[mapguide-internals] RE: [mapguide-users] MapGuide Java with
Apache and SSL setup andconfiguration
Scott Reisdorf
reisdorf1 at llnl.gov
Tue Apr 3 13:45:59 EDT 2007
I will create a ticket and some code changes.
-scott
Robert Bray wrote:
> Is there a ticket logged on this? Scott would you be willing to submit
> the changes as a patch?
> Bob
> Jason Birch wrote:
>> Hi all,
>> Another interesting post from the users list... if at all possible it
>> would be nice to get these fixes into 1.2 so that users can run MGOS
>> under SSL without warnings.
>> Annoying IE...
>> Scott, when you modified the source, did that take care of all the
>> problems?
>> Jason
>> ________________________________
>> From: Scott Reisdorf
>> Subject: Re: [mapguide-users] MapGuide Java with Apache and SSL setup
>> andconfiguration
>> I found the problem. I think this should be included in the next
>> release. There are 3 places were Frames or IFrames are used with out
>> a 'SRC'
>> element
>> ajaxmappane.templ - InitContextMenu() and InitToolbarFlyouts()
>> framesettaskbar.templ - <frame name="scriptFrame
>> framesetnotaskbar.templ - <frame name="scriptFrame
>> Without the src element, using https IE shows the following message
>> This page contains both secure and nonsecure items.
>> More info on the message can be found here:
>> http://support.microsoft.com/default.aspx?scid=kb;en-us;261188
>> -scott
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
