[mapguide-commits] r10185 - in branches/4.0/MgDev/Bindings/src/Bindings/DotNet: . Foundation Geometry MapGuideCommon PlatformBase Portable Web
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Sep 8 02:43:38 PDT 2025
Author: jng
Date: 2025-09-08 02:43:37 -0700 (Mon, 08 Sep 2025)
New Revision: 10185
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApiGen.xml
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApiGen.xml
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApiGen.xml
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApiGen.xml
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApiGen.xml
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Web/WebApiGen.xml
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore.i
   branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore_split.i
Get .net bindings working on Linux again. On Linux, use the same STRINGPARAM in typemap that we use for the Java binding and typedef STRINGPARAM to std::wstring instead of wchar_t when building the SWIG glue library on Linux
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApiGen.xml
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApiGen.xml	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApiGen.xml	2025-09-08 09:43:37 UTC (rev 10185)
@@ -33,8 +33,12 @@
 #if defined(PHP) || defined(JAVA)
 typedef std::wstring STRINGPARAM;
 #else
+#if defined(_WIN32)
 typedef wchar_t* STRINGPARAM;
+#else
+typedef std::wstring STRINGPARAM;
 #endif
+#endif
 </CppInline>
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApiGen.xml
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApiGen.xml	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApiGen.xml	2025-09-08 09:43:37 UTC (rev 10185)
@@ -34,8 +34,12 @@
 #else
+#else
 #endif
+#endif
 </CppInline>
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApiGen.xml
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApiGen.xml	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApiGen.xml	2025-09-08 09:43:37 UTC (rev 10185)
@@ -35,8 +35,12 @@
 #else
+#else
 #endif
+#endif
 </CppInline>
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApiGen.xml
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApiGen.xml	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApiGen.xml	2025-09-08 09:43:37 UTC (rev 10185)
@@ -35,8 +35,12 @@
 #else
+#else
 #endif
+#endif
 </CppInline>
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApiGen.xml
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApiGen.xml	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApiGen.xml	2025-09-08 09:43:37 UTC (rev 10185)
@@ -35,8 +35,12 @@
 #else
+#else
 #endif
+#endif
 </CppInline>
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Web/WebApiGen.xml
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Web/WebApiGen.xml	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Web/WebApiGen.xml	2025-09-08 09:43:37 UTC (rev 10185)
@@ -43,8 +43,12 @@
 #else
+#else
 #endif
+#endif
 </CppInline>
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore.i
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore.i	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore.i	2025-09-08 09:43:37 UTC (rev 10185)
@@ -100,7 +100,10 @@
     else
-        $1 = (STRINGPARAM) X2W((XMLCh*)$input);
+        xstring u16String((XMLCh*)$input);
+        lstring u32String;
+        UnicodeString::UTF16toUTF32(u16String.c_str(),u32String);
+        $1 = STRINGPARAM((const wchar_t*) u32String.c_str());
 #endif
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore_split.i
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore_split.i	2025-09-07 04:10:01 UTC (rev 10184)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/dotnetcore_split.i	2025-09-08 09:43:37 UTC (rev 10185)
@@ -99,7 +99,10 @@
     else
 #endif
More information about the mapguide-commits mailing list
