[mapguide-internals] RE: [mapguide-users] MapGuide Java with Apache and SSL setup andconfiguration
Robert Bray rbray at robertbray.net
Tue Apr 3 12:18:33 EDT 2007
Is there a ticket logged on this? Scott would you be willing to submit
the changes as a patch?
Bob
Jason Birch wrote:
> Hi all,
> Another interesting post from the users list... if at all possible it
> would be nice to get these fixes into 1.2 so that users can run MGOS
> under SSL without warnings.
> Annoying IE...
> Scott, when you modified the source, did that take care of all the
> problems?
> Jason
> ________________________________
> From: Scott Reisdorf
> Subject: Re: [mapguide-users] MapGuide Java with Apache and SSL setup
> andconfiguration
> I found the problem.  I think this should be included in the next
> release.
> There are 3 places were Frames or IFrames are used with out a 'SRC'
> element
> ajaxmappane.templ  - InitContextMenu() and InitToolbarFlyouts()
> framesettaskbar.templ - <frame name="scriptFrame
> framesetnotaskbar.templ - <frame name="scriptFrame
> Without the src element, using https IE shows the following message
> This page contains both secure and nonsecure items.
> More info on the message can be found here:
> http://support.microsoft.com/default.aspx?scid=kb;en-us;261188
> -scott
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
