[mapguide-commits] r10048 - trunk/MgDev
svn_mapguide at osgeo.org
Tue Apr 4 10:14:58 PDT 2023
Author: jng
Date: 2023-04-04 10:14:58 -0700 (Tue, 04 Apr 2023)
New Revision: 10048
trunk/MgDev/cmake_bootstrap.sh
Use SWIG 4.1.1 on Linux
Modified: trunk/MgDev/cmake_bootstrap.sh
--- trunk/MgDev/cmake_bootstrap.sh 2023-04-04 16:55:24 UTC (rev 10047)
+++ trunk/MgDev/cmake_bootstrap.sh 2023-04-04 17:14:58 UTC (rev 10048)
@@ -143,12 +143,12 @@
# If this dir exists, it's a no-op
mkdir -p /tmp/download
cd /tmp/download || exit
- if [ ! -f /tmp/download/master.zip ]; then
- # TODO: Until SWIG 4.1 is actually released, should fix the source archive to a particular commit (if it's possible)
- wget https://github.com/swig/swig/archive/refs/heads/master.zip
+ if [ ! -f /tmp/download/swig.zip ]; then
+ # Use SWIG 4.1.1 release
+ wget -O swig.zip https://github.com/swig/swig/archive/refs/tags/v4.1.1.zip
fi
- unzip -o master.zip
- cd /tmp/download/swig-master/ || exit
+ unzip -o swig.zip
+ cd /tmp/download/swig-4.1.1/ || exit
./autogen.sh
check_build
./configure
@@ -462,4 +462,4 @@
echo "Make sure to run cmake_linuxapt.sh next with --oem-working-dir set to: $OEM_WORK_DIR"
if [ "$COMMON_SUBSET_ONLY" != "1" ]; then
echo "If you are only building the common libs subset, you may ignore the above statement"
-fi
\ No newline at end of file
+fi
More information about the mapguide-commits
