[mapguide-commits] r10184 - branches/4.0/MgDev
    svn_mapguide at osgeo.org
    Sat Sep  6 21:10:02 PDT 2025
Author: jng
Date: 2025-09-06 21:10:01 -0700 (Sat, 06 Sep 2025)
New Revision: 10184
   branches/4.0/MgDev/clean.bat
Have clean.bat also clean out as much of the SWIG generated sources as possible
Modified: branches/4.0/MgDev/clean.bat
--- branches/4.0/MgDev/clean.bat	2025-09-03 10:25:10 UTC (rev 10183)
+++ branches/4.0/MgDev/clean.bat	2025-09-07 04:10:01 UTC (rev 10184)
@@ -26,6 +26,24 @@
 if exist packages\Installed\osgeo.mapguide.mapguidecommon rd /S /Q packages\Installed\osgeo.mapguide.mapguidecommon
 if exist packages\Installed\osgeo.mapguide.platformbase rd /S /Q packages\Installed\osgeo.mapguide.platformbase
 if exist packages\Installed\osgeo.mapguide.web rd /S /Q packages\Installed\osgeo.mapguide.web
+echo [clean]: Binding Generated Sources
+if exist Bindings\src\Bindings\DotNet\Foundation\*_wrap.cpp del /F Bindings\src\Bindings\DotNet\Foundation\*_wrap.cpp
+if exist Bindings\src\Bindings\DotNet\Geometry\*_wrap.cpp del /F Bindings\src\Bindings\DotNet\Geometry\*_wrap.cpp
+if exist Bindings\src\Bindings\DotNet\PlatformBase\*_wrap.cpp del /F Bindings\src\Bindings\DotNet\PlatformBase\*_wrap.cpp
+if exist Bindings\src\Bindings\DotNet\MapGuideCommon\*_wrap.cpp del /F Bindings\src\Bindings\DotNet\MapGuideCommon\*_wrap.cpp
+if exist Bindings\src\Bindings\DotNet\Web\*_wrap.cpp del /F Bindings\src\Bindings\DotNet\Web\*_wrap.cpp
+if exist Bindings\src\Bindings\DotNet\Portable\*_wrap.cpp del /F Bindings\src\Bindings\DotNet\Portable\*_wrap.cpp
+if exist Bindings\src\Bindings\Java\*_wrap.cpp del /F Bindings\src\Bindings\Java\*_wrap.cpp
+if exist Bindings\src\Bindings\Php\*_wrap.cpp del /F Bindings\src\Bindings\Php\*_wrap.cpp
+if exist Bindings\src\Managed\DotNet\OSGeo.MapGuide.Foundation\*.cs del /F Bindings\src\Managed\DotNet\OSGeo.MapGuide.Foundation\*.cs
+if exist Bindings\src\Managed\DotNet\OSGeo.MapGuide.Geometry\*.cs del /F Bindings\src\Managed\DotNet\OSGeo.MapGuide.Geometry\*.cs
+if exist Bindings\src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\*.cs del /F Bindings\src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\*.cs
+if exist Bindings\src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\*.cs del /F Bindings\src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\*.cs
+if exist Bindings\src\Managed\DotNet\OSGeo.MapGuide.Web\*.cs del /F Bindings\src\Managed\DotNet\OSGeo.MapGuide.Web\*.cs
+if exist Bindings\src\Managed\DotNet\OSGeo.MapGuide.Portable\*.cs del /F Bindings\src\Managed\DotNet\OSGeo.MapGuide.Portable\*.cs
+if exist Bindings\src\Managed\Java\org\osgeo\mapguide\*.class del /F Bindings\src\Managed\Java\org\osgeo\mapguide\*.class
+REM Not cleaning out java sources because MgBase64 and MgLocalizer would get caught in the crossfire and Java's package/filename/classname
+REM intransigence means we can't wildcard delete around them!
 echo [clean]: Common
 if exist Common\bin rd /S /Q Common\bin
 if exist Common\lib rd /S /Q Common\lib
More information about the mapguide-commits
