[mapguide-commits] r10290 - branches/4.0/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Nov 15 05:57:00 PST 2026
Author: jng
Date: 2026-11-15 05:56:59 -0800 (Sun, 15 Nov 2026)
New Revision: 10290
   branches/4.0/MgDev/cmake_package.sh
Harden cmake_package.sh to bail from making empty deb packages
Modified: branches/4.0/MgDev/cmake_package.sh
--- branches/4.0/MgDev/cmake_package.sh	2026-11-15 09:20:29 UTC (rev 10289)
+++ branches/4.0/MgDev/cmake_package.sh	2026-11-15 13:56:59 UTC (rev 10290)
@@ -9,7 +9,6 @@
 MG_ARCH=amd64
 LIBDIR=lib64
 PKG_OUTPUT_DIR=
-DPKG_MG_RELPATH="usr/local/mapguideopensource-${MG_VER}"
 THIS_DIR=$(readlink -f "$(dirname $0)")
 BUILD_CONF=Release
@@ -35,6 +34,14 @@
             MG_TARBALL=$2
             shift
+        --mg-ver)
+            MG_VER=$2
+            shift
+        --fdo-ver)
+            FDO_VER=$2
+            shift
         --debug)
             BUILD_CONF=Debug
@@ -43,6 +50,8 @@
             echo "Options:"
             echo "  --format [deb|rpm]"
             echo "  --tarball [Path to MapGuide tarball]"
+            echo "  --mg-ver [MapGuide version whose install prefix the packages carry, default ${MG_VER}]"
+            echo "  --fdo-ver [FDO version to resolve library dependencies against, default ${FDO_VER}]"
             echo "  --working-dir [Path to working directory]"
             echo "  --output-dir [Path to output directory]"
             echo "  --build-number [Build number]"
@@ -54,9 +63,12 @@
     shift   # Check next set of parameters.
 done
+DPKG_MG_RELPATH="usr/local/mapguideopensource-${MG_VER}"
 if [ ! -f "$MG_TARBALL" ]; then
     if [ ! -d "/$DPKG_MG_RELPATH" ]; then
         echo "MapGuide tarball not found. Please specify with the --tarball switch"
+        echo "(or --mg-ver, if /$DPKG_MG_RELPATH is not the tree being packaged)"
         exit 1
     else
         echo "MapGuide installation directory appears to already exist. Allowing omission of --tarball"
More information about the mapguide-commits mailing list
