[mapguide-commits] r10061 - in branches/4.0/MgDev: . BuildTools Doc Doc/dotnet_api Doc/dotnet_api/docs
svn_mapguide at osgeo.org
Fri Nov 10 08:16:28 PST 2023
Author: jng
Date: 2023-11-10 08:16:27 -0800 (Fri, 10 Nov 2023)
New Revision: 10061
Added:
branches/4.0/MgDev/Doc/dotnet_api/
branches/4.0/MgDev/Doc/dotnet_api/docfx.json
branches/4.0/MgDev/Doc/dotnet_api/docs/
branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md
branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md
branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml
branches/4.0/MgDev/Doc/dotnet_api/index.md
branches/4.0/MgDev/Doc/dotnet_api/toc.yml
branches/4.0/MgDev/acquire-doctools.ps1
Removed:
branches/4.0/MgDev/Doc/MgDesktop_Doxyfile
branches/4.0/MgDev/Doc/MgDesktop_run_doxygen.bat
branches/4.0/MgDev/Doc/MgOpenSource_Doxyfile
branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.bat
branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.sh
branches/4.0/MgDev/BuildTools/
branches/4.0/MgDev/build.bat
branches/4.0/MgDev/setenvironment64.bat
#2877:
- Add new top-level acquire-doctools.ps1 powershell script that ensures docfx is installed and doctum.phar is downloaded
- Remove top-level doxygen build files and remove doxygen references from our top-level scripts
- Add initial docfx project
Index: branches/4.0/MgDev/BuildTools
--- branches/4.0/MgDev/BuildTools 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/BuildTools 2023-11-10 16:16:27 UTC (rev 10061)
Property changes on: branches/4.0/MgDev/BuildTools
___________________________________________________________________
Added: svn:ignore
## -0,0 +1 ##
+doctum.phar
Deleted: branches/4.0/MgDev/Doc/MgDesktop_Doxyfile
--- branches/4.0/MgDev/Doc/MgDesktop_Doxyfile 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/Doc/MgDesktop_Doxyfile 2023-11-10 16:16:27 UTC (rev 10061)
@@ -1,360 +0,0 @@
-# Doxyfile 1.8.0
-# Project related configuration options
-DOXYFILE_ENCODING = UTF-8
-PROJECT_NAME = "mg-desktop" "API" "Reference"
-PROJECT_NUMBER =
-PROJECT_BRIEF =
-PROJECT_LOGO =
-OUTPUT_DIRECTORY =
-CREATE_SUBDIRS = YES
-OUTPUT_LANGUAGE = English
-BRIEF_MEMBER_DESC = YES
-REPEAT_BRIEF = YES
-ABBREVIATE_BRIEF =
-ALWAYS_DETAILED_SEC = NO
-INLINE_INHERITED_MEMB = NO
-FULL_PATH_NAMES = NO
-STRIP_FROM_PATH =
-STRIP_FROM_INC_PATH =
-SHORT_NAMES = NO
-JAVADOC_AUTOBRIEF = NO
-QT_AUTOBRIEF = NO
-MULTILINE_CPP_IS_BRIEF = NO
-INHERIT_DOCS = YES
-SEPARATE_MEMBER_PAGES = YES
-TAB_SIZE = 4
-ALIASES = ProdName="mg-desktop"
-ALIASES += DevGuide="<em>MapGuide Open Source Developer's Guide</em>"
-ALIASES += note1=""
-ALIASES += note2=""
-TCL_SUBST =
-OPTIMIZE_OUTPUT_FOR_C = NO
-OPTIMIZE_OUTPUT_JAVA = NO
-OPTIMIZE_FOR_FORTRAN = NO
-OPTIMIZE_OUTPUT_VHDL = NO
-EXTENSION_MAPPING =
-MARKDOWN_SUPPORT = YES
-BUILTIN_STL_SUPPORT = NO
-CPP_CLI_SUPPORT = NO
-SIP_SUPPORT = NO
-IDL_PROPERTY_SUPPORT = NO
-DISTRIBUTE_GROUP_DOC = NO
-SUBGROUPING = YES
-INLINE_GROUPED_CLASSES = NO
-INLINE_SIMPLE_STRUCTS = NO
-TYPEDEF_HIDES_STRUCT = NO
-SYMBOL_CACHE_SIZE = 0
-LOOKUP_CACHE_SIZE = 0
-# Build related configuration options
-EXTRACT_ALL = YES
-EXTRACT_PRIVATE = NO
-EXTRACT_PACKAGE = NO
-EXTRACT_STATIC = YES
-EXTRACT_LOCAL_CLASSES = YES
-EXTRACT_LOCAL_METHODS = NO
-EXTRACT_ANON_NSPACES = NO
-HIDE_UNDOC_MEMBERS = NO
-HIDE_UNDOC_CLASSES = NO
-HIDE_FRIEND_COMPOUNDS = NO
-HIDE_IN_BODY_DOCS = NO
-INTERNAL_DOCS = NO
-CASE_SENSE_NAMES = NO
-HIDE_SCOPE_NAMES = NO
-SHOW_INCLUDE_FILES = NO
-FORCE_LOCAL_INCLUDES = NO
-INLINE_INFO = YES
-SORT_MEMBER_DOCS = YES
-SORT_BRIEF_DOCS = YES
-SORT_MEMBERS_CTORS_1ST = NO
-SORT_GROUP_NAMES = NO
-SORT_BY_SCOPE_NAME = NO
-STRICT_PROTO_MATCHING = NO
-GENERATE_TODOLIST = NO
-GENERATE_TESTLIST = NO
-GENERATE_BUGLIST = NO
-GENERATE_DEPRECATEDLIST= YES
-ENABLED_SECTIONS = DESKTOPAPI
-MAX_INITIALIZER_LINES = 30
-SHOW_USED_FILES = NO
-SHOW_DIRECTORIES = NO
-SHOW_FILES = NO
-SHOW_NAMESPACES = NO
-FILE_VERSION_FILTER =
-LAYOUT_FILE =
-CITE_BIB_FILES =
-# configuration options related to warning and progress messages
-QUIET = NO
-WARNINGS = YES
-WARN_IF_UNDOCUMENTED = YES
-WARN_IF_DOC_ERROR = YES
-WARN_NO_PARAMDOC = YES
-WARN_FORMAT = "$file:$line: $text"
-WARN_LOGFILE = MgDesktop_warn_log.txt
-# configuration options related to the input files
-INPUT = external_topics \
- group_and_page_definitions \
- ../Common/Foundation \
- ../Common/Geometry \
- ../Common/PlatformBase \
- ../Desktop/MgDesktop
-INPUT_ENCODING = UTF-8
-FILE_PATTERNS = *.h
-RECURSIVE = YES
-EXCLUDE =
-EXCLUDE_SYMLINKS = NO
-EXCLUDE_PATTERNS = */Buffer/BorderWalker.h \
- */Buffer/buffer.h \
- */Buffer/bufraloc.h \
- */Buffer/bufrsort.h \
- */Buffer/bufrutil.h \
- */Buffer/DumpFFGF.h \
- */Buffer/eventarr.h \
- */Buffer/eventint.h \
- */Buffer/FloatTransform.h \
- */Buffer/GreatCircleBufferUtil.h \
- */Buffer/interlst.h \
- */Buffer/interprc.h \
- */Buffer/LatLonBorderWalker.h \
- */Buffer/oarray.h \
- */Buffer/oextent.h \
- */Buffer/ogeomtry.h \
- */Buffer/olinep.h \
- */Buffer/oobject.h \
- */Buffer/opline.h \
- */Buffer/opoint.h \
- */Buffer/opolygnp.h \
- */Buffer/opolygon.h \
- */Buffer/oppolygn.h \
- */Buffer/oppolyln.h \
- */Buffer/opsprimitive.h \
- */Buffer/orpplygn.h \
- */Buffer/ortree.h \
- */Buffer/planeswp.h \
- */Buffer/plgnbufr.h \
- */Buffer/plinbufr.h \
- */Buffer/pobjbufr.h \
- */Buffer/ppgunion.h \
- */Buffer/progcbck.h \
- */Buffer/sedgaloc.h \
- */Buffer/sweepedg.h \
- */Buffer/tuplearr.h \
- */Buffer/vertaloc.h \
- */Buffer/wedgaloc.h \
- */Buffer/wedgearr.h \
- */Buffer/wingedge.h \
- */Buffer/worklist.h \
- */Buffer/xordtree.h \
- */Geometry/Parse/LexAwkt.h \
- */Geometry/Parse/yyAwkt.h \
- */Geometry/Parse/Array.h \
- */Geometry/Parse/ParseAwkt.h \
- */Geometry/GeometryConsoleTest/* \
- */Geometry/Spatial/* \
- */MapLayer/Watermark.h \
- */System/CommonDefs.h \
- */System/Ptr.h \
- */System/FileUtil.h \
- */System/Util.h \
- */System/CryptographyManager.h \
- */PrintLayoutService/* \
- */Data/Point3D.h \
- */Data/Size2D.h \
- */Data/Vector3D.h \
- */Data/Margin.h \
- */Data/SerializableCollection.h \
- */.svn
-EXCLUDE_SYMBOLS =
-EXAMPLE_PATH = headers_and_footers
-EXAMPLE_PATTERNS = *
-EXAMPLE_RECURSIVE = YES
-IMAGE_PATH = other_graphics
-INPUT_FILTER =
-FILTER_PATTERNS =
-FILTER_SOURCE_FILES = NO
-FILTER_SOURCE_PATTERNS =
-# configuration options related to source browsing
-SOURCE_BROWSER = NO
-INLINE_SOURCES = NO
-STRIP_CODE_COMMENTS = NO
-REFERENCED_BY_RELATION = YES
-REFERENCES_RELATION = YES
-REFERENCES_LINK_SOURCE = YES
-USE_HTAGS = NO
-VERBATIM_HEADERS = NO
-# configuration options related to the alphabetical class index
-ALPHABETICAL_INDEX = YES
-COLS_IN_ALPHA_INDEX = 5
-IGNORE_PREFIX =
-# configuration options related to the HTML output
-GENERATE_HTML = YES
-HTML_OUTPUT = MgDesktop_WebAPIReference
-HTML_FILE_EXTENSION = .htm
-HTML_HEADER = headers_and_footers/header.html
-HTML_FOOTER = headers_and_footers/footer.html
-HTML_STYLESHEET = css/mg_open_source.css
-#HTML_HEADER =
-#HTML_FOOTER =
-#HTML_STYLESHEET =
-HTML_EXTRA_FILES =
-HTML_COLORSTYLE_HUE = 220
-HTML_COLORSTYLE_SAT = 100
-HTML_COLORSTYLE_GAMMA = 80
-HTML_TIMESTAMP = YES
-HTML_ALIGN_MEMBERS = YES
-HTML_DYNAMIC_SECTIONS = YES
-GENERATE_DOCSET = NO
-GENERATE_HTMLHELP = NO
-CHM_FILE =
-HHC_LOCATION =
-GENERATE_CHI = NO
-CHM_INDEX_ENCODING =
-BINARY_TOC = NO
-TOC_EXPAND = NO
-GENERATE_QHP = NO
-QCH_FILE =
-QHP_NAMESPACE = org.doxygen.Project
-QHP_VIRTUAL_FOLDER = doc
-QHP_CUST_FILTER_NAME =
-QHP_CUST_FILTER_ATTRS =
-QHP_SECT_FILTER_ATTRS =
-QHG_LOCATION =
-GENERATE_ECLIPSEHELP = NO
-ECLIPSE_DOC_ID = org.doxygen.Project
-DISABLE_INDEX = NO
-GENERATE_TREEVIEW = YES
-ENUM_VALUES_PER_LINE = 4
-USE_INLINE_TREES = NO
-TREEVIEW_WIDTH = 250
-EXT_LINKS_IN_WINDOW = NO
-FORMULA_FONTSIZE = 10
-FORMULA_TRANSPARENT = YES
-USE_MATHJAX = NO
-MATHJAX_RELPATH = http://cdn.mathjax.org/mathjax/latest
-MATHJAX_EXTENSIONS =
-SEARCHENGINE = YES
-SERVER_BASED_SEARCH = NO
-# configuration options related to the LaTeX output
-GENERATE_LATEX = NO
-LATEX_OUTPUT = latex
-LATEX_CMD_NAME = latex
-MAKEINDEX_CMD_NAME = makeindex
-COMPACT_LATEX = NO
-PAPER_TYPE = a4
-EXTRA_PACKAGES =
-LATEX_HEADER =
-LATEX_FOOTER =
-PDF_HYPERLINKS = YES
-USE_PDFLATEX = YES
-LATEX_BATCHMODE = NO
-LATEX_HIDE_INDICES = NO
-LATEX_SOURCE_CODE = NO
-LATEX_BIB_STYLE = plain
-# configuration options related to the RTF output
-GENERATE_RTF = NO
-RTF_OUTPUT = rtf
-COMPACT_RTF = NO
-RTF_HYPERLINKS = NO
-RTF_STYLESHEET_FILE =
-RTF_EXTENSIONS_FILE =
-# configuration options related to the man page output
-GENERATE_MAN = NO
-MAN_OUTPUT = man
-MAN_EXTENSION = .3
-MAN_LINKS = NO
-# configuration options related to the XML output
-GENERATE_XML = YES
-XML_OUTPUT = mgdesktop_xml
-XML_SCHEMA =
-XML_DTD =
-XML_PROGRAMLISTING = YES
-# configuration options for the AutoGen Definitions output
-GENERATE_AUTOGEN_DEF = NO
-# configuration options related to the Perl module output
-GENERATE_PERLMOD = NO
-PERLMOD_LATEX = NO
-PERLMOD_PRETTY = YES
-PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
-ENABLE_PREPROCESSING = YES
-MACRO_EXPANSION = YES
-EXPAND_ONLY_PREDEF = NO
-SEARCH_INCLUDES = YES
-INCLUDE_PATH =
-INCLUDE_FILE_PATTERNS =
-PREDEFINED = INTERNAL_API=private \
- EXTERNAL_API=private \
- PUBLISHED_API=public \
- protected=private
-EXPAND_AS_DEFINED =
-SKIP_FUNCTION_MACROS = YES
-# Configuration::additions related to external references
-TAGFILES =
-GENERATE_TAGFILE =
-ALLEXTERNALS = NO
-EXTERNAL_GROUPS = NO
-PERL_PATH = /usr/bin/perl
-# Configuration options related to the dot tool
-CLASS_DIAGRAMS = NO
-MSCGEN_PATH =
-HIDE_UNDOC_RELATIONS = YES
-HAVE_DOT = YES
-DOT_NUM_THREADS = 0
-DOT_FONTNAME = Helvetica
-DOT_FONTSIZE = 10
-DOT_FONTPATH =
-CLASS_GRAPH = YES
-COLLABORATION_GRAPH = NO
-GROUP_GRAPHS = NO
-UML_LOOK = NO
-UML_LIMIT_NUM_FIELDS = 10
-TEMPLATE_RELATIONS = NO
-INCLUDE_GRAPH = YES
-INCLUDED_BY_GRAPH = YES
-CALL_GRAPH = NO
-CALLER_GRAPH = NO
-GRAPHICAL_HIERARCHY = YES
-DIRECTORY_GRAPH = YES
-DOT_IMAGE_FORMAT = png
-INTERACTIVE_SVG = NO
-DOT_PATH =
-DOTFILE_DIRS =
-MSCFILE_DIRS =
-DOT_GRAPH_MAX_NODES = 50
-MAX_DOT_GRAPH_DEPTH = 1000
-DOT_TRANSPARENT = NO
-DOT_MULTI_TARGETS = NO
-GENERATE_LEGEND = YES
-DOT_CLEANUP = YES
Deleted: branches/4.0/MgDev/Doc/MgDesktop_run_doxygen.bat
--- branches/4.0/MgDev/Doc/MgDesktop_run_doxygen.bat 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/Doc/MgDesktop_run_doxygen.bat 2023-11-10 16:16:27 UTC (rev 10061)
@@ -1,32 +0,0 @@
- at echo off
-:: Copy the doxygen.css file
-echo Copying doxygen.css ...
-if not exist MgDesktop_WebAPIReference\ mkdir MgDesktop_WebAPIReference\
-copy css\doxygen.css MgDesktop_WebAPIReference
-:: Copy the XML schemas
-if not exist MgDesktop_WebAPIReference\xml_schemas mkdir MgDesktop_WebAPIReference\xml_schemas\
-xcopy /s /y "xml_schemas\*" MgDesktop_WebAPIReference\xml_schemas\
-:: Run Doxygen
-echo Running Doxygen ...
-doxygen MgDesktop_Doxyfile > MgDesktop_run_log.txt
-echo Doxygen generation is complete. The error log is in 'MgDesktop_warn_log.txt'.
-;: Post Process
-echo Running the post processor ...
-perl -w PostProcessor/post_process.MgDesktop.pl
-echo All done.
Deleted: branches/4.0/MgDev/Doc/MgOpenSource_Doxyfile
--- branches/4.0/MgDev/Doc/MgOpenSource_Doxyfile 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/Doc/MgOpenSource_Doxyfile 2023-11-10 16:16:27 UTC (rev 10061)
@@ -1,362 +0,0 @@
-# Doxyfile 1.8.0
-PROJECT_NAME = "MapGuide" "API" "Reference"
-PROJECT_NUMBER =
-PROJECT_BRIEF =
-PROJECT_LOGO =
-OUTPUT_DIRECTORY =
-REPEAT_BRIEF = YES
-ABBREVIATE_BRIEF =
-STRIP_FROM_PATH =
-SHORT_NAMES = NO
-QT_AUTOBRIEF = NO
-INHERIT_DOCS = YES
-TAB_SIZE = 4
-ALIASES = ProdName="MapGuide Open Source"
-TCL_SUBST =
-SIP_SUPPORT = NO
-SUBGROUPING = YES
-EXTRACT_ALL = YES
-INTERNAL_DOCS = NO
-INLINE_INFO = YES
-#This is to toggle MapGuide API-specific content
-ENABLED_SECTIONS = MAPGUIDEAPI
-SHOW_FILES = NO
-LAYOUT_FILE =
-CITE_BIB_FILES =
-QUIET = NO
-WARNINGS = YES
-WARN_LOGFILE = MgOpensource_warn_log.txt
- ../Common/MapGuideCommon \
- ../Web/src/WebApp
-RECURSIVE = YES
-EXCLUDE =
- */System/Ptr.h \
- */System/Util.h \
- */Data/Size2D.h \
- */Data/Margin.h \
- */.svn
-EXCLUDE_SYMBOLS =
-INPUT_FILTER =
-FILTER_PATTERNS =
-USE_HTAGS = NO
-IGNORE_PREFIX =
-HTML_OUTPUT = MgOpensource_WebAPIReference
-#HTML_HEADER =
-#HTML_FOOTER =
-#HTML_STYLESHEET =
-HTML_EXTRA_FILES =
-CHM_FILE =
-HHC_LOCATION =
-GENERATE_CHI = NO
-BINARY_TOC = NO
-TOC_EXPAND = NO
-GENERATE_QHP = NO
-QCH_FILE =
-QHG_LOCATION =
-DISABLE_INDEX = NO
-USE_MATHJAX = NO
-SEARCHENGINE = YES
-COMPACT_LATEX = NO
-PAPER_TYPE = a4
-EXTRA_PACKAGES =
-LATEX_HEADER =
-LATEX_FOOTER =
-USE_PDFLATEX = YES
-GENERATE_RTF = NO
-RTF_OUTPUT = rtf
-COMPACT_RTF = NO
-GENERATE_MAN = NO
-MAN_OUTPUT = man
-MAN_EXTENSION = .3
-MAN_LINKS = NO
-GENERATE_XML = NO
-XML_OUTPUT = xml
-XML_SCHEMA =
-XML_DTD =
-PERLMOD_LATEX = NO
-INCLUDE_PATH =
- protected=private
-TAGFILES =
-GENERATE_TAGFILE =
-ALLEXTERNALS = NO
-EXTERNAL_GROUPS = YES
-MSCGEN_PATH =
-HAVE_DOT = YES
-DOT_FONTSIZE = 10
-DOT_FONTPATH =
-CLASS_GRAPH = YES
-GROUP_GRAPHS = NO
-UML_LOOK = NO
-CALL_GRAPH = NO
-CALLER_GRAPH = NO
-DOT_PATH =
-DOTFILE_DIRS =
-MSCFILE_DIRS =
-DOT_CLEANUP = YES
Deleted: branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.bat
--- branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.bat 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.bat 2023-11-10 16:16:27 UTC (rev 10061)
@@ -1,32 +0,0 @@
- at echo off
-if not exist MgOpensource_WebAPIReference\ mkdir MgOpensource_WebAPIReference\
-copy css\doxygen.css MgOpensource_WebAPIReference
-if not exist MgOpensource_WebAPIReference\xml_schemas mkdir MgOpensource_WebAPIReference\xml_schemas\
-xcopy /s /y "xml_schemas\*" MgOpensource_WebAPIReference\xml_schemas\
-:: Run Doxygen
-doxygen MgOpenSource_Doxyfile > MGOpenSource_run_log.txt
-echo Doxygen generation is complete. The error log is in 'MgOpenSource_warn_log.txt'.
-;: Post Process
-perl -w PostProcessor/post_process.MgOpenSource.pl
-echo All done.
Deleted: branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.sh
--- branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.sh 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/Doc/MgOpenSource_run_doxygen.sh 2023-11-10 16:16:27 UTC (rev 10061)
@@ -1,40 +0,0 @@
-## Delete the old files
-echo Deleting old files ...
-rm --recursive --verbose --force MgOpensource_WebAPIReference/*.*
-## Copy the CSS file
-if [ ! -d MgOpensource_WebAPIReference/ ]; then
- mkdir MgOpensource_WebAPIReference
-fi
-cp -f css/doxygen.css MgOpensource_WebAPIReference/
-## Copy the XML schemas
-echo Copying XML schemas ...
-if [ ! -d MgOpensource_WebAPIReference/xml_schemas ]; then
- mkdir MgOpensource_WebAPIReference/xml_schemas
-fi
-cp --recursive xml_schemas/* MgOpensource_WebAPIReference/xml_schemas/
-## Run Doxygen
-doxygen MgOpenSource_Doxyfile_Linux
-echo Doxygen generation is complete. See 'MgOpenSource_warn_log.txt'.
-## Run the Perl post processor
-echo All done.
\ No newline at end of file
Index: branches/4.0/MgDev/Doc/dotnet_api
--- branches/4.0/MgDev/Doc/dotnet_api 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/Doc/dotnet_api 2023-11-10 16:16:27 UTC (rev 10061)
Property changes on: branches/4.0/MgDev/Doc/dotnet_api
Added: svn:ignore
## -0,0 +1,2 ##
+_site
+api
Added: branches/4.0/MgDev/Doc/dotnet_api/docfx.json
--- branches/4.0/MgDev/Doc/dotnet_api/docfx.json (rev 0)
+++ branches/4.0/MgDev/Doc/dotnet_api/docfx.json 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1,45 @@
+ "metadata": [
+ "src": [
+ "src": "../../Bindings/src/Managed/DotNet",
+ "files": [
+ "OSGeo.MapGuide.*/**.csproj"
+ "dest": "api"
+ "build": {
+ "content": [
+ "files": [
+ "**/*.{md,yml}"
+ "exclude": [
+ "_site/**"
+ "resources": [
+ "files": [
+ "images/**"
+ "output": "_site",
+ "template": [
+ "default",
+ "modern"
+ "globalMetadata": {
+ "_appName": "MapGuide .net API reference",
+ "_appTitle": "MapGuide .net API reference",
+ "_enableSearch": true,
+ "pdf": false
Added: branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md
--- branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md (rev 0)
+++ branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1 @@
+# Getting Started
Added: branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md
--- branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md (rev 0)
+++ branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1 @@
+# Introduction
Added: branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml
--- branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml (rev 0)
+++ branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1,4 @@
+- name: Introduction
+ href: introduction.md
+- name: Getting Started
+ href: getting-started.md
Added: branches/4.0/MgDev/Doc/dotnet_api/index.md
--- branches/4.0/MgDev/Doc/dotnet_api/index.md (rev 0)
+++ branches/4.0/MgDev/Doc/dotnet_api/index.md 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1,11 @@
+_layout: landing
+# This is the **HOMEPAGE**.
+Refer to [Markdown](http://daringfireball.net/projects/markdown/) for how to write markdown files.
+## Quick Start Notes:
+1. Add images to the *images* folder if the file is referencing an image.
Added: branches/4.0/MgDev/Doc/dotnet_api/toc.yml
--- branches/4.0/MgDev/Doc/dotnet_api/toc.yml (rev 0)
+++ branches/4.0/MgDev/Doc/dotnet_api/toc.yml 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1,4 @@
+- name: Docs
+ href: docs/
+- name: API
+ href: api/
Added: branches/4.0/MgDev/acquire-doctools.ps1
--- branches/4.0/MgDev/acquire-doctools.ps1 (rev 0)
+++ branches/4.0/MgDev/acquire-doctools.ps1 2023-11-10 16:16:27 UTC (rev 10061)
@@ -0,0 +1,9 @@
+Write-Host "Ensuring docfx is installed"
+dotnet tool update -g docfx
+Write-Host "Ensuring doctum is installed"
+if (Test-Path ./BuildTools/doctum.phar) {
+ Write-Host "doctum.phar is installed in the expected path"
+} else {
+ Write-Host "doctum.phar not found. Downloading it"
+ Invoke-WebRequest https://doctum.long-term.support/releases/latest/doctum.phar -OutFile ./BuildTools/doctum.phar
Modified: branches/4.0/MgDev/build.bat
--- branches/4.0/MgDev/build.bat 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/build.bat 2023-11-10 16:16:27 UTC (rev 10061)
@@ -19,9 +19,11 @@
rem 2) Download and install the following:
rem - Java SDK (http://java.sun.com)
rem - ant (http://ant.apache.org)
-rem - doxygen (http://www.doxygen.org)
rem
-rem 3) Call setenvironment.bat or setenvironment64.bat depending on whether you're building 32-bit or 64-bit MapGuide. Adjust any paths in those two files as appropriate so that it points to your specific JDK, ANT and Doxygen directories
+rem 3) Call acquire-doctools.ps1 to ensure the language-specifc API doc generation tools are installed/downloaded
+rem NOTE: You may have to change execution policy in order to run powershell scripts
+rem
+rem 4) Call setenvironment.bat or setenvironment64.bat depending on whether you're building 32-bit or 64-bit MapGuide. Adjust any paths in those two files as appropriate so that it points to your specific JDK and ANT directories
rem
rem For a "cleaner" build experience, run this script from an exported copy of the
rem MapGuide source code (ie. without subversion folders).
@@ -256,8 +258,8 @@
:build_doc
echo [build]: Building Doc
-pushd %MG_DOC%
-call MgOpenSource_run_doxygen.bat
+pushd %CD%\Bindings
+call build_doc.bat
popd
echo [build]: MapGuide Developer's Guide
pushd %MG_DOC%\devguide
Modified: branches/4.0/MgDev/setenvironment64.bat
--- branches/4.0/MgDev/setenvironment64.bat 2023-11-10 15:08:48 UTC (rev 10060)
+++ branches/4.0/MgDev/setenvironment64.bat 2023-11-10 16:16:27 UTC (rev 10061)
@@ -89,13 +89,12 @@
rem ==================================================
IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.7.0_80
-IF "%DOXYGEN%" == "" SET DOXYGEN=C:\Program Files\doxygen\bin
IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
IF "%ANT_HOME%" == "" SET ANT_HOME=C:\apache-ant
IF "%SWIG_DIR%" == "" SET SWIG_DIR=C:\swigwin-4.1.1
-SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
+SET PATH=%PATH%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
rem PHP/httpd env vars for Visual Studio
More information about the mapguide-commits
