[mapguide-dev] Fw: Start Autodesk mapguide studio
    Albina Penitente
    a.penitente at gepaspa.com
    Fri Nov  3 11:42:16 EST 2006
it watches what happens on the server?
http://data.mapguide.com/phpviewersample/ajax.......
http://localhost:8008/phpviewersample/ajax.......
Bye Alba
----- Original Message -----
To: <dev at mapguide.osgeo.org>
Sent: Friday, November 03, 2006 4:54 PM
Subject: Re: [mapguide-dev] Fw: Start Autodesk mapguide studio
> If you are running Studio on the same machine that you installed
> MapGuide on, the login information would be:
> http://localhost:8008/mapguide
> user: Administrator
> pass: admin
> If you changed the port during install, you will have to change this
> appropriately
> If you changed the password for the Administrator user, again you
> will have to change it here
> If you installed Studio on a different machine than MapGuide,
> substitute the ip address or name of the server for 'localhost'
> Cheers
> Paul
> On 3-Nov-06, at 10:42 AM, Albina Penitente wrote:
>> On the choice Site is not sites
>> How do the first login?
>> thanks Alba
>> ----- Original Message ----- From: "Paul Spencer"
>> <pspencer at dmsolutions.ca>
>> Sent: Friday, November 03, 2006 1:27 PM
>>> What error message?  There is an empty site authentication dialog
>>> and  an empty studio window.  You need to login first!
>>> Paul
>>>> From: Albina Penitente
>>>> To: users at mapguide.osgeo.org
>>>> Sent: Friday, November 03, 2006 11:59 AM
>>>> Subject: Start Autodesk mapguide studio
>>>> Hi all,
>>>> S.O.: window 2003 server
>>>> I install mapguide server
>>>> I install mapguide extensions with default setting (Apache, Php)
>>>> Test Map Agent ok
>>>> Test Site Administrator ok
>>>> After I look the manual 'Installing Sample Data and Viewer
>>>> Sample  Application'
>>>> when I exec the instruction of page 3 I have the error attached
>>>> <006401c6ff42$f919f470$a700a8c0>
>>>> <006501c6ff42$f919f470$a700a8c0>
>>>> someone knows to say to me because?
>>>> thank
>>>> Alba
>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>> |Chief Technology Officer                                         |
>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
Name: not available
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20061103/5307a329/attachment.jpe
Name: not available
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20061103/5307a329/attachment-0001.jpe
More information about the Mapguide-internals
