[mapguide-commits] r10268 - in branches/4.0/MgDev/Web/src: . openapi
svn_mapguide at osgeo.org
Wed Nov 4 19:55:47 PST 2026
Author: jng
Date: 2026-11-04 19:55:47 -0800 (Wed, 04 Nov 2026)
New Revision: 10268
Added:
branches/4.0/MgDev/Web/src/openapi/
branches/4.0/MgDev/Web/src/openapi/openapi.yaml
branches/4.0/MgDev/Web/src/openapi/swagger.html
#2899: Initial OpenAPI spec
Added: branches/4.0/MgDev/Web/src/openapi/openapi.yaml
--- branches/4.0/MgDev/Web/src/openapi/openapi.yaml (rev 0)
+++ branches/4.0/MgDev/Web/src/openapi/openapi.yaml 2026-11-05 03:55:47 UTC (rev 10268)
@@ -0,0 +1,5334 @@
+openapi: "3.0.3"
+info:
+ title: MapGuide MapAgent API
+ description: |
+ HTTP API for MapGuide Open Source, served by the MapAgent FastCGI endpoint.
+ All operations are dispatched to the single endpoint `/mapguide/mapagent/mapagent.fcgi` using
+ the `OPERATION` query parameter. Parameters can be passed via query string (GET) or form body (POST).
+ **Authentication**: Most operations require either a session token (`SESSION` parameter) or
+ HTTP Basic Authentication (`USERNAME` + `PASSWORD`). Create a session with `CREATESESSION` first.
+ **Response formats**: Operations that return structured data support `FORMAT=text/xml` (default)
+ and `FORMAT=application/json`. Version 4.0.0+ with `CLEAN=1` returns direct JSON serialization.
+ **Source of truth**: This spec is derived from the C++ handler registry in
+ `HttpRequest.cpp::InitializeStaticData()`. Operations present in HTML test forms but lacking
+ a registered C++ handler (Server Admin, ExecuteSqlQuery, SchemaReport) are intentionally excluded.
+ version: "4.0.0"
+ contact:
+ name: MapGuide Open Source
+ url: https://mapguide.osgeo.org
+ license:
+ name: LGPL-2.1
+ url: https://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
+servers:
+ - url: /mapguide/mapagent/mapagent.fcgi#
+ description: Single MapAgent FastCGI endpoint (fragment is stripped by all HTTP clients)
+tags:
+ - name: Session
+ description: Session lifecycle management
+ - name: Site
+ description: Server info, users, and groups
+ - name: Resource
+ description: Repository and resource CRUD, resource data, packages
+ - name: Feature
+ description: FDO feature source queries, schema discovery, spatial contexts
+ - name: Drawing
+ description: DWF drawing retrieval, layer/section enumeration
+ - name: Mapping
+ description: Runtime map creation, plots, legend images
+ - name: Rendering
+ description: Map images, dynamic overlays, feature queries on rendered maps
+ - name: Tile
+ description: Tiled map image retrieval and cache management
+ - name: KML
+ description: KML map and feature layer generation
+ - name: CoordinateSystem
+ description: CS-Map coordinate system transformations and enumeration
+ - name: GeoProcessing
+ description: Spatial geometry operations (buffer, distance, etc.)
+ - name: WebApplication
+ description: Application template, widget, and container enumeration
+components:
+ securitySchemes:
+ SessionAuth:
+ type: apiKey
+ in: query
+ name: SESSION
+ description: Session token obtained from CREATESESSION
+ BasicAuth:
+ type: http
+ scheme: basic
+ description: HTTP Basic Authentication using USERNAME and PASSWORD
+ parameters:
+ Session:
+ name: SESSION
+ in: query
+ required: false
+ description: Session token from CREATESESSION. Required for authenticated operations.
+ schema:
+ type: string
+ Locale:
+ name: LOCALE
+ in: query
+ required: false
+ description: Language locale
+ schema:
+ type: string
+ default: "en"
+ ClientAgent:
+ name: CLIENTAGENT
+ in: query
+ required: false
+ description: Client agent identifier
+ schema:
+ type: string
+ Format:
+ name: FORMAT
+ in: query
+ required: false
+ description: Response format for data operations
+ schema:
+ type: string
+ enum: ["text/xml", "application/json"]
+ default: "text/xml"
+ Clean:
+ name: CLEAN
+ in: query
+ required: false
+ description: Request clean/direct JSON serialization (only supported for VERSION > 4.0.0)
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ ImageFormat:
+ name: FORMAT
+ in: query
+ required: false
+ description: Output image format
+ schema:
+ type: string
+ enum: ["PNG", "GIF", "JPG", "PNG8", "TIFF"]
+ default: "PNG"
+ ResourceId:
+ name: RESOURCEID
+ in: query
+ required: true
+ description: Resource identifier (e.g. Library://Samples/Sheboygan/Data/Parcels.FeatureSource)
+ schema:
+ type: string
+ MapDefinition:
+ name: MAPDEFINITION
+ in: query
+ required: false
+ description: Map definition resource path
+ schema:
+ type: string
+ example: "Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition"
+ MapName:
+ name: MAPNAME
+ in: query
+ required: false
+ description: Runtime map name
+ schema:
+ type: string
+ Provider:
+ name: PROVIDER
+ in: query
+ required: true
+ description: FDO provider name (e.g. OSGeo.SDF, OSGeo.SHP)
+ schema:
+ type: string
+ ConnectionString:
+ name: CONNECTIONSTRING
+ in: query
+ required: false
+ description: FDO connection string
+ schema:
+ type: string
+ Schema:
+ name: SCHEMA
+ in: query
+ required: true
+ description: Feature schema name
+ schema:
+ type: string
+ ClassName:
+ name: CLASSNAME
+ in: query
+ required: true
+ description: Feature class name
+ schema:
+ type: string
+ responses:
+ XmlResponse:
+ description: Successful XML response
+ content:
+ text/xml:
+ schema:
+ type: string
+ JsonResponse:
+ description: Successful JSON response
+ content:
+ application/json:
+ schema:
+ type: object
+ TextResponse:
+ description: Successful plain text response
+ content:
+ text/plain:
+ schema:
+ type: string
+ ImagePngResponse:
+ description: PNG image
+ content:
+ image/png:
+ schema:
+ type: string
+ format: binary
+ HtmlResponse:
+ description: HTML page
+ content:
+ text/html:
+ schema:
+ type: string
+ EmptyResponse:
+ description: Operation completed successfully (no content)
+ UnauthorizedError:
+ description: Authentication required
+ content:
+ text/xml:
+ schema:
+ type: string
+ BadRequestError:
+ description: Invalid request parameters
+paths:
+ # SESSION OPERATIONS
+ /CreateSession:
+ post:
+ tags: [Session]
+ summary: Create a new session
+ description: Creates an authenticated session and returns the session ID. No prior authentication required.
+ operationId: CreateSession
+ security: []
+ requestBody:
+ required: true
+ content:
+ application/x-www-form-urlencoded:
+ schema:
+ type: object
+ required: [OPERATION, VERSION]
+ properties:
+ OPERATION:
+ type: string
+ enum: [CREATESESSION]
+ default: CREATESESSION
+ description: Operation name
+ VERSION:
+ type: string
+ enum: ["1.0.0", "1.2.0", "2.0.0", "2.2.0", "4.0.0"]
+ default: "1.0.0"
+ description: API version
+ USERNAME:
+ type: string
+ default: Anonymous
+ description: Username (defaults to Anonymous if not provided)
+ PASSWORD:
+ type: string
+ example: ""
+ description: Password
+ LOCALE:
+ type: string
+ example: "en"
+ default: "en"
+ description: Locale code (e.g., en)
+ CLIENTAGENT:
+ type: string
+ example: ""
+ responses:
+ '200':
+ $ref: '#/components/responses/TextResponse'
+ '401':
+ $ref: '#/components/responses/UnauthorizedError'
+ /GetSessionTimeout:
+ get:
+ tags: [Session]
+ summary: Get session timeout
+ description: Returns the configured session timeout value.
+ operationId: GetSessionTimeout
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSESSIONTIMEOUT]
+ default: GETSESSIONTIMEOUT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - $ref: '#/components/parameters/Session'
+ - $ref: '#/components/parameters/Locale'
+ - $ref: '#/components/parameters/ClientAgent'
+ - $ref: '#/components/parameters/Format'
+ - $ref: "#/components/parameters/Clean"
+ responses:
+ '200':
+ $ref: '#/components/responses/XmlResponse'
+ '401':
+ # SITE OPERATIONS
+ /GetSiteVersion:
+ get:
+ tags: [Site]
+ summary: Get site version
+ description: Returns the MapGuide server version information.
+ operationId: GetSiteVersion
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSITEVERSION]
+ default: GETSITEVERSION
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetSiteInfo:
+ get:
+ tags: [Site]
+ summary: Get site information
+ description: Returns site configuration and status information.
+ operationId: GetSiteInfo
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSITEINFO]
+ default: GETSITEINFO
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetSiteStatus:
+ get:
+ tags: [Site]
+ summary: Get site status
+ description: Returns current site operational status. No authentication required.
+ operationId: GetSiteStatus
+ security: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSITESTATUS]
+ default: GETSITESTATUS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ /EnumerateUsers:
+ get:
+ tags: [Site]
+ summary: Enumerate users
+ description: Lists users, optionally filtered by group.
+ operationId: EnumerateUsers
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEUSERS]
+ default: ENUMERATEUSERS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: GROUP
+ in: query
+ required: false
+ description: Filter users by group name
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /EnumerateGroups:
+ get:
+ tags: [Site]
+ summary: Enumerate groups
+ description: Lists all user groups.
+ operationId: EnumerateGroups
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEGROUPS]
+ default: ENUMERATEGROUPS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ # RESOURCE OPERATIONS — Repositories
+ /EnumerateRepositories:
+ get:
+ tags: [Resource]
+ summary: Enumerate repositories
+ description: Lists available repositories, optionally filtered by type.
+ operationId: EnumerateRepositories
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEREPOSITORIES]
+ default: ENUMERATEREPOSITORIES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: TYPE
+ in: query
+ required: false
+ description: Repository type filter
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /CreateRepository:
+ post:
+ tags: [Resource]
+ summary: Create repository
+ description: Creates a new repository.
+ operationId: CreateRepository
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CREATEREPOSITORY]
+ default: CREATEREPOSITORY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - $ref: '#/components/parameters/ResourceId'
+ - name: TYPE
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ $ref: '#/components/responses/EmptyResponse'
+ '401':
+ /DeleteRepository:
+ post:
+ tags: [Resource]
+ summary: Delete repository
+ description: Deletes an existing repository.
+ operationId: DeleteRepository
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [DELETEREPOSITORY]
+ default: DELETEREPOSITORY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /UpdateRepository:
+ post:
+ tags: [Resource]
+ summary: Update repository
+ description: Updates repository content and/or header.
+ operationId: UpdateRepository
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [UPDATEREPOSITORY]
+ default: UPDATEREPOSITORY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CONTENT
+ in: query
+ required: false
+ description: Repository content XML
+ schema:
+ type: string
+ - name: HEADER
+ in: query
+ required: false
+ description: Repository header XML
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetRepositoryContent:
+ get:
+ tags: [Resource]
+ summary: Get repository content
+ description: Returns the content of a repository.
+ operationId: GetRepositoryContent
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETREPOSITORYCONTENT]
+ default: GETREPOSITORYCONTENT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetRepositoryHeader:
+ get:
+ tags: [Resource]
+ summary: Get repository header
+ description: Returns the header/metadata of a repository.
+ operationId: GetRepositoryHeader
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETREPOSITORYHEADER]
+ default: GETREPOSITORYHEADER
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ # RESOURCE OPERATIONS — Resources
+ /EnumerateResources:
+ get:
+ tags: [Resource]
+ summary: Enumerate resources
+ description: Lists resources under a given path, with optional depth, type, and filter.
+ operationId: EnumerateResources
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATERESOURCES]
+ default: ENUMERATERESOURCES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: RESOURCEID
+ in: query
+ required: true
+ description: Parent resource path
+ schema:
+ type: string
+ - name: DEPTH
+ in: query
+ required: false
+ description: Recursion depth (-1 for infinite)
+ schema:
+ type: integer
+ default: 1
+ - name: TYPE
+ in: query
+ required: false
+ description: Resource type filter
+ schema:
+ type: string
+ - name: COMPUTECHILDREN
+ in: query
+ required: false
+ description: Whether to compute child counts
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ - name: FILTER
+ in: query
+ required: false
+ description: Name filter pattern
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /ResourceExists:
+ get:
+ tags: [Resource]
+ summary: Check if resource exists
+ description: Returns "true" or "false" as plain text.
+ operationId: ResourceExists
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [RESOURCEEXISTS]
+ default: RESOURCEEXISTS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /SetResource:
+ post:
+ tags: [Resource]
+ summary: Set/update resource
+ description: Creates or updates a resource with XML content and optional header.
+ operationId: SetResource
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [SETRESOURCE]
+ default: SETRESOURCE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CONTENT
+ in: query
+ required: true
+ description: Resource content XML
+ schema:
+ type: string
+ - name: HEADER
+ in: query
+ required: false
+ description: Resource header XML
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /DeleteResource:
+ post:
+ tags: [Resource]
+ summary: Delete resource
+ description: Deletes an existing resource.
+ operationId: DeleteResource
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [DELETERESOURCE]
+ default: DELETERESOURCE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /MoveResource:
+ post:
+ tags: [Resource]
+ summary: Move resource
+ description: Moves a resource from source to destination, optionally overwriting and cascading.
+ operationId: MoveResource
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [MOVERESOURCE]
+ default: MOVERESOURCE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: SOURCE
+ in: query
+ required: true
+ description: Source resource path
+ schema:
+ type: string
+ - name: DESTINATION
+ in: query
+ required: true
+ description: Destination resource path
+ schema:
+ type: string
+ - name: OVERWRITE
+ in: query
+ required: false
+ description: Overwrite existing destination
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ - name: CASCADE
+ in: query
+ required: false
+ description: Cascade the move to children
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ responses:
+ '200':
+ '401':
+ /CopyResource:
+ post:
+ tags: [Resource]
+ summary: Copy resource
+ description: Copies a resource from source to destination, optionally overwriting.
+ operationId: CopyResource
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [COPYRESOURCE]
+ default: COPYRESOURCE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: SOURCE
+ in: query
+ required: true
+ schema:
+ type: string
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: OVERWRITE
+ in: query
+ required: false
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ responses:
+ '200':
+ '401':
+ /GetResourceContent:
+ get:
+ tags: [Resource]
+ summary: Get resource content
+ description: Returns the XML content of a resource.
+ operationId: GetResourceContent
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETRESOURCECONTENT]
+ default: GETRESOURCECONTENT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetResourceHeader:
+ get:
+ tags: [Resource]
+ summary: Get resource header
+ description: Returns the header/metadata XML of a resource.
+ operationId: GetResourceHeader
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETRESOURCEHEADER]
+ default: GETRESOURCEHEADER
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /EnumerateResourceReferences:
+ get:
+ tags: [Resource]
+ summary: Enumerate resource references
+ description: Lists all resources referenced by a given resource.
+ operationId: EnumerateResourceReferences
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATERESOURCEREFERENCES]
+ default: ENUMERATERESOURCEREFERENCES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /ChangeResourceOwner:
+ post:
+ tags: [Resource]
+ summary: Change resource owner
+ description: Changes the owner of a resource, optionally including descendants.
+ operationId: ChangeResourceOwner
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CHANGERESOURCEOWNER]
+ default: CHANGERESOURCEOWNER
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: OWNER
+ in: query
+ required: true
+ description: New owner username
+ schema:
+ type: string
+ - name: INCLUDEDESCENDANTS
+ in: query
+ required: false
+ description: Apply to descendant resources
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ responses:
+ '200':
+ '401':
+ /InheritPermissionsFrom:
+ post:
+ tags: [Resource]
+ summary: Inherit permissions
+ description: Inherits permissions from a source resource.
+ operationId: InheritPermissionsFrom
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [INHERITPERMISSIONSFROM]
+ default: INHERITPERMISSIONSFROM
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ description: Target resource to apply inherited permissions to
+ schema:
+ type: string
+ - name: SOURCE
+ in: query
+ required: true
+ description: Source resource to inherit permissions from
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ # RESOURCE OPERATIONS — Resource Data
+ /EnumerateResourceData:
+ get:
+ tags: [Resource]
+ summary: Enumerate resource data
+ description: Lists binary resource data items attached to a resource.
+ operationId: EnumerateResourceData
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATERESOURCEDATA]
+ default: ENUMERATERESOURCEDATA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /SetResourceData:
+ post:
+ tags: [Resource]
+ summary: Set resource data
+ description: Uploads binary data to attach to a resource.
+ operationId: SetResourceData
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [SETRESOURCEDATA]
+ default: SETRESOURCEDATA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: DATANAME
+ in: query
+ required: true
+ description: Name for the data item
+ schema:
+ type: string
+ - name: DATATYPE
+ in: query
+ required: true
+ description: MIME type of the data
+ schema:
+ type: string
+ - name: DATALENGTH
+ in: query
+ required: false
+ description: Length of data in bytes
+ schema:
+ type: integer
+ - name: DATA
+ in: query
+ required: true
+ description: Base64-encoded binary data or file path
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /DeleteResourceData:
+ post:
+ tags: [Resource]
+ summary: Delete resource data
+ description: Removes a binary data item from a resource.
+ operationId: DeleteResourceData
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [DELETERESOURCEDATA]
+ default: DELETERESOURCEDATA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: DATANAME
+ in: query
+ required: true
+ description: Name of the data item to delete
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /RenameResourceData:
+ post:
+ tags: [Resource]
+ summary: Rename resource data
+ description: Renames a binary data item, optionally overwriting an existing one.
+ operationId: RenameResourceData
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [RENAMERESOURCEDATA]
+ default: RENAMERESOURCEDATA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: OLDDATANAME
+ in: query
+ required: true
+ description: Current name of the data item
+ schema:
+ type: string
+ - name: NEWDATANAME
+ in: query
+ required: true
+ description: New name for the data item
+ schema:
+ type: string
+ - name: OVERWRITE
+ in: query
+ required: false
+ description: Overwrite existing item with new name
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ responses:
+ '200':
+ '401':
+ /GetResourceData:
+ get:
+ tags: [Resource]
+ summary: Get resource data
+ description: Retrieves binary data attached to a resource.
+ operationId: GetResourceData
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETRESOURCEDATA]
+ default: GETRESOURCEDATA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: DATANAME
+ in: query
+ required: true
+ description: Name of the data item to retrieve
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Binary resource data
+ content:
+ application/octet-stream:
+ schema:
+ type: string
+ format: binary
+ '401':
+ /EnumerateUnmanagedData:
+ get:
+ tags: [Resource]
+ summary: Enumerate unmanaged data
+ description: Lists unmanaged (file-based) data under a resource path.
+ operationId: EnumerateUnmanagedData
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEUNMANAGEDDATA]
+ default: ENUMERATEUNMANAGEDDATA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: PATH
+ in: query
+ required: false
+ description: Sub-path for unmanaged data
+ schema:
+ type: string
+ - name: RECURSIVE
+ in: query
+ required: false
+ description: Recursively enumerate
+ schema:
+ type: integer
+ enum: [0, 1]
+ default: 0
+ - name: TYPE
+ in: query
+ required: false
+ description: Type filter
+ schema:
+ type: string
+ - name: FILTER
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ # RESOURCE OPERATIONS — Packages
+ /ApplyResourcePackage:
+ post:
+ tags: [Resource]
+ summary: Apply resource package
+ description: Uploads and applies a MapGuide Package (.mgp) file.
+ operationId: ApplyResourcePackage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [APPLYRESOURCEPACKAGE]
+ default: APPLYRESOURCEPACKAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ requestBody:
+ required: true
+ content:
+ multipart/form-data:
+ schema:
+ type: object
+ required: [OPERATION, VERSION, PACKAGE]
+ properties:
+ OPERATION:
+ type: string
+ VERSION:
+ type: string
+ SESSION:
+ type: string
+ example: ""
+ USERNAME:
+ type: string
+ example: ""
+ PASSWORD:
+ type: string
+ example: ""
+ LOCALE:
+ type: string
+ example: ""
+ default: "en"
+ CLIENTAGENT:
+ type: string
+ example: ""
+ MAX_FILE_SIZE:
+ type: integer
+ description: Maximum allowed file size in bytes
+ PACKAGE:
+ type: string
+ format: binary
+ description: The .mgp package file to upload
+ responses:
+ '200':
+ '401':
+ # FEATURE OPERATIONS
+ /GetFeatureProviders:
+ get:
+ tags: [Feature]
+ summary: Get feature providers
+ description: Lists all available FDO feature providers.
+ operationId: GetFeatureProviders
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETFEATUREPROVIDERS]
+ default: GETFEATUREPROVIDERS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetProviderCapabilities:
+ get:
+ tags: [Feature]
+ summary: Get provider capabilities
+ description: Returns the capabilities of a specific FDO provider.
+ operationId: GetProviderCapabilities
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETPROVIDERCAPABILITIES]
+ default: GETPROVIDERCAPABILITIES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - $ref: '#/components/parameters/Provider'
+ - $ref: '#/components/parameters/ConnectionString'
+ responses:
+ '200':
+ '401':
+ /GetConnectionPropertyValues:
+ get:
+ tags: [Feature]
+ summary: Get connection property values
+ description: Returns enumerable values for a specific connection property.
+ operationId: GetConnectionPropertyValues
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETCONNECTIONPROPERTYVALUES]
+ default: GETCONNECTIONPROPERTYVALUES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: PROPERTY
+ in: query
+ required: true
+ description: Connection property name
+ schema:
+ type: string
+ example: ReadOnly
+ responses:
+ '200':
+ '401':
+ /DescribeFeatureSchema:
+ get:
+ tags: [Feature]
+ summary: Describe feature schema
+ description: Returns the feature schema for a feature source, optionally filtered by schema and class names.
+ operationId: DescribeFeatureSchema
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [DESCRIBEFEATURESCHEMA]
+ default: DESCRIBEFEATURESCHEMA
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ description: Feature source resource ID
+ schema:
+ type: string
+ - name: SCHEMA
+ in: query
+ required: false
+ description: Schema name filter
+ schema:
+ type: string
+ - name: CLASSNAMES
+ in: query
+ required: false
+ description: Comma-separated class name filter
+ schema:
+ type: string
+ - name: SIMPLE
+ in: query
+ required: false
+ description: Request simplified output (v4.0.0+)
+ schema:
+ type: integer
+ enum: [0, 1]
+ responses:
+ '200':
+ '401':
+ /SelectFeatures:
+ get:
+ tags: [Feature]
+ summary: Select features
+ description: Queries features from a feature source with optional filter, property list, and transformation. Supports GeoJSON output via FORMAT=application/json.
+ operationId: SelectFeatures
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [SELECTFEATURES]
+ default: SELECTFEATURES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ description: Response format (text/xml for XML, application/json for GeoJSON)
+ schema:
+ type: string
+ enum: ["text/xml", "application/json", "GEOJSON"]
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: CLASSNAME
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: FILTER
+ in: query
+ required: false
+ description: FDO filter expression
+ schema:
+ type: string
+ - name: PROPERTIES
+ in: query
+ required: false
+ description: Comma-separated property names to return
+ schema:
+ type: string
+ - name: COMPUTED_PROPERTIES
+ in: query
+ required: false
+ description: Computed property expressions
+ schema:
+ type: string
+ - name: COMPUTED_ALIASES
+ in: query
+ required: false
+ description: Aliases for computed properties
+ schema:
+ type: string
+ - name: TRANSFORMTO
+ in: query
+ required: false
+ description: Target coordinate system code
+ schema:
+ type: string
+ example: LL84
+ - name: PRECISION
+ in: query
+ required: false
+ description: Coordinate precision
+ schema:
+ type: integer
+ default: 7
+ responses:
+ '200':
+ description: Feature data (XML or GeoJSON)
+ content:
+ text/xml:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /SelectAggregates:
+ get:
+ tags: [Feature]
+ summary: Select aggregates (spatial query)
+ description: Performs a spatial feature query and returns aggregated results.
+ operationId: SelectAggregates
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [SELECTAGGREGATES]
+ default: SELECTAGGREGATES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: CLASSNAME
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: FILTER
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ description: WKT geometry for spatial filter
+ schema:
+ type: string
+ - name: GEOMPROPERTY
+ in: query
+ required: true
+ description: Geometry property name
+ schema:
+ type: string
+ - name: SPATIALOP
+ in: query
+ required: true
+ description: Spatial operation
+ schema:
+ type: string
+ enum: [Intersects, Contains, Within, EnvelopeIntersects]
+ - name: OTHERGEOMETRY
+ in: query
+ required: false
+ description: Second WKT geometry for binary spatial operations
+ schema:
+ type: string
+ - name: ACTIVEONLY
+ in: query
+ required: false
+ description: Only return active features
+ schema:
+ type: integer
+ enum: [0, 1]
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetSpatialContexts:
+ get:
+ tags: [Feature]
+ summary: Get spatial contexts
+ description: Returns spatial context information for a feature source.
+ operationId: GetSpatialContexts
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSPATIALCONTEXTS]
+ default: GETSPATIALCONTEXTS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ in: query
+ required: false
+ description: Only return active spatial contexts
+ schema:
+ type: integer
+ enum: [0, 1]
+ responses:
+ '200':
+ '401':
+ /GetLongTransactions:
+ get:
+ tags: [Feature]
+ summary: Get long transactions
+ description: Returns long transaction information for a feature source.
+ operationId: GetLongTransactions
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETLONGTRANSACTIONS]
+ default: GETLONGTRANSACTIONS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ in: query
+ required: false
+ description: Only return active long transactions
+ schema:
+ type: integer
+ enum: [0, 1]
+ responses:
+ '200':
+ '401':
+ /TestConnection:
+ get:
+ tags: [Feature]
+ summary: Test connection
+ description: Tests a feature source connection. Returns "true" or "false" as plain text.
+ operationId: TestConnection
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [TESTCONNECTION]
+ default: TESTCONNECTION
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /EnumerateDataStores:
+ get:
+ tags: [Feature]
+ summary: Enumerate data stores
+ description: Lists available data stores for a provider and connection.
+ operationId: EnumerateDataStores
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEDATASTORES]
+ default: ENUMERATEDATASTORES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetSchemaMapping:
+ get:
+ tags: [Feature]
+ summary: Get schema mapping
+ description: Returns schema mapping information for a provider and connection.
+ operationId: GetSchemaMapping
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSCHEMAMAPPING]
+ default: GETSCHEMAMAPPING
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetSchemas:
+ get:
+ tags: [Feature]
+ summary: Get schemas
+ description: Lists available schemas for a feature source.
+ operationId: GetSchemas
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETSCHEMAS]
+ default: GETSCHEMAS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetClasses:
+ get:
+ tags: [Feature]
+ summary: Get classes
+ description: Lists available feature classes for a schema.
+ operationId: GetClasses
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETCLASSES]
+ default: GETCLASSES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - $ref: '#/components/parameters/Schema'
+ responses:
+ '200':
+ '401':
+ /GetClassDefinition:
+ get:
+ tags: [Feature]
+ summary: Get class definition
+ description: Returns the full class definition for a feature class.
+ operationId: GetClassDefinition
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETCLASSDEFINITION]
+ default: GETCLASSDEFINITION
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - $ref: '#/components/parameters/ClassName'
+ responses:
+ '200':
+ '401':
+ /GetIdentityProperties:
+ get:
+ tags: [Feature]
+ summary: Get identity properties
+ description: Returns identity properties for a feature class.
+ operationId: GetIdentityProperties
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETIDENTITYPROPERTIES]
+ default: GETIDENTITYPROPERTIES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetFdoCacheInfo:
+ get:
+ tags: [Feature]
+ summary: Get FDO cache info
+ description: Returns FDO data cache information.
+ operationId: GetFdoCacheInfo
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETFDOCACHEINFO]
+ default: GETFDOCACHEINFO
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ # DRAWING OPERATIONS
+ /DescribeDrawing:
+ get:
+ tags: [Drawing]
+ summary: Describe drawing
+ description: Returns metadata about a DWF drawing resource.
+ operationId: DescribeDrawing
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [DESCRIBEDRAWING]
+ default: DESCRIBEDRAWING
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ description: Drawing resource ID
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetDrawing:
+ get:
+ tags: [Drawing]
+ summary: Get drawing
+ description: Returns the DWF drawing file.
+ operationId: GetDrawing
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDRAWING]
+ default: GETDRAWING
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ description: DWF drawing file
+ content:
+ application/dwf:
+ schema:
+ type: string
+ format: binary
+ '401':
+ /EnumerateDrawingSections:
+ get:
+ tags: [Drawing]
+ summary: Enumerate drawing sections
+ description: Lists sections within a DWF drawing.
+ operationId: EnumerateDrawingSections
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEDRAWINGSECTIONS]
+ default: ENUMERATEDRAWINGSECTIONS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetDrawingSection:
+ get:
+ tags: [Drawing]
+ summary: Get drawing section
+ description: Returns a specific section from a DWF drawing.
+ operationId: GetDrawingSection
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDRAWINGSECTION]
+ default: GETDRAWINGSECTION
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: SECTION
+ in: query
+ required: true
+ description: Section name
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Drawing section data
+ content:
+ schema:
+ type: string
+ format: binary
+ '401':
+ /EnumerateDrawingSectionResources:
+ get:
+ tags: [Drawing]
+ summary: Enumerate drawing section resources
+ description: Lists resources within a drawing section.
+ operationId: EnumerateDrawingSectionResources
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEDRAWINGSECTIONRESOURCES]
+ default: ENUMERATEDRAWINGSECTIONRESOURCES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: SECTION
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetDrawingSectionResource:
+ get:
+ tags: [Drawing]
+ summary: Get drawing section resource
+ description: Returns a specific resource from a drawing section.
+ operationId: GetDrawingSectionResource
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDRAWINGSECTIONRESOURCE]
+ default: GETDRAWINGSECTIONRESOURCE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: RESOURCENAME
+ in: query
+ required: true
+ description: Section resource name
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Drawing section resource data
+ content:
+ schema:
+ type: string
+ format: binary
+ '401':
+ /EnumerateDrawingLayers:
+ get:
+ tags: [Drawing]
+ summary: Enumerate drawing layers
+ description: Lists layers within a drawing section.
+ operationId: EnumerateDrawingLayers
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEDRAWINGLAYERS]
+ default: ENUMERATEDRAWINGLAYERS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: SECTION
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetDrawingLayer:
+ get:
+ tags: [Drawing]
+ summary: Get drawing layer
+ description: Returns a specific layer from a drawing section.
+ operationId: GetDrawingLayer
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDRAWINGLAYER]
+ default: GETDRAWINGLAYER
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: SECTION
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: LAYER
+ in: query
+ required: true
+ description: Layer name
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Drawing layer data
+ content:
+ schema:
+ type: string
+ format: binary
+ '401':
+ /GetDrawingCoordinateSpace:
+ get:
+ tags: [Drawing]
+ summary: Get drawing coordinate space
+ description: Returns coordinate space information for a drawing.
+ operationId: GetDrawingCoordinateSpace
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDRAWINGCOORDINATESPACE]
+ default: GETDRAWINGCOORDINATESPACE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ # MAPPING OPERATIONS
+ /CreateRuntimeMap:
+ get:
+ tags: [Mapping]
+ summary: Create runtime map
+ description: Creates a runtime map from a map definition with optional layer customization.
+ operationId: CreateRuntimeMap
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CREATERUNTIMEMAP]
+ default: CREATERUNTIMEMAP
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["2.6.0", "3.0.0", "4.0.0"]
+ default: "2.6.0"
+ - $ref: '#/components/parameters/MapDefinition'
+ - name: REQUESTEDFEATURES
+ in: query
+ required: false
+ description: Number of features to request per layer
+ schema:
+ type: integer
+ - name: ICONSPERSCALERANGE
+ in: query
+ required: false
+ description: Maximum icons per scale range
+ schema:
+ type: integer
+ - name: TARGETMAPNAME
+ in: query
+ required: false
+ description: Target name for the runtime map
+ schema:
+ type: string
+ - name: ICONFORMAT
+ in: query
+ required: false
+ description: Icon image format
+ schema:
+ type: string
+ enum: ["PNG", "GIF", "JPG"]
+ - name: ICONWIDTH
+ in: query
+ required: false
+ description: Icon width in pixels
+ schema:
+ type: integer
+ - name: ICONHEIGHT
+ in: query
+ required: false
+ description: Icon height in pixels
+ schema:
+ type: integer
+ responses:
+ '200':
+ '401':
+ /DescribeRuntimeMap:
+ get:
+ tags: [Mapping]
+ summary: Describe runtime map
+ description: Returns the structure and layer information of a runtime map.
+ operationId: DescribeRuntimeMap
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [DESCRIBERUNTIMEMAP]
+ default: DESCRIBERUNTIMEMAP
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "2.6.0"
+ - $ref: '#/components/parameters/MapName'
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: ICONWIDTH
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: integer
+ responses:
+ '200':
+ '401':
+ /GetPlot:
+ get:
+ tags: [Mapping]
+ summary: Get plot (DWF)
+ description: Generates a DWF plot of a map using a specified layout.
+ operationId: GetPlot
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETPLOT]
+ default: GETPLOT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: LAYOUT
+ in: query
+ required: true
+ description: Plot layout resource ID
+ schema:
+ type: string
+ - name: WIDTH
+ in: query
+ required: false
+ description: Plot width
+ schema:
+ type: number
+ - name: HEIGHT
+ in: query
+ required: false
+ description: Plot height
+ schema:
+ type: number
+ - name: UNITS
+ in: query
+ required: false
+ description: Plot units
+ schema:
+ type: string
+ enum: ["mm", "cm", "in"]
+ - name: LAYOUTTITLE
+ in: query
+ required: false
+ description: Layout title
+ schema:
+ type: string
+ - name: LAYOUTUNITTYPE
+ in: query
+ required: false
+ description: Layout unit type
+ schema:
+ type: string
+ - name: MARGINS
+ in: query
+ required: false
+ description: Plot margins
+ schema:
+ type: string
+ responses:
+ '200':
+ description: DWF plot
+ content:
+ application/dwf:
+ schema:
+ type: string
+ format: binary
+ '401':
+ /GetLegendImage:
+ get:
+ tags: [Mapping]
+ summary: Get legend image
+ description: Generates a legend image for a map definition at a given scale.
+ operationId: GetLegendImage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETLEGENDIMAGE]
+ default: GETLEGENDIMAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: SCALE
+ in: query
+ required: true
+ description: Map scale for legend
+ schema:
+ type: number
+ - name: WIDTH
+ in: query
+ required: false
+ description: Legend image width
+ schema:
+ type: integer
+ - name: HEIGHT
+ in: query
+ required: false
+ description: Legend image height
+ schema:
+ type: integer
+ - $ref: '#/components/parameters/ImageFormat'
+ - name: TYPE
+ in: query
+ required: false
+ description: Legend type/style
+ schema:
+ type: string
+ - name: THEMECATEGORY
+ in: query
+ required: false
+ description: Theme category filter
+ schema:
+ type: string
+ responses:
+ '200':
+ $ref: '#/components/responses/ImagePngResponse'
+ '401':
+ /GetFeatureSetEnvelope:
+ get:
+ tags: [Mapping]
+ summary: Get feature set envelope
+ description: Returns the spatial envelope of a feature set.
+ operationId: GetFeatureSetEnvelope
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETFEATURESETENVELOPE]
+ default: GETFEATURESETENVELOPE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: FEATURESET
+ in: query
+ required: true
+ description: Feature set XML
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ # RENDERING OPERATIONS
+ /GetMapImage:
+ get:
+ tags: [Rendering]
+ summary: Get map image
+ description: Renders a map image from a map definition or runtime map with selection, clipping, and viewport.
+ operationId: GetMapImage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETMAPIMAGE]
+ default: GETMAPIMAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["1.0.0", "3.0.0"]
+ default: "1.0.0"
+ - name: KEEPSELECTION
+ in: query
+ required: false
+ description: Keep current selection visible
+ schema:
+ type: integer
+ enum: [0, 1]
+ - name: CLIP
+ in: query
+ required: false
+ description: Clip rendering to selection geometry
+ schema:
+ type: integer
+ enum: [0, 1]
+ - name: SELECTIONCOLOR
+ in: query
+ required: false
+ description: Selection highlight color (hex RRGGBBAA). Only supported for VERSION=3.0.0.
+ schema:
+ type: string
+ - name: SETVIEWCENTERX
+ in: query
+ required: false
+ description: View center X coordinate
+ schema:
+ type: number
+ - name: SETVIEWCENTERY
+ in: query
+ required: false
+ description: View center Y coordinate
+ schema:
+ type: number
+ - name: SETVIEWSCALE
+ in: query
+ required: false
+ description: View scale denominator
+ schema:
+ type: number
+ - name: SETDISPLAYDPI
+ in: query
+ required: false
+ description: Display DPI
+ schema:
+ type: integer
+ default: 96
+ - name: SETDISPLAYWIDTH
+ in: query
+ required: false
+ description: Display width in pixels
+ schema:
+ type: integer
+ - name: SETDISPLAYHEIGHT
+ in: query
+ required: false
+ description: Display height in pixels
+ schema:
+ type: integer
+ - name: SHOWLAYERS
+ in: query
+ required: false
+ description: Comma-separated layer names or IDs to show
+ schema:
+ type: string
+ - name: HIDELAYERS
+ in: query
+ required: false
+ description: Comma-separated layer names or IDs to hide
+ schema:
+ type: string
+ - name: SHOWGROUPS
+ in: query
+ required: false
+ description: Comma-separated group names or IDs to show
+ schema:
+ type: string
+ - name: HIDEGROUPS
+ in: query
+ required: false
+ description: Comma-separated group names or IDs to hide
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetMapLegendImage:
+ get:
+ tags: [Rendering]
+ summary: Get map legend image
+ description: Generates a legend image for a runtime map.
+ operationId: GetMapLegendImage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETMAPLEGENDIMAGE]
+ default: GETMAPLEGENDIMAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: WIDTH
+ in: query
+ required: false
+ schema:
+ type: integer
+ - name: HEIGHT
+ in: query
+ required: false
+ schema:
+ type: integer
+ responses:
+ '200':
+ '401':
+ /GetDynamicMapOverlayImage:
+ get:
+ tags: [Rendering]
+ summary: Get dynamic map overlay image
+ description: Generates a dynamic overlay image with optional layer and attribute filtering.
+ operationId: GetDynamicMapOverlayImage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDYNAMICMAPOVERLAYIMAGE]
+ default: GETDYNAMICMAPOVERLAYIMAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["1.0.0", "2.0.0", "2.1.0"]
+ default: "1.0.0"
+ in: query
+ required: false
+ description: Keep current selection visible. Only supported for VERSION=1.0.0.
+ schema:
+ type: integer
+ enum: [0, 1]
+ - name: BEHAVIOR
+ in: query
+ required: false
+ description: Rendering behavior. Only supported for VERSION=2.0.0 or 2.1.0.
+ schema:
+ type: integer
+ in: query
+ required: false
+ description: Selection highlight color (hex RRGGBBAA). Only supported for VERSION=2.0.0 or 2.1.0.
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: number
+ in: query
+ required: false
+ schema:
+ type: number
+ in: query
+ required: false
+ schema:
+ type: number
+ in: query
+ required: false
+ schema:
+ type: integer
+ default: 96
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /QueryMapFeatures:
+ get:
+ tags: [Rendering]
+ summary: Query map features
+ description: Queries features on a runtime map by layer and spatial/attribute filters.
+ operationId: QueryMapFeatures
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [QUERYMAPFEATURES]
+ default: QUERYMAPFEATURES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["1.0.0", "2.6.0", "4.0.0"]
+ default: "1.0.0"
+ - name: LAYERNAMES
+ in: query
+ required: false
+ description: Comma-separated layer names to query
+ schema:
+ type: string
+ - name: LAYERDEFINITION
+ in: query
+ required: false
+ description: Layer definition resource ID
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: FEATUREFILTER
+ in: query
+ required: false
+ description: Attribute filter expression
+ schema:
+ type: string
+ - name: SELECTIONVARIANT
+ in: query
+ required: false
+ description: Selection rendering variant
+ schema:
+ type: string
+ enum: [NORMAL, HATCH, SOLID]
+ - name: MAXFEATURES
+ in: query
+ required: false
+ description: Maximum features to return
+ schema:
+ type: integer
+ - name: LAYERATTRIBUTEFILTER
+ in: query
+ required: false
+ description: Layer attribute filter
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: PERSIST
+ in: query
+ required: false
+ description: Persist selection to session
+ schema:
+ type: integer
+ enum: [0, 1]
+ - name: REQUESTDATA
+ in: query
+ required: false
+ description: Request map data alongside query results (VERSION >= 2.6.0)
+ schema:
+ type: integer
+ enum: [0, 1]
+ - name: SELECTIONFORMAT
+ in: query
+ required: false
+ description: Selection image format (VERSION >= 2.6.0)
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetVisibleMapExtent:
+ get:
+ tags: [Rendering]
+ summary: Get visible map extent
+ description: Returns the visible extent of a runtime map.
+ operationId: GetVisibleMapExtent
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETVISIBLEMAPEXTENT]
+ default: GETVISIBLEMAPEXTENT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: false
+ schema:
+ type: number
+ in: query
+ required: false
+ schema:
+ type: number
+ in: query
+ required: false
+ schema:
+ type: number
+ in: query
+ required: false
+ schema:
+ type: integer
+ default: 96
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: integer
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ # TILE OPERATIONS
+ /GetTileImage:
+ get:
+ tags: [Tile]
+ summary: Get tile image
+ description: Retrieves a single map tile image by column, row, and scale index.
+ operationId: GetTileImage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETTILEIMAGE]
+ default: GETTILEIMAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["1.0.0", "1.2.0"]
+ default: "1.0.0"
+ - name: BASEMAPLAYERGROUPNAME
+ in: query
+ required: true
+ description: Base map layer group name
+ schema:
+ type: string
+ - name: TILECOL
+ in: query
+ required: true
+ description: Tile column index
+ schema:
+ type: integer
+ - name: TILEROW
+ in: query
+ required: true
+ description: Tile row index
+ schema:
+ type: integer
+ - name: SCALEINDEX
+ in: query
+ required: false
+ description: Scale index (v1.2.0+)
+ schema:
+ type: integer
+ responses:
+ '200':
+ '401':
+ /ClearTileCache:
+ post:
+ tags: [Tile]
+ summary: Clear tile cache
+ description: Clears the tile cache for a map definition.
+ operationId: ClearTileCache
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CLEARTILECACHE]
+ default: CLEARTILECACHE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetTileProviders:
+ get:
+ tags: [Tile]
+ summary: Get tile providers
+ description: Lists available tile providers for a map definition and tile set.
+ operationId: GetTileProviders
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETTILEPROVIDERS]
+ default: GETTILEPROVIDERS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["3.0.0", "4.0.0"]
+ default: "3.0.0"
+ - name: TILESET
+ in: query
+ required: true
+ description: Tile set name
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GetDefaultTileSizeX:
+ get:
+ tags: [Tile]
+ summary: Get default tile size X
+ description: Returns the default tile width for a map definition.
+ operationId: GetDefaultTileSizeX
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDEFAULTTILESIZEX]
+ default: GETDEFAULTTILESIZEX
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /GetDefaultTileSizeY:
+ get:
+ tags: [Tile]
+ summary: Get default tile size Y
+ description: Returns the default tile height for a map definition.
+ operationId: GetDefaultTileSizeY
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDEFAULTTILESIZEY]
+ default: GETDEFAULTTILESIZEY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ # KML OPERATIONS
+ /GetMapKml:
+ get:
+ tags: [KML]
+ summary: Get map KML
+ description: Generates KML output for a map definition within a bounding box.
+ operationId: GetMapKml
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETMAPKML]
+ default: GETMAPKML
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ description: Output format
+ schema:
+ type: string
+ default: "KML"
+ - name: BBOX
+ in: query
+ required: true
+ description: Bounding box (minX,minY,maxX,maxY)
+ schema:
+ type: string
+ - name: WIDTH
+ in: query
+ required: true
+ description: Output width in pixels
+ schema:
+ type: integer
+ - name: HEIGHT
+ in: query
+ required: true
+ description: Output height in pixels
+ schema:
+ type: integer
+ - name: DPI
+ in: query
+ required: false
+ description: Output DPI
+ schema:
+ type: integer
+ default: 96
+ - name: DRAWORDER
+ in: query
+ required: false
+ description: Layer draw order
+ schema:
+ type: string
+ responses:
+ '200':
+ description: KML document
+ content:
+ application/vnd.google-earth.kml+xml:
+ schema:
+ type: string
+ '401':
+ /GetLayerKml:
+ get:
+ tags: [KML]
+ summary: Get layer KML
+ description: Generates KML output for a specific layer definition within a bounding box.
+ operationId: GetLayerKml
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETLAYERKML]
+ default: GETLAYERKML
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: BBOX
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: WIDTH
+ in: query
+ required: true
+ schema:
+ type: integer
+ - name: HEIGHT
+ in: query
+ required: true
+ schema:
+ type: integer
+ - name: DPI
+ in: query
+ required: false
+ schema:
+ type: integer
+ - name: DRAWORDER
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ content:
+ schema:
+ type: string
+ '401':
+ /GetFeaturesKml:
+ get:
+ tags: [KML]
+ summary: Get features KML
+ description: Generates KML output for features in a layer definition within a bounding box.
+ operationId: GetFeaturesKml
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETFEATURESKML]
+ default: GETFEATURESKML
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: BBOX
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: WIDTH
+ in: query
+ required: true
+ schema:
+ type: integer
+ - name: HEIGHT
+ in: query
+ required: true
+ schema:
+ type: integer
+ - name: DPI
+ in: query
+ required: false
+ schema:
+ type: integer
+ - name: DRAWORDER
+ in: query
+ required: false
+ schema:
+ type: string
+ responses:
+ '200':
+ content:
+ schema:
+ type: string
+ '401':
+ # COORDINATE SYSTEM OPERATIONS
+ /CsConvertWktToCoordinateSystemCode:
+ get:
+ tags: [CoordinateSystem]
+ summary: Convert WKT to coordinate system code
+ description: Converts a WKT definition to a CS-Map coordinate system code.
+ operationId: CsConvertWktToCoordinateSystemCode
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.CONVERTWKTTOCOORDINATESYSTEMCODE]
+ default: CS.CONVERTWKTTOCOORDINATESYSTEMCODE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CSWKT
+ in: query
+ required: true
+ description: WKT coordinate system definition
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /CsConvertCoordinateSystemCodeToWkt:
+ get:
+ summary: Convert coordinate system code to WKT
+ description: Converts a CS-Map coordinate system code to its WKT definition.
+ operationId: CsConvertCoordinateSystemCodeToWkt
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.CONVERTCOORDINATESYSTEMCODETOWKT]
+ default: CS.CONVERTCOORDINATESYSTEMCODETOWKT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CSCODE
+ in: query
+ required: true
+ description: CS-Map coordinate system code
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /CsConvertEpsgCodeToWkt:
+ get:
+ summary: Convert EPSG code to WKT
+ description: Converts an EPSG code to its WKT coordinate system definition.
+ operationId: CsConvertEpsgCodeToWkt
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.CONVERTEPSGCODETOWKT]
+ default: CS.CONVERTEPSGCODETOWKT
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CSCODE
+ in: query
+ required: true
+ description: EPSG code
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /CsConvertWktToEpsgCode:
+ get:
+ summary: Convert WKT to EPSG code
+ description: Converts a WKT definition to its EPSG code.
+ operationId: CsConvertWktToEpsgCode
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.CONVERTWKTTOEPSGCODE]
+ default: CS.CONVERTWKTTOEPSGCODE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["1.0.0", "1.2.0", "2.0.0", "2.2.0", "4.0.0"]
+ default: "1.0.0"
+ - name: CSWKT
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /CsEnumerateCategories:
+ get:
+ summary: Enumerate coordinate system categories
+ description: Lists available coordinate system categories.
+ operationId: CsEnumerateCategories
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ description: Operation name
+ schema:
+ type: string
+ enum: [CS.ENUMERATECATEGORIES]
+ default: CS.ENUMERATECATEGORIES
+ - name: VERSION
+ in: query
+ required: true
+ description: API version
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CSCATEGORY
+ in: query
+ required: false
+ description: Parent category to enumerate
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ $ref: '#/components/responses/UnauthorizedError'
+ /CsEnumerateCoordinateSystems:
+ get:
+ summary: Enumerate coordinate systems
+ description: Lists coordinate systems within a category.
+ operationId: CsEnumerateCoordinateSystems
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.ENUMERATECOORDINATESYSTEMS]
+ default: CS.ENUMERATECOORDINATESYSTEMS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - $ref: '#/components/parameters/Session'
+ - $ref: '#/components/parameters/Locale'
+ - $ref: '#/components/parameters/ClientAgent'
+ - $ref: '#/components/parameters/Format'
+ - $ref: "#/components/parameters/Clean"
+ in: query
+ required: true
+ description: Coordinate system category
+ schema:
+ type: string
+ responses:
+ '200':
+ $ref: '#/components/responses/XmlResponse'
+ '401':
+ /CsGetBaseLibrary:
+ get:
+ summary: Get base library
+ description: Returns information about the CS-Map base library.
+ operationId: CsGetBaseLibrary
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.GETBASELIBRARY]
+ default: CS.GETBASELIBRARY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /CsIsValid:
+ get:
+ summary: Validate coordinate system WKT
+ description: Checks whether a WKT coordinate system definition is valid.
+ operationId: CsIsValid
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.ISVALID]
+ default: CS.ISVALID
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ - name: CSWKT
+ in: query
+ required: true
+ description: WKT coordinate system definition to validate
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /CsTransformCoordinates:
+ get:
+ summary: Transform coordinates
+ description: Transforms coordinates from one coordinate system to another.
+ operationId: CsTransformCoordinates
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [CS.TRANSFORMCOORDINATES]
+ default: CS.TRANSFORMCOORDINATES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: SOURCE
+ in: query
+ required: true
+ description: Source coordinate system WKT or code
+ schema:
+ type: string
+ - name: TARGET
+ in: query
+ required: true
+ description: Target coordinate system WKT or code
+ schema:
+ type: string
+ - name: COORDINATES
+ in: query
+ required: true
+ description: Space-separated coordinate pairs (X Y X Y ...)
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ # GEO-PROCESSING OPERATIONS
+ /GeoBoundary:
+ get:
+ tags: [GeoProcessing]
+ summary: Compute boundary
+ description: Computes the boundary of a geometry. Returns WKT or GeoJSON.
+ operationId: GeoBoundary
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.BOUNDARY]
+ default: GEO.BOUNDARY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ enum: ["WKT", "GEOJSON"]
+ default: "WKT"
+ - name: GEOMETRY
+ in: query
+ required: true
+ description: Input WKT geometry
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Geometry result
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoBuffer:
+ get:
+ summary: Compute buffer
+ description: Computes a buffer around a geometry.
+ operationId: GeoBuffer
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.BUFFER]
+ default: GEO.BUFFER
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: BUFFER_DISTANCE
+ in: query
+ required: true
+ description: Buffer distance
+ schema:
+ type: number
+ - name: BUFFER_UNITS
+ in: query
+ required: false
+ description: Buffer distance units
+ schema:
+ type: string
+ responses:
+ '200':
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoBinaryOperation:
+ get:
+ summary: Binary geometry operation
+ description: Performs a binary spatial operation on two geometries.
+ operationId: GeoBinaryOperation
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.BINARYOPERATION]
+ default: GEO.BINARYOPERATION
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ description: First input WKT geometry
+ schema:
+ type: string
+ in: query
+ required: true
+ description: Second input WKT geometry
+ schema:
+ type: string
+ - name: SPATIALOP
+ in: query
+ required: true
+ description: Binary spatial operation
+ schema:
+ type: string
+ enum: [Union, Intersection, Difference, SymmetricDifference]
+ responses:
+ '200':
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoConvexHull:
+ get:
+ summary: Compute convex hull
+ description: Computes the convex hull of a geometry.
+ operationId: GeoConvexHull
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.CONVEXHULL]
+ default: GEO.CONVEXHULL
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoDistance:
+ get:
+ summary: Compute distance
+ description: Computes the distance between two geometries.
+ operationId: GeoDistance
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.DISTANCE]
+ default: GEO.DISTANCE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Distance value
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoGeometryInfo:
+ get:
+ summary: Get geometry info
+ description: Returns geometric information (type, area, length, centroid) for a geometry.
+ operationId: GeoGeometryInfo
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.GEOMETRYINFO]
+ default: GEO.GEOMETRYINFO
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ '401':
+ /GeoSimplify:
+ get:
+ summary: Simplify geometry
+ description: Simplifies a geometry using the Douglas-Peucker algorithm.
+ operationId: GeoSimplify
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.SIMPLIFY]
+ default: GEO.SIMPLIFY
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: TOLERANCE
+ in: query
+ required: true
+ description: Simplification tolerance
+ schema:
+ type: number
+ responses:
+ '200':
+ description: Simplified geometry
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoSpatialPredicate:
+ get:
+ summary: Spatial predicate test
+ description: Tests a spatial relationship between two geometries.
+ operationId: GeoSpatialPredicate
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.SPATIALPREDICATE]
+ default: GEO.SPATIALPREDICATE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ in: query
+ required: true
+ schema:
+ type: string
+ - name: SPATIALOP
+ in: query
+ required: true
+ description: Spatial predicate to test
+ schema:
+ type: string
+ enum: [Intersects, Contains, Within, Crosses, Touches, Overlaps, Disjoint, Equals]
+ responses:
+ '200':
+ description: Boolean result
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ /GeoTessellate:
+ get:
+ summary: Tessellate geometry
+ description: Tessellates a geometry into triangles.
+ operationId: GeoTessellate
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GEO.TESSELLATE]
+ default: GEO.TESSELLATE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: ["4.0.0"]
+ default: "4.0.0"
+ - name: FORMAT
+ in: query
+ required: false
+ schema:
+ type: string
+ - name: GEOMETRY
+ in: query
+ required: true
+ schema:
+ type: string
+ responses:
+ '200':
+ description: Tessellated geometry
+ content:
+ text/plain:
+ schema:
+ type: string
+ application/json:
+ schema:
+ type: object
+ '401':
+ # WEB APPLICATION OPERATIONS
+ /EnumerateApplicationTemplates:
+ get:
+ tags: [WebApplication]
+ summary: Enumerate application templates
+ description: Lists available web application templates.
+ operationId: EnumerateApplicationTemplates
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEAPPLICATIONTEMPLATES]
+ default: ENUMERATEAPPLICATIONTEMPLATES
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /EnumerateApplicationWidgets:
+ get:
+ summary: Enumerate application widgets
+ description: Lists available web application widgets.
+ operationId: EnumerateApplicationWidgets
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEAPPLICATIONWIDGETS]
+ default: ENUMERATEAPPLICATIONWIDGETS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ /EnumerateApplicationContainers:
+ get:
+ summary: Enumerate application containers
+ description: Lists available web application containers.
+ operationId: EnumerateApplicationContainers
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [ENUMERATEAPPLICATIONCONTAINERS]
+ default: ENUMERATEAPPLICATIONCONTAINERS
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
+ # VIEWER PAGE OPERATIONS
+ /GetDwfViewerPage:
+ get:
+ tags: [Rendering]
+ summary: Get DWF viewer page
+ description: Returns the HTML page for launching the DWF viewer.
+ operationId: GetDwfViewerPage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETDWFVIEWERPAGE]
+ default: GETDWFVIEWERPAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ $ref: '#/components/responses/HtmlResponse'
+ '401':
+ /GetHtmlViewerPage:
+ get:
+ tags: [Rendering]
+ summary: Get AJAX viewer page
+ description: Returns the HTML page for launching the AJAX viewer.
+ operationId: GetHtmlViewerPage
+ security:
+ - SessionAuth: []
+ - BasicAuth: []
+ parameters:
+ - name: OPERATION
+ in: query
+ required: true
+ schema:
+ type: string
+ enum: [GETHTMLVIEWERPAGE]
+ default: GETHTMLVIEWERPAGE
+ - name: VERSION
+ in: query
+ required: true
+ schema:
+ type: string
+ default: "1.0.0"
+ responses:
+ '200':
+ '401':
Added: branches/4.0/MgDev/Web/src/openapi/swagger.html
--- branches/4.0/MgDev/Web/src/openapi/swagger.html (rev 0)
+++ branches/4.0/MgDev/Web/src/openapi/swagger.html 2026-11-05 03:55:47 UTC (rev 10268)
@@ -0,0 +1,45 @@
+<!DOCTYPE html>
+<html lang="en">
+<head>
+ <meta charset="UTF-8">
+ <meta name="viewport" content="width=device-width, initial-scale=1.0">
+ <title>MapGuide MapAgent API — Swagger UI</title>
+ <link rel="stylesheet" href="https://unpkg.com/swagger-ui-dist@5/swagger-ui.css">
+ <style>
+ html { box-sizing: border-box; overflow: -moz-scrollbars-vertical; overflow-y: scroll; }
+ *, *:before, *:after { box-sizing: inherit; }
+ body { margin: 0; background: #fafafa; }
+ #swagger-ui .topbar { background-color: #1b6ec2; }
+ #swagger-ui .topbar .wrapper { max-width: 100%; padding: 0 20px; }
+ #swagger-ui .topbar .download-url-wrapper { display: flex; align-items: center; }
+ #swagger-ui .info .title { font-size: 28px; }
+ </style>
+</head>
+<body>
+ <div id="swagger-ui"></div>
+ <script src="https://unpkg.com/swagger-ui-dist@5/swagger-ui-bundle.js" crossorigin></script>
+ <script src="https://unpkg.com/swagger-ui-dist@5/swagger-ui-standalone-preset.js" crossorigin></script>
+ <script>
+ window.onload = function () {
+ SwaggerUIBundle({
+ url: "./openapi.yaml",
+ dom_id: "#swagger-ui",
+ deepLinking: true,
+ presets: [SwaggerUIBundle.presets.apis, SwaggerUIStandalonePreset],
+ plugins: [SwaggerUIBundle.plugins.DownloadUrl],
+ layout: "StandaloneLayout",
+ defaultModelsExpandDepth: -1,
+ defaultModelExpandDepth: 2,
+ docExpansion: "list",
+ filter: true,
+ showExtensions: true,
+ showCommonExtensions: true,
+ tryItOutEnabled: true,
+ supportedSubmitMethods: ["get", "post"],
+ validatorUrl: null
+ </script>
+</body>
+</html>
More information about the mapguide-commits
