[mapguide-commits] r10269 - branches/4.0/MgDev/Web/src/openapi
svn_mapguide at osgeo.org
Thu Nov 5 05:01:48 PST 2026
Author: jng
Date: 2026-11-05 05:01:46 -0800 (Thu, 05 Nov 2026)
New Revision: 10269
branches/4.0/MgDev/Web/src/openapi/openapi.yaml
#2899: Correct the MapAgent OpenAPI spec against the live agent
- Drop the trailing '#' from the server URL. It put the path segment and the entire query string
into the URI fragment, which is never transmitted, so a generated client sent a bare
mapagent.fcgi with no OPERATION parameter at all.
- Describe the error responses the agent actually emits: 401 with a WWW-Authenticate challenge and
a text/plain body, and the non-standard 559 (HTTP_STATUS_MG_ERROR) with a text/html body carrying
the exception code in the status line. Every operation now declares 559, and the never-emitted
BadRequestError component is gone.
- GetLegendImage takes LAYERDEFINITION, not MAPDEFINITION: HttpGetLegendImage reads
reqMappingLayerDefinition, and the map definition id only produces
559 MgInvalidRepositoryTypeException.
- ApplyResourcePackage declares OPERATION and VERSION only in its multipart body. A POST is parsed
from the body alone, so the query copies were both wrong and harmful: OpenAPI Generator emitted
two OPERATION enums for the operation, which does not compile.
- ImageResponse covers the PNG/GIF/JPEG/TIFF binaries that FORMAT can select, instead of describing
PNG only.
- Remove EnumerateRepositories. The agent has no dispatch-table entry for ENUMERATEREPOSITORIES, so
the operation cannot succeed; the spec should not advertise it.
Validated with redocly lint and with clients generated by Kiota (C#) and OpenAPI Generator
(TypeScript and Java), each run against a live MapGuide server: GetMapImage returns real
PNG/GIF/JPEG streams, and the 401 and 559 shapes are asserted on the wire as well as through the
generated clients.
Modified: branches/4.0/MgDev/Web/src/openapi/openapi.yaml
--- branches/4.0/MgDev/Web/src/openapi/openapi.yaml 2026-11-05 03:55:47 UTC (rev 10268)
+++ branches/4.0/MgDev/Web/src/openapi/openapi.yaml 2026-11-05 13:01:46 UTC (rev 10269)
@@ -25,8 +25,12 @@
url: https://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
servers:
- - url: /mapguide/mapagent/mapagent.fcgi#
- description: Single MapAgent FastCGI endpoint (fragment is stripped by all HTTP clients)
+ - url: /mapguide/mapagent/mapagent.fcgi
+ description: |
+ MapAgent FastCGI endpoint. Every operation is dispatched by the OPERATION query
+ parameter; the trailing path segment (e.g. /GetMapImage) is request-routing decoration
+ that the MapAgent ignores (it reads only QUERY_STRING and the POST body). Clients should
+ set an absolute base URL such as http://localhost:8018/mapguide/mapagent/mapagent.fcgi.
tags:
- name: Session
@@ -131,6 +135,14 @@
schema:
type: string
example: "Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition"
+ LayerDefinition:
+ name: LAYERDEFINITION
+ in: query
+ required: true
+ description: Layer definition resource path to render the legend for
+ schema:
+ type: string
+ example: "Library://Samples/Sheboygan/Layers/Soils.LayerDefinition"
MapName:
in: query
@@ -186,13 +198,29 @@
text/plain:
schema:
type: string
- ImagePngResponse:
- description: PNG image
+ ImageResponse:
+ description: |
+ Rendered image stream. The concrete media type follows the request's FORMAT
+ parameter: PNG and PNG8 produce image/png, GIF produces image/gif, JPG produces
+ image/jpeg, and TIFF produces image/tiff. Clients should treat the body as a
+ binary stream and rely on the response Content-Type header.
content:
image/png:
schema:
type: string
format: binary
+ image/gif:
+ schema:
+ type: string
+ format: binary
+ image/jpeg:
+ schema:
+ type: string
+ format: binary
+ image/tiff:
+ schema:
+ type: string
+ format: binary
HtmlResponse:
description: HTML page
content:
@@ -202,13 +230,38 @@
EmptyResponse:
description: Operation completed successfully (no content)
UnauthorizedError:
- description: Authentication required
+ description: |
+ Authentication required or credentials rejected. The agent writes
+ `Status: 401 Unauthorized` together with a `WWW-Authenticate: Basic` challenge for
+ the MapGuide product realm and a short plain-text body. It emits this challenge
+ rather than the 559 error page when no SESSION/USERNAME credential is supplied,
+ and whenever an MgAuthenticationFailedException or MgUnauthorizedAccessException
+ is raised.
+ headers:
+ WWW-Authenticate:
+ description: Basic authentication challenge for the MapGuide realm.
+ schema:
+ type: string
+ example: 'Basic realm="MapGuide"'
content:
- text/xml:
+ text/plain:
schema:
type: string
- BadRequestError:
- description: Invalid request parameters
+ example: You must enter a valid login ID and password to access this site
+ MapAgentError:
+ description: |
+ MapGuide exception. Handler failures are returned with the non-standard status
+ code 559 (HTTP_STATUS_MG_ERROR), whose status line carries the MapGuide exception
+ code, for example `Status: 559 MgInvalidArgumentException`. The body is an HTML
+ page: the exception message is the heading and the detailed message follows it.
+ There is no 4xx/5xx distinction -- malformed parameters, missing resources and
+ provider failures all surface this way. The only other error status is 401 for
+ authentication (see UnauthorizedError); a 500 here means the agent could not
+ extract the exception details at all.
+ content:
+ text/html:
+ schema:
+ type: string
paths:
@@ -263,6 +316,8 @@
$ref: '#/components/responses/TextResponse'
'401':
$ref: '#/components/responses/UnauthorizedError'
+ '559':
+ $ref: '#/components/responses/MapAgentError'
/GetSessionTimeout:
get:
@@ -300,6 +355,8 @@
$ref: '#/components/responses/XmlResponse'
'401':
+ '559':
# SITE OPERATIONS
@@ -341,6 +398,8 @@
'401':
+ '559':
/GetSiteInfo:
get:
@@ -378,6 +437,8 @@
'401':
+ '559':
/GetSiteStatus:
get:
@@ -410,6 +471,8 @@
responses:
'200':
+ '559':
/EnumerateUsers:
get:
@@ -453,6 +516,8 @@
'401':
+ '559':
/EnumerateGroups:
get:
@@ -490,54 +555,13 @@
'401':
+ '559':
# RESOURCE OPERATIONS — Repositories
- /EnumerateRepositories:
- get:
- tags: [Resource]
- summary: Enumerate repositories
- description: Lists available repositories, optionally filtered by type.
- operationId: EnumerateRepositories
- security:
- - SessionAuth: []
- - BasicAuth: []
- parameters:
- - name: OPERATION
- in: query
- required: true
- description: Operation name
- schema:
- type: string
- enum: [ENUMERATEREPOSITORIES]
- default: ENUMERATEREPOSITORIES
- - name: VERSION
- in: query
- required: true
- description: API version
- schema:
- type: string
- enum: ["1.0.0", "1.2.0", "2.0.0", "2.2.0", "4.0.0"]
- default: "1.0.0"
- - $ref: '#/components/parameters/Session'
- - $ref: '#/components/parameters/Locale'
- - $ref: '#/components/parameters/ClientAgent'
- - $ref: '#/components/parameters/Format'
- - $ref: "#/components/parameters/Clean"
- - name: TYPE
- in: query
- required: false
- description: Repository type filter
- schema:
- type: string
- responses:
- '200':
- $ref: '#/components/responses/XmlResponse'
- '401':
- $ref: '#/components/responses/UnauthorizedError'
/CreateRepository:
post:
tags: [Resource]
@@ -579,6 +603,8 @@
$ref: '#/components/responses/EmptyResponse'
'401':
+ '559':
/DeleteRepository:
post:
@@ -615,6 +641,8 @@
'401':
+ '559':
/UpdateRepository:
post:
@@ -663,6 +691,8 @@
'401':
+ '559':
/GetRepositoryContent:
get:
@@ -701,6 +731,8 @@
'401':
+ '559':
/GetRepositoryHeader:
get:
@@ -739,6 +771,8 @@
'401':
+ '559':
# RESOURCE OPERATIONS — Resources
@@ -813,6 +847,8 @@
'401':
+ '559':
/ResourceExists:
get:
@@ -849,6 +885,8 @@
'401':
+ '559':
/SetResource:
post:
@@ -897,6 +935,8 @@
'401':
+ '559':
/DeleteResource:
post:
@@ -933,6 +973,8 @@
'401':
+ '559':
/MoveResource:
post:
@@ -996,6 +1038,8 @@
'401':
+ '559':
/CopyResource:
post:
@@ -1051,6 +1095,8 @@
'401':
+ '559':
/GetResourceContent:
get:
@@ -1089,6 +1135,8 @@
'401':
+ '559':
/GetResourceHeader:
get:
@@ -1127,6 +1175,8 @@
'401':
+ '559':
/EnumerateResourceReferences:
get:
@@ -1165,6 +1215,8 @@
'401':
+ '559':
/ChangeResourceOwner:
post:
@@ -1215,6 +1267,8 @@
'401':
+ '559':
/InheritPermissionsFrom:
post:
@@ -1262,6 +1316,8 @@
'401':
+ '559':
# RESOURCE OPERATIONS — Resource Data
@@ -1304,6 +1360,8 @@
'401':
+ '559':
/SetResourceData:
post:
@@ -1364,6 +1422,8 @@
'401':
+ '559':
/DeleteResourceData:
post:
@@ -1406,6 +1466,8 @@
'401':
+ '559':
/RenameResourceData:
post:
@@ -1462,6 +1524,8 @@
'401':
+ '559':
/GetResourceData:
get:
@@ -1509,6 +1573,8 @@
format: binary
'401':
+ '559':
/EnumerateUnmanagedData:
get:
@@ -1573,6 +1639,8 @@
'401':
+ '559':
# RESOURCE OPERATIONS — Packages
@@ -1587,25 +1655,10 @@
security:
- SessionAuth: []
- BasicAuth: []
- parameters:
- - name: OPERATION
- in: query
- required: true
- schema:
- type: string
- enum: [APPLYRESOURCEPACKAGE]
- default: APPLYRESOURCEPACKAGE
- - name: VERSION
- in: query
- required: true
- schema:
- type: string
- default: "1.0.0"
+ # No query parameters: for a POST the mapagent parses only the request body
+ # (ApacheAgent.cpp), so OPERATION, VERSION and the credentials travel as multipart form
+ # fields. Declaring them here as well would both misdescribe the agent and make generated
+ # clients emit two OPERATION enums for this operation, which does not compile.
requestBody:
required: true
content:
@@ -1648,6 +1701,8 @@
'401':
+ '559':
# FEATURE OPERATIONS
@@ -1689,6 +1744,8 @@
'401':
+ '559':
/GetProviderCapabilities:
get:
@@ -1728,6 +1785,8 @@
'401':
+ '559':
/GetConnectionPropertyValues:
get:
@@ -1774,6 +1833,8 @@
'401':
+ '559':
/DescribeFeatureSchema:
get:
@@ -1836,6 +1897,8 @@
'401':
+ '559':
/SelectFeatures:
get:
@@ -1936,6 +1999,8 @@
type: object
'401':
+ '559':
/SelectAggregates:
get:
@@ -2034,6 +2099,8 @@
'401':
+ '559':
/GetSpatialContexts:
get:
@@ -2084,6 +2151,8 @@
'401':
+ '559':
/GetLongTransactions:
get:
@@ -2134,6 +2203,8 @@
'401':
+ '559':
/TestConnection:
get:
@@ -2177,6 +2248,8 @@
'401':
+ '559':
/EnumerateDataStores:
get:
@@ -2222,6 +2295,8 @@
'401':
+ '559':
/GetSchemaMapping:
get:
@@ -2261,6 +2336,8 @@
'401':
+ '559':
/GetSchemas:
get:
@@ -2304,6 +2381,8 @@
'401':
+ '559':
/GetClasses:
get:
@@ -2348,6 +2427,8 @@
'401':
+ '559':
/GetClassDefinition:
get:
@@ -2393,6 +2474,8 @@
'401':
+ '559':
/GetIdentityProperties:
get:
@@ -2438,6 +2521,8 @@
'401':
+ '559':
/GetFdoCacheInfo:
get:
@@ -2475,6 +2560,8 @@
'401':
+ '559':
# DRAWING OPERATIONS
@@ -2522,6 +2609,8 @@
'401':
+ '559':
/GetDrawing:
get:
@@ -2568,6 +2657,8 @@
format: binary
'401':
+ '559':
/EnumerateDrawingSections:
get:
@@ -2611,6 +2702,8 @@
'401':
+ '559':
/GetDrawingSection:
get:
@@ -2663,6 +2756,8 @@
format: binary
'401':
+ '559':
/EnumerateDrawingSectionResources:
get:
@@ -2712,6 +2807,8 @@
'401':
+ '559':
/GetDrawingSectionResource:
get:
@@ -2764,6 +2861,8 @@
format: binary
'401':
+ '559':
/EnumerateDrawingLayers:
get:
@@ -2813,6 +2912,8 @@
'401':
+ '559':
/GetDrawingLayer:
get:
@@ -2871,6 +2972,8 @@
format: binary
'401':
+ '559':
/GetDrawingCoordinateSpace:
get:
@@ -2914,6 +3017,8 @@
'401':
+ '559':
# MAPPING OPERATIONS
@@ -2992,6 +3097,8 @@
'401':
+ '559':
/DescribeRuntimeMap:
get:
@@ -3060,6 +3167,8 @@
'401':
+ '559':
/GetPlot:
get:
@@ -3145,12 +3254,14 @@
format: binary
'401':
+ '559':
/GetLegendImage:
get:
tags: [Mapping]
summary: Get legend image
- description: Generates a legend image for a map definition at a given scale.
+ description: Generates a legend image for a layer definition at a given scale.
operationId: GetLegendImage
security:
- SessionAuth: []
@@ -3175,7 +3286,7 @@
- - $ref: '#/components/parameters/MapDefinition'
+ - $ref: '#/components/parameters/LayerDefinition'
- name: SCALE
in: query
required: true
@@ -3209,9 +3320,11 @@
type: string
responses:
'200':
- $ref: '#/components/responses/ImagePngResponse'
+ $ref: '#/components/responses/ImageResponse'
'401':
+ '559':
/GetFeatureSetEnvelope:
get:
@@ -3255,6 +3368,8 @@
'401':
+ '559':
# RENDERING OPERATIONS
@@ -3375,9 +3490,11 @@
type: string
responses:
'200':
'401':
+ '559':
/GetMapLegendImage:
get:
@@ -3424,9 +3541,11 @@
type: integer
responses:
'200':
'401':
+ '559':
/GetDynamicMapOverlayImage:
get:
@@ -3541,9 +3660,11 @@
type: string
responses:
'200':
'401':
+ '559':
/QueryMapFeatures:
get:
@@ -3650,6 +3771,8 @@
'401':
+ '559':
/GetVisibleMapExtent:
get:
@@ -3748,6 +3871,8 @@
'401':
+ '559':
# TILE OPERATIONS
@@ -3810,9 +3935,11 @@
type: integer
responses:
'200':
'401':
+ '559':
/ClearTileCache:
post:
@@ -3849,6 +3976,8 @@
'401':
+ '559':
/GetTileProviders:
get:
@@ -3894,6 +4023,8 @@
'401':
+ '559':
/GetDefaultTileSizeX:
get:
@@ -3933,6 +4064,8 @@
'401':
+ '559':
/GetDefaultTileSizeY:
get:
@@ -3972,6 +4105,8 @@
'401':
+ '559':
# KML OPERATIONS
@@ -4054,6 +4189,8 @@
type: string
'401':
+ '559':
/GetLayerKml:
get:
@@ -4125,6 +4262,8 @@
type: string
'401':
+ '559':
/GetFeaturesKml:
get:
@@ -4195,6 +4334,8 @@
type: string
'401':
+ '559':
# COORDINATE SYSTEM OPERATIONS
@@ -4242,6 +4383,8 @@
'401':
+ '559':
/CsConvertCoordinateSystemCodeToWkt:
get:
@@ -4285,6 +4428,8 @@
'401':
+ '559':
/CsConvertEpsgCodeToWkt:
get:
@@ -4328,6 +4473,8 @@
'401':
+ '559':
/CsConvertWktToEpsgCode:
get:
@@ -4371,6 +4518,8 @@
'401':
+ '559':
/CsEnumerateCategories:
get:
@@ -4414,6 +4563,8 @@
'401':
+ '559':
/CsEnumerateCoordinateSystems:
get:
@@ -4457,6 +4608,8 @@
'401':
+ '559':
/CsGetBaseLibrary:
get:
@@ -4494,6 +4647,8 @@
'401':
+ '559':
/CsIsValid:
get:
@@ -4537,6 +4692,8 @@
'401':
+ '559':
/CsTransformCoordinates:
get:
@@ -4593,6 +4750,8 @@
'401':
+ '559':
# GEO-PROCESSING OPERATIONS
@@ -4654,6 +4813,8 @@
type: object
'401':
+ '559':
/GeoBuffer:
get:
@@ -4721,6 +4882,8 @@
type: object
'401':
+ '559':
/GeoBinaryOperation:
get:
@@ -4789,6 +4952,8 @@
type: object
'401':
+ '559':
/GeoConvexHull:
get:
@@ -4844,6 +5009,8 @@
type: object
'401':
+ '559':
/GeoDistance:
get:
@@ -4905,6 +5072,8 @@
type: object
'401':
+ '559':
/GeoGeometryInfo:
get:
@@ -4953,6 +5122,8 @@
'401':
+ '559':
/GeoSimplify:
get:
@@ -5014,6 +5185,8 @@
type: object
'401':
+ '559':
/GeoSpatialPredicate:
get:
@@ -5082,6 +5255,8 @@
type: object
'401':
+ '559':
/GeoTessellate:
get:
@@ -5137,6 +5312,8 @@
type: object
'401':
+ '559':
# WEB APPLICATION OPERATIONS
@@ -5178,6 +5355,8 @@
'401':
+ '559':
/EnumerateApplicationWidgets:
get:
@@ -5215,6 +5394,8 @@
'401':
+ '559':
/EnumerateApplicationContainers:
get:
@@ -5252,6 +5433,8 @@
'401':
+ '559':
# VIEWER PAGE OPERATIONS
@@ -5292,6 +5475,8 @@
$ref: '#/components/responses/HtmlResponse'
'401':
+ '559':
/GetHtmlViewerPage:
get:
@@ -5328,6 +5513,8 @@
'401':
+ '559':
More information about the mapguide-commits
