[mapguide-commits] r10042 - trunk/MgDev/Web/src/localized
svn_mapguide at osgeo.org
Thu Mar 30 01:35:12 PDT 2023
Author: jng
Date: 2023-03-30 01:35:12 -0700 (Thu, 30 Mar 2023)
New Revision: 10042
Added:
trunk/MgDev/Web/src/localized/fr
Add french localization file for AJAX viewer.
Patch by Pierre Cardinal. Missing translation for string ERR_UNSUPPORTED_TILESET provided by me using Google Translate.
Fixes #2844
Added: trunk/MgDev/Web/src/localized/fr
--- trunk/MgDev/Web/src/localized/fr (rev 0)
+++ trunk/MgDev/Web/src/localized/fr 2023-03-30 08:35:12 UTC (rev 10042)
@@ -0,0 +1,281 @@
+# Web surround localized strings
+# French language
+# Important: This file must be saved with UTF-8 encoding
+# General
+# Fonts - the 6 following entries are mandatory
+ at fontWindows = Arial
+ at fontsizeWindows = 8pt
+ at fontLinux = Arial
+ at fontsizeLinux = 8pt
+ at fontMacintosh = Arial
+ at fontsizeMacintosh = 8pt
+# Distances
+DISTANCEMILES = Miles
+DISTANCEKILOMETERS = Kilomètres
+DISTANCEFEET = Pieds
+DISTANCEUSFEET = Pieds américains
+DISTANCEMETERS = Mètres
+# Fill Patterns/Values
+FILLSOLID = Solide
+FILLNET = Tamis
+FILLLINE = Ligne
+FILLLINE45 = Ligne_45
+FILLLINE90 = Ligne_90
+FILLLINE135 = Ligne_135
+FILLSQUARE = Carré
+FILLBOX = Parallélépipède
+FILLCROSS = Croix
+FILLDASH = Tiret
+FILLDOLMIT = Dolomite
+FILLHEX = Hex
+FILLSACNCR = Sacncr
+FILLSTEEL = Acier
+# Transparency
+TRANSPARENT = Transparent
+# Line Styles/Values
+LINESOLID = Solide
+LINEDASH = Tiret
+LINEDOT = Point
+LINEDASHDOT = Tiret point
+LINEDASHDOTDOT = Tiret point point
+LINERAIL = Rail
+LINEBORDER = Bordure
+LINEDIVIDE = Diviser
+LINEFENCELINE = Limite
+# Buttons
+BUTTONOK = OK
+BUTTONDONE = Terminer
+BUTTONCANCEL = Annuler
+BUTTONREFRESH = Rafraîchir
+BUTTONCLOSE = Fermer
+BUTTONCLEAR = Effacer
+BUTTONSAVE = Enregistrer
+# Colors
+COLORRED = Rouge
+COLORGREEN = Vert
+COLORBLUE = Bleu
+# BufferReport
+BUFFERREPORTTITLE = Créer une zone tampon
+BUFFERREPORTCREATED = %s a été créé.
+BUFFERREPORTUPDATED = %s a été mis à jour.
+BUFFERREPORTFEATURESSINGULAR = %s objet zone tampon a été créé.
+BUFFERREPORTFEATURESPLURAL = %s objets zones tampons ont été créés.
+BUFFERREPORTWARNINGSINGULAR = <b>Avertissement:</b> %s calque a été exclu du calcul de la zone tampon car il n'a pas de système de coordonnées ou que son système de coordonnées est incompatible avec celui de la carte
+BUFFERREPORTWARNINGPLURAL = <b>Avertissement:</b> %s calques ont été exclus du calcul de la zone tampon car ils n'ont pas de système de coordonnées ou que leurs systèmes de coordonnées sont incompatibles avec celui de la carte
+BUFFERREPORTERRORTITLE = Erreur de zone tampon
+# Buffer
+BUFFERCLASSDESCR = Classe d'objets pour le calque de zone tampon
+BUFFERSCHEMADESCR = Schéma de zone tampon temporaire
+BUFFERDIFFARBXY = Impossible de calculer une zone tampon unique autour des objets avec différents systèmes de coordonnées 'X-Y arbitraires'. Veuillez désélectionner l'option 'Fusionner les zones tampons' ou ne sélectionner qu'un seul calque
+# BufferUI
+BUFFERTITLE = Créer une zone tampon
+BUFFERSUBTITLE = Paramètres de zone tampon
+BUFFERINFOTEXT = Sélectionnez des objets sur l'image.
+BUFFERDISTANCE = Distance autour des objets:
+BUFFERLAYERS = Calques à inclure dans la zone tampon:
+BUFFERNOLAYER = <Aucun calque n'est sélectionné>
+BUFFERNAME = Nom du calque de zone tampon obtenu:
+BUFFERNAMETEXT = Zone tampon 1
+BUFFERMERGE = Fusionner les zones tampons
+BUFFERFILLSTYLE = Style de remplissage
+BUFFERFILLPATTERN = Motif de remplissage:
+BUFFERFOREGROUNDCOLOR = Couleur du premier plan:
+BUFFERTRANSPARENCY = Transparence:
+BUFFERBACKGROUNDCOLOR = Couleur de l'arrière-plan:
+BUFFERBORDERSTYLE = Style de bordure
+BUFFERBORDERLINEPATTERN = Motif de la ligne:
+BUFFERBORDERLINECOLOR = Couleur de la ligne:
+BUFFERBORDERLINETHICKNESS = Epaisseur de la ligne:
+BUFFERHELP = <li><p align="left">Les résultats de la zone tampon sont placés dans un nouveau calque au-dessus du calque d'objets supérieur. Ce calque de zone tampon porte le nom que vous entrez ici.</li><li><p align="left">Pour créer plusieurs calques de zone tampon, utilisez des nom différents pour les zones tampons.</li><li><p align="left">Pour masquer les calques de zone tampon, désactivez-les.</li><li><p align="left">Les calques de zone tampon sont temporaires et sont supprimés lorsque vous fermez la visionneuse.</li>
+BUFFERERRORZERODISTANCE = Entrez une distance différente de zéro.
+BUFFERERRORNOLAYERNAME = Veuillez entrer un nom de calque.
+BUFFERERRORNEGATIVETHICKNESS = Veuillez entrer une épaisseur positive ou nulle.
+BUFFERERRORNOSELECTION = Veuillez sélectionner le ou les objets autour desquels calculer une zone tampon.
+BUFFERINPUTWARNNING = L'entrée doit être numérique!
+# ColorPicker
+COLORPICKERDLGTITLE = Sélectionnez une couleur
+COLORPICKERTITLE = Palette de couleurs
+COLORPICKERSUBTITLE = Spécifiez une couleur
+COLORPICKER100TRANSPARENCY = 100%% transparent
+COLORPICKERHEXFORMAT = Format hex
+# MeasureUI
+MEASUREUNITS = Unités de mesure:
+MEASURETITLE = Mesurer la distance
+MEASUREINFO = Cliquez sur un point de départ et sur un point d'arrivée.
+RESUME = Reprendre
+STOP = Arrêter
+CLEAR = Effacer
+MILES = Miles
+KILOMETERS = Kilomètres
+MEASUREHELP = <li>Pour mesurer plusieurs distances, continuez de cliquer sur de nouveaux points.</li><li>Pour terminer, cliquez sur "Arrêter".</li><li>Vous pouvez effectuer un zoom ou un panoramique et continuer les mesures en cliquant sur "Reprendre".</li><li>Pour recommencer, cliquez sur "Effacer".</li>
+SEGMENT = Segment
+TOTAL = Total
+MEASUREERROR = Erreur de mesure
+# Measure
+MEASUREFEATURECLASS = Classe d'objets pour le calque de mesure
+MEASURESCHEMADESCR = Schéma de mesure temporaire
+MEASUREPARTIAL = Partiel
+MEASURETOTAL = total
+MEASURELAYER = Mesurer
+# HtmlViewerAbout
+HTMLABOUTTITLE = À propos de %s
+HTMLABOUTTITLEBAR = MapGuide Viewer
+HTMLABOUTSERVERTITLE = MapGuide Server
+HTMLABOUTVIEWERTITLE = MapGuide Viewer
+HTMLABOUTSERVERVERSION = %s (Version %s)
+HTMLABOUTVIEWERVERSION = %s (Version %s)
+HTMLABOUTTEXT = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL"). A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright © 2007 Autodesk, Inc.<br><br>
+HTMLABOUTLICENSE = fichier de licence
+HTMLABOUTLICENSEFILE = license_en.htm
+# LegendUI
+LEGENDLISTSEPARATOR = ,
+# PrintablePageUi
+PRINTTITLE = Obtenir une page imprimable
+PRINTELEMENTS = Sélectionner les éléments à inclure dans la mise en page.
+PRINTPAGETITLE = Titre de la page:
+PRINTLEGEND = Légende
+PRINTNORTHARROW = Flèche du nord
+PRINTCREATEPAGE = Créer une page
+# PropertyCtrl
+PROPERTIESNONE = Aucune sélection
+PROPERTIESNAME = Nom
+PROPERTIESVALUE = Valeur
+PROPERTIESITEMSEL = Eléments sélectionnés: {0}
+# Search
+SEARCHDLGTITLE = Rechercher objets
+SEARCHTITLE = Résultats de la recherche
+SEARCHERROR = Erreur lors de la recherche
+SEARCHREPORT = Rapport sur la recherche
+SEARCHLAYERNOTFOUND = Calque {0} introuvable!
+SEARCHNOMULTIPROP = L'identité multi-propriétés n'est pas encore prise en charge
+SEARCHTYYPENOTSUP = Le type de propriété d'identité n'est pas encore pris en charge ({0})
+SEARCHNOMATCHES = Aucune correspondance.
+# SearchPrompt
+SEARCHPROMPTFIND = Rechercher
+# SelectWithinUi
+SELECTWITHINTITLE = Sélectionner dans
+SELECTWITHINAREAS = Sélectionner des zones sur l'image.
+SELECTWITHINRESTRICTION = Limiter les résultats aux calques sélectionnés:
+SELECTWITHINTEXT = <li>Si vous continuez de sélectionner des zones sur l'image, cliquer sur "Rafraîchir" pour mettre à jour la liste des calques.</li><li>Pour terminer et sélectionner tous les objets situés dans les zones mises en surbrillance, cliquer sur "Terminer".</li><li>Pour recommencer, cliquer sur "Effacer".</li>
+# Error/Report
+REPORTTITLE = Rapport
+# Legend UI
+REFRESH = Rafraîchir
+EXPANDALL = Développer
+COLLAPSEALL = Tout réduire
+DISPLAYALLINGROUP = Tout afficher dans le groupe
+HIDEALLINGROUP = Tout masquer dans le groupe
+SHOWLONGTHEME = Afficher thème long
+ALLSELECTABLE = Tout sélectionnable
+ALLUNSELECTABLE = Tout non sélectionnable
+HIDEINVISIBLELAYERS = Masquer les calques invisibles
+SHOWINVISIBLELAYERS = Afficher les calques invisibles
+# Task Bar
+TASKS = Tâches
+TASKBARCLOSEBUTTONTEXT = Fermer le volet de tâches
+TASKBARCLOSEBUTTONDESC = Fermer le volet de tâches
+TASKBAROPENBUTTONTEXT = Ouvrir le volet de tâches
+TASKBAROPENBUTTONDESC = Ouvrir le volet de tâches
+# Viewer Options
+OPTIONSTITLE = Options de la visionneuse
+OPTIONSINFOTEXT = Sélectionnez des options de visualisation pour la barre d'état et les info-bulles.
+OPTIONSDISTANCE = Afficher les distances en
+OPTIONSMETRIC = Métrique (kilomètres, mètres)
+OPTIONSUSENGLISH = Impérial (miles, pieds)
+OPTIONSPOSITION = Afficher la position du curseur en
+OPTIONSLATLON = Latitude, longitude (degrés)
+OPTIONSMAPUNITS = Système de coordonnées de carte (X,Y)
+# AJAX Viewer
+VIEWERLAYERS = Calques
+VIEWERPROPS = Propriétés
+VIEWERPANNORTH = Panoramique nord
+VIEWERPANWEST = Panoramique ouest
+VIEWERPANSOUTH = Panoramique sud
+VIEWERPANEAST = Panoramique est
+VIEWERZOOMIN = Zoom avant
+VIEWERZOOMOUT = Zoom arrière
+VIEWERMOVESLIDER = Faire glisser pour déplacer le curseur
+VIEWERDRAGZOOM = Faire glisser pour zoomer
+ENDSEL = CTRL + clic pour terminer
+ENDSELSAFARI = SHIFT + clic pour terminer
+DECIMALSEPARATOR = ,
+THOUSANDSEPARATOR =
+OPENHYPERLINK = CTRL + clic pour ouvrir le lien
+OPENHYPERLINKMAC = COMMAND + clic pour ouvrir le lien
+# Main Frame
+NEEDLOGIN = Vous devez entrer un ID de connexion et un mot de passe corrects pour accéder à ce site
+ALREADYINMEASURE = Une seule commande de mesure est autorisée dans une présentation Web
+ACCESSDENIED = Accès refusé
+LATLONCURPOS = Lat: {0}, Lon: {1}
+MAPUNITSCURPOS = X: {0}, Y: {1}
+FEATURESSELECTED = {0} objets sélectionnés
+FEATURESELECTED = {0} objet sélectionné
+LAYERSELECTED = {0} {1} sélectionné
+MI = mi
+FT = pi
+IN = po
+KM = km
+MT = m
+CM = cm
+DIGALREADYRUNNING = Impossible d'exécuter la mesure: une commande de numérisation est en cours.
+MEASALREADYRUNNING = Impossible d'exécuter la numérisation: une mesure est en cours.
+# Localized Icon Files
+# Property Pane Toolbar
+ZOOMSELECTEDFEATUREDESC = Zoom sur cet objet
+# Multiple Property Processing
+SERVERERROR = Erreur du serveur
+# Quick Plot UI
+QUICKPLOT_HEADER = Tracé rapide
+QUICKPLOT_TITLE = Titre
+QUICKPLOT_SUBTITLE = Sous-titre
+QUICKPLOT_PAPER_SIZE = Format de papier
+QUICKPLOT_SCALING = Échelle
+QUICKPLOT_DPI = Impression PPP
+QUICKPLOT_GENERATE = Générer
+QUICKPLOT_ADVANCED_OPTIONS = Options avancées
+QUICKPLOT_PRINT = Imprimer
+QUICKPLOT_CANCEL = Annuler
+QUICKPLOT_PREVIEW_ERROR = Les ressources d'application nécessaires pour générer le tracé dépassent les paramètres définis par l'administrateur
+QUICKPLOT_RESOLUTION_WARNING = Les paramètres actuels dépassent la résolution de la carte. Zoom arrière ou augmenter l'échelle aidera à créer un tracé plus lisible
+QUICKPLOT_SCALE_LABEL = Échelle
+ERRORSTACKTRACE = Trace de la pile
+# Unsupported tile set
+ERR_UNSUPPORTED_TILESET = Fournisseur d'ensembles de vignettes non pris en charge : {0}
\ No newline at end of file
More information about the mapguide-commits
