[mapguide-commits] r10041 - trunk/MgDev/Common/Foundation/Exception
svn_mapguide at osgeo.org
Thu Mar 30 01:26:53 PDT 2023
Author: jng
Date: 2023-03-30 01:26:52 -0700 (Thu, 30 Mar 2023)
New Revision: 10041
trunk/MgDev/Common/Foundation/Exception/Exception.cpp
#2867: Fixing this problem of explaining why a localized exception message could not be retrieved is actually hard. So in the absence of a workable solution, add a series of debug-only conditional blocks in MgException so that internal developers can stick breakpoints and find out the actual reason for why a localized exception message could not be retrieved.
Fortunately, most of the time the reason for this is either:
1. The required string bundle was not found at the expected location
2. A MgException was thrown without the required number of exception message arguments
Breakpoints on the debug-only condition blocks should greatly help with case no 2.
Modified: trunk/MgDev/Common/Foundation/Exception/Exception.cpp
--- trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2023-03-30 08:07:39 UTC (rev 10040)
+++ trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2023-03-30 08:26:52 UTC (rev 10041)
@@ -293,7 +293,32 @@
MG_CATCH_AND_RELEASE()
+#if _DEBUG
+ if (nullptr != mgException.p)
+ // TODO: Ideally we want to be able to capture this exception message and pass it on as the "reason"
+ // for why we're failing to retrieve the original exception message. But my initial attempts at this
+ // resulted in massive recursively nested error messages due to us:
+ // a) Currently being in the exception message formatter
+ // b) Naively trying to call GetExceptionMessage() on this exception which has a very high chance of
+ // initiating a long cascading recursive chain of similar errors due to argument mismatches on each
+ // recursive iteration
+ // This is just a variant of the "what do we do if the exception handler itself throws an exception?"
+ // problem with some extra recursion thrown in.
+ // In the absence of an actual solution, the next best thing is just to stick a breakpoint in this block
+ // and inspect the contents of the caught mgException in a debugger.
+ // Fortunately, most of the time the actual reason is we are throwing a MgException somewhere but not
+ // passing the correct amount of arguments for the exception message. So your breakpoint here hits in a
+ // debugger, you know that it's most likely because of this case.
+ // Or the alternative reason is the obvious mapguide_$locale.res string bundle was not found at the
+ // expected location.
+#endif
if (message.empty() && NULL != resources && locale != MgResources::DefaultMessageLocale)
MG_TRY()
@@ -305,6 +330,12 @@
message = resources->FormatMessage(resourceStr, arguments);
+#if _DEBUG
+ // TODO: See above TODO
+#endif
if (message.empty() && NULL != resources)
More information about the mapguide-commits
