[mapguide-internals] Raster provider problems...
Traian Stanev
traian.stanev at autodesk.com
Sat Apr 7 13:09:12 EDT 2007
Yes I understand all that.
But mostly working is way better than none at all. That's all I was trying to say.
That, or every request for a raster -- even for formats that would work fine -- will have to pass through the same critical section in order to synchronize access. I wouldn't call that an enterprise class solution either.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Frank Warmerdam (External)
Sent: Sat 4/7/2007 12:40 PM
To: MapGuide Internals Mail List
Cc:
Subject: Re: [mapguide-internals] Raster provider problems...
Traian Stanev wrote:
> I think it's worth it to just change the capability to per-connection-threaded and see what happens.
> Seems like we need experimental verification.
Traian,
I'm not sure what you mean by experimental verification. Are you hoping
to verify that it works in per-connection-threading? Of course, it mostly
will. But "mostly" is a pretty weak position to take for enterprise class
software.
You really can't experimentally prove that software is threadsafe. At
mostly you can prove it isn't.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org <http://osgeo.org/>
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
