[mapguide-internals] RE: [mapguide-users] MapGuide Java with Apache and SSL setup andconfiguration
Jason Birch Jason.Birch at nanaimo.ca
Tue Apr 3 11:33:03 EDT 2007
Hi all,
Another interesting post from the users list... if at all possible it
would be nice to get these fixes into 1.2 so that users can run MGOS
under SSL without warnings.
Annoying IE...
Scott, when you modified the source, did that take care of all the
problems?
Jason
Subject: Re: [mapguide-users] MapGuide Java with Apache and SSL setup
andconfiguration
I found the problem.  I think this should be included in the next
release.
There are 3 places were Frames or IFrames are used with out a 'SRC'
element
ajaxmappane.templ  - InitContextMenu() and InitToolbarFlyouts()
framesettaskbar.templ - <frame name="scriptFrame
framesetnotaskbar.templ - <frame name="scriptFrame
Without the src element, using https IE shows the following message
This page contains both secure and nonsecure items.
More info on the message can be found here:
http://support.microsoft.com/default.aspx?scid=kb;en-us;261188
-scott
More information about the mapguide-internals mailing list
