[mapguide-commits] r10289 - in branches/4.0/MgDev: Doc/samples/dotnetsamples/analyzing_features Doc/samples/dotnetsamples/common Doc/samples/dotnetsamples/custom_output Doc/samples/dotnetsamples/digitizing_features Doc/samples/dotnetsamples/hello_map Doc/samples/dotnetsamples/hello_viewer Doc/samples/dotnetsamples/interacting_with_layers Doc/samples/dotnetsamples/modifying_maps_and_layers Doc/samples/dotnetsamples/working_with_feature_data Doc/samples/javasamples/common Doc/samples/javasamples/hello_map Doc/samples/javasamples/hello_viewer Doc/samples/javasamples/interacting_with_layers Doc/samples/phpsamples/analyzing_features Doc/samples/phpsamples/common Doc/samples/phpsamples/custom_output Doc/samples/phpsamples/digitizing_features Doc/samples/phpsamples/hello_map Doc/samples/phpsamples/hello_viewer Doc/samples/phpsamples/interacting_with_layers Doc/samples/phpsamples/modifying_maps_and_layers Doc/samples/phpsamples/working_with_feature_data Web/src/mapviewernet
svn_mapguide at osgeo.org
Sun Nov 15 01:20:32 PST 2026
Author: jng
Date: 2026-11-15 01:20:29 -0800 (Sun, 15 Nov 2026)
New Revision: 10289
branches/4.0/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/common/viewsource.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/digitizing_features/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_map/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_viewer/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/toggle_roads_label.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/listselection.aspx
branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx
branches/4.0/MgDev/Doc/samples/javasamples/common/viewsource.php
branches/4.0/MgDev/Doc/samples/javasamples/hello_map/task_pane.jsp
branches/4.0/MgDev/Doc/samples/javasamples/hello_viewer/task_pane.jsp
branches/4.0/MgDev/Doc/samples/javasamples/interacting_with_layers/task_pane.jsp
branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php
branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php
branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/common/viewsource.php
branches/4.0/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php
branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php
branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php
branches/4.0/MgDev/Web/src/mapviewernet/common.aspx
#2901: Fix the path traversal in the sample "view source" pages, and link to them relatively
The FILENAME parameter of the samples' "view source" pages went straight to the
filesystem and its contents were echoed back, so viewsource.aspx?FILENAME=C:\Windows\win.ini
or viewsource.php?FILENAME=/etc/passwd returned the file. No session or resource
permission is needed - the file is read before any MapGuide API is opened - and all
three pages are shipped (the ASP.NET one in the Windows installer, both PHP ones in the
Linux web-tier tarballs), so this is reachable on any deployment that installs them.
The PHP pages additionally handed FILENAME to file_get_contents(), which accepts a URL,
so the same parameter also made the server fetch a remote resource and echo it.
r10288 closed this class in the shipped viewers (Web/src) but did not cover Doc/samples,
which is where these pages live.
FILENAME is now a path relative to the samples tree the page belongs to
("hello_map/task_pane.aspx"), which also stops the samples from putting a server
directory in the HTML - and from breaking outright on a default Windows install, where
an unencoded C:\Program Files\... in the query string was truncated at the space.
Each sample page derives its own directory name from the request
(Path.GetFileName(Path.GetDirectoryName(Request.PhysicalPath)), basename(dirname(__FILE__)),
File.getParentFile().getName()), and the "view source" page resolves the name against the
samples root and requires the result to stay inside it: Path.GetFullPath() plus a prefix
test in ASP.NET, realpath() plus strncmp in PHP. A rooted name - a leading separator or a
drive:/scheme: prefix - is rejected outright, realpath() also rejects a URL and a name
that does not exist, and the PHP pages answer 403. Both pages HTML-encode the name they
echo, where it was previously reflected raw.
Also fixes interacting_with_layers/task_pane.aspx, which used a <?php tag in an .aspx
block, so its source-link line was printed as text and the second link named the previous
file.
Also corrects the .NET AJAX viewer guard from r10288, which required the template path to
stay under APPL_PHYSICAL_PATH: the viewer's templates are ../viewerfiles/*.templ and
../localized/help/..., i.e. beside the mapviewernet application rather than under it, so
every page failed with "Page is outside the application directory". The same check now
holds the path inside the web root instead.
The samples also used typed catches for MgLayerNotFoundException and
MgObjectNotFoundException, although the current API exposes one MgException and its
exception code. The .NET layer-label sample now classifies those codes with
GetExceptionCode(), and the legacy PHP snippets in createbuffer.php and
selectfeaturesinbuffer.php do the same while rethrowing other codes. A sample-wide
search found no remaining typed catches of MapGuide exception subclasses.
Verified: the PHP view-source endpoints were syntax-checked and exercised via a PHP CLI
over a www/phpsamples layout: they read hello_map/task_pane.php and main.php and answer
403 for ../ escapes, /etc/passwd, C:\Windows\win.ini, a URL and an empty value. The
ASP.NET SamplePath/ResolveSourceFile pair compiled and round-tripped over a
www/dotnetsamples layout. PHP lint was unavailable for the final working copy; the
latest PHP edits are in commented legacy snippets.
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -17,10 +17,18 @@
<%@ Page language="c#" %>
<%@ Import Namespace="System" %>
+<%@ Import Namespace="System.IO" %>
<script runat="server">
String sessionId;
String mapName;
String fullPath;
+// A "view source" link names a file by its path relative to the samples root, so what reaches
+// the browser never contains a physical path on the server.
+String SamplePath(String fileName)
+ return Path.GetFileName(Path.GetDirectoryName(Request.PhysicalPath)) + "/" + fileName;
</script>
<html>
<head>
@@ -65,7 +73,7 @@
<br/>Create a buffer around a selected parcel.
<br/>
- fullPath = Server.MapPath("createbuffer.aspx");
+ fullPath = SamplePath("createbuffer.aspx");
<a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >View source</a>
</li>
@@ -77,7 +85,7 @@
of type "MFG".
<br/>
- fullPath = Server.MapPath("selectfeaturesinbuffer.aspx");
+ fullPath = SamplePath("selectfeaturesinbuffer.aspx");
</li>
@@ -86,10 +94,10 @@
<p>View source for support files:</p>
- fullPath = Server.MapPath("task_pane.aspx");
- String fullPath2 = Server.MapPath("bufferfunctions.aspx");
- String fullPath3 = Server.MapPath("bufferlayerdefinition.xml");
- String fullPath4 = Server.MapPath("parcelmarker.xml");
+ fullPath = SamplePath("task_pane.aspx");
+ String fullPath2 = SamplePath("bufferfunctions.aspx");
+ String fullPath3 = SamplePath("bufferlayerdefinition.xml");
+ String fullPath4 = SamplePath("parcelmarker.xml");
<ul>
<li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>">task_pane.aspx</a></li>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/common/viewsource.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/common/viewsource.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/common/viewsource.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -22,19 +22,47 @@
<%@ Import Namespace="OSGeo.MapGuide" %>
String sourceFile;
+String sourcePath;
String fileContents;
+// The samples link here with a file path relative to the samples root, which is the directory
+// above this page's own: "hello_map/task_pane.aspx", never a physical path. Resolve the name
+// against that root and require the result to stay there, so neither an absolute path nor a
+// traversal sequence can name a file outside the samples.
+String ResolveSourceFile(HttpRequest request, String fileName)
+ if(fileName == null || fileName.Length == 0)
+ throw new FileNotFoundException("No FILENAME was given");
+ String pageDir = Path.GetDirectoryName(Path.GetFullPath(request.PhysicalPath));
+ String samplesRoot = Path.GetFullPath(Path.Combine(pageDir, ".."));
+ String samplesRootPrefix = samplesRoot.EndsWith(Path.DirectorySeparatorChar.ToString()) ? samplesRoot : samplesRoot + Path.DirectorySeparatorChar;
+ if(Path.IsPathRooted(fileName))
+ throw new FileNotFoundException("FILENAME must be relative to the samples directory", fileName);
+ String full = Path.GetFullPath(Path.Combine(samplesRoot, fileName));
+ if(!full.StartsWith(samplesRootPrefix, StringComparison.OrdinalIgnoreCase))
+ throw new FileNotFoundException("File is outside the samples directory", fileName);
+ return full;
</script>
- sourceFile = Request.Params["FILENAME"];
- fileContents = HttpUtility.HtmlEncode(File.ReadAllText(sourceFile));
+ sourcePath = Request.Params["FILENAME"];
+ sourceFile = ResolveSourceFile(Request, sourcePath);
+ fileContents = HttpUtility.HtmlEncode(File.ReadAllText(sourceFile));
<html>
<head>
- <title>Source of <%= Path.GetFileName(sourceFile) %></title>
+ <title>Source of <%= HttpUtility.HtmlEncode(Path.GetFileName(sourceFile)) %></title>
</head>
<body>
- <p><strong><%= sourceFile %></strong></p>
+ <p><strong><%= HttpUtility.HtmlEncode(sourcePath) %></strong></p>
<pre style="background-color: #f8f8f8; padding: 10px; border: 2px solid black">
<code><%= fileContents %>
</code>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -17,10 +17,18 @@
String sessionId;
String mapName;
String fullPath;
</script>
<html>
<head>
@@ -70,7 +78,7 @@
<br/>Create a printable page with an inset image of the selected property.
<br/>
- fullPath = Server.MapPath("property_report.aspx");
+ fullPath = SamplePath("property_report.aspx");
</li>
@@ -81,7 +89,7 @@
<br/>Create and display an ePlot. Requires Autodesk DWF Viewer or Autodesk Design Review on the client system.
<br/>
- fullPath = Server.MapPath("eplot.aspx");
+ fullPath = SamplePath("eplot.aspx");
</li>
@@ -92,7 +100,7 @@
<br/>Create and display a multi-plot ePlot. Requires Autodesk DWF Viewer or Autodesk Design Review on the client system.
<br/>
- fullPath = Server.MapPath("multiplot.aspx");
+ fullPath = SamplePath("multiplot.aspx");
</li>
@@ -102,11 +110,11 @@
<ul>
- fullPath = Server.MapPath("createmapimage.aspx");
+ fullPath = SamplePath("createmapimage.aspx");
<li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >createmapimage.aspx</a></li>
<li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >task_pane.aspx</a></li>
</ul>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/digitizing_features/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/digitizing_features/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/digitizing_features/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -26,6 +26,13 @@
String sessionId;
String mapName;
String fullPath;
</script>
<html>
<head>
@@ -49,7 +56,7 @@
<br/>Show digitizing functions.
<br/>
- fullPath = Server.MapPath("task_pane_digitizing.aspx");
+ fullPath = SamplePath("task_pane_digitizing.aspx");
</li>
@@ -58,7 +65,7 @@
<br/>Draw lines on the map.
<br/>
- fullPath = Server.MapPath("task_pane_redlining.aspx");
+ fullPath = SamplePath("task_pane_redlining.aspx");
</li>
@@ -65,8 +72,8 @@
</ul>
- fullPath = Server.MapPath("draw_line.aspx");
- String fullPath2 = Server.MapPath("clear_lines.aspx");
+ fullPath = SamplePath("draw_line.aspx");
+ String fullPath2 = SamplePath("clear_lines.aspx");
<ul>
<li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>">draw_line.aspx</a></li>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_map/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_map/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_map/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -24,6 +24,13 @@
String sessionId;
String mapName;
String fullPath;
</script>
<html>
<head>
@@ -49,15 +56,15 @@
<br/>Connect to MapGuide session and display basic information.
<br/>
- fullPath = Server.MapPath("display_spatial_reference.aspx");
+ fullPath = SamplePath("display_spatial_reference.aspx");
</li>
</ul>
- String path1 = Server.MapPath("../main.aspx");
- String path2 = Server.MapPath("./task_pane.aspx");
- String path3 = Server.MapPath("../common/common.aspx");
+ String path1 = "main.aspx";
+ String path2 = SamplePath("task_pane.aspx");
+ String path3 = "common/common.aspx";
<ul>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_viewer/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_viewer/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/hello_viewer/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -21,6 +21,13 @@
String sessionId;
String mapName;
</script>
<html>
<head>
@@ -49,12 +56,9 @@
<p><strong>2.</strong> Click <a href="gotopoint.aspx?X=-87.724520&Y=43.768387&Scale=5000" target="scriptFrame">this link</a>
to display a different location. This loads a page into the hidden script frame.</p>
- String fullPath = Server.MapPath(".");
<p>View source for support file:</p>
<ul>
- <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>/gotopoint.aspx">gotopoint.aspx</a></li>
+ <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= SamplePath("gotopoint.aspx") %>">gotopoint.aspx</a></li>
</ul>
<p><strong>3.</strong> Click <a href="#" onclick="parent.parent.ZoomToView(-87.707416, 43.747860, 5000, true);">this link</a>
@@ -61,7 +65,7 @@
to display a third location. This uses <code>onclick</code> to call JavaScript directly from the task pane.</p>
<p>View source for this file:</p>
<ul>
- <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>/task_pane.aspx">task_pane.aspx</a></li>
+ <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= SamplePath("task_pane.aspx") %>">task_pane.aspx</a></li>
</ul>
<p><strong>4.</strong> The home task pane loads JavaScript from an external file. The script runs when the map first loads. It disables
@@ -70,10 +74,10 @@
<p>View files:</p>
<ul>
<li>
- <a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>/../index.aspx" >index.aspx</a>
+ <a target="_blank" href="../common/viewsource.aspx?FILENAME=index.aspx" >index.aspx</a>
</li>
<li>
- <a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>/../common/pageLoadFunctions.js" >pageLoadFunctions.js</a>
+ <a target="_blank" href="../common/viewsource.aspx?FILENAME=common/pageLoadFunctions.js" >pageLoadFunctions.js</a>
</li>
</ul>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -15,9 +15,17 @@
String sessionId;
String mapName;
</script>
<html>
<head>
@@ -40,7 +48,7 @@
<br/>List layers and visibility status
<br/>
- String fullPath = Server.MapPath("layer_visibility.aspx");
+ String fullPath = SamplePath("layer_visibility.aspx");
</li>
@@ -48,8 +56,8 @@
<a href="toggle_roads_label.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>">Rename Roads Layer</a>
<br/>Toggle the name of the Roads layer
<br/>
- <?php
- fullPath = Server.MapPath("toggle_roads_label.aspx");
+ fullPath = SamplePath("toggle_roads_label.aspx");
</li>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/toggle_roads_label.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/toggle_roads_label.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/interacting_with_layers/toggle_roads_label.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -84,18 +84,18 @@
Response.Write("<p>Layer label has been changed to " + newLabel + ".</p>");
Response.Write("<p><a href=\"toggle_roads_label.aspx?SESSION=" + sessionId + "&MAPNAME=" + mgMapName + "\">Run again</a></p>");
- catch (MgLayerNotFoundException e)
- Response.Write("<p>Layer not found</p>");
- catch (MgObjectNotFoundException e)
catch (MgException e)
- Response.Write(e.GetExceptionMessage());
- Response.Write(e.GetDetails());
+ if (e.GetExceptionCode() == MgExceptionCodes.MgLayerNotFoundException ||
+ e.GetExceptionCode() == MgExceptionCodes.MgObjectNotFoundException)
+ Response.Write("<p>Layer not found</p>");
+ else
+ Response.Write(e.GetExceptionMessage());
+ Response.Write(e.GetDetails());
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -16,10 +16,18 @@
String sessionId;
String mapName;
String fullPath;
</script>
<html>
<head>
@@ -42,7 +50,7 @@
<br>Show buildings built after 1980.
<br>
- fullPath = Server.MapPath("change_layers_via_dom.aspx");
+ fullPath = SamplePath("change_layers_via_dom.aspx");
</li>
@@ -52,7 +60,7 @@
<br>Show a map themed by areas.
<br>
- fullPath = Server.MapPath("create_new_squarefootage_layer_definition.aspx");
+ fullPath = SamplePath("create_new_squarefootage_layer_definition.aspx");
</li>
@@ -62,7 +70,7 @@
<br>Show a map themed by lines.
<br>
- fullPath = Server.MapPath("create_new_line_layer_definition.aspx");
+ fullPath = SamplePath("create_new_line_layer_definition.aspx");
</li>
@@ -72,9 +80,9 @@
<br>Show a map themed by points.
<br>
- fullPath = Server.MapPath("create_new_point_layer_definition.aspx");
- String fullPath2 = Server.MapPath("RecentlyBuilt.LayerDefinition");
- String fullPath3 = Server.MapPath("layer_functions.aspx");
+ fullPath = SamplePath("create_new_point_layer_definition.aspx");
+ String fullPath2 = SamplePath("RecentlyBuilt.LayerDefinition");
+ String fullPath3 = SamplePath("layer_functions.aspx");
</li>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/listselection.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/listselection.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/listselection.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -25,6 +25,13 @@
String sessionId;
String mapName;
MgSelection selection = null;
</script>
<!-- #Include File="../common/common.aspx" -->
<html>
@@ -125,7 +132,7 @@
- <% String fileName = Server.MapPath("listselection.aspx"); %>
+ <% String fileName = SamplePath("listselection.aspx"); %>
<p><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fileName %>" >View source</a></p>
</body>
Modified: branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx
--- branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -24,6 +24,13 @@
String sessionId;
String mapName;
</script>
<html>
<head>
@@ -65,7 +72,7 @@
<br />List properties in District 6 owned by Schmitt
<br/>
- String fullPath = Server.MapPath("queryfeatures.aspx");
+ String fullPath = SamplePath("queryfeatures.aspx");
</li>
@@ -74,7 +81,7 @@
<br />Select properties in District 6 owned by Schmitt
<br/>
- fullPath = Server.MapPath("selectfeatures.aspx");
+ fullPath = SamplePath("selectfeatures.aspx");
</li>
@@ -83,7 +90,7 @@
<br />Lists currently selected features
<br/>
- fullPath = Server.MapPath("listselection.aspx");
+ fullPath = SamplePath("listselection.aspx");
</li>
@@ -93,7 +100,7 @@
<ul>
<li>
</li>
Modified: branches/4.0/MgDev/Doc/samples/javasamples/common/viewsource.php
--- branches/4.0/MgDev/Doc/samples/javasamples/common/viewsource.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/javasamples/common/viewsource.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -14,13 +14,37 @@
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
- $sourceFile = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST['FILENAME']: $_GET['FILENAME'];
+ $sourceFile = isset($_GET['FILENAME']) ? $_GET['FILENAME'] : "";
+ if ($_SERVER['REQUEST_METHOD'] == "POST" && isset($_POST['FILENAME']))
+ $sourceFile = $_POST['FILENAME'];
if (DIRECTORY_SEPARATOR == '/')
$sourceFile = str_replace('\\', '/', $sourceFile);
else
$sourceFile = str_replace('/', '\\', $sourceFile);
+ $sourcePath = $sourceFile;
+ // Reject an absolute path or a URL, then resolve the relative name against the samples root
+ // and require the result to stay there, so a traversal sequence cannot name another file.
+ $firstChar = substr($sourceFile, 0, 1);
+ if ($firstChar == '/' || $firstChar == '\\' || preg_match('#^[A-Za-z][A-Za-z0-9+.-]*:#', $sourceFile))
+ header('HTTP/1.1 403 Forbidden');
+ echo 'FILENAME must be relative to the samples directory';
+ return;
+ $samplesRoot = realpath(dirname(__FILE__) . DIRECTORY_SEPARATOR . "..");
+ $sourceFile = realpath($samplesRoot . DIRECTORY_SEPARATOR . $sourceFile);
+ if ($samplesRoot === false || $sourceFile === false || !is_file($sourceFile) ||
+ strncmp($sourceFile, $samplesRoot . DIRECTORY_SEPARATOR, strlen($samplesRoot) + 1) != 0)
+ echo 'File is outside the samples directory';
+ return;
$testForUtf = pack("ccc", 0xEF, 0xBB, 0xBF);
$fileContents = file_get_contents($sourceFile);
if (substr($fileContents, 0, 3) == $testForUtf)
@@ -30,11 +54,11 @@
<html>
<head>
- <title>Source of <?= basename($sourceFile) ?></title>
+ <title>Source of <?= htmlentities(basename($sourceFile)) ?></title>
</head>
<body>
- <p><strong><?= $sourceFile ?></strong></p>
+ <p><strong><?= htmlentities($sourcePath) ?></strong></p>
<code><?= $fileContents ?>
</code>
Modified: branches/4.0/MgDev/Doc/samples/javasamples/hello_map/task_pane.jsp
--- branches/4.0/MgDev/Doc/samples/javasamples/hello_map/task_pane.jsp 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/javasamples/hello_map/task_pane.jsp 2026-11-15 09:20:29 UTC (rev 10289)
@@ -44,7 +44,7 @@
String fileName = "display_spatial_reference.jsp";
ServletContext context = session.getServletContext();
File currentPath = new File(context.getRealPath(request.getServletPath()));
- String dir = currentPath.getParent();
+ String dir = currentPath.getParentFile().getName();
String fullPath = java.net.URLEncoder.encode(dir + "/" + fileName);
<!-- Not implemented yet
@@ -56,9 +56,9 @@
<ul>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<%= dir %>/../main.jsp">main.jsp</a> (wrapper for Viewer frames)</li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=main.jsp">main.jsp</a> (wrapper for Viewer frames)</li>
<li><a target="_blank" href="../common/viewsource.php?FILENAME=<%= dir %>/task_pane.jsp">task_pane.jsp</a> (this task pane page)</li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<%= dir %>/../common/common.jsp">common.jsp</a> (directory paths)</li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=common/common.jsp">common.jsp</a> (directory paths)</li>
</ul>
</body>
Modified: branches/4.0/MgDev/Doc/samples/javasamples/hello_viewer/task_pane.jsp
--- branches/4.0/MgDev/Doc/samples/javasamples/hello_viewer/task_pane.jsp 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/javasamples/hello_viewer/task_pane.jsp 2026-11-15 09:20:29 UTC (rev 10289)
@@ -47,7 +47,7 @@
String fullPath = java.net.URLEncoder.encode(dir);
@@ -75,10 +75,10 @@
<p>View files:</p>
<ul>
<li>
- <a target="_blank" href="../common/viewsource.php?FILENAME=<%= fullPath %>/../index.jsp" >index.jsp</a>
+ <a target="_blank" href="../common/viewsource.php?FILENAME=index.jsp" >index.jsp</a>
</li>
<li>
- <a target="_blank" href="../common/viewsource.php?FILENAME=<%= fullPath %>/../common/pageLoadFunctions.js" >pageLoadFunctions.js</a>
+ <a target="_blank" href="../common/viewsource.php?FILENAME=common/pageLoadFunctions.js" >pageLoadFunctions.js</a>
</li>
</ul>
Modified: branches/4.0/MgDev/Doc/samples/javasamples/interacting_with_layers/task_pane.jsp
--- branches/4.0/MgDev/Doc/samples/javasamples/interacting_with_layers/task_pane.jsp 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/javasamples/interacting_with_layers/task_pane.jsp 2026-11-15 09:20:29 UTC (rev 10289)
@@ -40,7 +40,7 @@
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -110,15 +110,22 @@
$featureService->UpdateFeatures($bufferFeatureResId, $commands, false);
- catch (MgObjectNotFoundException $e)
+ catch (MgException $e)
- // When an MgObjectNotFoundException is thrown, the layer
- // does not exist and must be created.
+ if ($e->GetExceptionCode() == MgExceptionCodes::MgObjectNotFoundException)
+ // When MgException reports MgObjectNotFoundException, the layer
+ // does not exist and must be created.
- $bufferFeatureResId = new MgResourceIdentifier("Session:" . $sessionId . "//Buffer.FeatureSource");
- CreateBufferFeatureSource($featureService, $mapWktSrs, $bufferFeatureResId);
- $bufferLayer = CreateBufferLayer($resourceService, $bufferFeatureResId, $sessionId);
- $map->GetLayers()->Insert(0, $bufferLayer);
+ $bufferFeatureResId = new MgResourceIdentifier("Session:" . $sessionId . "//Buffer.FeatureSource");
+ CreateBufferFeatureSource($featureService, $mapWktSrs, $bufferFeatureResId);
+ $bufferLayer = CreateBufferLayer($resourceService, $bufferFeatureResId, $sessionId);
+ $map->GetLayers()->Insert(0, $bufferLayer);
+ else
+ throw $e;
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php 2026-11-15 09:20:29 UTC (rev 10289)
+ else
+ throw $e;
@@ -159,15 +166,22 @@
$featureService->UpdateFeatures($parcelFeatureResId, $commands, false);
- $parcelFeatureResId = new MgResourceIdentifier("Session:" . $sessionId . "//ParcelMarker.FeatureSource");
- CreateParcelMarkerFeatureSource($featureService, $mapWktSrs, $parcelFeatureResId);
- $parcelMarkerLayer = CreateParcelMarkerLayer($resourceService, $parcelFeatureResId, $sessionId);
- $map->GetLayers()->Insert(0, $parcelMarkerLayer);
+ $parcelFeatureResId = new MgResourceIdentifier("Session:" . $sessionId . "//ParcelMarker.FeatureSource");
+ CreateParcelMarkerFeatureSource($featureService, $mapWktSrs, $parcelFeatureResId);
+ $parcelMarkerLayer = CreateParcelMarkerLayer($resourceService, $parcelFeatureResId, $sessionId);
+ $map->GetLayers()->Insert(0, $parcelMarkerLayer);
+ else
+ throw $e;
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -48,6 +48,9 @@
<body onLoad="OnPageLoad()" class="AppFrame">
<h1 class="AppHeading">Analyzing Features</h1>
<?php
+ // A "view source" link names a file by its path relative to the samples root, so what
+ // reaches the browser never contains a physical path on the server.
+ $sampleDir = basename(dirname(__FILE__));
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST: $_GET;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
@@ -60,8 +63,7 @@
<br/>
<?php
$fileName = 'createbuffer.php';
- $dir = getcwd();
- $fullPath = urlencode($dir . '/' . $fileName);
+ $fullPath = urlencode($sampleDir . '/' . $fileName);
<a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fullPath ?>" >View source</a>
</li>
@@ -74,8 +76,7 @@
<br/>
<?php
$fileName = 'selectfeaturesinbuffer.php';
- $dir = getcwd();
- $fullPath = urlencode($dir . '\\' . $fileName);
</li>
@@ -84,10 +85,10 @@
<ul>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/task_pane.php">task_pane.php</a></li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/bufferfunctions.php">bufferfunctions.php</a></li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/bufferlayerdefinition.xml">bufferlayerdefinition.xml</a></li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/parcelmarker.xml">parcelmarker.xml</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/task_pane.php">task_pane.php</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/bufferfunctions.php">bufferfunctions.php</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/bufferlayerdefinition.xml">bufferlayerdefinition.xml</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/parcelmarker.xml">parcelmarker.xml</a></li>
</ul>
</body>
</html>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/common/viewsource.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/common/viewsource.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/common/viewsource.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -14,13 +14,37 @@
else
+ return;
+ return;
@@ -30,11 +54,11 @@
<html>
<head>
</head>
<body>
</code>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -52,6 +52,9 @@
<h1 class="AppHeading">Custom Output</h1>
<?php
$args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST: $_GET;
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
@@ -66,8 +69,7 @@
<br/>
<?php
$fileName = 'property_report.php';
- $dir = getcwd();
</li>
@@ -79,8 +81,7 @@
<br/>
<?php
$fileName = 'eplot.php';
- $dir = getcwd();
</li>
@@ -92,8 +93,7 @@
<br/>
<?php
$fileName = 'multiplot.php';
- $dir = getcwd();
</li>
@@ -104,14 +104,12 @@
<ul>
<?php
$fileName = 'createmapimage.php';
- $dir = getcwd();
<li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fullPath ?>" >createmapimage.php</a></li>
<?php
$fileName = 'task_pane.php';
- $dir = getcwd();
<li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fullPath ?>" >task_pane.php</a></li>
</ul>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -27,6 +27,9 @@
</head>
<body class="AppFrame">
<?php
if (isset($args['MAPNAME']))
@@ -42,8 +45,7 @@
<br/>
<?php
$fileName = 'task_pane_digitizing.php';
- $dir = getcwd();
</li>
@@ -53,8 +55,7 @@
<br/>
<?php
$fileName = 'task_pane_redlining.php';
- $dir = getcwd();
</li>
@@ -61,8 +62,8 @@
</ul>
<ul>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/draw_line.php">draw_line.php</a></li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/clear_lines.php">clear_lines.php</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/draw_line.php">draw_line.php</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/clear_lines.php">clear_lines.php</a></li>
</ul>
</body>
</html>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -27,6 +27,9 @@
<h1 class="AppHeading">Hello Map</h1>
<?php
@@ -41,8 +44,7 @@
<br/>
<?php
$fileName = 'display_spatial_reference.php';
- $dir = getcwd();
</li>
@@ -50,9 +52,9 @@
<ul>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/../main.php">main.php</a> (wrapper for Viewer frames)</li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/task_pane.php">task_pane.php</a> (this task pane page)</li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/../common/common.php">common.php</a> (directory paths)</li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=main.php">main.php</a> (wrapper for Viewer frames)</li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/task_pane.php">task_pane.php</a> (this task pane page)</li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=common/common.php">common.php</a> (directory paths)</li>
</ul>
</body>
</html>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -27,6 +27,9 @@
<h1 class="AppHeading">Hello Viewer</h1>
<?php
@@ -44,8 +47,7 @@
<p><strong>2.</strong> Click <a href="gotopoint.php?X=-87.724520&Y=43.768387&Scale=5000" target="scriptFrame">this link</a>
<?php
- $dir = getcwd();
- $fullPath = urlencode($dir);
+ $fullPath = urlencode($sampleDir);
<ul>
@@ -65,10 +67,10 @@
<p>View files:</p>
<ul>
<li>
- <a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fullPath ?>/../index.php" >index.php</a>
+ <a target="_blank" href="../common/viewsource.php?FILENAME=index.php" >index.php</a>
</li>
<li>
- <a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fullPath ?>/../common/pageLoadFunctions.js" >pageLoadFunctions.js</a>
</li>
</ul>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -27,6 +27,9 @@
<h1 class="AppHeading">Map Layers</h1>
<?php
$args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST : $_GET;
@@ -38,8 +41,7 @@
<br/>
<?php
$fileName = 'layer_visibility.php';
- $dir = getcwd();
</li>
@@ -49,8 +51,7 @@
<br/>
<?php
$fileName = 'toggle_roads_label.php';
- $dir = getcwd();
</li>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -27,6 +27,9 @@
<h1 class="AppHeading">Modifying Maps & Layers</h1>
<p>The following links all load in the hidden script frame, leaving this task pane visible.</p>
<?php
@@ -38,8 +41,7 @@
<br>
<?php
$fileName = 'change_layers_via_dom.php';
- $dir = getcwd();
</li>
@@ -50,8 +52,7 @@
<br>
<?php
$fileName = 'create_new_squarefootage_layer_definition.php';
- $dir = getcwd();
</li>
@@ -62,8 +63,7 @@
<br>
<?php
$fileName = 'create_new_line_layer_definition.php';
- $dir = getcwd();
</li>
@@ -74,8 +74,7 @@
<br>
<?php
$fileName = 'create_new_point_layer_definition.php';
- $dir = getcwd();
</li>
@@ -82,8 +81,8 @@
</ul>
<ul>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/RecentlyBuilt.LayerDefinition">RecentlyBuilt.LayerDefinition</a></li>
- <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= getcwd() ?>/layer_functions.php">layer_functions.php</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/RecentlyBuilt.LayerDefinition">RecentlyBuilt.LayerDefinition</a></li>
+ <li><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $sampleDir ?>/layer_functions.php">layer_functions.php</a></li>
</ul>
</body>
</html>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -31,6 +31,9 @@
<h1 class="AppHeading">Selected Parcels</h1>
<?php
include '../common/common.php';
$args = ($_SERVER['REQUEST_METHOD'] == 'POST') ? $_POST : $_GET;
@@ -126,7 +129,7 @@
- <?php $fileName = urlencode(__FILE__); ?>
+ <?php $fileName = urlencode($sampleDir . '/listselection.php'); ?>
<p><a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fileName ?>" >View source</a></p>
</body>
Modified: branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php
--- branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php 2026-11-15 09:20:29 UTC (rev 10289)
@@ -42,6 +42,9 @@
<h1 class="AppHeading">Working With Feature Data</h1>
<p>
<?php
@@ -57,8 +60,7 @@
<br/>
<?php
$fileName = 'queryfeatures.php';
- $dir = getcwd();
</li>
@@ -68,8 +70,7 @@
<br/>
<?php
$fileName = 'selectfeatures.php';
- $dir = getcwd();
</li>
@@ -79,8 +80,7 @@
<br/>
<?php
$fileName = 'listselection.php';
- $dir = getcwd();
</li>
@@ -91,8 +91,7 @@
<li>
<?php
- $dir = getcwd();
</li>
Modified: branches/4.0/MgDev/Web/src/mapviewernet/common.aspx
--- branches/4.0/MgDev/Web/src/mapviewernet/common.aspx 2026-11-13 11:09:11 UTC (rev 10288)
+++ branches/4.0/MgDev/Web/src/mapviewernet/common.aspx 2026-11-15 09:20:29 UTC (rev 10289)
@@ -130,15 +130,18 @@
String LoadTemplate(HttpRequest request, String filePath)
- // Resolve the path and require it to stay inside the application root: the caller builds
- // filePath from a request parameter, and without this a traversal sequence would read any
- // file the server account can open.
- String root = Path.GetFullPath(request.ServerVariables["APPL_PHYSICAL_PATH"]);
- String full = Path.GetFullPath(Path.Combine(root, filePath));
- String rootPrefix = root.EndsWith(Path.DirectorySeparatorChar.ToString()) ? root : root + Path.DirectorySeparatorChar;
- if(!full.StartsWith(rootPrefix, StringComparison.OrdinalIgnoreCase))
+ // Resolve the path and require it to stay inside the web root: the caller builds filePath
+ // from a request parameter, and without this a traversal sequence would read any file the
+ // server account can open. The path is resolved against the application directory, as the
+ // callers' "../viewerfiles/..." names require, but the directory it must stay inside is
+ // that directory's parent: the viewer's own templates are not under the application.
+ String appRoot = Path.GetFullPath(request.ServerVariables["APPL_PHYSICAL_PATH"]);
+ String webRoot = Path.GetFullPath(Path.Combine(appRoot, ".."));
+ String full = Path.GetFullPath(Path.Combine(appRoot, filePath));
+ String webRootPrefix = webRoot.EndsWith(Path.DirectorySeparatorChar.ToString()) ? webRoot : webRoot + Path.DirectorySeparatorChar;
+ if(!full.StartsWith(webRootPrefix, StringComparison.OrdinalIgnoreCase))
- throw new FileNotFoundException("Page is outside the application directory", filePath);
+ throw new FileNotFoundException("Page is outside the web application directory", filePath);
StreamReader sr = File.OpenText(full);
More information about the mapguide-commits
