[mapguide-commits] r10047 - in trunk/MgDev: Common/MapGuideCommon/MapLayer Server/src/Services/Rendering
svn_mapguide at osgeo.org
Tue Apr 4 09:55:25 PDT 2023
Author: jng
Date: 2023-04-04 09:55:24 -0700 (Tue, 04 Apr 2023)
New Revision: 10047
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
Update MgMap::GetTileCoords to also take in a scale parameter, rather than infer it from the view scale. This fixes tile extent calculation at zoom=0 and restores the calculation to match 3.1 behavior in tile extent calculation
Fixes #2863
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2023-04-04 05:54:46 UTC (rev 10046)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2023-04-04 16:55:24 UTC (rev 10047)
@@ -1615,7 +1615,7 @@
// compute the tile coordinates from the x y index of the tiles and the meta tiling factor
void MgMap::GetTileCoords(int metaTileFactor, int tileColumn, int tileRow,
- int dpi, int tileWidth, int tileHeight,
+ int dpi, int tileWidth, int tileHeight, double scale,
double &tileMinX, double &tileMaxX, double &tileMinY, double & tileMaxY)
Ptr<MgEnvelope> mapExtent = this->GetMapExtent();
@@ -1626,7 +1626,6 @@
double mapMinY = rs_min(pt00->GetY(), pt11->GetY());
double mapMaxY = rs_max(pt00->GetY(), pt11->GetY());
- double scale = this->GetViewScale();
double metersPerUnit = this->GetMetersPerUnit();
double metersPerPixel = _METERS_PER_INCH / dpi;
double tileWidthMCS = (double)tileWidth * metersPerPixel * scale / metersPerUnit;
@@ -1636,6 +1635,11 @@
tileMaxX = mapMinX + (double)(tileColumn + metaTileFactor) * tileWidthMCS; // right edge
tileMinY = mapMaxY - (double)(tileRow + metaTileFactor) * tileHeightMCS; // bottom edge
tileMaxY = mapMaxY - (double)(tileRow)* tileHeightMCS; // top edge
+#ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) GetTileCoords @ (%d, %d, %f) -> [(%f, %f)] [(%f, %f)]\n", tileColumn, tileRow, scale, tileMinX, tileMinY, tileMaxX, tileMaxY));
+ ACE_DEBUG((LM_INFO, L"(%t) mpu: %f, mpp: %f, tw: %f, th: %f\n", metersPerUnit, metersPerPixel, tileWidthMCS, tileHeightMCS));
+#endif
@@ -1659,4 +1663,4 @@
INT32 MgMap::GetTilePixelRatio()
return m_tilePixelRatio;
\ No newline at end of file
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2023-04-04 05:54:46 UTC (rev 10046)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2023-04-04 16:55:24 UTC (rev 10047)
@@ -776,12 +776,12 @@
/// \brief
/// compute the coordinates of a tile, increase size by meta tiling Factor sm_useMetaTiles
- /// \param in metaTileFactor, tileColumn, tileRow, dpi, tileWidth, tileHeight,
+ /// \param in metaTileFactor, tileColumn, tileRow, dpi, tileWidth, tileHeight, scale
/// \param out tileMinX,tileMinY. tileMaxX , tileMaxY
/// min,max corners of the tile
virtual void GetTileCoords(int metaTileFactor, int tileColumn, int tileRow,
double &tileMinX, double &tileMaxX, double &tileMinY, double & tileMaxY);
protected:
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2023-04-04 05:54:46 UTC (rev 10046)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2023-04-04 16:55:24 UTC (rev 10047)
@@ -2497,7 +2497,7 @@
double tileMinX, tileMaxX, tileMinY, tileMaxY;
- map->GetTileCoords(std::max(metaTileFactor, 1), tileColumn, tileRow, tileDpi, tileWidth, tileHeight, tileMinX, tileMaxX, tileMinY, tileMaxY);
+ map->GetTileCoords(std::max(metaTileFactor, 1), tileColumn, tileRow, tileDpi, tileWidth, tileHeight, scale, tileMinX, tileMaxX, tileMinY, tileMaxY);
// make the call to render the tile
INT32 tw = tileWidth * std::max(metaTileFactor, 1);
More information about the mapguide-commits
