev/Oem/php/lib/php_gettext.lib
trunk/MgDev/Oem/php/lib/php_gmp.lib
trunk/MgDev/Oem/php/lib/php_imap.lib
trunk/MgDev/Oem/php/lib/php_intl.lib
trunk/MgDev/Oem/php/lib/php_ldap.lib
trunk/MgDev/Oem/php/lib/php_mbstring.lib
trunk/MgDev/Oem/php/lib/php_mysqli.lib
trunk/MgDev/Oem/php/lib/php_oci8_19.lib
trunk/MgDev/Oem/php/lib/php_odbc.lib
trunk/MgDev/Oem/php/lib/php_opcache.lib
trunk/MgDev/Oem/php/lib/php_openssl.lib
trunk/MgDev/Oem/php/lib/php_pdo_firebird.lib
trunk/MgDev/Oem/php/lib/php_pdo_mysql.lib
trunk/MgDev/Oem/php/lib/php_pdo_oci.lib
trunk/MgDev/Oem/php/lib/php_pdo_odbc.lib
trunk/MgDev/Oem/php/lib/php_pdo_pgsql.lib
trunk/MgDev/Oem/php/lib/php_pdo_sqlite.lib
trunk/MgDev/Oem/php/lib/php_pgsql.lib
trunk/MgDev/Oem/php/lib/php_shmop.lib
trunk/MgDev/Oem/php/lib/php_snmp.lib
trunk/MgDev/Oem/php/lib/php_soap.lib
trunk/MgDev/Oem/php/lib/php_sockets.lib
trunk/MgDev/Oem/php/lib/php_sodium.lib
trunk/MgDev/Oem/php/lib/php_sqlite3.lib
trunk/MgDev/Oem/php/lib/php_sysvshm.lib
trunk/MgDev/Oem/php/lib/php_tidy.lib
trunk/MgDev/Oem/php/lib/php_xsl.lib
trunk/MgDev/Oem/php/lib/php_zend_test.lib
trunk/MgDev/Oem/php/script/ext_deps.js
trunk/MgDev/Oem/php/script/phpize.js
trunk/MgDev/Oem/php/script/run-tests.php
trunk/MgDev/cmake_linuxapt.sh
#2852: Update PHP to 8.1.11.
Also finally remove old PHP 5.6 tarball in Oem/LinuxApt
Deleted: trunk/MgDev/Oem/LinuxApt/php-5.6.40.tar.bz2
(Binary files differ)
Added: trunk/MgDev/Oem/LinuxApt/php-8.1.11.tar.bz2
Index: trunk/MgDev/Oem/LinuxApt/php-8.1.11.tar.bz2
--- trunk/MgDev/Oem/LinuxApt/php-8.1.11.tar.bz2 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/LinuxApt/php-8.1.11.tar.bz2 2022-10-10 13:14:04 UTC (rev 9979)
Property changes on: trunk/MgDev/Oem/LinuxApt/php-8.1.11.tar.bz2
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Modified: trunk/MgDev/Oem/php/PROVENANCE.TXT
--- trunk/MgDev/Oem/php/PROVENANCE.TXT 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/PROVENANCE.TXT 2022-10-10 13:14:04 UTC (rev 9979)
@@ -1,6 +1,6 @@
-The contents of this directory originate from the PHP 8.1.4 development package SDK with key headers patched for ACE compatbility.
+The contents of this directory originate from the PHP 8.1.11 development package SDK with key headers patched for ACE compatbility.
-https://windows.php.net/downloads/releases/php-devel-pack-8.1.4-nts-Win32-vs16-x64.zip
-sha256: cc7d4a7f62feec88ea94a96d476ad5fae5ea9a953ecbe6a22eda94947d88d8a7
+https://windows.php.net/downloads/releases/php-devel-pack-8.1.11-nts-Win32-vs16-x64.zip
+sha256: e92f740408a3a5d90143f4352b05106ee93edfea0d49b59ca8b68342189124f4
Refer to CHANGES.TXT for details on what was patched
\ No newline at end of file
Modified: trunk/MgDev/Oem/php/include/Zend/zend.h
--- trunk/MgDev/Oem/php/include/Zend/zend.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -20,7 +20,7 @@
#ifndef ZEND_H
#define ZEND_H
-#define ZEND_VERSION "4.1.4"
+#define ZEND_VERSION "4.1.11"
#define ZEND_ENGINE_3
@@ -394,6 +394,7 @@
ZEND_API void zend_replace_error_handling(zend_error_handling_t error_handling, zend_class_entry *exception_class, zend_error_handling *current);
ZEND_API void zend_restore_error_handling(zend_error_handling *saved);
ZEND_API void zend_begin_record_errors(void);
+ZEND_API void zend_emit_recorded_errors(void);
ZEND_API void zend_free_recorded_errors(void);
END_EXTERN_C()
Modified: trunk/MgDev/Oem/php/include/Zend/zend_API.h
--- trunk/MgDev/Oem/php/include/Zend/zend_API.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_API.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -1333,6 +1333,7 @@
ZEND_API ZEND_COLD void ZEND_FASTCALL zend_wrong_callback_error(uint32_t num, char *error);
ZEND_API ZEND_COLD void ZEND_FASTCALL zend_wrong_callback_or_null_error(uint32_t num, char *error);
ZEND_API ZEND_COLD void ZEND_FASTCALL zend_unexpected_extra_named_error(void);
+ZEND_API ZEND_COLD void ZEND_FASTCALL zend_argument_error_variadic(zend_class_entry *error_ce, uint32_t arg_num, const char *format, va_list va);
ZEND_API ZEND_COLD void zend_argument_error(zend_class_entry *error_ce, uint32_t arg_num, const char *format, ...);
ZEND_API ZEND_COLD void zend_argument_type_error(uint32_t arg_num, const char *format, ...);
ZEND_API ZEND_COLD void zend_argument_value_error(uint32_t arg_num, const char *format, ...);
Modified: trunk/MgDev/Oem/php/include/Zend/zend_alloc_sizes.h
--- trunk/MgDev/Oem/php/include/Zend/zend_alloc_sizes.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_alloc_sizes.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -19,7 +19,7 @@
#ifndef ZEND_ALLOC_SIZES_H
#define ZEND_ALLOC_SIZES_H
-#define ZEND_MM_CHUNK_SIZE (2 * 1024 * 1024) /* 2 MB */
+#define ZEND_MM_CHUNK_SIZE ((size_t) (2 * 1024 * 1024)) /* 2 MB */
#define ZEND_MM_PAGE_SIZE (4 * 1024) /* 4 KB */
#define ZEND_MM_PAGES (ZEND_MM_CHUNK_SIZE / ZEND_MM_PAGE_SIZE) /* 512 */
#define ZEND_MM_FIRST_PAGE (1)
Modified: trunk/MgDev/Oem/php/include/Zend/zend_compile.h
--- trunk/MgDev/Oem/php/include/Zend/zend_compile.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_compile.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -917,6 +917,9 @@
#define ZEND_NAME_NOT_FQ 1
#define ZEND_NAME_RELATIVE 2
+/* ZEND_FETCH_ flags in class name AST of new const expression must not clash with ZEND_NAME_ flags */
+#define ZEND_CONST_EXPR_NEW_FETCH_TYPE_SHIFT 2
#define ZEND_TYPE_NULLABLE (1<<8)
#define ZEND_ARRAY_SYNTAX_LIST 1 /* list() */
Modified: trunk/MgDev/Oem/php/include/Zend/zend_constants.h
--- trunk/MgDev/Oem/php/include/Zend/zend_constants.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_constants.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -26,6 +26,7 @@
#define CONST_PERSISTENT (1<<0) /* Persistent */
#define CONST_NO_FILE_CACHE (1<<1) /* Can't be saved in file cache */
#define CONST_DEPRECATED (1<<2) /* Deprecated */
+#define CONST_OWNED (1<<3) /* constant should be destroyed together with class */
#define PHP_USER_CONSTANT 0x7fffff /* a constant defined in user space */
Modified: trunk/MgDev/Oem/php/include/Zend/zend_execute.h
--- trunk/MgDev/Oem/php/include/Zend/zend_execute.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_execute.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -74,6 +74,7 @@
ZEND_API ZEND_COLD void zend_wrong_string_offset_error(void);
ZEND_API ZEND_COLD void ZEND_FASTCALL zend_readonly_property_modification_error(zend_property_info *info);
+ZEND_API ZEND_COLD void ZEND_FASTCALL zend_readonly_property_indirect_modification_error(zend_property_info *info);
ZEND_API bool zend_verify_scalar_type_hint(uint32_t type_mask, zval *arg, bool strict, bool is_internal_arg);
ZEND_API ZEND_COLD void zend_verify_arg_error(
Modified: trunk/MgDev/Oem/php/include/Zend/zend_ini.h
--- trunk/MgDev/Oem/php/include/Zend/zend_ini.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_ini.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -72,7 +72,9 @@
ZEND_API void zend_ini_sort_entries(void);
ZEND_API zend_result zend_register_ini_entries(const zend_ini_entry_def *ini_entry, int module_number);
+ZEND_API zend_result zend_register_ini_entries_ex(const zend_ini_entry_def *ini_entry, int module_number, int module_type);
ZEND_API void zend_unregister_ini_entries(int module_number);
+ZEND_API void zend_unregister_ini_entries_ex(int module_number, int module_type);
ZEND_API void zend_ini_refresh_caches(int stage);
ZEND_API zend_result zend_alter_ini_entry(zend_string *name, zend_string *new_value, int modify_type, int stage);
ZEND_API zend_result zend_alter_ini_entry_ex(zend_string *name, zend_string *new_value, int modify_type, int stage, bool force_change);
Modified: trunk/MgDev/Oem/php/include/Zend/zend_operators.h
--- trunk/MgDev/Oem/php/include/Zend/zend_operators.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_operators.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -99,16 +99,6 @@
# define ZEND_DOUBLE_FITS_LONG(d) (!((d) >= (double)ZEND_LONG_MAX || (d) < (double)ZEND_LONG_MIN))
#endif
-#ifdef ZEND_DVAL_TO_LVAL_CAST_OK
-static zend_always_inline zend_long zend_dval_to_lval(double d)
- if (EXPECTED(zend_finite(d)) && EXPECTED(!zend_isnan(d))) {
- return (zend_long)d;
- } else {
- return 0;
-#else
ZEND_API zend_long ZEND_FASTCALL zend_dval_to_lval_slow(double d);
@@ -120,7 +110,6 @@
-#endif
/* Used to convert a string float to integer during an (int) cast */
static zend_always_inline zend_long zend_dval_to_lval_cap(double d)
Modified: trunk/MgDev/Oem/php/include/Zend/zend_portability.h
--- trunk/MgDev/Oem/php/include/Zend/zend_portability.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_portability.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -679,4 +679,10 @@
# define ZEND_VOIDP(ptr) (ptr)
#endif
+#if defined(__GNUC__) && ZEND_GCC_VERSION >= 9000
+# define ZEND_INDIRECT_RETURN __attribute__((__indirect_return__))
+#else
+#endif
#endif /* ZEND_PORTABILITY_H */
Modified: trunk/MgDev/Oem/php/include/Zend/zend_types.h
--- trunk/MgDev/Oem/php/include/Zend/zend_types.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_types.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -724,6 +724,7 @@
#define ZSTR_SET_CE_CACHE_EX(s, ce, validate) do { \
if (!(validate) || ZSTR_VALID_CE_CACHE(s)) { \
+ ZEND_ASSERT((validate) || ZSTR_VALID_CE_CACHE(s)); \
SET_CE_CACHE(GC_REFCOUNT(s), ce); \
} while (0)
Modified: trunk/MgDev/Oem/php/include/Zend/zend_vm_def.h
--- trunk/MgDev/Oem/php/include/Zend/zend_vm_def.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_vm_def.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -2541,7 +2541,18 @@
ZEND_VM_C_LABEL(try_assign_dim_array):
SEPARATE_ARRAY(object_ptr);
if (OP2_TYPE == IS_UNUSED) {
- value = GET_OP_DATA_ZVAL_PTR(BP_VAR_R);
+ value = GET_OP_DATA_ZVAL_PTR_UNDEF(BP_VAR_R);
+ if (OP_DATA_TYPE == IS_CV && UNEXPECTED(Z_TYPE_P(value) == IS_UNDEF)) {
+ HashTable *ht = Z_ARRVAL_P(object_ptr);
+ if (!(GC_FLAGS(ht) & IS_ARRAY_IMMUTABLE)) {
+ GC_ADDREF(ht);
+ value = zval_undefined_cv((opline+1)->op1.var EXECUTE_DATA_CC);
+ if (!(GC_FLAGS(ht) & IS_ARRAY_IMMUTABLE) && !GC_DELREF(ht)) {
+ zend_array_destroy(ht);
+ ZEND_VM_C_GOTO(assign_dim_error);
if (OP_DATA_TYPE == IS_CV || OP_DATA_TYPE == IS_VAR) {
ZVAL_DEREF(value);
@@ -4318,6 +4329,7 @@
zend_refcounted *ref = Z_COUNTED_P(retval_ptr);
ZVAL_COPY_VALUE(return_value, retval_ptr);
if (GC_MAY_LEAK(ref)) {
+ SAVE_OPLINE();
gc_possible_root(ref);
ZVAL_NULL(retval_ptr);
@@ -8354,8 +8366,8 @@
zend_refcounted *garbage = Z_COUNTED_P(variable_ptr);
ZVAL_REF(variable_ptr, ref);
+ SAVE_OPLINE();
if (GC_DELREF(garbage) == 0) {
- SAVE_OPLINE();
rc_dtor_func(garbage);
if (UNEXPECTED(EG(exception))) {
ZVAL_NULL(variable_ptr);
Modified: trunk/MgDev/Oem/php/include/Zend/zend_vm_execute.h
--- trunk/MgDev/Oem/php/include/Zend/zend_vm_execute.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/Zend/zend_vm_execute.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -4217,6 +4217,7 @@
+ SAVE_OPLINE();
@@ -4294,6 +4295,7 @@
+ SAVE_OPLINE();
@@ -18796,6 +18798,7 @@
+ SAVE_OPLINE();
@@ -21452,6 +21455,7 @@
+ SAVE_OPLINE();
@@ -23407,6 +23411,17 @@
if (IS_CONST == IS_UNUSED) {
value = RT_CONSTANT((opline+1), (opline+1)->op1);
+ if (IS_CONST == IS_CV && UNEXPECTED(Z_TYPE_P(value) == IS_UNDEF)) {
+ GC_ADDREF(ht);
+ goto assign_dim_error;
if (IS_CONST == IS_CV || IS_CONST == IS_VAR) {
ZVAL_DEREF(value);
@@ -23544,6 +23559,17 @@
value = _get_zval_ptr_tmp((opline+1)->op1.var EXECUTE_DATA_CC);
+ if (IS_TMP_VAR == IS_CV && UNEXPECTED(Z_TYPE_P(value) == IS_UNDEF)) {
+ GC_ADDREF(ht);
if (IS_TMP_VAR == IS_CV || IS_TMP_VAR == IS_VAR) {
ZVAL_DEREF(value);
@@ -23682,6 +23708,17 @@
value = _get_zval_ptr_var((opline+1)->op1.var EXECUTE_DATA_CC);
+ if (IS_VAR == IS_CV && UNEXPECTED(Z_TYPE_P(value) == IS_UNDEF)) {
+ GC_ADDREF(ht);
if (IS_VAR == IS_CV || IS_VAR == IS_VAR) {
ZVAL_DEREF(value);
@@ -23819,7 +23856,18 @@
try_assign_dim_array:
- value = _get_zval_ptr_cv_BP_VAR_R((opline+1)->op1.var EXECUTE_DATA_CC);
+ value = EX_VAR((opline+1)->op1.var);
+ if (IS_CV == IS_CV && UNEXPECTED(Z_TYPE_P(value) == IS_UNDEF)) {
+ GC_ADDREF(ht);
if (IS_CV == IS_CV || IS_CV == IS_VAR) {
ZVAL_DEREF(value);
@@ -26062,6 +26110,17 @@
if ((IS_TMP_VAR|IS_VAR) == IS_UNUSED) {
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -26199,6 +26258,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -26337,6 +26407,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -26474,7 +26555,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -27549,6 +27641,17 @@
if (IS_UNUSED == IS_UNUSED) {
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -27686,6 +27789,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -27824,6 +27938,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -27961,7 +28086,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -30181,6 +30317,17 @@
if (IS_CV == IS_UNUSED) {
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -30318,6 +30465,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -30456,6 +30614,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -30593,7 +30762,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -38144,6 +38324,7 @@
+ SAVE_OPLINE();
@@ -41187,6 +41368,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -41324,6 +41516,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -41462,6 +41665,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -41599,7 +41813,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -42894,8 +43119,8 @@
+ SAVE_OPLINE();
- SAVE_OPLINE();
@@ -44921,6 +45146,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -45058,6 +45294,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -45196,6 +45443,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -45333,7 +45591,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -46855,6 +47124,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -46992,6 +47272,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -47130,6 +47421,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -47267,7 +47569,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -50148,6 +50461,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -50285,6 +50609,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -50423,6 +50758,17 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -50560,7 +50906,18 @@
+ GC_ADDREF(ht);
ZVAL_DEREF(value);
@@ -55650,6 +56007,7 @@
+ SAVE_OPLINE();
@@ -55728,6 +56086,7 @@
+ SAVE_OPLINE();
@@ -57261,6 +57620,7 @@
+ SAVE_OPLINE();
@@ -57566,6 +57926,7 @@
+ SAVE_OPLINE();
@@ -58699,6 +59060,7 @@
+ SAVE_OPLINE();
Modified: trunk/MgDev/Oem/php/include/ext/date/lib/timelib.h
--- trunk/MgDev/Oem/php/include/ext/date/lib/timelib.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/ext/date/lib/timelib.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -1,7 +1,7 @@
* The MIT License (MIT)
- * Copyright (c) 2015-2021 Derick Rethans
+ * Copyright (c) 2015-2022 Derick Rethans
* Copyright (c) 2018,2021 MongoDB, Inc.
* Permission is hereby granted, free of charge, to any person obtaining a copy
@@ -30,9 +30,9 @@
# include "timelib_config.h"
#endif
-#define TIMELIB_VERSION 202111
-#define TIMELIB_EXTENDED_VERSION 20211101
-#define TIMELIB_ASCII_VERSION "2021.11"
+#define TIMELIB_VERSION 202116
+#define TIMELIB_EXTENDED_VERSION 20211601
+#define TIMELIB_ASCII_VERSION "2021.16"
#include <stdlib.h>
#include <stdbool.h>
Modified: trunk/MgDev/Oem/php/include/ext/mbstring/libmbfl/mbfl/mbfl_encoding.h
--- trunk/MgDev/Oem/php/include/ext/mbstring/libmbfl/mbfl/mbfl_encoding.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/ext/mbstring/libmbfl/mbfl/mbfl_encoding.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -74,6 +74,7 @@
mbfl_no_encoding_sjis_mac,
mbfl_no_encoding_sjis2004,
mbfl_no_encoding_cp932,
+ mbfl_no_encoding_sjiswin,
mbfl_no_encoding_cp51932,
mbfl_no_encoding_jis,
mbfl_no_encoding_2022jp,
Modified: trunk/MgDev/Oem/php/include/ext/mysqli/php_mysqli_structs.h
--- trunk/MgDev/Oem/php/include/ext/mysqli/php_mysqli_structs.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/ext/mysqli/php_mysqli_structs.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -127,8 +127,6 @@
#ifdef PHP_WIN32
#define PHP_MYSQLI_API __declspec(dllexport)
-#define MYSQLI_LLU_SPEC "%I64u"
-#define MYSQLI_LL_SPEC "%I64d"
#ifndef L64
#define L64(x) x##i64
#endif
@@ -139,10 +137,6 @@
# else
# define PHP_MYSQLI_API
# endif
-/* we need this for PRIu64 and PRId64 */
-#include <inttypes.h>
-#define MYSQLI_LLU_SPEC "%" PRIu64
-#define MYSQLI_LL_SPEC "%" PRId64
#ifndef L64
#define L64(x) x##LL
#endif
@@ -149,6 +143,11 @@
typedef int64_t my_longlong;
#endif
+/* we need this for PRIu64 and PRId64 */
+#include <inttypes.h>
+#define MYSQLI_LLU_SPEC "%" PRIu64
+#define MYSQLI_LL_SPEC "%" PRId64
#ifdef ZTS
#include "TSRM.h"
#endif
Modified: trunk/MgDev/Oem/php/include/main/SAPI.h
--- trunk/MgDev/Oem/php/include/main/SAPI.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/main/SAPI.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -143,6 +143,8 @@
SAPI_API void sapi_startup(sapi_module_struct *sf);
SAPI_API void sapi_shutdown(void);
SAPI_API void sapi_activate(void);
+SAPI_API void sapi_deactivate_module(void);
+SAPI_API void sapi_deactivate_destroy(void);
SAPI_API void sapi_deactivate(void);
SAPI_API void sapi_initialize_empty_request(void);
SAPI_API void sapi_add_request_header(const char *var, unsigned int var_len, char *val, unsigned int val_len, void *arg);
Modified: trunk/MgDev/Oem/php/include/main/php_syslog.h
--- trunk/MgDev/Oem/php/include/main/php_syslog.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/main/php_syslog.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -38,6 +38,7 @@
PHPAPI void php_syslog_str(int priority, const zend_string* message);
PHPAPI void php_syslog(int, const char *format, ...);
PHPAPI void php_openlog(const char *, int, int);
+PHPAPI void php_closelog(void);
END_EXTERN_C()
#endif
Modified: trunk/MgDev/Oem/php/include/main/php_version.h
--- trunk/MgDev/Oem/php/include/main/php_version.h 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/include/main/php_version.h 2022-10-10 13:14:04 UTC (rev 9979)
@@ -2,7 +2,7 @@
/* edit configure.ac to change version number */
#define PHP_MAJOR_VERSION 8
#define PHP_MINOR_VERSION 1
-#define PHP_RELEASE_VERSION 4
+#define PHP_RELEASE_VERSION 11
#define PHP_EXTRA_VERSION ""
-#define PHP_VERSION "8.1.4"
-#define PHP_VERSION_ID 80104
+#define PHP_VERSION "8.1.11"
+#define PHP_VERSION_ID 80111
Modified: trunk/MgDev/Oem/php/lib/php8.lib
Modified: trunk/MgDev/Oem/php/lib/php_bz2.lib
Modified: trunk/MgDev/Oem/php/lib/php_com_dotnet.lib
Modified: trunk/MgDev/Oem/php/lib/php_curl.lib
Modified: trunk/MgDev/Oem/php/lib/php_dba.lib
Added: trunk/MgDev/Oem/php/lib/php_dl_test.lib
Index: trunk/MgDev/Oem/php/lib/php_dl_test.lib
--- trunk/MgDev/Oem/php/lib/php_dl_test.lib 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/lib/php_dl_test.lib 2022-10-10 13:14:04 UTC (rev 9979)
Property changes on: trunk/MgDev/Oem/php/lib/php_dl_test.lib
## -0,0 +1 ##
Modified: trunk/MgDev/Oem/php/lib/php_enchant.lib
Modified: trunk/MgDev/Oem/php/lib/php_exif.lib
Modified: trunk/MgDev/Oem/php/lib/php_ffi.lib
Modified: trunk/MgDev/Oem/php/lib/php_fileinfo.lib
Modified: trunk/MgDev/Oem/php/lib/php_ftp.lib
Modified: trunk/MgDev/Oem/php/lib/php_gd.lib
Modified: trunk/MgDev/Oem/php/lib/php_gettext.lib
Modified: trunk/MgDev/Oem/php/lib/php_gmp.lib
Modified: trunk/MgDev/Oem/php/lib/php_imap.lib
Modified: trunk/MgDev/Oem/php/lib/php_intl.lib
Modified: trunk/MgDev/Oem/php/lib/php_ldap.lib
Modified: trunk/MgDev/Oem/php/lib/php_mbstring.lib
Modified: trunk/MgDev/Oem/php/lib/php_mysqli.lib
Modified: trunk/MgDev/Oem/php/lib/php_oci8_19.lib
Modified: trunk/MgDev/Oem/php/lib/php_odbc.lib
Modified: trunk/MgDev/Oem/php/lib/php_opcache.lib
Modified: trunk/MgDev/Oem/php/lib/php_openssl.lib
Modified: trunk/MgDev/Oem/php/lib/php_pdo_firebird.lib
Modified: trunk/MgDev/Oem/php/lib/php_pdo_mysql.lib
Modified: trunk/MgDev/Oem/php/lib/php_pdo_oci.lib
Modified: trunk/MgDev/Oem/php/lib/php_pdo_odbc.lib
Modified: trunk/MgDev/Oem/php/lib/php_pdo_pgsql.lib
Modified: trunk/MgDev/Oem/php/lib/php_pdo_sqlite.lib
Modified: trunk/MgDev/Oem/php/lib/php_pgsql.lib
Modified: trunk/MgDev/Oem/php/lib/php_shmop.lib
Modified: trunk/MgDev/Oem/php/lib/php_snmp.lib
Modified: trunk/MgDev/Oem/php/lib/php_soap.lib
Modified: trunk/MgDev/Oem/php/lib/php_sockets.lib
Modified: trunk/MgDev/Oem/php/lib/php_sodium.lib
Modified: trunk/MgDev/Oem/php/lib/php_sqlite3.lib
Modified: trunk/MgDev/Oem/php/lib/php_sysvshm.lib
Modified: trunk/MgDev/Oem/php/lib/php_tidy.lib
Modified: trunk/MgDev/Oem/php/lib/php_xsl.lib
Modified: trunk/MgDev/Oem/php/lib/php_zend_test.lib
Modified: trunk/MgDev/Oem/php/script/ext_deps.js
--- trunk/MgDev/Oem/php/script/ext_deps.js 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/script/ext_deps.js 2022-10-10 13:14:04 UTC (rev 9979)
@@ -14,6 +14,8 @@
PHP_DATE_SHARED=false;
PHP_DBA=true;
PHP_DBA_SHARED=true;
+PHP_DL_TEST=true;
+PHP_DL_TEST_SHARED=true;
PHP_ENCHANT=true;
PHP_ENCHANT_SHARED=true;
PHP_FFI=true;
Modified: trunk/MgDev/Oem/php/script/phpize.js
--- trunk/MgDev/Oem/php/script/phpize.js 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/script/phpize.js 2022-10-10 13:14:04 UTC (rev 9979)
@@ -3,9 +3,9 @@
var VC_VERSION=1929
var PHP_VERSION=8
var PHP_MINOR_VERSION=1
-var PHP_RELEASE_VERSION=4
+var PHP_RELEASE_VERSION=11
var PHP_EXTRA_VERSION=""
-var PHP_VERSION_STRING="8.1.4"
+var PHP_VERSION_STRING="8.1.11"
/* Generated extensions list with mode (static/shared) */
PHP_BCMATH_SHARED=false;
@@ -16,6 +16,7 @@
PHP_CURL_SHARED=true;
PHP_FFI_SHARED=true;
PHP_FILEINFO_SHARED=true;
Modified: trunk/MgDev/Oem/php/script/run-tests.php
--- trunk/MgDev/Oem/php/script/run-tests.php 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/Oem/php/script/run-tests.php 2022-10-10 13:14:04 UTC (rev 9979)
@@ -23,7 +23,7 @@
-/* $Id: b718246654392ccb7418d4922e00773b36fe2a89 $ */
+/* $Id: d772c85f95272ae802fd52d7a4ead33d8e254b66 $ */
/* Temporary variables while this file is being refactored. */
/** @var ?JUnit */
@@ -103,12 +103,12 @@
Do not delete 'all' files, 'php' test file, 'skip' or 'clean'
file.
- --set-timeout [n]
- Set timeout for individual tests, where [n] is the number of
+ --set-timeout <n>
+ Set timeout for individual tests, where <n> is the number of
seconds. The default value is 60 seconds, or 300 seconds when
testing for memory leaks.
- --context [n]
+ --context <n>
Sets the number of lines of surrounding context to print for diffs.
The default value is 3.
@@ -119,8 +119,8 @@
'mem'. The result types get written independent of the log format,
however 'diff' only exists when a test fails.
- --show-slow [n]
- Show all tests that took longer than [n] milliseconds to run.
+ --show-slow <n>
+ Show all tests that took longer than <n> milliseconds to run.
--no-clean Do not execute clean section if any.
@@ -530,7 +530,11 @@
$just_save_results = true;
break;
case '--set-timeout':
- $environment['TEST_TIMEOUT'] = $argv[++$i];
+ $timeout = $argv[++$i] ?? '';
+ if (!preg_match('/^\d+$/', $timeout)) {
+ error("'$timeout' is not a valid number of seconds, try e.g. --set-timeout 60 for 1 minute");
+ $environment['TEST_TIMEOUT'] = intval($timeout, 10);
break;
case '--context':
$context_line_count = $argv[++$i] ?? '';
@@ -545,7 +549,11 @@
break;
case '--show-slow':
- $slow_min_ms = $argv[++$i];
+ $slow_min_ms = $argv[++$i] ?? '';
+ if (!preg_match('/^\d+$/', $slow_min_ms)) {
+ error("'$slow_min_ms' is not a valid number of milliseconds, try e.g. --show-slow 1000 for 1 second");
+ $slow_min_ms = intval($slow_min_ms, 10);
break;
case '--temp-source':
$temp_source = $argv[++$i];
@@ -598,7 +606,7 @@
break;
case '--version':
- echo '$Id: b718246654392ccb7418d4922e00773b36fe2a89 $' . "\n";
+ echo '$Id: d772c85f95272ae802fd52d7a4ead33d8e254b66 $' . "\n";
exit(1);
default:
@@ -2085,11 +2093,19 @@
$ini_settings = $workerID ? ['opcache.cache_id' => "worker$workerID"] : [];
// Additional required extensions
+ $extensions = [];
if ($test->hasSection('EXTENSIONS')) {
+ $extensions = preg_split("/[\n\r]+/", trim($test->getSection('EXTENSIONS')));
+ if (is_array($IN_REDIRECT) && $IN_REDIRECT['EXTENSIONS'] != []) {
+ $extensions = array_merge($extensions, $IN_REDIRECT['EXTENSIONS']);
+ /* Load required extensions */
+ if ($extensions != []) {
$ext_params = [];
settings2array($ini_overwrites, $ext_params);
$ext_params = settings2params($ext_params);
- $extensions = preg_split("/[\n\r]+/", trim($test->getSection('EXTENSIONS')));
[$ext_dir, $loaded] = $skipCache->getExtensions("$orig_php $pass_options $extra_options $ext_params $no_file_cache");
$ext_prefix = IS_WINDOWS ? "php_" : "";
$missing = [];
@@ -2241,6 +2257,7 @@
$IN_REDIRECT['via'] = "via [$shortname]\n\t";
$IN_REDIRECT['dir'] = realpath(dirname($file));
$IN_REDIRECT['prefix'] = $tested;
+ $IN_REDIRECT['EXTENSIONS'] = $extensions;
if (!empty($IN_REDIRECT['TESTS'])) {
if (is_array($org_file)) {
@@ -3395,6 +3412,9 @@
'execution_time' => 0,
+ * @throws Exception
public function __construct(array $env, int $workerID)
// Check whether a junit log is wanted.
@@ -3612,6 +3632,9 @@
$this->suites[$suite_name] = self::EMPTY_SUITE + ['name' => $suite_name];
public function stopTimer(string $file_name): void
if (!$this->enabled) {
@@ -3811,6 +3834,9 @@
'CREDITS', 'DESCRIPTION', 'CONFLICTS', 'WHITESPACE_SENSITIVE',
+ * @throws BorkageException
public function __construct(string $fileName, bool $inRedirect)
$this->fileName = $fileName;
@@ -3851,6 +3877,9 @@
return !empty($this->sections[$name]);
public function getSection(string $name): string
if (!isset($this->sections[$name])) {
@@ -3866,7 +3895,7 @@
public function isCGI(): bool
- return $this->sectionNotEmpty('CGI')
+ return $this->hasSection('CGI')
|| $this->sectionNotEmpty('GET')
|| $this->sectionNotEmpty('POST')
|| $this->sectionNotEmpty('GZIP_POST')
@@ -3887,6 +3916,7 @@
* Load the sections of the test file
private function readFile(): void
@@ -3949,6 +3979,9 @@
fclose($fp);
private function validateAndProcess(bool $inRedirect): void
// the redirect section allows a set of tests to be reused outside of
Modified: trunk/MgDev/cmake_linuxapt.sh
--- trunk/MgDev/cmake_linuxapt.sh 2022-10-10 12:47:18 UTC (rev 9978)
+++ trunk/MgDev/cmake_linuxapt.sh 2022-10-10 13:14:04 UTC (rev 9979)
@@ -119,7 +119,7 @@
echo "Created LinuxApt working dir at: $LINUXAPT_WORK_DIR"
fi
-PHP_VER=8.1.9
+PHP_VER=8.1.11
HTTPD_VER=2.4.52
TC_VER=1.2.48
APR_VER=1.7.0
More information about the mapguide-commits
