[mapguide-commits] r9993 - in trunk/Tools/MgInstantSetup: InstantSetup InstantSetup.Core
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Oct 24 04:24:45 PDT 2022
Author: jng
Date: 2022-10-24 04:24:44 -0700 (Mon, 24 Oct 2022)
New Revision: 9993
   trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs
   trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs
   trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs
   trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs
#2852: Revert r9956. The necessary netstandard reference is already pre-written into the web.config that comes with mapviewernet, so this feature is no longer necessary.
Modified: trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs	2022-10-24 11:20:17 UTC (rev 9992)
+++ trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.Designer.cs	2022-10-24 11:24:44 UTC (rev 9993)
@@ -47,7 +47,6 @@
             this.groupBox4 = new System.Windows.Forms.GroupBox();
             this.rdDotNet = new System.Windows.Forms.RadioButton();
             this.rdPhp = new System.Windows.Forms.RadioButton();
-            this.chkRefNetstandard = new System.Windows.Forms.CheckBox();
             this.groupBox1.SuspendLayout();
             this.groupBox2.SuspendLayout();
             ((System.ComponentModel.ISupportInitialize)(this.numSitePort)).BeginInit();
@@ -271,27 +270,15 @@
             this.rdPhp.UseVisualStyleBackColor = true;
             this.rdPhp.CheckedChanged += new System.EventHandler(this.rdPhp_CheckedChanged);
-            // chkRefNetstandard
-            this.chkRefNetstandard.AutoSize = true;
-            this.chkRefNetstandard.Location = new System.Drawing.Point(12, 352);
-            this.chkRefNetstandard.Name = "chkRefNetstandard";
-            this.chkRefNetstandard.Size = new System.Drawing.Size(368, 17);
-            this.chkRefNetstandard.TabIndex = 2;
-            this.chkRefNetstandard.Text = "Add netstandard reference (needed for MGOS 4.0 Preview 4 and newer)";
-            this.chkRefNetstandard.UseVisualStyleBackColor = true;
-            this.chkRefNetstandard.CheckedChanged += new System.EventHandler(this.chkRefNetstandard_CheckedChanged);
             // IISConfigCtrl
             this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
-            this.Controls.Add(this.chkRefNetstandard);
             this.Controls.Add(this.groupBox4);
             this.Controls.Add(this.groupBox2);
             this.Controls.Add(this.groupBox1);
             this.Name = "IISConfigCtrl";
-            this.Size = new System.Drawing.Size(422, 383);
+            this.Size = new System.Drawing.Size(422, 358);
             this.groupBox1.ResumeLayout(false);
             this.groupBox1.PerformLayout();
             this.groupBox2.ResumeLayout(false);
@@ -302,7 +289,6 @@
             this.groupBox4.ResumeLayout(false);
             this.groupBox4.PerformLayout();
             this.ResumeLayout(false);
-            this.PerformLayout();
@@ -327,6 +313,5 @@
         private System.Windows.Forms.RadioButton rdPhp;
         private System.Windows.Forms.TextBox txtAppPool;
         private System.Windows.Forms.Label label7;
-        private System.Windows.Forms.CheckBox chkRefNetstandard;
Modified: trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs	2022-10-24 11:20:17 UTC (rev 9992)
+++ trunk/Tools/MgInstantSetup/InstantSetup/IISConfigCtrl.cs	2022-10-24 11:24:44 UTC (rev 9993)
@@ -47,9 +47,6 @@
             rdDotNet.Checked = _confImpl.EnableDotNet;
             rdPhp.Checked = _confImpl.EnablePhp;
-            chkRefNetstandard.Enabled = rdDotNet.Checked;
-            _confImpl.AddNetstandardReference = chkRefNetstandard.Checked;
         public AbstractSetupConfigurationProcess Config
@@ -67,8 +64,6 @@
             _confImpl.EnableDotNet = rdDotNet.Checked;
             _confImpl.EnablePhp = rdPhp.Checked;
         private void rdPhp_CheckedChanged(object sender, EventArgs e)
@@ -111,10 +106,5 @@
             _confImpl.ApplicationPool = txtAppPool.Text;
-        private void chkRefNetstandard_CheckedChanged(object sender, EventArgs e)
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs	2022-10-24 11:20:17 UTC (rev 9992)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/AppCmd.cs	2022-10-24 11:24:44 UTC (rev 9993)
@@ -3,7 +3,6 @@
 using System.Text;
 using System.IO;
 using System.Diagnostics;
-using System.Xml;
 namespace InstantSetup.Core
@@ -200,9 +199,9 @@
             return Process.Start(psi);
-        internal void SetupCore(FormatLineWriter writer, bool b64BitMapGuide, bool referenceNetstandard)
+        internal void SetupCore(FormatLineWriter writer, bool b64BitMapGuide)
-            writer($"Running a series of appcmd calls to set up IIS (64-bit: {b64BitMapGuide}, ref netstandard: {referenceNetstandard})");
+            writer($"Running a series of appcmd calls to set up IIS (64-bit: {b64BitMapGuide})");
             Process p = null;
             p = StartAppCmdProcess(writer, string.Format(CREATE_FASTCGI, _phpDir));
@@ -278,64 +277,6 @@
             p = StartAppCmdProcess(writer, string.Format(SET_MAPVIEWERNET_REQ_VALIDATION_MODE, _webSite, _virtualDir));
             Trace.TraceInformation(p.StandardOutput.ReadToEnd()); p.WaitForExit();
             //if (p.ExitCode != 0) Debugger.Break();
-            //HACK: I'm pretty sure there's a way to do this through appcmd, but I can't figure it out
-            //so we'll add the necessary reference through XML document manipulation
-            if (referenceNetstandard)
-                var webConfigPath = Path.Combine(this._webExtensionsRootDir, "www", "mapviewernet", "web.config");
-                if (File.Exists(webConfigPath))
-                    var webConfig = new XmlDocument();
-                    webConfig.Load(webConfigPath);
-                    bool bChanged = false;
-                    // We should have at least a configuration/system.web/compilation element already there
-                    var conf = webConfig.SelectSingleNode("//configuration/system.web/compilation");
-                    if (conf != null)
-                        const string NETSTANDARD_REF = "netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51";
-                        XmlNode asmNode = null;
-                        if (conf["assemblies"] == null)
-                            asmNode = webConfig.CreateElement("assemblies");
-                            conf.AppendChild(asmNode);
-                            bChanged = true;
-                        var nsRefNode = asmNode.SelectSingleNode($"add[assembly='{NETSTANDARD_REF}']");
-                        if (nsRefNode == null)
-                            nsRefNode = webConfig.CreateElement("add");
-                            var asmAttr = webConfig.CreateAttribute("assembly");
-                            asmAttr.Value = NETSTANDARD_REF;
-                            nsRefNode.Attributes.Append(asmAttr);
-                            asmNode.AppendChild(nsRefNode);
-                            bChanged = true;
-                            writer($"Added netstandard reference to web.config");
-                        if (bChanged)
-                            webConfig.Save(webConfigPath);
-                            writer($"web.config updated");
-                    else
-                        writer($"ERROR: Could not find the expected configuration/system.web/compilation element in this web.config file!");
-                else
-                    writer($"WARNING: Expected to find ({webConfigPath}), but it could not be found!");
         internal void SetDefaultDotNetViewer(FormatLineWriter writer)
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs	2022-10-24 11:20:17 UTC (rev 9992)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs	2022-10-24 11:24:44 UTC (rev 9993)
@@ -65,8 +65,6 @@
         public bool Enable32BitAppsOnWin64 { get; set; }
-        public bool AddNetstandardReference { get; set; }
         protected override void DoBackupConfigFiles(FormatLineWriter writer)
@@ -85,7 +83,7 @@
         protected override void ConfigureWebServer(FormatLineWriter writer)
             var cmd = new AppCmd(this.AppCmdPath, this.WebSiteName, this.VirtualDirectoryName, this.ApplicationPool, this.WebTierRootDir, this.WebTierPhpDir);
-            cmd.SetupCore(writer, this.Is64BitMapGuide, this.AddNetstandardReference);
+            cmd.SetupCore(writer, this.Is64BitMapGuide);
             if (this.EnableDotNet)
                 cmd.SetDefaultDotNetViewer(writer);
             else if (this.EnablePhp)
More information about the mapguide-commits mailing list
