[mapguide-commits] r9988 - in trunk/MgDev/Bindings/src/Managed/DotNet: MapGuideDotNetApi/Properties OSGeo.MapGuide.Foundation OSGeo.MapGuide.Foundation/Properties OSGeo.MapGuide.Geometry OSGeo.MapGuide.Geometry/Properties OSGeo.MapGuide.MapGuideCommon OSGeo.MapGuide.MapGuideCommon/Properties OSGeo.MapGuide.PlatformBase OSGeo.MapGuide.PlatformBase/Properties OSGeo.MapGuide.Web OSGeo.MapGuide.Web/Properties
svn_mapguide at osgeo.org
Mon Oct 17 03:30:34 PDT 2022
Author: jng
Date: 2022-10-17 03:30:34 -0700 (Mon, 17 Oct 2022)
New Revision: 9988
Added:
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/Properties/
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/Properties/AssemblyInfo.cs
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/Properties/
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/Properties/AssemblyInfo.cs
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/Properties/
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/Properties/AssemblyInfo.cs
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/Properties/
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/Properties/AssemblyInfo.cs
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/Properties/
trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/Properties/AssemblyInfo.cs
trunk/MgDev/Bindings/src/Managed/DotNet/MapGuideDotNetApi/Properties/AssemblyInfo.cs
#2852: Add missing AssemblyInfo.cs files and establish 4.0.0.0 as the base version
Modified: trunk/MgDev/Bindings/src/Managed/DotNet/MapGuideDotNetApi/Properties/AssemblyInfo.cs
--- trunk/MgDev/Bindings/src/Managed/DotNet/MapGuideDotNetApi/Properties/AssemblyInfo.cs 2022-10-17 09:26:54 UTC (rev 9987)
+++ trunk/MgDev/Bindings/src/Managed/DotNet/MapGuideDotNetApi/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
@@ -45,8 +45,8 @@
// You can specify all the values or you can default the Revision and Build Numbers
// by using the '*' as shown below:
-[assembly: AssemblyVersion("4.0.0.9389")]
-[assembly: AssemblyFileVersion("4.0.0.9389")]
+[assembly: AssemblyVersion("4.0.0.0")]
+[assembly: AssemblyFileVersion("4.0.0.0")]
[assembly: AssemblyInformationalVersion("4.0.0.0")]
Added: trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/Properties/AssemblyInfo.cs
--- trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
@@ -0,0 +1,77 @@
+// Copyright (C) 2004-2011 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+using System;
+using System.Reflection;
+using System.Runtime.CompilerServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("MapGuide .net API Dynamic Link Library")]
+[assembly: AssemblyDescription(".net wrapper for the MapGuide API (64-bit only)")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("MapGuide Open Source")]
+[assembly: AssemblyCopyright("")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+[assembly: CLSCompliant(true)]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Revision and Build Numbers
+// by using the '*' as shown below:
+[assembly: AssemblyInformationalVersion("4.0.0.0")]
+// In order to sign your assembly you must specify a key to use. Refer to the
+// Microsoft .NET Framework documentation for more information on assembly signing.
+// Use the attributes below to control which key is used for signing.
+// Notes:
+// (*) If no key is specified, the assembly is not signed.
+// (*) KeyName refers to a key that has been installed in the Crypto Service
+// Provider (CSP) on your machine. KeyFile refers to a file which contains
+// a key.
+// (*) If the KeyFile and the KeyName values are both specified, the
+// following processing occurs:
+// (1) If the KeyName can be found in the CSP, that key is used.
+// (2) If the KeyName does not exist and the KeyFile does exist, the key
+// in the KeyFile is installed into the CSP and used.
+// (*) In order to create a KeyFile, you can use the sn.exe (Strong Name) utility.
+// When specifying the KeyFile, the location of the KeyFile should be
+// relative to the project output directory which is
+// %Project Directory%\obj\<configuration>. For example, if your KeyFile is
+// located in the project directory, you would specify the AssemblyKeyFile
+// attribute as [assembly: AssemblyKeyFile("..\\..\\mykey.snk")]
+// (*) Delay Signing is an advanced option - see the Microsoft .NET Framework
+// documentation for more information on this.
+[assembly: AssemblyDelaySign(false)]
\ No newline at end of file
Added: trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/Properties/AssemblyInfo.cs
--- trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
@@ -0,0 +1,77 @@
+using System;
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// Notes:
+// a key.
Added: trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/Properties/AssemblyInfo.cs
--- trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
@@ -0,0 +1,77 @@
+using System;
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// Notes:
+// a key.
Added: trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/Properties/AssemblyInfo.cs
--- trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
@@ -0,0 +1,77 @@
+using System;
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// Notes:
+// a key.
Added: trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/Properties/AssemblyInfo.cs
--- trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
@@ -0,0 +1,77 @@
+using System;
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// Notes:
+// a key.
More information about the mapguide-commits
