[mapguide-dev] RE: MGOS 1.1.0 Release
Andy Morsell amorsell at spatialgis.com
Mon Dec 18 18:57:38 EST 2006
See if you can kill all javaw.exe processes from task manager and then try
to start Apache on port 8008.
Andy
-----Original Message-----
From: Jim O'Leary [mailto:joleary.public at gmail.com]
Sent: Monday, December 18, 2006 3:37 PM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] RE: MGOS 1.1.0 Release
netstat shows that this port and the following are linked to javaw.exe:
5225, 5226, 8008, 8005, 5226, 1079, 1081, 1084, 1085, 1104, 1106, 1107
Meanwhile, there is another problem. I successfully installed
WebServerExtensions 1.1.0 on port 8009, but when starting Studio got the
message:
The Studio version is incompatable with the Site version.
Andy Morsell wrote:
> It sounds like there is another instance of Apache running on port
> 8008 on that machine.  If you uninstalled and the Apache folder under
> MapGuide was your only Apache instance, have you rebooted between your
> uninstall and reinstall?  Either way, you definitely have a port
> conflict.  On Windows XP, try using the following command at a command
> prompt:
> netstat -a -b -n
> You should then see port 8008 somewhere in the list and whatever the
> owning executable and PID is.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> Sent: Monday, December 18, 2006 1:38 PM
> Subject: Re: [mapguide-dev] MGOS 1.1.0 Release
> I uninstalled 1.0.1 Server and Extensions and installed this release
> on my XP machine. The install did not generate and errors and did
> create required directories, but Apache did not start. It did not show
> in the Services, and when I executed Apache.exe from the command line
> in Apache2\bin, the error message said:
> C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\Apache2\bin>apache
> (OS 10048)Only one usage of each socket address (protocol/network
> address/port)
> is normally permitted.  : make_sock: could not bind to address
> 0.0.0.0:8008
> no listening sockets available, shutting down Unable to open logs
> I changed http.conf to read:
> Listen 8009
> and now it works. What is going on? I would like to go back to port 8008.
> Thanks
> Tom Fukushima wrote:
>> Hi,
>> Barring any problems we are planning to release MG 1.1.0 this coming
>> weekend (Dec 16th).  If there are any issues that you are aware of,
>> please reply to this mailing list.
>> Thanks
>> Tom
> http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7937071
> Sent from the MapGuide Dev mailing list archive at Nabble.com.
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7938876
More information about the Mapguide-internals mailing list
