MGOS 1.1.0 Release
Jim O'Leary
joleary.public at gmail.com
Mon Dec 18 19:30:29 EST 2006
Yes, that worked, thank you. I killed the javaw.exe process in Task Manager,
and Apache MapGuide got port 8008.
Andy Morsell wrote:
> See if you can kill all javaw.exe processes from task manager and then try
> to start Apache on port 8008.
> Andy
> -----Original Message-----
> From: Jim O'Leary [mailto:joleary.public at gmail.com]
> Sent: Monday, December 18, 2006 3:37 PM
> To: dev at mapguide.osgeo.org
> Subject: [mapguide-dev] RE: MGOS 1.1.0 Release
> netstat shows that this port and the following are linked to javaw.exe:
> 5225, 5226, 8008, 8005, 5226, 1079, 1081, 1084, 1085, 1104, 1106, 1107
> Meanwhile, there is another problem. I successfully installed
> WebServerExtensions 1.1.0 on port 8009, but when starting Studio got the
> message:
> The Studio version is incompatable with the Site version.
> Andy Morsell wrote:
>> It sounds like there is another instance of Apache running on port
>> 8008 on that machine. If you uninstalled and the Apache folder under
>> MapGuide was your only Apache instance, have you rebooted between your
>> uninstall and reinstall? Either way, you definitely have a port
>> conflict. On Windows XP, try using the following command at a command
>> prompt:
>> netstat -a -b -n
>> You should then see port 8008 somewhere in the list and whatever the
>> owning executable and PID is.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> Sent: Monday, December 18, 2006 1:38 PM
>> Subject: Re: [mapguide-dev] MGOS 1.1.0 Release
>> I uninstalled 1.0.1 Server and Extensions and installed this release
>> on my XP machine. The install did not generate and errors and did
>> create required directories, but Apache did not start. It did not show
>> in the Services, and when I executed Apache.exe from the command line
>> in Apache2\bin, the error message said:
>> C:\Program
>> Files\MapGuideOpenSource\WebServerExtensions\Apache2\bin>apache
>> (OS 10048)Only one usage of each socket address (protocol/network
>> address/port)
>> is normally permitted. : make_sock: could not bind to address
>> 0.0.0.0:8008
>> no listening sockets available, shutting down Unable to open logs
>> I changed http.conf to read:
>> Listen 8009
>> and now it works. What is going on? I would like to go back to port 8008.
>> Thanks
>> Tom Fukushima wrote:
>>> Hi,
>>> Barring any problems we are planning to release MG 1.1.0 this coming
>>> weekend (Dec 16th). If there are any issues that you are aware of,
>>> please reply to this mailing list.
>>> Thanks
>>> Tom
>> View this message in context:
>> http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7937071
>> Sent from the MapGuide Dev mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
> http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7938876
View this message in context: http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7939454
More information about the Mapguide-internals
