[mapguide-commits] r9991 - in trunk/Installer: . Bootstrapper Libraries/MapGuide Server Libraries/MapGuide Web Extensions
svn_mapguide at osgeo.org
Tue Oct 18 06:55:14 PDT 2022
Author: jng
Date: 2022-10-18 06:55:13 -0700 (Tue, 18 Oct 2022)
New Revision: 9991
Removed:
trunk/Installer/Bootstrapper/vcredist_2012_x64.exe
trunk/Installer/Bootstrapper/Setup.nsi
trunk/Installer/Libraries/MapGuide Server/FDO.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
trunk/Installer/build.bat
#2852: Fix up file list for installer and remove VC 2012 redist installer
Modified: trunk/Installer/Bootstrapper/Setup.nsi
--- trunk/Installer/Bootstrapper/Setup.nsi 2022-10-18 12:18:22 UTC (rev 9990)
+++ trunk/Installer/Bootstrapper/Setup.nsi 2022-10-18 13:55:13 UTC (rev 9991)
@@ -51,18 +51,6 @@
ClearErrors
BeginInstall:
- ; Install VC 2012 redist. Not going to check here. I think we can trust the vcredist install to not trample over anything
- Banner::show /NOUNLOAD "Installing Visual C++ 2012 Redistributable"
- Banner::getWindow /NOUNLOAD
-!if ${CPU} = "x64"
- File /r "${INSTALLER_OUTPUT}\vcredist_2012_x64.exe"
- ExecWait '"$OUTDIR\vcredist_2012_x64.exe" /install /quiet /norestart'
-!else
- File /r "${INSTALLER_OUTPUT}\vcredist_2012_x86.exe"
- ExecWait '"$OUTDIR\vcredist_2012_x86.exe" /install /quiet /norestart'
-!endif
- Banner::destroy
; Install VC 2015/2017/2022 redist. Not going to check here. I think we can trust the vcredist install to not trample over anything
Banner::show /NOUNLOAD "Installing Visual C++ 2015 Redistributable"
@@ -84,10 +72,8 @@
; Delete the MGOS installer and any other extracted after completion
Delete "$OUTDIR\${OUTNAME}.msi"
!if ${CPU} = "x64"
- Delete "$OUTDIR\vcredist_2012_x64.exe"
Delete "$OUTDIR\vc_redist.x64.exe"
!else
- Delete "$OUTDIR\vcredist_2012_x86.exe"
Delete "$OUTDIR\vc_redist.x86.exe"
!endif
Deleted: trunk/Installer/Bootstrapper/vcredist_2012_x64.exe
(Binary files differ)
Modified: trunk/Installer/Libraries/MapGuide Server/FDO.wxs
--- trunk/Installer/Libraries/MapGuide Server/FDO.wxs 2022-10-18 12:18:22 UTC (rev 9990)
+++ trunk/Installer/Libraries/MapGuide Server/FDO.wxs 2022-10-18 13:55:13 UTC (rev 9991)
@@ -146,8 +146,8 @@
<File Id="PostgreSqlOverrides" Checksum="yes" Source="$(var.MgSource)\Server\FDO\PostgreSQLOverrides.dll" />
<File Id="PostgreSqlProvider" Checksum="yes" Source="$(var.MgSource)\Server\FDO\PostgreSQLProvider.dll" />
<File Id="LibPq" Checksum="yes" Source="$(var.MgSource)\Server\FDO\libpq.dll" />
- <File Id="LibEay" Checksum="yes" Source="$(var.MgSource)\Server\FDO\libeay32.dll" />
- <File Id="SslEay" Checksum="yes" Source="$(var.MgSource)\Server\FDO\ssleay32.dll" />
+ <File Id="LibSsl" Checksum="yes" Source="$(var.MgSource)\Server\FDO\libssl-1_1-x64.dll" />
+ <File Id="LibCrypto" Checksum="yes" Source="$(var.MgSource)\Server\FDO\libcrypto-1_1-x64.dll" />
</Component>
<!-- SDF Provider -->
<Component Id="FdoSdfProviderComponent" Win64="$(var.Win64)" Guid="F0976038-9F62-42E7-AA6E-B37C33744C6F">
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs 2022-10-18 12:18:22 UTC (rev 9990)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs 2022-10-18 13:55:13 UTC (rev 9991)
@@ -6,10 +6,10 @@
<?if "$(var.MgPlatform)" = "x64" ?>
<!-- apache_actions.dll path -->
- <?define ACTION_DLL_PATH = "..\..\Custom\apache_actions\bin140_x64\apache_actions.dll" ?>
+ <?define ACTION_DLL_PATH = "..\..\Custom\apache_actions\bin142_x64\apache_actions.dll" ?>
<?else ?>
- <?define ACTION_DLL_PATH = "..\..\Custom\apache_actions\bin140_Win32\apache_actions.dll" ?>
+ <?define ACTION_DLL_PATH = "..\..\Custom\apache_actions\bin142_Win32\apache_actions.dll" ?>
<?endif ?>
<Fragment>
<Binary Id="ApacheActions" SourceFile="$(var.ACTION_DLL_PATH)" />
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat 2022-10-18 12:18:22 UTC (rev 9990)
+++ trunk/Installer/build.bat 2022-10-18 13:55:13 UTC (rev 9991)
@@ -319,15 +319,15 @@
goto quit
:build
-SET RUN_BUILD=%MSBUILD_CLR% /p:OutputName=%INSTALLER_NAME%;MgCulture=%CULTURE%;MgTitle=%INSTALLER_TITLE%;MgVersion=%INSTALLER_VERSION%;MgRegKey=%MG_REG_KEY%;MgPlatform=%PLATFORM_CLR%;Have_ArcSde=%MG_WITH_ARCSDE%
+SET RUN_BUILD=%MSBUILD% /p:OutputName=%INSTALLER_NAME%;MgCulture=%CULTURE%;MgTitle=%INSTALLER_TITLE%;MgVersion=%INSTALLER_VERSION%;MgRegKey=%MG_REG_KEY%;MgPlatform=%PLATFORM_CLR%;Have_ArcSde=%MG_WITH_ARCSDE%
if not ""=="%MG_SOURCE_INC%" set RUN_BUILD=%RUN_BUILD%;MgSource=%MG_SOURCE_INC%
echo [build]: Installer
%RUN_BUILD% InstallerWix.sln
if "%errorlevel%"=="1" goto error
+if not exist "%INSTALLER_OUTPUT%" mkdir "%INSTALLER_OUTPUT%"
pushd "%INSTALLER_DEV_BOOTSTRAP%"
echo [bootstrap]: Copying vcredist
-copy /Y vcredist_2012_%PLATFORM_CLR%.exe "%INSTALLER_OUTPUT%\vcredist_2012_%PLATFORM_CLR%.exe"
copy /Y vc_redist.%PLATFORM_CLR%.exe "%INSTALLER_OUTPUT%\vc_redist.%PLATFORM_CLR%.exe"
popd
More information about the mapguide-commits
