[mapguide-commits] r9992 - in trunk/MgDev: Doc/samples/dotnetsamples Doc/samples/dotnetviewersample Web/src/mapviewernet
svn_mapguide at osgeo.org
Mon Oct 24 04:20:18 PDT 2022
Author: jng
Date: 2022-10-24 04:20:17 -0700 (Mon, 24 Oct 2022)
New Revision: 9992
Added:
trunk/MgDev/Doc/samples/dotnetsamples/Web.config
trunk/MgDev/Doc/samples/dotnetviewersample/Web.config
trunk/MgDev/Web/src/mapviewernet/Web.config
#2852: Update web.config in mapviewernet to reference netstandard, avoiding us having to write this entry in our setup tools (whether InstantSetup or the windows installer). Also add this web.config in dotnetviewersample and dotnetsamples.
Added: trunk/MgDev/Doc/samples/dotnetsamples/Web.config
--- trunk/MgDev/Doc/samples/dotnetsamples/Web.config (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/Web.config 2022-10-24 11:20:17 UTC (rev 9992)
@@ -0,0 +1,105 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<configuration>
+ <system.web>
+ <!-- DYNAMIC DEBUG COMPILATION
+ Set compilation debug="true" to enable ASPX debugging. Otherwise, setting this value to
+ false will improve runtime performance of this application.
+ Set compilation debug="true" to insert debugging symbols (.pdb information)
+ into the compiled page. Because this creates a larger file that executes
+ more slowly, you should set this value to true only when debugging and to
+ false at all other times. For more information, refer to the documentation about
+ debugging ASP.NET files.
+ <compilation defaultLanguage="c#" debug="true">
+ <assemblies>
+ <add assembly="netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51" />
+ </assemblies>
+ </compilation>
+ <!-- CUSTOM ERROR MESSAGES
+ Set customErrors mode="On" or "RemoteOnly" to enable custom error messages, "Off" to disable.
+ Add <error> tags for each of the errors you want to handle.
+ "On" Always display custom (friendly) messages.
+ "Off" Always display detailed ASP.NET error information.
+ "RemoteOnly" Display custom (friendly) messages only to users not running
+ on the local Web server. This setting is recommended for security purposes, so
+ that you do not display application detail information to remote clients.
+ <customErrors
+ mode="RemoteOnly"
+ <!-- AUTHENTICATION
+ This section sets the authentication policies of the application. Possible modes are "Windows",
+ "Forms", "Passport" and "None"
+ "None" No authentication is performed.
+ "Windows" IIS performs authentication (Basic, Digest, or Integrated Windows) according to
+ its settings for the application. Anonymous access must be disabled in IIS.
+ "Forms" You provide a custom form (Web page) for users to enter their credentials, and then
+ you authenticate them in your application. A user credential token is stored in a cookie.
+ "Passport" Authentication is performed via a centralized authentication service provided
+ by Microsoft that offers a single logon and core profile services for member sites.
+ <authentication mode = "None">
+ <!--forms name="ProgAspNetCookie" loginUrl="Login.aspx" /-->
+ </authentication>
+ <!-- AUTHORIZATION
+ This section sets the authorization policies of the application. You can allow or deny access
+ to application resources by user or role. Wildcards: "*" mean everyone, "?" means anonymous
+ (unauthenticated) users.
+ <authorization>
+ <allow users="?" /> <!-- Allow all users -->
+ <!-- <allow users="[comma separated list of users]"
+ roles="[comma separated list of roles]"/>
+ <deny users="[comma separated list of users]"
+ <!--deny users="?" /-->
+ </authorization>
+ <!-- APPLICATION-LEVEL TRACE LOGGING
+ Application-level tracing enables trace log output for every page within an application.
+ Set trace enabled="true" to enable application trace logging. If pageOutput="true", the
+ trace information will be displayed at the bottom of each page. Otherwise, you can view the
+ application trace log by browsing the "trace.axd" page from your web application
+ root.
+ <trace
+ enabled="false"
+ requestLimit="10"
+ pageOutput="false"
+ traceMode="SortByTime"
+ localOnly="true"
+ <!-- SESSION STATE SETTINGS
+ By default ASP.NET uses cookies to identify which requests belong to a particular session.
+ If cookies are not available, a session can be tracked by adding a session identifier to the URL.
+ To disable cookies, set sessionState cookieless="true".
+ <sessionState
+ mode="InProc"
+ stateConnectionString="tcpip=127.0.0.1:42424"
+ sqlConnectionString="data source=127.0.0.1;Trusted_Connection=yes"
+ cookieless="false"
+ timeout="20"
+ <!-- GLOBALIZATION
+ This section sets the globalization settings of the application.
+ <globalization
+ requestEncoding="utf-8"
+ responseEncoding="utf-8"
+ <httpRuntime requestValidationMode="2.0" />
+ </system.web>
+</configuration>
Added: trunk/MgDev/Doc/samples/dotnetviewersample/Web.config
--- trunk/MgDev/Doc/samples/dotnetviewersample/Web.config (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/Web.config 2022-10-24 11:20:17 UTC (rev 9992)
@@ -0,0 +1,105 @@
+<configuration>
+ <system.web>
+ <assemblies>
+ </assemblies>
+ </compilation>
+ <customErrors
+ mode="RemoteOnly"
+ </authentication>
+ <authorization>
+ </authorization>
+ root.
+ <trace
+ enabled="false"
+ requestLimit="10"
+ localOnly="true"
+ <sessionState
+ mode="InProc"
+ timeout="20"
+ <globalization
+ </system.web>
+</configuration>
Modified: trunk/MgDev/Web/src/mapviewernet/Web.config
--- trunk/MgDev/Web/src/mapviewernet/Web.config 2022-10-18 13:55:13 UTC (rev 9991)
+++ trunk/MgDev/Web/src/mapviewernet/Web.config 2022-10-24 11:20:17 UTC (rev 9992)
@@ -1,4 +1,4 @@
-<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<system.web>
@@ -12,11 +12,11 @@
- <compilation
- defaultLanguage="c#"
- debug="true"
+ <assemblies>
+ </assemblies>
+ </compilation>
@@ -99,6 +99,7 @@
</system.web>
</configuration>
More information about the mapguide-commits
