[mapguide-commits] r9980 - in trunk/Installer: . Support/Web/x64 Support/Web/x64/configs/Apache2/conf Support/Web/x64/configs/Php
svn_mapguide at osgeo.org
Mon Oct 10 06:29:13 PDT 2022
Author: jng
Date: 2022-10-10 06:29:12 -0700 (Mon, 10 Oct 2022)
New Revision: 9980
Added:
trunk/Installer/Support/Web/x64/MODULE_VERSIONS.txt
trunk/Installer/Support/Web/x64/httpd-2.4.53-win64-VS16.zip
trunk/Installer/Support/Web/x64/php-8.1.11-nts-Win32-vs16-x64.zip
Removed:
trunk/Installer/Support/Web/x64/httpd-2.4.52-win64-VS16.zip
trunk/Installer/Support/Web/x64/php-5.6.40-x64-VC11.zip
trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
trunk/Installer/Support/Web/x64/configs/Php/php.ini
trunk/Installer/build.bat
#2852: Update httpd and PHP windows binaries for installer
Added: trunk/Installer/Support/Web/x64/MODULE_VERSIONS.txt
--- trunk/Installer/Support/Web/x64/MODULE_VERSIONS.txt (rev 0)
+++ trunk/Installer/Support/Web/x64/MODULE_VERSIONS.txt 2022-10-10 13:29:12 UTC (rev 9980)
@@ -0,0 +1,2 @@
+mod_jk.so - 1.2.48
+mod_fcgid.so - 2.3.10
\ No newline at end of file
Modified: trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf 2022-10-10 13:14:04 UTC (rev 9979)
+++ trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf 2022-10-10 13:29:12 UTC (rev 9980)
@@ -120,8 +120,7 @@
#Listen 12.34.56.78:80
Listen %MG_WEB_PORT%
-LoadFile "%MG_WEB_PHP%/php5ts.dll"
-LoadFile "%MG_WEB_PHP%/libssh2.dll"
+# Load native deps needed for mapagent handler module
LoadFile "%MG_WEB_PHP%/ACE.dll"
LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
@@ -193,9 +192,16 @@
#LoadModule usertrack_module modules/mod_usertrack.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
#LoadModule ssl_module modules/mod_ssl.so
-LoadModule php5_module "%MG_WEB_PHP%/php5apache2_4.dll"
LoadModule mgmapagent_module modules/mod_mgmapagent.so
+# For PHP
+LoadModule fcgid_module modules/mod_fcgid.so
+# PHP FastCGI setup
+FcgidInitialEnv PHPRC "%MG_WEB_PHP%"
+AddHandler fcgid-script .php
+FcgidWrapper "%MG_WEB_PHP%/php-cgi.exe" .php
# ExtendedStatus controls whether Apache will generate "full" status
# information (ExtendedStatus On) or just basic information (ExtendedStatus
@@ -960,12 +966,6 @@
# CustomLog logs/dummy-host.example.com-access_log common
#</VirtualHost>
-#Start PHP Config
-AddType application/x-httpd-php .php
-PHPIniDir "%MG_WEB_PHP%"
-#End PHP Config
# MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%/mapagent/mapagent.fcgi"
%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%/mapviewerphp/$1$2"
Modified: trunk/Installer/Support/Web/x64/configs/Php/php.ini
--- trunk/Installer/Support/Web/x64/configs/Php/php.ini 2022-10-10 13:14:04 UTC (rev 9979)
+++ trunk/Installer/Support/Web/x64/configs/Php/php.ini 2022-10-10 13:29:12 UTC (rev 9980)
@@ -3,159 +3,226 @@
; About php.ini ;
-; This file controls many aspects of PHP's behavior. In order for PHP to
-; read it, it must be named 'php.ini'. PHP looks for it in the current
-; working directory, in the path designated by the environment variable
-; PHPRC, and in the path that was defined in compile time (in that order).
-; Under Windows, the compile-time path is the Windows directory. The
-; path in which the php.ini file is looked for can be overridden using
-; the -c argument in command line mode.
-; The syntax of the file is extremely simple. Whitespace and Lines
+; PHP's initialization file, generally called php.ini, is responsible for
+; configuring many of the aspects of PHP's behavior.
+; PHP attempts to find and load this configuration from a number of locations.
+; The following is a summary of its search order:
+; 1. SAPI module specific location.
+; 2. The PHPRC environment variable. (As of PHP 5.2.0)
+; 3. A number of predefined registry keys on Windows (As of PHP 5.2.0)
+; 4. Current working directory (except CLI)
+; 5. The web server's directory (for SAPI modules), or directory of PHP
+; (otherwise in Windows)
+; 6. The directory from the --with-config-file-path compile time option, or the
+; Windows directory (usually C:\windows)
+; See the PHP docs for more specific information.
+; https://php.net/configuration.file
+; The syntax of the file is extremely simple. Whitespace and lines
; beginning with a semicolon are silently ignored (as you probably guessed).
; Section headers (e.g. [Foo]) are also silently ignored, even though
; they might mean something in the future.
+; Directives following the section heading [PATH=/www/mysite] only
+; apply to PHP files in the /www/mysite directory. Directives
+; following the section heading [HOST=www.example.com] only apply to
+; PHP files served from www.example.com. Directives set in these
+; special sections cannot be overridden by user-defined INI files or
+; at runtime. Currently, [PATH=] and [HOST=] sections only work under
+; CGI/FastCGI.
+; https://php.net/ini.sections
; Directives are specified using the following syntax:
; directive = value
; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
+; Directives are variables used to configure PHP or PHP extensions.
+; There is no name validation. If PHP can't find an expected
+; directive because it is not set or is mistyped, a default value will be used.
; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
-; (e.g. E_ALL & ~E_NOTICE), or a quoted string ("foo").
+; (e.g. E_ALL & ~E_NOTICE), a quoted string ("bar"), or a reference to a
+; previously set variable or directive (e.g. ${foo})
; Expressions in the INI file are limited to bitwise operators and parentheses:
-; | bitwise OR
-; & bitwise AND
-; ~ bitwise NOT
-; ! boolean NOT
+; | bitwise OR
+; ^ bitwise XOR
+; & bitwise AND
+; ~ bitwise NOT
+; ! boolean NOT
; Boolean flags can be turned on using the values 1, On, True or Yes.
; They can be turned off using the values 0, Off, False or No.
; An empty string can be denoted by simply not writing anything after the equal
; sign, or by using the None keyword:
-; foo = ; sets foo to an empty string
-; foo = none ; sets foo to an empty string
-; foo = "none" ; sets foo to the string 'none'
+; foo = ; sets foo to an empty string
+; foo = None ; sets foo to an empty string
+; foo = "None" ; sets foo to the string 'None'
; If you use constants in your value, and these constants belong to a
; dynamically loaded extension (either a PHP extension or a Zend extension),
; you may only use these constants *after* the line that loads the extension.
; About this file ;
-; This is the recommended, PHP 5-style version of the php.ini-dist file. It
-; sets some non standard settings, that make PHP more efficient, more secure,
-; and encourage cleaner coding.
-; The price is that with these settings, PHP may be incompatible with some
-; applications, and sometimes, more difficult to develop with. Using this
-; file is warmly recommended for production sites. As all of the changes from
-; the standard settings are thoroughly documented, you can go over each one,
-; and decide whether you want to use it or not.
-; For general information about the php.ini file, please consult the php.ini-dist
-; file, included in your PHP distribution.
-; This file is different from the php.ini-dist file in the fact that it features
-; different values for several directives, in order to improve performance, while
-; possibly breaking compatibility with the standard out-of-the-box behavior of
-; PHP. Please make sure you read what's different, and modify your scripts
-; accordingly, if you decide to use this file instead.
-; - register_globals = Off [Security, Performance]
-; Global variables are no longer registered for input data (POST, GET, cookies,
-; environment and other server variables). Instead of using $foo, you must use
-; you can use $_REQUEST["foo"] (includes any variable that arrives through the
-; request, namely, POST, GET and cookie variables), or use one of the specific
-; $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
-; on where the input originates. Also, you can look at the
-; import_request_variables() function.
-; Note that register_globals is going to be depracated (i.e., turned off by
-; default) in the next version of PHP, because it often leads to security bugs.
-; Read http://php.net/manual/en/security.registerglobals.php for further
-; information.
-; - register_long_arrays = Off [Performance]
-; Disables registration of the older (and deprecated) long predefined array
-; variables ($HTTP_*_VARS). Instead, use the superglobals that were
-; introduced in PHP 4.1.0
-; - display_errors = Off [Security]
-; With this directive set to off, errors that occur during the execution of
-; scripts will no longer be displayed as a part of the script output, and thus,
-; will no longer be exposed to remote users. With some errors, the error message
-; content may expose information about your script, web server, or database
-; server that may be exploitable for hacking. Production sites should have this
-; directive set to off.
-; - log_errors = On [Security]
-; This directive complements the above one. Any errors that occur during the
-; execution of your script will be logged (typically, to your server's error log,
-; but can be configured in several ways). Along with setting display_errors to off,
-; this setup gives you the ability to fully understand what may have gone wrong,
-; without exposing any sensitive information to remote users.
-; - output_buffering = 4096 [Performance]
-; Set a 4KB output buffer. Enabling output buffering typically results in less
-; writes, and sometimes less packets sent on the wire, which can often lead to
-; better performance. The gain this directive actually yields greatly depends
-; on which Web server you're working with, and what kind of scripts you're using.
-; - register_argc_argv = Off [Performance]
-; Disables registration of the somewhat redundant $argv and $argc global
-; variables.
-; - magic_quotes_gpc = Off [Performance]
-; Input data is no longer escaped with slashes so that it can be sent into
-; SQL databases without further manipulation. Instead, you should use the
-; function addslashes() on each input element you wish to send to a database.
-; - variables_order = "GPCS" [Performance]
-; The environment variables are not hashed into the $_ENV. To access
-; environment variables, you can use getenv() instead.
-; - error_reporting = E_ALL [Code Cleanliness, Security(?)]
-; By default, PHP surpresses errors of type E_NOTICE. These error messages
-; are emitted for non-critical errors, but that could be a symptom of a bigger
-; problem. Most notably, this will cause error messages about the use
-; of uninitialized variables to be displayed.
-; - allow_call_time_pass_reference = Off [Code cleanliness]
-; It's not possible to decide to force a variable to be passed by reference
-; when calling a function. The PHP 4 style to do this is by making the
-; function require the relevant argument by reference.
+; PHP comes packaged with two INI files. One that is recommended to be used
+; in production environments and one that is recommended to be used in
+; development environments.
+; php.ini-production contains settings which hold security, performance and
+; best practices at its core. But please be aware, these settings may break
+; compatibility with older or less security conscience applications. We
+; recommending using the production ini in production and testing environments.
+; php.ini-development is very similar to its production variant, except it is
+; much more verbose when it comes to errors. We recommend using the
+; development version only in development environments, as errors shown to
+; application users can inadvertently leak otherwise secure information.
+; This is the php.ini-production INI file.
+; Quick Reference ;
+; The following are all the settings which are different in either the production
+; or development versions of the INIs with respect to PHP's default behavior.
+; Please see the actual settings later in the document for more details as to why
+; we recommend these changes in PHP's behavior.
+; display_errors
+; Default Value: On
+; Development Value: On
+; Production Value: Off
+; display_startup_errors
+; error_reporting
+; Default Value: E_ALL
+; Development Value: E_ALL
+; Production Value: E_ALL & ~E_DEPRECATED & ~E_STRICT
+; log_errors
+; Default Value: Off
+; Production Value: On
+; max_input_time
+; Default Value: -1 (Unlimited)
+; Development Value: 60 (60 seconds)
+; Production Value: 60 (60 seconds)
+; output_buffering
+; Development Value: 4096
+; Production Value: 4096
+; register_argc_argv
+; Development Value: Off
+; request_order
+; Default Value: None
+; Development Value: "GP"
+; Production Value: "GP"
+; session.gc_divisor
+; Default Value: 100
+; Development Value: 1000
+; Production Value: 1000
+; session.sid_bits_per_character
+; Default Value: 4
+; Development Value: 5
+; Production Value: 5
+; short_open_tag
+; variables_order
+; Default Value: "EGPCS"
+; Development Value: "GPCS"
+; Production Value: "GPCS"
+; zend.exception_ignore_args
+; zend.exception_string_param_max_len
+; Default Value: 15
+; Development Value: 15
+; Production Value: 0
+; php.ini Options ;
+; Name for user-defined php.ini (.htaccess) files. Default is ".user.ini"
+;user_ini.filename = ".user.ini"
+; To disable this feature set this option to an empty value
+; TTL for user-defined php.ini files (time-to-live) in seconds. Default is 300 seconds (5 minutes)
+;user_ini.cache_ttl = 300
; Language Options ;
; Enable the PHP scripting language engine under Apache.
+; https://php.net/engine
engine = On
-; Enable compatibility mode with Zend Engine 1 (PHP 4.x)
-zend.ze1_compatibility_mode = Off
+; This directive determines whether or not PHP will recognize code between
+; <? and ?> tags as PHP source which should be processed as such. It is
+; generally recommended that <?php and ?> should be used and that this feature
+; should be disabled, as enabling it may result in issues when generating XML
+; documents, however this remains supported for backward compatibility reasons.
+; Note that this directive does not control the <?= shorthand tag, which can be
+; used regardless of this directive.
+; https://php.net/short-open-tag
+short_open_tag = Off
-; Allow the <? tag. Otherwise, only <?php and <script> tags are recognized.
-; NOTE: Using short tags should be avoided when developing applications or
-; libraries that are meant for redistribution, or deployment on PHP
-; servers which are not under your control, because short tags may not
-; be supported on the target server. For portable, redistributable code,
-; be sure not to use short tags.
-short_open_tag = On
-; Allow ASP-style <% %> tags.
-asp_tags = Off
; The number of significant digits displayed in floating point numbers.
-precision = 14
+; https://php.net/precision
+precision = 14
-; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
-y2k_compliance = On
-; Output buffering allows you to send header lines (including cookies) even
-; after you send body content, at the price of slowing PHP's output layer a
-; bit. You can enable output buffering during runtime by calling the output
-; buffering functions. You can also enable output buffering for all files by
-; setting this directive to On. If you wish to limit the size of the buffer
-; to a certain size - you can use a maximum number of bytes instead of 'On', as
-; a value for this directive (e.g., output_buffering=4096).
+; Output buffering is a mechanism for controlling how much output data
+; (excluding headers and cookies) PHP should keep internally before pushing that
+; data to the client. If your application's output exceeds this setting, PHP
+; will send that data in chunks of roughly the size you specify.
+; Turning on this setting and managing its maximum buffer size can yield some
+; interesting side-effects depending on your application and web server.
+; You may be able to send headers and cookies after you've already sent output
+; through print or echo. You also may see performance benefits if your server is
+; emitting less packets due to buffered output versus PHP streaming the output
+; as it gets it. On production servers, 4096 bytes is a good setting for performance
+; reasons.
+; Note: Output buffering can also be controlled via Output Buffering Control
+; functions.
+; Possible Values:
+; On = Enabled and buffer is unlimited. (Use with caution)
+; Off = Disabled
+; Integer = Enables the buffer and sets its maximum size in bytes.
+; Note: This directive is hardcoded to Off for the CLI SAPI
+; https://php.net/output-buffering
; You can redirect all of the output of your scripts to a function. For
@@ -163,29 +230,52 @@
; encoding will be transparently converted to the specified encoding.
; Setting any output handler automatically turns on output buffering.
; Note: People who wrote portable scripts should not depend on this ini
-; directive. Instead, explicitly set the output handler using ob_start().
-; Using this ini directive may cause problems unless you know what script
-; is doing.
+; directive. Instead, explicitly set the output handler using ob_start().
+; Using this ini directive may cause problems unless you know what script
+; is doing.
; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
-; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
+; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
; Note: output_handler must be empty if this is set 'On' !!!!
-; Instead you must use zlib.output_handler.
+; Instead you must use zlib.output_handler.
+; https://php.net/output-handler
;output_handler =
+; URL rewriter function rewrites URL on the fly by using
+; output buffer. You can set target tags by this configuration.
+; "form" tag is special tag. It will add hidden input tag to pass values.
+; Refer to session.trans_sid_tags for usage.
+; Default Value: "form="
+; Development Value: "form="
+; Production Value: "form="
+;url_rewriter.tags
+; URL rewriter will not rewrite absolute URL nor form by default. To enable
+; absolute URL rewrite, allowed hosts must be defined at RUNTIME.
+; Refer to session.trans_sid_hosts for more details.
+; Default Value: ""
+; Development Value: ""
+; Production Value: ""
+;url_rewriter.hosts
; Transparent output compression using the zlib library
; Valid values for this option are 'off', 'on', or a specific buffer size
; to be used for compression (default is 4KB)
; Note: Resulting chunk size may vary due to nature of compression. PHP
-; outputs chunks that are few hundreds bytes each as a result of
-; compression. If you prefer a larger chunk size for better
-; performance, enable output_buffering in addition.
+; outputs chunks that are few hundreds bytes each as a result of
+; compression. If you prefer a larger chunk size for better
+; performance, enable output_buffering in addition.
; Note: You need to use zlib.output_handler instead of the standard
-; output_handler, or otherwise the output will be corrupted.
+; output_handler, or otherwise the output will be corrupted.
+; https://php.net/zlib.output-compression
zlib.output_compression = Off
+; https://php.net/zlib.output-compression-level
+;zlib.output_compression_level = -1
; You cannot specify additional output handlers if zlib.output_compression
; is activated here. This setting does the same as output_handler but in
; a different order.
+; https://php.net/zlib.output-handler
;zlib.output_handler =
; Implicit flush tells PHP to tell the output layer to flush itself
@@ -193,127 +283,181 @@
; PHP function flush() after each and every call to print() or echo() and each
; and every HTML block. Turning this option on has serious performance
; implications and is generally recommended for debugging purposes only.
+; https://php.net/implicit-flush
+; Note: This directive is hardcoded to On for the CLI SAPI
implicit_flush = Off
; The unserialize callback function will be called (with the undefined class'
; name as parameter), if the unserializer finds an undefined class
-; which should be instanciated.
-; A warning appears if the specified function is not defined, or if the
-; function doesn't include/implement the missing class.
+; which should be instantiated. A warning appears if the specified function is
+; not defined, or if the function doesn't include/implement the missing class.
; So only set this entry, if you really want to implement such a
; callback-function.
-unserialize_callback_func=
+unserialize_callback_func =
-; When floats & doubles are serialized store serialize_precision significant
+; The unserialize_max_depth specifies the default depth limit for unserialized
+; structures. Setting the depth limit too high may result in stack overflows
+; during unserialization. The unserialize_max_depth ini setting can be
+; overridden by the max_depth option on individual unserialize() calls.
+; A value of 0 disables the depth limit.
+;unserialize_max_depth = 4096
+; When floats & doubles are serialized, store serialize_precision significant
; digits after the floating point. The default value ensures that when floats
; are decoded with unserialize, the data will remain the same.
-serialize_precision = 100
+; The value is also used for json_encode when encoding double values.
+; If -1 is used, then dtoa mode 0 is used which automatically select the best
+; precision.
+serialize_precision = -1
-; Whether to enable the ability to force arguments to be passed by reference
-; at function call time. This method is deprecated and is likely to be
-; unsupported in future versions of PHP/Zend. The encouraged method of
-; specifying which arguments should be passed by reference is in the function
-; declaration. You're encouraged to try and turn this option Off and make
-; sure your scripts work properly with it in order to ensure they will work
-; with future versions of the language (you will receive a warning each time
-; you use this feature, and the argument will be passed by value instead of by
-; reference).
-allow_call_time_pass_reference = Off
-; Safe Mode
-safe_mode = Off
-; By default, Safe Mode does a UID compare check when
-; opening files. If you want to relax this to a GID compare,
-; then turn on safe_mode_gid.
-safe_mode_gid = Off
-; When safe_mode is on, UID/GID checks are bypassed when
-; including files from this directory and its subdirectories.
-; (directory must also be in include_path or full path must
-; be used when including)
-safe_mode_include_dir =
-; When safe_mode is on, only executables located in the safe_mode_exec_dir
-; will be allowed to be executed via the exec family of functions.
-safe_mode_exec_dir =
-; Setting certain environment variables may be a potential security breach.
-; This directive contains a comma-delimited list of prefixes. In Safe Mode,
-; the user may only alter environment variables whose names begin with the
-; prefixes supplied here. By default, users will only be able to set
-; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
-; Note: If this directive is empty, PHP will let the user modify ANY
-; environment variable!
-safe_mode_allowed_env_vars = PHP_
-; This directive contains a comma-delimited list of environment variables that
-; the end user won't be able to change using putenv(). These variables will be
-; protected even if safe_mode_allowed_env_vars is set to allow to change them.
-safe_mode_protected_env_vars = LD_LIBRARY_PATH
; open_basedir, if set, limits all file operations to the defined directory
; and below. This directive makes most sense if used in a per-directory
-; or per-virtualhost web server configuration file. This directive is
-; *NOT* affected by whether Safe Mode is turned On or Off.
+; or per-virtualhost web server configuration file.
+; Note: disables the realpath cache
+; https://php.net/open-basedir
;open_basedir =
-; This directive allows you to disable certain functions for security reasons.
-; It receives a comma-delimited list of function names. This directive is
+; This directive allows you to disable certain functions.
+; It receives a comma-delimited list of function names.
+; https://php.net/disable-functions
disable_functions =
-; This directive allows you to disable certain classes for security reasons.
-; It receives a comma-delimited list of class names. This directive is
+; This directive allows you to disable certain classes.
+; It receives a comma-delimited list of class names.
+; https://php.net/disable-classes
disable_classes =
; Colors for Syntax Highlighting mode. Anything that's acceptable in
; <span style="color: ???????"> would work.
+; https://php.net/syntax-highlighting
;highlight.string = #DD0000
;highlight.comment = #FF9900
;highlight.keyword = #007700
-;highlight.bg = #FFFFFF
;highlight.default = #0000BB
;highlight.html = #000000
+; If enabled, the request will be allowed to complete even if the user aborts
+; the request. Consider enabling it if executing long requests, which may end up
+; being interrupted by the user or a browser timing out. PHP's default behavior
+; is to disable this feature.
+; https://php.net/ignore-user-abort
+;ignore_user_abort = On
-; Misc
+; Determines the size of the realpath cache to be used by PHP. This value should
+; be increased on systems where PHP opens many files to reflect the quantity of
+; the file operations performed.
+; Note: if open_basedir is set, the cache is disabled
+; https://php.net/realpath-cache-size
+;realpath_cache_size = 4096k
+; Duration of time, in seconds for which to cache realpath information for a given
+; file or directory. For systems with rarely changing files, consider increasing this
+; value.
+; https://php.net/realpath-cache-ttl
+;realpath_cache_ttl = 120
+; Enables or disables the circular reference collector.
+; https://php.net/zend.enable-gc
+zend.enable_gc = On
+; If enabled, scripts may be written in encodings that are incompatible with
+; the scanner. CP936, Big5, CP949 and Shift_JIS are the examples of such
+; encodings. To use this feature, mbstring extension must be enabled.
+;zend.multibyte = Off
+; Allows to set the default encoding for the scripts. This value will be used
+; unless "declare(encoding=...)" directive appears at the top of the script.
+; Only affects if zend.multibyte is set.
+;zend.script_encoding =
+; Allows to include or exclude arguments from stack traces generated for exceptions.
+; In production, it is recommended to turn this setting on to prohibit the output
+; of sensitive information in stack traces
+zend.exception_ignore_args = On
+; Allows setting the maximum string length in an argument of a stringified stack trace
+; to a value between 0 and 1000000.
+; This has no effect when zend.exception_ignore_args is enabled.
+; In production, it is recommended to set this to 0 to reduce the output
+; of sensitive information in stack traces.
+zend.exception_string_param_max_len = 0
+; Miscellaneous ;
; Decides whether PHP may expose the fact that it is installed on the server
; (e.g. by adding its signature to the Web server header). It is no security
; threat in any way, but it makes it possible to determine whether you use PHP
; on your server or not.
-expose_php = Off
+; https://php.net/expose-php
+expose_php = On
; Resource Limits ;
-max_execution_time = 180 ; Maximum execution time of each script, in seconds
-max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
-memory_limit = 256M ; Maximum amount of memory a script may consume
+; Maximum execution time of each script, in seconds
+; https://php.net/max-execution-time
+; Note: This directive is hardcoded to 0 for the CLI SAPI
+max_execution_time = 30
+; Maximum amount of time each script may spend parsing request data. It's a good
+; idea to limit this time on productions servers in order to eliminate unexpectedly
+; long running scripts.
+; Note: This directive is hardcoded to -1 for the CLI SAPI
+; https://php.net/max-input-time
+max_input_time = 60
+; Maximum input variable nesting level
+; https://php.net/max-input-nesting-level
+;max_input_nesting_level = 64
+; How many GET/POST/COOKIE input variables may be accepted
+;max_input_vars = 1000
+; Maximum amount of memory a script may consume
+; https://php.net/memory-limit
+memory_limit = 128M
; Error handling and logging ;
-; error_reporting is a bit-field. Or each number up to get desired error
-; reporting level
-; E_ALL - All errors and warnings (doesn't include E_STRICT)
+; This directive informs PHP of which errors, warnings and notices you would like
+; it to take action for. The recommended way of setting values for this
+; directive is through the use of the error level constants and bitwise
+; operators. The error level constants are below here for convenience as well as
+; some common settings and their meanings.
+; By default, PHP is set to take action on all errors, notices and warnings EXCEPT
+; those related to E_NOTICE and E_STRICT, which together cover best practices and
+; recommended coding standards in PHP. For performance reasons, this is the
+; recommend error reporting setting. Your production server shouldn't be wasting
+; resources complaining about best practices and coding standards. That's what
+; development servers and development settings are for.
+; Note: The php.ini-development file has this setting as E_ALL. This
+; means it pretty much reports everything which is exactly what you want during
+; development and early testing.
+; Error Level Constants:
+; E_ALL - All errors and warnings (includes E_STRICT as of PHP 5.4.0)
; E_ERROR - fatal run-time errors
+; E_RECOVERABLE_ERROR - almost fatal run-time errors
; E_WARNING - run-time warnings (non-fatal errors)
; E_PARSE - compile-time parse errors
; E_NOTICE - run-time notices (these are warnings which often result
; from a bug in your code, but it's possible that it was
; intentional (e.g., using an uninitialized variable and
-; relying on the fact it's automatically initialized to an
+; relying on the fact it is automatically initialized to an
; empty string)
; E_STRICT - run-time notices, enable to have PHP suggest changes
; to your code which will ensure the best interoperability
@@ -326,170 +470,268 @@
; E_USER_ERROR - user-generated error message
; E_USER_WARNING - user-generated warning message
; E_USER_NOTICE - user-generated notice message
+; E_DEPRECATED - warn about code that will not work in future versions
+; of PHP
+; E_USER_DEPRECATED - user-generated deprecation warnings
-; Examples:
-; - Show all errors, except for notices and coding standards warnings
-;error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT
-; - Show only errors
-;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR
-error_reporting = E_ALL
+; Common Values:
+; E_ALL (Show all errors, warnings and notices including coding standards.)
+; E_ALL & ~E_NOTICE (Show all errors, except for notices)
+; E_ALL & ~E_NOTICE & ~E_STRICT (Show all errors, except for notices and coding standards warnings.)
+; E_COMPILE_ERROR|E_RECOVERABLE_ERROR|E_ERROR|E_CORE_ERROR (Show only errors)
+; https://php.net/error-reporting
+error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT
-; Print out errors (as a part of the output). For production web sites,
-; you're strongly encouraged to turn this feature off, and use error logging
-; instead (see below). Keeping display_errors enabled on a production web site
-; may reveal security information to end users, such as file paths on your Web
-; server, your database schema or other information.
+; This directive controls whether or not and where PHP will output errors,
+; notices and warnings too. Error output is very useful during development, but
+; it could be very dangerous in production environments. Depending on the code
+; which is triggering the error, sensitive information could potentially leak
+; out of your application such as database usernames and passwords or worse.
+; For production environments, we recommend logging errors rather than
+; sending them to STDOUT.
+; Possible Values:
+; Off = Do not display any errors
+; stderr = Display errors to STDERR (affects only CGI/CLI binaries!)
+; On or stdout = Display errors to STDOUT
+; https://php.net/display-errors
-; Even when display_errors is on, errors that occur during PHP's startup
-; sequence are not displayed. It's strongly recommended to keep
-; display_startup_errors off, except for when debugging.
+; The display of errors which occur during PHP's startup sequence are handled
+; separately from display_errors. We strongly recommend you set this to 'off'
+; for production servers to avoid leaking configuration details.
+; https://php.net/display-startup-errors
display_startup_errors = Off
-; Log errors into a log file (server-specific log, stderr, or error_log (below))
-; As stated above, you're strongly advised to use error logging in place of
-; error displaying on production web sites.
+; Besides displaying errors, PHP can also log errors to locations such as a
+; server-specific log, STDERR, or a location specified by the error_log
+; directive found below. While errors should not be displayed on productions
+; servers they should still be monitored and logging is a great way to do that.
+; https://php.net/log-errors
log_errors = On
-; Set maximum length of log_errors. In error_log information about the source is
-; added. The default is 1024 and 0 allows to not apply any maximum length at all.
-log_errors_max_len = 1024
; Do not log repeated messages. Repeated errors must occur in same file on same
-; line until ignore_repeated_source is set true.
+; line unless ignore_repeated_source is set true.
+; https://php.net/ignore-repeated-errors
ignore_repeated_errors = Off
; Ignore source of message when ignoring repeated messages. When this setting
; is On you will not log errors with repeated messages from different files or
-; sourcelines.
+; source lines.
+; https://php.net/ignore-repeated-source
ignore_repeated_source = Off
; If this parameter is set to Off, then memory leaks will not be shown (on
-; stdout or in the log). This has only effect in a debug compile, and if
+; stdout or in the log). This is only effective in a debug compile, and if
; error reporting includes E_WARNING in the allowed list
+; https://php.net/report-memleaks
report_memleaks = On
-; Store the last error/warning message in $php_errormsg (boolean).
-track_errors = Off
+; This setting is off by default.
+;report_zend_debug = 0
-; Disable the inclusion of HTML tags in error messages.
-; Note: Never use this feature for production boxes.
-;html_errors = Off
+; Turn off normal error reporting and emit XML-RPC error XML
+; https://php.net/xmlrpc-errors
+;xmlrpc_errors = 0
-; If html_errors is set On PHP produces clickable error messages that direct
-; to a page describing the error or function causing the error in detail.
-; You can download a copy of the PHP manual from http://www.php.net/docs.php
+; An XML-RPC faultCode
+;xmlrpc_error_number = 0
+; When PHP displays or logs an error, it has the capability of formatting the
+; error message as HTML for easier reading. This directive controls whether
+; the error message is formatted as HTML or not.
+; https://php.net/html-errors
+;html_errors = On
+; If html_errors is set to On *and* docref_root is not empty, then PHP
+; produces clickable error messages that direct to a page describing the error
+; or function causing the error in detail.
+; You can download a copy of the PHP manual from https://php.net/docs
; and change docref_root to the base URL of your local copy including the
; leading '/'. You must also specify the file extension being used including
-; the dot.
+; the dot. PHP's default behavior is to leave these settings empty, in which
+; case no links to documentation are generated.
+; https://php.net/docref-root
+; Examples
;docref_root = "/phpmanual/"
+; https://php.net/docref-ext
;docref_ext = .html
-; String to output before an error message.
-;error_prepend_string = "<font color=ff0000>"
+; String to output before an error message. PHP's default behavior is to leave
+; this setting blank.
+; https://php.net/error-prepend-string
+; Example:
+;error_prepend_string = "<span style='color: #ff0000'>"
-; String to output after an error message.
-;error_append_string = "</font>"
+; String to output after an error message. PHP's default behavior is to leave
+; https://php.net/error-append-string
+; Example:
+;error_append_string = "</span>"
-; Log errors to specified file.
-;error_log = filename
-; Log errors to syslog (Event Log on NT, not valid in Windows 95).
+; Log errors to specified file. PHP's default behavior is to leave this value
+; empty.
+; https://php.net/error-log
+; Example:
+;error_log = %MG_WEB_APACHE%/logs/php_errors.log
+; Log errors to syslog (Event Log on Windows).
;error_log = syslog
+; The syslog ident is a string which is prepended to every message logged
+; to syslog. Only used when error_log is set to syslog.
+;syslog.ident = php
+; The syslog facility is used to specify what type of program is logging
+; the message. Only used when error_log is set to syslog.
+;syslog.facility = user
+; Set this to disable filtering control characters (the default).
+; Some loggers only accept NVT-ASCII, others accept anything that's not
+; control characters. If your logger accepts everything, then no filtering
+; is needed at all.
+; Allowed values are:
+; ascii (all printable ASCII characters and NL)
+; no-ctrl (all characters except control characters)
+; all (all characters)
+; raw (like "all", but messages are not split at newlines)
+; https://php.net/syslog.filter
+;syslog.filter = ascii
+;windows.show_crt_warning
+; Default value: 0
+; Development value: 0
+; Production value: 0
; Data Handling ;
-; Note - track_vars is ALWAYS enabled as of PHP 4.0.3
; The separator used in PHP generated URLs to separate arguments.
-; Default is "&".
+; PHP's default setting is "&".
+; https://php.net/arg-separator.output
+; Example:
;arg_separator.output = "&"
; List of separator(s) used by PHP to parse input URLs into variables.
-; Default is "&".
; NOTE: Every character in this directive is considered as separator!
+; https://php.net/arg-separator.input
+; Example:
;arg_separator.input = ";&"
-; This directive describes the order in which PHP registers GET, POST, Cookie,
-; Environment and Built-in variables (G, P, C, E & S respectively, often
-; referred to as EGPCS or GPC). Registration is done from left to right, newer
-; values override older values.
+; This directive determines which super global arrays are registered when PHP
+; starts up. G,P,C,E & S are abbreviations for the following respective super
+; globals: GET, POST, COOKIE, ENV and SERVER. There is a performance penalty
+; paid for the registration of these arrays and because ENV is not as commonly
+; used as the others, ENV is not recommended on productions servers. You
+; can still get access to the environment variables through getenv() should you
+; need to.
+; Production Value: "GPCS";
+; https://php.net/variables-order
-; Whether or not to register the EGPCS variables as global variables. You may
-; want to turn this off if you don't want to clutter your scripts' global scope
-; with user data. This makes most sense when coupled with track_vars - in which
-; case you can access all of the GPC variables through the $HTTP_*_VARS[],
-; variables.
-; You should do your best to write your scripts so that they do not require
-; register_globals to be on; Using form variables as globals can easily lead
-; to possible security problems, if the code is not very well thought of.
-register_globals = Off
+; This directive determines which super global data (G,P & C) should be
+; registered into the super global array REQUEST. If so, it also determines
+; the order in which that data is registered. The values for this directive
+; are specified in the same manner as the variables_order directive,
+; EXCEPT one. Leaving this value empty will cause PHP to use the value set
+; in the variables_order directive. It does not mean it will leave the super
+; globals array REQUEST empty.
+; https://php.net/request-order
+request_order = "GP"
-; Whether or not to register the old-style input arrays, HTTP_GET_VARS
-; and friends. If you're not using them, it's recommended to turn them off,
-; for performance reasons.
-register_long_arrays = Off
-; This directive tells PHP whether to declare the argv&argc variables (that
-; would contain the GET information). If you don't use these variables, you
-; should turn it off for increased performance.
+; This directive determines whether PHP registers $argv & $argc each time it
+; runs. $argv contains an array of all the arguments passed to PHP when a script
+; is invoked. $argc contains an integer representing the number of arguments
+; that were passed when the script was invoked. These arrays are extremely
+; useful when running scripts from the command line. When this directive is
+; enabled, registering these variables consumes CPU cycles and memory each time
+; a script is executed. For performance reasons, this feature should be disabled
+; on production servers.
+; https://php.net/register-argc-argv
-; When enabled, the SERVER and ENV variables are created when they're first
-; used (Just In Time) instead of when the script starts. If these variables
-; are not used within a script, having this directive on will result in a
-; performance gain. The PHP directives register_globals, register_long_arrays,
-; and register_argc_argv must be disabled for this directive to have any affect.
+; When enabled, the ENV, REQUEST and SERVER variables are created when they're
+; first used (Just In Time) instead of when the script starts. If these
+; variables are not used within a script, having this directive on will result
+; in a performance gain. The PHP directive register_argc_argv must be disabled
+; for this directive to have any effect.
+; https://php.net/auto-globals-jit
auto_globals_jit = On
+; Whether PHP will read the POST data.
+; This option is enabled by default.
+; Most likely, you won't want to disable this option globally. It causes $_POST
+; and $_FILES to always be empty; the only way you will be able to read the
+; POST data will be through the php://input stream wrapper. This can be useful
+; to proxy requests or to process the POST data in a memory efficient fashion.
+; https://php.net/enable-post-data-reading
+;enable_post_data_reading = Off
; Maximum size of POST data that PHP will accept.
-post_max_size = 64M
+; Its value may be 0 to disable the limit. It is ignored if POST data reading
+; is disabled through enable_post_data_reading.
+; https://php.net/post-max-size
+post_max_size = 8M
-; Magic quotes
+; Automatically add files before PHP document.
+; https://php.net/auto-prepend-file
+auto_prepend_file =
-; Magic quotes for incoming GET/POST/Cookie data.
-magic_quotes_gpc = Off
-; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
-magic_quotes_runtime = Off
-; Use Sybase-style magic quotes (escape ' with '' instead of \').
-magic_quotes_sybase = Off
-; Automatically add files before or after any PHP document.
-auto_prepend_file =
+; Automatically add files after PHP document.
+; https://php.net/auto-append-file
auto_append_file =
-; As of 4.0b4, PHP always outputs a character encoding by default in
-; the Content-type: header. To disable sending of the charset, simply
-; set it to be empty.
+; By default, PHP will output a media type using the Content-Type header. To
+; disable this, simply set it to be empty.
-; PHP's built-in default is text/html
+; PHP's built-in default media type is set to text/html.
+; https://php.net/default-mimetype
default_mimetype = "text/html"
-;default_charset = "iso-8859-1"
-; Always populate the $HTTP_RAW_POST_DATA variable.
-always_populate_raw_post_data = -1
+; PHP's default character set is set to UTF-8.
+; https://php.net/default-charset
+default_charset = "UTF-8"
+; PHP internal character encoding is set to empty.
+; If empty, default_charset is used.
+; https://php.net/internal-encoding
+;internal_encoding =
+; PHP input character encoding is set to empty.
+; https://php.net/input-encoding
+;input_encoding =
+; PHP output character encoding is set to empty.
+; See also output_buffer.
+; https://php.net/output-encoding
+;output_encoding =
; Paths and Directories ;
@@ -499,6 +741,9 @@
; Windows: "\path1;\path2"
;include_path = ".;c:\php\includes"
+; PHP's default setting for include_path is ".;/path/to/php/pear"
+; https://php.net/include-path
; The root of the PHP pages, used only if nonempty.
; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
@@ -505,53 +750,88 @@
; if you are running php as a CGI under any web server (other than IIS)
; see documentation for security issues. The alternate is to use the
; cgi.force_redirect configuration below
+; https://php.net/doc-root
doc_root =
; The directory under which PHP opens the script using /~username used only
; if nonempty.
+; https://php.net/user-dir
user_dir =
; Directory in which the loadable extensions (modules) reside.
-extension_dir = "%MG_WEB_PHP%ext"
+; https://php.net/extension-dir
+;extension_dir = "./"
+; On windows:
+;extension_dir = "ext"
+extension_dir = "ext"
+; Directory where the temporary files should be placed.
+; Defaults to the system default (see sys_get_temp_dir)
+sys_temp_dir = "%MG_WEB_TEMP%"
; Whether or not to enable the dl() function. The dl() function does NOT work
; properly in multithreaded servers, such as IIS or Zeus, and is automatically
; disabled on them.
-enable_dl = On
+; https://php.net/enable-dl
+enable_dl = Off
; cgi.force_redirect is necessary to provide security running PHP as a CGI under
; most web servers. Left undefined, PHP turns this on by default. You can
; turn it off here AT YOUR OWN RISK
; **You CAN safely turn this off for IIS, in fact, you MUST.**
-; cgi.force_redirect = 1
+; https://php.net/cgi.force-redirect
+;cgi.force_redirect = 1
; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
-; every request.
-; cgi.nph = 1
+; every request. PHP's default behavior is to disable this feature.
+;cgi.nph = 1
; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
; will look for to know it is OK to continue execution. Setting this variable MAY
; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
-; cgi.redirect_status_env = ;
+; https://php.net/cgi.redirect-status-env
+;cgi.redirect_status_env =
-; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
+; cgi.fix_pathinfo provides *real* PATH_INFO/PATH_TRANSLATED support for CGI. PHP's
+; previous behaviour was to set PATH_TRANSLATED to SCRIPT_FILENAME, and to not grok
+; what PATH_INFO is. For more information on PATH_INFO, see the cgi specs. Setting
+; this to 1 will cause PHP CGI to fix its paths to conform to the spec. A setting
+; of zero causes PHP to behave as before. Default is 1. You should fix your scripts
+; to use SCRIPT_FILENAME rather than PATH_TRANSLATED.
+; https://php.net/cgi.fix-pathinfo
+;cgi.fix_pathinfo=1
+; if cgi.discard_path is enabled, the PHP CGI binary can safely be placed outside
+; of the web tree and people will not be able to circumvent .htaccess security.
+;cgi.discard_path=1
+; FastCGI under IIS supports the ability to impersonate
; security tokens of the calling client. This allows IIS to define the
; security context that the request runs under. mod_fastcgi under Apache
; does not currently support this feature (03/17/2002)
; Set to 1 if running under IIS. Default is zero.
-; fastcgi.impersonate = 1;
+; https://php.net/fastcgi.impersonate
+;fastcgi.impersonate = 1
-; Disable logging through FastCGI connection
-; fastcgi.log = 0
+; Disable logging through FastCGI connection. PHP's default behavior is to enable
+; this feature.
+;fastcgi.logging = 0
; cgi.rfc2616_headers configuration option tells PHP what type of headers to
-; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
-; is supported by Apache. When this option is set to 1 PHP will send
+; use when sending HTTP response code. If set to 0, PHP sends Status: header that
+; is supported by Apache. When this option is set to 1, PHP will send
; RFC2616 compliant header.
; Default is zero.
+; https://php.net/cgi.rfc2616-headers
;cgi.rfc2616_headers = 0
+; cgi.check_shebang_line controls whether CGI PHP checks for line starting with #!
+; (shebang) at the top of the running script. This line might be needed if the
+; script support running both as stand-alone script and via PHP CGI<. PHP in CGI
+; mode skips this line and ignores its content if this directive is turned on.
+; https://php.net/cgi.check-shebang-line
+;cgi.check_shebang_line=1
; File Uploads ;
@@ -558,15 +838,20 @@
; Whether to allow HTTP file uploads.
+; https://php.net/file-uploads
file_uploads = On
; Temporary directory for HTTP uploaded files (will use system default if not
; specified).
+; https://php.net/upload-tmp-dir
;upload_tmp_dir =
; Maximum allowed size for uploaded files.
+; https://php.net/upload-max-filesize
upload_max_filesize = 2M
+; Maximum number of files that can be uploaded via a single request
+max_file_uploads = 20
; Fopen wrappers ;
@@ -573,15 +858,24 @@
; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
+; https://php.net/allow-url-fopen
allow_url_fopen = On
-; Define the anonymous ftp password (your email address)
+; Whether to allow include/require to open URLs (like https:// or ftp://) as files.
+; https://php.net/allow-url-include
+allow_url_include = Off
+; Define the anonymous ftp password (your email address). PHP's default setting
+; for this is empty.
+; https://php.net/from
;from="john at doe.com"
-; Define the User-Agent string
-; user_agent="PHP"
+; Define the User-Agent string. PHP's default setting for this is empty.
+; https://php.net/user-agent
+;user_agent="PHP"
; Default timeout for socket based streams (seconds)
+; https://php.net/default-socket-timeout
default_socket_timeout = 60
; If your scripts have to deal with files from Macintosh systems,
@@ -589,182 +883,282 @@
; unix or win32 systems, setting this flag will cause PHP to
; automatically detect the EOL character in those files so that
; fgets() and file() will work regardless of the source of the file.
-; auto_detect_line_endings = Off
+; https://php.net/auto-detect-line-endings
+;auto_detect_line_endings = Off
; Dynamic Extensions ;
; If you wish to have an extension loaded automatically, use the following
; syntax:
-; extension=modulename.extension
+; extension=modulename
-; For example, on Windows:
+; For example:
-; extension=msql.dll
+; extension=mysqli
-; ... or under UNIX:
+; When the extension library to load is not located in the default extension
+; directory, You may specify an absolute path to the library file:
-; extension=msql.so
+; extension=/path/to/extension/mysqli.so
-; Note that it should be the name of the module only; no directory information
-; needs to go here. Specify the location of the extension with the
-; extension_dir directive above.
+; Note : The syntax used in previous PHP versions ('extension=<ext>.so' and
+; 'extension='php_<ext>.dll') is supported for legacy reasons and may be
+; deprecated in a future PHP major version. So, when it is possible, please
+; move to the new ('extension=<ext>) syntax.
+; Notes for Windows environments :
+; - Many DLL files are located in the extensions/ (PHP 4) or ext/ (PHP 5+)
+; extension folders as well as the separate PECL DLL download (PHP 5+).
+; Be sure to appropriately set the extension_dir directive.
+;extension=bz2
+extension=curl
+;extension=ffi
+;extension=ftp
+;extension=fileinfo
+extension=gd
+;extension=gettext
+;extension=gmp
+;extension=intl
+;extension=imap
+;extension=ldap
+extension=mbstring
+;extension=exif ; Must be after mbstring as it depends on it
+;extension=mysqli
+;extension=oci8_12c ; Use with Oracle Database 12c Instant Client
+;extension=oci8_19 ; Use with Oracle Database 19 Instant Client
+;extension=odbc
+;extension=openssl
+;extension=pdo_firebird
+;extension=pdo_mysql
+;extension=pdo_oci
+;extension=pdo_odbc
+;extension=pdo_pgsql
+extension=pdo_sqlite
+;extension=pgsql
+;extension=shmop
+; The MIBS data available in the PHP distribution must be installed.
+; See https://www.php.net/manual/en/snmp.installation.php
+;extension=snmp
-;Windows Extensions
-;Note that ODBC support is built in, so no dll is needed for it.
+;extension=soap
+;extension=sockets
+;extension=sodium
+;extension=sqlite3
+;extension=tidy
+extension=xsl
+extension=MapGuideApi
+;zend_extension=opcache
-extension=php_mbstring.dll
-;extension=php_bz2.dll
-;extension=php_cpdf.dll
-extension=php_curl.dll
-;extension=php_dba.dll
-;extension=php_dbase.dll
-;extension=php_dbx.dll
-;extension=php_exif.dll
-;extension=php_fdf.dll
-;extension=php_filepro.dll
-extension=php_gd2.dll
-;extension=php_gettext.dll
-;extension=php_ifx.dll
-;extension=php_iisfunc.dll
-;extension=php_imap.dll
-;extension=php_interbase.dll
-;extension=php_java.dll
-;extension=php_ldap.dll
-;extension=php_mcrypt.dll
-;extension=php_mhash.dll
-;extension=php_mime_magic.dll
-;extension=php_ming.dll
-;extension=php_mssql.dll
-;extension=php_msql.dll
-;extension=php_mysql.dll
-;extension=php_oci8.dll
-extension=php_openssl.dll
-;extension=php_oracle.dll
-;extension=php_pdf.dll
-;extension=php_pgsql.dll
-;extension=php_shmop.dll
-;extension=php_snmp.dll
-;extension=php_sockets.dll
-;extension=php_sybase_ct.dll
-;extension=php_tidy.dll
-;extension=php_w32api.dll
-;extension=php_xmlrpc.dll
-extension=php_xsl.dll
-;extension=php_yaz.dll
-;extension=php_zip.dll
-extension=php_MapGuideApiEnvConfig.dll
-extension=php_MapGuideApi.dll
-extension=php_SQLitePhpApi.dll
; Module Settings ;
+[CLI Server]
+; Whether the CLI web server uses ANSI color coding in its terminal output.
+cli_server.color = On
[Date]
; Defines the default timezone used by the date functions
-; http://php.net/date.timezone
-date.timezone = 'UTC'
+; https://php.net/date.timezone
+;date.timezone =
-[Syslog]
-; Whether or not to define the various syslog variables (e.g. $LOG_PID,
-; $LOG_CRON, etc.). Turning it off is a good idea performance-wise. In
-; runtime, you can define these variables by calling define_syslog_variables().
-define_syslog_variables = Off
+; https://php.net/date.default-latitude
+;date.default_latitude = 31.7667
+; https://php.net/date.default-longitude
+;date.default_longitude = 35.2333
+; https://php.net/date.sunrise-zenith
+;date.sunrise_zenith = 90.833333
+; https://php.net/date.sunset-zenith
+;date.sunset_zenith = 90.833333
+[filter]
+; https://php.net/filter.default
+;filter.default = unsafe_raw
+; https://php.net/filter.default-flags
+;filter.default_flags =
+[iconv]
+; Use of this INI entry is deprecated, use global input_encoding instead.
+; If empty, default_charset or input_encoding or iconv.input_encoding is used.
+; The precedence is: default_charset < input_encoding < iconv.input_encoding
+;iconv.input_encoding =
+; Use of this INI entry is deprecated, use global internal_encoding instead.
+; If empty, default_charset or internal_encoding or iconv.internal_encoding is used.
+; The precedence is: default_charset < internal_encoding < iconv.internal_encoding
+;iconv.internal_encoding =
+; Use of this INI entry is deprecated, use global output_encoding instead.
+; If empty, default_charset or output_encoding or iconv.output_encoding is used.
+; The precedence is: default_charset < output_encoding < iconv.output_encoding
+; To use an output encoding conversion, iconv's output handler must be set
+; otherwise output encoding conversion cannot be performed.
+;iconv.output_encoding =
+[imap]
+; rsh/ssh logins are disabled by default. Use this INI entry if you want to
+; enable them. Note that the IMAP library does not filter mailbox names before
+; passing them to rsh/ssh command, thus passing untrusted data to this function
+; with rsh/ssh enabled is insecure.
+;imap.enable_insecure_rsh=0
+[intl]
+;intl.default_locale =
+; This directive allows you to produce PHP errors when some error
+; happens within intl functions. The value is the level of the error produced.
+; Default is 0, which does not produce any errors.
+;intl.error_level = E_WARNING
+;intl.use_exceptions = 0
+[sqlite3]
+; Directory pointing to SQLite3 extensions
+; https://php.net/sqlite3.extension-dir
+;sqlite3.extension_dir =
+; SQLite defensive mode flag (only available from SQLite 3.26+)
+; When the defensive flag is enabled, language features that allow ordinary
+; SQL to deliberately corrupt the database file are disabled. This forbids
+; writing directly to the schema, shadow tables (eg. FTS data tables), or
+; the sqlite_dbpage virtual table.
+; https://www.sqlite.org/c3ref/c_dbconfig_defensive.html
+; (for older SQLite versions, this flag has no use)
+;sqlite3.defensive = 1
+[Pcre]
+; PCRE library backtracking limit.
+; https://php.net/pcre.backtrack-limit
+;pcre.backtrack_limit=100000
+; PCRE library recursion limit.
+; Please note that if you set this value to a high number you may consume all
+; the available process stack and eventually crash PHP (due to reaching the
+; stack size limit imposed by the Operating System).
+; https://php.net/pcre.recursion-limit
+;pcre.recursion_limit=100000
+; Enables or disables JIT compilation of patterns. This requires the PCRE
+; library to be compiled with JIT support.
+;pcre.jit=1
+[Pdo]
+; Whether to pool ODBC connections. Can be one of "strict", "relaxed" or "off"
+; https://php.net/pdo-odbc.connection-pooling
+;pdo_odbc.connection_pooling=strict
+[Pdo_mysql]
+; Default socket name for local MySQL connects. If empty, uses the built-in
+; MySQL defaults.
+pdo_mysql.default_socket=
+[Phar]
+; https://php.net/phar.readonly
+;phar.readonly = On
+; https://php.net/phar.require-hash
+;phar.require_hash = On
+;phar.cache_list =
[mail function]
; For Win32 only.
+; https://php.net/smtp
SMTP = localhost
+; https://php.net/smtp-port
smtp_port = 25
; For Win32 only.
+; https://php.net/sendmail-from
;sendmail_from = me at example.com
; For Unix only. You may supply arguments as well (default: "sendmail -t -i").
+; https://php.net/sendmail-path
;sendmail_path =
; Force the addition of the specified parameters to be passed as extra parameters
; to the sendmail binary. These parameters will always replace the value of
-; the 5th parameter to mail(), even in safe mode.
+; the 5th parameter to mail().
;mail.force_extra_parameters =
-[SQL]
-sql.safe_mode = Off
+; Add X-PHP-Originating-Script: that will include uid of the script followed by the filename
+mail.add_x_header = Off
+; The path to a log file that will log all mail() calls. Log entries include
+; the full path of the script, line number, To address and headers.
+;mail.log =
+; Log mail to syslog (Event Log on Windows).
+;mail.log = syslog
[ODBC]
+; https://php.net/odbc.default-db
;odbc.default_db = Not yet implemented
+; https://php.net/odbc.default-user
;odbc.default_user = Not yet implemented
+; https://php.net/odbc.default-pw
;odbc.default_pw = Not yet implemented
+; Controls the ODBC cursor model.
+; Default: SQL_CURSOR_STATIC (default).
+;odbc.default_cursortype
; Allow or prevent persistent links.
+; https://php.net/odbc.allow-persistent
odbc.allow_persistent = On
; Check that a connection is still valid before reuse.
+; https://php.net/odbc.check-persistent
odbc.check_persistent = On
; Maximum number of persistent links. -1 means no limit.
+; https://php.net/odbc.max-persistent
odbc.max_persistent = -1
; Maximum number of links (persistent + non-persistent). -1 means no limit.
+; https://php.net/odbc.max-links
odbc.max_links = -1
; Handling of LONG fields. Returns number of bytes to variables. 0 means
; passthru.
+; https://php.net/odbc.defaultlrl
odbc.defaultlrl = 4096
; Handling of binary data. 0 means passthru, 1 return as is, 2 convert to char.
; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
-; of uodbc.defaultlrl and uodbc.defaultbinmode
+; of odbc.defaultlrl and odbc.defaultbinmode
+; https://php.net/odbc.defaultbinmode
odbc.defaultbinmode = 1
-[MySQL]
-; Allow or prevent persistent links.
-mysql.allow_persistent = On
+[MySQLi]
-mysql.max_persistent = -1
+; https://php.net/mysqli.max-persistent
+mysqli.max_persistent = -1
-; Maximum number of links (persistent + non-persistent). -1 means no limit.
-mysql.max_links = -1
+; Allow accessing, from PHP's perspective, local files with LOAD DATA statements
+; https://php.net/mysqli.allow_local_infile
+;mysqli.allow_local_infile = On
-; Default port number for mysql_connect(). If unset, mysql_connect() will use
-; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
-; compile-time value defined MYSQL_PORT (in that order). Win32 will only look
-; at MYSQL_PORT.
-mysql.default_port =
+; It allows the user to specify a folder where files that can be sent via LOAD DATA
+; LOCAL can exist. It is ignored if mysqli.allow_local_infile is enabled.
+;mysqli.local_infile_directory =
-; Default socket name for local MySQL connects. If empty, uses the built-in
-; MySQL defaults.
-mysql.default_socket =
+; Allow or prevent persistent links.
+; https://php.net/mysqli.allow-persistent
+mysqli.allow_persistent = On
-; Default host for mysql_connect() (doesn't apply in safe mode).
-mysql.default_host =
-; Default user for mysql_connect() (doesn't apply in safe mode).
-mysql.default_user =
-; Default password for mysql_connect() (doesn't apply in safe mode).
-; Note that this is generally a *bad* idea to store passwords in this file.
-; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
-; and reveal this password! And of course, any users with read access to this
-; file will be able to reveal the password as well.
-mysql.default_password =
-; Maximum time (in secondes) for connect timeout. -1 means no limit
-mysql.connect_timeout = 60
-; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
-; SQL-Errors will be displayed.
-mysql.trace_mode = Off
-[MySQLI]
; Maximum number of links. -1 means no limit.
+; https://php.net/mysqli.max-links
mysqli.max_links = -1
; Default port number for mysqli_connect(). If unset, mysqli_connect() will use
@@ -771,16 +1165,20 @@
; at MYSQL_PORT.
+; https://php.net/mysqli.default-port
mysqli.default_port = 3306
; MySQL defaults.
+; https://php.net/mysqli.default-socket
mysqli.default_socket =
+; Default host for mysqli_connect() (doesn't apply in safe mode).
+; https://php.net/mysqli.default-host
mysqli.default_host =
+; Default user for mysqli_connect() (doesn't apply in safe mode).
+; https://php.net/mysqli.default-user
mysqli.default_user =
; Default password for mysqli_connect() (doesn't apply in safe mode).
@@ -788,140 +1186,144 @@
; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
+; https://php.net/mysqli.default-pw
mysqli.default_pw =
; Allow or prevent reconnect
mysqli.reconnect = Off
-[mSQL]
-msql.allow_persistent = On
+; If this option is enabled, closing a persistent connection will rollback
+; any pending transactions of this connection, before it is put back
+; into the persistent connection pool.
+;mysqli.rollback_on_cached_plink = Off
-; Maximum number of persistent links. -1 means no limit.
-msql.max_persistent = -1
+[mysqlnd]
+; Enable / Disable collection of general statistics by mysqlnd which can be
+; used to tune and monitor MySQL operations.
+mysqlnd.collect_statistics = On
-; Maximum number of links (persistent+non persistent). -1 means no limit.
-msql.max_links = -1
+; Enable / Disable collection of memory usage statistics by mysqlnd which can be
+mysqlnd.collect_memory_statistics = Off
-[PostgresSQL]
+; Records communication from all extensions using mysqlnd to the specified log
+; file.
+; https://php.net/mysqlnd.debug
+;mysqlnd.debug =
+; Defines which queries will be logged.
+;mysqlnd.log_mask = 0
+; Default size of the mysqlnd memory pool, which is used by result sets.
+;mysqlnd.mempool_default_size = 16000
+; Size of a pre-allocated buffer used when sending commands to MySQL in bytes.
+;mysqlnd.net_cmd_buffer_size = 2048
+; Size of a pre-allocated buffer used for reading data sent by the server in
+; bytes.
+;mysqlnd.net_read_buffer_size = 32768
+; Timeout for network requests in seconds.
+;mysqlnd.net_read_timeout = 31536000
+; SHA-256 Authentication Plugin related. File with the MySQL server public RSA
+; key.
+;mysqlnd.sha256_server_public_key =
+[OCI8]
+; Connection: Enables privileged connections using external
+; credentials (OCI_SYSOPER, OCI_SYSDBA)
+; https://php.net/oci8.privileged-connect
+;oci8.privileged_connect = Off
+; Connection: The maximum number of persistent OCI8 connections per
+; process. Using -1 means no limit.
+; https://php.net/oci8.max-persistent
+;oci8.max_persistent = -1
+; Connection: The maximum number of seconds a process is allowed to
+; maintain an idle persistent connection. Using -1 means idle
+; persistent connections will be maintained forever.
+; https://php.net/oci8.persistent-timeout
+;oci8.persistent_timeout = -1
+; Connection: The number of seconds that must pass before issuing a
+; ping during oci_pconnect() to check the connection validity. When
+; set to 0, each oci_pconnect() will cause a ping. Using -1 disables
+; pings completely.
+; https://php.net/oci8.ping-interval
+;oci8.ping_interval = 60
+; Connection: Set this to a user chosen connection class to be used
+; for all pooled server requests with Oracle 11g Database Resident
+; Connection Pooling (DRCP). To use DRCP, this value should be set to
+; the same string for all web servers running the same application,
+; the database pool must be configured, and the connection string must
+; specify to use a pooled server.
+;oci8.connection_class =
+; High Availability: Using On lets PHP receive Fast Application
+; Notification (FAN) events generated when a database node fails. The
+; database must also be configured to post FAN events.
+;oci8.events = Off
+; Tuning: This option enables statement caching, and specifies how
+; many statements to cache. Using 0 disables statement caching.
+; https://php.net/oci8.statement-cache-size
+;oci8.statement_cache_size = 20
+; Tuning: Enables statement prefetching and sets the default number of
+; rows that will be fetched automatically after statement execution.
+; https://php.net/oci8.default-prefetch
+;oci8.default_prefetch = 100
+; Compatibility. Using On means oci_close() will not close
+; oci_connect() and oci_new_connect() connections.
+; https://php.net/oci8.old-oci-close-semantics
+;oci8.old_oci_close_semantics = Off
+[PostgreSQL]
+; https://php.net/pgsql.allow-persistent
pgsql.allow_persistent = On
; Detect broken persistent links always with pg_pconnect().
; Auto reset feature requires a little overheads.
+; https://php.net/pgsql.auto-reset-persistent
pgsql.auto_reset_persistent = Off
+; https://php.net/pgsql.max-persistent
pgsql.max_persistent = -1
+; https://php.net/pgsql.max-links
pgsql.max_links = -1
; Ignore PostgreSQL backends Notice message or not.
; Notice message logging require a little overheads.
+; https://php.net/pgsql.ignore-notice
pgsql.ignore_notice = 0
-; Log PostgreSQL backends Noitce message or not.
+; Log PostgreSQL backends Notice message or not.
; Unless pgsql.ignore_notice=0, module cannot log notice message.
+; https://php.net/pgsql.log-notice
pgsql.log_notice = 0
-[Sybase]
-sybase.allow_persistent = On
-sybase.max_persistent = -1
-sybase.max_links = -1
-;sybase.interface_file = "/usr/sybase/interfaces"
-; Minimum error severity to display.
-sybase.min_error_severity = 10
-; Minimum message severity to display.
-sybase.min_message_severity = 10
-; Compatability mode with old versions of PHP 3.0.
-; If on, this will cause PHP to automatically assign types to results according
-; to their Sybase type, instead of treating them all as strings. This
-; compatability mode will probably not stay around forever, so try applying
-; whatever necessary changes to your code, and turn it off.
-sybase.compatability_mode = Off
-[Sybase-CT]
-sybct.allow_persistent = On
-sybct.max_persistent = -1
-sybct.max_links = -1
-; Minimum server message severity to display.
-sybct.min_server_severity = 10
-; Minimum client message severity to display.
-sybct.min_client_severity = 10
-[dbx]
-; returned column names can be converted for compatibility reasons
-; possible values for dbx.colnames_case are
-; "unchanged" (default, if not set)
-; "lowercase"
-; "uppercase"
-; the recommended default is either upper- or lowercase, but
-; unchanged is currently set for backwards compatibility
-dbx.colnames_case = "lowercase"
[bcmath]
; Number of decimal digits for all bcmath functions.
+; https://php.net/bcmath.scale
bcmath.scale = 0
[browscap]
+; https://php.net/browscap
;browscap = extra/browscap.ini
-[Informix]
-; Default host for ifx_connect() (doesn't apply in safe mode).
-ifx.default_host =
-; Default user for ifx_connect() (doesn't apply in safe mode).
-ifx.default_user =
-; Default password for ifx_connect() (doesn't apply in safe mode).
-ifx.default_password =
-ifx.allow_persistent = On
-ifx.max_persistent = -1
-ifx.max_links = -1
-; If on, select statements return the contents of a text blob instead of its id.
-ifx.textasvarchar = 0
-; If on, select statements return the contents of a byte blob instead of its id.
-ifx.byteasvarchar = 0
-; Trailing blanks are stripped from fixed-length char columns. May help the
-; life of Informix SE users.
-ifx.charasvarchar = 0
-; If on, the contents of text and byte blobs are dumped to a file instead of
-; keeping them in memory.
-ifx.blobinfile = 0
-; NULL's are returned as empty strings, unless this is set to 1. In that case,
-; NULL's are returned as string 'NULL'.
-ifx.nullformat = 0
[Session]
; Handler used to store/retrieve data.
+; https://php.net/session.save-handler
session.save_handler = files
; Argument passed to save_handler. In the case of files, this is the path
@@ -928,15 +1330,15 @@
; where data files are stored. Note: Windows users have to change this
; variable in order to use PHP's session functions.
-; As of PHP 4.0.1, you can define the path as:
+; The path can be defined as:
; session.save_path = "N;/path"
; where N is an integer. Instead of storing all the session files in
; /path, what this will do is use subdirectories N-levels deep, and
-; store the session data in those directories. This is useful if you
-; or your OS have problems with lots of files in one directory, and is
-; a more efficient layout for servers that handle lots of sessions.
+; store the session data in those directories. This is useful if
+; your OS has problems with many files in one directory, and is
+; a more efficient layout for servers that handle many sessions.
; NOTE 1: PHP will not create this directory structure automatically.
; You can use the script in the ext/session dir for that purpose.
@@ -950,45 +1352,89 @@
; where MODE is the octal representation of the mode. Note that this
; does not overwrite the process's umask.
+; https://php.net/session.save-path
;session.save_path = "/tmp"
-session.save_path = "%MG_WEB_TEMP%"
+; Whether to use strict session mode.
+; Strict session mode does not accept an uninitialized session ID, and
+; regenerates the session ID if the browser sends an uninitialized session ID.
+; Strict mode protects applications from session fixation via a session adoption
+; vulnerability. It is disabled by default for maximum compatibility, but
+; enabling it is encouraged.
+; https://wiki.php.net/rfc/strict_sessions
+session.use_strict_mode = 0
; Whether to use cookies.
+; https://php.net/session.use-cookies
session.use_cookies = 1
-; This option enables administrators to make their users invulnerable to
-; attacks which involve passing session ids in URLs; defaults to 0.
-; session.use_only_cookies = 1
+; https://php.net/session.cookie-secure
+;session.cookie_secure =
+; This option forces PHP to fetch and use a cookie for storing and maintaining
+; the session id. We encourage this operation as it's very helpful in combating
+; session hijacking when not specifying and managing your own session id. It is
+; not the be-all and end-all of session hijacking defense, but it's a good start.
+; https://php.net/session.use-only-cookies
+session.use_only_cookies = 1
; Name of the session (used as cookie name).
+; https://php.net/session.name
session.name = PHPSESSID
; Initialize session on request startup.
+; https://php.net/session.auto-start
session.auto_start = 0
; Lifetime in seconds of cookie or, if 0, until browser is restarted.
+; https://php.net/session.cookie-lifetime
session.cookie_lifetime = 0
; The path for which the cookie is valid.
+; https://php.net/session.cookie-path
session.cookie_path = /
; The domain for which the cookie is valid.
+; https://php.net/session.cookie-domain
session.cookie_domain =
-; Handler used to serialize data. php is the standard serializer of PHP.
+; Whether or not to add the httpOnly flag to the cookie, which makes it
+; inaccessible to browser scripting languages such as JavaScript.
+; https://php.net/session.cookie-httponly
+session.cookie_httponly =
+; Add SameSite attribute to cookie to help mitigate Cross-Site Request Forgery (CSRF/XSRF)
+; Current valid values are "Strict", "Lax" or "None". When using "None",
+; make sure to include the quotes, as `none` is interpreted like `false` in ini files.
+; https://tools.ietf.org/html/draft-west-first-party-cookies-07
+session.cookie_samesite =
+; Handler used to serialize data. php is the standard serializer of PHP.
+; https://php.net/session.serialize-handler
session.serialize_handler = php
-; Define the probability that the 'garbage collection' process is started
-; on every session initialization.
-; The probability is calculated by using gc_probability/gc_divisor,
-; e.g. 1/100 means there is a 1% chance that the GC process starts
-; on each request.
+; Defines the probability that the 'garbage collection' process is started on every
+; session initialization. The probability is calculated by using gc_probability/gc_divisor,
+; e.g. 1/100 means there is a 1% chance that the GC process starts on each request.
+; Default Value: 1
+; Development Value: 1
+; Production Value: 1
+; https://php.net/session.gc-probability
session.gc_probability = 1
-session.gc_divisor = 1000
+; For high volume production servers, using a value of 1000 is a more efficient approach.
+; Default Value: 100
+; Development Value: 1000
+; Production Value: 1000
+; https://php.net/session.gc-divisor
+session.gc_divisor = 1000
; After this number of seconds, stored data will be seen as 'garbage' and
; cleaned up by the garbage collection process.
+; https://php.net/session.gc-maxlifetime
session.gc_maxlifetime = 1440
; NOTE: If you are using the subdirectory option for storing session files
@@ -995,243 +1441,265 @@
; (see session.save_path above), then garbage collection does *not*
; happen automatically. You will need to do your own garbage
; collection through a shell script, cron entry, or some other method.
-; For example, the following script would is the equivalent of
-; setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
-; cd /path/to/sessions; find -cmin +24 | xargs rm
+; For example, the following script is the equivalent of setting
+; session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
+; find /path/to/sessions -cmin +24 -type f | xargs rm
-; PHP 4.2 and less have an undocumented feature/bug that allows you to
-; to initialize a session variable in the global scope, albeit register_globals
-; is disabled. PHP 4.3 and later will warn you, if this feature is used.
-; You can disable the feature and the warning separately. At this time,
-; the warning is only displayed, if bug_compat_42 is enabled.
-session.bug_compat_42 = 0
-session.bug_compat_warn = 1
; Check HTTP Referer to invalidate externally stored URLs containing ids.
; HTTP_REFERER has to contain this substring for the session to be
; considered as valid.
+; https://php.net/session.referer-check
session.referer_check =
-; How many bytes to read from the file.
-session.entropy_length = 0
-; Specified here to create the session id.
-session.entropy_file =
-;session.entropy_length = 16
-;session.entropy_file = /dev/urandom
; Set to {nocache,private,public,} to determine HTTP caching aspects
; or leave this empty to avoid sending anti-caching headers.
+; https://php.net/session.cache-limiter
session.cache_limiter = nocache
; Document expires after n minutes.
+; https://php.net/session.cache-expire
session.cache_expire = 180
; trans sid support is disabled by default.
-; Use of trans sid may risk your users security.
+; Use of trans sid may risk your users' security.
; Use this option with caution.
; - User may send URL contains active session ID
; to other person via. email/irc/etc.
; - URL that contains active session ID may be stored
-; in publically accessible computer.
+; in publicly accessible computer.
; - User may access your site with the same session ID
; always using URL stored in browser's history or bookmarks.
+; https://php.net/session.use-trans-sid
session.use_trans_sid = 0
-; Select a hash function
-; 0: MD5 (128 bits)
-; 1: SHA-1 (160 bits)
-session.hash_function = 0
+; Set session ID character length. This value could be between 22 to 256.
+; Shorter length than default is supported only for compatibility reason.
+; Users should use 32 or more chars.
+; https://php.net/session.sid-length
+; Default Value: 32
+; Development Value: 26
+; Production Value: 26
+session.sid_length = 26
-; Define how many bits are stored in each character when converting
-; the binary hash data to something readable.
-; 4 bits: 0-9, a-f
-; 5 bits: 0-9, a-v
-; 6 bits: 0-9, a-z, A-Z, "-", ","
-session.hash_bits_per_character = 5
; The URL rewriter will look for URLs in a defined set of HTML tags.
-; form/fieldset are special; if you include them here, the rewriter will
+; <form> is special; if you include them here, the rewriter will
; add a hidden <input> field with the info which is otherwise appended
-; to URLs. If you want XHTML conformity, remove the form entry.
+; to URLs. <form> tag's action attribute URL will not be modified
+; unless it is specified.
; Note that all valid entries require a "=", even if no value follows.
-url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
+; Default Value: "a=href,area=href,frame=src,form="
+; Development Value: "a=href,area=href,frame=src,form="
+; Production Value: "a=href,area=href,frame=src,form="
+; https://php.net/url-rewriter.tags
+session.trans_sid_tags = "a=href,area=href,frame=src,form="
-[MSSQL]
-mssql.allow_persistent = On
+; URL rewriter does not rewrite absolute URLs by default.
+; To enable rewrites for absolute paths, target hosts must be specified
+; at RUNTIME. i.e. use ini_set()
+; <form> tags is special. PHP will check action attribute's URL regardless
+; of session.trans_sid_tags setting.
+; If no host is defined, HTTP_HOST will be used for allowed host.
+; Example value: php.net,www.php.net,wiki.php.net
+; Use "," for multiple hosts. No spaces are allowed.
+; Default Value: ""
+; Development Value: ""
+; Production Value: ""
+;session.trans_sid_hosts=""
-mssql.max_persistent = -1
+; Define how many bits are stored in each character when converting
+; the binary hash data to something readable.
+; Possible values:
+; 4 (4 bits: 0-9, a-f)
+; 5 (5 bits: 0-9, a-v)
+; 6 (6 bits: 0-9, a-z, A-Z, "-", ",")
+; Default Value: 4
+; Development Value: 5
+; Production Value: 5
+; https://php.net/session.hash-bits-per-character
+session.sid_bits_per_character = 5
-mssql.max_links = -1
+; Enable upload progress tracking in $_SESSION
+; Default Value: On
+; Development Value: On
+; Production Value: On
+; https://php.net/session.upload-progress.enabled
+;session.upload_progress.enabled = On
-mssql.min_error_severity = 10
+; Cleanup the progress information as soon as all POST data has been read
+; (i.e. upload completed).
+; https://php.net/session.upload-progress.cleanup
+;session.upload_progress.cleanup = On
-mssql.min_message_severity = 10
+; A prefix used for the upload progress key in $_SESSION
+; Default Value: "upload_progress_"
+; Development Value: "upload_progress_"
+; Production Value: "upload_progress_"
+; https://php.net/session.upload-progress.prefix
+;session.upload_progress.prefix = "upload_progress_"
-mssql.compatability_mode = Off
+; The index name (concatenated with the prefix) in $_SESSION
+; containing the upload progress information
+; Default Value: "PHP_SESSION_UPLOAD_PROGRESS"
+; Development Value: "PHP_SESSION_UPLOAD_PROGRESS"
+; Production Value: "PHP_SESSION_UPLOAD_PROGRESS"
+; https://php.net/session.upload-progress.name
+;session.upload_progress.name = "PHP_SESSION_UPLOAD_PROGRESS"
-; Connect timeout
-;mssql.connect_timeout = 5
+; How frequently the upload progress should be updated.
+; Given either in percentages (per-file), or in bytes
+; Default Value: "1%"
+; Development Value: "1%"
+; Production Value: "1%"
+; https://php.net/session.upload-progress.freq
+;session.upload_progress.freq = "1%"
-; Query timeout
-;mssql.timeout = 60
+; The minimum delay between updates, in seconds
+; Default Value: 1
+; https://php.net/session.upload-progress.min-freq
+;session.upload_progress.min_freq = "1"
-; Valid range 0 - 2147483647. Default = 4096.
-;mssql.textlimit = 4096
+; Only write session data when session data is changed. Enabled by default.
+; https://php.net/session.lazy-write
+;session.lazy_write = On
-;mssql.textsize = 4096
+[Assertion]
+; Switch whether to compile assertions at all (to have no overhead at run-time)
+; -1: Do not compile at all
+; 0: Jump over assertion at run-time
+; 1: Execute assertions
+; Changing from or to a negative value is only possible in php.ini! (For turning assertions on and off at run-time, see assert.active, when zend.assertions = 1)
+; Default Value: 1
+; Production Value: -1
+; https://php.net/zend.assertions
+zend.assertions = -1
-; Limits the number of records in each batch. 0 = all records in one batch.
-;mssql.batchsize = 0
-; Specify how datetime and datetim4 columns are returned
-; On => Returns data converted to SQL server settings
-; Off => Returns values as YYYY-MM-DD hh:mm:ss
-;mssql.datetimeconvert = On
-; Use NT authentication when connecting to the server
-mssql.secure_connection = Off
-; Specify max number of processes. Default = 25
-;mssql.max_procs = 25
-[Assertion]
; Assert(expr); active by default.
+; https://php.net/assert.active
;assert.active = On
-; Issue a PHP warning for each failed assertion.
+; Throw an AssertionError on failed assertions
+; https://php.net/assert.exception
+;assert.exception = On
+; Issue a PHP warning for each failed assertion. (Overridden by assert.exception if active)
+; https://php.net/assert.warning
;assert.warning = On
; Don't bail out by default.
+; https://php.net/assert.bail
;assert.bail = Off
; User-function to be called if an assertion fails.
+; https://php.net/assert.callback
;assert.callback = 0
-; Eval the expression with current error_reporting(). Set to true if you want
-; error_reporting(0) around the eval().
-;assert.quiet_eval = 0
-[Ingres II]
-ingres.allow_persistent = On
-ingres.max_persistent = -1
-; Maximum number of links, including persistents. -1 means no limit.
-ingres.max_links = -1
-; Default database (format: [node_id::]dbname[/srv_class]).
-ingres.default_database =
-; Default user.
-ingres.default_user =
-; Default password.
-ingres.default_password =
-[Verisign Payflow Pro]
-; Default Payflow Pro server.
-pfpro.defaulthost = "test-payflow.verisign.com"
-; Default port to connect to.
-pfpro.defaultport = 443
-; Default timeout in seconds.
-pfpro.defaulttimeout = 30
-; Default proxy IP address (if required).
-;pfpro.proxyaddress =
-; Default proxy port.
-;pfpro.proxyport =
-; Default proxy logon.
-;pfpro.proxylogon =
-; Default proxy password.
-;pfpro.proxypassword =
-[com]
+[COM]
; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
+; https://php.net/com.typelib-file
;com.typelib_file =
; allow Distributed-COM calls
+; https://php.net/com.allow-dcom
;com.allow_dcom = true
-; autoregister constants of a components typlib on com_load()
+; autoregister constants of a component's typelib on com_load()
+; https://php.net/com.autoregister-typelib
;com.autoregister_typelib = true
; register constants casesensitive
+; https://php.net/com.autoregister-casesensitive
;com.autoregister_casesensitive = false
-; show warnings on duplicate constat registrations
+; show warnings on duplicate constant registrations
+; https://php.net/com.autoregister-verbose
;com.autoregister_verbose = true
+; The default character set code-page to use when passing strings to and from COM objects.
+; Default: system ANSI code page
+;com.code_page=
+; The version of the .NET framework to use. The value of the setting are the first three parts
+; of the framework's version number, separated by dots, and prefixed with "v", e.g. "v4.0.30319".
+;com.dotnet_version=
[mbstring]
; language for internal character representation.
-mbstring.language = UTF-8
+; This affects mb_send_mail() and mbstring.detect_order.
+; https://php.net/mbstring.language
+;mbstring.language = Japanese
; internal/script encoding.
-; Some encoding cannot work as internal encoding.
-; (e.g. SJIS, BIG5, ISO-2022-*)
-mbstring.internal_encoding = UTF-8
+; Some encoding cannot work as internal encoding. (e.g. SJIS, BIG5, ISO-2022-*)
+;mbstring.internal_encoding =
; http input encoding.
-mbstring.http_input = UTF-8
+; mbstring.encoding_translation = On is needed to use this setting.
+; If empty, default_charset or input_encoding or mbstring.input is used.
+; The precedence is: default_charset < input_encoding < mbstring.http_input
+; https://php.net/mbstring.http-input
+;mbstring.http_input =
-; http output encoding. mb_output_handler must be
-; registered as output buffer to function
-mbstring.http_output = pass
+; http output encoding.
+; mb_output_handler must be registered as output buffer to function.
+; If empty, default_charset or output_encoding or mbstring.http_output is used.
+; The precedence is: default_charset < output_encoding < mbstring.http_output
+; To use an output encoding conversion, mbstring's output handler must be set
+; https://php.net/mbstring.http-output
+;mbstring.http_output =
-; enable automatic encoding translation accoding to
+; enable automatic encoding translation according to
; mbstring.internal_encoding setting. Input chars are
; converted to internal encoding by setting this to On.
; Note: Do _not_ use automatic encoding translation for
; portable libs/applications.
-mbstring.encoding_translation = Off
+; https://php.net/mbstring.encoding-translation
+;mbstring.encoding_translation = Off
; automatic encoding detection order.
-; auto means
-mbstring.detect_order = auto
+; "auto" detect order is changed according to mbstring.language
+; https://php.net/mbstring.detect-order
+;mbstring.detect_order = auto
; substitute_character used when character cannot be converted
; one from another
-;mbstring.substitute_character = none;
+; https://php.net/mbstring.substitute-character
+;mbstring.substitute_character = none
-; overload(replace) single byte functions by mbstring functions.
-; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
-; etc. Possible values are 0,1,2,4 or combination of them.
-; For example, 7 for overload everything.
-; 0: No overload
-; 1: Overload mail() function
-; 2: Overload str*() functions
-; 4: Overload ereg*() functions
-mbstring.func_overload = 0
+; Enable strict encoding detection.
+;mbstring.strict_detection = Off
-[FrontBase]
-;fbsql.allow_persistent = On
-;fbsql.autocommit = On
-;fbsql.default_database =
-;fbsql.default_database_password =
-;fbsql.default_host =
-;fbsql.default_password =
-;fbsql.default_user = "_SYSTEM"
-;fbsql.generate_warnings = Off
-;fbsql.max_connections = 128
-;fbsql.max_links = 128
-;fbsql.max_persistent = -1
-;fbsql.max_results = 128
-;fbsql.batchSize = 1000
+; This directive specifies the regex pattern of content types for which mb_output_handler()
+; is activated.
+; Default: mbstring.http_output_conv_mimetypes=^(text/|application/xhtml\+xml)
+;mbstring.http_output_conv_mimetypes=
+; This directive specifies maximum stack depth for mbstring regular expressions. It is similar
+; to the pcre.recursion_limit for PCRE.
+;mbstring.regex_stack_limit=100000
+; This directive specifies maximum retry count for mbstring regular expressions. It is similar
+; to the pcre.backtrack_limit for PCRE.
+;mbstring.regex_retry_limit=1000000
+[gd]
+; Tell the jpeg decode to ignore warnings and try to create
+; a gd image. The warning will then be displayed as notices
+; disabled by default
+; https://php.net/gd.jpeg-ignore-warning
+;gd.jpeg_ignore_warning = 1
[exif]
; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
; With mbstring support this will automatically be converted into the encoding
@@ -1238,31 +1706,246 @@
; given by corresponding encode setting. When empty mbstring.internal_encoding
; is used. For the decode settings you can distinguish between motorola and
; intel byte order. A decode setting cannot be empty.
+; https://php.net/exif.encode-unicode
;exif.encode_unicode = ISO-8859-15
+; https://php.net/exif.decode-unicode-motorola
;exif.decode_unicode_motorola = UCS-2BE
+; https://php.net/exif.decode-unicode-intel
;exif.decode_unicode_intel = UCS-2LE
+; https://php.net/exif.encode-jis
;exif.encode_jis =
+; https://php.net/exif.decode-jis-motorola
;exif.decode_jis_motorola = JIS
+; https://php.net/exif.decode-jis-intel
;exif.decode_jis_intel = JIS
[Tidy]
; The path to a default tidy configuration file to use when using tidy
+; https://php.net/tidy.default-config
;tidy.default_config = /usr/local/lib/php/default.tcfg
; Should tidy clean and repair output automatically?
; WARNING: Do not use this option if you are generating non-html content
; such as dynamic images
+; https://php.net/tidy.clean-output
tidy.clean_output = Off
[soap]
; Enables or disables WSDL caching feature.
+; https://php.net/soap.wsdl-cache-enabled
soap.wsdl_cache_enabled=1
; Sets the directory name where SOAP extension will put cache files.
+; https://php.net/soap.wsdl-cache-dir
soap.wsdl_cache_dir="/tmp"
-; (time to live) Sets the number of second while cached file will be used
+; (time to live) Sets the number of second while cached file will be used
; instead of original one.
+; https://php.net/soap.wsdl-cache-ttl
soap.wsdl_cache_ttl=86400
-; Local Variables:
-; tab-width: 4
-; End:
+; Sets the size of the cache limit. (Max. number of WSDL files to cache)
+soap.wsdl_cache_limit = 5
+[sysvshm]
+; A default size of the shared memory segment
+;sysvshm.init_mem = 10000
+[ldap]
+; Sets the maximum number of open links or -1 for unlimited.
+ldap.max_links = -1
+[dba]
+;dba.default_handler=
+[opcache]
+; Determines if Zend OPCache is enabled
+;opcache.enable=1
+; Determines if Zend OPCache is enabled for the CLI version of PHP
+;opcache.enable_cli=0
+; The OPcache shared memory storage size.
+;opcache.memory_consumption=128
+; The amount of memory for interned strings in Mbytes.
+;opcache.interned_strings_buffer=8
+; The maximum number of keys (scripts) in the OPcache hash table.
+; Only numbers between 200 and 1000000 are allowed.
+;opcache.max_accelerated_files=10000
+; The maximum percentage of "wasted" memory until a restart is scheduled.
+;opcache.max_wasted_percentage=5
+; When this directive is enabled, the OPcache appends the current working
+; directory to the script key, thus eliminating possible collisions between
+; files with the same name (basename). Disabling the directive improves
+; performance, but may break existing applications.
+;opcache.use_cwd=1
+; When disabled, you must reset the OPcache manually or restart the
+; webserver for changes to the filesystem to take effect.
+;opcache.validate_timestamps=1
+; How often (in seconds) to check file timestamps for changes to the shared
+; memory storage allocation. ("1" means validate once per second, but only
+; once per request. "0" means always validate)
+;opcache.revalidate_freq=2
+; Enables or disables file search in include_path optimization
+;opcache.revalidate_path=0
+; If disabled, all PHPDoc comments are dropped from the code to reduce the
+; size of the optimized code.
+;opcache.save_comments=1
+; If enabled, compilation warnings (including notices and deprecations) will
+; be recorded and replayed each time a file is included. Otherwise, compilation
+; warnings will only be emitted when the file is first cached.
+;opcache.record_warnings=0
+; Allow file existence override (file_exists, etc.) performance feature.
+;opcache.enable_file_override=0
+; A bitmask, where each bit enables or disables the appropriate OPcache
+; passes
+;opcache.optimization_level=0x7FFFBFFF
+;opcache.dups_fix=0
+; The location of the OPcache blacklist file (wildcards allowed).
+; Each OPcache blacklist file is a text file that holds the names of files
+; that should not be accelerated. The file format is to add each filename
+; to a new line. The filename may be a full path or just a file prefix
+; (i.e., /var/www/x blacklists all the files and directories in /var/www
+; that start with 'x'). Line starting with a ; are ignored (comments).
+;opcache.blacklist_filename=
+; Allows exclusion of large files from being cached. By default all files
+; are cached.
+;opcache.max_file_size=0
+; Check the cache checksum each N requests.
+; The default value of "0" means that the checks are disabled.
+;opcache.consistency_checks=0
+; How long to wait (in seconds) for a scheduled restart to begin if the cache
+; is not being accessed.
+;opcache.force_restart_timeout=180
+; OPcache error_log file name. Empty string assumes "stderr".
+;opcache.error_log=
+; All OPcache errors go to the Web server log.
+; By default, only fatal errors (level 0) or errors (level 1) are logged.
+; You can also enable warnings (level 2), info messages (level 3) or
+; debug messages (level 4).
+;opcache.log_verbosity_level=1
+; Preferred Shared Memory back-end. Leave empty and let the system decide.
+;opcache.preferred_memory_model=
+; Protect the shared memory from unexpected writing during script execution.
+; Useful for internal debugging only.
+;opcache.protect_memory=0
+; Allows calling OPcache API functions only from PHP scripts which path is
+; started from specified string. The default "" means no restriction
+;opcache.restrict_api=
+; Mapping base of shared memory segments (for Windows only). All the PHP
+; processes have to map shared memory into the same address space. This
+; directive allows to manually fix the "Unable to reattach to base address"
+; errors.
+;opcache.mmap_base=
+; Facilitates multiple OPcache instances per user (for Windows only). All PHP
+; processes with the same cache ID and user share an OPcache instance.
+;opcache.cache_id=
+; Enables and sets the second level cache directory.
+; It should improve performance when SHM memory is full, at server restart or
+; SHM reset. The default "" disables file based caching.
+;opcache.file_cache=
+; Enables or disables opcode caching in shared memory.
+;opcache.file_cache_only=0
+; Enables or disables checksum validation when script loaded from file cache.
+;opcache.file_cache_consistency_checks=1
+; Implies opcache.file_cache_only=1 for a certain process that failed to
+; reattach to the shared memory (for Windows only). Explicitly enabled file
+; cache is required.
+;opcache.file_cache_fallback=1
+; Enables or disables copying of PHP code (text segment) into HUGE PAGES.
+; This should improve performance, but requires appropriate OS configuration.
+;opcache.huge_code_pages=1
+; Validate cached file permissions.
+;opcache.validate_permission=0
+; Prevent name collisions in chroot'ed environment.
+;opcache.validate_root=0
+; If specified, it produces opcode dumps for debugging different stages of
+; optimizations.
+;opcache.opt_debug_level=0
+; Specifies a PHP script that is going to be compiled and executed at server
+; start-up.
+; https://php.net/opcache.preload
+;opcache.preload=
+; Preloading code as root is not allowed for security reasons. This directive
+; facilitates to let the preloading to be run as another user.
+; https://php.net/opcache.preload_user
+;opcache.preload_user=
+; Prevents caching files that are less than this number of seconds old. It
+; protects from caching of incompletely updated files. In case all file updates
+; on your site are atomic, you may increase performance by setting it to "0".
+;opcache.file_update_protection=2
+; Absolute path used to store shared lockfiles (for *nix only).
+;opcache.lockfile_path=/tmp
+[curl]
+; A default value for the CURLOPT_CAINFO option. This is required to be an
+; absolute path.
+;curl.cainfo =
+[openssl]
+; The location of a Certificate Authority (CA) file on the local filesystem
+; to use when verifying the identity of SSL/TLS peers. Most users should
+; not specify a value for this directive as PHP will attempt to use the
+; OS-managed cert stores in its absence. If specified, this value may still
+; be overridden on a per-stream basis via the "cafile" SSL stream context
+; option.
+;openssl.cafile=
+; If openssl.cafile is not specified or if the CA file is not found, the
+; directory pointed to by openssl.capath is searched for a suitable
+; certificate. This value must be a correctly hashed certificate directory.
+; Most users should not specify a value for this directive as PHP will
+; attempt to use the OS-managed cert stores in its absence. If specified,
+; this value may still be overridden on a per-stream basis via the "capath"
+; SSL stream context option.
+;openssl.capath=
+[ffi]
+; FFI API restriction. Possible values:
+; "preload" - enabled in CLI scripts and preloaded files (default)
+; "false" - always disabled
+; "true" - always enabled
+;ffi.enable=preload
+; List of headers files to preload, wildcard patterns allowed.
+;ffi.preload=
Deleted: trunk/Installer/Support/Web/x64/httpd-2.4.52-win64-VS16.zip
(Binary files differ)
Added: trunk/Installer/Support/Web/x64/httpd-2.4.53-win64-VS16.zip
Index: trunk/Installer/Support/Web/x64/httpd-2.4.53-win64-VS16.zip
--- trunk/Installer/Support/Web/x64/httpd-2.4.53-win64-VS16.zip 2022-10-10 13:14:04 UTC (rev 9979)
+++ trunk/Installer/Support/Web/x64/httpd-2.4.53-win64-VS16.zip 2022-10-10 13:29:12 UTC (rev 9980)
Property changes on: trunk/Installer/Support/Web/x64/httpd-2.4.53-win64-VS16.zip
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Deleted: trunk/Installer/Support/Web/x64/php-5.6.40-x64-VC11.zip
Added: trunk/Installer/Support/Web/x64/php-8.1.11-nts-Win32-vs16-x64.zip
Index: trunk/Installer/Support/Web/x64/php-8.1.11-nts-Win32-vs16-x64.zip
--- trunk/Installer/Support/Web/x64/php-8.1.11-nts-Win32-vs16-x64.zip 2022-10-10 13:14:04 UTC (rev 9979)
+++ trunk/Installer/Support/Web/x64/php-8.1.11-nts-Win32-vs16-x64.zip 2022-10-10 13:29:12 UTC (rev 9980)
Property changes on: trunk/Installer/Support/Web/x64/php-8.1.11-nts-Win32-vs16-x64.zip
## -0,0 +1 ##
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat 2022-10-10 13:14:04 UTC (rev 9979)
+++ trunk/Installer/build.bat 2022-10-10 13:29:12 UTC (rev 9980)
@@ -80,14 +80,14 @@
rem ==================================================
rem Web dependencies
-SET HTTPD_VERSION=2.4.52
+SET HTTPD_VERSION=2.4.53
SET HTTPD_VCVER=VS16
-SET PHP_VERSION=5.6.40
+SET PHP_VERSION=8.1.11
SET TOMCAT_VERSION=9.0.37
-SET HTTPD_PACKAGE=httpd-%HTTPD_VERSION%-%PLATFORM_CLR%-%HTTPD_VCVER%.zip
+SET HTTPD_PACKAGE=httpd-%HTTPD_VERSION%-%PLATFORM_WIN%-%HTTPD_VCVER%.zip
SET TOMCAT_PACKAGE_NAME=apache-tomcat-%TOMCAT_VERSION%
SET TOMCAT_PACKAGE=%MG_OEM%\LinuxApt\%TOMCAT_PACKAGE_NAME%.tar.gz
-SET PHP_TS_PACKAGE=php-%PHP_VERSION%-%PLATFORM_CLR%-VC11.zip
+SET PHP_TS_PACKAGE=php-%PHP_VERSION%-nts-Win32-vs16-%PLATFORM_CLR%.zip
:study_params
if (%1)==() goto start_build
@@ -184,7 +184,10 @@
popd
echo [prepare] Unpack Tomcat
pushd "%INSTALLER_DEV_SUPPORT%\Web\%PLATFORM_CLR%"
+echo [prepare] mod_jk
copy /Y mod_jk.so "%MG_SOURCE%\Web\Apache24\modules"
+echo [prepare] mod_fcgid
+copy /Y mod_fcgid.so "%MG_SOURCE%\Web\Apache24\modules"
REM we unpack to root because Tomcat is the root dir in the zip file
7z x "%TOMCAT_PACKAGE%" -y -o"%MG_SOURCE%\Web"
popd
@@ -206,15 +209,15 @@
popd
echo [prepare] Copy support dlls for PostgreSQL provider
copy /Y "%MG_SOURCE%\Web\Php\libpq.dll" "%MG_SOURCE%\Server\FDO"
-copy /Y "%MG_SOURCE%\Web\Php\libeay32.dll" "%MG_SOURCE%\Server\FDO"
-copy /Y "%MG_SOURCE%\Web\Php\ssleay32.dll" "%MG_SOURCE%\Server\FDO"
+copy /Y "%MG_SOURCE%\Web\Php\libssl-1_1-x64.dll" "%MG_SOURCE%\Server\FDO"
+copy /Y "%MG_SOURCE%\Web\Php\libcrypto-1_1-x64.dll" "%MG_SOURCE%\Server\FDO"
rem copy template configs on top
echo [prepare] Tomcat config
-%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM_CLR%\configs\Tomcat" "%MG_SOURCE%\Web\Tomcat" /EXCLUDE:svn_excludes.txt
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM_CLR%\configs\Tomcat" "%MG_SOURCE%\Web\Tomcat"
echo [prepare] Php config
-%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM_CLR%\configs\Php" "%MG_SOURCE%\Web\Php" /EXCLUDE:svn_excludes.txt
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM_CLR%\configs\Php" "%MG_SOURCE%\Web\Php"
echo [prepare] Apache2 config
-%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM_CLR%\configs\Apache2" "%MG_SOURCE%\Web\Apache24" /EXCLUDE:svn_excludes.txt
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM_CLR%\configs\Apache2" "%MG_SOURCE%\Web\Apache24"
echo [prepare] Apache2 mapagent so
copy /Y "%MG_BUILD_MAPAGENT%" "%MG_SOURCE%\Web\Apache24\modules"
echo [prepare] FDO providers.xml
More information about the mapguide-commits
