[mapguide-commits] r9994 - in trunk/MgDev: . Web/src/DevHttpServer
svn_mapguide at osgeo.org
Wed Oct 26 05:03:09 PDT 2022
Author: jng
Date: 2022-10-26 05:03:08 -0700 (Wed, 26 Oct 2022)
New Revision: 9994
trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj
trunk/MgDev/Web/src/DevHttpServer/postbuild.bat
trunk/MgDev/build.bat
#2852: Have MgDevHttpServer build to the same WebTier bin directory as other web tier targets. Fix up its postbuild.bat to copy required thirdparty dlls from their source locations. Fix up root build.bat to copy MgDevHttpServer binaries from the correct source location.
Modified: trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj
--- trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj 2022-10-24 11:24:44 UTC (rev 9993)
+++ trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj 2022-10-26 12:03:08 UTC (rev 9994)
@@ -62,16 +62,16 @@
<PropertyGroup Label="UserMacros" />
<PropertyGroup>
<_ProjectFileVersion>10.0.40219.1</_ProjectFileVersion>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\DevHttpServer\$(Configuration)\</OutDir>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\bin\$(Configuration)\</OutDir>
<IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\obj\$(Configuration)\DevHttpServer\</IntDir>
<LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\DevHttpServer\$(Configuration)64\</OutDir>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\bin\$(Configuration)64\</OutDir>
<IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\obj\$(Configuration)64\DevHttpServer\</IntDir>
<LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\DevHttpServer\$(Configuration)\</OutDir>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\bin\$(Configuration)\</OutDir>
<IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\obj\$(Configuration)\DevHttpServer\</IntDir>
<LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\DevHttpServer\$(Configuration)64\</OutDir>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\bin\$(Configuration)64\</OutDir>
<IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\obj\$(Configuration)64\DevHttpServer\</IntDir>
<LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
<CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
Modified: trunk/MgDev/Web/src/DevHttpServer/postbuild.bat
--- trunk/MgDev/Web/src/DevHttpServer/postbuild.bat 2022-10-24 11:24:44 UTC (rev 9993)
+++ trunk/MgDev/Web/src/DevHttpServer/postbuild.bat 2022-10-26 12:03:08 UTC (rev 9994)
@@ -2,6 +2,15 @@
SET PROJECT_DIR=%2
SET TYPE_BUILD=%3
+SET LIBDIR=lib64
+SET CONFDIR=Release
+if "%TYPE_BUILD%" == "Debug64" (
+ SET CONFDIR=Debug
+echo Copying to %TARGET_DIR%
IF NOT EXIST "%TARGET_DIR%Resources" mkdir "%TARGET_DIR%Resources"
echo Copy mapguide_en.res
xcopy /r /d /y "%PROJECT_DIR%..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" "%TARGET_DIR%Resources"
@@ -15,10 +24,14 @@
copy /y "%TARGET_DIR%..\..\src\viewerfiles\*.*" "%TARGET_DIR%wwwroot\viewerfiles"
echo Copy web tier dlls
copy /y "%TARGET_DIR%..\..\bin\%TYPE_BUILD%\Mg*.dll" "%TARGET_DIR%"
-copy /y "%TARGET_DIR%..\..\bin\%TYPE_BUILD%\ACE*.*" "%TARGET_DIR%"
-copy /y "%TARGET_DIR%..\..\bin\%TYPE_BUILD%\GEOS*.*" "%TARGET_DIR%"
-copy /y "%TARGET_DIR%..\..\bin\%TYPE_BUILD%\lib_json*.*" "%TARGET_DIR%"
-copy /y "%TARGET_DIR%..\..\bin\%TYPE_BUILD%\xerces-c_3_1mg*.*" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\ACE\ACE_Wrappers\%LIBDIR%\%CONFDIR%\ACE*.dll" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\ACE\ACE_Wrappers\%LIBDIR%\%CONFDIR%\ACE*.pdb" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\geos\VisualStudio\%TYPE_BUILD%\GEOS*.dll" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\geos\VisualStudio\%TYPE_BUILD%\GEOS*.pdb" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\jsoncpp\%LIBDIR%\%CONFDIR%\lib_json*.dll" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\jsoncpp\%LIBDIR%\%CONFDIR%\lib_json*.pdb" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\dbxml\bin64\%CONFDIR%\xerces-c_3_1mg*.dll" "%TARGET_DIR%"
+copy /y "%TARGET_DIR%..\..\..\Oem\dbxml\bin64\%CONFDIR%\xerces-c_3_1mg*.pdb" "%TARGET_DIR%"
echo Copy web tier pdbs
copy /y "%TARGET_DIR%..\..\..\Common\bin\%TYPE_BUILD%\Mg*.pdb" "%TARGET_DIR%"
echo Copy common dlls
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat 2022-10-24 11:24:44 UTC (rev 9993)
+++ trunk/MgDev/build.bat 2022-10-26 12:03:08 UTC (rev 9994)
@@ -407,8 +407,7 @@
echo [install]: Web Tier - MgDevHttpServer
if not exist "%MG_OUTPUT_WEB%\DevHttpServer" mkdir "%MG_OUTPUT_WEB%\DevHttpServer"
%XCOPY_SINGLE% "%MG_WEB_BIN%\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\DevHttpServer"
-copy /Y "%MG_WEB%\DevHttpServer\%TYPEBUILD%\*.dll" "%MG_OUTPUT_WEB%\DevHttpServer"
-copy /Y "%MG_WEB%\DevHttpServer\%TYPEBUILD%\*.exe" "%MG_OUTPUT_WEB%\DevHttpServer"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\MgDevHttpServer.exe" "%MG_OUTPUT_WEB%\DevHttpServer"
echo [install]: Web Tier - Apache module
if not exist "%MG_OUTPUT_WEB%\Apache24\modules" mkdir "%MG_OUTPUT_WEB%\Apache24\modules"
%XCOPY% /F "%MG_BUILD_MAPAGENT%" "%MG_OUTPUT_WEB%\Apache24\modules" /EXCLUDE:%CONFIGURATION%_excludes.txt
More information about the mapguide-commits
