[mapguide-commits] r10062 - in branches/4.0/MgDev/Doc: . dotnet_api dotnet_api/docs java_api landing
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Nov 10 10:20:56 PST 2023
Author: jng
Date: 2023-11-10 10:20:55 -0800 (Fri, 10 Nov 2023)
New Revision: 10062
Added:
   branches/4.0/MgDev/Doc/build.bat
   branches/4.0/MgDev/Doc/java_api/
   branches/4.0/MgDev/Doc/java_api/overview.html
   branches/4.0/MgDev/Doc/landing/
   branches/4.0/MgDev/Doc/landing/TODO.md
   branches/4.0/MgDev/Doc/landing/bib-dana99.md
   branches/4.0/MgDev/Doc/landing/bib-egenhofer91.md
   branches/4.0/MgDev/Doc/landing/bib-jts14.md
   branches/4.0/MgDev/Doc/landing/bib-ogc96-015r1.md
   branches/4.0/MgDev/Doc/landing/bib-ogc99-049.md
   branches/4.0/MgDev/Doc/landing/bib-osugr.md
   branches/4.0/MgDev/Doc/landing/bib-peat.md
   branches/4.0/MgDev/Doc/landing/collections.md
   branches/4.0/MgDev/Doc/landing/cs-testvalues.md
   branches/4.0/MgDev/Doc/landing/cs-wkttosrs.md
   branches/4.0/MgDev/Doc/landing/docfx.json
   branches/4.0/MgDev/Doc/landing/feature-properties.md
   branches/4.0/MgDev/Doc/landing/geom-collections.md
   branches/4.0/MgDev/Doc/landing/index.md
   branches/4.0/MgDev/Doc/landing/toc.yml
Removed:
   branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md
   branches/4.0/MgDev/Doc/dotnet_api/docfx.json
   branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md
   branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml
   branches/4.0/MgDev/Doc/dotnet_api/index.md
#2877:
 - Add landing site (also docfx based)
   - Start migrating some conceptual topics from doxygen to markdown
   - Link these migrated topics
 - Add overview page for javadoc
 - Add end-to-end build.bat
Added: branches/4.0/MgDev/Doc/build.bat
--- branches/4.0/MgDev/Doc/build.bat	                        (rev 0)
+++ branches/4.0/MgDev/Doc/build.bat	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,17 @@
+ at echo off
+REM TODO: Move to setenviroment64.bat once this is fully fleshed out
+SET LABEL=4.0 RC1
+pushd dotnet_api
+docfx build --metadata _appTitle="MapGuide .net API reference (%LABEL%)"
+popd
+pushd ..\Bindings\src\Managed\Java
+REM NOTE: javadoc may report errors, but that is okay as they are not "derail this build script"-tier errors and the docs
+REM for the affected classes will still be generated, these errors are mostly about malformed tags that are a by-product
+REM of being transferred from the C++ doxygen fragments
+REM TODO: These errors will go away by fixing the comments in question at the C++ source
+javadoc -d ..\..\..\..\Doc\landing\_site\java_api org.osgeo.mapguide -overview ..\..\..\..\Doc\java_api\overview.html -windowtitle "MapGuide Java API reference (%LABEL%)"
+popd
+pushd landing
+docfx build
+popd
+REM todo doctum once we've got IMake to generate doc'd proxy stub classes
\ No newline at end of file
Modified: branches/4.0/MgDev/Doc/dotnet_api/docfx.json
--- branches/4.0/MgDev/Doc/dotnet_api/docfx.json	2023-11-10 16:16:27 UTC (rev 10061)
+++ branches/4.0/MgDev/Doc/dotnet_api/docfx.json	2023-11-10 18:20:55 UTC (rev 10062)
@@ -30,7 +30,7 @@
-    "output": "_site",
+    "output": "../landing/_site/dotnet_api",
     "template": [
       "default",
       "modern"
Modified: branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md
--- branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md	2023-11-10 16:16:27 UTC (rev 10061)
+++ branches/4.0/MgDev/Doc/dotnet_api/docs/getting-started.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -1 +1,19 @@
-# Getting Started
+# Getting Started
+To get started, your application needs to reference the MapGuide API for .net assemblies. You can do this in one of 2 ways below.
+## NuGet Packages (recommended)
+The MapGuide API for .net is available as packages from nuget.org. New versions of these packages are published with each release of MapGuide.
+Simply install the following packges:
+ * `OSGeo.MapGuide.Foundation`
+ * `OSGeo.MapGuide.Geometry`
+ * `OSGeo.MapGuide.PlatformBase`
+ * `OSGeo.MapGuide.MapGuideCommon`
+ * `OSGeo.MapGuide.Web`
+## Local Packages
+Local copies of these nuget packages are also included with a normal MapGuide web tier installation, to use these local nuget packages, either copy/upload these `.nupkg` files to your local nuget registry or set up a package source in your `nuget.config` that points to the directory containing these files
Deleted: branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md
--- branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md	2023-11-10 16:16:27 UTC (rev 10061)
+++ branches/4.0/MgDev/Doc/dotnet_api/docs/introduction.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -1 +0,0 @@
-# Introduction
Modified: branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml
--- branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml	2023-11-10 16:16:27 UTC (rev 10061)
+++ branches/4.0/MgDev/Doc/dotnet_api/docs/toc.yml	2023-11-10 18:20:55 UTC (rev 10062)
@@ -1,4 +1,2 @@
-- name: Introduction
-  href: introduction.md
 - name: Getting Started
   href: getting-started.md
Modified: branches/4.0/MgDev/Doc/dotnet_api/index.md
--- branches/4.0/MgDev/Doc/dotnet_api/index.md	2023-11-10 16:16:27 UTC (rev 10061)
+++ branches/4.0/MgDev/Doc/dotnet_api/index.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -2,10 +2,6 @@
 _layout: landing
-# This is the **HOMEPAGE**.
+# Introduction
-Refer to [Markdown](http://daringfireball.net/projects/markdown/) for how to write markdown files.
-## Quick Start Notes:
-1. Add images to the *images* folder if the file is referencing an image.
+This is the home of the reference document for the MapGuide API for .net
Added: branches/4.0/MgDev/Doc/java_api/overview.html
--- branches/4.0/MgDev/Doc/java_api/overview.html	                        (rev 0)
+++ branches/4.0/MgDev/Doc/java_api/overview.html	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,7 @@
+<html>
+    <body>
+        <p>This is the Java reference for the MapGuide API</p>
+        <h2>Using this API</h2>
+        <p>To use the Java bindings for the MapGuide API, the <strong>MapGuideApi.jar</strong> must be in your application's classpath</p>
+    </body>
+</html>
Index: branches/4.0/MgDev/Doc/landing
--- branches/4.0/MgDev/Doc/landing	2023-11-10 16:16:27 UTC (rev 10061)
+++ branches/4.0/MgDev/Doc/landing	2023-11-10 18:20:55 UTC (rev 10062)
Property changes on: branches/4.0/MgDev/Doc/landing
___________________________________________________________________
Added: svn:ignore
## -0,0 +1 ##
+_site
Added: branches/4.0/MgDev/Doc/landing/TODO.md
--- branches/4.0/MgDev/Doc/landing/TODO.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/TODO.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,3 @@
+# TODO
+Oops! If you got here it means we haven't updated the original link
Added: branches/4.0/MgDev/Doc/landing/bib-dana99.md
--- branches/4.0/MgDev/Doc/landing/bib-dana99.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-dana99.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,5 @@
+# Dana99
+Dana, P. H., <i>The Geographer's Craft Project</i>, Department of
+Geography, The University of Colorado at Boulder, c1999,
+http://www.colorado.edu/geography/gcraft/notes/datum/datum_f.html
Added: branches/4.0/MgDev/Doc/landing/bib-egenhofer91.md
--- branches/4.0/MgDev/Doc/landing/bib-egenhofer91.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-egenhofer91.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,5 @@
+# Egenhofer91
+Egenhofer, M.F. and Franzosa, R.D., Point Set Topological
+Spatial Relations, <i>International Journal of Geographical
+Information Systems</i>, vol 5, no 2, 161-174, 1991.
Added: branches/4.0/MgDev/Doc/landing/bib-jts14.md
--- branches/4.0/MgDev/Doc/landing/bib-jts14.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-jts14.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,9 @@
+# JTS14
+Vivid Solutions, "JTS Topology Suite Technical Specifications", Version 1.4, 2003. Version 1.4 of this specification at
+http://www.geotools.org/Working+with+JTS+Geometries+from+DataStores
+The latest version of this specification is at
+http://www.vividsolutions.com/JTS/JTSHome.htm
Added: branches/4.0/MgDev/Doc/landing/bib-ogc96-015r1.md
--- branches/4.0/MgDev/Doc/landing/bib-ogc96-015r1.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-ogc96-015r1.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,44 @@
+# OGC96015R1
+<p>
+OpenGIS Consortium Inc., "The OpenGIS Abstract
+Specification: An Object Model For Interoperable
+Geoprocessing," Revision 1, OpenGIS Project Document Number
+96-015R1, 1966.
+</p>
+### Document Notice
+<p>Public documents on the OGC site are provided by the copyright holders under the following license.
+The software or Document Type Definitions (DTDs) associated with OGC specifications are governed
+by the Software Notice. By using and/or copying this document, or the OGC
+document from which this statement is linked, you (the licensee) agree that you have read, understood,
+and will comply with the following terms and conditions:</p>
+<p>Permission to use, copy, and distribute the contents of this document, or the OGC document from which
+this statement is linked, in any medium for any purpose and without fee or royalty is hereby granted,
+provided that you include the following on <i>ALL</i> copies of the document, or portions thereof, that you use:</p>
+<ol>
+<li>Include a link or URL to the original OGC document.</li>
+<li>The pre-existing copyright notice of the original author, or if it doesn't exist, a notice
+of the form: "Copyright � <date-of-document> Open Geospatial Consortium, Inc. All Rights Reserved.
+http://www.opengeospatial.org/ogc/document (Hypertext is preferred, but a textual representation is permitted.)</li>
+<li><em>If it exists</em>, the STATUS of the OGC document.</li>
+</ol>
+<p>When space permits, inclusion of the full text of this <b>NOTICE</b>should be provided. We request
+that authorship attribution be provided in any software, documents, or other items or products that you
+create pursuant to the implementation of the contents of this document, or any portion thereof.</p>
+<p>No right to create modifications or derivatives of OGC documents is granted pursuant to this license.
+However, if additional requirements (documented in the Copyright FAQ) are
+satisfied, the right to create modifications  or derivatives is sometimes granted by the OGC to individuals
+complying with those requirements.</p>
+<p>THIS DOCUMENT IS PROVIDED "AS IS," AND COPYRIGHT HOLDERS MAKE NO REPRESENTATIONS OR WARRANTIES,
+EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
+PURPOSE, NON-INFRINGEMENT, OR TITLE; THAT THE CONTENTS OF THE DOCUMENT ARE SUITABLE FOR ANY PURPOSE; NOR
+THAT THE IMPLEMENTATION OF SUCH CONTENTS WILL NOT INFRINGE ANY THIRD PARTY PATENTS, COPYRIGHTS, TRADEMARKS OR OTHER RIGHTS</p>
+<p>COPYRIGHT HOLDERS WILL NOT BE LIABLE FOR ANY DIRECT, INDIRECT, SPECIAL OR CONSEQUENTIAL DAMAGES ARISING
+OUT OF ANY USE OF THE DOCUMENT OR THE PERFORMANCE OR IMPLEMENTATION OF THE CONTENTS THEREOF.</p>
+<p>The name and trademarks of copyright holders may NOT be used in advertising or publicity pertaining to
+this document or its contents without specific, written prior permission. Title to copyright in this document
+will at all times remain with copyright holders.
+</p>
Added: branches/4.0/MgDev/Doc/landing/bib-ogc99-049.md
--- branches/4.0/MgDev/Doc/landing/bib-ogc99-049.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-ogc99-049.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,45 @@
+# OGC99049
+<p>
+Open GIS Consortium Inc., "OpenGIS Simple
+Features Specification for SQL", Revision 1.1, OpenGIs
+Project Document 99-049, May 5, 1999. To obtain this
+document, go to http://www.opengeospatial.org/specs/. Click
+on "OpenGIS Specifications," and then click on "Simple
+Features - SQL."
+</p>
+<h3>Document Notice</h3>
+<ol>
+</ol>
+</p>
Added: branches/4.0/MgDev/Doc/landing/bib-osugr.md
--- branches/4.0/MgDev/Doc/landing/bib-osugr.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-osugr.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,6 @@
+# OSUGR
+<p>
+"Oracle Spatial User Guide and Reference", 10g -
+Release 1 (10.1), Part No. B10826-01, Dec 2003.
+</p>
Added: branches/4.0/MgDev/Doc/landing/bib-peat.md
--- branches/4.0/MgDev/Doc/landing/bib-peat.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/bib-peat.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,6 @@
+# Peat
+<p>
+Peat, Chris, Heavens Above website,
+http://www.heavens-above.com/gloss.asp?term=azimuth.
+</p>
Added: branches/4.0/MgDev/Doc/landing/collections.md
--- branches/4.0/MgDev/Doc/landing/collections.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/collections.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,18 @@
+# Collections
+<p>
+  One of the functions of collections is to serve as a repository for
+  intermediate results. In this role, a collection is a helper class. An
+  example is the construction of an MgLineString geometry. From the
+  perspective of construction, this geometry is a set of coordinates. The
+  sequence of construction is:
+</p>
+<ol>
+  <li>create a coordinate</li>
+  <li>add coordinate to coordinate collection</li>
+  <li>do 1 and 2 until all coordinates created</li>
+  <li>create the line string using coordinate collection</li>
+</ol>
+<p>
+	See [Geometry Collections](geom-collections.md) for the list of collections used in the construction of geometries.
+</p>
Added: branches/4.0/MgDev/Doc/landing/cs-testvalues.md
--- branches/4.0/MgDev/Doc/landing/cs-testvalues.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/cs-testvalues.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,263 @@
+# CSTestValues
+<p>
+  These values are used for testing the coordinate system API.
+</p>
+<h2>Geodetic Coordinate System </h2>
+<h3>Used in the PHP Sample Code</h3>
+<p>
+  The following well-known text represents a coordinate system
+  based on longitude and latitude whose name is "Longitude /
+  Latitude (NAD 83)". The horizontal datum used to measure
+  positions on the surface of the earth is named "NAD 83". The
+  earth's surface is modeled as a squashed sphere. The name of
+  the model is "GRS 80". The "GRS 80" model has a semi-major
+  axis value of 6378137 and an inverse flattening value of
+  298.257222101. The longitudinal measurement is taken from the
+  Greenwich prime meridian. The Greenwich prime meridian is at
+  an angle of 0.000000 degrees relative to the reference
+  (Greenwich) prime meridian. The unit of measurement is an
+  angular type whose name is "Decimal Degree", which can be
+  converted to radians by applying the scalar factor of
+  0.01745329251994330.
+</p>
+SQL\> select cs_name,srid, wktext from mdsys.cs_srs where srid = 8265;
+cs_name = Longitude / Latitude (NAD 83)
+ srid=8265
+wktext=
+GEOGCS [
+   "Longitude / Latitude (NAD 83)",
+   DATUM
+      "NAD 83",
+      SPHEROID [
+         "GRS 80",
+         6378137,
+         298.257222101
+   PRIMEM [
+      "Greenwich",
+      0.000000
+   UNIT [
+      "Decimal Degree",
+<h3>Used in the C# Sample Code</h3>
+<p>
+  based on longitude and latitude whose name is "LL83".
+  The horizontal datum used to measure
+  positions on the surface of the earth is named "NAD83". The
+</p>
+GEOGCS [
+   "LL83",
+   DATUM [
+      "NAD83",
+      SPHEROID [
+         "GRS1980",
+	 6378137.000,
+	 298.25722210
+   PRIMEM [
+      "Greenwich",
+      0
+   UNIT [
+      "Degree",
+      0.01745329251994
+<h2>Projected Coordinate System </h2>
+<p>
+  The following well-known text represents a projected
+  coordinate system whose name is "UTM Zone 18 (NAD 83)". It
+  uses a parameterized transform called "Transverse Mercator"
+  to transform geographic coordinates into the projected
+  coordinates. The source coordinates are expressed in terms of
+  a geographic coordinate system whose name is "NAD 83
+  (Continental US)." based on longitude and latitude whose name
+  is "Longitude / Latitude (NAD 83)". The "Transverse Mercator"
+  transform takes three parameters. The name of the first
+  parameter is "Scale_Factor", and its value is 0.999600. The
+  name of the second parameter is "Central_Meridian", and its
+  value is -117.000000. The name of the third parameter is
+  "False_Easting", and its value is 500000.000000. The unit of
+  measurement is a linear type whose name is "Meter", which can
+  be converted to meters by applying the scalar factor of
+  1.000000000000.
+</p>
+SQL\> select cs_name,srid, wktext from mdsys.cs_srs where srid = 82217;
+cs_name=UTM Zone 11 (NAD 83)
+srid=82254
+wktext=
+PROJCS[
+   "UTM Zone 18 (NAD 83)",
+   GEOGCS [
+      "NAD 83 (Continental US)",
+      DATUM [
+         SPHEROID [
+            "GRS 80",
+            6378137,
+            298.257222101
+      PRIMEM [
+         "Greenwich", 0.000000
+      UNIT [
+         "Decimal Degree",
+   PROJECTION [
+      "Transverse Mercator"
+   PARAMETER [
+      "Scale_Factor",
+      0.999600
+   PARAMETER [
+      "Central_Meridian",
+      \-75.000000
+   PARAMETER [
+      "False_Easting",
+      500000.000000
+   UNIT [
+      "Meter",
+      1.000000000000
+<p>
+  coordinate system whose name is "UTM83-4". It
+  a geographic coordinate system whose name is "LL83".
+  The "Transverse Mercator" transform takes five parameters.
+  The name of the first parameter is "false_easting", and its value is 500000.000.
+  The name of the second parameter is "false_northing", and its value is 0.000.
+  The name of the third parameter is "central_meridian", and its value is -159.00000000000000.
+  The name of the fourth parameter is "scale_factor", and its value is 0.9996.
+  The name of the fifth parameter is "latitude_of_origin", and its value is 0.000.
+  The unit of measurement is a linear type whose name is "Meter", which can
+  be converted to meters by applying the scalar factor of 1.000000000000.
+</p>
+PROJCS[
+  "UTM83-4",
+  GEOGCS[
+    "LL83",
+    DATUM[
+      "NAD83",
+      SPHEROID[
+        "GRS1980",
+	6378137.000,
+	298.25722210
+    PRIMEM[
+      "Greenwich",
+      0
+    UNIT[
+      "Degree",
+      0.017453292519943295
+  PROJECTION[
+    "Transverse_Mercator"
+  PARAMETER[
+    "false_easting",
+    500000.000
+  PARAMETER[
+    "false_northing",
+    0.000
+  PARAMETER[
+    "central_meridian",
+    -159.00000000000000
+  PARAMETER[
+    "scale_factor",
+    0.9996
+  PARAMETER[
+    "latitude_of_origin",
+    0.000
+  UNIT[
+    "Meter",
+    1.00000000000000
+<h2> Arbitrary Coordinate System </h2>
+<p>
+  The following well-known text represents a local,
+  ungeoreferenced coordinate system whose name is "Non-Earth
+  (Mile)." The horizontal datum used to measure positions in
+  the coordinate system is named "Local Datum". The type of the
+  horizontal datum is 0. The unit of measurement is a linear
+  type whose name is "Mile", which can be converted to meters
+  by applying the scalar factor of 1.609344e+03. The system has
+  two AXIS values indicating that it is two-dimensional. The
+  directional value associated with the "X" AXIS signifies that
+  "X" increases positively in value moving east from the
+  origin. The directional value associated with the "Y" AXIS
+  signifies that "Y" increases positively in value moving north
+  from the origin.
+</p>
+select cs_name, srid, wktext from mdsys.cs_srs where wktext like '%LOCAL_CS%';
+cs_name=Non-Earth (Mile)
+srid=262156
+wktext=
+LOCAL_CS [
+   "Non-Earth (Mile)",
+   LOCAL_DATUM [
+      "Local Datum",
+      0
+    UNIT [
+      "Mile",
+      1.609344e+03
+   AXIS [
+      "X",
+      EAST
+   AXIS[
+      "Y",
+      NORTH
Added: branches/4.0/MgDev/Doc/landing/cs-wkttosrs.md
--- branches/4.0/MgDev/Doc/landing/cs-wkttosrs.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/cs-wkttosrs.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,56 @@
+# WKT of SRS
+This extended BNF grammar represents the syntax of a
+Well-Known Text (WKT) specification of a Spatial Reference
+System (SRS), also known as a coordinate system. The grammar
+is taken verbatim from OGC01009 and is
+reproduced here for convenience.
+<math transform> = <param mt> | <concat mt> | <inv mt> | <passthrough mt>
+<param mt> = PARAM_MT["<classification name>" {,<parameter>}* ]
+<parameter> = PARAMETER["<name>", <value>]
+<value> = <number>
+<concat mt> = CONCAT_MT[<math transform> {,<math transform>}* ]
+<inv mt> = INVERSE_MT[<math transform>]
+<passthrough mt> = PASSTHROUGH_MT[<integer>, <math transform>]
+<coordinate system> = <horz cs> | <geocentric cs> | <vert cs> | <compd cs> | <fitted cs> | <local cs>
+<horz cs> = <geographic cs> | <projected cs>
+<projected cs> = PROJCS["<name>", <geographic cs>, <projection>, {<parameter>,}* <linear unit> {,<twin axes>}{,<authority>}]
+<projection> = PROJECTION["<name>" {,<authority>}]
+<geographic cs> = GEOGCS["<name>", <datum>, <prime meridian>, <angular unit> {,<twin axes>} {,<authority>}]
+<datum> = DATUM["<name>", <spheroid> {,<to wgs84>} {,<authority>}]
+<spheroid> = SPHEROID["<name>", <semi-major axis>, <inverse flattening> {,<authority>}]
+<semi-major axis> = <number>
+<inverse flattening> = <number>
+<prime meridian> = PRIMEM["<name>", <longitude> {,<authority>}]
+<longitude> = <number>
+<angular unit> = <unit>
+<linear unit> = <unit>
+<unit> = UNIT["<name>", <conversion factor> {,<authority>}]
+<conversion factor> = <number>
+<geocentric cs> = GEOCCS["<name>", <datum>, <prime meridian>, <linear unit> {,<axis>, <axis>, <axis>} {,<authority>}]
+<authority> = AUTHORITY["<name>", "<code>"]
+<vert cs> = VERT_CS["<name>", <vert datum>, <linear unit>, {<axis>,} {,<authority>}]
+<vert datum> = VERT_DATUM["<name>", <datum type> {,<authority>}]
+<datum type> = <number>
+<compd cs> = COMPD_CS["<name>", <head cs>, <tail cs> {,<authority>}]
+<head cs> = <coordinate system>
+<tail cs> = <coordinate system>
+<twin axes> = <axis>, <axis>
+<axis> = AXIS["<name>", NORTH | SOUTH | EAST | WEST | UP | DOWN | OTHER]
+<to wgs84s> = TOWGS84[<seven param>]
+<seven param> = <dx>, <dy>, <dz>, <ex>, <ey>, <ez>, <ppm>
+<dx> = <number>
+<dy> = <number>
+<dz> = <number>
+<ex> = <number>
+<ey> = <number>
+<ez> = <number>
+<ppm> = <number>
+<fitted cs> = FITTED_CS["<name>", <to base>, <base cs>]
+<to base> = <math transform>
+<base cs> = <coordinate system>
+<local cs> = LOCAL_CS["<name>", <local datum>, <unit>, <axis>, {,<axis>}* {,<authority>}]
+<local datum> = LOCAL_DATUM["<name>", <datum type> {,<authority>}]
Added: branches/4.0/MgDev/Doc/landing/docfx.json
--- branches/4.0/MgDev/Doc/landing/docfx.json	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/docfx.json	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,32 @@
+  "build": {
+    "content": [
+        "files": [
+          "**/*.{md,yml}"
+        "exclude": [
+          "_site/**"
+    "resources": [
+        "files": [
+          "images/**"
+    "output": "_site",
+    "template": [
+      "default",
+      "modern"
+    "globalMetadata": {
+      "_appName": "MapGuide API Reference",
+      "_appTitle": "MapGuide API Reference",
+      "_enableSearch": true,
+      "pdf": false
Added: branches/4.0/MgDev/Doc/landing/feature-properties.md
--- branches/4.0/MgDev/Doc/landing/feature-properties.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/feature-properties.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,26 @@
+# Feature Properties
+A feature property is a key-value pair where the key is a
+property name as defined in a feature class definition, and
+the value is the property's value. The property's type is one
+of the classes derived from the base class `MgProperty` ([.net](dotnet_api/api/OSGeo.MapGuide.MgProperty.html) [Java](java_api/org/osgeo/mapguide/MgProperty.html) [PHP](TODO.md)). The
+following list shows the names of the classes derived from
+`MgProperty` and, for each class, the type returned by the
+`GetValue()` method:
+| Class | Returns |
+| `MgBlobProperty` | `MgByteReader` [.net](dotnet_api/api/OSGeo.MapGuide.MgByteReader.html) [Java](java_api/org/osgeo/mapguide/MgByteReader.html) [PHP](TODO.md) |
+| `MgBooleanProperty` | `bool` |
+| `MgByteProperty` | `byte` |
+| `MgClobProperty` | `MgByteReader` [.net](dotnet_api/api/OSGeo.MapGuide.MgByteReader.html) [Java](java_api/org/osgeo/mapguide/MgByteReader.html) [PHP](TODO.md) |
+| `MgDateTimeProperty` | `MgDateTime` [.net](dotnet_api/api/OSGeo.MapGuide.MgDateTime.html) [Java](java_api/org/osgeo/mapguide/MgDateTime.html) [PHP](TODO.md) |
+| `MgDoubleProperty` | `double` |
+| `MgFeatureProperty` | `MgFeatureReader` [.net](dotnet_api/api/OSGeo.MapGuide.MgFeatureReader.html) [Java](java_api/org/osgeo/mapguide/MgFeatureReader.html) [PHP](TODO.md) |
+| `MgGeometryProperty` | `MgByteReader` [.net](dotnet_api/api/OSGeo.MapGuide.MgByteReader.html) [Java](java_api/org/osgeo/mapguide/MgByteReader.html) [PHP](TODO.md) |
+| `MgInt16Property` | `int16` |
+| `MgInt32Property` | `int32` |
+| `MgInt64Property` | `int64` |
+| `MgRasterProperty` | `MgRaster` [.net](dotnet_api/api/OSGeo.MapGuide.MgRaster.html) [Java](java_api/org/osgeo/mapguide/MgRaster.html) [PHP](TODO.md) |
+| `MgSingleProperty` | `float` |
+| `MgStringProperty` | `string` |
Added: branches/4.0/MgDev/Doc/landing/geom-collections.md
--- branches/4.0/MgDev/Doc/landing/geom-collections.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/geom-collections.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,23 @@
+# Geometry Collections
+<p>The following collection classes are used by
+  MgGeometryFactory methods in the construction of geometries
+  and geometry components. See the MgGeometryFactory description for discussion and illustration of this use.</p>
+ * [MgGeometryFactory (.net)](dotnet_api/api/OSGeo.MapGuide.MgGeometryFactory.html)
+ * [MgGeometryFactory (java)](java_api/org/osgeo/mapguide/MgGeometryFactory.html)
+ * [MgGeometryFactory (PHP)](TODO.md)
+| Class                       |        |        |                |
+|MgCoordinateCollection       |[.net](dotnet_api/api/OSGeo.MapGuide.MgCoordinateCollection.html)|[Java](java_api/org/osgeo/mapguide/MgCoordinateCollection.html)|[PHP](TODO.md)|
+|MgCurvePolygonCollection     |[.net](dotnet_api/api/OSGeo.MapGuide.MgCurvePolygonCollection.html)|[Java](java_api/org/osgeo/mapguide/MgCurvePolygonCollection.html)|[PHP](TODO.md)|
+|MgCurveRingCollection        |[.net](dotnet_api/api/OSGeo.MapGuide.MgCurveRingCollection.html)|[Java](java_api/org/osgeo/mapguide/MgCurveRingCollection.html)|[PHP](TODO.md)|
+|MgCurveSegmentCollection     |[.net](dotnet_api/api/OSGeo.MapGuide.MgCurveSegmentCollection.html)|[Java](java_api/org/osgeo/mapguide/MgCurveSegmentCollection.html)|[PHP](TODO.md)|
+|MgCurveStringCollection      |[.net](dotnet_api/api/OSGeo.MapGuide.MgCurveStringCollection.html)|[Java](java_api/org/osgeo/mapguide/MgCurveStringCollection.html)|[PHP](TODO.md)|
+|MgGeometryCollection         |[.net](dotnet_api/api/OSGeo.MapGuide.MgGeometryCollection.html)|[Java](java_api/org/osgeo/mapguide/MgGeometryCollection.html)|[PHP](TODO.md)|
+|MgGeometryComponentCollection|[.net](dotnet_api/api/OSGeo.MapGuide.MgGeometryComponentCollection.html)|[Java](java_api/org/osgeo/mapguide/MgGeometryComponentCollection.html)|[PHP](TODO.md)|
+|MgLinearRingCollection       |[.net](dotnet_api/api/OSGeo.MapGuide.MgLinearRingCollection.html)|[Java](java_api/org/osgeo/mapguide/MgLinearRingCollection.html)|[PHP](TODO.md)|
+|MgLineStringCollection       |[.net](dotnet_api/api/OSGeo.MapGuide.MgLineStringCollection.html)|[Java](java_api/org/osgeo/mapguide/MgLineStringCollection.html)|[PHP](TODO.md)|
+|MgPointCollection            |[.net](dotnet_api/api/OSGeo.MapGuide.MgPointCollection.html)|[Java](java_api/org/osgeo/mapguide/MgPointCollection.html)|[PHP](TODO.md)|
+|MgPolygonCollection          |[.net](dotnet_api/api/OSGeo.MapGuide.MgPolygonCollection.html)|[Java](java_api/org/osgeo/mapguide/MgPolygonCollection.html)|[PHP](TODO.md)|
Added: branches/4.0/MgDev/Doc/landing/index.md
--- branches/4.0/MgDev/Doc/landing/index.md	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/index.md	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,13 @@
+_layout: landing
+# Welcome to the MapGuide API Reference
+The MapGuide API is available for the following languages/platforms below
+## Choose your language/platform
+ * [.net API reference](dotnet_api/index.html)
+ * [PHP API reference](php_api/index.html)
+ * [Java API reference](java_api/index.html)
Added: branches/4.0/MgDev/Doc/landing/toc.yml
--- branches/4.0/MgDev/Doc/landing/toc.yml	                        (rev 0)
+++ branches/4.0/MgDev/Doc/landing/toc.yml	2023-11-10 18:20:55 UTC (rev 10062)
@@ -0,0 +1,35 @@
+# TODO: Link to conceptual topics once they've all been migrated to markdown and copied into this dir
+#- name: Introduction
+#  href: introduction.md
+#- name: Getting Started
+#  href: getting-started.md
+- name: Collections
+  href: collections.md
+- name: Feature Service
+  items:
+    - name: Feature Properties
+      href: feature-properties.md
+- name: Geometry
+  items:
+    - name: Collections
+      href: geom-collections.md
+- name: Coordinate System
+  items:
+    - name: Test values
+      href: cs-testvalues.md
+    - name: WKT to SRS
+      href: cs-wkttosrs.md
+- name: Bibliography
+  items:
+    - name: Dana99
+      href: bib-dana99.md
+    - name: Egenhofer91
+      href: bib-egenhofer91.md
+    - name: OGC96015R1
+      href: bib-ogc96-015r1.md
+    - name: OGC99049
+      href: bib-ogc99-049.md
+    - name: OSUGR
+      href: bib-osugr.md
+    - name: Peat
+      href: bib-peat.md
More information about the mapguide-commits mailing list
