[mapguide-commits] r9995 - in trunk/Installer: Custom/apache_actions Support/Web/x64 Support/Web/x64/configs/Apache2/conf
svn_mapguide at osgeo.org
Wed Oct 26 08:27:41 PDT 2022
Author: jng
Date: 2022-10-26 08:27:39 -0700 (Wed, 26 Oct 2022)
New Revision: 9995
Added:
trunk/Installer/Support/Web/x64/mod_fcgid.so
trunk/Installer/Custom/apache_actions/apache_actions.cpp
trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
#2852: Add missing mod_fcgid.so binary for installer and update apache custom action to bake a custom php-cgi.exe path with proper space escaping to workaround mod_fcgid's inability to handle paths with spaces on Windows!
Modified: trunk/Installer/Custom/apache_actions/apache_actions.cpp
--- trunk/Installer/Custom/apache_actions/apache_actions.cpp 2022-10-26 12:03:08 UTC (rev 9994)
+++ trunk/Installer/Custom/apache_actions/apache_actions.cpp 2022-10-26 15:27:39 UTC (rev 9995)
@@ -239,6 +239,7 @@
// %MG_WEB_ROOT% for [WEBROOTLOCATION]
// %MG_WEB_PORT% for [APACHE_PORT]
// %MG_WEB_PHP% for [PHPLOCATION]
+ // %MG_WEB_PHP_FCGI% for [PHPLOCATION] with proper escaping for spaces
// %MG_WEB_APACHE% for [APACHELOCATION]
// %MG_VIRTUAL_DIR% for [VIRTUALDIR]
@@ -317,6 +318,14 @@
FindAndReplace(line, "%MG_WEB_ROOT%", szWebRootDir);
FindAndReplace(line, "%MG_WEB_PORT%", szPortNo);
FindAndReplace(line, "%MG_WEB_PHP%", szPhpDir);
+ // BOGUS: The mod_fcgid FcgidWrapper directive can't handle paths to php-cgi.exe that contain spaces
+ // Guess where the default windows installation root is? "C:\Program Files\...". What total BS!
+ // Per this comment (https://www.php.net/manual/en/install.windows.apache2.php#117707), the workaround
+ // is to put a backslash "\" before every space in the path
+ std::string phpDirFcgi = szPhpDir;
+ FindAndReplace(phpDirFcgi, " ", "\\ ");
+ FindAndReplace(line, "%MG_WEB_PHP_FCGI%", phpDirFcgi);
FindAndReplace(line, "%MG_WEB_APACHE%", szApacheDir);
FindAndReplace(line, "%MG_VIRTUAL_DIR%", szVirtualDir);
if (bJava)
Modified: trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf 2022-10-26 12:03:08 UTC (rev 9994)
+++ trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf 2022-10-26 15:27:39 UTC (rev 9995)
@@ -200,7 +200,7 @@
# PHP FastCGI setup
FcgidInitialEnv PHPRC "%MG_WEB_PHP%"
AddHandler fcgid-script .php
-FcgidWrapper "%MG_WEB_PHP%/php-cgi.exe" .php
+FcgidWrapper "%MG_WEB_PHP_FCGI%/php-cgi.exe" .php
# ExtendedStatus controls whether Apache will generate "full" status
Added: trunk/Installer/Support/Web/x64/mod_fcgid.so
(Binary files differ)
Index: trunk/Installer/Support/Web/x64/mod_fcgid.so
--- trunk/Installer/Support/Web/x64/mod_fcgid.so 2022-10-26 12:03:08 UTC (rev 9994)
+++ trunk/Installer/Support/Web/x64/mod_fcgid.so 2022-10-26 15:27:39 UTC (rev 9995)
Property changes on: trunk/Installer/Support/Web/x64/mod_fcgid.so
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
More information about the mapguide-commits
