[mapguide-commits] r9989 - in trunk/MgDev: . BuildTools/WebTools/SetAssemblyVersion BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release Portable/DesktopUnmanagedApi/DotNet/Partials Portable/MapViewer/Properties Portable/MapViewer.Desktop/Properties Portable/MgAppLayout/Properties
svn_mapguide at osgeo.org
Mon Oct 17 04:04:34 PDT 2022
Author: jng
Date: 2022-10-17 04:04:34 -0700 (Mon, 17 Oct 2022)
New Revision: 9989
trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln
trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs
trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj
trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.exe
trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.pdb
trunk/MgDev/Portable/DesktopUnmanagedApi/DotNet/Partials/AssemblyInfo.cs
trunk/MgDev/Portable/MapViewer.Desktop/Properties/AssemblyInfo.cs
trunk/MgDev/Portable/MapViewer/Properties/AssemblyInfo.cs
trunk/MgDev/Portable/MgAppLayout/Properties/AssemblyInfo.cs
trunk/MgDev/stampassemblies.bat
#2852: Fix up SetAssemblyVersion tool to allow stamping SDK csproj files as well.
Also establish base version 4.0.0.0 on more AssemblyInfo.cs files
Modified: trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs
--- trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs 2022-10-17 11:04:34 UTC (rev 9989)
@@ -4,6 +4,13 @@
namespace SetAssemblyVersion
+ enum StampTargetKind
+ CSharpAssemblyInfo,
+ VBAssemblyInfo,
+ SdkStyleCsProj
/// <summary>
/// A small utility to stamp the version of our .net API assemblies
@@ -17,7 +24,7 @@
private static string versionStr = null;
- private static bool isVB = false;
+ private static StampTargetKind targetKind = StampTargetKind.CSharpAssemblyInfo;
/// <summary>
/// The main entry point for the application.
@@ -40,12 +47,16 @@
fileName = args[i];
- if (Path.GetExtension(fileName).ToLower() == ".vb")
- isVB = true;
+ var ext = Path.GetExtension(fileName).ToLower();
+ if (ext == ".vb")
+ targetKind = StampTargetKind.VBAssemblyInfo;
+ else if (ext == ".csproj")
+ targetKind = StampTargetKind.SdkStyleCsProj;
if (fileName == "")
- System.Console.WriteLine("Usage: AssemblyInfoUtil <path to AssemblyInfo.cs or AssemblyInfo.vb file> [options]");
+ System.Console.WriteLine("Usage: AssemblyInfoUtil <path to AssemblyInfo.cs or AssemblyInfo.vb file or SDK-style .csproj file> [options]");
System.Console.WriteLine("Options: ");
System.Console.WriteLine(" -set:<new version number> - set new version number (in NN.NN.NN.NN format)");
System.Console.WriteLine(" -inc:<parameter index> - increases the parameter with specified index (can be from 1 to 4)");
@@ -78,12 +89,25 @@
private static string ProcessLine(string line)
- if (isVB)
+ if (targetKind == StampTargetKind.VBAssemblyInfo)
line = ProcessLinePart(line, "<Assembly: AssemblyVersion(\"");
line = ProcessLinePart(line, "<Assembly: AssemblyFileVersion(\"");
line = ProcessLinePart(line, "<Assembly: AssemblyInformationalVersion(\"");
+ else if (targetKind == StampTargetKind.SdkStyleCsProj)
+ // A SDK-style .csproj file has a <Version> element we want
+ // to update with the input version
+ int iVerStart = line.IndexOf("<Version>");
+ int iVerEnd = line.IndexOf("</Version>");
+ if (iVerStart >= 0 && iVerEnd > iVerStart)
+ line = line.Substring(0, iVerStart + "<Version>".Length)
+ + versionStr
+ + line.Substring(iVerEnd);
else
line = ProcessLinePart(line, "[assembly: AssemblyVersion(\"");
Modified: trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj
--- trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj 2022-10-17 11:04:34 UTC (rev 9989)
@@ -1,5 +1,5 @@
<?xml version="1.0" encoding="utf-8"?>
-<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+<Project ToolsVersion="Current" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
@@ -12,6 +12,11 @@
<AssemblyName>SetAssemblyVersion</AssemblyName>
<TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
<FileAlignment>512</FileAlignment>
+ <FileUpgradeFlags>
+ </FileUpgradeFlags>
+ <UpgradeBackupLocation>
+ </UpgradeBackupLocation>
+ <OldToolsVersion>3.5</OldToolsVersion>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
<DebugSymbols>true</DebugSymbols>
Modified: trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.exe
(Binary files differ)
Modified: trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.pdb
Modified: trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln
--- trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln 2022-10-17 11:04:34 UTC (rev 9989)
@@ -1,6 +1,8 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Version 17
+VisualStudioVersion = 17.3.32901.215
+MinimumVisualStudioVersion = 10.0.40219.1
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SetAssemblyVersion", "SetAssemblyVersion\SetAssemblyVersion.csproj", "{FB6810AB-F710-4542-A55C-9DB8AB151B06}"
EndProject
Global
@@ -17,4 +19,7 @@
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
EndGlobalSection
+ GlobalSection(ExtensibilityGlobals) = postSolution
+ SolutionGuid = {6EC2B2CF-E988-4E9C-AEF9-666962AC6C09}
+ EndGlobalSection
EndGlobal
Modified: trunk/MgDev/Portable/DesktopUnmanagedApi/DotNet/Partials/AssemblyInfo.cs
--- trunk/MgDev/Portable/DesktopUnmanagedApi/DotNet/Partials/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/Portable/DesktopUnmanagedApi/DotNet/Partials/AssemblyInfo.cs 2022-10-17 11:04:34 UTC (rev 9989)
@@ -45,9 +45,9 @@
// You can specify all the values or you can default the Revision and Build Numbers
// by using the '*' as shown below:
-[assembly: AssemblyVersion("3.1.0.0")]
-[assembly: AssemblyFileVersion("3.1.0.0")]
-[assembly: AssemblyInformationalVersion("3.1.0.0")]
+[assembly: AssemblyVersion("4.0.0.0")]
+[assembly: AssemblyFileVersion("4.0.0.0")]
+[assembly: AssemblyInformationalVersion("4.0.0.0")]
// In order to sign your assembly you must specify a key to use. Refer to the
Modified: trunk/MgDev/Portable/MapViewer/Properties/AssemblyInfo.cs
--- trunk/MgDev/Portable/MapViewer/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/Portable/MapViewer/Properties/AssemblyInfo.cs 2022-10-17 11:04:34 UTC (rev 9989)
@@ -31,8 +31,8 @@
// You can specify all the values or you can default the Build and Revision Numbers
-// [assembly: AssemblyVersion("3.1.0.0")]
+// [assembly: AssemblyVersion("4.0.0.0")]
[assembly: AssemblyKeyFile("..\\DesktopUnmanagedApi\\DotNet\\MgPortable.snk")]
Modified: trunk/MgDev/Portable/MapViewer.Desktop/Properties/AssemblyInfo.cs
--- trunk/MgDev/Portable/MapViewer.Desktop/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/Portable/MapViewer.Desktop/Properties/AssemblyInfo.cs 2022-10-17 11:04:34 UTC (rev 9989)
@@ -31,8 +31,8 @@
Modified: trunk/MgDev/Portable/MgAppLayout/Properties/AssemblyInfo.cs
--- trunk/MgDev/Portable/MgAppLayout/Properties/AssemblyInfo.cs 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/Portable/MgAppLayout/Properties/AssemblyInfo.cs 2022-10-17 11:04:34 UTC (rev 9989)
@@ -31,6 +31,6 @@
Modified: trunk/MgDev/stampassemblies.bat
--- trunk/MgDev/stampassemblies.bat 2022-10-17 10:30:34 UTC (rev 9988)
+++ trunk/MgDev/stampassemblies.bat 2022-10-17 11:04:34 UTC (rev 9989)
@@ -1,34 +1,47 @@
@echo off
SET PATH=%PATH%;%CD%\BuildTools\WebTools\SetAssemblyVersion\SetAssemblyVersion\bin\Release
SET VERSION=%1
+echo Stamping version %VERSION% to all relevant csproj files
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Foundation"
+SetAssemblyVersion.exe -set:%1 OSGeo.MapGuide.Foundation.csproj
+popd
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Geometry"
+SetAssemblyVersion.exe -set:%1 OSGeo.MapGuide.Geometry.csproj
+popd
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon"
+SetAssemblyVersion.exe -set:%1 OSGeo.MapGuide.MapGuideCommon.csproj
+popd
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.PlatformBase"
+SetAssemblyVersion.exe -set:%1 OSGeo.MapGuide.PlatformBase.csproj
+popd
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Web"
+SetAssemblyVersion.exe -set:%1 OSGeo.MapGuide.Web.csproj
+popd
echo Stamping version %VERSION% to all instances of AssemblyInfo.cs
-pushd "%CD%\Web\src\DotNetApi"
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Foundation\Properties"
SetAssemblyVersion.exe -set:%1 AssemblyInfo.cs
popd
-pushd "%CD%\Web\src\DotNetApi\Foundation"
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Geometry\Properties"
popd
-pushd "%CD%\Web\src\DotNetApi\Geometry"
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\Properties"
popd
-pushd "%CD%\Web\src\DotNetApi\MapGuideCommon"
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\Properties"
popd
-pushd "%CD%\Web\src\DotNetApi\PlatformBase"
+pushd "%CD%\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Web\Properties"
popd
-pushd "%CD%\Web\src\DotNetApi\Web"
+pushd "%CD%\Portable\DesktopUnmanagedApi\DotNet\Partials"
popd
-pushd "%CD%\Desktop\DesktopUnmanagedApi\DotNet\Partials"
+pushd "%CD%\Portable\MgAppLayout\Properties"
popd
-pushd "%CD%\Desktop\MgAppLayout\Properties"
+pushd "%CD%\Portable\MapViewer\Properties"
popd
-pushd "%CD%\Desktop\MapViewer\Properties"
+pushd "%CD%\Portable\MapViewer.Desktop\Properties"
-popd
-pushd "%CD%\Desktop\MapViewer.Desktop\Properties"
-SetAssemblyVersion.exe -set:%1 AssemblyInfo.cs
popd
\ No newline at end of file
More information about the mapguide-commits
